Bonnie
Canon i-SENSYS LBP212dw printer error: white screen, can't print
Ready formatter canon 214dw to use with canon 212dw
May 4, 2025
F
Farah
I have spare parts in my inbox
May 4, 2025
Currently, your printer has 2 errors 1: Printer screen error does not display 2: Computer error does not recognize the printer With...
May 4, 2025
S
Serena
If the printer does not recognize the formatter card, you need to try replacing the formatter first
May 4, 2025
S
Seraphina
The screen is broken, buy a new one to replace it
May 4, 2025
Z
Zelda
Format error, how to fix it?
May 4, 2025
H
Hilda
Have you tried replacing the formatter card?
May 4, 2025
Antaram
What should I do now?
May 4, 2025
K
Kerenza
Error like that is likely a formatter card error
May 4, 2025
Canon
I have a Canon LBP 212dw printer that turns on a white screen, the screen doesn't display anything. When I connect the printer to the...
May 4, 2025
S
Sigrid
Brother MFC-L2701D printer paper jam error, machine freeze
You are right. If you buy a printer, avoid Brother. It has not been fixed!
May 4, 2025
Rosalind
This Brother printer has all kinds of strange errors
May 4, 2025
Astrid
Check and re-plug all the connecting cables, when removing and re-plugging, is the pin broken and causing a short circuit?
May 4, 2025
Rishima
Check the scan cable, high voltage cable to see if it is loose
May 4, 2025
My machine has the same problem?
May 4, 2025
