Toshiba e-STUDIO 307/357/457/507 Service Manual Part 4
  1. RADF related service call​
    No service call for the RADF.
  2. Laser optical unit related service call​
    [CA10] Polygonal motor is abnormal​
    ClassificationError content
    Laser optical unit related service callPolygonal motor is abnormal
    Proce dureCheck itemResultMeasureNext Step
    1Is the polygonal motor rotating?Yes
    NoEven if the connector is not apparently disconnected, it may be connected loosely. Therefore check carefully that it is secure.
    1. Check if the conductor pattern on the LGC board is short circuited or open circuited.
    2. Replace the LGC board.
    3. Replace the laser optical unit.
    4. Check if the connector of the harness is disconnected between LGC board (CN314) and the laser optical unit. Reconnect it securely if so.
    5. Check if the harness is open circuited and the connector pin is disconnected.
    6. Check if the conductor pattern on the LGC board is short circuited or open circuited.
    7. Replace the laser optical unit.
    8. Replace the LGC board.
    Parts to be replacedRemark
    LGC board
    Laser optical unit
    [CA20] H-Sync detection error​
    1Are the harness open circuited and the connectors disconnected between the LGC board (CN313) and the laser optical unit?Yes1. Even if the connector is not apparently disconnected, it may be connected loosely. Therefore check carefully that it is secure.
    No
    1. Replace the LGC board.
    2. Replace the laser optical unit
    LGC board
    Laser optical unit
  3. Finisher related service call​
    Check itemMeasure
    Setting of the equipmentis set as the specified finisher on the equipment (08-4548).
    Finisher
    Converter
    • Check if the MJ-1101/1107, MJ-1106/1108, MJ-1032 or MJ-1033
    • Check if the harness connecting the equipment and the finisher controller PC board is disconnected or open circuited.
    • Check if the conductor pattern on the finisher controller PC board is open circuited or short circuited.
    • Update the finisher firmware.
    • Check if the connector connecting the converter board and the LGC board on the equipment is disconnected or open circuited.
    • Check if the conductor pattern on the converter PC board is open circuited or short circuited.
    • Update the converter firmware.
    [CB00] Finisher not connected [CB01] Finisher communication error​
    Finisher related service callFinisher not connected Finisher communication error
    8​
    Converter board
    Finisher control PC board
    MJ-1033
    ErrorTiming of detection
    Data communication errorThe communication between the equipment and the Finisher is interrupted. This error is detected by the equipment.
    [CB10] Entrance motor abnormality​
    ClassificationContents
    Finisher related service callEntrance motor abnormality: The entrance motor is not rotating normally.
    MJ-1101/1107
    Check ItemMeasure
    Entrance rollerIf there is mechanical problem when the entrance roller is rotated, fix the mechanism.
    Entrance motor (M1)Check the connectors and harnesses between the entrance motor (M1) and the finisher control PC board (CN7).
    Replacement partMeasure
    Entrance motor (M1)
    Finisher controller PC board
    MJ-1106/1108
    Check ItemMeasure
    Feeding rollerRotate the feeding roller.
    Fix any mechanical problem.
    Entrance motorCheck if the connector (CN26) on the finisher controller PC board is disconnected from the entrance motor (M1) and the harnesses are open circuited. Correct if so.
    Entrance motor
    [CB11] Buffer tray guide motor abnormality​
    * A [CB11] error occurs if the [ED16] error occurs three times in succession or the [ED16] error occurs during the initialization.
    Finisher related service callBuffer tray guide motor abnormality: The buffer tray guide motor is not rotating or the buffer tray guide is not moving normally.
    MJ-1101/1107
    Check ItemMeasure
    Buffer tray guideIf there is mechanical problem when the buffer tray guide is opened/closed while the buffer roller is lifted up, fix the mechanism.
    Buffer tray guide motor (M3)Check the connectors and harnesses between the buffer tray guide motor (M3) and the finisher control PC board (CN18).
    MJ-1106/1108
    Check ItemMeasure
    Buffer tray guideRaise the buffer roller and open/close the buffer tray guide. Fix any mechanical problem.
    Buffer tray guide motorCheck if the connector (CN11) on the finisher controller PC board is disconnected from the buffer tray guide motor (M2) and the harnesses are open circuited. Correct if so.
    [CB12] Buffer roller drive motor abnormality​
    Finisher related service callBuffer roller drive motor abnormality: The buffer roller drive motor is not rotating or the buffer roller is not moving normally.
    MJ-1101/1107
    Check ItemMeasure
    Buffer rollerIf there is mechanical problem when the buffer roller is rotated, fix the mechanism.
    Buffer roller drive motor (M6)Check the connectors and harnesses between the buffer roller drive motor (M6) and the finisher control PC board (CN18).
    MJ-1106/1108
    Check ItemMeasure
    Buffer rollerRotate the buffer roller.
    Buffer roller drive motorCheck if the connector (CN11) on the finisher controller PC board is disconnected from the buffer roller drive motor (M4) and the harnesses are open circuited. Correct if so.
    8​
    [CB13] Finisher exit motor (M11) abnormality​
    MJ-1101/1107/MJ-1106/1108
    ClassificationError item
    Check itemMeasures
    Exit roller
    Exit motor (M11).
    Finisher control board
    • Is there any mechanical problem when the exit roller is rotated?
    • Motor check
    • Connector check
    • Harness check
    • Connector check (CN13)
    • Board check
    Replace partsRemarks
    Exit motor
    [CB14] Paper pusher arm motor (M10) abnormality​
    Check itemMeasures
    Paper pusher cam
    • Is there any mechanical problem when the paper pusher cam is rotated?
    • Check itemMeasures
      Assist arm motor (M10)
    • Motor check
    • Connector check
    • Harness check
    • Board check
    Assist arm motor
    [CB30] Movable tray shift motor abnormality​
    MJ-1101/1107
    Finisher related service callMovable tray shift motor abnormality: The movable tray shift motor is not rotating or the movable tray is not moving normally.
    Check ItemMeasure
    Movable trayIf there is mechanical problem when the movable tray is moved, fix the mechanism.
    Movable tray shift motor (M7)Check the connectors and harnesses between the movable tray shift motor (M7) and the finisher control PC board (CN8).
    Movable tray position A, B, and C sensors (S13, S14, and S15)
    • Connector check
    • Sensor check
    MJ-1106/1108
    Check itemMeasures
    Movable tray shift motor (M12)Check the connectors and harnesses between the movable tray shift motor (M12) and the finisher control PC board (CN16).
    • Connector check
    • Sensor check
    e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507 © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved ERROR CODE AND TROUBLESHOOTING
    [CB30] Movable tray shift motor (M1) abnormality, Movable tray paper top detection error​
    8​
    MJ-1032
    Stack top detection solenoid (SOL1) Stack top detection sensor-1 (S1) Stack top detection sensor-2 (S2 Movable tray lower limit sensor (S14)
    A locking signal is detected after the specified time *while the movable tray is moving.
    * A locking signal is not monitored from the start driving the motor until the specified time has passed.
    The stack top position of paper is not detected after the movable tray shift motor (M1) is driven in the specified time when the movable tray is moved up.
    The lower limit position of the stack top of paper is not detected after the movable tray shift motor (M1) has been driven in the specified time during the initial movement of the movable tray.
    The turning OFF of the movable tray lower limit sensor (S14) is not detected when the movable tray is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF after the movable tray shift motor (M1) has been driven in the specified time.
    Probable causeChecking and measures
    Movable tray shift motor (M1) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor
    Movable tray lower limit sensor (S14) abnormalityMeasure the voltage on TP17 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity among the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN4, CN10)
    Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the motor, sensors and connectors, exchange the finisher control PC board (FIN).
    Stack top detection solenoid (SOL1) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the solenoid.
    Stack top detection sensor-1 (S1) abnormalityMeasure the voltage on TP11 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Stack top detection sensor-2 (S2) abnormalityMeasure the voltage on TP20 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN3)
    Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the solenoid, sensors and connector, exchange the finisher control PC board (FIN).
    © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507
    [CB30] Movable tray shift motor (M5) abnormality​
    MJ-1033
    Movable tray shift motor clock sensor
    The status of the movable tray shift motor clock sensor (S15) is not changed for the specified time when the movable tray shift motor (M5) is driven.
    Movable tray shift motor (M5) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Movable tray shift motor clock sensor (S15) abnormalityMeasure the voltage on pin CN7.3 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Movable tray upper limit sensor (S16) abnormalityMeasure the voltage on TP35 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Movable tray lower limit sensor (S17) abnormalityMeasure the voltage on TP28 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Movable tray middle sensor (S18) abnormalityMeasure the voltage on TP29 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity among the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN11, CN7, CN9, CN8)
    [CB31] Movable tray paper-full detection error​
    Finisher related service callMovable tray paper-full detection error: The actuator of the movable tray paper-full detection sensor does not move smoothly.
    MJ-1101/1107
    Check ItemMeasure
    Movable tray paper-full detection sensor (S16)
    • If there is mechanical problem when the actuator is moved, fix the mechanism.
    • Sensor check
    • Check the connectors and harnesses between the movable tray paper-full detection sensor (S16) and the finisher control PC board (CN13).
    MJ-1106/1108
    Check itemMeasures
    Movable tray paper-full sensorFix any mechanical problem occurring when the actuator is moved.
    Check if there is a disconnection of the connector, incorrect installation or breakage of the movable tray paper-full sensor (S16). If there is, reinstall the sensor correctly or replace it.
    Check if the connector (CN12) on the finisher controller PC board is disconnected from the movable tray paper-full sensor (S16) and the harnesses are open circuited. Correct if so.
    [CB31] Movable tray paper top detection error​
    8​
    MJ-1033
    Stack top holding/detecting sensor Paper holding home position sensor
    The stack top holding/detecting sensor (S11) and the paper holding home position sensor (S12) do not detect the position of the top of the stack of paper in the specified time when the paper holding lever is moved to the paper detection position.
    Exiting paper holding solenoid (SOL1) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the solenoid.
    Paper holding home position sensor (S12) abnormalityMeasure the voltage on TP13 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Stack top holding/detecting sensor (S11) abnormalityMeasure the voltage on TP71 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN3, CN4)
    [CB40] Front alignment motor abnormality​
    * You receive a [CB40] error when the [ED13] error occurs three times in succession.
    Finisher related service callFront alignment motor abnormality: The front alignment motor is not rotating or the front alignment plate is not moving normally.
    MJ-1101/1107
    Check ItemMeasure
    Front alignment plateIf there is mechanical problem when the front alignment plate is moved, fix the mechanism.
    Front alignment motor (M9)Check the connectors and harnesses between the front alignment motor (M9) and the finisher control PC board (CN10).
    MJ-1106/1108
    Check itemMeasures
    Front alignment motor (M5)Check the connectors and harnesses between the front alignment motor (M5) and the finisher control PC board (CN10).
    MJ-1032
    Rear alignment motor (M3)
    Rear alignment plate home position sensor (S6)
    The turning OFF of the rear alignment plate home position sensor (S6) is not detected when the rear alignment plate is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF after the rear alignment motor (M3) has been driven at the specified number of pulse.
    The turning ON of the rear alignment plate home position sensor (S6) is not detected when the rear alignment plate is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON after the rear alignment motor (M3) has been driven at the specified number of pulse.
    Rear alignment motor (M3) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Rear alignment plate home position sensor (S6) abnormalityMeasure the voltage on TP16 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN5, CN12)
    Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the motor, sensor and connectors, exchange the finisher control PC board (FIN).
    [CB40] Rear alignment motor (M7) abnormality​
    MJ-1033
    Rear aligning plate home position sensor
    The turning OFF of the rear alignment plate home position sensor (S10) is not detected in the specified time when the rear alignment plate is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF.
    The turning ON of the rear alignment plate home position sensor (S10) is not detected in the specified time when the rear alignment plate is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON.
    Rear alignment motor (M7) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Rear alignment plate home position sensor (S10) abnormalityMeasure the voltage on pin CN9.9 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN2, CN9)
    8​
    [CB50] Stapler home position error​
    * You receive a [CB50] error when the [EA50] error occurs three times in succession.
    Finisher related service callStapler home position error: The stapler home position sensor does not work.
    MJ-1101/1107
    Check ItemMeasure
    Stapler
    • Check the connectors and harnesses between the stapler(M4) and finisher controller PC board (CN2).
    • Check the harnesses in the stapler.
    MJ-1106/1108
    Check itemMeasures
    Stapler
    • Check the connectors and harnesses between the stapler and finisher controller PC board (CN19).
    Stapler
    [CB50] Staple motor (M10) abnormality​
    MJ-1032
    Stapler motor (M9)
    Staple unit clinching home position sensor (S16)
    The staple unit clinching home position sensor (S16) does not detect the opening of the staple unit after the stapler motor (M9) has been driven reversely in the specified time from the closing during the initial movement of the staple unit.
    The staple unit clinching home position sensor (S16) does not detect the opening of the staple unit in the specified time from the closing during the clinching movement of the staple unit, and also this sensor does not detect the opening by the reverse rotation of the motor after the stapler is stopped.
    The staple unit clinching home position sensor (S16) does not detect the closing of the staple unit after the specified time during the clinching movement of the staple unit.
    The staple unit clinching home position sensor (S16) does not detect the opening of the staple unit at the start of the clinching.
    Staple motor (M10) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the staple unit.
    Staple unit clinching home position sensor (S16) abnormalityMeasure the voltage on CN16 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when the sensor is ON and within the range of 3.3V 5% when OFF. If the voltage does not fall within the range mentioned, replace the staple unit.
    Staple unit improper clinching prevention sensor (S15) abnormalityMeasure the voltage on TP25 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V 5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN16, CN17)
    Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the motor, sensors, switch and connectors, exchange the finisher control PC board (FIN).
    [CB50] Edge staple unit motor (M13) abnormality​
    MJ-1033
    Staple unit sliding motor
    Edge staple unit improper clinching prevention sensor
    The turning OFF of the edge staple unit improper clinching prevention sensor (S25) is not detected in the specified time when the edge staple unit is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF.
    The turning ON of the edge staple unit improper clinching prevention sensor (S25) is not detected in the specified time when the edge staple unit is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON.
    Edge staple unit motor (M13) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the staple unit.
    Edge staple unit clinching home position sensor (S29) abnormalityMeasure the voltage on pin CN10.4 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when the sensor is ON and within the range of 5V5% when OFF. If the voltage does not fall within the range mentioned, replace the staple unit.
    Edge staple unit improper clinching prevention sensor (S25) abnormalityMeasure the voltage on pin CN10.11 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Edge staple unit interference switch (SW3) abnormalityMeasure the voltage on pin CN18.8 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when the switch is ON and within the range of 24V10% when OFF. If the voltage does not fall within the range mentioned, replace the switch. (Be sure that all covers and doors are closed before starting measurement.)
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN10, CN18, CN24)
    8​
    The turning OFF of the edge staple unit clinching home position sensor (S29) is not detected in the specified time when stapling is performed.
    The turning ON of the edge staple unit clinching home position sensor (S29) is not detected after the specified time has passed since the turning OFF of this sensor had been detected when stapling is performed, and also turning ON of this sensor is not detected in a reverse rotation after the stapler is stopped.
    [CB51] Stapler shift home position error​
    Finisher related service callStapler shift home position error: The stapler is not at the home position.
    MJ-1101/1107
    Check ItemMeasure
    StaplerIf there is mechanical problem when the stapler is moved, fix the mechanism.
    Stapler unit home position sensor (S10)
    Stapler unit shift motor (M4)Check the connectors and harnesses between the stapler unit shift motor (M4) and the finisher control PC board (CN5).
    • Sensor check
    • Check the connectors and harnesses between the stapler unit home position sensor (S10) and the finisher control PC board (CN1).
    MJ-1106/1108
    Check itemMeasures
    StaplerMove the stapler.
    Stapler unit home position sensorCheck if there is a disconnection of the connector, incorrect installation or breakage of the stapler unit home position sensor (S10). If there is, reinstall the sensor correctly or replace it.
    Check if the connector (CN21) on the finisher controller PC board is disconnected from the stapler unit home position sensor (S10) and the harnesses are open circuited. Correct if so.
    Stapler unit shift motorCheck if the connector (CN10) on the finisher controller PC board is disconnected from the stapler unit shift motor (M9) and the harnesses are open circuited. Correct if so.
    [CB51] Staple unit sliding motor (M7) abnormality​
    MJ-1032
    Staple unit sliding motor (M7) Staple unit sliding home position sensor (S3)The turning OFF of the staple unit sliding home position sensor (S3) is not detected when the staple unit is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF after the staple unit sliding motor (M7) has been driven at the specified number of pulse.
    The turning ON of the staple unit sliding home position sensor (S3) is not detected when the staple unit is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON after the staple unit sliding motor (M7) has been driven at the specified number of pulse.
    Staple unit sliding motor (M7) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the staple unit.
    Staple unit sliding home position sensor (S3) abnormalityMeasure the voltage on TP18 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN3, CN18)
    Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the staple unit, sensors and connectors, exchange the finisher control PC board (FIN).
    [CB51] Staple unit sliding motor (M11) abnormality​
    MJ-1033
    Edge staple unit sliding home position sensor
    The turning OFF of the edge staple unit sliding home position sensor (S14) is not detected in the specified time when the edge staple unit is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF.
    The turning ON of the edge staple unit sliding home position sensor (S14) is not detected in the specified time when the edge staple unit is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON.
    Staple unit sliding motor (M11) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the staple unit.
    Edge staple unit sliding home position sensor (S14) abnormalityMeasure the voltage on pin CN7.6 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Saddle stitch staple unit sliding home position sensor (S22) abnormalityMeasure the voltage on pin CN7.10 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN7, CN10, CN17)
    8​
    [CB60] Stapler unit shift motor abnormality​
    Finisher related service callStapler shift motor abnormality: Stapler shift motor is not rotating or staple unit is not moving normally.
    MJ-1101/1107
    Check ItemMeasure
    MJ-1106/1108
    Check ItemMeasure
    Stapler unit shift motor (M9)Check the connectors and harnesses between the stapler unit shift motor (M9) and the finisher control PC board (CN10).
    [CB80] Backup RAM data abnormality​
    Finisher related service callBackup RAM data abnormality: Abnormality of checksum value on finisher controller PC board is detected when the power is turned ON.
    Check ItemMeasure
    Main power switchTurn OFF the main power switch, then back ON.
    [CB80] Finisher control PC board (FIN) backup RAM error​
    MJ-1032
    Timing of detection
    EEPROMData readout check is performed after data writing and the result of the data readout check does not conform to the written data.
    The equipment does not enter the ready status after the specified time has passed from data writing.
    Probable cause
    Finisher control PC board (FIN) abnormalityReplace the finisher control PC board (FIN) as the cause is a fault in the IC of the backup RAM.
    MJ-1033
    Back-up memoryData readout check is performed after data writing and the result of the data readout check does not match with the written data.
    [CB80] Hole punch control PC board (HP) backup RAM error​
    MJ-6008
    Back-up memoryData readout checking is performed after data writing and the result of the data readout check do not match with the written data.
    Hole punch control PC board (HP) abnormalityIf the behavior in the hole punch RAM check mode is not normal, replace the hole punch control PC board (HP).
    [CB81] Flash ROM abnormality​
    8​
    Finisher related service callFlash ROM abnormality: Abnormality of checksum value on finisher controller PC board is detected when the power is turned ON.
    Check ItemMeasure
    Finisher controller PC boardBoard check
    Check ItemMeasure
    [CB82] Finisher main program error​
    MJ-1106/1108
    Finisher related service callFinisher - Main CPU program error
    Check itemMeasures
    Finisher control boardUpdate the firmware version of the finisher control PC board (FIN).
    [CB83] Saddle main program error​
    MJ-1106/1108
    Finisher related service callSaddle Stitch Finisher - Main CPU program error
    Check itemMeasures
    Saddle control PC board
    • Update the firmware version of the saddle control PC board (SDL).
    • Connector check
    • Board check
    [CB84] Punch unit main program error​
    Finisher related service callHole Punch Unit - Main CPU program error
    Check itemMeasures
    • Is the firmware version of the PNC board (HP) latest?
    • Connector check
    • Board check
    [CB90] Paper folding blade motor (M12) abnormality​
    MJ-1033
    Paper folding blade home position sensor
    The turning OFF of the paper folding blade home position sensor (S19) is not detected in the specified time when the paper folding blade is pushing while this sensor is ON.
    Turning ON of the paper folding blade home position sensor (S19) is not detected in the specified time when the paper folding blade is returned to its home position while this sensor is OFF.
    Paper folding blade motor Paper folding blade motor clock sensorThe status of the paper folding blade motor clock sensor (S24) is not changed for the specified time when the paper folding blade motor (M12) is driven.
    Paper folding blade motor (M12) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Paper folding blade motor clock sensor (S24) abnormalityMeasure the voltage on TP66 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Paper folding blade home position sensor (S19) abnormalityMeasure the voltage on TP64 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN11, CN15)
    [CB91] Saddle flash ROM abnormality​
    8​
    MJ-1106/1108
    Finisher related service callSaddle Stitch Finisher flash ROM abnormality
    Check itemMeasures
    Reboot
    Saddle controller PC board (SDL)
    • Is the error recovered when the power of the equipment is turned OFF and then back ON?
    • Check if the conductor pattern on the saddle controller PC board (SDL) is open circuited or short circuited.
    [CB92] Saddle Stitch Finisher RAM abnormality​
    MJ-1106/1108
    Finisher related service callSaddle Stitch Finisher RAM abnormality
    Check itemMeasures
    Reboot
    [CB93] Saddle Stitch Finisher additional folding motor abnormality​
    MJ-1106/1108
    Finisher related service callThe [CB93] error also occurs when the error [EF18] has occurred consecutively for 3 times.
    Check itemMeasures
    Additional folding carrier
    Additional folding motor (M20)
    Saddle control PC board (SDL)
    • Is there any mechanical problem when the additional folding carrier is moved?
    • Connector check
    • Harness check
    • Motor check
    • Connector check
    • Harness check
    • Connector check (CN18)
    • Board check
    [CB94] Saddle transport motor abnormality​
    MJ-1106/1108
    Finisher related service callThe [CB94] error also occurs when the error [EAB0] or [EF13] has occurred consecutively for 3 times.
    Check itemMeasures
    Transport roller
    Saddle transport motor (M16)
    • Is there any mechanical problem when the transport rollers are rotated?
    • Motor check
    • Connector check
    • Harness check
    • Board check
    [CB95] Saddle Stitch Finisher stacker motor abnormality​
    MJ-1106/1108
    Finisher related service callThe [CB95] error also occurs when the error [EF16] has occurred consecutively for 3 times.
    Check itemMeasures
    Stacker carrier
    Stacker motor (M14)
    • Is there any mechanical problem when the stacker carrier is moved?
    • Motor check
    • Connector check
    • Harness check
    • Connector check (CN4)
    • Board check
    Stacker motor
    [CBA0] Front saddle stapler home position error​
    MJ-1106/1108
    Finisher related service callThe stapler home position detection is abnormally operated and finished
    Check itemMeasures
    Front saddle stapler clinch unitHarness check
    • Connector check (CN6)
    • Board check
    8​
    [CBB0]Rear saddle stapler home position error​
    MJ-1106/1108
    Check itemMeasures
    Rear saddle stapler clinch unitHarness check
    • Connector check (CN7)
    • Board check
    [CBC0] Saddle Stitch Finisher side alignment motor (M15) abnormality​
    MJ-1106/1108
    * You receive a [CBC0] error when the [EF15] error occurs three times in succession.
    Check ItemMeasure
    Saddle UnitIf there is mechanical problem when the jog is moved, fix the mechanism.
    Side alignment motor (M15)Harness check
    • Board check
    [CBC0] Saddle stitch alignment motor (M8) abnormality​
    MJ-1033
    Saddle stitch alignment motor Saddle stitch alignment plate home position sensorThe turning OFF of the saddle stitch alignment plate home position sensor (S20) is not detected in the specified time when the saddle stitch alignment plate is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF.
    The turning ON of the saddle stitch alignment plate home position sensor (S20) is not detected in the specified time when the saddle stitch alignment plate is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON.
    Saddle stitch alignment motor (M8) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Saddle stitch alignment plate home position sensor (S20) abnormalityMeasure the voltage on pin CN16.12 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN6, CN16)
    [CBE0] Saddle Stitch Finisher folding motor (M17) abnormality​
    MJ-1106/1108
    * You receive a [CBE0] error when the [EF17] error occurs three times in succession.
    Finisher related service callAn encoder pulse interruption error or rotation abnormality occurs in the saddle stitch finisher folding motor.
    Check ItemMeasure
    Folding motor encoder sensor (S34)
    • Sensor check (S34)
    • Connector check
    • Harness check
    • Connector check (CN11, CN14)
    • Board check
    [CBF0] Stacker motor (M9) abnormality​
    MJ-1033
    Stacker motor
    Stacker home position sensor
    The turning OFF of the stacker home position sensor (S21) is not detected in the specified time when the stacker is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF.
    The turning ON of the stacker home position sensor (S21) is not detected in the specified time when the stacker is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON.
    Stacker motor (M9) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Stacker home position sensor (S21) abnormalityMeasure the voltage on pin CN16.15 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    8​
    [CC02] Stack exit roller nip home position detection error​
    MJ-1032
    Stack exit roller shift motor (M6) Stack exit roller home position sensor (S13)The stack exit roller home position sensor (S13) does not detect that the exit roller is not at the upper position after the stack exit roller motor (M6) has been driven in the specified time when the exit roller is moved down.
    The stack exit roller home position sensor (S13) does not detect that the exit roller is at the upper position after the stack exit roller shift motor (M6) has been driven in the specified time when the exit roller is moved up.
    [CC02] Exit roller nip adjustment motor (M4) abnormality​
    MJ-1033
    Exit roller nip adjustment motor Exit roller nip home position sensorThe exit roller nip home position sensor (S8) does not become OFF from ON in the specified time when the status in which the exit roller nip is large or small is changed to one in which the exit roller or the middle transport roller is released.
    The exit roller nip home position sensor (S8) does not become ON from OFF in the specified time when the status in which the exit roller or the middle transport roller is released is changed to one in which the exit roller nip is large or small.
    Exit roller nip adjustment motor (M4) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Exit roller nip home position sensor (S8) abnormalityMeasure the voltage on TP31 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    [CC20] Saddle communication error​
    MJ-1106/1108
    Finisher related service callSaddle communication error
    Check ItemMeasure
    Interface PC board (I/F)
    Interface PC board (I/F)Board check
    Finisher control PC board (FIN)Board check
    Saddle control PC board (SDL)Board check
    Finisher control PC board (FIN)Update the firmware version of the finisher control PC board (FIN).
    Saddle control PC board (SDL)Update the firmware version of the saddle control PC board (SDL).
    • Connector check
    • Harness check
    • Connector check
    • Harness check
    • Connector check
    • Harness check
    [CC21] Saddle stitch 3rd transport roller drive motor (M10) abnormality​
    MJ-1033
    Saddle stitch 3rd transport roller home position sensor
    The turning OFF of the saddle stitch 3rd transport roller home position sensor (S23) is not detected in the specified time when the saddle stitch 3rd transport roller is nipped or performing paper transport.
    The turning ON of the saddle stitch 3rd transport roller home position sensor (S23) is not detected in the specified time when the saddle stitch 3rd transport roller is released.
    Saddle stitch 3rd transport roller drive motor (M10) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Saddle stitch 3rd transport roller home position sensor (S23) abnormalityMeasure the voltage on TP67 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    [CC22] Saddle stitch stapler home position detection error​
    8​
    MJ-1033
    Saddle stitch stapler motor Saddle stitch staple unit clinching home position sensorThe turning OFF of the saddle stitch staple unit clinching home position sensor (S32) is not detected in the specified time when saddle stitch stapling is performed.
    The turning ON of the saddle stitch staple unit clinching home position sensor (S32) is not detected in the specified time after the turning OFF of this sensor had been detected when saddle stitch stapling is performed, and also the turning ON of this sensor is not detected in a reverse rotation after the saddle stitch stapler is stopped.
    Saddle stitch stapler motor (M14) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the saddle stitch staple unit.
    Saddle stitch staple unit clinching home position sensor (S32) abnormalityMeasure the voltage on pin CN17.5 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when the sensor is ON and within the range of 5V5% when OFF. If the voltage does not fall within the range mentioned, replace the saddle stitch staple unit.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the saddle stitch staple unit.
    Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the saddle stitch staple unit and the connectors, exchange the finisher control PC board (FIN).
    Saddle stitch staple empty sensor (S33) abnormalityMeasure the voltage on pin CN17.7 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when the sensor is ON and within the range of 5V5% when OFF. If the voltage does not fall within the range mentioned, replace the saddle stitch staple unit.
    Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the saddle stitch staple unit and the connector, exchange the finisher control PC board (FIN).
    [CC30] Stack transport motor abnormality​
    * You receive a [CC30] error when the [EA70] error occurs three times in succession.
    Finisher related service callStack transport motor abnormality: The stack transport motor is not rotating or the stack transport belt is not moving normally.
    MJ-1101/1107
    Check ItemMeasure
    Stack transport beltIf there is mechanical problem when the stack transport belt is moved, fix the mechanism.
    Stack transport motor (M5)Check the connectors and harnesses between the stack transport motor (M5) and the finisher control PC board (CN10).
    MJ-1106/1108
    Check itemMeasures
    Stack transport beltMove the stack transport belt. Fix any mechanical problem.
    Stack transport motorCheck if the connector (CN17) on the finisher controller PC board is disconnected from the stack transport motor (M8) and the harnesses are open circuited. Correct if so.
    [CC31] Transport motor abnormality​
    * You receive a [CC31] error when the [ED12] error occurs three times in succession.
    Finisher related service callTransport motor abnormality: The transport motor is not rotating or the stack transport roller -1 and -2 is not rotating normally.
    MJ-1101/1107
    Check ItemMeasure
    Stack transport rollerIf there is mechanical problem when the stack transport roller -1 and -2 are rotated, fix the mechanism.
    Transport motor (M2)Check the connectors and harnesses between the transport motor (M2) and the finisher control PC board (CN5).
    MJ-1106/1108
    Check itemMeasures
    Stack transport roller -1 Stack transport roller -2Rotate the stack transport roller -1 and -2. Fix any mechanical problem.
    Transport motorCheck if the connector (CN10) on the finisher controller PC board is disconnected from the transport motor (M7) and the harnesses are open circuited. Correct if so.
    Transport motor
    [CC41] Paper holder cam home position abnormality​
    Finisher related service callPaper holder cam home position abnormality: The paper holder cam is not at the home position.
    8​
    MJ-1101/1107
    Check ItemMeasure
    Paper holder camIf there is mechanical problem when the paper holder cam is rotated, fix the mechanism.
    Paper holder home position sensor (S6)Check the connectors and harnesses between the paper holder home position sensor (S6) and the finisher control PC board (CN17).
    MJ-1106/1108
    Check itemMeasures
    Paper pusher camRotate the paper pusher cam. Fix any mechanical problem.
    Paper holder home position sensorCheck if the connector (CN9) on the finisher controller PC board is disconnected from the paper holder home position sensor (S6) and the harnesses are open circuited. Correct if so.
    [CC51] Sideways adjustment motor (M2) abnormality​
    MJ-1101/1106 (when MJ-6103 is installed), MJ-1107/1108 (when MJ-6104 is installed)
    * You receive a [CC51] error when the [ED11] error occurs three times in succession or occurs during the initialization.
    Finisher related service callSideways adjustment motor (M2) abnormality: Sideways adjustment motor is not rotating or puncher is not shifting normally.
    Check ItemMeasure
    Transport pathIf there is any paper remaining on the transport path, remove the paper.
    Sideways deviation home position sensor (S3)
    • If there is mechanical problem when the sideways adjustment motor (M2) is rotated, fix the mechanism.
    • Check the connectors and harnesses between the hole punch control PC board (HP) and sideways adjustment motor (M2).
    • Sensor check
    • Harness check
    [CC51] Punch unit sliding motor (M12) abnormality​
    MJ-1032
    Punch unit sliding motor (M12) Punch sliding unit home position sensor (S23)The punch sliding unit is not slid after sliding request is sent.
    The punch sliding unit home position sensor (S23) does not detect that the unit is at its home position after the specified time when the unit is returned to the home position, or this sensor does not detect that the unit is out of its home position after the specified time when the unit is released.
    The punch sliding unit home position sensor (S23) does not detect that the unit is at its home position after the specified time when the unit is moved, or this sensor does not detect that the unit is at its home position when the unit is released.
    Punch unit sliding motor (M12) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Punch sliding unit home position sensor (S23) abnormalityMeasure the voltage on TP26 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Hole punch control PC board (HP): CN3, CN5, CN6)
    Hole punch control PC board (HP) abnormalityIf the error still occurs after replacing the motor, sensor and connectors, exchange the hole punch control PC board (HP).
    [CC51] Punch unit sliding motor (M16) abnormality​
    MJ-1033
    The turning OFF of the punch sliding unit home position sensor (S37) is not detected when the punch unit sliding motor (M16) is driven for the specified distance while this sensor is ON.
    The turning ON of the punch sliding unit home position sensor (S37) is not detected when the punch unit sliding motor (M16) is driven for the specified distance in the same direction as the ON direction of this sensor while returning to its home position
    Punch unit sliding motor (M16) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Punch sliding unit home position sensor (S38) abnormalityMeasure the voltage on pin CN5.3 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Hole punch control PC board (HP): CN5, CN7)
    8​
    [CC52] Skew adjustment motor (M1) abnormality​
    * The [CC52] error occurs when the [ED10] error occurs three times in succession or during the initial operation.
    Finisher related service callSkew adjustment motor (M1) abnormality: Skew adjustment motor is not rotating or puncher is not shifting normally.
    Check ItemMeasure
    Skew home position sensor (S2)
    • If there is mechanical problem when the skew adjustment motor (M1) is rotated, fix the mechanism.
    • Check the connectors and harnesses between the hole punch control PC board (HP) and skew adjustment motor (M1).
    • Sensor check
    • Harness check
    [CC53] Punch waste full sensors (S41 and S42) abnormality​
    MJ-1033
    Punch waste full sensorAfter the sensor output adjustment, the input value is lower than 1.2V against the output value of 2.8V, or the input value is higher than 1.5V against the output value of 0.1V.
    Punch waste full sensors (S41 and S42) abnormalityMeasure the voltage on TP49 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and 2.5V or higher when shielded. If the voltage does not fall within the range mentioned, replace a couple of PC boards on either the light-receiving side or the light-emitting side.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Hole punch control PC board (HP): CN5)
    Hole punch control PC board (HP) abnormalityIf the error still occurs after replacing the sensors and the connectors, exchange the hole punch control PC board (HP).
    [CC54] Abnormality of paper detection sensors (S24 and S25)​
    MJ-1032
    Paper detection sensor (S24/S25) adjustment errorThe adjustment of the paper detection sensors (S24 and S25) has been failed.
    Paper detection sensors (S24 and S25) abnormalityMeasure the voltage on pin CN6.8 on the hole punch control PC board (HP). Then check that the measured voltage is 3.0V or higher when not shielded and 1.2V or lower when shielded. If the voltage does not fall within the range mentioned, replace a couple of PC boards on either the light-receiving side or the light-emitting side.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Hole punch control PC board (HP): CN4, CN6)
    [CC54] Abnormality of trailing edge detection sensors (S39 and S40) and horizontal registration detection sensors (S39 and S40)​
    MJ-1033
    Trailing edge detection sensor Horizontal registration detection sensorAfter the sensor output adjustment, the input value is lower than 3.2V against the output value of 2.8V, or the input value is higher than 3.5V against the output value of 0.1V.
    Trailing edge detection sensors (S39 and S40) abnormalityMeasure the voltage on TP48 on the hole punch control PC board (HP). Then check that the measured voltage is 2.5V or higher when not shielded and 1V or lower when shielded. If the voltage does not fall within the range mentioned, replace a couple of PC boards on either the light-receiving side or the light-emitting side.
    Horizontal registration detection sensors (S39 and S40) abnormality (B5-R/ST-R)Measure the voltage on TP47 on the hole punch control PC board (HP). Then check that the measured voltage is 2.5V or higher when not shielded and 1V or lower when shielded. If the voltage does not fall within the range mentioned, replace a couple of PC boards on either the light-receiving side or the light-emitting side.
    Horizontal registration detection sensors (S39 and S40) abnormality (A4-R/LT-R)Measure the voltage on TP46 on the hole punch control PC board (HP). Then check that the measured voltage is 2.5V or higher when not shielded and 1V or lower when shielded. If the voltage does not fall within the range mentioned, replace a couple of PC boards on either the light-receiving side or the light-emitting side.
    Horizontal registration detection sensors (S39 and S40) abnormality (B4/LG)Measure the voltage on TP45 on the hole punch control PC board (HP). Then check that the measured voltage is 2.5V or higher when not shielded and 1V or lower when shielded. If the voltage does not fall within the range mentioned, replace a couple of PC boards on either the light-receiving side or the light-emitting side.
    Horizontal registration detection sensors (S39 and S40) abnormality (A3/LD)Measure the voltage on TP44 on the hole punch control PC board (HP). Then check that the measured voltage is 2.5V or higher when not shielded and 1V or lower when shielded. If the voltage does not fall within the range mentioned, replace a couple of PC boards on either the light-receiving side or the light-emitting side.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Hole punch control PC board (HP): CN4)
    8​
    [CC60, CC61] Punch motor abnormality​
    MJ-1032
    Punch motor (M11)
    Paper detection sensor (S24/S25) Punch shaft home position sensor (S26)
    Rear punch shaft home position sensor (S22)
    The paper detection sensors (S24 and S25) do not emit light after specified time when they are selected
    The level of the light-receiving amount is not lowered after the light- emitting amount of the paper detection sensors (S24 and S25) is adjusted to the lower limit.
    Punching is not performed after punching request is sent, or the punching request is sent during the punching.
    The status of the punch shaft home position sensor (S26) or the rear punch shaft home position sensor (S22) is not changed after punching request is sent.
    A punching locking signal is detected consistently over the specified time.
    The punch shaft home position sensor (S26) or the rear punch shaft home position sensor (S22) does not detect that the shaft is not at its home position at the start of punching or punch waste full detection.
    Punch motor (M11) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Rear punch shaft home position sensor (S22) abnormalityMeasure the voltage on TP25 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Punch shaft home position sensor (S26) abnormalityMeasure the voltage on TP24 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Punch motor clock sensor (S20) abnormalityMeasure the voltage on TP27 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Hole punch control PC board (HP): CN2, CN5, CN6)
    Hole punch control PC board (HP) abnormalityIf the error still occurs after replacing the motor, sensors and connectors, exchange the hole punch control PC board (HP).
    [CC60] Punch motor (M15) abnormality​
    MJ-1033
    Punch motor
    Punch shaft home position sensor Punch motor clock sensor
    The status of the punch motor clock sensor (S36) is not changed for the specified time when the punch motor (M15) is driven.
    The number of input pulses of the punch motor clock sensor (S36) does not fall within the range from 70 to 100 in the OFF period of the punch shaft home position sensor (S35), or is larger than 30 in the ON period of the punch shaft home position sensor (S35).
    Punch motor (M15) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
    Punch shaft home position sensor (S36) abnormalityMeasure the voltage on pin CN3.3 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Punch shaft rotational direction sensor (S35) abnormalityMeasure the voltage on pin CN3.9 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Punch motor clock sensor (S37) abnormalityMeasure the voltage on pin CN3.6 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
    Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Hole punch control PC board (HP): CN3, CN6)
    8​
    [CC61] Punch motor (M3) home position detection error​
    MJ-1101/1106 (When MJ-6103 is installed), MJ-1107/1108 (When MJ-6104 is installed)
    * The [CC61] error occurs when the [E9F0] error occurs three times in succession or during the initial operation.
    Finisher related service callPunch motor (M3) home position detection error: Punch motor is not rotating or puncher is not shifting normally.
    Check ItemMeasure
    Punch motor (M3)
    Punch home position sensor (S4)
    • If there is mechanical problem when the punch motor (M3) is rotated, fix the mechanism.
    • Check the connectors and harnesses between the hole punch control PC board (HP) and punch motor (M3).
    • Sensor check
    • Harness check
    Punch motor (M3)
    [CC71] Punch ROM checksum error​
    Finisher related service callPunch ROM checksum error: Abnormality of checksum value on Hole punch controller PC board is detected when the power is turned on.
    Check ItemMeasure
    Hole punch control PC board (HP)Board check
    MJ-1033
    Flash ROMA checksum error occurs on the flash ROM of the Hole Punch Unit.
    The main program of the Hole Punch Unit is damaged.
    [CC72] Punch RAM read/write error​
    Finisher related service callPunch RAM read/write error: Abnormality of checksum value on Hole punch controller PC board is detected when the power is turned on.
    Check ItemMeasure
    [CC80] Rear alignment motor abnormality​
    • You receive a [CC80] error when the [ED14] error occurs three times in succession.
      Finisher related service callRear alignment motor abnormality: The rear alignment motor is not rotating or the rear alignment plate is not moving normally.
      MJ-1101/1107
      Check ItemMeasure
      Rear alignment plateIf there is mechanical problem when the rear alignment plate is moved, fix the mechanism.
      Check ItemMeasure
      Rear alignment motor (M10)Check the connectors and harnesses between the rear alignment motor (M10) and the finisher control PC board (CN10).
      MJ-1106/1108
      Check ItemMeasure
      Rear alignment motor (M6)Check the connectors and harnesses between the rear alignment motor (M6) and the finisher control PC board (CN17).
      8​
      [CC80] Front alignment motor (M2) abnormality​
      MJ-1032
      Front alignment plate home position sensor (S5)
      The turning OFF of the front alignment plate home position sensor (S5) is not detected when the front alignment plate is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF after the front alignment motor (M2) has been driven at the specified number of pulse.
      The turning ON of the front alignment plate home position sensor (S5) is not detected when the front alignment plate is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON after the front alignment motor (M2) has been driven at the specified number of pulse.
      Front alignment motor (M2) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
      Front alignment plate home position sensor (S5) abnormalityMeasure the voltage on TP15 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
      [CC80] Front alignment motor (M6) abnormality​
      MJ-1033
      Front aligning plate home position sensor
      The turning OFF of the front alignment plate home position sensor (S9) is not detected in the specified time when the front alignment plate is moved from a point where this sensor is turned ON to one point where this sensor is turned OFF.
      The turning ON of the front alignment plate home position sensor (S9) is not detected in the specified time when the front alignment plate is moved from a point where this sensor is turned OFF to one point where this sensor is turned ON
      Front alignment motor (M6) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
      Front alignment plate home position sensor (S9) abnormalityMeasure the voltage on pin CN8.3 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
      Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN2, CN8)
      [CC91] Gripper arm home position detection error [CC92] Movable tray upper limit detection error MJ-1033​
      Movable tray shift motor Movable tray upper limit sensorThe turning ON of the movable tray upper limit sensor (S16) is detected.
      [CC93] Knurled roller shift solenoid abnormality​
      MJ-1032
      ErrorTiming of detection
      Knurled roller shift solenoid (SOL3) 2nd transport motor (M4)
      Knurled roller home position sensor (S10)
      The knurled roller home position sensor (S10) does not detect that the knurled roller is at the upper position after the 2nd transport motor (M4) has been driven at the specified number of pulses during the initial rising movement of the knurled roller.
      The knurled roller home position sensor (S10) does not detect that the knurled roller is not at the upper position after the 2nd transport motor (M4) has been driven at the specified number of pulses during the initial lowering movement of the knurled roller.
      The knurled roller home position sensor (S10) does not detect that the knurled roller is at the upper position when the pressurization of stack exit movement is finished.
      8​
      [CC94] Fan motor abnormality​
      Fan motor (M10)The turning ON of the fan locking signal is detected consistently after the specified time*.
      [CDE0] Paddle motor abnormality​
    • You receive a [CDE0] error when the [ED15] error occurs three times in succession or during the initial operation.
      ClassificationContents
      Finisher related service callPaddle motor abnormality: The paddle motor is not rotating or the paddle is not rotating normally.
      MJ-1101/1107
      Check ItemMeasure
      PaddleRotate the paddle.
      Paddle motorCheck the connectors and harnesses between the paddle motor (M8) and the finisher control PC board (CN6).
      Replacement partMeasure
      Paddle motor
      MJ-1106/1108
      Check ItemMeasure
      Paddle motor (M8)Check if the connector (CN22) on the finisher controller PC board is disconnected from the paddle motor (M3) and the harnesses are open circuited. Correct if so.
      Paddle motor (M8)
      [CF10] Communication module SRAM reading failure​
      Finisher related service callCommunication module SRAM reading failure.
      MJ-1101/1107
      Check ItemMeasure
      Setting of the equipmentCheck if the MJ-1101/1107 is set as the specified finisher on the equipment. (08-4548)
      Converter PC board
      Finisher control PC boardBoard check
      • Check the connectors and harnesses between the converter PC board and the finisher controller PC board.
      • Board check
      Converter PC board
      MJ-1101 (When MJ-6103 is installed) / MJ-1107 (When MJ-6104 is installed)
      Check ItemMeasure
      Converter PC board
      Hole punch control PC boardBoard check
      • Board check
      • Check the connectors and harnesses between the hole punch control PC board and the finisher control PC board.
      • Board check
      Converter PC board
  4. Offset tray related service call​
    [CDF0] Initialize error of the offset tray (e-STUDIO206L/256/306 / 207L/257/307)​
    Offset tray related service callInitialize error of the offset tray
    Check ItemMeasure
    OCT motor OCT board LGC board
    1. Check if each connector between the OCT motor and OCT board (CN261) is disconnected.
    2. Check if each connector between the OCT board (CN261) and LGC board (CN302) is disconnected.
    3. Check if each connector pin is removed or the harness is broken.
    4. Check if any conductor pattern on the OCT board and LGC board is short circuited or open circuited.
    OCT motor
    OCT board
    LGC board
    8​
    [CDF0] Initialize error of the offset tray (e-STUDIO356/456/506 / 357/457/507)​
    Check ItemMeasure
    Offset gate motor MOT2 board LGC board
    1. Check if each connector between the offset gate motor and MOT2 board (CN406) is disconnected.
    2. Check if each connector between the MOT2 board (CN406) and LGC board (CN302) is disconnected.
    4. Check if any conductor pattern on the MOT2 board and LGC board is short circuited or open circuited.
    Replacement partRemark
    Offset gate motor.
    MOT2 board
    LGC board
  5. Service call for others​
[F100_0] HDD format error (Operation failure of key data)​
Other service callHDD format error: Operation of HDD key data fails.
Check ItemMeasure
SettingReboot the equipment.
If it cannot be recovered, reinstall the software in the following procedure.
(1) Install the OS data.
 P. 11-15 "11.2.3 Update procedure"
[F100_1] HDD format error (HDD encryption key data damaged - one board)​
Other service callHDD format error: Encryption key data of either the SYS board or the SRAM board for the SYS board are damaged.
Check ItemMeasure
Encryption key statusCheck the displayed message. ([3] + [CLEAR]  Power-ON 
5. Key Backup Restore)
Take appropriate countermeasures shown in the table below according to the messages displayed in “SRAM Key Status” and “FROM Key Status”.
Remarks:​
If the error is not cleared, reinstallation of the OS data, master data and application is needed.
SRAM Key
Status
FROM Key
Status
Measure
OKAccessFailedReplace the SYS board.
 P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board" (all steps)
OKKeyNullRecover the encryption key on the SYS board.
 P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board" ( P. 9-25 "[E] Restore encryption key")
KeyBroken
AccessFailedOKReplace the SRAM board (for the SYS board). (USB backup data are not used)
 P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board" (all steps)
KeyNullOKRecover the encryption key on the SRAM board.
 P. 9-31 "9.3.8 Precautions and Procedures when replacing SRAM board" ([H]Backup encryption key)
KeyBroken
KeymismatchKeymismatch<The error occurs when the SYS board is replaced> Recover the encryption key on the SYS board.
 P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board" ([E]Restore encryption key)
<The error occurs except when the SYS board is replaced> Replace the SRAM board (for the SYS board).
e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507 © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved ERROR CODE AND TROUBLESHOOTING
[F100_2] HDD format error (HDD encryption key data damaged - both boards)​
Other service callHDD format error: Encryption key data of both the SYS board and the SRAM board for the SYS board are damaged.
Check ItemMeasure
Remarks:​
8​
If the error is not cleared, reinstallation of the OS data / master data and application is needed.
SRAM Key
Status
FROM Key
Status
Measure
*AccessFailedReplace the SYS board.
<With USB backup data: All key data recovery>
  1. Recover all the data on the SRAM board.
  2. Recover the encryption key/license on the SYS board. Follow the procedures below noted in  P. 9-24 "9.3.4 Precautions and Procedures when replacing the SYS board".
    1. Restore ADI key (only when ADI-HDD is installed)
    2. Restore encryption key
    3. Restore license
[5] + [9] + [POWER]  2. Restore SRAM Data from USB (For details, see "12.1.4Cloning procedure Restore procedure")
[TD]AccessFailed[/TD]
[TD]*[/TD]
[TD]Replace the SYS board.
(for the SYS board, all steps)[/TD]
[TD]KeyNull/ KeyBroken[/TD]
[TD]<No USB backup data>
1. Reinstall the system software.
 P. 11-11 "11.2 Firmware Updating with USB Media"
    3. Restore license
[5] + [9] + [POWER]  2. Restore SRAM Data from USB (For details, see "12.1.4Cloning procedure Restore procedure")[/TD]
  • AccessFailed, KeyNull or KeyBroken
[F101_0] HDD connection error (HDD connection cannot be detected.) [F101_1] Root partition mount error (HDD formatting fails.)​
[F101_2][F101_3] Partition mount error (The HDD cannot be connected (mounted) caused by damage to areas other than those described in the F101_1 and F101_4 to F101_9 errors.)​
Other service callHDD unmounted: Connection of HDD cannot be detected.
Sub-code 0: HDD connection error (HDD connection cannot be detected.)
Sub-code 1: Root partition mount error (HDD formatting fails.) Sub-code 2, 3: Partition mount error (The areas other than those described in the F101_1 and F101_4 to F101_9 errors are damaged.)
Check itemMeasures
HDD, SYS board, Setting
  1. Turn the power of the equipment OFF and check the connection of the HDD.
    • Connector and harness check
    • Check if the connector pins of the HDD are bent.
    • Check if HDD for other equipment is not installed.
    • Check if SRAM for other equipment is not installed.
  2. If the error still occurs after step 1, perform the following.
    • Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is “OK”.
    • If not, recover the key (copy “SRAM Key Status” to “FROM Key Status” or vice versa).
  3. If the error still persists after step 2, perform the following.
    • Perform [3C] - [3] (Format HDD), and then install “System Software (HD data)” with [49] - [4].
      • Message Log
      • Job Log
      • Spool Data (Print, Email reception)
      • Template
  4. If the error persists even after step 3, replace the HDD.
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
If F101_1 occurs with ADI-HDD or the error persists after performing step 3, perform step 3 after performing [4]+[C]+[POWER]1. Revert factory initial status HDD.
HDD
SYS board
8​
[F101_4] Partition mount error (The HDD cannot be connected (mounted) caused by damage to the “/work” partition.)​
Other service callHDD unmounted: Connection of HDD cannot be detected. Sub-code 4: Partition mount error (The “/work” partition is damaged.)
Check itemMeasures
  3. If the error persists after step 2, perform [5]+[C]+[POWER]2. Recovery F/S3. /work, and then restart the equipment.
  4. If the error persists after step 3, perform [5]+[C]+[POWER]3. Initialize HDD2. /work, and then restart the equipment.
  5. If the error still persists after step 4, perform the following.
      • Message Log
      • Job Log
      • Template
  6. If the error persists even after step 5, replace the HDD.
Notes:
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]1. Revert factory initial status HDD.
HDD
SYS board
© 2011-2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507
[F101_5] Partition mount error (The HDD cannot be connected (mounted) caused by damage to the “/registration” partition.)​
Sub-code 5: Partition mount error (The “/registration” partition is damaged.)
Check itemMeasures
  3. If the error persists after step 2, perform [5]+[C]+[POWER]2. Recovery F/S4. /registration, and then restart the equipment.
  4. If the error persists after step 3, perform [5]+[C]+[POWER]3. Initialize HDD3. /registration, and then restart the equipment.
      • Message Log
      • Job Log
      • Template
Notes:
HDD
SYS board
8​
[F101_6] Partition mount error (The HDD cannot be connected (mounted) caused by damage to the “/backup” partition.)​
Other service callHDD unmounted: Connection of HDD cannot be detected. Sub-code 6: Partition mount error (The “/backup” partition is damaged.)
Check itemMeasures
  3. If the error persists after step 2, perform [5]+[C]+[POWER]2. Recovery F/S5. /backup, and then restart the equipment.
  4. If the error persists after step 3, perform [5]+[C]+[POWER]3. Initialize HDD4. /backup, and then restart the equipment.
      • Message Log
      • Job Log
      • Template
Notes:
HDD
SYS board
[F101_7] Partition mount error (The HDD cannot be connected (mounted) caused by damage to the “/imagedata” partition.)​
Sub-code 7: Partition mount error (The “/imagedata” partition is damaged.)
Check itemMeasures
  3. If the error persists after step 2, perform [5]+[C]+[POWER]2. Recovery F/S6. /imagedata, and then restart the equipment.
  4. If the error persists after step 3, perform [5]+[C]+[POWER]3. Initialize HDD5. /imagedata, and then restart the equipment.
      • Message Log
      • Job Log
      • Template
Notes:
HDD
SYS board
8​
[F101_8] Partition mount error (The HDD cannot be connected (mounted) caused by damage to the “/storage” partition.)​
Other service callHDD unmounted: Connection of HDD cannot be detected. Sub-code 8: Partition mount error (The “/storage” partition is damaged.)
Check itemMeasures
  3. If the error persists after step 2, perform [5]+[C]+[POWER]2. Recovery F/S7. /storage, and then restart the equipment.
  4. If the error persists after step 3, perform [5]+[C]+[POWER]3. Initialize HDD6. /storage, and then restart the equipment.
      • Message Log
      • Job Log
      • Template
Notes:
HDD
SYS board
[F101_9] Partition mount error (The HDD cannot be connected (mounted) caused by damage to the “/encryption” partition.)​
Sub-code 9: Partition mount error (The “/encryption” partition is damaged.)
Check itemMeasures
  3. If the error persists after step 2, perform [5]+[C]+[POWER]2. Recovery F/S8. /encryption, and then restart the equipment.
  4. If the error persists after step 3, perform [5]+[C]+[POWER]3. Initialize HDD7. /encryption, and then restart the equipment.
      • Message Log
      • Job Log
      • Template
Notes:
HDD
SYS board
[F102] HDD start error [F103] HDD transfer time-out [F104] HDD data error​
[F105] HDD other error​
Other service callHDD unmounted: Connection of HDD cannot be detected. HDD start error: HDD cannot become “Ready” state.
HDD transfer time-out: Reading/writing cannot be performed in the specified period of time.
HDD data error: Abnormality is detected in the data of HDD. HDD other error
Check ItemMeasure
HDD
  • Perform the bad sector check (08-9072). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
HDD
SYS board
8​
[F106_0] ADI-HDD error: Illegal disk replacement detected (ADI-HDD Exchange to SATA-HDD)​
ClassificationError item
Other service callADI-HDD error: The ADI-HDD has been replaced illegally to SATA-HDD (normal type).
Check ItemMeasure
SettingCheck if the HDD has been replaced with a SATA-HDD (normal type).
  1. Start the equipment in the 4C mode: [4] + [C] + [POWER]
  2. Check the type of the HDD shown on the top left of the control panel display “Current HDD type”.
2a. In case of “SATA-HDD” (normal type), replace it with the original ADI-HDD or a new ADI-HDD.
Notes:
To replace with the original ADI-HDD, start the equipment in the normal mode and then reinstall master data (HD Data) only if any abnormality occurs.
2b. In case of “ADI-HDD”
Check each item in the Measures field for the HDD below.
If the error still occurs, reinstall the master data (HD Data).
HDD
  • Connector check
  • Harness check
If the check result is OK, recover the data in the HDD. If the check result fails, replace the HDD.
[F106_1] ADI-HDD error: HDD type detection error​
Other service callADI-HDD error: HDD type detection fails.
Check ItemMeasure
SettingIf the error is not recovered after rebooting the equipment or no abnormality is found on any check items for the HDD, reinstall the master data (HD Data).
HDD
  • Connector check
  • Harness check
  • Check that either the ADI-HDD or SATA-HDD (normal type) is mounted.
    2. Check the type of the HDD shown on the top left of the control panel display “Current HDD type”. Normal status: ADI-HDD or SATA-HDD
Abnormal status: Unknown HDD
If “Unknown HDD” is displayed, reinstall the master data (HD Data).
[F106_2] ADI-HDD error: ADI encryption key download operation error​
Other service callADI-HDD error: Downloading of or consistency check for ADI- HDD encryption key fails.
Check ItemMeasure
SettingChecking of ADI-HDD encryption key status
  1. Start the equipment in the 3C mode: [3] + [C] + [POWER]
  2. The authentication menu is displayed. Press [OK]. (Not required in the default setting)
  3. Select “5. Key Backup Restore” and then press the [START] button.
  4. Check the status of the ADI-HDD encryption key on the Key Backup Restore Mode menu.
  5. After the operation is completed, shut down the equipment by pressing the [POWER] button.
  • In case both the SRAM ADIKey and FROM ADIKey status are OK
  • In case either the SRAM ADIKey or FROM ADIKey status is other than OK
  • In case both of the SRAM ADIKey or FROM ADIKey status are other than OK
Reinstall the system ROM data (OS Data).
Restore the ADI-HDD encryption key.
Reinstall the master data (HD Data).
[F106_3] ADI-HDD error: ADI authentication Admin Password generation error​
Other service callADI-HDD error: The generation of ADI authentication Admin Password fails.
Check ItemMeasure
SettingReinstall the system ROM data (OS Data). Reinstall the master data (HD Data).
[F106_4] ADI-HDD error: Authentication random number generation error​
Other service callADI-HDD error: The generation of a random number for authentication data fails.
Check ItemMeasure
8​
[F106_5] ADI-HDD error: Authentication data transmission error​
Other service callADI-HDD error: The transmission of authentication data fails.
Check ItemMeasure
  • In case this error occurred after returning SRAM data for SRAM cloning:
    4. Select “6. ADIKey FROM to SRAM” and then press the [START] button.
    5. After the restoring of the encryption key has completed, “Operation Complete” is displayed.
    6. After the operation has completed, shut down the equipment by pressing the [POWER] button.
Copy the ADI-HDD encryption key from FROM to SRAM.
