SIDE TRAY TYPE M3 (D725)
Item Specification Paper size: A3 SEF, A4 SEF/LEF, A5 SEF/LEF, A6 SEF, B4 JIS SEF, B5 JIS SEF/LEF, B6 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8 1/2 × 11 SEF/LEF, 8 1/4 × 14
SEF, 8 1/4 × 13 SEF, 8 × 13 SEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 5 1/2 × 8 1/2 SEF, 4 1/8 × 9 1/2 SEF/LEF,
3 7/8 × 7 1/2 SEF/LEF, C5 Env SEF/LEF, C6 Env SEF/LEF, DL Env SEF/LEF, 8K SEF, 16K SEF/LEF, 12 × 18 SEF, 11 × 15 SEF, 10 × 14 SEF, SRA3 SEF, SRA4
SEF/LEF, custom sizePaper weight: 52–300 g/m2 (14 lb. Bond–110 lb. Cover) Paper capacity (80 g/m2, 20 lb. Bond): 250 sheets: A4, 81/2 × 11 or smaller 125 sheets: B4 JIS, 81/2 × 14 or larger Power consumption: 12 W (Power is supplied from the main unit.) Dimensions (W × D × H): 800 × 549 × 156 mm (31.5 × 21.7 × 6.2 inches) Weight: Approx. 4 kg (8.9 lb.) - Internal tray 1:
- External tray: 125 sheets
INTERNAL SHIFT TRAY SH3070 (D691)
SEF/LEF, custom sizePaper weight: 60–300 g/m2 (16 lb. Bond–110 lb. Cover) Paper sizes that can be shifted: A3 SEF, A4 SEF/LEF, A5 SEF/LEF, A6 SEF, B4 JIS SEF, B5 JIS SEF/LEF, B6 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8 1/2 × 11 SEF/LEF, 8 1/4 × 14
SEF/LEF, custom sizePaper weight that can be shifted: 60–300 g/m2 (16 lb. Bond–110 lb. Cover) Stack capacity (80 g/m2, 20 lb. Bond): Power consumption: 4.3 W (Power is supplied from the main unit.) Dimensions (W × D × H): 420 × 489 × 107 mm (16.6 × 19.3 × 4.3 inches) Weight: Approx. 2 kg (4.5 lb.) - 250 sheets: A4, 81/2 × 11 or smaller
- 125 sheets: B4 JIS, 81/2 × 14 or larger
1 BIN TRAY BN3110 (D3CQ)
Item Specification Number of bins: 1 Paper size: A3 SEF A4 SEF/LEF, A5 SEF/LEF, B4 JIS SEF B5 JIS SEF/LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8
1/2 × 11 SEF/LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 8 ×
13 SEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 51/2 × 8
1/2 SEF, 8K SEF, 16K SEF/LEF, 11 × 15 SEF, 10 × 14
SEF, SRA3 SEF, SRA4 SEF/LEF, custom sizePaper weight: 52–300 g/m2 (14 lb. Bond–110 lb. Cover) Paper capacity (80 g/m2, 20 lb. Bond): 125 sheets Power consumption: 1 W or less (Power is supplied from the main unit.) Dimensions (W × D × H): 444 × 450 × 150 mm (17.5 × 17.8 × 6.0 inches) Weight: Approx. 2 kg (4.5 lb.)
BRIDGE UNIT BU3070 (D685)
Item Specification Stack capacity (80 g/m2, 20 lb. Bond): Power consumption: 15 W (Power is supplied from the main unit.) Dimensions (W × D × H): 412 × 466 × 143 mm (16.3 × 18.4 × 5.7 inches) Weight: Approx. 4 kg (8.9 lb.) - 250 sheets: A4, 81/2 × 11 or smaller
INTERNAL FINISHER SR3130 (D690)
3 7/8 × 7 1/2 SEF/LEF, C5 Env SEF/LEF, C6 Env SEF/LEF, DL Env SEF/LEF, 8K SEF, 16K SEF/LEF, 12 × 18 SEF, 11 × 15 SEF, 10 × 14 SEF, SRA3 SEF, SRA4 SEF/LEF, custom sizePaper weight: 60–300 g/m2 (16 lb. Bond–110 lb. Cover) Paper sizes that can be shifted: A3 SEF, A4 SEF/LEF, A5 SEF/LEF, B4 JIS SEF, B5 JIS SEF/LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8
13 SEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, C5 Env
SEF/LEF, 8K SEF, 16K SEF/LEF, 11 × 15 SEF, 10 × 14
SEF, SRA4 LEF, custom sizePaper weight that can be shifted: 64–105 g/m2 (17–28 lb. Bond) Stack capacity (80 g/m2, 20 lb. Bond): Staple paper size: A3 SEF, A4 SEF/LEF, B4 JIS SEF, B5 JIS SEF/LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8 1/2 × 11
SEF/LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 7 1/4 × 10 1/2 SEF/LEF, 8K SEF, 16K SEF/LEFStaple paper weight: 64–105 g/m2 (17–28 lb. Bond) - 500 sheets: A4, 81/2 × 11 or smaller
- 250 sheets: B4 JIS, 81/2 × 14 or larger
Item Specification Staple capacity (80 g/m2, 20 lb. Bond): 30 sheets:
A3 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8
1/2 × 13 LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 8K SEF
50 sheets:
A4 SEF/LEF, B5 JIS SEF/LEF, 8 1/2 × 11 SEF/LEF, 7 1/4 × 10 1/2 SEF/LEF, 16K SEF/LEF
30 sheets:
A3 SEF/ A4 LEF, B4 JIS SEF/ B5 JIS SEF, 11 × 17 SEF/8 1/2 × 11 SEFStack capacity after stapling (80 g/m2, 20 lb. Bond): × 11 SEF) Staple position: Top 1, Bottom 1, Left 2, Top 2 Power consumption: Dimensions (W × D × H): 546 × 523 × 170 mm (21.5 × 20.6 × 6.7 inches) Weight: Approx. 13 kg (28.7 lb.) (without punch unit) Approx. 17 kg (37.5 lb.) (with punch unit)
- Without Mixed Size:
- With Mixed Size:
- 2–9 sheets: 55–46 sets (A4 LEF, B5 JIS LEF, 8 1/2 × 11 LEF)
- 10–50 sheets: 45–10 sets (A4 LEF, B5 JIS LEF, 8 1/2 × 11LEF)
- 2–9 sheets: 55–27 sets (A4 SEF, B5 JIS SEF, 8 1/2
- 10– 50 sheets: 25–8 sets (A4 SEF, B5 JIS SEF, 8 1/2 × 11 SEF)
- 2–9 sheets: 55–27 sets (A3 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF)
- 10–30 sheets: 25–8 sets (A3 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF)
- 50 W or less (without punch unit) (Power is supplied from the main unit.)
- 60 W or less (with punch unit) (Power is supplied from the main unit.)
Finisher part specifications
Item Specification Type Case system Shift tray Yes No. of sheets which can be accommodated A4, 81/2×11 or smaller: 500 / height: lower than 57mm B4, 81/2×14 or larger: 250 / height: lower than 28.5mm Paper thicknesses which can be handled
52g/m2-300g/m2Up/down shift function No Left/right shift function Yes Stapling function Yes Punching function Option Remainder detection No Full-load detection Yes Paper detection No Power consumption Less than 47W (24V DC /2A)
Power source24V DC (supplied from main printer), 5V SC (generated by FIN board), SELV (super-low voltage secondary power supply)
Item Specification
No. of sheets which can be stitchedA3 SEF, B4 SEF, 11"×17" SEF, 81/2”×14” SEF, 81/2”×13” SEF, 81/4”×14” SEF, 81/4”×13” SEF: 30
A4 LEF / SEF, B5 LEF / SEF, 81/2"×11" LEF / SEF,
71/4"×101/2" LEF / SEF: 50
When loading mixed widths: 30
Sizes which can be stitchedA3 SEF, B4 SEF, 11"×17" SEF, 81/2”×14” SEF, 81/2”×13” SEF, 81/4”×14” SEF, 81/4”×13” SEF
Thicknesses which can be stitched52g/m2 -105g/m2
The quality for sheets of paper which are thinner than 64g/m2 is not guaranteed.
No. of sheets to be stitched decreases when sheets of paper are thicker than 64g/m2, depending on the weight.Stitching position Top, bottom, 2 positions on the left, 2 positions on the top Staple supply Refill charge to dedicated staple cartridge Stitching capacity 5000 / cartridge
Specifications
PUNCH UNIT PU3040 NA/EU/SC (D716)
Paper size:
Punch unit type Paper size 2 & 4 holes type: 2 holes SEF: A3, A4, B4 JIS, B5 JIS, 11 × 17, 8 1/2 × 14, 8 1/2
× 13, 8 1/2 × 11, 7 1/4 × 10 1/2, 8K, 16K2 & 4 holes type: 2 holes LEF: A4, B5 JIS, 8 1/2 × 11, 16K 2 & 4 holes type: 4 holes SEF: A3, 11 × 17 2 & 4 holes type: 4 holes LEF: A4, 8 1/2 × 11 4 holes type: 4 holes SEF: A3, A4, B4 JIS, B5 JIS, 11 × 17, 8 1/2 × 14, 8 1/2
× 13, 8 1/2 × 11, 7 1/4 × 10 1/24 holes type: 4 holes LEF: A4, B5 JIS, 8 1/2 × 11 2 & 3 holes type: 2 holes SEF: A3, 11 × 17, 8 1/2 × 14, 8 1/2 × 13, 8 1/2 × 11, 7 1/4 × 10 1/2 2 & 3 holes type: 2 holes LEF: A4, 8 1/2 × 11 2 & 3 holes type: 3 holes SEF: A3, 11 × 17 2 & 3 holes type: 3 holes LEF: A4, 8 1/2 × 11
Paper weight:
60–169 g/m2 (16 lb. Bond –90 lb. Index)INTERNAL FINISHER SR3180 (D766)
Item Specification Paper size: A3 SEF, A4 LEF/SEF, B4 JIS SEF, B5 JIS LEF/SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 SEF, 8 1/2 × 11
LEF/SEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 7 1/4 × 10 1/2
LEF/SEF, 8K SEF, 16K LEF/SEF, custom sizePaper weight: 50–300 g/m2 (14 lb. Bond–110 lb. Cover) Paper sizes that can be shifted: A3 SEF, A4 LEF/SEF, B4 JIS SEF, B5 JIS LEF/SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 SEF, 8 1/2 × 11
LEF/SEF, 8K SEF, 16K LEF/SEF, custom sizePaper weight that can be shifted: 64–80 g/m2 (17–20 lb. Bond) Stack capacity (80 g/m2, 20 lb. Bond): A4 LEF, B5 JIS LEF/SEF, 81/2 × 11 LEF/SEF
A3 SEF to A4 SEF, B4 JIS SEF, 81/2 × 14 SEF, 11 × 17 SEFStapling paper size: A3 SEF, A4 LEF/SEF, B4 JIS SEF, B5 JIS LEF/SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 SEF, 8 1/2 × 11
LEF/SEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 7 1/4 × 10 1/2 LEF/SEF, 8K SEF, 16K LEF/SEFStapling paper weight: 64–80 g/m2 (17–20 lb. Bond) Stapling capacity (80 g/m2, 20 lb. Bond): 5 sheets:
A3 SEF, A4 LEF/SEF, B4 JIS LEF/SEF, B5JIS LEF/SEF, 11×17 SEF, 8 1/2×14 SEF, 8 1/2×13 SEF 81/2×11
LEF/SEF, 8 4/1×14SEF, 8 1/4×13 SEF, 7 1/4×10 1/2 LEF/ SEF, 8K SEF, 16K LEF SEFStack capacity after stapling (80 g/m2, 20 lb. Bond): - 250 sheets or more:
- 125 sheets:
- 30 sets or more (A4 LEF, 81/2 × 11 LEF)
- 20 sets or more (B5 JIS LEF/SEF)
- 15 sets or more (A3 SEF- A4 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 11 SEF)
Item Specification Staple position: Bottom Slant Power consumption: 30 W or less Dimensions (W × D × H): 435 × 515 × 150 mm (17.2 × 20.3 × 6.0 inches) Weight: Approx. 10 kg (22.1 lb.)
Specifications
Item Specification Type Case system Shift tray Yes No. of sheets which can be accommodated A4, 81/2×11 or smaller: 250 B4, 81/2×14 or larger: 125 Paper thicknesses which can be handled
52g/m2-300g/m2Up/down shift function No Left/right shift function Yes Stapling function Yes Punching function No Remainder detection No Full-load detection Yes Paper detection No Power consumption Less than 30W
Power source24V DC (supplied from main frame), 5V SC (generated by FIN board), SELV (super-low voltage secondary power supply)
Item Specification No. of sheets which can be stitched
2 to 5 sheetsSizes which can be stitched A3 SEF - B5 SEF / DLT SEF - LT SEF Thicknesses which can be stitched
54g/m2-80g/m2Stitching position 1 position (Top Slant) Staple supply No Stitching capacity No
WeightLess than 1.4 kg
(not including packaging materials and other items in package)Service life 1200k sheets or 5 years
*1 80g/m2 or less (paper exceeding 80g/m2 is calculated by weight)
*2 Up to 1280 mm in SP mode.
Specifications
BOOKLET FINISHER SR3220 (D3B9)
Item Specification Paper size for the finisher upper tray A3 SEF, B4 JIS SEF, A4 SEF/LEF B5 JIS SEF/LEF, A5 SEF/LEF, B6 JIS SEF, A6 SEF, 12 × 18 SEF, 11 × 17
SEF, 11 × 15 SEF, 10 × 14 SEF, 8 1/2 × 14 SEF, 8 1/2 ×
13 LEF, 8 1/2 × 11 SEF/LEF, 8 1/4 × 14 SEF, 8 1/4 × 13
SEF, 8 × 13 SEF, 8 × 10 SEF, 5 1/2 × 8 1/2 SEF, 7 1/4 × 10 1/2 SEF/LEF, 8K SEF, 16K SEF/LEF, SRA3 SEF,
SRA4 SEF/LEF, 8 1/2 × 13 2/5 LEF, custom sizePaper weight for the finisher upper tray: 52–169 g/m2 (14 lb. Bond–90 lb. Index) Stack capacity for the finisher upper tray (80 g/m2, 20 lb.
Bond):250 sheets: A4, 81/2 × 11 or smaller 50 sheets: B4 JIS, 81/2 × 14 or larger Paper size for the finisher shift tray: A3 SEF, B4 JIS SEF, A4 SEF/LEF, B5 JIS/LEF, A5 SEF/LEF, B6 JIS SEF, A6 SEF, 12 × 18 SEF, 11 × 17
SEF, 8 × 13 SEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 5 1/2 × 8 1/2 SEF, 8K SEF, 16K SEF/LEF, SRA3 SEF,
SRA4 SEF/LEF, 8 1/2 × 13 2/5 LEF, custom sizePaper weight for the finisher shift tray: 52–300 g/m2 (14 lb. Bond–110 lb. Cover) Paper sizes that can be shifted when delivered to the finisher shift tray: A3 SEF, A4 SEF/LEF, A5 SEF, B4 JIS SEF, B5 JIS SEF, B6 JIS SEF, 12 × 18 SEF, 11 × 17 SEF, 11 × 15 SEF, 10
× 14 SEF, 8 1/2 × 14 SEF, 8 1/2 × 13 LEF, 8 1/2 × 11
SEF/LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 8 × 13 SEF, 8
× 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 5 1/2 × 8 1/2 SEF, 8K SEF, 16K SEF/LEF SRA4 LEF, 8 1/2 × 13 2/5 LEFPaper weight that can be shifted when delivered to the finisher shift tray: 52–300 g/m2 (14 lb. Bond–110 lb. Cover) Item Specification Stack capacity for the finisher shift tray (80 g/m2, 20 lb.
Bond):1,000 sheets: A4, 81/2 × 14 or smaller 500 sheets: B4 JIS, 81/2 × 14 or larger Staple paper size: A3 SEF, B4 JIS SEF, A4 SEF/LEF, B5 JIS SEF/LEF, 11 × 17 SEF, 11 × 15 SEF, 10 × 14 SEF, 8 1/2 × 14 SEF, 8 1/2
× 11 SEF/LEF, 7 1/4 × 10 1/2 SEF/LEF, 8 × 13 SEF, 8B
1/2 × 13 LEF, 8 1/4 × 14 SEF, 8 1/4 × 13 SEF, 8 × 10 SEF, 12 × 18 SEF, 8K SEF, 16K SEF/LEF, 8 1/2 × 13 2/5
LEF, custom sizeStaple paper weight: 52–105 g/m2 (14-28 lb. Bond)
You can use two sheets of paper weighing up to 216 g/m2 (80 lb. Cover) per set as cover sheets.Staple capacity (80 g/m2, 20 lb. Bond): 30 sheets:
× 13 SEF, 8 1/2 × 13 LEF, 8 1/4 × 14 SEF, 8 1/4 × 13
SEF, 11 × 15 SEF, 10 × 14 SEF, 8K SEF, 12 × 18 SEF, 8 1/2 × 13 2/5 LEF
50 sheets:
A4 SEF/LEF, B5 JIS SEF/LEF, 8 1/2 × 11 SEF/LEF, 8 × 10 SEF, 7 1/4 × 10 1/2 SEF/LEF, 16K SEF/LEF
22 sheets:
A3 SEF/A4 LEF, B4 JIS SEF/B5 JIS SEF, 11 × 17 SEF/8 1/2 × 11 SEF- Without Mixed Size:
- With Mixed Size:
Item Specification Stack capacity after stapling (80 g/m2, 20 lb. Bond): × 11 LEF) Staple position: 3 positions (Top, Bottom, 2 Staples) Saddle stitch paper size: A3 SEF, A4 LEF, B4 JIS SEF, B5 JIS LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 11 LEF, 12 × 18 SEF Saddle stitch paper weight: 52–105 g/m2 (14–28 lb. Bond) Saddle stitch capacity (80 g/m2, 20 lb. Bond): 1 set (15 sheets) Stack capacity after saddle stitching (80 g/m2, 20 lb.
Bond):2–5 sheets: Approx. 20 sets
6–10 sheets: Approx. 10 sets
11–15 sheets: Approx. 7 setsSaddle stitch position: Center 2 positions Types of folds: Half Fold Half fold paper size: A3 SEF, A4 LEF, B4 JIS SEF, B5 JIS LEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 11 LEF, 12 × 18 SEF, 8 1/2 × 13
2/5 LEFHalf fold paper weight: 52–105 g/m2 (14–28 lb.Bond) Power consumption: 35.4 W (Power is supplied from the main unit.)
- 2–9 sheets: 100 sets (A4 LEF, B5 JIS LEF, 8 1/2
- 10–50 sheets: 100–20 sets (A4 LEF, B5 JIS LEF, 8 1/2 × 11 LEF)
- 10–50 sheets: 50–10 sets (A4 SEF, B5 JIS SEF, 8 1/2 × 11 SEF)
- 2–9 sheets: 50 sets (A3 SEF, A4 SEF, B4 JIS SEF, B5 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF, 8 1/2 × 11 SEF)
- 10–30 sheets: 50–10 sets (A3 SEF, B4 JIS SEF, 11 × 17 SEF, 8 1/2 × 14 SEF)
- With Mixed Size:
- 2–22 sheets: 22 sets (A3 SEF/ A4 LEF, B4 JIS SEF/B5 JIS SEF, 11 × 17 SEF/8 1/2 × 11 SEF)
- Specifications
Item Specification Dimensions (W × D × H): 575 × 620 × 960 mm (22.6 × 24.5 × 37.8 inches)
658 × 620 × 960 mm (25.9 × 24.5 × 37.8 inches)Weight: Approx. 42 kg (92.6 lb.) - Tray is folded:
- Tray is extended:
PUNCH UNIT PU3050 NA/EU/SC (D717)
Paper size:
Punch unit type Paper size 2 & 4 holes type: 2 holes SEF: A3, B4 JIS, A4, B5 JIS, A5, 11 × 17, 8 1/2 × 14, 8
1/2 × 11, 5 1/2 × 8 1/2, 7 1/4 × 10 1/2, 8 × 13, 8 1/2 ×
13, 8 1/4 × 13, 8K, 16K, 8 1/4 × 14, 8 × 10, 11 × 15, 10
× 142 & 4 holes type: 2 holes LEF: A4, B5 JIS, A5, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K 2 & 4 holes type: 4 holes SEF: A3, B4 JIS, 11 × 17, 11 × 15, 8K 2 & 4 holes type: 4 holes LEF: A4, B5 JIS, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K 4 holes type: 4 holes SEF: A3, B4 JIS, A4, B5 JIS, A5, 11 × 17, 8 1/2 × 14, 8
× 144 holes type: 4 holes LEF: A4, B5 JIS, A5, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K 2 & 3 holes type: 2 holes SEF: A3, B4 JIS, B5 JIS, A5, 11 × 17, 8 1/2 × 14, 8 1/2
× 11, 5 1/2 × 8 1/2, 7 1/4 × 10 1/2, 8 × 13, 8 1/2 × 13, 8
1/4 × 13, 8K, 16K, 8 1/4 × 14, 8 × 10, 11 × 15, 10 × 142 & 3 holes type: 2 holes LEF: A4, B5 JIS, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K 2 & 3 holes type: 3 holes SEF: A3, B4 JIS, 11 × 17, 11 × 15, 10 × 14, 8K 2 & 3 holes type: 3 holes LEF: A4, B5 JIS, 8 1/2 × 11, 7 1/4 × 10 1/2, 16K
Paper weight:
Specifications
52–256 g/m2 (14 lb. Bond–140 lb. Index)
BANNER PAPER GUIDE TRAY TYPE M19 (D3BF)
Item | Specification |
Dimensions (W × D × H): | Main Tray Tray is folded: 370 × 250 × 70 mm (14.6 × 9.8 × 2.8 inches) Tray is expanded: 370 × 250 × 250 mm (14.6 × 9.8 × 9.8 inches) Sub Tray Tray is folded: 150 × 110 × 15 mm (5.9 × 4.3 × 0.6 inches) Tray is expanded: 150 × 110 × 100 mm (5.9 × 4.3 × 3.9 inches) Lock Plate Locked: 135 × 150 × 25 mm (5.3 × 5.9 × 1.0 inches) Unlocked: 135 × 220 × 25 mm (5.3 × 8.7 × 1.0 inches) |
Weight: | Main Tray: 942 g (2.0 lb.) Sub Tray: 245 g (0.5 lb.) Lock Plate: 280 g (0.6 lb.) |
RE V IS ION H IST ORY | ||
APPENDIX: PREVENTIVE MAINTENANCE
Preventive Maintenance
PREVENTIVE MAINTENANCE ITEMS
- Yield Parts:
Some of the parts mentioned in these tables have a target yield. However, the total copy/print volume made by the machine will not reach the target yield within the machine's targeted lifetime if the machine is used under the target usage conditions (ACV, color ratio, P/J, and C/O). So, these parts are categorized not as PM parts but as yield parts (EM parts).
Chart: A4 (LT)/5% image coverage ratio Mode: 2 copies/original (prints/job) Color ratio: 20%
Environment: Normal temperature and humidity
Yield may change depending on circumstances and print conditions. Symbol keys: C: Clean, R: Replace, L: Lubricant, I: Inspect
Mainframe
The PM count for the following items is based on sheets of copy paper:
ItemPM
Parts
Cycle
EM
RemarksScanner
Exposure glass
C 300K
CClean with a cleaning cloth.
Do not clean with alcohol. Doing so may leave a whitish trace that affects image scanning.
Sheet-through exposure glass
C 300K
Do not clean with alcohol. Doing so may leave a whitish trace that affects image scanning.PCDU
ItemPM
Parts
Cycle
EM
Remarks
PCU(K)
R 60K
PCU(C,M,Y)
-R 48K
Development unit (K)
R 180K
PM parts: only for MP C2504Development unit (C,M,Y)
-R 120K
Waste toner bottle
R 100K
-Target yield (number of sheets) is only a guide and it is possible to collect up to 1,200,000 mg of waste toner. Full detection is a mechanical detection by a feeler. Replace when waste toner bottle full is detected. Transfer Image transfer cleaning unit
-R 240K
Image transfer belt unit
-R 240K
Paper transfer roller unit
-R 240K
-Fusing
Fusing sleeve belt unit
-R 240K
-Fusing entrance guide plate
Remove toner depositsFusing exit guide plate - - C Remove toner deposits Stripper plate - - C Remove toner deposits
ItemPM
Parts
Cycle
EM
Remarks
Pressure roller
-R 240K
Bearing: Pressure roller
-R/L 240K
-Lubricate with FLUTORIBO MG GREASE: 100G
Thermopile
-C 400K
Dry clothPressure roller gears - - R Replace if worn out Idler gear - - R Replace if worn out Fusing exit roller - - C Damp cloth Miscellaneous
Ozone filter/Dust filter
-R 300K
-Dust shield glass - - C Damp cloth
TM/ID sensor
CDamp cloth
Do not use a dry cloth that can cause static electricity.Paper feed Registration roller - - C Damp cloth
Registration sensor
CRemove toner and paper dust, Dry cloth Paper dust collection unit
Remove toner and paper dustTransport roller - - C Damp cloth
Transport sensor
Feed roller
ItemPM
Parts
Cycle
EM
Remarks
Separation roller
Pick-up roller
CRemove toner and paper dust, Dry cloth Duplex/Bypass/Exit
Duplex entrance sensor
Duplex exit sensor
CRemove toner and paper dust, Dry cloth Duplex transport roller - - C Damp cloth Duplex exit roller - - C Damp cloth Duplex entrance roller1, 2
Damp clothBypass paper feed roller - - C Damp cloth Bypass separation roller - - C Damp cloth Bypass pick-up roller - - C Damp cloth Bypass transport roller - - C Damp cloth Reverse roller - - C Damp cloth
Reverse sensor
CRemove toner and paper dust, Dry cloth Paper exit roller - - C Damp cloth
Paper exit sensor
ARDF DF3090
Item Cycle EM Remarks
Pick-up rollerR 120K
CWipe with a cloth dampened with ethyl alcohol.
Feed beltR 120K
CWipe with a cloth dampened with ethyl alcohol or water.
Separation rollerR 120K
CWipe with a cloth dampened with ethyl alcohol. Sensors - C Clean with a blower brush. Platen sheet - C Wipe with a cloth dampened with ethyl alcohol. Other rollers - C Scanner guide plate - C
SPDF DF3100
Feed beltR 120K
CIS (Glass area)
Do not clean with alcohol. Doing so may leave a whitish trace that affects image scanning.Sensors - C Clean with a blower brush. Item Cycle EM Remarks Gears - L Lubricate with Silicone Grease G-501 when noise occurred. Platen sheet - C Wipe with a cloth dampened with ethyl alcohol. Other rollers - C Scanner guide plate - C
Paper Feed Unit PB3220/PB3210
Item EM Remarks Paper feed roller C Wipe with a cloth dampened with ethyl alcohol. Pick-up roller C Wipe with a cloth dampened with ethyl alcohol. Separation roller C Wipe with a cloth dampened with ethyl alcohol. Relay rollers C Wipe with a cloth dampened with ethyl alcohol. Bottom plate pad C Remove dust with a dry cloth. Sensors C Remove dust with a dry cloth.
1 Bin Tray BN3110
Item EM Remarks Rollers C Wipe with a cloth dampened with ethyl alcohol.
Copy tray
CClean with a damp cloth, and then wipe with a dry cloth. Sensors C Clean with a blower brush.
Bridge Unit BU3070
Internal Shift Tray SH3070
Item EM Remarks
Exit Tray
Side Tray Type M3
Item EM Remarks Rollers C Wipe with a cloth dampened with ethyl alcohol. Sensors C Remove dust with a dry cloth.
Booklet Finisher SR3220/Punch Unit PU3050
Rollers
Quenching brush
CClean with a dry cloth if dirt adheres to it. Sensors - C Clean with a blower brush.
Stapler (Corner)
R 4000K
CReplace when the staple counter in the logging data reaches 500k.
Staple a few times for a test after replacement.Item Cycle EM Remarks
Booklet StaplerR 4000K
CReplace when the staple counter in the logging data reaches 200k.
PunchR 3000K
CRemove paper dust in the transport unit.
Punch wasteC 300K
CDiscard punch waste when hopper full is detected.
Internal Finisher SR3130
Item EM Remarks Rollers C Wipe with a cloth dampened with ethyl alcohol. Sensors C Clean with a blower brush.
Stapler
RReplace when the staple counter in the logging data reaches 200k.
Internal Finisher SR3180
Stapler
RE V IS ION H IST ORY Page Date Added/ Updated/ New None
APPENDIX: ENGINE SP MODE TABLES
Engine SP Mode Tables
- Yield Parts:
ENGINE SP TABLES - SP1000-1
SP1-XXX (FEED)
1001 [Leading Edge Registration] 1-001-001 Tray1: Thin *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-002 Tray1: Plain *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-003 Tray1: Mid-thick *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-004 Tray1: Thick 1 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-005 Tray1: Thick 2 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-006 Tray1: Thick 3 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-007 Tray1: Thick 4 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-008 Tray2/3/4/5/LCT: Thin *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-009 Tray2/3/4/5/LCT: Plain *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-010 Tray2/3/4/5/LCT: Mid-thick *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-011 Tray2/3/4/5/LCT: Thick 1 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-012 Tray2/3/4/5/LCT: Thick 2 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-013 Tray2/3/4/5/LCT: Thick 3 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-014 Tray2/3/4/5/LCT: Thick 4 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-015 By-pass: Thin *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-016 By-pass: Plain *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-017 By-pass: Mid-thick *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-018 By-pass: Thick 1 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-019 By-pass: Thick 2 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-020 By-pass: Thick 3 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-021 By-pass: Thick 4 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-022 Duplex: Thin *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-023 Duplex: Plain *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-024 Duplex: Mid-thick *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-025 Duplex: Thick 1 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-026 Duplex: Thick 2 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-027 Duplex: Thick 3 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-028 Tray1: Thin:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-029 Tray1: Plain:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-030 Tray1: Mid-thick:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-031 Tray1: Thick 1:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-032 Tray1: Thick 2:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-033 Tray1: Thick 3:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-034 Tray1: Thick 4:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-035 Tray2/3/4/5/LCT: Thin:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-036 Tray2/3/4/5/LCT: Plain:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-037 Tray2/3/4/5/LCT: Mid-thick:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-038 Tray2/3/4/5/LCT: Thick 1:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-039 Tray2/3/4/5/LCT: Thick 2:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-040 Tray2/3/4/5/LCT: Thick 3:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-041 Tray2/3/4/5/LCT: Thick 4:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-042 By-pass: Thin:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-043 By-pass: Plain:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-044 By-pass: Mid-thick:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-045 By-pass: Thick 1:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-046 By-pass: Thick 2:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-047 By-pass: Thick 3:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-048 By-pass: Thick 4:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-049 Duplex: Thin:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-050 Duplex: Plain:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-051 Duplex: Mid-thick:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-052 Duplex: Thick 1:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-053 Duplex: Thick 2:1200 *ENG [-9 to 9 / 0 / 0.1mm/step] 1-001-054 Duplex: Thick 3:1200 *ENG [-9 to 9 / 0 / 0.1mm/step]
1002 [Side-to-Side Registration] 1-002-001 By-pass Tray ENG [-4 to 4 / 0 / 0.1mm/step] 1-002-002 Paper Tray 1 ENG [-4 to 4 / 0 / 0.1mm/step] 1-002-003 Paper Tray 2 ENG [-4 to 4 / 0 / 0.1mm/step] 1-002-004 Paper Tray 3 ENG [-4 to 4 / 0 / 0.1mm/step] 1-002-005 Paper Tray 4 ENG [-4 to 4 / 0 / 0.1mm/step] 1-002-006 Duplex *ENG [-4 to 4 / 0 / 0.1mm/step] 1-002-007 Large Capacity Tray *ENG [-4 to 4 / 0 / 0.1mm/step]
1003 [Paper Buckle] 1-003-001 Paper Tray1: Thin *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-002 Paper Tray1: Plain *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-003 Paper Tray 1: Mid-thick *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-004 Paper Tray1: Thick1 *ENG [-4 to 5 / -3.5 / 0.1mm/step] 1-003-005 Tray2/3/4/5/LCT: Thin *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-006 Tray2/3/4/5/LCT: Plain *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-007 Tray 2/3/4/5/LCT: Mid-thick *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-008 Tray2/3/4/5/LCT: Thick 1 *ENG [-4 to 5 / -3.5 / 0.1mm/step] 1-003-009 By-pass: Thin *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-010 By-pass: Plain *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-011 By-pass: Mid-thick *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-012 By-pass:Thick1 *ENG [-4 to 5 / -3 / 0.1mm/step] 1-003-013 Duplex:Thin *ENG [-4 to 5 / -1.5 / 0.1mm/step] 1-003-014 Duplex lain
*ENG [-4 to 5 / -1.5 / 0.1mm/step] 1-003-015 Duplex: Mid-thick *ENG [-4 to 5 / -1.5 / 0.1mm/step] 1-003-016 Duplex:Thick1 *ENG [-4 to 5 / -3.5 / 0.1mm/step] 1-003-017 Paper Tray1: Thin:1200 *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-018 Paper Tray1: Plain:1200 *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-019 Paper Tray 1: Mid-thick:1200 *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-020 Paper Tray1: Thick1:1200 *ENG [-4 to 5 / -3.5 / 0.1mm/step] 1-003-021 Tray2/3/4/5/LCT: Thin:1200 *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-022 Tray2/3/4/5/LCT: Plain:1200 *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-023 Tray2/3/4/5/LCT: Mid:1200 *ENG [-4 to 5 / 0 / 0.1mm/step]
1-003-024Tray2/3/4/5/LCT: Thick 1:1200 *ENG
[-4 to 5 / -3.5 / 0.1mm/step]1-003-025 By-pass: Thin:1200 *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-026 By-pass: Plain:1200 *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-027 By-pass: Mid-thick:1200 *ENG [-4 to 5 / 0 / 0.1mm/step] 1-003-028 By-pass:Thick1:1200 *ENG [-4 to 5 / -3 / 0.1mm/step] 1-003-029 Duplex:Thin:1200 *ENG [-4 to 5 / -1.5 / 0.1mm/step] 1-003-030 Duplex lain:1200
*ENG [-4 to 5 / -1.5 / 0.1mm/step] 1007 [By-Pass Size Detection] 1-007-001 Switch LT SEF/LG SEF *ENG [0 or 1 / 0 / 1/step] 0:OFF
1:ON1-007-002 By-Pass Jam Detection Set *ENG [0 or 1 / 0 / 1/step]
0: Normal Detection
1: Simple Detection
1-003-031 Duplex: Mid-thick:1200 *ENG [-4 to 5 / -1.5 / 0.1mm/step] 1-003-032 Duplex:Thick1:1200 *ENG [-4 to 5 / -3.5 / 0.1mm/step]
1009 [Initial Operation Setting] 1-009-001 Registration Gear Backlash Cut *ENG [0 to 1 / 0 / 1/step] 1009 [Operation Setting] 1-009-002 Paper Exit Speed *ENG [0 to 1 / 1 / 1/step] 1009 [Pickup SOL Separate Setting] 1-009-003 Paper Tray1: Thin *ENG [0 to 1 / 1 / 1/step] 1-009-004 Paper Tray1: Plain *ENG [0 to 1 / 1 / 1/step] 1-009-005 Paper Tray1: Thick *ENG [0 to 1 / 1 / 1/step] 1-009-006 Paper Tray2: Thin *ENG [0 to 1 / 1 / 1/step] 1-009-007 Paper Tray2: Plain *ENG [0 to 1 / 1 / 1/step] 1-009-008 Paper Tray2: Thick *ENG [0 to 1 / 1 / 1/step] 1-009-009 Paper Tray3: Thin *ENG [0 to 1 / 1 / 1/step] 1-009-010 Paper Tray3: Plain *ENG [0 to 1 / 1 / 1/step] 1-009-011 Paper Tray3: Thick *ENG [0 to 1 / 1 / 1/step] 1-009-012 Paper Tray4: Thin *ENG [0 to 1 / 1 / 1/step] 1-009-013 Paper Tray4: Plain *ENG [0 to 1 / 1 / 1/step] 1-009-014 Paper Tray4: Thick *ENG [0 to 1 / 1 / 1/step] 1-009-015 Paper LCT: Thin *ENG [0 to 1 / 1 / 1/step] 1-009-016 Paper LCT: Plain *ENG [0 to 1 / 1 / 1/step] 1-009-017 Paper LCT: Thick *ENG [0 to 1 / 1 / 1/step]
1101 [Operation Setting] 1-009-018 Pre-rotation Start Temp. *ENG [0 to 3 / 1 / 1/step]
SP1-XXX (FUSING)
1101 | [Reload Permit Setting] | ||
1-101-001 | Pre-rotation Start Temp. | *ENG | [0 to 200 / 0 / 1deg/step] |
1-101-002 | Reload Target Temp.:Center | *ENG | [0 to 190 / 114 / 1deg/step] |
1-101-003 | Reload Target Temp. | *ENG | [0 to 200 / 120 / 1deg/step] |
1-101-004 | Temp. | *ENG | [4 to 200 / * / 1deg/step] *NA: 27, EU: 31, Asia: 31, CHN: 31, TWN: 27, KOR: 31 |
1-101-005 | Temp. | *ENG | [4 to 200 / * / 1deg/step] *NA: 27, EU: 31, Asia: 31, CHN: 31, TWN 27, KOR: 31 |
1-101-006 | Temp. | *ENG | [4 to 200 / 110 / 1deg/step] |
1-101-007 | Forced Reload Time:Cold | *ENG | [0 to 100 / 15 / 0.1sec/step] |
1-101-008 | Temp. | *ENG | [4 to 200 / 6 / 1deg/step] |
1-101-009 | Temp. | *ENG | [4 to 200 / 6 / 1deg/step] |
1-101-010 | Temp. | *ENG | [4 to 200 / 110 / 1deg/step] |
1-101-011 | Forced Reload Time:Low Power | *ENG | [0 to 100 / 15 / 0.1sec/step] |
1-101-012 | Temp. | *ENG | [4 to 200 / 6 / 1deg/step] |
1-101-013 | Temp. | *ENG | [4 to 200 / 6 / 1deg/step] |
1-101-014 | Temp. | *ENG | [4 to 200 / 110 / 1deg/step] |
1-101-015 | Forced Reload Time:Hot | *ENG | [0 to 100 / 15 / 0.1sec/step] |
1-101-016 | Temp. | *ENG | [4 to 200 / * / 1deg/step] *NA: 42, EU: 46, Asia: 46, CHN: 46, TWN: 42, KOR: 46 |
1-101-017 | Temp. | *ENG | [4 to 200 / * / 1deg/step] *NA: 42, EU: 46, Asia: 46, CHN: 46, TWN: 42, KOR: 46 |
1-101-018 | Temp. | *ENG | [4 to 200 / 110 / 1deg/step] |
1-101-019 | Forced Reload Time:Cold:BW1/2 | *ENG | [0 to 100 / 15 / 0.1sec/step] |
1-101-101 | Reload Target Temp.:Center:Energy Saving | *ENG | [0 to 200 / * / 1deg/step] *NA: 116, EU: 114, Asia: 114, CHN: 114, TWN: 116, KOR: 114 |
1-101-102 | Reload Target Temp. | *ENG | [0 to 200 / 120 / 1deg/step] |
1-101-103 | Temp. | *ENG | [0 to 200 / * / 1deg/step] *NA: 34, EU: 42, Asia: 42, CHN: 42, TWN: 34, KOR: 42 |
1-101-104 | Temp. | *ENG | [0 to 200 / * / 1deg/step] *NA: 34, EU: 42, Asia: 42, CHN: 42, TWN: 34, KOR: 42 |
1-101-105 | Temp. | *ENG | [4 to 200 / 100 / 1deg/step] |
1-101-106 | Forced Reload Time:Cold:Energy Saving | *ENG | [0 to 100 / 30 / 0.1sec/step] |
1-101-151 | Temp. | *ENG | [4 to 200 / 6 / 1deg/step] |
1-101-152 | Temp. | *ENG | [4 to 200 / 6 / 1deg/step] |
1-101-153 | Temp. | *ENG | [4 to 200 / 70 / 1deg/step] |
1-101-154 | Forced Reload Time:Low Temp. | *ENG | [0 to 100 / 35 / 0.1sec/step] |
1-101-201 | Temp. | *ENG | [4 to 200 / * / 1deg/step] *NA: 30, EU: 34, Asia: 34, CHN: 34, TWN: 30, KOR: 34 |
1-101-202 | Temp. | *ENG | [4 to 200 / * / 1deg/step] *NA: 30, EU: 34, Asia: 34, CHN: 34, TWN: 30, KOR: 34 |
1-101-203 | Temp. | *ENG | [4 to 200 / 110 / 1deg/step] |
1-101-204 | Forced Reload Time:Cold:FIN-less/ADF-less | *ENG | [0 to 100 / 15 / 0.1sec/step] |
1-101-211 | Temp | *ENG | [4 to 200 / * / 1deg/step] *NA: 30, EU: 34, Asia: 34, CHN: 34, TWN: 30, KOR: 34 |
1-101-212 | Temp. | *ENG | [4 to 200 / * / 1deg/step] *NA: 30, EU: 34, Asia: 34, CHN: 34, TWN: 30, KOR: 34 |
1-101-213 | Temp. | *ENG | [4 to 200 / 110 / 1deg/step] |
1-101-214 | ForcedReloadTime:Cold:FIN-less/ADF-attached | *ENG | [0 to 100 / 15 / 0.1sec/step] |
1102 | [Feed Permit Setting] | ||
1-102-001 | Temp.:Lower Delta:Center | *ENG | [0 to 200 / * / 1deg/step] *NA: 33, EU: 38, Asia: 38, CHN: 38, TWN: 33, KOR: 38 |
1-102-002 | Temp.:Lower Delta:End | *ENG | [0 to 200 / * / 1deg/step] *NA: 33, EU: 38, Asia: 38, CHN: 38, TWN: 33, KOR: 38 |
1-102-003 | Temp.:Upper Delta:Center | *ENG | [0 to 200 / 40 / 1deg/step] |
1-102-004 | Temp.:Upper Delta:End | *ENG | [0 to 200 / 40 / 1deg/step] |
1-102-005 | Temp.:Lower Delta | *ENG | [0 to 200 / 90 / 1deg/step] |
1-102-006 | Rotation Time | *ENG | [0 to 100 / 0.65 / 0.01sec/step] |
1-102-007 | Temp.:Lower Delta:Center:Sp.1 | *ENG | [0 to 200 / 5 / 1deg/step] |
1-102-008 | Temp.:Lower Delta:End:Sp.1 | *ENG | [0 to 200 / 5 / 1deg/step] |
1-102-009 | Temp.:Upper Delta:Center:Sp.1 | *ENG | [0 to 200 / 30 / 1deg/step] |
1-102-010 | Temp.:Upper Delta:End:Sp.1 | *ENG | [0 to 200 / 30 / 1deg/step] |
1-102-011 | Temp.:Lower Delta | *ENG | [0 to 200 / 45 / 1deg/step] |
1-102-012 | Rotation Time:Sp.1 | *ENG | [0 to 200 / 0.65 / 0.01sec/step] |
1-102-013 | Temp.:Lower Delta:Center:Sp.2 | *ENG | [0 to 100 / 0 / 0.01sec/step] |
1-102-014 | Temp.:Lower Delta:End:Sp.2 | *ENG | [0 to 200 / 5 / 1deg/step] |
1-102-015 | Temp.:Upper Delta:Center:Sp.2 | *ENG | [0 to 200 / 15 / 1deg/step] |
1-102-016 | Temp.:Upper Delta:End:Sp.2 | *ENG | [0 to 200 / 15 / 1deg/step] |
1-102-017 | Temp.:Lower Delta | *ENG | [0 to 200 / 100 / 1deg/step] |
1-102-018 | Rotation Time:Sp2 | *ENG | [0 to 100 / 0.65 / 0.01sec/step] |
1-102-019 | Feed Permit Time | *ENG | [0 to 200 / 60 / 1sec/step] |
1-102-020 | Temp.:Lower Delta:Center | *ENG | [0 to 200 / 40 / 1deg/step] |
1-102-021 | Temp.:Lower Delta:End | *ENG | [0 to 200 / 40 / 1deg/step] |
1-102-022 | Temp.:Upper Delta:Center | *ENG | [0 to 200 / 30 / 1deg/step] |
1-102-023 | Temp.:Upper Delta:End | *ENG | [0 to 200 / 30 / 1deg/step] |
1-102-024 | Temp.:Lower Delta | *ENG | [0 to 200 / 38 / 1deg/step] |
1-102-025 | Temp.:Lower Delta | *ENG | [0 to 200 / 53 / 1deg/step] |
1-102-026 | Rotation Time | *ENG | [0 to 100 / 0.65 / 0.01sec/step] |
1-102-027 | Temp.:Lower Delta:Center | *ENG | [0 to 200 / 5 / 1deg/step] |
1-102-028 | Temp.:Lower Delta:End | *ENG | [0 to 200 / 5 / 1deg/step] |
1-102-029 | Temp.:Upper Delta:Center | *ENG | [0 to 200 / 30 / 1deg/step] |
1-102-030 | Temp.:Upper Delta:End | *ENG | [0 to 200 / 30 / 1deg/step] |
1-102-031 | Temp.:Lower Delta | *ENG | [0 to 200 / 34 / 1deg/step] |
1-102-032 | Temp.:Lower Delta | *ENG | [0 to 200 / 49 / 1deg/step] |
1-102-033 | Rotation Time | *ENG | [0 to 100 / 0.65 / 0.01sec/step] |
1-102-034 | Temp.:Lower Delta:Center | *ENG | [0 to 200 / 5 / 1deg/step] |
1-102-035 | Temp.:Lower Delta:End | *ENG | [0 to 200 / 5 / 1deg/step] |
1-102-036 | Temp.:Upper Delta:Center | *ENG | [0 to 200 / 15 / 1deg/step] |
1-102-037 | Temp.:Upper Delta:End | *ENG | [0 to 200 / 15 / 1deg/step] |
1-102-038 | Temp.:Lower Delta | *ENG | [0 to 200 / 100 / 1deg/step] |
1-102-039 | Temp.:Lower Delta | *ENG | [0 to 200 / 100 / 1deg/step] |
1-102-040 | Rotation Time | *ENG | [0 to 100 / 0.65 / 0.01sec/step] |
1-102-041 | Judgment Power A | *ENG | [0 to 2000 / * / 1W/step] *NA: 1304, EU: 1429, Asia: 1429, CHN: 1429, TWN: 1304, KOR: 1429 |
1-102-042 | Temp.:Lower Delta:Center | *ENG | [0 to 200 / 49 / 1deg/step] |
1-102-043 | Temp.:Lower Delta: | *ENG | [0 to 200 / 49 / 1deg/step] |
1-102-044 | Temp.:Upper Delta:Center | *ENG | [0 to 200 / 40 / 1deg/step] |
1-102-045 | Temp.:Upper Delta:End | *ENG | [0 to 200 / 40 / 1deg/step] |
1-102-046 | Temp.:Lower Delta | *ENG | [0 to 200 / 90 / 1deg/step] |
1-102-047 | Rotation Time | *ENG | [0 to 100 / 0.65 / 0.01sec/step] |
1-102-051 | Judgment Power B | *ENG | [0 to 2000 / * / 1W/step] *NA: 1284, EU: 1409, Asia: 1409, CHN: 1409, TWN: 1284, KOR: 1409 |
1-102-052 | Temp.:Lower Delta:Center | *ENG | [0 to 200 / 49 / 1deg/step] |
1-102-053 | Temp.:Lower Delta:End | *ENG | [0 to 200 / 49 / 1deg/step] |
1-102-054 | Temp.:Upper Delta:Center | *ENG | [0 to 200 / 40 / 1deg/step] |
1-102-055 | Temp.:Upper Delta:End | *ENG | [0 to 200 / 40 / 1deg/step] |
1-102-056 | Temp.:Lower Delta | *ENG | [0 to 200 / 90 / 1deg/step] |
1-102-057 | Rotation Time | *ENG | [0 to 100 / 0.65 / 0.01sec/step] |
1-102-060 | Waiting Time: Stabilize Temp. | *ENG | [0 to 10000 / 0 / 1msec/step] |
1-102-070 | Timeout: Cold: Normal | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-071 | Timeout: Hot: Normal | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-072 | Timeout: Cold: Power 1 | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-073 | Timeout: Hot: Power 1 | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-074 | Timeout: Cold: Power 2 | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-075 | Timeout: Hot: Power 2 | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-076 | Timeout: 10sec: 11 | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-077 | Timeout: 10sec: 15 | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-078 | Timeout: 10sec: 16 | *ENG | [0 to 20000 / 4000 / 1msec/step] |
1-102-101 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-102 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-103 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-104 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-105 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-106 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-107 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-108 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-109 | Temp.:Lower Delta | *ENG | [0 to 200 / 17 / 1deg/step] |
1-102-110 | Temp.:Lower Delta | *ENG | [0 to 200 / 17 / 1deg/step] |
1-102-111 | Temp.:Lower Delta | *ENG | [0 to 200 / 13 / 1deg/step] |
1-102-112 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-113 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-114 | Temp.:Lower Delta | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-121 | Timeout | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-122 | Timeout | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-123 | Timeout | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-124 | Timeout | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-125 | Timeout | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-126 | Timeout | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-127 | Timeout | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-128 | Timeout | *ENG | [0 to 200 / 0 / 1deg/step] |
1-102-129 | Timeout | *ENG | [0 to 60000 / 5000 / 1msec/step] |
1-102-130 | Timeout | *ENG | [0 to 60000 / 5000 / 1msec/step] |
1-102-131 | Timeout | *ENG | [0 to 60000 / 3000 / 1msec/step] |
1-102-132 | Timeout: Press: 11 | *ENG | [0 to 60000 / 0 / 1msec/step] |
1-102-133 | Timeout: Press: 15 | *ENG | [0 to 60000 / 0 / 1msec/step] |
1-102-134 | Timeout: Press: 16 | *ENG | [0 to 60000 / 0 / 1msec/step] |
1105 | [Print Target Temp.] | ||
1-105-001 | Plain1:FC:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 126 *MP C2504: 123 |
1-105-002 | Plain1:FC | *ENG | [0 to 200 / 122 / 1deg/step] |
1-105-003 | Plain1:BW:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 123 *MP C2504: 120 |
1-105-004 | Plain1:BW | *ENG | [0 to 200 / 122 / 1deg/step] |
1-105-005 | Plain2:FC:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 128 *MP C2504: 122 |
1-105-006 | Plain2:FC | *ENG | [0 to 200 / 122 / 1deg/step] |
1-105-007 | Plain2:BW:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 128 *MP C2504: 122 |
1-105-008 | Plain2:BW | *ENG | [0 to 200 / 122 / 1deg/step] |
1-105-009 | Thin:FC:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 121 *MP C2504: 118 |
1-105-010 | Thin:FC | *ENG | [0 to 200 / 121 / 1deg/step] |
1-105-011 | Thin:BW:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 121 *MP C2504: 118 |
1-105-012 | Thin:BW | *ENG | [0 to 200 / 121 / 1deg/step] |
1-105-013 | M-thick:FC:Center | *ENG | [100 to 180 / 136 / 1deg/step] |
1-105-014 | M-thick:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-015 | M-thick:BW:Center | *ENG | [100 to 180 / 136 / 1deg/step] |
1-105-016 | M-thick:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-017 | Thick1:FC:Center | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-018 | Thick1:FC | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-019 | Thick1:BW:Center | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-020 | Thick1:BW | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-021 | Thick2:FC:Center | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-022 | Thick2:FC | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-023 | Thick2:BW:Center | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-024 | Thick2:BW | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-025 | Thick3:FC:Center | *ENG | [100 to 180 / 137 / 1deg/step] |
1-105-026 | Thick3:FC | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-027 | Thick3:BW:Center | *ENG | [100 to 180 / 137 / 1deg/step] |
1-105-028 | Thick3:BW | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-029 | Special1:FC:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 126 *MP C2504: 123 |
1-105-030 | Special1:FC | *ENG | [0 to 200 / 117 / 1deg/step] |
1-105-031 | Special1:BW:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 123 *MP C2504: 120 |
1-105-032 | Special1:BW | *ENG | [0 to 200 / 117 / 1deg/step] |
1-105-033 | Special2:FC:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 131 *MP C2504: 128 |
1-105-034 | Special2:FC | *ENG | [0 to 200 / 122 / 1deg/step] |
1-105-035 | Special2:BW:Center | *ENG | [100 to 180 / * / 1deg/step] *MP C2004: 128 *MP C2504: 125 |
1-105-036 | Special2:BW | *ENG | [0 to 200 / 122 / 1deg/step] |
1-105-037 | Special3:FC:Center | *ENG | [100 to 180 / 136 / 1deg/step] |
1-105-038 | Special3:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-039 | Special3:BW:Center | *ENG | [100 to 180 / 136 / 1deg/step] |
1-105-040 | Special3:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-041 | Envelop:Center | *ENG | [100 to 180 / 142 / 1deg/step] |
1-105-042 | Envelop | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-051 | Special1:FC:Center:Middle Speed | *ENG | [100 to 180 / 122 / 1deg/step] |
1-105-052 | Special1:FC | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-053 | Special1:BW:Center:Middle Speed | *ENG | [100 to 180 / 122 / 1deg/step] |
1-105-054 | Special1:BW | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-055 | Special2:FC:Center:Middle Speed | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-056 | Special2:FC | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-057 | Special2:BW:Center:Middle Speed | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-058 | Special2:BW | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-059 | Special3:FC:Center:Middle Speed | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-060 | Special3:FC | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-061 | Special3:BW:Center:Middle Speed | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-062 | Special3:BW | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-101 | Plain1:FC:Center:Low Speed | *ENG | [100 to 180 / 115 / 1deg/step] |
1-105-102 | Plain1:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-103 | Plain1:BW:Center:Low Speed | *ENG | [100 to 180 / 115 / 1deg/step] |
1-105-104 | Plain1:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-105 | Plain2:FC:Center:Low Speed | *ENG | [100 to 180 / 120 / 1deg/step] |
1-105-106 | Plain2:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-107 | Plain2:BW:Center:Low Speed | *ENG | [100 to 180 / 120 / 1deg/step] |
1-105-108 | Plain2:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-109 | M-thick:FC:Center:Low Speed | *ENG | [100 to 180 / 122 / 1deg/step] |
1-105-110 | M-thick:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-111 | M-thick:BW:Center:Low Speed | *ENG | [100 to 180 / 122 / 1deg/step] |
1-105-112 | M-thick:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-113 | Thick1:FC:Center:Low Speed | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-114 | Thick1:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-115 | Thick1:BW:Center:Low Speed | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-116 | Thick1:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-117 | Special1:FC:Center:Low Speed | *ENG | [100 to 180 / 122 / 1deg/step] |
1-105-118 | Special1:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-119 | Special1:BW:Center:Low Speed | *ENG | [100 to 180 / 122 / 1deg/step] |
1-105-120 | Special1:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-121 | Special2:FC:Center:Low Speed | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-122 | Special2:FC | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-123 | Special2:BW:Center:Low Speed | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-124 | Special2:BW | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-125 | Plain1:Glossy:Center | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-126 | Plain1:Glossy | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-127 | Plain2:Glossy:Center | *ENG | [100 to 180 / 137 / 1deg/step] |
1-105-128 | Plain2:Glossy | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-129 | M-thick:Glossy:Center | *ENG | [100 to 180 / 142 / 1deg/step] |
1-105-130 | M-thick:Glossy | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-131 | OHP:Center | *ENG | [100 to 180 / 160 / 1deg/step] |
1-105-132 | OHP | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-133 | Envelop:Center:Low Speed | *ENG | [100 to 180 / 135 / 1deg/step] |
1-105-134 | Envelop | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-135 | Thin:FC:Center:Low Speed | *ENG | [100 to 180 / 110 / 1deg/step] |
1-105-136 | Thin:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-137 | Thin:BW:Center:Low Speed | *ENG | [100 to 180 / 110 / 1deg/step] |
1-105-138 | Thin:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-139 | Thick4:FC:Center | *ENG | [100 to 180 / 142 / 1deg/step] |
1-105-140 | Thick4:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-141 | Thick4:BW:Center | *ENG | [100 to 180 / 142 / 1deg/step] |
1-105-142 | Thick4:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-143 | Postcard:Center | *ENG | [100 to 180 / 124 / 1deg/step] |
1-105-144 | Postcard | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-145 | Special3:FC:Center:Middle Speed | *ENG | [100 to 180 / 142 / 1deg/step] |
1-105-146 | Special3:FC | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-147 | Special3:BW:Center:Middle Speed | *ENG | [100 to 180 / 142 / 1deg/step] |
1-105-148 | Special3:BW | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-149 | Mid Thick:Matte:Center | *ENG | [100 to 180 / 136 / 1deg/step] |
1-105-150 | Mid Thick:Matte | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-151 | Thick1:Matte:Center | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-152 | Thick1:Matte | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-153 | Thick2:Matte:Center | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-154 | Thick2:Matte | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-155 | Thick3:Matte:Center | *ENG | [100 to 180 / 137 / 1deg/step] |
1-105-156 | Thick3:Matte | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-157 | Thick4:Matte:Center | *ENG | [100 to 180 / 142 / 1deg/step] |
1-105-158 | Thick4:Matte | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-159 | Mid Thick:Matte:Center:Low Speed | *ENG | [100 to 180 / 122 / 1deg/step] |
1-105-160 | Mid Thick:Matte | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-161 | Thick1:Matte:Center:Low Speed | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-162 | Thick1:Matte | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-163 | Mid Thick:Glossy:Center | *ENG | [100 to 180 / 136 / 1deg/step] |
1-105-164 | Mid Thick:Glossy | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-165 | Thick1:Glossy:Center | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-166 | Thick1:Glossy | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-167 | Thick2:Glossy:Center | *ENG | [100 to 180 / 132 / 1deg/step] |
1-105-168 | Thick2:Glossy | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-169 | Thick3:Glossy:Center | *ENG | [100 to 180 / 137 / 1deg/step] |
1-105-170 | Thick3:Glossy | *ENG | [0 to 200 / 120 / 1deg/step] |
1-105-171 | Thick4:Glossy:Center | *ENG | [100 to 180 / 142 / 1deg/step] |
1-105-172 | Thick4:Glossy | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-173 | Mid Thick:Glossy:Center:Low Speed | *ENG | [100 to 180 / 122 / 1deg/step] |
1-105-174 | Mid Thick:Glossy | *ENG | [0 to 200 / 118 / 1deg/step] |
1-105-175 | Thick1:Glossy:Center:Low Speed | *ENG | [100 to 180 / 127 / 1deg/step] |
1-105-176 | Thick1:Glossy | *ENG | [0 to 200 / 118 / 1deg/step] |
1106 | [Fusing Temp. Display] | ||
1-106-001 | Heat Center | ENG | [-10 to 250 / 0 / 1deg/step] |
1-106-002 | Heat End | ENG | [-10 to 250 / 0 / 1deg/step] |
1-106-003 | Press Center | ENG | [-10 to 250 / 0 / 1deg/step] |
1107 | [Standby Target Temp. Setting] | ||
1-107-001 | Stanby/Preheat1:Center | *ENG | [0 to 125 / 90 / 1deg/step] |
1-107-003 | Preheat2:Center | *ENG | [0 to 200 / 90 / 1deg/step] |
1-107-005 | Low Power:Center | *ENG | [0 to 125 / 60 / 1deg/step] |
1-107-007 | Print Ready:Center | *ENG | [85 to 180 / * / 1deg/step] *MP C2004: 121 *MP C2504: 118 |
1-107-008 | Print Ready | *ENG | [0 to 200 / 120 / 1deg/step] |
1-107-011 | Standby Heater Off Time | *ENG | [0 to 100 / 0 / 1sec/step] |
1-106-004 | Press End | ENG | [-10 to 250 / 0 / 1deg/step] |
1-106-005 | Press End | ENG | [-10 to 250 / 0 / 1deg/step] |
1108 | [After Reload/Job Target Temp.] | ||
1-108-001 | Center | *ENG | [85 to 200 / * / 1deg/step] *MP C2004: 121 *MP C2504: 118 |
1-108-002 | Press | *ENG | [0 to 200 / 120 / 1deg/step] |
1-108-011 | Center:Energy Saving | *ENG | [85 to 200 / * / 1deg/step] *NA: 116, EU: 114, Asia: 114, CHN: 114, TWN: 116, KOR: 114 |
1-108-012 | Press:Energy Saving | *ENG | [0 to 200 / 120 / 1deg/step] |
1111 | [Environment Correction:Fusing] | ||
1-111-001 | Temp.: Threshold: Low | *ENG | [0 to 100 / 15 / 1deg/step] |
1-111-002 | Temp.: Threshold: High | *ENG | [0 to 100 / 30 / 1deg/step] |
1-111-003 | Low Temp. Correction | *ENG | [0 to 15 / 3 / 1deg/step] |
1-111-004 | High Temp. Correction | *ENG | [0 to 15 / 0 / 1deg/step] |
1-111-005 | Job Low Temp. Correction | *ENG | [0 to 10 / 0.6 / 0.1deg/step] |
