Ricoh MP C2004/C2504 Service Manual Part 25
  1. SIDE TRAY TYPE M3 (D725)​
    ItemSpecification
    Paper size:A3 SEF, A4 SEF/LEF, A5 SEF/LEF, A6 SEF, B4 JIS SEF, B5 JIS SEF/LEF, B6 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8 1/2 × 11 SEF/LEF, 8 1/4 × 14
    SEF, 8 1/4 × 13 SEF, 8 × 13 SEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 5 1/2 × 8 1/2 SEF, 4 1/8 × 9 1/2 SEF/LEF,
    3 7/8 × 7 1/2 SEF/LEF, C5 Env SEF/LEF, C6 Env SEF/LEF, DL Env SEF/LEF, 8K SEF, 16K SEF/LEF, 12 × 18 SEF, 11 × 15 SEF, 10 × 14 SEF, SRA3 SEF, SRA4
    SEF/LEF, custom size
    Paper weight:52–300 g/m2 (14 lb. Bond–110 lb. Cover)
    Paper capacity (80 g/m2, 20 lb. Bond):250 sheets: A4, 81/2 × 11 or smaller 125 sheets: B4 JIS, 81/2 × 14 or larger
    Power consumption:12 W (Power is supplied from the main unit.)
    Dimensions (W × D × H):800 × 549 × 156 mm (31.5 × 21.7 × 6.2 inches)
    Weight:Approx. 4 kg (8.9 lb.)
    • Internal tray 1:
    • External tray: 125 sheets
    Specifications
  2. INTERNAL SHIFT TRAY SH3070 (D691)​
    ItemSpecification
    Paper weight:60–300 g/m2 (16 lb. Bond–110 lb. Cover)
    Paper sizes that can be shifted:A3 SEF, A4 SEF/LEF, A5 SEF/LEF, A6 SEF, B4 JIS SEF, B5 JIS SEF/LEF, B6 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8 1/2 × 11 SEF/LEF, 8 1/4 × 14
    Paper weight that can be shifted:60–300 g/m2 (16 lb. Bond–110 lb. Cover)
    Stack capacity (80 g/m2, 20 lb. Bond):
    Power consumption:4.3 W (Power is supplied from the main unit.)
    Dimensions (W × D × H):420 × 489 × 107 mm (16.6 × 19.3 × 4.3 inches)
    Weight:Approx. 2 kg (4.5 lb.)
    • 250 sheets: A4, 81/2 × 11 or smaller
    • 125 sheets: B4 JIS, 81/2 × 14 or larger
  3. 1 BIN TRAY BN3110 (D3CQ)​
    ItemSpecification
    Number of bins:1
    Paper size:A3 SEF A4 SEF/LEF, A5 SEF/LEF, B4 JIS SEF B5 JIS SEF/LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8
    1/2 × 11 SEF/LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 8 ×
    13 SEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 51/2 × 8
    1/2 SEF, 8K SEF, 16K SEF/LEF, 11 × 15 SEF, 10 × 14
    SEF, SRA3 SEF, SRA4 SEF/LEF, custom size
    Paper capacity (80 g/m2, 20 lb. Bond):125 sheets
    Power consumption:1 W or less (Power is supplied from the main unit.)
    Dimensions (W × D × H):444 × 450 × 150 mm (17.5 × 17.8 × 6.0 inches)
  4. BRIDGE UNIT BU3070 (D685)​
    ItemSpecification
    Power consumption:15 W (Power is supplied from the main unit.)
    Dimensions (W × D × H):412 × 466 × 143 mm (16.3 × 18.4 × 5.7 inches)
    Specifications
  5. INTERNAL FINISHER SR3130 (D690)​
    ItemSpecification
    3 7/8 × 7 1/2 SEF/LEF, C5 Env SEF/LEF, C6 Env SEF/LEF, DL Env SEF/LEF, 8K SEF, 16K SEF/LEF, 12 × 18 SEF, 11 × 15 SEF, 10 × 14 SEF, SRA3 SEF, SRA4 SEF/LEF, custom size
    Paper sizes that can be shifted:A3 SEF, A4 SEF/LEF, A5 SEF/LEF, B4 JIS SEF, B5 JIS SEF/LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8
    13 SEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, C5 Env
    SEF/LEF, 8K SEF, 16K SEF/LEF, 11 × 15 SEF, 10 × 14
    SEF, SRA4 LEF, custom size
    Paper weight that can be shifted:64–105 g/m2 (17–28 lb. Bond)
    Staple paper size:A3 SEF, A4 SEF/LEF, B4 JIS SEF, B5 JIS SEF/LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8 1/2 × 11
    SEF/LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 7 1/4 × 10 1/2 SEF/LEF, 8K SEF, 16K SEF/LEF
    Staple paper weight:64–105 g/m2 (17–28 lb. Bond)
    • 500 sheets: A4, 81/2 × 11 or smaller
    • 250 sheets: B4 JIS, 81/2 × 14 or larger
    • ItemSpecification
      Staple capacity (80 g/m2, 20 lb. Bond):30 sheets:
      A3 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8
      1/2 × 13 LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 8K SEF
      50 sheets:
      A4 SEF/LEF, B5 JIS SEF/LEF, 8 1/2 × 11 SEF/LEF, 7 1/4 × 10 1/2 SEF/LEF, 16K SEF/LEF
      30 sheets:
      A3 SEF/ A4 LEF, B4 JIS SEF/ B5 JIS SEF, 11 × 17 SEF/8 1/2 × 11 SEF
      Stack capacity after stapling (80 g/m2, 20 lb. Bond):× 11 SEF)
      Staple position:Top 1, Bottom 1, Left 2, Top 2
      Power consumption:
      Dimensions (W × D × H):546 × 523 × 170 mm (21.5 × 20.6 × 6.7 inches)
      Weight:Approx. 13 kg (28.7 lb.) (without punch unit) Approx. 17 kg (37.5 lb.) (with punch unit)
    • Without Mixed Size:
    • With Mixed Size:
    • 2–9 sheets: 55–46 sets (A4 LEF, B5 JIS LEF, 8 1/2 × 11 LEF)
    • 10–50 sheets: 45–10 sets (A4 LEF, B5 JIS LEF, 8 1/2 × 11LEF)
    • 2–9 sheets: 55–27 sets (A4 SEF, B5 JIS SEF, 8 1/2
    • 10– 50 sheets: 25–8 sets (A4 SEF, B5 JIS SEF, 8 1/2 × 11 SEF)
    • 2–9 sheets: 55–27 sets (A3 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF)
    • 10–30 sheets: 25–8 sets (A3 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF)
    • 50 W or less (without punch unit) (Power is supplied from the main unit.)
    • 60 W or less (with punch unit) (Power is supplied from the main unit.)
    Specifications
    Finisher part specifications
    ItemSpecification
    TypeCase system
    Shift trayYes
    No. of sheets which can be accommodatedA4, 81/2×11 or smaller: 500 / height: lower than 57mm B4, 81/2×14 or larger: 250 / height: lower than 28.5mm
    Paper thicknesses which can be handled
    52g/m2-300g/m2
    Up/down shift functionNo
    Left/right shift functionYes
    Stapling functionYes
    Punching functionOption
    Remainder detectionNo
    Full-load detectionYes
    Paper detectionNo
    Power consumptionLess than 47W (24V DC /2A)
    Power source
    24V DC (supplied from main printer), 5V SC (generated by FIN board), SELV (super-low voltage secondary power supply)
    Stapler unit specifications
    ItemSpecification
    No. of sheets which can be stitched
    A3 SEF, B4 SEF, 11"×17" SEF, 81/2”×14” SEF, 81/2”×13” SEF, 81/4”×14” SEF, 81/4”×13” SEF: 30
    A4 LEF / SEF, B5 LEF / SEF, 81/2"×11" LEF / SEF,
    71/4"×101/2" LEF / SEF: 50
    When loading mixed widths: 30
    Sizes which can be stitched
    Thicknesses which can be stitched
    52g/m2 -105g/m2
    The quality for sheets of paper which are thinner than 64g/m2 is not guaranteed.
    No. of sheets to be stitched decreases when sheets of paper are thicker than 64g/m2, depending on the weight.
    Stitching positionTop, bottom, 2 positions on the left, 2 positions on the top
    Staple supplyRefill charge to dedicated staple cartridge
    Stitching capacity5000 / cartridge
    Specifications
  6. PUNCH UNIT PU3040 NA/EU/SC (D716)​
    Paper size:
    Punch unit typePaper size
    2 & 4 holes type: 2 holesSEF: A3, A4, B4 JIS, B5 JIS, 11 × 17, 8 1/2 × 14, 8 1/2
    × 13, 8 1/2 × 11, 7 1/4 × 10 1/2, 8K, 16K
    2 & 4 holes type: 2 holesLEF: A4, B5 JIS, 8 1/2 × 11, 16K
    2 & 4 holes type: 4 holesSEF: A3, 11 × 17
    2 & 4 holes type: 4 holesLEF: A4, 8 1/2 × 11
    4 holes type: 4 holesSEF: A3, A4, B4 JIS, B5 JIS, 11 × 17, 8 1/2 × 14, 8 1/2
    4 holes type: 4 holesLEF: A4, B5 JIS, 8 1/2 × 11
    2 & 3 holes type: 2 holesSEF: A3, 11 × 17, 8 1/2 × 14, 8 1/2 × 13, 8 1/2 × 11, 7 1/4 × 10 1/2
    2 & 3 holes type: 2 holesLEF: A4, 8 1/2 × 11
    2 & 3 holes type: 3 holesSEF: A3, 11 × 17
    2 & 3 holes type: 3 holesLEF: A4, 8 1/2 × 11
    Paper weight:
    60–169 g/m2 (16 lb. Bond –90 lb. Index)
  7. INTERNAL FINISHER SR3180 (D766)​
    ItemSpecification
    Paper size:A3 SEF, A4 LEF/SEF, B4 JIS SEF, B5 JIS LEF/SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 SEF, 8 1/2 × 11
    LEF/SEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 7 1/4 × 10 1/2
    LEF/SEF, 8K SEF, 16K LEF/SEF, custom size
    Paper weight:50–300 g/m2 (14 lb. Bond–110 lb. Cover)
    Paper sizes that can be shifted:A3 SEF, A4 LEF/SEF, B4 JIS SEF, B5 JIS LEF/SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 SEF, 8 1/2 × 11
    Paper weight that can be shifted:64–80 g/m2 (17–20 lb. Bond)
    Stack capacity (80 g/m2, 20 lb. Bond):A4 LEF, B5 JIS LEF/SEF, 81/2 × 11 LEF/SEF
    A3 SEF to A4 SEF, B4 JIS SEF, 81/2 × 14 SEF, 11 × 17 SEF
    Stapling paper size:A3 SEF, A4 LEF/SEF, B4 JIS SEF, B5 JIS LEF/SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 SEF, 8 1/2 × 11
    LEF/SEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 7 1/4 × 10 1/2 LEF/SEF, 8K SEF, 16K LEF/SEF
    Stapling paper weight:64–80 g/m2 (17–20 lb. Bond)
    Stapling capacity (80 g/m2, 20 lb. Bond):5 sheets:
    A3 SEF, A4 LEF/SEF, B4 JIS LEF/SEF, B5JIS LEF/SEF, 11×17 SEF, 8 1/2×14 SEF, 8 1/2×13 SEF 81/2×11
    LEF/SEF, 8 4/1×14SEF, 8 1/4×13 SEF, 7 1/4×10 1/2 LEF/ SEF, 8K SEF, 16K LEF SEF
    • 250 sheets or more:
    • 125 sheets:
    • 30 sets or more (A4 LEF, 81/2 × 11 LEF)
    • 20 sets or more (B5 JIS LEF/SEF)
    • 15 sets or more (A3 SEF- A4 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 11 SEF)
    • ItemSpecification
      Staple position:Bottom Slant
      Power consumption:30 W or less
      Dimensions (W × D × H):435 × 515 × 150 mm (17.2 × 20.3 × 6.0 inches)
      Weight:Approx. 10 kg (22.1 lb.)
    Specifications
    ItemSpecification
    TypeCase system
    Shift trayYes
    No. of sheets which can be accommodatedA4, 81/2×11 or smaller: 250 B4, 81/2×14 or larger: 125
    52g/m2-300g/m2
    Punching functionNo
    Paper detectionNo
    Power consumptionLess than 30W
    Power source
    24V DC (supplied from main frame), 5V SC (generated by FIN board), SELV (super-low voltage secondary power supply)
    ItemSpecification
    2 to 5 sheets
    Sizes which can be stitchedA3 SEF - B5 SEF / DLT SEF - LT SEF
    54g/m2-80g/m2
    Stitching position1 position (Top Slant)
    Staple supplyNo
    Stitching capacityNo
    Weight
    Less than 1.4 kg
    (not including packaging materials and other items in package)
    Service life1200k sheets or 5 years
    *1 80g/m2 or less (paper exceeding 80g/m2 is calculated by weight)
    *2 Up to 1280 mm in SP mode.
    Specifications
  8. BOOKLET FINISHER SR3220 (D3B9)​
    ItemSpecification
    Paper size for the finisher upper trayA3 SEF, B4 JIS SEF, A4 SEF/LEF B5 JIS SEF/LEF, A5 SEF/LEF, B6 JIS SEF, A6 SEF, 12 × 18 SEF, 11 × 17
    SEF, 11 × 15 SEF, 10 × 14 SEF, 8 1/2 × 14 SEF, 8 1/2 ×
    13 LEF, 8 1/2 × 11 SEF/LEF, 8 1/4 × 14 SEF, 8 1/4 × 13
    SEF, 8 × 13 SEF, 8 × 10 SEF, 5 1/2 × 8 1/2 SEF, 7 1/4 × 10 1/2 SEF/LEF, 8K SEF, 16K SEF/LEF, SRA3 SEF,
    SRA4 SEF/LEF, 8 1/2 × 13 2/5 LEF, custom size
    Paper weight for the finisher upper tray:52–169 g/m2 (14 lb. Bond–90 lb. Index)
    Stack capacity for the finisher upper tray (80 g/m2, 20 lb.
    Bond):
    250 sheets: A4, 81/2 × 11 or smaller 50 sheets: B4 JIS, 81/2 × 14 or larger
    Paper size for the finisher shift tray:A3 SEF, B4 JIS SEF, A4 SEF/LEF, B5 JIS/LEF, A5 SEF/LEF, B6 JIS SEF, A6 SEF, 12 × 18 SEF, 11 × 17
    SEF, 8 × 13 SEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 5 1/2 × 8 1/2 SEF, 8K SEF, 16K SEF/LEF, SRA3 SEF,
    Paper weight for the finisher shift tray:52–300 g/m2 (14 lb. Bond–110 lb. Cover)
    Paper sizes that can be shifted when delivered to the finisher shift tray:A3 SEF, A4 SEF/LEF, A5 SEF, B4 JIS SEF, B5 JIS SEF, B6 JIS SEF, 12 × 18 SEF, 11 × 17 SEF, 11 × 15 SEF, 10
    × 14 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8 1/2 × 11
    SEF/LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 8 × 13 SEF, 8
    × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 5 1/2 × 8 1/2 SEF, 8K SEF, 16K SEF/LEF SRA4 LEF, 8 1/2 × 13 2/5 LEF
    Paper weight that can be shifted when delivered to the finisher shift tray:52–300 g/m2 (14 lb. Bond–110 lb. Cover)
    ItemSpecification
    Stack capacity for the finisher shift tray (80 g/m2, 20 lb.
    Bond):
    1,000 sheets: A4, 81/2 × 14 or smaller 500 sheets: B4 JIS, 81/2 × 14 or larger
    Staple paper size:A3 SEF, B4 JIS SEF, A4 SEF/LEF, B5 JIS SEF/LEF, 11 × 17 SEF, 11 × 15 SEF, 10 × 14 SEF, 8 1/2 × 14 SEF, 8 1/2
    × 11 SEF/LEF, 7 1/4 × 10 1/2 SEF/LEF, 8 × 13 SEF, 8B
    1/2 × 13 LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 8 × 10 SEF, 12 × 18 SEF, 8K SEF, 16K SEF/LEF, 8 1/2 × 13 2/5
    LEF, custom size
    Staple paper weight:52–105 g/m2 (14-28 lb. Bond)
    You can use two sheets of paper weighing up to 216 g/m2 (80 lb. Cover) per set as cover sheets.
    × 13 SEF, 8 1/2 × 13 LEF, 8 1/4 × 14 SEF, 8 1/4 × 13
    SEF, 11 × 15 SEF, 10 × 14 SEF, 8K SEF, 12 × 18 SEF, 8 1/2 × 13 2/5 LEF
    50 sheets:
    A4 SEF/LEF, B5 JIS SEF/LEF, 8 1/2 × 11 SEF/LEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 16K SEF/LEF
    22 sheets:
    A3 SEF/A4 LEF, B4 JIS SEF/B5 JIS SEF, 11 × 17 SEF/8 1/2 × 11 SEF
    • With Mixed Size:
    • ItemSpecification
      Stack capacity after stapling (80 g/m2, 20 lb. Bond):× 11 LEF)
      Staple position:3 positions (Top, Bottom, 2 Staples)
      Saddle stitch paper size:A3 SEF, A4 LEF, B4 JIS SEF, B5 JIS LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 11 LEF, 12 × 18 SEF
      Saddle stitch paper weight:52–105 g/m2 (14–28 lb. Bond)
      Saddle stitch capacity (80 g/m2, 20 lb. Bond):1 set (15 sheets)
      Stack capacity after saddle stitching (80 g/m2, 20 lb.
      Bond):
      2–5 sheets: Approx. 20 sets
      6–10 sheets: Approx. 10 sets
      11–15 sheets: Approx. 7 sets
      Saddle stitch position:Center 2 positions
      Types of folds:Half Fold
      Half fold paper size:A3 SEF, A4 LEF, B4 JIS SEF, B5 JIS LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 11 LEF, 12 × 18 SEF, 8 1/2 × 13
      2/5 LEF
      Half fold paper weight:52–105 g/m2 (14–28 lb.Bond)
      Power consumption:35.4 W (Power is supplied from the main unit.)
      • 2–9 sheets: 100 sets (A4 LEF, B5 JIS LEF, 8 1/2
      • 10–50 sheets: 100–20 sets (A4 LEF, B5 JIS LEF, 8 1/2 × 11 LEF)
      • 10–50 sheets: 50–10 sets (A4 SEF, B5 JIS SEF, 8 1/2 × 11 SEF)
      • 2–9 sheets: 50 sets (A3 SEF, A4 SEF, B4 JIS SEF, B5 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 11 SEF)
      • 10–30 sheets: 50–10 sets (A3 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF)
    • With Mixed Size:
      • 2–22 sheets: 22 sets (A3 SEF/ A4 LEF, B4 JIS SEF/B5 JIS SEF, 11 × 17 SEF/8 1/2 × 11 SEF)
    • Specifications
    ItemSpecification
    Dimensions (W × D × H):575 × 620 × 960 mm (22.6 × 24.5 × 37.8 inches)
    658 × 620 × 960 mm (25.9 × 24.5 × 37.8 inches)
    Weight:Approx. 42 kg (92.6 lb.)
    • Tray is folded:
    • Tray is extended:
  9. PUNCH UNIT PU3050 NA/EU/SC (D717)​
    Paper size:
    2 & 4 holes type: 2 holesSEF: A3, B4 JIS, A4, B5 JIS, A5, 11 × 17, 8 1/2 × 14, 8
    1/2 × 11, 5 1/2 × 8 1/2, 7 1/4 × 10 1/2, 8 × 13, 8 1/2 ×
    13, 8 1/4 × 13, 8K, 16K, 8 1/4 × 14, 8 × 10, 11 × 15, 10
    × 14
    2 & 4 holes type: 2 holesLEF: A4, B5 JIS, A5, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K
    2 & 4 holes type: 4 holesSEF: A3, B4 JIS, 11 × 17, 11 × 15, 8K
    2 & 4 holes type: 4 holesLEF: A4, B5 JIS, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K
    4 holes type: 4 holesSEF: A3, B4 JIS, A4, B5 JIS, A5, 11 × 17, 8 1/2 × 14, 8
    × 14
    4 holes type: 4 holesLEF: A4, B5 JIS, A5, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K
    2 & 3 holes type: 2 holesSEF: A3, B4 JIS, B5 JIS, A5, 11 × 17, 8 1/2 × 14, 8 1/2
    × 11, 5 1/2 × 8 1/2, 7 1/4 × 10 1/2, 8 × 13, 8 1/2 × 13, 8
    1/4 × 13, 8K, 16K, 8 1/4 × 14, 8 × 10, 11 × 15, 10 × 14
    2 & 3 holes type: 2 holesLEF: A4, B5 JIS, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K
    2 & 3 holes type: 3 holesSEF: A3, B4 JIS, 11 × 17, 11 × 15, 10 × 14, 8K
    2 & 3 holes type: 3 holesLEF: A4, B5 JIS, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K
    Paper weight:
    Specifications
    52–256 g/m2 (14 lb. Bond–140 lb. Index)
  10. BANNER PAPER GUIDE TRAY TYPE M19 (D3BF)​
ItemSpecification
Dimensions (W × D × H):Main Tray
Tray is folded:
370 × 250 × 70 mm (14.6 × 9.8 × 2.8 inches)
Tray is expanded:
370 × 250 × 250 mm (14.6 × 9.8 × 9.8 inches)
Sub Tray
Tray is folded:
150 × 110 × 15 mm (5.9 × 4.3 × 0.6 inches)
Tray is expanded:
150 × 110 × 100 mm (5.9 × 4.3 × 3.9 inches)
Lock Plate
Locked:
135 × 150 × 25 mm (5.3 × 5.9 × 1.0 inches)
Unlocked:
135 × 220 × 25 mm (5.3 × 8.7 × 1.0 inches)
Weight:Main Tray: 942 g (2.0 lb.)
Sub Tray: 245 g (0.5 lb.)
Lock Plate: 280 g (0.6 lb.)
RE V IS ION H IST ORY
PageDateAdded/ Updated/ New
None
APPENDIX: PREVENTIVE MAINTENANCE​
Preventive Maintenance
  1. PREVENTIVE MAINTENANCE​
      1. PREVENTIVE MAINTENANCE ITEMS​
        • Yield Parts:
          Some of the parts mentioned in these tables have a target yield. However, the total copy/print volume made by the machine will not reach the target yield within the machine's targeted lifetime if the machine is used under the target usage conditions (ACV, color ratio, P/J, and C/O). So, these parts are categorized not as PM parts but as yield parts (EM parts).
          Chart: A4 (LT)/5% image coverage ratio Mode: 2 copies/original (prints/job) Color ratio: 20%
          Environment: Normal temperature and humidity
          Yield may change depending on circumstances and print conditions. Symbol keys: C: Clean, R: Replace, L: Lubricant, I: Inspect
          Mainframe
          The PM count for the following items is based on sheets of copy paper:
          Item
          PM
          Parts
          Cycle
          EM
          Remarks
          Scanner
          Exposure glass
          C 300K
          Clean with a cleaning cloth.
          Do not clean with alcohol. Doing so may leave a whitish trace that affects image scanning.
          Sheet-through exposure glass
          C 300K
          PCDU
          Item
          PM
          Parts
          Cycle
          EM
          Remarks
          PCU(K)
          R 60K
          PCU(C,M,Y)
          R 48K
          Development unit (K)
          R 180K
          PM parts: only for MP C2504
          Development unit (C,M,Y)
          R 120K
          Waste toner bottle
          R 100K
          Target yield (number of sheets) is only a guide and it is possible to collect up to 1,200,000 mg of waste toner. Full detection is a mechanical detection by a feeler. Replace when waste toner bottle full is detected.
          Transfer
          Image transfer cleaning unit
          R 240K
          Image transfer belt unit
          R 240K
          Paper transfer roller unit
          R 240K
          Fusing
          Fusing sleeve belt unit
          R 240K
          Fusing entrance guide plate
          Remove toner deposits
          Fusing exit guide plate--CRemove toner deposits
          Stripper plate--CRemove toner deposits
          Item
          PM
          Parts
          Cycle
          EM
          Remarks
          Pressure roller
          R 240K
          Bearing: Pressure roller
          R/L 240K
          Lubricate with FLUTORIBO MG GREASE: 100G
          Thermopile
          C 400K
          Dry cloth
          Pressure roller gears--RReplace if worn out
          Idler gear--RReplace if worn out
          Fusing exit roller--CDamp cloth
          Miscellaneous
          Ozone filter/Dust filter
          R 300K
          Dust shield glass--CDamp cloth
          TM/ID sensor
          Damp cloth
          Do not use a dry cloth that can cause static electricity.
          Paper feed
          Registration roller--CDamp cloth
          Registration sensor
          Remove toner and paper dust, Dry cloth
          Paper dust collection unit
          Transport roller--CDamp cloth
          Transport sensor
          Feed roller
          Item
          PM
          Parts
          Cycle
          EM
          Remarks
          Separation roller
          Pick-up roller
          Duplex/Bypass/Exit
          Duplex entrance sensor
          Duplex exit sensor
          Duplex transport roller--CDamp cloth
          Duplex exit roller--CDamp cloth
          Duplex entrance roller1, 2
          Damp cloth
          Bypass paper feed roller--CDamp cloth
          Bypass separation roller--CDamp cloth
          Bypass pick-up roller--CDamp cloth
          Bypass transport roller--CDamp cloth
          Reverse roller--CDamp cloth
          Reverse sensor
          Paper exit roller--CDamp cloth
          Paper exit sensor
          ARDF DF3090
          ItemCycleEMRemarks
          Pick-up roller
          R 120K
          Wipe with a cloth dampened with ethyl alcohol.
          Feed belt
          R 120K
          Wipe with a cloth dampened with ethyl alcohol or water.
          Separation roller
          R 120K
          Sensors-CClean with a blower brush.
          Platen sheet-CWipe with a cloth dampened with ethyl alcohol.
          Other rollers-C
          Scanner guide plate-C
          SPDF DF3100
          ItemCycleEMRemarks
          Pick-up roller
          R 120K
          Feed belt
          R 120K
          Separation roller
          R 120K
          CIS (Glass area)
          ItemCycleEMRemarks
          Gears-LLubricate with Silicone Grease G-501 when noise occurred.
          Other rollers-C
          Paper Feed Unit PB3220/PB3210
          ItemEMRemarks
          Paper feed rollerCWipe with a cloth dampened with ethyl alcohol.
          Pick-up rollerCWipe with a cloth dampened with ethyl alcohol.
          Separation rollerCWipe with a cloth dampened with ethyl alcohol.
          Relay rollersCWipe with a cloth dampened with ethyl alcohol.
          Bottom plate padCRemove dust with a dry cloth.
          SensorsCRemove dust with a dry cloth.
          1 Bin Tray BN3110
          ItemEMRemarks
          RollersCWipe with a cloth dampened with ethyl alcohol.
          Copy tray
          Clean with a damp cloth, and then wipe with a dry cloth.
          SensorsCClean with a blower brush.
          Bridge Unit BU3070
          ItemEMRemarks
          Internal Shift Tray SH3070
          ItemEMRemarks
          Exit Tray
          Side Tray Type M3
          ItemEMRemarks
          Booklet Finisher SR3220/Punch Unit PU3050
          ItemCycleEMRemarks
          Rollers
          Quenching brush
          Clean with a dry cloth if dirt adheres to it.
          Stapler (Corner)
          R 4000K
          Replace when the staple counter in the logging data reaches 500k.
          Staple a few times for a test after replacement.
          ItemCycleEMRemarks
          Booklet Stapler
          R 4000K
          Replace when the staple counter in the logging data reaches 200k.
          Punch
          R 3000K
          Remove paper dust in the transport unit.
          Punch waste
          C 300K
          Discard punch waste when hopper full is detected.
          Internal Finisher SR3130
          ItemEMRemarks
          Stapler
          Internal Finisher SR3180
          ItemEMRemarks
          Stapler
          None
          APPENDIX: ENGINE SP MODE TABLES​
          Engine SP Mode Tables
  2. ENGINE SP MODE TABLES​
    1. ENGINE SP TABLES - SP1000-1​
      1. SP1-XXX (FEED)​
        1001[Leading Edge Registration]
        1-001-001Tray1: Thin*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-002Tray1: Plain*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-003Tray1: Mid-thick*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-004Tray1: Thick 1*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-005Tray1: Thick 2*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-006Tray1: Thick 3*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-007Tray1: Thick 4*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-008Tray2/3/4/5/LCT: Thin*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-009Tray2/3/4/5/LCT: Plain*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-010Tray2/3/4/5/LCT: Mid-thick*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-011Tray2/3/4/5/LCT: Thick 1*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-012Tray2/3/4/5/LCT: Thick 2*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-013Tray2/3/4/5/LCT: Thick 3*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-014Tray2/3/4/5/LCT: Thick 4*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-015By-pass: Thin*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-016By-pass: Plain*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-017By-pass: Mid-thick*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-018By-pass: Thick 1*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-019By-pass: Thick 2*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-020By-pass: Thick 3*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-021By-pass: Thick 4*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-022Duplex: Thin*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-023Duplex: Plain*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-024Duplex: Mid-thick*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-025Duplex: Thick 1*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-026Duplex: Thick 2*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-027Duplex: Thick 3*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-028Tray1: Thin:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-029Tray1: Plain:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-030Tray1: Mid-thick:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-031Tray1: Thick 1:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-032Tray1: Thick 2:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-033Tray1: Thick 3:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-034Tray1: Thick 4:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-035Tray2/3/4/5/LCT: Thin:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-036Tray2/3/4/5/LCT: Plain:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-037Tray2/3/4/5/LCT: Mid-thick:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-038Tray2/3/4/5/LCT: Thick 1:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-039Tray2/3/4/5/LCT: Thick 2:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-040Tray2/3/4/5/LCT: Thick 3:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-041Tray2/3/4/5/LCT: Thick 4:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-042By-pass: Thin:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-043By-pass: Plain:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-044By-pass: Mid-thick:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-045By-pass: Thick 1:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-046By-pass: Thick 2:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-047By-pass: Thick 3:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-048By-pass: Thick 4:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-049Duplex: Thin:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-050Duplex: Plain:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-051Duplex: Mid-thick:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-052Duplex: Thick 1:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-053Duplex: Thick 2:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1-001-054Duplex: Thick 3:1200*ENG[-9 to 9 / 0 / 0.1mm/step]
        1002[Side-to-Side Registration]
        1-002-001By-pass TrayENG[-4 to 4 / 0 / 0.1mm/step]
        1-002-002Paper Tray 1ENG[-4 to 4 / 0 / 0.1mm/step]
        1-002-003Paper Tray 2ENG[-4 to 4 / 0 / 0.1mm/step]
        1-002-004Paper Tray 3ENG[-4 to 4 / 0 / 0.1mm/step]
        1-002-005Paper Tray 4ENG[-4 to 4 / 0 / 0.1mm/step]
        1-002-006Duplex*ENG[-4 to 4 / 0 / 0.1mm/step]
        1-002-007Large Capacity Tray*ENG[-4 to 4 / 0 / 0.1mm/step]
        1003[Paper Buckle]
        1-003-001Paper Tray1: Thin*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-002Paper Tray1: Plain*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-003Paper Tray 1: Mid-thick*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-004Paper Tray1: Thick1*ENG[-4 to 5 / -3.5 / 0.1mm/step]
        1-003-005Tray2/3/4/5/LCT: Thin*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-006Tray2/3/4/5/LCT: Plain*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-007Tray 2/3/4/5/LCT: Mid-thick*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-008Tray2/3/4/5/LCT: Thick 1*ENG[-4 to 5 / -3.5 / 0.1mm/step]
        1-003-009By-pass: Thin*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-010By-pass: Plain*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-011By-pass: Mid-thick*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-012By-pass:Thick1*ENG[-4 to 5 / -3 / 0.1mm/step]
        1-003-013Duplex:Thin*ENG[-4 to 5 / -1.5 / 0.1mm/step]
        1-003-014Duplex:plain*ENG[-4 to 5 / -1.5 / 0.1mm/step]
        1-003-015Duplex: Mid-thick*ENG[-4 to 5 / -1.5 / 0.1mm/step]
        1-003-016Duplex:Thick1*ENG[-4 to 5 / -3.5 / 0.1mm/step]
        1-003-017Paper Tray1: Thin:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-018Paper Tray1: Plain:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-019Paper Tray 1: Mid-thick:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-020Paper Tray1: Thick1:1200*ENG[-4 to 5 / -3.5 / 0.1mm/step]
        1-003-021Tray2/3/4/5/LCT: Thin:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-022Tray2/3/4/5/LCT: Plain:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-023Tray2/3/4/5/LCT: Mid:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-024
        1-003-025By-pass: Thin:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-026By-pass: Plain:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-027By-pass: Mid-thick:1200*ENG[-4 to 5 / 0 / 0.1mm/step]
        1-003-028By-pass:Thick1:1200*ENG[-4 to 5 / -3 / 0.1mm/step]
        1-003-029Duplex:Thin:1200*ENG[-4 to 5 / -1.5 / 0.1mm/step]
        1-003-030Duplex:plain:1200*ENG[-4 to 5 / -1.5 / 0.1mm/step]
        1007[By-Pass Size Detection]
        1-007-001Switch LT SEF/LG SEF*ENG[0 or 1 / 0 / 1/step] 0:OFF
        1:ON
        1-007-002By-Pass Jam Detection Set*ENG[0 or 1 / 0 / 1/step]
        0: Normal Detection
        1: Simple Detection
        1-003-031Duplex: Mid-thick:1200*ENG[-4 to 5 / -1.5 / 0.1mm/step]
        1-003-032Duplex:Thick1:1200*ENG[-4 to 5 / -3.5 / 0.1mm/step]
        1009[Initial Operation Setting]
        1-009-001Registration Gear Backlash Cut*ENG[0 to 1 / 0 / 1/step]
        1009[Operation Setting]
        1-009-002Paper Exit Speed*ENG[0 to 1 / 1 / 1/step]
        1009[Pickup SOL Separate Setting]
        1-009-003Paper Tray1: Thin*ENG[0 to 1 / 1 / 1/step]
        1-009-004Paper Tray1: Plain*ENG[0 to 1 / 1 / 1/step]
        1-009-005Paper Tray1: Thick*ENG[0 to 1 / 1 / 1/step]
        1-009-006Paper Tray2: Thin*ENG[0 to 1 / 1 / 1/step]
        1-009-007Paper Tray2: Plain*ENG[0 to 1 / 1 / 1/step]
        1-009-008Paper Tray2: Thick*ENG[0 to 1 / 1 / 1/step]
        1-009-009Paper Tray3: Thin*ENG[0 to 1 / 1 / 1/step]
        1-009-010Paper Tray3: Plain*ENG[0 to 1 / 1 / 1/step]
        1-009-011Paper Tray3: Thick*ENG[0 to 1 / 1 / 1/step]
        1-009-012Paper Tray4: Thin*ENG[0 to 1 / 1 / 1/step]
        1-009-013Paper Tray4: Plain*ENG[0 to 1 / 1 / 1/step]
        1-009-014Paper Tray4: Thick*ENG[0 to 1 / 1 / 1/step]
        1-009-015Paper LCT: Thin*ENG[0 to 1 / 1 / 1/step]
        1-009-016Paper LCT: Plain*ENG[0 to 1 / 1 / 1/step]
        1-009-017Paper LCT: Thick*ENG[0 to 1 / 1 / 1/step]
        1101[Operation Setting]
        1-009-018Pre-rotation Start Temp.*ENG[0 to 3 / 1 / 1/step]
      2. SP1-XXX (FUSING)​
1101[Reload Permit Setting]
1-101-001Pre-rotation Start Temp.*ENG[0 to 200 / 0 / 1deg/step]
1-101-002Reload Target Temp.:Center*ENG[0 to 190 / 114 / 1deg/step]
1-101-003Reload Target Temp.:press*ENG[0 to 200 / 120 / 1deg/step]
1-101-004Temp.:Delta:Cold:Center*ENG[4 to 200 / * / 1deg/step]
*NA: 27, EU: 31, Asia:
31, CHN: 31, TWN: 27,
KOR: 31
1-101-005Temp.:Delta:Cold:End*ENG[4 to 200 / * / 1deg/step]
31, CHN: 31, TWN 27,
KOR: 31
1-101-006Temp.:Delta:Cold:press*ENG[4 to 200 / 110 / 1deg/step]
1-101-007Forced Reload Time:Cold*ENG[0 to 100 / 15 / 0.1sec/step]
1-101-008Temp.:Delta:Low Power:Center*ENG[4 to 200 / 6 / 1deg/step]
1-101-009Temp.:Delta:Low Power:End*ENG[4 to 200 / 6 / 1deg/step]
1-101-010Temp.:Delta:Low Power:press*ENG[4 to 200 / 110 / 1deg/step]
1-101-011Forced Reload Time:Low Power*ENG[0 to 100 / 15 / 0.1sec/step]
1-101-012Temp.:Delta:Hot:Center*ENG[4 to 200 / 6 / 1deg/step]
1-101-013Temp.:Delta:Hot:End*ENG[4 to 200 / 6 / 1deg/step]
1-101-014Temp.:Delta:Hot:press*ENG[4 to 200 / 110 / 1deg/step]
1-101-015Forced Reload Time:Hot*ENG[0 to 100 / 15 / 0.1sec/step]
1-101-016Temp.:Delta:Cold:BW1/2:Center*ENG[4 to 200 / * / 1deg/step]
*NA: 42, EU: 46, Asia:
46, CHN: 46, TWN: 42,
KOR: 46
1-101-017Temp.:Delta:Cold:BW1/2:End*ENG[4 to 200 / * / 1deg/step]
KOR: 46
1-101-018Temp.:Delta:Cold:BW1/2:press*ENG[4 to 200 / 110 / 1deg/step]
1-101-019Forced Reload Time:Cold:BW1/2*ENG[0 to 100 / 15 / 0.1sec/step]
1-101-101Reload Target Temp.:Center:Energy Saving*ENG[0 to 200 / * / 1deg/step]
*NA: 116, EU: 114, Asia:
114, CHN: 114, TWN:
116, KOR: 114
1-101-102Reload Target Temp.:press:Energy Saving*ENG[0 to 200 / 120 / 1deg/step]
1-101-103Temp.:Delta:Cold:Energy Saving:Center*ENG[0 to 200 / * / 1deg/step]
*NA: 34, EU: 42, Asia:
42, CHN: 42, TWN: 34,
KOR: 42
1-101-104Temp.:Delta:Cold:Energy Saving:End*ENG[0 to 200 / * / 1deg/step]
KOR: 42
1-101-105Temp.:Delta:Cold:Energy Saving:press*ENG[4 to 200 / 100 / 1deg/step]
1-101-106Forced Reload Time:Cold:Energy Saving*ENG[0 to 100 / 30 / 0.1sec/step]
1-101-151Temp.:Delta:Low Temp.:Center*ENG[4 to 200 / 6 / 1deg/step]
1-101-152Temp.:Delta:Low Temp.:End*ENG[4 to 200 / 6 / 1deg/step]
1-101-153Temp.:Delta:Low Temp.:press*ENG[4 to 200 / 70 / 1deg/step]
1-101-154Forced Reload Time:Low Temp.*ENG[0 to 100 / 35 / 0.1sec/step]
1-101-201Temp.:Delta:Cold:Center:FIN-less/ADF-less*ENG[4 to 200 / * / 1deg/step]
*NA: 30, EU: 34, Asia:
34, CHN: 34, TWN: 30,
KOR: 34
1-101-202Temp.:Delta:Cold:End:FIN-less/ADF-less*ENG[4 to 200 / * / 1deg/step]
KOR: 34
1-101-203Temp.:Delta:Cold:press:FIN-less/ADF-less*ENG[4 to 200 / 110 / 1deg/step]
1-101-204Forced Reload Time:Cold:FIN-less/ADF-less*ENG[0 to 100 / 15 / 0.1sec/step]
1-101-211Temp:Delta:Cold:Center:FIN-less/ADF-attached*ENG[4 to 200 / * / 1deg/step]
KOR: 34
1-101-212Temp.:Delta:Cold:End:FIN-less/ADF-attached*ENG[4 to 200 / * / 1deg/step]
KOR: 34
1-101-213Temp.:Delta:Cold:press:FIN-less/ADF-attached*ENG[4 to 200 / 110 / 1deg/step]
1-101-214ForcedReloadTime:Cold:FIN-less/ADF-attached*ENG[0 to 100 / 15 / 0.1sec/step]
1102[Feed Permit Setting]
1-102-001Temp.:Lower Delta:Center*ENG[0 to 200 / * / 1deg/step]
*NA: 33, EU: 38, Asia: 38, CHN: 38,
TWN: 33, KOR: 38
1-102-002Temp.:Lower Delta:End*ENG[0 to 200 / * / 1deg/step]
TWN: 33, KOR: 38
1-102-003Temp.:Upper Delta:Center*ENG[0 to 200 / 40 / 1deg/step]
1-102-004Temp.:Upper Delta:End*ENG[0 to 200 / 40 / 1deg/step]
1-102-005Temp.:Lower Delta:press*ENG[0 to 200 / 90 / 1deg/step]
1-102-006Rotation Time*ENG[0 to 100 / 0.65 / 0.01sec/step]
1-102-007Temp.:Lower Delta:Center:Sp.1*ENG[0 to 200 / 5 / 1deg/step]
1-102-008Temp.:Lower Delta:End:Sp.1*ENG[0 to 200 / 5 / 1deg/step]
1-102-009Temp.:Upper Delta:Center:Sp.1*ENG[0 to 200 / 30 / 1deg/step]
1-102-010Temp.:Upper Delta:End:Sp.1*ENG[0 to 200 / 30 / 1deg/step]
1-102-011Temp.:Lower Delta:press:Sp.1*ENG[0 to 200 / 45 / 1deg/step]
1-102-012Rotation Time:Sp.1*ENG[0 to 200 / 0.65 / 0.01sec/step]
1-102-013Temp.:Lower Delta:Center:Sp.2*ENG[0 to 100 / 0 / 0.01sec/step]
1-102-014Temp.:Lower Delta:End:Sp.2*ENG[0 to 200 / 5 / 1deg/step]
1-102-015Temp.:Upper Delta:Center:Sp.2*ENG[0 to 200 / 15 / 1deg/step]
1-102-016Temp.:Upper Delta:End:Sp.2*ENG[0 to 200 / 15 / 1deg/step]
1-102-017Temp.:Lower Delta:press:Sp.2*ENG[0 to 200 / 100 / 1deg/step]
1-102-018Rotation Time:Sp2*ENG[0 to 100 / 0.65 / 0.01sec/step]
1-102-019Feed Permit Time*ENG[0 to 200 / 60 / 1sec/step]
1-102-020Temp.:Lower Delta:Center*ENG[0 to 200 / 40 / 1deg/step]
1-102-021Temp.:Lower Delta:End*ENG[0 to 200 / 40 / 1deg/step]
1-102-022Temp.:Upper Delta:Center*ENG[0 to 200 / 30 / 1deg/step]
1-102-023Temp.:Upper Delta:End*ENG[0 to 200 / 30 / 1deg/step]
1-102-024Temp.:Lower Delta:press*ENG[0 to 200 / 38 / 1deg/step]
1-102-025Temp.:Lower Delta:press*ENG[0 to 200 / 53 / 1deg/step]
1-102-026Rotation Time*ENG[0 to 100 / 0.65 / 0.01sec/step]
1-102-027Temp.:Lower Delta:Center*ENG[0 to 200 / 5 / 1deg/step]
1-102-028Temp.:Lower Delta:End*ENG[0 to 200 / 5 / 1deg/step]
1-102-029Temp.:Upper Delta:Center*ENG[0 to 200 / 30 / 1deg/step]
1-102-030Temp.:Upper Delta:End*ENG[0 to 200 / 30 / 1deg/step]
1-102-031Temp.:Lower Delta:press*ENG[0 to 200 / 34 / 1deg/step]
1-102-032Temp.:Lower Delta:press*ENG[0 to 200 / 49 / 1deg/step]
1-102-033Rotation Time*ENG[0 to 100 / 0.65 / 0.01sec/step]
1-102-034Temp.:Lower Delta:Center*ENG[0 to 200 / 5 / 1deg/step]
1-102-035Temp.:Lower Delta:End*ENG[0 to 200 / 5 / 1deg/step]
1-102-036Temp.:Upper Delta:Center*ENG[0 to 200 / 15 / 1deg/step]
1-102-037Temp.:Upper Delta:End*ENG[0 to 200 / 15 / 1deg/step]
1-102-038Temp.:Lower Delta:press*ENG[0 to 200 / 100 / 1deg/step]
1-102-039Temp.:Lower Delta:press*ENG[0 to 200 / 100 / 1deg/step]
1-102-040Rotation Time*ENG[0 to 100 / 0.65 / 0.01sec/step]
1-102-041Judgment Power A*ENG[0 to 2000 / * / 1W/step]
*NA: 1304, EU: 1429, Asia: 1429,
CHN: 1429, TWN: 1304, KOR:
1429
1-102-042Temp.:Lower Delta:Center:power A*ENG[0 to 200 / 49 / 1deg/step]
1-102-043Temp.:Lower Delta::power A*ENG[0 to 200 / 49 / 1deg/step]
1-102-044Temp.:Upper Delta:Center:power A*ENG[0 to 200 / 40 / 1deg/step]
1-102-045Temp.:Upper Delta:End:power A*ENG[0 to 200 / 40 / 1deg/step]
1-102-046Temp.:Lower Delta:press:power A*ENG[0 to 200 / 90 / 1deg/step]
1-102-047Rotation Time:power A*ENG[0 to 100 / 0.65 / 0.01sec/step]
1-102-051Judgment Power B*ENG[0 to 2000 / * / 1W/step]
*NA: 1284, EU: 1409, Asia: 1409,
CHN: 1409, TWN: 1284, KOR:
1409
1-102-052Temp.:Lower Delta:Center:power B*ENG[0 to 200 / 49 / 1deg/step]
1-102-053Temp.:Lower Delta:End:power B*ENG[0 to 200 / 49 / 1deg/step]
1-102-054Temp.:Upper Delta:Center:power B*ENG[0 to 200 / 40 / 1deg/step]
1-102-055Temp.:Upper Delta:End:power B*ENG[0 to 200 / 40 / 1deg/step]
1-102-056Temp.:Lower Delta:press:power B*ENG[0 to 200 / 90 / 1deg/step]
1-102-057Rotation Time:power B*ENG[0 to 100 / 0.65 / 0.01sec/step]
1-102-060Waiting Time: Stabilize Temp.*ENG[0 to 10000 / 0 / 1msec/step]
1-102-070Timeout: Cold: Normal*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-071Timeout: Hot: Normal*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-072Timeout: Cold: Power 1*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-073Timeout: Hot: Power 1*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-074Timeout: Cold: Power 2*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-075Timeout: Hot: Power 2*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-076Timeout: 10sec: 11*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-077Timeout: 10sec: 15*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-078Timeout: 10sec: 16*ENG[0 to 20000 / 4000 / 1msec/step]
1-102-101Temp.:Lower Delta:press0*ENG[0 to 200 / 0 / 1deg/step]
1-102-102Temp.:Lower Delta:press10*ENG[0 to 200 / 0 / 1deg/step]
1-102-103Temp.:Lower Delta:press1*ENG[0 to 200 / 0 / 1deg/step]
1-102-104Temp.:Lower Delta:press2*ENG[0 to 200 / 0 / 1deg/step]
1-102-105Temp.:Lower Delta:press3*ENG[0 to 200 / 0 / 1deg/step]
1-102-106Temp.:Lower Delta:press13*ENG[0 to 200 / 0 / 1deg/step]
1-102-107Temp.:Lower Delta:press4*ENG[0 to 200 / 0 / 1deg/step]
1-102-108Temp.:Lower Delta:press14*ENG[0 to 200 / 0 / 1deg/step]
1-102-109Temp.:Lower Delta:press5*ENG[0 to 200 / 17 / 1deg/step]
1-102-110Temp.:Lower Delta:press6*ENG[0 to 200 / 17 / 1deg/step]
1-102-111Temp.:Lower Delta:press7*ENG[0 to 200 / 13 / 1deg/step]
1-102-112Temp.:Lower Delta:press11*ENG[0 to 200 / 0 / 1deg/step]
1-102-113Temp.:Lower Delta:press15*ENG[0 to 200 / 0 / 1deg/step]
1-102-114Temp.:Lower Delta:press16*ENG[0 to 200 / 0 / 1deg/step]
1-102-121Timeout:press0*ENG[0 to 200 / 0 / 1deg/step]
1-102-122Timeout:press10*ENG[0 to 200 / 0 / 1deg/step]
1-102-123Timeout:press1*ENG[0 to 200 / 0 / 1deg/step]
1-102-124Timeout:press2*ENG[0 to 200 / 0 / 1deg/step]
1-102-125Timeout:press3*ENG[0 to 200 / 0 / 1deg/step]
1-102-126Timeout:press13*ENG[0 to 200 / 0 / 1deg/step]
1-102-127Timeout:press4*ENG[0 to 200 / 0 / 1deg/step]
1-102-128Timeout:press14*ENG[0 to 200 / 0 / 1deg/step]
1-102-129Timeout:press5*ENG[0 to 60000 / 5000 / 1msec/step]
1-102-130Timeout:press6*ENG[0 to 60000 / 5000 / 1msec/step]
1-102-131Timeout:press7*ENG[0 to 60000 / 3000 / 1msec/step]
1-102-132Timeout: Press: 11*ENG[0 to 60000 / 0 / 1msec/step]
1-102-133Timeout: Press: 15*ENG[0 to 60000 / 0 / 1msec/step]
1-102-134Timeout: Press: 16*ENG[0 to 60000 / 0 / 1msec/step]
1105[Print Target Temp.]
1-105-001Plain1:FC:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 126
*MP C2504: 123
1-105-002Plain1:FC:press*ENG[0 to 200 / 122 / 1deg/step]
1-105-003Plain1:BW:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 123
*MP C2504: 120
1-105-004Plain1:BW:press*ENG[0 to 200 / 122 / 1deg/step]
1-105-005Plain2:FC:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 128
*MP C2504: 122
1-105-006Plain2:FC:press*ENG[0 to 200 / 122 / 1deg/step]
1-105-007Plain2:BW:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 128
*MP C2504: 122
1-105-008Plain2:BW:press*ENG[0 to 200 / 122 / 1deg/step]
1-105-009Thin:FC:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 121
*MP C2504: 118
1-105-010Thin:FC:press*ENG[0 to 200 / 121 / 1deg/step]
1-105-011Thin:BW:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 121
*MP C2504: 118
1-105-012Thin:BW:press*ENG[0 to 200 / 121 / 1deg/step]
1-105-013M-thick:FC:Center*ENG[100 to 180 / 136 / 1deg/step]
1-105-014M-thick:FC:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-015M-thick:BW:Center*ENG[100 to 180 / 136 / 1deg/step]
1-105-016M-thick:BW:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-017Thick1:FC:Center*ENG[100 to 180 / 127 / 1deg/step]
1-105-018Thick1:FC:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-019Thick1:BW:Center*ENG[100 to 180 / 127 / 1deg/step]
1-105-020Thick1:BW:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-021Thick2:FC:Center*ENG[100 to 180 / 132 / 1deg/step]
1-105-022Thick2:FC:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-023Thick2:BW:Center*ENG[100 to 180 / 132 / 1deg/step]
1-105-024Thick2:BW:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-025Thick3:FC:Center*ENG[100 to 180 / 137 / 1deg/step]
1-105-026Thick3:FC:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-027Thick3:BW:Center*ENG[100 to 180 / 137 / 1deg/step]
1-105-028Thick3:BW:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-029Special1:FC:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 126
*MP C2504: 123
1-105-030Special1:FC:press*ENG[0 to 200 / 117 / 1deg/step]
1-105-031Special1:BW:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 123
*MP C2504: 120
1-105-032Special1:BW:press*ENG[0 to 200 / 117 / 1deg/step]
1-105-033Special2:FC:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 131
*MP C2504: 128
1-105-034Special2:FC:press*ENG[0 to 200 / 122 / 1deg/step]
1-105-035Special2:BW:Center*ENG[100 to 180 / * / 1deg/step]
*MP C2004: 128
*MP C2504: 125
1-105-036Special2:BW:press*ENG[0 to 200 / 122 / 1deg/step]
1-105-037Special3:FC:Center*ENG[100 to 180 / 136 / 1deg/step]
1-105-038Special3:FC:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-039Special3:BW:Center*ENG[100 to 180 / 136 / 1deg/step]
1-105-040Special3:BW:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-041Envelop:Center*ENG[100 to 180 / 142 / 1deg/step]
1-105-042Envelop:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-051Special1:FC:Center:Middle Speed*ENG[100 to 180 / 122 / 1deg/step]
1-105-052Special1:FC:press:Middle Speed*ENG[0 to 200 / 120 / 1deg/step]
1-105-053Special1:BW:Center:Middle Speed*ENG[100 to 180 / 122 / 1deg/step]
1-105-054Special1:BW:press:Middle Speed*ENG[0 to 200 / 120 / 1deg/step]
1-105-055Special2:FC:Center:Middle Speed*ENG[100 to 180 / 127 / 1deg/step]
1-105-056Special2:FC:press:Middle Speed*ENG[0 to 200 / 120 / 1deg/step]
1-105-057Special2:BW:Center:Middle Speed*ENG[100 to 180 / 127 / 1deg/step]
1-105-058Special2:BW:press:Middle Speed*ENG[0 to 200 / 120 / 1deg/step]
1-105-059Special3:FC:Center:Middle Speed*ENG[100 to 180 / 132 / 1deg/step]
1-105-060Special3:FC:press:Middle Speed*ENG[0 to 200 / 120 / 1deg/step]
1-105-061Special3:BW:Center:Middle Speed*ENG[100 to 180 / 132 / 1deg/step]
1-105-062Special3:BW:press:Middle Speed*ENG[0 to 200 / 120 / 1deg/step]
1-105-101Plain1:FC:Center:Low Speed*ENG[100 to 180 / 115 / 1deg/step]
1-105-102Plain1:FC:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-103Plain1:BW:Center:Low Speed*ENG[100 to 180 / 115 / 1deg/step]
1-105-104Plain1:BW:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-105Plain2:FC:Center:Low Speed*ENG[100 to 180 / 120 / 1deg/step]
1-105-106Plain2:FC:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-107Plain2:BW:Center:Low Speed*ENG[100 to 180 / 120 / 1deg/step]
1-105-108Plain2:BW:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-109M-thick:FC:Center:Low Speed*ENG[100 to 180 / 122 / 1deg/step]
1-105-110M-thick:FC:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-111M-thick:BW:Center:Low Speed*ENG[100 to 180 / 122 / 1deg/step]
1-105-112M-thick:BW:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-113Thick1:FC:Center:Low Speed*ENG[100 to 180 / 127 / 1deg/step]
1-105-114Thick1:FC:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-115Thick1:BW:Center:Low Speed*ENG[100 to 180 / 127 / 1deg/step]
1-105-116Thick1:BW:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-117Special1:FC:Center:Low Speed*ENG[100 to 180 / 122 / 1deg/step]
1-105-118Special1:FC:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-119Special1:BW:Center:Low Speed*ENG[100 to 180 / 122 / 1deg/step]
1-105-120Special1:BW:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-121Special2:FC:Center:Low Speed*ENG[100 to 180 / 132 / 1deg/step]
1-105-122Special2:FC:press:Low Speed*ENG[0 to 200 / 120 / 1deg/step]
1-105-123Special2:BW:Center:Low Speed*ENG[100 to 180 / 132 / 1deg/step]
1-105-124Special2:BW:press:Low Speed*ENG[0 to 200 / 120 / 1deg/step]
1-105-125Plain1:Glossy:Center*ENG[100 to 180 / 132 / 1deg/step]
1-105-126Plain1:Glossy:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-127Plain2:Glossy:Center*ENG[100 to 180 / 137 / 1deg/step]
1-105-128Plain2:Glossy:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-129M-thick:Glossy:Center*ENG[100 to 180 / 142 / 1deg/step]
1-105-130M-thick:Glossy:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-131OHP:Center*ENG[100 to 180 / 160 / 1deg/step]
1-105-132OHP:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-133Envelop:Center:Low Speed*ENG[100 to 180 / 135 / 1deg/step]
1-105-134Envelop:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-135Thin:FC:Center:Low Speed*ENG[100 to 180 / 110 / 1deg/step]
1-105-136Thin:FC:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-137Thin:BW:Center:Low Speed*ENG[100 to 180 / 110 / 1deg/step]
1-105-138Thin:BW:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-139Thick4:FC:Center*ENG[100 to 180 / 142 / 1deg/step]
1-105-140Thick4:FC:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-141Thick4:BW:Center*ENG[100 to 180 / 142 / 1deg/step]
1-105-142Thick4:BW:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-143Postcard:Center*ENG[100 to 180 / 124 / 1deg/step]
1-105-144Postcard:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-145Special3:FC:Center:Middle Speed*ENG[100 to 180 / 142 / 1deg/step]
1-105-146Special3:FC:press:Middle Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-147Special3:BW:Center:Middle Speed*ENG[100 to 180 / 142 / 1deg/step]
1-105-148Special3:BW:press:Middle Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-149Mid Thick:Matte:Center*ENG[100 to 180 / 136 / 1deg/step]
1-105-150Mid Thick:Matte:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-151Thick1:Matte:Center*ENG[100 to 180 / 127 / 1deg/step]
1-105-152Thick1:Matte:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-153Thick2:Matte:Center*ENG[100 to 180 / 132 / 1deg/step]
1-105-154Thick2:Matte:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-155Thick3:Matte:Center*ENG[100 to 180 / 137 / 1deg/step]
1-105-156Thick3:Matte:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-157Thick4:Matte:Center*ENG[100 to 180 / 142 / 1deg/step]
1-105-158Thick4:Matte:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-159Mid Thick:Matte:Center:Low Speed*ENG[100 to 180 / 122 / 1deg/step]
1-105-160Mid Thick:Matte:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-161Thick1:Matte:Center:Low Speed*ENG[100 to 180 / 127 / 1deg/step]
1-105-162Thick1:Matte:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-163Mid Thick:Glossy:Center*ENG[100 to 180 / 136 / 1deg/step]
1-105-164Mid Thick:Glossy:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-165Thick1:Glossy:Center*ENG[100 to 180 / 127 / 1deg/step]
1-105-166Thick1:Glossy:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-167Thick2:Glossy:Center*ENG[100 to 180 / 132 / 1deg/step]
1-105-168Thick2:Glossy:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-169Thick3:Glossy:Center*ENG[100 to 180 / 137 / 1deg/step]
1-105-170Thick3:Glossy:press*ENG[0 to 200 / 120 / 1deg/step]
1-105-171Thick4:Glossy:Center*ENG[100 to 180 / 142 / 1deg/step]
1-105-172Thick4:Glossy:press*ENG[0 to 200 / 118 / 1deg/step]
1-105-173Mid Thick:Glossy:Center:Low Speed*ENG[100 to 180 / 122 / 1deg/step]
1-105-174Mid Thick:Glossy:press:Low Speed*ENG[0 to 200 / 118 / 1deg/step]
1-105-175Thick1:Glossy:Center:Low Speed*ENG[100 to 180 / 127 / 1deg/step]
1-105-176Thick1:Glossy:press:Low Speed*ENG
1106[Fusing Temp. Display]
1-106-001Heat CenterENG[-10 to 250 / 0 / 1deg/step]
1-106-002Heat EndENG[-10 to 250 / 0 / 1deg/step]
1-106-003Press CenterENG[-10 to 250 / 0 / 1deg/step]
1107[Standby Target Temp. Setting]
1-107-001Stanby/Preheat1:Center*ENG[0 to 125 / 90 / 1deg/step]
1-107-003Preheat2:Center*ENG[0 to 200 / 90 / 1deg/step]
1-107-005Low Power:Center*ENG[0 to 125 / 60 / 1deg/step]
1-107-007Print Ready:Center*ENG[85 to 180 / * / 1deg/step]
*MP C2004: 121
*MP C2504: 118
1-107-008Print Ready:press*ENG[0 to 200 / 120 / 1deg/step]
1-107-011Standby Heater Off Time*ENG[0 to 100 / 0 / 1sec/step]
1-106-004Press EndENG[-10 to 250 / 0 / 1deg/step]
1-106-005Press EndENG[-10 to 250 / 0 / 1deg/step]
1108[After Reload/Job Target Temp.]
1-108-001Center*ENG[85 to 200 / * / 1deg/step]
*MP C2004: 121
*MP C2504: 118
1-108-002Press*ENG[0 to 200 / 120 / 1deg/step]
1-108-011Center:Energy Saving*ENG[85 to 200 / * / 1deg/step]
*NA: 116, EU: 114, Asia: 114, CHN:
114, TWN: 116, KOR: 114
1-108-012Press:Energy Saving*ENG[0 to 200 / 120 / 1deg/step]
1111[Environment Correction:Fusing]
1-111-001Temp.: Threshold: Low*ENG[0 to 100 / 15 / 1deg/step]
1-111-002Temp.: Threshold: High*ENG[0 to 100 / 30 / 1deg/step]
1-111-003Low Temp. Correction*ENG[0 to 15 / 3 / 1deg/step]
1-111-004High Temp. Correction*ENG[0 to 15 / 0 / 1deg/step]
1-111-005Job Low Temp. Correction*ENG[0 to 10 / 0.6 / 0.1deg/step]
Write your reply...
