Toshiba e-STUDIO 307/357/457/507 Service Manual Part 2
[EB50] Paper left on the transport path due to multiple feeding​
ClassificationError content
Paper transport jamThe multiple feeding of preceding paper caused the misfeeding of upcoming paper.
When the paper is fed from the upper drawer:
Proce dureCheck itemResultMeasureNext Step
1ADUOpen the ADU and remove paper if there is any on the transport path.2
2Is the registration sensor working? (Perform the input check: 03-[FAX]/ON/ [9]/[A])YesCheck the rollers. Replace them if they are worn out
No3
3LGC board
  1. Check if the connector CN316 on the LGC board is disconnected.
  2. Check if the connector pins are disconnected or the harnesses are open circuited.
  3. Check if the conductor patterns on the LGC board are short circuited or open circuited.
Parts to be replacedRemark
Registration sensor
LGC board
Rollers on the transport path
8​
When the paper is fed from the bypass tray:
2Is the 1st transport sensor working? (Perform the input check: 03-[FAX]/ OFF/[6]/[A])Yes3
No4
3Is the registration sensor working? (Perform the input check in the test mode: 03-[FAX]ON/[9]/[A])YesCheck the rollers. Replace them if they are worn out
No5
4LGC board
  4. Replace the 1st transport sensor.
  5. Replace the LGC board.
5LGC board, registration sensor
  4. Replace the registration sensor.
LGC board
Registration sensor
When the paper is fed from the lower drawer:
No3
3LGC board, registration sensor
Registration sensor
LGC board
When the paper is fed from the PFP or LCF
1Feed coverOpen the feed cover and remove paper if there is any on the transport path.2
2Is the 2nd transport sensor working? (Perform the input check: 03-[FAX]/ OFF/[7]/[A])YesCheck the rollers. Replace them if they are worn out
No3
3LGC board, 2nd transport sensor
  4. Replace the 2nd transport sensor.
LGC board
[EB60] Paper left on the transport path due to multiple feeding​
1Open the Automatic duplexing unit. Is there any paper in front of the registration sensor?YesRemove the paper.
No2
(Perform the input check in the test mode: 03- [FAX]OFF/[6]/[E])
Yes3
No
  • Check if the connector CN316 on the LGC board is disconnected.
  • Check if the connector of the registration sensor is disconnected.
  • Check if the connector pins are disconnected and the harnesses are open circuited.
  • Check if the conductor pattern on the LGC board is short circuited or open circuited.
  • Replace the registration sensor.
  • Replace the LGC board.
3Roller
  • Check the rollers. Replace them if they are worn out.
Registration sensor
LGC board
8​
[E360] Paper fed from the PFP lower drawer not reaching the PFP upper drawer feed sensor​
Paper transport jamJam not reaching the PFP upper drawer feed sensor
1Open the PFP side cover.YesRemove the paper.
Is there any paper in frontNo2
of the PFP upper drawer
feed sensor?
2Is the PFP upper drawer feed sensor working? (Perform the input check in the test mode: 03- [FAX]OFF/[7]/[A])Yes3
No
  • Check if the connector of the PFP upper drawer feed sensor is disconnected.
  • Check if either of the connectors CN241 or CN243 on the PFP board is disconnected.
  • Check if the connector CN318 on the LGC board is disconnected.
  • Check if the conductor patterns on the PFP board and LGC board are short circuited or open circuited.
  • Replace the PFP upper drawer feed sensor.
  • Replace the PFP board.
3Is the PFP feed clutch working? (Perform the output check in the test mode: 03-226)Yes4
No
  • Check if the connector of the PFP transport clutch is disconnected.
  • Check if any of the connectors CN241 and CN247 on the PFP board is disconnected.
  • Replace the PFP transport clutch.
4Feed roller Separation roller Pickup roller
PFP transfer roller
  • Check the condition of the feed roller, separation roller and pickup roller of each paper source, and replace them if they are worn out.
  • Check the PFP transport roller. Replace it if it is worn out.
PFP board
LGC board
Feed roller
Separation roller
Pickup roller
e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507 © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved ERROR CODE AND TROUBLESHOOTING
  1. Paper misfeeding​
    8​
    [E110] ADU misfeeding​
    Paper misfeedingJam not reaching the registration sensor)
    1Open the ADU. Is there any paper in front of the registration sensor?YesRemove the paper.
    No2
    (Perform the input check in the test mode: 03- [FAX]ON/[9]/[A])
    Yes3
    No
    3Is the ADU clutch working? (Perform the output check in the test mode: 03-222)Yes4
    No
    4Rollers in the ADU
    • Check if the connector of the 1st transport sensor is disconnected.
    • Replace the 1st registration sensor.
    • Check if the connector of the ADU clutch is disconnected.
    • Check if the connector CN304 on the LGC board is disconnected.
    • Replace the ADU clutch.
    • Check the rollers in the ADU. Replace them if they are worn out.
    ADU clutch
    LGC board
    Rollers in the ADU
    © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507
    [E120] Bypass misfeeding​
    Paper misfeedingJam not reaching the 1st transport sensor
    1Open the Automatic duplexing unit. Is there any paper in front of the 1st transport sensor?YesRemove the paper.
    No2
    (Perform the input check in the test mode: 03- [FAX]OFF/[6]/[A])
    Yes3
    No
    3Is the bypass feed clutch working? (Perform the output check in the test mode: 03-204)
    Is the bypass paper sensor working? (Perform the input check in the test mode: 03-[FAX]OFF/[1]/ [D])
    Yes4
    No
    4Bypass feed roller Separation pad
    • Replace the 1st transport sensor.
    • Check if the connector of the bypass feed clutch and bypass paper sensor are disconnected.
    • Check if the connector CN311 on the LGC board is disconnected.
    • Replace the bypass feed clutch and bypass paper sensor.
    • Check the bypass feed roller and separation pad. Replace them if they are worn out.
    LGC board
    Bypass feed clutch
    Bypass paper sensor
    Bypass feed roller
    Separation pad
    8​
    [E130] Upper drawer misfeeding (paper not reaching the 1st transport sensor)​
    No2
    Yes3
    No
    3Is the upper drawer feed clutch working?
    (Perform the output check in the test mode: 03-201)
    Yes4
    No
    4Upper drawer feed roller Separation roller
    • Check if the connector of the upper drawer feed clutch is disconnected.
    • Check if the connector CN315 on the LGC board is disconnected.
    • Replace the upper drawer feed clutch.
    • Check the upper drawer feed roller, separation roller and pickup roller. Replace them if they are worn out.
    LGC board
    Upper drawer feed clutch
    Separation roller
    Pickup roller
    [E140] Lower drawer misfeeding (paper not reaching the 2nd transport sensor)​
    Paper misfeedingJam not reaching the 2nd transport sensor
    1Open the feed cover. Is there any paper in front of the 2nd transport sensor?YesRemove the paper.
    No2
    Yes3
    No
    3Is the lower drawer feed clutch working?
    (Perform the output check in the test mode: 03-202)
    Yes4
    No
    4Lower drawer feed roller Separation roller
    Pickup roller
    • Check if the connector of the 2nd transport sensor is disconnected.
    • Replace the 2nd transport sensor.
    • Check if the connector of the lower drawer feed clutch is disconnected.
    • Replace the lower drawer feed clutch.
    • Check the lower drawer feed roller, separation roller and pickup roller. Replace them if they are worn out.
    LGC board
    Lower drawer feed clutch
    Separation roller
    Pickup roller
    8​
    [E150] PFP upper drawer misfeeding (paper not reaching the PFP upper drawer feed sensor)​
    Paper misfeedingJam not reaching the PFP upper drawer feed sensor
    1Open the PFP side cover. Is there any paper in front of the PFP upper drawer feed sensor?YesRemove the paper.
    No2
    2Is the PFP upper drawer feed sensor working? (Perform the input check in the test mode: 03- [FAX]OFF/[2]/)
    [TD]Yes[/TD]
    [TD][/TD]
    [TD]3[/TD]
    [TD]No[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]3[/TD]
    [TD]Is the PFP upper drawer feed clutch working? (Perform the output check in the test mode: 03-226)[/TD]
    [TD]Yes[/TD]
    [TD][/TD]
    [TD]4[/TD]
    [TD]No[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]4[/TD]
    [TD]PFP upper drawer feed roller
    Separation roller Pickup roller[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    • Check if the connector of the PFP upper drawer feed clutch is disconnected.
    • Replace the PFP upper drawer feed clutch.
    • Check the PFP upper drawer feed roller, separation roller and pickup roller. Replace them if they are worn out.
    PFP board
    LGC board
    Separation roller
    Pickup roller
    [E160] PFP lower drawer misfeeding (paper not reaching the PFP lower drawer feed sensor)​
    Paper misfeedingJam not reaching the PFP lower drawer feed sensor
    1Open the PFP side cover. Is there any paper in front of the PFP lower drawer feed sensor?YesRemove the paper.
    No2
    2Is the PFP lower drawer feed sensor working? (Perform the input check in the test mode: 03- [FAX]OFF/[3]/)
    [TD]Yes[/TD]
    [TD][/TD]
    [TD]3[/TD]
    [TD]No[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]3[/TD]
    [TD]Is the PFP lower drawer feed clutch working? (Perform the output check in the test mode: 03-228)[/TD]
    [TD]Yes[/TD]
    [TD][/TD]
    [TD]4[/TD]
    [TD]No[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]4[/TD]
    [TD]PFP lower drawer feed roller
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    • Check if the connector of the PFP lower drawer feed sensor is disconnected.
    • Replace the PFP lower drawer feed sensor.
    • Check if the connector of the PFP lower drawer feed clutch is disconnected.
    • Check if any of the connectors CN241 and CN248 on the PFP board is disconnected.
    • Replace the PFP lower drawer feed clutch.
    • Check the PFP lower drawer feed roller, separation roller and pickup roller. Replace them if they are worn out.
    PFP board
    LGC board
    Separation roller
    Pickup roller
    8​
    [E190] LCF misfeeding (paper not reaching the LCF feed sensor)​
    Paper misfeedingJam not reaching the LCF feed sensor
    1Open the LCF side cover. Is there any paper in front of the LCF feed sensor?YesRemove the paper.
    No2
    2Is the LCF feed sensor working?
    (Perform the input check in the test mode: 03- [FAX]OFF/[4]/[C])
    Yes3
    No
    3Is the LCF feed clutch working? (Perform the output check in the test mode: 03-209)Yes4
    No
    4LCF feed roller Separation roller Pickup rollerReplace them if they are worn out.
    • Check if the connector of the LCF feed sensor is disconnected.
    • Check if either of the connectors CN1 or CN7 on the LCF board is disconnected.
    • Check if the conductor patterns on the LCF board and LGC board are short circuited or open circuited.
    • Replace the LCF feed sensor.
    • Replace the LCF board.
    • Check if the connector of the LCF feed clutch is disconnected.
    • Check if any of the connectors CN1 and CN6 on the LCF board is disconnected.
    • Replace the LCF feed clutch.
    • Check the LCF feed roller, separation roller and pickup roller.
    LCF feed sensor
    LCF board
    LGC board
    LCF feed clutch
    LCF feed roller
    Separation roller
    Pickup roller
    Cover open jam​
    8​
    [E410] Front cover opened during printing​
    Cover open jamFront cover open jam
    1Is the front cover open?YesClose the cover.
    No2
    2Is the front cover opening/ closing switch working? (Perform the input check in the test mode: 03- [FAX]ON/[9]/[D])Yes3
    No
    3Is the voltage of 24V being supplied from the power supply unit?
    (Perform the input check in the test mode: 03-[FAX] ON/[2]/[A])
    Yes4
    No
    4LGC board
    • Check if the connector of the front cover opening/closing switch is disconnected.
    • Check if the connector CN310 on the LGC board is disconnected.
    • Replace the front cover opening/closing switch.
    • Check if the connector for 24 V power supply is disconnected.
    • Check if the connector CN301 on the LGC board is disconnected.
    Front cover opening/closing switch
    LGC board
    [E420] PFP side cover opened during printing​
    Cover open jamPFP side cover open jam
    1Is the PFP side cover open?YesRemove the paper if there is any, then close the cover.
    No2
    2Is the PFP side cover opening/closing switch working?
    (Perform the input check in the test mode: 03- [FAX]OFF/[2]/[A])
    Yes3
    No
    3Replacing board
    • Check if the connector of the PFP side cover opening/closing switch is disconnected.
    • Replace the PFP side cover opening/ closing switch.
    PFP board
    LGC board
    8​
    [E430] ADU opened during printing​
    Cover open jamADU open jam
    1Is the ADU open?YesRemove the paper if there is any, then close the ADU.
    No2
    2Is the ADU opening/ closing switch working? (Perform the input check in the test mode: 03- [FAX]ON/[9]/[F])Yes3
    No
    3Replacing board
    • Check if the connector of the ADU opening/ closing switch is disconnected.
    • Check if the conductor patterns on the LGC board are short circuited or open circuited.
    • Replace the ADU opening/closing switch.
    LGC board
    [E440] Feed cover opened during printing​
    Cover open jamFeed cover open jam
    1Is the feed cover open?YesRemove the paper if there is any, then close the cover.
    No2
    2Is the feed cover opening/ closing detection sensor working?
    (Perform the input check in the test mode: 03- [FAX]ON/[9]/[E])
    Yes3
    No
    3Replacing board
    • Check if the connector of the feed cover opening/closing detection sensor is disconnected.
    • Replace the feed cover opening/closing detection sensor.
    Feed cover opening/closing detection sensor
    LGC board
    8​
    [E450] LCF side cover opened during printing​
    Cover open jamLCF side cover open jam
    1Is the LCF side cover open?YesRemove the paper if there is any, then close the cover.
    No2
    2Is the LCF side cover opening/closing switch working?
    (Perform the input check in the test mode: 03- [FAX]OFF/[4]/)
    [TD]Yes[/TD]
    [TD][/TD]
    [TD]3[/TD]
    [TD]No[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]3[/TD]
    [TD]Replacing board[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    • Check if the connector of the LCF side cover opening/closing switch is disconnected.
    • Replace the LCF side cover opening/ closing switch.
    LCF board
    LGC board
    [E480] Bridge unit opened during printing​
    Cover open jamBridge unit open jam
    1Is the bridge unit open?YesRemove the paper if there is any, then close the unit.
    No2
    2Is the bridge unit opening/ closing switch working? (Perform the input check in the test mode:
    03-[FAX]ON/[3]/[E]:
    e-STUDIO206L/256/306 / 207L/257/307
    03-[FAX]ON/[4]/[E]:
    e-STUDIO356/456/506 / 357/457/507)
    Yes3
    No
    3Replacing board
    • Check if the connector of the bridge unit opening/closing switch is disconnected.
    • Check if the connector CN302 / CN400 on the LGC board is disconnected.
    • Replace the bridge unit opening/closing switch.
    The bridge unit opening/closing switch
    LGC board
    8​
    [E490] JSP cover opened during printing​
    Cover open jamJob separator cover open jam
    1Is the JSP cover open?YesRemove the paper if there is any, then close the cover.
    No2
    2Is the JSP cover switch working?
    (Perform the input check in the test mode: 03- [FAX]ON/[3]/[E])
    Yes3
    No
    3Replacing board
    • Check if the connector of the JSP cover switch is disconnected.
    • Check if either of the connectors CN260 or CN261 on the JSP board is disconnected.
    • Check if the connector CN302 on the LGC board is disconnected.
    • Check if the conductor patterns on the JSP board and LGC board are short circuited or open circuited.
    • Replace the JSP cover switch.
    • Replace the JSP board.
    JSP cover switch
    JSP board
    LGC board
    [E491] OCT cover opened during printing​
    Cover open jamOffset tray cover open jam
    1Is the OCT cover open?YesRemove the paper if there is any, then close the cover
    No2
    2Is the OCT cover switch working?
    Yes3
    No
    3Replacing board
    • Check if the connector of the OCT cover switch is disconnected?
    • Check if either of the connectors CN260 or CN261 on the OCT board is disconnected.
    • Check if the connector CN302 on the OCT board is disconnected.
    • Check if the conductor patterns on the OCT board and LGC board are short circuited or open circuited.
    • Replace the OCT cover switch.
    • Replace the OCT board.
    OCT cover switch
    OCT board.
    LGC board
    Other jam​
    [E030] Paper remaining inside the equipment at power-ON​
    Other jamPower-ON jam
    1Open the cover of the unit/ area whose picture is blinking on the control panel. Is there any paper on the transport path? (Refer to the following table.)YesRemove the paper.
    No2
    2Is the sensor in the jamming area working? (Perform the input check in the test mode: refer to the following table.)Yes3
    No
    3LGC board
    • Check if the connector of the sensor is disconnected.
    • Check if any of the connectors on the LGC board is disconnected.
    • Replace the sensor
    SensorRefer to the following table
    LGC board
    8​
    Relation between the jamming area and the corresponding sensors and covers
    (If a jam is occurring in the ADU, LCF, PFP, JSP or OCT check the board in each unit.)
    Jamming areaCoverSensorTest mode / Input check
    Registration areaAutomatic duplexing unitRegistration sensor03-[FAX]ON/[9]/[A]
    1st transport sensor03-[FAX]OFF/[6]/[A]
    Exit areaAutomatic duplexing unitExit sensor03-[FAX]ON/[9]/
    [TD]ADU[/TD]
    [TD]ADU[/TD]
    [TD]ADU entrance sensor[/TD]
    [TD]03-[FAX]OFF/[1]/[D][/TD]
    [TD]ADU exit sensor[/TD]
    [TD]03-[FAX]OFF/[1]/E][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Feeding area (Main unit)[/TD]
    [TD]Feed cover[/TD]
    [TD]2nd transport sensor[/TD]
    [TD]03-[FAX]OFF/[7]/[A][/TD]
    [TD]LCF[/TD]
    [TD]LCF side cover[/TD]
    [TD]LCF feed sensor[/TD]
    [TD]03-[FAX]OFF/[4]/[C][/TD]
    [TD]PFP[/TD]
    [TD]PFP side cover[/TD]
    [TD]PFP upper drawer feed sensor[/TD]
    [TD]03-[FAX]OFF/[2]/[/TD]
    [TD]PFP lower drawer feed sensor[/TD]
    [TD]03-[FAX]OFF/[3]/[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Bridge unit[/TD]
    [TD]Bridge unit transport sensor-1[/TD]
    [TD]03-[FAX]ON/[4]/[G]
    03-[FAX]ON/[3]/[G][/TD]
    [TD]Bridge unit transport sensor-2[/TD]
    [TD]03-[FAX]ON/[4]/[F]
    [TD][/TD]
    [TD][/TD]
    [TD]JSP[/TD]
    [TD]JSP cover[/TD]
    [TD]JSP feed sensor[/TD]
    [TD]03-[FAX]ON/[3]/G][/TD]
    [TD]OCT[/TD]
    [TD]OCT cover[/TD]
    [TD]OCT feed sensor[/TD]
    [TD]03-[FAX]ON/[3]/[G][/TD]
    [E061] Incorrect paper size setting for upper drawer [E062] Incorrect paper size setting for lower drawer [E063] Incorrect paper size setting for PFP upper drawer [E064] Incorrect paper size setting for PFP lower drawer [E065] Incorrect paper size setting for bypass tray​
    Other jamThe size of paper in the 1st drawer differs from size setting of the equipment.
    Check itemMeasures
    Paper sizeIf any paper remains in the equipment or drawer, remove it. Match the paper size of the drawer setting and the one in the drawer.
    * Paper size detection is performed at the first sheet of paper when the drawer is opened or closed, or when the power of the equipment is turned ON.
    [E550] Paper remaining on the transport path​
    Other jamPaper remaining jam on the transport path
    1Open the cover of the unit/ area whose picture is blinking on the control panel. Is there any paper on the transport path?YesRemove the paper.
    No2
    2Is the sensor in the jamming area working? (Perform the input check in the test mode: refer to the following table)Yes3
    No
    3LGC board
    • Replace the sensor.
    LGC board
    Relation between the jamming area and the corresponding sensors/covers
    Jamming areaCoverSensorTest mode/Input check
    [TD]ADU[/TD]
    [TD]ADU[/TD]
    [TD]03-[FAX]OFF/[1]/[E][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Feed cover[/TD]
    [TD]LCF[/TD]
    [TD]PFP[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]JSP[/TD]
    [TD]JSP cover[/TD]
    [TD]OCT[/TD]
    [TD]OCT cover[/TD]
    [TD]Finisher[/TD]
    [TD]Finisher door[/TD]
    [TD]Sensors in the finisher[/TD]
    [TD]-[/TD]
    8​
    [E551] Paper remaining jam on the transport path (when a service call occurs) [E552] Paper remaining jam on the transport path (when the cover is closed)​
    Other jamPaper remaining on the transport path when printing is finished (when a service call occurs) (E551)
    Paper remaining on the transport path when printing is finished (when the cover is closed) (E552)
    StepCheck ItemResultMeasureNext Step
    Jamming transport pathOpen the cover of the unit/area whose picture is flashing on the control panel and remove any paper on the transport path.
    Sensor in the jamming area
    LGC board
    Notes:
    If the jam is occurring in the ADU, LCF or PFP, check the board in each unit.
    • Sensor check (Refer to the table below)
    • Harness check
    • Connector check
    • Harness check
    • Connector check
    • Board check
    Sensor in the jamming areaRefer to the table below.
    LGC board
    Jamming areaCoverSensorTest Mode/Input check
    Paper path sectionDuplexing unitRegistration sensor03-[ALL]OFF/[4]/
    03-[COPY]ON/[5]/[H]
    [TD]Transfer belt paper clinging detection sensor[/TD]
    [TD]03-[ALL]OFF/[9]/[C][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]2nd transfer side paper clinging detection sensor[/TD]
    [TD]03-[ALL]OFF/[9]/[D][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]1st drawer transport sensor[/TD]
    [TD]03-[SCAN]ON/[1]/[D][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Fuser[/TD]
    [TD]Duplexing unit[/TD]
    [TD]Fuser transport sensor[/TD]
    [TD]03-[ALL]OFF/[2]/[C]
    03-[COPY]ON/[5]/[F][/TD]
    [TD]Reverse path sensor[/TD]
    [TD]03-[ALL]OFF/[1]/[C]
    03-[SCAN]ON/[3]/[E][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]ADU[/TD]
    [TD]Duplexing unit Cover[/TD]
    [TD]Duplexing unit path exit sensor[/TD]
    [TD]03-[SCAN]ON/[3]/[G][/TD]
    [TD]Duplexing unit path entrance sensor[/TD]
    [TD]03-[SCAN]ON/[3]/[H][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Bypass unit[/TD]
    [TD]Bypass feed sensor[/TD]
    [TD]03-[SCAN]ON/[3]/[A][/TD]
    [TD]Feeding area (equipment)[/TD]
    [TD]Paper feed cover[/TD]
    [TD]4th drawer transport sensor[/TD]
    [TD]03-[SCAN]ON/[1]/[A][/TD]
    [TD]3rd drawer/tandem LCF transport sensor[/TD]
    [TD]03-[SCAN]ON/[1]/[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]2nd drawer transport sensor[/TD]
    [TD]03-[SCAN]ON/[1]/[C][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]LCF[/TD]
    [TD]Option LCF feed sensor[/TD]
    [TD]03-[SCAN]ON/[5]/[E][/TD]
    [TD]Front cover[/TD]
    [TD]Bridge unit path exit sensor[/TD]
    [TD]03-[ALL]OFF/[1]/[A]
    03-[SCAN]ON/[3]/[C][/TD]
    [TD]Bridge unit path entrance sensor[/TD]
    03-[SCAN]ON/[3]/[D][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Reverse sensor[/TD]
    [TD]03-[SCAN]ON/[3]/[F][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Reverse section stationary jam detection sensor[/TD]
    [TD]03-[SCAN]ON/[4]/[A][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Upper exit section[/TD]
    [TD]-[/TD]
    [TD]Upper paper exit sensor[/TD]
    [TD]03-[ALL]OFF/[1]/[E]
    03-[COPY]ON/[7]/[A][/TD]
    [TD]Lower exit section[/TD]
    [TD]-[/TD]
    [TD]Lower paper exit sensor[/TD]
    [TD]03-[ALL]OFF/[4]/[C]
    03-[COPY]ON/[5]/[G][/TD]
    [TD]Reverse section[/TD]
    [TD]Reverse path cover[/TD]
    [TD]Reverse section paper transport detection sensor[/TD]
    [TD]03-[COPY]ON/[8]/[F][/TD]
    [TD]Finisher[/TD]
    [TD]-[/TD]
    [E090] Paper jam by HDD abnormality​
    Other jamPaper jam by HDD abnormality
    Check itemMeasures
    RebootCheck if the error is cleared by turning the power OFF and then back ON.
    HDDCheck if the connectors of the HDD are disconnected.
    SYS boardCheck if the connector pins are disconnected and the harnesses are open circuited.
    Replace partsRemarks
    HDD
    SYS board
    8​
    [EAD0] Print end command time-out jam​
    Other jamPrint end command time-out jam
    1Is the main motor rotating normally?Yes
    No2
    2Replacing the PC board
    • Replace the SYS board.
    SYS board
    LGC board
    RADF jam​
    [E712] Jam not reaching the original registration sensor​
    RADF jamJam not reaching the original registration sensor
    Check itemMeasures
    Pickup roller Feed roller Separation rollerClean them if there are stained.
    Original registration sensor
    RADF board
    • Sensor check (Perform the input check: 03-[FAX] ON[7]/[H])
    • Connector check (CN74)
    • Harness check
    • Board check
    • Harness check
    RADF board
    Pickup rollerReplace it if it is worn out
    Feed rollerReplace it if it is worn out.
    Separation rollerReplace it if it is worn out.
    [E714] Feed signal reception jam​
    RADF jamFeed signal reception jam
    Check itemMeasures
    Empty sensor
    • Sensor check (Perform the input check: 03-[FAX] ON[7]/)
      [*]Lever check
      [*]Connector check (CN75)
      [*]Harness check
    Empty sensor
    [E721] Jam not reaching the read sensor​
    RADF jamJam not reaching the read sensor
    Check itemMeasures
    Registration sensor Read rollerClean the registration roller and the read roller if they are stained.
    Read sensor
    RADF board
    • Sensor check (Perform the input check: 03-[FAX] ON[7]/[G])
    • Connector check (CN76)
    • Harness check
    • Board check
    • Harness check
    Read sensor
    RADF board
    Registration rollerReplace it if it is worn out.
    Read rollerReplace it if it is worn out.
    8​
    [E722] Jam not reaching the original exit/reverse sensor (during scanning)​
    RADF jamJam not reaching the original exit/reverse sensor (during scanning)
    Check itemMeasures
    Read rollerClean the read roller if it is stained.
    Original exit/reverse sensor
    RADF board
    • Sensor check (Perform the input check: 03-[FAX] ON[7]/[E])
    • Connector check (CN75)
    • Harness check
    • Board check
    • Harness check
    RADF board
    [E724] Stop jam at the registration sensor​
    RADF jamStop jam at the registration sensor
    Check itemMeasures
    Registration rollerClean the registration roller if it is stained.
    Registration sensor(Perform the input check: 03-[FAX] ON[7]/[H])
    RADF board
    • Sensor check
    • Harness check
    • Board check
    • Harness check
    Registration sensor
    RADF board
    [E725] Stop jam at the read sensor​
    RADF jamStop jam at the read sensor
    Check itemMeasures
    Read rollerClean the registration roller if it is stained.
    Read sensor(Perform the input check: 03-[FAX] ON[7]/[G])
    RADF board
    • Sensor check
    • Harness check
    • Board check
    • Harness check
    Read sensor
    RADF board
    [E726] Transport/exit signal reception jam​
    RADF jamTransport/exit signal reception jam
    Check itemMeasures
    RADF board
    SLG board
    Switching power supply
    • Board check
    • Connector check
    • Harness check
    • Board check
    • Connector check
    • Harness check
    • Check if the 24V and 5V outputs of the switching power supply are normal.
    • Board check
    • Connector check
    • Harness check
    RADF board
    SLG board
    Switching regulator
    8​
    [E731] Stop jam at the exit sensor​
    RADF jamStop jam at the exit sensor
    Check itemMeasures
    Exit rollerClean the registration roller if it is stained.
    Exit sensor(Perform the input check: 03-[FAX] ON[7]/[E])
    RADF board
    • Sensor check
    • Harness check
    • Board check
    • Harness check
    Exit sensor
    RADF board
    Exit rollerReplace it if it is worn out.
    [E860] RADF jam access cover open​
    RADF jamRADF jam access cover open
    Check itemMeasures
    RADF jam access coverClose the RADF jam access cover if it is opened. Remove if there is any original before closing it.
    RADF jam access cover switch(Perform the input check: 03-[FAX] ON[7]/[C])
    RADF board
    • Sensor check
    • Connector check (CN8)
    • Harness check
    • Board check
    • Harness check
    RADF board
    [E870] RADF open jam​
    RADF jamRADF open jam
    Check itemMeasures
    RADFClose the RADF if it is opened. Remove if there is any original before closing it.
    RADF opening/closing sensor(Perform the input check: 03-[FAX] ON[7]/[D])
    RADF board
    • Sensor check
    • Harness check
    • Board check
    • Harness check
    RADF opening/closing sensorIs the RADF opening/closing sensor adjusted within the specified range?
    RADF board
    8​
    [E871] Cover open jam in the read ready status​
    RADF jamCover open jam in the read ready status. (MR-3021/3022)
    Check itemMeasures
    RADF jam access cover Front coverClose the RADF jam access cover or the front cover if they are opened in the read ready status.
    RADF jam access cover sensor(Perform the input check: 03-[FAX] ON[7]/[C])
    • Sensor check
    • Harness check
    RADF board
    Finisher jam​
[ 1 ] Jam in bridge unit​
[E910] Paper not reaching the bridge unit transport sensor-1 [E920] Paper stopping at the bridge unit transport sensor-1​
Finisher jam (Bridge unit)Paper not reaching the bridge unit transport sensor-1 Paper stopping at the bridge unit transport sensor-1
1Bridge unitCheck if there is any paper in the bridge unit and remove it if there is.2
2Is the bridge unit transport sensor-1 working? (Perform the input check: 03-[FAX]OFF/[3]/[F]) / 03-
[FAX]OFF/[4]/[F])
Yes3
No
  1. Check if the connector CN302 on the LGC board is disconnected from the bridge unit transport sensor-1 (entrance sensor) or the harnesses are open circuited. Check if the connector J681 of the bridge unit is disconnected. Correct if any.
  2. Replace the bridge unit transport sensor-1.
  3. Replace the LGC board.
3Is the bridge unit gate solenoid working? (Perform the output check: 03-232)Yes4
No
  1. Check if the connector CN302 on the LGC board is disconnected from the bridge unit gate solenoid or the harnesses are open circuited. Check if the connector J681 of the bridge unit is disconnected. Correct if any.
  2. Replace the bridge unit gate solenoid.
4Does the transport roller of the bridge unit work when the fuser motor is rotated? (Perform the output check: 03-113/163)YesCheck if the rollers in the exit roller, the pressure spring and the bridge unit are worn out.
NoCheck the drive system of the equipment and bridge unit.
LGC board
Bridge unit gate solenoid
8​
[E930] Paper not reaching the bridge unit transport sensor-2 [E940] Paper stopping at the bridge unit transport sensor-2​
Finisher jam (Bridge unit)Paper not reaching the bridge unit transport sensor-2 Paper stopping at the bridge unit transport sensor-2
2Is the bridge unit transport sensor-2 working? (Perform the input check: 03-[FAX]OFF/[3]/[G]) / 03-
[FAX]OFF/[4]/[G])
Yes3
No
  1. Check if the connector CN334 on the LGC board is disconnected from the bridge unit transport sensor-2 (exit sensor) or the harnesses are open circuited. Check if the connector J523 of the bridge unit is disconnected. Correct if any.
  2. Replace the bridge unit transport sensor-2.
3Does the transport roller of the bridge unit work when the fuser motor is rotated? (Perform the output check: 03-113/163)YesCheck if the rollers in the exit roller, the pressure spring and the bridge unit are worn out.
LGC board
[ 2 ] Job separator jam​
[E950] Jam not reaching the JSP feed sensor [E951] Stop jam at the JSP feed sensor​
Job separator jamJam not reaching the job separator transport sensor Stop jam at the job separator transport sensor
1Open the JSP cover. Is there any paper on the transport path?YesRemove the paper.
No2
2Is the JSP feed sensor working?
(Perform the input check in the test mode: 03- [FAX]ON/[3]/[D])
Yes3
No
  • Check if the connector of the JSP feed sensor is disconnected.
  • Check if either of the connectors CN260 or CN262 on the JSP board is disconnected.
  • Replace the JSP feed sensor.
3Replacing board
JSP feed sensor
JSP board
LGC board
[ 3 ] Offset tray jam​
8​
[E960] Jam not reaching the OCT feed sensor [E961] Stop jam at the OCT feed sensor​
Offset tray jamJam not reaching the offset tray transport sensor Stop jam at the offset tray transport sensor
1Open the OCT cover. Is there any paper on the transport path?YesRemove the paper.
No2
2Is the OCT feed sensor working?
(Perform the input check in the test mode: 03- [FAX]ON/[3]/[G])
Yes3
No
  • Check if the connector of the OCT feed sensor is disconnected.
  • Check if either of the connectors CN260 or CN262 on the OCT board is disconnected.
  • Replace the OCT feed sensor.
3PC board
OCT feed sensor
OCT board
LGC board
[ 4 ] Paper jam in puncher unit​
[E9F0] Punching jam​
Finisher jam (Puncher unit)Punching jam
MJ-1101 (when MJ-6103 is installed), MJ-1107 (when MJ-6104 is installed)​
Check itemMeasures
Punch motor
  • Motor check
  • Connector check
  • Harness check
Punch HP sensor
  • Sensor check
  • Connector check
  • Harness check
Hole punch control PC board
  • Board check
  • Connector check
  • Harness check
Punch motor
Punch HP sensor
MJ-6008
ErrorTiming of detection
Punch motor
Punch shaft home position sensor Punch shaft rotational direction sensor
The turning OFF of the punch shaft home position sensor (S35) is not detected in the specified time when the punch motor (M15) is rotated.
The turning ON of the punch shaft home position sensor (S35) is not detected in the specified time when the punch motor (M15) is rotated.
The punch shaft home position sensor (S35) and the punch shaft rotational direction sensor (S34) do not specify the home position or the rotational direction correspondingly during initialization, or initialization is not finished at a turning-ON point for the punch shaft home position sensor (S35).
Probable causeChecking and measures
Punch motor (M15) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
Punch shaft home position sensor (S36) abnormalityMeasure the voltage on pin CN3.3 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Punch shaft rotational direction sensor (S35) abnormalityMeasure the voltage on pin CN3.9 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Punch motor clock sensor (S37) abnormalityMeasure the voltage on pin CN3.6 on the hole punch control PC board (HP). Then check that the measured voltage is 1V or lower when not shielded and within the range of 5V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Hole punch control PC board (HP): CN3, CN6)
Hole punch control PC board (HP) abnormalityIf the error still occurs after replacing the motor, sensors and connectors, exchange the hole punch control PC board (HP).
8​
[ 5 ] Paper jam in finisher section​
[EA10] Paper transport delay jam​
Paper jam in finisher sectionPaper transport delay jam
MJ-1101/1107
Check itemMeasures
Removing paperCheck if there is any paper in the finisher or on the transport path of the equipment and remove it if there is.
Entrance sensorIs there a disconnection of the connector, incorrect installation or breakage of the entrance sensor (S1)?
Gate solenoid
  • Is the gap between the flapper and entrance roller shaft other than 0.600.20mm when the gate solenoid (SOL2) is pulled?
  • Is the harness between the gate solenoid (SOL2) and the finisher control PC board (CN22) disconnected or open circuited?
Entrance motorIs the harness between the entrance motor (M1) and the finisher control PC board (CN7) disconnected or open circuited?
Harness checkIs the harness between the gate solenoid (SOL2) and the finisher control PC board (CN22) disconnected or open circuited?
Entrance sensor
Finisher controller PC board
[EA10] Transport delay jam (paper not inserted)​
MJ-1106/1108
Paper jam in finisher sectionTransport delay jam (paper not inserted)
Check itemMeasures
Feeding sensor (S22)Check if there is a disconnection of the connector, incorrect installation or breakage of the feeding sensor (S22). If there is, reinstall the sensor correctly or replace it.
Transport path switching solenoid (SOL5)Check that the gap between the transfer guide surface and the upper surface of the flapper tip is in the acceptable range according to the status of the transport path switching solenoid (SOL5) (solenoid OFF: 1.5 to 2.1 mm, solenoid ON: 2.3 to 2.9 mm). If it is not, adjust it.
Entrance motor (M1)Check the harness between the entrance motor (M1) and the finisher controller board (CN26). If there is any abnormality, correct it.
Interface PC board (I/F)Check the harness between the transport path switching solenoid (SOL5) and the interface PC board (CN6), If there is any abnormality, correct it.
  • Board check
  • Connector check (CN5, CN6, CN7)
  • Harness check
Check itemMeasures
Finisher control PC board (FIN)
  • Board check
  • Connector check (CN25, CN27)
  • Harness check
Entrance motor (M1)
[EA20] Paper transport stop jam​
8​
MJ-1101/1107
Check itemMeasures
Transport sensor
  • Sensor check
  • Connector check (S2)
  • Harness check
Finisher controller PC boardBoard check(CN22)
Transport sensor
MJ-1106/1108
Check itemMeasures
FinisherCheck if there is any paper in the finisher or on the transport path of the equipment and remove it if there is.
Entrance sensor (S1)
  • Sensor check
  • Connector check
  • Harness check
  • Board check
  • Connector check (CN26)
  • Harness check
[EA10, EA20] 1st transport motor (M8) fault/ 2nd transport motor (M4) fault​
Finisher jam (Finisher section)Paper transport delay jam
MJ-1032
1st transport motor (M8) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN22)
2nd transport motor (M4) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN14)
Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the motor and the connector, exchange the finisher control PC board (FIN).
[EA10, EA20] Transport motor-1 (M1) fault/ Transport motor-2 (M2) fault​
MJ-1033
Transport motor-1 (M1) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN13)
Transport motor-2 (M2) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
Paddle home position sensor faultMeasure the voltage of the TP30 on the finisher control PC board (FIN), and check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V  5% when shielded. If the voltage does not fall within the above range, replace the sensor.
[EA21] Paper size error jam (outlet sensor)​
[EA22] Paper size error jam (punch paper edge sensor)​
Finisher jam (Finisher section)Paper size error jam (outlet sensor)
MJ-1101/1107
Check itemMeasures
Entrance sensor
  • Sensor check(S1)
  • Connector check (CN7, CN22)
  • Harness check
Transport sensor
  • Sensor check(S2)
  • Harness check
Entrance sensor
Transport sensor
8​
MJ-1106/1108
Check itemMeasures
  • Sensor check
  • Connector check
  • Harness check
Transport sensor (S2)
  • Sensor check
  • Connector check
  • Harness check
  • Board check
  • Connector check (CN6, CN26)
  • Harness check
[EA23] Paper transport stop jam (transport sensor)​
[EA24] Paper transport stop jam (between entrance & transport sensor) [EA25] Paper transport stop jam (after paper stack exit)​
[EA26] Paper transport stop jam (stop command request) [EA27] Paper transport stop jam (paper not inserted)​
[EA28] Paper transport stop jam (paper holder plate operation delay) [EA29] Paper transport stop jam (stack transport delay)​
Paper jam in finisher sectionPaper transport stop jam
MJ-1101/1107
Check itemMeasures
Entrance sensor
  • Sensor check(S1)
  • Harness check
Transport sensor
  • Sensor check(S2)
  • Harness check
Entrance sensor
Transport sensor
MJ-1106/1108
Check itemMeasures
  • Sensor check
  • Connector check
  • Harness check
  • Sensor check
  • Connector check
  • Harness check
Processing tray sensor (S12)
  • Sensor check
  • Connector check
  • Harness check
Paper holding camIs there any mechanical problem when the paper holding cam is rotated?
Assist arm motor (M10)
  • Motor check
  • Connector check
  • Harness check
Buffer tray guideOpen and close the buffer tray guide.
If there is any mechanical problem, fix its mechanism.
buffer tray guide motor (M2)
  • Motor check
  • Connector check
  • Harness check
  • Board check
  • Connector check (CN6, CN13, CN11, CN18, CN26)
  • Harness check
[EA25] Stack exit motor (M5) abnormality​
Paper jam in finisher sectionPaper transport jam in the Finisher
MJ-1032
Stack exit motor (M5) abnormalityCheck if the electrical continuity of the coil is normal. If electricity is not conducted, replace the motor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN14)
Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the motor, sensor and connectors, exchange the finisher control PC board (FIN).
[EA2E, EA31] Transport jam in Finisher​
Paper jam in finisher sectionPaper transport remaining jam in the Finisher
8​
MJ-1032
Entrance path sensor (S19) abnormalityMeasure the voltage on TP86 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Middle path sensor (S7) abnormalityMeasure the voltage on TP84 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V±5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Sub-path sensor (S8) abnormalityMeasure the voltage on TP85 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V±5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN6, CN22)
Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the sensor and the connector, exchange the finisher control PC board (FIN).
[EA31] Transport path paper remaining jam​
Paper jam in finisher sectionTransport path paper remaining jam
MJ-1101/1107
Check itemMeasures
Transport sensor
  • Sensor check(S2)
  • Connector check (CN22)
  • Harness check
  • Board check
  • Harness check
Transport sensor
MJ-1106/1108
Check itemMeasures
  • Sensor check
  • Connector check
  • Harness check
  • Board check
  • Connector check (CN6)
  • Harness check
[EA31] Transport jam in Finisher​
Paper jam in finisher sectionPaper transport remaining jam in the Finisher:
MJ-1033
Entrance path sensor (S1) abnormalityMeasure the voltage on TP1 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN1)
[EA32] Exit paper remaining jam​
Paper jam in finisher sectionExit paper remaining jam
MJ-1101/1107
Check itemMeasures
  • Sensor check (S12)
  • Connector check (CN11)
  • Harness check
  • Sensor check
  • Harness check
8​
MJ-1106/1108
Check itemMeasures
  • Sensor check
  • Connector check
  • Harness check
  • Board check
  • Connector check (CN18)
  • Harness check
[EA32] Finishing tray paper detection error​
MJ-1032
Finishing tray sensor (S4) abnormalityMeasure the voltage on TP14 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN5)
MJ-1033
Finishing tray sensor (S2) abnormalityMeasure the voltage on TP26 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN8)
[EA40] Cover open error​
Paper jam in finisher sectionCover open error
MJ-1101/1107/MJ-1106/1108
Check itemMeasures
Cover
  • Close the front cover or the stationary tray if they are opened.
Front cover switch (SW1)
  • Sensor check
  • Connector check
  • Harness check
Stationary tray opening/closing switch (SW2)
  • Sensor check
  • Connector check
  • Harness check
Finisher controller board
  • Connector check(CN16)
  • Board check
Cover locking bracketIf it is broken.
[EA40] Cover open detection error​
MJ-1032
Sub-path opening/closing sensor (S12) abnormalityMeasure the voltage on TP12 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when not shielded and within the range of 3.3V±5% when shielded. If the voltage does not fall within the range mentioned, replace the sensor.
Front cover switch (SW1) abnormalityMeasure the voltage on TP77 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when the switch is ON and within the range of 3.3V ± 5% when OFF. If the voltage does not fall within the range mentioned, replace the switch.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connector. (Finisher control PC board (FIN): CN10, CN13)
Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the switches, sensor and connector, exchange the finisher control PC board (FIN).
8​
[EA50] Stapling jam​
Paper jam in finisher sectionStapling jam
MJ-1101/1107
Check itemMeasures
Finisher
  • Check if there is any paper in the finisher or on the transport path of the equipment or on the finishing tray. Remove it if there is.
  • Is the jam cleared by taking off the staple cartridge from the finisher and removing the staple sheet slid from the staple case?
  • Check if the actuator of the stapler interference sensor (S11) moves smoothly.
  • Check if the connector CN2 on the finisher controller PC board is disconnected from the stapler or the harnesses are open circuited. Correct if any.
  • Check the harnesses in the stapler are disconnected or open circuited. Correct if any.
MJ-1032
Staple unit stapling start position sensor (S17) abnormalityMeasure the voltage on TP23 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when the sensor is ON and within the range of 3.3V5% when OFF. If the voltage does not fall within the range mentioned, replace the staple unit.
Staple unit staple empty sensor (S18) abnormalityMeasure the voltage on TP24 on the finisher control PC board (FIN). Then check that the measured voltage is 1V or lower when the sensor is ON and within the range of 3.3V5% when OFF. If the voltage does not fall within the range mentioned, replace the staple unit.
Faulty cables and connectorsCheck if the electrical continuity between the connector terminals is normal. If electricity is not conducted, replace the connectors. (Finisher control PC board (FIN): CN17)
Finisher control PC board (FIN) abnormalityIf the error still occurs after replacing the staple unit and the connectors, exchange the finisher control PC board (FIN).
[EA60] Early arrival jam​
Paper jam in finisher sectionEarly arrival jam
MJ-1101/1107
Check itemMeasures
Finisher
  • Check if there is any disconnection, incorrect installation or breakage on the entrance sensor (S1). Correct if any.
  • Check if the connector CN7 on the finisher controller PC board is disconnected from the entrance sensor (S1) and the harnesses are disconnected or open circuited. Correct if any.
Entrance sensor
[EA70] Stack exit belt home position error / Stack slider home position error​
Paper jam in finisher sectionStack exit belt home position error / Stack slider home position error
MJ-1101/1107
Check itemMeasures
Stack belt exit home position sensorCheck if the connector CN11 on the finisher controller PC board is disconnected from the stack belt exit home position sensor (S9) and the harnesses are open circuited. Correct if any.
Stack transport motorIs the harness between the stack transport motor (M5) and the finisher control PC board (CN10) disconnected or open circuited?
8​
MJ-1106/1108
Check itemMeasures
Stack belt exit home position sensorCheck if there is a disconnection of the connector, incorrect installation or breakage of the stack belt exit home position sensor (S9). If there is, reinstall the sensor correctly or replace it.
Check if the connector (CN18) on the finisher controller PC board is disconnected from the stack belt exit home position sensor (S9) and the harnesses are open circuited. Correct if any.
Stack transport motorCheck if the connector (CN17) on the finisher controller PC board is disconnected from the stack transport motor (M8) and the harnesses are open circuited. Correct if any.
