Kyocera 4012i photocopier refilled ink but still reported out of ink
Hello everyone, I have a question for you guys. Kyocera 4012i photocopier reports out of ink. I refilled the ink but it still shows an error. What's the problem? Anyone who has refilled the ink, please tell me how to fix it
Rosalind
Under the ink cartridge, there's a yellow sticker with a chip as small as a match head. Remove it and the ink will run out.
A
Antaram
You should replace the genuine Kyocera ink, otherwise the background will be dark and the black line on the 2nd side will be dark
K
Kaytlyn
Thank you, I ordered the genuine Kyocera ink cartridge
D
Donatella
After refilling the ink for this Kyocera 4012i series, you have to peel off the chip at the bottom of the ink cartridge and throw it away
I
Ingrid
Even if you stick 10 ink chips, it still won't work
Cara
Remove the chip under the ink cartridge, plus with this Konica line, just use genuine ink, don't use non-genuine ink, it will quickly damage the drum unit
