2-457-002 | PaperTransfer:Standard:2Side | ENG | [0 to 995 / 100 / 5%/step] |
2-457-003 | Paper Transfer:Low:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-457-004 | Paper Transfer:Low:2side | ENG | [0 to 995 / 100 / 5%/step] |
2458 | [Middle:SwitchTimingTrailEdge] | ||
2-458-001 | PaperTransfer:Standard:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-458-002 | PaperTransfer:Standard:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2-458-003 | Paper Transfer:Low:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-458-004 | Paper Transfer:Low:2side | ENG | [0 to 50 / 0 / 2mm/step] |
Engine SP Mode Tables
3.4 ENGINE SP TABLES - SP2000-2
3.4.1 SP2-XXX (DRUM)
2463 | [Thin:Bias:BW] | ||
2-463-001 | PaperTransfer:Standard:1Sid | ENG | [0 to 200 / 22 / 1-uA/step] |
2-463-002 | PaperTransfer:Standard:2Sid | ENG | [0 to 200 / 22 / 1-uA/step] |
2-463-003 | Paper Transfer:Low:1side | ENG | [0 to 200 / 11 / 1-uA/step] |
2-463-004 | Paper Transfer:Low:2side | ENG | [0 to 200 / 11 / 1-uA/step] |
2467 | [Thin:Bias:FC] | ||
2-467-001 | PaperTransfer:Standard:1Sid | ENG | [0 to 200 / 29 / 1-uA/step] |
2-467-002 | PaperTransfer:Standard:2Sid | ENG | [0 to 200 / 29 / 1-uA/step] |
2-467-003 | Paper Transfer:Low:1side | ENG | [0 to 200 / 14 / 1-uA/step] |
2-467-004 | Paper Transfer:Low:2side | ENG | [0 to 200 / 14 / 1-uA/step] |
2471 | [Thin:SizeCorrection:BW] | ||
2-471-001 | PaperTransfer:Standard:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-471-002 | PaperTransfer:Standard:2Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-471-003 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-471-004 | PaperTransfer:Low:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-471-005 | PaperTransfer:Standard:1Sid:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-471-006 | PaperTransfer:Standard:2Sid:S2 | ENG | [100 to 995 / 105 / 1%/step] |
2-471-007 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-471-008 | PaperTransfer:Low:2Side:S2 | ENG | [100 to 995 / 105 / 1%/step] |
2-471-009 | PaperTransfer:Standard:1Sid:S3 | ENG | [100 to 995 / 111 / 1%/step] |
2-471-010 | PaperTransfer:Standard:2Sid:S3 | ENG | [100 to 995 / 140 / 1%/step] |
2-471-011 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 111 / 1%/step] |
2-471-012 | PaperTransfer:Low:2Side:S3 | ENG | [100 to 995 / 140 / 1%/step] |
2-471-013 | PaperTransfer:Standard:1Sid:S4 | ENG | [100 to 995 / 121 / 1%/step] |
2-471-014 | PaperTransfer:Standard:2Sid:S4 | ENG | [100 to 995 / 175 / 1%/step] |
2-471-015 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 121 / 1%/step] |
2-471-016 | PaperTransfer:Low:2Side:S4 | ENG | [100 to 995 / 175 / 1%/step] |
2-471-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [100 to 995 / 132 / 1%/step] |
2-471-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [100 to 995 / 211 / 1%/step] |
2-471-019 | PaperTransfer:Low:1Side:S5 | ENG | [100 to 995 / 132 / 1%/step] |
2-471-020 | PaperTransfer:Low:2Side:S5 | ENG | [100 to 995 / 211 / 1%/step] |
2-471-021 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-471-022 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-471-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-471-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-471-025 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-471-026 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-471-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-471-028 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-471-029 | Wide Roller | ENG | [100 to 995 / 111 / 1%/step] |
2-471-030 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-471-031 | Wide Roller | ENG | [100 to 995 / 111 / 1%/step] |
2-471-032 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-471-033 | Wide Roller | ENG | [100 to 995 / 121 / 1%/step] |
2-471-034 | Wide Roller | ENG | [100 to 995 / 175 / 1%/step] |
2-471-035 | Wide Roller | ENG | [100 to 995 / 121 / 1%/step] |
2-471-036 | Wide Roller | ENG | [100 to 995 / 175 / 1%/step] |
2-471-037 | Wide Roller | ENG | [100 to 995 / 132 / 1%/step] |
2-471-038 | Wide Roller | ENG | [100 to 995 / 211 / 1%/step] |
2-471-039 | Wide Roller | ENG | [100 to 995 / 132 / 1%/step] |
2-471-040 | Wide Roller | ENG | [100 to 995 / 211 / 1%/step] |
2472 | [Thin:SizeCorrection:FC] | ||
2-472-001 | PaperTransfer:Standard:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-472-002 | PaperTransfer:Standard:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-472-003 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-472-004 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-472-005 | PaperTransfer:Standard:1Sid:S2 | ENG | [100 to 995 / 106 / 1%/step] |
2-472-006 | PaperTransfer:Standard:1Sid:S2 | ENG | [100 to 995 / 130 / 1%/step] |
2-472-007 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 106 / 1%/step] |
2-472-008 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 130 / 1%/step] |
2-472-009 | PaperTransfer:Standard:1Sid:S3 | ENG | [100 to 995 / 117 / 1%/step] |
2-472-010 | PaperTransfer:Standard:1Sid:S3 | ENG | [100 to 995 / 153 / 1%/step] |
2-472-011 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 117 / 1%/step] |
2-472-012 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 153 / 1%/step] |
2-472-013 | PaperTransfer:Standard:1Sid:S4 | ENG | [100 to 995 / 128 / 1%/step] |
2-472-014 | PaperTransfer:Standard:1Sid:S4 | ENG | [100 to 995 / 177 / 1%/step] |
2-472-015 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 128 / 1%/step] |
2-472-016 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 177 / 1%/step] |
2-472-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [100 to 995 / 140 / 1%/step] |
2-472-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [100 to 995 / 200 / 1%/step] |
2-472-019 | PaperTransfer:Low:1Side:S5 | ENG | [100 to 995 / 140 / 1%/step] |
2-472-020 | PaperTransfer:Low:2Side:S5 | ENG | [100 to 995 / 200 / 1%/step] |
2-472-021 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-472-022 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-472-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-472-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-472-025 | Wide Roller | ENG | [100 to 995 / 106 / 1%/step] |
2-472-026 | Wide Roller | ENG | [100 to 995 / 130 / 1%/step] |
2-472-027 | Wide Roller | ENG | [100 to 995 / 106 / 1%/step] |
2-472-028 | Wide Roller | ENG | [100 to 995 / 130 / 1%/step] |
2-472-029 | Wide Roller | ENG | [100 to 995 / 117 / 1%/step] |
2-472-030 | Wide Roller | ENG | [100 to 995 / 153 / 1%/step] |
2-472-031 | Wide Roller | ENG | [100 to 995 / 117 / 1%/step] |
2-472-032 | Wide Roller | ENG | [100 to 995 / 153 / 1%/step] |
2-472-033 | Wide Roller | ENG | [100 to 995 / 128 / 1%/step] |
2-472-034 | Wide Roller | ENG | [100 to 995 / 177 / 1%/step] |
2-472-035 | Wide Roller | ENG | [100 to 995 / 128 / 1%/step] |
2-472-036 | Wide Roller | ENG | [100 to 995 / 177 / 1%/step] |
2-472-037 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-472-038 | Wide Roller | ENG | [100 to 995 / 200 / 1%/step] |
2-472-039 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-472-040 | Wide Roller | ENG | [100 to 995 / 200 / 1%/step] |
2473 | [Thin:Size-Env.Correct:BW] | ||
2-473-001 | PaperTransfer:Standard:1Sid:S1 | ENG | [1 to 110 / 10 / 1/step] |
2-473-002 | PaperTransfer:Standard:1Sid:S1 | ENG | [1 to 110 / 15 / 1/step] |
2-473-003 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 10 / 1/step] |
2-473-004 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 15 / 1/step] |
2-473-005 | PaperTransfer:Standard:1Sid:S2 | ENG | [1 to 110 / 11 / 1/step] |
2-473-006 | PaperTransfer:Standard:1Sid:S2 | ENG | [1 to 110 / 16 / 1/step] |
2-473-007 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 11 / 1/step] |
2-473-008 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 16 / 1/step] |
2-473-009 | PaperTransfer:Standard:1Sid:S3 | ENG | [1 to 110 / 12 / 1/step] |
2-473-010 | PaperTransfer:Standard:1Sid:S3 | ENG | [1 to 110 / 30 / 1/step] |
2-473-011 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 12 / 1/step] |
2-473-012 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 30 / 1/step] |
2-473-013 | PaperTransfer:Standard:1Sid:S4 | ENG | [1 to 110 / 13 / 1/step] |
2-473-014 | PaperTransfer:Standard:1Sid:S4 | ENG | [1 to 110 / 31 / 1/step] |
2-473-015 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 13 / 1/step] |
2-473-016 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 31 / 1/step] |
2-473-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [1 to 110 / 14 / 1/step] |
2-473-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [1 to 110 / 32 / 1/step] |
2-473-019 | PaperTransfer:Low:1Side:S5 | ENG | [1 to 110 / 14 / 1/step] |
2-473-020 | PaperTransfer:Low:2Side:S5 | ENG | [1 to 110 / 32 / 1/step] |
2-473-021 | Wide Roller | ENG | [1 to 110 / 10 / 1/step] |
2-473-022 | Wide Roller | ENG | [1 to 110 / 15 / 1/step] |
2-473-023 | Wide Roller | ENG | [1 to 110 / 10 / 1/step] |
2-473-024 | Wide Roller | ENG | [1 to 110 / 15 / 1/step] |
2-473-025 | Wide Roller | ENG | [1 to 110 / 11 / 1/step] |
2-473-026 | Wide Roller | ENG | [1 to 110 / 16 / 1/step] |
2-473-027 | Wide Roller | ENG | [1 to 110 / 11 / 1/step] |
2-473-028 | Wide Roller | ENG | [1 to 110 / 16 / 1/step] |
2-473-029 | Wide Roller | ENG | [1 to 110 / 12 / 1/step] |
2-473-030 | Wide Roller | ENG | [1 to 110 / 30 / 1/step] |
2-473-031 | Wide Roller | ENG | [1 to 110 / 12 / 1/step] |
2-473-032 | Wide Roller | ENG | [1 to 110 / 30 / 1/step] |
2-473-033 | Wide Roller | ENG | [1 to 110 / 13 / 1/step] |
2-473-034 | Wide Roller | ENG | [1 to 110 / 31 / 1/step] |
2-473-035 | Wide Roller | ENG | [1 to 110 / 13 / 1/step] |
2-473-036 | Wide Roller | ENG | [1 to 110 / 31 / 1/step] |
2-473-037 | Wide Roller | ENG | [1 to 110 / 14 / 1/step] |
2-473-038 | Wide Roller | ENG | [1 to 110 / 32 / 1/step] |
2-473-039 | Wide Roller | ENG | [1 to 110 / 14 / 1/step] |
2-473-040 | Wide Roller | ENG | [1 to 110 / 32 / 1/step] |
2474 | [Thin:Size-Env.Correct:FC] | ||
2-474-001 | PaperTransfer:Standard:1Sid:S1 | ENG | [1 to 110 / 20 / 1/step] |
2-474-002 | PaperTransfer:Standard:1Sid:S1 | ENG | [1 to 110 / 25 / 1/step] |
2-474-003 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 20 / 1/step] |
2-474-004 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 25 / 1/step] |
2-474-005 | PaperTransfer:Standard:1Sid:S2 | ENG | [1 to 110 / 21 / 1/step] |
2-474-006 | PaperTransfer:Standard:1Sid:S2 | ENG | [1 to 110 / 35 / 1/step] |
2-474-007 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 21 / 1/step] |
2-474-008 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 35 / 1/step] |
2-474-009 | PaperTransfer:Standard:1Sid:S3 | ENG | [1 to 110 / 33 / 1/step] |
2-474-010 | PaperTransfer:Standard:1Sid:S3 | ENG | [1 to 110 / 36 / 1/step] |
2-474-011 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 33 / 1/step] |
2-474-012 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 36 / 1/step] |
2-474-013 | PaperTransfer:Standard:1Sid:S4 | ENG | [1 to 110 / 34 / 1/step] |
2-474-014 | PaperTransfer:Standard:1Sid:S4 | ENG | [1 to 110 / 37 / 1/step] |
2-474-015 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 34 / 1/step] |
2-474-016 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 37 / 1/step] |
2-474-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [1 to 110 / 24 / 1/step] |
2-474-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [1 to 110 / 38 / 1/step] |
2-474-019 | PaperTransfer:Low:1Side:S5 | ENG | [1 to 110 / 24 / 1/step] |
2-474-020 | PaperTransfer:Low:2Side:S5 | ENG | [1 to 110 / 38 / 1/step] |
2-474-021 | Wide Roller | ENG | [1 to 110 / 20 / 1/step] |
2-474-022 | Wide Roller | ENG | [1 to 110 / 25 / 1/step] |
2-474-023 | Wide Roller | ENG | [1 to 110 / 20 / 1/step] |
2-474-024 | Wide Roller | ENG | [1 to 110 / 25 / 1/step] |
2-474-025 | Wide Roller | ENG | [1 to 110 / 21 / 1/step] |
2-474-026 | Wide Roller | ENG | [1 to 110 / 35 / 1/step] |
2-474-027 | Wide Roller | ENG | [1 to 110 / 21 / 1/step] |
2-474-028 | Wide Roller | ENG | [1 to 110 / 35 / 1/step] |
2-474-029 | Wide Roller | ENG | [1 to 110 / 33 / 1/step] |
2-474-030 | Wide Roller | ENG | [1 to 110 / 36 / 1/step] |
2-474-031 | Wide Roller | ENG | [1 to 110 / 33 / 1/step] |
2-474-032 | Wide Roller | ENG | [1 to 110 / 36 / 1/step] |
2-474-033 | Wide Roller | ENG | [1 to 110 / 34 / 1/step] |
2-474-034 | Wide Roller | ENG | [1 to 110 / 37 / 1/step] |
2-474-035 | Wide Roller | ENG | [1 to 110 / 34 / 1/step] |
2-474-036 | Wide Roller | ENG | [1 to 110 / 37 / 1/step] |
2-474-037 | Wide Roller | ENG | [1 to 110 / 24 / 1/step] |
2-474-038 | Wide Roller | ENG | [1 to 110 / 38 / 1/step] |
2-474-039 | Wide Roller | ENG | [1 to 110 / 24 / 1/step] |
2-474-040 | Wide Roller | ENG | [1 to 110 / 38 / 1/step] |
2478
2475 | [Thin:LeadingEdgeCorrection] | ||
2-475-001 | PaperTransfer:Standard:1Side | ENG | [0 to 995 / 100 / 5%/step] |
2-475-002 | PaperTransfer:Standard:2Side | ENG | [0 to 995 / 100 / 5%/step] |
2-475-003 | Paper Transfer:Low:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-475-004 | Paper Transfer:Low:2side | ENG | [0 to 995 / 100 / 5%/step] |
2476 | [Thin:SwitchTimingLeadEdge] | ||
2-476-001 | PaperTransfer:Standard:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-476-002 | PaperTransfer:Standard:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2-476-003 | Paper Transfer:Low:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-476-004 | Paper Transfer:Low:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2477 | [Thin:TrailEdgeCorrection] | ||
2-477-001 | PaperTransfer:Standard:1Side | ENG | [0 to 995 / 100 / 5%/step] |
2-477-002 | PaperTransfer:Standard:2Side | ENG | [0 to 995 / 100 / 5%/step] |
2-477-003 | Paper Transfer:Low:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-477-004 | Paper Transfer:Low:2side | ENG | [0 to 995 / 100 / 5%/step] |
[Thin:SwitchTimingTrailEdge]
2-478-001 | PaperTransfer:Standard:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-478-002 | PaperTransfer:Standard:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2-478-003 | Paper Transfer:Low:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-478-004 | Paper Transfer:Low:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2483 | [Thick1:Bias:BW] | ||
2-483-001 | PaperTransfer:middle:1side | ENG | [0 to 200 / 16 / 1-uA/step] |
2-483-002 | PaperTransfer:middle:2side | ENG | [0 to 200 / 13 / 1-uA/step] |
2-483-003 | PaperTransfer:low:1side | ENG | [0 to 200 / 11 / 1-uA/step] |
2-483-004 | PaperTransfer:low:2side | ENG | [0 to 200 / 9 / 1-uA/step] |
2487 | [Thick1:Bias:FC] | ||
2-487-001 | PaperTransfer:middle:1side | ENG | [0 to 200 / 23 / 1-uA/step] |
2-487-002 | PaperTransfer:middle:2side | ENG | [0 to 200 / 26 / 1-uA/step] |
2-487-003 | PaperTransfer:low:1side | ENG | [0 to 200 / 16 / 1-uA/step] |
2-487-004 | PaperTransfer:low:2side | ENG | [0 to 200 / 18 / 1-uA/step] |
2491 | [Thick1:SizeCorrection:BW] | ||
2-491-001 | PaperTransfer:middle:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-002 | PaperTransfer:middle:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-003 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-004 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-005 | PaperTransfer:middle:1Sid:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-006 | PaperTransfer:middle:1Sid:S2 | ENG | [100 to 995 / 177 / 1%/step] |
2-491-007 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-008 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 177 / 1%/step] |
2-491-009 | PaperTransfer:middle:1Sid:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-010 | PaperTransfer:middle:1Sid:S3 | ENG | [100 to 995 / 231 / 1%/step] |
2-491-011 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-012 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 231 / 1%/step] |
2-491-013 | PaperTransfer:middle:1Sid:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-014 | PaperTransfer:middle:1Sid:S4 | ENG | [100 to 995 / 270 / 1%/step] |
2-491-015 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-016 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 270 / 1%/step] |
2-491-017 | PaperTransfer:middle:1Sid:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-018 | PaperTransfer:middle:2Sid:S5 | ENG | [100 to 995 / 308 / 1%/step] |
2-491-019 | PaperTransfer:Low:1Side:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-491-020 | PaperTransfer:Low:2Side:S5 | ENG | [100 to 995 / 308 / 1%/step] |
2-491-021 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-022 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-025 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-026 | Wide Roller | ENG | [100 to 995 / 177 / 1%/step] |
2-491-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-028 | Wide Roller | ENG | [100 to 995 / 177 / 1%/step] |
2-491-029 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-030 | Wide Roller | ENG | [100 to 995 / 231 / 1%/step] |
2-491-031 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-032 | Wide Roller | ENG | [100 to 995 / 231 / 1%/step] |
2-491-033 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-034 | Wide Roller | ENG | [100 to 995 / 270 / 1%/step] |
2-491-035 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-036 | Wide Roller | ENG | [100 to 995 / 270 / 1%/step] |
2-491-037 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-038 | Wide Roller | ENG | [100 to 995 / 308 / 1%/step] |
2-491-039 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-491-040 | Wide Roller | ENG | [100 to 995 / 308 / 1%/step] |
2492 | [Thick1:SizeCorrection:FC] | ||
2-492-001 | PaperTransfer:middle:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-002 | PaperTransfer:middle:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-003 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-004 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-005 | PaperTransfer:middle:1Sid:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-006 | PaperTransfer:middle:1Sid:S2 | ENG | [100 to 995 / 173 / 1%/step] |
2-492-007 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-008 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 173 / 1%/step] |
2-492-009 | PaperTransfer:middle:1Sid:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-010 | PaperTransfer:middle:1Sid:S3 | ENG | [100 to 995 / 250 / 1%/step] |
2-492-011 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-012 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 250 / 1%/step] |
2-492-013 | PaperTransfer:middle:1Sid:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-014 | PaperTransfer:middle:1Sid:S4 | ENG | [100 to 995 / 308 / 1%/step] |
2-492-015 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-016 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 308 / 1%/step] |
2-492-017 | PaperTransfer:middle:1Sid:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-018 | PaperTransfer:middle:2Sid:S5 | ENG | [100 to 995 / 385 / 1%/step] |
2-492-019 | PaperTransfer:Low:1Side:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-492-020 | PaperTransfer:Low:2Side:S5 | ENG | [100 to 995 / 385 / 1%/step] |
2-492-021 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-022 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-025 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-026 | Wide Roller | ENG | [100 to 995 / 173 / 1%/step] |
2-492-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-028 | Wide Roller | ENG | [100 to 995 / 173 / 1%/step] |
2-492-029 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-030 | Wide Roller | ENG | [100 to 995 / 250 / 1%/step] |
2-492-031 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-032 | Wide Roller | ENG | [100 to 995 / 250 / 1%/step] |
2-492-033 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-034 | Wide Roller | ENG | [100 to 995 / 308 / 1%/step] |
2-492-035 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-036 | Wide Roller | ENG | [100 to 995 / 308 / 1%/step] |
2-492-037 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-038 | Wide Roller | ENG | [100 to 995 / 385 / 1%/step] |
2-492-039 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-492-040 | Wide Roller | ENG | [100 to 995 / 385 / 1%/step] |
2493 | [Thick1:Size-Env.Correct:BW] | ||
2-493-001 | PaperTransfer:middle:1Sid:S1 | ENG | [1 to 110 / 54 / 1/step] |
2-493-002 | PaperTransfer:middle:1Sid:S1 | ENG | [1 to 110 / 57 / 1/step] |
2-493-003 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 54 / 1/step] |
2-493-004 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 57 / 1/step] |
2-493-005 | PaperTransfer:middle:1Sid:S2 | ENG | [1 to 110 / 55 / 1/step] |
2-493-006 | PaperTransfer:middle:1Sid:S2 | ENG | [1 to 110 / 58 / 1/step] |
2-493-007 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 55 / 1/step] |
2-493-008 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 58 / 1/step] |
2-493-009 | PaperTransfer:middle:1Sid:S3 | ENG | [1 to 110 / 56 / 1/step] |
2-493-010 | PaperTransfer:middle:1Sid:S3 | ENG | [1 to 110 / 59 / 1/step] |
2-493-011 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 56 / 1/step] |
2-493-012 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 59 / 1/step] |
2-493-013 | PaperTransfer:middle:1Sid:S4 | ENG | [1 to 110 / 56 / 1/step] |
2-493-014 | PaperTransfer:middle:1Sid:S4 | ENG | [1 to 110 / 60 / 1/step] |
2-493-015 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 56 / 1/step] |
2-493-016 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 60 / 1/step] |
2-493-017 | PaperTransfer:middle:1Sid:S5 | ENG | [1 to 110 / 56 / 1/step] |
2-493-018 | PaperTransfer:middle:2Sid:S5 | ENG | [1 to 110 / 61 / 1/step] |
2-493-019 | PaperTransfer:Low:1Side:S5 | ENG | [1 to 110 / 56 / 1/step] |
2-493-020 | PaperTransfer:Low:2Side:S5 | ENG | [1 to 110 / 61 / 1/step] |
2-493-021 | Wide Roller | ENG | [1 to 110 / 54 / 1/step] |
2-493-022 | Wide Roller | ENG | [1 to 110 / 57 / 1/step] |
2-493-023 | Wide Roller | ENG | [1 to 110 / 54 / 1/step] |
2-493-024 | Wide Roller | ENG | [1 to 110 / 57 / 1/step] |
2-493-025 | Wide Roller | ENG | [1 to 110 / 55 / 1/step] |
2-493-026 | Wide Roller | ENG | [1 to 110 / 58 / 1/step] |
2-493-027 | Wide Roller | ENG | [1 to 110 / 55 / 1/step] |
2-493-028 | Wide Roller | ENG | [1 to 110 / 58 / 1/step] |
2-493-029 | Wide Roller | ENG | [1 to 110 / 56 / 1/step] |
2-493-030 | Wide Roller | ENG | [1 to 110 / 59 / 1/step] |
2-493-031 | Wide Roller | ENG | [1 to 110 / 56 / 1/step] |
2-493-032 | Wide Roller | ENG | [1 to 110 / 59 / 1/step] |
2-493-033 | Wide Roller | ENG | [1 to 110 / 56 / 1/step] |
2-493-034 | Wide Roller | ENG | [1 to 110 / 60 / 1/step] |
2-493-035 | Wide Roller | ENG | [1 to 110 / 56 / 1/step] |
2-493-036 | Wide Roller | ENG | [1 to 110 / 60 / 1/step] |
2-493-037 | Wide Roller | ENG | [1 to 110 / 56 / 1/step] |
2-493-038 | Wide Roller | ENG | [1 to 110 / 61 / 1/step] |
2-493-039 | Wide Roller | ENG | [1 to 110 / 56 / 1/step] |
2-493-040 | Wide Roller | ENG | [1 to 110 / 61 / 1/step] |
2494 | [Thick1:Size-Env.Correct:FC] | ||
2-494-001 | PaperTransfer:middle:1Sid:S1 | ENG | [1 to 110 / 13 / 1/step] |
2-494-002 | PaperTransfer:middle:1Sid:S1 | ENG | [1 to 110 / 65 / 1/step] |
2-494-003 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 13 / 1/step] |
2-494-004 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 65 / 1/step] |
2-494-005 | PaperTransfer:middle:1Sid:S2 | ENG | [1 to 110 / 63 / 1/step] |
2-494-006 | PaperTransfer:middle:1Sid:S2 | ENG | [1 to 110 / 66 / 1/step] |
2-494-007 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 63 / 1/step] |
2-494-008 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 66 / 1/step] |
2-494-009 | PaperTransfer:middle:1Sid:S3 | ENG | [1 to 110 / 63 / 1/step] |
2-494-010 | PaperTransfer:middle:1Sid:S3 | ENG | [1 to 110 / 67 / 1/step] |
2-494-011 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 63 / 1/step] |
2-494-012 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 67 / 1/step] |
2-494-013 | PaperTransfer:middle:1Sid:S4 | ENG | [1 to 110 / 64 / 1/step] |
2-494-014 | PaperTransfer:middle:1Sid:S4 | ENG | [1 to 110 / 68 / 1/step] |
2-494-015 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 64 / 1/step] |
2-494-016 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 68 / 1/step] |
2-494-017 | PaperTransfer:middle:1Sid:S5 | ENG | [1 to 110 / 64 / 1/step] |
2-494-018 | PaperTransfer:middle:2Sid:S5 | ENG | [1 to 110 / 69 / 1/step] |
2-494-019 | PaperTransfer:Low:1Side:S5 | ENG | [1 to 110 / 64 / 1/step] |
2-494-020 | PaperTransfer:Low:2Side:S5 | ENG | [1 to 110 / 69 / 1/step] |
2-494-021 | Wide Roller | ENG | [1 to 110 / 13 / 1/step] |
2-494-022 | Wide Roller | ENG | [1 to 110 / 65 / 1/step] |
2-494-023 | Wide Roller | ENG | [1 to 110 / 13 / 1/step] |
2-494-024 | Wide Roller | ENG | [1 to 110 / 65 / 1/step] |
2-494-025 | Wide Roller | ENG | [1 to 110 / 63 / 1/step] |
2-494-026 | Wide Roller | ENG | [1 to 110 / 66 / 1/step] |
2-494-027 | Wide Roller | ENG | [1 to 110 / 63 / 1/step] |
2-494-028 | Wide Roller | ENG | [1 to 110 / 66 / 1/step] |
2-494-029 | Wide Roller | ENG | [1 to 110 / 63 / 1/step] |
2-494-030 | Wide Roller | ENG | [1 to 110 / 67 / 1/step] |
2-494-031 | Wide Roller | ENG | [1 to 110 / 63 / 1/step] |
2-494-032 | Wide Roller | ENG | [1 to 110 / 67 / 1/step] |
2-494-033 | Wide Roller | ENG | [1 to 110 / 64 / 1/step] |
2-494-034 | Wide Roller | ENG | [1 to 110 / 68 / 1/step] |
2-494-035 | Wide Roller | ENG | [1 to 110 / 64 / 1/step] |
2-494-036 | Wide Roller | ENG | [1 to 110 / 68 / 1/step] |
2-494-037 | Wide Roller | ENG | [1 to 110 / 64 / 1/step] |
2-494-038 | Wide Roller | ENG | [1 to 110 / 69 / 1/step] |
2-494-039 | Wide Roller | ENG | [1 to 110 / 64 / 1/step] |
2-494-040 | Wide Roller | ENG | [1 to 110 / 69 / 1/step] |
2498
2495 | [Thick1:LeadingEdgeCorrection] | ||
2-495-001 | PaperTransfer:middle:1Side | ENG | [0 to 995 / 100 / 5%/step] |
2-495-002 | PaperTransfer:middle:2Side | ENG | [0 to 995 / 100 / 5%/step] |
2-495-003 | Paper Transfer:Low:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-495-004 | Paper Transfer:Low:2side | ENG | [0 to 995 / 100 / 5%/step] |
2496 | [Thick1:SwitchTimingLeadEdge] | ||
2-496-001 | PaperTransfer:middle:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-496-002 | PaperTransfer:middle:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2-496-003 | Paper Transfer:Low:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-496-004 | Paper Transfer:Low:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2497 | [Thick1:TrailEdgeCorrection] | ||
2-497-001 | PaperTransfer:middle:1Side | ENG | [0 to 995 / 100 / 5%/step] |
2-497-002 | PaperTransfer:middle:2Side | ENG | [0 to 995 / 100 / 5%/step] |
2-497-003 | Paper Transfer:Low:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-497-004 | Paper Transfer:Low:2side | ENG | [0 to 995 / 100 / 5%/step] |
[Thick1:SwitchTimingTrailEdge]
2-498-001 | PaperTransfer:middle:1Side | ENG | [0 to 50 / 0 / 2mm/step] |
2-498-002 | PaperTransfer:middle:2Side | ENG | [0 to 50 / 0 / 2mm/step] |
2-498-003 | Paper Transfer:Low:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-498-004 | Paper Transfer:Low:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2503 | [Thick2:Bias:BW] | ||
2-503-003 | PaperTransfer:1side | ENG | [0 to 200 / 11 / 1-uA/step] |
2-503-004 | PaperTransfer:2side | ENG | [0 to 200 / 15 / 1-uA/step] |
2507 | [Thick2:Bias:FC] | ||
2-507-003 | PaperTransfer:1side | ENG | [0 to 200 / 19 / 1-uA/step] |
2-507-004 | PaperTransfer:2side | ENG | [0 to 200 / 21 / 1-uA/step] |
2511 | [Thick2:SizeCorrection:BW] | ||
2-511-003 | PaperTransfer:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-511-004 | PaperTransfer:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-511-007 | PaperTransfer:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-511-008 | PaperTransfer:2Side:S2 | ENG | [100 to 995 / 133 / 1%/step] |
2-511-011 | PaperTransfer:1Side:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-511-012 | PaperTransfer:2Side:S3 | ENG | [100 to 995 / 167 / 1%/step] |
2-511-015 | PaperTransfer:1Side:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-511-016 | PaperTransfer:2Side:S4 | ENG | [100 to 995 / 233 / 1%/step] |
2-511-019 | PaperTransfer:1Side:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-511-020 | PaperTransfer:2Side:S5 | ENG | [100 to 995 / 267 / 1%/step] |
2-511-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-511-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-511-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-511-028 | Wide Roller | ENG | [100 to 995 / 133 / 1%/step] |
2-511-031 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-511-032 | Wide Roller | ENG | [100 to 995 / 167 / 1%/step] |
2-511-035 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-511-036 | Wide Roller | ENG | [100 to 995 / 233 / 1%/step] |
2-511-039 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-511-040 | Wide Roller | ENG | [100 to 995 / 267 / 1%/step] |
2512 | [Thick2:SizeCorrection:FC] | ||
2-512-003 | PaperTransfer:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-512-004 | PaperTransfer:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-512-007 | PaperTransfer:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-512-008 | PaperTransfer:2Side:S2 | ENG | [100 to 995 / 181 / 1%/step] |
2-512-011 | PaperTransfer:1Side:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-512-012 | PaperTransfer:2Side:S3 | ENG | [100 to 995 / 229 / 1%/step] |
2-512-015 | PaperTransfer:1Side:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-512-016 | PaperTransfer:2Side:S4 | ENG | [100 to 995 / 286 / 1%/step] |
2-512-019 | PaperTransfer:1Side:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-512-020 | PaperTransfer:2Side:S5 | ENG | [100 to 995 / 381 / 1%/step] |
2-512-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-512-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-512-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-512-028 | Wide Roller | ENG | [100 to 995 / 181 / 1%/step] |
2-512-031 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-512-032 | Wide Roller | ENG | [100 to 995 / 229 / 1%/step] |
2-512-035 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-512-036 | Wide Roller | ENG | [100 to 995 / 286 / 1%/step] |
2-512-039 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-512-040 | Wide Roller | ENG | [100 to 995 / 381 / 1%/step] |
2513 | [Thick2:Size-Env.Correct:BW] | ||
2-513-003 | PaperTransfer:1Side:S1 | ENG | [1 to 110 / 70 / 1/step] |
2-513-004 | PaperTransfer:2Side:S1 | ENG | [1 to 110 / 72 / 1/step] |
2-513-007 | PaperTransfer:1Side:S2 | ENG | [1 to 110 / 71 / 1/step] |
2-513-008 | PaperTransfer:2Side:S2 | ENG | [1 to 110 / 73 / 1/step] |
2-513-011 | PaperTransfer:1Side:S3 | ENG | [1 to 110 / 71 / 1/step] |
2-513-012 | PaperTransfer:2Side:S3 | ENG | [1 to 110 / 74 / 1/step] |
2-513-015 | PaperTransfer:1Side:S4 | ENG | [1 to 110 / 71 / 1/step] |
2-513-016 | PaperTransfer:2Side:S4 | ENG | [1 to 110 / 75 / 1/step] |
2-513-019 | PaperTransfer:1Side:S5 | ENG | [1 to 110 / 71 / 1/step] |
2-513-020 | PaperTransfer:2Side:S5 | ENG | [1 to 110 / 76 / 1/step] |
2-513-023 | Wide Roller | ENG | [1 to 110 / 70 / 1/step] |
2-513-024 | Wide Roller | ENG | [1 to 110 / 72 / 1/step] |
2-513-027 | Wide Roller | ENG | [1 to 110 / 71 / 1/step] |
2-513-028 | Wide Roller | ENG | [1 to 110 / 73 / 1/step] |
2-513-031 | Wide Roller | ENG | [1 to 110 / 71 / 1/step] |
2-513-032 | Wide Roller | ENG | [1 to 110 / 74 / 1/step] |
2-513-035 | Wide Roller | ENG | [1 to 110 / 71 / 1/step] |
2-513-036 | Wide Roller | ENG | [1 to 110 / 75 / 1/step] |
2-513-039 | Wide Roller | ENG | [1 to 110 / 71 / 1/step] |
2-513-040 | Wide Roller | ENG | [1 to 110 / 76 / 1/step] |
2514 | [Thick2:Size-Env.Correct:FC] | ||
2-514-003 | PaperTransfer:1Side:S1 | ENG | [1 to 110 / 77 / 1/step] |
2-514-004 | PaperTransfer:2Side:S1 | ENG | [1 to 110 / 80 / 1/step] |
2-514-007 | PaperTransfer:1Side:S2 | ENG | [1 to 110 / 78 / 1/step] |
2-514-008 | PaperTransfer:2Side:S2 | ENG | [1 to 110 / 81 / 1/step] |
2-514-011 | PaperTransfer:1Side:S3 | ENG | [1 to 110 / 79 / 1/step] |
2-514-012 | PaperTransfer:2Side:S3 | ENG | [1 to 110 / 82 / 1/step] |
2-514-015 | PaperTransfer:1Side:S4 | ENG | [1 to 110 / 79 / 1/step] |
2-514-016 | PaperTransfer:2Side:S4 | ENG | [1 to 110 / 83 / 1/step] |
2-514-019 | PaperTransfer:1Side:S5 | ENG | [1 to 110 / 79 / 1/step] |
2-514-020 | PaperTransfer:2Side:S5 | ENG | [1 to 110 / 84 / 1/step] |
2-514-023 | Wide Roller | ENG | [1 to 110 / 77 / 1/step] |
2-514-024 | Wide Roller | ENG | [1 to 110 / 80 / 1/step] |
2-514-027 | Wide Roller | ENG | [1 to 110 / 78 / 1/step] |
2-514-028 | Wide Roller | ENG | [1 to 110 / 81 / 1/step] |
2-514-031 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2-514-032 | Wide Roller | ENG | [1 to 110 / 82 / 1/step] |
2-514-035 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2-514-036 | Wide Roller | ENG | [1 to 110 / 83 / 1/step] |
2-514-039 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2-514-040 | Wide Roller | ENG | [1 to 110 / 84 / 1/step] |
2515 | [Thick2:LeadingEdgeCorrection] | ||
2-515-003 | Paper Transfer:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-515-004 | Paper Transfer:2side | ENG | [0 to 995 / 100 / 5%/step] |
2516 | [Thick2:SwitchTimingLeadEdge] | ||
2-516-003 | Paper Transfer:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-516-004 | Paper Transfer:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2517 | [Thick2:TrailEdgeCorrection] | ||
2-517-003 | Paper Transfer:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-517-004 | Paper Transfer:2side | ENG | [0 to 995 / 100 / 5%/step] |
2518 | [Thick2:SwitchTimingTrailEdge] | ||
2-518-003 | Paper Transfer:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-518-004 | Paper Transfer:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2523 | [Thick3:Bias:BW] | ||
2-523-003 | PaperTransfer:1side | ENG | [0 to 200 / 11 / 1-uA/step] |
2-523-004 | PaperTransfer:2side | ENG | [0 to 200 / 15 / 1-uA/step] |
2527 | [Thick3:Bias:FC] | ||
2-527-003 | PaperTransfer:1side | ENG | [0 to 200 / 19 / 1-uA/step] |
2-527-004 | PaperTransfer:2side | ENG | [0 to 200 / 21 / 1-uA/step] |
2531 | [Thick3:SizeCorrection:BW] | ||
2-531-003 | PaperTransfer:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-531-004 | PaperTransfer:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-531-007 | PaperTransfer:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-531-008 | PaperTransfer:2Side:S2 | ENG | [100 to 995 / 133 / 1%/step] |
2-531-011 | PaperTransfer:1Side:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-531-012 | PaperTransfer:2Side:S3 | ENG | [100 to 995 / 167 / 1%/step] |
2-531-015 | PaperTransfer:1Side:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-531-016 | PaperTransfer:2Side:S4 | ENG | [100 to 995 / 233 / 1%/step] |
2-531-019 | PaperTransfer:1Side:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-531-020 | PaperTransfer:2Side:S5 | ENG | [100 to 995 / 267 / 1%/step] |
2-531-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-531-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-531-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-531-028 | Wide Roller | ENG | [100 to 995 / 133 / 1%/step] |
2-531-031 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-531-032 | Wide Roller | ENG | [100 to 995 / 167 / 1%/step] |
2-531-035 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-531-036 | Wide Roller | ENG | [100 to 995 / 233 / 1%/step] |
2-531-039 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-531-040 | Wide Roller | ENG | [100 to 995 / 267 / 1%/step] |
2532 | [Thick3:SizeCorrection:FC] | ||
2-532-003 | PaperTransfer:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-532-004 | PaperTransfer:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-532-007 | PaperTransfer:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-532-008 | PaperTransfer:2Side:S2 | ENG | [100 to 995 / 181 / 1%/step] |
2-532-011 | PaperTransfer:1Side:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-532-012 | PaperTransfer:2Side:S3 | ENG | [100 to 995 / 229 / 1%/step] |
2-532-015 | PaperTransfer:1Side:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-532-016 | PaperTransfer:2Side:S4 | ENG | [100 to 995 / 286 / 1%/step] |
2-532-019 | PaperTransfer:1Side:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-532-020 | PaperTransfer:2Side:S5 | ENG | [100 to 995 / 381 / 1%/step] |
2-532-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-532-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-532-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-532-028 | Wide Roller | ENG | [100 to 995 / 181 / 1%/step] |
2-532-031 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-532-032 | Wide Roller | ENG | [100 to 995 / 229 / 1%/step] |
2-532-035 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-532-036 | Wide Roller | ENG | [100 to 995 / 286 / 1%/step] |
2-532-039 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-532-040 | Wide Roller | ENG | [100 to 995 / 381 / 1%/step] |
2533 | [Thick3:Size-Env.Correct:BW] | ||
2-533-003 | PaperTransfer:1Side:S1 | ENG | [1 to 110 / 85 / 1/step] |
2-533-004 | PaperTransfer:2Side:S1 | ENG | [1 to 110 / 87 / 1/step] |
2-533-007 | PaperTransfer:1Side:S2 | ENG | [1 to 110 / 86 / 1/step] |
2-533-008 | PaperTransfer:2Side:S2 | ENG | [1 to 110 / 88 / 1/step] |
2-533-011 | PaperTransfer:1Side:S3 | ENG | [1 to 110 / 86 / 1/step] |
2-533-012 | PaperTransfer:2Side:S3 | ENG | [1 to 110 / 89 / 1/step] |
2-533-015 | PaperTransfer:1Side:S4 | ENG | [1 to 110 / 86 / 1/step] |
2-533-016 | PaperTransfer:2Side:S4 | ENG | [1 to 110 / 90 / 1/step] |
2-533-019 | PaperTransfer:1Side:S5 | ENG | [1 to 110 / 86 / 1/step] |
2-533-020 | PaperTransfer:2Side:S5 | ENG | [1 to 110 / 91 / 1/step] |
2-533-023 | Wide Roller | ENG | [1 to 110 / 85 / 1/step] |
2-533-024 | Wide Roller | ENG | [1 to 110 / 87 / 1/step] |
2-533-027 | Wide Roller | ENG | [1 to 110 / 86 / 1/step] |
2-533-028 | Wide Roller | ENG | [1 to 110 / 88 / 1/step] |
2-533-031 | Wide Roller | ENG | [1 to 110 / 86 / 1/step] |
2-533-032 | Wide Roller | ENG | [1 to 110 / 89 / 1/step] |
2-533-035 | Wide Roller | ENG | [1 to 110 / 86 / 1/step] |
2-533-036 | Wide Roller | ENG | [1 to 110 / 90 / 1/step] |
2-533-039 | Wide Roller | ENG | [1 to 110 / 86 / 1/step] |
2-533-040 | Wide Roller | ENG | [1 to 110 / 91 / 1/step] |
2534 | [Thick3:Size-Env.Correct:FC] | ||
2-534-003 | PaperTransfer:1Side:S1 | ENG | [1 to 110 / 77 / 1/step] |
2-534-004 | PaperTransfer:2Side:S1 | ENG | [1 to 110 / 92 / 1/step] |
2-534-007 | PaperTransfer:1Side:S2 | ENG | [1 to 110 / 78 / 1/step] |
2-534-008 | PaperTransfer:2Side:S2 | ENG | [1 to 110 / 93 / 1/step] |
2-534-011 | PaperTransfer:1Side:S3 | ENG | [1 to 110 / 79 / 1/step] |
2-534-012 | PaperTransfer:2Side:S3 | ENG | [1 to 110 / 94 / 1/step] |
2-534-015 | PaperTransfer:1Side:S4 | ENG | [1 to 110 / 79 / 1/step] |
2-534-016 | PaperTransfer:2Side:S4 | ENG | [1 to 110 / 95 / 1/step] |
2-534-019 | PaperTransfer:1Side:S5 | ENG | [1 to 110 / 79 / 1/step] |
2-534-020 | PaperTransfer:2Side:S5 | ENG | [1 to 110 / 96 / 1/step] |
2-534-023 | Wide Roller | ENG | [1 to 110 / 77 / 1/step] |
2-534-024 | Wide Roller | ENG | [1 to 110 / 92 / 1/step] |
2-534-027 | Wide Roller | ENG | [1 to 110 / 78 / 1/step] |
2-534-028 | Wide Roller | ENG | [1 to 110 / 93 / 1/step] |
2-534-031 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2-534-032 | Wide Roller | ENG | [1 to 110 / 94 / 1/step] |
2-534-035 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2-534-036 | Wide Roller | ENG | [1 to 110 / 95 / 1/step] |
2535 | [Thick3:LeadingEdgeCorrection] | ||
2-535-003 | Paper Transfer:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-535-004 | Paper Transfer:2side | ENG | [0 to 995 / 100 / 5%/step] |
2-534-039 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2-534-040 | Wide Roller | ENG | [1 to 110 / 96 / 1/step] |
2536 | [Thick3:SwitchTimingLeadEdge] | ||
2-536-003 | Paper Transfer:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-536-004 | Paper Transfer:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2537 | [Thick3:TrailEdgeCorrection] | ||
2-537-003 | Paper Transfer:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-537-004 | Paper Transfer:2side | ENG | [0 to 995 / 100 / 5%/step] |
2538 | [Thick3:SwitchTimingTrailEdge] | ||
2-538-003 | Paper Transfer:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-538-004 | Paper Transfer:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2543 | [OHP:Bias:BW] | ||
2-543-003 | PaperTransfer | ENG | [0 to 200 / 11 / 1-uA/step] |
2547 | [OHP:Bias:FC] | ||
2-547-003 | PaperTransfer | ENG | [0 to 200 / 19 / 1-uA/step] |
2551 | [OHP:SizeCorrection:BW] | ||
2-551-003 | PaperTransfer:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-551-007 | PaperTransfer:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-551-011 | PaperTransfer:S3 | ENG | [100 to 995 / 100 / 1%/step] |
2-551-015 | PaperTransfer:S4 | ENG | [100 to 995 / 100 / 1%/step] |
2-551-019 | PaperTransfer:S5 | ENG | [100 to 995 / 100 / 1%/step] |
2-551-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-551-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-551-031 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-551-035 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-551-039 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2552 | [OHP:SizeCorrection:FC] | ||
2-552-003 | PaperTransfer:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-552-007 | PaperTransfer:S2 | ENG | [100 to 995 / 181 / 1%/step] |
2-552-011 | PaperTransfer:S3 | ENG | [100 to 995 / 229 / 1%/step] |
2-552-015 | PaperTransfer:S4 | ENG | [100 to 995 / 286 / 1%/step] |
2-552-019 | PaperTransfer:S5 | ENG | [100 to 995 / 381 / 1%/step] |
2-552-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-552-027 | Wide Roller | ENG | [100 to 995 / 181 / 1%/step] |
2-552-031 | Wide Roller | ENG | [100 to 995 / 229 / 1%/step] |
2-552-035 | Wide Roller | ENG | [100 to 995 / 286 / 1%/step] |
2-552-039 | Wide Roller | ENG | [100 to 995 / 381 / 1%/step] |
2553 | [OHP:Size-Env.Correct:BW] | ||
2-553-003 | PaperTransfer:S1 | ENG | [1 to 110 / 70 / 1/step] |
2-553-007 | PaperTransfer:S2 | ENG | [1 to 110 / 71 / 1/step] |
2-553-011 | PaperTransfer:S3 | ENG | [1 to 110 / 72 / 1/step] |
2-553-015 | PaperTransfer:S4 | ENG | [1 to 110 / 72 / 1/step] |
2-553-019 | PaperTransfer:S5 | ENG | [1 to 110 / 72 / 1/step] |
2-553-023 | Wide Roller | ENG | [1 to 110 / 70 / 1/step] |
2-553-027 | Wide Roller | ENG | [1 to 110 / 71 / 1/step] |
2-553-031 | Wide Roller | ENG | [1 to 110 / 72 / 1/step] |
2-553-035 | Wide Roller | ENG | [1 to 110 / 72 / 1/step] |
2-553-039 | Wide Roller | ENG | [1 to 110 / 72 / 1/step] |
2554 | [OHP:Size-Env.Correct:FC] | ||
2-554-003 | PaperTransfer:S1 | ENG | [1 to 110 / 77 / 1/step] |
2-554-007 | PaperTransfer:S2 | ENG | [1 to 110 / 78 / 1/step] |
2-554-011 | PaperTransfer:S3 | ENG | [1 to 110 / 79 / 1/step] |
2-554-015 | PaperTransfer:S4 | ENG | [1 to 110 / 79 / 1/step] |
2-554-019 | PaperTransfer:S5 | ENG | [1 to 110 / 79 / 1/step] |
2-554-023 | Wide Roller | ENG | [1 to 110 / 77 / 1/step] |
2-554-027 | Wide Roller | ENG | [1 to 110 / 78 / 1/step] |
2-554-031 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2-554-035 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2-554-039 | Wide Roller | ENG | [1 to 110 / 79 / 1/step] |
2555 | [OHP:LeadingEdgeCorrection] | ||
2-555-003 | Paper Transfer | ENG | [0 to 995 / 100 / 5%/step] |
2556 | [OHP:SwitchTimingLeadEdge] | ||
2-556-003 | Paper Transfer | ENG | [0 to 50 / 0 / 2mm/step] |
2557 | [OHP:TrailEdgeCorrection] | ||
2-557-003 | Paper Transfer | ENG | [0 to 995 / 100 / 5%/step] |
2558 | [OHP:SwitchTimingTrailEdge] | ||
2-558-003 | Paper Transfer | ENG | [0 to 50 / 0 / 2mm/step] |
2563 | [Special1:Bias:BW] | ||
2-563-001 | PaperTransfer:standard:1side | ENG | [0 to 200 / 22 / 1-uA/step] |
2-563-002 | PaperTransfer:standard:2side | ENG | [0 to 200 / 22 / 1-uA/step] |
2-563-003 | PaperTransfer:low:1side | ENG | [0 to 200 / 11 / 1-uA/step] |
2-563-004 | PaperTransfer:low:2side | ENG | [0 to 200 / 11 / 1-uA/step] |
2567 | [Special1:Bias:FC] | ||
2-567-001 | PaperTransfer:standard:1side | ENG | [0 to 200 / 29 / 1-uA/step] |
2-567-002 | PaperTransfer:standard:2side | ENG | [0 to 200 / 29 / 1-uA/step] |
2-567-003 | PaperTransfer:low:1side | ENG | [0 to 200 / 14 / 1-uA/step] |
2-567-004 | PaperTransfer:low:2side | ENG | [0 to 200 / 14 / 1-uA/step] |
2571 | [Special1:SizeCorrection:BW] | ||
2-571-001 | PaperTransfer:Standard:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-571-002 | PaperTransfer:Standard:2Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-571-003 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-571-004 | PaperTransfer:Low:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-571-005 | PaperTransfer:Standard:1Sid:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-571-006 | PaperTransfer:Standard:2Sid:S2 | ENG | [100 to 995 / 105 / 1%/step] |
2-571-007 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-571-008 | PaperTransfer:Low:2Side:S2 | ENG | [100 to 995 / 105 / 1%/step] |
2-571-009 | PaperTransfer:Standard:1Sid:S3 | ENG | [100 to 995 / 105 / 1%/step] |
2-571-010 | PaperTransfer:Standard:2Sid:S3 | ENG | [100 to 995 / 118 / 1%/step] |
2-571-011 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 105 / 1%/step] |
2-571-012 | PaperTransfer:Low:2Side:S3 | ENG | [100 to 995 / 118 / 1%/step] |
2-571-013 | PaperTransfer:Standard:1Sid:S4 | ENG | [100 to 995 / 118 / 1%/step] |
2-571-014 | PaperTransfer:Standard:2Sid:S4 | ENG | [100 to 995 / 131 / 1%/step] |
2-571-015 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 118 / 1%/step] |
2-571-016 | PaperTransfer:Low:2Side:S4 | ENG | [100 to 995 / 131 / 1%/step] |
2-571-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [100 to 995 / 132 / 1%/step] |
2-571-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [100 to 995 / 184 / 1%/step] |
2-571-019 | PaperTransfer:Low:1Side:S5 | ENG | [100 to 995 / 132 / 1%/step] |
2-571-020 | PaperTransfer:Low:2Side:S5 | ENG | [100 to 995 / 184 / 1%/step] |
2-571-021 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-571-022 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-571-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-571-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-571-025 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-571-026 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-571-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-571-028 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-571-029 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-571-030 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-571-031 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-571-032 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-571-033 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-571-034 | Wide Roller | ENG | [100 to 995 / 131 / 1%/step] |
2-571-035 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-571-036 | Wide Roller | ENG | [100 to 995 / 131 / 1%/step] |
2-571-037 | Wide Roller | ENG | [100 to 995 / 132 / 1%/step] |
2-571-038 | Wide Roller | ENG | [100 to 995 / 184 / 1%/step] |
2-571-039 | Wide Roller | ENG | [100 to 995 / 132 / 1%/step] |
2-571-040 | Wide Roller | ENG | [100 to 995 / 184 / 1%/step] |
2572 | [Special1:SizeCorrection:FC] | ||
2-572-001 | PaperTransfer:Standard:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-572-002 | PaperTransfer:Standard:2Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-572-003 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-572-004 | PaperTransfer:Low:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-572-005 | PaperTransfer:Standard:1Sid:S2 | ENG | [100 to 995 / 120 / 1%/step] |
2-572-006 | PaperTransfer:Standard:2Sid:S2 | ENG | [100 to 995 / 140 / 1%/step] |
2-572-007 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 120 / 1%/step] |
2-572-008 | PaperTransfer:Low:2Side:S2 | ENG | [100 to 995 / 140 / 1%/step] |
2-572-009 | PaperTransfer:Standard:1Sid:S3 | ENG | [100 to 995 / 118 / 1%/step] |
2-572-010 | PaperTransfer:Standard:2Sid:S3 | ENG | [100 to 995 / 180 / 1%/step] |
2-572-011 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 118 / 1%/step] |
2-572-012 | PaperTransfer:Low:2Side:S3 | ENG | [100 to 995 / 180 / 1%/step] |
2-572-013 | PaperTransfer:Standard:1Sid:S4 | ENG | [100 to 995 / 130 / 1%/step] |
2-572-014 | PaperTransfer:Standard:2Sid:S4 | ENG | [100 to 995 / 200 / 1%/step] |
2-572-015 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 130 / 1%/step] |
2-572-016 | PaperTransfer:Low:2Side:S4 | ENG | [100 to 995 / 200 / 1%/step] |
2-572-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [100 to 995 / 140 / 1%/step] |
2-572-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [100 to 995 / 240 / 1%/step] |
2-572-019 | PaperTransfer:Low:1Side:S5 | ENG | [100 to 995 / 140 / 1%/step] |
2-572-020 | PaperTransfer:Low:2Side:S5 | ENG | [100 to 995 / 240 / 1%/step] |
2-572-021 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-572-022 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-572-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-572-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-572-025 | Wide Roller | ENG | [100 to 995 / 120 / 1%/step] |
2-572-026 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-572-027 | Wide Roller | ENG | [100 to 995 / 120 / 1%/step] |
2-572-028 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-572-029 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-572-030 | Wide Roller | ENG | [100 to 995 / 180 / 1%/step] |
2-572-031 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-572-032 | Wide Roller | ENG | [100 to 995 / 180 / 1%/step] |
2-572-033 | Wide Roller | ENG | [100 to 995 / 130 / 1%/step] |
2-572-034 | Wide Roller | ENG | [100 to 995 / 200 / 1%/step] |
2-572-035 | Wide Roller | ENG | [100 to 995 / 130 / 1%/step] |
2-572-036 | Wide Roller | ENG | [100 to 995 / 200 / 1%/step] |
2-572-037 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-572-038 | Wide Roller | ENG | [100 to 995 / 240 / 1%/step] |
2-572-039 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-572-040 | Wide Roller | ENG | [100 to 995 / 240 / 1%/step] |
2573 | [Special1:Size-Env.Correct:BW] | ||
2-573-001 | PaperTransfer:Standard:1Sid:S1 | ENG | [1 to 110 / 10 / 1/step] |
2-573-002 | PaperTransfer:Standard:2Sid:S1 | ENG | [1 to 110 / 15 / 1/step] |
2-573-003 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 10 / 1/step] |
2-573-004 | PaperTransfer:Low:2Side:S1 | ENG | [1 to 110 / 15 / 1/step] |
2-573-005 | PaperTransfer:Standard:1Sid:S2 | ENG | [1 to 110 / 11 / 1/step] |
2-573-006 | PaperTransfer:Standard:2Sid:S2 | ENG | [1 to 110 / 16 / 1/step] |
2-573-007 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 11 / 1/step] |
2-573-008 | PaperTransfer:Low:2Side:S2 | ENG | [1 to 110 / 16 / 1/step] |
2-573-009 | PaperTransfer:Standard:1Sid:S3 | ENG | [1 to 110 / 12 / 1/step] |
2-573-010 | PaperTransfer:Standard:2Sid:S3 | ENG | [1 to 110 / 17 / 1/step] |
2-573-011 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 12 / 1/step] |
2-573-012 | PaperTransfer:Low:2Side:S3 | ENG | [1 to 110 / 17 / 1/step] |
2-573-013 | PaperTransfer:Standard:1Sid:S4 | ENG | [1 to 110 / 13 / 1/step] |
2-573-014 | PaperTransfer:Standard:2Sid:S4 | ENG | [1 to 110 / 18 / 1/step] |
2-573-015 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 13 / 1/step] |
2-573-016 | PaperTransfer:Low:2Side:S4 | ENG | [1 to 110 / 18 / 1/step] |
2-573-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [1 to 110 / 14 / 1/step] |
2-573-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [1 to 110 / 19 / 1/step] |
2-573-019 | PaperTransfer:Low:1Side:S5 | ENG | [1 to 110 / 14 / 1/step] |
2-573-020 | PaperTransfer:Low:2Side:S5 | ENG | [1 to 110 / 19 / 1/step] |
2-573-021 | Wide Roller | ENG | [1 to 110 / 10 / 1/step] |
2-573-022 | Wide Roller | ENG | [1 to 110 / 15 / 1/step] |
2-573-023 | Wide Roller | ENG | [1 to 110 / 10 / 1/step] |
2-573-024 | Wide Roller | ENG | [1 to 110 / 15 / 1/step] |
2-573-025 | Wide Roller | ENG | [1 to 110 / 11 / 1/step] |
2-573-026 | Wide Roller | ENG | [1 to 110 / 16 / 1/step] |
2-573-027 | Wide Roller | ENG | [1 to 110 / 11 / 1/step] |
2-573-028 | Wide Roller | ENG | [1 to 110 / 16 / 1/step] |
2-573-029 | Wide Roller | ENG | [1 to 110 / 12 / 1/step] |
2-573-030 | Wide Roller | ENG | [1 to 110 / 17 / 1/step] |
2-573-031 | Wide Roller | ENG | [1 to 110 / 12 / 1/step] |
2-573-032 | Wide Roller | ENG | [1 to 110 / 17 / 1/step] |
2-573-033 | Wide Roller | ENG | [1 to 110 / 13 / 1/step] |
2-573-034 | Wide Roller | ENG | [1 to 110 / 18 / 1/step] |
2-573-035 | Wide Roller | ENG | [1 to 110 / 13 / 1/step] |
2-573-036 | Wide Roller | ENG | [1 to 110 / 18 / 1/step] |
2-573-037 | Wide Roller | ENG | [1 to 110 / 14 / 1/step] |
2-573-038 | Wide Roller | ENG | [1 to 110 / 19 / 1/step] |
2-573-039 | Wide Roller | ENG | [1 to 110 / 14 / 1/step] |
2574 | [Special1:Size-Env.Correct:FC] | ||
2-574-001 | PaperTransfer:Standard:1Sid:S1 | ENG | [1 to 110 / 20 / 1/step] |
2-574-002 | PaperTransfer:Standard:2Sid:S1 | ENG | [1 to 110 / 25 / 1/step] |
2-574-003 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 20 / 1/step] |
2-574-004 | PaperTransfer:Low:2Side:S1 | ENG | [1 to 110 / 25 / 1/step] |
2-574-005 | PaperTransfer:Standard:1Sid:S2 | ENG | [1 to 110 / 21 / 1/step] |
2-574-006 | PaperTransfer:Standard:2Sid:S2 | ENG | [1 to 110 / 26 / 1/step] |
2-574-007 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 21 / 1/step] |
2-574-008 | PaperTransfer:Low:2Side:S2 | ENG | [1 to 110 / 26 / 1/step] |
2-574-009 | PaperTransfer:Standard:1Sid:S3 | ENG | [1 to 110 / 22 / 1/step] |
2-574-010 | PaperTransfer:Standard:2Sid:S3 | ENG | [1 to 110 / 27 / 1/step] |
2-574-011 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 22 / 1/step] |
2-574-012 | PaperTransfer:Low:2Side:S3 | ENG | [1 to 110 / 27 / 1/step] |
2-574-013 | PaperTransfer:Standard:1Sid:S4 | ENG | [1 to 110 / 23 / 1/step] |
2-574-014 | PaperTransfer:Standard:2Sid:S4 | ENG | [1 to 110 / 28 / 1/step] |
2-574-015 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 23 / 1/step] |
2-574-016 | PaperTransfer:Low:2Side:S4 | ENG | [1 to 110 / 28 / 1/step] |
2-574-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [1 to 110 / 24 / 1/step] |
2-574-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [1 to 110 / 29 / 1/step] |
2-574-019 | PaperTransfer:Low:1Side:S5 | ENG | [1 to 110 / 24 / 1/step] |
2-574-020 | PaperTransfer:Low:2Side:S5 | ENG | [1 to 110 / 29 / 1/step] |
2-574-021 | Wide Roller | ENG | [1 to 110 / 20 / 1/step] |
2-573-040 | Wide Roller | ENG | [1 to 110 / 19 / 1/step] |
2-574-022 | Wide Roller | ENG | [1 to 110 / 25 / 1/step] |
2-574-023 | Wide Roller | ENG | [1 to 110 / 20 / 1/step] |
2-574-024 | Wide Roller | ENG | [1 to 110 / 25 / 1/step] |
2-574-025 | Wide Roller | ENG | [1 to 110 / 21 / 1/step] |
2-574-026 | Wide Roller | ENG | [1 to 110 / 26 / 1/step] |
2-574-027 | Wide Roller | ENG | [1 to 110 / 21 / 1/step] |
2-574-028 | Wide Roller | ENG | [1 to 110 / 26 / 1/step] |
2-574-029 | Wide Roller | ENG | [1 to 110 / 22 / 1/step] |
2-574-030 | Wide Roller | ENG | [1 to 110 / 27 / 1/step] |
2-574-031 | Wide Roller | ENG | [1 to 110 / 22 / 1/step] |
2-574-032 | Wide Roller | ENG | [1 to 110 / 27 / 1/step] |
2-574-033 | Wide Roller | ENG | [1 to 110 / 23 / 1/step] |
2-574-034 | Wide Roller | ENG | [1 to 110 / 28 / 1/step] |
2-574-035 | Wide Roller | ENG | [1 to 110 / 23 / 1/step] |
2-574-036 | Wide Roller | ENG | [1 to 110 / 28 / 1/step] |
2-574-037 | Wide Roller | ENG | [1 to 110 / 24 / 1/step] |
2-574-038 | Wide Roller | ENG | [1 to 110 / 29 / 1/step] |
2-574-039 | Wide Roller | ENG | [1 to 110 / 24 / 1/step] |
2-574-040 | Wide Roller | ENG | [1 to 110 / 29 / 1/step] |
2578
2575 | [Special1:LeadingEdgeCorrection] | ||
2-575-001 | PaperTransfer:Standard:1Side | ENG | [0 to 995 / 100 / 5%/step] |
2-575-002 | PaperTransfer:Standard:2Side | ENG | [0 to 995 / 100 / 5%/step] |
2-575-003 | Paper Transfer:Low:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-575-004 | Paper Transfer:Low:2side | ENG | [0 to 995 / 100 / 5%/step] |
2576 | [Special1:SwitchTimingLeadEdge] | ||
2-576-001 | PaperTransfer:Standard:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-576-002 | PaperTransfer:Standard:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2-576-003 | Paper Transfer:Low:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-576-004 | Paper Transfer:Low:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2577 | [Special1:TrailEdgeCorrection] | ||
2-577-001 | PaperTransfer:Standard:1Side | ENG | [0 to 995 / 100 / 5%/step] |
2-577-002 | PaperTransfer:Standard:2Side | ENG | [0 to 995 / 100 / 5%/step] |
2-577-003 | Paper Transfer:Low:1side | ENG | [0 to 995 / 100 / 5%/step] |
2-577-004 | Paper Transfer:Low:2side | ENG | [0 to 995 / 100 / 5%/step] |
[Special1:SwitchTimingTrailEdge]
2-578-001 | PaperTransfer:Standard:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-578-002 | PaperTransfer:Standard:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2-578-003 | Paper Transfer:Low:1side | ENG | [0 to 50 / 0 / 2mm/step] |
2-578-004 | Paper Transfer:Low:2side | ENG | [0 to 50 / 0 / 2mm/step] |
2583 | [Special2:Bias:BW] | ||
2-583-001 | PaperTransfer:standard:1side | ENG | [0 to 200 / 22 / 1-uA/step] |
2-583-002 | PaperTransfer:standard:2side | ENG | [0 to 200 / 22 / 1-uA/step] |
2-583-003 | PaperTransfer:low:1side | ENG | [0 to 200 / 11 / 1-uA/step] |
2-583-004 | PaperTransfer:low:2side | ENG | [0 to 200 / 11 / 1-uA/step] |
2587 | [Special2:Bias:FC] | ||
2-587-001 | PaperTransfer:standard:1side | ENG | [0 to 200 / 29 / 1-uA/step] |
2-587-002 | PaperTransfer:standard:2side | ENG | [0 to 200 / 29 / 1-uA/step] |
2-587-003 | PaperTransfer:low:1side | ENG | [0 to 200 / 14 / 1-uA/step] |
2-587-004 | PaperTransfer:low:2side | ENG | [0 to 200 / 14 / 1-uA/step] |
2591 | [Special2:SizeCorrection:BW] | ||
2-591-001 | PaperTransfer:standard:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-591-002 | PaperTransfer:standard:2Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-591-003 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-591-004 | PaperTransfer:Low:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-591-005 | PaperTransfer:standard:1Sid:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-591-006 | PaperTransfer:standard:2Sid:S2 | ENG | [100 to 995 / 105 / 1%/step] |
2-591-007 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 100 / 1%/step] |
2-591-008 | PaperTransfer:Low:2Side:S2 | ENG | [100 to 995 / 105 / 1%/step] |
2-591-009 | PaperTransfer:standard:1Sid:S3 | ENG | [100 to 995 / 105 / 1%/step] |
2-591-010 | PaperTransfer:standard:2Sid:S3 | ENG | [100 to 995 / 118 / 1%/step] |
2-591-011 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 105 / 1%/step] |
2-591-012 | PaperTransfer:Low:2Side:S3 | ENG | [100 to 995 / 118 / 1%/step] |
2-591-013 | PaperTransfer:standard:1Sid:S4 | ENG | [100 to 995 / 118 / 1%/step] |
2-591-014 | PaperTransfer:standard:2Sid:S4 | ENG | [100 to 995 / 131 / 1%/step] |
2-591-015 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 118 / 1%/step] |
2-591-016 | PaperTransfer:Low:2Side:S4 | ENG | [100 to 995 / 131 / 1%/step] |
2-591-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [100 to 995 / 132 / 1%/step] |
2-591-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [100 to 995 / 184 / 1%/step] |
2-591-019 | PaperTransfer:Low:1Side:S5 | ENG | [100 to 995 / 132 / 1%/step] |
2-591-020 | PaperTransfer:Low:2Side:S5 | ENG | [100 to 995 / 184 / 1%/step] |
2-591-021 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-591-022 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-591-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-591-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-591-025 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-591-026 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-591-027 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-591-028 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-591-029 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-591-030 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-591-031 | Wide Roller | ENG | [100 to 995 / 105 / 1%/step] |
2-591-032 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-591-033 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-591-034 | Wide Roller | ENG | [100 to 995 / 131 / 1%/step] |
2-591-035 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-591-036 | Wide Roller | ENG | [100 to 995 / 131 / 1%/step] |
2-591-037 | Wide Roller | ENG | [100 to 995 / 132 / 1%/step] |
2-591-038 | Wide Roller | ENG | [100 to 995 / 184 / 1%/step] |
2-591-039 | Wide Roller | ENG | [100 to 995 / 132 / 1%/step] |
2-591-040 | Wide Roller | ENG | [100 to 995 / 184 / 1%/step] |
2592 | [Special2:SizeCorrection:FC] | ||
2-592-001 | PaperTransfer:standard:1Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-592-002 | PaperTransfer:standard:2Sid:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-592-003 | PaperTransfer:Low:1Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-592-004 | PaperTransfer:Low:2Side:S1 | ENG | [100 to 995 / 100 / 1%/step] |
2-592-005 | PaperTransfer:standard:1Sid:S2 | ENG | [100 to 995 / 120 / 1%/step] |
2-592-006 | PaperTransfer:standard:2Sid:S2 | ENG | [100 to 995 / 140 / 1%/step] |
2-592-007 | PaperTransfer:Low:1Side:S2 | ENG | [100 to 995 / 120 / 1%/step] |
2-592-008 | PaperTransfer:Low:2Side:S2 | ENG | [100 to 995 / 140 / 1%/step] |
2-592-009 | PaperTransfer:standard:1Sid:S3 | ENG | [100 to 995 / 118 / 1%/step] |
2-592-010 | PaperTransfer:standard:2Sid:S3 | ENG | [100 to 995 / 180 / 1%/step] |
2-592-011 | PaperTransfer:Low:1Side:S3 | ENG | [100 to 995 / 118 / 1%/step] |
2-592-012 | PaperTransfer:Low:2Side:S3 | ENG | [100 to 995 / 180 / 1%/step] |
2-592-013 | PaperTransfer:standard:1Sid:S4 | ENG | [100 to 995 / 130 / 1%/step] |
2-592-014 | PaperTransfer:standard:2Sid:S4 | ENG | [100 to 995 / 200 / 1%/step] |
2-592-015 | PaperTransfer:Low:1Side:S4 | ENG | [100 to 995 / 130 / 1%/step] |
2-592-016 | PaperTransfer:Low:2Side:S4 | ENG | [100 to 995 / 200 / 1%/step] |
2-592-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [100 to 995 / 140 / 1%/step] |
2-592-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [100 to 995 / 240 / 1%/step] |
2-592-019 | PaperTransfer:Low:1Side:S5 | ENG | [100 to 995 / 140 / 1%/step] |
2-592-020 | PaperTransfer:Low:2Side:S5 | ENG | [100 to 995 / 240 / 1%/step] |
2-592-021 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-592-022 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-592-023 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-592-024 | Wide Roller | ENG | [100 to 995 / 100 / 1%/step] |
2-592-025 | Wide Roller | ENG | [100 to 995 / 120 / 1%/step] |
2-592-026 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-592-027 | Wide Roller | ENG | [100 to 995 / 120 / 1%/step] |
2-592-028 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-592-029 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-592-030 | Wide Roller | ENG | [100 to 995 / 180 / 1%/step] |
2-592-031 | Wide Roller | ENG | [100 to 995 / 118 / 1%/step] |
2-592-032 | Wide Roller | ENG | [100 to 995 / 180 / 1%/step] |
2-592-033 | Wide Roller | ENG | [100 to 995 / 130 / 1%/step] |
2-592-034 | Wide Roller | ENG | [100 to 995 / 200 / 1%/step] |
2-592-035 | Wide Roller | ENG | [100 to 995 / 130 / 1%/step] |
2-592-036 | Wide Roller | ENG | [100 to 995 / 200 / 1%/step] |
2-592-037 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-592-038 | Wide Roller | ENG | [100 to 995 / 240 / 1%/step] |
2-592-039 | Wide Roller | ENG | [100 to 995 / 140 / 1%/step] |
2-592-040 | Wide Roller | ENG | [100 to 995 / 240 / 1%/step] |
2593 | [Special2:Size-Env.Correct:BW] | ||
2-593-001 | PaperTransfer:standard:1Sid:S1 | ENG | [1 to 110 / 10 / 1/step] |
2-593-002 | PaperTransfer:standard:2Sid:S1 | ENG | [1 to 110 / 15 / 1/step] |
2-593-003 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 10 / 1/step] |
2-593-004 | PaperTransfer:Low:2Side:S1 | ENG | [1 to 110 / 15 / 1/step] |
2-593-005 | PaperTransfer:standard:1Sid:S2 | ENG | [1 to 110 / 11 / 1/step] |
2-593-006 | PaperTransfer:standard:2Sid:S2 | ENG | [1 to 110 / 16 / 1/step] |
2-593-007 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 11 / 1/step] |
2-593-008 | PaperTransfer:Low:2Side:S2 | ENG | [1 to 110 / 16 / 1/step] |
2-593-009 | PaperTransfer:standard:1Sid:S3 | ENG | [1 to 110 / 12 / 1/step] |
2-593-010 | PaperTransfer:standard:2Sid:S3 | ENG | [1 to 110 / 17 / 1/step] |
2-593-011 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 12 / 1/step] |
2-593-012 | PaperTransfer:Low:2Side:S3 | ENG | [1 to 110 / 17 / 1/step] |
2-593-013 | PaperTransfer:standard:1Sid:S4 | ENG | [1 to 110 / 13 / 1/step] |
2-593-014 | PaperTransfer:standard:2Sid:S4 | ENG | [1 to 110 / 18 / 1/step] |
2-593-015 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 13 / 1/step] |
2-593-016 | PaperTransfer:Low:2Side:S4 | ENG | [1 to 110 / 18 / 1/step] |
2-593-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [1 to 110 / 14 / 1/step] |
2-593-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [1 to 110 / 19 / 1/step] |
2-593-019 | PaperTransfer:Low:1Side:S5 | ENG | [1 to 110 / 14 / 1/step] |
2-593-020 | PaperTransfer:Low:2Side:S5 | ENG | [1 to 110 / 19 / 1/step] |
2-593-021 | Wide Roller | ENG | [1 to 110 / 10 / 1/step] |
2-593-022 | Wide Roller | ENG | [1 to 110 / 15 / 1/step] |
2-593-023 | Wide Roller | ENG | [1 to 110 / 10 / 1/step] |
2-593-024 | Wide Roller | ENG | [1 to 110 / 15 / 1/step] |
2-593-025 | Wide Roller | ENG | [1 to 110 / 11 / 1/step] |
2-593-026 | Wide Roller | ENG | [1 to 110 / 16 / 1/step] |
2-593-027 | Wide Roller | ENG | [1 to 110 / 11 / 1/step] |
2-593-028 | Wide Roller | ENG | [1 to 110 / 16 / 1/step] |
2-593-029 | Wide Roller | ENG | [1 to 110 / 12 / 1/step] |
2-593-030 | Wide Roller | ENG | [1 to 110 / 17 / 1/step] |
2-593-031 | Wide Roller | ENG | [1 to 110 / 12 / 1/step] |
2-593-032 | Wide Roller | ENG | [1 to 110 / 17 / 1/step] |
2-593-033 | Wide Roller | ENG | [1 to 110 / 13 / 1/step] |
2-593-034 | Wide Roller | ENG | [1 to 110 / 18 / 1/step] |
2-593-035 | Wide Roller | ENG | [1 to 110 / 13 / 1/step] |
2-593-036 | Wide Roller | ENG | [1 to 110 / 18 / 1/step] |
2-593-037 | Wide Roller | ENG | [1 to 110 / 14 / 1/step] |
2-593-038 | Wide Roller | ENG | [1 to 110 / 19 / 1/step] |
2-593-039 | Wide Roller | ENG | [1 to 110 / 14 / 1/step] |
2594 | [Special2:Size-Env.Correct:FC] | ||
2-594-001 | PaperTransfer:standard:1Sid:S1 | ENG | [1 to 110 / 20 / 1/step] |
2-594-002 | PaperTransfer:standard:2Sid:S1 | ENG | [1 to 110 / 25 / 1/step] |
2-594-003 | PaperTransfer:Low:1Side:S1 | ENG | [1 to 110 / 20 / 1/step] |
2-594-004 | PaperTransfer:Low:2Side:S1 | ENG | [1 to 110 / 25 / 1/step] |
2-594-005 | PaperTransfer:standard:1Sid:S2 | ENG | [1 to 110 / 21 / 1/step] |
2-594-006 | PaperTransfer:standard:2Sid:S2 | ENG | [1 to 110 / 26 / 1/step] |
2-594-007 | PaperTransfer:Low:1Side:S2 | ENG | [1 to 110 / 21 / 1/step] |
2-594-008 | PaperTransfer:Low:2Side:S2 | ENG | [1 to 110 / 26 / 1/step] |
2-594-009 | PaperTransfer:standard:1Sid:S3 | ENG | [1 to 110 / 22 / 1/step] |
2-594-010 | PaperTransfer:standard:2Sid:S3 | ENG | [1 to 110 / 27 / 1/step] |
2-594-011 | PaperTransfer:Low:1Side:S3 | ENG | [1 to 110 / 22 / 1/step] |
2-594-012 | PaperTransfer:Low:2Side:S3 | ENG | [1 to 110 / 27 / 1/step] |
2-594-013 | PaperTransfer:standard:1Sid:S4 | ENG | [1 to 110 / 23 / 1/step] |
2-594-014 | PaperTransfer:standard:2Sid:S4 | ENG | [1 to 110 / 28 / 1/step] |
2-594-015 | PaperTransfer:Low:1Side:S4 | ENG | [1 to 110 / 23 / 1/step] |
2-594-016 | PaperTransfer:Low:2Side:S4 | ENG | [1 to 110 / 28 / 1/step] |
2-594-017 | PaperTransfer:Standard:1Sid:S5 | ENG | [1 to 110 / 24 / 1/step] |
2-594-018 | PaperTransfer:Standard:2Sid:S5 | ENG | [1 to 110 / 29 / 1/step] |
2-594-019 | PaperTransfer:Low:1Side:S5 | ENG | [1 to 110 / 24 / 1/step] |
2-594-020 | PaperTransfer:Low:2Side:S5 | ENG | [1 to 110 / 29 / 1/step] |
2-594-021 | Wide Roller | ENG | [1 to 110 / 20 / 1/step] |
2-593-040 | Wide Roller | ENG | [1 to 110 / 19 / 1/step] |
Engine SP Mode Tables
