[0 or 1 / 0 / 1/step]
0: paper exist
1: paper non exist
Responds to paper existence on register sensor position. (0: paper exist, 1: paper non exist)
5-803-002
Paper Feed Sensor 1
This setting is not available for MP C2004/MP C2504.
ENG
0: paper exist
1: paper non exist
Responds to paper existence on 1st paper feed sensor position. (0: paper exist, 1: paper non exist)
5-803-003
Transport Sensor 1
ENG
0: paper exist
1: paper non exist
Responds to paper existence on 1st carry sensor position. (0: paper exist, 1: paper non exist)
5-803-004
Paper Feed Sensor 2
ENG
0: paper exist
1: paper non exist
Responds to paper existence on 2nd paper feed sensor position. (0: paper exist, 1: paper non exist)
5-803-005
Transport Sensor 2
ENG
0: paper exist
1: paper non exist
Responds to paper existence on 2nd carry sensor position. (0: paper exist, 1: paper non exist)
5-803-006
Fusing Entrance Sensor
ENG
0: paper exist
1: paper non exist
Responds to paper existence on fusing entrance sensor position. (0: paper exist, 1: paper non exist)
5-803-007
Fusing Exit Sensor
ENG
0: paper exist
1: paper non exist
Responds to paper existence on fusing exit sensor position. (0: paper exist, 1: paper non exist)
5-803-008
Paper Exit Sensor
ENG
0: paper exist
1: paper non exist
Responds to paper existence on paper exit sensor position. (0: paper exist, 1: paper non exist)
5-803-009
Inverter Sensor
ENG
0: paper exist
1: paper non exist
Responds to paper existence on reverse sensor position. (0: paper exist, 1: paper non exist)
5-803-010
Duplex Exit Sensor
ENG
0: paper exist
1: paper non exist
Responds to paper existence on duplex exit sensor position. (0: paper exist, 1: paper non exist)
5-803-011
Duplex Entrance Sensor
ENG
0: paper exist
1: paper non exist
Responds to paper existence on duplex entrance sensor position. (0: paper exist, 1: paper non exist)
5-803-012
Tray Full Exit Sensor
ENG
0: Not full
1: full
Detects paper full of main unit paper exit tray. (0: Not full, 1: full)
5-803-013
Tray 1: Paper Height Sensor
ENG
[0 to 3 / 0 / 1/step] When full is 100%, 11: 71 to 100%
01: 31 to 70%
00: 11 to 30%
10: 1 to 10%
Detects remaining paper amount of 1st paper feed tray. (When full is 100%,
11: 71 to 100%, 01: 31 to 70%, 00: 11 to 30%, 10: 1 to 10%)
*Check SP5-803-015 for paper end.
5-803-014
Tray 1: Upper Limit Sensor
ENG
[0 or 1 / 0 / 1/step] 0: less then limit 1: high then limit
Detects the height of paper loaded in 1st paper feed tray. (0: less then limit, 1: high then limit)
* As long as you do not press the white bar of the machine side in the tray back, not output.
5-803-015
Tray 1: Paper End Detection
ENG
0: No paper
1: paper remaining
Detects paper is running out on 1st paper feed tray. (0: No paper, 1: paper remaining)
5-803-016
Tray 1: Set Sensor
ENG
0: set 1:not set
Detects that 1st paper feed tray is set to main unit. (0: set, 1:not set)
Engine SP Mode Tables
5-803-017
Tray 2: Paper Height Sensor
ENG
01: 31 to 70%
00: 11 to 30%
10: 1 to 10%
Detects remaining paper amount of 2nd paper feed tray. (When full is 100%,
*Check SP5-803-019 for paper end.
5-803-018
Tray 2: Paper End Sensor
ENG
Detects the height of paper loaded in 2nd paper feed tray. (0: less then limit, 1: high then limit)
5-803-019
Tray 2: Paper End Detection
ENG
0: No paper
1: paper remaining
Detects paper running out of 2nd paper feed tray. (0: No paper, 1: paper remaining)
5-803-020
Tray 2: Set Sensor
ENG
0: set
1: not set
Detects that 2nd paper feed tray is set to main unit. (0: set, 1:not set)
5-803-021
Tray 2: Size Sensor
ENG
[0 to 15 / 0 / 1/step]
Value changes depending on paper size (fence position) set to 2nd paper feed tray.
5-803-022
By-pass: Paper End Sensor
ENG
0: No paper
1: paper remaining
Detects paper is running out on bypass tray. (0: No paper, 1: paper remaining)
5-803-023
By-pass: Main Scan Length Sensor
ENG
[0 to 31 / 0 / 1/step]
Value changes depending on main scan direction of paper set to bypass tray.
5-803-024
By-pass: Sub Scan Length Sensor
ENG
Value changes depending on sub scan direction of paper set to bypass tray.
Detects paper transfer unit status. (0: open, 1: close)
5-803-029
ITB Contact Sensor
ENG
0: Abutting
1: Alienate
Detects image transfer roller (Y, M, and C) and photoreceptors distance. (0: Abutting, 1: Alienate)
5-803-030
PTR Contact Sensor
ENG
0: Abutting
1: Alienate
Detects image transfer belt and paper transfer rollers distance. (0: Abutting, 1: Alienate)
5-803-031
New ITB Unit Detection
ENG
Not available with C1
5-803-032
Toner Collection Full Sensor
ENG
0: Not full
1: full
Detects full of waste toner bottle. (0: Not full, 1: full)
5-803-033
Toner Collection Bottle Set Sensor
ENG
0: set
1: not set
Detects that waste toner bottle is set to main unit. (0: set, 1:not set)
5-803-034
Toner End Sensor:Y
ENG
0: End
1: Not End
Detects remaining toner amount.
*Power with SP5-804-173 before checking. (0: End, 1: Not End)
5-803-035
Toner End Sensor:M
ENG
0: End
1: Not End
5-803-036
Toner End Sensor:C
ENG
0: End
1: Not End
5-803-037
Toner End Sensor:K
ENG
0: End
1: Not End
*Power with SP5-804-172 before checking. (0: End, 1: Not End)
5-803-038
Fusing:Area Detection
ENG
[0 to 15 / 0 / 1/step] 01:200V system 10:100V System 00, 01:unit set error
Detects region of fusing unit.
(0111: 200V system, 1011: 100V System)
5-803-039
Fusing:New Unit Detection
ENG
0: New
1: Old
Detects New/Old of fusing unit. (0: New, 1: Old)
5-803-040
Fusing Temp Detect
ENG
0: Normal
1: High temperature
Detects whether high temperature is detected from fusing unit. (0: Normal, 1: High temperature)
5-803-041
NC Sensor Temp Detection/ 2
ENG
0: Normal
1: High temperature
5-803-042
NC Sensor Temp Detection/ 1
ENG
0: Normal
1: High temperature
5-803-047
Nip Pres. Release Home Position Sensor
ENG
0: Pressured
1: Not pressured
Detects state of fusing nip pressure. (0: Pressured , 1: Not pressured)
5-803-048
Fusing Fan: Lock
ENG
0: Running
1: Stopped, or locked
Detects locking of fusing exhaust heat fan. (0: Running, 1: Stopped, or locked)
5-803-049
Dev Fan: Right: Lock
ENG
0: Running
Detects locking of developer air intake fan (right). (0: Running, 1: Stopped, or locked)
5-803-051
PSU Cooling Fan: Lock
ENG
0: Running
Detects locking of PSU cooling fan. (0: Running, 1: Stopped, or locked)
5-803-052
Ozone Fan: Lock
ENG
0: Running
Detects locking of ozone exhaust air fan. (0: Running, 1: Stopped, or locked)
5-803-054
PSU Fan: Lock
ENG
0: Running
Detects locking of PSU exhaust heat fan. (0: Running, 1: Stopped, or locked)
5-803-055
PCB Box Cooling Fan: Lock
ENG
0: Running
Detects locking of electric box cooling fan. (0: Running, 1: Stopped, or locked)
5-803-058
Paper Exit Cooling Fan: Lock
ENG
0: Running
Detects locking of paper exit cooling fan. (0: Running, 1: Stopped, or locked)
5-803-060
Toner Supply Cooling Fan: Lock
ENG
0: Running
Detects locking of toner supply cooling fan. (0: Running, 1: Stopped, or locked)
5-803-063
Development Motor FC: Lock
ENG
0: Stopped, or locked 1: Running
Detects locking of developer motor (FC). (0: Running, 1: Stopped, or locked)
5-803-064
Drum Motor FC: Lock
ENG
Detects locking of drum motor (FC). (0: Running, 1: Stopped, or locked)
5-803-065
Fusing Motor: Lock
ENG
Detects locking of fusing motor.
5-803-066
Transfer Drum Motor K: Lock
ENG
Detects locking of transfer drum motor K. (0: Running, 1: Stopped, or locked)
5-803-068
PP:CB:SC Detection
ENG
0: SC detected
1: Normal
Detects SC of HVP (electrify/develop). (0: SC detected, 1: Normal)
5-803-069
PP:TTS:SC Detection
ENG
0: SC detected
1: Normal
Detects SC of HVP (transfer). (0: SC detected, 1: Normal)
5-803-072
Key Counter: Set 1
ENG
0: set 1:unset
Detects setting of key counter. (0: set, 1:unset)
(key counter: set 1=0, 2=1 for set, others for unset)
5-803-073
Key Counter: Set 2
ENG
0: unset 1:set
Detects setting of key counter. (0: unset, 1:set)
5-803-074
Key Card Set
ENG
0: set
1: not set
Detects that key card is set to main unit. (0: set, 1:not set)
5-803-075
1 Bin Tray: Paper Sensor
ENG
0: paper exist
1: paper non exist
Detects that paper is left upon the tray. (0: paper exist, 1: paper non exist)
5-803-076
1 Bin Tray: Set Detection System
ENG
0: paper exist
1: paper non exist
Detects that tray is set to main unit. (0: set, 1:not set)
5-803-077
Bridge Relay Sensor
ENG
0: paper exist
1: paper non exist
Responds to paper existence on carry sensor position or bridge unit. (0: paper exist, 1: paper non exist)
5-803-078
Bridge Exit Sensor
ENG
0: Paper exist
1: Paper do not exist
Responds to paper existence on paper exit sensor position or bridge unit. (0: paper exist, 1: paper non exist)
5-803-079
Bridge Set Detection System
ENG
10: set 11:not set
Detects that bridge unit is set to main unit. (10: set, 11:not set)
5-803-082
Bridge Relay/Left Exit Cover Sensor
ENG
0: close
1: open
Detects open/close of the left carry cover open/close sensor (left paper exit tray) and the relay carry cover open/close sensor (bridge unit).
(0: close, 1: open)
5-803-083
Bridge Exit/Upper Exit Cover Sensor
ENG
0: close
1: open
Detects open/close of the upper carry cover open/close sensor (left paper exit tray) and the relay paper exit cover open/close sensor (bridge unit). (0: close, 1: open)
5-803-084
Shift Tray: Set Detection System
ENG
01: set 11:not set
Detects that shift tray is set to main unit. (01: set, 11:not set)
5-803-085
Shift Tray: Position Sensor 1
ENG
0: Stop on this side. during moving towards inner
1: Stop on inner side. during moving towards this side
Detects shift tray position.
(0: Stop on this side. during moving towards inner,
1: Stop on inner side. during moving towards this side)
5-803-086
Shift Tray: Position Sensor 2
ENG
*It is a backup sensor with this machine, so "1" is always displayed)
5-803-094
GAVD Open/Close Detection
ENG
For checking door open/close during process. No need to operate.
5-803-095
Bridge 24V Fuse Detection
ENG
0: Not cut
1: Cut
Detects state of 24V fuse on the bridge unit. (0: Not cut, 1: Cut)
5-803-096
Bridge 5V Fuse Detection
ENG
0: Not cut
1: Cut
Detects state of 5V fuse on the bridge unit. (0: Not cut, 1: Cut)
5-803-200
HP Sensor
ENG
Tests the scanner HP sensor.
5-803-201
Platen Cover Sensor
ENG
Tests the book open/close sensor.
5803
[INPUT Check]
Gets information of specified sensor.
5-803-211
Bank: Tray3: Feed Sensor
ENG
0: paper not detected 1: paper detected.
5-803-212
Bank: Tray4: Feed Sensor
ENG
5-803-213
Bank: Tray5: Feed Sensor
ENG
5-803-214
Bank: Tray3: Transport Sensor
ENG
5-803-215
Bank: Tray4: Transport Sensor
ENG
5-803-216
Bank: Tray5: Transport Sensor
ENG
5-803-217
Bank: Feed Cover Open Detection 1
ENG
0: cover open
1: cover closed
5-803-218
Bank: Feed Cover Open Detection 2
ENG
5-803-219
LCT Paper Supply Open/Close
ENG
5-803-220
LCT Slide Open/Close
ENG
0: slide open
1: slide closed
ADF
6007
[ADF INPUT Check]
Gets sensor information from ADF. Displays signal level of sensor as it is.
6-007-001
Original Length 1 (B5 Detection Sensor)
ENG
6-007-002
Original Length 2 (A4 Detection Sensor)
ENG
6-007-003
Original Length 3 (LG Detection Sensor)
ENG
6-007-004
Original Width 1
ENG
6-007-005
Original Width 2
ENG
6-007-006
Original Width 3
ENG
6-007-007
Original Width 4
ENG
6-007-008
Original Width 5
ENG
6-007-009
Original Detection
ENG
6-007-011
Skew Correction
ENG
6-007-013
Registration Sensor
ENG
6-007-014
Exit Sensor
ENG
6-007-015
Feed Cover Sensor
ENG
6-007-016
Lift Up Sensor
ENG
6-007-023
Rear Edge Detection
ENG
6011
[1-Pass ADF INPUT Check]
For Single-Pass simultaneous duplex models only.
6-011-001
Original Length 1 (B5 Sensor)
ENG
Gets sensor information from ADF. Gives 1 when there is a paper at sensor area.
6-011-002
Original Length 2 (A4 Sensor)
ENG
6-011-003
Original Length 3 (LG Sensor)
ENG
6-011-004
Original Width 1
ENG
6-011-005
Original Width 2
ENG
6-011-006
Original Width 3
ENG
6-011-007
Original Width 4
ENG
6-011-008
Original Width 5
ENG
6-011-009
Original Detection
ENG
Gets sensor information from ADF. Gives 1 when original is set.
6-011-010
Separation Sensor
ENG
6-011-011
Skew Correction
ENG
6-011-012
Scan Entrance Sensor
ENG
6-011-013
Registration Sensor
ENG
6-011-014
Exit Sensor
ENG
6-011-015
Feed Cover Sensor
ENG
Gets sensor information from ADF. Gives 1 when cover is open.
6-011-016
Lift Up Sensor
ENG
Gets sensor information from ADF. Gives 1 when lift up.
6-011-018
Pick-Up Roller HP Sensor
ENG
Gets sensor information from ADF. Gives 1 when pick up roller is not in home position.
6-011-021
Bottom Plate HP Sensor
ENG
Gets sensor information from ADF. Gives 1 when bottom plate is not in home position.
6-011-022
Bottom Plate Position Sensor
ENG
Gets sensor information from ADF. Gives 1 when pick up roller is not in the correct position.
6-011-023
Original Length 4 (LT/A4 Tail Sensor)
ENG
Finisher
6123
[INPUT Check: 2K/3K FIN]
6-123-001
Entrance Sensor
ENG
Gets information of specified sensor. Displays signal level of sensor as it is.
6-123-002
Horizontal Transport Sensor
ENG
6-123-003
Switchback Transport Sensor
ENG
6-123-004
Proof Tray Exit Sensor
ENG
6-123-005
Shift Tray Exit Sensor
ENG
6-123-006
Booklet Stapler Exit Sensor
ENG
6-123-007
Paper Exit Open/Close Guide HP Sensor
ENG
6-123-008
Punch HP Sensor
ENG
6-123-009
Punch Move HP Sensor
ENG
6-123-010
S-to-S Registration Detection HP Sensor
ENG
6-123-011
Lower Junction Solenoid HP Sensor
ENG
6-123-012
Jogger HP Sensor
ENG
6-123-013
Positioning Roller HP Sensor
ENG
6-123-014
Feed-out HP Sensor
ENG
6-123-015
Stapler Moving HP Sensor
ENG
6-123-016
Booklet Stapler HP Sensor
ENG
6-123-017
Booklet Jogger HP Sensor
ENG
6-123-018
Booklet Jog Solenoid HP Sensor
ENG
6-123-019
Booklet Standard Fence HP Sensor
ENG
6-123-020
ENG
6-123-022
Folder Blade Cam HP Sensor
ENG
6-123-023
Folder Blade HP Sensor
ENG
6-123-024
Shift Roller HP Sensor
ENG
6-123-028
Drag Roller Vibrating HP Sensor
ENG
6-123-029
LE Guide HP Sensor
ENG
6-123-030
TE Stack Plate HP Sensor
ENG
6-123-031
Staple Tray Paper Sensor
ENG
6-123-032
ITB Paper Sensor
ENG
6-123-033
Booklet Stapler Transport Paper Sn: Upper
ENG
6-123-034
Booklet Stapler Transport Paper Sn: Lower
ENG
6-123-035
Paper Height Sensor: Shift
ENG
6-123-036
Corner Stapler Paper Height Sensor 1
ENG
6-123-037
Corner Stapler Paper Height Sensor 2
ENG
6-123-038
Proof Tray Full Sensor
ENG
6-123-039
Booklet Stapler Full Sensor 1
ENG
6-123-040
Booklet Stapler Full Sensor 2
ENG
6-123-041
S-to-S Registration Detection Sensor
ENG
6-123-042
Punch RPS Sensor
ENG
6-123-043
Corner Stapler Leading Edge Detection Sensor
ENG
6-123-044
Corner Stapler Staple End Sensor
ENG
6-123-045
Booklet Stapler Staple End Sensor: Front
ENG
6-123-046
Booklet Stapler Staple End Sensor: Rear
ENG
6-123-047
Shift Tray Lower Limit Sensor 1
ENG
6-123-048
Shift Tray Lower Limit Sensor 2
ENG
6-123-049
Shift Tray Lower Limit Sensor 3
ENG
6-123-050
Shift Tray Lower Limit Sensor 4
ENG
6-123-051
Shift Tray Lower Limit Sensor 5
ENG
6-123-052
Punch Chad Full Sensor
ENG
6-123-053
Punch Set Detection
ENG
0: connected
1: not connected
Gets connection status of punch unit.
6-123-054
Shift Jogger Set Detection
ENG
0: connected
1: not connected
Gets connection status of setting jogger unit.
* Not use: currently, VOLGA-B does not have setting jogger in system configuration.
6-123-055
Booklet Stapler Set Detection
ENG
0: not connected
1: connected
Gets connection status of saddle stitch unit.
6-123-056
Front Door SW
ENG
Gets information of specified switch. Displays signal level of switch as it is.
6-123-057
Dynamic Roller Open/Close Guide Plate Sensor
ENG
6-123-058
Tray Upper Limit SW
ENG
6-123-059
Paper Exit Open/Close Guide Plate Limit SW
ENG
6-123-060
Punch Selection DIPSW 1
ENG
6-123-061
Punch Selection DIPSW 2
ENG
6-123-065
Paper Guide HP Sensor
ENG
6-123-066
Shift Jogger HP Sensor: Front
ENG
6-123-067
Shift Jogger HP Sensor: Rear
ENG
6-123-068
Shift Jogger Retraction HP Sensor: Upper
ENG
6-123-069
Shift Jogger Retraction HP Sensor: Lower
ENG
6135
[INPUT Check: FrontFIN]
6-135-001
Entrance Sensor
*ENG
6-135-002
Carry Sensor
*ENG
6-135-003
Exit Sensor
*ENG
6-135-004
*ENG
6-135-005
Front Jogger HP Sensor
*ENG
6-135-006
Rear Jogger HP Sensor
*ENG
6-135-007
Sft Roller HP Sensor
*ENG
6-135-008
Hitroll HP Sensor
*ENG
6-135-009
Ext Guide Plate HP Sensor
*ENG
6-135-010
Staple Moving HP Sensor
ENG
6-135-011
Shift Tray Paper Sensor
ENG
6-135-012
Shift Tray Limit Sensor
ENG
6-135-013
Staple Rotation Sensor
ENG
6-135-014
Staple Near End Sensor
ENG
6-135-015
Self Priming Sensor
ENG
6-135-016
Stopper HP Sensor
ENG
6-135-017
Punch HP Sensor
ENG
6-135-018
Punch Pluse Count Sensor
ENG
6-135-019
ENG
6-135-020
Punch Moving HP Sensor
ENG
6-135-021
Punch Registration Detection HP Sensor
ENG
6-135-022
Punch Registration Detection Sensor
ENG
6135
6-135-023
Slide Door SW
ENG
6-135-024
Shift Tray Upper Limit SW
ENG
6161
[FIN (1K FIN) INPUT Check]
6-161-001
Entrance Sensor
ENG
6-161-002
Upper Cover Open/Close Sensor
ENG
6-161-003
ENG
6-161-004
ENG
6-161-005
Shift HP Sensor
ENG
6-161-006
Exit Guide Plate Open/Close HP Sensor
ENG
6-161-007
Shift Paper Exit (Lift Tray Exit) Sensor
ENG
6-161-008
ENG
6-161-009
Lift Tray Paper Sensor
ENG
6-161-010
Jogger HP Sensor
ENG
6-161-011
Feed Out HP Sensor
ENG
6-161-012
Lift Tray Lower Limit Sensor (Upper)
ENG
6-161-013
Lift Tray Lower Limit Sensor (Lower)
ENG
6-161-014
ENG
6-161-015
ENG
6-161-016
Near End Sensor (Common: Corner/Bklt Stplr)
ENG
6-161-017
Self Priming Sensor (Common:Crnr/Bklt Stplr)
ENG
6-161-018
Driver HP Sensor (Corner/Booklet Stapler)
ENG
6-161-020
Clincher HP Sensor (Corner/Booklet Stapler)
ENG
6-161-022
Stapler Retraction Sensor
ENG
6-161-023
Untitled
ENG
6-161-024
Untitled
ENG
6-161-025
Untitled
ENG
6-161-026
Punch HP Sensor
ENG
6-161-027
Punch RP Sensor
ENG
6-161-028
Punch Hopper Full Sensor
ENG
6-161-029
ENG
6-161-030
ENG
6-161-031
ENG
6161
6-161-032
ENG
6-161-033
ENG
6161
6-161-034
ITB Transport Sensor: Right
ENG
6-161-035
ITB Transport Sensor: Left
ENG
6-161-036
Stack Transport Sensor
ENG
6-161-037
Stack Trans Upper Pressure Release HP Sensor
ENG
6-161-038
Stack Trans Lower Pressure Release HP Sensor
ENG
6-161-039
Fold Blade HP Sensor
ENG
6-161-040
Fold Cam HP Sensor
ENG
6-161-041
TE Stopper Transport Sensor
ENG
6-161-042
TE Stopper HP Sensor
ENG
6-161-043
Booklet Folder Exit Sensor
ENG
6-161-044
Booklet Folder Tray Full Sensor: Upper
ENG
6-161-045
Booklet Folder Tray Full Sensor: Lower
ENG
6161
6-161-046
Door Open/Close SW
ENG
6-161-047
Lift Tray Upper Limit SW
ENG
6161
6-161-048
ENG
6184
[Input Check: NoStplBindFIN]
6-184-001
Entrance Sensor
ENG
Gets the entrance sensor information of non staple finisher. (0: Sensor Off, 1: Sensor On)
6-184-002
Exit Sensor
ENG
Gets the paper exit sensor information of non staple finisher. (0: Sensor Off, 1: Sensor On)
6-184-003
Horizontal Registration Detection Sensor
ENG
Gets the horizontal registration sensor information of non staple finisher. (0: Sensor Off, 1: Sensor On)
6-184-004
Shift HP Sensor
ENG
Gets the shift HP sensor information of non staple finisher. (0: Sensor Off, 1: Sensor On)
6-184-005
ENG
Gets the junction solenoid HP sensor information of non staple finisher. (0: Sensor Off, 1: Sensor On, “0“ appears if sensor detects home position)
6-184-006
Exit Pressure Release HP Sensor
ENG
Gets the exit pressure release HP sensor information of non staple finisher. (0: Sensor Off, 1: Sensor On)
6-184-007
Stapler HP Sensor
ENG
Gets the stapler HP sensor information of non staple finisher. (0: Sensor On, “0“ appears if sensor detects home position)
6-184-008
Tray Full Detection Sensor 1
ENG
Gets the tray full detection sensor 1 information of non staple finisher. (0: Paper overflow )
6-184-009
Tray Full Detection Sensor 2
ENG
Gets the tray full detection sensor 2 information of non staple finisher. (0: Paper overflow )
6-184-010
Slide Door Open/Close Door SW
ENG
Gets the slide door switch information of non staple finisher. (0: Close, 1: Open)
OUTPUT CHECK TABLE
Main Machine, Paper Feed Tray
5804
[OUTPUT Check]
5-804-001
Feed Pickup Solenoid 1 This setting is not available for
MP C2004/MP C2504.
ENG
Moves 1st paper feed tray pick up solenoid.
5-804-002
Feed Pickup Solenoid 2 This setting is not available for
MP C2004/MP C2504.
ENG
Moves 2nd paper feed tray pick up solenoid.
5-804-003
Bypass Pickup Solenoid
ENG
Moves bypass pick up solenoid.
5-804-004
Exit Junction Solenoid
ENG
Moves output paper divide solenoid.
5804
[OUTPUT Check]
Moves paper feed tray rising motor.
* Do not execute SP 5-804-006/008 without removing the paper tray. Otherwise, the tray might be damaged.
5-804-005
Tray 1 Lift Motor:CW
ENG
5-804-006
Tray 1 Lift Motor:CCW
ENG
5-804-007
Tray 2 Lift Motor:CW
ENG
5-804-008
Tray 2 Lift Motor:CCW
ENG
5804
[OUTPUT Check]
Moves register motor.
5-804-009
Regist Motor:CCW:Standard Speed
ENG
5-804-011
Regist Motor:CCW:Low Speed
ENG
5804
[OUTPUT Check]
5-804-015
Regist Motorosition Hold
ENG
Holds position of register motor.
5804
[OUTPUT Check]
Moves paper feed motor.
* It is fed if there is paper in the paper tray.
5-804-016
Feed Motor:CW:Standard Speed
ENG
5-804-018
Feed Motor:CW:Low Speed
ENG
5-804-022
Feed Motor:CCW:Standard Speed
ENG
5-804-024
Feed Motor:CCW:Low Speed
ENG
5804
[OUTPUT Check]
Moves transport motor.
5-804-028
Bypass V-Transport Motor:CW:Std Speed
ENG
5-804-030
Bypass V-Transport Motor:CW:Low Speed
ENG
5804
[OUTPUT Check]
5-804-034
Bypass V-Transport Motorosition Hold
ENG
Holds position of transport motor.
5-804-037
Exit Motor: CW: Fusing Pressure Release
ENG
Moves fusing dis-pressure.
* If driving this motor while attaching the fusing unit, be sure to stop it less than 5 seconds. Otherwise, the unit might be damaged.
5804
[OUTPUT Check]
Moves paper exit motor.
5-804-041
Exit Motor:CCW:Standard Speed
ENG
5-804-043
Exit Motor:CCW:Low Speed
ENG
5804
[OUTPUT Check]
Moves reverse motor.
5-804-047
Inverter Motor:CW:Standard Speed
ENG
5-804-049
Inverter Motor:CW:Low Speed
ENG
5-804-052
Inverter Mt: CW: Normal Speed: Duplex
ENG
5-804-054
Inverter Mt: CW: Low Speed: Duplex
ENG
5-804-056
Inverter Motor:CCW:Standard Speed
ENG
5-804-058
Inverter Motor:CCW:Low Speed
ENG
5-804-061
Inverter Mt: CCW: Normal Speed: Inc Speed
ENG
5804
[OUTPUT Check]
Moves duplex entrance motor.
5-804-065
Duplex Entrance Motor:CW:Standard Speed
ENG
5-804-067
Duplex Entrance Motor:CW:Low Speed
ENG
5-804-068
Duplex Entrance Motor: Normal Speed: Duplex
ENG
5-804-069
Duplex Entrance Motor: Low Speed: Duplex
ENG
5804
[OUTPUT Check]
Moves bypass/duplex motor.
5-804-071
Duplex Bypass Motor:CW:Standard Speed
ENG
5-804-073
Duplex Bypass Motor:CW:Low Speed
ENG
5-804-074
Duplex Bypass Motor: CW: Normal Speed: Dup
ENG
5-804-075
Duplex Bypass Motor: CW: Low Speed: Duplex
ENG
5-804-077
Duplex Bypass Motor:CCW:Standard Speed
ENG
5-804-079
Duplex Bypass Motor:CCW:Low Speed
ENG
5804
[OUTPUT Check]
5-804-083
Duplex Bypass Motorosition Hold
ENG
Holds position of bypass/duplex motor.
5804
[OUTPUT Check]
Moves fusing motor. *See Important below
5-804-092
Fusing Motor:CW:Standard Speed
ENG
5-804-094
Fusing Motor:CW:Low Speed
ENG
5-804-098
Fusing Motor:CCW:Low Speed
ENG
Important: Use the procedure below to do the output checks for the fusing exit motor. If you do not follow this procedure, a kink will form in the fusing belt sleeve, and the fusing sleeve belt unit will need to be replaced.
1. Do one of the following:
Open the right cover of the paper bank
Remove one of the toner bottles
Pull out the waste toner bottle half-way
Remove the fusing unit
Enter SP mode.
Do the following out output checks:
SP5-804-092 (Fusing Motor:CW:Standard Speed)
SP5-804-094 (Fusing Motor:CW:Low Speed)
SP5-804-098 (Fusing Motor:CCW:Low Speed)
Without exiting SP mode, turn the main power switch off and then on again. Important: If you exit SP mode before you turn the main power switch off, the fusing exit motor will stay off when the machine warms up. Heat will be concentrated in one area of the fusing belt sleeve and cause a kink to form. If this happens, you will need to replace the fusing sleeve belt unit.
Do the reverse of what you did in step 1 (for example, reattach the fusing unit).
5804
[OUTPUT Check]
5-804-104
Polygon Motor: L
ENG
Runs motor with 21969 rpm.
5-804-105
Polygon Motor: M
ENG
Runs motor with 25512 rpm.
5-804-106
Polygon Motor: H
ENG
Runs motor with 30236 rpm.
5-804-107
Polygon Motor: HH
ENG
Runs motor with 34488 rpm.
5-804-110
Fusing Fan: Full Speed
ENG
Moves fusing exhaust fan.
5-804-111
Fusing Fan: Half Speed
ENG
5-804-113
PSU Cooling/Exhaust Heat Fan
ENG
Moves PSU cooling fan and PSU exhaust fan (not included in this machine).
5-804-114
Ozone Fan
ENG
Moves ozone exhaust heat fan.
5-804-115
PCB Box Cooling Fan/ Exhaust Cooling Fan
ENG
Moves controller box cooling fan and exhaust cooling fan.
5-804-116
Development: Right: Half Speed
ENG
Moves development intake fan.
5-804-117
Drive Cooling/ Main/ Toner Supply Cooling Fan
ENG
Moves drive cooling fan (not included in this machine), main exhaust fan (not included in this machine), and toner supply cooling fan.
5-804-118
Development: Right
ENG
5-804-119
Development Solenoid
ENG
Moves development solenoid.
5804
[OUTPUT Check]
Moves development motor.
5-804-128
Development Motor FC: Standard Speed
ENG
5-804-130
Development Motor FC: Low Speed
ENG
5804
[OUTPUT Check]
Moves/Stops PCU motor :CMY.
* Execute this SP after correcting the cam position so that ITB contact/separation lever of the color station is released.
5-804-132
Drum Motor FC: Standard Speed
ENG
5-804-134
Drum Motor FC: Low Speed
ENG
5804
[OUTPUT Check]
Moves/Stops PCU motor: Black/ ITB drive motor.
5-804-136
Transfer Drum Motor K: Standard Speed
ENG
5-804-138
Transfer Drum Motor K: Low Speed
ENG
5804
[OUTPUT Check]
Moves paper transfer contact and release motor.
5-804-140
PTR Contact Motor:CW
ENG
5-804-141
PTR Contact Motor:CCW
ENG
5804
[OUTPUT Check]
Moves ITB contact and release motor (reverse to toner supply motor M).
5-804-150
Toner Supply Motor M:CWITB Contact)
ENG
5804
[OUTPUT Check]
Moves relay carry motor (bridge unit)/left paper exit carry motor (left paper exit tray).
5-804-163
Bridge Relay/Left Exit Motor: Normal Speed
ENG
5-804-165
Bridge Relay/Left Exit Motor: Low Speed
ENG
5-804-166
Bridge Relay/Left Ex Mt: Normal Speed Upper
ENG
5804
[OUTPUT Check]
5-804-169
Bridge Junction/Left Exit Junction Solenoid
ENG
Moves relay divide solenoid (bridge unit)/left paper exit divide solenoid (left paper exit tray).
5-804-170
Shift Tray Motor:CW
ENG
Moves shift tray motor.
5-804-171
Shift Tray Motor:CCW
ENG
5-804-172
Toner End Sensor: K Power
ENG
Supples power to toner end sensor (K).
5-804-173
Toner End Sensor: FC Power
ENG
Supples power to toner end sensor (FC).
5-804-174
Drum PCL: K
ENG
Lights (PWM drive) the drum PCL (K).
* Continuing the OPC's exposure, it might accumulate damage due to electrostatic locally.
If operating QL without rotation, be sure to stop it within 10 seconds.
Do rotate the OPC drum when QL is turned on.
5-804-175
Drum PCL: FC
ENG
Lights (PWM drive) the drum PCL (FC).
5804
[OUTPUT Check]
Outputs PWM for electrify HVP (DC/AC:Y/M/C/K).
5-804-176
PP: Charge DC: Y
ENG
5-804-177
PP: Charge DC: M
ENG
5-804-178
PP: Charge DC: C
ENG
5-804-179
PP: Charge DC: K
ENG
5-804-180
PP: Charge AC: Y
ENG
5-804-181
PP: Charge AC: M
ENG
5-804-182
PP: Charge AC: C
ENG
5-804-183
PP: Charge AC: K
ENG
5804
[OUTPUT Check]
Outputs PWM for develop HVP.
5-804-184
PP: Development: Y
ENG
5-804-185
PP: Development: M
ENG
5-804-186
PP: Development: C
ENG
5-804-187
PP: Development: K
ENG
5804
[OUTPUT Check]
Outputs PWM for transfer HVP (image transfer: Y/M/C/K).
5-804-195
PP: ITB: Y
ENG
5-804-196
PP: ITB: M
ENG
5-804-197
PP: ITB: C
ENG
5-804-198
PP: ITB: K
ENG
5804
[OUTPUT Check]
Outputs PWM for transfer HVP (paper transfer: +/-).
