Ricoh MP C2004/C2504 Service Manual Part 28
2-110-001Error BkENG[0x0000 to 0xFFFF / 0x0000 / 1/step]
2-110-002Error MaENG[0x0000 to 0xFFFF / 0x0000 / 1/step]
2-110-003Error CyENG[0x0000 to 0xFFFF / 0x0000 / 1/step]
2-110-004Error YeENG[0x0000 to 0xFFFF / 0x0000 / 1/step]
2-110-005Writing Unit Adj. TransferENG[0 or 1 / 0 / 1/step]
2118​
2111[Forced Line Position Adj.]
2-111-001Mode aENG[0 or 1 / 0 / 1/step]
2-111-002Mode bENG[0 or 1 / 0 / 1/step]
2-111-003Mode cENG[0 or 1 / 0 / 1/step]
2-111-004Mode dENG[0 or 1 / 0 / 1/step]
2112[TM/ID Sensor Check]
2-112-001ExecuteENG[0 or 1 / 0 / 1/step]
2112[TM/ID Sensor Test]
2-112-010General:FCR*ENG[0 to 999 / 0 / 1/step]
2-112-020Threshold Setting*ENG[0 to 3.5 / 1.9 / 0.01-V/step]
2117[Skew Adjustment]
2-117-001Pulse: M*ENG[-75 to 75 / 0 / 1pulse/step]
2-117-002Pulse: C*ENG[-75 to 75 / 0 / 1pulse/step]
2-117-003Pulse: Y*ENG[-99 to 99 / 0 / 1pulse/step]
[Skew Adjustment]​
2-118-001Execute: MENG[0 or 1 / - / 1/step]
2-118-002Execute: CENG[0 or 1 / - / 1/step]
2-118-003Execute: YENG[0 or 1 / - / 1/step]
Engine SP Mode Tables
2119[Skew Adjustment Display]
2-119-001M*ENG[-75 to 75 / 0 / 1pulse/step]
2-119-002C*ENG[-75 to 75 / 0 / 1pulse/step]
2-119-003Y*ENG[-99 to 99 / 0 / 1pulse/step]
2120[Skew Adj Changing Line Speed]
2-120-001On/Off*ENG[0 or 1 / 0 / 1/step]
2121[Skew Adjust Coefficient]
2-121-001Coefficient*ENG[0 to 2 / 0 / 1/step]
2140[TM/ID Sensor Check Result]
2-140-005PWM: FrontENG[0 to 1023 / 0 / 1/step]
2-140-006PWM: Center*ENG[0 to 1023 / 0 / 1/step]
2-140-007PWM: Rear*ENG[0 to 1023 / 0 / 1/step]
2141[TM/ID Sensor Check Result]
2-141-005Average: Front*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-141-006Average: Center*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-141-007Average: Rear*ENG[0 to 5.5 / 0 / 0.01-V/step]
2142[TM/ID Sensor Check Result]
2-142-005Maximum: Front*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-142-006Maximum: Center*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-142-007Maximum: Rear*ENG[0 to 5.5 / 0 / 0.01-V/step]
2143[TM/ID Sensor Check Result]
2-143-005Minimum: Front*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-143-006Minimum: Center*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-143-007Minimum: Rear*ENG[0 to 5.5 / 0 / 0.01-V/step]
2144[TM/ID Sensor Check Result]
2-144-005Maximum 2: Front*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-144-006Maximum 2: Center*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-144-007Maximum 2: Rear*ENG[0 to 5.5 / 0 / 0.01-V/step]
2145[TM/ID Sensor Check Result]
2-145-005Minimum 2: Front*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-145-006Minimum 2: Center*ENG[0 to 5.5 / 0 / 0.01-V/step]
2-145-007Minimum 2: Rear*ENG[0 to 5.5 / 0 / 0.01-V/step]
2146[TM-Sensor Test]
2-146-005Number of Edge Detection:Front*ENG[0 to 16 / 0 / 1/step]
2-146-006Number of Edge Detection:Center*ENG[0 to 16 / 0 / 1/step]
2-146-007Number of Edge Detection:Rear*ENG[0 to 16 / 0 / 1/step]
2150[Area Mag. Correction]
2-150-027Area 0: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-028Area 1: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-029Area 2: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-030Area 3: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-031Area 4: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-032Area 5: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-033Area 6: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-034Area 7: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-035Area 8: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-036Area 9: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-037Area 10: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-038Area 11: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-039Area 12: Bk*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-079Area 0: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-080Area 1: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-081Area 2: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-082Area 3: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-083Area 4: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-084Area 5: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-085Area 6: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-086Area 7: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-087Area 8: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-088Area 9: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-089Area 10: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-090Area 11: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-091Area 12: Ma*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-131Area 0: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-132Area 1: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-133Area 2: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-134Area 3: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-135Area 4: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-136Area 5: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-137Area 6: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-138Area 7: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-139Area 8: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-140Area 9: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-141Area 10: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-142Area 11: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-143Area 12: Cy*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-183Area 0: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-184Area 1: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-185Area 2: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-186Area 3: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-187Area 4: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-188Area 5: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-189Area 6: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-190Area 7: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-191Area 8: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-192Area 9: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-193Area 10: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-194Area 11: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2-150-195Area 12: Ye*ENG[-16 to 16 / 0 / 0.01dot/step]
2152[Shad. Correct Setting]
2-152-001Standard Speed: Bk*ENG[50 to 120 / 100 / 0.1%/step]
2-152-002Standard Speed: Ma*ENG[50 to 120 / 100 / 0.1%/step]
2-152-003Standard Speed: Cy*ENG[50 to 120 / 100 / 0.1%/step]
2-152-004Standard Speed: Ye*ENG[50 to 120 / 100 / 0.1%/step]
2-152-005Middle Speed: Bk*ENG[50 to 120 / 100 / 0.1%/step]
2-152-006Middle Speed: Ma*ENG[50 to 120 / 100 / 0.1%/step]
2-152-007Middle Speed: Cy*ENG[50 to 120 / 100 / 0.1%/step]
2-152-008Middle Speed: Ye*ENG[50 to 120 / 100 / 0.1%/step]
2-152-009Low Speed: Bk*ENG[50 to 120 / 100 / 0.1%/step]
2-152-010Low Speed: Ma*ENG[50 to 120 / 100 / 0.1%/step]
2-152-011Low Speed: Cy*ENG[50 to 120 / 100 / 0.1%/step]
2-152-012Low Speed: Ye*ENG[50 to 120 / 100 / 0.1%/step]
2154[Shad. Correct Setting]
2-154-002Front End Area: Bk: LD1*ENG[50 to 150 / 100 / 0.1%/step]
2-154-003Front End Area: Bk: LD2*ENG[50 to 150 / 100 / 0.1%/step]
2-154-004Front End Area: Bk: LD3*ENG[50 to 150 / 100 / 0.1%/step]
2-154-005Front End Area: Bk: LD4*ENG[50 to 150 / 100 / 0.1%/step]
2-154-007Front End Area: Ma: LD1*ENG[50 to 150 / 100 / 0.1%/step]
2-154-008Front End Area: Ma: LD2*ENG[50 to 150 / 100 / 0.1%/step]
2-154-009Front End Area: Ma: LD3*ENG[50 to 150 / 100 / 0.1%/step]
2-154-010Front End Area: Ma: LD4*ENG[50 to 150 / 100 / 0.1%/step]
2-154-012Front End Area: Cy: LD1*ENG[50 to 150 / 100 / 0.1%/step]
2-154-013Front End Area: Cy: LD2*ENG[50 to 150 / 100 / 0.1%/step]
2-154-014Front End Area: Cy: LD3*ENG[50 to 150 / 100 / 0.1%/step]
2-154-015Front End Area: Cy: LD4*ENG[50 to 150 / 100 / 0.1%/step]
2-154-017Front End Area: Ye: LD1*ENG[50 to 150 / 100 / 0.1%/step]
2-154-018Front End Area: Ye: LD2*ENG[50 to 150 / 100 / 0.1%/step]
2-154-019Front End Area: Ye: LD3*ENG[50 to 150 / 100 / 0.1%/step]
2-154-020Front End Area: Ye: LD4*ENG[50 to 150 / 100 / 0.1%/step]
2160[Vertical Line Width]
2-160-001600dpi:Bk*ENG[10 to 15 / 15 / 1/step]
2-160-002600dpi:Ma*ENG[10 to 15 / 15 / 1/step]
2-160-003600dpi:Cy*ENG[10 to 15 / 15 / 1/step]
2-160-004600dpi:Ye*ENG[10 to 15 / 15 / 1/step]
2-160-0051200dpi:Bk*ENG[10 to 15 / 15 / 1/step]
2-160-0061200dpi:Ma*ENG[10 to 15 / 15 / 1/step]
2-160-0071200dpi:Cy*ENG[10 to 15 / 15 / 1/step]
2-160-0081200dpi:Ye*ENG[10 to 15 / 15 / 1/step]
2-160-009600dpi:Indet.:Bk*ENG[10 to 15 / 14 / 1/step]
2-160-0101200dpi:Indet.:Bk*ENG[10 to 15 / 15 / 1/step]
2180[Line Pos. Adj. Clear]
2-180-001Color Regist.ENG[0 or 1 / 0 / 1/step]
2-180-002Main Scan Length DetectionENG[0 or 1 / 0 / 1/step]
2-180-003MUSIC ResultENG[0 or 1 / 0 / 1/step]
2-180-004Area Magnification CorrectionENG[0 or 1 / 0 / 1/step]
2181[Line Position Adj. Result]
2-181-003Skew: M*ENG[-5000 to 5000 / 0 / 0.001um/step]
2-181-011M. Cor.: Dot: M*ENG[-512 to 511 / 0 / 1dot/step]
2-181-012M. Cor.: Subdot: M*ENG[-1 to 1 / 0 / 0.01dot/step]
2-181-013S. Cor.: 1200 Line: Middle: M*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-014S. Cor.: 1200 Sub: Middle: M*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-015M. Left Mag.: Subdot: M*ENG[-32 to 32 / 0 / 0.01dot/step]
2-181-016M. Right Mag.: Subdot: M*ENG[-32 to 32 / 0 / 0.01dot/step]
2-181-017S. Cor.: 1200 Line: Standard: M*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-018S. Cor.: 1200 Sub: Standard: M*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-019S. Cor.: 1200 Line: Low: M*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-020S. Cor.: 1200 Sub: Low: M*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-021Skew: C*ENG[-5000 to 5000 / 0 / 0.001 / um]
2-181-029M. Cor.: Dot: C*ENG[-512 to 511 / 0 / 1dot/step]
2-181-030M. Cor.: Subdot: C*ENG[-1 to 1 / 0 / 0.01dot/step]
2-181-031S. Cor.: 1200 Line: Middle: C*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-032S. Cor.: 1200 Sub: Middle: C*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-033C. Left Mag.: Subdot: M*ENG[-32 to 32 / 0 / 0.01dot/step]
2-181-034C. Right Mag.: Subdot: M*ENG[-32 to 32 / 0 / 0.01dot/step]
2-181-035S. Cor.: 1200 Line: Standard: C*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-036S. Cor.: 1200 Sub: Standard: C*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-037S. Cor.: 1200 Line: Low: C*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-038S. Cor.: 1200 Sub: Low: C*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-039Skew: Y*ENG[-5000 to 5000 / 0 / 0.001um/step]
2-181-047M. Cor.: Dot: Y*ENG[-512 to 511 / 0 / 1dot/step]
2-181-048M. Cor.: Subdot: Y*ENG[-1 to 1 / 0 / 0.01dot/step]
2-181-049S. Cor.: 1200 Line: Middle: Y*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-050S. Cor.: 1200 Sub: Middle: Y*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-051Y. Left Mag.: Subdot: M*ENG[-32 to 32 / 0 / 0.01dot/step]
2-181-052Y. Right Mag.: Subdot: M*ENG[-32 to 32 / 0 / 0.01dot/step]
2-181-053S. Cor.: 1200 Line: Standard: Y*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-054S. Cor.: 1200 Sub: Standard: Y*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-055S. Cor.: 1200 Line: Low: Y*ENG[-16384 to 16383 / 0 / 1line/step]
2-181-056S. Cor.: 1200 Sub: Low: Y*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-057S. Cor.: 600 Sub*ENG[-1 to 1 / 0 / 0.001line/step]
2-181-059S. Cor.: 1200 Sub :High*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-060S. Cor.: 1200 Sub :Low*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-061S. Cor.: 1200 Sub :Middle*ENG[-2 to 2 / 0 / 0.001line/step]
2-181-064M. Cor.: Dot: K*ENG[-512 to 511 / 0 / 1dot/step]
2-181-072LineSift: StandardSpeed: M*ENG[0 to 3 / 0 / 1line/step]
2-181-073LineSift: MidSpeed: M*ENG[0 to 1 / 0 / 1line/step]
2-181-074LineSift: StandardSpeed: C*ENG[0 to 3 / 0 / 1line/step]
2-181-075LineSift: MidSpeed: C*ENG[0 to 1 / 0 / 1line/step]
2-181-076LineSift: StandardSpeed: Y*ENG[0 to 3 / 0 / 1line/step]
2-181-077LineSift: MidSpeed: Y*ENG[0 to 1 / 0 / 1line/step]
2-181-080Detect Diff.: M*ENG[-1000 to 1000 / 0 / 0.1/step]
2-181-081Detect Diff.: C*ENG[-1000 to 1000 / 0 / 0.1/step]
2-181-082Detect Diff.: Y*ENG[-1000 to 1000 / 0 / 0.1/step]
2182[Line Position Adj. Offset]
2-182-004M. Scan: Standard: Dot: M*ENG[-512 to 511 / 0 / 1dot/step]
2-182-005M. Scan: Standard: Subdot: M*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-006M. Scan: Middle: Dot: M*ENG[-512 to 511 / 0 / 1dot/step]
2-182-007M. Scan: Middle: Subdot: M*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-008M. Scan: Low: Dot: M*ENG[-512 to 511 / 0 / 1dot/step]
2-182-009M. Scan: Low: Subdot: M*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-010M. Scan: Standard: Dot: C*ENG[-512 to 511 / 0 / 1dot/step]
2-182-011M. Scan: Standard: Subdot: C*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-012M. Scan: Middle: Dot: C*ENG[-512 to 511 / 0 / 1dot/step]
2-182-013M. Scan: Middle: Subdot: C*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-014M. Scan: Low: Dot: C*ENG[-512 to 511 / 0 / 1dot/step]
2-182-015M. Scan: Low: Subdot: C*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-016M. Scan: Standard: Dot: Y*ENG[-512 to 511 / 0 / 1dot/step]
2-182-017M. Scan: Standard: Subdot: Y*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-018M. Scan: Middle: Dot: Y*ENG[-512 to 511 / 0 / 1dot/step]
2-182-019M. Scan: Middle: Subdot: Y*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-020M. Scan: Low: Dot: Y*ENG[-512 to 511 / 0 / 1dot/step]
2-182-021M. Scan: Low: Subdot: Y*ENG[-1 to 1 / 0 / 0.01dot/step]
2-182-022S. Scan: Standard: Line: M*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-023S. Scan: Standard: Subline: M*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-024S. Scan: Middle: Line: M*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-025S. Scan: Middle: Subline: M*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-026S. Scan: Low: Line: M*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-027S. Scan: Low: Subline: M*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-028S. Scan: Standard: Line: C*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-029S. Scan: Standard: Subline: C*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-030S. Scan: Middle: Line: C*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-031S. Scan: Middle: Subline: C*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-032S. Scan: Low: Line: C*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-033S. Scan: Low: Subline: C*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-034S. Scan: Standard: Line: Y*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-035S. Scan: Standard: Subline: Y*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-036S. Scan: Middle: Line: Y*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-037S. Scan: Middle: Subline: Y*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-038S. Scan: Low: Line: Y*ENG[-16384 to 16383 / 0 / 1line/step]
2-182-039S. Scan: Low: Subline: Y*ENG[-1 to 1 / 0 / 0.01line/step]
2-182-040M. Scan: Dot: K*ENG[-512 to 511 / 0 / 1dot/step]
2187[Method Select]
2-187-002MUSIC Pattern Length Adj.*ENG[-300 to 300 / 0 / 1dot/step]
2-187-003Pattern Width Adj.*ENG[-512 to 511 / 0 / 1dot/step]
2-187-004Pattern Interval Adj.*ENG[-512 to 511 / 0 / 1dot/step]
2190[Line Position Adj.]
2-190-012SnSErr Range*ENG[0 to 3500 / 200 / 1um/step]
2193[MUSIC Condition Set]
2-193-002Page: Job End: BW+FC*ENG[0 to 999 / 500 / 1page/step]
2-193-003Page: Job End: FC*ENG[0 to 999 / 200 / 1page/step]
2-193-004Page: Interrupt: BW+FC*ENG[0 to 999 / 200 / 1page/step]
2-193-005Page: Interrupt: FC*ENG[0 to 999 / 200 / 1page/step]
2-193-006Page: Stand-By: BW*ENG[0 to 999 / 100 / 1page/step]
2-193-007Page: Stand-By: FC*ENG[0 to 999 / 100 / 1page/step]
2-193-008Temp.*ENG[0 to 100 / 5 / 1deg/step]
2-193-011Temp. 2*ENG[0 to 100 / 5 / 1deg/step]
2-193-013Temp. 3*ENG[0 to 100 / 10 / 1deg/step]
2-193-016Page: Power ON:BW+FC*ENG[0 to 999 / 200 / 1page/step]
2-193-017Skew*ENG[0 to 999 / 50 / 1um/step]
2-193-018Page: Low Speed: BW+FC*ENG[0 to 999 / 50 / 1page/step]
2-193-019Page: Low Speed: FC*ENG[0 to 999 / 50 / 1page/step]
2195​
2194[MUSIC Execution Result]
2-194-001Year*ENG[0 to 99 / 0 / 1year/step]
2-194-002Month*ENG[1 to 12 / 1 / 1month/step]
2-194-003Day*ENG[1 to 31 / 1 / 1day/step]
2-194-004Hour*ENG[0 to 23 / 0 / 1hour/step]
2-194-005Minute*ENG[0 to 59 / 0 / 1minute/step]
2-194-006Temperature*ENG[0 to 100 / 0 / 1deg/step]
2-194-007Execution Result*ENG[0 or 1 / 0 / 1/step]
2-194-008Number of Execution*ENG[0 to 999999 / 0 / 1time/step]
2-194-009Number of Failure*ENG[0 to 999999 / 0 / 1time/step]
2-194-010Error Result: C*ENG[0 to 9 / 0 / 1/step]
2-194-011Error Result: M*ENG[0 to 9 / 0 / 1/step]
2-194-012Error Result: Y*ENG[0 to 9 / 0 / 1/step]
2-194-013Error Result: K*ENG[0 to 9 / 0 / 1/step]
2-194-014Temperature 2*ENG[-10 to 100 / 0 / 1deg/step]
[Realtime MUSIC Condition Set]​
2-195-001ON/OFF*ENG[0 or 1 / 1 / 1/step]
2-195-002Page: Interrupt: BW+FC*ENG[0 to 999 / 50 / 1page/step]
2-195-003Page: Interrupt: FC*ENG[0 to 999 / 50 / 1page/step]
2-195-004Temperature 4*ENG[0 to 100 / 1 / 1deg/step]
2-195-005Temperature 5*ENG[0 to 100 / 1 / 1deg/step]
2220[Skew Origin Set]
2-220-001M: Skew MotorENG[0 or 1 / 0 / 1/step]
2-220-002C: Skew MotorENG[0 or 1 / 0 / 1/step]
2-220-003Y: Skew MotorENG[0 or 1 / 0 / 1/step]
2221[LD Power: Fixed]
2-221-001K*ENG[0 to 217 / 100 / 1%/step]
2-221-002C*ENG
2-221-003M*ENG
2-221-004Y*ENG
2229[Develop DC Bias]
2-229-001Standard Speed: Bk*ENG[0 to 800 / 550 / 1-V/step]
2-229-002Standard Speed: C*ENG[0 to 800 / 550 / 1-V/step]
2-229-003Standard Speed: M*ENG[0 to 800 / 550 / 1-V/step]
2-229-004Standard Speed: Y*ENG[0 to 800 / 550 / 1-V/step]
2-229-005Middle Speed Bk*ENG[0 to 800 / 550 / 1-V/step]
2-229-006Middle Speed C*ENG[0 to 800 / 550 / 1-V/step]
2-229-007Middle Speed M*ENG[0 to 800 / 550 / 1-V/step]
2-229-008Middle Speed Y*ENG[0 to 800 / 550 / 1-V/step]
2-229-009Low Speed: Bk*ENG[0 to 800 / 550 / 1-V/step]
2-229-010Low Speed: C*ENG[0 to 800 / 550 / 1-V/step]
2-229-011Low Speed: M*ENG[0 to 800 / 550 / 1-V/step]
2-229-012Low Speed: Y*ENG[0 to 800 / 550 / 1-V/step]
2230[QL Power Setting]
2-230-001Standard Speed*ENG[0 to 100 / 26 / 1%/step]
2-230-002Middle Speed*ENG[0 to 100 / 13 / 1%/step]
2-230-003Low Speed*ENG[0 to 100 / 13 / 1%/step]
2241[Temperature/Humidity: Display]
2-241-003Exec Interval: Extra Fan Control*ENG[1 to 3600 / 10 / 1sec/step]
2241[AIT Temperature]
2-241-004AIT TemperatureENG[0 to 70 / 0 / 0.1deg/step]
2242[TS Operation Env. Log]
2-242-001TS<=A-3ENG[0 to 99999999 / 0 / 1mm/step]
2-242-002A-3<TS<=AENG[0 to 99999999 / 0 / 1mm/step]
2-242-003A<TS<=A+3ENG[0 to 99999999 / 0 / 1mm/step]
2-242-004A+3<TSENG[0 to 99999999 / 0 / 1mm/step]
2-242-100Log ClearENG[0 or 1 / 0 / 1/step]
2250[Interval Downmode]
2-250-001ON/OFF SettingENG[0 or 1 / 1 / 1/step]
2302[Environmental Correction:Trans]
2-302-001Current Environmental DisplayENG[0 to 0 / 0 / 0/step]
2-302-002Forced Setting*ENG[0 to 6 / 0 / 1/step]
0: Sensor detect
1: LL
2: ML
3: MM
4: HM
5: HH
6: SLL
2-302-003Absolute Humidity:Threshold 1*ENG[0 to 100 / 4 / 0.01g/m3/step]
2-302-004Absolute Humidity:Threshold 2*ENG[0 to 100 / 8 / 0.01g/m3/step]
2-302-005Absolute Humidity:Threshold 3*ENG[0 to 100 / 16 / 0.01g/m3/step]
2-302-006Absolute Humidity:Threshold 4*ENG[0 to 100 / 24 / 0.01g/m3/step]
2-302-007Temperature:Threshold*ENG[-5 to 30 / 5 / 1deg/step]
2303[Time-Lapse Correction]
2-303-001Current Div K*ENG[0 to 3 / 0 / 1/step]
2-303-002Current Div C*ENG[0 to 3 / 0 / 1/step]
2-303-003Current Div M*ENG[0 to 3 / 0 / 1/step]
2-303-004Current Div Y*ENG[0 to 3 / 0 / 1/step]
2-303-005Correction Threshold 1_Bk*ENG[0 to 600000 / 5000 /
10page/step]
2-303-006Correction Threshold 1_Color*ENG[0 to 600000 / 5000 /
10page/step]
2-303-007Correction Threshold 2_Bk*ENG[0 to 600000 / 20000 /
10page/step]
2-303-008Correction Threshold 2_Color*ENG[0 to 600000 / 20000 /
10page/step]
2-303-009Correction Threshold 3_Bk*ENG[0 to 600000 / 50000 /
10page/step]
2-303-010
Correction Threshold 3_Color
10page/step]
2308[Paper Size Correction]
2-308-001Threshold 1*ENG[0 to 350 / 297 / 1mm/step]
2-308-002Threshold 2*ENG[0 to 350 / 257 / 1mm/step]
2-308-003Threshold 3*ENG[0 to 350 / 210 / 1mm/step]
2-308-004Threshold 4*ENG[0 to 350 / 148 / 1mm/step]
2-308-005Threshold 1*ENG[0 to 350 / 297 / 1mm/step]
2-308-006Threshold 2*ENG[0 to 350 / 257 / 1mm/step]
2-308-007Threshold 3*ENG[0 to 350 / 210 / 1mm/step]
2-308-008Threshold 4*ENG[0 to 350 / 148 / 1mm/step]
2311[Non Image Area:Bias]
2-311-001Image Transfer*ENG[10 to 250 / 100 / 5%/step]
2-311-002Paper Transfer*ENG[0 to 230 / 0 / 1-uA/step]
2-311-003Paper Transfer*ENG[0 to 2100 / 500 / 10V/step]
2316[Power ON:Bias]
2-316-001Image Transfer*ENG[0 to 80 / 5 / 1uA/step]
2326[Transfer Roller CL:Bias]
2-326-001Positive:befor and after JOB*ENG[0 to 2100 / 250 / 10V/step]
2-326-002Negative:befor and after JOB*ENG[10 to 995 / 100 / 10%/step]
2-326-003Positive:befor and afterProcon*ENG[0 to 2100 / 2000 / 10V/step]
2-326-004
Negative:befor and afterProcon
*ENG
2-326-005Positive:prevention*ENG[0 to 2100 / 500 / 10-V/step]
2326[Transfer Roller CL:Env]
2-326-011Positive:befor and after JOB*ENG[1 to 110 / 100 / 1/step]
2-326-013Positive:befor and afterProcon*ENG[1 to 110 / 100 / 1/step]
2-326-015Positive:prevention*ENG[1 to 110 / 100 / 1/step]
2351[Common:BW:Bias]
2-351-001Image Transfer:standard*ENG[0 to 60 / 28 / 1uA/step]
2-351-002Image Transfer:MiddleENG[0 to 60 / 24 / 1uA/step]
2-351-003Image Transfer:lowENG[0 to 60 / 13 / 1uA/step]
2357[Common:FC:Bias]
2-357-001ImageTransfer:standard:Bk*ENG[0 to 60 / 28 / 1uA/step]
2-357-002ImageTransfer:standard:C*ENG[0 to 60 / 27 / 1uA/step]
2-357-003ImageTransfer:standard:M*ENG[0 to 60 / 27 / 1uA/step]
2-357-004ImageTransfer:standard:Y*ENG[0 to 60 / 28 / 1uA/step]
2-357-005ImageTransfer:Middle:BkENG[0 to 60 / 24 / 1uA/step]
2-357-006ImageTransfer:Middle:CENG[0 to 60 / 24 / 1uA/step]
2-357-007ImageTransfer:Middle:MENG[0 to 60 / 26 / 1uA/step]
2-357-008ImageTransfer:Middle:YENG[0 to 60 / 28 / 1uA/step]
2-357-009Image Transfer:low:BkENG[0 to 60 / 12 / 1uA/step]
2-357-010Image Transfer:low:CENG[0 to 60 / 11 / 1uA/step]
2-357-011Image Transfer:low:MENG[0 to 60 / 11 / 1uA/step]
2-357-012Image Transfer:low:YENG[0 to 60 / 12 / 1uA/step]
2358[TC adjust Process Control:Bias]
2-358-001ImageTransfer:standard:FC:Bk*ENG[0 to 60 / 28 / 1uA/step]
2-358-002ImageTransfer:standard:FC:C*ENG[0 to 60 / 27 / 1uA/step]
2-358-003ImageTransfer:standard:FC:M*ENG[0 to 60 / 27 / 1uA/step]
2-358-004ImageTransfer:standard:FC:Y*ENG[0 to 60 / 28 / 1uA/step]
2-358-005ImageTransfer:standard:Bk:Bk*ENG[0 to 60 / 28 / 1uA/step]
2360[Common:BW:Env.CorrectionTable]
2-360-001Image Transfer:standard*ENG[1 to 110 / 13 / 1/step]
2-360-002Image Transfer:MiddleENG[1 to 110 / 2 / 1/step]
2-360-003Image Transfer:lowENG[1 to 110 / 54 / 1/step]
2-360-004ImageTransfer:standard:Bk*ENG[1 to 110 / 13 / 1/step]
2-360-005ImageTransfer:standard:C*ENG[1 to 110 / 54 / 1/step]
2-360-006ImageTransfer:standard:M*ENG[1 to 110 / 54 / 1/step]
2-360-007ImageTransfer:standard:Y*ENG[1 to 110 / 55 / 1/step]
2-360-008ImageTransfer:Middle:BkENG[1 to 110 / 1 / 1/step]
2-360-009ImageTransfer:Middle:CENG[1 to 110 / 2 / 1/step]
2-360-010ImageTransfer:Middle:MENG[1 to 110 / 3 / 1/step]
2-360-011ImageTransfer:Middle:YENG[1 to 110 / 4 / 1/step]
2-360-012Image Transfer:low:BkENG[1 to 110 / 15 / 1/step]
2-360-013Image Transfer:low:CENG[1 to 110 / 55 / 1/step]
2-360-014Image Transfer:low:MENG[1 to 110 / 56 / 1/step]
2-360-015Image Transfer:low:YENG[1 to 110 / 56 / 1/step]
2361[Time-Lapse Correction: Div 1]
2-361-001Standard Speed: Bk*ENG[1 to 60 / 2 / 1/step]
2-361-002Mid Speed: BkENG
2-361-003Low Speed: BkENG
2-361-004Standard Speed: FC: K*ENG[1 to 60 / 1 / 1/step]
2-361-005Standard Speed: FC: C*ENG
2-361-006Standard Speed: FC: M*ENG
2-361-007Standard Speed: FC: Y*ENG
2-361-008Mid Speed: FC: KENG
2-361-009Mid Speed: FC: CENG
2-361-010Mid Speed: FC: MENG
2-361-011Mid Speed: FC: YENG
2-361-012Low Speed: FC: KENG
2-361-013Low Speed: FC: CENG
2-361-014Low Speed: FC: MENG
2-361-015Low Speed: FC: YENG
2362[Time-Lapse Correction: Div 2]
2-362-001Standard Speed: Bk*ENG[1 to 60 / 3 / 1/step]
2-362-002Mid Speed: BkENG
2-362-003Low Speed: BkENG
2-362-004Standard Speed: FC: K*ENG[1 to 60 / 1 / 1/step]
2-362-005Standard Speed: FC: C*ENG
2-362-006Standard Speed: FC: M*ENG
2-362-007Standard Speed: FC: Y*ENG
2-362-008Mid Speed: FC: KENG
2-362-009Mid Speed: FC: CENG
2-362-010Mid Speed: FC: MENG
2-362-011Mid Speed: FC: YENG
2-362-012Low Speed: FC: KENG
2-362-013Low Speed: FC: CENG
2-362-014Low Speed: FC: MENG
2-362-015Low Speed: FC: YENG
2363[Time-Lapse Correction: Div 3]
2-363-001Standard Speed: Bk*ENG[1 to 60 / 4 / 1/step]
2-363-002Mid Speed: BkENG
2-363-003Low Speed: BkENG
2-363-004Standard Speed: FC: K*ENG[1 to 60 / 1 / 1/step]
2-363-005Standard Speed: FC: C*ENG
2-363-006Standard Speed: FC: M*ENG
2-363-007Standard Speed: FC: Y*ENG
2-363-008Mid Speed: FC: KENG
2-363-009Mid Speed: FC: CENG
2-363-010Mid Speed: FC: MENG
2-363-011Mid Speed: FC: YENG
2-363-012Low Speed: FC: KENG
2-363-013Low Speed: FC: CENG
2-363-014Low Speed: FC: MENG
2-363-015Low Speed: FC: YENG
2400[Paper Transfer Roller Settings]
2-400-001Width of Paper Transfer Roller*ENG[0 or 1 / 0 / 1/step]
0: Default roller
1: Wide roller
2-400-002Detatch timing in waitingENG[0 to 600 / 240 / 1min/step]
2403[Plain1:Bias:BW]
2-403-001PaperTransfer:standard:1sideENG[0 to 200 / 22 / 1-uA/step]
2-403-002PaperTransfer:standard:2sideENG[0 to 200 / 22 / 1-uA/step]
2-403-003PaperTransfer:low:1sideENG[0 to 200 / 11 / 1-uA/step]
2-403-004PaperTransfer:low:2sideENG[0 to 200 / 11 / 1-uA/step]
2407[Plain1:Bias:FC]
2-407-001PaperTransfer:standard:1side*ENG[0 to 200 / 29 / 1-uA/step]
2-407-002PaperTransfer:standard:2sideENG[0 to 200 / 29 / 1-uA/step]
2-407-003PaperTransfer:low:1sideENG[0 to 200 / 14 / 1-uA/step]
2-407-004PaperTransfer:low:2sideENG[0 to 200 / 14 / 1-uA/step]
2411[Plain1:SizeCorrection:BW]
2-411-001PaperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-411-002PaperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-411-003PaperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-411-004PaperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-411-005PaperTransfer:Standard:1Sid:S2ENG[100 to 995 / 100 / 1%/step]
2-411-006PaperTransfer:Standard:2Sid:S2ENG[100 to 995 / 105 / 1%/step]
2-411-007PaperTransfer:Low:1Side:S2ENG[100 to 995 / 100 / 1%/step]
2-411-008PaperTransfer:Low:2Side:S2ENG[100 to 995 / 105 / 1%/step]
2-411-009PaperTransfer:Standard:1Sid:S3ENG[100 to 995 / 105 / 1%/step]
2-411-010PaperTransfer:Standard:2Sid:S3ENG[100 to 995 / 118 / 1%/step]
2-411-011PaperTransfer:Low:1Side:S3ENG[100 to 995 / 105 / 1%/step]
2-411-012PaperTransfer:Low:2Side:S3ENG[100 to 995 / 118 / 1%/step]
2-411-013PaperTransfer:Standard:1Sid:S4ENG[100 to 995 / 118 / 1%/step]
2-411-014PaperTransfer:Standard:2Sid:S4ENG[100 to 995 / 131 / 1%/step]
2-411-015PaperTransfer:Low:1Side:S4ENG[100 to 995 / 118 / 1%/step]
2-411-016PaperTransfer:Low:2Side:S4ENG[100 to 995 / 131 / 1%/step]
2-411-017PaperTransfer:Standard:1Sid:S5ENG[100 to 995 / 132 / 1%/step]
2-411-018PaperTransfer:Standard:2Sid:S5ENG[100 to 995 / 184 / 1%/step]
2-411-019PaperTransfer:Low:1Side:S5ENG[100 to 995 / 132 / 1%/step]
2-411-020PaperTransfer:Low:2Side:S5ENG[100 to 995 / 184 / 1%/step]
2-411-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-411-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-411-023Wide Roller:paperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-411-024Wide Roller:paperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-411-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[100 to 995 / 100 / 1%/step]
2-411-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[100 to 995 / 105 / 1%/step]
2-411-027Wide Roller:paperTransfer:Low:1Side:S2ENG[100 to 995 / 100 / 1%/step]
2-411-028Wide Roller:paperTransfer:Low:2Side:S2ENG[100 to 995 / 105 / 1%/step]
2-411-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[100 to 995 / 105 / 1%/step]
2-411-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[100 to 995 / 118 / 1%/step]
2-411-031Wide Roller:paperTransfer:Low:1Side:S3ENG[100 to 995 / 105 / 1%/step]
2-411-032Wide Roller:paperTransfer:Low:2Side:S3ENG[100 to 995 / 118 / 1%/step]
2-411-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[100 to 995 / 118 / 1%/step]
2-411-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[100 to 995 / 131 / 1%/step]
2-411-035Wide Roller:paperTransfer:Low:1Side:S4ENG[100 to 995 / 118 / 1%/step]
2-411-036Wide Roller:paperTransfer:Low:2Side:S4ENG[100 to 995 / 131 / 1%/step]
2-411-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[100 to 995 / 132 / 1%/step]
2-411-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[100 to 995 / 184 / 1%/step]
2-411-039Wide Roller:paperTransfer:Low:1Side:S5ENG[100 to 995 / 132 / 1%/step]
2-411-040
Wide Roller:paperTransfer:Low:2Side:S5
ENG
2412[Plain1:SizeCorrection:FC]
2-412-001PaperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-412-002PaperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-412-003PaperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-412-004PaperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-412-005PaperTransfer:Standard:1Sid:S2ENG[100 to 995 / 120 / 1%/step]
2-412-006PaperTransfer:Standard:2Sid:S2ENG[100 to 995 / 140 / 1%/step]
2-412-007PaperTransfer:Low:1Side:S2ENG[100 to 995 / 120 / 1%/step]
2-412-008PaperTransfer:Low:2Side:S2ENG[100 to 995 / 140 / 1%/step]
2-412-009PaperTransfer:Standard:1Sid:S3ENG[100 to 995 / 118 / 1%/step]
2-412-010PaperTransfer:Standard:2Sid:S3ENG[100 to 995 / 180 / 1%/step]
2-412-011PaperTransfer:Low:1Side:S3ENG[100 to 995 / 118 / 1%/step]
2-412-012PaperTransfer:Low:2Side:S3ENG[100 to 995 / 180 / 1%/step]
2-412-013PaperTransfer:Standard:1Sid:S4ENG[100 to 995 / 130 / 1%/step]
2-412-014PaperTransfer:Standard:2Sid:S4ENG[100 to 995 / 200 / 1%/step]
2-412-015PaperTransfer:Low:1Side:S4ENG[100 to 995 / 130 / 1%/step]
2-412-016PaperTransfer:Low:2Side:S4ENG[100 to 995 / 200 / 1%/step]
2-412-017PaperTransfer:Standard:1Sid:S5ENG[100 to 995 / 140 / 1%/step]
2-412-018PaperTransfer:Standard:2Sid:S5ENG[100 to 995 / 240 / 1%/step]
2-412-019PaperTransfer:Low:1Side:S5ENG[100 to 995 / 140 / 1%/step]
2-412-020PaperTransfer:Low:2Side:S5ENG[100 to 995 / 240 / 1%/step]
2-412-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-412-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-412-023Wide Roller:paperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-412-024Wide Roller:paperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-412-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[100 to 995 / 120 / 1%/step]
2-412-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[100 to 995 / 140 / 1%/step]
2-412-027Wide Roller:paperTransfer:Low:1Side:S2ENG[100 to 995 / 120 / 1%/step]
2-412-028Wide Roller:paperTransfer:Low:2Side:S2ENG[100 to 995 / 140 / 1%/step]
2-412-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[100 to 995 / 118 / 1%/step]
2-412-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[100 to 995 / 180 / 1%/step]
2-412-031Wide Roller:paperTransfer:Low:1Side:S3ENG[100 to 995 / 118 / 1%/step]
2-412-032Wide Roller:paperTransfer:Low:2Side:S3ENG[100 to 995 / 180 / 1%/step]
2-412-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[100 to 995 / 130 / 1%/step]
2-412-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[100 to 995 / 200 / 1%/step]
2-412-035Wide Roller:paperTransfer:Low:1Side:S4ENG[100 to 995 / 130 / 1%/step]
2-412-036Wide Roller:paperTransfer:Low:2Side:S4ENG[100 to 995 / 200 / 1%/step]
2-412-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[100 to 995 / 140 / 1%/step]
2-412-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[100 to 995 / 240 / 1%/step]
2-412-039Wide Roller:paperTransfer:Low:1Side:S5ENG[100 to 995 / 140 / 1%/step]
2-412-040Wide Roller:paperTransfer:Low:2Side:S5ENG[100 to 995 / 240 / 1%/step]
2413[Plain1:Size-Env.Correct:BW]
2-413-001PaperTransfer:Standard:1Sid:S1ENG[1 to 110 / 10 / 1/step]
2-413-002PaperTransfer:Standard:2Sid:S1ENG[1 to 110 / 15 / 1/step]
2-413-003PaperTransfer:Low:1Side:S1ENG[1 to 110 / 10 / 1/step]
2-413-004PaperTransfer:Low:2Side:S1ENG[1 to 110 / 15 / 1/step]
2-413-005PaperTransfer:Standard:1Sid:S2ENG[1 to 110 / 11 / 1/step]
2-413-006PaperTransfer:Standard:2Sid:S2ENG[1 to 110 / 16 / 1/step]
2-413-007PaperTransfer:Low:1Side:S2ENG[1 to 110 / 11 / 1/step]
2-413-008PaperTransfer:Low:2Side:S2ENG[1 to 110 / 16 / 1/step]
2-413-009PaperTransfer:Standard:1Sid:S3ENG[1 to 110 / 12 / 1/step]
2-413-010PaperTransfer:Standard:2Sid:S3ENG[1 to 110 / 17 / 1/step]
2-413-011PaperTransfer:Low:1Side:S3ENG[1 to 110 / 12 / 1/step]
2-413-012PaperTransfer:Low:2Side:S3ENG[1 to 110 / 17 / 1/step]
2-413-013PaperTransfer:Standard:1Sid:S4ENG[1 to 110 / 13 / 1/step]
2-413-014PaperTransfer:Standard:2Sid:S4ENG[1 to 110 / 18 / 1/step]
2-413-015PaperTransfer:Low:1Side:S4ENG[1 to 110 / 13 / 1/step]
2-413-016PaperTransfer:Low:2Side:S4ENG[1 to 110 / 18 / 1/step]
2-413-017PaperTransfer:Standard:1Sid:S5ENG[1 to 110 / 14 / 1/step]
2-413-018PaperTransfer:Standard:2Sid:S5ENG[1 to 110 / 19 / 1/step]
2-413-019PaperTransfer:Low:1Side:S5ENG[1 to 110 / 14 / 1/step]
2-413-020PaperTransfer:Low:2Side:S5ENG[1 to 110 / 19 / 1/step]
2-413-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[1 to 110 / 10 / 1/step]
2-413-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[1 to 110 / 15 / 1/step]
2-413-023Wide Roller:paperTransfer:Low:1Side:S1ENG[1 to 110 / 10 / 1/step]
2-413-024Wide Roller:paperTransfer:Low:2Side:S1ENG[1 to 110 / 15 / 1/step]
2-413-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[1 to 110 / 11 / 1/step]
2-413-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[1 to 110 / 16 / 1/step]
2-413-027Wide Roller:paperTransfer:Low:1Side:S2ENG[1 to 110 / 11 / 1/step]
2-413-028Wide Roller:paperTransfer:Low:2Side:S2ENG[1 to 110 / 16 / 1/step]
2-413-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[1 to 110 / 12 / 1/step]
2-413-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[1 to 110 / 17 / 1/step]
2-413-031Wide Roller:paperTransfer:Low:1Side:S3ENG[1 to 110 / 12 / 1/step]
2-413-032Wide Roller:paperTransfer:Low:2Side:S3ENG[1 to 110 / 17 / 1/step]
2-413-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[1 to 110 / 13 / 1/step]
2-413-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[1 to 110 / 18 / 1/step]
2-413-035Wide Roller:paperTransfer:Low:1Side:S4ENG[1 to 110 / 13 / 1/step]
2-413-036Wide Roller:paperTransfer:Low:2Side:S4ENG[1 to 110 / 18 / 1/step]
2-413-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[1 to 110 / 14 / 1/step]
2-413-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[1 to 110 / 19 / 1/step]
2-413-039Wide Roller:paperTransfer:Low:1Side:S5ENG[1 to 110 / 14 / 1/step]
2414[Plain1:Size-Env.Correct:FC]
2-414-001PaperTransfer:Standard:1Sid:S1*ENG[1 to 110 / 20 / 1/step]
2-414-002PaperTransfer:Standard:2Sid:S1ENG[1 to 110 / 25 / 1/step]
2-414-003PaperTransfer:Low:1Side:S1ENG[1 to 110 / 20 / 1/step]
2-414-004PaperTransfer:Low:2Side:S1ENG[1 to 110 / 25 / 1/step]
2-414-005PaperTransfer:Standard:1Sid:S2ENG[1 to 110 / 21 / 1/step]
2-414-006PaperTransfer:Standard:2Sid:S2ENG[1 to 110 / 26 / 1/step]
2-414-007PaperTransfer:Low:1Side:S2ENG[1 to 110 / 21 / 1/step]
2-414-008PaperTransfer:Low:2Side:S2ENG[1 to 110 / 26 / 1/step]
2-414-009PaperTransfer:Standard:1Sid:S3ENG[1 to 110 / 22 / 1/step]
2-414-010PaperTransfer:Standard:2Sid:S3ENG[1 to 110 / 27 / 1/step]
2-414-011PaperTransfer:Low:1Side:S3ENG[1 to 110 / 22 / 1/step]
2-414-012PaperTransfer:Low:2Side:S3ENG[1 to 110 / 27 / 1/step]
2-414-013PaperTransfer:Standard:1Sid:S4ENG[1 to 110 / 23 / 1/step]
2-414-014PaperTransfer:Standard:2Sid:S4ENG[1 to 110 / 28 / 1/step]
2-414-015PaperTransfer:Low:1Side:S4ENG[1 to 110 / 23 / 1/step]
2-414-016PaperTransfer:Low:2Side:S4ENG[1 to 110 / 28 / 1/step]
2-414-017PaperTransfer:Standard:1Sid:S5ENG[1 to 110 / 24 / 1/step]
2-414-018PaperTransfer:Standard:2Sid:S5ENG[1 to 110 / 29 / 1/step]
2-414-019PaperTransfer:Low:1Side:S5ENG[1 to 110 / 24 / 1/step]
2-414-020PaperTransfer:Low:2Side:S5ENG[1 to 110 / 29 / 1/step]
2-414-021Wide Roller:paperTransfer:Standard:1Sid:S1*ENG[1 to 110 / 20 / 1/step]
2-413-040Wide Roller:paperTransfer:Low:2Side:S5ENG[1 to 110 / 19 / 1/step]
2-414-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[1 to 110 / 25 / 1/step]
2-414-023Wide Roller:paperTransfer:Low:1Side:S1ENG[1 to 110 / 20 / 1/step]
2-414-024Wide Roller:paperTransfer:Low:2Side:S1ENG[1 to 110 / 25 / 1/step]
2-414-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[1 to 110 / 21 / 1/step]
2-414-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[1 to 110 / 26 / 1/step]
2-414-027Wide Roller:paperTransfer:Low:1Side:S2ENG[1 to 110 / 21 / 1/step]
2-414-028Wide Roller:paperTransfer:Low:2Side:S2ENG[1 to 110 / 26 / 1/step]
2-414-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[1 to 110 / 22 / 1/step]
2-414-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[1 to 110 / 27 / 1/step]
2-414-031Wide Roller:paperTransfer:Low:1Side:S3ENG[1 to 110 / 22 / 1/step]
2-414-032Wide Roller:paperTransfer:Low:2Side:S3ENG[1 to 110 / 27 / 1/step]
2-414-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[1 to 110 / 23 / 1/step]
2-414-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[1 to 110 / 28 / 1/step]
2-414-035Wide Roller:paperTransfer:Low:1Side:S4ENG[1 to 110 / 23 / 1/step]
2-414-036Wide Roller:paperTransfer:Low:2Side:S4ENG[1 to 110 / 28 / 1/step]
2-414-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[1 to 110 / 24 / 1/step]
2-414-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[1 to 110 / 29 / 1/step]
2-414-039Wide Roller:paperTransfer:Low:1Side:S5ENG[1 to 110 / 24 / 1/step]
2-414-040Wide Roller:paperTransfer:Low:2Side:S5ENG[1 to 110 / 29 / 1/step]
2418​
2415[Plain1:LeadingEdgeCorrection]
2-415-001PaperTransfer:Standard:1SideENG[0 to 995 / 100 / 5%/step]
2-415-002PaperTransfer:Standard:2SideENG[0 to 995 / 100 / 5%/step]
2-415-003Paper Transfer:Low:1sideENG[0 to 995 / 100 / 5%/step]
2-415-004Paper Transfer:Low:2sideENG[0 to 995 / 100 / 5%/step]
2416[Plain1:SwitchTimingLeadEdge]
2-416-001PaperTransfer:Standard:1sideENG[0 to 50 / 0 / 2mm/step]
2-416-002PaperTransfer:Standard:2sideENG[0 to 50 / 0 / 2mm/step]
2-416-003Paper Transfer:Low:1sideENG[0 to 50 / 0 / 2mm/step]
2-416-004Paper Transfer:Low:2sideENG[0 to 50 / 0 / 2mm/step]
2417[Plain1:TrailEdgeCorrection]
2-417-001PaperTransfer:Standard:1SideENG[0 to 995 / 100 / 5%/step]
2-417-002PaperTransfer:Standard:2SideENG[0 to 995 / 100 / 5%/step]
2-417-003Paper Transfer:Low:1sideENG[0 to 995 / 100 / 5%/step]
2-417-004Paper Transfer:Low:2sideENG[0 to 995 / 100 / 5%/step]
[Plain1:SwitchTimingTrailEdge]​
2-418-001PaperTransfer:Standard:1sideENG[0 to 50 / 0 / 2mm/step]
2-418-002PaperTransfer:Standard:2sideENG[0 to 50 / 0 / 2mm/step]
2-418-003Paper Transfer:Low:1sideENG[0 to 50 / 0 / 2mm/step]
2-418-004Paper Transfer:Low:2sideENG[0 to 50 / 0 / 2mm/step]
2423[Plain2:Bias:BW]
2-423-001PaperTransfer:standard:1sideENG[0 to 200 / 22 / 1-uA/step]
2-423-002PaperTransfer:standard:2sideENG[0 to 200 / 22 / 1-uA/step]
2-423-003PaperTransfer:low:1sideENG[0 to 200 / 11 / 1-uA/step]
2-423-004PaperTransfer:low:2sideENG[0 to 200 / 11 / 1-uA/step]
2425[Hhsmall:LeadEdgeCorrection]
2-425-001PaperTransfer:1sideENG[0 to 995 / 100 / 5%/step]
2-425-002PaperTransfer:2stSideENG[0 to 995 / 100 / 5%/step]
2427[Plain2:Bias:FC]
2-427-001PaperTransfer:standard:1sideENG[0 to 200 / 29 / 1-uA/step]
2-427-002PaperTransfer:standard:2sideENG[0 to 200 / 29 / 1-uA/step]
2-427-003PaperTransfer:low:1sideENG[0 to 200 / 14 / 1-uA/step]
2-427-004PaperTransfer:low:2sideENG[0 to 200 / 14 / 1-uA/step]
2431[Plain2:SizeCorrection:BW]
2-431-001PaperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-431-002PaperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-431-003PaperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-431-004PaperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-431-005PaperTransfer:Standard:1Sid:S2ENG[100 to 995 / 100 / 1%/step]
2-431-006PaperTransfer:Standard:2Sid:S2ENG[100 to 995 / 105 / 1%/step]
2-431-007PaperTransfer:Low:1Side:S2ENG[100 to 995 / 100 / 1%/step]
2-431-008PaperTransfer:Low:2Side:S2ENG[100 to 995 / 105 / 1%/step]
2-431-009PaperTransfer:Standard:1Sid:S3ENG[100 to 995 / 105 / 1%/step]
2-431-010PaperTransfer:Standard:2Sid:S3ENG[100 to 995 / 118 / 1%/step]
2-431-011PaperTransfer:Low:1Side:S3ENG[100 to 995 / 105 / 1%/step]
2-431-012PaperTransfer:Low:2Side:S3ENG[100 to 995 / 118 / 1%/step]
2-431-013PaperTransfer:Standard:1Sid:S4ENG[100 to 995 / 118 / 1%/step]
2-431-014PaperTransfer:Standard:2Sid:S4ENG[100 to 995 / 131 / 1%/step]
2-431-015PaperTransfer:Low:1Side:S4ENG[100 to 995 / 118 / 1%/step]
2-431-016PaperTransfer:Low:2Side:S4ENG[100 to 995 / 131 / 1%/step]
2-431-017PaperTransfer:Standard:1Sid:S5ENG[100 to 995 / 132 / 1%/step]
2-431-018PaperTransfer:Standard:2Sid:S5ENG[100 to 995 / 184 / 1%/step]
2-431-019PaperTransfer:Low:1Side:S5ENG[100 to 995 / 132 / 1%/step]
2-431-020PaperTransfer:Low:2Side:S5ENG[100 to 995 / 184 / 1%/step]
2-431-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-431-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-431-023Wide Roller:paperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-431-024Wide Roller:paperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-431-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[100 to 995 / 100 / 1%/step]
2-431-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[100 to 995 / 105 / 1%/step]
2-431-027Wide Roller:paperTransfer:Low:1Side:S2ENG[100 to 995 / 100 / 1%/step]
2-431-028Wide Roller:paperTransfer:Low:2Side:S2ENG[100 to 995 / 105 / 1%/step]
2-431-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[100 to 995 / 105 / 1%/step]
2-431-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[100 to 995 / 118 / 1%/step]
2-431-031Wide Roller:paperTransfer:Low:1Side:S3ENG[100 to 995 / 105 / 1%/step]
2-431-032Wide Roller:paperTransfer:Low:2Side:S3ENG[100 to 995 / 118 / 1%/step]
2-431-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[100 to 995 / 118 / 1%/step]
2-431-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[100 to 995 / 131 / 1%/step]
2-431-035Wide Roller:paperTransfer:Low:1Side:S4ENG[100 to 995 / 118 / 1%/step]
2-431-036Wide Roller:paperTransfer:Low:2Side:S4ENG[100 to 995 / 131 / 1%/step]
2-431-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[100 to 995 / 132 / 1%/step]
2-431-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[100 to 995 / 184 / 1%/step]
2-431-039Wide Roller:paperTransfer:Low:1Side:S5ENG[100 to 995 / 132 / 1%/step]
2-431-040Wide Roller:paperTransfer:Low:2Side:S5ENG[100 to 995 / 184 / 1%/step]
2432[Plain2:SizeCorrection:FC]
2-432-001PaperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-432-002PaperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-432-003PaperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-432-004PaperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-432-005PaperTransfer:Standard:1Sid:S2ENG[100 to 995 / 120 / 1%/step]
2-432-006PaperTransfer:Standard:2Sid:S2ENG[100 to 995 / 140 / 1%/step]
2-432-007PaperTransfer:Low:1Side:S2ENG[100 to 995 / 120 / 1%/step]
2-432-008PaperTransfer:Low:2Side:S2ENG[100 to 995 / 140 / 1%/step]
2-432-009PaperTransfer:Standard:1Sid:S3ENG[100 to 995 / 118 / 1%/step]
2-432-010PaperTransfer:Standard:2Sid:S3ENG[100 to 995 / 180 / 1%/step]
2-432-011PaperTransfer:Low:1Side:S3ENG[100 to 995 / 118 / 1%/step]
2-432-012PaperTransfer:Low:2Side:S3ENG[100 to 995 / 180 / 1%/step]
2-432-013PaperTransfer:Standard:1Sid:S4ENG[100 to 995 / 130 / 1%/step]
2-432-014PaperTransfer:Standard:2Sid:S4ENG[100 to 995 / 200 / 1%/step]
2-432-015PaperTransfer:Low:1Side:S4ENG[100 to 995 / 130 / 1%/step]
2-432-016PaperTransfer:Low:2Side:S4ENG[100 to 995 / 200 / 1%/step]
2-432-017PaperTransfer:Standard:1Sid:S5ENG[100 to 995 / 140 / 1%/step]
2-432-018PaperTransfer:Standard:2Sid:S5ENG[100 to 995 / 240 / 1%/step]
2-432-019PaperTransfer:Low:1Side:S5ENG[100 to 995 / 140 / 1%/step]
2-432-020PaperTransfer:Low:2Side:S5ENG[100 to 995 / 240 / 1%/step]
2-432-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-432-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-432-023Wide Roller:paperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-432-024Wide Roller:paperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-432-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[100 to 995 / 120 / 1%/step]
2-432-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[100 to 995 / 140 / 1%/step]
2-432-027Wide Roller:paperTransfer:Low:1Side:S2ENG[100 to 995 / 120 / 1%/step]
2-432-028Wide Roller:paperTransfer:Low:2Side:S2ENG[100 to 995 / 140 / 1%/step]
2-432-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[100 to 995 / 118 / 1%/step]
2-432-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[100 to 995 / 180 / 1%/step]
2-432-031Wide Roller:paperTransfer:Low:1Side:S3ENG[100 to 995 / 118 / 1%/step]
2-432-032Wide Roller:paperTransfer:Low:2Side:S3ENG[100 to 995 / 180 / 1%/step]
2-432-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[100 to 995 / 130 / 1%/step]
2-432-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[100 to 995 / 200 / 1%/step]
2-432-035Wide Roller:paperTransfer:Low:1Side:S4ENG[100 to 995 / 130 / 1%/step]
2-432-036Wide Roller:paperTransfer:Low:2Side:S4ENG[100 to 995 / 200 / 1%/step]
2-432-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[100 to 995 / 140 / 1%/step]
2-432-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[100 to 995 / 240 / 1%/step]
2-432-039Wide Roller:paperTransfer:Low:1Side:S5ENG[100 to 995 / 140 / 1%/step]
2433[Plain2:Size-Env.Correct:BW]
2-433-001PaperTransfer:Standard:1Sid:S1ENG[1 to 110 / 10 / 1/step]
2-433-002PaperTransfer:Standard:2Sid:S1ENG[1 to 110 / 15 / 1/step]
2-433-003PaperTransfer:Low:1Side:S1ENG[1 to 110 / 10 / 1/step]
2-433-004PaperTransfer:Low:2Side:S1ENG[1 to 110 / 15 / 1/step]
2-433-005PaperTransfer:Standard:1Sid:S2ENG[1 to 110 / 11 / 1/step]
2-433-006PaperTransfer:Standard:2Sid:S2ENG[1 to 110 / 16 / 1/step]
2-433-007PaperTransfer:Low:1Side:S2ENG[1 to 110 / 11 / 1/step]
2-433-008PaperTransfer:Low:2Side:S2ENG[1 to 110 / 16 / 1/step]
2-433-009PaperTransfer:Standard:1Sid:S3ENG[1 to 110 / 12 / 1/step]
2-433-010PaperTransfer:Standard:2Sid:S3ENG[1 to 110 / 17 / 1/step]
2-433-011PaperTransfer:Low:1Side:S3ENG[1 to 110 / 12 / 1/step]
2-433-012PaperTransfer:Low:2Side:S3ENG[1 to 110 / 17 / 1/step]
2-433-013PaperTransfer:Standard:1Sid:S4ENG[1 to 110 / 13 / 1/step]
2-433-014PaperTransfer:Standard:2Sid:S4ENG[1 to 110 / 18 / 1/step]
2-433-015PaperTransfer:Low:1Side:S4ENG[1 to 110 / 13 / 1/step]
2-433-016PaperTransfer:Low:2Side:S4ENG[1 to 110 / 18 / 1/step]
2-433-017PaperTransfer:Standard:1Sid:S5ENG[1 to 110 / 14 / 1/step]
2-433-018PaperTransfer:Standard:2Sid:S5ENG[1 to 110 / 19 / 1/step]
2-433-019PaperTransfer:Low:1Side:S5ENG[1 to 110 / 14 / 1/step]
2-433-020PaperTransfer:Low:2Side:S5ENG[1 to 110 / 19 / 1/step]
2-433-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[1 to 110 / 10 / 1/step]
2-432-040Wide Roller:paperTransfer:Low:2Side:S5ENG[100 to 995 / 240 / 1%/step]
2-433-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[1 to 110 / 15 / 1/step]
2-433-023Wide Roller:paperTransfer:Low:1Side:S1ENG[1 to 110 / 10 / 1/step]
2-433-024Wide Roller:paperTransfer:Low:2Side:S1ENG[1 to 110 / 15 / 1/step]
2-433-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[1 to 110 / 11 / 1/step]
2-433-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[1 to 110 / 16 / 1/step]
2-433-027Wide Roller:paperTransfer:Low:1Side:S2ENG[1 to 110 / 11 / 1/step]
2-433-028Wide Roller:paperTransfer:Low:2Side:S2ENG[1 to 110 / 16 / 1/step]
2-433-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[1 to 110 / 12 / 1/step]
2-433-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[1 to 110 / 17 / 1/step]
2-433-031Wide Roller:paperTransfer:Low:1Side:S3ENG[1 to 110 / 12 / 1/step]
2-433-032Wide Roller:paperTransfer:Low:2Side:S3ENG[1 to 110 / 17 / 1/step]
2-433-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[1 to 110 / 13 / 1/step]
2-433-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[1 to 110 / 18 / 1/step]
2-433-035Wide Roller:paperTransfer:Low:1Side:S4ENG[1 to 110 / 13 / 1/step]
2-433-036Wide Roller:paperTransfer:Low:2Side:S4ENG[1 to 110 / 18 / 1/step]
2-433-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[1 to 110 / 14 / 1/step]
2-433-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[1 to 110 / 19 / 1/step]
2-433-039Wide Roller:paperTransfer:Low:1Side:S5ENG[1 to 110 / 14 / 1/step]
2-433-040Wide Roller:paperTransfer:Low:2Side:S5ENG[1 to 110 / 19 / 1/step]
2434[Plain2:Size-Env.Correct:FC]
2-434-001PaperTransfer:Standard:1Sid:S1ENG[1 to 110 / 20 / 1/step]
2-434-002PaperTransfer:Standard:2Sid:S1ENG[1 to 110 / 25 / 1/step]
2-434-003PaperTransfer:Low:1Side:S1ENG[1 to 110 / 20 / 1/step]
2-434-004PaperTransfer:Low:2Side:S1ENG[1 to 110 / 25 / 1/step]
2-434-005PaperTransfer:Standard:1Sid:S2ENG[1 to 110 / 21 / 1/step]
2-434-006PaperTransfer:Standard:2Sid:S2ENG[1 to 110 / 26 / 1/step]
2-434-007PaperTransfer:Low:1Side:S2ENG[1 to 110 / 21 / 1/step]
2-434-008PaperTransfer:Low:2Side:S2ENG[1 to 110 / 26 / 1/step]
2-434-009PaperTransfer:Standard:1Sid:S3ENG[1 to 110 / 22 / 1/step]
2-434-010PaperTransfer:Standard:2Sid:S3ENG[1 to 110 / 27 / 1/step]
2-434-011PaperTransfer:Low:1Side:S3ENG[1 to 110 / 22 / 1/step]
2-434-012PaperTransfer:Low:2Side:S3ENG[1 to 110 / 27 / 1/step]
2-434-013PaperTransfer:Standard:1Sid:S4ENG[1 to 110 / 23 / 1/step]
2-434-014PaperTransfer:Standard:2Sid:S4ENG[1 to 110 / 28 / 1/step]
2-434-015PaperTransfer:Low:1Side:S4ENG[1 to 110 / 23 / 1/step]
2-434-016PaperTransfer:Low:2Side:S4ENG[1 to 110 / 28 / 1/step]
2-434-017PaperTransfer:Standard:1Sid:S5ENG[1 to 110 / 24 / 1/step]
2-434-018PaperTransfer:Standard:2Sid:S5ENG[1 to 110 / 29 / 1/step]
2-434-019PaperTransfer:Low:1Side:S5ENG[1 to 110 / 24 / 1/step]
2-434-020PaperTransfer:Low:2Side:S5ENG[1 to 110 / 29 / 1/step]
2-434-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[1 to 110 / 20 / 1/step]
2-434-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[1 to 110 / 25 / 1/step]
2-434-023Wide Roller:paperTransfer:Low:1Side:S1ENG[1 to 110 / 20 / 1/step]
2-434-024Wide Roller:paperTransfer:Low:2Side:S1ENG[1 to 110 / 25 / 1/step]
2-434-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[1 to 110 / 21 / 1/step]
2-434-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[1 to 110 / 26 / 1/step]
2-434-027Wide Roller:paperTransfer:Low:1Side:S2ENG[1 to 110 / 21 / 1/step]
2-434-028Wide Roller:paperTransfer:Low:2Side:S2ENG[1 to 110 / 26 / 1/step]
2-434-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[1 to 110 / 22 / 1/step]
2-434-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[1 to 110 / 27 / 1/step]
2-434-031Wide Roller:paperTransfer:Low:1Side:S3ENG[1 to 110 / 22 / 1/step]
2-434-032Wide Roller:paperTransfer:Low:2Side:S3ENG[1 to 110 / 27 / 1/step]
2-434-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[1 to 110 / 23 / 1/step]
2-434-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[1 to 110 / 28 / 1/step]
2-434-035Wide Roller:paperTransfer:Low:1Side:S4ENG[1 to 110 / 23 / 1/step]
2-434-036Wide Roller:paperTransfer:Low:2Side:S4ENG[1 to 110 / 28 / 1/step]
2-434-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[1 to 110 / 24 / 1/step]
2-434-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[1 to 110 / 29 / 1/step]
2-434-039Wide Roller:paperTransfer:Low:1Side:S5ENG[1 to 110 / 24 / 1/step]
2-434-040Wide Roller:paperTransfer:Low:2Side:S5ENG[1 to 110 / 29 / 1/step]
2435[Plain2:LeadingEdgeCorrection]
2-435-001PaperTransfer:Standard:1SideENG[0 to 995 / 100 / 5%/step]
2-435-002PaperTransfer:Standard:2SideENG[0 to 995 / 100 / 5%/step]
2-435-003Paper Transfer:Low:1sideENG[0 to 995 / 100 / 5%/step]
2-435-004Paper Transfer:Low:2sideENG[0 to 995 / 100 / 5%/step]
2436[Plain2:SwitchTimingLeadEdge]
2-436-001PaperTransfer:Standard:1sideENG[0 to 50 / 0 / 2mm/step]
2-436-002PaperTransfer:Standard:2sideENG[0 to 50 / 0 / 2mm/step]
2-436-003Paper Transfer:Low:1sideENG[0 to 50 / 0 / 2mm/step]
2-436-004Paper Transfer:Low:2sideENG[0 to 50 / 0 / 2mm/step]
2437[Plain2:TrailEdgeCorrection]
2-437-001PaperTransfer:Standard:1SideENG[0 to 995 / 100 / 5%/step]
2-437-002PaperTransfer:Standard:2SideENG[0 to 995 / 100 / 5%/step]
2-437-003Paper Transfer:Low:1sideENG[0 to 995 / 100 / 5%/step]
2-437-004Paper Transfer:Low:2sideENG[0 to 995 / 100 / 5%/step]
2438[Plain2:SwitchTimingTrailEdge]
2-438-001PaperTransfer:Standard:1sideENG[0 to 50 / 0 / 2mm/step]
2-438-002PaperTransfer:Standard:2sideENG[0 to 50 / 0 / 2mm/step]
2-438-003Paper Transfer:Low:1sideENG[0 to 50 / 0 / 2mm/step]
2-438-004Paper Transfer:Low:2sideENG[0 to 50 / 0 / 2mm/step]
2443[Middle:Bias:BW]
2-443-001PaperTransfer:standard:1sideENG[0 to 200 / 22 / 1-uA/step]
2-443-002PaperTransfer:standard:2sideENG[0 to 200 / 22 / 1-uA/step]
2-443-003PaperTransfer:low:1sideENG[0 to 200 / 11 / 1-uA/step]
2-443-004PaperTransfer:low:2sideENG[0 to 200 / 11 / 1-uA/step]
2447[Middle:Bias:FC]
2-447-001PaperTransfer:standard:1sideENG[0 to 200 / 29 / 1-uA/step]
2-447-002PaperTransfer:standard:2sideENG[0 to 200 / 29 / 1-uA/step]
2-447-003PaperTransfer:low:1sideENG[0 to 200 / 14 / 1-uA/step]
2-447-004PaperTransfer:low:2sideENG[0 to 200 / 14 / 1-uA/step]
2451[Middle:SizeCorrection:BW]
2-451-001PaperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-451-002PaperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-451-003PaperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-451-004PaperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-451-005PaperTransfer:Standard:1Sid:S2ENG[100 to 995 / 100 / 1%/step]
2-451-006PaperTransfer:Standard:2Sid:S2ENG[100 to 995 / 106 / 1%/step]
2-451-007PaperTransfer:Low:1Side:S2ENG[100 to 995 / 100 / 1%/step]
2-451-008PaperTransfer:Low:2Side:S2ENG[100 to 995 / 106 / 1%/step]
2-451-009PaperTransfer:Standard:1Sid:S3ENG[100 to 995 / 105 / 1%/step]
2-451-010PaperTransfer:Standard:2Sid:S3ENG[100 to 995 / 110 / 1%/step]
2-451-011PaperTransfer:Low:1Side:S3ENG[100 to 995 / 105 / 1%/step]
2-451-012PaperTransfer:Low:2Side:S3ENG[100 to 995 / 110 / 1%/step]
2-451-013PaperTransfer:Standard:1Sid:S4ENG[100 to 995 / 113 / 1%/step]
2-451-014PaperTransfer:Standard:2Sid:S4ENG[100 to 995 / 120 / 1%/step]
2-451-015PaperTransfer:Low:1Side:S4ENG[100 to 995 / 113 / 1%/step]
2-451-016PaperTransfer:Low:2Side:S4ENG[100 to 995 / 120 / 1%/step]
2-451-017PaperTransfer:Standard:1Sid:S5ENG[100 to 995 / 118 / 1%/step]
2-451-018PaperTransfer:Standard:2Sid:S5ENG[100 to 995 / 140 / 1%/step]
2-451-019PaperTransfer:Low:1Side:S5ENG[100 to 995 / 118 / 1%/step]
2-451-020PaperTransfer:Low:2Side:S5ENG[100 to 995 / 140 / 1%/step]
2-451-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-451-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-451-023Wide Roller:paperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-451-024Wide Roller:paperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-451-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[100 to 995 / 100 / 1%/step]
2-451-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[100 to 995 / 106 / 1%/step]
2-451-027Wide Roller:paperTransfer:Low:1Side:S2ENG[100 to 995 / 100 / 1%/step]
2-451-028Wide Roller:paperTransfer:Low:2Side:S2ENG[100 to 995 / 106 / 1%/step]
2-451-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[100 to 995 / 105 / 1%/step]
2-451-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[100 to 995 / 110 / 1%/step]
2-451-031Wide Roller:paperTransfer:Low:1Side:S3ENG[100 to 995 / 105 / 1%/step]
2-451-032Wide Roller:paperTransfer:Low:2Side:S3ENG[100 to 995 / 110 / 1%/step]
2-451-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[100 to 995 / 113 / 1%/step]
2-451-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[100 to 995 / 120 / 1%/step]
2-451-035Wide Roller:paperTransfer:Low:1Side:S4ENG[100 to 995 / 113 / 1%/step]
2-451-036Wide Roller:paperTransfer:Low:2Side:S4ENG[100 to 995 / 120 / 1%/step]
2-451-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[100 to 995 / 118 / 1%/step]
2-451-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[100 to 995 / 140 / 1%/step]
2-451-039Wide Roller:paperTransfer:Low:1Side:S5ENG[100 to 995 / 118 / 1%/step]
2-451-040Wide Roller:paperTransfer:Low:2Side:S5ENG[100 to 995 / 140 / 1%/step]
2452[Middle:SizeCorrection:FC]
2-452-001PaperTransfer:Standard:1Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-452-002PaperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-452-003PaperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-452-004PaperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-452-005PaperTransfer:Standard:1Sid:S2ENG[100 to 995 / 106 / 1%/step]
2-452-006PaperTransfer:Standard:2Sid:S2ENG[100 to 995 / 132 / 1%/step]
2-452-007PaperTransfer:Low:1Side:S2ENG[100 to 995 / 106 / 1%/step]
2-452-008PaperTransfer:Low:2Side:S2ENG[100 to 995 / 132 / 1%/step]
2-452-009PaperTransfer:Standard:1Sid:S3ENG[100 to 995 / 110 / 1%/step]
2-452-010PaperTransfer:Standard:2Sid:S3ENG[100 to 995 / 170 / 1%/step]
2-452-011PaperTransfer:Low:1Side:S3ENG[100 to 995 / 110 / 1%/step]
2-452-012PaperTransfer:Low:2Side:S3ENG[100 to 995 / 170 / 1%/step]
2-452-013PaperTransfer:Standard:1Sid:S4ENG[100 to 995 / 120 / 1%/step]
2-452-014PaperTransfer:Standard:2Sid:S4ENG[100 to 995 / 189 / 1%/step]
2-452-015PaperTransfer:Low:1Side:S4ENG[100 to 995 / 120 / 1%/step]
2-452-016PaperTransfer:Low:2Side:S4ENG[100 to 995 / 189 / 1%/step]
2-452-017PaperTransfer:Standard:1Sid:S5ENG[100 to 995 / 140 / 1%/step]
2-452-018PaperTransfer:Standard:2Sid:S5ENG[100 to 995 / 245 / 1%/step]
2-452-019PaperTransfer:Low:1Side:S5ENG[100 to 995 / 140 / 1%/step]
2-452-020PaperTransfer:Low:2Side:S5ENG[100 to 995 / 245 / 1%/step]
2-452-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[100 to 995 / 100 / 1%/step]
2-452-023Wide Roller:paperTransfer:Low:1Side:S1ENG[100 to 995 / 100 / 1%/step]
2-452-024Wide Roller:paperTransfer:Low:2Side:S1ENG[100 to 995 / 100 / 1%/step]
2-452-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[100 to 995 / 106 / 1%/step]
2-452-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[100 to 995 / 132 / 1%/step]
2-452-027Wide Roller:paperTransfer:Low:1Side:S2ENG[100 to 995 / 106 / 1%/step]
2-452-028Wide Roller:paperTransfer:Low:2Side:S2ENG[100 to 995 / 132 / 1%/step]
2-452-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[100 to 995 / 110 / 1%/step]
2-452-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[100 to 995 / 170 / 1%/step]
2-452-031Wide Roller:paperTransfer:Low:1Side:S3ENG[100 to 995 / 110 / 1%/step]
2-452-032Wide Roller:paperTransfer:Low:2Side:S3ENG[100 to 995 / 170 / 1%/step]
2-452-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[100 to 995 / 120 / 1%/step]
2-452-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[100 to 995 / 189 / 1%/step]
2-452-035Wide Roller:paperTransfer:Low:1Side:S4ENG[100 to 995 / 120 / 1%/step]
2-452-036Wide Roller:paperTransfer:Low:2Side:S4ENG[100 to 995 / 189 / 1%/step]
2-452-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[100 to 995 / 140 / 1%/step]
2-452-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[100 to 995 / 245 / 1%/step]
2-452-039Wide Roller:paperTransfer:Low:1Side:S5ENG[100 to 995 / 140 / 1%/step]
2453[Middle:Size-Env.Correct:BW]
2-453-001PaperTransfer:Standard:1Sid:S1ENG[1 to 110 / 10 / 1/step]
2-453-002PaperTransfer:Standard:2Sid:S1ENG[1 to 110 / 41 / 1/step]
2-453-003PaperTransfer:Low:1Side:S1ENG[1 to 110 / 10 / 1/step]
2-453-004PaperTransfer:Low:2Side:S1ENG[1 to 110 / 41 / 1/step]
2-453-005PaperTransfer:Standard:1Sid:S2ENG[1 to 110 / 39 / 1/step]
2-453-006PaperTransfer:Standard:2Sid:S2ENG[1 to 110 / 42 / 1/step]
2-453-007PaperTransfer:Low:1Side:S2ENG[1 to 110 / 39 / 1/step]
2-453-008PaperTransfer:Low:2Side:S2ENG[1 to 110 / 42 / 1/step]
2-453-009PaperTransfer:Standard:1Sid:S3ENG[1 to 110 / 40 / 1/step]
2-453-010PaperTransfer:Standard:2Sid:S3ENG[1 to 110 / 43 / 1/step]
2-453-011PaperTransfer:Low:1Side:S3ENG[1 to 110 / 40 / 1/step]
2-453-012PaperTransfer:Low:2Side:S3ENG[1 to 110 / 43 / 1/step]
2-453-013PaperTransfer:Standard:1Sid:S4ENG[1 to 110 / 40 / 1/step]
2-453-014PaperTransfer:Standard:2Sid:S4ENG[1 to 110 / 44 / 1/step]
2-453-015PaperTransfer:Low:1Side:S4ENG[1 to 110 / 40 / 1/step]
2-453-016PaperTransfer:Low:2Side:S4ENG[1 to 110 / 44 / 1/step]
2-453-017PaperTransfer:Standard:1Sid:S5ENG[1 to 110 / 40 / 1/step]
2-453-018PaperTransfer:Standard:2Sid:S5ENG[1 to 110 / 45 / 1/step]
2-453-019PaperTransfer:Low:1Side:S5ENG[1 to 110 / 40 / 1/step]
2-453-020PaperTransfer:Low:2Side:S5ENG[1 to 110 / 45 / 1/step]
2-453-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[1 to 110 / 10 / 1/step]
2-452-040Wide Roller:paperTransfer:Low:2Side:S5ENG[100 to 995 / 245 / 1%/step]
2-453-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[1 to 110 / 41 / 1/step]
2-453-023Wide Roller:paperTransfer:Low:1Side:S1ENG[1 to 110 / 10 / 1/step]
2-453-024Wide Roller:paperTransfer:Low:2Side:S1ENG[1 to 110 / 41 / 1/step]
2-453-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[1 to 110 / 39 / 1/step]
2-453-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[1 to 110 / 42 / 1/step]
2-453-027Wide Roller:paperTransfer:Low:1Side:S2ENG[1 to 110 / 39 / 1/step]
2-453-028Wide Roller:paperTransfer:Low:2Side:S2ENG[1 to 110 / 42 / 1/step]
2-453-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[1 to 110 / 40 / 1/step]
2-453-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[1 to 110 / 43 / 1/step]
2-453-031Wide Roller:paperTransfer:Low:1Side:S3ENG[1 to 110 / 40 / 1/step]
2-453-032Wide Roller:paperTransfer:Low:2Side:S3ENG[1 to 110 / 43 / 1/step]
2-453-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[1 to 110 / 40 / 1/step]
2-453-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[1 to 110 / 44 / 1/step]
2-453-035Wide Roller:paperTransfer:Low:1Side:S4ENG[1 to 110 / 40 / 1/step]
2-453-036Wide Roller:paperTransfer:Low:2Side:S4ENG[1 to 110 / 44 / 1/step]
2-453-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[1 to 110 / 40 / 1/step]
2-453-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[1 to 110 / 45 / 1/step]
2-453-039Wide Roller:paperTransfer:Low:1Side:S5ENG[1 to 110 / 40 / 1/step]
2-453-040Wide Roller:paperTransfer:Low:2Side:S5ENG[1 to 110 / 45 / 1/step]
2454[Middle:Size-Env.Correct:FC]
2-454-001PaperTransfer:Standard:1Sid:S1ENG[1 to 110 / 20 / 1/step]
2-454-002PaperTransfer:Standard:2Sid:S1ENG[1 to 110 / 49 / 1/step]
2-454-003PaperTransfer:Low:1Side:S1ENG[1 to 110 / 20 / 1/step]
2-454-004PaperTransfer:Low:2Side:S1ENG[1 to 110 / 49 / 1/step]
2-454-005PaperTransfer:Standard:1Sid:S2ENG[1 to 110 / 46 / 1/step]
2-454-006PaperTransfer:Standard:2Sid:S2ENG[1 to 110 / 50 / 1/step]
2-454-007PaperTransfer:Low:1Side:S2ENG[1 to 110 / 46 / 1/step]
2-454-008PaperTransfer:Low:2Side:S2ENG[1 to 110 / 50 / 1/step]
2-454-009PaperTransfer:Standard:1Sid:S3ENG[1 to 110 / 47 / 1/step]
2-454-010PaperTransfer:Standard:2Sid:S3ENG[1 to 110 / 51 / 1/step]
2-454-011PaperTransfer:Low:1Side:S3ENG[1 to 110 / 47 / 1/step]
2-454-012PaperTransfer:Low:2Side:S3ENG[1 to 110 / 51 / 1/step]
2-454-013PaperTransfer:Standard:1Sid:S4ENG[1 to 110 / 48 / 1/step]
2-454-014PaperTransfer:Standard:2Sid:S4ENG[1 to 110 / 52 / 1/step]
2-454-015PaperTransfer:Low:1Side:S4ENG[1 to 110 / 48 / 1/step]
2-454-016PaperTransfer:Low:2Side:S4ENG[1 to 110 / 52 / 1/step]
2-454-017PaperTransfer:Standard:1Sid:S5ENG[1 to 110 / 48 / 1/step]
2-454-018PaperTransfer:Standard:2Sid:S5ENG[1 to 110 / 53 / 1/step]
2-454-019PaperTransfer:Low:1Side:S5ENG[1 to 110 / 48 / 1/step]
2-454-020PaperTransfer:Low:2Side:S5ENG[1 to 110 / 53 / 1/step]
2-454-021Wide Roller:paperTransfer:Standard:1Sid:S1ENG[1 to 110 / 20 / 1/step]
2-454-022Wide Roller:paperTransfer:Standard:2Sid:S1ENG[1 to 110 / 49 / 1/step]
2-454-023Wide Roller:paperTransfer:Low:1Side:S1ENG[1 to 110 / 20 / 1/step]
2-454-024Wide Roller:paperTransfer:Low:2Side:S1ENG[1 to 110 / 49 / 1/step]
2-454-025Wide Roller:paperTransfer:Standard:1Sid:S2ENG[1 to 110 / 46 / 1/step]
2-454-026Wide Roller:paperTransfer:Standard:2Sid:S2ENG[1 to 110 / 50 / 1/step]
2-454-027Wide Roller:paperTransfer:Low:1Side:S2ENG[1 to 110 / 46 / 1/step]
2-454-028Wide Roller:paperTransfer:Low:2Side:S2ENG[1 to 110 / 50 / 1/step]
2-454-029Wide Roller:paperTransfer:Standard:1Sid:S3ENG[1 to 110 / 47 / 1/step]
2-454-030Wide Roller:paperTransfer:Standard:2Sid:S3ENG[1 to 110 / 51 / 1/step]
2-454-031Wide Roller:paperTransfer:Low:1Side:S3ENG[1 to 110 / 47 / 1/step]
2-454-032Wide Roller:paperTransfer:Low:2Side:S3ENG[1 to 110 / 51 / 1/step]
2-454-033Wide Roller:paperTransfer:Standard:1Sid:S4ENG[1 to 110 / 48 / 1/step]
2-454-034Wide Roller:paperTransfer:Standard:2Sid:S4ENG[1 to 110 / 52 / 1/step]
2-454-035Wide Roller:paperTransfer:Low:1Side:S4ENG[1 to 110 / 48 / 1/step]
2-454-036Wide Roller:paperTransfer:Low:2Side:S4ENG[1 to 110 / 52 / 1/step]
2-454-037Wide Roller:paperTransfer:Standard:1Sid:S5ENG[1 to 110 / 48 / 1/step]
2-454-038Wide Roller:paperTransfer:Standard:2Sid:S5ENG[1 to 110 / 53 / 1/step]
2-454-039Wide Roller:paperTransfer:Low:1Side:S5ENG[1 to 110 / 48 / 1/step]
2-454-040Wide Roller:paperTransfer:Low:2Side:S5ENG[1 to 110 / 53 / 1/step]
Engine SP Mode Tables
2455[Middle:LeadingEdgeCorrection]
2-455-001PaperTransfer:Standard:1SideENG[0 to 995 / 100 / 5%/step]
2-455-002PaperTransfer:Standard:2SideENG[0 to 995 / 100 / 5%/step]
2-455-003Paper Transfer:Low:1sideENG[0 to 995 / 100 / 5%/step]
2-455-004Paper Transfer:Low:2sideENG[0 to 995 / 100 / 5%/step]
2456[Middle:SwitchTimingLeadEdge]
2-456-001PaperTransfer:Standard:1sideENG[0 to 50 / 0 / 2mm/step]
2-456-002PaperTransfer:Standard:2sideENG[0 to 50 / 0 / 2mm/step]
2-456-003Paper Transfer:Low:1sideENG[0 to 50 / 0 / 2mm/step]
2-456-004Paper Transfer:Low:2sideENG[0 to 50 / 0 / 2mm/step]
2457[Middle:TrailEdgeCorrection]
2-457-001PaperTransfer:Standard:1SideENG[0 to 995 / 100 / 5%/step]
