Ricoh MP C2004/C2504 Service Manual Part 16
Ricoh
SC No. Type Error Name/Error Condition/Major Cause/Solution SC521-01 C Duplex Entrance Motor: Lock SC521-02 C Duplex Bypass...
Mar 6, 2025
Ricoh MP C2004/C2504 Service Manual Part 15
Ricoh
SC code Name 827-00 Self-diagnostics error: RAM 828-00 Self-diagnostics error: ROM 829-00 Self-diagnostics error: Optional...
Mar 5, 2025
Ricoh MP C2004/C2504 Service Manual Part 14
Ricoh
Enter the SP mode. Do SP5-846-051 (Backup All Addr Book). Exit the SP mode, and then turn OFF the main power switch. Remove the SD card...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 13
Ricoh
Service Mode Lock/Unlock At locations where the machine contains sensitive data, the customer engineer cannot operate the machine until...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 12
Ricoh
CONTROLLER BOX Controller cover (page 4-10) Controller box cover (page 4-182) Bracket [A] Controller box [A] IMAGING IOB...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 11
Ricoh
Replacement and Adjustment Paper exit sensor unit [A] Paper exit sensor [A] REVERSE SENSOR Paper exit unit (page 4-145)...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 10
Ricoh
TEMPERATURE AND HUMIDITY SENSOR Remove the 1st and 2nd paper tray. Main power switch cover [A] Insert a screwdriver through the hole...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 9
Ricoh
Replacement and Adjustment Rear cover (page 4-14) Controller box cover (page 4-182) While pressing the lock release lever, pull out...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 8
Ricoh
PREPARATION BEFORE OPERATION CHECK Clean the exposure glasses (for DF and book scanning). Enter the user tools mode. Do the "Automatic...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 7
Ricoh
Installation Remove the operation panel right cover [A]. Thread the USB cable through the notch in the front upper cover [A] and...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 6
Ricoh
Installation Insert the Ethernet cable [A] into the Ethernet port on this option. Insert the other end of the Ethernet cable to a...
Feb 28, 2025
Ricoh MP C2004/C2504 Service Manual Part 5
Ricoh
Installation Open the right door, and then remove the small cover [A]. Remove the screw and connector, and then remove the front...
Feb 27, 2025
Ricoh MP C2004/C2504 Service Manual Part 4
Ricoh
1 BIN TRAY BN3110 (D3CQ) ACCESSORY CHECK No. Description Q’ty Remarks 1 Tray 1 2 1 Bin Tray Unit 1 3 Tray support...
Feb 27, 2025
Ricoh MP C2004/C2504 Service Manual Part 3
Ricoh
Installation Remove the sheet-through exposure glass [A] Remove the rear scale [A] Remove the left scale and exposure glass [A]...
Feb 27, 2025
Ricoh MP C2004/C2504 Service Manual Part 2
Ricoh
Machine Codes and Peripherals Configuration No. Item Code Remarks 10 Internal Finisher SR3180 D766-18, -22 11 Booklet...
Feb 27, 2025
