Ricoh MP C3003 C3503 C4503 C5503 Service manual Part 3
Toner Supply / Waste Toner Bottle​
No.DescriptionNo.Description
1ID chip (Y)10Toner end sensor (Y)
2Toner bottle drive motor (Y)11Toner transport motor (M)
3ID chip (M)12Toner end sensor (M)
4Toner bottle drive motor (M)13Toner transport motor (C)
5ID chip (C)14Toner end sensor (C)
6Toner bottle drive motor (C)15Toner end sensor (Bk)
7ID chip (Bk)16Toner transport motor (Bk)
8Toner bottle drive motor (Bk)17Waste toner capacity sensor
9Toner transport motor (Y)18Waste toner bottle set switch
Product Information
Paper Feed Unit​
1Tray set switch (1st feed tray)10Paper feed sensor (1st feed tray)
2Lift motor (1st feed tray)11Paper end sensor (2nd feed tray)
3Tray set switch (2nd feed tray)12Limit sensor (2nd feed tray)
4Lift motor (2nd feed tray)13Transport sensor (1st feed tray)
5Registration sensor14Paper end sensor (1st feed tray)
6Size switch (2nd Feed Tray)15Limit sensor (1st feed tray)
7Anti-condensation heater16Pick-up solenoid (2nd feed tray)
8Paper feed sensor (2nd Feed Tray)17Pick-up solenoid (1st feed tray)
9Transport sensor (2nd Feed Tray)
Duplex Unit​
1Duplex entrance motor6By-pass/Duplex motor
2Duplex unit open/close sensor7Double feed sensor (D150 only)
3Duplex entrance sensor8By-pass paper end sensor
4By-pass unit open/close sensor9Duplex exit sensor
5By-pass pick-up solenoid
Product Information
By-pass unit​
Upper fig.: D146/D147/D148/D149 Lower fig.: D150
1Main Scanning Sensor5By-pass length sensor
2By-pass length sensor6Side Fence Drive Motor
3Main Scanning Sensor7Side Fence Paper Contact sensor
4Side Fence Paper Contact sensor
Fusing Unit​
1Fusing pressure release sensor9Thermistor (center)
2Shield position sensor (Lower)10Thermostat (edge)
3Shield position sensor (Upper)11Thermostat (center)
4Thermopile (edge)12NC sensor (center)
5Thermopile (center)13NC sensor (edge)
6Fusing exit sensor14Thermistor (edge)
7Shield drive motor15Shield sensor 1 / 2
8Fusing heater
Product Information
Paper Transfer / Paper Exit​
1
Inversion Motor
5
Paper transfer roller home position sensor
2Paper exit full sensor6Fusing entrance sensor
3Inversion Sensor7Fusing jam sensor
4Paper exit sensor8Paper exit solenoid
Air Flow​
1Paper exit cooling fan7Thermistor
2Development intake fan/right8Drive cooling fan*
3Development intake fan/left9Toner supply cooling fan
4PSU cooling fan10Fusing exhaust heat fan
5PSU exhaust heat fan*11Main exhaust fan*
6Ozone exhaust fan
* D150/D149/D148 only
Product Information
Drive Unit​
1Imaging IOB7Registration Motor
2Development Motor: CMY8PCU Motor: CMY
3Development Motor: Black9Phase sensor
4PCU: Black / Image Transfer Motor10Fusing Motor
5Paper Feed Motor11Paper Exit / Pressure Release Motor
6Transport Motor
Board / Switch​
1Power switch7PSU (AC controller board)
2Interlock switch: front cover8PSU (DC Power)
3HVP_TTS9BCU
4Control board10Controller box cooling fan
5HDD11IPU
6Paper Transport IOB12IPU Sub*
* SPDF only
Product Information
    1. PAPER PATH​
      1SPDF DF30804Booklet Finisher SR3150
      2LCIT RT30305Bridge Unit BU3070
      3LCIT PB3170
      1ARDF DF30903Paper Feed Unit PB3160
      2LCIT RT30304Internal Finisher SR3130
      Product Information
      1Platen Cover PN20003Side Tray Type M3
      2Paper Feed Unit PB315041 Bin Tray BN3110
    2. DRIVE LAYOUT​
      1Paper feed motor12Toner bottle drive motor (C)
      2Duplex / By-pass motor13Toner bottle drive motor (M)
      3Transport motor14Toner bottle drive motor (Y)
      4Registration motor15Toner transport motor (Y)
      5Paper transfer contact motor16Toner transport motor (M)
      6Fusing motor17Toner transport motor (C)
      7Paper exit / Pressure release motor18Toner transport motor (Bk)
      8Duplex entrance motor19Development Motor: CMY
      9Inversion motor20PCU Motor: CMY
      10Scanner motor21Development Motor: Black
      11Toner bottle drive motor (Bk)22PCU: Black / Image Transfer Motor
      Product Information
  1. MACHINE CODES AND PERIPHERALS CONFIGURATION​
1.2.1 DIAGRAM​
D146/D147 Options (mainly North America)​
Mainframe (D146/D147): ARDF as standard
ItemMachine CodeCall out
Finisher SR3140D68712
Booklet Finisher SR3150D68613
Punch Unit PU3050D717-17 (NA)-
Internal Finisher SR3130D69011
Punch Unit PU3040D716-17 (NA)-
Paper Feed Unit PB3160D6936
Paper Feed Unit PB3150D6942
