Why do you need to replace the Canon IR2525 fuser? After a period of use, the components in the fuser will be weak and damaged, causing drying errors, black streaks in the print, dirty prints, and continuous paper jams in the photocopier. At this time, we need to replace the new fuser.
First you need to open the right door, now you will see the dryer assembly. Removing the dryer assembly is very simple, you just need to remove the 2 screws that fix the dryer to the machine at the 2 ends of the dryer and then carefully pull the dryer assembly out.
After removing the photocopier's fuser assembly, install the new fuser assembly.
