Ricoh MP C2004/C2504 Service Manual Part 26
1-111-006Job High Temp. Correction*ENG[0 to 100 / 0 / 0.1deg/step]
1-111-007Job Low Temp. Correction:Sp.*ENG[0 to 10 / 0.7 / 0.1deg/step]
1-111-008Job High Temp. Correction:Sp.*ENG[0 to 100 / 0 / 0.1deg/step]
1-111-011Standard Environment Temp.*ENG[10 to 30 / 23 / 1deg/step]
1112[Image Processing Temp. Correct]
1-112-001Temp.:plain:Center:Level1/2*ENG[-20 to 20 / 0 / 1deg/step]
1-112-002Temp.:plain:Center:Energy*ENG[-30 to 20 / * / 1deg/step]
Saving*MP C2004:
*NA: -12, EU: -14, Asia: -14, CHN:
-14, TWN: -12, KOR: -14
*MP C2504:
*NA: -9, EU: -11, Asia: -11, CHN:
-11, TWN: -9 , KOR: -11
1113[Curl Correction]
1-113-001Execute Pattern*ENG[0 to 2 / 0 / 1/step]
1: ON(No Decurl)
2: ON
1-113-002Humidity:Threshold:M-humid*ENG[0 to 100 / 1 / 1%/step]
1-113-003Humidity:Threshold:H-humid*ENG[0 to 100 / 65 / 1%/step]
1-113-004Permit Temp.:Delta:press:M-humid*ENG[0 to 200 / 60 / 1deg/step]
1-113-005Permit Temp.:Delta:press:H-humid*ENG[0 to 200 / 50 / 1deg/step]
1-113-006Permit
Temp.:Delta:press:M-humid:No Decurl
1-113-007Permit
Temp.:Delta:press:H-humid:No Decurl
*ENG[0 to 200 / 40 / 1deg/step]
1-113-008CPM:M-humid*ENG[0 to 100 / 80 / 1%/step]
1-113-009CPM:H-humid*ENG[0 to 100 / 65 / 1%/step]
1-113-010CPM:M-humid:No Decurl*ENG[0 to 100 / 80 / 1%/step]
1-113-011CPM:H-humid:No Decurl*ENG[0 to 100 / 65 / 1%/step]
Engine SP Mode Tables
1114[Heat Storage Status]
1-114-001Temp.:Threshold:press*ENG[0 to 200 / 80 / 1deg/step]
1-114-002Temp.Threshold:Atmosphere*ENG[0 to 200 / 40 / 1deg/step]
1-114-003Temp.:Threshold:CPM Down*ENG[0 to 200 / 60 / 1deg/step]
1-114-004Temp.:Threshold:Voltage Detection*ENG[0 to 200 / 40 / 1deg/step]
1115[Target Temp. Correction]
1-115-001Temp.:Delta:End*ENG[-100 to 100 / 0 / 1deg/step]
1116[Heat Storage FB Control]
1-116-001Execution mode*ENG[0 to 2 / 2 / 1/step]
1-116-002Correction Formula Judge Temp*ENG[0 to 200 / 97 / 1deg/step]
1-116-003Heat Gap Correction Temp*ENG[0 to 200 / 0 / 1deg/step]
1-116-011Time Out*ENG[0 to 500 / 10 / 1sec/step]
1-116-012Time Out:Energy Saving*ENG[0 to 500 / 10 / 1sec/step]
1-116-021Delay:Standard Speed:FC:1*ENG[0 to 20000 / 3590 / 1msec/step]
1-116-022Delay:Standard Speed:BW:1*ENG[0 to 20000 / 1320 / 1msec/step]
1-116-023Delay:Mid. Speed:FC:1*ENG[0 to 20000 / 3590 / 1msec/step]
1-116-024Delay:Mid. Speed:BW:1*ENG[0 to 20000 / 1320 / 1msec/step]
1-116-025Delay:Low Speed:FC:1*ENG[0 to 20000 / 7180 / 1msec/step]
1-116-026Delay:Low Speed:BW:1*ENG[0 to 20000 / 2640 / 1msec/step]
1-116-031Delay:Standard Speed:FC:2*ENG[0 to 20000 / 3590 / 1msec/step]
1-116-032Delay:Standard Speed:BW:2*ENG[0 to 20000 / 1320 / 1msec/step]
1-116-033Delay:Mid. Speed:FC:2*ENG[0 to 20000 / 3590 / 1msec/step]
1-116-034Delay:Mid. Speed:BW:2*ENG[0 to 20000 / 1320 / 1msec/step]
1-116-035Delay:Low Speed:FC:2*ENG[0 to 20000 / 7180 / 1msec/step]
1-116-036Delay:Low Speed:BW:2*ENG[0 to 20000 / 2640 / 1msec/step]
1-116-041Press Reference Temp.*ENG[0 to 200 / 86 / 1deg/step]
1-116-042Temp. Correction Lower Limit*ENG[-30 to 0 / 0 / 1deg/step]
1-116-043Temp. Correction Upper Limit*ENG[0 to 30 / 4 / 1deg/step]
1-116-044Press Reference Temp.:Energy Saving*ENG[0 to 200 / 75 / 1deg/step]
1-116-045Temp. Corr. Lower Limit:Energy Saving*ENG[-30 to 0 / -1 / 1deg/step]
1-116-046Temp. Corr. Upper Limit:Energy Saving*ENG[0 to 30 / 0 / 1deg/step]
1-116-051Paper Thickness Coefficient:plain1*ENG[-100 to 100 / * / 1/step]
*MP C2004: -20
*MP C2504: -30
1-116-052Paper Thickness Coefficient:plain2*ENG[-100 to 100 / -40 / 1/step]
1-116-053Paper Thickness Coeff.:Thin*ENG[-100 to 100 / * / 1/step]
*MP C2004: -20
*MP C2504: -40
1-116-054Paper Thickness Coeff.:M-thick*ENG[-100 to 100 / * / 1/step]
*MP C2004: -60
*MP C2504: -50
1-116-073Paper Thickness Coeff.:Low Speed*ENG[-100 to 100 / 0 / 1/step]
1-116-074Paper Thickness Coeff.:plain1/2:Energy Save*ENG[-100 to 100 / 30 / 1/step]
1117[Repeat Temp. Correction] DFU
1-117-001Control Time 1:A3*ENG[0 to 300 / 0 / 1sec/step]
1-117-002Control Time 2:A3*ENG[0 to 300 / 4 / 1sec/step]
1-117-003Temp.:Center:1:A3*ENG[-30 to 30 / 0 / 1deg/step]
1-117-004Temp.:End:1:A3*ENG[-30 to 30 / 5 / 1deg/step]
1-117-005Temp.:Center:2:A3*ENG[-30 to 30 / 0 / 1deg/step]
1-117-006Temp.:End:2:A3*ENG[-30 to 30 / 0 / 1deg/step]
1-117-011Control Time 1:DLT*ENG[0 to 300 / 0 / 1sec/step]
1-117-012Control Time 2:DLT*ENG[0 to 300 / 0 / 1sec/step]
1-117-013Temp.:Center:1:DLT*ENG[-30 to 30 / 0 / 1deg/step]
1-117-014Temp.:End:1:DLT*ENG[-30 to 30 / 0 / 1deg/step]
1-117-015Temp.:Center:2:DLT*ENG[-30 to 30 / 0 / 1deg/step]
1-117-016Temp.:End:2:DLT*ENG[-30 to 30 / 0 / 1deg/step]
1-117-021Control Time 1:B4*ENG[0 to 300 / 0 / 1sec/step]
1-117-022Control Time 2:B4*ENG[0 to 300 / 10 / 1sec/step]
1-117-023Temp.:Center:1:B4*ENG[-30 to 30 / 0 / 1deg/step]
1-117-024Temp.:End:1:B4*ENG[-30 to 30 / 25 / 1deg/step]
1-117-025Temp.:Center:2:B4*ENG[-30 to 30 / 0 / 1deg/step]
1-117-026Temp.:End:2:B4*ENG[-30 to 30 / 25 / 1deg/step]
1-117-031Control Time 1:LT*ENG[0 to 300 / 0 / 1sec/step]
1-117-032Control Time 2:LT*ENG[0 to 300 / 0 / 1sec/step]
1-117-033Temp.:Center:1:LT*ENG[-30 to 30 / 6 / 1deg/step]
1-117-034Temp.:End:1:LT*ENG[-30 to 30 / 21 / 1deg/step]
1-117-035Temp.:Center:2:LT*ENG[-30 to 30 / 6 / 1deg/step]
1-117-036Temp.:End:2:LT*ENG[-30 to 30 / 21 / 1deg/step]
1-117-041Control Time 1:Energy Saving*ENG[0 to 300 / 0 / 1sec/step]
1-117-042Control Time 2:Energy Saving*ENG[0 to 300 / 40 / 1sec/step]
1-117-043Temp.:Center:1:Energy Saving*ENG[-30 to 30 / 0 / 1deg/step]
1-117-044Temp.:End:1:Energy Saving*ENG[-30 to 30 / * / 1deg/step]
*NA: 1, EU: 3, Asia: 1, CHN: 1,
TWN: 3, KOR: 1
1-117-045Temp.:Center:2:Energy Saving*ENG[-30 to 30 / 9 / 1deg/step]
1-117-046Temp.:End:2:Energy Saving*ENG[-30 to 30 / 11 / 1deg/step]
1-117-051Control Time 1:A4*ENG[0 to 300 / 0 / 1sec/step]
1-117-052Control Time 2:A4*ENG[0 to 300 / 120 / 1sec/step]
1-117-053Temp.:Center:1:A4*ENG[-30 to 30 / 0 / 1deg/step]
1-117-054Temp.:End:1:A4*ENG[-30 to 30 / 21 / 1deg/step]
1-117-055Temp.:Center:2:A4*ENG[-30 to 30 / * / 1deg/step]
*NA: 6, EU: 0, Asia: 0, CHN: 0,
TWN: 6, KOR: 0
1-117-056Temp.:End:2:A4*ENG[-30 to 30 / -30 / 1deg/step]
1-117-061Control Time 1:A3:M-thick*ENG[0 to 300 / 0 / 1sec/step]
1-117-062Control Time 2:A3:M-thick*ENG[0 to 300 / 0 / 1sec/step]
1-117-063Temp.:Center:1:A3:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-064Temp.:End:1:A3:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-065Temp.:Center:2:A3:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-066Temp.:End:2:A3:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-071Control Time 1:DLT:M-thick*ENG[0 to 300 / 0 / 1sec/step]
1-117-072Control Time 2:DLT:M-thick*ENG[0 to 300 / 0 / 1sec/step]
1-117-073Temp.:Center:1:DLT:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-074Temp.:End:1:DLT:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-075Temp.:Center:2:DLT:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-076Temp.:End:2:DLT:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-081Control Time 1:Envelope:Long*ENG[0 to 300 / 0 / 1sec/step]
1-117-082Control Time 2:Envelope:Long*ENG[0 to 300 / 0 / 1sec/step]
1-117-083Temp.:Center:1:Envelope:Long*ENG[-30 to 30 / 0 / 1deg/step]
1-117-084Temp.:End:1:Envelope:Long*ENG[-30 to 30 / 10 / 1deg/step]
1-117-085Temp.:Center:2:Envelope:Long*ENG[-30 to 30 / 0 / 1deg/step]
1-117-086Temp.:End:2:Envelope:Long*ENG[-30 to 30 / 10 / 1deg/step]
1-117-091Control Time 1:Envelope:Short*ENG[0 to 300 / 0 / 1sec/step]
1-117-092Control Time 2:Envelope:Short*ENG[0 to 300 / 0 / 1sec/step]
1-117-093Temp.:Center:1:Envelope:Short*ENG[-30 to 30 / 0 / 1deg/step]
1-117-094Temp.:End:1:Envelope:Short*ENG[-30 to 30 / 0 / 1deg/step]
1-117-095Temp.:Center:2:Envelope:Short*ENG[-30 to 30 / 0 / 1deg/step]
1-117-096Temp.:End:2:Envelope:Short*ENG[-30 to 30 / 0 / 1deg/step]
1-117-101Control Time 1:B5*ENG[0 to 300 / 0 / 1sec/step]
1-117-102Control Time 2:B5*ENG[0 to 300 / 0 / 1sec/step]
1-117-103Temp.:Center:1:B5*ENG[-30 to 30 / 0 / 1deg/step]
1-117-104Temp.:End:1:B5*ENG[-125 to 30 / -125 / 1deg/step]
1-117-105Temp.:Center:2:B5*ENG[-30 to 30 / 0 / 1deg/step]
1-117-106Temp.:End:2:B5*ENG[-125 to 30 / -125 / 1deg/step]
1-117-111Control Time 1:12inch*ENG[0 to 300 / 0 / 1sec/step]
1-117-112Control Time 2:12inch*ENG[0 to 300 / 0 / 1sec/step]
1-117-113Temp.:Center:1:12inch*ENG[-30 to 30 / -2 / 1deg/step]
1-117-114Temp.:End:1:12inch*ENG[-30 to 30 / -1 / 1deg/step]
1-117-115Temp.:Center:2:12inch*ENG[-30 to 30 / -2 / 1deg/step]
1-117-116Temp.:End:2:12inch*ENG[-30 to 30 / -1 / 1deg/step]
1-117-121Control Time 1:12inch:M-thick*ENG[0 to 300 / 0 / 1sec/step]
1-117-122Control Time 2:12inch:M-thick*ENG[0 to 300 / 0 / 1sec/step]
1-117-123Temp.:Center:1:12inch:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-124Temp.:End:1:12inch:M-thick*ENG[-30 to 30 / 4 / 1deg/step]
1-117-125Temp.:Center:2:12inch:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-126Temp.:End:2:12inch:M-thick*ENG[-30 to 30 / 4 / 1deg/step]
1-117-131Control Time 1:SRA3*ENG[0 to 300 / 0 / 1sec/step]
1-117-132Control Time 2:SRA3*ENG[0 to 300 / 11 / 1sec/step]
1-117-133Temp.:Center:1:SRA3*ENG[-30 to 30 / 0 / 1deg/step]
1-117-134Temp.:End:1:SRA3*ENG[-30 to 30 / 30 / 1 / deg
1-117-135Temp.:Center:2:SRA3*ENG[-30 to 30 / 0 / 1deg/step]
1-117-136Temp.:End:2:SRA3*ENG[-30 to 30 / 17 / 1deg/step]
1-117-141Control Time 1:SRA3:M-thick*ENG[0 to 300 / 0 / 1sec/step]
1-117-142Control Time 2:SRA3:M-thick*ENG[0 to 300 / 11 / 1sec/step]
1-117-143Temp.:Center:1:SRA3:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-117-144Temp.:End:1:SRA3:M-thick*ENG[-30 to 30 / 6 / 1deg/step]
1-117-145Temp.:Center:2:SRA3:M-thick*ENG[-30 to 30 / 5 / 1deg/step]
1-117-146Temp.:End:2:SRA3:M-thick*ENG[-30 to 30 / 8 / 1deg/step]
1-117-151Control Time 1:A3:Low*ENG[0 to 300 / 0 / 1sec/step]
1-117-152Control Time 2:A3:Low*ENG[0 to 300 / 0 / 1sec/step]
1-117-153Temp.:Center:1:A3:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-117-154Temp.:End:1:A3:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-117-155Temp.:Center:2:A3:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-117-156Temp.:End:2:A3:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-117-161Control Time 1:DLT:Low*ENG[0 to 300 / 0 / 1sec/step]
1-117-162Control Time 2:DLT:Low*ENG[0 to 300 / 0 / 1sec/step]
1-117-163Temp.:Center:1:DLT:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-117-164Temp.:End:1:DLT:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-117-165Temp.:Center:2:DLT:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-117-166Temp.:End:2:DLT:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-117-171Control Time 1:A4LEF*ENG[0 to 300 / 0 / 1sec/step]
1-117-172Control Time 2:A4LEF*ENG[0 to 300 / 0 / 1sec/step]
1-117-173Temp.:Center:1:A4LEF*ENG[-30 to 30 / 0 / 1deg/step]
1-117-174Temp.:End:1:A4LEF*ENG[-30 to 30 / 0 / 1deg/step]
1-117-175Temp.:Center:2:A4LEF*ENG[-30 to 30 / 0 / 1deg/step]
1-117-176Temp.:End:2:A4LEF*ENG[-30 to 30 / 0 / 1deg/step]
1118[Before Job Temp. Correct]
1-118-001Temp.:Center:12inch*ENG[-30 to 30 / 0 / 1deg/step]
1-118-002Temp.:End:12inch*ENG[-30 to 30 / 0 / 1deg/step]
1-118-003Temp.:Center:A3*ENG[-30 to 30 / 0 / 1deg/step]
1-118-004Temp.:End:A3*ENG[-30 to 30 / 0 / 1deg/step]
1-118-005Temp.:Center:DLT*ENG[-30 to 30 / 0 / 1deg/step]
1-118-006Temp.:End:DLT*ENG[-30 to 30 / 0 / 1deg/step]
1-118-007Temp.:Center:SRA3*ENG[-30 to 30 / 0 / 1deg/step]
1-118-008Temp.:End:SRA3*ENG[-30 to 30 / 17 / 1deg/step]
1-118-011Temp.:Center:12inch:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-012Temp.:End:12inch:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-013Temp.:Center:A3:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-014Temp.:End:A3:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-015Temp.:Center:DLT:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-016Temp.:End:DLT:M-thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-017Temp.:Center:SRA3:M-thick*ENG[-30 to 30 / 3 / 1deg/step]
1-118-018Temp.:End:SRA3:M-thick*ENG[-30 to 30 / 6 / 1deg/step]
1-118-021Temp.:Center:12inch:Thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-022Temp.:End:12inch:Thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-023Temp.:Center:A3:Thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-024Temp.:End:A3:Thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-025Temp.:Center:DLT:Thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-026Temp.:End:DLT:Thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-027Temp.:Center:SRA3:Thick*ENG[-30 to 30 / 0 / 1deg/step]
1-118-028Temp.:End:SRA3:Thick*ENG[-30 to 30 / 20 / 1deg/step]
1120[Reserve SP]
1-120-001Recovery mode SW:Low Temp*ENG[0 to 1 / 0 / 1deg/step]
1-120-002Recovery mode SW:Voltage:Low*ENG[0 to 1 / 0 / 1 deg/step]
1-120-003UC3*ENG[0 to 255 / 0 / 1deg/step]
1-120-004UC4*ENG[0 to 255 / 0 / 1deg/step]
1-120-005Ini. CPM Down Time:High Power*ENG[0 to 255 / 2 / 1sec/step]
1-120-006Ini. CPM Down Time:Mid.Power*ENG[0 to 255 / 2 / 1sec/step]
1-120-007Ini. CPM Down Time:Voltage:Low*ENG[0 to 255 / 2 / 1sec/step]
1-120-008Ini. CPM Down Time:Low Temp*ENG[0 to 255 / 2 / 1sec/step]
1-120-009Temp.:Center:3:DLT:Voltage:Low*ENG[0 to 30 / 0 / 1deg/step]
1-120-010Temp.:End:3:DLT:Voltage:Low*ENG[0 to 30 / 0 / 1deg/step]
1-120-011Control Time 1:DLT:Voltage:Low*ENG[0 to 300 / 0 / 1sec/step]
1-120-012Control Time 2:DLT:Voltage:Low*ENG[0 to 300 / 0 / 1sec/step]
1-120-013Control Time 3:DLT:Voltage:Low*ENG[0 to 300 / 0 / 1sec/step]
1-120-014Control Time 1:DLT:Voltage:Low*ENG[0 to 300 / 0 / 1sec/step]
1-120-015Control Time 2:DLT:Voltage:Low*ENG[0 to 300 / 0 / 1sec/step]
1-120-016Control Time 3:DLT:Voltage:Low*ENG[0 to 300 / 0 / 1sec/step]
1-120-017UW7*ENG[0 to 60000 / 0 / 1msec/step]
1-120-018UW8*ENG[0 to 60000 / 0 / 1msec/step]
1-120-019Temp.:End:2:DLT:Voltage:Low*ENG[0 to 100.00 / 0 / 0.01sec/step]
1-120-020Temp.:Center:3:DLT:Voltage:Low*ENG[0 to 100.00 / 0 / 0.01sec/step]
1-120-021Temp.:Center:1:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-022Temp.:End:1:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-023Temp.:Center:2:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-024Temp.:End:2:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-025Temp.:Center:3:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-026Temp.:End:3:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-027Temp.:Center:1:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-028Temp.:End:1:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-029Temp.:Center:2:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1-120-030Temp.:End:2:DLT:Voltage:Low*ENG[-30 to 30 / 0 / 1deg/step]
1121[Switch:Rotation Start/Stop]
1-121-001Time:After Reload*ENG[0 to 100 / 30 / 1sec/step]
1-121-002Time:After Recovery*ENG[0 to 100 / 15 / 1sec/step]
1-121-004Press Temp.:After Reload*ENG[0 to 160 / 160 / 1deg/step]
1-121-005End Temp.:After Job:SRA3*ENG[100 to 250 / 200 / 1deg/step]
1-121-006ShiftTemp:After Job:pressEdge:A3*ENG[100 to 250 / 200 / 1deg/step]
1-121-007ShiftTemp:After Job:pressEdge:DLT*ENG[100 to 250 / 200 / 1deg/step]
1-121-008Overshoot Prevent Temp.*ENG[0 to 250 / 185 / 1deg/step]
1-121-009Overshoot Prevent Time*ENG[0 to 100 / 10 / 1sec/step]
1-121-010End Temp.:After Job:B4*ENG[100 to 250 / 143 / 1deg/step]
1-121-011End Temp.:After Job:LT*ENG[100 to 250 / * / 1deg/step]
*NA: 210, EU: 153, Asia: 153, CHN:
153, TWN: 210, KOR: 153
1-121-012End Temp.:After Job:B5*ENG[100 to 250 / 155 / 1deg/step]
1-121-013End Temp.:After Job:A5*ENG[100 to 250 / 155 / 1deg/step]
1-121-014End Temp.:After Job:B6*ENG[100 to 250 / 145 / 1deg/step]
1-121-015ShiftTemp:FC:After Job:pressCenter:A6*ENG[100 to 250 / 160 / 1deg/step]
1-121-016ShiftTemp:Bk:After Job:pressFl-B_Edge:SRA3*ENG[100 to 250 / 200 / 1deg/step]
1-121-017ShiftTemp:Bk:After Job:pressEdge:A3*ENG[100 to 250 / 200 / 1deg/step]
1-121-018ShiftTemp:Bk:After Job:pressEdge:DLT*ENG[100 to 250 / 200 / 1deg/step]
1-121-019ShiftTemp:Bk:After Job:pressEdge:B4*ENG[100 to 250 / 148 / 1deg/step]
1-121-020ShiftTemp:Bk:After Job:FusingEdge:LT*ENG[100 to 250 / * / 1deg/step]
*NA: 215, EU: 153, Asia: 153, CHN:
153, TWN: 215, KOR: 153
1-121-021Time:After Main Switch On*ENG[0 to 100 / 30 / 1sec/step]
1-121-022ShiftTemp:Bk:After Job:pressCenter:B5*ENG[100 to 250 / 160 / 1deg/step]
1-121-023ShiftTemp:Bk:After Job:pressCenter:A5*ENG[100 to 250 / 160 / 1deg/step]
1-121-024ShiftTemp:Bk:After Job:pressCenter:B6*ENG[100 to 250 / 150 / 1deg/step]
1-121-025ShiftTemp:Bk:After Job:pressCenter:A6*ENG[100 to 250 / 150 / 1deg/step]
1-121-031Pre Job Paper Feed Time:FC:A3*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-032Soaking Rotary Time:FC:A3*ENG[0 to 100 / 0 / 1sec/step]
1-121-033Pre Job Paper Feed Time:FC:DLT*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-034Soaking Rotary Time:FC:DLT*ENG[0 to 100 / 0 / 1sec/step]
1-121-035Pre Job Paper Feed Time:FC:B4*ENG[0 to 10000 / 235 / 1sec/step]
1-121-036Soaking Rotary Time:FC:B4*ENG[0 to 100 / 15 / 1sec/step]
1-121-037Pre Job Paper Feed Time:FC:LT*ENG[0 to 10000 / 250 / 1sec/step]
1-121-038Soaking Rotary Time:FC:LT*ENG[0 to 100 / 10 / 1sec/step]
1-121-039Pre Job Paper Feed Time:FC:B5*ENG[0 to 10000 / 180 / 1sec/step]
1-121-040Soaking Rotary Time:FC:B5*ENG[0 to 100 / 15 / 1sec/step]
1-121-041Pre Job Paper Feed Time:FC:A5*ENG[0 to 10000 / 31 / 1sec/step]
1-121-042Soaking Rotary Time:FC:A5*ENG[0 to 100 / 20 / 1sec/step]
1-121-043Pre Job Paper Feed Time:FC:B6*ENG[0 to 10000 / 27 / 1sec/step]
1-121-044Soaking Rotary Time:FC:B6*ENG[0 to 100 / 25 / 1sec/step]
1-121-045Pre Job Paper Feed Time:FC:A6*ENG[0 to 10000 / * / 1sec/step]
*NA: 70, EU: 40, Asia: 40, CHN: 40,
TWN: 70 , KOR: 40
1-121-046Soaking Rotary Time:FC:A6*ENG[0 to 100 / 60 / 1sec/step]
1-121-051Pre Job Paper Feed Time:Bk:A3*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-052Soaking Rotary Time:Bk:A3*ENG[0 to 100 / 0 / 1sec/step]
1-121-053Pre Job Paper Feed Time:Bk:DLT*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-054Soaking Rotary Time:Bk:DLT*ENG[0 to 100 / 0 / 1sec/step]
1-121-055Pre Job Paper Feed Time:Bk:B4*ENG[0 to 10000 / 235 / 1sec/step]
1-121-056Soaking Rotary Time:Bk:B4*ENG[0 to 100 / 10 / 1sec/step]
1-121-057Pre Job Paper Feed Time:Bk:LT*ENG[0 to 10000 / 250 / 1sec/step]
1-121-058Soaking Rotary Time:Bk:LT*ENG[0 to 100 / 5 / 1sec/step]
1-121-059Pre Job Paper Feed Time:Bk:B5*ENG[0 to 10000 / 180 / 1sec/step]
1-121-060Soaking Rotary Time:Bk:B5*ENG[0 to 100 / 10 / 1sec/step]
1-121-061Pre Job Paper Feed Time:Bk:A5*ENG[0 to 10000 / 31 / 1sec/step]
1-121-062Soaking Rotary Time:Bk:A5*ENG[0 to 100 / 20 / 1sec/step]
1-121-063Pre Job Paper Feed Time:Bk:B6*ENG[0 to 10000 / 27 / 1sec/step]
1-121-064Soaking Rotary Time:Bk:B6*ENG[0 to 100 / 20 / 1sec/step]
1-121-065Pre Job Paper Feed Time:Bk:A6*ENG[0 to 10000 / 80 / 1sec/step]
1-121-066Soaking Rotary Time:Bk:A6*ENG[0 to 100 / 5 / 1sec/step]
1-121-080Shift Time: AfterReload: LineSpd Dwn*ENG[0 to 60 / 10 / 0.1sec/step]
1-121-101Heat Off Time:Start:Warm Up*ENG[0 to 60000 / 0 / 1msec/step]
1-121-102Heat Off Time:Start:End of A Control*ENG[0 to 600000 / 100000 / 1msec/step]
1-121-103Time After Feeler Edge Detect*ENG[0 to 200 / 0 / 1sec/step]
1-121-114Relay ON Temp.:Warm Up*ENG[0 to 250 / 200 / 1deg/step]
1-121-120ShiftTemp:press_Full-Bd Edge:SRA3*ENG[100 to 250 / 220 / 1deg/step]
1-121-121ShiftTemp:pressEdge:A3*ENG[100 to 250 / 215 / 1deg/step]
1-121-122ShiftTemp:pressEdge:DLT*ENG[100 to 250 / 205 / 1deg/step]
1-121-123ShiftTemp:pressEdge:B4*ENG[100 to 250 / 215 / 1deg/step]
1-121-124ShiftTemp:FusingEdge:LT*ENG[100 to 250 / 225 / 1deg/step]
1-121-125ShiftTemp:pressCenter:B5*ENG[100 to 250 / 220 / 1deg/step]
1-121-126ShiftTemp:pressCenter:A5*ENG[100 to 250 / 210 / 1deg/step]
1-121-127ShiftTemp:pressCenter:B6*ENG[100 to 250 / 210 / 1deg/step]
1-121-128ShiftTemp:pressCenter:A6*ENG[100 to 250 / 210 / 1deg/step]
1-121-141Pre Job Paper Feed Time:A3*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-142Soaking Rotary Time:A3*ENG[0 to 100 / 10 / 1sec/step]
1-121-143Pre Job Paper Feed Time:DLT*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-144Soaking Rotary Time:DLT*ENG[0 to 100 / 10 / 1sec/step]
1-121-145Pre Job Paper Feed Time:B4*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-146Soaking Rotary Time:B4*ENG[0 to 100 / 10 / 1sec/step]
1-121-147Pre Job Paper Feed Time:LT*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-148Soaking Rotary Time:LT*ENG[0 to 100 / 10 / 1sec/step]
1-121-149Pre Job Paper Feed Time:B5*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-150Soaking Rotary Time:B5*ENG[0 to 100 / 10 / 1sec/step]
1-121-151Pre Job Paper Feed Time:A5*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-152Soaking Rotary Time:A5*ENG[0 to 100 / 10 / 1sec/step]
1-121-153Pre Job Paper Feed Time:B6*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-154Soaking Rotary Time:B6*ENG[0 to 100 / 10 / 1sec/step]
1-121-155Pre Job Paper Feed Time:A6*ENG[0 to 10000 / 10000 / 1sec/step]
1-121-156Soaking Rotary Time:A6*ENG[0 to 100 / 10 / 1sec/step]
1122[Standby Rotation Setting]
1-122-001Rotation Interval*ENG[0 to 240 / 60 / 1min/step]
1-122-002Rotation Time*ENG[0.0 to 60.0 / 8.0 / 0.1sec/step]
1123[Paper Jam Rotation Setting]
1-123-001Normal Rotation Distance*ENG[0 to 10000 / 75 / 1mm/step]
1-123-002Reverse Rotation Distance*ENG[0 to 10000 / 25 / 1mm/step]
1124[CPM Down Setting] DFU
1-124-001High:Down Temp.*ENG[-50 to 0 / -30 / 1deg/step]
1-124-002High:Up Temp.*ENG[-50 to 0 / -15 / 1deg/step]
1-124-003Low :1st CPM*ENG[10 to 100 / 80 / 1%/step]
1-124-004Low :2nd CPM*ENG[10 to 100 / 65 / 1%/step]
1-124-005Low :3rd CPM*ENG[10 to 100 / 50 / 1%/step]
1-124-007High:2nd CPM*ENG[10 to 100 / 50 / 1%/step]
1-124-008High:3rd CPM*ENG[10 to 100 / 30 / 1%/step]
1-124-009High:1st CPM Down Temp.:A3:press End*ENG[100 to 250 / 205 / 1deg/step]
1-124-010High:2nd CPM Down Temp.:A3:press End*ENG[100 to 250 / 210 / 1deg/step]
1-124-011High:3rd CPM Down Temp.:A3:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-012High:1st CPM Down Temp.:DLT:press End*ENG[100 to 250 / 205 / 1deg/step]
1-124-013High:2nd CPM Down Temp.:DLT:press End*ENG[100 to 250 / 210 / 1deg/step]
1-124-014High:3rd CPM Down Temp.:DLT:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-015High:1st CPM Down Temp.:B4:press End*ENG[100 to 250 / 200 / 1deg/step]
1-124-016High:2nd CPM Down Temp.:B4:press End*ENG[100 to 250 / 210 / 1deg/step]
1-124-017High:3rd CPM Down Temp.:B4:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-018High:1st CPM Down Temp.:LT:Fuser End*ENG[100 to 250 / 215 / 1deg/step]
1-124-019High:2nd CPM Down Temp.:LT:Fuser End*ENG[100 to 250 / 220 / 1deg/step]
1-124-020High:3rd CPM Down Temp.:LT:Fuser End*ENG[100 to 250 / 225 / 1deg/step]
1-124-021High:1st CPM Down Temp.:A4:Fuser End*ENG[100 to 250 / 215 / 1deg/step]
1-124-022High:2nd CPM Down Temp.:A4:Fuser End*ENG[100 to 250 / 220 / 1deg/step]
1-124-023High:3rd CPM Down Temp.:A4:Fuser End*ENG[100 to 250 / 225 / 1deg/step]
1-124-024High:1st CPM Down Temp.:B5:press Center*ENG[100 to 250 / 205 / 1deg/step]
1-124-025High:2nd CPM Down Temp.:B5:press Center*ENG[100 to 250 / 210 / 1deg/step]
1-124-026High:3rd CPM Down Temp.:B5:press Center*ENG[100 to 250 / 215 / 1deg/step]
1-124-027High:1st CPM Down Temp.:A5:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 170, EU: 204, Asia: 204, CHN:
204, TWN: 170, KOR: 204
1-124-028High:2nd CPM Down Temp.:A5:press Center*ENG[100 to 250 / 209 / 1deg/step]
1-124-029High:3rd CPM Down Temp.:A5:press Center*ENG[100 to 250 / 217 / 1deg/step]
1-124-030High:1st CPM Down Temp.:B6:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 180, EU: 209, Asia: 209, CHN:
209, TWN: 180, KOR: 209
1-124-031High:2nd CPM Down Temp.:B6:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 185, EU: 214, Asia: 214, CHN:
214, TWN: 185, KOR: 214
1-124-032High:3rd CPM Down Temp.:B6:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 192, EU: 219, Asia: 219, CHN:
29, TWN: 192, KOR: 219
1-124-033High:1st CPM Down Temp.:A6:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-034High:2nd CPM Down Temp.:A6:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-035High:3rd CPM Down Temp.:A6:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-036High:1st CPM Down Temp.:SRA3:press End*ENG[100 to 250 / 210 / 1deg/step]
1-124-037High:2nd CPM Down Temp.:SRA3:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-038High:3rd CPM Down Temp.:SRA3:press End*ENG[100 to 250 / 220 / 1deg/step]
1-124-040Low Temp.:1st CPM_2*ENG[10 to 100 / 80 / 1%/step]
1-124-041Low Temp.:2nd CPM_2*ENG[10 to 100 / 65 / 1%/step]
1-124-042Low Temp.:1st CPM_3*ENG[10 to 100 / 80 / 1%/step]
1-124-043Low Temp.:2nd CPM_3*ENG[10 to 100 / 65 / 1%/step]
1-124-051Judging Interval*ENG[1 to 250 / 4 / 1sec/step]
1-124-060Ini. CPM Down Time*ENG[0 to 255 / 2 / 1sec/step]
1-124-061Ini. CPM Down Time 10sec recovery*ENG[0 to 255 / 2 / 1sec/step]
1-124-071L:High:1st Temp.:DLT:press End*ENG[100 to 250 / 205 / 1deg/step]
1-124-072L:High:2nd Temp.:DLT:press End*ENG[100 to 250 / 210 / 1deg/step]
1-124-073L:High:3rd Temp.:DLT:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-074L:High:4th Temp.:DLT:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-075L:High:1st Temp.:B4:press End*ENG[100 to 250 / 180 / 1deg/step]
1-124-076L:High:2nd Temp.:B4:press End*ENG[100 to 250 / 180 / 1deg/step]
1-124-077L:High:3rd Temp.:B4:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-078L:High:4th Temp.:B4:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-079L:High:1st Temp.:B5:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 155, EU: 193, Asia: 193, CHN:
193, TWN: 205, KOR: 193
1-124-080L:High:2nd Temp.:B5:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 160, EU: 199, Asia: 199, CHN:
199, TWN: 210, KOR: 199
1-124-081L:High:3rd Temp.:B5:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 165, EU: 205, Asia: 205, CHN:
205, TWN: 165, KOR: 205
1-124-082L:High:4th Temp.:B5:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 200, EU: 205, Asia: 205, CHN:
205, TWN: 200, KOR: 205
1-124-083L:High:1st Temp.:A5:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 160, EU: 193, Asia: 193, CHN:
193, TWN: 160, KOR: 193
1-124-084L:High:2nd Temp.:A5:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 170, EU: 199, Asia: 199, CHN:
199, TWN: 170, KOR: 199
1-124-085L:High:3rd Temp.:A5:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 190, EU: 205, Asia: 205, CHN:
205, TWN: 190, KOR: 205
1-124-086L:High:4th Temp.:A5:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-087L:High:1st Temp.:B6:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 155, EU: 191, Asia: 191, CHN:
191, TWN: 155, KOR: 191
1-124-088L:High:2nd Temp.:B6:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 178, EU: 196, Asia: 196, CHN:
196, TWN: 178, KOR: 196
1-124-089L:High:3rd Temp.:B6:press Center*ENG[100 to 250 / * / 1deg/step]
*NA: 192, EU: 201, Asia: 201, CHN:
201, TWN: 192, KOR: 201
1-124-090L:High:4th Temp.:B6:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-091L:High:1st Temp.:A6:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-092L:High:2nd Temp.:A6:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-093L:High:3rd Temp.:A6:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-094L:High:4th Temp.:A6:press Center*ENG[100 to 250 / * / 1deg/step]
1-124-101High:1st CPM Down Time:A3*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-102High:2nd CPM Down Time:A3*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-103High:3rd CPM Down Time:A3*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-104High:1st CPM Down Time:DLT*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-105High:2nd CPM Down Time:DLT*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-106High:3rd CPM Down Time:DLT*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-107High:1st CPM Down Time:B4*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-108High:2nd CPM Down Time:B4*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-109High:3rd CPM Down Time:B4*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-110High:1st CPM Down Time:LT*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-111High:2nd CPM Down Time:LT*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-112High:3rd CPM Down Time:LT*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-113High:1st CPM Down Time:A4*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-114High:2nd CPM Down Time:A4*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-115High:3rd CPM Down Time:A4*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-116High:1st CPM Down Time:B5*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-117High:2nd CPM Down Time:B5*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-118High:3rd CPM Down Time:B5*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-119High:1st CPM Down Time:A5*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-120High:2nd CPM Down Time:A5*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-121High:3rd CPM Down Time:A5*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-122High:1st CPM Down Time:B6*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-123High:2nd CPM Down Time:B6*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-124High:3rd CPM Down Time:B6*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-125High:1st CPM Down Time:A6*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-126High:2nd CPM Down Time:A6*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-127High:3rd CPM Down Time:A6*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-128High:1st CPM Down Time:SRA3*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-129High:2nd CPM Down Time:SRA3*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-130High:3rd CPM Down Time:SRA3*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-151High:1st CPM Down Time:A3:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-152High:2nd CPM Down Time:A3:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-153High:3rd CPM Down Time:A3:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-154High:1st CPM Down Time:DLT:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-155High:2nd CPM Down Time:DLT:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-156High:3rd CPM Down Time:DLT:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-157High:1st CPM Down Time:B4:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-158High:2nd CPM Down Time:B4:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-159High:3rd CPM Down Time:B4:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-160High:1st CPM Down Time:LT:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-161High:2nd CPM Down Time:LT:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-162High:3rd CPM Down Time:LT:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-163High:1st CPM Down Time:A4:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-164High:2nd CPM Down Time:A4:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-165High:3rd CPM Down Time:A4:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-166High:1st CPM Down Time:B5:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-167High:2nd CPM Down Time:B5:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-168High:3rd CPM Down Time:B5:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-169High:1st CPM Down Time:A5:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-170High:2nd CPM Down Time:A5:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-171High:3rd CPM Down Time:A5:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-172High:1st CPM Down Time:B6:Low Speed*ENG[0 to 10000 / 60 / 1sec/step]
1-124-173High:2nd CPM Down Time:B6:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-174High:3rd CPM Down Time:B6:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-175High:1st CPM Down Time:A6:Low Speed*ENG[0 to 10000 / 60 / 1sec/step]
1-124-176High:2nd CPM Down Time:A6:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-177High:3rd CPM Down Time:A6:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-178High:1st CPM Down Time:SRA3:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-179High:2nd CPM Down Time:SRA3:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-180High:3rd CPM Down Time:SRA3:Low Speed*ENG[0 to 10000 / 10000 / 1sec/step]
1-124-190NC:1st CPM:Decreased Temp.*ENG[80 to 250 / 123 / 1deg/step]
1-124-191NC:2nd CPM:Decreased Temp.*ENG[80 to 250 / 124 / 1deg/step]
1-124-192NC:3rd CPM:Decreased Temp.*ENG[80 to 250 / 125 / 1deg/step]
1-124-193NC:1st CPM:Decreased Ratio*ENG[10 to 100 / 50 / 1%/step]
1-124-194NC:2nd CPM:Decreased Ratio*ENG[10 to 100 / 30 / 1%/step]
1-124-195NC:3rd CPM:Decreased Ratio*ENG[10 to 100 / 10 / 1%/step]
1-124-201Low:Down Temp.*ENG[-50 to 0 / -30 / 1deg/step]
1-124-202Low:Up Temp.*ENG[-50 to 0 / -15 / 1deg/step]
1-124-203High Temp: Decreased Temp: Mid-Low Spd*ENG[-50 to 0 / -20 / 1deg/step]
1-124-204High Temp: Increased Temp: Mid-Low Spd*ENG[-50 to 0 / -15 / 1deg/step]
1-124-205Low Temp: Decreased Temp: Mid-Low Spd*ENG[-50 to 0 / -20 / 1deg/step]
1-124-206Low Temp: Increased Temp: Mid-Low Spd*ENG[-50 to 0 / -15 / 1deg/step]
1-124-210Temp.:Threshold::Low Power*ENG[0 to 200 / 0 / 1deg/step]
1-124-211CPM Level 2: Judge:Low Power*ENG[0 to 200 / 110 / 1deg/step]
1-124-212Temp.:Threshold:Judge:Mid. Power*ENG[0 to 200 / 0 / 1deg/step]
1-124-213CPM Level 2: Judge:Mid. Power*ENG[0 to 200 / 110 / 1deg/step]
1-124-214Temp.:Threshold:Judge:High Power*ENG[0 to 200 / 0 / 1deg/step]
1-124-215CPM Level 2: Judge:High Power*ENG[0 to 200 / 110 / 1deg/step]
1-124-220Ini.: HighTemp: DownTemp*ENG[-50 to 0 / -30 / 1deg/step]
1-124-221Ini.: HighTemp: UpTemp*ENG[-50 to 50 / -15 / 1deg/step]
1-124-222Ini.: LowTemp: DownTemp*ENG[-50 to 0 / -30 / 1deg/step]
1-124-223Ini.: LowTemp: UpTemp*ENG[-50 to 50 / -15 / 1deg/step]
1-124-224Ini.: HighTemp: DownTemp: Mid-Low Spd*ENG[-50 to 0 / -20 / 1deg/step]
1-124-225Ini.: HighTemp: UpTemp: Mid-Low Spd*ENG[-50 to 50 / -15 / 1deg/step]
1-124-226Ini.: LowTemp: DownTemp: Mid-Low Spd*ENG[-50 to 0 / -20 / 1deg/step]
1-124-227Ini.: LowTemp: UpTemp: Mid-Low Spd*ENG[-50 to 50 / -15 / 1deg/step]
1-124-241L:High:3rd Temp.:SRA3:press End*ENG[100 to 250 / 220 / 1deg/step]
1-124-242L:High:3rd Temp.:A3:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-243L:High:3rd Temp.:DLT:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-244L:High:3rd Temp.:B4:press End*ENG[100 to 250 / 215 / 1deg/step]
1-124-245L:High:3rd Temp.:LT:Fuser End*ENG[100 to 250 / 225 / 1deg/step]
1-124-246L:High:3rd Temp.:A4:Fuser End*ENG[100 to 250 / 225 / 1deg/step]
1-124-247L:High:3rd Temp.:B5:press Center*ENG[100 to 250 / 215 / 1deg/step]
1-124-248L:High:3rd Temp.:A5:press Center*ENG[100 to 250 / 217 / 1deg/step]
1-124-249L:High:3rd Temp.:B6:press Center*ENG[100 to 250 / * / 1deg/step]
219, TWN: 192, KOR: 219
1-124-250L:High:3rd Temp.:A6:press Center*ENG[100 to 250 / * / 1deg/step]
1125[CPM Down Setting]
1-125-001High:1st CPM:A3:Large Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-002High:2nd CPM:A3:Large Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-003High:3rd CPM:A3:Large Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-004High:1st CPM:A3:Small Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-005High:2nd CPM:A3:Small Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-006High:3rd CPM:A3:Small Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-007High:1st CPM:DLT:Large Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-008High:2nd CPM:DLT:Large Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-009High:3rd CPM:DLT:Large Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-010High:1st CPM:DLT:Small Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-011High:2nd CPM:DLT:Small Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-012High:3rd CPM:DLT:Small Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-013High:1st CPM:B4:Large Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-014High:2nd CPM:B4:Large Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-015High:3rd CPM:B4:Large Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-016High:1st CPM:B4:Small Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-017High:2nd CPM:B4:Small Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-018High:3rd CPM:B4:Small Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-019High:1st CPM:LT:Large Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-020High:2nd CPM:LT:Large Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-021High:3rd CPM:LT:Large Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-022High:1st CPM:LT:Small Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-023High:2nd CPM:LT:Small Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-024High:3rd CPM:LT:Small Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-025High:1st CPM:A4:Large Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-026High:2nd CPM:A4:Large Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-027High:3rd CPM:A4:Large Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-028High:1st CPM:A4:Small Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-029High:2nd CPM:A4:Small Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-030High:3rd CPM:A4:Small Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-031High:1st CPM:B5:Large Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-032High:2nd CPM:B5:Large Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-033High:3rd CPM:B5:Large Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-034High:1st CPM:B5:Small Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-035High:2nd CPM:B5:Small Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-036High:3rd CPM:B5:Small Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-037High:1st CPM:A5:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-038High:2nd CPM:A5:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-039High:3rd CPM:A5:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-040High:1st CPM:B6:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-041High:2nd CPM:B6:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-042High:3rd CPM:B6:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-043High:1st CPM:A6:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-044High:2nd CPM:A6:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-045High:3rd CPM:A6:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-046High:1st CPM:SRA3:Large Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-047High:2nd CPM:SRA3:Large Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-048High:3rd CPM:SRA3:Large Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-049High:1st CPM:SRA3:Small Size:Normal Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-050High:2nd CPM:SRA3:Small Size:Normal Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-051High:3rd CPM:SRA3:Small Size:Normal Speed*ENG[0 to 100 / 30 / 1%/step]
1-125-101High:1st CPM:A3:Large Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-102High:2nd CPM:A3:Large Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-104High:1st CPM:A3:Small Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-105High:2nd CPM:A3:Small Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-107High:1st CPM:DLT:Large Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-108High:2nd CPM:DLT:Large Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-110High:1st CPM:DLT:Small Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-111High:2nd CPM:DLT:Small Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-113High:1st CPM:B4:Large Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-114High:2nd CPM:B4:Large Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-116High:1st CPM:B4:Small Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-117High:2nd CPM:B4:Small Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-119High:1st CPM:LT:Large Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-120High:2nd CPM:LT:Large Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-122High:1st CPM:LT:Small Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-123High:2nd CPM:LT:Small Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-125High:1st CPM:A4:Large Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-126High:2nd CPM:A4:Large Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-128High:1st CPM:A4:Small Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-129High:2nd CPM:A4:Small Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-131High:1st CPM:B5:Large Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-132High:2nd CPM:B5:Large Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-134High:1st CPM:B5:Small Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-135High:2nd CPM:B5:Small Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-137High:1st CPM:A5:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-138High:2nd CPM:A5:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-140High:1st CPM:B6:Middle Speed*ENG[0 to 100 / 60 / 1%/step]
1-125-141High:2nd CPM:B6:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-143High:1st CPM:A6:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-144High:2nd CPM:A6:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-145High:1st CPM:SRA3:Large Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-146High:2nd CPM:SRA3:Large Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-147High:1st CPM:SRA3:Small Size:Middle Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-148High:2nd CPM:SRA3:Small Size:Middle Speed*ENG[0 to 100 / 50 / 1%/step]
1-125-201High:1st CPM:A3:Large Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-204High:1st CPM:A3:Small Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-207High:1st CPM:DLT:Large Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-210High:1st CPM:DLT:Small Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-213High:1st CPM:B4:Large Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-216High:1st CPM:B4:Small Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-219High:1st CPM:LT:Large Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-222High:1st CPM:LT:Small Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-225High:1st CPM:A4:Large Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-228High:1st CPM:A4:Small Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-231High:1st CPM:B5:Large Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-234High:1st CPM:B5:Small Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-237High:1st CPM:A5:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-125-240High:1st CPM:B6:Low Speed*ENG[0 to 100 / 83 / 1%/step]
1-125-243High:1st CPM:A6:Low Speed*ENG[0 to 100 / 93 / 1%/step]
1-125-244High:1st CPM:SRA3:Large Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1126[Heating Start Delay]
1-126-001Judgement Temp 1*ENG[0 to 180 / 30 / 1deg/step]
1-126-002Judgement Temp 2*ENG[0 to 180 / 32 / 1deg/step]
1-126-003Judgement Temp 3*ENG[0 to 180 / 45 / 1deg/step]
1-126-011Set TimeA: Div 1*ENG[0 to 10000 / * / 1msec/step]
*NA: 1100, EU: 1500, Asia: 1500,
CHN: 1500, TWN: 1100, KOR:
1500
1-126-012Set TimeA: Div 2*ENG[0 to 10000 / * / 1msec/step]
*NA: 1600, EU: 2200, Asia: 2200,
CHN: 2200, TWN: 1600, KOR:
2200
1-126-013Set TimeA: Div 3*ENG[0 to 10000 / * / 1msec/step]
*NA: 1900, EU: 2500, Asia: 2500,
CHN: 2500, TWN: 1900, KOR:
2500
1-126-014Set TimeA: Div 4*ENG[0 to 10000 / * / 1msec/step]
1500
1-126-021Delay Time: Div 1*ENG[0 to 10000 / * / 1msec/step]
1500
1-126-022Delay Time: Div 2*ENG[0 to 10000 / * / 1msec/step]
2200
1-125-245High:1st CPM:SRA3:Small Size:Low Speed*ENG[0 to 100 / 80 / 1%/step]
1-126-023Delay Time: Div 3*ENG[0 to 10000 / * / 1msec/step]
2500
1-126-024Delay Time: Div 4*ENG[0 to 10000 / * / 1msec/step]
1500
1127[Energy Saving PprFeed Judgment]
1-127-001Judging Method ChangeENG[0 to 2 / 1 / 1/step]
1-127-002Temp.: Threshold: PressENG[0 to 200 / 50 / 1deg/step]
1-127-003Temp.: Threshold: AtmosphereENG[0 to 200 / 60 / 1deg/step]
1-127-004Power Supply Voltage: LowerENG[0 to 300 / * / 1V/step]
*NA: 108, EU: 206, Asia: 206, CHN:
206, TWN: 102 , KOR: 206
1-127-005Power Supply Voltage: UpperENG[0 to 300 / * / 1V/step]
*NA: 134, EU: 252, Asia: 252, CHN:
252, TWN: 121 , KOR: 252
1-127-006Judgment Time-OutENG[0 to 10.0 / 10.0 / 0.1sec/step]
1131[Continuous Print Mode Switch]
1-131-001Feed Permit Condition*ENG[0 to 2 / 1 / 1/step]
0: Productivity Mode
1: Fusing Quality Mode 2: Fusing Quality Mode 2
1132[Maximum Duty Switch]
1-132-001Control Method Switch*ENG[0 or 1 / 1 / 1/step]
0: Fixed Duty
1: AutoOffstCtl
1133[Voltage Detection]
1-133-001Heater ON*ENG[0 to 350.0 / * / 0.1V/step]
*NA: 116.0, EU: 223.0, Asia: 223.0,
CHN: 223.0, TWN: 107.0 , KOR:
223.0
1-133-002Max*ENG[0 to 350.0 / 0 / 0.1V/step]
1-133-003Min*ENG[0 to 350.0 / 350.0 / 0.1V/step]
1-133-004Last*ENG[0 to 350.0 / 0 / 0.1V/step]
1-133-005SC*ENG[0 to 350.0 / 0 / 0.1V/step]
1-133-006
Threshold Voltage
*ENG[0 to 255 / * / 1V/step]
*NA: 96, EU: 178, Asia: 178, CHN:
178, TWN: 88 , KOR: 178
1134[Effective Duty Adjustment]
1-134-001Control Method Switch*ENG[0 or 1 / 1 / 1/step]
1135[Inrush Control]
1-135-001Inrush Control*ENG[0 or 1 / 0 / 1/step] 0: Normal (Do not)
1: Inrush current suppress (Do)
1-135-002Flicker Control*ENG[0 or 1 / 0 / 1/step]
1141[Fusing SC Error Time Info]
1-141-001SC Number*ENG[0 to 99999 / 0 / 1/step]
1-141-101Htg Roller:Ctr Det1*ENG[-100 to 300 / 0 / 1deg/step]
1-141-102Htg Roller:End Det1*ENG[-100 to 300 / 0 / 1deg/step]
1-141-103Press Roller:Ctr Det1*ENG[-100 to 300 / 0 / 1deg/step]
1-141-104Press Roller:End Det1*ENG[-100 to 300 / 0 / 1deg/step]
1-141-105NC Sensor: Center Atmosphere Temp 1*ENG[-100 to 300 / 0 / 1deg/step]
1-141-106NC Sensor: End Atmosphere Temp 1*ENG[-100 to 300 / 0 / 1deg/step]
1-141-151Htg Roller:Ctr Det2*ENG[-100 to 300 / 0 / 1deg/step]
1-141-152Htg Roller:End Det2*ENG[-100 to 300 / 0 / 1deg/step]
1-141-153Press Roller:Ctr Det2*ENG[-100 to 300 / 0 / 1deg/step]
1-141-154Press Roller:End Det2*ENG[-100 to 300 / 0 / 1deg/step]
1-141-155NC Sensor: Center Atmosphere Temp 2*ENG[-100 to 300 / 0 / 1deg/step]
1-141-156NC Sensor: End Atmosphere Temp 2*ENG[-100 to 300 / 0 / 1deg/step]
1-141-201Htg Roller:Ctr Det3*ENG[-100 to 300 / 0 / 1deg/step]
1-141-202Htg Roller:End Det3*ENG[-100 to 300 / 0 / 1deg/step]
1-141-203Press Roller:Ctr Det3*ENG[-100 to 300 / 0 / 1deg/step]
1-141-204Press Roller:End Det3*ENG[-100 to 300 / 0 / 1deg/step]
1-141-205NC Sensor: Center Atmosphere Temp 3*ENG[-100 to 300 / 0 / 1deg/step]
1-141-206NC Sensor: End Atmosphere Temp 3*ENG
1151​
1142[Fusing Jam Detection]
1-142-001SC Display*ENG[0 or 1 / 0 / 1/step]
[Pressure Setting]​
1-151-001Pressure Change ON/OFF*ENG[0 or 1 / 1 / 1/step]
1-151-002Pressure Time1*ENG[0 to 10000 / 70 / 10msec/step]
1-151-003Pressure Time2*ENG[0 to 10000 / 70 / 10msec/step]
1-151-005Depressure Time*ENG[0 to 10000 / 0 / 10msec/step]
1-151-010Shift Time:Energy Saving*ENG[0 to 3600 / 0 / 1sec/step]
1-151-011Shift Time*ENG[0 to 3600 / 60 / 1sec/step]
1-151-051Rotary speed*ENG[-12.8 to 12.7 / 0 / 0.1%/step]
1-151-101Pressure:plain1/2*ENG[0 to 3 / 2 / 1/step]
1-151-102Pressure:Thin*ENG[0 to 3 / 2 / 1/step]
1-151-103Pressure:M-thick*ENG[0 to 3 / 2 / 1/step]
1-151-104Pressure:Thick1*ENG[0 to 3 / 2 / 1/step]
1-151-105Pressure:Thick2*ENG[0 to 3 / 2 / 1/step]
1-151-106Pressure:Thick3*ENG[0 to 3 / 2 / 1/step]
1-151-107Pressure:Special1*ENG[0 to 3 / 2 / 1/step]
1-151-108Pressure:Special2*ENG[0 to 3 / 2 / 1/step]
1-151-109Pressure:Special3*ENG[0 to 3 / 2 / 1/step]
1-151-110Pressure:Envelope*ENG[0 to 3 / 2 / 1/step]
1-151-151Pressure:plain1/2:Low Speed*ENG[0 to 3 / 2 / 1/step]
1-151-152Pressure:M-thick:Low Speed*ENG[0 to 3 / 2 / 1/step]
1-151-153Pressure:Thick1:Low Speed*ENG[0 to 3 / 2 / 1/step]
1-151-154Pressure:Special1:Low Speed*ENG[0 to 3 / 2 / 1/step]
1-151-157Pressure:M-thick:Glossy*ENG[0 to 3 / 2 / 1/step]
1-151-158Pressure:OHP*ENG[0 to 3 / 2 / 1/step]
1-151-159Pressure:Envelope:Low Speed*ENG[0 to 3 / 2 / 1/step]
1-151-160Pressure:Thin:Low Speed*ENG[0 to 3 / 2 / 1/step]
1-151-161Pressure:Thick4*ENG[0 to 3 / 2 / 1/step]
1-151-162Pressure:postcard*ENG[0 to 3 / 2 / 1/step]
1152[Fusing Nip Band Check]
1-152-001ExecuteENG[0 or 1 / 0 / 1/step]
1-152-002Pre-idling Time*ENG[0 to 999 / 300 / 1sec/step]
1-152-003Stop Time*ENG[0 to 100 / 20 / 1sec/step]
1-152-004Pressure Position*ENG[1 to 2 / 2 / 1/step]
1153[Abnormal Noise Confirmation]
1-153-001Unit: ExecuteENG[0 or 1 / 0 / 1/step]
1-153-002No Unit: ExecuteENG[0 or 1 / 0 / 1/step]
1-153-003Operation Line SpeedENG[0 to 2 / 0 / 1/step]
0: Std Speed
1: Mid Speed
2: Low Speed
1-153-004Operation TimeENG[0 to 240 / 60 / 1sec/step]
1-153-005Heat Center Target TempENG[100 to 180 / 130 / 1deg/step]
1-153-006Heat End Target TempENG[100 to 180 / 130 / 1deg/step]
1-153-007Press Target TempENG[0 to 200 / 0 / 1deg/step]
1154[Switch:Rotation Start/Stop]
1-154-001Judging Method Change*ENG[0 or 1 / 0 / 1/step]
0: On
1: Off
1155[Small Size Paper Control]
1-155-001Print Width*ENG[0 to 300 / 0 / 1mm/step]
1-154-005Heater ON Timing*ENG[0 to 250 / 50 / 1 / 10msec/step]
1-154-006
Overshoot Prevent Temp.:SC*ENG
[0 to 250 / 180 / 1deg/step]
1157[Overshoot Prevent Control]
1-157-001Decision Time*ENG[0 to 100 / 5 / 1sec/step]
1-157-002Decision Temp.*ENG[0 to 250 / 185 / 1deg/step]
1-157-003-*ENG[0 to 300 / 15 / 1sec/step]
1-157-004Timeout*ENG[0 to 300 / 300 / 1sec/step]
1161[Shading Plate Control]
1-161-001Judgment Temp AENG[0 to 250 / 250 / 1deg/step]
1-161-002Judgment Temp BENG[0 to 250 / 250 / 1deg/step]
1-161-003Position Transition TimeENG[0 to 10000 / 1000 / 1msec/step]
1-161-004After Transition Time OutENG[0 to 20000 / 0 / 1msec/step]
1-161-005Shading Plate Retry Volume*ENG
[0 to 100 / 60 / 1pulse/step]
1162[Shading Plate Control]
1-162-001Shading Position Temp: 12inch: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-002Shading Position Temp: 12inch: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-003Shading Position Temp: 12inch: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-004Shading Position Temp: A3: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-005Shading Position Temp: A3: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-006Shading Position Temp: A3: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-007Shading Position Temp: DLT: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-008Shading Position Temp: DLT: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-009Shading Position Temp: DLT: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-010Shading Position Temp: B4: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-011Shading Position Temp: B4: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-012Shading Position Temp: B4: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-013Shading Position Temp: LT: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-014Shading Position Temp: LT: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-015Shading Position Temp: LT: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-016Shading Position Temp: A4: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-017Shading Position Temp: A4: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-018Shading Position Temp: A4: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-019Shading Position Temp: B5: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-020Shading Position Temp: B5: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-021Shading Position Temp: B5: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-022Shading Position Temp: A5: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-023Shading Position Temp: A5: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-024Shading Position Temp: A5: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-025Shading Position Temp: B6: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-026Shading Position Temp: B6: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-027Shading Position Temp: B6: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-028Shading Position Temp: DLEnv: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-029Shading Position Temp: DLEnv: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-030Shading Position Temp: DLEnv: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-031Shading Position Temp: COM10: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-032Shading Position Temp: COM10: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-033Shading Position Temp: COM10: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-034Shading Position Temp: Postcard: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-035Shading Position Temp: Postcard: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-036Shading Position Temp: Postcard: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-037Shading Position Temp: 12inch: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-038Shading Position Temp: 12inch: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-039Shading Position Temp: 12inch: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-040Shading Position Temp: 12inch: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-041Shading Position Temp: 12inch: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-042Shading Position Temp: A3: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-043Shading Position Temp: A3: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-044Shading Position Temp: A3: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-045Shading Position Temp: A3: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-046Shading Position Temp: A3: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-047Shading Position Temp: DLT: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-048Shading Position Temp: DLT: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-049Shading Position Temp: DLT: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-050Shading Position Temp: DLT: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-051Shading Position Temp: DLT: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-052Shading Position Temp: B4: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-053Shading Position Temp: B4: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-054Shading Position Temp: B4: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-055Shading Position Temp: B4: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-056Shading Position Temp: B4: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-057Shading Position Temp: LT: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-058Shading Position Temp: LT: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-059Shading Position Temp: LT: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-060Shading Position Temp: LT: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-061Shading Position Temp: LT: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-062Shading Position Temp: A4: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-063Shading Position Temp: A4: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-064Shading Position Temp: A4: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-065Shading Position Temp: A4: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-066Shading Position Temp: A4: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-067Shading Position Temp: B5: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-068Shading Position Temp: B5: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-069Shading Position Temp: B5: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-070Shading Position Temp: B5: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-071Shading Position Temp: B5: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-072Shading Position Temp: A5: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-073Shading Position Temp: A5: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-074Shading Position Temp: A5: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-075Shading Position Temp: A5: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-076Shading Position Temp: A5: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-077Shading Position Temp: B6: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-078Shading Position Temp: B6: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-079Shading Position Temp: B6: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-080Shading Position Temp: B6: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-081Shading Position Temp: B6: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-082Shading Position Temp: DLEnv: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-083Shading Position Temp: DLEnv: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-084Shading Position Temp: DLEnv: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-085Shading Position Temp: DLEnv: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-086Shading Position Temp: DLEnv: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-087Shading Position Temp: COM10: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-088Shading Position Temp: COM10: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-089Shading Position Temp: COM10: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-090Shading Position Temp: COM10: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-091Shading Position Temp: COM10: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-092Shading Position Temp: Postcard: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-093Shading Position Temp: Postcard: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-094Shading Position Temp: Postcard: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-095Shading Position Temp: Postcard: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-096Shading Position Temp: Postcard: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-121Shading Position Temp: SRA3: 1ENG[0 to 250 / 250 / 1deg/step]
1-162-122Shading Position Temp: SRA3: 2ENG[0 to 250 / 250 / 1deg/step]
1-162-123Shading Position Temp: SRA3: 3ENG[0 to 250 / 250 / 1deg/step]
1-162-124Shading Position Temp: SRA3: 4ENG[0 to 250 / 250 / 1deg/step]
1-162-125Shading Position Temp: SRA3: 5ENG[0 to 250 / 250 / 1deg/step]
1-162-126Shading Position Temp: SRA3: 6ENG[0 to 250 / 250 / 1deg/step]
1-162-127Shading Position Temp: SRA3: 7ENG[0 to 250 / 250 / 1deg/step]
1-162-128Shading Position Temp: SRA3: 8ENG[0 to 250 / 250 / 1deg/step]
1-162-201Shading Position Temp: 12inch: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-202Shading Position Temp: A3: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-203Shading Position Temp: DLT: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-204Shading Position Temp: B4: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-205Shading Position Temp: LT: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-206Shading Position Temp: A4: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-207Shading Position Temp: B5: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-208Shading Position Temp: A5: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-209Shading Position Temp: B6: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-210Shading Position Temp: DLEnv: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-211Shading Position Temp: COM10: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-212Shading Position Temp: Postcard: ClearENG[0 to 250 / 0 / 1deg/step]
1-162-213Shading Position Temp: SRA3: ClearENG
1163[Shading Plate Control]
1-163-001Shading Position Time: 12inch: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-002Shading Position Time: 12inch: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-003Shading Position Time: 12inch: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-004Shading Position Time: A3: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-005Shading Position Time: A3: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-006Shading Position Time: A3: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-007Shading Position Time: DLT: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-008Shading Position Time: DLT: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-009Shading Position Time: DLT: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-010Shading Position Time: B4: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-011Shading Position Time: B4: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-012Shading Position Time: B4: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-013Shading Position Time: LT: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-014Shading Position Time: LT: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-015Shading Position Time: LT: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-016Shading Position Time: A4: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-017Shading Position Time: A4: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-018Shading Position Time: A4: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-019Shading Position Time: B5: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-020Shading Position Time: B5: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-021Shading Position Time: B5: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-022Shading Position Time: A5: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-023Shading Position Time: A5: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-024Shading Position Time: A5: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-025Shading Position Time: B6: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-026Shading Position Time: B6: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-027Shading Position Time: B6: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-028Shading Position Time: DLEnv: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-029Shading Position Time: DLEnv: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-030Shading Position Time: DLEnv: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-031Shading Position Time: COM10: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-032Shading Position Time: COM10: 2ENG[0 to 10000 / 10000 / 1sec/step]
1-163-033Shading Position Time: COM10: 3ENG[0 to 10000 / 10000 / 1sec/step]
1-163-034Shading Position Time: Postcard: 1ENG[0 to 10000 / 10000 / 1sec/step]
1-163-035Shading Position Time: Postcard: 2ENG[0 to 10000 / 10000 / 1sec/step]
