Adelaide
Konica bizhub 450i photocopier, black print
Do you have any code to reduce the ink of this one?
Apr 28, 2025
Antaram
Redo all the ink and developer unit.
Apr 28, 2025
Rachel
Clean the mirror, laser cluster
Apr 28, 2025
Are you using non-genuine ink?
Apr 28, 2025
Erasmus
If the word file is highlighted, it will be black
Apr 28, 2025
G
Giselle
Only the PDF file is black, is the word excel file black?
Apr 28, 2025
Calista
I adjusted the resolution but it only got better, not completely gone
Apr 28, 2025
N
Nenito
You adjust the resolution in the print driver or install the printer according to the correct driver of the machine
Apr 28, 2025
Konica Minolta
Can I ask, Konica bizhub 450i, every time I print pdf or any highlighted line, it gets like this. Does anyone know how to tell me and I...
Apr 28, 2025
Jocelyn
Sharp AR-M460N photocopier has a black print error
So you have to contact the big guys who specialize in Sharp products to borrow to test, because this product is rare and the price is a...
Apr 28, 2025
S
Seraphina
I've cleaned it all. It's a little clearer
Apr 28, 2025
Bridget
Remove the drum unit to clean it, clean the high voltage drum, the high voltage next to the black charging shaft...
Apr 28, 2025
Is this power source expensive?
Apr 28, 2025
Venessa
If cleaning the high pressure doesn't fix this error, replace the components, replace the drum unit... This error is usually due to high...
Apr 28, 2025
Sharp
I have a Sharp AR-M460N photocopier with black printout as shown in the photo. After cleaning the drum unit, it was white, but after a...
Apr 28, 2025
