Ricoh MP C2004/C2504 Service Manual Part 17
SC No.TypeError Name/Error Condition/Major Cause/Solution
SC667-40DMacaron1 Mode Setting Error
The machine detects the Macaron1 mode error when starting up, or recovery from energy saver mode.
The following board defects (Parts implementation defect, solder scrap, implemented parts defect, etc.);
  • BCU
  • IPU
  1. Turn the main power OFF/ON.
  2. Replace the IPU.
  3. Reconnect the harness between BCU and IPU.
  4. Replace the harness between BCU and IPU.
  5. Replace the BCU.
SC667-41DMacaron2 Mode Setting Error
The machine detects the Macaron2 mode error when starting up, or recovery from energy saver mode.
  • BCU
  • IPU
  2. Replace the IPU.
  5. Replace the BCU.
SC668-01DVodka1 Version Setting Error
The machine detects the version settings error in Vodka1 when starting up, or recovery from energy saver mode.
  • BCU
  • Paper Transport IOB
  2. Replace the Paper Transport IOB.
  3. Replace the BCU.
SC668-02DVodka2 Version Setting Error
The machine detects the version settings error in Vodka2 when starting up, or recovery from energy saver mode.
  • BCU
  • Imaging IOB
  2. Replace the Imaging IOB.
  3. Replace the BCU.
SC668-03DVodka1,2 Version Setting Error
The machine detects the version settings error in both Vodka 1 and Vodka2 when starting up, or recovery from energy saver mode.
  • BCU
  • Imaging IOB
  2. Replace the BCU.
  3. Replace the Imaging IOB.
  4. Replace the Paper Transport IOB.
SC669-**EEPROM Communication Error
SC669-01DEEPROM OPEN: ID error
SC669-02DEEPROM OPEN: Channel error
SC669-03DEEPROM OPEN: Device error
SC669-04DEEPROM OPEN: Communication abort error
SC669-05DEEPROM OPEN: Communication timeout error
SC669-06DEEPROM OPEN: Operation stopped error
SC669-07DEEPROM OPEN: Buffer full
SC669-08DEEPROM OPEN: No error code
SC669-09DEEPROM CLOSE: ID error
SC669-10DEEPROM CLOSE: No error code
SC669-11DEEPROM Data write: ID error
SC669-12DEEPROM Data write: Channel error
SC669-13DEEPROM Data write: Device error
SC669-14DEEPROM Data write: Communication abort error
SC669-15DEEPROM Data write: Communication timeout error
SC669-16DEEPROM Data write: Operation stopped error
SC669-17DEEPROM Data write: Buffer full
SC669-18DEEPROM Data write: No error code
SC669-19DEEPROM Data read: ID error
SC669-20DEEPROM Data read: Channel error
SC669-21DEEPROM Data read: Device error
SC669-22DEEPROM Data read: Communication abort error
SC669-23DEEPROM Data read: Communication timeout error
SC669-24DEEPROM Data read: Operation stopped error
SC669-25DEEPROM Data read: Buffer full
SC669-26DEEPROM Data read: No error code
SC669-36DVerification error
SC669-37DError Detection
The TD sensor cannot be recovered after retrying N*1 times for EEPROM communication error.
(*1 SC669-01 to 26: 3, SC669-36: 2, SC669-37: 1)
  • Electrical noise
  • EEPROM not connected fully
  • EEPROM not installed
  • EEPROM damaged
  • BCU damaged
  2. Reconnect the EEPROM.
  3. Replace the EEPROM.
  4. Replace the BCU.
681-**DToner bottle: ID Chip Communication error
When error notification was received during communication with the tag and operation is not resumed after N*1 retries.
*1 See the detailed table below.
  • Corrupted ID data
  • Disconnected ID chip
  • No ID chip
  • Noise
Turn the main power off, and then do the following.
  1. Clean ID chip connections inside the toner bottle, and check if any of the ID Chip Contact Board connector pins have snapped. If there are any snapped pin, follow step 5.
  2. Reconnect the connectors between Imaging IOB and ID Chip Contact Board.
  3. Reconnect the FFC between Imaging IOB and BCU.
  4. Replace the ID Chip Contact Board.
  5. Reconnect the harness between Imaging IOB and ID Chip Contact Board.
  6. Replace the FFC between Imaging IOB and BCU.
  7. Replace the Imaging IOB.
  8. Replace the BCU.
SC681 Details​
No.DetailCausesRetry
01 - 04Invalid device IDNoise, Incorrect connection, Malfunction3
06 - 09Channel errorNoise, Incorrect connection, Malfunction3
11 - 14Device ErrorNoise, Incorrect connection3
16 - 19Communication error (interrupted)Noise, Incorrect connection3
21 - 24Communication timeoutNoise, Incorrect connection, Malfunction3
26 - 29Device stops (logically)Noise, Incorrect connection, Malfunction3
31 - 34Full of buffer (request)Noise, Incorrect connection, Malfunction3
36 - 39Verification errorNoise, Incorrect connection2
  • If the last digit of the SC’s branch number (-**) is:​
1 or 6, then do the above steps for K 2 or 7, then do the above steps for M 3 or 8, then do the above steps for C 4 or 9, then do the above steps for Y
SC682-**DTD sensor communication error
TD sensor cannot be recovered after retrying N*1 times for an ID chip communication error.
  • Corrupted ID data
  • No ID chip
  • Noise
  1. Reinstall the PCU.
  2. Reconnect the connectors between Imaging IOB and TD sensor.
  4. Replace the PCU.
  5. Reconnect the harness between Imaging IOB and TD sensor.
  8. Replace the BCU.
SC682 Details​
No.DescriptionCauseRetry
SC687-00DPER Not Received Error
Unable to receive the PER command from the controller.
Communication error
Replace the BCU.
6.8.2 SC600 (CONTROLLER)​
SC632-00DCounter device error 1
After 3 attempts to send a data frame to the optional counter device via the serial communication line, no ACK signal was received within 100 ms.
Serial line between the optional counter device, the relay board and copier control board is disconnected or damaged.
  • Turn the main power off/on.
  • Check the serial communication line.
SC633-00DCounter device error 2
After communication was established, the controller received the brake signal from the accounting device.
SC634-00DCounter device error 3
A backup RAM error was returned by the counter device.
Counter device control board or the backup battery of counter device defective
  • Replace the counter device control board.
  • Replace the backup battery.
SC635-00DCounter device error 4
A backup battery error was returned by the counter device.
SC636-01DIC Card Error (Expanded authentication module error)
Issued when expanded authentication management is set to "ON" but either of the following occur.
  • There is no expanded authentication module in the machine.
  • The SD card or the file of the expanded authentication module is broken.
  • There is no DESS module in the machine.
  • There is no DESS module in the machine (models on which the function is optional).
  • Set a working SD card/expanded authentication module file.
  • Install the DESS module.
  • In the SSP mode set SP5-401-160 to "0".
  • In the SSP mode, set SP5-401-161 to "0".
  • Replace the NVRAM.
SC636-02DIC Card Error (Version error)
The version of the expanded authentication module is not correct.
Incorrect module version
Install the correct file of the expanded authentication module.
SC637-01DTracking Information Notification Error (Tracking application error)
Tracking information was lost.
  • Tracking SDK application error
  • Internal notification error
SC637-02DTracking Information Notification Error (Management server error)
Communication with tracking management server failed.
  • Network error
  • tracking management server error
SC No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
SC641-00DCommunication error between BCU and Controller board.
Controller board does not respond after BCU tries to communicate three times.
  • Controller board software error
  • Connect error between BCU and Controller board
  • Engine board software error
  • Check connections between Controller board and BCU.
  • Turn the main switch off and on.
SC650-01CRemote Service Modem Communication Error (Dialup authentication failure)
  • An error related to communication (dialup connection, modem board etc.) using the RC Gate Type M was detected or an error that prevents RC Gate operation was detected at power on.
  • Displayed only when an error is detected while RC Gate is operating.
  • SC is not issued if an error occurs during RC Gate installation (because it can be referenced using SP).
Check the following SPs.
  • SP5-816-156
  • SP5-816-157
SC650-04CRemote Service Modem Communication Error (dialup failing because of incorrect modem configuration)
Dialup failing because of incorrect modem configuration
Check if the setting of SP5-816-160 is correct. If it is correct, then there is a software bug.
SC650-05CRemote Service Modem Communication Error (insufficient current or connection error)
Insufficient current or connection error
The line is not supported and nothing can be done.
SC650-13CRemote Service Modem Communication Error (RC Gate Type M was installed but modem is not present (detected during operation))
  • If a modem board is not installed, install it.
  • Check again if the modem driver configurations (SP5-816-160, SP5-816-165 to 171) are correct.
  • If the problem is not solved, replace the modem.
SC650-14CRemote Service Modem Communication Error (RC Gate Type N was installed but modem is present or wired/wireless LAN is not working correctly)
  • An error related to communication (dialup connection, modem board etc.) using the RC Gate was detected or an error that prevents RC Gate operation was detected at power on.
SC651-01CIllegal Remote Service Dial-up (Chat program parameter error)
An unexpected error occurred when RC Gate Type M dialed up the NRS Center.
Software bug
Logging only.
  • If a modem board is attached, remove it.
  • Check if wired/wireless LAN works.
SC651-02CIllegal Remote Service Dial-up (Chat program execution error)
An unexpected error occurred when RC Gate dialed up the NRS Center.
Software bug
Logging only.
SC652-00ARemote service ID2 mismatching
There was an authentication mismatch between ID2 for
@Remote, the controller board, and NVRAM.
  • Used controller board installed
  • Used NVRAM installed (such action is not allowed.)
  • If this occurs during RC Gate installation:
  • If this occurs after RC Gate installation:
Check the validity of the certificate and the NVRAM, check the machine serial number, write the common certificate, and then begin installation again.
Clear the RC Gate install status, check the validity of the certificate and the NVRAM, check the machine serial number, write the common certificate, and then begin installation again.
SC653-00AIncorrect remote service ID2
ID2 stored in the NVRAM has either of the following problems.
  • Number of characters is not 17.
  • Includes a character that cannot be printed.
  • All spaces
  • NULL
Replace the NVRAM.
Clear the RC Gate install status, write the common certificate, and then begin installation again.
SC670-01DEngine start up error when the machine boots up
  • /ENGRDY signal was not asserted when the machine was turned on.
  • PCI I/F is not linked up when the machine returns from energy saver mode.
  • /IPURDY signal was not asserted when the machine was turned on or returned from energy saver mode.
  • EC/PC/SC response was not received within specified time from power on.
  • Writing to Rapi driver failed (the other party not found through PCI).
  • Connection defect between controller board and IPU.
  • IPU is down / unstable
  • BCU is down / unstable
Engine board does not start up.
Refer to page 6-227 "When SC670 (Engine start up error) is displayed".
SC670-02DEngine start up error when the machine is in operation
  • CPU reset by software
  • CPU reset by anomaly CPU
  • CPU reset by hardware defect / noise
  • Hardware defect
Engine board reset unexpectedly.
SC670-03DIPU start up error when the machine boots up
VDET_EPCI signal was not asserted when the machine was turned on.
  • IPU, PSU, and/or CTL defective
  • Incorrect connection between CTL and IPU.
  • Harness of IPU disconnected
SC670-04DCommunication error between the engine and controller
Communication could not linked up.
  • IPU and/or CTL defective
SC672-10DController start up error
After the machine was powered on, communication between the controller and the operation panel was not established.
  • Controller stalled
  • Board installed incorrectly
  • Controller board defective
  • Operation panel connector loose, broken, or defective
  • Controller late
Refer to page 6-229 "When SC672 (Controller start up error) Is Displayed".
SC672-11DController start up error
After the machine was powered on, communication between the controller and the operation panel was not established, or communication with controller was interrupted after a normal startup.
  • Controller late
SC672-12DController start up error
Communication with controller was interrupted after a normal startup.
  • Controller late
SC672-13DController start up error
The operation panel detects that the controller is down due to other reason shown in SC672-10, SC672-11, and SC672-12.
  • Controller late
SC672-99DController start up error
The operation panel software ended abnormally.
  • Controller late
SC673-10DOperation panel Flair communication error (Smart Operation Panel)
This SC is issued only for the machine that has the Smart Operation Panel installed.
  • Communication between Smart Operation Panel and main machine (this is called "Flair communication") is not sent to Smart Operation Panel.
  • SP setting (SP5-748-201) for Smart Operation Panel is not activated.
The CATS module (controller) did not see the response to notification of monitoring service module (operation panel).
  • Turn the main power OFF/ON.
  • Set SP5-748-201 (OpePanel Setting: Cheetah Panel Connect Setting) to "1: Connect" if the value is "0: Not connect".
  1. SERVICE CALL 700-792​
    1. SC700 (ENGINE: PERIPHERALS)​
      SC700SPDF DF3100 (D3B0) Error
      SC700-01DADF bottom plate lift motor error
      SC700-02DADF pick-up roller lift motor
      SC700-04DADF feed motor error
      SC700-05DADF entrance motor error
      SC700-06DADF transport motor error
      SC700-07DADF scanning motor error
      SC700-09DADF exit motor error
      -01
      Even if the base plate motor is rotated in the base plate ascent
      direction, the base plate paper feed correct position sensor does
      not detect.
      Even if the base plate motor is rotated in the base plate descent
      direction, the base plate home position sensor does not detect.
      -02
      Even if the pickup arm motor is rotated, the pickup arm home
      -04, 05, 06, 07, 09
      When an error notification signal is detected during the motor
      drive period.
      -01
      -02
      -04, 05, 06, 07, 09
      Check if the SC occurs by turning the main power OFF then ON, opening/closing covers, and input/output check. If the SC occurs again, do the following steps. Check if the SC reoccurs by cycling the power after each step.
      The target parts that need to be checked are as follows;
      • Base plate paper feed correct position sensor error (output error)
      • Base plate home position sensor error (output error)
      • Base plate motor error (does not rotate)
      • Controller error
      • Pick-up home position sensor error (output error)
      • Pick-up motor error (does not rotate)
      • Controller error
      • Motor defective
      • Connector disconnected
      • Harness broken
      • Overload
      • -01: all motors, and Pick-up Roller HP Sensor
      • -02: all motors, and Bottom Plate Lift Sensor, Bottom Plate HP Sensor
      • -03, 04, 05, 06, 07, 09: all parts in ADF.
      • Check if the connector of the target part is connected securely. Reconnect the connector if it is disconnected, or loose.
      • Check the harness for the target part. Replace the harness if it is disconnected, or damaged.
      • Check if the motor runs, sensors turn OFF/ON, has no overloads, and is properly driven. Replace the parts if there are any defects.
      • Check if there are any signs of a short circuit. Replace the parts if there are any defects.
      • Troubleshooting
      SC701ARDF DF3090 (D779) Error
      SC701-03DPaper Feed Motor Driver Error
      Detection of error signal from motor driver
      SC701-08DPaper Exit Motor Driver Error
      Detection of error signal from motor driver.
      • Encoder disconnection
      • Encoder connector dropout
      • Encoder defective
      • Overload
      • Motor deterioration
      • The target parts that need to be checked are all motors, all solenoids, all clutches, and all sensors.
      • Troubleshooting
      SC702ARDF DF3090 (D779) Error
      SC702-01DProtection Device Intercept Error
      When original source 5V power supply is ON, protection device intercept of 24V power supply system is detected.
      Any of feed motor, transport motor, reverse solenoid, paper feed solenoid, paper feed clutch and FAN motor defective, a harness short-circuit occurs, and the protection device of the 24V power supply system intercepts.
      • The target parts that need to be checked are all motors, all solenoids, and all clutches.
      • Check if the specific part runs (OUTPUT Check), has no overloads, and is properly driven. Replace the part if there are any defects.
      SC702-02DProtection Device Intercept Error 2
      When original source 5V power supply is ON, protection device intercept of 24V OUT power supply system is detected.
      Solenoid defective or harness short-circuit occurs in 24VOUT power supply system.
      • Troubleshooting
      SC702-03DProtection Device Intercept Error 3
      When original source 5V power supply is ON, protection device intercept of 5VE power supply system is detected.
      Sensor defective or a harness short-circuit occur in 5VE power supply system.
      1. Check if the connector for Original Set Sensor is connected securely. Reconnect the connector if it is disconnected, or loose.
      2. Check the harness for Original Set Sensor. Replace the harness if it is disconnected, or damaged.
      3. Check if the Original Set Sensor turns OFF/ON (INPUT Check). Replace the part if there are any defects.
      4. Check if there are any signs of a short circuit. Replace the parts if there are any defects.
      SC702ARDF/SPDF Error
      SC702-04DProtection Device Intercept Error 4
      Motor defective in any of the pickup motor, completion stamp, base plate motor or FAN motor, or a harness short-circuit occurs, and the protection device of the non-interlocking power supply system intercepts.
      Motor defective or a harness short-circuit occurs in the non-interlocking power supply system.
      • The target parts that need to be checked are the Pick-up Roller Lift Motor, Stamp Solenoid, Feed Motor, and Cooling Fan Motor.
      • Check if the motor runs, has no overloads, and is properly driven. Replace the parts if there are any defects.
      • Troubleshooting
      SC702-05DProtection Device Intercept Error 5
      Motor defective in the paper feed motor, pullout motor, intermediate motor, scanner motor or paper exit motor, or a harness short-circuit occurs, and the protection device of the interlocking power supply system intercepts.
      Motor defective or a harness short-circuit occurs in the interlocking power supply system.
      • The target parts that need to be checked are the Feed Motor, Pick-up Roller Lift Motor, Relay Motor, Transport Motor, and Exit Motor.
      SC721Booklet Finisher SR3220 (D3B9) Error
      SC721-03BProtection Device Intercept Error 1
      Fuse blowout is detected
      SC721-06CSee the descriptions next table below.
      SC721-10BTransport Motor 1 Error
      Motor driver detects an error state (DC motor control error) (1st time is jam notification, 2nd time is SC notification).
      SC721-11BTransport Motor 2 Error
      SC721-17BPaper Eject Motor 2 Error
      SC721-24BPaper Exit Guide Plate Open/Close motor Error
      • During movement to home, the home position could not be detected within a predetermined pulse (1st time is jam notification, 2nd time is SC notification).
      • During movement from home, the home position was detected for longer than a predetermined pulse (1st time is jam notification, 2nd time is SC notification).
      • Troubleshooting
      SC721-25BPunch Drive Motor Error
      SC721-27BPunch Movement Motor Error
      SC721-28BPunch Horizontal Registration Detection Error
      SC721-30BJogger Motor 1 Error
      SC721-33BPositioning Roller Motor Error
      SC721-41BRelease Motor Error
      SC721-42BStapler Retreat Motor Error
      • During movement to home, the home position could not be detected within a predetermined time (1st time is jam notification, 2nd time is SC notification).
      • During movement from home, the home position was detected even after a predetermined time elapsed (1st time is jam notification, 2nd time is SC notification).
      • Output from the encoder could not be counted for a predetermined number of times within a predetermined time (1st time is jam notification, 2nd time is SC notification).
      • During movement from home, the home position was detected even after a predetermined pulse elapsed (1st time is jam notification, 2nd time is SC notification).
      • SC No.TypeError Name/Error Condition/Major Cause/Solution
        SC721-44BStapler Motor Error
        SC721-52BFolding Plate Drive Motor Error
      • During movement from home, retreat sensor ON could not be detected even after a predetermined pulse elapsed (1st time is jam notification, 2nd time is SC notification).
      • During initialization, retreat sensor ON was detected simultaneously when the home position is detected (1st time is jam notification, 2nd time is SC notification).
      • During movement to home, the home position could not be detected even after a predetermined time elapsed (1st time is jam notification, 2nd time is SC notification).
      • During motor drive, the output from the encoder could not be counted for a predetermined number of times within a predetermined time (1st time is jam notification, 2nd time is SC notification).
      • Motor driver detects an error (short-circuit and overheating) (1st time is SC).
      • Troubleshooting
      SC721-53BRear End Fence Displacement Motor Error
      SC721-58BBundle Transport 1 Release Motor Error
      SC721-59BBundle Transport 2 Release Motor Error
      SC721-80BFolding Transport Motor Error
      SC721-70BTray 1 Lift Motor Error
      • Motor driver detects an error (short-circuit or overheating) (1st time is SC)
      • Motor driver detects an error (short-circuit or overheating) (1st time is SC).
      • During descent, the paper surface sensor still detects paper even after a predetermined time elapses (1st time is jam notification, 2nd time is SC notification).
      • During ascent, the paper surface sensor could not detect the paper surface even after a predetermined time elapses (1st time is jam notification, 2nd time is SC notification).
      SC721-71BShift Motor 1 Error
      SC721-81BPaper Guide Drive Motor Error
      • Overcurrent (-03 only)
      • Staple jam (-44 only)
      • Encoder error (-11, -11, -25, -44)
      • Motor defective
      • Connecter disconnected, or loose
      • Motor overload
      • HP sensor defective
      • Paper surface sensor defective (-70 only)
        Check if the SC occurs by opening/closing covers, and input/output check. If the SC occurs again, do the following steps. Check if the SC reoccurs by cycling the power after each step.
      • The target parts are the motor and related HP sensor that SC occurred.
      • Troubleshooting
      SC721-06CAccess error to NVRAM
      Error occurs when accessing NV memory.
      Connection failure or malfunction of NV memory
      Check if the SC occurs by turning the main power OFF then ON. If the SC occurs again, do the following steps.
      1. Pull out and reinsert the NV memory to check if the NV memory is correctly inserted into the IC socket. If the SC cannot be recovered, replace the main board.
      SC723Internal Finisher SR3180 (D766) Error
      SC723-03BPower Supply Error
      When original source 24V power supply is ON, protection device intercept of non-interlock power supply system is detected.
      A motor failure or harness short-circuit occur in the non-interlock power supply system.
      SC723-10BTransport Motor Error
      The DCM driver error detection is started after reset, and the error signal is detected for 0.2 sec.
      This SC will be issued when the above phenomenon repeated 2 times.
      • Replace the short-circuited harnesses
      • Replace the protection devices
      • Transport Motor failure
      • Harness short-circuit
      • Circuit board failure
      • Over current
      • Abnormal temperature
      • Replace the motor
      • Replace the harness
      • Replace the circuit board.
      • Troubleshooting
      SC723-20BJunction Gate Motor Error
      When the junction gate HP sensor was not turned off for 0.1 sec. applied to the junction gate motor with the HP sensor turned on. When the junction gate HP sensor was not turned on for 0.6 sec. applied to the junction gate motor with the HP sensor turned off. This SC will be issued when the above phenomenon repeated 2 times.
      SC723-24BExit Paper Pressure Motor Error
      When the exit paper pressure HP sensor was not turned off for
      0.15 sec. applied to the exit pressure release motor with the HP sensor turned on.
      When paper output pressure HP sensor was not turned on for
      0.7 sec. applied to the exit pressure release motor with the HP sensor turned off.
      • Junction Gate Motor failure
      • Over load
      • Junction gate HP sensor error
      • Check the connection
      • Replace the motor/sensor
      • Exit Pressure Release Motor failure
      • Over load
      • Exit pressure release HP sensor error
      SC723-44BStapler Motor Error
      When the stapler drive HP sensor was not turned off for 0.6 sec. applied to the stapler motor with the HP sensor turned on.
      When stapler drive HP sensor was not turned on for 9 sec. applied to the stapler motor with the HP sensor turned off. The STM driver error detection is started after reset, and the signal is detected for 0.2 sec.
      SC723-71BShift Motor Error
      When the shift HP sensor was not turned off for 0.15 sec. applied to the shift motor with the HP sensor turned on.
      When shift HP sensor was not turned on for 1.1 sec. applied to the shift motor with the HP sensor turned off.
      The STM driver error detection is started after reset, and the error signal is detected for 0.2 sec.
      • Stapler Motor failure
      • Stapler Motor overload
      • Stapler HP sensor error
      • Excess current
      • Shift Motor failure
      • Shift Motor overload
      • Shift HP sensor error
      • Excess current
      • Troubleshooting
      SC724Internal Finisher SR3130 (D690) Error
      SC724-24BPaper Exit Guide Plate Open/Close Motor Error
      0.15 sec. after paper exit guide plate HP sensor ON, the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      0.15 sec. after paper exit guide plate HP sensor OFF, the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      SC724-25BPunch Motor Error
      SC724-27BPunch Displacement Motor Error
      SC724-28BPunch Horizontal Registration Detection Motor Error
      • When paper exit guide plate open/close motor is driven for
      • When punch motor is driven for 0.05 sec. after punch HP sensor ON, the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • When punch motor is driven for 0.15 sec after punch HP sensor OFF, the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      • When punch displacement motor is driven for 0.166 sec. when punch displacement HP sensor is ON, the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • When punch displacement motor is driven for 0.832 sec. when punch displacement HP sensor is OFF, the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      • When horizontal registration displacement motor is driven for 0.428 sec. when horizontal registration displacement HP sensor is ON, the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • When horizontal registration displacement motor is driven for 1.81 sec. when horizontal registration displacement HP sensor is OFF, the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
        SC724-31BJogger Front Motor Error
        SC724-32BJogger Rear Motor Error
        SC724-33BPositioning Roller Motor Error
        SC724-38BPaper Press Motor Error
      • When front jogger motor is driven for 0.114 sec. when front jogger HP sensor is ON, the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • When front jogger motor is driven for 0.6 sec. when front jogger HP sensor is OFF, the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      • When rear jogger motor is driven for 0.114 sec. when rear jogger HP sensor is ON, the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • When rear jogger motor is driven for 0.6 sec. when rear jogger HP sensor is OFF, the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      • During initialization/positioning roller descent, even when the positioning roller motor is driven for 0.357 sec. when the positioning roller HP sensor is ON, the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • During initialization, even when the positioning roller motor is driven for 0.714 sec. when the positioning roller HP sensor is OFF, the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      • When the positioning roller is lifted from the press position, even when driven for 0.714 sec., the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      • Troubleshooting
      SC724-42BStapler Displacement Movable Motor Error
      SC724-70BShift Tray Ascent/Descent Motor Error
      SC724-71BShift Motor Error
      The level of shift sensor output does not change when the shift motor is driven for 1.86 sec. after the motor in turned ON.
      • When the paper press HP sensor is ON and the paper press motor is driven for 0.1 sec., the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • When the paper press HP sensor is OFF and the paper press motor is driven for 0.1 sec., the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      • Sifter stapler displacement HP sensor ON, even when the stapler retreat motor is driven for 0.25 sec., the HP sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • After stapler displacement HP sensor OFF, even when the stapler retreat motor is driven for 4.5 sec. the HP sensor does not switch ON (1st time is jam notification, 2nd time is SC notification).
      • During ascent from paper surface sensor ON, even after 2 sec. elapses, the paper surface sensor does not switch OFF (1st time is jam notification, 2nd time is SC notification).
      • During descent from paper surface sensor OFF, the paper surface sensor does not switch ON even after 2 sec. elapses (1st time is jam notification, 2nd time is SC notification).
      • During descent to the packing position, the full sensor does not switch ON even if 2 sec. elapses.
      • Motor defective
      • Motor overload
      • Home position sensor error
      • Paper surface sensor error (*SC724-38, 70 only)
      • Troubleshooting
      SC724-80BShift Motor Error
      0.567 sec.
      1st time is jam notification, 2nd time is SC notification.
      1.417 sec.
      • When the shift roller HP sensor is ON, the HP sensor does not switch OFF even when the shift roller motor is driven for
      • When the shift roller HP sensor is OFF, the HP sensor does not switch ON even when the shift roller motor is driven for
      SC724-86BStapler Motor Error
      • HP sensor does not switch OFF even when the stapler motor is driven for 0.6 sec. after the stapler HP sensor switches ON (1st time is jam notification, 2nd time is SC notification).
      • HP sensor does not switch ON even when the stapler motor is driven for 0.6 sec. after the stapler HP sensor switches OFF (1st time is jam notification, 2nd time is SC notification).
      • Motor defective
      • Motor overload
      • Staple jam (*SC724-86 only)
        SC761Bridge Unit BU3070 (D685) or Side Tray Type M3 (D725) Error
        SC761-03BProtection Device Intercept Error 5V
        SC761-04BProtection Device Intercept Error 24V
        Fuse blowout occurs due to over current during power injection (output detected for longer than 2 seconds).
      • Over current of bridge unit motor
      • Over current due to short-circuit in PCB
      • Replace the bridge unit or side tray
      • Replace the PCB of bridge unit or side tray
      • Troubleshooting
      SC780-01DBank 1 (Upper optional paper tray) Protection Device Intercept Error
      When original source of 5V power supply is ON, protection device intercept of 24V power system is detected.
      In 24V power supply system:
      • Motor defective
      • Solenoid defective
      • Harness short- circuit
        Remove the jammed paper or slip of paper from the tray, and check if the SC occurs by turning the main power OFF then ON. If the SC occurs again, do the following steps. Check if the SC reoccurs by cycling the power after each step.
      1. Check if all connectors in tray 1, 2, and optional upper tray are connected securely. Reconnect the connectors if they are disconnected, or loose.
      2. Check the harness in tray 1, 2, and optional upper tray. Replace the harness if it is disconnected, or damaged.
      3. Check if the motor runs, has no overloads, and is properly driven. Replace the parts if there are any defects.
      SC781-01DBank 2 (Lower optional paper tray) Protection Device Intercept Error
      • Motor defective
      1. Check if all connectors in tray 1, 2, and optional upper/lower trays are connected securely. Reconnect the connectors if they are disconnected, or loose.
      2. Check the harness in tray 1, 2, and optional upper/lower trays. Replace the harness if it is disconnected, or damaged.
      5. Troubleshooting
      SC791-00DNo bridge unit when finisher is present
      When power supply is switched on or paper is fed, finisher set is detected but bridge unit set is not detected.
      (during internal finisher connection, not detected)
      • Bridge unit not attached
      • Bridge unit defective
      • Reset the bridge unit
      SC792-00BNo finisher, bridge unit provided
      When power supply is switched on, it is recognized there is no finisher, and a bridge unit is fitted.
      Connect finisher or disconnect bridge unit, and turn the main power OFF/ON.
      • Finisher connector set incorrectly
      • In a machine which has a bridge unit connected, a finisher is not fitted
      • Finisher defective
  2. SERVICE CALL 816-899​
    1. SC800 (CONTROLLER)​
SC816-**[0x0000]Energy save I/O subsystem error
SC816-01DSubsystem error
SC816-02DSysarch (LPUX_GET_PORT_INFO) error
SC816-03DTransition to STR was denied.
SC816-04DInterrupt in kernel communication driver
SC816-05, 06
D
Preparation for transition to STR failed.
SC816-07DSysarch (LPUX_GET_PORT_INFO) error
SC816-08DSysarch (LPUX_ENGINE_TIMERCTRL) error
SC816-09DSysarch (LPUX_RETURN_FACTOR_STR) error
SC816-10
to 12
D
SC816-13Dopen() error
SC816-14DMemory address error
SC816-15
to 18
D
open() error
SC816-19DDouble open() error
SC816-20Dopen() error
SC816-22DParameter error
SC816-23, 24
D
read() error
SC816-25Dwrite () error
SC816-26
to 28
D
write() communication retry error
SC816-29, 30
D
read() communication retry error
SC816-35Dread() error
SC816-36 to 96, 99
D
Subsystem error
Energy save I/O subsystem detected some abnormality.
  • Energy save I/O subsystem defective
  • Energy save I/O subsystem detected a controller board error (non-response).
  • Error was detected during preparation for transition to STR.
  • SC816-99 occurs as a subsystem error except any error from -06 to 96.
Check if the SC occurs by turning the power OFF then ON. If the SC occurs again, do the following steps. Check if the SC reoccurs by cycling the power after each step.
  1. Update the "System/Copy" firmware and the other system firmware modules to the latest version.
  2. Disable the STR shift function by SP5-191-001 (Power Str Set).
  3. Replace the controller board.
