No. | Type | Error Name/Error Condition/Major Cause/Solution |
SC817-00 | D | Monitor error: File detection / Digital signature error |
- Bootloader cannot read any of diagnostic module, kernel, or root filesystem.
- In a bootloader SD card, the digital signature checking for any of diagnostic module, kernel, or root filesystem is failed.
- Any of the following items does not exist or is broken OS Flash ROM, Diagnostic module in SD card, Kernel, Root filesystem
- Any of the following items is revised fraudulently: Diagnostic module in SD card, Kernel, Root filesystem
- ROM update for controller system
- Use another booting SD card having a valid digital signature
SC818-00 | D | Watchdog timer error |
The system program fell into a bus-hold state or an endless loop of the program interruption occurred, causing other process to stop. | | |
- System program defective
- Controller board defective
- Optional board defective
- Turn the main power OFF/ON.
- Replace the controller board.
SC819-00 | D | Kernel halt error
[xxxx]: Detailed error code |
Due to a control error, a RAM overflow occurred during system processing. One of the following messages was displayed on the operation panel. | | |
| [0x5032] | HAIC-P2 error |
HAIC-P2 decompression error (An error occurred in the ASIC compression/decompression module.) | | |
- The code data saved in the HDD was broken for an unexpected reason. (HDD device defective)
- The code data saved to memory was broken for an unexpected reason. (Memory device defective)
- ASIC defective
- Data other than code data was unzipped due to a software malfunction.
- Replace the HDD.
- Replace the memory
- Fix the software
| [0x5245] | Link up error |
Link up transaction between Engine ASIC and Veena was not completed within 100 ms. | | |
Either one of following message appears on console if Link up error occurs.
RESUME CI-Express bus ROOT_DL status error RESUME CI-Express bus DETUP status error "0x53554D45" -> Link up error
Also, error code "0x5245" and detail code ""0x53554D45" -> Link up error" appears on operation panel. | | |
- Replace the controller board or the engine board (IPU, BCU)
| [0x5355] | L2 status time out |
L2 status register between Engine ASIC and Veena was not reached the target value within 1 sec. | | |
| | Engine ASIC during operation was rebooted or shifted to energy saving mode.
Machine reboots when SC23x, SC30x occurs.
If Engine ASIC is working when rebooting (or shifting to the energy saving mode), L2 status value is not on target.
The following message appears on console. SUSPEND CI-Express L2 Status Check Error SUSPEND CI-Express L2 Status Check Error
Also, error code "0x5355" and detail code ""0x5350454E44" -> L2 status time out" appears on operation panel. |
| [0x6261] | HDD defective |
Received file system data was broken even if the initialization succeeds and there was no error reply from the HDD. | | |
Power supply disconnection during data writing to the HDD. | | |
Replace the HDD.
This SC may occur when turning on the machine for the first time with a new HDD. In this case, turn the main power off/on. | | |
| [0x696e] | gwinit processing end |
If the SCS process is ended for some reason | | |
If an unexpected error occurs at SCS processing end, gwint processing also halts (this result is judged a kernel stop error, by gwinit specification)
"0x69742064" -> "init died" | | |
Turn the main power OFF/ON. | | |
| [0x766d] | VM full error |
Occurs when too much RAM is used during system processing | | |
"vm_pageout: VM is full" | | |
| Console string | Other error (characters on operation panel) |
System detected internal mismatch error | | |
- Software defective
- Insufficient memory
- Hardware driver defective (RAM, flash memory)
- Replace with a larger capacity RAM, or flash memory.
- Replace the connected controller option with a new one.
SC820-00 | C | Self-diagnostics error: CPU [XXXX]: Detailed error code |
[0612] | ASIC interrupt error | |
Interrupt occurs in an ASIC. | | |
- ASIC device error
- Peripherals device error
SC821-00 | D | Self-diagnostics error: ASIC [xxxx]: Detailed error code |
[0B00] | ASIC register check error | |
The write-&-verify check has occurred in the ASIC. | | |
Defective ASIC device | | |
Replace the controller board. | | |
[0B06] | ASIC detection error | |
Error in the I/O ASIC for system control detection | | |
- Defective ASIC
- Defective North Bridge and PCII/F
| [0D05] | Comparison error of CPU and ASIC timer |
The CPU checks if the ASIC timer works correctly compared with the CPU timer. If the ASIC timer does not function in the specified range, this SC code is displayed. | | |
- Defective ASIC timer device
- Defective CPU device
[50A1] | Video bridge device detection error | |
Video bridge device is not detected. | | |
- Video bridge device ASIC (HARP or KLAVIER) defective.
- Connection error between PCI I / F of the controller ASIC and video bridge device ASIC.
Replace the controller board | | |
[50A2] | Video bridge device (ASIC) register error | |
The CPU detects the video bridge device, but detects error data from the video bridge device. | | |
Defective I/F between the video bridge device and the controller | | |
No. |
Type | Details (Symptom, Possible Cause, Troubleshooting Procedures) |
SC822-00 | D | Self-diagnostic error: HDD [xxxx]: Detailed error code |
[3003] | HDD timeout | |
Check performed only when HDD is installed:
- HDD device busy for over 31sec.
- After a diagnostic command is set for the HDD, but the device remains busy for over 6sec.
- HDD defective
- HDD harness disconnected, defective
- Replace the HDD.
- Replace the HDD connector.
[3004] | Diagnostic command error | |
No response to the self-diagnostic command from the ASIC to the HDD. | | |
HDD defective | | |
Replace the HDD. | | |
| [3013] | HDD timeout (first machine) |
HDD device busy for over 31 seconds.
A diagnostic command is set for the HDD, but the device remains busy for over 6 seconds. | | |
- Defective HDD device
- Defective HDD connector
- Defective ASIC device
- Replace or remove the HDD device.
No. |
| [3014] | Diagnostics command error (First machine) |
Result of the issuance of diagnostic command is error. | | |
Defective HDD device | | |
Replace the HDD device. | | |
SC823-00 | B | Self-diagnostics error: NIC [XXXX]: Detailed error code |
[6101] | MAC address check sum error | |
The result of the MAC address check sum does not match the check sum stored in ROM. | | |
- Defective SEEP ROM
- Defective I2C bus (connection)
[6104] | PHY IC error | |
The PHY IC on the controller cannot be correctly recognized. | | |
- Defective PHY chip
- Defective ASIC MII I/F
[6105] | PHY IC loop-back error | |
An error occurred during the loop-back test for the PHY IC on the controller. | | |
- PHY chip
- Defective MAC of ASIC (SIMAC/COMIC/CELLO)
- Defective I/F with the PHY board
- Defective solder on the PHY board
SC824-00 | C | Self-diagnostics error: NVRAM (resident) [XXXX]: Detailed error code |
[1401] | NVRAM verify error | |
NVRAM device is missing or NVRAM device is damaged. | | |
- The NVRAM device is missing.
- The NVRAM device is damaged.
- NVRAM backup battery exhausted
- NVRAM socket damaged
Replace the NVRAM device. | | |
SC833-00 | D | Self-diagnostic error: Engine I/F ASIC [XXXX]: Detailed error code |
[0F30] | Engine I/F ASIC detection error | |
ASIC (Mandolin) for engine control could not be detected. | | |
ASIC (Mandolin) error | | |
Replace the Engine I/F board (mother board). | | |
[50B1] | Video device: clock generator detection error | |
Could not initialize or read the bus connection. | | |
- Defective connection bus
- Defective SSCG
[50B2] | Video device: clock generator verify error | |
Value of the SSCG register is incorrect. | | |
- Defective SSCG
SC834-00 | D | Self-diagnostic error: Optional memory |
[5101] | Engine I/F optional memory verify error | |
An error occurs after write/verify check for optional RAM on the engine I/F board (mother board). | | |
Defective memory device | | |
SC835-00 | B | Self-diagnostic error: Centronic device [xxxx]: Detailed error code |
[1102] | Verify error | |
The loopback connector is connected but check results is an error. | | |
- IEEE1284 connector error
- Centronic loopback connector defective
[110C] | DMA verify error | |
- ASIC device error
- Centronic loopback connector is defective
[1120] | Loopback connector not detected | |
Centronic loopback connector is not connected for detailed self-diagnostic test. | | |
- Centronic loopback connector not connected correctly
- ASIC device is defective
- Connect the centronic loopback connector
- Replace the centronic loopback connector
SC838-00 | C | Self-diagnostic Error: Clock Generator [xxxx]: Detailed error code |
[2701] | Verify error | |
A verify error occurred when setting data was read from the clock generator via the I2C bus. | | |
- Defective clock generator
- Defective I2C bus
- Defective I2C port on the CPU
SC839-00 | D | Self-diagnostic Error: Serial Flash [xxxx]: Detailed error code |
[9001] | Serial Flash access error | |
USB NAND Flash ROM cannot be read. | | |
Defective controller board | | |
SC840-00 | D | EEPROM access error |
- During the I/O processing, a reading error occurred. The 3rd reading failure causes this SC code.
- During the I/O processing, a writing error occurred.
SC841-00 | D | EEPROM read data error |
Mirrored data of the EEPROM is different from the original data in EEPROM. | | |
Data in the EEPROM is overwritten for some reason. | | |
SC842-00 | C | Nand-Flash updating verification error |
SCS write error (verify error) occurred at the Nand-Flash module when remote ROM or main ROM was updated. | | |
Nand-Flash defective | | |
SC842-01 | C | Insufficient Nand-Flash blocks (threshold exceeded) |
At startup, or when machine returned from low power mode, the Nand-Flash status was read and judged that the number of unusable blocks had exceeded threshold, and then SCS generated the SC code. | | |
Number of unusable blocks exceeded threshold for Nand-Flash | | |
SC842-02 | C | Number of Nand-Flash block deletions exceeded |
At startup, or when the machined returned from low power mode, the Nand-Flash was read and judged that the number of deleted blocks had exceeded threshold, and then SCS generated this SC code. | | |
Number of blocks deleted exceeded threshold for Nand-Flash | | |
SC845 | | Hardware Error Detected when the automatic firmware update |
SC845-01 | D | Engine Board |
SC845-02 | D | Controller Board |
SC845-03 | D | Operation Panel (Normal) |
SC845-04 | D | Operation Panel (Smart Panel) |
SC845-05 | D | FCU |
| | When updating the firmware automatically (ARFU), the firmware cannot be read or written normally, and the firmware update cannot be completed even by 3 retries. |
| | Hardware abnormality of the target board |
Replacing the target board
For SC845-02, HDD and memory may cause the problem. Replace the HDD or memory if the SC cannot be recovered by replacing the controller board. | | |
SC853-00 | B | Bluetooth device connection error |
The Bluetooth hardware (USB type) was connected after the machine was turned on. | | |
Always connect the Bluetooth device (USB type) before the machine is turned on. | | |
SC854-00 | B | Bluetooth device disconnected |
The Bluetooth hardware (USB type) was disconnected after the machine was turned on. | | |
Never remove Bluetooth (USB type) after machine starts | | |
SC855-01 | B | Wireless LAN board error (driver attachment failure) |
Wireless LAN board error (wireless LAN card: 802.11 is covered) | | |
- Defective wireless LAN board
- Loose connection
- Replace wireless LAN board
SC855-02 | B | Wireless LAN board error (driver initialization failure) |
- Loose connection
SC857-00 | B | USB I/F Error |
The USB interface is unusable because of a driver error. | | |
USB driver error (There are three causes of USB error: RX error/CRC error/STALL. SC is issued only in the case of STALL.) | | |
- Check USB connection.
SC858-00 | A | Data encryption conversion error (Key Setting Error) |
A serious error occurred during an attempt to update the encryption key. | | |
- USB Flash, other data, corrupted
- Communication error caused by electrostatic noise
SC858-01 | A | Data encryption conversion error (HDD Key Setting Error) |
- If the error persists, replace the controller board.
SC858-02 | A | Data encryption conversion error (NVRAM Read/Write Error) |
A serious error occurred after data conversion during an attempt to update the encryption key. | | |
NVRAM defective | | |
- Replace the NVRAM.
SC858-30 | A | Data encryption conversion error (NVRAM Before Replace Error) |
Software error such as conversion parameters being invalid. | | |
SC858-31 | A | Data encryption conversion error (Other Error) |
Controller board defective | | |
SC859-00 | B | Data encryption conversion HDD conversion error |
When the data encryption key was updated, HDD data was converted, but not correctly. Image displayed at conversion only (this SC is not displayed), but SC is displayed after machine is cycled off/on. | | |
- HDD conversion was set with the data encryption key update function, but the HDD was removed.
- Machine lost power during data encryption key update
- Electrostatic noise, or an HDD error occurred, during data encryption key update, and data was not encrypted.
- Check HDD connection.
- Format the HDD (SP5-832: HDD formatting).
- If there is a problem with the HDD, it has to be replaced.
SC859-01 | B | Data encryption conversion HDD conversion error (HDD check error) |
SC859-02 | B | Data encryption conversion HDD conversion error (Power failure during conversion) |
Details:
NVRAM/HDD conversion is incomplete. | | |
Power failure occurred during encryption key update. | | |
The display after restart instructs the user to format the HDD. | | |
SC859-10 | B | Data encryption conversion HDD conversion error (Data read/write command error) |
Details:
Abnormal DMAC return value has been received two or more times (DMAC timeout, serial communication error etc.) | | |
HDD was not successfully converted during encryption key update due to HDD errors or cable noises. | | |
SC860-00 | B | HDD startup error at main power on (HDD error) |
- The HDD is connected but the driver detected the following errors.
- SS_NO.T_READY:/* (-2)HDD does not become READY*/
- SS_BAD_LABEL:/* (-4)Wrong partition type*/
- SS_READ_ERROR:/* (-5)Error occurred while reading or checking the label*/
- SS_WRITE_ERROR:/* (-6)Error occurred while writing or checking the label*/
- SS_FS_ERROR:/* (-7)Failed to repair the filesystem*/
- SS_MOUNT_ERROR:/* (-8)Failed to mount the filesystem*/
- SS_COMMAND_ERROR:/* (-9)Drive not responding to command*/
- SS_KERNEL_ERROR:/* (-10)Internal kernel error*/
- SS_SIZE_ERROR:/* (-11)Drive size too small*/
- SS_NO._PARTITION:/* (-12)The specified partition does not exist*/
- SS_NO._FILE:/* (-13)Device file does not exist*/
- Attempted to acquire HDD status through the driver but there has been no response for 30 seconds or more.
- Unformatted HDD
- Label data corrupted
- HDD defective
Format the HDD (SP5-832: HDD formatting) through SP mode. | | |
SC862-00 | D | Number of the defective sector reaches the maximum count |
101 defective sectors are generated at the image storage area in the HDD. | | |
SC863 occurs during the HDD reading and defective sectors are registered up to 101. | | |
- Format the HDD with SPSP5-832.
- Replace the HDD.
SC863-01 | D | HDD data read failure |
The data written to the HDD cannot be read normally. | | |
Bad sectors were generated during operation.
(An error occurred in an area that does not belong to a partition, such as the disk label area.) | | |
Guide for when to replace the HDD
- When SC863 has occurred ten times or more
- The interval is short.
- Repeatedly occurs in the same situation (At power-on, etc.).
- Startup takes a long time when the main power is turned on.
- It takes a long time after main power on for the operation panel to become ready.
HDD access may be consuming time. Normal HDD access time after main power on is about 5 seconds. If the machine is not waiting for the engine to be ready and it still takes 20 to 30 seconds or more, the HDD may be the cause. If there is a problem with the HDD, HDD-related SCs such as SC860 and SC863 will occur frequently. Print the SC log data and check them. | | |
SC863-02
to 23 | D | HDD data read failure |
(An error occurred in partition "a" (SC863-02) to partition "v"
(SC863-23)). | | |
SC864-00 | D | HD data CRC error |
During HD operation, the HD cannot respond to a CRC error query. Data transfer did not execute normally while data was being written to the HD. | | |
HD defective | | |
SC864-01 | D | HDD data CRC error |
During HDD operation, the HDD cannot respond to a CRC error query. Data transfer did not execute normally while data was being written to the HDD. | | |
- Format the HDD.
- Replace the HDD.
SC864-02
to 23 | D | HDD data CRC error |
(An error occurred in partition "a" (SC864-02) to partition "v" (SC864-23)). | | |
- Format the HDD.
- Replace the HDD.
SC865-00 | D | HD access error |
During HDD operation, the HDD returned an error. | | |
The HDD returned an error that does not constitute SC863 (bad sector) or SC864 (CRC error). | | |
SC865-01 | D | HDD access error |
SC865-02
to 23 | D | HDD access error |
(An error occurred in partition "a" (SC865-02) to partition "v" (SC865-23)). | | |
SC865-50
to 73 | D | HDD time-out error |
The machine does not detect a reply from the HDD during the HDD operation. | | |
The HDD does not respond to the read/ write command from the machine. | | |
- Check the harness connections between the controller board and HDD.
- Replace the HDD.
SC866-00 | B | SD card authentication error |
A license error of an application that is started from the SD card was detected. | | |
Invalid program data is stored on the SD card. | | |
Store a valid program data on the SD card. | | |
SC867-00 | C | SD card removed |
The SD card was removed while the machine is on. | | |
An application SD card has been removed from the slot (mount point of /mnt/sd0). | | |
SC867-01 | C | SD card removed |
An application SD card has been removed from the slot (mount point of /mnt/sd1). | | |
SC867-02 | C | SD card removed |
An application SD card has been removed from the slot (mount point of /mnt/sd2). | | |
SC868-** | | SD card access error |
SC868-00 | D | The SD controller returned an error during operation. (An error occurred at the mount point of /mnt/sd0) |
SC868-01 | D | The SD controller returned an error during operation. (An error occurred at the mount point of /mnt/sd1) |
SC868-02 | D | The SD controller returned an error during operation. (An error occurred at the mount point of /mnt/sd2) |
- SD card defective
- SD controller defective
Slot number is displayed on the sub code.
Detail code is described in SMC print can confirm the details of the error.
- -13 to -3: File system check error
- Otherwise (no code, -2) : Device access error
SD card that starts an application
- Turn the main power off and check the SD card insertion status.
- If no problem is found, insert the SD card and turn the main power on.
- If an error occurs, replace the SD card.
- If the error persists even after replacing the SD card, replace the controller board.
SD card for users
1. In case of a file system error, reformat the SD card (using the "SD Formatter" made by Panasonic).*
In case of a device access error
- If an error occurs, use another SD card.
* Do not format an SD card supplied with the main machine or sold as an option. You may only format SD cards used for firmware update by a customer engineer.
SC869-** | | Malfunction of the proximity sensor (human detection sensor) is detected |
SC869-01 | C | Continuously detecting malfunction |
The proximity sensor (human detection sensor) keeps in a detection state and accumulated time exceeds 24 hours. | | |
The proximity sensor (human detection sensor) is disabled and is in the detection state at all times. | | |
SC869-02 | C | Continuously non-detecting malfunction |
In the non-detection state, the following operations are detected 20 times continuously.
- Pressing "energy saver" key or touching the operation panel
- Opening/closing the plate cover or ADF
- Setting the original
- Opening the front cover
- Opening the paper feed tray
The proximity sensor (human detection sensor) is disabled and is in the non-detection state at all times. | | |
- Go to the SP5-102-203 (AutoDetect: HumanDetectSetting).
- Cover the sensor with 10 sheets of plain paper, and then execute the SP. Make sure that it becomes "0". (Do not place your hand near the sensor, even over the paper, when covering the sensor)
- Remove the paper from the sensor and make sure that it becomes "1".
- If the sensor reacts normally in step 2 and 3, check if there are any other possible factors around the machine that may cause the temperature change such as a heater or a fan. (Deal with the issue as necessary)
- Replace the proximity sensors (human detection sensors) and proximity sensor (human detection sensor) board if an abnormal value is detected during steps 2 and 3.
- Turn on the main power on and perform steps 1, 2, and 3 again.
- If the SC is not solved, turn the main power off and replace the harness which connects the proximity sensors (human detection sensors) and the proximity sensor (human detection sensor) board.
- If the SC is still not solved, there is a possibility that other parts of the machine such as the connector at the controller side or the harness between proximity sensor (human detection sensor) board and IPU are broken.
SC870-00 | B | Address Book data error (Anytime: Address Book Error.) |
SC870-01 | B | Address Book data error (On startup: Media required for storing the Address Book is missing.) |
SC870-02 | B | Address Book data error (On startup: encryption is configured but the module required for encryption (DESS) is missing.) |
SC870-03 | B | Address Book data error (Initialization: Failed to generate a file to store internal Address Book.) |
SC870-04 | B | Address Book data error (Initialization: Failed to generate a file to store delivery sender.) |
SC870-05 | B | Address Book data error (Initialization: Failed to generate a file to store delivery destination.) |
SC870-06 | B | Address Book data error (Initialization: Failed to generate a file to store information required for LDAP search.) |
SC870-07 | B | Address Book data error (Initialization: Failed to initialize entries required for machine operation.) |
SC870-08 | B | Address Book data error (Machine configuration: HDD is present but the space for storing the Address Book is unusable.) |
SC870-09 | B | Address Book data error (Machine configuration: Inconsistency in the NVRAM area used for storing settings required for Address Book configuration.) |
SC870-10 | B | Address Book data error (Machine configuration: Cannot make a directory for storing the Address Book in the SD/USB FlashROM.) |
SC870-11 | B | Address Book data error (On startup: Inconsistency in Address Book entry number.) |
SC870-20 | B | Address Book data error (File I/O: Failed to initialize file.) |
SC870-21 | B | Address Book data error (File I/O: Failed to generate file.) |
SC870-22 | B | Address Book data error (File I/O: Failed to open file.) |
SC870-23 | B | Address Book data error (File I/O: Failed to write to file.) |
SC870-24 | B | Address Book data error (File I/O: Failed to read file.) |
SC870-25 | B | Address Book data error (File I/O: Failed to check file size.) |
SC870-26 | B | Address Book data error (File I/O: Failed to delete data.) |
SC870-27 | B | Address Book data error (File I/O: Failed to add data.) |
SC870-30 | B | Address Book data error (Search: Failed to obtain data from cache when searching in the machine Address Book. delivery destination/sender.) |
SC870-31 | B | Address Book data error (Search: Failed to obtain data from cache during LDAP search.) |
SC870-32 | B | Address Book data error (Search: Failed to obtain data from cache while searching the WS-Scanner Address Book.) |
SC870-41 | B | Address Book data error (Cache: failed to obtain data from cache.) |
SC870-50 | B | Address Book data error (On startup: Detected abnormality of the Address Book encryption status.) |
SC870-51 | B | Address Book data error (Encryption settings: Failed to create directory required for conversion between plaintext and encrypted text.) |
SC870-52 | B | Address Book data error (Encryption settings: Failed to convert from plaintext to encrypted text.) |
SC870-53 | B | Address Book data error (Encryption settings: Failed to convert from encrypted text to plaintext.) |
SC870-54 | B | Address Book data error (Encryption settings: Detected data inconsistency when reading the encrypted Address Book.) |
SC870-55 | B | Address Book data error (Encryption settings: Failed to delete file when changing encryption setting.) |
SC870-56 | B | Address Book data error (Encryption settings: Failed to erase the file that records the encryption key during an attempt to change the encryption setting.) |
SC870-57 | B | Address Book data error (Encryption settings: Failed to move a file during an attempt to change the encryption setting.) |
SC870-58 | B | Address Book data error (Encryption settings: Failed to delete a directory during an attempt to change the encryption setting.) |
SC870-59 | B | Address Book data error (Encryption settings: Detected a resource shortage during an attempt to change the encryption setting.) |
SC870-60 | B | Address Book data error (Unable to obtain the on/off setting for administrator authentication (06A and later).) |
| | When an error related to the Address Book is detected during startup or operation. |
- Software bug
- Inconsistency of Address Book source location (machine/delivery server/LDAP server)
- Inconsistency of Address Book encryption setting or encryption key (NVRAM or HDD was replaced individually without formatting the Address Book)
- Address Book storage device (SD/HDD) was temporarily removed or hardware configuration does not match the application configuration.
- Address Book data corruption was detected.
Install the device that contains address book information properly, and turn the main power off/on. If SC occurs again, do the following steps.
- After installing the HDD, or SD/USB ROM, execute SP5-846-046 (UCS Setting).
- Wait more than 3 seconds, then execute SP5-832 (HDD Formatting).
Procedure after SC870 is cleared
1. If there is backup data in SD card or Web Image Monitor, restore the address book data. (To restore from SD card, enter the encryption password which is the same as when you enter to backup.) | | |
SC871-00 | D | FCU error |
An error occurred when FCS detects FCU defective. | | |
- Time-out error
- Abnormal Parameter
- Update the firmware if more recent firmware was released.
SC872-00 | B | HDD mail reception error |
An error was detected on the HDD immediately after the machine was turned on. | | |
- HDD defective
- Power was turned off while the machine used the HDD.
- Format the HDD (SP5-832-007: HDD Formatting: Mail RX Data).).
- Replace the HDD.
- Partly received partial mail messages.
- Already-read statuses of POP3-received messages (All messages on the mail server are handled as new messages).
When you do the above, the following information will be initialized. | | |
SC873-00 | B | HDD mail reception error |
- HDD defective
- Format the HDD (SP5-832-007 : HDD Formatting: Mail RX Data).
- Replace the HDD.
- Sender’s mail text
- Default sender name/password (SMB/FTP/NCP)
- Administrator mail address
- Scanner delivery history
SC874-05 | D | Delete all error (Delete data area) : Read error |
SC874-06 | D | Delete all error (Delete data area) : Write error |
SC874-09 | D | Delete all error (Delete data area) : No response from HDD |
SC874-10 | D | Delete all error (Delete data area) : Error in Kernel |
SC874-12 | D | Delete all error (Delete data area) : No designated partition |
SC874-13 | D | Delete all error (Delete data area) : No device file |
SC874-14 | D | Delete all error (Delete data area) : Start option error |
SC874-15 | D | Delete all error (Delete data area) : No designated sector number |
SC874-16 | D | Delete all error (Delete data area) : failure in performing hdderase |
SC874-41 | D | Delete all error (Delete data area) : Other fatal errors |
SC874-42 | D | Delete all error (Delete data area) : End by cancellation |
SC874-61
to -65 | D | Delete all error (Delete data area) : library error |
SC874-66 | D | Delete all error (Delete data area) : Unavailable |
SC874-67 | D | Delete all error (Delete data area) : Erasing not finished |
SC874-68 | D | Delete all error (Delete data area) : HDD format failure (Normal) |
SC874-69 | D | Delete all error (Delete data area) : HDD format failure (Abnormal) |
SC874-70 | D | Delete all error (Delete data area) : Unauthorized library |
SC874-99 | D | Delete all error (Delete data area) : other errors |
| | An error occurred while data was being erased on HDD or NVRAM. |
- Error detected in HDD data delete program
- Error detected in NVRAM data delete program
- The "Delete All" option was not set
- Turn the main power switch off and back on, and then execute "Erase All Memory" under UP mode again. (However, if there is a defective sector or other problem with the hard disk, the error will persist even after trying the above.)
- If the "Delete All" option is not installed when this error occurs, install the option.
SC875-01 | D | Delete all error (HDD erasure) (hddchack –i error) |
SC875-02 | D | Delete all error (HDD erasure) (Data deletion failure) |
| | An error was detected before HDD/data erasure starts. (Failed to erase data/failed to logically format HDD) |
- HDD logical formatting failed.
- The modules failed to erase data.
SC876-00 | D | Log Data Error |
An error was detected in the handling of the log data at power on or during machine operation. | | |
- Damaged log data file.
- Log encryption is enabled but encryption module is not installed.
- Inconsistency of encryption key between NV-RAM and HDD.
- Software bug.
Try the SC876-01 to -99 solutions listed below. If it is not solved, do the following steps (for when only an HDD is replaced):
- Disconnect the HDD and turn ON the main power.
- Execute SP5-801-019 (Memory Clear: LCS Memory Clr) to Initialize the LCS settings.
- Turn OFF the main power.
- Connect the HDD and turn ON the main power.
- Execute SP5-832-004 (HDD Formatting (Job Log)).
- Turn ON the main power.
* The following step is to configure the logging/encryption setting again. | | |
SC876-01 | D | Log Data Error 1 |
Damaged log data file | | |
Initialize the HDD (SP5-832-004). | | |
SC876-02 | D | Log Data Error 2 |
Log encryption is enabled but encryption module is not installed. | | |
- Replace or set again the encryption module.
- Disable the log encryption setting.
SC876-03 | D | Log Data Error 3 |
Inconsistency of encryption key between NV-RAM and HDD. | | |
- Initialize LCS memory (SP5801-019).
- Initialize the HDD (SP5-832-004).
SC876-04 | D | Log Data Error 4 |
- Log encryption key is disabled but the log data file is encrypted. (NVRAM data corruption)
- Log encryption key is enabled but the log data file is not encrypted. (NVRAM data corruption)
SC876-05 | D | Log Data Error 5 |
- Only the NV-RAM has been replaced with one previously used in another machine.
- Only the HDD has been replaced with one previously used in another machine.
- Attach the original NV-RAM.
- Attach the original HDD.
- With the configuration that caused the SC, initialize the HDD (SP5-832-004).
SC876-99 | D | Log Data Error 99 |
Other causes | | |
SC877-00 | B | Data Overwrite Security card error |
The "Auto Erase Memory" function of the Data Overwrite Security is set to on but it cannot be done. | | |
- Data Overwrite Security option SD card is broken.
- Data Overwrite Security option SD card has been removed.
- If the SD card is broken, prepare a new Data Overwrite Security option SD card and replace the NVRAM.
- If the SD card has been removed, turn the main power off and reinstall a working Data Overwrite Security option SD card.
SC878-00 | D | TPM authentication error |
TPM electronic recognition failure | | |
- Update of system module attempted without correct update path
- USB flash memory not operating correctly
Trusted Platform Module
- In computing, Trusted Platform Module (TPM) is both the name of a published specification detailing a secure crypto processor that can store cryptographic keys that protect information, as well as the general name of implementations of that specification often called the "TPM chip" or "TPM Security Device" (as designated in certain Dell BIOS settings).
SC878-01 | D | USB flash error |
There is a problem in the file system of the USB flash memory. | | |
USB Flash system files corrupted | | |
SC878-02 | D | TPM error |
An error occurred in either TPM or the TPM driver | | |
TPM not operating correctly | | |
SC878-03 | D | TCSD error |
An error occurred in the TPM software stack. | | |
- TPM, TPM software cannot start
- A file required by TPM is missing
SC878-20 | D | Random number test error |
An error was detected when a random number table was generated during a self-test. The random number table is generated by TPM (Trusted Platform Module). The table generated by TPM failed the test.
TPM is defective | | |
- TPM (Trusted Platform Module) is a computer chip that can securely store information used to authenticate the platform. This information can include passwords, certificates, and encryption keys.
SC880-00 | D | MLB error |
Reply to MLB access was not returned within a specified time. | | |
MLB defective | | |
- Replace the MLB.
- Remove the MLB.
- Troubleshooting
SC881-01 | D | Management area error |
Example: When a job is sent to the printer/when logged on from the operation panel/when logged on from a Web browser | | |
- A problem was detected in the software
- This error may even occur is an IC card option is not installed.
- This is caused by accumulation of abnormal authentication information in the software. (User operation will not directly cause it.)
- At login
SC899-00 | D | Software performance error (signal reception end) |
Unknown software error occurred. | | |
Occurs when an internal program behaves abnormally. | | |
In the case of a hardware defect
In the case of a software error | | |
- Replace the hardware.
- Try updating the firmware.
SERVICE CALL 900-998
SC900 (ENGINE: OTHERS)
SC No. | Type | Error Name/Error Condition/Major Cause/Solution |
SC995-01 | D | CPM setting error 1 |
Comparison of machine serial number (11 digits) and machine identification code.
Details: | | |
Machine serial number (11 digits) or machine identification code does not match. | | |
SP5-811(MachineSerial), and then turn the power on/off. | | |
- Machine serial number cannot be identified because of BICU replacement or malfunctioning.
- Machine serial number cannot be identified because of NV-RAM replacement
- Enter the machine serial number using
- Attach the NV-RAM that was installed previously.
SC995-02 | D | CPM setting error 2 |
Details:
Machine serial number cannot be identified because of NV-RAM replacement or malfunctioning. | | |
- Download data on the NV-RAM using SP5-825 (NV-RAM Data Download).
SC995-03 | D | CPM setting error 3 |
Details:
Unable to recognize machine identification code because the controller was replaced incorrectly or is malfunctioning. | | |
Replace it with a specified controller. | | |
SC995-04 | D | CPM setting error 4 |
Comparison of machine serial number (11 digits) and machine identification code. | | |
Return the parts to the original configuration, and then replace them according to the manual. | | |
SC900 (CONTROLLER)
SC900-00 | A | Electric counter error |
The electric total counter value is out of specification. Error is detected when increasing the total counter. | | |
Replace the NV-RAM. | | |
- Unexpected NV-RAM is attached.
- NV-RAM defective
- NV-RAM data corrupted.
- Data written to unexpected area because of external factor etc.
- The count requested by the SRM on receiving PRT is not completed.
SC910-01 | C | External controller error 1 |
SC910-02 | C | External controller error 2 |
SC910-03 | C | External controller error 3 |
| | -01 |
The external controller receives the unexpected command from | | |
the engine side. | | |
-02 | | |
The external controller wrongly receives the command from the | | |
engine side. | | |
-03 | | |
The external controller receives the engine status out of | | |
specification. | | |
Refer to the instructions for the external controller | | |
SC910-10 | C | External controller error 1 |
The external controller error is detected due to other reason shown in SC910-01 to -03. | | |
SC919-00 | D | External controller down |
While EAC (External Application Converter), the conversion module, was operating normally, the receipt of a power line interrupt signal from the FLUTE serial driver was detected, of BREAK signal from the other station was detected. | | |
External controller and the machine had been operating correctly (*) but the external controller was turned off or rebooted, or the video bus was disconnected.
* Printing or scanning using the external controller. | | |
SC920-02 | B | Printer application error (WORK memory cannot be acquired) |
SC920-04 | B | Printer application error (Filter process ended abnormally) |
| | An error was detected in the application, and no further operation is possible. |
- There is a bug in the software.
- The hardware configuration is not as planned (for example, insufficient memory).
- Increase the memory storage capacity.
SC921-00 | B | Printer application error (Resident font not found) |
The resident fonts cannot be found at printer startup. | | |
The resident font file is missing. | | |
Turn the main power off/on. | | |
SC925-00 | B | NetFile function error |
SC925-01 | B | NetFile function error |
| | The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. |
- HDD defective
- HDD inconsistency caused by power failure during HDD access, etc.
- Software bug
| | If another SC related to HDD errors (SC860 to SC865) is issued at the same time, the HDD is the cause. Solve the other SC.
Procedure:
Approval by the customer is required because documents and Address Book information in the HDD will be lost.
Received fax messages stored are protected but the order may be changed. |
- If SC860 to SC865 is not issued
- Turn the main power off/on.
- If this does not work, initialize the HDD NetFile partition (SP5-832-011: HDD Formatting (Ridoc I/F)). Approval by the customer is required because received fax message waiting to be delivered and documents waiting to be captured will be lost.
- Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
- In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
- Do SP5-832-011, then turn the machine power off and on.
- If this does not solve the problem, initialize all partitions of the HDD (SP5-832-001: HDD Formatting (ALL)), then turn the machine power off and on.
- If this does not solve the problem, replace the HDD.
- Troubleshooting
SC990-00 | D | Software operation error |
Software attempted an unexpected operation. | | |
- Parameter error
- Internal parameter error
- Insufficient work memory
- Operation error caused by abnormalities that are normally undetectable.
- Reinstall the software of the controller and BCU board.
SC991-00 | C | Recoverable software operation error |
SC991 covers recoverable errors as opposed toCS990. | | |
Logging only | | |
- Parameter error
SC992-00 | D | Undefined SC issued. |
An SC, that is not controlled by the system, occurred. | | |
- An SC for the previous model was used mistakenly, etc.
- Basically a software bug.
SC994-00 | C | Operation error caused by abnormalities that are normally undetectable. |
An error occurred because the number of records exceeded the limit for images managed in the service layer of the firmware. | | |
This can occur if there are too many application screens open on the operation panel. | | |
Logging only. | | |
SC997-00 | D | Application function selection error |
The application selected by the operation panel key operated abnormally (No response, abnormal ending). | | |
Software bug (mainly the application) | | |
- Check the optional RAM, DIMM, boards required by the application program.
- Check if the combination of downloaded programs are correct.
SC998-00 | D | Application start error |
(No application starts/All applications have been terminated abnormally) | | |
- No application was registered to system within a specified time after the main power was turned on.
- Application started but cannot be drawn now for some reason.
- Software bug (mainly the application)
- The optional RAM, DIMM, boards required by the application program. Are not installed correctly.
- Check the combination of programs
6.12 TROUBLESHOOTING FOR SC ERRORS
6.12.1 WHEN SC285-02 (MUSIC ERROR) IS DISPLAYED
Causes
- The ID sensor cannot detect the MUSIC pattern
- Color registration error is larger than the specified value [Assumed Cause]
Large drifting
"Large drifting" is the state where the color registration error is larger than the specified value. In the "Large drifting" state, the MUSIC pattern is shifted a long distance in the main scan direction (side to side), and is moved to the position where the MUSIC Sensor (TM/ID sensor) cannot be detected, or each pattern cannot be detected due to the pattern overlapping.
MUSIC pattern density error
Pattern with the lower density
Defective Image transfer belt/Image transfer unit
- Belt scratched
- Belt corrugation, belt skew
- Cleaning failure
- Background stains
- Filming
"Filming" is a phenomenon where surface properties change over time.
Glossiness is one of the surface properties. In the "Filming" state, the whole or part (belt shaped) of the Image Transfer Belt surface becomes foggy. "Filming" changes reflected light, and the MUSIC Sensor (TM/ID sensor) may detect the input wrongly, which causes an error.
MUSIC sensor (TM/ID sensor) defective
- Connector/ harness disconnected
- Sensor surface dirty
- Sensor malfunction
- BCU malfunction
Paper transfer contact/release mechanism defective
- Motor/ sensor malfunction
- Imaging IOB malfunction
Laser optics positioning motor in laser unit defective
- Motor malfunction
Solutions
As SC285-02 is a logging SC (SC Type C), it is not displayed at once when an error occurs. Though the equipment can be operated, check the SC history and perform a recovery operation if the SC has occurred.
Countermeasure (1): Large drifting
An abnormal value may be contained in the SP where the MUSIC corrected result is saved.
- Execute SP2-180-001 (Line Pos. Adj.: Clear Color Regist.).
- Execute SP2-111-004 (Forced Line Position: Adj. Mode d).
- Execute SP2-194-007 (MUSIC Execution Result: Execution Result).
Countermeasure (2): MUSIC pattern density Error
Execute MUSIC and check the result.
1. Execute SP3-011-001 (Manual ProCon :Exe : Normal ProCon).
