Toshiba e-STUDIO 307/357/457/507 Service Manual Part 9
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of scanning pages at Full Color Mode in Scanning FunctionSCN60680Large08 digitsSYSCounts the number of scanning pages at the Full Color Mode in the Scanning Function according to its size (large/small).
Large: Number of output pages of large-sized paper defined at 08-6011
Small: Number of output pages other than set as large- sized
paper
Total: Total number output pages of all paper sizes.
08Setting modeCounterCounterDisplay of number of scanning pages at Full Color Mode in Scanning FunctionSCN60681Small08 digitsSYSCounts the number of scanning pages at the Full Color Mode in the Scanning Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in copier functionPPC60700Large08 digitsSYSCounts the number of scanning pages in the Copier Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in copier functionPPC60701Small08 digitsSYSCounts the number of scanning pages in the Copier Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of scanning pages in FAX functionFAX60710Large08 digitsSYSCounts the number of scanning pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in FAX functionFAX60711Small08 digitsSYSCounts the number of scanning pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in scanning functionSCN60720Large08 digitsSYSCounts the number of scanning pages in the Scanning Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in scanning functionSCN60721Small08 digitsSYSCounts the number of scanning pages in the Scanning Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of transmitted pages in FAX functionFAX60730Large08 digitsSYSCounts the number of transmitted pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of transmitted pages in FAX functionFAX60731Small08 digitsSYSCounts the number of transmitted pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of received pages in FAX functionFAX60740Large08 digitsSYSCounts the number of received pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of received pages in FAX functionFAX60741Small08 digitsSYSCounts the number of received pages in the FAX Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCustom counterFor dealer6080Enabling/Disabling custom counter00~1SYSWhen this setting is enabled, the custom counter of total counter is enabled. Related code: 08-6088, 6089. When this setting is enabled, 08-6010 does not affect the total counter. Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
1Yes
08Setting modeCounterCustom counter/Jo b QuotaFor administratorWeighting/Scanning60810Black/Gray00~9999SYSWeights subtraction of scanning from department/user Job Quota and addition of Scan Counter to Custom Counter.
0 (weight: 0.00) – 9999 (weight: 99.99)
4Yes
08Setting modeCounterCustom counter/Jo b QuotaFor administratorWeighting/Scanning60811Full Color00~9999SYSWeights subtraction of scanning from department/user Job Quota and addition of Scan Counter to Custom Counter.
4Yes
08Setting modeCounterDouble count setting for paper type60831Thick1/2/3/4 (Back)Refer to contents0~1SYSSets the weight of fee charging count for printing per page. Scan counter and fax counter are not influenced. 0: Single
1: Double
<Default value> JPD/CND: 0
Others: 1
4Yes
08Setting modeCounterDouble count setting for paper type60832Special1/2 (Back)Refer to contents0~1SYSSets the weight of fee charging count for printing per page. Scan counter and fax counter are not influenced. 0: Single
1: Double
Others: 1
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterDouble count setting for paper type60833TransparencyRefer to contents0~1SYSSets the weight of fee charging count for printing per page. Scan counter and fax counter are not influenced. 0: Single
1: Double
Others: 1
4Yes
08Setting modeCounterDouble count setting for paper type60834EnvelopRefer to contents0~1SYSSets the weight of fee charging count for printing per page. Scan counter and fax counter are not influenced. 0: Single
1: Double
Others: 1
4Yes
08Setting modeCounterDouble count setting for paper type60835Tab paperRefer to contents0~1SYSSets the weight of fee charging count for printing per page. Scan counter and fax counter are not influenced. 0: Single
1: Double
Others: 1
4Yes
08Setting modeCounterCustom counter/Jo b QuotaFor administrator6084Enabling/Disabling custom counter/Job Quota00-1SYSWhen this setting is enabled, the custom counter and Job Quota of department/user are enabled. Related code: 08-6081, 6085.
When this setting is enabled, 08-6010 does not affect the counter/Quota of department/user.
1Yes
08Setting modeCounterCustom counter/Jo b QuotaFor administratorWeighting/Print60850Black/Small1000~9999SYSWeights subtraction of printing from department/user Job Quota and addition of printing to Custom Counter. 0 (weight: 0.00) – 9999 (weight: 99.99)4
08Setting modeCounterCustom counter/Jo b QuotaFor administratorWeighting/Print60851Black/Large1000~9999SYSWeights subtraction of printing from department/user Job Quota and addition of printing to Custom Counter. 0 (weight: 0.00) – 9999 (weight: 99.99)4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeCounterCounter Settings6087Color/Black quota selection at twin/mono color count00-1SYSWhen the pages are counted for twin/mono color counter, this code sets whether the pages are subtracted from ColorQuota or BlackQuota.
Not all the pages of TwinColor/MonoColor are subtracted. The pages assigned to twin/mono color counter are subtracted. The setting of this code is enabled only in the Color/BlackQuota mode and not enabled in the JobQuota mode.
If the value of this code is set to "0" (ColorQuota), an error occurs if a user without color permission performs twin color printing. Note that the same error occurs in the JobQuota mode.
0: ColorQuota 1: BlackQuota Related code:
08-6084, 08-9128, 08-9892
08Setting ModeCounterCustom counterFor dealerWeighting/Scanning60880Black/Gray00-9999SYSWeights addition of Scan Counter to Custom Counter (Total Counter). Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
08Setting ModeCounterCustom counterFor dealerWeighting/Scanning60881Full Color00-9999SYSWeights addition of Scan Counter to Custom Counter (Total Counter). Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
08Setting ModeCounterCustom counterFor dealerWeighting/Print60890Black/Small1000-9999SYSWeights addition of print to Custom Counter (Total Counter). Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeCounterCustom counterFor dealerWeighting/Print60891Black/Large1000-9999SYSWeights addition of print to Custom Counter (Total Counter). Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
08Setting ModeCounterCustom counterFor dealer6090Truncation after decimal point of custom counter value00-1SYSSets the display method of custom counter value of total counter.
When the value is displayed as integer, the total counter value (total value of each color) is sum of the truncated custom counter value of each color. Note that the value is slightly decreases compared to display with decimal point.
0: Displays 2 decimal places.
1: Displays integer (Truncation after decimal point)
08Setting ModeCounterCustom counterFor dealer6091Output of annotation for custom counter10-1SYSSets whether the annotation "Custom Counter is result of..." for custom counter of total counter is output or not. 0: Annotation is not output
1: Annotation is output
08Setting modeCounterCounter of Paper feed6110Upper drawer08 digitsMCounts the number of sheets fed from upper drawer2Yes
08Setting modeCounterCounter of Paper feed6111Lower drawer08 digitsMCounts the number of sheets fed from lower drawer2Yes
08Setting modeCounterCounter of Paper feed6112Bypass feed08 digitsMCounts the number of sheets fed from bypass feed2Yes
08Setting modeCounterCounter of Paper feed6113LCF08 digitsMCounts the number of sheets fed from LCF2Yes
08Setting modeCounterCounter of Paper feed6114PFP upper drawer08 digitsMCounts the number of sheets fed from PFP upper drawer2Yes
08Setting modeCounterCounter of Paper feed6115PFP lower drawer08 digitsMCounts the number of sheets fed from PFP lower drawer2Yes
08Setting modeCounterCounter of Paper feed6116ADU08 digitsMCounts the number of output pages of duplex printing.2Yes
08Setting modeCounterCounter of Paper feed6117RADF08 digitsSYSCounts the number of originals fed from RADF2Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterMaintenan cePM counterK6190Setting valueRefer to contents8 digitsM<Default>
e-STUDIO206L: JPD: 0
Other: 80000 e-STUDIO256:
JPD: 0
Other: 100000 e-STUDIO306:
JPD: 0
Other: 120000 e-STUDIO356:
JPD: 0
Other: 125000
e-STUDIO456/506: JPD: 0
Other: 150000
1Yes
08Setting modeCounterMaintenan cePM drive counterK6191Setting valueRefer to contents8 digitsMTime accumulating counter
<Default value>
e-STUDIO206L/256/306: JPD: 0
Other: 161000
e-STUDIO356/456/506: JPD: 0
Other: 135000
1Yes
08Setting modeCounterMaintenan cePM counterK6194Current value08 digitsMCounts up when the registration sensor is ON.1Yes
08Setting modeCounterMaintenan cePM drive counterK6195Current value08 digitsMCounts the drum driving time.1Yes
08Setting modeCounterMaintenan ce6198Switching of output pages/ driving counts at K-PM00~2MSelects the reference to notify the PM timing. (The message is displayed on the LCD screen.)
0: PM counter (The number of output pages is set at 08-6190.)
1: PM time counter (The timing is set at 08-6191.) 2: Whichever comes faster
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounter6225Number of output pages(Thick paper 1)08 digitsMCounts up when the registration sensor is ON. When the counter value of the fuser roller is cleared, this counter value is also cleared in sync at the PM support mode.1
08Setting modeCounterCounter6226Number of output pages(Thick paper 2)08 digitsMCounts up when the registration sensor is ON. When the counter value of the fuser roller is cleared, this counter value is also cleared in sync at PM support mode.1
08Setting modeCounterCounter6227Number of output pages(Thick paper 3)08 digitsMCounts up when the registration sensor is ON. When the counter value of the fuser roller is cleared, this counter value is also cleared in sync at PM support mode.1
08Setting modeCounterCounter6228Number of output pages (OHP film)08 digitsMCounts up when the registration sensor is ON. When the counter value of the fuser roller is cleared, this counter value is also cleared in sync at PM support mode.1
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6230Upper drawer08 digitsMCounts the number of times of the feeding retry from the upper drawer.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6231Lower drawer08 digitsMCounts the number of times of the feeding retry from the lower drawer.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6232PFP upper drawer08 digitsMCounts the number of times of the feeding retry from the PFP upper drawer.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6233PFP lower drawer08 digitsMCounts the number of times of the feeding retry from the PFP lower drawer.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6234Bypass feed08 digitsMCounts the number of times of the feeding retry from the bypass tray.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6235LCF08 digitsMCounts the number of times of the feeding retry from the LCF.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPaper feeding6236Feeding retry counter upper limit value(Upper drawer)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6237Feeding retry counter upper limit value(Lower drawer)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6238Feeding retry counter upper limit value(PFP upper drawer)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6239Feeding retry counter upper limit value(PFP lower drawer)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6240Feeding retry counter upper limit value(Bypass feed)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6241Feeding retry counter upper limit value(Tandem LCF)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterCounter6244Counter for tab paper08 digitsMCounts up when the registration sensor is ON in the tab paper mode.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounter6247Counter for envelope08 digitsMCounts up when the registration sensor is ON.
When the counter value of the fuser roller is reset, this counter is reset in sync at the PM support mode.
1Yes
08Setting modeCounterPM
counter
Photoconductive drum62500Present number of output pages08 digitsM4
counter
Photoconductive drum62501Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
e-STUDIO206L: 80,000
e-STUDIO256: 100,000
e-STUDIO306: 120,000
e-STUDIO356: 125,000
e-STUDIO456/506: 150,000
counter
Photoconductive drum62502Number of output
pages at the last replacement
08 digitsM4
counter
Photoconductive drum62503Present driving counts08 digitsM4
counter
Photoconductive drum62504Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
e-STUDIO206L/256/306: 161,000
e-STUDIO356/456/506: 135,000
counter
Photoconductive drum62505Driving counts at the last replacement08 digitsM4
counter
Photoconductive drum62506Present output pages for control08 digitsM4
counter
Photoconductive drum62507Present driving counts for control08 digitsM4
counter
Photoconductive drum62508Number of times replaced08 digitsM4
counter
Photoconductive drum6251-Date of previous replacement08 digitsM2
counter
Drum cleaning blade62580Present number of output pages08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Drum cleaning blade62581Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Drum cleaning blade62582Number of output
08 digitsM4
counter
Drum cleaning blade62583Present driving counts08 digitsM4
counter
Drum cleaning blade62584Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Drum cleaning blade62585Driving counts at the last replacement08 digitsM4
counter
Drum cleaning blade62586Present output pages for control08 digitsM4
counter
Drum cleaning blade62587Present driving counts for control08 digitsM4
counter
Drum cleaning blade62588Number of times replaced08 digitsM4
counter
Drum cleaning blade6259-Date of previous replacement08 digitsM2
counter
Drum separation finger62720Present number of output pages08 digitsM4
counter
Drum separation finger62721Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Drum separation finger62722Number of output pages at the last
replacement
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Drum separation finger62723Present driving counts08 digitsM4
counter
Drum separation finger62724Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Drum separation finger62725Driving counts at the last replacement08 digitsM4
counter
Drum separation finger62726Present output pages for control08 digitsM4
counter
Drum separation finger62727Present driving counts for control08 digitsM4
counter
Drum separation finger62728Number of times replaced08 digitsM4
counter
Drum separation finger6273-Date of previous replacement08 digitsM2
counter
Charger grid62740Present number of output pages08 digitsM4
counter
Charger grid62741Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Charger grid62742Number of output
08 digitsM4
counter
Charger grid62743Present driving counts08 digitsM4
counter
Charger grid62744Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Charger grid62745Driving counts at the last replacement08 digitsM4
counter
Charger grid62746Present output pages for control08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Charger grid62747Present driving counts for control08 digitsM4
counter
Charger grid62748Number of times replaced08 digitsM4
counter
Charger grid6275-Date of previous replacement08 digitsM2
counter
Charger (Wire)62820Present number of output pages08 digitsM4
counter
Charger (Wire)62821Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Charger (Wire)62822Number of output
08 digitsM4
counter
Charger (Wire)62823Present driving counts08 digitsM4
counter
Charger (Wire)62824Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Charger (Wire)62825Driving counts at the last replacement08 digitsM4
counter
Charger (Wire)62826Present output pages for control08 digitsM4
counter
Charger (Wire)62827Present driving counts for control08 digitsM4
counter
Charger (Wire)62828Number of times replaced08 digitsM4
counter
Charger (Wire)6283-Date of previous replacement08 digitsM2
counter
Ozone filter62980Present number of output pages08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Ozone filter62981Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
e-STUDIO206L: 240,000
e-STUDIO256: 200,000
e-STUDIO306: 240,000
e-STUDIO356: 250,000
e-STUDIO456/506: 300,000
counter
Ozone filter62982Number of output
08 digitsM4
counter
Ozone filter62983Present driving counts08 digitsM4
counter
Ozone filter62984Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
e-STUDIO206L: 483,000
e-STUDIO256/306: 322,000
e-STUDIO356/456/506: 270,000
counter
Ozone filter62985Driving counts at the last replacement08 digitsM4
counter
Ozone filter62986Present output pages for control08 digitsM4
counter
Ozone filter62987Present driving counts for control08 digitsM4
counter
Ozone filter62988Number of times replaced08 digitsM4
counter
Ozone filter6299-Date of previous replacement08 digitsM2
counter
Developer material63000Present number of output pages08 digitsM4
counter
Developer material63001Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Developer material63002Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Developer material63003Present driving counts08 digitsM4
counter
Developer material63004Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Developer material63005Driving counts at the last replacement08 digitsM4
counter
Developer material63006Present output pages for control08 digitsM4
counter
Developer material63007Present driving counts for control08 digitsM4
counter
Developer material63008Number of times replaced08 digitsM4
counter
Developer material6301-Date of previous replacement08 digitsM2
counter
Transfer (wire/belt/ roller)63140Present number of output pages08 digitsM4
counter
Transfer (wire/belt/ roller)63141Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Transfer (wire/belt/ roller)63142Number of output
08 digitsM4
counter
Transfer (wire/belt/ roller)63143Present driving counts08 digitsM4
counter
Transfer (wire/belt/ roller)63144Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Transfer (wire/belt/ roller)63145Driving counts at the last replacement08 digitsM4
counter
Transfer (wire/belt/ roller)63146Present output pages for control08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Transfer (wire/belt/ roller)63147Present driving counts for control08 digitsM4
counter
Transfer (wire/belt/ roller)63148Number of times replaced08 digitsM4
counter
Transfer (wire/belt/ roller)6315-Date of previous replacement08 digitsM2
counter
Fuser roller63460Present number of output pages08 digitsM4
counter
Fuser roller63461Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Fuser roller63462Number of output
08 digitsM4
counter
Fuser roller63463Present driving counts08 digitsM4
counter
Fuser roller63464Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Fuser roller63465Driving counts at the last replacement08 digitsM4
counter
Fuser roller63466Present output pages for control08 digitsM4
counter
Fuser roller63467Present driving counts for control08 digitsM4
counter
Fuser roller63468Number of times replaced08 digitsM4
counter
Fuser roller6347-Date of previous replacement08 digitsM2
counter
Pressure roller63500Present number of output pages08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Pressure roller63501Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Pressure roller63502Number of output
08 digitsM4
counter
Pressure roller63503Present driving counts08 digitsM4
counter
Pressure roller63504Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Pressure roller63505Driving counts at the last replacement08 digitsM4
counter
Pressure roller63506Present output pages for control08 digitsM4
counter
Pressure roller63507Present driving counts for control08 digitsM4
counter
Pressure roller63508Number of times replaced08 digitsM4
counter
Pressure roller6351-Date of previous replacement08 digitsM2
counter
Fuser roller separation finger63680Present number of output pages08 digitsM4
counter
Fuser roller separation finger63681Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Fuser roller separation finger63682Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Fuser roller separation finger63683Present driving counts08 digitsM4
counter
Fuser roller separation finger63684Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Fuser roller separation finger63685Driving counts at the last replacement08 digitsM4
counter
Fuser roller separation finger63686Present output pages for control08 digitsM4
counter
Fuser roller separation finger63687Present driving counts for control08 digitsM4
counter
Fuser roller separation finger63688Number of times replaced08 digitsM4
counter
Fuser roller separation finger6369-Date of previous replacement08 digitsM2
counter
Pickup roller (RADF)63820Present number of output pages08 digitsSYS4
counter
Pickup roller (RADF)63821Recommended number of output pages for replacement120,0008 digitsSYS4
counter
Pickup roller (RADF)63822Number of output
08 digitsSYS4
counter
Pickup roller (RADF)63828Number of times replaced08 digitsSYS4
counter
Pickup roller (RADF)6383-Date of previous replacement08 digitsSYS2
counter
Feed roller (RADF)63840Present number of output pages08 digitsSYS4
counter
Feed roller (RADF)63841Recommended number of output pages for replacement120,0008 digitsSYS4
counter
Feed roller (RADF)63842Number of output pages at the last
replacement
08 digitsSYS4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Feed roller (RADF)63848Number of times replaced08 digitsSYS4
counter
Feed roller (RADF)6385-Date of previous replacement08 digitsSYS2
counter
Separation roller (RADF)63860Present number of output pages08 digitsSYS4
counter
Separation roller (RADF)63861Recommended number of output pages for replacement120,0008 digitsSYS4
counter
Separation roller (RADF)63862Number of output
08 digitsSYS4
counter
Separation roller (RADF)63868Number of times replaced08 digitsSYS4
counter
Separation roller (RADF)6387-Date of previous replacement08 digitsSYS2
counter
Pickup roller (Upper drawer of equipment)63900Present number of output pages08 digitsM4
counter
Pickup roller (Upper drawer of equipment)63901Recommended number of output pages for replacement80,0008 digitsM4
counter
Pickup roller (Upper drawer of equipment)63902Number of output
08 digitsM4
counter
Pickup roller (Upper drawer of equipment)63908Number of times replaced08 digitsM4
counter
Pickup roller (Upper drawer of equipment)6391-Date of previous replacement08 digitsM2
counter
Pickup roller (Lower drawer of equipment)63920Present number of output pages08 digitsM4
counter
Pickup roller (Lower drawer of equipment)63921Recommended number of output pages for replacement80,0008 digitsM4
counter
Pickup roller (Lower drawer of equipment)63922Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Pickup roller (Lower drawer of equipment)63928Number of times replaced08 digitsM4
counter
Pickup roller (Lower drawer of equipment)6393-Date of previous replacement08 digitsM2
counter
Pickup roller (Optional LCF)63940Present number of output pages08 digitsM4
counter
Pickup roller (Optional LCF)63941Recommended number of output pages for replacement160,0008 digitsM4
counter
Pickup roller (Optional LCF)63942Number of output
08 digitsM4
counter
Pickup roller (Optional LCF)63948Number of times replaced08 digitsM4
counter
Pickup roller (Optional LCF)6395-Date of previous replacement08 digitsM2
counter
Feed roller (Upper drawer of equipment)63980Present number of output pages08 digitsM4
counter
Feed roller (Upper drawer of equipment)63981Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Upper drawer of equipment)63982Number of output
08 digitsM4
counter
Feed roller (Upper drawer of equipment)63988Number of times replaced08 digitsM4
counter
Feed roller (Upper drawer of equipment)6399-Date of previous replacement08 digitsM2
counter
Feed roller (Lower drawer of equipment)64000Present number of output pages08 digitsM4
counter
Feed roller (Lower drawer of equipment)64001Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Lower drawer of equipment)64002Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Feed roller (Lower drawer of equipment)64008Number of times replaced08 digitsM4
counter
Feed roller (Lower drawer of equipment)6401-Date of previous replacement08 digitsM2
counter
Feed roller (Optional LCF)64020Present number of output pages08 digitsM4
counter
Feed roller (Optional LCF)64021Recommended number of output pages for replacement160,0008 digitsM4
counter
Feed roller (Optional LCF)64022Number of output
08 digitsM4
counter
Feed roller (Optional LCF)64028Number of times replaced08 digitsM4
counter
Feed roller (Optional LCF)6403-Date of previous replacement08 digitsM2
counter
Separation roller
64060Present number of output pages08 digitsM4
counter
Separation roller (Upper drawer of equipment)64061Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller
64062Number of output
08 digitsM4
counter
Separation roller
64068Number of times replaced08 digitsM4
counter
Separation roller
6407-Date of previous replacement08 digitsM2
counter
Separation roller
64080Present number of output pages08 digitsM4
counter
Separation roller (Lower drawer of equipment)64081Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller
64082Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Separation roller
64088Number of times replaced08 digitsM4
counter
Separation roller
6409-Date of previous replacement08 digitsM2
counter
Separation roller (Optional LCF)64100Present number of output pages08 digitsM4
counter
Separation roller (Optional LCF)64101Recommended number of output pages for replacement160,0008 digitsM4
counter
Separation roller (Optional LCF)64102Number of output
08 digitsM4
counter
Separation roller (Optional LCF)64108Number of times replaced08 digitsM4
counter
Separation roller (Optional LCF)6411-Date of previous replacement08 digitsM2
counter
Separation roller
(Upper drawer of PFP)
64120Present number of output pages08 digitsM4
counter
Separation roller (Upper drawer of PFP)64121Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller
64122Number of output
08 digitsM4
counter
Separation roller
64128Number of times replaced08 digitsM4
counter
Separation roller
6413-Date of previous replacement08 digitsM2
counter
Separation roller
(Lower drawer of PFP)
64140Present number of output pages08 digitsM4
counter
Separation roller (Lower drawer of PFP)64141Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller
64142Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Separation roller
64148Number of times replaced08 digitsM4
counter
Separation roller
6415-Date of previous replacement08 digitsM2
counter
Separation roller (Bypass unit)64160Present number of output pages08 digitsM4
counter
Separation roller (Bypass unit)64161Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller (Bypass unit)64162Number of output
08 digitsM4
counter
Separation roller (Bypass unit)64168Number of times replaced08 digitsM4
counter
Separation roller (Bypass unit)6417-Date of previous replacement08 digitsM2
counter
Feed roller (Upper drawer of PFP)64200Present number of output pages08 digitsM4
counter
Feed roller (Upper drawer of PFP)64201Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Upper drawer of PFP)64202Number of output
08 digitsM4
counter
Feed roller (Upper drawer of PFP)64208Number of times replaced08 digitsM4
counter
Feed roller (Upper drawer of PFP)6421-Date of previous replacement08 digitsM2
counter
Feed roller (Lower drawer of PFP)64220Present number of output pages08 digitsM4
counter
Feed roller (Lower drawer of PFP)64221Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Lower drawer of PFP)64222Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Feed roller (Lower drawer of PFP)64228Number of times replaced08 digitsM4
counter
Feed roller (Lower drawer of PFP)6423-Date of previous replacement08 digitsM2
counter
Feed roller (Bypass unit)64240Present number of output pages08 digitsM4
counter
Feed roller (Bypass unit)64241Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Bypass unit)64242Number of output
08 digitsM4
counter
Feed roller (Bypass unit)64248Number of times replaced08 digitsM4
counter
Feed roller (Bypass unit)6425-Date of previous replacement08 digitsM2
counter
Pickup roller (Upper drawer of PFP)64280Present number of output pages08 digitsM4
counter
Pickup roller (Upper drawer of PFP)64281Recommended number of output pages for replacement80,0008 digitsM4
counter
Pickup roller (Upper drawer of PFP)64282Number of output
08 digitsM4
counter
Pickup roller (Upper drawer of PFP)64288Number of times replaced08 digitsM4
counter
Pickup roller (Upper drawer of PFP)6429-Date of previous replacement08 digitsM2
counter
Pickup roller (Lower drawer of PFP)64300Present number of output pages08 digitsM4
counter
Pickup roller (Lower drawer of PFP)64301Recommended number of output pages for replacement80,0008 digitsM4
counter
Pickup roller (Lower drawer of PFP)64302Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Pickup roller (Lower drawer of PFP)64308Number of times replaced08 digitsM4
counter
Pickup roller (Lower drawer of PFP)6431-Date of previous replacement08 digitsM2
counter
Recovery blade64360Present number of output pages08 digitsM4
counter
Recovery blade64361Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Recovery blade64362Number of output
08 digitsM4
counter
Recovery blade64363Present driving counts08 digitsM4
counter
Recovery blade64364Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Recovery blade64365Driving counts at the last replacement08 digitsM4
counter
Recovery blade64366Present output pages for control08 digitsM4
counter
Recovery blade64367Present driving counts for control08 digitsM4
counter
Recovery blade64368Number of times replaced08 digitsM4
counter
Recovery blade6437-Date of previous replacement08 digitsM2
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counter6500Standard paper size settingRefer to contents0~1SYSSelects the standard paper size to convert it into the pixel count (%).
0: A4 1: LT
<Default value> NAD: 1
Other: 0
08Setting modeCounterPixel counter6501Pixel counter all clearing--SYSClears all information related to the pixel counter.3
08Setting modeCounterPixel counter6502Service technician reference counter clearing--SYSClears all information related to the service technician reference pixel counter.3
08Setting modeCounterPixel counter6503Toner cartridge
--SYSClears all information related to the toner cartridge reference pixel counter.3
08Setting modeCounterPixel counter6504Pixel counter display setting10~1SYSSelects whether or not to display the pixel counter on the LCD screen. 0: Displayed 1: Not displayed1
08Setting modeCounterPixel counter6505Displayed reference setting00~1SYSSelects the reference when displaying the pixel counter on the LCD screen.
0: Service technician reference 1: Toner cartridge reference
08Setting modeCounterPixel counter6506Counter setting for toner empty00~1SYS0: Number of sheets 1: Value of pixel counter1
08Setting modeCounterPixel counter6507Number of sheets for toner empty8000~999SYSSets the number of sheets for toner empty.1
08Setting modeCounterPixel counter6508Pixel counter value for toner empty351000~60000SYSSets the pixel counter value for toner empty.1
08Setting modeCounterPixel counter6509Pixel counter clear flag/Service technician reference00~1SYSBecomes "1" when 08-6502 is performed.2
08Setting modeCounterPixel counter6510Service technician
reference cleared date
-0~9999999
SYSDisplays the date on which 08-6502 was performed.2
08Setting modeCounterPixel counter6514Toner cartridge
-0~9999999
SYSDisplays the date on which 08-6503 was performed.2
08Setting modeCounterPixel counter6522Toner cartridge reference count
started date
-0~9999999
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterNumber of output pages(Service technician reference)6558PPC08 digitsSYSCounts the number of output pages converted to the standard paper size in the copy function and service technician reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Service technician reference)6560PRT08 digitsSYSCounts the number of output pages converted to the standard paper size in the printer function and service technician reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Service technician reference)6561FAX08 digitsSYSCounts the number of output pages converted to the standard paper size in the FAX function and service technician reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Toner cartridge reference)6563PPC08 digitsSYSCounts the number of output pages converted to the standard paper size in the copy function and toner cartridge reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Toner cartridge reference)6565PRT08 digitsSYSCounts the number of output pages converted to the standard paper size in the printer function and toner cartridge reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Toner cartridge reference)6566FAX08 digitsSYSCounts the number of output pages converted to the standard paper size in the FAX function and toner cartridge reference. [Unit. page]2
08Setting modeCounterPixel counter6576Toner cartridge replacement counter03 digitsSYSCounts the number of time of the toner cartridge replacement.2
08Setting modeCounterPixel counterAverage pixel count(Service technician reference)6602PPC00~10000SYSDisplays the average pixel count in the copy function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Service technician reference)6603PRT00~10000SYSDisplays the average pixel count in the printer function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Service technician reference)6604FAX00~10000SYSDisplays the average pixel count in the FAX function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Service technician reference)6605PPC/PRT/FAX00~10000SYSDisplays the average pixel count in the copy/printer/FAX function and service technician reference. [Unit: 0.01%]2
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterLatest pixel count(Service technician reference)6616PPC00~10000SYSDisplays the latest pixel count in the copy function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterLatest pixel count(Service technician reference)6617PRT00~10000SYSDisplays the latest pixel count in the printer function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterLatest pixel count(Service technician reference)6618FAX00~10000SYSDisplays the latest pixel count in the FAX function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Toner cartridge reference)6623PPC00~10000SYSDisplays the average pixel count in the copy function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Toner cartridge reference)6629PRT00~10000SYSDisplays the average pixel count in the printer function, and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Toner cartridge reference)6634PPC/PRT/FAX00~10000SYSDisplays the average pixel count in the copy/printer/FAX function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Toner cartridge reference)6635FAX00~10000SYSDisplays the average pixel count in the FAX function and toner cartridge reference. [Unit: 0.01%]2
6644FAX00~10000SYSDisplays the latest pixel count in the FAX function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterPixel count distributionPPC672100-5%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC672115.1-10%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721210.1-15%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterPixel count distributionPPC6721315.1-20%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721420.1-25%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721525.1-30%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721630.1-40%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721740.1-60%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721860.1-80%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721980.1-100%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT672200-5%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT672215.1-10%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722210.1-15%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722315.1-20%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterPixel count distributionPRT6722420.1-25%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722525.1-30%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722630.1-40%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722740.1-60%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722860.1-80%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722980.1-100%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX672300-5%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX672315.1-10%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723210.1-15%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723315.1-20%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723420.1-25%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterPixel count distributionFAX6723525.1-30%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723630.1-40%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723740.1-60%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723860.1-80%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723980.1-100%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterLatest pixel count/black(Toner cartridge reference)6724PPC00~10000SYSDisplays the latest pixel count in the copy function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterLatest pixel count/black(Toner cartridge reference)6725PRT00~10000SYSDisplays the latest pixel count in the printer function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterCounter for toner- save modePrint in toner-save mode68200Small size/black08 digitsSYSNumber of printed sheets in the toner-save mode.4
08Setting modeCounterCounter for toner- save modePrint in non-toner- save mode68201Small size/black08 digitsSYSNumber of printed sheets in the non-toner-save mode.4
08Setting modeCounterCounter for toner- save modePrint in toner-save mode68230Large size/black08 digitsSYSNumber of printed sheets in the toner-save mode.4
08Setting modeCounterCounter for toner- save modePrint in non-toner- save mode68231Large size/black08 digitsSYSNumber of printed sheets in the non-toner-save mode.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterBlack job counter68520PPC08 digitsSYSCounter for monochrome copy job.4
08Setting modeCounterBlack job counter68521PRT08 digitsSYSCounter for monochrome print job.4
08Setting modeCounterBlack job counter68522PPC/PRT08 digitsSYSTotal counter for monochrome copy and print job.4
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)69770Latest01 digit or 8digitsM1 digit: Production location indicated.
-0: Cartridge not installed
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
-6: Cartridge not detected (when the IC chip information cannot be detected)
8 digits: Lot No. indicated
4Yes
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)697711 cartridge earlier01 digit or 8digitsM1 digit: Production location indicated.
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
4Yes
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)697722 cartridges earlier01 digit or 8digitsM1 digit: Production location indicated.
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)697733 cartridges earlier01 digit or 8digitsM1 digit: Production location indicated.
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
4Yes
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)697744 cartridges earlier01 digit or 8digitsM1 digit: Production location indicated.
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
4Yes
08Setting modeImage Processin gImageClearing of adjustment values of all image process (PPC) related 05 codes7000PPC--M/SY
Sclea r
Clears the gamma correction table values and the adjustment values of the following 05 codes: 05-7000 to 7299, 7600 to 7999
After executing this code, execute 08-4581.
08Setting modeImage Processin gImageClearing of all gamma correction table values (PPC related areas only)7001PPC--SYSClears all the gamma correction table values in the PPC related areas of the HDD.3
08Setting modeImage
Processin g
ImageError diffusion and dither setting7014Photo mode10~1SYSSets the image reproduction method at photo mode. 0: Error diffusion 1: Dither1
08Setting modeImage Processin gImageError diffusion and dither setting7015Photo mode (Custom Mode)10~1SYSSwitches the image processing method when Custom Mode 3 is set.
08Setting modeImage Processin gUser interfaceUser mode setting7034PPC00~3SYS0: Not used 1: Text/Photo is set as a base 2: Text is set as a base
3: Photo is set as a base
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeImage Processin gAutomatic tone correction dataLast updated date and time7051Monochrome PPC00-
421231235
SYSLast updated date and time of automatic tone correction data.
YYMMDDHHMM
YY: year, MM: month, DD: day, HH: hour, MM: minute
2Yes
08Setting modeImage Processin gImageClearing of adjustment values of all image process (network print) related 05 codes7300PRT--SYS/ MClears the gamma correction table values and the adjustment values of the following 05 codes:
05-7300 to 7399
05-8200 to 8299
08Setting modeImage Processin gImageClearing of adjustment values of all image process (network scan) related 05 codes7400SCN--SYSClears the adjustment values of the following 05 codes: 05-7400 to 7499
05-8300 to 8499
08Setting modeImage
Processin g
User interfaceUser mode settingSCN7401Black00~3SYS0: Unused 1: Text/Photo base 2: Text base 3: Photo base1Yes
08Setting modeImage Processin gImageClearing of adjustment values of all image process (Fax) related 05 codes7500FAX--SYS/ MClears the adjustment values of the following 05 codes: 05-7500 to 7599
08Setting modeImage Processin gUser interfaceUser mode settingSCN8303Color00~4SYS0: Unused 1: Text/Photo base 2: Text base 3: Photo base 4: e-document base
* e-document: This is the mode that corresponds to the law in Japan. This mode is used to clarify area where changes were made with such as a correction fluid.
1Yes
08Setting modeSystemGeneral8504Feeding method of odd page number in duplex printing(Raw print)00~1SYS0: One side 1: Both sides1
08Setting modeSystemGeneral8506Forcible mode
change in cartridge empty status
10~2SYS0: SLEEP MODE 1: AUTO POWER SAVE 2: READY1
08Setting modeSystemGeneralWide A4 Mode (for PCL)8511PRT00~1SYS0: Disable 1: Enable1
08Setting modeSystemGeneral8512Number of jobs in batch processing102~10SYS2-10: From 2 to jobs can be specified1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral8514Threshold value setting for RIP standard paper judgment205~30SYSThis code is used for changing the range in which the non-standard paper size is judged as standard paper size. If the page size information is within standard paper size ± setting value, the page size is judged as standard paper size when PS/PDF printing. If the page size information is out of the range, the page size is judged as non-standard paper size. The unit of setting value is PS point. 1 PS point is approx. 0.35 mm.1Yes
08Setting modeSystemGeneralOutside erase
judgment threshold (Default)
PPC8515PPC0-3~3SYSThe larger the value is, area to be erased increases. The smaller the value is, area to be erased decreases.1
SCN8516SCN0-3~3SYSThe larger the value is, area to be erased increases. The smaller the value is, area to be erased decreases.1
08Setting modeSystemGeneral8517Remote Scan User authentication automatic login10~1SYS0: OFF (A user always enters manually (current method))
1: ON (Previous authentication information will be used)
08Setting modeSystemGeneral8518Overwriting mode for scanned files00~3SYS0: Always OFF
1: Meta Scan function ON / Normal scan function OFF 2: Meta Scan function OFF / Normal scan function ON 3: Always ON
08Setting modeSystemGeneral8519Scan PDF file Paper size10~1SYS0: Equivalent to scan image size 1: Fitted into any standard size1
08Setting modeSystemGeneral8520Underscore conversion of prohibited character in filename10-1SYSSets the prohibited characters in filename to covert to underscore.
0: \ / > < , " | ? * : ; = [ ] +
1: \ / > < " | ? * :
* 0: Existing model standard 1: Windows standard Since setting the value to "1" allows some prohibited characters, filename might not be processed in external application or server.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral8521Switchover of output format of Service Notification attachmentRefer to contents0-1SYSSwitches the output format of date in attachment of Service Notification.
0: YYYY.MM.DD
1: YYYY-MM-DDTHH:MM:SS
Others: 0
08Setting modeSystemUser interfaceScreen setting8523Toner near-empty status MessageRefer to contents0~1SYS0: ON 1: OFF
<Default value> JPD/NAD/MJD/AUD/ARD: 1
Others: 0
1Yes
08Setting modeSystemGeneral8524No paper Message display00~1SYS0: ON 1: OFF1
08Setting modeSystemGeneral8525No paper in the left
tray of tandem LCF message
08Setting modeSystemGeneral8532Control panel
Brightness level adjustment
41~7SYS1-7: Brightness level1
08Setting modeSystemGeneralSorting method for displaying private print jobs8537PRT00~1SYSChanges the sorting order for print jobs on the private print list.
0: Descending order 1: Ascending order
08Setting modeSystemMaintenan
ce (Remote)
8538Notification setting for toner nearly empty00~1SYS0: Disabled 1: Enabled1
08Setting modeSystemScannerDate/time format in
the Meta Scan XML file
8540SCN10~1SYS0: YYYY/MM/DDhh:mm:ss.mmm
1: YYYY-MM-DDThh:mm:ss.mmmTZD
08Setting modeSystemUser interface8543Transition to the energy saving mode when in the Sleep mode10~1SYS0: Disabled 1: Enabled (depending on conditions)1Yes
08Setting modeSystemUser interface8544Tolerance for switching to Super Sleep mode55~600SYSThe interval between recovering from the Super Sleep mode and making the transition to the Super Sleep mode again. Unit: seconds.1Yes
08Setting modeSystemUser interface8546Input setting of minus value for image shift when copying00~1SYS0: Inputting minus value is disabled. 1: Inputting minus value is enabled.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemPaper feedingChange of the paper size setting on the touch panel when printing is interrupted by size mismatch8548PRT00~1SYS0: Change of the paper size setting on the touch panel is disabled.
1: Change of the paper size setting on the touch panel is enabled.
08Setting modeSystemCounter8549Hardware key control when external counter is installed00~1SYS0: No control 1: Mode switch key is disabled.1
08Setting modeSystemMaintenan ce8584Selects whether or
not to transmit the Subject.
10~1SYS0: Disabled 1: Enabled1
08Setting modeSystemMaintenan ce8585Selects the edit setting of the Subject.10~1SYS0: Disabled 1: Enabled1
08Setting modeSystemMaintenan ce8586Selects whether or not to add the date and time to the Subject.10~1SYS0: Not added 1: Added1
08Setting modeSystemMaintenan ce8587Selects the setting of the Subject, by using the fixed string or inputting the specified one.00~1SYS0: Fixed string (Default) 1: Specified string1
08Setting modeSystemLDAP user authenticat ionAttribute value setting8592Sender addressmail-SYSSets the default attribute value of sender address. Maximum 32 characters (ASCII).11
08Setting modeSystemLDAP user authenticat ionAttribute value setting8593Sender nameuid-SYSSets the default attribute value of sender name. Maximum 32 characters (ASCII).11
08Setting modeSystemMaintenan ce8597Updates the Private/Hold Print job list automatically00~1SYS0: Disabled 1: Enabled1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemMaintenan ce8598Selects the template icon layout on the touch panel00~1SYS0: Pattern 1
(1) (2) (3) (4)
(5) (6) (7) (8)
(9) (10) (11) (12)
(13) (14) (15) (16)
1: Pattern 2
(1) (2) (9) (10)
(3) (4) (11) (12)
(5) (6) (13) (14)
(7) (8) (15) (16)
08Setting modeSystemGeneralOutside erase8600Change of default value00~1SYS0: Disabled
1Yes
08Setting modeSystemMaintenan ce8603Special usage of external options I/F00~2SYS0: None (Default) 1: Usage 1 2: Usage 21
08Setting modeSystemNetworkPrioritized authentication server8608Windows00-100SYSSets the prioritized authentication server to be searched (0 to 100). The servers displayed on the screen accessed by TopAccess -> Administration -> Maintenance -> Directory Service are numbered beginning at the top (0 to 100).1
08Setting modeSystemNetworkPrioritized authentication server8609LDAP00-100SYSSets the prioritized authentication server to be searched (0 to 100). The servers displayed on the screen accessed by TopAccess -> Administration -> Maintenance -> Directory Service are numbered beginning at the top (0 to 100).1
08Setting modeSystemNetworkPrioritized authentication server8610Card00-100SYSSets the prioritized authentication server to be searched (0 to 100). The servers displayed on the screen accessed by TopAccess -> Administration -> Maintenance -> Directory Service are numbered beginning at the top (0 to 100).1
08Setting modeSystemUser interface8622Date and time addition setting to file name of scan to file/e- mail10-1SYS0: Not added
1: Added
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemGeneral86230RIP function setting10-1SYSEnables/Disables the function related to Excel boarder rendering of PCL6. The function is to prevent missing lines when scaling down and inconsistent line width when scaling up.
0: Disabled (No correction. Compliant with PCL6 language)
08Setting modeSystemUser interface8624Switchover of display method of filename30-3SYSSwitches the display method of filename. 0: Displays the filename from the beginning 1: Displays the trailing characters
2: Displays the beginning and trailing characters 3: Displays the filename without abbreviation
08Setting modeSystemUser interface8628Job operation on the COPY screen when the coin controller is connected00-1SYSThis setting enables user to move from the COPY screen to JOB STATUS screen, and then operate jobs during printing when the coin controller is connected. This code is valid when the value of 08-9016 is "1".
08Setting ModeSystemFAX8631Filename creation at fax reception and forwarding00-1SYS0: Use address name (family-name/first-name) as filename if multiple names are found by address book search of TSI (sender information).
1: Use address name (family-name/first-name) as filename only when single name is found by address book search of TSI (sender information).
08Setting modeSystemUser interface8640Job build operation when the coin controller is connected00-1SYSThis setting enables user to use the job build function when the coin controller is connected. This code is valid when the value of 08-9016 is "1".
08Setting ModeSystemGeneral8641Notification setting for job cancel10-1SYSSets the notification setting for job cancel. This setting is effective for the following error codes:
1CC0, 2BB0, 2CC0, 2DC0, 2EC0
0: Disabled (Not notified) 1: Enabled (Notified)
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8642LDAP attribute name settings 2eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8643LDAP attribute name settings 3eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8644LDAP attribute name settings 4eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8645LDAP attribute name settings 5eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8646LDAP attribute name settings 6eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8647LDAP attribute name settings 7eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8648LDAP attribute name settings 8eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8649LDAP attribute name settings 9eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8650LDAP attribute name settings 10eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8651LDAP attribute name settings 11eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8652LDAP attribute name settings 12eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8653LDAP attribute name settings 13eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8654LDAP attribute name settings 14eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8655LDAP attribute name settings 15eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8656LDAP attribute name settings 16eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceSound8657Placing original00-1SYS0: OFF 1: ON1
08Setting ModeSystemUser interfaceSound8658Pressing [INTERRUPT] button00-1SYS0: OFF 1: ON1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemUser interfaceSound8659Switchover of function00-1SYS0: OFF 1: ON1
08Setting ModeSystemUser interfaceSound8660Completion of job (except for FAX)00-1SYS0: OFF 1: ON1
08Setting ModeSystemUser interfaceSound8661End of warming- up/prewarming/sleep00-1SYS0: OFF 1: ON1
08Setting ModeSystemUser interfaceSound8662Job interrupt (out of paper)00-1SYS0: OFF 1: ON1
08Setting ModeSystemUser interfaceSound8663Fax transmission error00-1SYS0: OFF 1: ON1
08Setting ModeSystemUser interfaceSoundHours for mute86640Enable/Disable setting of mute00-1SYS0: Mute is disabled 1: Mute is enabled4
08Setting ModeSystemUser interfaceSoundHours for mute86641Starting time00-2359SYS(Hour/Hour/Minute/Minute)4
08Setting ModeSystemUser interfaceSoundHours for mute86642Ending time00-2359SYS(Hour/Hour/Minute/Minute)4
08Setting ModeSystemGeneral8667Saving image log00-1SSDK0: Disabled 1: Enabled1
08Setting ModeSystemGeneral8668Number of pages saved as image log10-1SSDK0: First page
1: All pages
08Setting ModeSystemNetworkNumber of retry for file transfer86710FTP30-10SYSThe transmission may succeed when the number of
retry increases. However, it takes longer time to complete the job.
08Setting ModeSystemNetworkNumber of retry for file transfer86711SMB30-10SYSThe transmission may succeed when the number of
08Setting ModeSystemNetworkNumber of retry for file transfer86712NetWare30-10SYSThe transmission may succeed when the number of
08Setting ModeSystemNetworkRetry interval for file transfer86720FTP1800-999SYSThe transmission may succeed when the retry interval becomes longer. However, it takes longer time to complete the job. (Unit: sec.)4
08Setting ModeSystemNetworkRetry interval for file transfer86721SMB1800-999SYSThe transmission may succeed when the retry interval becomes longer. However, it takes longer time to complete the job. (Unit: sec.)4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemNetworkRetry interval for file transfer86722NetWare1800-999SYSThe transmission may succeed when the retry interval becomes longer. However, it takes longer time to complete the job. (Unit: sec.)4
08Setting ModeSystemGeneral8673Disclosure of image log function00-1SSDK0: Not opened to public 1: Opened to public1
08Setting ModeSystemGeneral8674Prohibition of transition to sleep mode during network initialization00-1SYS0: Allowed
1: Prohibited
08Setting modeSystemFAX8700Secret reception setting00-2SYSWhen the value of 08-8924 is "0", the value of this code can be set to "1" or "2".
0: Always Off
1: Always On
2. Scheduled reception
08Setting modeSystemUser interface8704Restriction of Email/FAX address00~1SYSThis code is used to restrict Email/FAX Address to LDAP server specified via TopAccess. When the value of this code is set to "1", the address cannot be input directly and registered from the local address book.
0: No restriction
1: Looking up in external LDAP only
08Setting modeSystemUser interface8709Service notification (equipment information)Refer to contents0-1SYSSets whether the [SERVICE NOTIFICATION] (Equipment Information) button accessed by [USER FUNCTIONS] -> [ADMIN] -> [SERVICE] is displayed or not.
<Default value> JPC/NAD/MJD: 1
Others: 0
1Yes
08Setting modeSystemScanning8710Setting of character code for Scan to FTP00-2SYS0: Automatic selection
1: UTF8
2: Shift-JIS
08Setting modeSystemUser interface8712Display setting of the drawer setting button10-1SYSSets whether the drawer button in USER FUNCTIONS is displayed or not.
0: Not displayed
1: Displayed
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface8713Setting of web upload/web printing00-1SYSSets whether the web upload and web printing function is enabled or disabled.
  • Web upload is a function which uploads the image data created on the equipment to the web page displayed on EWB.
  • Web printing is a function which prints the web page displayed on EWB or the PDF file included in the web page displayed on EWB.
08Setting modeSystemUser interfaceService notification information8715Password for zip file with password#104810
-SYSPassword for zip file with password of service notification information.
Minimum number of digits: 0, maximum number of digits: 20
Available character: alphanumeric characters and symbols
08Setting modeSystemUser interface8717Shutdown operation when Super Sleep is enabled00-1SYSSets the operation when the power button on the control panel is press for a few seconds if Super Sleep is enabled.
0: Hibernation
1: Super Sleep
1Yes
08Setting modeSystemUser interface8718Selection for caching the screen of control panel at start-up00-17SYSUse this code to shorten the time to switch the function on the control panel for the first time immediately after start-up. However, the start-up time becomes longer (about 1 to 3 seconds per screen). When selecting multiple screens, enter the total value.
1: Copy
16: Fax
08Setting modeSystemNetwork8719MTU setting of network communication1500576-1500NICNormally there's no need to change the MTU value. Set the proper MTU value when MFP is connected to the Internet using broadband router and so on.12
08Setting modeSystemUser interface8720Department code display with asterisk00-1SYS0: Displays department code with asterisk when inputting it.
1: Displays department code as it is when inputting it.
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemFAX8721Automatic FAX sending at AutoClear when scanning original put on the glass00-1SYSSets whether the job is sent or canceled when AutoClear is executed on the interruption screen to confirm the next original displayed after scanning the original put on the glass. Use this code to cancel job when the equipment is left unattended while the interruption screen is displayed.
0: Sends job
1: Cancels job
1Yes
08Setting modeSystemUser interface8722Display method of "Cannot find the Home Directory" on the control panel00-1SYSSets the display method of error if the Home Directory for user cannot be obtained from the server when setting the Home Directory for scanning. Use this code to disable the pop-up display when the Home Directory cannot be obtained depending on the user.
0: Displays the pop-up dialogue when user logs in
1: Displays the message in the guidance area when the Scan to File screen is displayed
1Yes
08Setting modeSystemUser interface8723Pop-up display of logging out of user authentication and department management on the control panel10-1SYSSets whether the pop-up dialog of confirmation for logging out is displayed when user or department logs out by pressing [FUNCTION CLEAR] button twice or pressing [ACCESS] button.
0: Logs out without displaying pop-up dialog 1: Displays pop-up dialog when logging out
1Yes
08Setting modeSystemUser interface8724Display setting of Edit From Address button for Scan to email10-1SYS0: Not displayed (From Address cannot be edited) 1: Displayed (From Address can be edited)1Yes
08Setting modeSystemUser interface8725Display setting of [USER FUNCTIONS]-
> CHANGE
LANGUAGE button
10-1SYSSets whether the [CHANGE LANGUAGE] button accessed from [USER FUNCTIONS] button is displayed or not. Use this code to prohibit users from changing the language displayed on the control panel. Administrators can change the language.
0: Not displayed
1: Displayed
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral8726Job deletion on the Job Status screen00-1SYSUse this code to enable the job deletion on the [Job Status] screen. When "3: High level" is set for code 08- 8911, be sure to disable this setting.
1Yes
08Setting ModeSystemUser interfaceCard reading device8727Display of dedicated screen for card authentication00-1SYSSwitches whether the message to hold a card over the card reader is displayed on the login screen when the card authentication is enabled.
08Setting ModeSystemForced printing of user name87280Display/Non-display setting in TopAccess00-1SYS0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87281Enable/Disable setting of forced printing00-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87282Prioritizing printer driver setting10-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87283Application to network fax job00-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87284Enable/Disable setting of prefix/suffix00-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87286White background setting10-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87287Print position00-3SYSNormally this setting is made in TopAccess.
0: Bottom left 1: Top left 2: Bottom right 3: Top right
08Setting ModeSystemForced printing of user name87288Fine adjustment of print position (X)30-100SYSAdjusts the print position in X direction. The print position shifts toward inside of original when the value increases. Unit: pt. 1pt = 0.35mm.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemForced printing of user name87289Fine adjustment of print position (Y)30-100SYSAdjusts the print position in Y direction. The print position shifts toward inside of original when the value increases. Unit: pt. 1pt = 0.35mm.4
08Setting ModeSystemForced printing of user name872810Font setting00-9SYSNormally this setting is made in TopAccess.
0: Helvetica 1: AlbertusMT 2: Chicago 3: Eurostile 4:
Geneva 5: GillSans 6: LetterGothic 7: Monaco 8:
Taffy 9: TimesNewRomanPSMT
08Setting ModeSystemForced printing of user name872811Font size setting86-16SYSNormally this setting is made in TopAccess. 6-16pt.4
08Setting ModeSystemForced printing of user name872812Font color setting00-1SYSNormally this setting is made in TopAccess. 0: Black 1: Gray4
08Setting ModeSystemForced printing of user name872813Density setting of light font color4010-90SYSSets the density when the font color is set to gray.4
08Setting ModeSystemForced printing of user name8729Prefix settingPrinted by-SYSNormally this setting is made in TopAccess. Maximum 64 characters.11
08Setting ModeSystemForced printing of user name8730Suffix setting--SYSNormally this setting is made in TopAccess. Maximum 64 characters.11
08Setting ModeSystemScanning8735Sending setting of ScanToURL00-1SYS0: Disabled 1: Enabled1
08Setting ModeSystemScanning8736Maximum size for ScanToURL attachment50-100SYSSets the maximum size of attachment that can be sent with ScanToURL.
0: Always sends URL
1-100: Maximum size (MB)
08Setting ModeSystemUser interfaceScreen setting8738E-mail address direct input button10-1SYSSwitches the display setting of the [INPUT @] button. 0: Not displayed
1: Displayed
08Setting modeSystemUser interfaceScreen setting8744Switchover of pop-up display during scanning10-1SYSSwitches the pop-up display during scanning 0: Not displayed
1: Displayed
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface8745Enable/Disable setting of EWB history00-1SYSSets whether part of the cookie, password, and form data of user who logs in to EWB is saved or not.
08Setting modeSystemUser interface8746Port number setting of destination 10 for sending trap1621-65535NICSets the port number of destination 10 for sending SNMP trap. If the port is used when using the real time log notification function, change the port number.12
08Setting ModeSystemUser interface8748Input of department
code at user authentication
00-1SYS0: Not required
1: Required
08Setting ModeSystemNetwork8749User authentication by logon information to domain (external authentication)00-1SYS0: Disabled
08Setting ModeSystemUser interface8754Error sheet output at reception of non- supported PDL10-1SYS0: Error sheet is not output 1: Error sheet is output1
08Setting ModeSystemMaintenan ceNotification of
remaining amount of toner
8755Enable/Disable setting00-1SYS0: Disabled
87560Remaining amount at first notification250-100SYS0 to 100%4
87561Notification interval101-25SYS1 to 25%4
08Setting ModeSystemUser interfaceCard reading device8758Overwriting of login at authentication00-1SYSSwitches the enable/disable setting for the function to overwrite the login information at the card authentication.
08Setting ModeSystemGeneral8761Retention of print (spooling) data00-1SYSUse this code to retain and obtain the print data (spooling data) if problem occurs. After obtaining the data, be sure to disable the setting.
0: Disabled (print data is deleted) 1: Enabled (print data is retained)
08Setting ModeSystemMaintenan ceDisplay of remaining amount of toner (for RDMS/MMDT)87620K00-100SYS0 to 100%14
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork8771Account setting for access to Home Directory00-1SYS0: Setting of Remote1 is used
1: Setting of Remote1 and Remote2 is used
08Setting modeSystemNetwork8774Password authentication for print job00-1SYSSets whether the user authentication for network printing/FAX/InternetFAX using the user information and password input on the printer driver is enabled or disabled. When this setting is enabled, the setting of 08-8749 is automatically disabled.
08Setting modeSystemNetworkPIN code8775PIN code authentication setting at user authentication00-2SYS0: Disabled
1: PIN code
2: Card+PIN code
08Setting modeSystemNetworkPIN code8776Logging setting of PIN code00-1SYS0: Disabled
08Setting modeSystemNetworkPIN code8777Attribute value setting of LDAP PIN
authentication server 1
eBMUse rPIN-SYSAttribute name of PIN code11
08Setting modeSystemNetworkPIN code8778Attribute value setting of LDAP PIN
authentication server 2
08Setting modeSystemNetworkPIN code8779Attribute value setting of LDAP PIN
authentication server 3
08Setting modeSystemNetworkPIN code8780Prioritized authentication server11-3SYSSets the prioritized authentication server to be searched.1
08Setting modeSystemUser interfaceDisplay setting8781Default setting of print screen when USB is inserted00-1SYS0: Disabled (The setting of 08-9236 is used) 1: USB print screen1
08Setting modeSystemGeneralInterval settingTransition to Super Sleep8782For fax1515-600SYSSets the interval to shift to Super Sleep again after recovery from Super Sleep. (Unit: seconds)1
08Setting modeSystemGeneral8783Switchover of document sorting order of e-Filing Box10-1SYS0: Sorted by saved date
1: Sorted by document name
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface8785Display/Non-display of pop-up for card authenticationRefer to contents0-1SYSSets whether the pop-up is displayed or not after the success of card authentication. This code is effective when the value of 08-8727 is "1" (Enabled).
0: Does not display pop-up 1: Displays pop-up
<Default value> JPD: 0
Others: 1
08Setting modeSystemUser interfaceDefault keyboard setting87860Japanese30-4SYSSets the default keyboard for inputting user name. 0: Romaji 1: Hiragana 2: Katakana (one-byte) 3:
Alphabetical character (one-byte) 4: Symbol (one-byte)
08Setting modeSystemUser interfaceDefault keyboard setting87861Chinese00-2SYSSets the default keyboard for inputting user name. 0: Alphabetical character (one-byte) 1: Pinyin 2: Symbol (one-byte)4
08Setting ModeSystemNetwork8788Detection interval when authentication server is down601-1440SSDKSets the interval to access the authentication server again after the detection of server down.
1-1440 (min.)
08Setting modeSystemUser interface8789Display/Non-display of pop-up for automatic output of jobs00-1SYSSets whether the pop-up is displayed or not when jobs are automatically released after user authentication. This code is effective when the value of 08-8915 is "1" (Enabled).
0: Pop-up is not displayed 1: Pop-up is displayed
08Setting ModeSystemNetwork8790Switchover of server when authentication server is down00-1SSDKEnables/disables the function that switches the access to another authentication server when it is detected that the authentication server is down.
08Setting ModeSystemNetwork8791Transition to sleep mode after printing10-1SYSThis code sets whether the equipment shifts to the sleep mode again immediately after completion of printing when the equipment recovers from the super- sleep mode for network printing.
08Setting ModeSystemNetwork8792Format of host name used for Scan To URL00-2SYS0: IP address
1: Host name (FQDN) 2: NetBIOS name
