N
Nenito
Computer does not recognize speakers or headphones
I reinstalled the driver and it still doesn't work.
Apr 26, 2025
Adelaide
Check the realtek audio driver again.
Apr 26, 2025
Laptop PC Computer
My PC suddenly does not recognize speakers or headphones, plugging them in still says not plugged in, what's wrong? The speaker light is...
Apr 26, 2025
Y
Yaretzi
HP 404dn printer error event code 13.14.14 remove tray 2, push the green
HP
Has anyone encountered this error on HP 404dn printer?: power on error "event code 13.14.14 remove tray 2, push the green" even though...
Apr 25, 2025
Computer automatically turns off print spooler
Replace a new computer, it should be fine
Apr 25, 2025
Rishima
This is the installation part + some resets after installing Windows. Try to google to find out first bro....
Apr 25, 2025
L
Lealia
Check if the USB port or the customer's cable is loose. If it is unstable, it will also be affected
Apr 25, 2025
I
Imelda
If you can't install Windows, take your computer to get an antivirus. You have to know how to do it!
Apr 25, 2025
Eudora
I have a blank ISO from Microsoft but it still happens, bro 😢
Apr 25, 2025
Ermintrude
Reinstall another Windows, if this problem is not solved, reinstall Windows, then you have to give up :)))
Apr 25, 2025
Astrid
In my opinion, if you reinstalled Windows and it still happens, you should ask the customer if the printer often gets paper jammed? If...
Apr 25, 2025
Ermintrude
I turned it off to prevent it from scanning, but after restarting, it got stuck
Apr 25, 2025
Ermintrude
Before fixing, turn off the antivirus, if you just install it directly, even Windows will still have errors
Apr 25, 2025
Chinmayi
Reinstall new Windows. After loading Windows, install Kaspersky and then do anything else
Apr 25, 2025
Amanda
Copy 3 spooler files from another computer and then copy them to the faulty computer.
Apr 25, 2025
