Photocopier and Printer
Toshiba
Toshiba e-STUDIO 307/357/457/507 Service Manual Part 15
<blockquote data-quote="John" data-source="post: 45" data-attributes="member: 2"><p> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9388</td><td></td><td>Date display format of the file name of "Save as file" and Email transmission</td><td>0</td><td>0~5</td><td>SYS</td><td>Sets the data display format of the file of "Save as file" and Email transmission.<br /> 0: [YYYY][MM][DD] [HH][mm][SS]<br /> 1: [YY][MM][DD] [HH][mm][SS]<br /> 2: [YYYY][MM][DD]<br /> 3: [YY][MM][DD]<br /> 4: [HH][mm][SS]<br /> 5: [YYYY][MM][DD] [HH][mm][SS][mm0]<br /> The order of [YY], [MM] and [DD] varies depending on the setting of the code 08-9102 (Data display format).</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9389</td><td></td><td>Single page data saving directory at "Save as file"</td><td>0</td><td>0~1</td><td>SYS</td><td>Sets the directory where the file of "Save as file" is saved.<br /> 0: Save it under a subfolder<br /> 1: Save it without creating a subfolder</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9390</td><td></td><td>Page number display format of the file of "Save as file" and Email transmission</td><td>4</td><td>3~6</td><td>SYS</td><td>Sets the digit of a page number attached on the file. 3-6: 3-6 digits</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9391</td><td></td><td>Extension (suffix) format of the file of "Save as file"</td><td>3</td><td>3~6</td><td>SYS</td><td>Sets the extension digits of the file to be saved. 3: Auto 4: 4 digits 5: 5 digits 6: 6 digits</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9394</td><td></td><td>Single-page option for storing File and sending Email</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Sets 1 page as 1 file<br /> 1: Makes a file based on the original</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9397</td><td></td><td>Execution of user authentication when the user ID is not entered</td><td>2</td><td>0~2</td><td>SYS</td><td>0: Forcible execution<br /> 1: Execution impossible (pooled in the invalid queue) 2: Forcible deletion</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Card reader</td><td>LDAP authentication</td><td>9398</td><td></td><td>LDAP attribute name settings 1</td><td>eBMUse rCard</td><td>-</td><td>SYS</td><td>Maximum 32 characters (ASCII).</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9399</td><td></td><td>Role Based Access DAP search index</td><td>0</td><td>Refer to contents</td><td>SYS</td><td>This code is used to specify the ID for the LDAP server to implement Role-Based Access Control.<br /> <Acceptable value> 0~4294967295</td><td>5</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9403</td><td></td><td>Communication speed and settings of<br /> Ethernet</td><td>1</td><td>Refer to contents</td><td>NIC</td><td>1: Auto(100MBPS) 3: 10MBPS Full Duplex 5:<br /> 100MBPS Full Duplex 6: Auto(1000MBPS) 7: 1000MBPS Full Duplex</td><td>12</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9406</td><td></td><td>Method for acquiring IP address</td><td>2</td><td>1~3</td><td>NIC</td><td>1: Static IP address 2: Dynamic IP address (DHCP) 3: Dynamic IP address (DHCP) without AutoIP</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Address</td><td></td><td>9408</td><td></td><td>IP address</td><td>Refer to contents</td><td>Refer to contents</td><td>NIC</td><td><Default value> 0.0.0.0<br /> <Acceptable value> 0.0.0.0-255.255.255.255</td><td>12</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Address</td><td></td><td>9409</td><td></td><td>Subnet mask</td><td>Refer to contents</td><td>Refer to contents</td><td>NIC</td><td><Default value> 0.0.0.0<br /> <Acceptable value> 0.0.0.0-255.255.255.255</td><td>12</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Address</td><td></td><td>9410</td><td></td><td>Gateway</td><td>Refer to contents</td><td>Refer to contents</td><td>NIC</td><td><Default value> 0.0.0.0<br /> <Acceptable value> 0.0.0.0-255.255.255.255</td><td>12</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9411</td><td></td><td>Availability of IPX/SPX</td><td>2</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9414</td><td></td><td>Availability of AppleTalk</td><td>2</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9416</td><td></td><td>Availability of LDAP</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>DNS</td><td></td><td>9417</td><td></td><td>Availability of DNS</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Address</td><td></td><td>9418</td><td></td><td>IP address to DNS server (Primary)</td><td>Refer to contents</td><td>Refer to contents</td><td>NIC</td><td>000.000.000.000-255.255.255.255<br /> <Default value> 000.000.000.000<br /> <Acceptable value> 0.0.0.0~255.255.255.255</td><td>12</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Address</td><td></td><td>9419</td><td></td><td>IP address to DNS server (Secondary)</td><td>Refer to contents</td><td>Refer to contents</td><td>NIC</td><td>000.000.000.000-255.255.255.255<br /> <Default value> 000.000.000.000<br /> <Acceptable value> 0.0.0.0~255.255.255.255</td><td>12</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9421</td><td></td><td>Availability of SLP</td><td>1</td><td>1~2</td><td>NIC</td><td>Sets the availability of SLP on NetWare. 1: Enabled 2: Disabled</td><td>12</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9426</td><td></td><td>Availability of Bindery</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9427</td><td></td><td>Availability of NDS</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9430</td><td></td><td>Availability of HTTP server</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9437</td><td></td><td>Availability of SMTP client</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9440</td><td></td><td>Availability of SMTP server</td><td>1</td><td>1~2</td><td>UTY</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9446</td><td></td><td>Availability of POP3 clients</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9459</td><td></td><td>Availability of FTP server</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9463</td><td></td><td>MIB function</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Valid 2: Invalid</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9473</td><td></td><td>Availability of Raw/TCP</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Valid 2: Invalid</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9475</td><td></td><td>Availability of LPD client</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Valid 2: Invalid</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9478</td><td></td><td>Availability of IPP</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Valid 2: Invalid</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9481</td><td></td><td>IPP printer name</td><td>MFPseri al</td><td>-</td><td>NIC</td><td>Maximum 127 letters The Network-related serial number of the<br /> equipment appears on “serial“</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9486</td><td></td><td>IPP printer "Make and Model"</td><td>mfp<br /> model name</td><td>-</td><td>NIC</td><td>Maximum 127 letters</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9487</td><td></td><td>IPP printer information (more) MFGR</td><td>-</td><td>-</td><td>NIC</td><td>Maximum 127 letters</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9488</td><td></td><td>IPP message from operator</td><td>-</td><td>-</td><td>NIC</td><td>Maximum 127 letters</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9489</td><td></td><td>Availability of FTP print</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Available 2: Not available</td><td>12</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9499</td><td></td><td>Page number limitation for printing text of received E- mail</td><td>5</td><td>1~99</td><td>SYS</td><td></td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9505</td><td></td><td>Bonjour setting</td><td>1</td><td>1~2</td><td>NIC</td><td>1: Valid 2: Invalid</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9515</td><td></td><td>Windows domain<br /> No.1 of user authentication</td><td>-</td><td>-</td><td>UTY</td><td>Maximum 128 letters</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9516</td><td></td><td>PDC (Primary Domain Controller) name</td><td>-</td><td>-</td><td>UTY</td><td>Maximum 128 letters</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9517</td><td></td><td>BDC (Backup Domain Controller) name</td><td>-</td><td>-</td><td>UTY</td><td>Maximum 128 letters</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Address</td><td></td><td>9525</td><td></td><td>Display of MAC address</td><td>-</td><td>-</td><td>-</td><td>(**:**:**:**:**:**)<br /> The address is displayed as above. 6-byte data is divided by colon.</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9548</td><td></td><td>SSL setting HTTP<br /> server OFF/ON setting</td><td>2</td><td>1~2</td><td>-</td><td>1: Enabled 2: Disabled</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9550</td><td></td><td>SSL setting IPP<br /> server OFF/ON setting</td><td>2</td><td>1~2</td><td>-</td><td>1: Enabled 2: Disabled</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9552</td><td></td><td>SSL setting SSL ftp server OFF/ON</td><td>2</td><td>1~2</td><td>-</td><td>OFF/ON<br /> 1: Valid2: Invalid</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9556</td><td></td><td>SSL setting SSL POP3 Client OFF/ON</td><td>2</td><td>1~3</td><td>-</td><td>OFF/ON<br /> 1: Valid 2: Invalid 3: Use imported certificate</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9563</td><td></td><td>IP Conflict Detect</td><td>1</td><td>1~2</td><td>-</td><td>OFF/ON<br /> 1: Valid 2: Invalid</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9564</td><td></td><td>SNTP Enable</td><td>2</td><td>1~2</td><td>-</td><td>OFF/ON<br /> 1: Valid 2: Invalid</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Enabling server's IP address acquired by DHCP</td><td></td><td>9580</td><td></td><td>Domain Name Server option (6)</td><td>1</td><td>1~2</td><td>-</td><td>1: Enabled 2: Disabled<br /> * This value is used only when DHCP is enabled.</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Enabling server's IP address acquired by DHCP</td><td></td><td>9581</td><td></td><td>NetBIOS over TCP/IP Name Server option<br /> (44) = Primary and Secondary Wins NAME</td><td>1</td><td>1~2</td><td>-</td><td>1: Enabled 2: Disabled<br /> * This value is used only when DHCP is enabled</td><td>12</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Enabling server's IP address acquired by DHCP</td><td></td><td>9584</td><td></td><td>SMTP Server Option<br /> (69) Simple Mail Server Address</td><td>2</td><td>1~2</td><td>-</td><td>1: Enabled 2: Disabled<br /> * This value is used only when DHCP is enabled.</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Enabling server's IP address acquired by DHCP</td><td></td><td>9585</td><td></td><td>POP3 Server Option<br /> (70) Post Office Server Address</td><td>2</td><td>1~2</td><td>-</td><td>1: Enabled 2: Disabled<br /> * This value is used only when DHCP is enabled.</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Enabling server's IP address acquired by DHCP</td><td></td><td>9587</td><td></td><td>SNTP Server Option<br /> (42) NTP Server Address</td><td>2</td><td>1~2</td><td>-</td><td>1: Enabled 2: Disabled<br /> * This value is used only when DHCP is enabled.</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Network</td><td></td><td></td><td>9599</td><td></td><td>Samba server ON/OFF setting</td><td>1</td><td>1-4</td><td>NIC</td><td>1: Samba enabled<br /> 2: Samba disabled<br /> 3: Print Share disabled 4: File Share disabled</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>General</td><td></td><td>9601</td><td></td><td>Equipment number<br /> (serial number) display</td><td>0</td><td>9 digits</td><td>SYS</td><td>This code can be also keyed in from the adjustment mode (05-9043). 9 digits</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9602</td><td></td><td>Dealer's name</td><td>-</td><td>-</td><td>SYS</td><td>Maximum 100 letters Needed at initial registration</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>General</td><td>9603</td><td></td><td>Login name</td><td>-</td><td>-</td><td>SYS</td><td>Maximum 20 letters Needed at initial registration</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>Call /Display function</td><td>9604</td><td></td><td>Display set of [Service Notification] button</td><td>Refer to contents</td><td>0~1</td><td>SYS</td><td>0: Not displayed 1: displayed<br /> <Default value> NAD: 1<br /> MJD: 1<br /> Other: 0</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan<br /> ce (Remote)</td><td></td><td></td><td>9605</td><td></td><td>Sending error history of equipment</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Invalid 1: Valid</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan<br /> ce (Remote)</td><td></td><td></td><td>9606</td><td></td><td>Setting total counter transmission interval</td><td>-</td><td>-</td><td>SYS</td><td>(Hour/Hour/Minute/Minute)</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan<br /> ce (Remote)</td><td></td><td></td><td>9607</td><td></td><td>Destination E-mail address 2</td><td>-</td><td>-</td><td>SYS</td><td>Maximum 192 letters</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan<br /> ce (Remote)</td><td></td><td></td><td>9608</td><td></td><td>Destination E-mail address 3</td><td>-</td><td>-</td><td>SYS</td><td>Maximum 192 letters</td><td>11</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9610</td><td></td><td>Remote-controlled service polling day selection Day-1</td><td>0</td><td>0~31</td><td>SYS</td><td>0: OFF 1 to 31: 1st to 31st of a month</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9611</td><td></td><td>Remote-controlled service polling day selection Day-2</td><td>0</td><td>0~31</td><td>SYS</td><td>0: OFF 1 to 31: 1st to 31st of a month</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9612</td><td></td><td>Remote-controlled service polling day selection Day-3</td><td>0</td><td>0~31</td><td>SYS</td><td>0: OFF 1 to 31: 1st to 31st of a month</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9613</td><td></td><td>Remote-controlled service polling day selection Day-4</td><td>0</td><td>0~31</td><td>SYS</td><td>0: OFF 1 to 31: 1st to 31st of a month</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Maintenan ce</td><td>RDMS</td><td>Remote-controlled service polling day</td><td>9614</td><td></td><td>Sunday</td><td>1</td><td>0-1</td><td>SYS</td><td>0: Invalid<br /> 1: Valid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Maintenan ce</td><td>RDMS</td><td>Remote-controlled service polling day</td><td>9615</td><td></td><td>Monday</td><td>1</td><td>0-1</td><td>SYS</td><td>0: Invalid<br /> 1: Valid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Maintenan ce</td><td>RDMS</td><td>Remote-controlled service polling day</td><td>9616</td><td></td><td>Tuesday</td><td>1</td><td>0-1</td><td>SYS</td><td>0: Invalid<br /> 1: Valid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Maintenan ce</td><td>RDMS</td><td>Remote-controlled service polling day</td><td>9617</td><td></td><td>Wednesday</td><td>1</td><td>0-1</td><td>SYS</td><td>0: Invalid<br /> 1: Valid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Maintenan ce</td><td>RDMS</td><td>Remote-controlled service polling day</td><td>9618</td><td></td><td>Thursday</td><td>1</td><td>0-1</td><td>SYS</td><td>0: Invalid<br /> 1: Valid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Maintenan ce</td><td>RDMS</td><td>Remote-controlled service polling day</td><td>9619</td><td></td><td>Friday</td><td>1</td><td>0-1</td><td>SYS</td><td>0: Invalid<br /> 1: Valid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Maintenan ce</td><td>RDMS</td><td>Remote-controlled service polling day</td><td>9620</td><td></td><td>Saturday</td><td>1</td><td>0-1</td><td>SYS</td><td>0: Invalid<br /> 1: Valid</td><td>1</td><td>Yes</td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9624</td><td></td><td>Information of supplies setting of toner cartridge K</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Invalid 1: Valid</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>Remote-controlled service polling</td><td>9626</td><td></td><td>End of month</td><td>0</td><td>0-1</td><td>SYS</td><td>0: Invalid 1: Valid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9627</td><td></td><td>Sending mail text of InternetFAX</td><td>1</td><td>0-1</td><td>SYS</td><td>0: Invalid (Not sending the mail text) 1: Valid (Sending the mail text)</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9628</td><td></td><td>From Name Creation setting in SMTP authentication</td><td>0</td><td>0-2</td><td>SYS</td><td>0: Not edited<br /> 1: Account name of FROM ADDRESS and Device name<br /> 2: LDAP searching</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Wireless LAN</td><td></td><td></td><td>9649</td><td></td><td>Wireless LAN supplicant Wireless LAN setting</td><td>2</td><td>1~2</td><td>NIC</td><td>This setting is whether the wireless LAN connection is enabled or disabled.<br /> 1: Enabled 2: Disabled</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Bluetooth</td><td></td><td></td><td>9680</td><td></td><td>Bluetooth ON/OFF setting</td><td>1</td><td>0~1</td><td>SYS</td><td>0: OFF 1: ON</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Bluetooth</td><td></td><td></td><td>9681</td><td></td><td>Bluetooth Device name</td><td>MFPseri al</td><td>-</td><td>SYS</td><td>Maximum 32 letters</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Bluetooth</td><td></td><td></td><td>9682</td><td></td><td>Bluetooth Discovery</td><td>1</td><td>0~1</td><td>SYS</td><td>0: Not allowed 1: Allowed</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Bluetooth</td><td></td><td></td><td>9683</td><td></td><td>Bluetooth Security</td><td>1</td><td>0~1</td><td>SYS</td><td>0: Security function OFF 1: Security function ON</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Bluetooth</td><td></td><td></td><td>9684</td><td></td><td>Bluetooth PIN</td><td>0000</td><td>-</td><td>SYS</td><td>Maximum 8 digits (8-digit sequence) This setting is valid only when the bluetooth security function is ON.</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Bluetooth</td><td></td><td></td><td>9685</td><td></td><td>Bluetooth Data encryption</td><td>1</td><td>0~1</td><td>SYS</td><td>0: Not encrypted 1: Encrypted This setting is valid only when the bluetooth security function is ON.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>Enabling server's IP address acquired by DHCP</td><td></td><td>9694</td><td></td><td>DNS domain name Option (15) DNS domain name of the client</td><td>1</td><td>1~2</td><td>-</td><td>1: Enabled 2: Disabled<br /> * This value is used only when DHCP is enabled.</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>General</td><td></td><td>9700</td><td></td><td>Service technician telephone number</td><td>0</td><td>32 digits</td><td>SYS</td><td>A telephone number can be entered up to 32 digits. Use the [Pause] button to enter a hyphen (-).</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td></td><td></td><td>9702</td><td></td><td>Automatic calibration disclosure level</td><td>1</td><td>0-2</td><td>SYS</td><td>Sets the disclosing level of automatic calibration. 0: Service technician 1: Administrator 2: User</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>Counter</td><td>Maintenan ce</td><td></td><td></td><td>9703</td><td></td><td>Error history display</td><td>-</td><td>-</td><td>SYS</td><td>Displaying of the latest 20 errors data</td><td>2</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9709</td><td></td><td>Default data saving directory of "Scan to File"</td><td>0</td><td>0~2</td><td>SYS</td><td>0: Local directory 1: REMOTE 1 2: REMOTE 2</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>General</td><td>9710</td><td></td><td>Remote-controlled service function</td><td>2</td><td>0~2</td><td>SYS</td><td>0: Valid (Remote-controlled server) 1: Valid (L2) 2: Invalid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9711</td><td></td><td>Remote-controlled service URL setting</td><td>NULL</td><td>-</td><td>SYS</td><td>Maximum 256 Bytes</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9715</td><td></td><td>Initially-registered server URL setting</td><td>Refer to contents</td><td>-</td><td>SYS</td><td>Maximum 256 letters<br /> <br /> <Default value> <a href="https://device.mfp-" target="_blank">https://device.mfp-</a><br /> support.com:443/device/firstregist.ashx</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Short time interval of emergency mode</td><td></td><td>9718</td><td></td><td>Recovery time setting</td><td>24</td><td>1~48</td><td>SYS</td><td>Sets the time interval to recover from the emergency mode to the normal mode. (Unit: Hour)</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Short time interval of emergency mode</td><td></td><td>9719</td><td></td><td>Interval setting</td><td>60</td><td>30~360</td><td>SYS</td><td>(Unit: Minute)</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>General</td><td>9723</td><td></td><td>Periodical polling timing</td><td>1700</td><td>0~2359</td><td>SYS</td><td>0 (0:00) to 2359 (23:59)</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>General</td><td>9724</td><td></td><td>Writing data of self- diagnostic code</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Prohibited 1: Accepted</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>General</td><td>9726</td><td></td><td>Remote-service initial registration</td><td>0</td><td>0~3</td><td>SYS</td><td>0: OFF 1: Start 2: Only certification is scanned 3: RDMS communication starts</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>General</td><td>9727</td><td></td><td>Remote-controlled service tentative password</td><td>NULL</td><td>-</td><td>SYS</td><td>Maximum 10 letters</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>General</td><td>9729</td><td></td><td>Status of remote- service initial regist</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Not registered 1: Registered</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>Maintenan ce</td><td>RDMS</td><td>Call /Display function</td><td>9730</td><td></td><td>Service center call function</td><td>1</td><td>0-2</td><td>SYS</td><td>0: OFF<br /> 1: Notifies all service calls<br /> 2: Notifies all but paper jams</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9732</td><td></td><td>Service center call<br /> HTTP server URL setting</td><td>NULL</td><td>-</td><td>SYS</td><td>Maximum 256 letters</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Counter</td><td></td><td></td><td>9736</td><td></td><td>Validity of interrupt copying when external counters are installed</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Invalid1: Valid</td><td>1</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>Call /Display function</td><td>9739</td><td></td><td>Toner-end notification</td><td>0</td><td>0~2</td><td>SYS</td><td>0: RDMS toner empty notified immediately 1: RDMS toner empty notified once a day 2: RDMS toner empty not notified</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9740</td><td></td><td>HTTP proxy setting</td><td>1</td><td>0~1</td><td>SYS</td><td>0: Valid 1: Invalid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9741</td><td></td><td>HTTP proxy IP address setting</td><td>Refer to contents</td><td>-</td><td>SYS</td><td>Input IP address or FQDN.<br /> <Default value> 0.0.0.0</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9742</td><td></td><td>HTTP proxy port number setting</td><td>0</td><td>0~65535</td><td>SYS</td><td></td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9743</td><td></td><td>HTTP proxy ID setting</td><td>NULL</td><td>-</td><td>SYS</td><td>Maximum 30 letters</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9744</td><td></td><td>HTTP proxy password setting</td><td>NULL</td><td>-</td><td>SYS</td><td>Maximum 30 letters</td><td>11</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>HTTP</td><td>9745</td><td></td><td>HTTP proxy panel display</td><td>1</td><td>0~1</td><td>SYS</td><td>0: Valid 1: Invalid</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9746</td><td></td><td>802.1X/Dynamic WEP selecting button display</td><td>1</td><td>0~1</td><td>SYS</td><td>Switches whether a selecting button for Security mode 802.1X/Dynamic WEP is displayed or not.<br /> 0: Not displayed 1: Displayed</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9749</td><td></td><td>WIA Scan Driver</td><td>1</td><td>1~2</td><td>NIC</td><td>Selects WIA Scan Driver. 1: TTEC 2: Microsoft</td><td>12</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9750</td><td></td><td>Automatic ordering function of supplies</td><td>3</td><td>0~3</td><td>SYS</td><td>0: Ordered by FAX 1: Ordered by E-mail 2: Ordered by HTTP 3: OFF</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9751</td><td></td><td>Automatic ordering function of supplies FAX number</td><td>-</td><td></td><td>SYS</td><td>Maximum 32 digits Enter hyphen with the [Pause] button</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9752</td><td></td><td>Automatic ordering function of supplies E- mail address</td><td>-</td><td></td><td>SYS</td><td>Maximum 192 letters List: 256 digits</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9756</td><td></td><td>Automatic ordering function of supplies User's name</td><td>-</td><td></td><td>SYS</td><td>Maximum 50 letters</td><td>11</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9757</td><td></td><td>Automatic ordering function of supplies User's telephone number</td><td>-</td><td></td><td>SYS</td><td>Maximum 32 digits Enter hyphen with the [Pause] button</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9758</td><td></td><td>Automatic ordering function of supplies User's E-mail address</td><td>-</td><td></td><td>SYS</td><td>Maximum 192 letters List: 256 digits</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9759</td><td></td><td>Automatic ordering function of supplies User's address</td><td>-</td><td></td><td>SYS</td><td>Maximum 100 letters</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9760</td><td></td><td>Automatic ordering function of supplies Service number</td><td>-</td><td></td><td>SYS</td><td>Maximum 5 digits</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9761</td><td></td><td>Automatic ordering function of supplies Service technician's name</td><td>-</td><td></td><td>SYS</td><td>Maximum 50 letters</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9762</td><td></td><td>Automatic ordering function of supplies Service technician's telephone number</td><td>-</td><td></td><td>SYS</td><td>Maximum 32 digits Enter hyphen with the [Pause] button</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9763</td><td></td><td>Automatic ordering function of supplies Service technician's E-mail address</td><td>-</td><td></td><td>SYS</td><td>Maximum 192 letters List: 256 digits</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9764</td><td></td><td>Automatic ordering function of supplies Supplier's name</td><td>-</td><td></td><td>SYS</td><td>Maximum 50 letters</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9765</td><td></td><td>Automatic ordering function of supplies Supplier's address</td><td>-</td><td></td><td>SYS</td><td>Maximum 100 letters</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9766</td><td></td><td>Automatic ordering function of supplies Notes</td><td>-</td><td></td><td>SYS</td><td>Maximum 128 letters</td><td>11</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9776</td><td></td><td>Information about supplies Part number of toner cartridge</td><td>-</td><td></td><td>SYS</td><td>Maximum 20 digits</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9777</td><td></td><td>Information about supplies Order quantity of toner cartridge</td><td>1</td><td>1~99</td><td>SYS</td><td></td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9778</td><td></td><td>Information about supplies Condition number of toner cartridge</td><td>1</td><td>1~99</td><td>SYS</td><td></td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td>Remote-controlled service</td><td>Call /Display function</td><td>9783</td><td></td><td>Automatic supply ordering display</td><td>Refer to contents</td><td>0~2</td><td>SYS</td><td>0: Valid (FAX/Internet FAX)<br /> 1: Valid (FAX/Internet FAX/HTTP) 2: Invalid<br /> <Default value> NAD: 0<br /> Others: 2</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan<br /> ce (Remote)</td><td></td><td></td><td>9784</td><td></td><td>Counter notification Remote FAX setting</td><td>-</td><td></td><td>SYS</td><td>Maximum 32 digits Enter hyphen with the [PAUSE] button.</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9787</td><td></td><td>Suspend when quota is empty</td><td>0</td><td>0-1</td><td>SYS</td><td>Sets whether the process is suspended immediately or suspended after the job is completed if quota is used up.<br /> 0: Suspended immediately<br /> 1: Suspended after the job is finished</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9788</td><td></td><td>Service call checking period setting</td><td>6</td><td>0~12</td><td>SYS</td><td>0: No checking period specified (= Calls service technician immediately)<br /> 1: 10 minutes 2: 30 minutes 3: 1 hour 4: 6 hours 5:<br /> 12 hours 6: 24 hours 7: 48 hours 8: 7 days 9: 1<br /> month 10: 1 year 11: 5 years<br /> 12: Not limited (= Calls service technician if such error has occurred in the past even once or more)</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9793</td><td></td><td>Service Notification setting</td><td>0</td><td>0~2</td><td>SYS</td><td>Enables to set up to 3 E-mail addresses to be sent. (08-9793, 9794, 9795)<br /> 0: Invalid 1: Valid (E-mail) 2: Valid (FAX)</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan<br /> ce (Remote)</td><td></td><td></td><td>9794</td><td></td><td>Destination E-mail address 1</td><td>-</td><td></td><td>SYS</td><td>Maximum 192 letters</td><td>11</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan<br /> ce (Remote)</td><td></td><td></td><td>9795</td><td></td><td>Total counter<br /> information transmission setting</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Invalid 1: Valid</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce (Remote)</td><td></td><td></td><td>9796</td><td></td><td>Total counter transmission date setting</td><td>0</td><td>0~31</td><td>SYS</td><td>0 to 31</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan<br /> ce (Remote)</td><td></td><td></td><td>9797</td><td></td><td>PM counter notification setting</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Invalid 1: Valid</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9798</td><td></td><td>Temporary communication password setting</td><td>99999</td><td>-</td><td>SYS</td><td>Sets a temporary communication password. The password can be entered in alphanumeric characters (A to Z, a to z, 0 to 9) up to 10 digits.<br /> The entered password is displayed with "*" on the touch panel and the self-diagnostic lists. (Maximum 10 digits, minimum 5 digits)</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9799</td><td></td><td>Local authentication mode switchover</td><td>0</td><td>0~1</td><td>SYS</td><td>Sets the authentication mode when "0: (Internal authentication)" is selected in the code 08-9293. 0: Card ID differs from the User ID<br /> 1: Card ID is the same as the User ID</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Process</td><td></td><td></td><td>9804</td><td></td><td>Forcible mode<br /> change in toner empty status</td><td>1</td><td>0~2</td><td>SYS</td><td>0: SLEEP MODE 1: AUTO POWER SAVE 2: READY</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Laser</td><td></td><td></td><td>9805</td><td></td><td>Polygonal motor standby rotation Shift waiting time at job end</td><td>3</td><td>0~9</td><td>SYS</td><td>0: 0 sec. (current setting) (Polygonal motor ready rotation at job end)<br /> 1 to 9:Setting value x 5sec.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Interruption of stapling operation (no<br /> staple)</td><td></td><td>9810</td><td>0</td><td>Copying</td><td>1</td><td>0~1</td><td>SYS</td><td>0: Continues printing by switching sort setting 1: Interrupts printing</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Interruption of stapling operation (no<br /> staple)</td><td></td><td>9810</td><td>1</td><td>Printing / BOX printing</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Continues printing by switching sort setting 1: Interrupts printing</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling setting Maximum number of sheets acceptable exceeding upper limit<br /> / Long size</td><td></td><td>9811</td><td>0</td><td>Plain/Recycled</td><td>0</td><td>-50~50</td><td>SYS</td><td>-50 to 50</td><td>4</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling setting Maximum number of sheets acceptable exceeding upper limit<br /> / Long size</td><td></td><td>9811</td><td>1</td><td>Thick1</td><td>0</td><td>-50~50</td><td>SYS</td><td>-50 to 50</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling setting Maximum number of sheets acceptable exceeding upper limit<br /> / Long size</td><td></td><td>9811</td><td>2</td><td>Thick2</td><td>0</td><td>-50~50</td><td>SYS</td><td>-50 to 50</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling setting Maximum number of sheets acceptable exceeding upper limit<br /> / Long size</td><td></td><td>9811</td><td>3</td><td>Thick3</td><td>0</td><td>-50~50</td><td>SYS</td><td>-50 to 50</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9816</td><td></td><td>Addition of the page number to the multi- page file name of File</td><td>0</td><td>0~1</td><td>SYS</td><td>Only when job is executed with TimeStamp enabled for file storage, page number is added with the format set at 08-9387.<br /> 0: Invalid (Page number not added) 1: Valid (Page number added)</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9817</td><td></td><td>Maximum number of decimals in extension fields</td><td>2</td><td>0~6</td><td>SYS</td><td>0: 0 digit 1: 1 digit 2: 2 digits 3: 3 digits 4: 4 digits 5: 5<br /> digits 6: 6 digits</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9818</td><td></td><td>Default saving/attachment files of "File/Email"</td><td>0</td><td>0~1</td><td>SYS</td><td>0: DOCYYMMDD 1: NetBios name</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Off Device Customization Architecture</td><td></td><td>9819</td><td></td><td>STAGE SSL</td><td>0</td><td>0-1</td><td>SYS</td><td>Sets whether SSL communication is enabled or disabled for remote scanning.<br /> 0: Disabled<br /> 1: Enabled</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Off Device Customization Architecture</td><td></td><td>9820</td><td></td><td>STAGE I/F</td><td>1</td><td>0-1</td><td>SYS</td><td>Sets whether interface is enabled or disabled for remote scanning.<br /> 0: Disabled<br /> 1: Enabled</td><td>1</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Off Device Customization Architecture</td><td></td><td>9821</td><td></td><td>Port number</td><td>49629</td><td>0-65535</td><td>SYS</td><td>Sets a port number for the remote scanning.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Off Device Customization Architecture</td><td></td><td>9822</td><td></td><td>SSL port number</td><td>49630</td><td>0-65535</td><td>SYS</td><td>Sets an SSL port number for remote scanning using SSL communication.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9823</td><td></td><td>User name and password at user authentication or "Save as file"</td><td>0</td><td>0~2</td><td>SYS</td><td>0: User name and password of the device<br /> 1: User name and password at the user authentication (Template registration information comes first when a template is retrieved.)<br /> 2: User name and password at the user authentication (User information of the authentication comes first when a template is retrieved.)</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Image</td><td></td><td></td><td>9825</td><td></td><td>Image quality of the black part in the ACS mode</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Black 1: Gray scale</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9829</td><td></td><td>Department management limitation setting</td><td>0</td><td>0~1</td><td>SYS</td><td>Decide the default limitation setting when the new department code is created.<br /> 0: No limit 1: Limited</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Bluetooth</td><td></td><td></td><td>9841</td><td></td><td>Bluetooth BIP Paper type</td><td>0</td><td>0~3</td><td>SYS</td><td>0: Fit page 1: 1/2 size 2: 1/4 size 3: 1/8 size</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Bluetooth</td><td></td><td></td><td>9846</td><td></td><td>Bluetooth BIP Paper size</td><td>Refer to contents</td><td>0~13</td><td>SYS</td><td>0: Ledger 1: Legal 2: Letter 3: Computer 4: Statement<br /> 5: A3 6: A4 7: A5 9: B4 10: B5 11: Folio 12: Legal13"<br /> 13: LetterSquare<br /> <Default value> NAD: 2<br /> Others: 6</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td></td><td></td><td>9847</td><td></td><td>Hole punching setting</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Invalid 1: Valid</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9880</td><td></td><td>Total counter transmission date setting (2)</td><td>0</td><td>0~31</td><td>SYS</td><td>0 to 31</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9881</td><td></td><td>Day of total counter data transmission</td><td>0</td><td>0~127</td><td>SYS</td><td>1 byte 00000000(0)-01111111(127)<br /> From the 2nd bit - Sunday, Monday, Tuesday, Wednesday,<br /> Thursday, Friday, Saturday</td><td>1</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9883</td><td></td><td>Hardcopy security printing</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Disable1 1: Enable</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Counter</td><td></td><td></td><td>9884</td><td></td><td>Count switching of hardcopy security printing level 1</td><td>0</td><td>0~1</td><td>SYS</td><td>Sets the way of counting for hardcopy security printing. 0: Counted as 1<br /> 1: Counted as 2</td><td>2</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Scanning</td><td></td><td></td><td>9886</td><td></td><td>Decimal point indication for Enhanced Scan Template</td><td>Refer to contents</td><td>0~1</td><td>SYS</td><td>0: Comma 1: Period<br /> <Default value> MJD: 0<br /> Others: 1</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Scanner</td><td></td><td></td><td>9888</td><td></td><td>Permission setting for changing the scan parameter when recalling an extension</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Prohibited 1: Permitted</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td>Data cloning</td><td></td><td>9889</td><td></td><td>Status display for USB cloning</td><td>0</td><td>0~1</td><td>SYS</td><td>Acceptance of the usage of the USB data cloning tool 0: Accepted 1: Not accepted</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Screen setting</td><td></td><td>9891</td><td></td><td>Warning message<br /> when PM time has come</td><td>1</td><td>0~1</td><td>SYS</td><td>0: No warning notification 1: Display warning notification</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9894</td><td></td><td>Calibration chart charging method</td><td>0</td><td>0-1</td><td>SYS</td><td>Decides whether the calibration chart printing is charged or not 0: No charge 1: Charge</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Image</td><td></td><td></td><td>9897</td><td></td><td>Default value setting of background peak adjustment (Black)</td><td>5</td><td>1~9</td><td>SYS</td><td>1: -4 2: -3 3: -2 4: -1 5: 0 6: +1 7: +2 8: +3 9: +4</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Image</td><td></td><td></td><td>9898</td><td></td><td>Default value setting of density in the scan mode (Color)</td><td>6</td><td>0~11</td><td>SYS</td><td>0: Auto 1: -5 2: -4 3: -3 4: -2 5: -1 6: 0 7: +1 8: +2 9: +3<br /> 10: +4 11: +5</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Image</td><td></td><td></td><td>9899</td><td></td><td>Default value setting of density in the scan mode (Gray)</td><td>6</td><td>0~11</td><td>SYS</td><td>0: Auto 1: -5 2: -4 3: -3 4: -2 5: -1 6: 0 7: +1 8: +2 9: +3<br /> 10: +4 11: +5</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td>System</td><td></td><td>9900</td><td></td><td>System software ROM version</td><td>-</td><td>-</td><td>-</td><td>T330SYXXXXXX</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td>Engine</td><td></td><td>9901</td><td></td><td>Engine ROM version</td><td>-</td><td></td><td>-</td><td>33xM-XXX</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td>Engine</td><td></td><td>9902</td><td></td><td>Scanner ROM version</td><td>-</td><td></td><td>-</td><td>330S-XXX</td><td>2</td><td>Yes</td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td>Engine</td><td></td><td>9903</td><td></td><td>RADF ROM version</td><td>-</td><td></td><td>-</td><td>DF-XXXX</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td>Finisher</td><td></td><td>9904</td><td></td><td>Finisher ROM version</td><td>-</td><td></td><td>-</td><td>SDL-XXX FIN-XXX</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td>FAX</td><td></td><td>9905</td><td></td><td>Fax board ROM version</td><td>-</td><td></td><td>-</td><td>F670-XXX</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td>HDD</td><td></td><td>9930</td><td></td><td>System software OS version</td><td>-</td><td></td><td>-</td><td>T160SF0WXXXX</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9933</td><td></td><td>Domain participation confirmation of printing when LDAP authentication is used</td><td>1</td><td>0~1</td><td>SYS</td><td>When LDAP is selected as authentication method for user authentication, checking of domain participation of client computer for print job authentication is set. This function is available only when department management is enabled.<br /> 0: Disabled<br /> 1: Enabled</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling setting Acceptable number of sheets exceeding upper limit / Short size</td><td></td><td>9937</td><td>0</td><td>Plain/Recycled</td><td>0</td><td>-100~100</td><td>SYS</td><td>-100 to 100</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling setting Acceptable number of sheets exceeding upper limit / Short size</td><td></td><td>9937</td><td>1</td><td>Thick1</td><td>0</td><td>-100~100</td><td>SYS</td><td>-100 to 100</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling setting Acceptable number of sheets exceeding upper limit / Short size</td><td></td><td>9937</td><td>2</td><td>Thick2</td><td>0</td><td>-100~100</td><td>SYS</td><td>-100 to 100</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling setting Acceptable number of sheets exceeding upper limit / Short size</td><td></td><td>9937</td><td>3</td><td>Thick3</td><td>0</td><td>-100~100</td><td>SYS</td><td>-100 to 100</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling Acceptable number of sheets exceeding upper limit<br /> / Saddle stitch</td><td></td><td>9938</td><td>0</td><td>Plain/Recycled</td><td>0</td><td>-15~15</td><td>SYS</td><td>-15 to 15</td><td>4</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling Acceptable number of sheets exceeding upper limit<br /> / Saddle stitch</td><td></td><td>9938</td><td>1</td><td>Thick1</td><td>0</td><td>-15~15</td><td>SYS</td><td>-15 to 15</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling Acceptable number of sheets exceeding upper limit<br /> / Saddle stitch</td><td></td><td>9938</td><td>2</td><td>Thick2</td><td>0</td><td>-15~15</td><td>SYS</td><td>-15 to 15</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Finisher</td><td>Stapling Acceptable number of sheets exceeding upper limit<br /> / Saddle stitch</td><td></td><td>9938</td><td>3</td><td>Thick3</td><td>0</td><td>-15~15</td><td>SYS</td><td>-15 to 15</td><td>4</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td>Finisher</td><td></td><td>9944</td><td></td><td>Finisher punch ROM version</td><td>-</td><td>-</td><td>-</td><td>PUN-XXX FIN-XXX</td><td>2</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Version</td><td></td><td></td><td>9945</td><td></td><td>Finisher Converter ROM version</td><td>-</td><td>-</td><td>-</td><td>CNV-XXX</td><td>2</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>E-mail</td><td></td><td>9946</td><td></td><td>Number of Email transmission retries</td><td>3</td><td>0~14</td><td>SYS</td><td>The number of times of E-mail communication retry for Scan to E-mail and Internet Fax is set.</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td>E-mail</td><td></td><td>9947</td><td></td><td>E-mail transmission retry interval</td><td>1</td><td>0~15</td><td>SYS</td><td>When E-mail transmission retry for Scan to E-mail and<br /> Internet Fax is performed, the interval is set. 0 min - 15 min</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9954</td><td></td><td>Control box counter /<br /> job list printing operation</td><td>0</td><td>0-1</td><td>SYS</td><td>0: Invalid<br /> 1: Valid</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td></td><td></td><td>9955</td><td></td><td>Name of [EXTENSION] button</td><td>EXTENS ION</td><td></td><td>SYS</td><td>Sets the name of " EXTENSION" button displayed on the MENU screen. Maximum 10 characters with alphameric characters and symbols.</td><td>11</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9958</td><td></td><td>Bcc address display ON/OFF setting (Job Log / Job Status)</td><td>0</td><td>0~1</td><td>SYS</td><td>Sets whether the Bcc address is displayed or not on the Job Log or Job Status.<br /> 0: OFF (Bcc address not displayed) 1: ON (Bcc address displayed)</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9959</td><td></td><td>Bcc address display ON/OFF setting (Job Notification)</td><td>1</td><td>0~1</td><td>SYS</td><td>Sets whether the Bcc address is displayed or not on all the Job Notifications except for the administrator.<br /> 0: OFF (Bcc address not displayed) 1: ON (Bcc address displayed)</td><td>1</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9960</td><td></td><td>Equipment information (SRAM)</td><td>Refer to contents</td><td>0~2</td><td>SYS</td><td>Displays the equipment information in SRAM. 0: Not set<br /> 1: Destinations other than NAD 2: NAD<br /> <Default value> NAD: 2<br /> Others: 1</td><td>2</td><td></td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>User interface</td><td></td><td></td><td>9963</td><td></td><td>Display of receiving job on PRINT/JOB STATUS screen</td><td>2</td><td>0-2</td><td>SYS</td><td>0: Disabled<br /> 1: Enabled (Other user's receiving job can be deleted) 2: Enabled (Other user's receiving job cannot be deleted)<br /> * This setting is automatically disabled in the high security mode.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Default mode setting</td><td>Default setting (PPC)</td><td>9970</td><td></td><td>Original mode (Black)</td><td>0</td><td>0~4</td><td>SYS</td><td>0: Text/Photo 1: Text 2: Photo 3: Not used 4: Custom</td><td>1</td><td>Yes</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>General</td><td></td><td></td><td>9971</td><td></td><td>Image quality density adjustment at power- ON Default setting</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Automatic 1: Manual (Center)</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Blank page judgment Default setting</td><td>PPC</td><td>9972</td><td></td><td>Blank page judgment Default setting</td><td>0</td><td>-3~3</td><td>SYS</td><td>The larger the value is, the more the paper is judged as a blank page. The smaller the value is, the less the paper is judged as a blank page.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>Blank page judgment Default setting</td><td>SCN</td><td>9973</td><td></td><td>Blank page judgment Default setting</td><td>0</td><td>-3~3</td><td>SYS</td><td>The larger the value is, the more the paper is judged as a blank page. The smaller the value is, the less the paper is judged as a blank page.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td>ACS judgment adjustment Default setting</td><td>SCN</td><td>9975</td><td></td><td>ACS judgment adjustment Default setting</td><td>0</td><td>-3~3</td><td>SYS</td><td>The larger the value is, the more the original is judged as color data. The smaller the value is, the less the original is judged as black data.</td><td>1</td><td></td></tr></table> <table style='width: 100%'><tr><td>05/08</td><td>Mode</td><td>Element</td><td>Sub<br /> element</td><td>Item</td><td>Subitem</td><td>Code</td><td>Sub-<br /> code</td><td>Details</td><td>Default<br /> value</td><td>Acceptable<br /> value</td><td>RAM</td><td>Contents</td><td>Proc<br /> edure</td><td>Service<br /> UI</td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9980</td><td></td><td>Address setting for TO/CC/BCC at authentication</td><td>0</td><td>0-4</td><td>SYS</td><td>Sets address of TO/CC/BCC when the user authentication and E-mail authentication are enabled. When the value of this code is set to "1", the address specified as From Address is input to TO destination field. TO/CC/BCC field cannot be edited.<br /> When the value of this code is set to "2 to 4", the address specified as From Address is input to each field. TO/CC/BCC field can be edited by pressing the TO/CC/BCC button.<br /> 0: Disabled<br /> 1: Fixed to TO field. 2: Added to TO field. 3: Added to CC field.<br /> 4: Added to BCC field.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Network</td><td></td><td></td><td>9981</td><td></td><td>Sending body text of email</td><td>1</td><td>0~1</td><td>SYS</td><td>Sets whether the job information is output in the body of e-mail when executing e-mail send job.<br /> 0: Disabled 1: Enabled</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>User interface</td><td></td><td></td><td>9982</td><td></td><td>Switch of display attribute of [EXTENSION] icon</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Touch is invalid when authentication is not completed.<br /> 1: Touch is valid when authentication is not completed.</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9984</td><td></td><td>Document name in printing/scanning</td><td>0</td><td>0~1</td><td>SYS</td><td>0: Not confidential name (default) 1: Confidential name</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting Mode</td><td>System</td><td>User interface</td><td></td><td></td><td>9985</td><td></td><td>Screen displayed by<br /> pressing MENU button</td><td>0</td><td>0-1</td><td>SYS</td><td>0: MENU screen<br /> 1: EWB screen</td><td>1</td><td></td></tr><tr><td>08</td><td>Setting mode</td><td>System</td><td>Maintenan ce</td><td></td><td></td><td>9987</td><td></td><td>Retention of fax sending settings</td><td>0</td><td>0~3</td><td>SYS</td><td>Sets whether the fax sending settings are retained or not.<br /> 0: Clears all settings (The authentication screen is displayed if user authentication or department management is enabled.)<br /> 1: Clears all<br /> 2: Clears only addresses 3: Retains all settings<br /> * When the value of this code is set to "3", the value of 08-3847 (FAX mistransmission prevention) is automatically set to "1" (Enabled).</td><td>1</td><td></td></tr></table><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p>e-STUDIO206L/256/306/356/456/506</p><p></p><p></p><p></p><table style='width: 100%'><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr></table><p></p><p></p><table style='width: 100%'><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr></table><p></p><p></p><table style='width: 100%'><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr></table><p></p><p></p><table style='width: 100%'><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_001.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_002.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_003.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_004.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_005.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_006.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_007.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_008.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_009.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_010.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_011.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_012.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_013.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_014.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_015.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_016.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_017.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_018.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_019.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_020.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_021.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_022.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_023.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_024.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_025.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_026.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_027.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_028.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_029.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_030.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_031.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_032.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_033.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_034.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_035.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_036.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_037.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_038.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_039.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_040.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_041.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_042.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_043.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_044.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_045.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_046.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_047.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_048.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_049.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_050.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_051.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_052.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_053.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_054.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_055.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_056.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_057.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_058.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_059.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_060.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_061.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_062.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_063.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_064.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_065.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_066.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_067.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_068.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_069.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_070.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_071.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_072.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_073.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_074.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_075.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_076.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_077.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_078.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_079.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_080.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_081.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_082.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_083.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_084.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_085.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_086.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_087.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_088.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_089.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_090.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_091.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_092.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_093.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_094.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_095.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_096.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_097.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_098.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_099.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_100.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_101.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_102.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_103.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_104.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_105.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td></tr></table> <table style='width: 100%'><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_106.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_107.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_108.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_109.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_110.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_111.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_112.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_113.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_114.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_115.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_116.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_117.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_118.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_119.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_120.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_121.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_122.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_123.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_124.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_125.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_126.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_127.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_128.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_129.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_130.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_131.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_132.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_133.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_134.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_135.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_136.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_137.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_138.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_139.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_140.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_141.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_142.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_143.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_144.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_145.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_146.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_147.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_148.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_149.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_150.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_151.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_152.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_153.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_154.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_155.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_156.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_157.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_158.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_159.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_160.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_161.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_162.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_163.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_164.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_165.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_166.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_167.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td></tr></table><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p>e-STUDIO207L/257/307/357/457/507</p><p></p><p></p><p></p><table style='width: 100%'><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr></table><p></p><p></p><table style='width: 100%'><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr></table><p></p><p></p><table style='width: 100%'><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr></table><p></p><p></p><table style='width: 100%'><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_168.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_169.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_170.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_171.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_172.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_173.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_174.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_175.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_176.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_177.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_178.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_179.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_180.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_181.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_182.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_183.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_184.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_185.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_186.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_187.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_188.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_189.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_190.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_191.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_192.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_193.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_194.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_195.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_196.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_197.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_198.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_199.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_200.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_201.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_202.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_203.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_204.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_205.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_206.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_207.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_208.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_209.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_210.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_211.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_212.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_213.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_214.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_215.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_216.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_217.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_218.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_219.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_220.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_221.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_222.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_223.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_224.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_225.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_226.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_227.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_228.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_229.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_230.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_231.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_232.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_233.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_234.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_235.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_236.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_237.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_238.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_239.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_240.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_241.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_242.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_243.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_244.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_245.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_246.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_247.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_248.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_249.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_250.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_251.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_252.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_253.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_254.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_255.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_256.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_257.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_258.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_259.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_260.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_261.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_262.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_263.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_264.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_265.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_266.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_267.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_268.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_269.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_270.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_271.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_272.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td></tr></table> <table style='width: 100%'><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_273.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_274.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_275.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_276.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_277.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_278.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_279.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_280.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_281.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_282.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_283.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_284.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_285.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_286.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_287.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_288.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_289.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_290.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_291.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_292.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_293.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_294.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_295.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_296.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_297.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_298.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_299.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_300.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_301.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_302.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_303.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_304.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_305.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_306.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_307.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_308.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_309.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_310.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_311.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_312.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_313.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_314.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_315.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_316.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_317.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_318.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_319.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_320.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_321.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_322.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_323.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_324.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td><td></td></tr><tr><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_325.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_326.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_327.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_328.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_329.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_330.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_331.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_332.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_333.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td><br /> <img src="https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_334.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td></tr></table><p></p><p></p><h3>REVISION RECORD</h3><h3>Ver.06</h3><p></p><p></p><table style='width: 100%'><tr><td>Ver. 06 <2014.04.17></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>Cover</td><td>Model names have been added.</td></tr><tr><td>Precautions</td><td>Model names and a note have been added.</td></tr><tr><td>1-1</td><td>"1.2 Main Features of e-STUDIO257/257P/357/457/507" has been added.</td></tr><tr><td>2-1 to 2-11</td><td>Specifications for the new models have been added.</td></tr><tr><td>2-14</td><td>New options have been added.</td></tr><tr><td>2-20</td><td>New options have been added.</td></tr><tr><td>2-23</td><td>Information of the supplies for the new models has been added.</td></tr><tr><td>3-1</td><td>A model information has been added.</td></tr><tr><td>3-3</td><td>A sectional view for the new models has been added.</td></tr><tr><td>3-4</td><td>A sectional view for the new models has been added.</td></tr><tr><td>3-5</td><td>Electric parts for the new models have been added.</td></tr><tr><td>3-7</td><td>An electric parts layout for the new models has been added.</td></tr><tr><td>3-10</td><td>An electric parts layout for the new models has been added.</td></tr><tr><td>3-13</td><td>An electric parts layout for the new models has been added.</td></tr><tr><td>3-14</td><td>An electric parts layout for the new models has been added.</td></tr><tr><td>3-15</td><td>New model names have been added.</td></tr><tr><td>3-16</td><td>New model names have been added.</td></tr><tr><td>3-19 to 3-24</td><td>A model information has been added.</td></tr><tr><td>3-28</td><td>A process condition for the new models has been added.</td></tr><tr><td>3-36</td><td>A model information has been added.</td></tr><tr><td>3-39</td><td>An illustration of the control panel for the new models has been added.</td></tr><tr><td>3-41 to 3-47</td><td>A new model information has been added.</td></tr><tr><td>3-48</td><td>"3.9.5 Process of detection of original size" has been added.</td></tr><tr><td>3-51</td><td>An external appearance of the new models has been added.</td></tr><tr><td>3-65 to 3-67</td><td>A model information has been added.</td></tr><tr><td>3-69</td><td>A model information has been added.</td></tr><tr><td>3-71 to 3-79</td><td>A model information has been added.</td></tr><tr><td>3-80</td><td>A model information has been added.</td></tr><tr><td>3-81</td><td>A model information has been added.</td></tr><tr><td>3-83</td><td>A model information has been added.</td></tr><tr><td>3-86</td><td>A model information has been added.</td></tr><tr><td>3-88</td><td>An information for the new models has been added.</td></tr><tr><td>3-89</td><td>An information for the new models has been added.</td></tr><tr><td>3-90</td><td>A model information has been added.</td></tr><tr><td>3-91</td><td>An information for the new models has been added.</td></tr><tr><td>4-1</td><td>A model information has been added.</td></tr><tr><td>4-8 to 4-17</td><td>Procedures of disassembly and replacement of the covers for the new models have been added.</td></tr><tr><td>4-18</td><td>A model information has been added.</td></tr><tr><td>4-22 to 4-25</td><td>Procedures of disassembly and replacement of the control panel for the new models have been added.</td></tr><tr><td>4-26</td><td>A model information has been added.</td></tr><tr><td>4-45 to 4-57</td><td>Procedures of disassembly and replacement of the scanner for the new models have been added.</td></tr><tr><td>4-58</td><td>A model information has been added.</td></tr><tr><td>4-60 to 4-62</td><td>Procedures of disassembly and replacement of the laser optical unit for the new models have been added.</td></tr></table><p></p><p></p><p>© 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 REVISION RECORD</p><p></p><table style='width: 100%'><tr><td>Ver. 06 <2014.04.17></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>4-66</td><td>New model names have been added.</td></tr><tr><td>4-77</td><td>New model names have been added.</td></tr><tr><td>4-78</td><td>New model names have been added.</td></tr><tr><td>4-86</td><td>New model names have been added.</td></tr><tr><td>4-87</td><td>Procedures of disassembly and replacement of the process unit fan for the new models have been added.</td></tr><tr><td>4-91</td><td>New model names have been added.</td></tr><tr><td>4-93</td><td>New model names have been added.</td></tr><tr><td>4-105</td><td>New model names have been added.</td></tr><tr><td>4-114</td><td>New model names have been added.</td></tr><tr><td>4-115</td><td>New model names have been added.</td></tr><tr><td>4-119</td><td>"Note" has been moved.</td></tr><tr><td>4-124</td><td>New model names have been added.</td></tr><tr><td>4-129</td><td>New model names have been added.</td></tr><tr><td>4-131</td><td>New model names have been added.</td></tr><tr><td>4-132</td><td>New model names have been added.</td></tr><tr><td>4-133</td><td>New model names have been added.</td></tr><tr><td>4-143</td><td>New model names have been added.</td></tr><tr><td>4-155</td><td>New model names have been added.</td></tr><tr><td>4-156</td><td>New model names have been added.</td></tr><tr><td>4-159</td><td>New model names have been added.</td></tr><tr><td>4-160</td><td>New model names have been added.</td></tr><tr><td>4-162</td><td>New model names have been added.</td></tr><tr><td>4-163</td><td>New model names have been added.</td></tr><tr><td>4-178 to 4-190</td><td>Procedures of disassembly and replacement of the damp heater have been added.</td></tr><tr><td>5-1</td><td>An information for the new models has been added.</td></tr><tr><td>5-14</td><td>Notes have been added.</td></tr><tr><td>5-15</td><td>"Note" has been added.</td></tr><tr><td>5-23</td><td>A note has been added.</td></tr><tr><td>5-27</td><td>"Note" has been added.</td></tr><tr><td>6-9 to 6-11</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-13</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-15 to 6-18</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-23</td><td>A model information has been added.</td></tr><tr><td>6-25</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-26</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-27</td><td>A model information has been added.</td></tr><tr><td>6-28</td><td>A model information has been added.</td></tr><tr><td>6-29</td><td>An adjustment procedure has been added.</td></tr><tr><td>6-31</td><td>A model information has been added.</td></tr><tr><td>6-34</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-36</td><td>A model information has been added.</td></tr><tr><td>6-37</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-39</td><td>A model information has been added.</td></tr><tr><td>6-39</td><td>Descriptions for the adjustment have been added.</td></tr><tr><td>6-41</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-42</td><td>An adjustment procedure has been added.</td></tr><tr><td>6-50</td><td>Descriptions for the new models have been added.</td></tr><tr><td>6-57</td><td>A model information has been added.</td></tr><tr><td>6-58</td><td>Descriptions for the new models have been added.</td></tr></table><p>e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD</p><p></p><table style='width: 100%'><tr><td>Ver. 06 <2014.04.17></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>6-60</td><td>A model information has been added.</td></tr><tr><td>6-61</td><td>A model information has been added.</td></tr><tr><td>6-71</td><td>A model information has been added.</td></tr><tr><td>6-72</td><td>A model information has been added.</td></tr><tr><td>6-73</td><td>A model information has been added.</td></tr><tr><td>6-74</td><td>A model information has been added.</td></tr><tr><td>6-77</td><td>A model information has been added.</td></tr><tr><td>6-85</td><td>A model information has been added.</td></tr><tr><td>6-95</td><td>New model names have been added.</td></tr><tr><td>6-108</td><td>New model names have been added.</td></tr><tr><td>7-4</td><td>New model names have been added.</td></tr><tr><td>7-5</td><td>The illustration of the operational flow has been changed.</td></tr><tr><td>7-16</td><td>New model names have been added.<br /> The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-17</td><td>Descriptions for the new models have been added.<br /> The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-18</td><td>Descriptions for the new models have been added.</td></tr><tr><td>7-19</td><td>The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-22</td><td>The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-24</td><td>The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-26</td><td>The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-27</td><td>Notes have been added.</td></tr><tr><td>7-28</td><td>New model names have been added.<br /> The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-29</td><td>The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-30</td><td>The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-31</td><td>The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-34</td><td>New model names have been added.<br /> The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-36</td><td>New model names have been added.<br /> The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-40</td><td>Model names have been added.<br /> The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-45</td><td>Model names have been added.<br /> The symbols given in the Replacement column have been changed.</td></tr><tr><td>7-50</td><td>PM kits for the new models have been added.</td></tr><tr><td>7-51</td><td>An information for the new models has been added.</td></tr><tr><td>7-53</td><td>A model information has been added.</td></tr><tr><td>7-54</td><td>"7.13 Machine Refreshing Checklist (e-STUDIO207L/257/307/357/457/507)" has been added.</td></tr><tr><td>8-9</td><td>Model names have been added.</td></tr><tr><td>8-10</td><td>Model names have been added.</td></tr><tr><td>8-11</td><td>Model names have been added.</td></tr><tr><td>8-12</td><td>Model names have been added.</td></tr><tr><td>8-13</td><td>Model names have been added.</td></tr><tr><td>8-14</td><td>Error codes C261 and C262 have been added.</td></tr><tr><td>8-15</td><td>Error codes C443, C445, C447, C449, C452 and C4B0 have been added. Model names have been added.</td></tr><tr><td>8-16</td><td>An error code C911 has been added. Model names have been added.</td></tr><tr><td>8-17</td><td>Model names have been added.</td></tr><tr><td>8-18</td><td>Model names have been added.</td></tr></table><p></p><p></p><p>© 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 REVISION RECORD</p><p></p><table style='width: 100%'><tr><td>Ver. 06 <2014.04.17></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>8-19</td><td>Model names have been added.</td></tr><tr><td>8-33</td><td>The title for chapter 8.2.5 has been changed from "TopAccess related error" to "TOSHIBA Remote monitoring system error".</td></tr><tr><td>8-35</td><td>An error code 6014 has been added.</td></tr><tr><td>8-50</td><td>Model names have been added.</td></tr><tr><td>8-51</td><td>Model names have been added.</td></tr><tr><td>8-72</td><td>Model names have been added.</td></tr><tr><td>8-90</td><td>Model names have been added.</td></tr><tr><td>8-92</td><td>Model names have been added.</td></tr><tr><td>8-93</td><td>Model names have been added.</td></tr><tr><td>8-95</td><td>Model names have been added.</td></tr><tr><td>8-96</td><td>Model names have been added.</td></tr><tr><td>8-98</td><td>Model names have been added.</td></tr><tr><td>8-99</td><td>Model names have been added.</td></tr><tr><td>8-100</td><td>Model names have been added.</td></tr><tr><td>8-101</td><td>Model names have been added.</td></tr><tr><td>8-102</td><td>Model names have been added.</td></tr><tr><td>8-103</td><td>Model names have been added.</td></tr><tr><td>8-104</td><td>Model names have been added.</td></tr><tr><td>8-105</td><td>Model names have been added.</td></tr><tr><td>8-107</td><td>Model names have been added.</td></tr><tr><td>8-109</td><td>Model names have been added.</td></tr><tr><td>8-110</td><td>Model names have been added.</td></tr><tr><td>8-111</td><td>Model names have been added.</td></tr><tr><td>8-112</td><td>Model names have been added.</td></tr><tr><td>8-113</td><td>Model names have been added.</td></tr><tr><td>8-114</td><td>Model names have been added.</td></tr><tr><td>8-115</td><td>Model names have been added.</td></tr><tr><td>8-116</td><td>Model names have been added.</td></tr><tr><td>8-117</td><td>Model names have been added.</td></tr><tr><td>8-118</td><td>Model names have been added.</td></tr><tr><td>8-119</td><td>Model names have been added.</td></tr><tr><td>8-120</td><td>Model names have been added.</td></tr><tr><td>8-128</td><td>The troubleshooting for C260 has been changed.</td></tr><tr><td>8-129</td><td>A troubleshooting for C260 for the new models has been added.</td></tr><tr><td>8-130</td><td>A troubleshooting for C261 have been added.</td></tr><tr><td>8-131</td><td>A troubleshooting for C262 have been added. Model names have been added.</td></tr><tr><td>8-133</td><td>A troubleshooting for C270 for the new models has been added.</td></tr><tr><td>8-134</td><td>A troubleshooting for C280 for the new models has been added. Model names have been added.</td></tr><tr><td>8-136</td><td>Model names have been added.</td></tr><tr><td>8-137</td><td>A troubleshooting for C290 for the new models has been added.</td></tr><tr><td>8-140</td><td>A troubleshooting for C911 for the new models has been added.</td></tr><tr><td>8-141</td><td>A troubleshooting for C411 has been added. A troubleshooting for C412 has been added.</td></tr><tr><td><br /> 8-144</td><td>A troubleshooting for C443 has been added. A troubleshooting for C445 has been added. A troubleshooting for C447 has been added.</td></tr><tr><td>8-145</td><td>A troubleshooting for C449 has been added.</td></tr><tr><td>8-146</td><td>A troubleshooting for C452 has been added.</td></tr></table><p></p><p></p><p>e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD</p><p></p><table style='width: 100%'><tr><td>Ver. 06 <2014.04.17></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>8-147</td><td>A troubleshooting for C4B0 has been added.</td></tr><tr><td>8-149</td><td>Model names have been added.</td></tr><tr><td>8-150</td><td>Model names have been added.</td></tr><tr><td>8-152</td><td>Model names have been added.</td></tr><tr><td>8-153</td><td>Model names have been added.</td></tr><tr><td>8-155</td><td>Model names have been added.</td></tr><tr><td>8-156</td><td>Model names have been added.</td></tr><tr><td>8-157</td><td>Model names have been added.</td></tr><tr><td>8-158</td><td>Model names have been added.</td></tr><tr><td>8-160</td><td>Model names have been added.</td></tr><tr><td>8-161</td><td>Model names have been added.</td></tr><tr><td>8-162</td><td>Model names have been added.</td></tr><tr><td>8-163</td><td>Model names have been added.</td></tr><tr><td>8-165</td><td>Model names have been added.</td></tr><tr><td>8-166</td><td>Model names have been added.</td></tr><tr><td>8-167</td><td>Model names have been added.</td></tr><tr><td>8-168</td><td>Model names have been added.</td></tr><tr><td>8-169</td><td>Model names have been added.</td></tr><tr><td>8-170</td><td>Model names have been added.</td></tr><tr><td>8-171</td><td>Model names have been added.</td></tr><tr><td>8-172</td><td>Model names have been added.</td></tr><tr><td>8-173</td><td>Model names have been added.</td></tr><tr><td>8-174</td><td>Model names have been added.</td></tr><tr><td>8-176</td><td>Model names have been added.</td></tr><tr><td>8-178</td><td>Model names have been added.</td></tr><tr><td>8-179</td><td>Model names have been added.</td></tr><tr><td>8-180</td><td>Model names have been added.</td></tr><tr><td>8-181</td><td>Model names have been added.</td></tr><tr><td>8-185</td><td>Model names have been added.</td></tr><tr><td>8-186</td><td>Model names have been added.</td></tr><tr><td>8-187</td><td>Model names have been added.</td></tr><tr><td>8-189</td><td>Model names have been added.</td></tr><tr><td>8-190</td><td>Model names have been added.</td></tr><tr><td>8-191</td><td>Model names have been added.</td></tr><tr><td>8-218</td><td>Model names have been added.</td></tr><tr><td>8-264</td><td>A troubleshooting for 6014 has been added.</td></tr><tr><td>8-292</td><td>The troubleshooting of "Background fogging" has been changed.</td></tr><tr><td>8-294</td><td>Model names have been added.</td></tr><tr><td>8-297</td><td>Model names have been added.</td></tr><tr><td>8-299</td><td>Model names have been added.</td></tr><tr><td>8-312</td><td>Model names have been added.</td></tr><tr><td>8-316</td><td>"8.5.3 Error code ÅgM00Åh is displayed while updating firmware" has been added.</td></tr><tr><td>9-1</td><td>Model names have been added.</td></tr><tr><td>9-8 to 9-15</td><td>Procedures of disassembly and replacement of the PC boards for the new models have been added.</td></tr><tr><td>9-16</td><td>An explanation of the difference between the current and new models has been added.</td></tr><tr><td>9-19</td><td>Notes have been added.</td></tr><tr><td>9-28</td><td>A model information has been added.</td></tr><tr><td>9-29</td><td>A model information has been added.</td></tr><tr><td>9-31</td><td>A note has been added.</td></tr></table><p>© 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 REVISION RECORD</p><p></p><table style='width: 100%'><tr><td>Ver. 06 <2014.04.17></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>9-32</td><td>A model information has been added.</td></tr><tr><td>9-33</td><td>A model information has been added. A note has been added.</td></tr><tr><td>9-36</td><td>A model information has been added.</td></tr><tr><td>11-1</td><td>Model names have been added.</td></tr><tr><td>11-7 to 11-10</td><td>Procedures of firmware upgrading for the new models have been added.</td></tr><tr><td>11-11</td><td>Model names have been added.</td></tr><tr><td>11-13 to 11-14</td><td>Procedures of firmware upgrading for the new models have been added.</td></tr><tr><td>11-15</td><td>Model names have been added.</td></tr><tr><td>11-17</td><td>Procedures of firmware upgrading for the new models have been added.</td></tr><tr><td>11-18</td><td>Explanations have been added.</td></tr><tr><td>11-20</td><td>An explanation for the M00 error has been added.</td></tr><tr><td>11-21</td><td>Descriptions for the punch firmware update errors have been added.</td></tr><tr><td>11-22</td><td>Descriptions for the finisher firmware update errors have been added. Descriptions for the saddle firmware update errors have been added.</td></tr><tr><td>11-23</td><td>The explanation about the change of the LCD screen has been altered.</td></tr><tr><td>11-24</td><td>The explanation about the change of the LCD screen has been altered.</td></tr><tr><td>11-25</td><td>Model names have been added.</td></tr><tr><td>11-27</td><td>Procedures of firmware upgrading for the new models have been added.</td></tr><tr><td>11-30</td><td>Procedures of firmware upgrading for the new models have been added.</td></tr><tr><td>11-34</td><td>Explanations for the firmware upgrading jig have been added.</td></tr><tr><td>11-35</td><td>Explanations for the firmware upgrading jig have been added.</td></tr><tr><td>11-38</td><td>Procedures of firmware upgrading for the new models have been added.</td></tr><tr><td>11-39</td><td>Procedures of firmware upgrading for the new models have been added.</td></tr><tr><td>11-44</td><td>A model information has been added.</td></tr><tr><td>11-46</td><td>A model information has been added.</td></tr><tr><td>11-77</td><td>A model information has been added.</td></tr><tr><td>11-78 to 11-80</td><td>Procedures of firmware upgrading for the new models have been added.</td></tr><tr><td>11-82</td><td>A model information has been added.</td></tr><tr><td>12-1</td><td>The note has been deleted.</td></tr><tr><td>12-2</td><td>The explanation about the filename has been changed.</td></tr><tr><td>14-1</td><td>Model names have been added.</td></tr><tr><td>14-2</td><td>An AC wire harness diagram for the new models has been added.</td></tr><tr><td>14-7 to 14-10</td><td>A DC wire harness diagram for the new models has been added.</td></tr><tr><td>1068</td><td>A model information has been added.</td></tr><tr><td>1131</td><td>Descriptions for the 08-2002 have been changeed.</td></tr><tr><td>1287 to 1341</td><td>05 codes for the new models have been added.</td></tr><tr><td>1342 to 1503</td><td>05 codes for the new models have been added.</td></tr><tr><td>1505</td><td>The maintenance check list of a model has been added.</td></tr></table><p></p><p></p><p>e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD</p><p></p><h3>Ver.05</h3><p></p><p></p><table style='width: 100%'><tr><td>Ver. 05 <2014.01.10></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td><br /> Trademarks</td><td>Windows 8, Windows Server 2003, Windows Server 2008, and Windows Server 2012 have been added.<br /> The trademark sentence for Microsoft has been changed. The official company name of “Apple” has been corrected.</td></tr><tr><td>2-9</td><td>The supported OS has been corrected.</td></tr><tr><td>5-1</td><td>The reference chapter for the self-diagnosis code has been corrected.</td></tr><tr><td>5-5</td><td>The reference chapter for the self-diagnosis code has been corrected.</td></tr><tr><td>5-30</td><td>The descriptions for (05) adjustment value difference, (08) setting value difference, and Job log/Message log have been added.</td></tr><tr><td>5-31</td><td>The CSV file names for (05) adjustment value difference, (08) setting value difference, and Job log/Message log have been added.</td></tr><tr><td>5-32</td><td>The descriptions for (05) adjustment value difference, (08) setting value difference, and Job log/Message log have been added.</td></tr><tr><td>5-33</td><td>The reference chapter for the self-diagnosis code has been corrected.</td></tr><tr><td>5-34</td><td>The reference chapter for the self-diagnosis code has been corrected.</td></tr><tr><td>5-35</td><td>The format of “PM SUPPORT CODE LIST” has been corrected.</td></tr><tr><td>5-36</td><td>The format of “PIXEL COUNTER CODE LIST (TONER CARTRIDGE)” has been corrected.</td></tr><tr><td>5-37</td><td>The format of “PIXEL COUNTER CODE LIST (SERVICEMAN)” has been corrected.</td></tr><tr><td>5-41</td><td>The format of “VERSION LIST” has been corrected.</td></tr><tr><td>5-42</td><td>The format of “TOTAL COUNTER LIST” has been corrected.</td></tr><tr><td>5-43</td><td>The list for (05) adjustment value/(08) setting value difference has been added.</td></tr><tr><td>5-52</td><td>08-6588 has been deleted.</td></tr><tr><td>6-27</td><td>The description has been changed.</td></tr><tr><td>6-40</td><td>05-9107 has been deleted.</td></tr><tr><td>7-5</td><td>The format of “PM SUPPORT CODE LIST” has been corrected.</td></tr><tr><td>7-16</td><td>08-6212, 08-6218, 08-6220, and 08-6222 have been deleted.</td></tr><tr><td>8-36</td><td>5C22 has been deleted.</td></tr><tr><td>8-37</td><td>Error code 6013 has been added.</td></tr><tr><td>8-255</td><td>5C22 has been deleted.</td></tr><tr><td>8-256</td><td>The troubleshooting for 6013 has been added.</td></tr><tr><td>8-286</td><td>08-2172 is changed to 08-2142.</td></tr><tr><td>8-307</td><td>The troubleshooting for H04 has been added.</td></tr><tr><td>9-17</td><td>The contents of “Precautions and Procedures when replacing the SYS board” has been changed.</td></tr><tr><td>9-18</td><td>The contents of “Precautions and Procedures when replacing the SYS board” has been changed.</td></tr><tr><td>9-19</td><td>The contents of “Precautions and Procedures when replacing the SYS board” has been changed.</td></tr><tr><td>9-20</td><td>The contents of “Precautions and Procedures when replacing the SYS board” has been changed.</td></tr><tr><td>9-22</td><td>The reference chapter for the self-diagnosis code has been corrected.</td></tr><tr><td>10-1</td><td>The description has been changed.</td></tr><tr><td>10-11</td><td>The description has been changed.</td></tr><tr><td>10-13</td><td>The toner remaining information has been added.</td></tr><tr><td>10-15</td><td>The toner remaining information has been added.</td></tr><tr><td>10-16</td><td>The toner remaining information has been added.</td></tr><tr><td>10-26</td><td>The toner remaining information has been added.</td></tr><tr><td>10-28</td><td>The toner remaining information has been added.</td></tr><tr><td>10-29</td><td>The toner remaining information has been added.</td></tr><tr><td>10-31</td><td>The toner remaining information has been added.</td></tr></table><p></p><p></p><p>© 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 REVISION RECORD</p><p></p><table style='width: 100%'><tr><td>Ver. 05 <2014.01.10></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>10-32</td><td>The toner remaining information has been added.</td></tr><tr><td>10-37</td><td>The toner remaining information has been added.</td></tr><tr><td>10-38</td><td>The toner remaining information has been added.</td></tr><tr><td>11-13</td><td>Note for the “Invalid Signature” error has been added. Error code H04 has been added.</td></tr><tr><td>11-29</td><td>Error code H04 has been added.</td></tr><tr><td>13-4</td><td>The value “5” has been added for 08-9016.</td></tr><tr><td><br /> Chapter 15</td><td>05-3009 and 9149 have been added.<br /> The acceptable value of 08-3623 has been changed.<br /> 08-3637, 3638, 3639, 3644, 6088-0, -1, 6089-0, -1, 6090, 6091, 8642, 8643, 8644, 8645,<br /> 8646, 8647, 8648, 8649, 8650, 8651, 8652, 8653, 8654, 8655, 8656, 8657, 8658, 8659,<br /> 8660, 8661, 8662, 8663, 8664-0, -1, -2, 8667, 8668, 8671-0, -1, -2, 8672-0, -1, -2, 8673,<br /> 8674, 8727, 8728-0, -1, -2, -3, -4, -6, -7, -8, -9, -10, -11, -12, -13, 8729, 8730, 8735, 8736,<br /> 8754, 8755, 8756-0, -1, 8758, 8762-0, 8771, 8774, 8781, 8785, 8786-0, -1, 8788, 8789,<br /> 8790, 8791, 8792, 8826, 8827, 8831, 9255, and 9963 have been added.<br /> The contents of 08-3864, 4105, 4131, 8981, 9022 have been changed. The item, details, and contents of 08-6080 have been changed.<br /> The sub element, item, subitem, and details of 08-6081-0, -1, 6084, 6085-0, -1 have been changed.<br /> The default values of 08-8520 and 8745 have been changed.<br /> The acceptable values and contents of 08-9016 and 9017 have been changed. The details of 08-9398 have been changed.</td></tr></table><p></p><p></p><h3>Ver.04</h3><p></p><p></p><table style='width: 100%'><tr><td>Ver. 04 <2013.10.3></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>GENERAL PRECAUTIONS</td><td>"General operations" has been added.</td></tr><tr><td>2-3</td><td>The description of warm-up time has been added.</td></tr><tr><td>3-31</td><td>The descriptions of the hibernation function have been added.</td></tr><tr><td>5-19</td><td>The descriptions of operations have been changed.</td></tr><tr><td>5-22</td><td>The descriptions of operations have been changed.</td></tr><tr><td>5-24</td><td>The step has been changed. The image has been changed.</td></tr><tr><td>5-25</td><td>The note has been added.</td></tr><tr><td>5-35</td><td>The illustration has been changed.</td></tr><tr><td>5-36</td><td>The illustration has been changed.</td></tr><tr><td>5-37</td><td>The illustration has been changed.</td></tr><tr><td>5-38</td><td>The illustration has been changed.</td></tr><tr><td>5-39</td><td>The illustration has been changed.</td></tr><tr><td>5-40</td><td>The illustration has been changed.</td></tr><tr><td>5-41</td><td>The illustration has been changed.</td></tr><tr><td>5-42</td><td>The illustration has been changed.</td></tr><tr><td>5-50</td><td>The illustration has been changed.</td></tr><tr><td>5-51</td><td>The illustration has been changed.</td></tr><tr><td>6-33</td><td>The table has been changed.</td></tr><tr><td>6-72</td><td>The step has been changed.</td></tr><tr><td>6-75</td><td>The step has been changed.</td></tr><tr><td>7-4</td><td>The codes have been added.</td></tr><tr><td>7-6</td><td>The illustration has been changed.</td></tr><tr><td>7-11</td><td>The illustration has been changed.</td></tr><tr><td>7-14</td><td>The codes have been changed.</td></tr><tr><td>7-51</td><td>The PM kits have been added. The column of Part name has been deleted.</td></tr><tr><td>8-3</td><td>The description has been added.</td></tr></table><p></p><p></p><p>e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD</p><p></p><table style='width: 100%'><tr><td>Ver. 04 <2013.10.3></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>8-21</td><td>Error code of F101_4 to F101_9 have been added</td></tr><tr><td>8-22</td><td>Error code of F106_6 and F106_UNDEF have been added.</td></tr><tr><td>8-33</td><td>The error code 4242 has been added.</td></tr><tr><td>8-35</td><td>Error code of 5010 to 50FF have been added</td></tr><tr><td>8-44</td><td>The example and code have been changed.</td></tr><tr><td>8-45</td><td>The example and code have been changed.</td></tr><tr><td>8-130</td><td>Descriptions of C260 have been changed.</td></tr><tr><td>8-131</td><td>Descriptions of C270 and C280 have been changed.</td></tr><tr><td>8-132</td><td>Descriptions of C290 have been changed.</td></tr><tr><td>8-133</td><td>Descriptions of C290 have been changed.</td></tr><tr><td>8-138</td><td>The illustration has been changed.</td></tr><tr><td>8-140</td><td>The measures for C550 have been changed.</td></tr><tr><td>8-186</td><td>The descriptions of F101_0 to F101_3 have been changed.</td></tr><tr><td>8-187</td><td>F101_4 has been added..</td></tr><tr><td>8-188</td><td>F101_5 has been added.</td></tr><tr><td>8-189</td><td>F101_6 has been added.</td></tr><tr><td>8-190</td><td>F101_7 has been added.</td></tr><tr><td>8-191</td><td>F101_8 has been added.</td></tr><tr><td>8-192</td><td>F101_9 has been added.</td></tr><tr><td>8-195</td><td>F106_6 to F106_UNDEF have been added.</td></tr><tr><td>8-196</td><td>F106_6 to F106_UNDEF have been added.</td></tr><tr><td>8-247</td><td>The troubleshooting for 4241 and 4242 has been added.</td></tr><tr><td>8-251</td><td>The troubleshooting for 5010 and 5014 has been added.</td></tr><tr><td>8-252</td><td>The troubleshooting for 5015 and 5019 has been added.</td></tr><tr><td>8-253</td><td>The troubleshooting for 501A and 50FF has been added.</td></tr><tr><td>9-14</td><td>The step has been changed.</td></tr><tr><td>Appendix</td><td>The default value of 05-2382 has been changed. 05-4150-0, -1, -2, and 9107 have been deleted. The contents of 05-9043 have been changed.<br /> The default values of 08-2847, 2848, 6368-1, -4, 8523, and 9486 have been changed.<br /> The contents of 08-3500, 3501, 3502, 4016-0, -1, and 9987 have been changed.<br /> 08-3509, 3636, 5000, 6023-2, 6024-8, 6025-0, 6026-1, 6043-7, 6044-8, 6045-0, 6050-1,<br /> 6051-1Å`25, 8737, 9482, 9483, 9484, and 9485 have been deleted.<br /> The acceptable value and contents of 08-3724, 5155, and 9307 have been changed. 08-5156-3, 5810, 5811, 6820-0, -1, 6823-0, -1, 6852-0Å`2, 8521, 8623-0, 8628, 8640,<br /> 8641, 8761, 8775, 8776, 8777, 8778, 8779, 8780, 8782, 8783, 8825, 8942, and 9599 have<br /> been added.<br /> The details of 08-9398 have been changed.</td></tr></table><p></p><p></p><h3>Ver.03</h3><p></p><p></p><table style='width: 100%'><tr><td>Ver. 03 <2012.07.06></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>2-13</td><td>"2.3 System List" has been corrected.</td></tr><tr><td>3-33</td><td>The part name has been changed from "LED driving PC board" to "LED board". (Uniform terminology)</td></tr><tr><td>3-34</td><td>The part name has been changed from "LED driving PC board" to "LED board". (Uniform terminology)</td></tr><tr><td>3-37</td><td>The part name has been changed from "LED driving PC board" to "LED board". (Uniform terminology)</td></tr><tr><td>4-31</td><td>The part name has been changed from "LED driving PC board" to "LED board". (Uniform terminology)</td></tr><tr><td>5-52</td><td>"5.15 PM support mode related code" has been deleted.</td></tr><tr><td>7-51</td><td>The part name of the ozone filter has been corrected.</td></tr></table> <table style='width: 100%'><tr><td>Ver. 03 <2012.07.06></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>8-3</td><td>"8.1.2 Collection of debug logs with a USB device" has been added.</td></tr><tr><td>8-19</td><td>F101_0 to F101_3 have been added and the description of F101 has been corrected. The descriptions of F100_0 to F100_2 have been corrected.</td></tr><tr><td>8-20</td><td>F109_5 and F109_6 have been added.<br /> The descriptions of F121 and F122 have been corrected. F901_1 has been added. F131 has been added.</td></tr><tr><td>8-31</td><td>4F10 has been added.</td></tr><tr><td><br /> 8-181</td><td>Descriptions of F101_0 and F101_1 have been added. Descriptions of F101_2 and F101_3 have been added. F101 has been added.</td></tr><tr><td>8-182</td><td>F101 has been removed.</td></tr><tr><td>8-187</td><td>The descriptions of F109_3 and F109_4 have been corrected.</td></tr><tr><td>8-189</td><td>Descriptions of F109_5 and F109_6 have been added.</td></tr><tr><td>8-193</td><td>The descriptions of F121 and F122 have been corrected.</td></tr><tr><td>8-194</td><td>A description of F131 has been added.</td></tr><tr><td>8-199</td><td>F901_1 has been added.</td></tr><tr><td>8-238</td><td>A description of 4F10 has been added.</td></tr><tr><td>9-1</td><td>"9.1.2 Hard disk (HDD)" has been corrected.</td></tr><tr><td>9-4</td><td>A note has been added to 9.1.3. A note has been added to 9.1.4.</td></tr><tr><td>9-9</td><td>Steps 6 and 7 have been added to 9.2.1.</td></tr><tr><td>9-12</td><td>A note has been added to 9.2.3.</td></tr><tr><td>9-17</td><td>"9.2.4 Precautions and Procedures when replacing the SYS board" has been changed.</td></tr><tr><td>9-18</td><td>"[E] Restore ADI key" has been added.</td></tr><tr><td>9-20</td><td>"Note" has been added to "<em> Check ROM versions".</em></td></tr></table><p><em><br /> </em> <em><br /> [TR]<br /> [TD]9-21[/TD]<br /> <br /> [TD]The notes in 9.2.5 have been changed.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]9-22[/TD]<br /> <br /> [TD]"9.2.7 Procedures when replacing the SLG board" has been corrected.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]9-23[/TD]<br /> <br /> [TD]The figure in 9.2.8 has been corrected and a "Note" has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]9-25[/TD]<br /> <br /> [TD]"[G] Backup ADI key" has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]9-26[/TD]<br /> <br /> [TD]The procedures of "[J] Initialize SRAM board" have been changed.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]9-33[/TD]<br /> <br /> [TD]The description of 9.3.1 has been corrected and a description of 9.3.2 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]11-34[/TD]<br /> <br /> [TD]The procedures of "11.4.2 System ROM" have been corrected.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]11-35[/TD]<br /> <br /> [TD]"947" has been changed to "9030".[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]Appendix[/TD]<br /> <br /> [TD]08-6087, 6250-0 to 8, 6251, 6258-0 to 8, 6259, 6272-0 to 8, 6273, 6274-0 to 8, 6275, 6282-<br /> 0 to 8, 6283, 6298-0 to 8, 6299, 6300-0 to 8, 6301, 6314-0 to 8, 6315, 6346-0 to 8, 6347,<br /> 6350-0 to 8, 6351, 6368-0 to 8, 6369, 6382-0 to 2,-8, 6383, 6384-0 to 2,-8, 6385, 6386-0 to<br /> 2,-8, 6387, 6390-0 to 2,-8, 6391, 6392-0 to 2,-8, 6393, 6394-0 to 2,-8, 6395, 6398-0 to 2,-8,<br /> 6399, 6400-0 to 2,-8, 6401, 6402-0 to 2,-8, 6403, 6406-0 to 2,-8, 6407, 6408-0 to 2,-8,<br /> 6409, 6410-0 to 2,-8, 6411, 6412-0 to 2,-8, 6413, 6414-0 to 2,-8, 6415, 6416-0 to 2,-8,<br /> 6417, 6420-0 to 2,-8, 6421, 6422-0 to 2,-8, 6423, 6424-0 to 2,-8, 6425, 6428-0 to 2,-8,<br /> 6429, 6430-0 to 2,-8, 6431, 6436-0 to 8, 6437, 8303, 8624, 8631, 8713, 8738, 8744, 8745,<br /> 8746, 8748, 8749, 8824, 8952, 9294, 9954, 9985 have been added.<br /> The default values of 08-9484, 9485, 9487, 9614, 9615, 9616, 9617, 9618, 9619, 9620,<br /> 9730, 3631 have been changed.<br /> The acceptable value and contents of 08-9132 have been changed.<br /> The acceptable values of 08-3500, 3501, 3502, 3503 have been changed. The contents of 08-4548 have been changed.[/TD]<br /> [/TR]<br /> </em></p><p><em></em></p><p><em></em></p><p><em></em></p><p><em><h3>Ver.02</h3><p></em></p><p><em></em></p><p><em> <table style='width: 100%'><tr><td>Ver. 02 <2012.04.20></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>Cover</td><td>e-STUDIO506 has been added.</td></tr><tr><td>GENERAL PRECAUTIONS</td><td>e-STUDIO506 has been added.</td></tr><tr><td>1-1</td><td>e-STUDIO506 has been added.</td></tr></table><p></em></p><p><em></em></p><p><em>e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD</em></p><p><em></em></p><p><em> <table style='width: 100%'><tr><td>Ver. 02 <2012.04.20></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>2-1</td><td>The notes text for "2.1 Specifications" has been deleted.<br /> The information for the scanning light source has been changed.</td></tr><tr><td>2-2</td><td>e-STUDIO506 has been added.</td></tr><tr><td>2-3</td><td>e-STUDIO506 has been added.</td></tr><tr><td>2-4</td><td>The first copy time for the e-STUDIO506 has been added.</td></tr><tr><td>2-5</td><td>The copy speed table for the e-STUDIO506 has been added.</td></tr><tr><td>2-6</td><td>The copy speed for thick paper for the e-STUDIO506 has been added to the tables.</td></tr><tr><td>2-9</td><td>The system copy speed for the e-STUDIO506 has been added to the tables. "Black mode" has been added.</td></tr><tr><td>2-12</td><td>"Control panel stopper" has been deleted from the table in "2.2 Accessories".</td></tr><tr><td>2-14</td><td>e-STUDIO506 has been added.<br /> "Bluetooth module GN-2020" has been deleted from the system list.</td></tr><tr><td>2-16</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-3</td><td>In A16, "Inverter board" has been changed to "Inverter board / LED board".</td></tr><tr><td>3-4</td><td>In Fig. 3-3, "INV" has been changed to "INV / LEDB".</td></tr><tr><td>3-8</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-10</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-13</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-14</td><td>e-STUDIO506 has been added.<br /> "Main switch" has been changed to "Main power switch".</td></tr><tr><td>3-15</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-16</td><td>e-STUDIO506 has been added.<br /> The description of the function of the EXP has been changed.</td></tr><tr><td>3-17</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-18</td><td>The description of the function of the INV has been changed. In "3.3.9 Others", the item for LEDB has been added.</td></tr><tr><td>3-19</td><td>In Fig. 3-12, "Xenon lamp" has been changed to "Xenon lamp / LED".</td></tr><tr><td>3-20</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-21</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-26</td><td>"Main switch" has been changed to "Main power switch".</td></tr><tr><td>3-29</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-33</td><td>In "3.8.1 General Description", the contents have been changed.</td></tr><tr><td><br /> 3-34</td><td>"Xenon lamp (17W)" has been changed to "Xenon lamp / LED".<br /> "Lamp inverter board (INV)" has been changed to "Lamp inverter board (INV) / LED board (LEDB)".<br /> In "3.8.2 Construction", the table for "CCD sensor and exposure lamp combinations" has been added.</td></tr><tr><td>3-35</td><td>The description of the exposure lamp (EXP) and reflector have been changed.</td></tr><tr><td>3-37</td><td>"8. Lamp inverter board (INV)" has been changed to "8. Lamp inverter board (INV) / LED board (LEDB)".</td></tr><tr><td>3-38</td><td>The description of the scanning speed has been added.</td></tr><tr><td>3-56</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-57</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-58</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-61</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-63</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-64</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-65</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-67</td><td>"Main switch" has been changed to "Main power switch". e-STUDIO506 has been added.</td></tr><tr><td>3-68</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-69</td><td>e-STUDIO506 has been added.</td></tr></table> <table style='width: 100%'><tr><td>Ver. 02 <2012.04.20></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>3-70</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-71</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-72</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-74</td><td>e-STUDIO506 has been added.</td></tr><tr><td>3-76</td><td>"Main switch" has been changed to "Main power switch".</td></tr><tr><td>3-77</td><td>"Main switch" has been changed to "Main power switch".</td></tr><tr><td>3-78</td><td>"Main switch" has been changed to "Main power switch".</td></tr><tr><td><br /> 3-81</td><td>"Main switch" has been changed to "Main power switch". The description of the parts for the SLG has been changed. e-STUDIO506 has been added.</td></tr><tr><td>4-6</td><td>e-STUDIO506 has been added.</td></tr><tr><td>4-16</td><td>"[A] Xenon lamp" has been added.</td></tr><tr><td>4-18</td><td>"<strong> LED" and the disassembly and replacement procedures have been added.</strong></td></tr></table><p><strong><br /> </strong> <strong><br /> [TR]<br /> [TD]4-19[/TD]<br /> <br /> [TD]"[A] 4-line CCD" has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-21[/TD]<br /> <br /> [TD]The contents of Note 2 have been changed.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-22[/TD]<br /> <br /> [TD]"<strong> 3-line CCD" and the disassembly and replacement procedures have been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-26[/TD]<br /> <br /> [TD]The contents of step (7) in the disassembly and replacement procedures for the carriage-1 have been changed.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-31[/TD]<br /> <br /> [TD]The disassembly and replacement procedures in "4.3.10 LED driving PC board (LEDB)" have been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-39[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-50[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-58[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-62[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-64[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-76[/TD]<br /> <br /> [TD]"(Refer to Service Handbook Chap. 3)" has been deleted from the Notes. e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-87[/TD]<br /> <br /> [TD]The contents of Note 2 have been changed.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-90[/TD]<br /> <br /> [TD]The note has been added. The Fig.4-256 have been changed.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-95[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-99[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-100[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-101[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-102[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-103[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]4-134[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]5-1[/TD]<br /> <br /> [TD]In [A], "Refer to "Appendix" for the codes in Test mode (03), Test print mode (04), Adjustment mode (05), and Setting mode (08)." has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]5-40[/TD]<br /> <br /> [TD]"Main switch" has been changed to "Main power switch".[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]5-53[/TD]<br /> <br /> [TD]In the Remarks, the default values for the e-STUDIO506 have been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]5-54[/TD]<br /> <br /> [TD]In the Remarks, the default values for the e-STUDIO506 have been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]5-55[/TD]<br /> <br /> [TD]In the Remarks, the default values for the e-STUDIO506 have been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]5-56[/TD]<br /> <br /> [TD]In the Remarks, the default values for the e-STUDIO506 have been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]6-48[/TD]<br /> <br /> [TD]e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]6-55[/TD]<br /> <br /> [TD]The contents of "[A] Replacing the lens unit" have been changed.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]7-5[/TD]<br /> <br /> [TD]The preventive maintenance timing for the e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]<br /> 7-6[/TD]<br /> <br /> [TD]In Fig. 7-2, the operational flow has been changed.<br /> "* When the authentication screen appears, press [OK]. (Enter the password, if one has been set.)" has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]7-17[/TD]<br /> <br /> [TD]The cleaning and lubricating timing for the e-STUDIO506 has been added to the Notes. e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]7-20[/TD]<br /> <br /> [TD]The replacement cycle for the e-STUDIO506 has been added.[/TD]<br /> [/TR]<br /> </strong></strong></p><p><strong><strong></strong></strong></em></p><p><em><strong><strong>e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD</strong></strong></em></p><p><em><strong><strong></strong></strong></em></p><p><em><strong><strong> <table style='width: 100%'><tr><td>Ver. 02 <2012.04.20></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>7-23</td><td>The replacement cycle for the e-STUDIO506 has been added.</td></tr><tr><td>7-25</td><td>The replacement cycle for the e-STUDIO506 has been added.</td></tr><tr><td>7-27</td><td>The replacement cycle for the e-STUDIO506 has been added.</td></tr><tr><td>7-29</td><td>e-STUDIO506 has been added.</td></tr><tr><td>7-31</td><td>The replacement cycle for the e-STUDIO506 has been added.</td></tr><tr><td>7-32</td><td>The replacement cycle for the e-STUDIO506 has been added.</td></tr><tr><td><br /> 7-51</td><td>e-STUDIO506 has been added.<br /> "FR-KIT-4530" has been changed to "FR-KIT-4590". "SCRAPER-470" has been changed to "SCRAPER-16X". "FR-KIT-3000" has been changed to "FR-KIT-3020".</td></tr><tr><td>7-52</td><td>e-STUDIO506 has been added.</td></tr><tr><td>7-54</td><td>The overhaul timing for the e-STUDIO506 has been added.</td></tr><tr><td>8-19</td><td>The error code F140 has been added.</td></tr><tr><td>8-47</td><td>e-STUDIO506 has been added.</td></tr><tr><td>8-54</td><td>"CN305" has been changed to "CN316".</td></tr><tr><td>8-69</td><td>e-STUDIO506 has been added.</td></tr><tr><td>8-125</td><td>"Inverter" has been changed to "Inverter / LED board".</td></tr><tr><td>8-177</td><td>e-STUDIO506 has been added.</td></tr><tr><td>8-183</td><td>The contents of the troubleshooting for [F109_0] have been changed.</td></tr><tr><td>8-188</td><td>The troubleshooting for [F140] has been added.</td></tr><tr><td>8-265</td><td>e-STUDIO506 has been added.</td></tr><tr><td>8-267</td><td>e-STUDIO506 has been added.</td></tr><tr><td>8-269</td><td>"inverter" has been changed to "inverter / LED board".</td></tr><tr><td>8-282</td><td>e-STUDIO506 has been added.</td></tr><tr><td>9-3</td><td>e-STUDIO506 has been added.</td></tr><tr><td>9-4</td><td>"Main switch" has been changed to "Main power switch". e-STUDIO506 has been added.</td></tr><tr><td>9-5</td><td>e-STUDIO506 has been added.</td></tr><tr><td>9-25</td><td>In "[L] Enable HDD encryption", the contents of step (3) have been changed.</td></tr><tr><td>11-1</td><td>“Engine ROM” has been added.</td></tr><tr><td>11-2</td><td>“Engine ROM” has been added.</td></tr><tr><td>11-7</td><td>e-STUDIO506 has been added.</td></tr><tr><td>11-11</td><td>e-STUDIO506 has been added.</td></tr><tr><td>11-15</td><td>"Main switch" has been changed to "Main power switch".</td></tr><tr><td>11-30</td><td>“Engine ROM” has been added.</td></tr><tr><td>11-33</td><td>“Engine ROM” has been added.</td></tr><tr><td>11-35</td><td>"Main switch" has been changed to "Main power switch".</td></tr><tr><td>11-36</td><td>“Engine ROM” has been added.</td></tr><tr><td><br /> 11-39</td><td>The Notes text has been deleted.<br /> "* When the authentication screen appears, press [OK]. (Enter the password, if one has been set.)" has been added.</td></tr><tr><td>11-41</td><td>"Since the update data for the MR-3021 and the MR-3022 differ, be sure to install the correct." has been added.</td></tr><tr><td>11-43</td><td>The illustration for step (1) has been deleted.</td></tr><tr><td>11-45</td><td>The illustration for step (1) has been deleted.</td></tr><tr><td>11-49</td><td>In "[A] Update Procedure", the illustration for step (1) has been deleted.</td></tr><tr><td>11-51</td><td>In "[A] Checking the hole punch position", the illustrations for step (2) have been changed.</td></tr><tr><td>11-52</td><td>In "<strong> Update Procedure", the contents and the illustrations for step (3) have been changed.</strong></td></tr></table><p><strong><br /> </strong> <strong><br /> [TR]<br /> [TD]11-57[/TD]<br /> <br /> [TD]The illustration for step (1) has been deleted.[/TD]<br /> [/TR]<br /> [TR]<br /> [TD]11-62[/TD]<br /> <br /> [TD]In "[A] Update Procedure", the contents of step (16) have been changed.[/TD]<br /> [/TR]<br /> </strong></p><p><strong></strong></strong></strong></em></p><p><em><strong><strong><strong> <table style='width: 100%'><tr><td>Ver. 02 <2012.04.20></td><td></td></tr><tr><td>Page</td><td>Contents</td></tr><tr><td>11-63</td><td>In "[A] Update Procedure", the illustration for step (1) has been deleted. In "[A] Update Procedure", the contents of step (2) have been changed.</td></tr><tr><td>11-64</td><td>In "[A] Update Procedure", the illustration for step (5) has been changed.</td></tr><tr><td>11-65</td><td>In "[A] Update Procedure", the contents and the illustration for step (6) have been changed.</td></tr><tr><td>11-66</td><td>In "[A] Update Procedure", the contents of step (11) have been changed. In "[A] Update Procedure", the contents of step (16) have been changed.</td></tr><tr><td>11-67</td><td>In "[A] Update Procedure", the illustration for step (1) has been deleted.</td></tr><tr><td>11-72</td><td>"Main switch" has been changed to "Main power switch".</td></tr><tr><td>14-1</td><td>"Main switch" has been changed to "Main power switch". e-STUDIO506 has been added.</td></tr><tr><td><br /> 14-4</td><td>In "[A] Scanner unit, control panel", the illustration has been changed. "Main switch" has been changed to "Main power switch".<br /> In "Others", the item for LEDB has been added.</td></tr><tr><td>14-5</td><td>e-STUDIO506 has been added.</td></tr><tr><td><br /> 14-6</td><td>e-STUDIO506 has been added.<br /> In "[A] Scanner unit, control panel", the illustration has been changed. "Main switch" has been changed to "Main power switch".<br /> In "Others", the item for LEDB has been added.</td></tr><tr><td>Appendix</td><td>e-STUDIO506 has been added.<br /> The default values of 05-4100-0 to 2, 4101-0 to 2, 4108-0 to 2, 4109-0 to 2, 4111, 4115-0 to<br /> 5, 4116-0 to 2, 4117-0 to 2, 4118-0 to 2, and 4119 have been changed.<br /> 08-8900-0 to 3 have been added.</td></tr></table><p></strong></strong></strong></em></p></blockquote><p></p>
[QUOTE="John, post: 45, member: 2"] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9388[/TD] [TD][/TD] [TD]Date display format of the file name of "Save as file" and Email transmission[/TD] [TD]0[/TD] [TD]0~5[/TD] [TD]SYS[/TD] [TD]Sets the data display format of the file of "Save as file" and Email transmission. 0: [YYYY][MM][DD] [HH][mm][SS] 1: [YY][MM][DD] [HH][mm][SS] 2: [YYYY][MM][DD] 3: [YY][MM][DD] 4: [HH][mm][SS] 5: [YYYY][MM][DD] [HH][mm][SS][mm0] The order of [YY], [MM] and [DD] varies depending on the setting of the code 08-9102 (Data display format).[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9389[/TD] [TD][/TD] [TD]Single page data saving directory at "Save as file"[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Sets the directory where the file of "Save as file" is saved. 0: Save it under a subfolder 1: Save it without creating a subfolder[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9390[/TD] [TD][/TD] [TD]Page number display format of the file of "Save as file" and Email transmission[/TD] [TD]4[/TD] [TD]3~6[/TD] [TD]SYS[/TD] [TD]Sets the digit of a page number attached on the file. 3-6: 3-6 digits[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9391[/TD] [TD][/TD] [TD]Extension (suffix) format of the file of "Save as file"[/TD] [TD]3[/TD] [TD]3~6[/TD] [TD]SYS[/TD] [TD]Sets the extension digits of the file to be saved. 3: Auto 4: 4 digits 5: 5 digits 6: 6 digits[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9394[/TD] [TD][/TD] [TD]Single-page option for storing File and sending Email[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Sets 1 page as 1 file 1: Makes a file based on the original[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9397[/TD] [TD][/TD] [TD]Execution of user authentication when the user ID is not entered[/TD] [TD]2[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]0: Forcible execution 1: Execution impossible (pooled in the invalid queue) 2: Forcible deletion[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Card reader[/TD] [TD]LDAP authentication[/TD] [TD]9398[/TD] [TD][/TD] [TD]LDAP attribute name settings 1[/TD] [TD]eBMUse rCard[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 32 characters (ASCII).[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9399[/TD] [TD][/TD] [TD]Role Based Access DAP search index[/TD] [TD]0[/TD] [TD]Refer to contents[/TD] [TD]SYS[/TD] [TD]This code is used to specify the ID for the LDAP server to implement Role-Based Access Control. <Acceptable value> 0~4294967295[/TD] [TD]5[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9403[/TD] [TD][/TD] [TD]Communication speed and settings of Ethernet[/TD] [TD]1[/TD] [TD]Refer to contents[/TD] [TD]NIC[/TD] [TD]1: Auto(100MBPS) 3: 10MBPS Full Duplex 5: 100MBPS Full Duplex 6: Auto(1000MBPS) 7: 1000MBPS Full Duplex[/TD] [TD]12[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9406[/TD] [TD][/TD] [TD]Method for acquiring IP address[/TD] [TD]2[/TD] [TD]1~3[/TD] [TD]NIC[/TD] [TD]1: Static IP address 2: Dynamic IP address (DHCP) 3: Dynamic IP address (DHCP) without AutoIP[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Address[/TD] [TD][/TD] [TD]9408[/TD] [TD][/TD] [TD]IP address[/TD] [TD]Refer to contents[/TD] [TD]Refer to contents[/TD] [TD]NIC[/TD] [TD]<Default value> 0.0.0.0 <Acceptable value> 0.0.0.0-255.255.255.255[/TD] [TD]12[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Address[/TD] [TD][/TD] [TD]9409[/TD] [TD][/TD] [TD]Subnet mask[/TD] [TD]Refer to contents[/TD] [TD]Refer to contents[/TD] [TD]NIC[/TD] [TD]<Default value> 0.0.0.0 <Acceptable value> 0.0.0.0-255.255.255.255[/TD] [TD]12[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Address[/TD] [TD][/TD] [TD]9410[/TD] [TD][/TD] [TD]Gateway[/TD] [TD]Refer to contents[/TD] [TD]Refer to contents[/TD] [TD]NIC[/TD] [TD]<Default value> 0.0.0.0 <Acceptable value> 0.0.0.0-255.255.255.255[/TD] [TD]12[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9411[/TD] [TD][/TD] [TD]Availability of IPX/SPX[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9414[/TD] [TD][/TD] [TD]Availability of AppleTalk[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9416[/TD] [TD][/TD] [TD]Availability of LDAP[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]DNS[/TD] [TD][/TD] [TD]9417[/TD] [TD][/TD] [TD]Availability of DNS[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Address[/TD] [TD][/TD] [TD]9418[/TD] [TD][/TD] [TD]IP address to DNS server (Primary)[/TD] [TD]Refer to contents[/TD] [TD]Refer to contents[/TD] [TD]NIC[/TD] [TD]000.000.000.000-255.255.255.255 <Default value> 000.000.000.000 <Acceptable value> 0.0.0.0~255.255.255.255[/TD] [TD]12[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Address[/TD] [TD][/TD] [TD]9419[/TD] [TD][/TD] [TD]IP address to DNS server (Secondary)[/TD] [TD]Refer to contents[/TD] [TD]Refer to contents[/TD] [TD]NIC[/TD] [TD]000.000.000.000-255.255.255.255 <Default value> 000.000.000.000 <Acceptable value> 0.0.0.0~255.255.255.255[/TD] [TD]12[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9421[/TD] [TD][/TD] [TD]Availability of SLP[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]Sets the availability of SLP on NetWare. 1: Enabled 2: Disabled[/TD] [TD]12[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9426[/TD] [TD][/TD] [TD]Availability of Bindery[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9427[/TD] [TD][/TD] [TD]Availability of NDS[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9430[/TD] [TD][/TD] [TD]Availability of HTTP server[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9437[/TD] [TD][/TD] [TD]Availability of SMTP client[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9440[/TD] [TD][/TD] [TD]Availability of SMTP server[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]UTY[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9446[/TD] [TD][/TD] [TD]Availability of POP3 clients[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9459[/TD] [TD][/TD] [TD]Availability of FTP server[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9463[/TD] [TD][/TD] [TD]MIB function[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Valid 2: Invalid[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9473[/TD] [TD][/TD] [TD]Availability of Raw/TCP[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Valid 2: Invalid[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9475[/TD] [TD][/TD] [TD]Availability of LPD client[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Valid 2: Invalid[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9478[/TD] [TD][/TD] [TD]Availability of IPP[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Valid 2: Invalid[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9481[/TD] [TD][/TD] [TD]IPP printer name[/TD] [TD]MFPseri al[/TD] [TD]-[/TD] [TD]NIC[/TD] [TD]Maximum 127 letters The Network-related serial number of the equipment appears on “serial“[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9486[/TD] [TD][/TD] [TD]IPP printer "Make and Model"[/TD] [TD]mfp model name[/TD] [TD]-[/TD] [TD]NIC[/TD] [TD]Maximum 127 letters[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9487[/TD] [TD][/TD] [TD]IPP printer information (more) MFGR[/TD] [TD]-[/TD] [TD]-[/TD] [TD]NIC[/TD] [TD]Maximum 127 letters[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9488[/TD] [TD][/TD] [TD]IPP message from operator[/TD] [TD]-[/TD] [TD]-[/TD] [TD]NIC[/TD] [TD]Maximum 127 letters[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9489[/TD] [TD][/TD] [TD]Availability of FTP print[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Available 2: Not available[/TD] [TD]12[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9499[/TD] [TD][/TD] [TD]Page number limitation for printing text of received E- mail[/TD] [TD]5[/TD] [TD]1~99[/TD] [TD]SYS[/TD] [TD][/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9505[/TD] [TD][/TD] [TD]Bonjour setting[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]1: Valid 2: Invalid[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9515[/TD] [TD][/TD] [TD]Windows domain No.1 of user authentication[/TD] [TD]-[/TD] [TD]-[/TD] [TD]UTY[/TD] [TD]Maximum 128 letters[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9516[/TD] [TD][/TD] [TD]PDC (Primary Domain Controller) name[/TD] [TD]-[/TD] [TD]-[/TD] [TD]UTY[/TD] [TD]Maximum 128 letters[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9517[/TD] [TD][/TD] [TD]BDC (Backup Domain Controller) name[/TD] [TD]-[/TD] [TD]-[/TD] [TD]UTY[/TD] [TD]Maximum 128 letters[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Address[/TD] [TD][/TD] [TD]9525[/TD] [TD][/TD] [TD]Display of MAC address[/TD] [TD]-[/TD] [TD]-[/TD] [TD]-[/TD] [TD](**:**:**:**:**:**) The address is displayed as above. 6-byte data is divided by colon.[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9548[/TD] [TD][/TD] [TD]SSL setting HTTP server OFF/ON setting[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]1: Enabled 2: Disabled[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9550[/TD] [TD][/TD] [TD]SSL setting IPP server OFF/ON setting[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]1: Enabled 2: Disabled[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9552[/TD] [TD][/TD] [TD]SSL setting SSL ftp server OFF/ON[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]OFF/ON 1: Valid2: Invalid[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9556[/TD] [TD][/TD] [TD]SSL setting SSL POP3 Client OFF/ON[/TD] [TD]2[/TD] [TD]1~3[/TD] [TD]-[/TD] [TD]OFF/ON 1: Valid 2: Invalid 3: Use imported certificate[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9563[/TD] [TD][/TD] [TD]IP Conflict Detect[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]OFF/ON 1: Valid 2: Invalid[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9564[/TD] [TD][/TD] [TD]SNTP Enable[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]OFF/ON 1: Valid 2: Invalid[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Enabling server's IP address acquired by DHCP[/TD] [TD][/TD] [TD]9580[/TD] [TD][/TD] [TD]Domain Name Server option (6)[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]1: Enabled 2: Disabled * This value is used only when DHCP is enabled.[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Enabling server's IP address acquired by DHCP[/TD] [TD][/TD] [TD]9581[/TD] [TD][/TD] [TD]NetBIOS over TCP/IP Name Server option (44) = Primary and Secondary Wins NAME[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]1: Enabled 2: Disabled * This value is used only when DHCP is enabled[/TD] [TD]12[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Enabling server's IP address acquired by DHCP[/TD] [TD][/TD] [TD]9584[/TD] [TD][/TD] [TD]SMTP Server Option (69) Simple Mail Server Address[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]1: Enabled 2: Disabled * This value is used only when DHCP is enabled.[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Enabling server's IP address acquired by DHCP[/TD] [TD][/TD] [TD]9585[/TD] [TD][/TD] [TD]POP3 Server Option (70) Post Office Server Address[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]1: Enabled 2: Disabled * This value is used only when DHCP is enabled.[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Enabling server's IP address acquired by DHCP[/TD] [TD][/TD] [TD]9587[/TD] [TD][/TD] [TD]SNTP Server Option (42) NTP Server Address[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]1: Enabled 2: Disabled * This value is used only when DHCP is enabled.[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9599[/TD] [TD][/TD] [TD]Samba server ON/OFF setting[/TD] [TD]1[/TD] [TD]1-4[/TD] [TD]NIC[/TD] [TD]1: Samba enabled 2: Samba disabled 3: Print Share disabled 4: File Share disabled[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]General[/TD] [TD][/TD] [TD]9601[/TD] [TD][/TD] [TD]Equipment number (serial number) display[/TD] [TD]0[/TD] [TD]9 digits[/TD] [TD]SYS[/TD] [TD]This code can be also keyed in from the adjustment mode (05-9043). 9 digits[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9602[/TD] [TD][/TD] [TD]Dealer's name[/TD] [TD]-[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 100 letters Needed at initial registration[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]General[/TD] [TD]9603[/TD] [TD][/TD] [TD]Login name[/TD] [TD]-[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 20 letters Needed at initial registration[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]Call /Display function[/TD] [TD]9604[/TD] [TD][/TD] [TD]Display set of [Service Notification] button[/TD] [TD]Refer to contents[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Not displayed 1: displayed <Default value> NAD: 1 MJD: 1 Other: 0[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9605[/TD] [TD][/TD] [TD]Sending error history of equipment[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9606[/TD] [TD][/TD] [TD]Setting total counter transmission interval[/TD] [TD]-[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD](Hour/Hour/Minute/Minute)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9607[/TD] [TD][/TD] [TD]Destination E-mail address 2[/TD] [TD]-[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 192 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9608[/TD] [TD][/TD] [TD]Destination E-mail address 3[/TD] [TD]-[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 192 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9610[/TD] [TD][/TD] [TD]Remote-controlled service polling day selection Day-1[/TD] [TD]0[/TD] [TD]0~31[/TD] [TD]SYS[/TD] [TD]0: OFF 1 to 31: 1st to 31st of a month[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9611[/TD] [TD][/TD] [TD]Remote-controlled service polling day selection Day-2[/TD] [TD]0[/TD] [TD]0~31[/TD] [TD]SYS[/TD] [TD]0: OFF 1 to 31: 1st to 31st of a month[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9612[/TD] [TD][/TD] [TD]Remote-controlled service polling day selection Day-3[/TD] [TD]0[/TD] [TD]0~31[/TD] [TD]SYS[/TD] [TD]0: OFF 1 to 31: 1st to 31st of a month[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9613[/TD] [TD][/TD] [TD]Remote-controlled service polling day selection Day-4[/TD] [TD]0[/TD] [TD]0~31[/TD] [TD]SYS[/TD] [TD]0: OFF 1 to 31: 1st to 31st of a month[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]RDMS[/TD] [TD]Remote-controlled service polling day[/TD] [TD]9614[/TD] [TD][/TD] [TD]Sunday[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]RDMS[/TD] [TD]Remote-controlled service polling day[/TD] [TD]9615[/TD] [TD][/TD] [TD]Monday[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]RDMS[/TD] [TD]Remote-controlled service polling day[/TD] [TD]9616[/TD] [TD][/TD] [TD]Tuesday[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]RDMS[/TD] [TD]Remote-controlled service polling day[/TD] [TD]9617[/TD] [TD][/TD] [TD]Wednesday[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]RDMS[/TD] [TD]Remote-controlled service polling day[/TD] [TD]9618[/TD] [TD][/TD] [TD]Thursday[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]RDMS[/TD] [TD]Remote-controlled service polling day[/TD] [TD]9619[/TD] [TD][/TD] [TD]Friday[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]RDMS[/TD] [TD]Remote-controlled service polling day[/TD] [TD]9620[/TD] [TD][/TD] [TD]Saturday[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9624[/TD] [TD][/TD] [TD]Information of supplies setting of toner cartridge K[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]Remote-controlled service polling[/TD] [TD]9626[/TD] [TD][/TD] [TD]End of month[/TD] [TD]0[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9627[/TD] [TD][/TD] [TD]Sending mail text of InternetFAX[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid (Not sending the mail text) 1: Valid (Sending the mail text)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9628[/TD] [TD][/TD] [TD]From Name Creation setting in SMTP authentication[/TD] [TD]0[/TD] [TD]0-2[/TD] [TD]SYS[/TD] [TD]0: Not edited 1: Account name of FROM ADDRESS and Device name 2: LDAP searching[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Wireless LAN[/TD] [TD][/TD] [TD][/TD] [TD]9649[/TD] [TD][/TD] [TD]Wireless LAN supplicant Wireless LAN setting[/TD] [TD]2[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]This setting is whether the wireless LAN connection is enabled or disabled. 1: Enabled 2: Disabled[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Bluetooth[/TD] [TD][/TD] [TD][/TD] [TD]9680[/TD] [TD][/TD] [TD]Bluetooth ON/OFF setting[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: OFF 1: ON[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Bluetooth[/TD] [TD][/TD] [TD][/TD] [TD]9681[/TD] [TD][/TD] [TD]Bluetooth Device name[/TD] [TD]MFPseri al[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 32 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Bluetooth[/TD] [TD][/TD] [TD][/TD] [TD]9682[/TD] [TD][/TD] [TD]Bluetooth Discovery[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Not allowed 1: Allowed[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Bluetooth[/TD] [TD][/TD] [TD][/TD] [TD]9683[/TD] [TD][/TD] [TD]Bluetooth Security[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Security function OFF 1: Security function ON[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Bluetooth[/TD] [TD][/TD] [TD][/TD] [TD]9684[/TD] [TD][/TD] [TD]Bluetooth PIN[/TD] [TD]0000[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 8 digits (8-digit sequence) This setting is valid only when the bluetooth security function is ON.[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Bluetooth[/TD] [TD][/TD] [TD][/TD] [TD]9685[/TD] [TD][/TD] [TD]Bluetooth Data encryption[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Not encrypted 1: Encrypted This setting is valid only when the bluetooth security function is ON.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]Enabling server's IP address acquired by DHCP[/TD] [TD][/TD] [TD]9694[/TD] [TD][/TD] [TD]DNS domain name Option (15) DNS domain name of the client[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]-[/TD] [TD]1: Enabled 2: Disabled * This value is used only when DHCP is enabled.[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]General[/TD] [TD][/TD] [TD]9700[/TD] [TD][/TD] [TD]Service technician telephone number[/TD] [TD]0[/TD] [TD]32 digits[/TD] [TD]SYS[/TD] [TD]A telephone number can be entered up to 32 digits. Use the [Pause] button to enter a hyphen (-).[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD][/TD] [TD][/TD] [TD]9702[/TD] [TD][/TD] [TD]Automatic calibration disclosure level[/TD] [TD]1[/TD] [TD]0-2[/TD] [TD]SYS[/TD] [TD]Sets the disclosing level of automatic calibration. 0: Service technician 1: Administrator 2: User[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]Counter[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9703[/TD] [TD][/TD] [TD]Error history display[/TD] [TD]-[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Displaying of the latest 20 errors data[/TD] [TD]2[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9709[/TD] [TD][/TD] [TD]Default data saving directory of "Scan to File"[/TD] [TD]0[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]0: Local directory 1: REMOTE 1 2: REMOTE 2[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]General[/TD] [TD]9710[/TD] [TD][/TD] [TD]Remote-controlled service function[/TD] [TD]2[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]0: Valid (Remote-controlled server) 1: Valid (L2) 2: Invalid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9711[/TD] [TD][/TD] [TD]Remote-controlled service URL setting[/TD] [TD]NULL[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 256 Bytes[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9715[/TD] [TD][/TD] [TD]Initially-registered server URL setting[/TD] [TD]Refer to contents[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 256 letters <Default value> [URL]https://device.mfp-[/URL] support.com:443/device/firstregist.ashx[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Short time interval of emergency mode[/TD] [TD][/TD] [TD]9718[/TD] [TD][/TD] [TD]Recovery time setting[/TD] [TD]24[/TD] [TD]1~48[/TD] [TD]SYS[/TD] [TD]Sets the time interval to recover from the emergency mode to the normal mode. (Unit: Hour)[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Short time interval of emergency mode[/TD] [TD][/TD] [TD]9719[/TD] [TD][/TD] [TD]Interval setting[/TD] [TD]60[/TD] [TD]30~360[/TD] [TD]SYS[/TD] [TD](Unit: Minute)[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]General[/TD] [TD]9723[/TD] [TD][/TD] [TD]Periodical polling timing[/TD] [TD]1700[/TD] [TD]0~2359[/TD] [TD]SYS[/TD] [TD]0 (0:00) to 2359 (23:59)[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]General[/TD] [TD]9724[/TD] [TD][/TD] [TD]Writing data of self- diagnostic code[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Prohibited 1: Accepted[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]General[/TD] [TD]9726[/TD] [TD][/TD] [TD]Remote-service initial registration[/TD] [TD]0[/TD] [TD]0~3[/TD] [TD]SYS[/TD] [TD]0: OFF 1: Start 2: Only certification is scanned 3: RDMS communication starts[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]General[/TD] [TD]9727[/TD] [TD][/TD] [TD]Remote-controlled service tentative password[/TD] [TD]NULL[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 10 letters[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]General[/TD] [TD]9729[/TD] [TD][/TD] [TD]Status of remote- service initial regist[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Not registered 1: Registered[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]RDMS[/TD] [TD]Call /Display function[/TD] [TD]9730[/TD] [TD][/TD] [TD]Service center call function[/TD] [TD]1[/TD] [TD]0-2[/TD] [TD]SYS[/TD] [TD]0: OFF 1: Notifies all service calls 2: Notifies all but paper jams[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9732[/TD] [TD][/TD] [TD]Service center call HTTP server URL setting[/TD] [TD]NULL[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 256 letters[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Counter[/TD] [TD][/TD] [TD][/TD] [TD]9736[/TD] [TD][/TD] [TD]Validity of interrupt copying when external counters are installed[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Invalid1: Valid[/TD] [TD]1[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]Call /Display function[/TD] [TD]9739[/TD] [TD][/TD] [TD]Toner-end notification[/TD] [TD]0[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]0: RDMS toner empty notified immediately 1: RDMS toner empty notified once a day 2: RDMS toner empty not notified[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9740[/TD] [TD][/TD] [TD]HTTP proxy setting[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Valid 1: Invalid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9741[/TD] [TD][/TD] [TD]HTTP proxy IP address setting[/TD] [TD]Refer to contents[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Input IP address or FQDN. <Default value> 0.0.0.0[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9742[/TD] [TD][/TD] [TD]HTTP proxy port number setting[/TD] [TD]0[/TD] [TD]0~65535[/TD] [TD]SYS[/TD] [TD][/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9743[/TD] [TD][/TD] [TD]HTTP proxy ID setting[/TD] [TD]NULL[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 30 letters[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9744[/TD] [TD][/TD] [TD]HTTP proxy password setting[/TD] [TD]NULL[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Maximum 30 letters[/TD] [TD]11[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]HTTP[/TD] [TD]9745[/TD] [TD][/TD] [TD]HTTP proxy panel display[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Valid 1: Invalid[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9746[/TD] [TD][/TD] [TD]802.1X/Dynamic WEP selecting button display[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Switches whether a selecting button for Security mode 802.1X/Dynamic WEP is displayed or not. 0: Not displayed 1: Displayed[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9749[/TD] [TD][/TD] [TD]WIA Scan Driver[/TD] [TD]1[/TD] [TD]1~2[/TD] [TD]NIC[/TD] [TD]Selects WIA Scan Driver. 1: TTEC 2: Microsoft[/TD] [TD]12[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9750[/TD] [TD][/TD] [TD]Automatic ordering function of supplies[/TD] [TD]3[/TD] [TD]0~3[/TD] [TD]SYS[/TD] [TD]0: Ordered by FAX 1: Ordered by E-mail 2: Ordered by HTTP 3: OFF[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9751[/TD] [TD][/TD] [TD]Automatic ordering function of supplies FAX number[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 32 digits Enter hyphen with the [Pause] button[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9752[/TD] [TD][/TD] [TD]Automatic ordering function of supplies E- mail address[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 192 letters List: 256 digits[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9756[/TD] [TD][/TD] [TD]Automatic ordering function of supplies User's name[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 50 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9757[/TD] [TD][/TD] [TD]Automatic ordering function of supplies User's telephone number[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 32 digits Enter hyphen with the [Pause] button[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9758[/TD] [TD][/TD] [TD]Automatic ordering function of supplies User's E-mail address[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 192 letters List: 256 digits[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9759[/TD] [TD][/TD] [TD]Automatic ordering function of supplies User's address[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 100 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9760[/TD] [TD][/TD] [TD]Automatic ordering function of supplies Service number[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 5 digits[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9761[/TD] [TD][/TD] [TD]Automatic ordering function of supplies Service technician's name[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 50 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9762[/TD] [TD][/TD] [TD]Automatic ordering function of supplies Service technician's telephone number[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 32 digits Enter hyphen with the [Pause] button[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9763[/TD] [TD][/TD] [TD]Automatic ordering function of supplies Service technician's E-mail address[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 192 letters List: 256 digits[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9764[/TD] [TD][/TD] [TD]Automatic ordering function of supplies Supplier's name[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 50 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9765[/TD] [TD][/TD] [TD]Automatic ordering function of supplies Supplier's address[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 100 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9766[/TD] [TD][/TD] [TD]Automatic ordering function of supplies Notes[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 128 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9776[/TD] [TD][/TD] [TD]Information about supplies Part number of toner cartridge[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 20 digits[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9777[/TD] [TD][/TD] [TD]Information about supplies Order quantity of toner cartridge[/TD] [TD]1[/TD] [TD]1~99[/TD] [TD]SYS[/TD] [TD][/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9778[/TD] [TD][/TD] [TD]Information about supplies Condition number of toner cartridge[/TD] [TD]1[/TD] [TD]1~99[/TD] [TD]SYS[/TD] [TD][/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD]Remote-controlled service[/TD] [TD]Call /Display function[/TD] [TD]9783[/TD] [TD][/TD] [TD]Automatic supply ordering display[/TD] [TD]Refer to contents[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]0: Valid (FAX/Internet FAX) 1: Valid (FAX/Internet FAX/HTTP) 2: Invalid <Default value> NAD: 0 Others: 2[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9784[/TD] [TD][/TD] [TD]Counter notification Remote FAX setting[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 32 digits Enter hyphen with the [PAUSE] button.[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9787[/TD] [TD][/TD] [TD]Suspend when quota is empty[/TD] [TD]0[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]Sets whether the process is suspended immediately or suspended after the job is completed if quota is used up. 0: Suspended immediately 1: Suspended after the job is finished[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9788[/TD] [TD][/TD] [TD]Service call checking period setting[/TD] [TD]6[/TD] [TD]0~12[/TD] [TD]SYS[/TD] [TD]0: No checking period specified (= Calls service technician immediately) 1: 10 minutes 2: 30 minutes 3: 1 hour 4: 6 hours 5: 12 hours 6: 24 hours 7: 48 hours 8: 7 days 9: 1 month 10: 1 year 11: 5 years 12: Not limited (= Calls service technician if such error has occurred in the past even once or more)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9793[/TD] [TD][/TD] [TD]Service Notification setting[/TD] [TD]0[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]Enables to set up to 3 E-mail addresses to be sent. (08-9793, 9794, 9795) 0: Invalid 1: Valid (E-mail) 2: Valid (FAX)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9794[/TD] [TD][/TD] [TD]Destination E-mail address 1[/TD] [TD]-[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Maximum 192 letters[/TD] [TD]11[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9795[/TD] [TD][/TD] [TD]Total counter information transmission setting[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9796[/TD] [TD][/TD] [TD]Total counter transmission date setting[/TD] [TD]0[/TD] [TD]0~31[/TD] [TD]SYS[/TD] [TD]0 to 31[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce (Remote)[/TD] [TD][/TD] [TD][/TD] [TD]9797[/TD] [TD][/TD] [TD]PM counter notification setting[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9798[/TD] [TD][/TD] [TD]Temporary communication password setting[/TD] [TD]99999[/TD] [TD]-[/TD] [TD]SYS[/TD] [TD]Sets a temporary communication password. The password can be entered in alphanumeric characters (A to Z, a to z, 0 to 9) up to 10 digits. The entered password is displayed with "*" on the touch panel and the self-diagnostic lists. (Maximum 10 digits, minimum 5 digits)[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9799[/TD] [TD][/TD] [TD]Local authentication mode switchover[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Sets the authentication mode when "0: (Internal authentication)" is selected in the code 08-9293. 0: Card ID differs from the User ID 1: Card ID is the same as the User ID[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Process[/TD] [TD][/TD] [TD][/TD] [TD]9804[/TD] [TD][/TD] [TD]Forcible mode change in toner empty status[/TD] [TD]1[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]0: SLEEP MODE 1: AUTO POWER SAVE 2: READY[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Laser[/TD] [TD][/TD] [TD][/TD] [TD]9805[/TD] [TD][/TD] [TD]Polygonal motor standby rotation Shift waiting time at job end[/TD] [TD]3[/TD] [TD]0~9[/TD] [TD]SYS[/TD] [TD]0: 0 sec. (current setting) (Polygonal motor ready rotation at job end) 1 to 9:Setting value x 5sec.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Interruption of stapling operation (no staple)[/TD] [TD][/TD] [TD]9810[/TD] [TD]0[/TD] [TD]Copying[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Continues printing by switching sort setting 1: Interrupts printing[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Interruption of stapling operation (no staple)[/TD] [TD][/TD] [TD]9810[/TD] [TD]1[/TD] [TD]Printing / BOX printing[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Continues printing by switching sort setting 1: Interrupts printing[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling setting Maximum number of sheets acceptable exceeding upper limit / Long size[/TD] [TD][/TD] [TD]9811[/TD] [TD]0[/TD] [TD]Plain/Recycled[/TD] [TD]0[/TD] [TD]-50~50[/TD] [TD]SYS[/TD] [TD]-50 to 50[/TD] [TD]4[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling setting Maximum number of sheets acceptable exceeding upper limit / Long size[/TD] [TD][/TD] [TD]9811[/TD] [TD]1[/TD] [TD]Thick1[/TD] [TD]0[/TD] [TD]-50~50[/TD] [TD]SYS[/TD] [TD]-50 to 50[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling setting Maximum number of sheets acceptable exceeding upper limit / Long size[/TD] [TD][/TD] [TD]9811[/TD] [TD]2[/TD] [TD]Thick2[/TD] [TD]0[/TD] [TD]-50~50[/TD] [TD]SYS[/TD] [TD]-50 to 50[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling setting Maximum number of sheets acceptable exceeding upper limit / Long size[/TD] [TD][/TD] [TD]9811[/TD] [TD]3[/TD] [TD]Thick3[/TD] [TD]0[/TD] [TD]-50~50[/TD] [TD]SYS[/TD] [TD]-50 to 50[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9816[/TD] [TD][/TD] [TD]Addition of the page number to the multi- page file name of File[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Only when job is executed with TimeStamp enabled for file storage, page number is added with the format set at 08-9387. 0: Invalid (Page number not added) 1: Valid (Page number added)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9817[/TD] [TD][/TD] [TD]Maximum number of decimals in extension fields[/TD] [TD]2[/TD] [TD]0~6[/TD] [TD]SYS[/TD] [TD]0: 0 digit 1: 1 digit 2: 2 digits 3: 3 digits 4: 4 digits 5: 5 digits 6: 6 digits[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9818[/TD] [TD][/TD] [TD]Default saving/attachment files of "File/Email"[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: DOCYYMMDD 1: NetBios name[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Off Device Customization Architecture[/TD] [TD][/TD] [TD]9819[/TD] [TD][/TD] [TD]STAGE SSL[/TD] [TD]0[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]Sets whether SSL communication is enabled or disabled for remote scanning. 0: Disabled 1: Enabled[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Off Device Customization Architecture[/TD] [TD][/TD] [TD]9820[/TD] [TD][/TD] [TD]STAGE I/F[/TD] [TD]1[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]Sets whether interface is enabled or disabled for remote scanning. 0: Disabled 1: Enabled[/TD] [TD]1[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Off Device Customization Architecture[/TD] [TD][/TD] [TD]9821[/TD] [TD][/TD] [TD]Port number[/TD] [TD]49629[/TD] [TD]0-65535[/TD] [TD]SYS[/TD] [TD]Sets a port number for the remote scanning.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Off Device Customization Architecture[/TD] [TD][/TD] [TD]9822[/TD] [TD][/TD] [TD]SSL port number[/TD] [TD]49630[/TD] [TD]0-65535[/TD] [TD]SYS[/TD] [TD]Sets an SSL port number for remote scanning using SSL communication.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9823[/TD] [TD][/TD] [TD]User name and password at user authentication or "Save as file"[/TD] [TD]0[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]0: User name and password of the device 1: User name and password at the user authentication (Template registration information comes first when a template is retrieved.) 2: User name and password at the user authentication (User information of the authentication comes first when a template is retrieved.)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Image[/TD] [TD][/TD] [TD][/TD] [TD]9825[/TD] [TD][/TD] [TD]Image quality of the black part in the ACS mode[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Black 1: Gray scale[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9829[/TD] [TD][/TD] [TD]Department management limitation setting[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Decide the default limitation setting when the new department code is created. 0: No limit 1: Limited[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Bluetooth[/TD] [TD][/TD] [TD][/TD] [TD]9841[/TD] [TD][/TD] [TD]Bluetooth BIP Paper type[/TD] [TD]0[/TD] [TD]0~3[/TD] [TD]SYS[/TD] [TD]0: Fit page 1: 1/2 size 2: 1/4 size 3: 1/8 size[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Bluetooth[/TD] [TD][/TD] [TD][/TD] [TD]9846[/TD] [TD][/TD] [TD]Bluetooth BIP Paper size[/TD] [TD]Refer to contents[/TD] [TD]0~13[/TD] [TD]SYS[/TD] [TD]0: Ledger 1: Legal 2: Letter 3: Computer 4: Statement 5: A3 6: A4 7: A5 9: B4 10: B5 11: Folio 12: Legal13" 13: LetterSquare <Default value> NAD: 2 Others: 6[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD][/TD] [TD][/TD] [TD]9847[/TD] [TD][/TD] [TD]Hole punching setting[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9880[/TD] [TD][/TD] [TD]Total counter transmission date setting (2)[/TD] [TD]0[/TD] [TD]0~31[/TD] [TD]SYS[/TD] [TD]0 to 31[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9881[/TD] [TD][/TD] [TD]Day of total counter data transmission[/TD] [TD]0[/TD] [TD]0~127[/TD] [TD]SYS[/TD] [TD]1 byte 00000000(0)-01111111(127) From the 2nd bit - Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday[/TD] [TD]1[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9883[/TD] [TD][/TD] [TD]Hardcopy security printing[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Disable1 1: Enable[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Counter[/TD] [TD][/TD] [TD][/TD] [TD]9884[/TD] [TD][/TD] [TD]Count switching of hardcopy security printing level 1[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Sets the way of counting for hardcopy security printing. 0: Counted as 1 1: Counted as 2[/TD] [TD]2[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Scanning[/TD] [TD][/TD] [TD][/TD] [TD]9886[/TD] [TD][/TD] [TD]Decimal point indication for Enhanced Scan Template[/TD] [TD]Refer to contents[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Comma 1: Period <Default value> MJD: 0 Others: 1[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Scanner[/TD] [TD][/TD] [TD][/TD] [TD]9888[/TD] [TD][/TD] [TD]Permission setting for changing the scan parameter when recalling an extension[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Prohibited 1: Permitted[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD]Data cloning[/TD] [TD][/TD] [TD]9889[/TD] [TD][/TD] [TD]Status display for USB cloning[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Acceptance of the usage of the USB data cloning tool 0: Accepted 1: Not accepted[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Screen setting[/TD] [TD][/TD] [TD]9891[/TD] [TD][/TD] [TD]Warning message when PM time has come[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: No warning notification 1: Display warning notification[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9894[/TD] [TD][/TD] [TD]Calibration chart charging method[/TD] [TD]0[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]Decides whether the calibration chart printing is charged or not 0: No charge 1: Charge[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Image[/TD] [TD][/TD] [TD][/TD] [TD]9897[/TD] [TD][/TD] [TD]Default value setting of background peak adjustment (Black)[/TD] [TD]5[/TD] [TD]1~9[/TD] [TD]SYS[/TD] [TD]1: -4 2: -3 3: -2 4: -1 5: 0 6: +1 7: +2 8: +3 9: +4[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Image[/TD] [TD][/TD] [TD][/TD] [TD]9898[/TD] [TD][/TD] [TD]Default value setting of density in the scan mode (Color)[/TD] [TD]6[/TD] [TD]0~11[/TD] [TD]SYS[/TD] [TD]0: Auto 1: -5 2: -4 3: -3 4: -2 5: -1 6: 0 7: +1 8: +2 9: +3 10: +4 11: +5[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Image[/TD] [TD][/TD] [TD][/TD] [TD]9899[/TD] [TD][/TD] [TD]Default value setting of density in the scan mode (Gray)[/TD] [TD]6[/TD] [TD]0~11[/TD] [TD]SYS[/TD] [TD]0: Auto 1: -5 2: -4 3: -3 4: -2 5: -1 6: 0 7: +1 8: +2 9: +3 10: +4 11: +5[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD]System[/TD] [TD][/TD] [TD]9900[/TD] [TD][/TD] [TD]System software ROM version[/TD] [TD]-[/TD] [TD]-[/TD] [TD]-[/TD] [TD]T330SYXXXXXX[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD]Engine[/TD] [TD][/TD] [TD]9901[/TD] [TD][/TD] [TD]Engine ROM version[/TD] [TD]-[/TD] [TD][/TD] [TD]-[/TD] [TD]33xM-XXX[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD]Engine[/TD] [TD][/TD] [TD]9902[/TD] [TD][/TD] [TD]Scanner ROM version[/TD] [TD]-[/TD] [TD][/TD] [TD]-[/TD] [TD]330S-XXX[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD]Engine[/TD] [TD][/TD] [TD]9903[/TD] [TD][/TD] [TD]RADF ROM version[/TD] [TD]-[/TD] [TD][/TD] [TD]-[/TD] [TD]DF-XXXX[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD]Finisher[/TD] [TD][/TD] [TD]9904[/TD] [TD][/TD] [TD]Finisher ROM version[/TD] [TD]-[/TD] [TD][/TD] [TD]-[/TD] [TD]SDL-XXX FIN-XXX[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD]FAX[/TD] [TD][/TD] [TD]9905[/TD] [TD][/TD] [TD]Fax board ROM version[/TD] [TD]-[/TD] [TD][/TD] [TD]-[/TD] [TD]F670-XXX[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD]HDD[/TD] [TD][/TD] [TD]9930[/TD] [TD][/TD] [TD]System software OS version[/TD] [TD]-[/TD] [TD][/TD] [TD]-[/TD] [TD]T160SF0WXXXX[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9933[/TD] [TD][/TD] [TD]Domain participation confirmation of printing when LDAP authentication is used[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]When LDAP is selected as authentication method for user authentication, checking of domain participation of client computer for print job authentication is set. This function is available only when department management is enabled. 0: Disabled 1: Enabled[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling setting Acceptable number of sheets exceeding upper limit / Short size[/TD] [TD][/TD] [TD]9937[/TD] [TD]0[/TD] [TD]Plain/Recycled[/TD] [TD]0[/TD] [TD]-100~100[/TD] [TD]SYS[/TD] [TD]-100 to 100[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling setting Acceptable number of sheets exceeding upper limit / Short size[/TD] [TD][/TD] [TD]9937[/TD] [TD]1[/TD] [TD]Thick1[/TD] [TD]0[/TD] [TD]-100~100[/TD] [TD]SYS[/TD] [TD]-100 to 100[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling setting Acceptable number of sheets exceeding upper limit / Short size[/TD] [TD][/TD] [TD]9937[/TD] [TD]2[/TD] [TD]Thick2[/TD] [TD]0[/TD] [TD]-100~100[/TD] [TD]SYS[/TD] [TD]-100 to 100[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling setting Acceptable number of sheets exceeding upper limit / Short size[/TD] [TD][/TD] [TD]9937[/TD] [TD]3[/TD] [TD]Thick3[/TD] [TD]0[/TD] [TD]-100~100[/TD] [TD]SYS[/TD] [TD]-100 to 100[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling Acceptable number of sheets exceeding upper limit / Saddle stitch[/TD] [TD][/TD] [TD]9938[/TD] [TD]0[/TD] [TD]Plain/Recycled[/TD] [TD]0[/TD] [TD]-15~15[/TD] [TD]SYS[/TD] [TD]-15 to 15[/TD] [TD]4[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling Acceptable number of sheets exceeding upper limit / Saddle stitch[/TD] [TD][/TD] [TD]9938[/TD] [TD]1[/TD] [TD]Thick1[/TD] [TD]0[/TD] [TD]-15~15[/TD] [TD]SYS[/TD] [TD]-15 to 15[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling Acceptable number of sheets exceeding upper limit / Saddle stitch[/TD] [TD][/TD] [TD]9938[/TD] [TD]2[/TD] [TD]Thick2[/TD] [TD]0[/TD] [TD]-15~15[/TD] [TD]SYS[/TD] [TD]-15 to 15[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Finisher[/TD] [TD]Stapling Acceptable number of sheets exceeding upper limit / Saddle stitch[/TD] [TD][/TD] [TD]9938[/TD] [TD]3[/TD] [TD]Thick3[/TD] [TD]0[/TD] [TD]-15~15[/TD] [TD]SYS[/TD] [TD]-15 to 15[/TD] [TD]4[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD]Finisher[/TD] [TD][/TD] [TD]9944[/TD] [TD][/TD] [TD]Finisher punch ROM version[/TD] [TD]-[/TD] [TD]-[/TD] [TD]-[/TD] [TD]PUN-XXX FIN-XXX[/TD] [TD]2[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Version[/TD] [TD][/TD] [TD][/TD] [TD]9945[/TD] [TD][/TD] [TD]Finisher Converter ROM version[/TD] [TD]-[/TD] [TD]-[/TD] [TD]-[/TD] [TD]CNV-XXX[/TD] [TD]2[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]E-mail[/TD] [TD][/TD] [TD]9946[/TD] [TD][/TD] [TD]Number of Email transmission retries[/TD] [TD]3[/TD] [TD]0~14[/TD] [TD]SYS[/TD] [TD]The number of times of E-mail communication retry for Scan to E-mail and Internet Fax is set.[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD]E-mail[/TD] [TD][/TD] [TD]9947[/TD] [TD][/TD] [TD]E-mail transmission retry interval[/TD] [TD]1[/TD] [TD]0~15[/TD] [TD]SYS[/TD] [TD]When E-mail transmission retry for Scan to E-mail and Internet Fax is performed, the interval is set. 0 min - 15 min[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9954[/TD] [TD][/TD] [TD]Control box counter / job list printing operation[/TD] [TD]0[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: Invalid 1: Valid[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD][/TD] [TD][/TD] [TD]9955[/TD] [TD][/TD] [TD]Name of [EXTENSION] button[/TD] [TD]EXTENS ION[/TD] [TD][/TD] [TD]SYS[/TD] [TD]Sets the name of " EXTENSION" button displayed on the MENU screen. Maximum 10 characters with alphameric characters and symbols.[/TD] [TD]11[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9958[/TD] [TD][/TD] [TD]Bcc address display ON/OFF setting (Job Log / Job Status)[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Sets whether the Bcc address is displayed or not on the Job Log or Job Status. 0: OFF (Bcc address not displayed) 1: ON (Bcc address displayed)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9959[/TD] [TD][/TD] [TD]Bcc address display ON/OFF setting (Job Notification)[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Sets whether the Bcc address is displayed or not on all the Job Notifications except for the administrator. 0: OFF (Bcc address not displayed) 1: ON (Bcc address displayed)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9960[/TD] [TD][/TD] [TD]Equipment information (SRAM)[/TD] [TD]Refer to contents[/TD] [TD]0~2[/TD] [TD]SYS[/TD] [TD]Displays the equipment information in SRAM. 0: Not set 1: Destinations other than NAD 2: NAD <Default value> NAD: 2 Others: 1[/TD] [TD]2[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD][/TD] [TD][/TD] [TD]9963[/TD] [TD][/TD] [TD]Display of receiving job on PRINT/JOB STATUS screen[/TD] [TD]2[/TD] [TD]0-2[/TD] [TD]SYS[/TD] [TD]0: Disabled 1: Enabled (Other user's receiving job can be deleted) 2: Enabled (Other user's receiving job cannot be deleted) * This setting is automatically disabled in the high security mode.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Default mode setting[/TD] [TD]Default setting (PPC)[/TD] [TD]9970[/TD] [TD][/TD] [TD]Original mode (Black)[/TD] [TD]0[/TD] [TD]0~4[/TD] [TD]SYS[/TD] [TD]0: Text/Photo 1: Text 2: Photo 3: Not used 4: Custom[/TD] [TD]1[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]General[/TD] [TD][/TD] [TD][/TD] [TD]9971[/TD] [TD][/TD] [TD]Image quality density adjustment at power- ON Default setting[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Automatic 1: Manual (Center)[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Blank page judgment Default setting[/TD] [TD]PPC[/TD] [TD]9972[/TD] [TD][/TD] [TD]Blank page judgment Default setting[/TD] [TD]0[/TD] [TD]-3~3[/TD] [TD]SYS[/TD] [TD]The larger the value is, the more the paper is judged as a blank page. The smaller the value is, the less the paper is judged as a blank page.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]Blank page judgment Default setting[/TD] [TD]SCN[/TD] [TD]9973[/TD] [TD][/TD] [TD]Blank page judgment Default setting[/TD] [TD]0[/TD] [TD]-3~3[/TD] [TD]SYS[/TD] [TD]The larger the value is, the more the paper is judged as a blank page. The smaller the value is, the less the paper is judged as a blank page.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD]ACS judgment adjustment Default setting[/TD] [TD]SCN[/TD] [TD]9975[/TD] [TD][/TD] [TD]ACS judgment adjustment Default setting[/TD] [TD]0[/TD] [TD]-3~3[/TD] [TD]SYS[/TD] [TD]The larger the value is, the more the original is judged as color data. The smaller the value is, the less the original is judged as black data.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]05/08[/TD] [TD]Mode[/TD] [TD]Element[/TD] [TD]Sub element[/TD] [TD]Item[/TD] [TD]Subitem[/TD] [TD]Code[/TD] [TD]Sub- code[/TD] [TD]Details[/TD] [TD]Default value[/TD] [TD]Acceptable value[/TD] [TD]RAM[/TD] [TD]Contents[/TD] [TD]Proc edure[/TD] [TD]Service UI[/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9980[/TD] [TD][/TD] [TD]Address setting for TO/CC/BCC at authentication[/TD] [TD]0[/TD] [TD]0-4[/TD] [TD]SYS[/TD] [TD]Sets address of TO/CC/BCC when the user authentication and E-mail authentication are enabled. When the value of this code is set to "1", the address specified as From Address is input to TO destination field. TO/CC/BCC field cannot be edited. When the value of this code is set to "2 to 4", the address specified as From Address is input to each field. TO/CC/BCC field can be edited by pressing the TO/CC/BCC button. 0: Disabled 1: Fixed to TO field. 2: Added to TO field. 3: Added to CC field. 4: Added to BCC field.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Network[/TD] [TD][/TD] [TD][/TD] [TD]9981[/TD] [TD][/TD] [TD]Sending body text of email[/TD] [TD]1[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]Sets whether the job information is output in the body of e-mail when executing e-mail send job. 0: Disabled 1: Enabled[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD][/TD] [TD][/TD] [TD]9982[/TD] [TD][/TD] [TD]Switch of display attribute of [EXTENSION] icon[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Touch is invalid when authentication is not completed. 1: Touch is valid when authentication is not completed.[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9984[/TD] [TD][/TD] [TD]Document name in printing/scanning[/TD] [TD]0[/TD] [TD]0~1[/TD] [TD]SYS[/TD] [TD]0: Not confidential name (default) 1: Confidential name[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting Mode[/TD] [TD]System[/TD] [TD]User interface[/TD] [TD][/TD] [TD][/TD] [TD]9985[/TD] [TD][/TD] [TD]Screen displayed by pressing MENU button[/TD] [TD]0[/TD] [TD]0-1[/TD] [TD]SYS[/TD] [TD]0: MENU screen 1: EWB screen[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD]08[/TD] [TD]Setting mode[/TD] [TD]System[/TD] [TD]Maintenan ce[/TD] [TD][/TD] [TD][/TD] [TD]9987[/TD] [TD][/TD] [TD]Retention of fax sending settings[/TD] [TD]0[/TD] [TD]0~3[/TD] [TD]SYS[/TD] [TD]Sets whether the fax sending settings are retained or not. 0: Clears all settings (The authentication screen is displayed if user authentication or department management is enabled.) 1: Clears all 2: Clears only addresses 3: Retains all settings * When the value of this code is set to "3", the value of 08-3847 (FAX mistransmission prevention) is automatically set to "1" (Enabled).[/TD] [TD]1[/TD] [TD][/TD] [/TR] [/TABLE] e-STUDIO206L/256/306/356/456/506 [TABLE] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_001.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_002.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_003.png[/IMG][/TD] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_004.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_005.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_006.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_007.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_008.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_009.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_010.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_011.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_012.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_013.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_014.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_015.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_016.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_017.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_018.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_019.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_020.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_021.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_022.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_023.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_024.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_025.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_026.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_027.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_028.png[/IMG][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_029.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_030.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_031.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_032.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_033.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_034.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_035.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_036.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_037.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_038.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_039.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_040.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_041.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_042.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_043.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_044.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_045.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_046.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_047.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_048.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_049.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_050.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_051.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_052.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_053.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_054.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_055.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_056.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_057.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_058.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_059.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_060.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_061.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_062.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_063.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_064.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_065.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_066.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_067.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_068.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_069.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_070.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_071.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_072.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_073.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_074.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_075.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_076.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_077.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_078.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_079.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_080.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_081.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_082.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_083.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_084.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_085.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_086.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_087.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_088.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_089.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_090.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_091.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_092.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_093.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_094.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_095.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_096.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_097.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_098.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_099.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_100.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_101.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_102.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_103.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_104.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_105.png[/IMG][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_106.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_107.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_108.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_109.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_110.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_111.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_112.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_113.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_114.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_115.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_116.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_117.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_118.png[/IMG][/TD] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_119.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_120.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_121.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_122.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_123.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_124.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_125.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_126.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_127.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_128.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_129.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_130.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_131.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_132.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_133.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_134.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_135.png[/IMG][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_136.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_137.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_138.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_139.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_140.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_141.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_142.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_143.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_144.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_145.png[/IMG][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_146.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_147.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_148.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_149.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_150.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_151.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_152.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_153.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_154.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_155.png[/IMG][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_156.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_157.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_158.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_159.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_160.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_161.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_162.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_163.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_164.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_165.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_166.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_167.png[/IMG][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] e-STUDIO207L/257/307/357/457/507 [TABLE] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_168.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_169.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_170.png[/IMG][/TD] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_171.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_172.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_173.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_174.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_175.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_176.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_177.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_178.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_179.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_180.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_181.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_182.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_183.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_184.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_185.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_186.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_187.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_188.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_189.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_190.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_191.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_192.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_193.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_194.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_195.png[/IMG][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_196.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_197.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_198.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_199.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_200.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_201.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_202.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_203.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_204.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_205.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_206.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_207.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_208.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_209.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_210.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_211.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_212.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_213.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_214.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_215.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_216.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_217.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_218.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_219.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_220.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_221.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_222.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_223.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_224.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_225.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_226.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_227.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_228.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_229.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_230.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_231.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_232.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_233.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_234.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_235.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_236.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_237.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_238.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_239.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_240.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_241.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_242.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_243.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_244.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_245.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_246.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_247.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_248.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_249.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_250.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_251.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_252.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_253.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_254.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_255.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_256.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_257.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_258.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_259.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_260.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_261.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_262.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_263.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_264.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_265.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_266.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_267.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_268.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_269.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_270.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_271.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_272.png[/IMG][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_273.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_274.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_275.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_276.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_277.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_278.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_279.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_280.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_281.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_282.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_283.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_284.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_285.png[/IMG][/TD] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_286.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_287.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_288.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_289.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_290.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_291.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_292.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_293.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_294.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_295.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_296.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_297.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_298.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_299.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_300.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_301.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_302.png[/IMG][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_303.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_304.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_305.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_306.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_307.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_308.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_309.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_310.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_311.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_312.png[/IMG][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_313.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_314.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_315.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_316.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_317.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_318.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_319.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_320.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_321.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_322.png[/IMG][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_323.png[/IMG] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_324.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_325.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_326.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_327.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_328.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_329.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_330.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_331.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_332.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_333.png[/IMG][/TD] [TD] [IMG alt="image"]https://todaynetnews.com/uploads/toshiba/toshiba-e-studio-207l-257-307-357-457-507-service-manual/part15/Image_334.png[/IMG][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [HEADING=2]REVISION RECORD[/HEADING] [HEADING=2]Ver.06[/HEADING] [TABLE] [TR] [TD]Ver. 06 <2014.04.17>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]Cover[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]Precautions[/TD] [TD]Model names and a note have been added.[/TD] [/TR] [TR] [TD]1-1[/TD] [TD]"1.2 Main Features of e-STUDIO257/257P/357/457/507" has been added.[/TD] [/TR] [TR] [TD]2-1 to 2-11[/TD] [TD]Specifications for the new models have been added.[/TD] [/TR] [TR] [TD]2-14[/TD] [TD]New options have been added.[/TD] [/TR] [TR] [TD]2-20[/TD] [TD]New options have been added.[/TD] [/TR] [TR] [TD]2-23[/TD] [TD]Information of the supplies for the new models has been added.[/TD] [/TR] [TR] [TD]3-1[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-3[/TD] [TD]A sectional view for the new models has been added.[/TD] [/TR] [TR] [TD]3-4[/TD] [TD]A sectional view for the new models has been added.[/TD] [/TR] [TR] [TD]3-5[/TD] [TD]Electric parts for the new models have been added.[/TD] [/TR] [TR] [TD]3-7[/TD] [TD]An electric parts layout for the new models has been added.[/TD] [/TR] [TR] [TD]3-10[/TD] [TD]An electric parts layout for the new models has been added.[/TD] [/TR] [TR] [TD]3-13[/TD] [TD]An electric parts layout for the new models has been added.[/TD] [/TR] [TR] [TD]3-14[/TD] [TD]An electric parts layout for the new models has been added.[/TD] [/TR] [TR] [TD]3-15[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]3-16[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]3-19 to 3-24[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-28[/TD] [TD]A process condition for the new models has been added.[/TD] [/TR] [TR] [TD]3-36[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-39[/TD] [TD]An illustration of the control panel for the new models has been added.[/TD] [/TR] [TR] [TD]3-41 to 3-47[/TD] [TD]A new model information has been added.[/TD] [/TR] [TR] [TD]3-48[/TD] [TD]"3.9.5 Process of detection of original size" has been added.[/TD] [/TR] [TR] [TD]3-51[/TD] [TD]An external appearance of the new models has been added.[/TD] [/TR] [TR] [TD]3-65 to 3-67[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-69[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-71 to 3-79[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-80[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-81[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-83[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-86[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-88[/TD] [TD]An information for the new models has been added.[/TD] [/TR] [TR] [TD]3-89[/TD] [TD]An information for the new models has been added.[/TD] [/TR] [TR] [TD]3-90[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]3-91[/TD] [TD]An information for the new models has been added.[/TD] [/TR] [TR] [TD]4-1[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]4-8 to 4-17[/TD] [TD]Procedures of disassembly and replacement of the covers for the new models have been added.[/TD] [/TR] [TR] [TD]4-18[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]4-22 to 4-25[/TD] [TD]Procedures of disassembly and replacement of the control panel for the new models have been added.[/TD] [/TR] [TR] [TD]4-26[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]4-45 to 4-57[/TD] [TD]Procedures of disassembly and replacement of the scanner for the new models have been added.[/TD] [/TR] [TR] [TD]4-58[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]4-60 to 4-62[/TD] [TD]Procedures of disassembly and replacement of the laser optical unit for the new models have been added.[/TD] [/TR] [/TABLE] © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 REVISION RECORD [TABLE] [TR] [TD]Ver. 06 <2014.04.17>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]4-66[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-77[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-78[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-86[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-87[/TD] [TD]Procedures of disassembly and replacement of the process unit fan for the new models have been added.[/TD] [/TR] [TR] [TD]4-91[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-93[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-105[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-114[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-115[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-119[/TD] [TD]"Note" has been moved.[/TD] [/TR] [TR] [TD]4-124[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-129[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-131[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-132[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-133[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-143[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-155[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-156[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-159[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-160[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-162[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-163[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]4-178 to 4-190[/TD] [TD]Procedures of disassembly and replacement of the damp heater have been added.[/TD] [/TR] [TR] [TD]5-1[/TD] [TD]An information for the new models has been added.[/TD] [/TR] [TR] [TD]5-14[/TD] [TD]Notes have been added.[/TD] [/TR] [TR] [TD]5-15[/TD] [TD]"Note" has been added.[/TD] [/TR] [TR] [TD]5-23[/TD] [TD]A note has been added.[/TD] [/TR] [TR] [TD]5-27[/TD] [TD]"Note" has been added.[/TD] [/TR] [TR] [TD]6-9 to 6-11[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-13[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-15 to 6-18[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-23[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-25[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-26[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-27[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-28[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-29[/TD] [TD]An adjustment procedure has been added.[/TD] [/TR] [TR] [TD]6-31[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-34[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-36[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-37[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-39[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-39[/TD] [TD]Descriptions for the adjustment have been added.[/TD] [/TR] [TR] [TD]6-41[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-42[/TD] [TD]An adjustment procedure has been added.[/TD] [/TR] [TR] [TD]6-50[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]6-57[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-58[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [/TABLE] e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD [TABLE] [TR] [TD]Ver. 06 <2014.04.17>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]6-60[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-61[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-71[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-72[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-73[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-74[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-77[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-85[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]6-95[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]6-108[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]7-4[/TD] [TD]New model names have been added.[/TD] [/TR] [TR] [TD]7-5[/TD] [TD]The illustration of the operational flow has been changed.[/TD] [/TR] [TR] [TD]7-16[/TD] [TD]New model names have been added. The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-17[/TD] [TD]Descriptions for the new models have been added. The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-18[/TD] [TD]Descriptions for the new models have been added.[/TD] [/TR] [TR] [TD]7-19[/TD] [TD]The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-22[/TD] [TD]The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-24[/TD] [TD]The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-26[/TD] [TD]The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-27[/TD] [TD]Notes have been added.[/TD] [/TR] [TR] [TD]7-28[/TD] [TD]New model names have been added. The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-29[/TD] [TD]The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-30[/TD] [TD]The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-31[/TD] [TD]The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-34[/TD] [TD]New model names have been added. The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-36[/TD] [TD]New model names have been added. The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-40[/TD] [TD]Model names have been added. The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-45[/TD] [TD]Model names have been added. The symbols given in the Replacement column have been changed.[/TD] [/TR] [TR] [TD]7-50[/TD] [TD]PM kits for the new models have been added.[/TD] [/TR] [TR] [TD]7-51[/TD] [TD]An information for the new models has been added.[/TD] [/TR] [TR] [TD]7-53[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]7-54[/TD] [TD]"7.13 Machine Refreshing Checklist (e-STUDIO207L/257/307/357/457/507)" has been added.[/TD] [/TR] [TR] [TD]8-9[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-10[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-11[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-12[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-13[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-14[/TD] [TD]Error codes C261 and C262 have been added.[/TD] [/TR] [TR] [TD]8-15[/TD] [TD]Error codes C443, C445, C447, C449, C452 and C4B0 have been added. Model names have been added.[/TD] [/TR] [TR] [TD]8-16[/TD] [TD]An error code C911 has been added. Model names have been added.[/TD] [/TR] [TR] [TD]8-17[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-18[/TD] [TD]Model names have been added.[/TD] [/TR] [/TABLE] © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 REVISION RECORD [TABLE] [TR] [TD]Ver. 06 <2014.04.17>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]8-19[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-33[/TD] [TD]The title for chapter 8.2.5 has been changed from "TopAccess related error" to "TOSHIBA Remote monitoring system error".[/TD] [/TR] [TR] [TD]8-35[/TD] [TD]An error code 6014 has been added.[/TD] [/TR] [TR] [TD]8-50[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-51[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-72[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-90[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-92[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-93[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-95[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-96[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-98[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-99[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-100[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-101[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-102[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-103[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-104[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-105[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-107[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-109[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-110[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-111[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-112[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-113[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-114[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-115[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-116[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-117[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-118[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-119[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-120[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-128[/TD] [TD]The troubleshooting for C260 has been changed.[/TD] [/TR] [TR] [TD]8-129[/TD] [TD]A troubleshooting for C260 for the new models has been added.[/TD] [/TR] [TR] [TD]8-130[/TD] [TD]A troubleshooting for C261 have been added.[/TD] [/TR] [TR] [TD]8-131[/TD] [TD]A troubleshooting for C262 have been added. Model names have been added.[/TD] [/TR] [TR] [TD]8-133[/TD] [TD]A troubleshooting for C270 for the new models has been added.[/TD] [/TR] [TR] [TD]8-134[/TD] [TD]A troubleshooting for C280 for the new models has been added. Model names have been added.[/TD] [/TR] [TR] [TD]8-136[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-137[/TD] [TD]A troubleshooting for C290 for the new models has been added.[/TD] [/TR] [TR] [TD]8-140[/TD] [TD]A troubleshooting for C911 for the new models has been added.[/TD] [/TR] [TR] [TD]8-141[/TD] [TD]A troubleshooting for C411 has been added. A troubleshooting for C412 has been added.[/TD] [/TR] [TR] [TD] 8-144[/TD] [TD]A troubleshooting for C443 has been added. A troubleshooting for C445 has been added. A troubleshooting for C447 has been added.[/TD] [/TR] [TR] [TD]8-145[/TD] [TD]A troubleshooting for C449 has been added.[/TD] [/TR] [TR] [TD]8-146[/TD] [TD]A troubleshooting for C452 has been added.[/TD] [/TR] [/TABLE] e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD [TABLE] [TR] [TD]Ver. 06 <2014.04.17>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]8-147[/TD] [TD]A troubleshooting for C4B0 has been added.[/TD] [/TR] [TR] [TD]8-149[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-150[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-152[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-153[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-155[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-156[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-157[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-158[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-160[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-161[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-162[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-163[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-165[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-166[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-167[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-168[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-169[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-170[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-171[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-172[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-173[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-174[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-176[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-178[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-179[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-180[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-181[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-185[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-186[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-187[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-189[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-190[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-191[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-218[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-264[/TD] [TD]A troubleshooting for 6014 has been added.[/TD] [/TR] [TR] [TD]8-292[/TD] [TD]The troubleshooting of "Background fogging" has been changed.[/TD] [/TR] [TR] [TD]8-294[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-297[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-299[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-312[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]8-316[/TD] [TD]"8.5.3 Error code ÅgM00Åh is displayed while updating firmware" has been added.[/TD] [/TR] [TR] [TD]9-1[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]9-8 to 9-15[/TD] [TD]Procedures of disassembly and replacement of the PC boards for the new models have been added.[/TD] [/TR] [TR] [TD]9-16[/TD] [TD]An explanation of the difference between the current and new models has been added.[/TD] [/TR] [TR] [TD]9-19[/TD] [TD]Notes have been added.[/TD] [/TR] [TR] [TD]9-28[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]9-29[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]9-31[/TD] [TD]A note has been added.[/TD] [/TR] [/TABLE] © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 REVISION RECORD [TABLE] [TR] [TD]Ver. 06 <2014.04.17>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]9-32[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]9-33[/TD] [TD]A model information has been added. A note has been added.[/TD] [/TR] [TR] [TD]9-36[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]11-1[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]11-7 to 11-10[/TD] [TD]Procedures of firmware upgrading for the new models have been added.[/TD] [/TR] [TR] [TD]11-11[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]11-13 to 11-14[/TD] [TD]Procedures of firmware upgrading for the new models have been added.[/TD] [/TR] [TR] [TD]11-15[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]11-17[/TD] [TD]Procedures of firmware upgrading for the new models have been added.[/TD] [/TR] [TR] [TD]11-18[/TD] [TD]Explanations have been added.[/TD] [/TR] [TR] [TD]11-20[/TD] [TD]An explanation for the M00 error has been added.[/TD] [/TR] [TR] [TD]11-21[/TD] [TD]Descriptions for the punch firmware update errors have been added.[/TD] [/TR] [TR] [TD]11-22[/TD] [TD]Descriptions for the finisher firmware update errors have been added. Descriptions for the saddle firmware update errors have been added.[/TD] [/TR] [TR] [TD]11-23[/TD] [TD]The explanation about the change of the LCD screen has been altered.[/TD] [/TR] [TR] [TD]11-24[/TD] [TD]The explanation about the change of the LCD screen has been altered.[/TD] [/TR] [TR] [TD]11-25[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]11-27[/TD] [TD]Procedures of firmware upgrading for the new models have been added.[/TD] [/TR] [TR] [TD]11-30[/TD] [TD]Procedures of firmware upgrading for the new models have been added.[/TD] [/TR] [TR] [TD]11-34[/TD] [TD]Explanations for the firmware upgrading jig have been added.[/TD] [/TR] [TR] [TD]11-35[/TD] [TD]Explanations for the firmware upgrading jig have been added.[/TD] [/TR] [TR] [TD]11-38[/TD] [TD]Procedures of firmware upgrading for the new models have been added.[/TD] [/TR] [TR] [TD]11-39[/TD] [TD]Procedures of firmware upgrading for the new models have been added.[/TD] [/TR] [TR] [TD]11-44[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]11-46[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]11-77[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]11-78 to 11-80[/TD] [TD]Procedures of firmware upgrading for the new models have been added.[/TD] [/TR] [TR] [TD]11-82[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]12-1[/TD] [TD]The note has been deleted.[/TD] [/TR] [TR] [TD]12-2[/TD] [TD]The explanation about the filename has been changed.[/TD] [/TR] [TR] [TD]14-1[/TD] [TD]Model names have been added.[/TD] [/TR] [TR] [TD]14-2[/TD] [TD]An AC wire harness diagram for the new models has been added.[/TD] [/TR] [TR] [TD]14-7 to 14-10[/TD] [TD]A DC wire harness diagram for the new models has been added.[/TD] [/TR] [TR] [TD]1068[/TD] [TD]A model information has been added.[/TD] [/TR] [TR] [TD]1131[/TD] [TD]Descriptions for the 08-2002 have been changeed.[/TD] [/TR] [TR] [TD]1287 to 1341[/TD] [TD]05 codes for the new models have been added.[/TD] [/TR] [TR] [TD]1342 to 1503[/TD] [TD]05 codes for the new models have been added.[/TD] [/TR] [TR] [TD]1505[/TD] [TD]The maintenance check list of a model has been added.[/TD] [/TR] [/TABLE] e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD [HEADING=2]Ver.05[/HEADING] [TABLE] [TR] [TD]Ver. 05 <2014.01.10>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD] Trademarks[/TD] [TD]Windows 8, Windows Server 2003, Windows Server 2008, and Windows Server 2012 have been added. The trademark sentence for Microsoft has been changed. The official company name of “Apple” has been corrected.[/TD] [/TR] [TR] [TD]2-9[/TD] [TD]The supported OS has been corrected.[/TD] [/TR] [TR] [TD]5-1[/TD] [TD]The reference chapter for the self-diagnosis code has been corrected.[/TD] [/TR] [TR] [TD]5-5[/TD] [TD]The reference chapter for the self-diagnosis code has been corrected.[/TD] [/TR] [TR] [TD]5-30[/TD] [TD]The descriptions for (05) adjustment value difference, (08) setting value difference, and Job log/Message log have been added.[/TD] [/TR] [TR] [TD]5-31[/TD] [TD]The CSV file names for (05) adjustment value difference, (08) setting value difference, and Job log/Message log have been added.[/TD] [/TR] [TR] [TD]5-32[/TD] [TD]The descriptions for (05) adjustment value difference, (08) setting value difference, and Job log/Message log have been added.[/TD] [/TR] [TR] [TD]5-33[/TD] [TD]The reference chapter for the self-diagnosis code has been corrected.[/TD] [/TR] [TR] [TD]5-34[/TD] [TD]The reference chapter for the self-diagnosis code has been corrected.[/TD] [/TR] [TR] [TD]5-35[/TD] [TD]The format of “PM SUPPORT CODE LIST” has been corrected.[/TD] [/TR] [TR] [TD]5-36[/TD] [TD]The format of “PIXEL COUNTER CODE LIST (TONER CARTRIDGE)” has been corrected.[/TD] [/TR] [TR] [TD]5-37[/TD] [TD]The format of “PIXEL COUNTER CODE LIST (SERVICEMAN)” has been corrected.[/TD] [/TR] [TR] [TD]5-41[/TD] [TD]The format of “VERSION LIST” has been corrected.[/TD] [/TR] [TR] [TD]5-42[/TD] [TD]The format of “TOTAL COUNTER LIST” has been corrected.[/TD] [/TR] [TR] [TD]5-43[/TD] [TD]The list for (05) adjustment value/(08) setting value difference has been added.[/TD] [/TR] [TR] [TD]5-52[/TD] [TD]08-6588 has been deleted.[/TD] [/TR] [TR] [TD]6-27[/TD] [TD]The description has been changed.[/TD] [/TR] [TR] [TD]6-40[/TD] [TD]05-9107 has been deleted.[/TD] [/TR] [TR] [TD]7-5[/TD] [TD]The format of “PM SUPPORT CODE LIST” has been corrected.[/TD] [/TR] [TR] [TD]7-16[/TD] [TD]08-6212, 08-6218, 08-6220, and 08-6222 have been deleted.[/TD] [/TR] [TR] [TD]8-36[/TD] [TD]5C22 has been deleted.[/TD] [/TR] [TR] [TD]8-37[/TD] [TD]Error code 6013 has been added.[/TD] [/TR] [TR] [TD]8-255[/TD] [TD]5C22 has been deleted.[/TD] [/TR] [TR] [TD]8-256[/TD] [TD]The troubleshooting for 6013 has been added.[/TD] [/TR] [TR] [TD]8-286[/TD] [TD]08-2172 is changed to 08-2142.[/TD] [/TR] [TR] [TD]8-307[/TD] [TD]The troubleshooting for H04 has been added.[/TD] [/TR] [TR] [TD]9-17[/TD] [TD]The contents of “Precautions and Procedures when replacing the SYS board” has been changed.[/TD] [/TR] [TR] [TD]9-18[/TD] [TD]The contents of “Precautions and Procedures when replacing the SYS board” has been changed.[/TD] [/TR] [TR] [TD]9-19[/TD] [TD]The contents of “Precautions and Procedures when replacing the SYS board” has been changed.[/TD] [/TR] [TR] [TD]9-20[/TD] [TD]The contents of “Precautions and Procedures when replacing the SYS board” has been changed.[/TD] [/TR] [TR] [TD]9-22[/TD] [TD]The reference chapter for the self-diagnosis code has been corrected.[/TD] [/TR] [TR] [TD]10-1[/TD] [TD]The description has been changed.[/TD] [/TR] [TR] [TD]10-11[/TD] [TD]The description has been changed.[/TD] [/TR] [TR] [TD]10-13[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]10-15[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]10-16[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]10-26[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]10-28[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]10-29[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]10-31[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [/TABLE] © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 REVISION RECORD [TABLE] [TR] [TD]Ver. 05 <2014.01.10>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]10-32[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]10-37[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]10-38[/TD] [TD]The toner remaining information has been added.[/TD] [/TR] [TR] [TD]11-13[/TD] [TD]Note for the “Invalid Signature” error has been added. Error code H04 has been added.[/TD] [/TR] [TR] [TD]11-29[/TD] [TD]Error code H04 has been added.[/TD] [/TR] [TR] [TD]13-4[/TD] [TD]The value “5” has been added for 08-9016.[/TD] [/TR] [TR] [TD] Chapter 15[/TD] [TD]05-3009 and 9149 have been added. The acceptable value of 08-3623 has been changed. 08-3637, 3638, 3639, 3644, 6088-0, -1, 6089-0, -1, 6090, 6091, 8642, 8643, 8644, 8645, 8646, 8647, 8648, 8649, 8650, 8651, 8652, 8653, 8654, 8655, 8656, 8657, 8658, 8659, 8660, 8661, 8662, 8663, 8664-0, -1, -2, 8667, 8668, 8671-0, -1, -2, 8672-0, -1, -2, 8673, 8674, 8727, 8728-0, -1, -2, -3, -4, -6, -7, -8, -9, -10, -11, -12, -13, 8729, 8730, 8735, 8736, 8754, 8755, 8756-0, -1, 8758, 8762-0, 8771, 8774, 8781, 8785, 8786-0, -1, 8788, 8789, 8790, 8791, 8792, 8826, 8827, 8831, 9255, and 9963 have been added. The contents of 08-3864, 4105, 4131, 8981, 9022 have been changed. The item, details, and contents of 08-6080 have been changed. The sub element, item, subitem, and details of 08-6081-0, -1, 6084, 6085-0, -1 have been changed. The default values of 08-8520 and 8745 have been changed. The acceptable values and contents of 08-9016 and 9017 have been changed. The details of 08-9398 have been changed.[/TD] [/TR] [/TABLE] [HEADING=2]Ver.04[/HEADING] [TABLE] [TR] [TD]Ver. 04 <2013.10.3>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]GENERAL PRECAUTIONS[/TD] [TD]"General operations" has been added.[/TD] [/TR] [TR] [TD]2-3[/TD] [TD]The description of warm-up time has been added.[/TD] [/TR] [TR] [TD]3-31[/TD] [TD]The descriptions of the hibernation function have been added.[/TD] [/TR] [TR] [TD]5-19[/TD] [TD]The descriptions of operations have been changed.[/TD] [/TR] [TR] [TD]5-22[/TD] [TD]The descriptions of operations have been changed.[/TD] [/TR] [TR] [TD]5-24[/TD] [TD]The step has been changed. The image has been changed.[/TD] [/TR] [TR] [TD]5-25[/TD] [TD]The note has been added.[/TD] [/TR] [TR] [TD]5-35[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-36[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-37[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-38[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-39[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-40[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-41[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-42[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-50[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]5-51[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]6-33[/TD] [TD]The table has been changed.[/TD] [/TR] [TR] [TD]6-72[/TD] [TD]The step has been changed.[/TD] [/TR] [TR] [TD]6-75[/TD] [TD]The step has been changed.[/TD] [/TR] [TR] [TD]7-4[/TD] [TD]The codes have been added.[/TD] [/TR] [TR] [TD]7-6[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]7-11[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]7-14[/TD] [TD]The codes have been changed.[/TD] [/TR] [TR] [TD]7-51[/TD] [TD]The PM kits have been added. The column of Part name has been deleted.[/TD] [/TR] [TR] [TD]8-3[/TD] [TD]The description has been added.[/TD] [/TR] [/TABLE] e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD [TABLE] [TR] [TD]Ver. 04 <2013.10.3>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]8-21[/TD] [TD]Error code of F101_4 to F101_9 have been added[/TD] [/TR] [TR] [TD]8-22[/TD] [TD]Error code of F106_6 and F106_UNDEF have been added.[/TD] [/TR] [TR] [TD]8-33[/TD] [TD]The error code 4242 has been added.[/TD] [/TR] [TR] [TD]8-35[/TD] [TD]Error code of 5010 to 50FF have been added[/TD] [/TR] [TR] [TD]8-44[/TD] [TD]The example and code have been changed.[/TD] [/TR] [TR] [TD]8-45[/TD] [TD]The example and code have been changed.[/TD] [/TR] [TR] [TD]8-130[/TD] [TD]Descriptions of C260 have been changed.[/TD] [/TR] [TR] [TD]8-131[/TD] [TD]Descriptions of C270 and C280 have been changed.[/TD] [/TR] [TR] [TD]8-132[/TD] [TD]Descriptions of C290 have been changed.[/TD] [/TR] [TR] [TD]8-133[/TD] [TD]Descriptions of C290 have been changed.[/TD] [/TR] [TR] [TD]8-138[/TD] [TD]The illustration has been changed.[/TD] [/TR] [TR] [TD]8-140[/TD] [TD]The measures for C550 have been changed.[/TD] [/TR] [TR] [TD]8-186[/TD] [TD]The descriptions of F101_0 to F101_3 have been changed.[/TD] [/TR] [TR] [TD]8-187[/TD] [TD]F101_4 has been added..[/TD] [/TR] [TR] [TD]8-188[/TD] [TD]F101_5 has been added.[/TD] [/TR] [TR] [TD]8-189[/TD] [TD]F101_6 has been added.[/TD] [/TR] [TR] [TD]8-190[/TD] [TD]F101_7 has been added.[/TD] [/TR] [TR] [TD]8-191[/TD] [TD]F101_8 has been added.[/TD] [/TR] [TR] [TD]8-192[/TD] [TD]F101_9 has been added.[/TD] [/TR] [TR] [TD]8-195[/TD] [TD]F106_6 to F106_UNDEF have been added.[/TD] [/TR] [TR] [TD]8-196[/TD] [TD]F106_6 to F106_UNDEF have been added.[/TD] [/TR] [TR] [TD]8-247[/TD] [TD]The troubleshooting for 4241 and 4242 has been added.[/TD] [/TR] [TR] [TD]8-251[/TD] [TD]The troubleshooting for 5010 and 5014 has been added.[/TD] [/TR] [TR] [TD]8-252[/TD] [TD]The troubleshooting for 5015 and 5019 has been added.[/TD] [/TR] [TR] [TD]8-253[/TD] [TD]The troubleshooting for 501A and 50FF has been added.[/TD] [/TR] [TR] [TD]9-14[/TD] [TD]The step has been changed.[/TD] [/TR] [TR] [TD]Appendix[/TD] [TD]The default value of 05-2382 has been changed. 05-4150-0, -1, -2, and 9107 have been deleted. The contents of 05-9043 have been changed. The default values of 08-2847, 2848, 6368-1, -4, 8523, and 9486 have been changed. The contents of 08-3500, 3501, 3502, 4016-0, -1, and 9987 have been changed. 08-3509, 3636, 5000, 6023-2, 6024-8, 6025-0, 6026-1, 6043-7, 6044-8, 6045-0, 6050-1, 6051-1Å`25, 8737, 9482, 9483, 9484, and 9485 have been deleted. The acceptable value and contents of 08-3724, 5155, and 9307 have been changed. 08-5156-3, 5810, 5811, 6820-0, -1, 6823-0, -1, 6852-0Å`2, 8521, 8623-0, 8628, 8640, 8641, 8761, 8775, 8776, 8777, 8778, 8779, 8780, 8782, 8783, 8825, 8942, and 9599 have been added. The details of 08-9398 have been changed.[/TD] [/TR] [/TABLE] [HEADING=2]Ver.03[/HEADING] [TABLE] [TR] [TD]Ver. 03 <2012.07.06>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]2-13[/TD] [TD]"2.3 System List" has been corrected.[/TD] [/TR] [TR] [TD]3-33[/TD] [TD]The part name has been changed from "LED driving PC board" to "LED board". (Uniform terminology)[/TD] [/TR] [TR] [TD]3-34[/TD] [TD]The part name has been changed from "LED driving PC board" to "LED board". (Uniform terminology)[/TD] [/TR] [TR] [TD]3-37[/TD] [TD]The part name has been changed from "LED driving PC board" to "LED board". (Uniform terminology)[/TD] [/TR] [TR] [TD]4-31[/TD] [TD]The part name has been changed from "LED driving PC board" to "LED board". (Uniform terminology)[/TD] [/TR] [TR] [TD]5-52[/TD] [TD]"5.15 PM support mode related code" has been deleted.[/TD] [/TR] [TR] [TD]7-51[/TD] [TD]The part name of the ozone filter has been corrected.[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]Ver. 03 <2012.07.06>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]8-3[/TD] [TD]"8.1.2 Collection of debug logs with a USB device" has been added.[/TD] [/TR] [TR] [TD]8-19[/TD] [TD]F101_0 to F101_3 have been added and the description of F101 has been corrected. The descriptions of F100_0 to F100_2 have been corrected.[/TD] [/TR] [TR] [TD]8-20[/TD] [TD]F109_5 and F109_6 have been added. The descriptions of F121 and F122 have been corrected. F901_1 has been added. F131 has been added.[/TD] [/TR] [TR] [TD]8-31[/TD] [TD]4F10 has been added.[/TD] [/TR] [TR] [TD] 8-181[/TD] [TD]Descriptions of F101_0 and F101_1 have been added. Descriptions of F101_2 and F101_3 have been added. F101 has been added.[/TD] [/TR] [TR] [TD]8-182[/TD] [TD]F101 has been removed.[/TD] [/TR] [TR] [TD]8-187[/TD] [TD]The descriptions of F109_3 and F109_4 have been corrected.[/TD] [/TR] [TR] [TD]8-189[/TD] [TD]Descriptions of F109_5 and F109_6 have been added.[/TD] [/TR] [TR] [TD]8-193[/TD] [TD]The descriptions of F121 and F122 have been corrected.[/TD] [/TR] [TR] [TD]8-194[/TD] [TD]A description of F131 has been added.[/TD] [/TR] [TR] [TD]8-199[/TD] [TD]F901_1 has been added.[/TD] [/TR] [TR] [TD]8-238[/TD] [TD]A description of 4F10 has been added.[/TD] [/TR] [TR] [TD]9-1[/TD] [TD]"9.1.2 Hard disk (HDD)" has been corrected.[/TD] [/TR] [TR] [TD]9-4[/TD] [TD]A note has been added to 9.1.3. A note has been added to 9.1.4.[/TD] [/TR] [TR] [TD]9-9[/TD] [TD]Steps 6 and 7 have been added to 9.2.1.[/TD] [/TR] [TR] [TD]9-12[/TD] [TD]A note has been added to 9.2.3.[/TD] [/TR] [TR] [TD]9-17[/TD] [TD]"9.2.4 Precautions and Procedures when replacing the SYS board" has been changed.[/TD] [/TR] [TR] [TD]9-18[/TD] [TD]"[E] Restore ADI key" has been added.[/TD] [/TR] [TR] [TD]9-20[/TD] [TD]"Note" has been added to "[I] Check ROM versions".[/I][/TD][I] [/i][/TR][I] [TR] [TD]9-21[/TD] [TD]The notes in 9.2.5 have been changed.[/TD] [/TR] [TR] [TD]9-22[/TD] [TD]"9.2.7 Procedures when replacing the SLG board" has been corrected.[/TD] [/TR] [TR] [TD]9-23[/TD] [TD]The figure in 9.2.8 has been corrected and a "Note" has been added.[/TD] [/TR] [TR] [TD]9-25[/TD] [TD]"[G] Backup ADI key" has been added.[/TD] [/TR] [TR] [TD]9-26[/TD] [TD]The procedures of "[J] Initialize SRAM board" have been changed.[/TD] [/TR] [TR] [TD]9-33[/TD] [TD]The description of 9.3.1 has been corrected and a description of 9.3.2 has been added.[/TD] [/TR] [TR] [TD]11-34[/TD] [TD]The procedures of "11.4.2 System ROM" have been corrected.[/TD] [/TR] [TR] [TD]11-35[/TD] [TD]"947" has been changed to "9030".[/TD] [/TR] [TR] [TD]Appendix[/TD] [TD]08-6087, 6250-0 to 8, 6251, 6258-0 to 8, 6259, 6272-0 to 8, 6273, 6274-0 to 8, 6275, 6282- 0 to 8, 6283, 6298-0 to 8, 6299, 6300-0 to 8, 6301, 6314-0 to 8, 6315, 6346-0 to 8, 6347, 6350-0 to 8, 6351, 6368-0 to 8, 6369, 6382-0 to 2,-8, 6383, 6384-0 to 2,-8, 6385, 6386-0 to 2,-8, 6387, 6390-0 to 2,-8, 6391, 6392-0 to 2,-8, 6393, 6394-0 to 2,-8, 6395, 6398-0 to 2,-8, 6399, 6400-0 to 2,-8, 6401, 6402-0 to 2,-8, 6403, 6406-0 to 2,-8, 6407, 6408-0 to 2,-8, 6409, 6410-0 to 2,-8, 6411, 6412-0 to 2,-8, 6413, 6414-0 to 2,-8, 6415, 6416-0 to 2,-8, 6417, 6420-0 to 2,-8, 6421, 6422-0 to 2,-8, 6423, 6424-0 to 2,-8, 6425, 6428-0 to 2,-8, 6429, 6430-0 to 2,-8, 6431, 6436-0 to 8, 6437, 8303, 8624, 8631, 8713, 8738, 8744, 8745, 8746, 8748, 8749, 8824, 8952, 9294, 9954, 9985 have been added. The default values of 08-9484, 9485, 9487, 9614, 9615, 9616, 9617, 9618, 9619, 9620, 9730, 3631 have been changed. The acceptable value and contents of 08-9132 have been changed. The acceptable values of 08-3500, 3501, 3502, 3503 have been changed. The contents of 08-4548 have been changed.[/TD] [/TR] [/i][/TABLE][I] [HEADING=2]Ver.02[/HEADING] [TABLE] [TR] [TD]Ver. 02 <2012.04.20>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]Cover[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]GENERAL PRECAUTIONS[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]1-1[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [/TABLE] e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD [TABLE] [TR] [TD]Ver. 02 <2012.04.20>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]2-1[/TD] [TD]The notes text for "2.1 Specifications" has been deleted. The information for the scanning light source has been changed.[/TD] [/TR] [TR] [TD]2-2[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]2-3[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]2-4[/TD] [TD]The first copy time for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]2-5[/TD] [TD]The copy speed table for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]2-6[/TD] [TD]The copy speed for thick paper for the e-STUDIO506 has been added to the tables.[/TD] [/TR] [TR] [TD]2-9[/TD] [TD]The system copy speed for the e-STUDIO506 has been added to the tables. "Black mode" has been added.[/TD] [/TR] [TR] [TD]2-12[/TD] [TD]"Control panel stopper" has been deleted from the table in "2.2 Accessories".[/TD] [/TR] [TR] [TD]2-14[/TD] [TD]e-STUDIO506 has been added. "Bluetooth module GN-2020" has been deleted from the system list.[/TD] [/TR] [TR] [TD]2-16[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-3[/TD] [TD]In A16, "Inverter board" has been changed to "Inverter board / LED board".[/TD] [/TR] [TR] [TD]3-4[/TD] [TD]In Fig. 3-3, "INV" has been changed to "INV / LEDB".[/TD] [/TR] [TR] [TD]3-8[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-10[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-13[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-14[/TD] [TD]e-STUDIO506 has been added. "Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD]3-15[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-16[/TD] [TD]e-STUDIO506 has been added. The description of the function of the EXP has been changed.[/TD] [/TR] [TR] [TD]3-17[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-18[/TD] [TD]The description of the function of the INV has been changed. In "3.3.9 Others", the item for LEDB has been added.[/TD] [/TR] [TR] [TD]3-19[/TD] [TD]In Fig. 3-12, "Xenon lamp" has been changed to "Xenon lamp / LED".[/TD] [/TR] [TR] [TD]3-20[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-21[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-26[/TD] [TD]"Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD]3-29[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-33[/TD] [TD]In "3.8.1 General Description", the contents have been changed.[/TD] [/TR] [TR] [TD] 3-34[/TD] [TD]"Xenon lamp (17W)" has been changed to "Xenon lamp / LED". "Lamp inverter board (INV)" has been changed to "Lamp inverter board (INV) / LED board (LEDB)". In "3.8.2 Construction", the table for "CCD sensor and exposure lamp combinations" has been added.[/TD] [/TR] [TR] [TD]3-35[/TD] [TD]The description of the exposure lamp (EXP) and reflector have been changed.[/TD] [/TR] [TR] [TD]3-37[/TD] [TD]"8. Lamp inverter board (INV)" has been changed to "8. Lamp inverter board (INV) / LED board (LEDB)".[/TD] [/TR] [TR] [TD]3-38[/TD] [TD]The description of the scanning speed has been added.[/TD] [/TR] [TR] [TD]3-56[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-57[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-58[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-61[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-63[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-64[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-65[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-67[/TD] [TD]"Main switch" has been changed to "Main power switch". e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-68[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-69[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]Ver. 02 <2012.04.20>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]3-70[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-71[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-72[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-74[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]3-76[/TD] [TD]"Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD]3-77[/TD] [TD]"Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD]3-78[/TD] [TD]"Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD] 3-81[/TD] [TD]"Main switch" has been changed to "Main power switch". The description of the parts for the SLG has been changed. e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-6[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-16[/TD] [TD]"[A] Xenon lamp" has been added.[/TD] [/TR] [TR] [TD]4-18[/TD] [TD]"[B] LED" and the disassembly and replacement procedures have been added.[/B][/TD][B] [/b][/TR][B] [TR] [TD]4-19[/TD] [TD]"[A] 4-line CCD" has been added.[/TD] [/TR] [TR] [TD]4-21[/TD] [TD]The contents of Note 2 have been changed.[/TD] [/TR] [TR] [TD]4-22[/TD] [TD]"[B] 3-line CCD" and the disassembly and replacement procedures have been added.[/TD] [/TR] [TR] [TD]4-26[/TD] [TD]The contents of step (7) in the disassembly and replacement procedures for the carriage-1 have been changed.[/TD] [/TR] [TR] [TD]4-31[/TD] [TD]The disassembly and replacement procedures in "4.3.10 LED driving PC board (LEDB)" have been added.[/TD] [/TR] [TR] [TD]4-39[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-50[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-58[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-62[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-64[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-76[/TD] [TD]"(Refer to Service Handbook Chap. 3)" has been deleted from the Notes. e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-87[/TD] [TD]The contents of Note 2 have been changed.[/TD] [/TR] [TR] [TD]4-90[/TD] [TD]The note has been added. The Fig.4-256 have been changed.[/TD] [/TR] [TR] [TD]4-95[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-99[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-100[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-101[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-102[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-103[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]4-134[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]5-1[/TD] [TD]In [A], "Refer to "Appendix" for the codes in Test mode (03), Test print mode (04), Adjustment mode (05), and Setting mode (08)." has been added.[/TD] [/TR] [TR] [TD]5-40[/TD] [TD]"Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD]5-53[/TD] [TD]In the Remarks, the default values for the e-STUDIO506 have been added.[/TD] [/TR] [TR] [TD]5-54[/TD] [TD]In the Remarks, the default values for the e-STUDIO506 have been added.[/TD] [/TR] [TR] [TD]5-55[/TD] [TD]In the Remarks, the default values for the e-STUDIO506 have been added.[/TD] [/TR] [TR] [TD]5-56[/TD] [TD]In the Remarks, the default values for the e-STUDIO506 have been added.[/TD] [/TR] [TR] [TD]6-48[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]6-55[/TD] [TD]The contents of "[A] Replacing the lens unit" have been changed.[/TD] [/TR] [TR] [TD]7-5[/TD] [TD]The preventive maintenance timing for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD] 7-6[/TD] [TD]In Fig. 7-2, the operational flow has been changed. "* When the authentication screen appears, press [OK]. (Enter the password, if one has been set.)" has been added.[/TD] [/TR] [TR] [TD]7-17[/TD] [TD]The cleaning and lubricating timing for the e-STUDIO506 has been added to the Notes. e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]7-20[/TD] [TD]The replacement cycle for the e-STUDIO506 has been added.[/TD] [/TR] [/B][/b][/TABLE][B][B] e-STUDIO206L/256/306/356/456/506 © 2011 - 2014 TOSHIBA TEC CORPORATION All rights reserved REVISION RECORD [TABLE] [TR] [TD]Ver. 02 <2012.04.20>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]7-23[/TD] [TD]The replacement cycle for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]7-25[/TD] [TD]The replacement cycle for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]7-27[/TD] [TD]The replacement cycle for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]7-29[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]7-31[/TD] [TD]The replacement cycle for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]7-32[/TD] [TD]The replacement cycle for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD] 7-51[/TD] [TD]e-STUDIO506 has been added. "FR-KIT-4530" has been changed to "FR-KIT-4590". "SCRAPER-470" has been changed to "SCRAPER-16X". "FR-KIT-3000" has been changed to "FR-KIT-3020".[/TD] [/TR] [TR] [TD]7-52[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]7-54[/TD] [TD]The overhaul timing for the e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]8-19[/TD] [TD]The error code F140 has been added.[/TD] [/TR] [TR] [TD]8-47[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]8-54[/TD] [TD]"CN305" has been changed to "CN316".[/TD] [/TR] [TR] [TD]8-69[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]8-125[/TD] [TD]"Inverter" has been changed to "Inverter / LED board".[/TD] [/TR] [TR] [TD]8-177[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]8-183[/TD] [TD]The contents of the troubleshooting for [F109_0] have been changed.[/TD] [/TR] [TR] [TD]8-188[/TD] [TD]The troubleshooting for [F140] has been added.[/TD] [/TR] [TR] [TD]8-265[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]8-267[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]8-269[/TD] [TD]"inverter" has been changed to "inverter / LED board".[/TD] [/TR] [TR] [TD]8-282[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]9-3[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]9-4[/TD] [TD]"Main switch" has been changed to "Main power switch". e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]9-5[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]9-25[/TD] [TD]In "[L] Enable HDD encryption", the contents of step (3) have been changed.[/TD] [/TR] [TR] [TD]11-1[/TD] [TD]“Engine ROM” has been added.[/TD] [/TR] [TR] [TD]11-2[/TD] [TD]“Engine ROM” has been added.[/TD] [/TR] [TR] [TD]11-7[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]11-11[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD]11-15[/TD] [TD]"Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD]11-30[/TD] [TD]“Engine ROM” has been added.[/TD] [/TR] [TR] [TD]11-33[/TD] [TD]“Engine ROM” has been added.[/TD] [/TR] [TR] [TD]11-35[/TD] [TD]"Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD]11-36[/TD] [TD]“Engine ROM” has been added.[/TD] [/TR] [TR] [TD] 11-39[/TD] [TD]The Notes text has been deleted. "* When the authentication screen appears, press [OK]. (Enter the password, if one has been set.)" has been added.[/TD] [/TR] [TR] [TD]11-41[/TD] [TD]"Since the update data for the MR-3021 and the MR-3022 differ, be sure to install the correct." has been added.[/TD] [/TR] [TR] [TD]11-43[/TD] [TD]The illustration for step (1) has been deleted.[/TD] [/TR] [TR] [TD]11-45[/TD] [TD]The illustration for step (1) has been deleted.[/TD] [/TR] [TR] [TD]11-49[/TD] [TD]In "[A] Update Procedure", the illustration for step (1) has been deleted.[/TD] [/TR] [TR] [TD]11-51[/TD] [TD]In "[A] Checking the hole punch position", the illustrations for step (2) have been changed.[/TD] [/TR] [TR] [TD]11-52[/TD] [TD]In "[B] Update Procedure", the contents and the illustrations for step (3) have been changed.[/B][/TD][B] [/b][/TR][B] [TR] [TD]11-57[/TD] [TD]The illustration for step (1) has been deleted.[/TD] [/TR] [TR] [TD]11-62[/TD] [TD]In "[A] Update Procedure", the contents of step (16) have been changed.[/TD] [/TR] [/b][/TABLE][B] [TABLE] [TR] [TD]Ver. 02 <2012.04.20>[/TD] [TD][/TD] [/TR] [TR] [TD]Page[/TD] [TD]Contents[/TD] [/TR] [TR] [TD]11-63[/TD] [TD]In "[A] Update Procedure", the illustration for step (1) has been deleted. In "[A] Update Procedure", the contents of step (2) have been changed.[/TD] [/TR] [TR] [TD]11-64[/TD] [TD]In "[A] Update Procedure", the illustration for step (5) has been changed.[/TD] [/TR] [TR] [TD]11-65[/TD] [TD]In "[A] Update Procedure", the contents and the illustration for step (6) have been changed.[/TD] [/TR] [TR] [TD]11-66[/TD] [TD]In "[A] Update Procedure", the contents of step (11) have been changed. In "[A] Update Procedure", the contents of step (16) have been changed.[/TD] [/TR] [TR] [TD]11-67[/TD] [TD]In "[A] Update Procedure", the illustration for step (1) has been deleted.[/TD] [/TR] [TR] [TD]11-72[/TD] [TD]"Main switch" has been changed to "Main power switch".[/TD] [/TR] [TR] [TD]14-1[/TD] [TD]"Main switch" has been changed to "Main power switch". e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD] 14-4[/TD] [TD]In "[A] Scanner unit, control panel", the illustration has been changed. "Main switch" has been changed to "Main power switch". In "Others", the item for LEDB has been added.[/TD] [/TR] [TR] [TD]14-5[/TD] [TD]e-STUDIO506 has been added.[/TD] [/TR] [TR] [TD] 14-6[/TD] [TD]e-STUDIO506 has been added. In "[A] Scanner unit, control panel", the illustration has been changed. "Main switch" has been changed to "Main power switch". In "Others", the item for LEDB has been added.[/TD] [/TR] [TR] [TD]Appendix[/TD] [TD]e-STUDIO506 has been added. The default values of 05-4100-0 to 2, 4101-0 to 2, 4108-0 to 2, 4109-0 to 2, 4111, 4115-0 to 5, 4116-0 to 2, 4117-0 to 2, 4118-0 to 2, and 4119 have been changed. 08-8900-0 to 3 have been added.[/TD] [/TR] [/TABLE][/b][/b][/b][/i] [/QUOTE]
Photocopier and Printer
Toshiba
Toshiba e-STUDIO 307/357/457/507 Service Manual Part 15
