Toshiba e-STUDIO 307/357/457/507 Service Manual Part 8
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop setting in ready status (Side thermistor)21213The fourth dropRefer to contents0~10MThis code is valid only when "20" is set to 08-2135. Setting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO206L/256/306: 4
e-STUDIO356/456/506: 0
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Center thermistor)21330The first drop1510~60MThis code is valid only when "20" is set to 08-2135. Setting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Center thermistor)21331The second drop1510~60MThis code is valid only when "20" is set to 08-2135. Setting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Center thermistor)21332The third drop1510~60MThis code is valid only when "20" is set to 08-2135. Setting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Center thermistor)21333The fourth drop1510~60MThis code is valid only when "20" is set to 08-2135. Setting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Side thermistor)21340The first drop1510~60MThis code is valid only when "20" is set to 08-2135. Setting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Side thermistor)21341The second drop1510~60MThis code is valid only when "20" is set to 08-2135. Setting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Side thermistor)21342The third drop1510~60MThis code is valid only when "20" is set to 08-2135. Setting value x 1 min.: from 10 to 60 min. later4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Side thermistor)21343The fourth drop1510~60MThis code is valid only when "20" is set to 08-2135. Setting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuser2135Temperature drop control setting in ready status (Temperature/Time)20~20M0: None 1: Pattern 1 2: Pattern 2 3: Pattern 3 4:
Pattern 4 5: Pattern 5 6: Pattern 6 7: Pattern 7 8:
Pattern 8 9: Pattern 9 10: Pattern 10 11: Pattern 11
12: Pattern 12 13: Pattern 13 14: Pattern 14 15:
Pattern 15 16: Pattern 16 17: Pattern 17 18: Pattern
18 19: Pattern 19 20: Manual adjustment
08Setting modeProcessFuser2140Fuser roller temperature during printing(Side thermistor/Plain paper)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
C 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10: 190°C 11:
195°C 12: 200°C 13: 205°C 14: 210°C
<Default value>
e-STUDIO206L/256/306: 8
e-STUDIO356/456/506: 10
08Setting modeProcessFuser2141Fuser roller temperature during printing(Side thermistor/Thick paper 1)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuser2142Fuser roller temperature during printing(Side thermistor/Thick paper 2)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuser2143Fuser roller temperature during printing(Side thermistor/OHP film)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop setting during printing (Center thermistor)21900The first dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
This code is valid only when "20" is set to 08-2214-0.
<Default value>
e-STUDIO206L/256/306: 1
08Setting modeProcessFuserTemperature drop setting during printing (Center thermistor)21901The second drop20~10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop setting during printing (Center thermistor)21902The third dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO206L/256/306: 2
e-STUDIO356/456/506: 3
08Setting modeProcessFuserTemperature drop setting during printing (Center thermistor)21903The fourth drop30~10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop setting during printing (Side thermistor)21910The first dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO356/456/506: 4
08Setting modeProcessFuserTemperature drop setting during printing (Side thermistor)21911The second dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO206L/256/306: 3
e-STUDIO356/456/506: 6
08Setting modeProcessFuserTemperature drop setting during printing (Side thermistor)21912The third dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop setting during printing (Side thermistor)21913The fourth dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO206L/256/306: 5
08Setting modeProcessFuser2192Fuser roller temperature during printing(Side thermistor/Thick paper 3)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuser2194Fuser roller temperature during printing(Center thermistor/Envelope)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
e-STUDIO206L/256/306: 11
e-STUDIO356/456/506: 13
08Setting modeProcessFuser2195Fuser roller temperature during printing(Side thermistor/Envelope)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
e-STUDIO206L/256/306: 9
e-STUDIO356/456/506: 11
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Center thermistor)21980The first dropRefer to contents0~200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
e-STUDIO206L/256/306: 20
e-STUDIO356/456/506: 5
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Center thermistor)21981The second dropRefer to contents0~200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
e-STUDIO206L/256/306: 30
e-STUDIO356/456/506: 18
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Center thermistor)21982The third dropRefer to contents0~200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
e-STUDIO206L/256/306: 40
e-STUDIO356/456/506: 24
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Center thermistor)21983The fourth drop750~200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.4
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Side thermistor)21990The first dropRefer to contents0~200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Side thermistor)21991The second dropRefer to contents0~200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Side thermistor)21992The third dropRefer to contents0~200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Side thermistor)21993The fourth drop750~200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.4
08Setting modeProcessFuserDropping temperature setting when printing on thick paper22000First dropRefer to contents0~10MSetting value x 5°C: 0 to 50°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserDropping temperature setting when printing on thick paper22001Second drop20~10MSetting value x 5°C: 0 to 50°C
08Setting modeProcessFuserDropping temperature setting when printing on thick paper22002Third dropRefer to contents0~10MSetting value x 5°C: 0 to 50°C
<Default value>
08Setting modeProcessFuserDropping temperature setting when printing on thick paper22003Fourth drop30~10MSetting value x 5°C: 0 to 50°C
08Setting modeProcessFuserTemperature drop setting during printing on thick paper (Side thermistor)22010The first dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing on thick paper (Side thermistor)22011The second dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing on thick paper (Side thermistor)22012The third dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing on thick paper (Side thermistor)22013The fourth dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingProcessFuserTemperature control22050Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (PlaincontentsC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
paper/Normal185°C 12: 120°C
temperature)<Default value>
e-STUDIO206L/256/306: 7
e-STUDIO356/456/506: 8
08SettingProcessFuserTemperature control22051Side thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
paper/at ordinary185°C 12: 120°C
08SettingProcessFuserTemperature control22060Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
paper/Low185°C 12: 120°C
08SettingProcessFuserTemperature control22061Side thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
e-STUDIO356/456/506: 7
08SettingProcessFuserTemperature control22070Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (OHP film)contentsC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
185°C 12: 120°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingProcessFuserTemperature control22071Side thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
185°C 12: 120°C
<Default value>
e-STUDIO206L/256/306: 6
08SettingProcessFuserTemperature control22080Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (ThickcontentsC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
paper 1)185°C 12: 120°C
<Default value>
08SettingProcessFuserTemperature control22081Side thermistor60~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (ThickC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
08SettingProcessFuserTemperature control22090Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
paper 2)185°C 12: 120°C
<Default value>
08SettingProcessFuserTemperature control22091Side thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
<Default value>
08SettingProcessFuserTemperature control22100Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
paper 3)185°C 12: 120°C
<Default value>
e-STUDIO206L/256/306: 10
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature control lower limit (Thick paper 3)22101Side thermistorRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
185°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature control lower limit (Envelope)22110Center thermistorRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
185°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature control lower limit (Envelope)22111Side thermistorRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
185°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing (Center thermistor)22120The first dropRefer to contents0~200MSetting value x 5 sec.: from 0 to 1,000 sec. later
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing (Center thermistor)22121The second dropRefer to contents0~200MSetting value x 5 sec.: from 0 to 1,000 sec. later
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing (Center thermistor)22122The third dropRefer to contents0~200MSetting value x 5 sec.: from 0 to 1,000 sec. later
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop switching time setting during printing (Center thermistor)22123The fourth drop750~200MSetting value x 5 sec.: from 0 to 1,000 sec. later
08Setting modeProcessFuserTemperature drop switching time setting during printing (Side thermistor)22130The first dropRefer to contents0~200MSetting value x 5 sec.: from 0 to 1,000 sec. later
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing (Side thermistor)22131The second dropRefer to contents0~200MSetting value x 5 sec.: from 0 to 1,000 sec. later
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing (Side thermistor)22132The third dropRefer to contents0~200MSetting value x 5 sec.: from 0 to 1,000 sec. later
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing (Side thermistor)22133The fourth drop750~200MSetting value x 5 sec.: from 0 to 1,000 sec. later
08Setting modeProcessFuser22140Temperature drop control setting during printing(Temperature/ Time)Refer to contents0~20M0: None 1: Pattern 1 2: Pattern 2 3: Pattern 3 4: Pattern
4 5: Pattern 5 6: Pattern 6 7: Pattern 7 8: Pattern 8 9:
Pattern 9 10: Pattern 10 11: Pattern 11 12: Pattern 12
13: Pattern 13 14: Pattern 14 15: Pattern 15 16: Pattern
16 17: Pattern 17 18: Pattern 18 19: Pattern 19 20: Manual adjustment
<Default value>
e-STUDIO356/456/506: 20
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser22141Temperature drop control setting during printing(Temperature/ Time)Refer to contents0~20M0: None 1: Pattern 1 2: Pattern 2 3: Pattern 3 4: Pattern
<Default value>
08Setting modeProcessFuserEnergy Saving ModeFuser roller temperature2250Side thermistor00~13M0: OFF 1: 40°C 2: 50°C 3: 60°C 4: 70°C 5: 80°C
6: 90°C 7: 100°C 8: 110°C 9: 120°C 10: 130°C
11: 140°C 12: 150°C 13: 160°C
1Yes
08Setting modeProcessFuser2282Pre-running time for first printing(Envelope)100~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5 sec.
6: 6 sec. 7: 7 sec. 8: 8 sec. 9: 9 sec. 10: 10 sec. 11: 12
sec. 12: 14 sec. 13: 16 sec. 14: 18 sec. 15: 20 sec.
08Setting modeProcessDeveloper2827Developer bias AC control ON/OFF10~2M0: ON 1: ON-OFF 2: OFF1
08Setting modeProcessProcess2835Switching of recycled toner saving control00~1M0: Switched 1: Not switched1
08Setting modeProcessProcess2837Correction by temperature/humidity00~3MSets the correction by temperature/humidity. 0: All valid
1: All invalid
2: Valid only in autotoner sensor
3: All valid except transfer and separation
08Setting modeProcessProcess2847Life correction switching of drum reverse rotation amountRefer to contents0~30MSet value x 4 msec. = Drum rotation time e-STUDIO206L/256/306:
0: No correction
1 to 30: Corrected (4 to 120 msec.: approx. 0.5 to 16mm)
0: No correction
1 to 30: Corrected (4 to 120 msec.: approx. 0.8 to 25mm)
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessProcess2848Life correction switching of normal rotation amount after drum reverse rotationRefer to contents0~30MSet value x 4 msec. = Drum rotation time e-STUDIO206L/256/306:
0: No correction
0: No correction
<Default value>
e-STUDIO206L/256/306: 14
e-STUDIO356/456/506: 9
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (Normal)29200PRT1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (Normal)29202PPC1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (Text)29203PPC1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (Photo)29204PPC1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(FAX)29206FAX1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (hardcopy security printing)29207PRT1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(Text/Photo/ OHP film)29210PRT1080~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(Text/Photo/ OHP film)29212PPC1080~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(Text/OHP film)29213PPC1080~255MCorrects the value of the developer bias adjustment (05-2020).4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(Photo/OHP film)29214PPC1080~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloper2922Developer bias Hi2 correction1240~255MCorrects the value of the developer bias adjustment (05-2020).1
08Setting modeProcessChargerMain charger bias correction (Normal)29260PRT1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (Normal)29262PPC1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (Text)29263PPC1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (Photo)29264PPC1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (FAX)29266PPC1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (hardcopy security printing)29267PRT1280~ 255MCorrects the value of the main charger bias adjustment (05-2040).4
08Setting modeProcessTransfer29280Transfer transformer DC correction (H)1280~255MCorrects the value of the transfer transformer DC output adjustment (05-2052).4
08Setting modeProcessTransfer29281Transfer transformer DC correction (C)1280~255MCorrects the value of the transfer transformer DC output adjustment (05-2052).4
08Setting modeProcessTransfer29282Transfer transformer DC correction (L)Refer to contents0~255MCorrects the value of the transfer transformer DC output adjustment (05-2052).
<Default value>
e-STUDIO206L/256/306: 112
e-STUDIO356/456/506: 108
08Setting modeProcessTransfer29290Thick 1 transfer correction (H)1280~255MThe output value of the transfer bias at the leading edge of paper is corrected.4
08Setting modeProcessTransfer29291Thick 1 transfer correction (C)1280~255MThe output value of the transfer bias at the center of the paper is corrected.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransfer29292Thick 1 transfer correction (L)Refer to contents0~255MThe output value of the transfer bias at the trailing edge of paper is corrected.
<Default value>
e-STUDIO206L/256/306: 128
e-STUDIO356/456/506: 120
08Setting modeProcessTransfer29300Thick 2 transfer correction (H)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
e-STUDIO206L/256/306: 131
e-STUDIO356/456/506: 138
08Setting modeProcessTransfer29301Thick 2 transfer correction (C)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
08Setting modeProcessTransfer29302Thick 2 transfer correction (L)Refer to contents0~255MThe output value of the transfer bias at the trailing edge of paper is corrected.
<Default value>
e-STUDIO206L/256/306: 122
08Setting modeProcessTransfer29320OHP film transfer correction (H)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
e-STUDIO206L/256/306: 106
e-STUDIO356/456/506: 118
08Setting modeProcessTransfer29321OHP film transfer correction (C)Refer to contents0~255MThe output value of the transfer bias at the center of the paper is corrected.
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransfer29322OHP film transfer correction (L)Refer to contents0~255MThe output value of the transfer bias at the trailing edge of paper is corrected.
<Default value>
e-STUDIO206L/256/306: 114
e-STUDIO356/456/506: 110
08Setting modeProcessTransfer29330Envelope transfer correction (H)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
e-STUDIO206L/256/306: 133
e-STUDIO356/456/506: 140
08Setting modeProcessTransfer29331Envelope transfer correction (C)Refer to contents0~255MThe output value of the transfer bias at the center of the paper is corrected.
<Default value>
08Setting modeProcessTransfer29332Envelope transfer correction (L)Refer to contents0~255MThe output value of the transfer bias at the trailing edge of paper is corrected.
<Default value>
e-STUDIO206L/256/306: 132
e-STUDIO356/456/506: 136
08Setting modeProcessSeparation29340Separation
1280~255MCorrects the value of the separation transformer DC output adjustment (05-2078).4
08Setting modeProcessSeparation29341Separation transformer DC correction (H)Refer to contents0~255MCorrects the value of the separation transformer DC output adjustment (05-2078).
<Default value>
e-STUDIO206L/256/306: 118
e-STUDIO356/456/506: 121
08Setting modeProcessSeparation29342Separation transformer DC correction (L)Refer to contents0~255MCorrects the value of the separation transformer DC output adjustment (05-2078).
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessSeparation29350Separation correction value at Duplex printing (H)1280~255M4
08Setting modeProcessSeparation29351Separation correction value at Duplex printing (C)1280~255M4
08Setting modeProcessSeparation29352Separation correction value at Duplex printing (L)1280~255M4
08Setting modeProcessSeparation29360Separation correction value for transparencies (H)1280~255M4
08Setting modeProcessSeparation29361Separation correction value for transparencies (C)1280~255M4
08Setting modeProcessSeparation29362Separation correction value for transparencies (L)1280~255M4
08Setting modeProcessLaserLaser power correction (Normal)29400PRT1280~255MCorrects the value of the laser power adjustment (05- 2250).4
correction (Text/Photo)
29402PPC1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessLaserLaser power correction (Text)29403PPC1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessLaserLaser power correction (Photo)29404PPC1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessLaserLaser power correction (FAX)29406PPC1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessProcessLaser output correction (hardcopy security printing)29407PRT1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessTransfer29610Thick 3 transfer correction (H)Refer to contents0~255M<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransfer29611Thick 3 transfer correction (C)Refer to contents0~255M<Default value>
08Setting modeProcessTransfer29612Thick 3 transfer correction (L)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 116
08Setting modeProcessTransfer296202-sided thick paper transfer correction (H)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 126
e-STUDIO356/456/506: 123
08Setting modeProcessTransfer296212-sided thick paper transfer correction (C)Refer to contents0~255M<Default value>
08Setting modeProcessTransfer296222-sided thick paper transfer correction (L)Refer to contents0~255M<Default value>
e-STUDIO356/456/506: 112
08Setting modeProcessTransfer29630Thin paper transfer leading edge output correction (H)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 100
e-STUDIO356/456/506: 88
08Setting modeProcessTransfer29631Thin paper transfer center output correction (C)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 104
e-STUDIO356/456/506: 92
08Setting modeProcessTransfer29632Thin paper transfer trailing edge output correction (L)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 120
08Setting modeProcessSeparation29660Thin paper separation leading edge output correction (H)1410~255M4
08Setting modeProcessSeparation29661Thin paper separation center output correction (C)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 151
e-STUDIO356/456/506: 148
08Setting modeProcessSeparation29662Thin paper separation trailing edge output correction (L)Refer to contents0~255M<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessDeveloper2978Switching of correction of development contrast life40-8MAdjusts the density of the image. The smaller the corrected amount is, the darker the image becomes. 0 to 5: Starts correction when the developer counter counts 5k sheets.
6 to 8: Starts correction when the developer counter counts 10k sheets.
If the developer counter does not reach the values above, the density does not change even if the setting value is altered.
Corrected amount for 08-2978 0: -65
1: ±0
2: -22
3: -43
4: -85
5: -105
6: -65 (correction starts from 10k sheets) 7: -43 (correction starts from 10k sheets) 8: -85 (correction starts from 10k sheets) (Unit: V)
  • Be sure to check the image after the change.
  • The changed setting value is taken over after the replacement of the process unit or the developer material.
08Setting modeProcessProcess2987Transfer bias output correction between sheets of paperRefer to contents0~255MThe transfer cleaning bias is output between sheets of paper during printing so as to prevent the toner on the photoconductive drum from adhering to the transfer roller. This code is used to correct the output between sheets of paper to that adjusted in 05-2084 (Transfer cleaning bias adjustment (negative)). The larger the setting value is, the higher the value of the current (more negative) is. Note that toner with a different polarity will adhere easily if the setting value is too large or too small.
<Default value>
e-STUDIO206L/256/306: 110
e-STUDIO356/456/506: 104
08Setting modeScannerScanner3015Pre-scan setting switchover00~1SYS0: Not performing pre-scanning 1: Performing pre- scanning1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeScannerRADF3021Set for switchback- mixed size copy00~1SYSThis setting is whether the original length is detected or not by transporting without scanning in reverse when A4-R/FOLIO paper or LT-R/LG paper is detected in a mixed-size copying.
0: Disabled - AMS:
A series - Judges as A4-R without transporting in reverse with no scanning.
LT series - Judges whether it is LT-R or LG by its length
without transporting in reverse with no scanning. APS:
A series - Judges whether it is A4-R or FOLIO without transporting in reverse with no scanning.
LT series - Judges whether it is LT-R or LG without transporting in reverse with no scanning.
1: Enable 1 AMS:
A series - Judges whether it is A4-R or FOLIO by transporting without scanning in reverse to detect its length.
LT series - Judges whether it is LT-R or LG by transporting
without scanning in reverse to detect its length. APS:
The same as that of APS in 0: Disabled.
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemUser interfaceCard reader3500Device setting00-
429496729
SYSTo enable the e-Bridge ID Gate, a card reading device should be set in the order of "ABYYZZZZ". (Enter the corresponding values to "A", "B", "YY" and "ZZZZ".)
  • AB: Special setting
    • A: Debugging NIC 0: Not used 1: Used
    • B: Interface
  • YY: Authentication
  • ZZZZ: Sub-code (Specifies the usage type of card ID) 0000: No authentication using card
0: USB connection 1: Serial connection (KP-2003 only)
00: No authentication using card 03: Mifare (KP-2005 only)
04: HID (KP-2004 only)
06: KB Emulation I/F Reader
07: 3Track Magnetic Swipe Reader 09: 2Track Magnetic Swipe Reader
0001: IDm (Felica/NFC-Felica) and (or) UID (Mifare/NFC-Mifare)
0002: Data (Felica/NFC-Felica/Mifare/NFC-Mifare)
0003: SSFC mode
5Yes
08Setting ModeSystemUser interfaceCard reader3501Format information 100-
429496729
SYSTo access the data in the noncontact IC card, the Key Information "LLLL" and the Sector Number "MMMM" should be set. The "LLLL" should be set first, and then "MMMM".
<KP-2005>
LLLL: Key information
MMMM: Sector number (hexadecimal number)
5Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemUser interfaceCard reader3502Format information 200-
429496729
SYSThe data of the block number in the noncontact IC is set.
<KP-2005>
RRBSEbse (hexadecimal number) RR: 00 (Fixed)
B: 1st area block number
S: 1st area beginning byte offset E: 1st area ending byte offset
b: 2nd area block number
s: 2nd area beginning byte offset e: 2nd area ending byte offset
* If the 2nd block/area is not used, set the SSTU to "FFFF" (hexadecimal number), the bse to"FFF" (hexadecimal number).
5Yes
08Setting ModeSystemUser interfaceCard reader3503Format information 300-
0xFFFFFF FFFFFFFF FF
SYSSecurity key "KKKKKKKKKKKK" (12 digits)
<hexadecimal number> in the [Key Information] of the [Sector Number] set in the code 08-3501 should be entered.
5Yes
08Setting modeSystemUser interfaceCard reader3504Card authentication LDAP server00~100SYSLDAP server number for the card authentication when a non-contact IC card is used should be set.1
08Setting modeSystemGeneral3612Date of unpacking-13 digitsSYSYear/month/date/day/hour/minute/second Example: 03 07 0 13 13 27 48
"Day" - "0" is for "Sunday". Proceeds Monday through Saturday from "1" to "6".
11Yes
08Setting modeSystemGeneral3615List print USB storage setting00~1SYS0: Enable (USB storage available)
1: Disable (USB storage not available)
08Setting modeSystemGeneral3619Clearing of service history list file--SYSInitializes the service history list file.3
08Setting modeSystemGeneral3623Job filtering setting for real time log notification function00-65535SYSChanges target type of job for notification in real time log notification function.1
08Setting modeSystemGeneral3624Log item filtering setting for real time log notification function2147483
921
0~4294967
295
SYSChanges target log items for notification in real time log notification function.5
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneralReal time log notification function3626Department information transmission setting of real time log notification function00-1SYSSets whether the department information (number, name, code) is transmitted or not in the real time log notification function.
0: Department number, department name, department code
1: Department number, department name
08Setting modeSystemGeneral3628Enable/Disable setting of standard data overwrite function10-1SYS0: Disabled
* This code is valid for the following model or destination:
- e-STUDIO256SE/306SE/356SE/456SE/506SE
08Setting modeSystemGeneral3629Enable/Disable setting of standard EWB function10-1SYS0: Disabled
- e-STUDIO206L/256/306/356/456/506 for MJD
08Setting modeSystemNetwork3631Remote Access (SNMP)10-1SYS0: Disabled
08Setting modeSystemUser interface3635Trial copy function10~1SYS0: Invalid 1: Valid1
08Setting modeSystemNetworkInternetFax3637Addition of transmission header00-1SYS0: Disabled 1: Enabled1
08Setting modeSystemNetworkInternetFax3638Addition of receiving record00-1SYS0: Disabled 1: Enabled1
08Setting modeSystemNetworkInternetFax3639Adding method of transmission header11-2SYS1: Overwriting inside the image (5 mm from the top) 2: Adding outside the image (5 mm from the top)1
08Setting modeSystemGeneral3644Login restriction for reissued card00-1SYS0: Disabled 1: Enabled1
08Setting modeSystemNetwork3702Device name for device authenticationMFP's
serial number
--Maximum 128 letters
"MFP's serial number" is set as default. Perform 08- 9083 to set the default value.
08Setting modeSystemNetwork3704PDC (Primary Domain Controller) name 2 for user authentication--UTYUp to 128 letters12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork3705BDC (Backup Domain Controller) name 2 for user authentication--UTYUp to 128 letters12
08Setting modeSystemNetwork3706PDC (Primary Domain Controller) name 3 for user authentication--UTYUp to 128 letters12
08Setting modeSystemNetwork3707BDC (Backup Domain Controller) name 3 for user authentication--UTYUp to 128 letters12
08Setting modeSystemNetwork3719Windows domain No.
2 of user authentication
--UTYMaximum 128 letters12
08Setting modeSystemNetwork3720Windows domain No.
3 of user authentication
08Setting modeSystemNetwork3721AppleTalk Device NameMFP's
serial number
--Maximum 32 letters
08Setting modeSystemNetwork3722PDC/BDC timeout value of Windows Domain Authentication (Unit: Seconds)601~180NICApplied to the device authentication12
08Setting modeSystemNetwork3723User authentication PDC/BDC time-out period (Unit: Seconds)301~180NICApplied to the user authentication12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork3724Windows Domain Authentication method of Windows Domain/User Authentication11-4NICSets the Windows domain authentication method for device authentication, Scan to SMB, and user authentication. When the setting of the domain authentication method is unknown, it's strongly recommended to set the value of this code to "1" (Auto).
1: Auto 2: Kerberos 3: NTLMv2 4: NTLMv1
* Note that the internal processing is different between user authentication and Windows logon authentication/Scan to SMB as follows.
  • User authentication
  • Windows logon authentication/Scan to SMB "1" (Auto): Auto (Kerberos -> NTLMv1)
"1" (Auto): Auto (Kerberos -> NTLMv2) "4" (NTLMv1): NTLMv2
"4" (NTLMv1): NTLMv1
08Setting modeSystemNetwork3725IPP max connection161~16NIC12
08Setting modeSystemNetwork3726IPP active connection101~16NIC12
08Setting modeSystemNetwork3727LPD max connection101~16NIC12
08Setting modeSystemNetwork3728LPD active connection101~16NIC12
08Setting modeSystemNetwork3729ATalk PS max Connection101~16NIC12
08Setting modeSystemNetwork3730ATalk PS active Connection101~16NIC12
08Setting modeSystemNetwork3731Raw TCP max Connection101~16NIC12
08Setting modeSystemNetwork3732Raw TCP active connection101~16NIC12
08Setting modeSystemNetwork3736DNS Client Time Out51~180NICUse when a timeout occurred at DNS client connection12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork3739FTP Client Time Out (SCAN)301~180NICUse when a timeout occurred at FTP client connection12
08Setting modeSystemNetwork3743LDAP Client Time Out51~180NICUse when a timeout occurred at LDAP client connection12
08Setting modeSystemNetwork3754Switching DPWS Printer setting11~2NICDPWS printer /DPWS secure printer function is switched.
1: Enabled 2: Disabled
08Setting modeSystemNetwork3755Switching DPWS Scanner setting11~2NICDPWS scanner function is switched. 1: Enabled 2: Disabled12
08Setting modeSystemNetwork3757DPWS Discovery Port Number37021~65535NICPort number used for DPWS Discovery12
08Setting modeSystemNetwork3758DPWS Metadata
Exchange Port Number
500811~65535NICPort number used for DPWS Metadata Exchange12
08Setting modeSystemNetwork3759DPWS Print Port Number500821~65535NICPort number used for DPWS Print12
08Setting modeSystemNetwork3760DPWS Scan Port Number500831~65535NICPort number used for DPWS Scan12
08Setting modeSystemNetwork3765DPWS Print Max
numbers of connection
101~20NICMaximum numbers received from more than one connection request in the DPWS print12
08Setting modeSystemNetwork3766DPWS Print Max numbers of reception101~20NICMaximum numbers of data received from more than one clients in the DPWS print12
08Setting modeSystemNetwork3767Switching IPv6 setting21~2NICIPv6 function is switched. 1: Enabled 2: Disabled12
08Setting modeSystemNetworkIPv63768Switching IP(IPv6) Address Acquisition21~3NICIP(IPv6) Address Acquisition setting is switched. 1: Manual
2: Stateless
3: Stateful
08Setting modeSystemNetworkIPv63770IPv6 Address---Displays IPv6 address. Maximum 40 characters (byte).12
08Setting modeSystemNetworkIPv63771Prefix display setting---Sets the length of the displayed prefix. Maximum 3 characters (byte).12
08Setting modeSystemNetworkIPv63772Default Gateway setting---Sets the default gateway for IPv6 address. Maximum 40 characters (byte).12
08Setting modeSystemNetwork3774DHCPv6 Option setting21~2NICDHCPv6 Option is switched when the Manual is set. 1: Enabled 2: Disabled12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork3777Stateless Address setting21~2NICIP Address is acquired by both Stateless and State full Address. 1: Enabled2: Disabled12
08Setting modeSystemNetwork3778Acquiring DHCPv6 Option21~2NICWhen Stateless Address is selected, an option is acquired from DHCPv6 server.
08Setting modeSystemNetwork3779Stateful Address setting11~2NICIP Address is acquired from DHCPv6 server. 1: Enabled 2: Disabled12
08Setting modeSystemNetwork3780Stateful Option setting11~2NICAn option is acquired from DHCPv6 server. 1: Enabled 2: Disabled12
08Setting modeSystemNetworkIPv63781Primary DNS Server Address Registration---Registration of Primary DNS Server Address. Maximum 40 characters (byte).12
08Setting modeSystemNetworkIPv63782Secondary DNS Server Address Registration(IPv6)---Registration of Secondary DNS Server Address. Maximum 40 characters (byte).12
08Setting modeSystemNetwork3793Switching LLTD setting11~2NICLLTD function is switched. 1: Enabled 2: Disabled12
08Setting modeSystemGeneral3802USB media direct printing Paper sizeRefer to contents0~13SYS0: ledger 1: legal 2: letter 3: computer 4: statement 5:
A3 6: A4 7: A5 9: B4 10: B5 11: Folio 12: Legal13" 13:
LetterSquare
<Default value> NAD: 2
Others: 6
08Setting modeSystemGeneral3803USB media direct
printing function setting
10~1SYSSets the USB media direct printing function.0: Disabled1: Enabled1
08Setting modeSystemScanner3805Department Management setting by Remote Scan30~3SYSDepartment Management is set when Remote Scan is performed.
0: w/o GUI OFF,w/ GUI OFF
1: w/o GUI ON,w/ GUI OFF
2: w/o GUI OFF,w/ GUI ON
3: w/o GUI ON,w/ GUI ON
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetworkDirect SMTP3810Communication setting00~1SYSWhen an Internet Fax is sent, Direct SMTP communication is set.
When "0: Disabled" is set, an Internet Fax is sent using an SMTP server.
When "1: Enabled" is set, direct SMTP communication is enabled and an Internet Fax is sent to MFPs on the intranet without using an SMTP server.
Since no SMTP server is used, the SSL encryption and SMTPAUTH function cannot be used for internet Fax transmission.
If "1: Enabled" is set in 08-3810, set "1: Enabled" in 08-
3812 as well.
1Yes
08Setting modeSystemNetworkDirect SMTP3811Image encrypting at the Direct SMTP00~1SYSWhen Direct SMTP communication is performed, an attached image is encrypted. 0: Disabled 1: Enabled1Yes
08Setting modeSystemNetworkInternet Fax3812Dummy full mode at I- Fax transmission00~1SYSWhen an Internet Fax is sent, the resolution ratio and the paper size of an attached image are set to the full mode.0: Disabled
1: Enabled If "1: Enabled" is set in 08-3810, set "1: Enabled" in 08-3812 as well.
1Yes
08Setting modeSystemScanner3815XPS file thumbnail addition10~1SYSThumbnail is added to the XPS file produced by the Scan function.
0: Not added 1: Only the top page added
08Setting modeSystemScanner3816XPS file paper size setting10~1SYSThe paper size of the XPS file produced by the Scan function is set.
0: Scanned image size 1: Standard size
08Setting modeSystemScanner3817PDF file version setting40~4SYSThe version of PDF file produced by the Scan function is set.
0: PDF V1.3 1: PDF V1.4 4: PDF V1.7
08Setting modeSystemGeneral3833Home directory function00~1SYSFunction to store a file in the user's home directory 0: Disabled 1: Enabled1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral3837Display switching for the machine name/computer name shown in the notification00~1SYSThe display method of the machine name/computer name shown in the event-related notification is switched.
0: IP address 1: NetBIOS name/FQDN
08Setting modeSystemGeneralLicense control3840Registration/Deletion---Registers electronic keys for setting related optional items (e.g. when the equipment is delivered). Returns the license file having the same ID as that in the one- time dongle. Displays all the electronic keys stored in a USB media connected to the equipment in a list.
Displays electronic keys registered in the equipment.
08Setting modeSystemOptionFAX3847FAX mistransmission prevention00~1SYSFAX mistransmission prevention function is switched. 0: OFF (Disabled) 1: ON (Enabled)1Yes
08Setting modeSystemOptionFAX3848Restriction on Address Book destination setting00~1SYSAvailability of destination selection from the Address Book is switched as one of FAX mistransmission prevention functions when setting FAX destinations. 0: OFF (Disabled) 1: ON (Enabled)1Yes
08Setting modeSystemOptionFAX3849Restriction on destination direct entry00~1SYSAvailability of direct entry is switched as one of FAX mistransmission prevention functions when setting FAX destinations. 0: OFF (Disabled )1: ON (Enabled)1Yes
08Setting modeSystemGeneral3851Template display00~1SYSThe order of displaying templates on the LCD screen is switched.
0: Order of IDs 1: Alphabetical order
08Setting modeSystemGeneral3852Automatic summer time changeRefer to contents0~1SYSAutomatic summer time change on the day previously set is switched.
<Default value> NAD/MJD: 1
Others: 0
08Setting modeSystemGeneral3853Summer time mode Offset value20~7SYSSummer time is started as follows when 08-3852 is enabled.
0: +2:00 1: +1:30 2: +1:00 3: +0:30 4: -0:30 5: -1:00
6: -1:30 7: -2:00
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral3854Summer time mode Starting monthRefer to contents1~12SYSThe month in which summer time is started is set.
1: January 2: February 3: March 4: April 5: May 6: June
7: July 8: August 9: September 10: October 11:
November 12: December
<Default value> NAD/MJD: 3
Others: 1
08Setting modeSystemGeneral3855Summer time mode Starting weekRefer to contents1~5SYSThe week in which summer time is started is set. 1: 1st 2: 2nd 3: 3rd 4: 4th 5: Last
MJD: 5
Others: 1
08Setting modeSystemGeneral3856Summer time mode Starting day00~6SYSThe day on which summer time is started is set. 0: Sunday1: Monday2: Tuesday3: Wednesday4: Thursday5: Friday6: Saturday1
08Setting modeSystemGeneral3857Summer time mode Starting timeRefer to contents00~23SYSThe time at which summer time is started is set. 00-23
<Default value> NAD/MJD: 2
Others: 0
08Setting modeSystemGeneral3858Summer time mode Starting minute000~59SYSThe minute at which summer time is started is set. 00-591
08Setting modeSystemGeneral3859Summer time mode Ending monthRefer to contents1~12SYSThe month in which summer time is ended is set.
<Default value> NAD: 11
MJD: 10
Others: 1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral3860Summer time mode Ending weekRefer to contents1~5SYSThe week in which summer time is ended is set. 1: 1st 2: 2nd 3: 3rd 4: 4th 5: Last
<Default value> MJD: 5
Other: 1
08Setting modeSystemGeneral3861Summer time mode Ending day00~6SYSThe day on which summer time is ended is set.
0: Sunday 1: Monday 2: Tuesday 3: Wednesday 4:
Thursday 5: Friday 6: Saturday
08Setting modeSystemGeneral3862Summer time mode Ending timeRefer to contents00~23SYSThe time at which summer time is ended is set. 00-23
MJD: 3
Others: 0
08Setting modeSystemGeneral3863Summer time mode Ending minute000~59SYSThe minute at which summer time is ended is set.00-591
08Setting modeSystemNetwork3864Disclosure of telnet function00~1SYS0: Not disclosed 1: Disclosed
When this value is set at "0", the value of code 08-3865 must be "2".
08Setting modeSystemNetwork3865Availability of Telnet Server21~2NICAvailability of Telnet Server is switched. 1: Enabled 2: Disabled12
08Setting modePrinterLaser4002Judged number of polygonal motor rotation error(Normal rotation)00~1MDisplays the error [CA10] when the set number of rotation error has been detected.
0: 2 times 1: 12 times
08Setting modePrinterLaser4003Judged number of polygonal motor rotation error(At acceleration/decelerat ion)00~1M0: Time taken from an overshoot occurring to normal value range is 0.6 sec.
1: Time taken from an overshoot occurring to normal value range is 2.2 sec.
08Setting modePrinterLaser4004Polygonal motor
rotation number on standby
50~5M0: 38,090.55 rpm 1: 35,000 rpm 2: 30,000 rpm 3:
25,000 rpm
4: 20,000 rpm 5: 10,000 rpm
08Setting modePrinterLaser4005Polygonal motor rotation in the energy saving mode00~1M0: Stopped 1: 10,000 rpm1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterLaser4009Setting of polygonal motor type30~3MSet the type of polygonal motor.
0: 2-clock type 1: 3-clock type 2: 4-clock type 3: 6-clock type
08Setting modePrinterPaper feedingDefault setting of paper sourcePPC401000~5SYS0: A4/LT 1: LCF 2: Upper drawer 3: Lower drawer 4: PFP upper drawer 5: PFP lower drawer1
08Setting modePrinterFeeding system/Pa per transportAutomatic change of paper sourceAuto4011PPC11~2SYSSets whether or not changing the drawer automatically to the other drawer with the paper of the same size when paper in the selected drawer has run out.
1: Changes to the drawer with the same paper direction and size: e.g., A4 to A4
2: Changes to the drawer with the same paper size. Paper with the different direction is acceptable as long as the size is the same: e.g., A4 to A4-R, LT-R to LT. “1”is applied when the staple/hole-punch is specified.
1Yes
08Setting modePrinterLaser4012Pre-running rotation of polygonal motor00~2SYSSets whether or not switching the polygonal motor from the standby rotation to the normal rotation when the original is set on the RADF or the original cover is opened.
0: Valid (when using RADF and the original is set manually)
1: Invalid
2: Valid (when using RADF only)
08Setting modePrinterLaser4013Polygonal motor rotational status switching at the Auto Clear Mode00~1SYSSets whether or not switching the polygonal motor from the normal rotation to the standby rotation at the Auto Clear Mode. 0: Valid 1: Invalid1
08Setting modePrinterLaser4014Rotational status of polygonal motor on standby10~1SYSSets the rotational status of polygonal motor on standby.
0: Rotated (The rotational speed is set at 08-4005.) 1: Stopped
08Setting modePrinterLaser4015Timing of auto- clearing of polygonal motor pre-running rotation30~6SYSSwitches the polygonal motor to the standby rotation when a certain period of time has passed from the pre- running. At this code, the period to switch the status to the standby rotation is set.
0: 15 sec. 1: 20 sec. 2: 25 sec. 3: 30 sec. 4: 35 sec. 5:
40 sec. 6: 45 sec.
* This setting is effective when “0” or “2” is set at 08- 4012.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transportAutomatic change of paper sourceWhen a drawer is specified40160PPC00~1SYSSets whether the automatic change of paper source is performed or not if the drawer is specified as the paper source and the paper in the specified drawer runs out when coping.
0: Does not change the paper source automatically 1: Changes the paper source automatically
4Yes
08Setting modePrinterFeeding system/Pa per transportAutomatic change of paper sourceWhen a drawer is specified40161Printing/BOX printing00~1SYSSets whether the automatic change of paper source is performed or not if the drawer is specified as the paper source and the paper in the specified drawer runs out when printing/BOX printing.
4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingUpper drawer40200Plain paper50~5MSets the number of times of the feeding retry from the upper drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingUpper drawer40201Others50~5MSets the number of times of the feeding retry from the upper drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingLower drawer40210Plain paper50~5MSets the number of times of the feeding retry from the lower drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingLower drawer40211Others50~5MSets the number of times of the feeding retry from the lower drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingPFP upper drawer40220Plain paper50~5MSets the number of times of the feeding retry from the PFP upper drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingPFP upper drawer40221Others50~5MSets the number of times of the feeding retry from the PFP upper drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingPFP lower drawer40230Plain paper50~5MSets the number of times of the feeding retry from the PFP lower drawer.4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingPFP lower drawer40231Others50~5MSets the number of times of the feeding retry from the PFP lower drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingbypass feed40240Plain paper50~5MSets the number of times of the feeding retry from the bypass tray.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingbypass feed40241Others50~5MSets the number of times of the feeding retry from the bypass tray.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingLCF40250Plain paper50~5MSets the number of times of the feeding retry from the LCF.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingLCF40251Others50~5MSets the number of times of the feeding retry from the LCF.4Yes
08Setting modePrinterFeeding system/Pa per transport4100Paper size for upper drawerRefer to contents0-255MPress the button on the LCD to select the size.
<Default value> EUR: A4
UC: LT JPN: A4
08Setting modePrinterFeeding system/Pa per transport4101Paper size for lower drawerRefer to contents0-255MPress the button on the LCD to select the size.
<Default value> EUR: A3
UC: LD JPN: A3
08Setting modePrinterFeeding system/Pa per transport4102Paper size for PFP upper drawerRefer to contents0-255MPress the button on the LCD to select the size.
<Default value> EUR: A4-R
UC: LT-R JPN: A4-R
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transport4103Paper size for PFP lower drawerRefer to contents0-255MPress the button on the LCD to select the size.
UC: LG JPN: B4
08Setting modePrinterFeeding system/Pa per transport4104Paper size setting
/LCF
UC: LT JPN: A4
08Setting modePrinterFeeding system/Pa per transport4105PFP/LCF installation00~4M0: Auto
1: PFP upper-drawer type installed
2: PFP upper-drawer and lower-drawer type installed 3: LCF installed
4: Neither PFP nor LCF installed
In the following case, set the value to "0" (Automatic) or change the value to the corresponding one.
  • When any of the above option is replaced
  • When any of the above option is installed while "4" (Not installed) has been set
08Setting modePrinterFeeding system/Pa per transport4106Paper size (A3) feeding/widthwise direction420/297182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4107Paper size (A4-R) feeding/widthwise direction297/210182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4108Paper size (A5-R) feeding/widthwise direction210/148182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4109Paper size (B4-R) feeding/widthwise direction364/257182~432/1
40~297
M10
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingPrinterFeeding4110Paper size (B5-R)257/182182~432/1M10
modesystem/Pafeeding/widthwise40~297
perdirection
transport
08SettingPrinterFeeding4111Paper size (LT-R)279/216182~432/1M10
perdirection
transport
08SettingPrinterFeeding4112Paper size (LD-R)432/279182~432/1M10
perdirection
transport
08SettingPrinterFeeding4113Paper size (LG-R)356/216182~432/1M10
perdirection
transport
08SettingPrinterFeeding4114Paper size (ST-R)216/140182~432/1M10
perdirection
transport
08SettingPrinterFeeding4115Paper size356/257182~432/1M10
modesystem/Pa(COMPUTER-R)40~297
perfeeding/widthwise
transportdirection
08SettingPrinterFeeding4116Paper size (FOLIO)330/210182~432/1M10
perdirection
transport
08SettingPrinterFeeding4117Paper size (13" LG-R)330/216182~432/1M10
perdirection
transport
08SettingPrinterFeeding4118Paper size (8.5"X8.5"-216/216182~432/1M10
modesystem/PaR) feeding/widthwise40~297
perdirection
transport
08SettingPrinterFeeding4119Paper size (Non-432/279148~432/1SYS10
modesystem/Pastandard)05~297
transportdirection
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transport4120Paper size (8K-R) feeding/widthwise direction390/270182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4121Paper size (16K-R) feeding/widthwise direction270/195182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4123Paper size (A6-R) feeding/widthwise direction148/105148~432/1
05~297
M10
08Setting modePrinterFeeding system/Pa per transport4124Paper size (#10- R)feeding/widthwise direction241/105148~432/1
05~297
M10
08Setting modePrinterFeeding system/Pa per transport4127Paper size (DL- R)feeding/widthwise direction220/110148~432/1
05~297
M10
08Setting modePrinterFeeding system/Pa per transport4131Feeding retry setting00~1M0: Enabled
1: Disabled
* When the value of 08-9016 is set to "5", the value of this code is automatically set to "1".
08Setting modePrinterFeeding system/Pa per transport4140Paper size for bypass feed2550-255SYSPress the button on the LCD to select the size.9
08Setting modePrinterFeeding system/Pa per transport4143Paper size (Envelope: Monarch- R)feeding/widthwise direction191/98148~432/9
8~297
M10
08Setting modePrinterFeeding system/Pa per transport4144Paper size (Envelope: CHO-3-
235/120148~432/1
05~297
M10
08Setting modePrinterFeeding system/Pa per transport4145Paper size (Envelope: YOU-4-
235/105148~432/1
05~297
M10
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transport4206Paper size (Postcard) feeding/widthwise direction148/100148~432/1
00~297
M* Postcard is supported only for JPN model.10
08Setting modePrinterFeeding system/Pa per transport4450Switching of paper pushing amount/lower drawer00~1MSwitches pushing process by the transport roller when paper loaded from the lower drawer starts to be transported from the registration section.
0: The paper is pushed until its trailing edge reaches the position where the 2nd transport sensor is turned OFF.
1: If the length of the paper is more than 297 mm, it is pushed by the transport roller for a specified time.
08Setting modePrinterFeeding system/Pa per transport4542Switching for incorrect size jam detection00~1M0: Enabled 1: Disabled1Yes
08Setting modePrinterFeeding system/Pa per transport4547Manual stapling time- out period153~30M3-30sec.(In increments of 1sec.)1
08Setting modePrinterFinisher4548Finisher model switching setting value00~1MSets the model of the finisher. 0: MJ-1032/1033/1101/1106
1: MJ-1032/1033/1101/1106
08Setting modePrinterGeneral4549Detection setting of new or old fuser unit00~1M0: Enabled 1: Disabled1
08Setting modePrinterGeneral4555Information check of
new or old EPU memory
652800 to 65535M65280 (0xFF00): New EPU 255 (0x00FF): Installed EPU2
08Setting modePrinterGeneral4556Detection setting of new or old EPU10~1M0: Disabled 1: Enabled1
08Setting modePrinterProcessConditions at the occurrence of fuser related error45700Center thermistor00-255MOutput value of thermistor4
08Setting modePrinterProcessConditions at the occurrence of fuser related error45701Side thermistor00-255MOutput value of thermistor4
08Setting modePrinterProcessConditions at the occurrence of fuser related error45702Edge thermistor00-255MOutput value of thermistor4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterProcessConditions at the occurrence of fuser related error45705Error counter00-255M1-3: Fusing error when warm-up-40-degrees C detected
4-10: Fusing error when warm-up-100-degrees C detected
11-25: Fusing error when ready from warm-up 50-55: Fusing error at ready
100-111: Fusing error at printing
150-153: Fusing error in the prewarming/JAM/cover open/adjustment mode
08Setting modePrinterGeneral4581SRAM Backup---The data in the SRAM is backed up in the EEPROM.3
08Setting modePrinterGeneral4582SRAM copy---The data in the EEPROM is copied to the SRAM.3
08Setting modePrinterFeeding system/Pa per transportBypass paper size detection setting4621PPC/PRT00~1MDetects whether the size of paper fed by bypass feeding is the same as the paper size set on the control panel. If the sizes are not the same, the warning message is displayed (Paper jam does not occur).
When the bypass paper size detection is broken, the equipment can be used without the size detection by disabling this setting. After repair, enable this setting. 0: Enabled 1: Disabled
08Setting modePrinterFeeding system/Pa per transportBypass paper size detection counter4622PPC/PRT00~65535MThis is a counter for bypass paper size detection setting. If the printing is executed with the paper size that differs from the paper size set on the control panel, the counter is counted up.1
08Setting modePrinterGeneral4675Paper ejection setting for wrong bypass
paper size
20-2M0 and 1: Disabled
2: Ejected
08Setting modePrinterCounter4676Ejection counter for wrong bypass paper
size
00~65535MNumber of ejection times1
08Setting modePrinterFeeding system/Pa per transport4691Switching of the display of jam location in the drawer when paper feed jam occurs10~1M0: Disabled
08Setting modePrinterFinisher4695Synchronous writing of the finisher adjustment value--MWrites the adjustment code from 05-4819 to 4827 in the SRAM of the finisher. (for MJ-1032 and MJ-1033)3
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFinisher4696Synchronous reading of the finisher adjustment value--MReads the adjustment code from 05-4819 to 4827 from the SRAM of the finisher. (for MJ-1032 and MJ-1033)3
08Setting modeProcessProcess50010Print job end cleaning bias polarity switching frequency00~9MIn the cleaning operation of the transfer roller at the end of printing, the cleaning bias, in which the polarity is switched from positive to negative, is output so that the toner adhering to the transfer roller is returned to the photoconductive drum. This code is used to set the cleaning bias switching frequency. Perform adjustment when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller. Note that the drum driving time will increase if the setting value of the cleaning bias switching frequency is too large. The setting code differs depending on the operation status of the equipment when there is any stain on the back side of the printed paper. Select the code from 5001 to 5003 according to the operation status. Set this code when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller in normal printing.
0: Once 1: Twice 2: Three times 3: Four times 4: Five
times 5: Six times 6: Seven times 7: Eight times 8: Nine times 9: Ten times
08Setting modeProcessProcess50011Print job end cleaning bias polarity switching frequency (Bypass non-standard)30~9MSet this code when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller in printing non-standard paper from the bypass tray.
08Setting modeProcessProcess50012Print job end cleaning bias polarity switching frequency (Mass printing of small size paper)30~9MSet this code when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller in printing maximum size paper after printing a large amount of small size paper (1 to 9).
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessProcess5002Job end cleaning bias polarity switching frequency (When not printing)30~9MSet this code when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller after the warming-up, forced toner supply or auto-toner adjustment.
08Setting modeProcessProcess5003Job end cleaning bias polarity switching frequency (At jam recovery)30~9MSets when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller after a paper jam is cleared.
4: Five times 5: Six times 6: Seven times 7: Eight times
08Setting modeProcessTransfer5005Switching transfer
bias between sheets of paper
10~1M0: Positive, 1: Negative1
08Setting modeProcessTransfer50750Paper width transfer output correction (H) (Middle)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 136
e-STUDIO356/456/506: 146
08Setting modeProcessTransfer50751Paper width transfer output correction (C) (Middle)Refer to contents0~255M<Default value>
08Setting modeProcessTransfer50752Paper width transfer output correction (L) (Middle)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 146
e-STUDIO356/456/506: 156
08Setting modeProcessTransfer50760Paper width transfer output correction (H) (Small)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 150
e-STUDIO356/456/506: 168
08Setting modeProcessTransfer50761Paper width transfer output correction (C) (Small)Refer to contents0~255M<Default value>
08Setting modeProcessTransfer50762Paper width transfer output correction (L) (Small)Refer to contents0~255M<Default value>
e-STUDIO206L/256/306: 162
e-STUDIO356/456/506: 177
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessProcess5101Toner cartridge correction table switching00~2MCorrects the image density according to the detection value of the sensor. Changing this code varies the correction amount of the image density. Set this code when the density is too high or low.
0: Middle-level correction 1: Low-level correction 2: High-level correction It is hardly corrected at the normal temperature and humidity.
08Setting modeProcessDevelopm entToner near empty5155Toner near empty threshold setting10-5M0: The period from the appearance of the toner near- empty sign to the actual complete consumption of the toner is set to long.
1: Normal (Default)
2: The period from the appearance of the toner near- empty sign to the actual complete consumption of the toner is set to short.
3: No detection
4: Toner near-empty status threshold value: (%)*
5: Toner near-empty status threshold value: (Number of sheets)*
* The toner near-empty status is displayed if the remaining amount of toner is equal to or less than the amount set in 08-5810/5811 (percentage or number of sheets).
1Yes
08Setting modeProcessDevelopm entToner near emptyFine adjustment of threshold for displaying remaining toner and toner near empty51563K8350-150MAdjusts the threshold value for displaying remaining amount of toner and toner near empty.
Display threshold value = default threshold value x setting value/100 (unit: %)
08Setting modeProcessFuserFusing correction control time immediately after warming-up52100Temperature correction20~10M0: Disabled, 1: 1 min. 2: 2 min. 3: 3 min. 4: 4 min. 5:
5 min. 6: 6 min. 7: 7 min. 8: 8 min. 9: 10 min. 10: 15 min.
08Setting modeProcessFuserFusing correction control time immediately after warming-up52101Maximum time of lamp ON20~10M0: Disabled, 1: 1 min. 2: 2 min. 3: 3 min. 4: 4 min. 5:
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingProcessFuser5285Fusing temperatureRefer to0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°1
modeduring printing (PlaincontentsC 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10: 190°C 11:
paper/Sub)195°C 12: 200°C 13: 205°C 14: 210°C
<Default value>
e-STUDIO206L/256/306: -
08SettingProcessFuser5328Fusing temperatureRefer to0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°1
modeduring printing (ThickcontentsC 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10: 190°C 11:
paper 1/Sub)195°C 12: 200°C 13: 205°C 14: 210°C
<Default value>
08SettingProcessFuser5329Fusing temperatureRefer to0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°1
paper 2/Sub)195°C 12: 200°C 13: 205°C 14: 210°C
<Default value>
08SettingProcessFuser5330Fusing temperatureRefer to0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°1
paper 3/Sub)195°C 12: 200°C 13: 205°C 14: 210°C
<Default value>
08SettingProcessFuser5331Fusing temperatureRefer to0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°1
modeduring printingcontentsC 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10: 190°C 11:
(Overhead195°C 12: 200°C 13: 205°C 14: 210°C
transparencies /Sub)<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser5332Fusing temperature during printing (Envelope/Sub)Refer to contents0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
e-STUDIO206L/256/306: - e-STUDIO356/456/506: 12
08Setting modeProcessFuserTemperature drop during printing (Sub)53330The first dropRefer to contents0 to 10MSetting value x -5°C: from 0°C to -50°C
This code is valid only when "20" is set to 08-2214-0.
<Default value>
e-STUDIO206L/256/306: - e-STUDIO356/456/506: 0
08Setting modeProcessFuserTemperature drop during printing (Sub)53331The second dropRefer to contents0 to 10MSetting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO206L/256/306: - e-STUDIO356/456/506: 4
08Setting modeProcessFuserTemperature drop during printing (Sub)53332The third dropRefer to contents0 to 10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop during printing (Sub)53333The forth dropRefer to contents0 to 10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting (Sub)53340The first dropRefer to contents0 to 200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-0.
<Default value>
e-STUDIO206L/256/306: - e-STUDIO356/456/506: 5
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop switching time setting (Sub)53341The second dropRefer to contents0 to 200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-0.
<Default value>
e-STUDIO206L/256/306: - e-STUDIO356/456/506: 18
08Setting modeProcessFuserTemperature drop switching time setting (Sub)53342The third dropRefer to contents0 to 200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-0.
<Default value>
e-STUDIO206L/256/306: - e-STUDIO356/456/506: 24
08Setting modeProcessFuserTemperature drop switching time setting (Sub)53343The forth dropRefer to contents0 to 200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-0.
<Default value>
e-STUDIO206L/256/306: - e-STUDIO356/456/506: 75
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)53350The first dropRefer to contents0 to 10MSetting value x -5°C: from 0°C to -50°C
This code is valid only when "20" is set to 08-2214-1.
<Default value>
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)53351The second dropRefer to contents0 to 10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)53352The third dropRefer to contents0 to 10MSetting value x -5°C: from 0°C to -50°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)53353The forth dropRefer to contents0 to 10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Sub)53360The first dropRefer to contents0 to 200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Sub)53361The second dropRefer to contents0 to 200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Sub)53362The third dropRefer to contents0 to 200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Sub)53363The fourth dropRefer to contents0 to 200MSetting value x 5 seconds: from 0 to 1000 seconds This code is valid only when "20" is set to 08-2214-1.
<Default value>
08Setting modeProcessFuserCorrection of temperature rising prevention (Latest value)53370Ready00~15M0: 0℃ 1: -1℃ 2: -2℃ 3: -3℃ 4: -4℃ 5: -5℃ 6: -6℃
7: -7℃ 8: -8℃ 9: -9℃ 10: -10℃ 11: -11℃ 12: -12℃
13: -13℃ 14: -14℃ 15: -15℃
08Setting modeProcessFuserCorrection of temperature rising prevention (Latest value)53371Print00~15M0: 0℃ 1: -1℃ 2: -2℃ 3: -3℃ 4: -4℃ 5: -5℃ 6: -6℃
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterMaintenan ce5554PM counter setting value for developer material (K)Refer to content8 digitsMSets the number of printed sheets to display the message that prompts the PM of developer material.
<Default value> e-STUDIO206L:
JPD: 0
Other: 80000 e-STUDIO256:
JPD: 0
Other: 100000 e-STUDIO306:
JPD: 0
Other: 120000 e-STUDIO356:
JPD: 0
Other: 125000 e-STUDIO456:
JPD: 0
Other: 150000 e-STUDIO506:
JPD: 0
Other: 150000
08Setting modeCounterMaintenan ce5555PM time counter setting value for developer material (K)Refer to contents8 digitsMSets the accumulated driving time to display the message that prompts the PM of developer material.
<Default value>
e-STUDIO206L/256/306: 161000
e-STUDIO356/456/506: 135000
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterMaintenan ce5562PM counter setting value for partRefer to content8 digitsMSets the number of printed sheets to display the message that prompts the PM of part.
JPD: 0
Other: 240000 e-STUDIO256:
JPD: 0
Other: 200000 e-STUDIO306:
JPD: 0
Other: 240000 e-STUDIO356:
JPD: 0
Other: 250000 e-STUDIO456:
JPD: 0
Other: 300000 e-STUDIO506:
JPD: 0
Other: 300000
08Setting modeCounterMaintenan ce5563PM time counter setting value for partRefer to content8 digitsMSets the accumulated driving time to display the message that prompts the PM of part.
<Default value>
e-STUDIO206L: 483000
e-STUDIO256/306: 322000
e-STUDIO356/456/506: 270000
08Setting modeCounterMaintenan ce5568Current value of PM counter for developer material (K)08 digitsMDisplays the current number of printed sheets. Counts up by turning on the registration sensor.1
08Setting modeCounterMaintenan ce5569Current value of PM time counter for developer material (K)08 digitsMDisplays the current driving time.1
08Setting modeCounterMaintenan ce5576Current value of PM counter for part08 digitsMDisplays the current number of printed sheets. Counts up by turning on the registration sensor.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterMaintenan ce5577Current value of PM time counter for part08 digitsMDisplays the current driving time of fuser.1
08Setting modeCounterMaintenan ce5581Switching of output pages/driving counts at PM/developer material (K)00~2M0: Pages 1: driving count 2: Whichever comes faster1
08Setting modeCounterMaintenan ce5585Switching of output pages/driving counts at PM/part00~2M0: Pages 1: driving count 2: Whichever comes faster1
08Setting modeProcessDevelopm entToner near empty5810Toner near-empty status threshold value setting (%)31-99MThis code is used when the value of 08-5155 is set to "4". Use this code to specify the threshold value (unit:
%) for displaying the toner near-empty status. The accuracy of value is influenced by usage environment or originals.
08Setting modeProcessDevelopm entToner near empty5811Toner near-empty status threshold value setting (number of sheets)10001-9999MThis code is used when the value of 08-5155 is set to "5". Use this code to specify the threshold value (unit: number of sheets) for displaying the toner near-empty status. The accuracy of value is influenced by usage environment or originals.1
08Setting modeCounterDouble countFor fee chargingPaper size6010Large-sized paperRefer to contents0~2M0: Counted as 1 1: Counted as 2 2: Counted as 1 (Mechanical counter is double counter)
<Default value> JPN: 0
OTHER: 1
1Yes
08Setting modeCounterDouble countFor fee chargingPaper size6011Definition setting of large sized paper00~1M0: A3/LD 1: A3/LD/B4/LG/FOLIO/COMP/8K1Yes
08Setting modeCounterDouble countFor PMPaper size6012Large-sized paper10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterDouble countFor PMPaper size6013Definition setting of large sized paper10~1M0: A3/LD 1: A3/LD/B4/LG/FOLIO/COMP1Yes
08Setting modeCounterDouble countFor PMPaper type6014Thick paper10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterDouble countFor PMPaper type6015OHP10~1M0: Counted as 1 1: Counted as 21Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterDouble countFor PMPaper type6016Envelope10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterDouble countFor PMPaper type6017Tab paper10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterCounterDisplay of number of output pages in copier functionPPC60630Large08 digitsSYSCounts the number of output pages in the Copier Function according to its size (large/small).
Large: Number of output pages of large-sized paper defined at 08-6011
Small: Number of output pages other than set as large- sized paper
Total: Total number output pages of all paper sizes.
08Setting modeCounterCounterDisplay of number of output pages in copier functionPPC60631Small08 digitsSYSCounts the number of output pages in the Copier Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of output pages in printer functionPRT60640Large08 digitsSYSCounts the number of output pages in the Printer Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of output pages in printer functionPRT60641Small08 digitsSYSCounts the number of output pages in the Printer Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of output pages at list print modePRT60650Large08 digitsSYSCounts the number of output pages at the List Print Mode Function according to its size (large/small). Large: Number of output pages of large-sized paper defined at 08-6011
paper
08Setting modeCounterCounterDisplay of number of output pages at list print modePRT60651Small08 digitsSYSCounts the number of output pages at the List Print Mode Function according to its size (large/small). Large: Number of output pages of large-sized paper defined at 08-6011
paper
08Setting modeCounterCounterDisplay of number of output pages in FAX functionPRT60660Large08 digitsSYSCounts the number of output pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of output pages in FAX functionPRT60661Small08 digitsSYSCounts the number of output pages in the FAX Function according to its size (large/small).
paper
