Ricoh MP C2004/C2504 Service Manual Part 16
SC No.TypeError Name/Error Condition/Major Cause/Solution
SC521-01CDuplex Entrance Motor: Lock
SC521-02CDuplex Bypass Motor: Lock
During motor ON, after checking the motor error notification registers (err_velo and err_posi) for 0.5 sec, the error state of either register was detected at least 5 times.
  • Motor defective
  • Connector disconnected
  • Harness broken
  • IOB defective
  • Encoder defective
  • Replace the motor.
  • Reset the connector.
  • Replace the harness.
  • Replace the paper transport IOB.
SC522-00CPaper Exit Motor: Lock
  • Motor defective
  • Harness broken
  • IOB defective
  • Encoder defective
6.7.2 SC500 (ENGINE: FUSING)​
SC530-00DFusing Exhaust Fan Lock
In the motor ON state, the value of the lock sensor is checked every 0.1 sec.
If a lock signal is not obtained for 50 times consecutively.
  • Motor defective
  • Harness broken
  • IOB defective
  • Replace the fusing exhaust fan.
  • Reconnect the connector.
SC531-01DDevelopment Intake Fan/Right Lock
SC531-03DDrive Cooling Fan Lock
  • Motor defective
  • Harness broken
  • IOB defective
  • Replace the development intake fan/right for SC531-01, or drive cooling fan for SC531-03.
  • Replace the imaging IOB.
SC533-03DPSU Cooling Fan Lock
SC533-04DController Box Cooling Fan Lock
  • Motor defective
  • Harness broken
  • IOB defective
  • Replace the PSU exhaust fan for SC533-01, PSU cooling fan for SC533-04 or controller box cooling fan for
  • Replace the paper transport IOB (for SC533-01, -03).
  • Replace the imaging IOB (for SC533-04).
SC533-04.
SC534-01DMain Exhaust Fan Lock
SC534-02DToner Supply Cooling Fan Lock
SC534-03DOzone Exhaust Fan Lock
  • Motor defective
  • Harness broken
  • IOB defective
  • Replace the development intake fan/right for SC534-01, or drive cooling fan for SC534-03.
  • Replace the imaging IOB (SC534-01, -02).
  • Replace the paper transport IOB (for SC534-03).
SC535-00DPaper Exit Cooling Fan Lock
  • Motor defective
  • Harness broken
  • IOB defective
  • Replace the paper exit cooling fan.
SC540-00DFusing Motor: Lock
Motor status is observed at 0.1 sec intervals during motor ON, and the unlock status is detected at least 20 times.
  • Motor defective
  • Harness broken
  • IOB defective
  • Unit torque increased
  • Replace the fusing motor.
Fusing Sleeve (Center) Error (SC54*-**)​
SC541-01AThermopile (Center) Disconnection
Below -50 degrees C (or below CB) is detected for 0.1 sec continuously.
  • Thermopile disconnection
  • Harness disconnection between the fusing unit and the BCU
  • BCU defective
  1. Reconnect the connectors (main machine side, BCU side).
  2. Replace the thermopile (center).
  3. Replace the harness between the fusing unit and the BCU.
  4. Replace the BCU.
SC541-02ANon-contact Thermistor (Center) Disconnection
Above 3F6 is detected for 1 sec. continuously (NC sensor center: detection & compensation NC sensor edge: detection & compensation).
Detection period: 0.1 sec, detection frequency: 10 times or more.
  • Non-contact thermistor disconnection
  • Harness disconnection in the fusing unit
  • BCU defective
  1. Reconnect the connectors (between the fusing unit and the BCU).
  2. Replace the non-contact thermistor with the harness.
  3. Replace the fusing unit.
  4. Replace the harness between the fusing unit and the BCU.
  5. Replace the BCU.
SC541-03ANon-contact Thermistor (Center) short-circuit
Below AD value: 8 is detected for 1 sec. continuously. Detection period: 0.1 sec, detection frequency: 10 times or more.
  • Non-contact thermistor short-circuit
  • BCU defective
  5. Replace the BCU.
SC542-02AThermopile (Center) does not reload
65 degrees C not reached after fusing lamp 1 ON for 10 sec continuously.
SC542-03AThermopile (Center) does not reload
Heating central reload permission temperature not reached after fusing lamp 1 ON for 35 sec continuously.
SC542-05DThermopile (Center) does not reload (Low Power)
SC542-06DThermopile (Center) does not reload (Low Power)
  • Outside input voltage guarantee
  • Jammed paper between the thermopile and fusing unit
  • Thermopile lens dirt
  • Thermopile modification/float
  • After excessive temperature rise prevention unit operation
  • Fusing lamp disconnection
  • Harness disconnection between the fusing unit and the BCU or the PSU (AC controller board)
  • BCU defective
  • AC controller board defective
  1. Check the power supply voltage and reconnect the cable to the outlet.
  2. Remove the jammed paper between the thermopile and fusing unit.
  3. Clean or replace the thermopile (center).
  4. Replace the fusing sleeve thermostat
  5. Replace the fusing sleeve belt unit.
  6. Reconnect or replace the harness between the fusing unit and the BCU or the PSU (AC controller board).
  7. Replace the BCU.
  8. Replace the PSU (AC controller board).
SC543-00AThermopile (Center) high temperature detection (software)
Above 240 degrees C detected for 1 sec continuously. Detection period: 0.1 sec, detection count: 10 times or more.
  • Fusing sleeve belt defective
  • Paper setting misdetection
  • Incorrect paper position in the paper feed tray
  • Gear abrasion
  • Thermopile failure
  • Triac defective (short-circuit)
  • BCU failure
  • AC controller board failure
  1. Inspect the fusing sleeve belt unit, and replace if damaged.
  2. Check the paper settings.
  3. Check the paper position in the paper feed tray.
  4. Reconnect the connectors (main machine side, BCU side).
  5. Inspect or replace the gears in the fusing unit or main machine.
  6. Replace the thermopile (center).
  7. Replace the harness between the fusing unit and the BCU or the PSU (AC controller board).
  8. Replace the BCU.
  9. Replace the PSU (AC controller board).
If the problem cannot be solved after performing the above steps, replace the fusing unit.
SC544-01AThermopile (Center) high temperature detection (hardware)
In the event of an error
  • Gear abrasion
  • Pressure roller HP sensor disconnected
  • BCU failure
  6. Inspect the pressure roller HP sensor with SP5-803-047.
  7. Replace the thermopile (center).
  8. Replace the harness between the fusing unit and the BCU or the PSU (AC controller board).
  9. Replace the BCU.
  10. Replace the PSU (AC controller board).
SC544-02ANon-contact Thermistor (Center) high temperature detection (hardware)
  • BCU failure
  5. Remove the jammed paper between the thermopile and fusing unit.
  6. Clean or replace the thermopile (center).
  7. Replace the fusing unit.
  8. Inspect the pressure roller HP sensor with SP5-803-047.
  9. Replace the harness between the fusing unit and the BCU or the PSU (AC controller board).
  10. Replace the BCU.
  11. Replace the PSU (AC controller board).
SC545-01AFusing Central Lamp Continuously Heat
SC545-05DFusing Central Lamp Continuously Heat (Low Power)
After waiting for full power for more than 5 sec continuously.
  • Definition of fusing lamp full power
  • Measurement start point
  • Measurement stop condition
  • Maximum heat-up duty (SP interlinked value) 0% is excluded.
Continuously heating rate set point (maximum heating rate)
After reload (after fusing lamp extinguished, after rotation complete) below the standby temperature (target temperature), measurement starts after a fusing lamp heat-up request is issued.
Rotation started due to a print signal during measurement or other.
  • BCU defective
  4. Replace the fusing sleeve thermostat.
  7. Replace the BCU.
SC547-01DZero cross error (relay-contact soldering)
Zero-cross signal is detected while the fusing relay is OFF.
  • Fusing relay defective (contact soldering)
  • Fusing relay drive circuit error
  1. Reconnect the connectors between PSU (AC controller board) and paper transport IOB.
  2. Replace the PSU (AC controller board).
  3. Replace the paper transport IOB.
SC547-02DZero cross error (relay contact error)
Zero-cross signal is not detected while the fusing relay is ON.
  • Fusing relay damage (contact open)
  • PSU fuse (24 VS) blowout
  1. Reconnect the connectors between PSU (AC controller board) and Paper transport IOB.
  4. Replace the harness between PSU (AC controller board) and paper transport IOB.
SC547-03DZero cross error (low-frequency error)
Mains power supply frequency is determined to be 44 Hz or lower.
Frequency instability of mains power supply
  1. Check that the mains power supply frequency is higher than 44 Hz. If it is equal to or lower than 44 Hz, infrastructure may have defects to be dealt with.
Fusing Sleeve (Edge) Error (SC55*-**)​
SC551-01AThermopile (Edge) Disconnection
  • BCU defective
  2. Replace the thermopile (edge).
  4. Replace the BCU.
SC551-02ANon-contact Thermistor (Edge) Disconnection
Above 3F6 is detected for 1 sec continuously (NC sensor center: detection & compensation NC sensor edge: detection & compensation).
  • BCU defective
  5. Replace the BCU.
SC551-03ANon-contact Thermistor (Edge) Short-circuit
  • BCU defective
  5. Replace the BCU.
SC552-02AThermopile (Edge) Does Not Reload
65 degrees C not reached after fusing lamp 1 ON for 14 sec continuously.
SC552-03AThermopile (Edge) Does Not Reload
Heating edge reload permission temperature not reached after fusing lamp 1 ON for 28 sec continuously.
SC552-05DThermopile (Edge) Does Not Reload (Low Power)
SC552-06DThermopile (Edge) Does Not Reload (Low Power)
  • Harness disconnection between the fusing unit and BCU or the PSU (AC controller board)
  • BCU defective
  3. Clean or replace the thermopile (edge).
  5. Reconnect the fusing sleeve belt unit.
  7. Replace the BCU.
SC553-00AThermopile (Edge) High Temperature Detection (software)
  • Gear abrasion
  • BCU failure
  6. Replace the thermopile (edge).
  8. Replace the BCU.
SC554-01AThermopile (Edge) high temperature detection (hardware)
  • Gear abrasion
  • BCU failure
  7. Replace the thermopile (edge).
  9. Replace the BCU.
SC554-02ANon-contact Thermistor (Edge) high temperature detection (hardware)
  • BCU failure
  6. Clean or replace the thermopile (edge).
SC555-01AFusing Edge Lamp Continuously Heat
SC555-05DFusing Edge Lamp Continuously Heat (Low Power)
  • Maximum heat-up Duty (SP interlinked value) 0% is excluded
  • BCU defective
  7. Replace the BCU.
SC557-00CZero Cross Frequency Exceeded
Frequency instability of mains power supply /Noise
SC558-01CLow Input Voltage
Input voltage below the specification is detected on the mains power supply
Low input of mains power supply
SC559-00AFusing Jam Detected for 3 Times Consecutively
Fusing jam (does not reach fusing exit sensor) is detected for 3 times consecutively.
  • Detection conditions
  • Control ON/OFF
  • Counter reset condition occurs fusing jam
    1. Normal paper exit has been done during this continuous fusing jam, fusing jam counter is reset.
    2. When "1" is changed to "0" SP1-142-001, to reset the (SP9-912-001) fusing jam counter.
    3. When after displaying SC559, SC release is made, reset the (SP9912-001) fusing jam counter.
Displays the SC559-00 at the time of integrating the counter each time fusing jam occurs, became fusing jam counter value = 3.
The counter value is retained without fusing jam also reset by OFF/ON the power supply.
And enables ON / OFF is this SC, the default is set to OFF, then ON at the time of customer requirements.
SP1-142-001 0: OFF (default), 1: ON (Set at the time of customer requirements)
  • Stripper plate float/ mounting failure
  • Gear abrasion
  • Fusing motor failure
  1. Inspect or replace the stripper plate.
  2. Replace the gears in the fusing unit or main machine.
  3. Replace the fusing motor.
  4. Replace the fusing unit.
Pressure Roller Thermistor (Center) Error (SC56*-**)​
SC561-01APressure Roller Thermistor (Center) Disconnection
SC561-05DPressure Roller Thermistor (Center) Disconnection (Low Power)
Below 0 degree C detected for 20 sec continuously. Detection period 0.1 sec, detection count: 10 times or more.
  • BCU defective
  • Fusing lamp defective
  1. Check the power supply voltage and reconnect the cable to the outlet. (-05 only)
  2. Reconnect the connectors (between the fusing unit and the BCU).
  3. Replace the thermistor.
  5. Replace the harness between the fusing unit and the BCU or the PSU (AC controller board).
  6. Replace the BCU.
  7. Replace the fusing sleeve belt unit.
SC562-02APressure Roller Thermistor (Center) Does Not Reload
SC562-05DPressure Roller Thermistor (Center) Does Not Reload (Low Power)
Does not reach 40 degree C after fusing lamp 1ON for 12 sec.
  • Thermistor dirt
  • Thermistor modification/float
  • Thermopile defective
  • BCU defective
  2. Clean or replace the thermistor.
  3. Replace the fusing sleeve thermostat.
  4. Replace the fusing sleeve belt unit.
  7. Replace the BCU.
SC563-00APressure Roller Thermistor (Center) High Temperature Detection (software)
Above 230 degrees C detected for 1 sec continuously. Detection period: 0.1 sec, detection count: 10 times or more.
  • Jammed paper between the center thermopile and fusing unit
  • BCU failure
  1. Check the paper settings.
  2. Check the paper position in the paper feed tray.
  3. Reconnect the connectors (main machine side, BCU side).
  4. Remove the jammed paper between the center thermopile and fusing unit.
  5. Clean or replace the thermopile (center).
  6. Replace the harness between the fusing unit and the BCU or the PSU (AC controller board).
  7. Replace the BCU.
SC564-00APressure Roller Thermistor (Center) High Temperature Detection (Hardware)
Above 240 degrees C detected.
  • BCU failure
  8. Replace the BCU.
SC569-00DPaper Exit/ Pressure Release Motor Error Detection
Retry operation fails 3 times consecutively.
  • Pressure release encoder modification
  • Fusing unit defective
  • Paper exit/ pressure release motor disconnected
Inspect the pressure roller HP sensor with SP5-803-047. If no response from the sensor, perform steps 1 and 2.
  1. Check the connection of the pressure roller HP sensor.
  2. Inspect the pressure roller HP sensor.
  3. Inspect the pressure release encoder.
  5. Check the connectors of the paper exit/ pressure release motor.
Pressure Roller Thermistor (Edge) Error (SC57*-**)​
SC571-01APressure Roller Thermistor (Edge) Disconnection
SC571-05DPressure Roller Thermistor (Edge) Disconnection (Low Power)
Below 0 degree C detected for 40 sec. continuously. Detection period: 0.1 sec, detection counts: 10 times or more.
  • Thermistor disconnection
  • BCU defective
  2. Reconnect the connectors (between the fusing unit and the BCU or the PSU (AC controller board).
  6. Replace the BCU.
SC572-04APressure Roller Thermistor (Edge) Does Not Reload
SC572-05DPressure Roller Thermistor (Edge) Does Not Reload ( Low Power)
After starting continuous job with paper width of 257mm or more, does not reach 0 degrees C after 100 sec.
  • Thermistor dirt
  • BCU defective
  5. Reconnect or replace the harness between the fusing unit and the BCU or the PSU (AC controller board).
  7. Replace the BCU.
SC573-00APressure Roller Thermistor (Edge) High Temperature Detection (software)
  • BCU failure
  4. Remove the jammed paper between the thermopile and fusing unit.
  5. Clean or replace the thermopile (edge).
  7. Replace the BCU.
SC574-00APressure Roller Thermistor (edge) High Temperature Detection (hardware)
  • BCU failure
  3. Reconnect the connector.
  8. Replace the BCU.
Pressure Roller Thermistor (Full-bleed edge) Error (SC58*-**)​
SC581-01APressure Roller Thermistor (Full-bleed edge) Thermistor Disconnection
SC581-05DPressure Roller Thermistor (Full-bleed edge) Disconnection (Low Power)
Below 0 degree C detected for 40 sec. continuously. Detection period: 0.1 sec, detection count: 10 times or more.
  • BCU defective
  6. Replace the BCU.
SC582-04APressure Roller Thermistor (Full-bleed edge) Does Not Reload
SC582-05DPressure Roller Thermistor (Full-bleed edge) Does Not Reload (Low Power)
After starting continuous job with paper width of 257 mm or more, does not reach 0 degrees C after 100 sec.
  • Thermistor dirt
  • BCU defective
  7. Replace the BCU.
SC583-00APressure Roller Thermistor (Full-bleed edge) High Temperature Detection (software)
  • Thermopile lens dirt.
  • BCU failure
  7. Replace the BCU.
SC584-00APressure Roller Thermistor (Full-bleed edge) High Temperature Detection (hardware)
  • BCU failure
  8. Replace the BCU.
6.8 SERVICE CALL 620-687​
6.8.1 SC600 (ENGINE: COMMUNICATION AND OTHERS)​
SC620-01DADF Communication error 1 (DF3090 (D779)/ DF3100 (D3B0))
After ADF connection was recognized on startup, an error is detected. (disconnection detection)
  • ADF connection error
  • ADF defection
  • IPU board defection
  • Noise contamination
Check if the SC occurs by turning the main power OFF then ON. If the SC occurs again, do the following steps. Check if the SC reoccurs by cycling the power after each step.
  1. Check if all connectors related to SPDF/ARDF are connected securely. Reconnect the connectors if they are disconnected, or loose.
  2. Check the machine and ADF firmware version.
    • Proceed to Step 3 if there is no new firmware released.
    • Run the firmware update when there is a new firmware released.
  3. Check the harness. Replace the harness if it is disconnected, or damaged.
  4. Replace the IPU.
  5. Check if there are any signs of a short circuit on the SPDF/ARDF Main Board. If there are any defects, replace the board.
SC620-02DADF Communication error 2 (DF3090 (D779)/ DF3100 (D3B0))
After ADF connection was recognized on startup, an error is detected. (Retry out due to communication error)
  • ADF defection
Follow the solution for SC620-01.
SC620-03DADF Communication error 3 (DF3100 (D3B0))
SC is displayed when CIS initialization complete command is not received for certain time.
  • ADF defection
  • Unsupported ADF is connected
  2. Check the harness. Replace the harness if it is disconnected, or damaged.
  3. Check if there are any signs of a short circuit on the SPDF Main Board. If there are any defects, replace the board.
SC621-00DFinisher communication error
  • Detected an error when connecting the communication line.
  • Received a communication error notification from the URAT.
  • Finisher control board defective.
  • BCU defective
  • IOB defective
  • Connection error between finisher and main machine.
  • Reconnect the Finisher interface cable.
  • Replace the BCU.
  • Replace the Imaging IOB.
  • Replace the finisher.
  • Turn the power off/on.
SC622-01DPaper bank 1 communication error for Paper Feed Unit PB3150 (D694)
SC622-11DPaper bank 1 communication error for Paper Feed Unit PB3220/PB3210 (D787)
  • Paper bank control board defective
  • BCU defective
  • IOB defective
  • Paper bank-main machine connection error
  1. Check if all connectors in tray 1, 2, and optional paper tray are connected securely. Reconnect the connectors if they are disconnected, or loose.
  2. Check the harness in tray 1, 2, and optional paper tray. Replace the harness if it is disconnected, or damaged.
  3. Check if there are any signs of a short circuit on the Bank Main Board. If there are any defects, replace the board.
SC663-01DReset Detection: Imaging IOB: Software hang-up occurs
SC663-02DReset Detection: Imaging IOB: Power ON reset occurs
SC663-03DReset Detection: Imaging IOB: Software reset occurs
SC663-11DReset Detection: Paper Transport IOB: Software hang-up occurs
SC663-12DReset Detection: Paper Transport IOB: Power ON reset occurs
SC663-13DReset Detection: Paper Transport IOB: Software reset occurs
SC is displayed when unexpected reset from Imaging IOB/Paper Transport IOB is detected while standby/operation.
  • Unexpected noise from inside the machine gets into Paper Transport IOB.
  • Parts defect and implementation defect of Imaging IOB/ Paper Transport IOB.
  • Software ran reset to ASIC when there was a bug in the software or unexpected signal was input (-03/-13 only).
  1. Turn the main power OFF/ON.
  2. Replace the Paper Transport IOB (-01 to -03)
  3. Replace the Imaging IOB (-11 to -13)
SC664-01DVODKA1 (Paper Transport Vodka) access permission error to VODKA SRAM
SC664-02DVODKA1 (Paper Transport Vodka) write error to VODKA SRAM
SC664-03DVODKA1 (Paper Transport Vodka) VODKA program launch error
SC664-11DVODKA2 (Imaging Vodka) access permission error to VODKA SRAM
SC664-12DVODKA2 (Imaging Vodka) write error to VODKA SRAM
SC664-13DVODKA2 (Imaging Vodka) VODKA program launch error
The machine detects the communication error between VODKA and SRAM when starting up, or recovery from energy saver mode.
The following board defects (Parts implementation defect, solder scrap, implemented parts defect, etc.);
  • BCU
  • Imaging IOB
  • Paper Transport IOB
-01 to 03
  2. Replace the Paper Transport IOB.
  3. Replace the BCU.
  4. Replace the Imaging IOB.
-11 to 13
  2. Replace the Imaging IOB.
  3. Replace the BCU.
SC665-01DConnection Error (BCU - IPU)
The machine detects the communication error between BCU and IPU (No FFC connection) when starting up, or recovery from energy saver mode.
  • FFC connection error
  • FFC defective (disconnected, foreign object, etc.)
  • The following board defects (Parts implementation defect, solder scrap, implemented parts defect, etc.);
    • BCU
    • IPU
  1. Reconnect the FFC between BCU and IPU.
  2. Replace the FFC between BCU and IPU.
  3. Replace the BCU.
  4. Replace the IPU.
SC665-02DConnection Error (BCU – Imaging IOB)
The machine detects the communication error between BCU and Imaging IOB (No connection) when starting up, or recovery from energy saver mode.
    • BCU
    • Imaging IOB
  1. Reconnect the FFC between BCU and Imaging IOB.
  2. Replace the FFC between BCU and Imaging IOB.
  3. Replace the BCU.
SC665-03DConnection Error (Paper Transport IOB – Imaging IOB)
The machine detects the communication error between Imaging IOB and Paper Transport IOB (No connection) when starting up, or recovery from energy saver mode.
    • Paper Transport IOB.
    • Imaging IOB.
  1. Reconnect the FFC between Paper Transport IOB and Imaging IOB.
  2. Replace the FFC between Paper Transport IOB and Imaging IOB.
  3. Replace the Imaging IOB.
  4. Replace the Paper Transport IOB.
SC665-04DIOB does not start up
The IOB does not start up when starting up, or recovery from energy saver mode.
  • Harness disconnected
    • BCU
    • Imaging IOB
  2. Reconnect the following FFC;
    • BCU - Imagine IOB
    • Imaging IOB - Paper Transport IOB
  3. Replace the following FFC;
    • BCU - Imagine IOB
  4. Replace the BCU.
  5. Replace the Imaging IOB.
  6. Replace the Paper Transport IOB.
SC665-05DMaster Device Communication Error
The machine detects the communication error between CPU and Slave1 when starting up, or recovery from energy saver mode.
    • BCU
    • IPU
    • Imaging IOB
    • BCU - Imagine IOB
    • BCU - Imagine IOB
  4. Replace the BCU.
SC665-06DIPU and IOB signal Communication Error
    • BCU
    • IPU
    • Imaging IOB
    • BCU - Imagine IOB
    • BCU - Imagine IOB
  4. Replace the BCU.
  5. Replace the IPU.
  6. Replace the Imaging IOB.
  7. Replace the Paper Transport IOB.
SC665-07DIPU signal Communication Error
The machine detects the communication error between CPU and Slave device when starting up, or recovery from energy saver mode.
    • BCU
    • IPU
    • BCU - Imagine IOB
    • BCU - Imagine IOB
  4. Replace the BCU.
  5. Replace the IPU.
SC665-08DIOB signal Communication Error
    • BCU
    • Imaging IOB
    • BCU - Imagine IOB
    • BCU - Imagine IOB
  4. Replace the BCU.
SC665-11DVodka1 Communication Error
The machine detects the communication error between CPU and Vodka1 when starting up, or recovery from energy saver mode.
    • BCU
  2. Reconnect the FFC between Imaging IOB and Paper Transport IOB.
  3. Replace the harness between Imaging IOB and Paper Transport IOB.
  5. Replace the Paper Transport IOB.
  6. Reconnect the FFC between BCU and Imaging IOB.
  7. Replace the FFC between BCU and Imaging IOB
  8. Replace the BCU.
SC665-12DVodka2 Communication Error
The machine detects the communication error between CPU and Vodka2 when starting up, or recovery from energy saver mode.
    • BCU
    • Imaging IOB.
  2. Reconnect the FFC between BCU and Imaging IOB.
  3. Replace the FFC between BCU and Imaging IOB
  4. Replace the BCU.
  6. Pull out all the PCUs and check if the SC reoccurs or not. If SC message disappears, replace the PCU.
  7. Pull out all the toner bottles and check if the SC reoccurs or not. If SC message disappears, replace the toner bottle.
SC665-41DMacaron1 Communication Error
The machine detects the communication error between CPU and Macaron1 when starting up, or recovery from energy saver mode.
    • BCU
    • IPU
  2. Replace the IPU.
  3. Reconnect the FFC between BCU and IPU.
  4. Replace the FFC between BCU and IPU.
  5. Replace the BCU.
SC665-42DMacaron2 Communication Error
The machine detects the communication error between CPU and Macaron2 when starting up, or recovery from energy saver mode.
    • BCU
    • IPU
  2. Replace the IPU.
  5. Replace the BCU.
SC667-01DMaster Device Mode Setting Error
The machine detects the CPU mode error when starting up, or recovery from energy saver mode.
  • BCU
  2. Replace the BCU.
SC667-10DSlave1 Device Mode Setting Error
The machine detects the Slave1 mode error when starting up, or recovery from energy saver mode.
  • BCU
  3. Reconnect the FFC between Imaging IOB and Paper Transport IOB.
  4. Replace the harness between Imaging IOB and Paper Transport IOB.
  6. Reconnect the harness between BCU and Imaging IOB.
  7. Replace the harness between BCU and Imaging IOB.
  8. Replace the BCU.
SC667-11DSlave2 Device Mode Setting Error
The machine detects the Slave2 mode error when starting up, or recovery from energy saver mode.
  • BCU
  3. Reconnect the harness between BCU and Imaging IOB.
  4. Replace the harness between BCU and Imaging IOB.
  5. Replace the BCU.
