Install Windows 11 on a low-configuration computer, can it run?
B
Bonnie
Normal installation, what's wrong with it!
The problem is whether it runs smoothly or not
Verity
My laptop's configuration does not meet the requirements to install Windows 11, I wonder if it will work?
A
Aneurin
My computer i3 2328m is crazy, upgrading to win 11 is also beautiful but it is quite laggy so I went back to win 10
M
Meadow
With low-configuration computers, Windows 11 can still be installed normally but it is very slow. To improve speed, you need to edit and turn off unnecessary services, remove redundant applications. But this will cause many errors while using the computer.
If your computer uses an HDD, it will definitely be installed but not usable.
If the computer uses an SSD, it is still acceptable
O
Oralie
In general, it's still ok to upgrade. But it will be unstable and not smooth or freeze
N
Nadia
If it's not enough, don't force it, after upgrading some incompatible drivers, it will take time to downgrade.
While the configuration is low, it can't run the win 11 version
S
Seraphina
This configuration is not recommended! Best regards!
Venus
If I3 install win 11, it will destroy the machine. It's too hot
Evelyn
Use Win 10, if you have enough conditions, don't upgrade to Win 11
