Toshiba e-STUDIO 307/357/457/507 Service Manual Part 7
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41030Plain paper; Long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter
<Default value>
e-STUDIO206L/256/306: 44
e-STUDIO356/456/506: 28
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41031Plain paper; Middle sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41032Plain paper; Short size1Refer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41040Thick paper1; Long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41041Thick paper1; Middle sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41042Thick paper1; Short size1Refer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41050Thick paper2; Long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41051Thick paper2; Middle sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41052Thick paper2; Short size1Refer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41060Thick paper3; Long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41061Thick paper3; Middle sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41062Thick paper3; Short sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41063Postcard350~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41070OHP film; Long size240~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41071OHP film; Middle size240~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentBypass feeding41072OHP film; Short sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentPFP upper drawer41080Plain paper; Long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the
<Paper length>
<Default value>
e-STUDIO206L/256/306: 30
e-STUDIO356/456: 15
e-STUDIO506: 12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenPrinterFeedingPaper aligningPFP upper drawer41081Plain paper; MiddleRefer to0~63Me-STUDIO206L/256/306:When the value increases by4
t modesystem/Paamount adjustmentsizecontents“1”, the
peraligning amount increases by approx. 0.3 mm.
transporte-STUDIO356/456/506:When the value increases by
<Paper length>
<Default value>
e-STUDIO206L/256/306: 28
e-STUDIO356/456: 15
e-STUDIO506: 12
05AdjustmenPrinterFeedingPaper aligningPFP upper drawer41082Plain paper; ShortRefer to0~63Me-STUDIO206L/256/306:When the value increases by4
peraligning amount increases by approx.0.3 mm.
“1”, the aligning amount increases by approx.0.4 mm.
<Paper length>
<Default value>
e-STUDIO206L/256/306: 25
e-STUDIO356/456: 14
e-STUDIO506: 9
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenPrinterFeedingPaper aligningPFP lower drawer41090Plain paper; LongRefer to0~63Me-STUDIO206L/256/306:When the value increases by4
t modesystem/Paamount adjustmentsizecontents“1”, the aligning amount increases by approx.0.3 mm.
pere-STUDIO356/456/506:When the value increases by
transport“1”, the aligning amount increases by approx.0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 15
e-STUDIO506: 12
05AdjustmenPrinterFeedingPaper aligningPFP lower drawer41091Plain paper; MiddleRefer to0~63Me-STUDIO206L/256/306:When the value increases by4
<Paper length>
<Default value>
e-STUDIO356/456: 15
e-STUDIO506: 12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentPFP lower drawer41092Plain paper; Short sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx.0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx.0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 14
e-STUDIO506: 9
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentADU41100Plain paper; Long size190~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentADU41101Plain paper; Middle size190~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentADU41102Plain paper; Short size190~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentT-LCF4111Plain paperRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 14
e-STUDIO506: 9
05Adjustmen t modePrinterPaper feedingAdjustment of paper pushing amount/Bypass feeding41120Plain paper00~20MWhen the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section.
*Postcard is supported only for JPN model.
05Adjustmen t modePrinterPaper feedingAdjustment of paper pushing amount/Bypass feeding41121Postcard00~20MWhen the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section.
05Adjustmen t modePrinterPaper feedingAdjustment of paper pushing amount/Bypass feeding41123Envelope00~20MWhen the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterPaper feedingAdjustment of paper pushing amount/Bypass feeding41124Thick paper 100~20MWhen the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section.
05Adjustmen t modePrinterPaper feedingAdjustment of paper pushing amount/Bypass feeding41125Thick paper 200~20MWhen the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section.
05Adjustmen t modePrinterPaper feedingAdjustment of paper pushing amount/Bypass feeding41126Thick paper 300~20MWhen the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section.
05Adjustmen t modePrinterPaper feedingAdjustment of paper pushing amount/Bypass feeding41127OHP film00~20MWhen the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section.
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment1st drawer41150Thick paper1; Long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO206L/256/306: 37
e-STUDIO356/456: 21
e-STUDIO506: 17
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment1st drawer41151Thick paper1; Middle sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 21
e-STUDIO506: 17
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment1st drawer41152Thick paper1; Short sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 21
e-STUDIO506: 17
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment1st drawer41153Thick paper2; Long size200~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment1st drawer41154Thick paper2; Middle size200~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment1st drawer41155Thick paper2; Short size200~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment2nd drawer41160Thick paper1; Long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 20
e-STUDIO506: 9
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenPrinterFeedingPaper aligning2nd drawer41161Thick paper1; MiddleRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
t modesystem/Paamount adjustmentsizecontents“1”, the aligning amount increases by approx. 0.3 mm.
transport“1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 20
e-STUDIO506: 9
05AdjustmenPrinterFeedingPaper aligning2nd drawer41162Thick paper1; ShortRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
<Paper length>
<Default value>
e-STUDIO206L/256/306: 31
e-STUDIO356/456: 16
e-STUDIO506: 9
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenPrinterFeedingPaper aligningPFP upper drawer41170Thick paper1; LongRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
<Paper length>
<Default value>
e-STUDIO356/456: 20
e-STUDIO506: 12
05AdjustmenPrinterFeedingPaper aligningPFP upper drawer41171Thick paper1; MiddleRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
<Paper length>
<Default value>
e-STUDIO356/456: 20
e-STUDIO506: 12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenPrinterFeedingPaper aligningPFP upper drawer41172Thick paper1; ShortRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
<Paper length>
<Default value>
e-STUDIO356/456: 16
e-STUDIO506: 9
05AdjustmenPrinterFeedingPaper aligningPFP lower drawer41180Thick paper1; LongRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
<Paper length>
<Default value>
e-STUDIO356/456: 20
e-STUDIO506: 12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenPrinterFeedingPaper aligningPFP lower drawer41181Thick paper1; MiddleRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
<Paper length>
<Default value>
e-STUDIO356/456: 20
e-STUDIO506: 12
05AdjustmenPrinterFeedingPaper aligningPFP lower drawer41182Thick paper1; ShortRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
<Paper length>
<Default value>
e-STUDIO356/456: 16
e-STUDIO506: 9
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentT-LCF4119Thick paper1Refer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO206L/256/306:37 e-STUDIO356/456:15
e-STUDIO506: 9
1Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentADU41200Thick paper1; Long size190~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentADU41201Thick paper1; Middle size190~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentADU41202Thick paper1; Short size190~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentRegistration section44050Bypass feed/Envelope; long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentRegistration section44051Bypass feed/Envelope; middle sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustmentRegistration section44052Bypass feed/Envelope; short sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
4Yes
05Adjustmen t modePrinterDriveFine adjustment of reverse motor speed4817-For resolution in inches1280~255MWhen the value increases by "1", the rotation accelerates by approx. 0.05%.1
05Adjustmen t modePrinterDriveFine adjustment of reverse motor speed4818-For FAX resolution in millimeters1280~255MWhen the value increases by "1", the rotation accelerates by approx. 0.05%.1
05Adjustmen t modePrinterPrinterTray position
judgment time adjustment
48190Drawer (upper/lower)440~255M4
48191PFP drawer (upper/lower)440~255M4
05Adjustmen t modePrinterFinisherStapling position adjustment value48200LD/A30-17~17M4
05Adjustmen t modePrinterFinisherStapling position adjustment value48201LG/B4/8K/A4-R/LT- R/16K-R0-17~17M4
05Adjustmen t modePrinterFinisherPaper stack folding position adjustment value48210LD/A30-17~17M4
05Adjustmen t modePrinterFinisherPaper stack folding position adjustment value48211LG/B4/8K/A4-R/LT- R/16K-R0-17~17M4
05Adjustmen t modePrinterFinisherAlignment position adjustment48220Front0-17~17M4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterFinisherAlignment position adjustment48221Rear0-17~17M4
05Adjustmen t modePrinterFinisherStapling position adjustment48230One place (Rear)0-25~25M4Yes
05Adjustmen t modePrinterFinisherStapling position adjustment48231One place (Rear/R- series sizes)0-17~25M4Yes
05Adjustmen t modePrinterFinisherStapling position adjustment48232One place (Front)0-25~25M4Yes
05Adjustmen t modePrinterFinisherStapling position adjustment48233One place (Front/R- series sizes)0-25~17M4Yes
05Adjustmen t modePrinterFinisherStapling position adjustment48234Two places (Center)0-17~17M4Yes
05Adjustmen t modePrinterFinisherStapling position adjustment48235Two places (Pitch)0-15~12M4Yes
05Adjustmen t modePrinterFinisher4824Punching position center adjustment0-15~15M1Yes
05Adjustmen t modePrinterFinisher4825Punch hole position adjustment0-20~12M1Yes
05Adjustmen t modePrinterFinisher4826Saddle stitch alignment adjustment0-15~15M1Yes
05Adjustmen t modePrinterFinisher4827Gripper arm exiting position adjustment0-15~15M1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tPPC(black)7025ADF1280~255SYSThe smaller the adjustment value is, the lighter the background becomes. The larger the adjustment value is, the darker the background becomes.1Yes
g
Backgroun d
adjustmen
PPC(black)Black/Automatic density adjustment7033Text/Photo1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
PPC(black)Black/Automatic density adjustment7034Text1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
PPC(black)Black/Manual density adjustment7041Text/Photo1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
PPC(black)Black/Manual density adjustment7042Text1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
Backgroun
d adjustmen
PPC(black)Black/Automatic density adjustment7043Photo1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
PPC(black)Black/Manual density adjustment7048Photo1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
PPC(black)Black/Automatic density adjustment7050Presentation1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
PPC(black)Black/Manual density adjustment7051Presentation1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tPPC(black)7056Text/Photo1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tPPC(black)7057Text1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tPPC(black)7058Photo1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tPPC(black)7059Presentation1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSmudged/f aint text adjustmen tPPC(black)7097Text/Photo20~4SYS0: Faint text is suppressed most.
4: Smudged text is suppressed most.
1Yes
05Adjustmen t modeImage Processin gSmudged/f aint text adjustmen tPPC(black)7098Text20~4SYS0: Faint text is suppressed most.
1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
adjustment/Center value
7114Text/Photo1280~255SYSThe larger the value is, the darker the image at the center value becomes.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
7115Text1280~255SYSThe larger the value is, the darker the image at the center value becomes.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
7116Photo1280~255SYSThe larger the value is, the darker the image at the center value becomes.1Yes
g
Density adjustmen
t
PPC(black)Manual adjustment/Light step
value
7117Text/Photo200~255SYSWhen the value increases, the image of the "light" steps becomes lighter.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
Density
adjustmen t
PPC(black)Manual
adjustment/Light step value
7118Text200~255SYSWhen the value increases, the image of the "light" steps becomes lighter.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
7119Photo200~255SYSWhen the value increases, the image of the "light" steps becomes lighter.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
adjustment/Dark step value
7120Text/Photo200~255SYSWhen the value increases, the image of the "dark" steps becomes darker.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
7121Text200~255SYSWhen the value increases, the image of the "dark" steps becomes darker.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
7122Photo200~255SYSWhen the value increases, the image of the "dark" steps becomes darker.1Yes
Processin g
Density
adjustmen t
PPC(black)Automatic density adjustment7123Text/Photo1280~255SYSWhen the value increases, the image becomes darker.1Yes
Processin g
Density
adjustmen t
PPC(black)Automatic density adjustment7124Text1280~255SYSWhen the value increases, the image becomes darker.1Yes
Processin g
Density
adjustmen t
PPC(black)Automatic density adjustment7125Photo1280~255SYSWhen the value increases, the image becomes darker.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
7126Presentation1280~255SYSWhen the value increases, the image becomes darker; when the former decreases, the latter becomes lighter.1Yes
Processin g
Density
adjustmen t
PPC(black)Automatic density adjustment7129Presentation1280~255SYSWhen the value increases, the image becomes darker; when the former decreases, the latter becomes lighter.1Yes
05Adjustmen t modeImage Processin gAutomatic gamma adjustmen tPPC(black)7165All media types---When color deviation is found in gradation reproduction, the gradation reproduction of color K can be corrected with the automatic gamma adjustment. The result of the correction above will be applied to all media types.7
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Text/Photo71900Low density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Text/Photo71901Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Text/Photo71902High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Text71910Low density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Text71911Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Text71912High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Photo71920Low density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Photo71921Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Photo71922High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Presentation71930Low density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Presentation71931Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)Presentation71932High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text/Photo72180Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text/Photo72181Beam level 1/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text/Photo72182Beam level 2/450~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text/Photo72183Beam level 3/460~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text/Photo72184Beam level 4/480~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text72190Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text72191Beam level 1/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text72192Beam level 2/450~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text72193Beam level 3/460~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Text72194Beam level 4/490~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Photo72200Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Photo72201Beam level 1/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Photo72202Beam level 2/450~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Photo72203Beam level 3/460~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Photo72204Beam level 4/490~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Presentation72210Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Presentation72211Beam level 1/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Presentation72212Beam level 2/450~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Presentation72213Beam level 3/460~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionPPC(black)Presentation72214Beam level 4/490~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Automatic density adjustment7236User custom10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Manual density adjustment7237User custom10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tPPC(black)7249User custom1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSmudged/f aint text adjustmen tPPC(black)7252User custom20~4SYS0: Smudged text is suppressed most. 4: Faint text is suppressed most.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
Density
adjustmen t
PPC(black)Manual
7258User custom1280~255SYSWhen the value increases, the image of the center step becomes darker.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
7261User custom200~255SYSWhen the value increases, the image of the "light" step density becomes lighter.1Yes
Processin g
Density
adjustmen t
PPC(black)Manual
7264User custom200~255SYSWhen the value increases, the image of the "dark" step density becomes darker.1Yes
Processin g
Density
adjustmen t
PPC(black)Automatic density adjustment7267User custom1280~255SYSWhen the value increases, the image becomes darker.1Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)User custom72760Low density1280~255SYSThe larger the value is, the darker the image of the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)User custom72761Medium density1280~255SYSThe larger the value is, the darker the image of the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPPC(black)User custom72762High density1280~255SYSThe larger the value is, the darker the image of the target area becomes.4Yes
Processin g
Backgroun
d adjustmen
PPC(black)Black/Automatic density adjustment7279User custom1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
PPC(black)Black/Manual density adjustment7280User custom1280~255SYSThe larger the value is, the lighter the background becomes.1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Automatic density adjustment7283Text/Photo10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Automatic density adjustment7284Text10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Automatic density adjustment7285Photo10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Manual density adjustment7286Text/Photo10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Manual density adjustment7287Text10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Manual density adjustment7288Photo00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Automatic density adjustment7289Presentation10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tPPC(black)Black/Manual density adjustment7290Presentation00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PS/Smooth/600dpi73150Low density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
M: Medium density area H: High density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PS/Smooth/600dpi73151Medium density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PS/Smooth/600dpi73152High density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PS/Detail/600dpi73160Low density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PS/Detail/600dpi73161Medium density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PS/Detail/600dpi73162High density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PCL/Smooth/600dpi73170Low density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PCL/Smooth/600dpi73171Medium density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PCL/Smooth/600dpi73172High density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PCL/Detail/600dpi73180Low density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PCL/Detail/600dpi73181Medium density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)PCL/Detail/600dpi73182High density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)XPS/Smooth/600dpi73190Low density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)XPS/Smooth/600dpi73191Medium density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)XPS/Smooth/600dpi73192High density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)XPS/Detail/600dpi73200Low density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)XPS/Detail/600dpi73201Medium density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tPRT(black)XPS/Detail/600dpi73202High density1280~255SYSWhen the value increases, the density in the target area becomes higher.
L: Low density area
4Yes
05Adjustmen t modeImage Processin gImageAdjustment of smudged/faint textPRT7325PS50~9MAdjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed.1Yes
05Adjustmen t modeImage Processin gImageAdjustment of smudged/faint textPRT7326PCL50~9MAdjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed.1Yes
05Adjustmen t modeImage Processin gImageAdjustment of smudged/faint textPRT7327XPS50~9MAdjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving OFF73500Beam level 0/400~10MAdjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving OFF73501Beam level 1/440~10MAdjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving OFF73502Beam level 2/450~10MAdjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving OFF73503Beam level 3/460~10MAdjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving OFF73504Beam level 4/490~10MAdjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PS73510Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PS73511Beam level 1/410~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PS73512Beam level 2/420~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PS73513Beam level 3/430~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PS73514Beam level 4/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PCL73520Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PCL73521Beam level 1/410~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PCL73522Beam level 2/420~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PCL73523Beam level 3/430~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/PCL73524Beam level 4/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4Yes
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/XPS73530Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/XPS73531Beam level 1/410~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/XPS73532Beam level 2/420~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/XPS73533Beam level 3/430~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerToner saving ON/XPS73534Beam level 4/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerHardcopy security printing73540Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerHardcopy security printing73541Beam level 1/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerHardcopy security printing73542Beam level 2/450~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerHardcopy security printing73543Beam level 3/460~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerHardcopy security printing73544Beam level 4/490~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerTest print73550Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerTest print73551Beam level 1/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerTest print73552Beam level 2/450~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerTest print73553Beam level 3/460~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerTest print73554Beam level 4/490~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerBox printing73560Beam level 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerBox printing73561Beam level 1/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerBox printing73562Beam level 2/450~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerBox printing73563Beam level 3/460~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gSetting beam level conversionBlack NW printerBox printing73564Beam level 4/490~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/text73600Low density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/text73601Medium density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/text73602High density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/graphics73610Low density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/graphics73611Medium density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/graphics73612High density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/image73620Low density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/image73621Medium density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoPS/image73622High density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/text73660Low density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/text73661Medium density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/text73662High density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/graphics73670Low density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/graphics73671Medium density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/graphics73672High density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/image73680Low density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/image73681Medium density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tMonochrome/600dpi/ AutoXPS/image73682High density1280-255SYSLarger the value, the density value increases, and smaller the value, the density value decreases.4Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Aut omatic)Black/Automatic density adjustment7416Text/Photo10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Aut omatic)Black/Automatic density adjustment7417Text10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Aut omatic)Black/Automatic density adjustment7418Photo10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Aut omatic)Black/Automatic density adjustment7419Gray scale10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Ma nual)Black/Manual density adjustment7421Text/Photo00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Ma nual)Black/Manual density adjustment7422Text00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Ma nual)Black/Manual density adjustment7423Photo00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Ma nual)Black/Manual density adjustment7424Gray scale00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black/Aut omatic)Black/Automatic density adjustment7425User custom10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tRange correction adjustment(Black / Manual density adjustment)Black/Manual density adjustment7426User custom00~1SYS0: Background peak - Fixed 1: Background peak - Varied1
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN(black)7430Text/Photo1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN(black)7431Text1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN(black)7432Photo1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN(black)7433Gray scale1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
Processin g
Density
adjustmen t
SCN(black)Manual
7444Text/Photo1280~255SYSThe larger the value is, the darker the image of the center value becomes.1Yes
Processin g
Density
adjustmen t
SCN(black)Manual
7445Text1280~255SYSThe larger the value is, the darker the image of the center value becomes.1Yes
Processin g
Density
adjustmen t
SCN(black)Manual
7446Photo1280~255SYSThe larger the value is, the darker the image of the center value becomes.1Yes
Processin g
Density
adjustmen t
SCN(black)Manual
7447Gray scale1280~255SYSThe larger the value is, the darker the image of the center value becomes.1Yes
Processin g
Density
adjustmen t
SCN(black)Automatic density adjustment7456Text/Photo1280~255SYSWhen the value increases, the image becomes darker.1Yes
g
Density adjustmen
t
SCN(black)Automatic density adjustment7457Text1280~255SYSWhen the value increases, the image becomes darker.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
Density
adjustmen t
SCN(black)Automatic density adjustment7458Photo1280~255SYSWhen the value increases, the image becomes darker.1Yes
Processin g
Density
adjustmen t
SCN(black)Automatic density adjustment7459Gray scale1280~255SYSWhen the value increases, the image becomes darker.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN(black)7470User custom1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
Processin g
Density
adjustmen t
SCN(black)Manual
7475User custom1280~255SYSThe larger the value is, the darker the image at the center value becomes.1Yes
Processin g
Density
adjustmen t
SCN(black)Automatic density adjustment7478User custom1280~255SYSThe larger the value is, the darker the image at the center value becomes.1Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)User custom74800Low density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)User custom74801Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)User custom74802High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Text/Photo74850Low density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Text/Photo74851Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Text/Photo74852High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Photo74870Low density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Photo74871Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Photo74872High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Gray scale74880Low density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Gray scale74881Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Gray scale74882High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4Yes
05Adjustmen t modeImage Processin gImage7489Amount of surrounding void (network scanning)00~255SYSWhen the value increases, the blank area around the scanned image becomes wider. (e.g.: In network scanning with 600 dpi, if the setting value is "1", the blank area increases by 1 dot.)1
Processin g
Density
adjustmen t
FAX(black)Manual
7533Text/Photo1280~255SYSThe larger the value is, the darker the image at the center value becomes.1Yes
Processin g
Density
adjustmen t
FAX(black)Simple binarization
adjustmentt/Center value
7534Text1280~255SYSThe larger the value is, the darker the image at the center value becomes.1Yes
Processin g
Density
adjustmen t
FAX(black)Manual
7535Photo1280~255SYSThe larger the value is, the darker the image at the center value becomes.1Yes
Processin g
Density
adjustmen t
FAX(black)Automatic density adjustment7542Text/Photo1280~255SYSWhen the value increases, the image becomes darker.1Yes
Processin g
Density
adjustmen t
FAX(black)Automatic density adjustment7543Photo1280~255SYSWhen the value increases, the image becomes darker.1Yes
Processin g
ImageSetting beam level conversion(FAX)FAX75950Beamlevel 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
Processin g
ImageSetting beam level conversion(FAX)FAX75951Beamlevel 1/420~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
g
ImageSetting beam level conversion(FAX)FAX75952Beamlevel 2/430~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
ImageSetting beam level conversion(FAX)FAX75953Beamlevel 3/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
Processin g
ImageSetting beam level conversion(FAX)FAX75954Beamlevel 4/480~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gBlank page judgment threshold adjustmen t7618PPC/SCN1280~255SYSThe larger the value is, the more the original tends to be judged as a blank page.1Yes
05Adjustmen t modeImage Processin gACS
judgment threshold
7630PPC/SCN700~255SYSThe larger the value is, the more an original tends to be judged as black even at the auto color mode. The smaller value is, the more it tends to be judged as color.1Yes
05Adjustmen t modeImage Processin gStroke adjustmen tPS/PDF automatic stroke adjustment600dpi82390Default setting00-1SYSThis code is used to change the width of fine line when PS and PDF printing. Automatic stroke adjustment is the function that prevents the width from changing by position.
This code sets whether the automatic stroke adjustment is enabled or disabled if automatic stroke adjustment is not included in the print data. If this setting is disabled, the case in which the width of fine line becomes thicker by 1 dot when printed increases. 0: Disabled
05Adjustmen t modeImage Processin gStroke adjustmen tPS/PDF automatic stroke adjustment600dpi82391Minimum stroke width when disabled21-2SYSThis code is used to change the width of fine line when PS and PDF printing. Automatic stroke adjustment is the function that prevents the width from changing by position.
This code sets the minimum width of fine line when the automatic stroke adjustment is disabled. For example, if automatic stroke adjustment is disabled and the width of fine line is set to "0" in the PS command, the width of line becomes 1 dot if the value of this code is set to "1", and the width of line becomes 2 dots if the value of this code is set to "2."
1: 1 dot
2: 2 dots
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
Backgroun
d adjustmen
SCN (color)8309Text/Photo1280~255SYSThe smaller the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
SCN (color)8310Text1280~255SYSThe smaller the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
SCN (color)8311Printed image1280~255SYSThe smaller the value is, the lighter the background becomes.1Yes
05Adjustmen t modeImage Processin gFine adjustmen t of black densitySCN (color)8314Text/Photo10~4SYSThe larger the value is, the darker the black side of the image becomes.1Yes
05Adjustmen t modeImage Processin gFine adjustmen t of black densitySCN (color)8315Text00~4SYSThe larger the value is, the darker the black side of the image becomes.1Yes
05Adjustmen t modeImage Processin gFine adjustmen t of black densitySCN (color)8316Printed image00~4SYSThe larger the value is, the darker the black side of the image becomes.1Yes
05Adjustmen t modeImage Processin gRGB
conversion method selection
SCN (color)8319Text/photo00~3SYSSets the color space format of the output image. 0: sRGB
1: AppleRGB
2: ROMMRGB
3: AdobeRGB
1Yes
SCN (color)8320Text00~3SYSSets the color space format of the output image. 0: sRGB
1: AppleRGB
2: ROMMRGB
3: AdobeRGB
1Yes
SCN (color)8321Printed image00~3SYSSets the color space format of the output image. 0: sRGB
1: AppleRGB
2: ROMMRGB
3: AdobeRGB
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
Saturation
adjustmen t
SCN (color)8324Text/photo1280~255SYSThe larger the value is, the brighter the image
becomes. The smaller the value is, the duller the image becomes.
1Yes
Processin g
Saturation
adjustmen t
SCN (color)8325Text1280~255SYSThe larger the value is, the brighter the image
1Yes
Processin g
Saturation
adjustmen t
SCN (color)8326Printed image1280~255SYSThe larger the value is, the brighter the image
1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tSCN (color)Full color/Automatic density adjustment8330Text10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tSCN (color)Full color/Automatic density adjustment8331Printed image10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tSCN (color)Full color/Automatic density adjustment8334User custom10~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN (color)Full color8335Text1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN (color)Full color8336Printed image1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
Processin g
Density
adjustmen t
SCN (color)Manual
8339Text/photo1280~255SYSWhen the value increases, the image becomes darker.1Yes
g
Density adjustmen
t
SCN (color)Manual adjustment/Center
value
8340Text1280~255SYSWhen the value increases, the image becomes darker.1Yes
g
Density adjustmen
t
value
8341Printed image1280~255SYSWhen the value increases, the image becomes darker.1Yes
05Adjustmen t modeImage Processin gDensity adjustmen tSCN (color)Manual adjustment/Light step value8344Text200~255SYSSets the changing amount per step of the density adjustment buttons on the control panel. The larger the value is, the lighter the image of the "light" step becomes.1Yes
05Adjustmen t modeImage Processin gDensity adjustmen tSCN (color)Manual adjustment/Light step value8345Printed image200~255SYSSets the changing amount per step of the density adjustment buttons on the control panel. The larger the value is, the lighter the image of the "light" step becomes.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gDensity adjustmen tSCN (color)Manual adjustment/Dark step value8348Text200~255SYSSets the changing amount per step of the density adjustment buttons on the control panel. The larger the value is, the darker the image of the "dark" step becomes.1Yes
05Adjustmen t modeImage Processin gDensity adjustmen tSCN (color)Manual adjustment/Dark step value8349Printed image200~255SYSSets the changing amount per step of the density adjustment buttons on the control panel. The larger the value is, the darker the image of the "dark" step becomes.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN (color)8354Text/photo1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Automatic density adjustment8355Text/photo1280~255SYSThe larger the value is, the lighter the background becomes. The smaller the value is, the darker it becomes.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Manual density adjustment8356Text/photo1280~255SYSThe larger the value is, the lighter the background becomes. The smaller the value is, the darker it becomes.1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tSCN(color)Full color/Manual density adjustment8360Text/Photo00-1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tSCN (color)Full color/Manual density adjustment8361Text00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tSCN (color)Full color/Manual density adjustment8362Printed image00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
05Adjustmen t modeImage Processin gRange correction adjustmen tSCN (color)Full color/Manual density adjustment8365User custom00~1SYS0: Background peak - Fixed 1: Background peak - Varied1Yes
Processin g
Backgroun
d adjustmen
SCN (color)8370User custom1280~255SYSWhen the value increases, the background becomes lighter.1Yes
05Adjustmen t modeImage Processin gFine adjustmen t of black densitySCN (color)8371User custom00~4SYSAdjusts the black density of the scanned image. When the value increases, the black density becomes darker.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
SCN (color)8372User custom00~3SYSSets the color space format of the output image.
0: sRGB 1: AppleRGB 2: ROMMRGB 3: AdobeRGB
1Yes
Processin g
Saturation
adjustmen t
SCN (color)8373User custom1280~255SYSThe larger the value is, the brighter the image
1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN (color)Full color8375User custom1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
Processin g
Density
adjustmen t
SCN (color)Manual
8380User custom1280~255SYSWhen the value increases, the image becomes darker.1Yes
05Adjustmen t modeImage Processin gDensity adjustmen tSCN (color)Manual adjustment/Light step value8381User custom200~255SYSSets the changing amount per step of the density adjustment buttons on the control panel. The larger the value is, the lighter the image of the "light" step becomes.1Yes
05Adjustmen t modeImage Processin gDensity adjustmen tSCN (color)Manual adjustment/Dark step value8382User custom200~255SYSSets the changing amount per step of the density adjustment buttons on the control panel. The larger the value is, the darker the image of the "dark" step becomes.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Automatic density adjustment8385Text1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Automatic density adjustment8386Printed image1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Automatic density adjustment8389User custom1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Manual density adjustment8390Text1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Manual density adjustment8391Printed image1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Manual density adjustment8394User custom1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Automatic density adjustment8400Text/Photo1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Automatic density adjustment8402Photo1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Automatic density adjustment8403Gray scale1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Automatic density adjustment8404User custom1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Manual density adjustment8405Text/Photo1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Manual density adjustment8407Photo1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Manual density adjustment8408Gray scale1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Manual density adjustment8409User custom1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1Yes
05Adjustmen t modeSystemMaintenan ce9043Equipment number (serial number) entry--SYSWhen this adjustment is performed with this code, the
setting code (08-9601) is also performed automatically (9 digits).
05Adjustmen t modeSystemImage9104Compression quality of s SLIM PDF background processing50~10SYS0-10
0: High compression, low image quality 10: Low compression, high image quality
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeSystemImage9149Saving image position adjustment log---Saves the image position adjustment log to the USB device. Insert the USB device to the equipment before performing this code.6
05Adjustmen t modeSystemGeneral9960Equipment information(SRAM)Refer to contents0~2SYSDisplays the equipment information in SRAM. 0: Not set
1: Destinations other than NAD 2: NAD
<Default value> NAD: 2
Others: 1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser2002Fuser unit error status counter00~19M0: No error 1: C410 (Once) 2: C410 (consecutively
occurred) 4: C430 5: C440 6: C450 7: C440 9: C440
08Setting modeProcessFuser2009Fuser roller temperature on standby(Center thermistor)Refer to contents0~12M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
165°C 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10:
190°C 11: 195°C 12: 200°C
<Default value>
e-STUDIO206L/256/306: 8
e-STUDIO356/456/506: 10
08Setting modeProcessFuser2010Fuser roller temperature during printing(Center thermistor/Plain paper)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
190°C 11: 195°C 12: 200°C 13: 205°C 14: 210°C
<Default value>
08Setting modeProcessFuser2028Fuser roller temperature during printing(Center thermistor/Thick paper 3)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
08Setting modeProcessFuser2031Pre-running time for first printing(Thick paper 3)100~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec. 6: 6 sec. 7: 7 sec. 8: 8 sec. 9: 9 sec. 10: 10 sec.
11: 12 sec. 12: 14 sec. 13: 16 sec. 14: 18 sec. 15: 20
sec.
08Setting modeProcessFuser2040Drop control when ready10~2M0: Invalid, 1:Valid, 2: Invalid in low temperature1
08Setting modeProcessFuserTemperature drop setting in ready status (Center thermistor)20410The first dropRefer to contents0~10MThis code is valid only when "20" is set to 08-2135. Setting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO206L/256/306: 1
e-STUDIO356/456/506: 0
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop setting in ready status (Center thermistor)20411The second dropRefer to contents0~10MThis code is valid only when "20" is set to 08-2135. Setting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting in ready status (Center thermistor)20412The third dropRefer to contents0~10MThis code is valid only when "20" is set to 08-2135. Setting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting in ready status (Center thermistor)20413The fourth dropRefer to contents0~10MThis code is valid only when "20" is set to 08-2135. Setting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserEnergy Saving ModeFuser roller temperature2042Center thermistor00~13M0: OFF 1: 40°C 2: 50°C 3: 60°C 4: 70°C 5: 80°C 6: 90°
C 7: 100°C 8: 110°C 9: 120°C 10: 130°C 11: 140°C
12: 150°C 13: 160°C
1Yes
08Setting modeProcessFuser2049Fuser roller temperature during printing(Center thermistor/Thick paper 1)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
08Setting modeProcessFuser2050Fuser roller temperature during printing(Center thermistor /Thick paper 2)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser2051Fuser roller temperature during printing(Center thermistor/OHP film)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
08Setting modeProcessFuser2052Pre-running time for first printing (OHP film)00~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec.
08Setting modeProcessFuser2053Pre-running time for first printing(Plain paper/Low temperature)00~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec.
08Setting modeProcessFuser2054Pre-running time for first printing(Thick paper 1)00~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec.
08Setting modeProcessFuser2055Pre-running time for first printing(Thick paper 2)100~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec.
08Setting modeProcessFuser2075Pre-running operation cycle in ready status and energy saving mode (Times of heat source ON)Refer to contents0~6M0: Not controlled 1: 180 times 2: 360 times 3: 540
times 4: 720 times 5: 900 times 6: 1080 times
<Default value>
e-STUDIO206L/256/306: 2
e-STUDIO356/456/506: 3
08Setting modeProcessFuser2100Temperature setting of warming-up(Center thermistor)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
e-STUDIO206L/256/306: 4
e-STUDIO356/456/506: 8
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser2101Temperature setting of warming-up(Side thermistor)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
08Setting modeProcessFuser2111Pre-running time (Normal temperature)30~18M0: Disabled 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
11: 15 sec. 12: 20 sec. 13: 25 sec. 14: 30 sec. 15: 40
sec. 16: 50 sec. 17: 60 sec.
18: 150 sec.
08Setting modeProcessFuser2120Fuser roller temperature in ready status(Side thermistor)Refer to contents0~12M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
C 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10: 190°C 11:
195°C 12: 200°C
<Default value>
08Setting modeProcessFuserTemperature drop setting in ready status (Side thermistor)21210The first dropRefer to contents0~10MThis code is valid only when "20" is set to 08-2135. Setting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting in ready status (Side thermistor)21211The second dropRefer to contents0~10MThis code is valid only when "20" is set to 08-2135. Setting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting in ready status (Side thermistor)21212The third dropRefer to contents0~10MThis code is valid only when "20" is set to 08-2135. Setting value x -5°C: from 0°C to -50°C
<Default value>
