other than F106_0 to 5 errors
[F109_0] Key consistency error (Consistency check operation error)
[F109_2] Key consistency error (Signature Check public key damage)
Take measures given in the following table according to the messages displayed in the SRAM Key Status and FROM Key Status fields.
Remarks:
If the error is not cleared, reinstallation of the OS data, master data and application is needed.
[TD]AccessFailed[/TD]
[TD]*[/TD]
[TD]Replace the SYS board.
P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board" (for the SYS board, all steps)[/TD]
[TD]OK[/TD]
[TD]KeyNull/ KeyBroken[/TD]
[TD]Recover the encryption key on the SYS board.
P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board" ([E]Restore encryption key)[/TD]
[TD]OK[/TD]
[TD]Replace the SRAM board (for the SYS board).
P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board" (all steps)[/TD]
[TD]OK[/TD]
[TD]Recover the encryption key on the SRAM board.
P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board" (for the SYS board, [H]Backup encryption key)[/TD]
* AccessFailed, KeyNull or KeyBroken
[F109_4] Key consistency error (license data damage)
Remarks:
[TD]*[/TD]
* AccessFailed or KeyMismatch
[F109_5] Key consistency error (encryption key for ADI-HDD is damaged)
Remarks:
If the error is not cleared, reinstallation of the system firmware, system software and application is needed. ([4]+[9] Power-ON)
[TD]*[/TD]
[TD]OK[/TD]
[TD]Recover the ADI key on the SYS board.
P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board" ([D]Restore ADI key)[/TD]
e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507 © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved ERROR CODE AND TROUBLESHOOTING
[TD]KeyMismatch[/TD]
[TD]<The error occurs when the SYS board is replaced> Recover the encryption key on the SYS board. (Transfer the license from SYS-SRAM to SYS-FROM.)
P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board"([D]Restore ADI key)
<The error occurs except when the SYS board is replaced> Recover the encryption key on the SRAM board. (Transfer the license from SYS-FROM to SYS-SRAM.)
P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board"([G]Backup ADI key)[/TD]
© 2011-2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507
[F109_6] Key consistency error (administrator password error for ADI-HDD authentication)
Remarks:
[TD]*[/TD]
[TD]OK[/TD]
[TD]OK[/TD]
P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board" ([G]Backup ADI key)[/TD]
[F120] Database abnormality
[F122] Database abnormality (message/job log management database)
[F130] Invalid MAC address
[F131] Error due to damage to filtering setting file
[F140] ASIC format error
[F200] Data Overwrite option (GP-1070) disabled
[F500] HD partition damage
[F510] Application start error
[F521] Integrity check error
[F550] Encryption partition error
[F600] F/W update error
[F800] Date error
[F901_1] Engine speed error (second time or later)
[4011] Print job cancellation
[4021] Print job power failure
[4030] No printer kit/Invalid
[4031] HDD full error
[4032] Private-print-only error
[4033] Printing data storing limitation error
[4034] e-Filing storing limitation error
[4035] Local file storing limitation error
[4037] Hardcopy security printing error
[4038] Restriction error (only for hold print jobs)
[4039] Restriction error (only for private/hold print jobs)
[4040] Not being authorized to perform JOB
Classification | Error item |
Other service call | ADI-HDD error: Error caused by reason other than F106_0 to 5 errors |
Check item | Measures |
Setting | Perform [3]+[C]+[POWER]-> [3.Format HDD], and then install the system software by performing [4]+[9]+[POWER]-> [4.System Software(HD data)]. Notes: The following items will be deleted by performing [3]+[C]+[POWER]-> [3.Format HDD].
Classification | Contents |
Other service call | Key consistency error - Key consistency check on each key data fails. |
Check Item | Measure |
Setting | Reboot the equipment. If it cannot be recovered, reinstall the software in the following procedure.
P. 9-19 "9.3.3 Precautions and procedures when replacing the HDD" [E] Replace / Format HDD (Step (3) and later in [E] Replace / Format HDD) |
SRAM board |
P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board" |
Other service call | Key consistency error - AES key data used for SRAM encryption are damaged. |
Setting | Reboot the equipment. If it cannot be recovered, reinstall the software in the following procedure. (1) Install the OS data. P. 11-15 "11.2.3 Update procedure" |
Other service call | Key consistency error - Public key data used for Integrity Check are damaged. |
Other service call | Key consistency error - Parameter used for HDD partition encryption are damaged. |
Encryption key status confirmation | Check the message displayed by [3] + [C] + [START] 5. Key Backup Restore. |
Remarks:
SRAM Key Status | FROM Key Status | Measure |
* | AccessFailed | Replace the SYS board. P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board" (all steps) <With USB backup data: All key data recovery>
[TD]*[/TD]
[TD]OK[/TD]
[TD]OK[/TD]
[TD]OK[/TD]
KeyNull/ KeyBroken | KeyNull/ KeyBroken | <No USB backup data> 1. Reinstall the system software. P. 11-11 "11.2 Firmware Updating with USB Media" <With USB backup data: All key data recovery>
Other service call | Key consistency error - The license data are damaged. |
Remarks:
SRAM Licence Status | FROM Licence Status | Measure |
[TD]*[/TD]
KeyMismatch | KeyMismatch | <The error occurs when the SYS board is replaced> Recover the license on the SYS board. (Transfer the license from SYS-SRAM to SYS-FROM.) P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board"([F]Restore license) <The error occurs except when the SYS board is replaced> Recover the license on the SRAM board. (Transfer the license from SYS-FROM to SYS-SRAM.) P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board"(Backup license) |
Other service call | Key consistency error - Encryption key for ADI-HDD is damaged. |
Encryption key status confirmation | Check the message displayed by [3] + [C] + [POWER] 5. Key Backup Restore. |
Remarks:
[TD]*[/TD]
[TD]OK[/TD]
KeyNull/ KeyBroken | OK | Recover the encryption key on the SRAM board. P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board" ([G]Backup ADI key) |
KeyNull/ KeyBroken | KeyNull/ KeyBroken | <No USB backup data> 1. Create the partition in the HDD/SSD, and reinstall the system software. P. 9-19 "9.3.3 Precautions and procedures when replacing the HDD"(Perform step 3 or later in “[E]Replace / Format HDD”) <With USB backup data: All key data recovery>
Other service call | Key consistency error - Administrator password error for ADI- HDD authentication. |
Remarks:
[TD]*[/TD]
[TD]OK[/TD]
[TD]OK[/TD]
Other service call | Database abnormality: Database is not operating normally. |
Setting |
Notes: |
Other service call | Login after the startup fails in any starting mode because user management database is corrupted. |
Setting |
Other service call | Login after the startup fails in any starting mode because log management database is corrupted. |
Setting |
Other service call | Login after the startup fails in any starting mode because language management database is corrupted. |
Setting | Delete the journal file: [5] + [C] + [START] -> 4. Initialize DB - > 3. Language DB If the recovery is still not completed, reinstall the master data and application program. P. 11-15 "11.2.3 Update procedure" |
Other service call | Invalid MAC address |
Setting | Compare the serial number of the equipment with a number displayed with 08-9601. If they are different, enter the correct serial number at 08-9601, 08-9083. |
Other service call | The filtering function is not working properly due to the damage to the file for the filtering setting. |
Setting |
It may take more than 30 minutes to finish the checking. Notes: User data will be deleted when [3] + [C] + [POWER] -> [3] is perform ed. |
Classification | Error content |
Other service call | ASIC formatting fails or memory acquiring fails when software is formatted |
SYS board |
Main memory |
Parts to be replaced | Remark |
Main memory |
SYS board |
Other service call | Data Overwrite option (GP-1070) disabled |
Setting | Perform firmware installation (all firmware: OS, HDD, SYS, PFC Firmware, Engine Main Firmware, and Scanner Firmware) with the USB media. * When the function of the Data Overwrite option (GP- 1070) is deleted from the equipment, the service call “F200” occurs. |
Perform 08-3840 to install the Data Overwrite Enabler (GP- 1070). * If F200 occurs while High (“3”) is set for the security level (08-8911), it cannot be released by installing the firmware using the USB media. Install the Data Overwrite Enabler (GP-1070) by 08-3840. |
Other service call | The file system is abnormal. |
Setting |
Other service call | The application fails to start. |
Setting |
Other service call | The operation system fails to start. |
Setting |
Other service call | Authentication of program data failed. |
Setting | Restart the equipment. If the error is not recovered after restarting the equipment, reinstall software following the procedure below.
Other service call | The encryption partition fails to be read and written. |
Setting |
Other service call | The firmware fails to be updated. |
Setting |
Other service call | Overwriting fails. |
Setting |
[F800] Date error
Other service call | The year 2038 problem |
Setting | Reset the date, and request the administrator to set the date and time.
Other service call | Machine information alignment error: The machine information is damaged. |
Setting | Recover the machine information by means of the following procedure. Notes: The following procedure is supported in the firmware with the version “2050” or later. If the version is before “2050”, first upgrade it to “2050” or later with [4] + [9] -> [1] for “SYSTEM FIRMWARE (OS Data)”. <Machine information recovery>
Other service call | The speed information of the LGC board is damaged. The LGC board in which is not corresponding to the equipment model is installed. The F901_1 error occurs when the power is turned ON if the LGC board is not replaced in the correct procedure after the F901 error. |
Harness | Check if there is no problem in the harness for connecting to the following connectors. LGC board: CN311 and CN316 |
LGC board | Check if the LGC board in which is corresponded to the equipment model is installed. Check if the label color of the LGC board (indicated in the figure with the arrow) is corresponded to the equipment model (indicated on the rating label). e-STUDIO206L / e-STUDIO207L: White e-STUDIO256 / e-STUDIO257: Pink e-STUDIO306 / e-STUDIO307: Blue e-STUDIO356 / e-STUDIO357: Yellow e-STUDIO456 / e-STUDIO457: Green e-STUDIO506 / e-STUDIO507: Red
If they are not corresponding correctly, replace the LGC board with the correct one by referring to the procedures described below. Reference: "9.3.5Procedures when replacing the LGC board" Notes: The F901_1 may occur especially when the equipment is not started up with the 08 mode according to the procedures when replacing the LGC board. |
Replacement part | Remark |
Harness | |
LGC board |
Error in Internet FAX / Scanning Function
Notes:
When formatting the HDD ([5] + [C] + [POWER] -> 3 -> 1), all data in the shared folder, Electronic Filing, Address Book, template, etc. are erased. Back up these data before the initialization. Note that some of data cannot be backed up (Page 5-1).
[ 1 ] Internet FAX related error
[1C10] System access abnormality [1C32] File deletion failure
Classification Error item Internet FAX related error System access abnormality File deletion failure
Check item Measures Setting - Turn the power OFF and then back ON. Perform the job in error again.
- If the error still occurs, first, check if there are no jobs existing and then perform the HDD formatting ([5] + [C] + [POWER] -> 3 -> 1).
[1C11] Insufficient memory
Classification Error item Internet FAX related error Insufficient memory
Check item Measures Setting - When there are running jobs, perform the job in error again after the completion of the running jobs.
- If the error still occurs, turn the power OFF and then back ON, and perform the job again.
Classification Error item Internet FAX related error Message reception error Message transmission error
Classification Error item Internet FAX related error Invalid parameter
Check item Measures Setting - When a template is used, form the template again.
Classification Error item Internet FAX related error Exceeding file capacity
Check item Measures Setting - Reset and extend the “Maximum send to E-mail/iFAX size” or reduce the number of pages and perform the job again.
[1C22] Job control module access abnormality
Classification Error item Internet FAX related error System management module access abnormality Job control module access abnormality
Check item Measures Setting - Turn the power OFF and then back ON. Perform the job in error again. Check if there are no other running jobs and perform the HDD formatting ([5] + [C] + [POWER] -> 3 -> 1). If the recovery is still not completed, replace the SYS board.
[1C33] File access failure
Classification Error item Internet FAX related error Directory creation failure File creation failure
File access failure
Check item Measures Setting - Check if the access privilege to the storage directory is writable. Check if the server or local disk has a sufficient space in disk capacity.
Classification Error item Internet FAX related error Image conversion abnormality
- Replace the main memory and perform the job again.
Replace parts Remarks Main memory
Classification Error item Internet FAX related error HDD full failure during processing
Check item Measures Setting - Delete the job in progress or being set or in the HOLD/ PRIVATE/PROOF/INVALID, and perform it again.
- Check if the server or local disk has a sufficient space in disk capacity.
[1C61] Address Book reading failure
Classification Error item Internet FAX related error Address Book reading failure
- Reset the data in the Address Book and perform the job again.
[1C63] Terminal IP address unset
Classification Error item Internet FAX related error Terminal IP address unset
Check item Measures Setting - Reset the Terminal IP address.
Classification Error item Internet FAX related error Terminal mail address unset
Check item Measures Setting - Reset the Terminal mail address.
Classification Error item Internet FAX related error SMTP mail address unset
Check item Measures Setting - Reset the SMTP address and perform the job.
Classification Error item Internet FAX related error Server time-out error
Check item Measures Setting - Check if the SMTP server is operating properly.
Classification Error item Internet FAX related error SMTP server connection error
Check item Measures Setting - Reset the login name or password of SMTP server and perform the job again.
Classification Error item Internet FAX related error Terminal mail address error
Check item Measures Setting - Check the SMTP Authentication method.
- Check if there is an illegal character in the Terminal mail address.
- Set the correct SMTP Authentication method or delete the illegal character and reset the appropriate Terminal mail address, then perform the job again.
Classification Error item Internet FAX related error Destination mail address error
Check item Measures Setting - Check if there is an illegal character in the Destination mail address.
- Delete the illegal character and reset the appropriate Destination mail address, then perform the job again.
Classification Error item Internet FAX related error System error
- If the error still occurs, replace the SYS board.
Replace parts Remarks SYS board
Classification Error item Internet FAX related error SMTP client OFF
Check item Measures Setting - Set the SMTP valid and perform the job again.
Classification Error item Internet FAX related error SMTP authentication ERROR
Check item Measures Setting - Check that SMTP authentication method, login name and password are correct, then perform authentication again.
[1C72] POP Before SMTP ERROR
Classification Error item Internet FAX related error POP Before SMTP ERROR
Check item Measures Setting - Check that both the POP Before SMTP setting and POP3 setting are correct, then perform authentication again.
Classification Error item Internet FAX related error Internet FAX transmission failure when processing FAX job received
Check item Measures Setting - Reset the “Received InternetFax Forward”.
Classification Error item Internet FAX related error Onramp Gateway transmission failure
Check item Measures Setting - Reset the mail box.
Check item Measures Setting - Reset the “Received Fax Forward”
Classification Error item Internet FAX related error Power failure
Check item Measures Setting - Check if the power cable is connected properly and it is inserted securely.
- Check if the power voltage is unstable.
[2500] HOST NAME error (RFC: 500) / Destination mail address error (RFC: 500) / Terminal mail address error (RFC: 500)
[2501] HOST NAME error (RFC: 501) / Destination mail address error (RFC: 501) / Terminal mail address error (RFC: 501)
Classification Error item RFC related error
Check item Measures Setting - Check if the Terminal mail address and Destination mail address are correct.
- Check if the mail server is operating properly.
[2551] Destination mail address error (RFC: 551)
Check item Measures Setting - Check if the mail server is operating properly.
[2550] Destination mail address error (RFC: 550)
Check item Measures Setting - Check the state of the mail box in the mail server.
Check item Measures Setting - Confirm the size on the mail server.
- Transmit again in text mode or with lower resolution or divide the document and transmit again.
- If the error still occurs, turn the power OFF and then back ON. Perform the job in error again.
Check item Measures Setting - Check if there is an illegal character in the mail box in the mail server.
[2B10] No applicable job error in Job control module [2B11] JOB status abnormality
[2B20] File library function error
[2B30] Insufficient disk space in BOX partition [2BC0] Fatal failure occurred
[2BC1] System management module resource acquiring failure
Classification Error item Electronic Filing related error
Check item Measures Setting - Erase some data in the Electronic Filing or the shared folder and perform the job in error again (in case of [2B30]).
- Check that there is no other job in progress, and format the HDD with [5] + [C] + [START].
- If the recovery is still not completed, replace the SYS board.
Remarks
Replace parts
SYS board
[2B21] Exceeding file capacity
Check item Measures Setting - Reset and extend the “Maximum send to E-mail/Internet FAX size” or reduce the number of pages and perform the job again.
Check item Measures Setting - Check if the specified Electronic Filing or folder exists. (If no, this error would not occur.)
- Delete the specified Electronic Filing or folder.
- Perform the job in error again.
- If the specified box/folder cannot be deleted, initialize the Electronic Filing with [5] + [C] + [START].
- [2B32] Electronic Filing printing failure: Specified document can not be printed because of client's access (being edited, etc.)
Check item Measures Setting Delete the specified document. Perform the job in error again. - Check if the specified document exists. (If no, this error would not occur.)
- © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507
[2B90] Insufficient memory capacity
- If the error still occurs, replace the main memory.
- Delete the job in progress or being set or in the HOLD/ PRIVATE/PROOF/INVALID, and retry the job in error.
- Check that there is no other job in progress, and initialize the Electronic Filing with [5] + [C] + [START].
[2B51] List library error
Check item Measures Setting + [START]. - Check if the Function list can be printed.
- If it can be printed, retry the job which was in error.
- If it cannot be printed, replace the main memory.
- If it still cannot be recovered, format the HDD with [5] + [C]
Check item Measures Setting - Check if the password is correct.
- Reset the password.
- When this error occurs when printing the data in the Electronic Filing, perform the printing with the administrator's password.
- If it still cannot be recovered, or a password for the operation other than printing is invalid, initialize the Electronic Filing with [5] + [C] + [START].
Classification Error item Electronic Filing related error A Paper size not supported in the Electronic Filing function is being selected.
Check item Measures Setting - The specified paper size, color mode or resolution cannot be used. Check the setting.
[2BB1] Power failure
[2BD0] Power failure occurred during restoring of Electronic Filing
Classification Error item Electronic Filing related error Power failure
[2BF0] Exceeding maximum number of pages
Check item Measures Setting - Reduce the number of inserting pages and perform the job again.
Check item Measures Setting - Backup the documents in the box or folder to PC or delete them.
Check item Measures Setting - Backup the folders in the box or folder to PC or delete them.
[2A20] System management module resource acquiring failure
Classification Error item Remote scanning related error
Check item Measures Setting - Retry the job in error.
- If the error still occurs, turn the power OFF and then back ON, then retry the job in error.
Classification Error item Remote scanning related error A job is performed while WS Scan function is disabled.
Check item Measures Setting Check if WS Scan (Web Scanning Services) function is disabled on the TopAccess screen. If it is disabled, enable it.
[2A40] System error
Check item Measures Setting - Turn the power OFF and then back ON, then retry the job in error.
Check item Measures Setting - Check if the power supply voltage is inconstant.
Classification Error item Remote scanning related error WS Scan for job authentication failed.
Check item Measures Setting - When “1” (TTEC’s WIA driver) is set for 08-9749 and also Windows Fax&Scan is used Check if the user name that you used to log in Windows is a name registered as a user.
- When MFP panel or EWB Scan is used Check if the login user name is a name registered as a user.
Classification Error item Remote scanning related error A job is performed by a user without Remote Scan privilege.
Check item Measures Setting Check if correct privilege is given to the user.
[2A71] WS Scan privilege check error
Classification Error item Remote scanning related error A job is performed by a user without WS Scan privilege.
[2A72] e-Filing data access privilege check error (Scan Utility)
Classification Error item Remote scanning related error A user without e-Filing data access privilege tried to use Scan utility.
[2C10] System access abnormality [2C32] File deletion failure
Classification Error item E-mail related error
- If the error still occurs, check that there is no job, and format the HDD with [5] + [C] + [START].
[2C20] System management module access abnormality [2C21] Job control module access abnormality
[2C22] Job control module access abnormality
[2C30] Directory creation failure
[2C31] File creation failure [2C33] File access failure
[2C43] Encryption error
Check item Measures Setting - Reset the encryption and perform the job in error again.
- If an image file not encrypted is created, consult your administrators.
Classification Error item E-mail related error Creation of meta data failed when a user tried to perform meta scan for Scan to Email.
Check item Measures Setting Check the template settings. Perform the job in error again. If the error still occurs, turn the power OFF and then back ON, and then perform the job in error again.
[2C60] HDD full failure during processing
- Check that there is enough space in the server or local disk.
[2C66] Server time-out error
Check item Measures Setting - Reset the login name and password of SMTP server and perform the job again.
Check item Measures Setting - Check if there is an illegal character in the device name.
- Delete the illegal character and reset the appropriate device name.
- e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507 © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved ERROR CODE AND TROUBLESHOOTING
Check item Measures Setting - Reset the setting of the mail box or “Received InternetFax Forward”.
[2CC1] Power failure
[2D10] System access abnormality [2D32] File deletion failure
[2DA6] File deletion failure [2DA7] Resource acquiring failure
Classification Error item File sharing related error System access abnormality File deletion failure Resource acquiring failure
Check item Measures Setting - Delete some files in the shared folder by using Explorer because of automatic/manual file deletion failure (in case of [2DA6])
Classification Error item File sharing related error Insufficient memory
Classification Error item File sharing related error Message reception error Message transmission error
Classification Error item File sharing related error Invalid parameter
Classification Error item File sharing related error Exceeding the maximum size for file sharing
Check item Measures Setting - Divide the file in error into several files and retry. Or retry the job in a single-page format.
[2D22] Job control module access abnormality [2D60] File library access abnormality
Classification Error item File sharing related error System management module access abnormality Job control module access abnormality
Check item Measures Setting Check if there are no other running jobs and perform the HDD formatting ([5] + [C] + [POWER] -> 3 -> 1). If the recovery is still not completed, replace the SYS board. - Turn the power OFF and then back ON. Perform the job in error again.
[2D30] Directory creation failure
[2D31] File creation failure [2D33] File access failure
Classification Error item File sharing related error Directory creation failure File creation failure
File access failure
Classification Error item File sharing related error Image conversion abnormality
- If the error still occurs, check that there is no job, and initialize the shared folder with [5] + [C] + [START].
Classification Error item File sharing related error Encryption error
Classification Error item File sharing related error Encryption PDF enforced mode error
Classification Error item File sharing related error Creation of meta data failed when a user tried to perform meta scan for Scan to File.
[2D62] File server connection error
Classification Error item File sharing related error File server connection error
Check item Measures Setting - Check the IP address or path of the server.
- Check if the server is operating properly.
Classification Error item File sharing related error Invalid network path
Check item Measures Setting - Check the network path.
- If the path is correct, turn the power OFF and then back ON, and perform the job again.
Classification Error item File sharing related error Login failure
Check item Measures Setting - Reset the login name and password. Perform the job.
- Check if the account of the server is properly set up.
Classification Error item File sharing related error Exceeding documents in folder: Creating new document is failed
Check item Measures Setting - Delete some documents in the folder.
[2D66] Storage capacity full failure during processing
Classification Error item File sharing related error Storage capacity full failure during processing
Check item Measures Setting - Check if the setting of FTP service is valid.
Classification Error item File sharing related error File sharing service not available
Check item Measures Setting - Check if the setting of SMB is valid.
Classification Error item File sharing related error When a user tried to perform Scan to File with NetWare protocol even though the NetWare setting is disabled, a message notifies the user that NetWare service is disabled.
Check item Measures Setting Check if the Netware setting is enabled.
[2DC1] Power failure
Classification Error item File sharing related error Power failure
Classification Error item File sharing related error Job status is invalid.
Check item Measures Setting Turn the power OFF and then back ON. Perform the job in error again.
[2E11] Insufficient memory capacity for USB storage
Classification Error item File sharing related error Memory in the USB folder is not sufficient.
Check item Measures Setting If there is a job in progress, perform the job in error again after the job in progress is finished. If the error still occurs, turn the power OFF and then back ON, and then perform the job in error again.
[2E12] Message reception error in USB storage [2E13] Message transmission error in USB storage
Classification Error item File sharing related error The specified parameter is invalid.
Check item Measures Setting If a template is being used, recreate the template. If the error still occurs, turn the power OFF and then back ON. Perform the job in error again.
[2E15] Exceeding maximum file capacity
Classification Error item File sharing related error There are too many files in the folder.
Check item Measures Setting Delete some files in the folder. Perform the job in error again.
[2E30] Directory creation failure in USB storage
Classification Error item File sharing related error Creation of a directory failed.
Check item Measures Setting Check if access privilege to the storage directory is writable. Check if the server or local disk has sufficient space in its disk capacity.
[2E31] File creation failure in USB storage
Classification Error item File sharing related error Creation of a file failed.
[2E32] File deletion failure in USB storage
Classification Error item File sharing related error Deletion of a file failed.
Classification Error item File sharing related error Access to a file failed.
[2E40] Image conversion abnormality in USB storage
Classification Error item File sharing related error Conversion of image file format failed.
Check item Measures Setting Turn the power OFF and then back ON. Perform the job in error again. Replace the main memory and then perform the job in error again.
[2E43] Encryption failure in USB storage
Classification Error item File sharing related error Creation of a file failed due to PDF encryption error.
[2E44] Encryption PDF enforced mode error in USB storage
Classification Error item File sharing related error Creation of an image file is not permitted.
Check item Measures Setting Reset the encryption and perform the job in error again. To create an image file not encrypted, consult your administrator.
[2E45] Meta data creation error in USB storage (Scan to File)
Classification Error item File sharing related error Creation of meta data failed.
Classification Error item File sharing related error Creation of a new file failed because there were too many files in the USB folder
Check item Measures Setting Delete unnecessary files in the folder.
[2E66] HDD full failure in USB storage
Classification Error item File sharing related error HDD became full while storing data in HDD.
Check item Measures Setting Delete the job in progress or being set or in the HOLD/ PRIVATE/PROOF/INVALID, and perform it again.
Check that there is enough space in the USB memory.
[2EC1] Power failure in USB storage
Classification Error item File sharing related error Power failure occurred.
Check item Measures Setting Check if the power cable is connected properly and inserted securely. Check if the power voltage is unstable.
[3A10] E-mail MIME error
Classification Error item E-mail reception related error E-mail MIME error
Check item Measures Setting - The format of the mail is not corresponding to MIME 1.0.
- Request the sender to retransmit the mail in the format corresponding to MIME 1.0.
Classification Error item E-mail reception related error E-mail analysis error E-mail format error E-mail decode error
Check item Measures Setting - These errors occur when the mail data is damaged from the transmission to the reception of the mail.
- Request the sender to retransmit the mail.
Classification Error item E-mail reception related error Partial mail time-out error
Check item Measures Setting - The partial mail is not received in a specified period of time.
- Request the sender to retransmit the partial mail, or set the time-out period of the partial mail longer.
Classification Error item E-mail reception related error Partial mail related error
Check item Measures Setting - The format of the partial mail is not corresponding to this equipment.
- Request the sender to remake and retransmit the partial mail in RFC2046 format.
Classification Error item E-mail reception related error Insufficient HDD capacity error
Check item Measures Setting - These errors occur when the HDD capacity is not sufficient for a temporary concentration of the jobs, etc.
- Request the sender to retransmit after a certain period of time, or divide the mail into more than one.
- Insufficient HDD capacity error also occurs when printing is disabled for no printing paper.
- In this case, supply the printing paper.
[3A70] Warning of partial mail interruption
Classification Error item E-mail reception related error Warning of partial mail interruption
Check item Measures Setting - This error occurs when the partial mail reception setting becomes OFF during the partial mail reception.
- Reset the partial mail reception setting ON and then request the sender to retransmit the mail.
[3A80] Partial mail reception setting OFF
Check item Measures Setting - Reset the partial mail reception setting ON and then request the sender to retransmit the mail.
Classification Error item E-mail reception related error Content-Type error
Check item Measures Setting - The format of the attached file is not supported by this equipment (TIFF-FX).
- Request the sender to retransmit the file in TIFF-FX.
[3C10] TIFF analysis error [3C13] TIFF analysis error
Classification Error item E-mail reception related error TIFF analysis error
Check item Measures Setting - These errors occur when the mail data is damaged from the transmission to the reception of the mail, or when the format of the attached file is not supported by this equipment (TIFF-FX).
Classification Error item E-mail reception related error TIFF compression error
Check item Measures Setting - The compression method of the TIFF file is not acceptable for this equipment. (Acceptable: MH/MR/MMR/JBIG)
- Request the sender to retransmit the file in the acceptable compression method.
Classification Error item E-mail reception related error TIFF resolution error
Check item Measures Setting - The resolution of the TIFF file is not acceptable for this equipment. (Acceptable: 200 x 100, 200 x 200, 200 x 400, 400 x 400, 300 x 300 or equivalent)
- Request the sender to retransmit the file in the acceptable resolution.
Classification Error item E-mail reception related error TIFF paper size error
Check item Measures Setting - The paper size of the TIFF file is not acceptable for this equipment. (Acceptable: A4, B4, A3, B5, LT, LG, LD or ST)
- Request the sender to retransmit the file in the acceptable paper size.
[3C50] Offramp destination error
Classification Error item E-mail reception related error Offramp destination error
Check item Measures Setting - These errors occur when the FAX number of the offramp destination is incorrect.
- Request the sender to correct the FAX number of offramp destination and then retransmit the mail.
Classification Error item E-mail reception related error Offramp security error
Check item Measures Setting - These errors occur when the FAX number of the offramp destination is not on the Address Book.
- Check if the FAX number of the offramp destination is correctly entered or the number has not been changed.
[3C70] Power failure error
Classification Error item E-mail reception related error Power failure error
Check item Measures Setting - Check if the mail is recovered after turning ON the power again.
- Request the sender to retransmit the mail if it is not recovered.
Classification Error item E-mail reception related error OffRamp Fax transmission disable error
Check item Measures Setting - OffRamp Fax transmission disable error has been detected in the received mail.
- Confirm if the Fax Send Function of MFP setting is disable or not.
- [3D10] Destination address error
Classification Error item E-mail reception related error Destination address error
Check item Measures Setting - Check if the setting of the server or DNS is correct. Correct if any of the setting is incorrect.
- When the content of the setting is correct, confirm the sender if the destination is correct.
[3D20] Offramp destination limitation error
Classification Error item E-mail reception related error Offramp destination limitation error
Check item Measures Setting - Inform the sender that the transfer of the FAX data over 40 is not supported.
Classification Error item E-mail reception related error FAX board error
Check item Measures Setting - This error occurs when the FAX board is not installed or the FAX board has an abnormality.
- Check if the FAX board is correctly connected.
Classification Error item E-mail reception related error POP3 server connection error
Check item Measures Setting - Check if the IP address or domain name of the POP3 server set for this equipment is correct, or check if POP3 server to be connected is operating properly.
Classification Error item E-mail reception related error POP3 server connection time-out error
Check item Measures Setting - Check if POP3 server to be connected is operating properly.
- Check if the LAN cable is correctly connected.
Classification Error item E-mail reception related error POP3 login error
Check item Measures Setting - Check if the POP3 server login name and password set for this equipment are correct.
[3E40] POP3 Login Type ERROR
Classification Error item E-mail reception related error POP3 Login Type ERROR
Check item Measures Setting - Check that the login type (Auto, POP3 or APOP) to the POP3 server is correct.
[3F10] File I/O error [3F20] File I/O error
Classification Error item E-mail reception related error File I/O error
Check item Measures Setting - These errors occur when the mail data is not transferred properly to the HDD.
- Replace the HDD if the error still occurs after retransmission.
ERROR CODE AND TROUBLESHOOTINGPrinter function error
Printer function error | Print job cancellation |
Setting |
Printer function error | Print job power failure |
Setting |
TopAccess related error | No printer kit/Invalid |
Setting |
TopAccess related error | HDD full error |
Setting |
TopAccess related error | Private-print-only error |
Setting |
TopAccess related error | Printing data storing limitation error |
Setting |
TopAccess related error | e-Filing storing limitation error |
Setting |
TopAccess related error | Local file storing limitation error |
Setting |
TopAccess related error | Hardcopy security printing error |
Setting |
TopAccess related error | Restriction error (only for hold print jobs) |
Setting |
TopAccess related error | Restriction error (only for private/hold print jobs) |
Setting |
TopAccess related error | Not being authorized to perform JOB |
Setting |
