Toshiba e-STUDIO 307/357/457/507 Service Manual Part 6
[4041] User authentication error
ClassificationError item
TopAccess related errorUser authentication error
Check itemMeasures
Setting
  • Perform the authentication or register as a user, and then perform the printing again.
[4042] Department authentication error
TopAccess related errorDepartment authentication error
Check itemMeasures
Setting
  • Check department information registered in this equipment.
[4050] Problem in LDAP server connection or LDAP server authorization settings
TopAccess related errorProblem in LDAP server connection or LDAP server authorization settings
Check itemMeasures
Setting
  • Confirm the administrator for the LDAP server connection or LDAP server authorization settings.
[4111] Quota over error (The number of the assigned pages set by department and user management has reached 0.)
Printer function errorQuota over error (The number of the assigned pages set by department and user management has reached 0.)
Check itemMeasures
Setting
  • The number of the assigned pages set by the department and the number of those assigned by user management have both reached 0. Assign the number of the pages again or perform initialization.
[4112] Quota over error (The number of the assigned pages set by user management has reached 0.
Printer function errorQuota over error (The number of the assigned pages set by user management has reached 0.
Check itemMeasures
Setting
  • The number of the assigned pages set by the user management has reached 0. Assign the number of the pages again or perform initialization.
[4113] Quota over error (The number of the assigned pages set by department management has reached 0.
Printer function errorQuota over error (The number of the assigned pages set by department management has reached 0.
Check itemMeasures
Setting
  • The number of the assigned pages set by the department management has reached 0. Assign the number of the pages again or perform initialization.
[4121]Job canceling due to external counter error
TopAccess related errorJob canceling due to external counter error
Check itemMeasures
Setting
  1. Drop a coin in. Perform the print job in error again.
  2. Insert a key card and then perform the print job in error again, or consult your administrator.
  3. Insert a key copy counter and then perform the print job in error again.
  4. Reset the scheduled print job and then perform the print job in error again.
[4214] Fax/Internet Fax transmission limitation error
TopAccess related errorFax/Internet Fax transmission limitation error
Check itemMeasures
Setting
  • Check the settings of this equipment.
[4241] No Printer kit / Printer function disabled
Printer function errorPrinting functions are disabled since the Printer kit or Printer/ Scanner kit is not installed firmly
Check itemMeasures
Setting
  • Check that the Printer kit or Printer/Scanner kit is installed firmly.
[4242] No Scanner kit / Scanner function disabled
Scanner function errorInternet FAX or storing to a share folder function using a network fax driver is disabled since the Scanner kit is not installed firmly, but the Printer kit is installed.
Check itemMeasures
Setting
  • Check that the Scanner kit is installed firmly.
[4300] Job execution error due to functional restrictions
TopAccess related errorJob execution error due to functional restrictions
Check itemMeasures
Setting
  • USB direct printing cannot be performed because the function is restricted by the self-diagnosis. Check the self- diagnosis setting.
[4301] File conversion error
TopAccess related errorPrinting a file whose format is not supported, or an invalid file
Check itemMeasures
Setting
  • The format of this file (other than PDF and JPEG) is not supported in USB direct printing, or the file is invalid. Check the file.
[4311] Not being authorized to perform JOB
TopAccess related errorNot being authorized to perform JOB
Check itemMeasures
Setting
  • Confirm the administrator for the JOB authorization.
[4312] Not authorized to store a file
TopAccess related errorNot authorized to store a file
Check itemMeasures
Setting
  • The user has not been authorized to perform this operation. Ask your administrator.
[4313] No privilege for e-Filing storage
[4314] No privilege for Fax / Internet FAX transmission
TopAccess related errorNo privilege for e-Filing storage
Check itemMeasures
Setting
  • Check the privilege given, or request the administrator to add the necessary privilege.
[4411] Image data creation failure)
TopAccess related errorImage data creation failure)
Check itemMeasures
SettingCheck if the file to be printed is broken. Perform printing again or use another printer driver.
  • Network print: Perform the print job in error again, or use another printer driver (e.g.; PS3, Universal).
  • Direct print: Check if the file is corrupted (e.g. checking if the file is displayed on your PC monitor), or check if the file format is supported by this equipment.
[4412] Double-sign encoding error
TopAccess related errorDouble-sign encoding error
Check itemMeasures
Setting
  • Printing using this function cannot be performed due to a decoding process error which occurs because the PDF file is encrypted incorrectly or encrypted in a language not supported.
[4611] Font download failure (reached the registration limit) [4612] Font download failure (HDD full)
TopAccess related errorFont download failure (reached the registration limit) Font download failure (HDD full)
Check itemMeasures
Setting
  • Delete one or more font already registered.
[4613] Font download failure (others)
TopAccess related errorFont download failure (others)
Check itemMeasures
Setting
  • Reattempt the downloading. Recreate font data and reattempt the downloading.
[4621] Font deletion failure
TopAccess related errorFont deletion failure
Check itemMeasures
Setting
  • Check if the font to be deleted is registered (or pre- registered) in this equipment.
[4F10] System abnormality
TopAccess related errorPrinting was not performed successfully due to other abnormalities.
Check itemMeasures
Setting
  1. Perform the job in error again. If the error still occurs, turn the power OFF and then back ON, and perform the job again.
  2. Collect the debug log with USB media.
  3. Initialize HDD.
 P. 8-3 "8.1.2 Collection of debug logs with a USB device"
Refer to step 3 and later in [E]Replace / Format HDDin
 P. 9-19 "9.3.3 Precautions and procedures when replacing the HDD".
e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507 © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved ERROR CODE AND TROUBLESHOOTING
  1. TopAccess related error​
    [5010] Internal setting error
    Communication error with external applicationThere is a print job, a proof print job, a private print job, a print job without a set department code, a scan job or a fax job remaining in this equipment.
    Check itemMeasures
    SettingDelete the remaining jobs.
    Turn the power OFF and then back ON. Until the initial registration is begun, do not press any button on the control panel or start any print or fax job.
    Communication error with external applicationA temporary password downloaded from e-Bridge and entered in this equipment is not valid, or the permanent password set in the e-Bridge is not valid.
    [5012] Authentication error
    Check itemMeasures
    SettingConfirm the user name and tentative password.
    [5013] e-Bridge communication error
    Communication error with external applicationCommunication is attempted while the e-Bridge is enabled for some reason such as version upgrade.
    Check itemMeasures
    SettingCheck if the MFP is connected to the eBR2 server.
    [5014] No SSL certificate
    Communication error with external applicationThere is no SSL certificate or the certificate is not in a correct file format.
    Check itemMeasures
    SettingInstall the correct SSL certificate.
    © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507
    [5015] Invalid SSL certificate
    Communication error with external applicationSSL certificate is not valid.
    Check itemMeasures
    [5016] Expired SSL certificate
    Communication error with external applicationSSL certificate is expired.
    Check itemMeasures
    SettingSet the correct time.
    [5017] Other SSL certificate related error
    Communication error with external applicationSSL certificate is invalid.
    Check itemMeasures
    [5018] Invalid DNS error
    Communication error with external applicationDNS address is invalid.
    Check itemMeasures
    SettingSet the correct DNS address.
    If any setting is needed in DNS, consult your administrators.
    [5019] Connection error
    Communication error with external applicationSettings for initial URL and proxy are incorrect.
    Check itemMeasures
    SettingPerform the correct settings for initial URL and proxy.
    [501A] Proxy error
    Communication error with external applicationIP address or port for proxy setting is invalid.
    Check itemMeasures
    SettingSet the correct IP address or port for the proxy setting.
    If any setting is needed in proxy, consult your administrators.
    [501B] No URL (host/port) or invalid path
    Communication error with external applicationInitial URL is invalid.
    Check itemMeasures
    SettingSet the correct initial URL.
    [5030] HTTP communication error
    Communication error with external applicationAn error in the HTTP communication
    Check itemMeasures
    SettingCheck the URL for communication.
    Check that the valid IP address is assigned to connect to the server.
    [50FF] eBR2 internal error
    MFP internal errorA fatal error occurred in the MFP
    Check itemMeasures
    SettingRestart the MFP, and then try again.
    [5110] Toner cartridge detection error
    TopAccess related errorToner cartridge detection error.
    Check itemMeasures
    Setting
    • Check if the toner cartridge is installed properly.
    • Check if the toner cartridge detection sensor operates properly.
    [5BD0] Power failure during restoration
    TopAccess related errorPower supply is cut off during the restoration of database sent from TopAccess
    Check itemMeasures
    Setting
    • Check if the power cable is connected properly and is inserted securely.
    • Check if the power voltage is unstable.
    • Reattempt the restoration of the database (Address Book, templates, F-code (Mailbox) or user information).
    [5C10] FAX Unit attachment error
    TopAccess related errorNetwork FAX is disabled because the FAX Unit is not attached
    Check itemMeasures
    Setting
    • Check if the FAX Unit is attached.
    • Check if there is any damage or abnormality on the FAX board.
    • Check if the connector on the FAX board is connected properly.
    [5C11] Network FAX transmission error
    TopAccess related errorThe network FAX job failed because the specified address is not registered in the Address Book
    Check itemMeasures
    SettingThe address specified for the network FAX is not registered on the Address Book. Register it.
    [5C20] Data import from TopAccess succeeded
    TopAccess related errorDisplayed when data have been imported from TopAccess (Not an error message)
    Check itemMeasures
    SettingData (Address book, department or user information) have been imported successfully. No troubleshooting is required.
    [5C21] Error in data import from TopAccess
    TopAccess related errorData import from TopAccess failed due to invalid file format
    Check itemMeasures
    SettingData import failed because the specified file (Address Book, department or user information) is incorrect or damaged. Check if the file is incorrect or damaged, and then reattempt the import.
  2. MFP access error​
    [6007] Unsuccessful User Login to MFP
    MFP access errorUser authentication cannot be done because connection to the authentication server has failed.
    Check itemMeasures
    SettingCheck if the operating status of the server and connection from an MFP have been confirmed.
    [6008] Failed to connect on External Role Base Access Control (LDAP) Server
    MFP access errorUser authentication cannot be done because connection to an external RBAC server has failed.
    Check itemMeasures
    SettingCheck if the operating status of the server and connection from the MFP have been confirmed.
    [6013] Connection failure to the authentication server
    MFP access errorFailed to connect to the authentication server
    Check itemMeasures
    SettingCheck that the server setting is proper by accessing [TopAccess] -> [Administration] -> [Maintenance] -> [Directory Service].
    When “Auto” is selected as the authentication method, this error may output to the log depending on the environment.
    [6014] The authentication server that cannot be accessed is detected
    MFP access errorThe authentication server that cannot be accessed is detected
    Check itemMeasures
    SettingCheck if the authentication server is down since the access to the authentication server is not available. The unavailable authentication server is accessed again if the time set in 08- 8788 passes or the power of the equipment is turned OFF and back ON.
    [6032] Card related error: Expired card
    MFP access errorThe card cannot be used because it has expired.
    Check itemMeasures
    SettingUse a card with a valid expiration.
    [6033] Card related error: Invalid flag data (no room-entry data)
    MFP access errorThe card cannot be used because no room-entry data are recorded in it.
    Check itemMeasures
    SettingUse a correct card that has been used for entering the room.
    [6034] Card related error: Invalid flag data (invalid card data)
    MFP access errorThe card cannot be used because the data required for the use of the card are not correctly set.
    Check itemMeasures
    SettingUse a valid card.
    MFP access errorThe equipment or device cannot be used since no privilege is given.
    [6037] Flags not available
    Check itemMeasures
    SettingUse the enable card or contact your administrator.
    [6041] Card authentication: Card related error
    MFP access errorThe self-diagnostic code required for card authentication is not set in this equipment correctly.
    Check itemMeasures
    SettingReattempt scanning. If the error still occurs after reattempting scanning for several times, card data may be corrupted or the card reader may be out of order.
    [6042] Card authentication: Card setting error
    Check itemMeasures
    MFP access errorSet the correct self-diagnostic code.
    [6100] User account locking out
    MFP access errorUser account is locked
    Check itemMeasures
    SettingLog into TopAccess as an administrator, and release the locked user account.
    [6101] e-Filing box locking out
    MFP access errorThe e-Filing Box became inaccessible because an incorrect password has been entered for the specified number of times.
    Check itemMeasures
    SettingRetry access after a few minutes. For the locking period, ask your administrator.
    [6102] User account being locking out
    MFP access errorFailed to login because the user account had been locked out
    Check itemMeasures
    [6103] e-Filing Box is locked out
    Check itemMeasures
    [6121] Automatic Secure Erase failure
    MFP access errorThe automatic secure erase fails.
    Check itemMeasures
    SettingData overwriting failed for some reason. If the error still occurs after rebooting the equipment, start up using the following procedure:[3] + [C] + [START]  3. HDD formatting
     Reinstallation of software or HDD replacement
    [6131] Clock skew failure to time server
    MFP access errorClock skew failure to time server
    Check itemMeasures
    SettingCheck that the time server works properly. Moreover, log into TopAccess as an administrator, and check that the SNTP setting is correct.
    [6150] Print log DB full
    MFP access errorPrint log DB full
    Check itemMeasures
    SettingPerform Clear Log with TopAccess Logs>Export Logs>Print Job Log Export.
    [6151] Print log DB near-full (95%
    MFP access errorPrint log DB near-full (95%)
    Check itemMeasures
    [6152] Print log DB near-full (90%)
    MFP access errorPrint log DB near-full (90%)
    Check itemMeasures
    [6153] Print log DB near-full (80%)
    MFP access errorPrint log DB near-full (80%)
    Check itemMeasures
    [6154] Print log database near-full (70%)
    MFP access errorPrint log DB near-full (70%)
    Check itemMeasures
    [6160] Scan log DB full
    MFP access errorScan log DB full
    Check itemMeasures
    SettingPerform Clear Log with TopAccess Logs>Export Logs>Scan Job Log Export.
    [6161] Scan log DB near-full (95%)
    MFP access errorScan log DB near-full (95%)
    Check itemMeasures
    [6162] Scan log DB near-full (90%)
    MFP access errorScan log DB near-full (90%)
    Check itemMeasures
    [6163] Scan log DB near-full (80%)
    MFP access errorScan log DB near-full (80%)
    Check itemMeasures
    [6164] Scan log DB near-full (70%)
    MFP access errorScan log DB near-full (70%)
    Check itemMeasures
    [6170] FAX transmission log DB full
    MFP access errorFAX transmission log DB full
    Check itemMeasures
    SettingPerform Clear Log with TopAccess Logs>Export Logs>Fax Transmission Journal Export.
    [6171] FAX transmission log DB near-full (95%)
    MFP access errorFAX transmission log DB near-full (95%)
    Check itemMeasures
    [6172] FAX transmission log DB near-full (90%)
    MFP access errorFAX transmission log DB near-full (90%)
    Check itemMeasures
    [6173] FAX transmission log DB near-full (80%)
    MFP access errorFAX transmission log DB near-full (80%)
    Check itemMeasures
    [6174] FAX transmission log DB near-full (70%)
    MFP access errorFAX transmission log DB near-full (70%)
    Check itemMeasures
    [6180] FAX reception log DB full
    MFP access errorFAX reception log DB full
    Check itemMeasures
    SettingPerform Clear Log with TopAccess Logs>Export Logs>Fax Reception Journal Export.
    [6181] FAX reception log DB near-full (95%)
    MFP access errorFAX reception log DB near-full (95%)
    Check itemMeasures
    [6182] FAX reception log DB near-full (90%)
    MFP access errorFAX reception log DB near-full (90%)
    Check itemMeasures
    [6183] FAX reception log DB near-full (80%)
    MFP access errorFAX reception log DB near-full (80%)
    Check itemMeasures
    [6184] FAX reception log DB near-full (70%)
    MFP access errorFAX reception log DB near-full (70%)
    Check itemMeasures
    [6190] Message log DB full
    MFP access errorMessage log DB full
    Check itemMeasures
    SettingPerform Clear Log with TopAccess Logs>Export Logs>Message Log Export.
    [6191] Message log DB near-full (95%)
    MFP access errorMessage log DB near-full (95%)
    Check itemMeasures
    [6192] Message log DB near-full (90%)
    MFP access errorMessage log DB near-full (90%)
    Check itemMeasures
    [6193] Message log DB near-full (80%)
    MFP access errorMessage log DB near-full (80%)
    Check itemMeasures
    [6194] Message log DB near-full (70%)
    MFP access errorMessage log DB near-full (70%)
    Check itemMeasures
  3. Maintenance error​
    [7101] System firmware installation failure [7103] Engine firmware installation failure [7105] Scanner firmware installation failure [7107] MEP firmware installation failure [7111] Patch installation failure
    Maintenance errorSystem firmware installation failed. ([7101]) Engine firmware installation failed. ([7103]) Scanner firmware installation failed. ([7105]) MEP firmware installation failed. ([7107]) Patch installation failed. ([7111])
    Plug-in installation failed. ([7113]) HDD data installation failed. ([7115]) DF firmware installation failed. ([7117])
    [7113] Plug-in installation failure [7115] HDD data installation failure [7117] DF firmware installation failure
    Check itemMeasures
    SettingSoftware package file may have a problem or may be corrupted. Check the software package file and then reattempt the installation.
    [7109] Printer driver update failure
    Maintenance errorPrinter driver upload failed.
    Check itemMeasures
    SettingPrinter driver file may have a problem or may be corrupted. Check the package file and then reattempt the upload.
    [710B] Point and Print data installation failure
    Maintenance errorPoint and Print data upload failed.
    Check itemMeasures
    SettingPoint and Print data may have a problem or may be corrupted. Check the package file and then reattempt the upload.
    [710F] Language Pack installation failure
    Maintenance errorLanguage Pack installation failed.
    Check itemMeasures
    SettingLanguage Pack file may have a problem or may be corrupted. Check the package file and then reattempt the installation.
    [711D] License key returning failure
    Maintenance errorThe one-time dongle license fails to be returned to USB media.
    Check itemMeasures
    SettingReturn the license to the USB media used for installing the license.
    Check that the USB media is correctly installed.
    Notes:
    The GP-1080 IPSec Enabler cannot return to the USB media due to license problem.
    The GP-1070 Overwrite Enabler cannot return to the USB media in the high security (08-8911: 3).
    [711F] License key installation failure
    Maintenance errorThe one-time dongle license fails to be installed.
    Check itemMeasures
    SettingCheck that the USB media is correctly installed.
    [7121] Unsuccessful Import of Address Book Data
    Maintenance errorThe import of Address Book data failed.
    Check itemMeasures
    SettingCheck if you are importing a valid file.
    [7123] Unsuccessful Import of Template Data
    Maintenance errorThe import of template data failed.
    Check itemMeasures
    [7125] Unsuccessful Import of MailBox Data
    Maintenance errorThe import of Mailbox data failed.
    Check itemMeasures
    [7127] Unsuccessful Import of Format File for Metascan
    Maintenance errorThe import of Meta Scan format file failed.
    Check itemMeasures
    [7129] Unsuccessful Import of User Information
    Maintenance errorThe import of user information failed.
    Check itemMeasures
    [712B] Unsuccessful Import of Role Information
    Maintenance errorThe import of role information failed.
    Check itemMeasures
    [712D] Unsuccessful Import of Department Data
    Maintenance errorThe import of department data failed.
    Check itemMeasures
    [712F] Unsuccessful Import of ICC Profile
    Maintenance errorThe import of ICC Profile failed.
    Check itemMeasures
    [7131] Failed to import Print Data Converter
    Maintenance errorThe import of Print Data Converter failed.
    Check itemMeasures
    [7132] Failed to import any users
    Maintenance errorA part of the user information was not imported.
    Check itemMeasures
    SettingThere is a possibility that the amount of user information has exceeded the maximum for registration during the import or the file contains invalid data. Check if you are importing a valid file and also that the amount of user information does not exceed the maximum.
    [7133] Failed to import any user, role and group information
    Maintenance errorA part of the user, role or group information was not imported.
    Check itemMeasures
    SettingThere is a possibility that the amount of the combined user information has exceeded the maximum for registration during the import or the file contains invalid data. Check if you are importing a valid file and also that the amount of the combined user information does not exceed the maximum.
    [7134] Department data import partial failure
    Maintenance errorA part of the department data was not imported.
    Check itemMeasures
    SettingThere is a possibility that the amount of department data has exceeded the maximum for registration during the import or the file contains invalid data. Check if you are importing a valid file and also that the amount of department data does not exceed the maximum.
    [7139] Unsuccessful Acquisition of Certificate from SCEP Server
    Maintenance errorFailed to import the certificate by SCEP
    Check itemMeasures
    SettingCheck the SCEP server and the SCEP setting (automatic) in TopAccess Administration>Security>Certificate Management.
    [713B] Unsuccessful Import of Certificate from TopAccess
    Check itemMeasures
    SettingCertificate may have a problem or be corrupted. Check the certificate and perform the job again.
    [713D] Unsuccessful Import of User Combined Data
    Maintenance errorThe import of combined user information failed.
    Check itemMeasures
    [713F] Unsuccessful Import of All Data (Template/AddressBook/MailBox)
    Maintenance errorThe import of all data (templates, Address Book, Mailbox) failed.
    Check itemMeasures
    Maintenance errorThe export of Address Book data failed.
    Check itemMeasures
    SettingCheck if there is enough capacity in the HDD and then retry the export.
    [7141] Unsuccessful Export of Address Book Data
    [7143] Unsuccessful Export of Template Data
    Maintenance errorThe export of template data failed.
    Check itemMeasures
    [7145] Unsuccessful Export of MailBox Data
    Maintenance errorThe export of Mailbox data failed.
    Check itemMeasures
    [7147] Unsuccessful Export of Format File for Metascan
    Maintenance errorThe export of a Meta Scan format file failed.
    Check itemMeasures
    [7149] Unsuccessful Export of User Information
    Maintenance errorThe export of user information failed.
    Check itemMeasures
    [714B] Unsuccessful Export of Role Information
    Maintenance errorThe export of role information failed.
    Check itemMeasures
    [714D] Unsuccessful Export of Department Information
    Maintenance errorThe export of department data failed.
    Check itemMeasures
    [714F] Unsuccessful Export of ICC Profile
    Maintenance errorThe export of ICC Profile failed.
    Check itemMeasures
    [7151] Unsuccessful Export of Log Data
    Maintenance errorThe export of log data failed.
    Check itemMeasures
    SettingCheck if there is enough capacity in the HDD and the USB media and then retry the export.
    [715B] Unsuccessful Print Data Converter
    Maintenance errorThe export of Print Data Converter failed.
    Check itemMeasures
    [715D] Unsuccessful export of User Combined Data
    Maintenance errorThe export of combined user information failed.
    Check itemMeasures
    [715F] Unsuccessful Export of All Data (Template/AddressBook/MailBox)
    Maintenance errorThe export of all data (templates, Address Book, Mailbox) failed.
    Check itemMeasures
    [7191] DDNS public key file upload failure
    Maintenance errorFailed to upload DDNS public key file
    Check itemMeasures
    SettingDDNS public key file may have a problem or be corrupted. Check the file and perform the job again.
    [7193] DDNS private key file upload failure
    Maintenance errorFailed to upload DDNS private key file
    Check itemMeasures
    SettingDDNS private key file may have a problem or be corrupted. Check the file and perform the job again.
    [71A2] Unsuccessful Addition of CA Certificate
    Maintenance errorFailed to add CA certificate
    Check itemMeasures
    SettingCA certificate may have a problem or be corrupted. Check the CA certificate and perform the job again.
    [71A4] Cryptographic key consistency confirmation failure
    Maintenance errorCryptographic key consistency confirmation failed.
    Check itemMeasures
    SettingStart up the equipment in the following procedure:[3] + [C] + [START]  5. Key Backup Restore Then overwrite the corrupted license key with a normal one.
    [71A6] Device certificate deletion failure
    Maintenance errorThe deletion of device certificate failed.
    Check itemMeasures
    SettingRestart the equipment and then retry.
    [71A8] CA certificate deletion failure
    Maintenance errorThe deletion of the CA certificate failed.
    Check itemMeasures
    [71AA] Unidentified error during certificate acquisition from SCEP server
    Maintenance errorUnidentified error occurred during certificate acquisition from SCEP server.
    Check itemMeasures
    SettingCheck SCEP server and the SCEP setting (automatic) on the TopAccess screen as follows: TopAccess Administration  Security  Certificate Management
    [71AB] Timeout error during certificate acquisition from SCEP server
    Maintenance errorTimeout error occurred during certificate acquisition from SCEP server.
    Check itemMeasures
    SettingCheck SCEP server and the SCEP setting (automatic) on the TopAccess screen in the following procedure: TopAccess Administration  Security  Certificate Management
    [71AC] File save error during certificate acquisition from SCEP server
    Maintenance errorFile save error occurred during certificate acquisition from SCEP server.
    Check itemMeasures
    SettingFile saving failed for some reason. If the error still occurs after rebooting the equipment, start up using the following procedure:[3] + [C] + [START]  3. HDD formatting  Reinstallation of software or HDD replacement
    [71AD] Failed SCEP operation
    Maintenance errorSCEP operation is failed
    Check itemMeasures
    SettingCheck SCEP server and the SCEP setting on the TopAccess menu as follows:
    [Administration] > [Security] > [Certificate Management] > SCEP (Automatic)
    [71B0] Software package file decryption failure
    Maintenance errorSoftware package file decryption failed.
    Check itemMeasures
    [71D0] Factory Default Failure
    Maintenance errorFactory default setting failed.
    Check itemMeasures
    [71F1] Unsuccessful Creation of Clone File
    Maintenance errorThe creation of a clone file failed.
    Check itemMeasures
    SettingCheck if there is enough capacity in the HDD and the USB media and then retry the creation.
    [71F3] Unsuccessful Import of Clone Data
    Maintenance errorThe import of clone data failed.
    Check itemMeasures
    SettingThe clone file may be invalid. Check the file and then retry the import.
    [71F4] Failed to decrypt Clone file
    Maintenance errorThe decryption of a clone file failed.
    Check itemMeasures
    SettingThe clone file may be invalid or the password may be incorrect. Check the file and the password, and then retry the import.
    [71F5] Failed to encrypt Clone file
    Maintenance errorThe encryption of a clone file failed.
    Check itemMeasures
    SettingRestart the equipment and then retry the encryption.
  4. Network error​
[8000] Static IPv4 address conflict
Network errorIPv4 address overlaps.
Check itemMeasures
SettingCheck if the same IP address is not used by other machine.
[8011] Linklocal Address Conflict
Network errorLinklocal Address Conflict
Check itemMeasures
[8012] Manual Address Conflict
Network errorManual IPv6 Address Conflict
Check itemMeasures
[8013] Stateless Address Conflict
Network errorStateless Address Conflict
Check itemMeasures
[8014] Stateful Address Conflict
Network errorStateful Address Conflict
Check itemMeasures
[8022] Authentication Failure
Network errorFailed in 802.1X authentication.
Check itemMeasures
SettingCheck the user credential.
[8023] Can not contact Authentication Server/Switch
Network errorFailed in connection to authentication server and switch.
Check itemMeasures
SettingCheck connectivity to switch or server.
[8024] Certificate verification Failure
Network errorFailed in verification of certificate.
Check itemMeasures
SettingCheck if a valid certificate is installed.
[8031] IKEv1 certification failed
Network errorIpsec error for ikev1 certification failed
Check itemMeasures
SettingCheck
  1. CA and user certificate in both MFP and remote peer - certificate timestamp and IPsec Certificate template should be valid.
  2. CRL DP server name is mapped in MFP’s host table or DNS entry.
  3. Certificate against CRL.
[8032] IKEv1 wrong proposal chosen
Network errorIpsec error for wrong proposal chosen
Check itemMeasures
SettingCheck the IKEv1 IPsec proposal parameters (like encryption/ authentication algorithms, DH group, authentication methods) in MFP and peer machine.
[8033] IKEv1 shared key authentication failed
Network errorIpsec error if auth for shared key failed
Check itemMeasures
SettingMismatch in IKEv1 Pre Shared Key. Check the PSK in MFP and remote machine.
[8034] IKEv1 invalid certificate
Network errorIpsec error if invalid certificate uploaded
Check itemMeasures
SettingCheck the CA and User certificate in MFP and peer machine.
[8035] IKEv1 certificate not supported
Network errorIpsec error if certificate not supported
Check itemMeasures
SettingCheck the User certificate type.
[8036] IKEv1 invalid certificate authentication
Network errorIpsec error if invalid certificate authentication
Check itemMeasures
SettingCheck the CA certificate in MFP and Peer machine.
[8037] IKEv1 certificate unavailable
Network errorIpsec error if certificate are not available
Check itemMeasures
SettingCertificate has been deleted from Certificate store. Re-upload the corresponding certificates.
[8038] IKEv1 no SA established
Network errorIpsec error for SA is not present
Check itemMeasures
SettingCheck the IKEv1/IPsec proposal parameters (like encryption/ authentication algorithms, DH group, authentication methods) in MFP and peer machine.
Check
1. CA and user certificate in both MFP and remote peer - certificate timestamp and IPsec Certificate template.
[8039] IKEv1 invalid signature
Network errorIpsec error for invalid signature for certificate
Check itemMeasures
SettingMismatch in Signature payload (MAC or IV).
Check the CA and user certificate in MFP and peer machine.
[803A] IKEv2 wrong proposal chosen
Network errorIpsec error if proposal chosen is wrong
Check itemMeasures
SettingCheck the IKEv2/IPsec proposal parameters (encryption/ authentication algorithms, DH group, authentication methods) in MFP and peer machine.
[803B] IKEv2 Certificate failed
Network errorIpsec error for ikev2 certification failed
Check itemMeasures
SettingCheck
[803C] IKEv2 secret key authentication failed
Network errorIpsec error for ikev2 if secret key auth failed
Check itemMeasures
SettingMismatch in IKEv2 Pre Shared Key. Check the PSK in MFP and peer machine.
[803D] IKEv2 falling back to IKEv1
Network errorIpsec error if peer does not support IKEv2 and falling back to IKEv1
Check itemMeasures
SettingRemote machine is not supporting IKEv2. Going back to use IKEv1.
[803E] IKEv2 ISAKMP SA unavailable
Network errorIpsec error if ISAKMP SA is not created of destroyed due to some uncertain condition
Check itemMeasures
SettingRestart IPsec service on Peer and retry.
[803F] IKEv2 cryptographic operation failed
Network errorIpsec error for ikev2 if crypto operation failed
Check itemMeasures
SettingIf Certificates are being used, re-upload the corresponding certificates using Security Services. Restart IPsec Service on MFP.
[8040] IKEv2 invalid key information
Network errorIpsec error for ikev2 if key info is invalid
Check itemMeasures
SettingCheck IKE settings in MFP and peer.
[8041] IKEv2 CA not trusted
Network errorIpsec error for ikev2 if CA is not trusted
Check itemMeasures
SettingCheck the CA certificate in MFP and peer machine. Check the CA certificate timestamp.
[8042] IKEv2 Authentication method mismatch
Network errorIpsec error if authentication method is not matching
Check itemMeasures
SettingMismatch in IKE authentication type.
Check the Authentication type in MFP and peer.
[8043] IPsec IKE version mismatch
Network errorIpsec error if ike version is not matching
Check itemMeasures
SettingMismatch in IKE version.
Check the IKE version in MFP and peer.
[8044] IPsec encapsulation mismatch
Network errorIpsec error for encapsulation is not matching
Check itemMeasures
SettingCheck the IPsec mode (Transport/Tunnel) in MFP and peer.
[8045] IPsec Peer IP mismatch
Network errorIpsec error for peer ip mismatch
Check itemMeasures
SettingRemote Traffic selector mismatch.
Check the destination address/port in IPsec filter.
[8046] IPsec local IP mismatch
Network errorIpsec error for local ip mismatch
Check itemMeasures
SettingLocal traffic selector mismatch.
Check the source address/port in IPsec filter.
[8047] IPsec local ID mismatch
Network errorIpsec error for local id mismatch
Check itemMeasures
SettingCheck the user certificate in MFP
[8048] IPsec Remote ID mismatch
Network errorIpsec error for remote id mismatch
Check itemMeasures
SettingCheck the user certificate in peer machine.
[8049] IPsec Remote IP mismatch
Network errorIpsec error for remote ip mismatch
Check itemMeasures
SettingRemote traffic selector mismatch.
[804A] IPsec IKE timeout
Network errorIpsec error for ike timeout
Check itemMeasures
SettingCheck the network connectivity between MFP and peer machine.
Select the Flush Connections Option and retry.
[804B] IPSec invalid manual key
Network errorIpsec error id manual key is not valid
Check itemMeasures
SettingCheck the Inbound and Outbound (ESP Encryption/ Authentication and AH Authentication) keys in MFP and Remote PC.
[8061] Secure primary DDNS update error [8062] Secure secondary DDNS update error [8063] IPv6 Secure primary DDNS update error
[8064] IPv6 Secure secondary DDNS update error [8065] IPv6 primary DDNS update error
[8066] IPv6 secondary DDNS update error [8067] IPv4 primary DDNS update error [8068] IPv4 secondary DDNS update error
Network errorSecure update to primary IPv4 server failed. ([8061]) Secure update to secondary IPv4 server failed. ([8062]) Secure update to primary IPv6 server failed. ([8063]) Secure update to secondary IPv6 server failed. ([8064]) IPv6 primary DDNS update error. ([8065])
IPv6 secondary DDNS update error. ([8066]) IPv4 primary DDNS update error. ([8067]) IPv4 secondary DDNS update error. ([8068])
Check itemMeasures
SettingCheck if there is any problem with DNS or DDNS settings.
[8069] Invalid TSIG/SIG(0) Key file
Network errorThis message is displayed when the key file for SIG(0) or TSIG is invalid.
Check itemMeasures
SettingVerify the TSIG/SIG(0) key files used.
[8101] Wireless association with Access point failure
Network errorWireless association with Access point failure
Check itemMeasures
SettingVerify the credentials used for association with Access point.
[8102] MFP not able to contact the Access point with the specified SSID
Network errorMFP not able to contact the Access point with the specified SSID
Check itemMeasures
SettingVerify the access point name setting and mechanism used for association same as Access Point setting.
[8103] Wireless Certificate verification failure
Network errorWireless Certificate verification failure
Check itemMeasures
SettingVerify the certificate settings used for association.
[8111] SNMP writing access failure
Network errorAn error occurred during SNMP data writing.
Check itemMeasures
SettingCheck if the parameter entered in the application is correct. Check if the entered department code and box password are correct.
If the error still occurs after the correct parameter is entered, restart the equipment and the application.
[8112] SNMP communication failure
Network errorSNMP communication failed.
Check itemMeasures
SettingCheck if there is any problem in the application.
[8121] Domain authentication error: Domain authentication error
Network errorAn unidentified domain authentication error occurred during the connection of domain controller.
Check itemMeasures
SettingCheck the network configuration of this equipment and then reconnect to the domain controller.
[8122] Domain authentication error: Invalid user name or password
Network errorLogin is not permitted because the user name or a password for domain authentication is invalid.
Check itemMeasures
SettingCheck if the user name and the password for this equipment are correct. Specify upper- and lower-case characters correctly when you enter them.
[8123] Domain authentication error: Invalid server
Network errorThe server was not discovered during domain authentication.
Check itemMeasures
SettingCheck if the server is down or the network configuration of this equipment is correct. If domain name resolution is used, check the DNS and DDNS settings.
[8124] Domain authentication error: Invalid user account
Network errorThe user account is invalid and not available for login for domain authentication
Check itemMeasures
SettingCheck the setting to see if the user account noted in the Active Directory Users and Computers window is valid.
[8125] Domain authentication error: Expired user account
Network errorThe user account is expired and not available for login for domain authentication.
Check itemMeasures
SettingCheck the setting to see if the user account noted in the Active Directory Users and Computers window is not expired.
[8126] Domain authentication error: User account lockout
Network errorThe user account is locked out and not available for login for domain authentication.
Check itemMeasures
SettingCheck the account lockout setting of the server.
[8127] Domain authentication error: Invalid logon hours
Network errorThe logon hour is invalid and not available for login for domain
authentication.
Check itemMeasures
SettingCheck the logon hour setting for the user account noted in the Active Directory Users and Computers window.
[8128] Active Directory domain authentication error: Time delay between server and equipment
Network errorThere is a difference of 5 minutes or longer between the time settings of this equipment and the server, and therefore the login is not available for Active Directory domain authentication.
Check itemMeasures
SettingSet the time of this equipment and that of the domain controller the same. SNTP is recommended if there is an SNTP server in the network.
[8129] Active Directory domain authentication error: Expired Kerberos ticket
Network errorThe Kerberos ticket is expired and not available for login for Active Directory domain authentication.
Check itemMeasures
SettingCheck if the Kerberos ticket on the Kerberos server is expired.
[812A] Active Directory domain authentication error: Kerberos ticket authentication error
Network errorLogin is not available for Active Directory domain authentication due to a Kerberos ticket authentication error.
Check itemMeasures
SettingCheck if the user name and the password for this equipment are correct. If the error still occurs, ask your Windows Server administrator.
[812B] Active Directory domain authentication error: invalid realm name
Network errorThe realm name is invalid and not available for login for Active Directory domain authentication.
Check itemMeasures
SettingCheck if the realm name of this equipment for the Active Directory server is correct. If the error still occurs, ask your Windows Server administrator.
Output check (test mode 03)​
CodeFunctionProcedure
101Main motor ON (operational without developer unit)1
102Toner motor ON (normal rotation)1
103Polygonal motor ON (600 dpi)1
108Registration clutch ON1
109PFP motor ON1
110ADU motor ON (low speed)1
118Laser ON1
120Exit motor ON (normal rotation)1
121Exit motor ON (reverse rotation)1
122LCF motor ON1
123Reverse motor ON (normal rotation) * e-STUDIO356/456 only1
124Reverse motor ON (reverse rotation) * e-STUDIO356/456 only1
151Code No. 101 function OFF1
152Code No. 102 function OFF1
153Code No. 103 function OFF1
158Code No. 108 function OFF1
159Code No. 109 function OFF1
160Code No. 110 function OFF1
168Code No. 118 function OFF1
170Code No. 120 function OFF1
171Code No. 121 function OFF1
172Code No. 122 function OFF1
173Code No. 123 function OFF1
174Code No. 124 function OFF1
177Offset Tray motor ON (reciprocating movement)2
201Upper drawer feed clutch ON/OFF3
202Lower drawer feed clutch ON/OFF3
203Transport clutch (high speed) ON/OFF3
204Bypass feed clutch ON/OFF3
205Transport clutch (low speed) ON/OFF3
206LCF pickup solenoid ON/OFF3
207
LCF end fence reciprocating movement
This function is disabled in the following conditions.
  • When the LCF tray is up.
  • When the left drawer is not inserted.
  • When the LCF misfeed insertion detection sensor is incorrectly inserted.
209LCF feed clutch ON/OFF3
218Key copy counter count up2
222ADU clutch ON/OFF3
225PFP transport clutch ON/OFF3
226PFP upper drawer feed clutch ON/OFF3
228PFP lower drawer feed clutch ON/OFF3
232Bridge unit gate solenoid ON/OFF3
233Reverse solenoid ON/OFF * e-STUDIO356/456 only3
235Discharge lamp ON/OFF3
236Suction fan ON/OFF (low speed)3
237Suction fan ON/OFF (high speed)3
242Upper drawer tray-up motor ON (tray up)2
243Lower drawer tray-up motor ON (tray up)2
249Developer bias [-DC] ON/OFF3
250Developer bias [AC] ON/OFF3
252Main charger ON/OFF3
253Separation charger ON/OFF3
255Transfer guide bias ON/OFF3
256Transfer charger (positive/center) ON/OFF3
257Transfer charger (positive/high) ON/OFF3
258Transfer charger (negative) ON/OFF3
261Scan motor ON (Automatically stops at limit position; speed
can be changed with the [ZOOM] button
267Scanner exposure lamp ON/OFF3
271LCF tray-up motor (up/down)2
278PFP upper drawer tray-up motor ON (tray up)2
280PFP lower drawer tray-up motor ON (tray up)2
281RADF feed motor ON/OFF (normal rotation)3
282RADF feed motor ON/OFF (reverse rotation)3
283RADF read motor ON/OFF (normal rotation)3
284RADF exit motor ON/OFF (normal rotation)3
285RADF exit motor ON/OFF (reverse rotation)3
289Developer cooling fan ON/OFF (high speed)3
290Developer cooling fan ON/OFF (low speed)3
294Reverse gate solenoid ON/OFF3
295Power OFF mode (for 200 V series)4
297RADF fan motor ON/OFF3
301Modem test 2100Hz2
302Modem test 14.4KBPS (V17)2
303Modem test 9.6KBPS (V29)2
304Modem test 4.8KBPS (V27)2
305Modem test 300BPS2
306Modem test 1850Hz2
307Modem test 1650Hz2
308Modem test 1100Hz2
309Modem test 462Hz2
310Modem test 1300Hz2
311Modem test 33.6KBPS (V.34)2
312Modem test 28.8KBPS (V.34)2
313Modem test 24.0KBPS (V.34)2
314Modem test 16.8KBPS (V.34)2
315Dial test 10PPS5
316Dial test 20PPS5
317Dial test PB5
318Modem test 12.0KBPS (V.17)2
319Modem test 7.2KBPS (V.29)2
320Modem test 2.4KBPS (V.27ter)2
322CML relay ON2
410Power supply cooling fan ON/OFF (low speed)3
411Power supply cooling fan ON/OFF (high speed)3
461Return the Finisher condition to packaging position2
Test print mode (test mode 04)​
CodeTypes of test patternRemarksRemarksOutput from
114Secondary scanning direction 17 gradationError diffusion1SLG
142Grid patternPattern width: 2 dots,1LGC
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeProcessDeveloperAutomatic adjustment of auto-toner sensor2000Fuser heater ON--As the value increases, the sensor output increases correspondingly. The value starts changing approx. 2 minutes after this adjustment was started and is automatically set in the range of 2.35 to 2.45 V.
* Selection is disable when developer unit is not installed.
17Yes
05Adjustmen t modeProcessDeveloperCorrection of auto- toner sensor2001Fuser heater ON1410~255MCorrects the control value of the auto-toner sensor setup in 05-2000.
3Yes
05Adjustmen t modeProcessDeveloper2020Developer bias DC output adjustment1410~255MAs the value increases, the transformer output increases correspondingly. Remove the developer unit and install the adjustment jig to make adjustment.3Yes
05Adjustmen t modeProcessCharger2040Main charger grid bias output adjustmentRefer to contents0~255MAs the value increases, the transformer output increases correspondingly. Remove the developer unit and install the adjustment jig to make adjustment.
<Default value>
e-STUDIO206L/256/306: 90
e-STUDIO356/456/506: 95
05Adjustmen t modeProcessTransfer2052Transfer transformer DC output adjustment (C)Refer to contents0~255MAs the value increases, the transformer output increases correspondingly. Remove the developer unit and install the adjustment jig to make adjustment.
<Default value>
e-STUDIO206L/256/306: 88
e-STUDIO356/456/506: 117
05Adjustmen t modeProcessSeparation2078Separation transformer DC output adjustment (C)520~255MAs the value increases, the transformer output increases correspondingly. Remove the developer unit and install the adjustment jig to make adjustment.3
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeProcessTransferTransfer cleaning bias adjustment2083PositiveRefer to contents0~255MWhen the high-voltage transformer is replaced, the transfer cleaning bias needs to be adjusted with this code. The larger the setting value is, the higher the value of the current (more positive) is. This causes a reduction in the toner adhering to the transfer roller and an improvement in the cleaning performance. Perform this adjustment after the process units (cleaner and developer unit) have been removed. When the high- voltage transformer is replaced, adjusting with the following codes needs to be performed in addition to this adjustment.
05-2020, 05-2040, 05-2052, 05-2078
<Default value>
e-STUDIO206L/256/306: 63
e-STUDIO356/456/506: 96
3Yes
05Adjustmen t modeProcessTransferTransfer cleaning bias adjustment2084Negative410~255MWhen the high-voltage transformer is replaced, the transfer cleaning bias needs to be adjusted with this code. The larger the setting value is, the higher the value of the current (more negative) is. This causes a reduction in the toner adhering to the transfer roller and an improvement in the cleaning performance. Perform this adjustment after the process units (cleaner and developer unit) have been removed. When the high- voltage transformer is replaced, adjusting with the following codes need to be performed in addition to this adjustment.
3Yes
05Adjustmen t modeProcessTransferTemperature/humidity sensor2192Humidity display500~100MDisplays the humidity value detected by temperature/humidity sensor.2Yes
05Adjustmen t modeProcessProcessTemperature/humidity sensor2194Temperature display250~50MDisplays the humidity value detected by temperature/humidity sensor.2Yes
05Adjustmen t modeProcessCharger2196Drum thermistor
temperature display (K)
250~100M(Unit: °C)2Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeProcessImage quality control2250Laser power adjustmentRefer to contents0~255MWhen the value increases, the laser output increases correspondingly.
<Default value>
e-STUDIO206L/256/306: 65
e-STUDIO356/456/506: 121
3Yes
05Adjustmen t modeProcessProcess2382Reverse time of the drumRefer to contents0~255M<Default value>
e-STUDIO206L/256/306: 12
e-STUDIO356/456/506: 8
05Adjustmen t modeProcessToner recycle2390Forced performing of idling-MPerform this adjustment before the replacement of the developer material. (The toner is forcibly removed from the cleaner.)6Yes
05Adjustmen t modeScannerScanner3009Log table switching for RADF copying (color)00~4SYS0: Same log table as the one used at copying with original glass
1: Background reproduction - Light 2
2: Background reproduction - Light 1
3: Background reproduction - Dark 1
4: Background reproduction - Dark 2
05Adjustmen t modeScannerScannerImage location adjustment3030Primary scanning
direction (scan. section)
750~255SYSWhen the value increases by "1", the image shifts by approx. 0.04233 mm toward the front side of the paper.1Yes
05Adjustmen t modeScannerScannerImage location adjustment3031Secondary scanning direction(scan.section
13090~166SYSWhen the value increases by "1", the image shifts by
approx. 0.13013 mm toward the trailing edge of the paper.
1Yes
05Adjustmen t modeScannerScannerReproduction ratio adjustment3032Adj. secondary scan.direction12863~193SYSWhen the value increases by "1", the reproduction ratio in the secondary scanning direction (vertical to paper feeding direction) increases by approx. 0.025 %.1Yes
05Adjustmen t modeScannerScannerDistortion mode3033Distortion mode--Moves carriages to the adjusting position.6Yes
05Adjustmen t modeScannerScannerShading position adjustment3034Original glass11792~165SYS0.13013 mm/step1
05Adjustmen t modeScannerScannerShading position adjustment3035RADF13392~165SYS0.13013 mm/step1
05Adjustmen t modeScannerRADFAdjustment of RADF paper alignment3040Front side100~20SYSWhen the value increases by "1", the aligning amount increases by approx. 0.5 mm.1
05Adjustmen t modeScannerRADFAdjustment of RADF paper alignment3041Back side100~20SYSWhen the value increases by "1", the aligning amount increases by approx. 0.5 mm.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeScannerRADF3042Fine adjustment of RADF transport speed500~100SYSWhen the value increases by "1", the reproduction ratio of the secondary scanning direction when using the RADF increases by approx. 0.1%.1Yes
05Adjustmen t modeScannerRADF3043RADF sideways deviation adjustment1280~255SYSWhen the value increases by "1", the image of original fed from the RADF shifts toward the rear side of paper by approx. 0.08423 mm.1Yes
05Adjustmen t modeScannerRADFRADF leading edge position adjustment3044Front side500~100SYSWhen the value increases by "1", the copied image of original fed from the RADF shifts toward the trailing edge of paper by approx.0.2 mm.1Yes
05Adjustmen t modeScannerRADFLeading edge position adjustment3045Back side500~100SYSWhen the value increases by "1", the copied image of original fed from the RADF shifts toward the trailing edge of paper by approx.0.2 mm.1Yes
05Adjustmen t modeScannerScanner3046Carriage position adjustment during scanning from RADF (black)1280~255SYSWhen the value increases by "1", the carriage position shifts by approx. 0.1 mm toward the exit side when using the RADF.1
05Adjustmen t modeScannerScanner3047Carriage position adjustment during scanning from RADF (color)1280~255SYSWhen the value increases by "1", the carriage position shifts by approx. 0.1 mm toward the exit side when using the RADF.1
05Adjustmen t modeScannerScannerData transfer of characteristic value3203SLG board -> SYS board-SYSTransfers the characteristic values of the scanner (shading correction factor / RGB color correction / reproduction ratio color deviation correction / shading position correction factor / reproduction ratio correction value in primary scanning direction)6Yes
05Adjustmen t modeScannerScanner3209Data transfer of characteristic value of scanner / SYS board -
> SLG board
-SYSTransfers the characteristic values of the scanner (shading correction factor / RGB color correction / reproduction ratio color aberration correction / shading position correction factor / reproduction ratio correction value in primary scanning direction)6
05Adjustmen t modePrinterPrinterFine adjustment of polygonal motor rotation speedAdjustment of primary scanning direction reproduction ratio4000PPC1300~255MWhen the value increases by "1", the reproduction ratio of primary scanning direction increases by approx.
0.07%. (approx. 0.1 mm/step)
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterPrinterFine adjustment of polygonal motor rotation speedAdjustment of primary scanning direction reproduction ratio4001PRT1330~255MWhen the value increases by "1", the reproduction ratio of primary scanning direction increases by approx.
1Yes
05Adjustmen t modePrinterImageAdjustment of primary scanning laser writing start position.4005PPCRefer to contents0~255MWhen the value increases by "1", the writing start position shifts to the front side by approx. 0.0423 mm.
<Default value>
e-STUDIO356/456/506: 99
1Yes
05Adjustmen t modePrinterImageAdjustment of primary scanning laser writing start position.4006PRTRefer to contents0~255MWhen the value increases by "1", the writing start position shifts to the front side by approx. 0.0423 mm.
<Default value>
1Yes
05Adjustmen t modePrinterDriveFine adjustment of main motor speedAdjustment of secondary scanning direction reproduction ratio4009PPC/PRT1320~255MWhen the value increases by "1", the reproduction ratio of secondary scanning direction increases by approx. 0.04%.1Yes
05Adjustmen t modePrinterDriveFine adjustment of main motor speedAdjustment of secondary scanning direction reproduction ratio4010FAX1280~255MWhen the value increases by "1", the reproduction ratio of secondary scanning direction increases by approx. 0.04%.1Yes
05Adjustmen t modePrinterDriveFine adjustment of exit motor speed4013PPC/PRT1280~255Me-STUDIO206L/256/306: When the value increases by "1", the rotation accelerates by approx. 0.03%.
e-STUDIO356/456/506: When the value increases by "1", the rotation accelerates by approx. 0.05%.
1Yes
05Adjustmen t modePrinterDriveFine adjustment of exit motor speed4014FAX1280~255Me-STUDIO206L/256/306:When the value increases by "1", the rotation accelerates by approx. 0.03%.
e-STUDIO356/456/506:When the value increases by "1", the rotation accelerates by approx. 0.05%.
1Yes
05Adjustmen t modePrinterImageAdj. of drawer sideways deviation401801st drawer1280~255MWhen the value increases by "1", the image shifts toward the front side by 0.0423 mm.4Yes
05Adjustmen t modePrinterImageAdj. of drawer sideways deviation401812nd drawer1280~255MWhen the value increases by "1", the image shifts toward the front side by 0.0423 mm.4Yes
05Adjustmen t modePrinterImageAdj. of drawer sideways deviation40182PFP upper drawer1280~255MWhen the value increases by "1", the image shifts toward the front side by 0.0423 mm.4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterImageAdj. of drawer sideways deviation40183PFP lower drawer1280~255MWhen the value increases by "1", the image shifts toward the front side by 0.0423 mm.4Yes
05Adjustmen t modePrinterImageAdj. of drawer sideways deviation40184T-LCF1280~255MWhen the value increases by "1", the image shifts toward the front side by 0.0423 mm.4Yes
05Adjustmen t modePrinterImageAdj. of drawer sideways deviation40185Bypass feeding1280~255MWhen the value increases by "1", the image shifts toward the front side by 0.0423 mm.4Yes
05Adjustmen t modePrinterImageAdj. of primary scan. laser writing startDuplex feeding40190Long size1480~255MWhen the value increases by "1", the image shifts toward the front side by 0.0423 mm.4Yes
05Adjustmen t modePrinterImageAdj. of primary scan. laser writing startDuplex feeding40191Short size1480~255MWhen the value increases by "1", the image shifts toward the front side by 0.0423 mm.4Yes
05Adjustmen t modePrinterImageMargin adjustmentPPC4050Top margin adjustment150~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.1Yes
05Adjustmen t modePrinterImage4051Left margin adjustment(blank area at the left of the paper along the paper feeding direction)00~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.1
05Adjustmen t modePrinterImageMargin adjustmentPPC4052Right margin adjustmentRefer to contents0~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.
<Default value>
e-STUDIO356/456/506: 24
1Yes
05Adjustmen t modePrinterImageMargin adjustmentPPC4053Bottom margin adjustment550~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.1Yes
05Adjustmen t modePrinterImage4054Top margin adjustment(blank area at the leading edge of the paper)240~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.1
05Adjustmen t modePrinterImage4055Left margin adjustment(blank area at the left of the paper along the paper feeding direction)00~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterImage4056Right margin adjustment(blank area at the right of the paper along the paper feeding direction)00~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.1
05Adjustmen t modePrinterImage4057Bottom margin adjustment(blank area at the trailing edge of the paper)00~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.1
05Adjustmen t modePrinterImageLeading edge position adjustmentNormal speed40581st drawer60~15MWhen the value increases by "1", the image shifts
toward the trailing edge of the paper by approx. 0.4 mm.
1Yes
05Adjustmen t modePrinterImageLeading edge position adjustmentNormal speed40592nd drawerRefer to contents0~40MWhen the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4 mm.
<Default value>
e-STUDIO206L/256/306: 20
e-STUDIO356/456/506: 27
1Yes
05Adjustmen t modePrinterImageLeading edge position adjustmentNormal speed4060PFP80~15MWhen the value increases by "1", the image shifts
1Yes
05Adjustmen t modePrinterImageLeading edge position adjustmentNormal speed4061Bypass feedingRefer to contents0~15MWhen the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4 mm.
<Default value>
e-STUDIO206L/256/306: 7
1Yes
05Adjustmen t modePrinterImageLeading edge position adjustmentNormal speed4062Duplex feeding80~15MWhen the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4
mm.
1Yes
05Adjustmen t modePrinterImageLeading edge position adjustmentNormal speed4063O-LCF80~15MWhen the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4
mm.
1Yes
05Adjustmen t modePrinterImage40640Bottom margin adjustment (blank area at the trailing edge of the paper)/Reverse side at duplexing290~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modePrinterImage40641Right margin adjustment (blank area at the right of the paper along the paper feeding direction)/Reverse side at duplexing00~255MWhen the value increases by "1", the blank area becomes wider by approx. 0.0423 mm.4
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment1st drawer41000Plain paper; Long sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter
<Default value>
e-STUDIO206L/256/306: 37
e-STUDIO356/456: 21
e-STUDIO506: 17
4Yes
05Adjustmen t modePrinterFeeding system/Pa per transportPaper aligning amount adjustment1st drawer41001Plain paper; Middle sizeRefer to contents0~63Me-STUDIO206L/256/306:When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO356/456/506:When the value increases by “1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 21
e-STUDIO506: 17
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenPrinterFeedingPaper aligning1st drawer41002Plain paper; ShortRefer to0~63Me-STUDIO206L/256/306:When the value increases by4Yes
t modesystem/Paamount adjustmentsize1contents“1”, the aligning amount increases by approx. 0.3 mm.
pere-STUDIO356/456/506:When the value increases by
transport“1”, the aligning amount increases by approx. 0.4 mm.
<Paper length>
<Default value>
e-STUDIO356/456: 21
e-STUDIO506: 17
05AdjustmenPrinterFeedingPaper aligning2nd drawer41010Plain paper; LongRefer to0~63Me-STUDIO206L/256/306:When the value increases by4
t modesystem/Paamount adjustmentsizecontents“1”, the aligning amount increases by approx. 0.3 mm.
<Paper length>
<Default value>
e-STUDIO206L/256/306: 30
e-STUDIO356/456: 15
e-STUDIO506: 9
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenPrinterFeedingPaper aligning2nd drawer41011Plain paper; MiddleRefer to0~63Me-STUDIO206L/256/306:When the value increases by4
<Paper length>
<Default value>
e-STUDIO206L/256/306: 28
e-STUDIO356/456: 15
e-STUDIO506: 9
05AdjustmenPrinterFeedingPaper aligning2nd drawer41012Plain paper; ShortRefer to0~63Me-STUDIO206L/256/306:When the value increases by4
<Paper length>
<Default value>
e-STUDIO206L/256/306: 25
e-STUDIO356/456: 14
e-STUDIO506: 9
