Cara
Kyocera 4012i photocopier refilled ink but still reported out of ink
Remove the chip under the ink cartridge, plus with this Konica line, just use genuine ink, don't use non-genuine ink, it will quickly...
Apr 28, 2025
Eunice
If you pour this ink, there is a possibility that there will be a black line on the back of the paper
Apr 28, 2025
I
Ingrid
Even if you stick 10 ink chips, it still won't work
Apr 28, 2025
After refilling the printout, the background is darkened. Black on side 2
Apr 28, 2025
Verity
Ink Chip
Apr 28, 2025
D
Donatella
After refilling the ink for this Kyocera 4012i series, you have to peel off the chip at the bottom of the ink cartridge and throw it away
Apr 28, 2025
K
Kaytlyn
Thank you, I ordered the genuine Kyocera ink cartridge
Apr 28, 2025
Antaram
You should replace the genuine Kyocera ink, otherwise the background will be dark and the black line on the 2nd side will be dark
Apr 28, 2025
Rosalind
Under the ink cartridge, there's a yellow sticker with a chip as small as a match head. Remove it and the ink will run out.
Apr 28, 2025
G
Grainne
There's also the toner chip. After refilling the toner, remove the toner chip
Apr 28, 2025
Kyocera
Hello everyone, I have a question for you guys. Kyocera 4012i photocopier reports out of ink. I refilled the ink but it still shows an...
Apr 28, 2025
Bonnie
Computer using H510M-F mainboard error when booting up, it automatically enters BIOS
Check if the network cable is receiving a signal
Apr 28, 2025
M
Mia
According to the picture, it says there's no hard drive information, bro
Apr 28, 2025
P
Philomena
Change it back to UEFI or enable CSM to see how it goes, these net machines boot LAN
Apr 28, 2025
K
Kerenza
Yes, please check the ssd drive again, remove it and plug it back into the cmos to check the hard drive to see if it shows up! If not...
Apr 28, 2025
