Ricoh MP C3003 C3503 C4503 C5503 Service manual Part 8
  1. Return the paper feed tray to the machine.
  2. Attach the decals as shown below.
    [A]: Tray number decal : Paper size decal
    • The tray number decal and paper size decal are packaged together with the machine.
    [*]Lock the casters of the paper feed unit.
    [*]Connect the power cord to the machine.
    • A stabilizer is attached to the machine when it is shipped. Do not remove it.
    [*]Turn the power switch ON.
    [*]Set the paper, and check that the paper size set in the paper feed tray is displayed on the operation panel.
    [*]Adjust the registration for the paper feed unit.
SP1-002-004 (Side-to-Side Registration Paper Tray 3)
Changing the paper size​
Paper size is set as shown below when the machine is shipped from the factory. NA: LT LEF
EU.AA.CHN: A4 LEF
The paper size can be changed to A4 or LT.
  1. Pull out the left tray and right tray.
  2. Right tray side fence (front), [A], right tray side fence (rear) and right tray end fence [C]
    ×3)
    [*]Attach the fences to the required position (A4 or LT).
    [*]Make sure that the spring [A] is attached.
    [*]Left tray side fence (front) [A] and left tray side fence (rear)
    ×2)
    [A]: A4 position (Holes are visible) : LT position (Holes are hidden)
    [*]Set the SP SP5-181-007 0: A4, 1: LT
    1. LCIT RT3030​
      1. ACCESSORY CHECK​
        DescriptionQ’ty
        Screws – M3 × 61
        Tapping screw – M3 × 61
        Connecter Cover1
        Rating label1
        Joint Bracket1
        Harness1
      2. INSTALLATION PROCEDURE​
        • When installing this option, turn the power of the machine off, and unplug the power plug from the wall socket.
        • If it is installed when the power is on, it will result in an electric shock or a malfunction.
        • Before installing this option, first attach the “Paper Feed Unit PB3160” or “LCIT PB3170”.
          1. Remove the orange tape and retainers.
          2. Remove the enclosed items (fixing screws, etc.).
          3. Covers on the right of the paper feed table (8).
          4. Attach the connecting pins [A] to the front and rear on the right of the paper feed table.
          5. Attach the brackets [A], at the positions of the connecting pins ( ×4).
            [*]Paper feed table rear covers [A]
            ×2).
            [*]Clamp the harness [A].
            [*]Attach the paper feed table rear cover.
            [*]Attach the hook of the side LCT to the bracket.
            [*]Connect the cable [A] of the side LCT to the machine
            ×1).
            [*]Attach the cable cover [A]
            ×1).
            [*]Push the side LCT towards the machine.
            [*]Set the paper, and check that the paper size set in the paper feed tray is displayed on the control unit.
            [*]Do the registration adjustment for the large capacity tray. SP1-002-007 (Side-to-Side Registration Large Capacity Tray)
          Changing the Paper Size​
          EU.AA.CHN: A4 LEF
          The paper size can be changed to A4, LT, or B5.
          1. Open the tray cover.​
          1. Remove the upper screw at the front side fence, and after setting the side fence to the position of the paper (outer: A4 LEF, center: LT LEF, inner: B5 LEF), tighten the screw that was removed.
          2. Also change the rear side fence to the same size position.
          3. Change the paper size according to the new side fence position. SP5-181-017 (Size Adjust LCT)
            0: A4, 1: LT, 2: B5
      CASTER TABLE TYPE M3​
      1. ACCESSORY CHECK​
        No.DescriptionQ’ty
        1Right Lower Cover1
        2Securing Bracket2
        3Screws (M4 × 10)2
        4Screw with Spring Washer (M4 × 10)1
        • Removal of stabilizers must always be with the consent of the customer. Do not remove them at your own judgment.
        • The machine must be held at the correct locations, and must be lifted slowly.
        • If it is lifted with force, handled carelessly or dropped, it will result in an injury.
        • If installing this option, turn the power to the machine off, and unplug the power plug from the wall socket.
        • If it is installed when the power is on, it will result in an electric shock or malfunction.
        • Be sure to join the machine and caster table to prevent equipment from falling over.
        • If it is not joined, the machine will move or fall over, which will result in an injury.
          1. Attach the 3 locating pins.
          2. Holding the grips on the machine, align with the locating pin, and place the machine on the caster table.
            • When you lift the machine, hold the lifting handles.
            • In particular, do not lift it by holding the scanner unit, etc., (as it may deform). .
            • Do not put the machine down on the caster table as a temporary resting place. This may cause the machine to deform. Always connect the machine and caster unit properly.
          3. Pull out the 2nd paper feed tray.
          4. Using a securing bracket, fix the machine to the paper tray unit (spring washer : screw: M4×10: 1).
          5. Attach the securing brackets [A] at 2 positions to left and right at the rear of the machine (screws: 1 each).
          6. Return the paper feed tray to the machine.
      PLATEN COVER PN2000​
      1. ACCESSORY CHECK​
        Check that you have the accessories indicated below.
        No.DescriptionQ’ty
        1Platen Cover1
        2Platen Sheet1
        3Feeler Guide1
        4Stepped Screw2
        • Unplug the machine power cord before starting the following procedure.
    [*]Install the stepped screws
    × 2).
    [*]Install the feeler guide [A].
    [*]Install the platen cover [A].
    [*]Place the platen sheet [A] on the exposure glass.
    [*]Line up the rear left corner of the platen sheet flush against corner on the exposure glass.
    [*]Close the platen cover.
    [*]Open the platen cover.
    [*]Press the surface of the platen sheet gently to fix it on the platen cover securely.
