Toshiba e-STUDIO 307/357/457/507 Service Manual Part 14
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeImage Processin gImageSCN8300ADF scan noise reduction30-3SYSSets the adjustment level for reducing color streaks when the RADF is used.
3: Disabled (default)
2: Noise reduction level - Low
1: Noise reduction level - Middle (recommended) 0: Noise reduction level - High
08Setting modeImage Processin gUser interfaceUser mode settingSCN8303Color00~4SYS0: Unused 1: Text/Photo base 2: Text base 3: Photo base 4: e-document base
* e-document: This is the mode that corresponds to the law in Japan. This mode is used to clarify area where changes were made with such as a correction fluid.
1Yes
08Setting modeSystemGeneral8504Feeding method of odd page number in duplex printing(Raw print)00~1SYS0: One side 1: Both sides1
08Setting modeSystemGeneral8506Forcible mode
change in cartridge empty status
10~2SYS0: SLEEP MODE 1: AUTO POWER SAVE 2: READY1
08Setting modeSystemGeneralWide A4 Mode (for PCL)8511PRT00~1SYS0: Disable 1: Enable1
08Setting modeSystemGeneral8512Number of jobs in batch processing102~10SYS2-10: From 2 to jobs can be specified1
08Setting modeSystemGeneral8514Threshold value setting for RIP standard paper judgment205~30SYSThis code is used for changing the range in which the non-standard paper size is judged as standard paper size. If the page size information is within standard paper size ± setting value, the page size is judged as standard paper size when PS/PDF printing. If the page size information is out of the range, the page size is judged as non-standard paper size. The unit of setting value is PS point. 1 PS point is approx. 0.35 mm.1Yes
08Setting modeSystemGeneralOutside erase
judgment threshold (Default)
PPC8515PPC0-3~3SYSThe larger the value is, area to be erased increases. The smaller the value is, area to be erased decreases.1
SCN8516SCN0-3~3SYSThe larger the value is, area to be erased increases. The smaller the value is, area to be erased decreases.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral8517Remote Scan User authentication automatic login10~1SYS0: OFF (A user always enters manually (current method))
1: ON (Previous authentication information will be used)
08Setting modeSystemGeneral8518Overwriting mode for scanned files00~3SYS0: Always OFF
1: Meta Scan function ON / Normal scan function OFF 2: Meta Scan function OFF / Normal scan function ON 3: Always ON
08Setting modeSystemGeneral8519Scan PDF file Paper size10~1SYS0: Equivalent to scan image size 1: Fitted into any standard size1
08Setting modeSystemGeneral8520Underscore conversion of prohibited character in filename10-1SYSSets the prohibited characters in filename to covert to underscore.
0: \ / > < , " | ? * : ; = [ ] +
1: \ / > < " | ? * :
* 0: Existing model standard 1: Windows standard Since setting the value to "1" allows some prohibited characters, filename might not be processed in external application or server.
08Setting modeSystemGeneral8521Switchover of output format of Service Notification attachmentRefer to contents0-1SYSSwitches the output format of date in attachment of Service Notification.
0: YYYY.MM.DD
1: YYYY-MM-DDTHH:MM:SS
<Default value> NAD: 1
Others: 0
08Setting modeSystemUser interfaceScreen setting8523Toner near-empty status MessageRefer to contents0~1SYS0: ON 1: OFF
<Default value> JPD/NAD/MJD/AUD/ARD: 1
Others: 0
1Yes
08Setting modeSystemGeneral8524No paper Message display00~1SYS0: ON 1: OFF1
08Setting modeSystemGeneral8525No paper in the left
tray of tandem LCF message
08Setting modeSystemScanningScanning preview8526Default setting00-1SYS0: Disabled 1: Enabled1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemScanningScanning preview8527Default display type00-1SYS0: Fit page
1: Fit width
08Setting modeSystemGeneral8532Control panel
Brightness level adjustment
41~7SYS1-7: Brightness level1
08Setting modeSystemGeneralSorting method for displaying private print jobs8537PRT00~1SYSChanges the sorting order for print jobs on the private print list.
0: Descending order 1: Ascending order
08Setting modeSystemMaintenan
ce (Remote)
8538Notification setting for toner nearly empty00~1SYS0: Disabled 1: Enabled1
08Setting modeSystemScannerDate/time format in
the Meta Scan XML file
8540SCN10~1SYS0: YYYY/MM/DDhh:mm:ss.mmm
1: YYYY-MM-DDThh:mm:ss.mmmTZD
08Setting modeSystemUser interface8543Transition to the energy saving mode when in the Sleep mode10~1SYS0: Disabled 1: Enabled (depending on conditions)1Yes
08Setting modeSystemUser interface8544Tolerance for switching to Super Sleep mode55~600SYSThe interval between recovering from the Super Sleep mode and making the transition to the Super Sleep mode again. Unit: seconds.1Yes
08Setting modeSystemUser interface8546Input setting of minus value for image shift when copying00~1SYS0: Inputting minus value is disabled. 1: Inputting minus value is enabled.1Yes
08Setting modeSystemPaper feedingChange of the paper size setting on the touch panel when printing is interrupted by size mismatch8548PRT00~1SYS0: Change of the paper size setting on the touch panel is disabled.
1: Change of the paper size setting on the touch panel is enabled.
08Setting modeSystemCounter8549Hardware key control when external counter is installed00~1SYS0: No control 1: Mode switch key is disabled.1
08Setting modeSystemMaintenan ce8584Selects whether or
not to transmit the Subject.
10~1SYS0: Disabled 1: Enabled1
08Setting modeSystemMaintenan ce8585Selects the edit setting of the Subject.10~1SYS0: Disabled 1: Enabled1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemMaintenan ce8586Selects whether or not to add the date and time to the Subject.10~1SYS0: Not added 1: Added1
08Setting modeSystemMaintenan ce8587Selects the setting of the Subject, by using the fixed string or inputting the specified one.00~1SYS0: Fixed string (Default) 1: Specified string1
08Setting modeSystemLDAP user authenticat ionAttribute value setting8592Sender addressmail-SYSSets the default attribute value of sender address. Maximum 32 characters (ASCII).11
08Setting modeSystemLDAP user authenticat ionAttribute value setting8593Sender nameuid-SYSSets the default attribute value of sender name. Maximum 32 characters (ASCII).11
08Setting modeSystemMaintenan ce8597Updates the Private/Hold Print job list automatically00~1SYS0: Disabled 1: Enabled1
08Setting modeSystemMaintenan ce8598Selects the template icon layout on the touch panel00~1SYS0: Pattern 1
(1) (2) (3) (4)
(5) (6) (7) (8)
(9) (10) (11) (12)
(13) (14) (15) (16)
1: Pattern 2
(1) (2) (9) (10)
(3) (4) (11) (12)
(5) (6) (13) (14)
(7) (8) (15) (16)
08Setting modeSystemGeneralOutside erase8600Change of default value00~1SYS0: Disabled
1Yes
08Setting modeSystemMaintenan ce8603Special usage of external options I/F00~2SYS0: None (Default) 1: Usage 1 2: Usage 21
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetworkPrioritized authentication server8608Windows00-100SYSSets the prioritized authentication server to be searched (0 to 100). The servers displayed on the screen accessed by TopAccess -> Administration -> Maintenance -> Directory Service are numbered beginning at the top (0 to 100).1
08Setting modeSystemNetworkPrioritized authentication server8609LDAP00-100SYSSets the prioritized authentication server to be searched (0 to 100). The servers displayed on the screen accessed by TopAccess -> Administration -> Maintenance -> Directory Service are numbered beginning at the top (0 to 100).1
08Setting modeSystemNetworkPrioritized authentication server8610Card00-100SYSSets the prioritized authentication server to be searched (0 to 100). The servers displayed on the screen accessed by TopAccess -> Administration -> Maintenance -> Directory Service are numbered beginning at the top (0 to 100).1
08Setting modeSystemUser interface8622Date and time addition setting to file name of scan to file/e- mail10-1SYS0: Not added
1: Added
08Setting ModeSystemGeneral86230RIP function setting10-1SYSEnables/Disables the function related to Excel boarder rendering of PCL6. The function is to prevent missing lines when scaling down and inconsistent line width when scaling up.
0: Disabled (No correction. Compliant with PCL6 language)
08Setting modeSystemUser interface8624Switchover of display method of filename30-3SYSSwitches the display method of filename. 0: Displays the filename from the beginning 1: Displays the trailing characters
2: Displays the beginning and trailing characters 3: Displays the filename without abbreviation
1Yes
08Setting modeSystemUser interface8628Job operation on the COPY screen when the coin controller is connected00-1SYSThis setting enables user to move from the COPY screen to JOB STATUS screen, and then operate jobs during printing when the coin controller is connected. This code is valid when the value of 08-9016 is "1".
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemFAX8631Filename creation at fax reception and forwarding00-1SYS0: Use address name (family-name/first-name) as filename if multiple names are found by address book search of TSI (sender information).
1: Use address name (family-name/first-name) as filename only when single name is found by address book search of TSI (sender information).
08Setting modeSystemUser interface8640Job build operation when the coin controller is connected00-1SYSThis setting enables user to use the job build function when the coin controller is connected. This code is valid when the value of 08-9016 is "1".
08Setting ModeSystemGeneral8641Notification setting for job cancel10-1SYSSets the notification setting for job cancel. This setting is effective for the following error codes:
1CC0, 2BB0, 2CC0, 2DC0, 2EC0
0: Disabled (Not notified) 1: Enabled (Notified)
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8642LDAP attribute name settings 2eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8643LDAP attribute name settings 3eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8644LDAP attribute name settings 4eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8645LDAP attribute name settings 5eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8646LDAP attribute name settings 6eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8647LDAP attribute name settings 7eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8648LDAP attribute name settings 8eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8649LDAP attribute name settings 9eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8650LDAP attribute name settings 10eBMUse rCard-SYSMaximum 32 characters (ASCII).11
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8651LDAP attribute name settings 11eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8652LDAP attribute name settings 12eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8653LDAP attribute name settings 13eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8654LDAP attribute name settings 14eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8655LDAP attribute name settings 15eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceCard reading deviceLDAP authentication8656LDAP attribute name settings 16eBMUse rCard-SYSMaximum 32 characters (ASCII).11
08Setting ModeSystemUser interfaceSound8657Placing original00-1SYS0: OFF 1: ON1Yes
08Setting ModeSystemUser interfaceSound8658Pressing [INTERRUPT] button00-1SYS0: OFF 1: ON1Yes
08Setting ModeSystemUser interfaceSound8659Switchover of function00-1SYS0: OFF 1: ON1Yes
08Setting ModeSystemUser interfaceSound8660Completion of job (except for FAX)00-1SYS0: OFF 1: ON1Yes
08Setting ModeSystemUser interfaceSound8661End of warming- up/prewarming/sleep00-1SYS0: OFF 1: ON1Yes
08Setting ModeSystemUser interfaceSound8662Job interrupt (out of paper)00-1SYS0: OFF 1: ON1Yes
08Setting ModeSystemUser interfaceSound8663Fax transmission error00-1SYS0: OFF 1: ON1Yes
08Setting ModeSystemUser interfaceSoundHours for mute86640Enable/Disable setting of mute00-1SYS0: Mute is disabled 1: Mute is enabled4Yes
08Setting ModeSystemUser interfaceSoundHours for mute86641Starting time00-2359SYS(Hour/Hour/Minute/Minute)4Yes
08Setting ModeSystemUser interfaceSoundHours for mute86642Ending time00-2359SYS(Hour/Hour/Minute/Minute)4Yes
08Setting ModeSystemGeneral8667Saving image log00-1SSDK0: Disabled 1: Enabled1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemGeneral8668Number of pages saved as image log10-1SSDK0: First page
1: All pages
08Setting ModeSystemGeneral8670e-Filing print setting when key counter/totalizer is installed00-1SYS0: Not allowed
1: Allowed
08Setting ModeSystemNetworkNumber of retry for file transfer86710FTP30-10SYSThe transmission may succeed when the number of
retry increases. However, it takes longer time to complete the job.
08Setting ModeSystemNetworkNumber of retry for file transfer86711SMB30-10SYSThe transmission may succeed when the number of
08Setting ModeSystemNetworkNumber of retry for file transfer86712NetWare30-10SYSThe transmission may succeed when the number of
08Setting ModeSystemNetworkRetry interval for file transfer86720FTP1800-999SYSThe transmission may succeed when the retry interval becomes longer. However, it takes longer time to complete the job. (Unit: sec.)4
08Setting ModeSystemNetworkRetry interval for file transfer86721SMB1800-999SYSThe transmission may succeed when the retry interval becomes longer. However, it takes longer time to complete the job. (Unit: sec.)4
08Setting ModeSystemNetworkRetry interval for file transfer86722NetWare1800-999SYSThe transmission may succeed when the retry interval becomes longer. However, it takes longer time to complete the job. (Unit: sec.)4
08Setting ModeSystemGeneral8673Disclosure of image log function00-1SSDK0: Not opened to public 1: Opened to public1
08Setting ModeSystemGeneral8674Prohibition of transition to sleep mode during network initialization00-1SYS0: Allowed
1: Prohibited
08Setting modeSystemFAX8700Secret reception setting00-2SYSWhen the value of 08-8924 is "0", the value of this code can be set to "1" or "2".
0: Always Off
1: Always On
2. Scheduled reception
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface8704Restriction of Email/FAX address00~1SYSThis code is used to restrict Email/FAX Address to LDAP server specified via TopAccess. When the value of this code is set to "1", the address cannot be input directly and registered from the local address book.
0: No restriction
1: Looking up in external LDAP only
08Setting modeSystemUser interface8709Service notification (equipment information)Refer to contents0-1SYSSets whether the [SERVICE NOTIFICATION] (Equipment Information) button accessed by [USER FUNCTIONS] -> [ADMIN] -> [SERVICE] is displayed or not.
<Default value> JPC/NAD/MJD: 1
Others: 0
1Yes
08Setting modeSystemScanning8710Setting of character code for Scan to FTP00-2SYS0: Automatic selection
1: UTF8
2: Shift-JIS
08Setting modeSystemUser interface8712Display setting of the drawer setting button10-1SYSSets whether the drawer button in USER FUNCTIONS is displayed or not.
0: Not displayed
1: Displayed
08Setting modeSystemUser interface8713Setting of web upload/web printing00-1SYSSets whether the web upload and web printing function is enabled or disabled.
  • Web upload is a function which uploads the image data created on the equipment to the web page displayed on EWB.
  • Web printing is a function which prints the web page displayed on EWB or the PDF file included in the web page displayed on EWB.
08Setting modeSystemUser interfaceService notification information8715Password for zip file with password#104810
-SYSPassword for zip file with password of service notification information.
Minimum number of digits: 0, maximum number of digits: 20
Available character: alphanumeric characters and symbols
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface8717Shutdown operation when Super Sleep is enabled00-1SYSSets the operation when the power button on the control panel is press for a few seconds if Super Sleep is enabled.
0: Hibernation
1: Super Sleep
1Yes
08Setting modeSystemUser interface8718Selection for caching the screen of control panel at start-up00-17SYSUse this code to shorten the time to switch the function on the control panel for the first time immediately after start-up. However, the start-up time becomes longer (about 1 to 3 seconds per screen). When selecting multiple screens, enter the total value.
1: Copy
16: Fax
08Setting modeSystemNetwork8719MTU setting of network communication1500576-1500NICNormally there's no need to change the MTU value. Set the proper MTU value when MFP is connected to the Internet using broadband router and so on.12
08Setting modeSystemUser interface8720Department code display with asterisk00-1SYS0: Displays department code with asterisk when inputting it.
1: Displays department code as it is when inputting it.
1Yes
08Setting modeSystemFAX8721Automatic FAX sending at AutoClear when scanning original put on the glass00-1SYSSets whether the job is sent or canceled when AutoClear is executed on the interruption screen to confirm the next original displayed after scanning the original put on the glass. Use this code to cancel job when the equipment is left unattended while the interruption screen is displayed.
0: Sends job
1: Cancels job
1Yes
08Setting modeSystemUser interface8722Display method of "Cannot find the Home Directory" on the control panel00-1SYSSets the display method of error if the Home Directory for user cannot be obtained from the server when setting the Home Directory for scanning. Use this code to disable the pop-up display when the Home Directory cannot be obtained depending on the user.
0: Displays the pop-up dialogue when user logs in
1: Displays the message in the guidance area when the Scan to File screen is displayed
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface8723Pop-up display of logging out of user authentication and department management on the control panel10-1SYSSets whether the pop-up dialog of confirmation for logging out is displayed when user or department logs out by pressing [FUNCTION CLEAR] button twice or pressing [ACCESS] button.
0: Logs out without displaying pop-up dialog 1: Displays pop-up dialog when logging out
1Yes
08Setting modeSystemUser interface8724Display setting of Edit From Address button for Scan to email10-1SYS0: Not displayed (From Address cannot be edited) 1: Displayed (From Address can be edited)1Yes
08Setting modeSystemUser interface8725Display setting of [USER FUNCTIONS]-
> CHANGE
LANGUAGE button
10-1SYSSets whether the [CHANGE LANGUAGE] button accessed from [USER FUNCTIONS] button is displayed or not. Use this code to prohibit users from changing the language displayed on the control panel. Administrators can change the language.
0: Not displayed
1: Displayed
1Yes
08Setting modeSystemGeneral8726Job deletion on the Job Status screen00-1SYSUse this code to enable the job deletion on the [Job Status] screen. When "3: High level" is set for code 08- 8911, be sure to disable this setting.
1Yes
08Setting ModeSystemUser interfaceCard reading device8727Display of dedicated screen for card authentication00-1SYSSwitches whether the message to hold a card over the card reader is displayed on the login screen when the card authentication is enabled.
08Setting ModeSystemForced printing of user name87280Display/Non-display setting in TopAccess00-1SYS0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87281Enable/Disable setting of forced printing00-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87282Prioritizing printer driver setting10-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemForced printing of user name87283Application to network fax job00-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87284Enable/Disable setting of prefix/suffix00-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87286White background setting10-1SYSNormally this setting is made in TopAccess. 0: Disabled 1: Enabled4
08Setting ModeSystemForced printing of user name87287Print position00-3SYSNormally this setting is made in TopAccess.
0: Bottom left 1: Top left 2: Bottom right 3: Top right
08Setting ModeSystemForced printing of user name87288Fine adjustment of print position (X)30-100SYSAdjusts the print position in X direction. The print position shifts toward inside of original when the value increases. Unit: pt. 1pt = 0.35mm.4
08Setting ModeSystemForced printing of user name87289Fine adjustment of print position (Y)30-100SYSAdjusts the print position in Y direction. The print position shifts toward inside of original when the value increases. Unit: pt. 1pt = 0.35mm.4
08Setting ModeSystemForced printing of user name872810Font setting00-9SYSNormally this setting is made in TopAccess.
0: Helvetica 1: AlbertusMT 2: Chicago 3: Eurostile 4:
Geneva 5: GillSans 6: LetterGothic 7: Monaco 8:
Taffy 9: TimesNewRomanPSMT
08Setting ModeSystemForced printing of user name872811Font size setting86-16SYSNormally this setting is made in TopAccess. 6-16pt.4
08Setting ModeSystemForced printing of user name872812Font color setting00-1SYSNormally this setting is made in TopAccess. 0: Black 1: Gray4
08Setting ModeSystemForced printing of user name872813Density setting of light font color4010-90SYSSets the density when the font color is set to gray.4
08Setting ModeSystemForced printing of user name8729Prefix settingPrinted by-SYSNormally this setting is made in TopAccess. Maximum 64 characters.11
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemForced printing of user name8730Suffix setting--SYSNormally this setting is made in TopAccess. Maximum 64 characters.11
08Setting modeSystemUser interface8732Default Menu Screen Setting00-1SYSSwitches the default screen of MENU 0: User
1: Public
08Setting ModeSystemScanning8735Sending setting of ScanToURL00-1SYS0: Disabled 1: Enabled1
08Setting ModeSystemScanning8736Maximum size for ScanToURL attachment50-100SYSSets the maximum size of attachment that can be sent with ScanToURL.
0: Always sends URL
1-100: Maximum size (MB)
08Setting ModeSystemUser interfaceScreen setting8738E-mail address direct input button10-1SYSSwitches the display setting of the [INPUT @] button. 0: Not displayed
1: Displayed
1Yes
08Setting modeSystemUser interfaceScreen setting8744Switchover of pop-up display during scanning10-1SYSSwitches the pop-up display during scanning 0: Not displayed
1: Displayed
08Setting modeSystemUser interface8745Enable/Disable setting of EWB history00-1SYSSets whether part of the cookie, password, and form data of user who logs in to EWB is saved or not.
08Setting modeSystemUser interface8746Port number setting of destination 10 for sending trap1621-65535NICSets the port number of destination 10 for sending SNMP trap. If the port is used when using the real time log notification function, change the port number.12
08Setting ModeSystemUser interface8748Input of department code at user
authentication
00-1SYS0: Not required
1: Required
08Setting ModeSystemNetwork8749User authentication by logon information to domain (external authentication)00-1SYS0: Disabled
08Setting ModeSystemUser interface8754Error sheet output at reception of non- supported PDL10-1SYS0: Error sheet is not output 1: Error sheet is output1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemMaintenan ceNotification of
remaining amount of toner
8755Enable/Disable setting00-1SYS0: Disabled
1Yes
87560Remaining amount at first notification250-100SYS0 to 100%4Yes
87561Notification interval101-25SYS1 to 25%4Yes
08Setting ModeSystemUser interfaceCard reading device8758Overwriting of login at authentication00-1SYSSwitches the enable/disable setting for the function to overwrite the login information at the card authentication.
08Setting ModeSystemGeneral8761Retention of print (spooling) data00-1SYSUse this code to retain and obtain the print data (spooling data) if problem occurs. After obtaining the data, be sure to disable the setting.
0: Disabled (print data is deleted) 1: Enabled (print data is retained)
1Yes
08Setting ModeSystemMaintenan ceDisplay of remaining amount of toner (for RDMS/MMDT)87620K00-100SYS0 to 100%14
08Setting modeSystemNetwork8771Account setting for access to Home Directory00-1SYS0: Setting of Remote1 is used
1: Setting of Remote1 and Remote2 is used
08Setting modeSystemNetwork8774Password authentication for print job00-1SYSSets whether the user authentication for network printing/FAX/InternetFAX using the user information and password input on the printer driver is enabled or disabled. When this setting is enabled, the setting of 08-8749 is automatically disabled.
08Setting modeSystemNetworkPIN code8775PIN code authentication setting at user authentication00-2SYS0: Disabled
1: PIN code
2: Card+PIN code
08Setting modeSystemNetworkPIN code8776Logging setting of PIN code00-1SYS0: Disabled
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetworkPIN code8777Attribute value setting of LDAP PIN
authentication server 1
eBMUse rPIN-SYSAttribute name of PIN code11
08Setting modeSystemNetworkPIN code8778Attribute value setting of LDAP PIN
authentication server 2
08Setting modeSystemNetworkPIN code8779Attribute value setting of LDAP PIN
authentication server 3
08Setting modeSystemNetworkPIN code8780Prioritized authentication server11-3SYSSets the prioritized authentication server to be searched.1
08Setting modeSystemUser interfaceDisplay setting8781Default setting of print screen when USB is inserted00-1SYS0: Disabled (The setting of 08-9236 is used) 1: USB print screen1
08Setting modeSystemGeneralInterval settingTransition to Super Sleep8782For fax1515-600SYSSets the interval to shift to Super Sleep again after recovery from Super Sleep. (Unit: seconds)1Yes
08Setting modeSystemGeneral8783Switchover of document sorting order of e-Filing Box10-1SYS0: Sorted by saved date
1: Sorted by document name
08Setting modeSystemUser interface8785Display/Non-display of pop-up for card authenticationRefer to contents0-1SYSSets whether the pop-up is displayed or not after the success of card authentication. This code is effective when the value of 08-8727 is "1" (Enabled).
0: Does not display pop-up 1: Displays pop-up
<Default value> JPD: 0
Others: 1
08Setting modeSystemUser interfaceDefault keyboard setting87860Japanese30-4SYSSets the default keyboard for inputting user name. 0: Romaji 1: Hiragana 2: Katakana (one-byte) 3:
Alphabetical character (one-byte) 4: Symbol (one-byte)
4Yes
08Setting modeSystemUser interfaceDefault keyboard setting87861Chinese00-2SYSSets the default keyboard for inputting user name. 0: Alphabetical character (one-byte) 1: Pinyin 2: Symbol (one-byte)4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemNetwork8788Detection interval when authentication server is down601-1440SSDKSets the interval to access the authentication server again after the detection of server down.
1-1440 (min.)
08Setting modeSystemUser interface8789Display/Non-display of pop-up for automatic output of jobs00-1SYSSets whether the pop-up is displayed or not when jobs are automatically released after user authentication. This code is effective when the value of 08-8915 is "1" (Enabled).
0: Pop-up is not displayed 1: Pop-up is displayed
08Setting ModeSystemNetwork8790Switchover of server when authentication server is down00-1SSDKEnables/disables the function that switches the access to another authentication server when it is detected that the authentication server is down.
08Setting ModeSystemNetwork8791Transition to sleep mode after printing10-1SYSThis code sets whether the equipment shifts to the sleep mode again immediately after completion of printing when the equipment recovers from the super- sleep mode for network printing.
1Yes
08Setting ModeSystemNetwork8792Format of host name used for Scan To URL00-2SYS0: IP address
1: Host name (FQDN) 2: NetBIOS name
08Setting ModeSystemUser interface8795Default setting of duplex mode for printer driverRefer to contents0-1SYS0: Single-sided 1: Duplex
Others: 1
08Setting modeSystemMaintenan ceGeneral8796Method of scheduled automatic reboot00-1SYS0:Normal reboot 1:Silent reboot1
08Setting modeSystemMaintenan ceGeneral8797Reboot setting for resource check00-1SYS0: OFF 1: ON
* This code is valid only when the value of 08-8796 is "1".
08Setting modeSystemNetwork8800Enabling / Disabling of 802.1X21~2NIC1: Enabled 2: Disabled12
08Setting modeSystemNetwork8802Enabling / Disabling of IPsec21~2NIC1: Enabled2: Disabled12
08Setting modeSystemNetwork8803Enabling / Disabling of SNMPv321~2NIC1: Enabled2: Disabled12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork8804Enabling / Disabling of IP filtering21~2SYS1: Enabled2: Disabled1
08Setting modeSystemNetwork8805Enabling / Disabling
of MAC address filtering
08Setting modeSystemNetwork8820IPsec NAT-Traversal setting11~3NIC1: Default (IKEv1: Disabled, IKEv2: Enabled) 2: Enable IKEv1 & IKEv2
3: Disable IKEv1 & IKEv2
08Setting modeSystemNetwork8821IPsec CRL setting21~2NIC1: Enable CRL 2: Disable CRL12
08Setting modeSystemNetwork8824FTP client mode00-2NICSets the FTP transfer mode when FTP is selected for "FILE" to save the scanned data.
0: Automatic
1: Passive mode
2: Active mode
08Setting modeSystemNetwork8825Sending of host announcement in Super Sleep mode11-2NICSince MFP is deleted from the master browser of Windows network if MFP is in the Super Sleep mode for 36 minutes or more, enable this setting to always display MFP in the browse list.
2: Disabled
08Setting modeSystemNetworkDynamic update of DNS server8826Enable/Disable setting11-2NICSets whether the function that gets the secondary DNS server to work as the primary DNS server temporarily is enabled or not when the primary DNS server is not available.
12Yes
08Setting modeSystemNetworkDynamic update of DNS server8827Operating interval601-1440NICSets the operating interval of dynamic update. 1-1440 (min.)12Yes
08Setting modeSystemNetwork88300Beep setting to identify printer for AirPrint IPP10-1SYSSets whether the beep for identifying printer is emitted or not when IPP is used for AirPrint.
0: Emits beep
1: No beep
08Setting modeSystemNetwork88301Blinking setting to identify printer for AirPrint IPP10-1SYSSets whether the blinking for identifying printer is enabled or not when IPP is used for AirPrint.
0: Disabled (No blinking) 1: Enabled
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork88302Switchover of PDF print size with AirPrint11-2SYS1: A4/LT size
2: Original size
08Setting modeSystemNetwork8831Time-out period for
EWB network connection
601-300SYS1 to 300 (sec.)1
08Setting modeSystemNetwork8833SMB server protocol11-2NIC1: SMB1.0
2: SMB2.0
08Setting modeSystemNetwork8835Link down detection of network cable10-1NIC0: Disabled
08Setting modeSystemGeneralRegistration number for workflow89000Total20001000-2000SYSChanges the maximum number for workflow that is registrable.4
08Setting modeSystemGeneralRegistration number for workflow89001Number of interrupt copy11SYSChanges the maximum number for workflow that is registrable.4
08Setting modeSystemGeneralRegistration number for workflow89002Number of transmission and calling of Fax/InternetFax10010-100SYSChanges the maximum number for workflow that is registrable.4
08Setting modeSystemGeneralRegistration number for workflow89003Number of printing1000150-1000SYSChanges the maximum number for workflow that is registrable.4
08Setting modeSystemFax preview8901Default setting00-1SYS0: Disabled 1: Enabled1
08Setting modeSystemFax preview8902Default display type00-1SYS0: Fit page
1: Fit width
08Setting modeSystem8904Job jump instruction setting00-1SYSSets whether waiting job is executed or not if print job in process is interrupted.
08Setting modeSystem8905Forcible printing against unacceptable paper error00-1SYS0: OFF (printing not continued)
1: ON (printing continued by automatically selecting the available exit tray)
08Setting modeSystemContinuou s print setting when punching dust box is full8906Copy00-1SYS0: OFF (copying not continued)
1: ON (copying continued by canceling punching setting)
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemContinuou s print setting when punching dust box is full8907Printer/e-Filing10-1SYS0: OFF (copying not continued)
08Setting modeSystemGeneral8910Time to auto-clearing when in the self- diagnostic mode00-5SYS0: None
1: 1 min.
2: 5 min.
3: 10 min.
4: 30 min.
5: 99 min.
08Setting modeSystemGeneral8911Security mode (level) setting11-4SYSLevel setting for security function 1: Low level
2: -
3: High level
4: -
08Setting modeSystemMaintenan ceGeneral8912Serial number display of finisher---FIN S/N: XXXXXXXXX2
08Setting modeSystemMaintenan ceGeneral8913Warning display for password expiration150-30SYS0: None
1-30: Remaining days until the password expiration for warning start.
08Setting modeSystemMFP
function setting
89140Copy10-1SYSSets whether the Copier function is enabled or disabled.
function setting
89141e-Filing10-1SYSSets whether the filing function is enabled or disabled. 0: Disabled
function setting
89142Fax10-1SYSSets whether the Fax function is enabled or disabled. 0: Disabled
function setting
89143InternetFAX10-1SYSSets whether the InternetFAX function is enabled or disabled.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
function setting
89144Email10-1SYSSets whether the email function is enabled or disabled. 0: Disabled
function setting
89145Save as Local HDD10-1SYSSets whether the function that saves data to HDD in the equipment is enabled or disabled.
function setting
89146Save as Local HDD from Print10-1SYSSets whether the function that saves data to HDD in the equipment using print function is enabled or disabled. 0: Disabled
function setting
89147Save as Local HDD from Fax10-1SYSSets whether the function that saves data to HDD in the equipment using Fax function is enabled or disabled.
function setting
89148Save to USB Media10-1SYSSets whether the function that saves scanned data of originals to USB media is enabled or disabled.
function setting
89149Save as FTP10-1SYSSets whether the function that saves scanned data of originals to FTP server is enabled or disabled.
function setting
891410Save as FTPS10-1SYSSets whether the function that saves scanned data of originals to FTP server using SSL is enabled or disabled.
function setting
891411Save as SMB10-1SYSSets whether the function that saves scanned data of originals to the SMB server is enabled or disabled.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
function setting
891412Save as Netware10-1SYSSets whether the function that saves scanned data of originals to the Netware server is enabled or disabled. 0: Disabled
function setting
891413Web Service Scanning (WS Scan)10-1SYSSets whether the WS scanning function is enabled or disabled.
function setting
891414Twain Scanning (Remote Scan)10-1SYSSets whether the remote scanning function is enabled or disabled.
function setting
891415Send to External Controller10-1SYSSets whether the function that saves data to the external server is enabled or disabled.
function setting
891416Network Fax10-1SYSSets whether the Network Fax function is enabled or disabled.
function setting
891417Network InternetFAX10-1SYSSets whether the Network InternetFAX function is enabled or disabled.
08Setting modeSystemNetwork8915Automatic output of jobs at login00-1SYSSets whether jobs registered in the hold queue of user are automatically output or not when the user logs in. 0: Disabled
08Setting modeSystemGeneral8919Service password--SYSSets the password to log into the self-diagnostic mode and Service UI.11
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemOptionFAX8920Output tray for FAX/InternetFAX/e- mail printing00-2SYSSets the output tray of the equipment or options.
<When no options are installed (equipment only)> 0: Inner tray 1: Inner tray 2: Inner tray
<MJ-1032 is installed>
0: Stationary tray 1: Movable tray 2: Movable tray
<MJ-1033 is installed>
0: Inner tray 1: Movable tray 2: Movable tray
<MJ-1101 or MJ-1106 is installed>
0: Inner tray 1: Stationary tray 2: Movable tray
<When MJ-5004 or MJ-5006 is installed> 0: Upper tray 1: Lower tray 2: Upper tray
<When MJ-5005 is installed>
0: OCT tray 1: OCT tray 2: OCT tray
1Yes
08Setting modeSystemDepartme nt managem ent8921Clearing of the user/department counter10-1SYS0: Not allowed
1: Allowed
1Yes
08Setting modeSystemUser interface8922Email header print setting00-1SYSSets whether the header of an Email or an Internet Fax is printed or not as they are received.
0: Not printed
1: Printed
08Setting modeSystemUser interface8923Email body print setting10-1SYSSets whether the body of an Email or an Internet Fax is printed or not as they are received.
0: Not printed
1: Printed
08Setting modeSystemUser interface8924Registration of the received Fax / Internet Fax / Email jobs to hold queue00-1SYSRegisters the received Fax / Internet Fax / Email jobs to the hold queue instead of printing immediately. Data in the hold queue are not printed unless the user allows printing by means of the control panel.
0: Not registered (normal printing) 1: Register
08Setting modeSystemGeneral8925Data tampering checking at startup00-1SYSSets whether data tampering is checked or not at startup.
0: Not checked
1: Checked
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemDepartme nt managem ent8926Clearing of all department counters--SYSIn cases when the administrator has prohibited the clearing of department counter data using code 08- 8921, a service technician can clear the data using this code.3Yes
08Setting modeSystemDepartme nt managem ent8927Clearing of all user counter--SYSIn cases when the administrator has prohibited the clearing of user counter data using code 08-8921, a service technician can clear the data using this code.3Yes
08Setting modeSystemFinisherUpper limit number of sheets of center fold89280Plain / Recycled paper0-25-25SYS-25 to 254
08Setting modeSystemFinisherUpper limit number of sheets of center fold89281Thick paper 10-25-25SYS-25 to 254
08Setting modeSystemFinisherUpper limit number of sheets of center fold89282Thick paper 20-25-25SYS-25 to 254
08Setting modeSystemFinisherUpper limit number of sheets of center fold89283Thick paper 30-25-25SYS-25 to 254
08Setting modeSystemPassword8929Administrator password reset--SYSThe default password is set. When "3: High level" is set for code 08-8911, the default password is set as a temporary password.3Yes
08Setting modeSystemUser interfaceOff Device Customization Architecture8931Output Management Service setting10-1SYS0: Disabled
08Setting modeSystemUser interface8932Availability of Netware21-2NIC1: Enabled
2: Disabled
08Setting modeSystemUser interface8933SSL setting (SSL SMTP Client Off/on)21-3NIC1: Enabled (accepts all server certificates) 2: Disabled
3: Enabled (uses the imported CA certificate)
08Setting modeSystemUser interface8934SSL setting (SMTP Client SSL/TLS)11-2NIC1:STARTTLS
2:Over SSL
08Setting modeSystemUser interface8935Remote Scanning10-1NIC0: Disabled
08Setting modeSystemUser interface8936Remote Scanning with SSL00-1NIC0: Disabled
08Setting modeSystemUser interface8937Remote Scanning port number200800-65535NIC12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface8938Remote Scanning SSL port number204430-65535NIC12
08Setting modeSystem8942Debug level setting20, 2-Sets the output volume of debug log. When the value is set to "0", the performance may decrease.
0: Debug log level - high
2: Debug log level - normal
08Setting modeSystemMaintenan ceRemote service89460Acquisition starting time for RDMS00-
99999999
SYSMonth/day/hour/minute of starting time14
08Setting modeSystemMaintenan ceRemote service89461Acquisition ending time for RDMS00-
99999999
SYSMonth/day/hour/minute of ending time14
08Setting modeSystemUser interfaceCard reader8947Automatic user registration for card authentication00-1SSDK0: Disabled
08Setting modeSystemUser interfaceGeneral8948Language package information---Displays the information of the installed language package.2Yes
08Setting modeSystem8952External version of HDD data---External version of file system for system software.2
08Setting modePrinterFeeding system / Paper transport8967Rotation printing by guides width of bypass feed tray10-1SYSIf the printing size and the guides width of the bypass feed tray are different, it is judged that paper is set in the wrong direction. The occurrence frequency of interruption by the error of the guides width may be decreased. However, this code does not work depending on the conditions, such as when stapling is selected. Set this code when requested by user or the guides width sensor is broken. Related code: 08-4621. 0: Invalid
1: Valid
08Setting modeSystemUser interfaceGeneral8968Language package
information (Panel Help)
---Displays the language package information of the installed Panel Help.2Yes
08Setting modeSystemUser interfaceGeneral8969Language package
information (WebHelp)
---Displays the language package information of the installed WebHelp.2Yes
08Setting modeSystemUser interfaceGeneral8970Language package
information (Service UI)
---Displays the language package information of the installed Service UI.2Yes
08Setting modeSystemUser interfaceGeneral8971Installation of language package---Installs the language package.3Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneralSelf-certificate8973Length of public key10-1SYS0: 1024 bit
1: 2048 bit
08Setting modeSystemGeneralSelf-certificate8974Signature algorithm00-4SYS0: SHA1
1: SHA224
2: SHA256
3: SHA384
4: SHA512
08Setting modeSystemNetwork8975Data clearing of Point and Print--SYSPoint and Print in the equipment is deleted when this code is performed. Perform this code when a trouble occurs such as when uploading Point and Print is not possible. After performing this code, upload Point and Print from [Maintenance] menu in the [Administration] menu of TopAccess.3
08Setting ModeSystemGeneralDetection of originals prohibited from duplication89770Copy00-1SYSSets whether the originals that are prohibited from duplication are detected or not.
0: Detection disabled
1: Detection enabled
08Setting ModeSystemGeneralDetection of originals prohibited from duplication89771Scan00-1SYSSets whether the originals that are prohibited from duplication are detected or not.
08Setting ModeSystemGeneralDetection of originals prohibited from duplication89772FAX00-1SYSSets whether the originals that are prohibited from duplication are detected or not.
08Setting modeSystemScanning8980Execution of Remote Scan while control panel is operated00-1NICSets whether the remote scanning is enabled or disabled if the user is logged in using the control panel when user authentication or department management is enabled.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneralScheduled automatic reboot8981Day of the week00-255SYSSets the condition and day of the week for scheduled automatic reboot. The condition and day of the week are assigned to each bit as follows. Input the sum of each bit as setting value.
<Input value>
bit1: Monday 0: Disabled 1: Enabled
bit2: Tuesday 0: Disabled 2: Enabled
bit3: Wednesday 0: Disabled 4: Enabled
bit4: Thursday 0: Disabled 8: Enabled
bit5: Friday 0: Disabled 16: Enabled
bit6: Saturday 0: Disabled 32: Enabled
bit7: Sunday 0: Disabled 64: Enabled bit8: Set the condition of reboot
0: Reboots only when in the sleep or super sleep mode
128: Reboots regardless of the sleep mode
<Example>
  • Reboots every day regardless of the sleep mode: 255 (1+2+4+8+16+32+64+128=255)
  • Reboots on Sundays: 192 (0+0+0+0+0+0+64+128=192)
  • Reboots every day only when in the sleep or super sleep mode: 127
  • Reboots on Sundays only when in the sleep or super sleep mode: 64
(1+2+4+8+16+32+64+0=127)
(0+0+0+0+0+0+64+0=64)
08Setting modeSystemGeneralScheduled automatic reboot8982Time (Hour)00-23SYSSets time (hour) for scheduled automatic reboot.1
08Setting modeSystemGeneralScheduled automatic reboot8983Time (Minute)00-59SYSSets time (minute) for scheduled automatic reboot.1
08Setting modeSystemUser interfaceNFC reader8986Usage type00-
429496729
SYS0011ZZZZ (First 4 digits are fixed)
-ZZZZ: Sub code
0000: No authentication using card
0001: IDm (Felica/NFC-FeliCa) and (or) UID (Mifare/NFC-Mifare) are used
0002: Data (Felica/NFC-FeliCa/Mifare/NFC-Mifare)
0003: SSFC mode
5Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interfaceNFC reader8987Format information 100-
429496729
SYS000ASSSS (hexadecimal, first 3 digits are fixed)
-A:
0: A key
1: B key
-SSSS:
Sector number (first 2 digits are fixed to "0")
5Yes
08Setting modeSystemUser interfaceNFC reader8988Format information 200-
429496729
SYS00BSEbse (hexadecimal, first 2 digits are fixed)
-B: Block number of first block
-S: Starting offset of first block
-E: Ending offset of first block
-b: Block number of second block
-s: Starting offset of second block
-e: Ending offset of second block
5Yes
08Setting modeSystemUser interfaceNFC reader8989Format information 300-
0xFFFFFF FFFFFFFF FF
SYS0000KKKKKKKKKKKK (hexadecimal, first 4 digits are fixed)
-KKKKKKKKKKKK: key (12 digits)
5Yes
08Setting modeSystemMaintenan ceNotification of
Notification setting8991Notification setting00~1SYS0: Disabled
2Yes
Notification day 18992Notification day 100-31SYS1st to 31th. Input "0" to disable this setting.1Yes
Notification day 28993Notification day 200-31SYS1st to 31th. Input "0" to disable this setting.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemMaintenan ceNotification of equipment informationNotification day of the week8994Notification day of the week00-127SYSInput the value which corresponds to the day of the week. Input "0" to disable this setting.
Sunday: 64
Monday: 32
Tuesday: 16
Wednesday: 8
Thursday: 4
Friday: 2
Saturday: 1
e.g.) Monday: 32
Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday: 127 (64+32+16+8+4+2+1=127)
1Yes
Notification time8995Notification time3000-2359SYS(Hour/Hour/Minute/Minute)1Yes
Email address 1 for notification8996Email address 1 for notification--SYSMaximum 192 characters.11Yes
Email address 2 for notification8997Email address 2 for notification--SYSMaximum 192 characters.11Yes
Email address 3 for notification8998Email address 3 for notification--SYSMaximum 192 characters.11Yes
Adjustment mode
(05) data list
89991Adjustment mode
(05) data list
00-1SYS0: Disabled
4Yes
Setting mode (08) data list89992Setting mode (08) data list00-1SYS0: Disabled
4Yes
PM support mode data list89993PM support mode data list00-1SYS0: Disabled
4Yes
Pixel counter list89994Toner cartridge reference00-1SYS0: Disabled
4Yes
Pixel counter list89995Service engineer reference00-1SYS0: Disabled
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Error history list89996Maximum 1000 items00-1SYS0: Disabled
4Yes
Error history list89997Latest 80 items00-1SYS0: Disabled
4Yes
Firmware upgrade log89998Maximum 200 items00-1SYS0: Disabled
4Yes
Power ON/OFF log89999Power ON/OFF log00-1SYS0: Disabled
4Yes
Version list899910Version list00-1SYS0: Disabled
4Yes
Engine firmware log899911Engine firmware log00-1SYS0: Disabled
4Yes
Total counter list899912Total counter list00-1SYS0: Disabled
4Yes
08Setting modeSystemGeneral9000Destination selectionEUR: 0
UC: 1
JPN: 2
0~2M0: EUR 1: UC 2: JPN1
08Setting modeSystemOptionFAX9001Destination settingRefer to contents0~25SYS0: Japan 1: Asia 2: TAP 3: Hong Kong 4:
U.S.A./Canada 5: Germany 6: U.K. 7: Italy 8: Belgium
9: Netherlands 10: Finland
11: Spain 12: Austria 13: Switzerland 14: Sweden 15: Denmark
16: Norway 17: Portugal 18: France 19: Greece 20: Poland
21: Hungary 22: Czech 23: Turkey 24: South Africa 25: Taiwan
<Default value> EUR: 5
UC: 4
JPN: 0
Other: 1
1Yes
08Setting modeSystemGeneral9010Line adjustment mode00~1M0: For factory shipment 1: For line Field: "0" must be selected1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface9012Language displayed at power-ONRefer to contents-SYS<Default value> JPD: Japanese
TWD: Traditional Chinese CND: Simplified Chinese KRD: Korean
Others: English
08Setting modeSystemUser interface9016Counter installed externally00-5M0: No external counter
1: Coin controller (If the value of 08-9979 is "0" (ACS), it is changed to "2" (Full color).)
2: Totalizer/Key card (This value is valid only when "2" is set for 08-9000.)
3: Key counter
5: Coin controller supporting ACS/mixed-size (The value of 08-4131 is set to "1")
* "4" cannot be set.
08Setting modeSystemCounter9017Setting for counter installed externally10-7MSelects the job to count up for the external counter. 0: Not selected
1: Copier
2: Fax
3: Copier/Fax
4: Printer
5: Copier/Printer
6: Fax/Printer
7: Copier/Fax/Printer
08Setting modeSystemGeneral9022Easy setup production process flag990~99SYSPerform this code when an error occurs during the easy setup (unpacking manual adjustment) and you want to finish the easy setup, or when the error is canceled and you want to restart the unpacking manual adjustment. 0: Packing mode finished (before unpacking is started) 1: Auto-toner adjustment finished (The message prompting the
installation of the toner cartridge is displayed.) 2: Toner cartridge is installed
3: Automatic gamma adjustment finished 99: All the unpacking adjustments finished
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral9023Trial period setting2541~60SYSSets the trial period from 1 to 60 days. This setting is effective only when the default value is "254". Once the default value is set, this value is only used for a reference.1Yes
08Setting modeSystemGeneral9025Notifying condition of trial period end30~255SYSSets when the end of trial period is notified.0: On the day it ends 1 to 255: n days before1Yes
08Setting modeSystemGeneral9026Notifying address of trial period end30~3SYSSets where the end of the trial period is to be notified.
0: OFF 1: User 2: Service center 3: User and service center
1Yes
08Setting modeSystemGeneral9027Forcible end of trial period--SYS[CANCEL]: Cancel [INITIALIZE]: Forcible end
When the “Forcible end of trial period” is performed, “0” is set in the code (08-9023) to end up the trial period forcibly.
3Yes
08Setting modeSystemInitializatio n9030Initialization after software version up--SYSPerform this code when the software in this equipment has been upgraded.3Yes
08Setting modeSystemUser interfaceCounter installed externally9037Job handling-short paid-coin controller10~1SYSSets whether pause or stop the printing job when it is
short paid using a coin controller.0: Pause the job 1: Stop the job
08Setting modeSystemMaintenan ceGeneral9050Performing panel calibration--SYSPerforms the calibration of the pressing position on the touch panel (LCD screen). The calibration is performed by pressing 4 reference positions after this code is started up.1Yes
08Setting modeSystemUser interfaceScreen setting9051Panel calibration setting value00~1SYSSwitches whether the screen for displaying panel calibration setting values is displayed or not.0: Disabled (screen not displayed) 1: Enabled (screen displayed)1Yes
08Setting modeSystem9060Destination display at SRAM initializationRefer to contents0-255SYS0: MJD 1: NAD 2: JPD 3: AUD 4: CND 5: KRD 6:
TWD 7: Not used 8: ASU 9: ASD 10: ARD 11: Not
used 12: CNS
<Default value>
MJD: 0 NAD: 1 JPD: 2 AUD: 3 CND: 4 KRD: 5
TWD: 6 SAD: 7 ASU: 8 ASD: 9 ARD: 10 CNS: 12
08Setting modeSystemHDD9065HDD diagnostic menu display--SYSDisplay the HDD information2Yes
08Setting modeSystemHDD9072Performing HDD testing--SYSChecks the bad sector. It may take more than 30 minutes to finish the checking.3Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral9081Initialization of department management information--SYSInitializing of the department management information
* Key in the code and press the [INITIALIZE] button to perform the initialization. If the area storing the department management information is destroyed for some reason, “Enter
Department Code” is displayed on the control panel even if
the department management function is not set on. In this case, initialize the area with this code. This area is normally
initialized at the factory.
08Setting modeSystemInitializatio nInitialization of NIC information9083Initialization of NIC information--SYSReturns the value to the factory shipping default value.3Yes
08Setting modeSystemAll clearing9090Printer all clear--MIf the data of the self-diagnosis 05/08 code become abnormal, performing 08-4582 can restore them. If not, perform this code. All data of the self-diagnosis 05/08 code with "M" in the "RAM" field are initialized, except the destination setting data. Perform this code if the above problem occurs or the data of the self-diagnosis 05/08 code and the backup data are damaged after replacing the LGC board and performing 08-4582.
Procedure:
1. Set 08-9000.
2. Perform 08-9090.
3. Perform 08-4581.
4. Set 08-9080 to "0".
If you have got the order wrong, repeat the procedure from step 1. After this code is performed, it is necessary to replace the developer material and to adjust the autotoner sensor. Since the information of the PM counter is initialized, enter it again as required.
3Yes
08Setting modeSystemGeneral9100Date and time setting-13 digits-Year/month/date/day/hour/minute/second Example:03 07 0 13 13 27 48 "Day" - "0" is for
"Sunday". Proceeds Monday through Saturday from "1" to "6".
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingSystemUser9102Date display formatRefer to0~2SYS0: YYYY.MM.DD. 1: DD.MM.YYYY 2: MM.DD.YYYY1
modeinterfacecontents<Default value>
EUR: 1
UC: 2
JPN: 0
08SettingSystemGeneral9103Time differencesEUR: 240~47SYS0: +12.0h 1: +11.5h2: +11.0h 3: +10.5h 4: +10.0h 5:1
modeUC: 40+9.5h
JPN: 66: +9.0h 7: +8.5h 8: +8.0h 9: +7.5h 10: +7.0h 11: +6.5h
12: +6.0h 13: +5.5h 14: +5.0h 15: +4.5h 16: +4.0h 17:
+3.5h
18: +3.0h 19: +2.5h 20: +2.0h 21: +1.5h 22: +1.0h 23:
+0.5h
24: 0.0h 25: -0.5h 26: -1.0h 27: -1.5h 28: -2.0h 29: -
2.5h
30: -3.0h 31: -3.5h 32: -4.0h 33: -4.5h 34: -5.0h 35: -
5.5h
36: -6.0h 37: -6.5h 38: -7.0h 39: -7.5h 40: -8.0h 41: -
8.5h
08Setting modeSystemUser interface9110Auto-clear timer setting30~10SYSTimer to return the equipment to the default settings when the [START] button is not pressed after the function and the mode are set 0: Not cleared 1 to 10: Set number x 15 sec.1
08Setting modeSystemUser interface9111Auto power save mode timer setting40~15SYSTimer to automatically switch to the Auto power save mode when the equipment has not been used.
0: Invalid 4: 1 min. 6: 3 min. 7: 4 min. 8: 5 min. 9: 7
min. 10: 10 min. 11: 15 min. 12: 20 min. 13: 30 min.
14: 45 min. 15: 60 min.
1Yes
08SettingSystemUser9112Auto Shut Off timer210~21SYSTimer to turn OFF the power or to enter the Sleep1Yes
modeinterfacesetting (Sleep Mode)Mode automatically when the equipment has not been
used.
0: 3 min. 1: 5 min. 2: 10 min. 3: 15 min. 4: 20 min. 5:
25 min. 6: 30 min. 7: 40 min. 8: 50 min. 9: 60 min.
10: 70 min. 11: 80 min. 12: 90 min. 13: 100 min. 14:
110 min. 15: 120 min. 16: 150 min. 17: 180 min. 18:
210 min. 19: 240 min. 20: Disabled 21: 1 min.
08Setting modeSystemUser interfaceEnergy save9113Screen setting for automatic energy saver / automatic power OFFRefer to contents0~1SYS0: OFF 1: ON
<Default value> JPD/NAD: 1
Others: 0
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interfaceEnergy save9114Mode after the time [Sleep Timer] has passed10~1SYS0: OFF
1: Sleep/Super Sleep
08Setting modeSystemGeneral9117Raw printing
job(Blank page will not be printed)
00~1SYS0: OFF 1: ON1
08Setting modeSystemUser interfaceDepartment setting9120Department setting00~1SYS0: Invalid 1: Valid1Yes
08Setting modeSystemUser interfaceDepartment setting9121Print setting without department/registratio n code10~2SYS0: Printed 1: Not printed (pooled in the invalid queue) 2: Deleted forcibly1Yes
08Setting modeSystemUser interfaceDepartment setting9122Copy10~1SYS0: Invalid 1: Valid1Yes
08Setting modeSystemUser interfaceDepartment setting9123FAX10~1SYS0: Invalid 1: Valid1Yes
08Setting modeSystemUser interfaceDepartment setting9124Printer10~1SYS0: Invalid 1: Valid1Yes
08Setting modeSystemUser interfaceDepartment setting9125Scanning10~1SYS0: Invalid 1: Valid1Yes
08Setting modeSystemUser interfaceDepartment setting9126List print10~1SYS0: Invalid 1: Valid1Yes
08Setting modeSystemUser interfaceExternal counter9129Duplex print setting when coin controller is used10~1SYSWhen the duplex printing is short paid with a coin controller, reverse side of the original is not printed and is considered as a defect (printing job may be cleared). To solve this problem, the selection of printing method is enabled with this setting
.0: Invalid (Only one side printed)
1: Valid (Both sides printed/One side printed)
08Setting modeSystemUser interface9130Highlighting display on LCD00~1SYS0: Black letter on white background 1: White letter on black background1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interfaceDefault mode settingDefault setting9132Default setting of screen (Function)00-7, 99SYSSets the screen to be displayed after the auto-clear time has passed or it has recovered from the energy saving mode or sleep mode.
0: COPY
1: FAX
2: SCAN
3: BOX
4: PRINT
5: TEMPLATE
6: MENU
7: JOB STATUS
99: EWB
* Only 0 to 7, and 99 can be entered.
1Yes
08Setting modeSystemUser interface9133Default setting for APS/AMS00~2SYS0: APS (Automatic Paper Selection)
1: AMS (Automatic Magnification Selection) 2: Not selected
08Setting modeSystemUser interfaceDefault setting of RADF mode9134Default setting00~1SYS0: Continuous feeding (by pressing the [START] button) 1: Single feeding (by setting original on the tray)1Yes
08Setting modeSystemUser interface9135Book type original priority00~1SYS0: Left page to right page 1: Right page to left page1
08Setting modeSystemUser interface9136Maximum number of copy volume (MAX9)11~3SYS1: 999 2: 99 3: 91
08Setting modeSystemUser interfaceDefault mode settingDefault setting9137Setting for automatic duplexing mode00~3SYS0: Invalid
1: Single-sided to duplex copying 2: Double-sided to duplex copying 3: User selection
1Yes
08Setting modeSystemUser interface9140Paper size selection for [OTHER] buttonRefer to contents0-255SYSPress the button on the LCD to select the size.
<Default value> EUR: FOLIO UC: COMP JPN: A5-R
08Setting modeSystemUser interfaceDefault setting of RADF mode9142Default setting of RADF original size00~1SYS0: Scanned as all in same size 1: Scanned as each original size1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemPaper feeding9143Time lag before Auto Job Start of bypass feeding100~10SYSSets the time taken to add paper feeding when paper in the bypass tray has run out during the bypass feed copying.
0: Paper is not drawn in unless the [START] button is pressed.
1-10: Setting value x 0.5 sec.
08Setting modeSystemUser interface9144Blank copying prevention mode during RADF jamming00~1SYS0: OFF 1: ON (Start printing when the scanning of each page is finished)1
08Setting modeSystemUser interfaceRotation printing9146Rotation printing at the non-sorting00~1SYS0: Not rotating 1: Rotating1Yes
08Setting modeSystemUser interface9147Direction priority of original image00~1SYS0: Automatic 1: Portrait1
08Setting modeSystemUser interface9148Inner receiving tray
priority at Non-sort Mode
00~1SYS0: Normal 1: Inner receiving tray1
08Setting modeSystemUser interface9149Width setting for image shift copying (linkage of front side and back side)00~1SYS0: ON 1: OFF1
08Setting modeSystemUser interface9150Automatic Sorting Mode setting (RADF)20~4SYS0: Invalid 1: STAPLE 2: SORT 3: GROUP 4: ROTATE SORT1
08Setting modeSystemUser interface9151Default setting of Sorter Mode00~4SYS0: NON-SORT 1: STAPLE 2: SORT 3: GROUP 4: ROTATE SORT1
08Setting modeSystemUser interface9152Correction of reproduction ratio in editing copy100~10SYSSets the reproduction ratio for the "X in 1" printing (including magazine sort) to the "Reproduction ratio x Correction ratio".
0: 90% 1: 91% 2: 92% 3: 93% 4: 94% 5: 95% 6: 96% 7:
97% 8: 98% 9: 99% 10: 100%
08Setting modeSystemUser interface9153Image position in editing20~3SYSSets the page pasted position for "X in 1" to the upper left corner/center.
0: PPC:Cornering/PRT:Cornering
1: PPC:Centering/PRT:Cornering
2: PPC:Cornering/PRT:Centering
3: PPC:Centering/PRT:Centering
08Setting modeSystemUser interface9155Magazine sort setting00~1SYS0: Left page to right page 1: Right page to left page1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface91562 in 1/4 in 1 page
allocating order setting
00~1SYS0: Horizontal 1: Vertical1
08Setting modeSystemUser interface9157Printing format setting for Time stamp and Page Number20~3SYSHyphen (with page number) /Dropout (with date, time and
page number)
0: OFF/OFF 1: ON/OFF 2: OFF/ON 3: ON/ON
Note: Hyphen printing format ON: -1- OFF: 1
08Setting modeSystemUser interfaceCascade operation settingPPC/FAX91580ON/OFF00~1SYSSets the tray switch operation if the output tray becomes full of paper while printing.
0: OFF 1: ON
08Setting modeSystemUser interfaceCascade operation settingPPC/FAX91581Cascade operation00~1SYS0: Switches one time 1: Circulation (loop)4
08Setting modeSystemUser interfaceCascade operation settingPRINTER/BOX91590ON/OFF00~1SYSSets the tray switch operation if the output tray becomes full of paper while printing.
0: OFF 1: ON
08Setting modeSystemUser interfaceCascade operation settingPRINTER/BOX91591Cascade operation00~1SYS0: Switches one time 1: Circulation (loop)4
08Setting modeSystemUser interface9163Direction priority for
date and time stamp printing
00~1SYS0: Short edge 1: Long edge1
08Setting modeSystemUser interfacePaper Feed9164Auto-start setting for bypass feed printing00~1SYSSets whether or not feeding a paper automatically into the equipment when it is placed on the bypass tray.
0: OFF (Press the [START] button to start feeding.) 1: ON (Automatic feeding)
1Yes
08Setting modeSystemUser interface9165Auto Job start setting for bypass feed printing10~1SYSSets whether or not feeding a paper automatically into the equipment when it is placed on the bypass tray.
08Setting modeSystemOptionFAX9183Adaptation of paper source00~1SYS0: Not subjected for APS judgment 1: Subjected for APS judgment1Yes
08Setting modeSystemUser interface9184Centering printing of primary/secondary direction at AMS10~1SYS0: Invalid 1: Valid1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interfaceFeeding paper media91850Copier11, 16, 17SYSSets a media type for APS drawer searching in the copier functions.
Each bit 0: Excluded from feeding target media Each bit 1: Feeding target media
bit 0: Plain paper
bit 1: N/A (Always set "0")
bit 2: N/A (Always set "0")
bit 3: N/A (Always set "0")
bit 4: Thick paper 1
08Setting modeSystemUser interfaceFeeding paper media91851Printer/Box11SYSSets a media type to print on plain paper in the printer/box functions. This setting is used for drawer searching or media type inconsistency judgment. The setting result does not affect other media types, other than plain paper.
bit 0: Plain paper
bit 4: N/A (Always set "0")
08Setting modeSystemNetworkRetention period9193Web data retention period103 digitsSYSWhen a certain period of time has passed without operation after accessing TopAccess, the data being registered is automatically reset. This period is set at this code. (Unit: Minute)1Yes
08Setting modeSystemGeneral9199Automatic interruption page setting during printing00~100SYSSets the number of pages to interrupt the printing automatically. If the setting value is one or more, printing is interrupted when the setting value x 10 is reached, then printing is resumed. 0-100: 0 to 100 pages1
08Setting modeSystemNetworkRetention period9200File retention period300~999SYS0: No limits 1 to 999: 1 to 999 days1Yes
08Setting modeSystemNetworkE-mail9201Max. size in email transmission302~100SYS2 to 100 M bytes1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemElectronic Filing9203Full guarantee of documents in Electronic Filing when HDD is full10~1SYSSets the file retention level when editing the files in the Electronic Filing (at CutDoc/SaveDoc command execution). 0: Not full retained
1: Fully retained - Retains the source file until CutDoc/SaveDoc command is completed. * The file is not deleted even if the HDD has become
full during the execution of command when “1” is set.
08Setting modeSystemUser interface9204Binarizing level selection (When judging as black in the ACS Mode)31-5SYS0: Step -2
1: Step -1
2: Step 0 (center)
3: Step 1
4: Step 2
The binarizing level of each step is set at 08-9230.
08Setting modeSystemElectronic Filing9207Default value for user box retention period00~999SYSSets the data retention period when creating a user
box. 0: Not deleted 1 to 999: Retention period (Unit: Day)
08Setting modeSystemHDD9208Warning notification- File Share/e-Filling900~100SYSSets the percentage of HDD partition filled when warning notification is sent.
0 to 100: 0 to 100%
* Related code 08-9225
1Yes
08Setting modeSystemScanning9209Notification setting of
E-mail saving time limit
30~99SYSSets the days left the notification of E-mail saving time limit appears 0 to 99: 0 to 99 days1
08Setting modeSystemScanning9210Default setting of partial size when transmitting E-mail00~6SYSSets the default value for the partial size of E-mail to be transmitted when creating a template. 0: Not divided 1: 64 2: 128 3: 256 4: 512 5: 1024 6: 2048 (Unit: KB)1
08Setting modeSystemOptionFAX9211Default setting of page by page-I FAX00~4SYSSets the default value for the page by page of Internet FAX to be transmitted when creating a template. 0: Not divide 1: 256 2: 512 3: 1024 4: 2048 (Unit: KB)1Yes
08Setting modeSystemUser interfaceDefault mode settingDefault setting (SCN)9213Default setting for density adjustment00~11SYS0: Automatic density 1: Step -5 2: Step -4 3: Step -3 4:
Step -2 5: Step -1 6: Step 0 (center) 7: Step +1 8: Step
+2 9: Step +3 10: Step +4 11: Step +5 (1 to 11: Manual density)
1Yes
08Setting modeSystemUser interface9214Default setting of background adjustment(Full Color)51~9SYS1: Step -4 2: Step -3 3: Step -2 4: Step -1 5: Step 0
(center) 6: Step +1 7: Step +2 8: Step +3 9: Step +4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interfaceDefault mode settingDefault setting (SCN)9215Color mode00~4SYS0: Black 1: Gray Scale 2: Unused 3: Full Color 4: Auto Color1Yes
08Setting modeSystemUser interfaceDefault mode settingDefault setting of resolution (SCN)9216Full Color20~5SYS0: 100 dpi 1: 150 dpi 2: 200 dpi 3: 300dpi 4: 400 dpi 5: 600dpi1Yes
08Setting modeSystemUser interfaceDefault mode settingDefault setting of resolution (SCN)9217Gray Scale20~5SYS0: 100 dpi 1: 150 dpi 2: 200 dpi 3: 300dpi 4: 400 dpi 5: 600dpi1Yes
08Setting modeSystemUser interfaceDefault mode settingDefault setting of resolution (SCN)9218Black10~5SYS0: 150 dpi 1: 200 dpi 2: 300 dpi 3: 400dpi 4: 600dpi 5: 100dp1Yes
08Setting modeSystemUser interfaceDefault mode settingDefault setting (SCN)9219Original mode (Full color)00~3SYS0: Text
1: Text/Photo
2: Photo
3: Custom (Valid only when a setting other than "0" is set for 08-8303)
1Yes
08Setting modeSystemUser interfaceDefault mode settingDefault setting (SCN)9220Original mode (Black)00~3SYS0: Text
1: Text/Photo
2: Photo
3: Custom
The value other than "0" needs to be set for 08-7401 to select "3: Custom."
1Yes
08Setting modeSystemUser interface9221Default setting of duplex mode00~2SYS0: Single 1: Book 2: Tablet1
08Setting modeSystemUser interface9222Default setting of
rotation angle of original
00~3SYS0: 0 degree 1: 90 degrees 2: 180 degrees 3: 270 degrees1
08Setting modeSystemUser interface9223Default setting of original paper size00~22SYS0: Automatic 1: A3 2: A4 3: LD 4: LT 5: A4-R 6: A5-R 7:
LT-R 8: LG 9: B4 10: B5 11: ST-R 12: COMP 13: B5-R
14: FOLIO 15: 13”LG 16: 8.5” x 8.5” 18: A6-R 19: Size
mixed 20: 8K 21: 16K 22: 16K-R
08Setting modeSystemGeneral9225Searching interval of deleting expired flies and checking capacity of HDD partitions121~24SYSSets the search interval of deleting expired files and checking capacity of HDD partition. (Unit: Hour) * Related code 08-92081
08Setting modeSystemUser interface9226Default setting of background adjustment(Gray Scale)51~9SYS1: Step -4 2: Step -3 3: Step -2 4: Step -1 5: Step 0
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interfaceDefault setting of filing formatE-mail9227Black10~6SYS0: TIFF (Multi) 1: PDF (Multi) 3: TIFF (Single) 4: PDF
(Single) 5: XPS (Multi) 6: XPS (Single)
1Yes
08Setting modeSystemUser interfaceDefault setting of filing formatStoring files9228Color/ACS10~8SYS0: TIFF (Multi) 1: PDF (Multi) 2: JPG 3: TIFF (Single) 4:
PDF (Single) 5: SLIM PDF (Multi) 6: SLIM PDF (Single) 7: XPS (Multi) 8: XPS (Single)
1Yes
08Setting modeSystemUser interfaceDefault setting of filing formatStoring files9229BlackRefer to contents0~6SYS0: TIFF (Multi) 1: PDF (Multi) 3: TIFF (Single) 4: PDF
<Default value> MJD: 1
Others: 0
1Yes
08Setting modeSystemImageBinarizing level setting (When judging as black in the ACS Mode)92300Step -2880-255SYSSets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204.4
08Setting modeSystemImageBinarizing level setting (When judging as black in the ACS Mode)92301Step -11080-255SYSSets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204.4
08Setting modeSystemImageBinarizing level setting (When judging as black in the ACS Mode)92302Step 0 (center)1480-255SYSSets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204.4
08Setting modeSystemImageBinarizing level setting (When judging as black in the ACS Mode)92303Step +11780-255SYSSets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204.4
08Setting modeSystemImageBinarizing level setting (When judging as black in the ACS Mode)92304Step +22080-255SYSSets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204.4
08Setting modeSystemElectronic Filing9233Equipment name and user name setting to a folder when saving files00~2SYSSets whether or not adding the equipment name and user name to the folder when saving files.
0: Not add 1: Add the equipment name 2: Add the user name
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface9236Default setting of print menu11~4SYS1: Private print screen (Job list of log-in user is displayed if user authentication is enabled.)
2: Hold print screen (Job list of log-in user is displayed if user authentication is enabled.)
3: Private print screen (If the private print screen is displayed when user authentication is enabled, user list is displayed if user logs in as GUEST, and job list of log-in user is displayed if user logs in as general user.) 4: Hold print screen (If the private print screen is displayed when user authentication is enabled, user list is displayed if user logs in as GUEST, and job list of log-in user is displayed if user logs in as general user.)
* If user data department management (08-9264) is changed from OFF to ON, the value in this code changes from "1" to "2", and "3" to "4". The value does not change if it is "2" or"4". Reset this value as necessary when changing user data department management (08-9264) from OFF to ON.
08Setting modeSystemData overwrite kit9240HDD data overwriting type setting30-3SYSSelect the type of the overwriting level for deleting HDD data. (This setting is enabled only when the GP-1070 is installed.)
0: LOW
Standard overwriting method. 1: MEDIUM
More secure overwriting method than LOW. The overwriting time is between LOW and HIGH.
2: HIGH
The most secure overwriting method. The overwriting time is the longest.
3: SIMPLE
Simple overwriting method. The time for overwriting is the shortest.
08Setting modeSystemPaper feeding9248Automatic feed setting of tab paper and insertion sheet(Remote)10~1SYS0: Disabled 1: Enabled1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface9251Access code entry for
Electronic Filing printing
00~1SYS0: Renewed automatically 1: Enter every time1
08Setting modeSystemUser interface9252Clearing timing for files and Electronic Filing Agent10~1SYS0: Immediately after the completion of scanning 1: Cleared by Auto Clear1
08Setting modeSystemPaper feeding9253Setting of paper size switching to 13" LG00~2SYS0: Not switched 1: LG → 13”LG 2: FOLIO → 13”LG1
08Setting ModeSystemOptionFAX9255FOLIO/A4-R
judgment when width of paper is mixed
00-1SYSWhen the value of this code is "0", the paper size is judged by performing switchback.
When the value of this code is "1" and the paper size is AB-series, FOLIO is judged as A4-R and switchback is not performed. When the paper size is LT-series, the switchback is always performed. When the value of this code is set to "1", the scanning performance increases at fax transmission. However, the whole image cannot be output since FOLIO is judged as A4-R.
0: Judgment is enabled 1: Judgment is disabled
08Setting modeSystemUser interface9261Maximum number of time job build performed10005~1000SYSSets the maximum number of time a job build has been performed.
5-1000: 5 to 1000 times
08Setting modeSystemGeneral9264User data department management00~1SYS0: Invalid 1: Valid
* When this code is set to "1" (Valid), the department management setting (08-9120) should be "1" (Valid).
08Setting modeSystemPaper feeding9267Detection method of 13" LG for single-size document00~1SYS0: Disabled 1: Enabled1
08Setting modeSystemOptionFAX9268Inbound FAX function (Forwarding by TSI)10~1SYS0: OFF(Function disabled) 1: ON(Function enabled)1Yes
08Setting modeSystemOptionFAX9269Tab/cover sheet-FAX Printing stop function00~1SYSSets on or off of the printing function of special sheets such as tab or cover sheet of FAX, Email or list print. 0: Function off 1: Function on1Yes
08Setting modeSystemNetwork9271Authentication
method of "Scan to Email"
00~2SYS0: Disable 1: SMTP authentication 2: LDAP authentication1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork9272Setting whether use of Internet FAX is permitted or not when it is given an authentication00~1SYS0: Not permitted 1: Permitted1
08Setting modeSystemNetwork9274"From" address assignment method when it is given an authentication00~2SYS0: "User name" + @ + "Domain name"1: LDAP search 2: Use the address registered in "From" field of E-mail setting1
08Setting modeSystemNetwork9276Setting for "From" address edit at "Scan to Email"00~1SYS0: Not permitted 1: Permitted1
08Setting modeSystemNetwork9278E-mail domain name--SYS96+2 (delimiter) character ASCII sequence only11
08Setting modeSystemUser interfaceSound9280Error sound10~1SYS0: OFF 1: ON1Yes
08Setting modeSystemUser interfaceSound9281Sound setting -- Energy SavingRefer to contents0~1SYS0: OFF 1: ON
Other: 1
1Yes
08Setting modeSystemGeneral9293User authentication method00~2SYS0: Local 1: NTLM (NT Domain) 2: LDAP1
08Setting ModeSystemGeneral9294Automatic user registration for external authentication10-1SYS0: Disabled 1: Enabled1
08Setting modeSystemGeneral9295User data
management limitation setting
08Setting modeSystemGeneral9296User data management limitation Setting by number of printouts07 digitsSYS0-9,999,999: 0-9,999,999 sheets1
08Setting modeSystemNetwork9298Restriction on Address book operation by administrator00~1SYSSome restrictions can be given on the administrator for operating the Address book.
0: No restriction
1: Can be operated only under the administrator's authorization
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork9299Restriction on "To" ("cc") address00~3SYS0: No restriction
1: Can be set from both of the Address book and LDAP server 2: Can be set only from the Address book
3: Can be set only from the LDAP server
08Setting modeSystemPaper feeding9300Drawer 1Paper information00~1SYS0: Plain paper 1: Thick paper 11
08Setting modeSystemPaper feeding9301Drawer 2Paper information00~1SYS0: Plain paper 1: Thick paper 11
08Setting modeSystemPaper feeding9302PFP 1 Paper information00~1SYS0: Plain paper 1: Thick paper 11
08Setting modeSystemPaper feeding9303PFP 2 Paper information00~1SYS0: Plain paper 1: Thick paper 11
08Setting modeSystemPaper feeding9304LCF Paper information00~1SYS0: Plain paper 1: Thick paper 11
08Setting modeSystemPaper feeding9305Bypass tray Paper information00~3, 11,
16, 32
SYS0: Plain paper 1: Thick paper 1 2: Thick paper 2 3:
Thick paper 3 11: Thin paper 16: OHP film 32: Envelope
08Setting modeSystemPaper feeding9306LT <-> A4/LD <-> A300~1SYSSets whether the data is printed on the different but similar size paper or not when the paper of corresponding size is not available.
0: Valid (The data is printed on A4/A3 when LT/LD is selected or vice versa.)
1: Invalid (The message to use the selected paper size is displayed.)
08Setting modeSystemNetworkRetention period9307Storage period at trail and private140-53SYS0: No limits
1 to 30: 1 to 30 days
31: 1 hour 32: 2 hours 33: 4 hours 34: 8 hours 35: 12
hours 50: 5 min. 51: 10 min. 52: 15 min. 53: 30 min.
1Yes
08Setting modeSystemNetwork9308Raw printing job (Duplex)10~1SYS0: Valid 1: Invalid1
08Setting modeSystemNetwork9309Raw printing job(Paper size)EUR: 6
UC: 2
JPN: 6
0 ~13SYS0: LD 1: LG 2: LT 3: COMP 4: ST 5: A3 6: A4 7: A5 8:
A6 9: B4 10: B5 11: FOLIO 12: 13”LG 13: 8.5” x 8.5”
08Setting modeSystemNetwork9310Raw printing job(Paper type)00~6SYS0: Plain paper 1: Thick paper 1 2: Thick paper 2 3:
Thick paper 3 4: OHP film 6: Thin paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork9311Raw printing job(Paper direction)00~1SYS0: Portrait 1: Landscape1
08Setting modeSystemNetwork9312Raw printing job (Staple)10~1SYS0: Valid 1: Invalid1
08Setting modeSystemNetwork9313Raw printing job(receiving tray)00~6SYS0: Inner tray
1: Finisher tray 1
2: Finisher tray 2
3: Not used
4: Job Separator upper tray 5: Job Separator lower tray
* The settings 4 and 5 are effective only when the Job Separator (MJ- 5004) is installed.
08Setting modeSystemNetwork9314Raw printing
job(Number of form lines)
1200500~12800SYSSets the number of form lines from 5 to 128. (A
hundredfold of the number of form lines is defined as the setting value.)
08Setting modeSystemNetwork9315Raw printing job(PCL font pitch)100044~9999SYSSets the font pitch from 0.44 to 99.99. (A hundredfold of the font pitch is defined as the setting value.)1
08Setting modeSystemNetwork9316Raw printing job(PCL font size)1200400~99975SYSSets the font size from 4 to 999.75. (A hundredfold of the font size is defined as the setting value.)1
08Setting modeSystemNetwork9317Raw printing job(PCL font number)00~9999SYSSets the PCL font number.1
08Setting modeSystemPaper feeding9318Memory 1 Paper size (bypass feeding/non- standard type) feeding/widthwise direction148/100148~432/1
00~297
SYSRegisters the paper size of bypass feed (non-standard type) into [MEMORY 1].10
08Setting modeSystemPaper feeding9319Memory 2 Paper size (bypass feeding/non- standard type) feeding/widthwise direction148/100148~432/1
00~297
SYSRegisters the paper size of bypass feed (non-standard type) into [MEMORY 2].10
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemPaper feeding9320Memory 3 Paper size (bypass feeding/non- standard type) feeding/widthwise direction148/100148~432/1
00~297
SYSRegisters the paper size of bypass feed (non-standard type) into [MEMORY 3].10
08Setting modeSystemPaper feeding9321Memory 4 Paper size (bypass feeding/non- standard type) feeding/widthwise direction148/100148~432/1
00~297
SYSRegisters the paper size of bypass feed (non-standard type) into [MEMORY 4].10
08Setting modeSystemUser interfaceSound9325Key touch sound of control panel10~1SYS0: OFF 1: ON1Yes
08Setting modeSystemUser interfaceScreen setting9326Size indicator00~1SYS0: Invalid 1: Valid1Yes
08Setting modeSystemGeneral9327Setting of banner advertising display00~1SYSSets whether or not displaying the banner advertising. The setting contents of 08-9328 and 08-9329 are displayed at the time display section on the right top of the screen. When both are set, each content is displayed alternately.
0: Not displayed 1: Displayed
08Setting modeSystemGeneral9328Banner advertising display 1--SYSMaximum 27 letters (one-byte character)11
08Setting modeSystemGeneral9329Banner advertising display 2--SYSMaximum 27 letters (one-byte character)11
08Setting modeSystemGeneral9330Display of [BANNER MESSAGE] button00~1SYS0: Not displayed 1: Displayed
* This button enables the entry of "Banner advertising display 1 (08-9328)" and "Banner advertising display 2 (08-9329)" on the control panel.
08Setting modeSystemNetwork9331Local I/F time-out period61~50SYSSets the period of time when the job is judged as completed in local I/F printing (USB or parallel).
1: 1.0 sec. 2: 1.5 sec. - 50: 25.5 sec. (in increments of
0.5 sec.)
08Setting modeSystemUser interface9332Original counter displayMJD: 2
Other: 0
0,2,4SYSSets whether the original counter is displayed or not. 0: Not displayed 2: Displayed 4: Displayed (Double sized original is counted as 2.)1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork9334PCL line feed code setting00~3SYSSets the PCL line feed code.0: Automatic setting
1: CR=CR, LF=LF 2: CR=CR+LF, LF=LF 3: CR=CR, LF=CR+LF
08Setting modeSystemFeeding system/Pa per transport9335Feeding direction setting of envelope00~1SYSSets the feeding direction of envelopes.
0: Envelope flap comes on its trailing edge (front side of the equipment)
1: Envelope flap comes on its leading edge (rear side of the equipment)
1Yes
08Setting modeSystemPaper feeding9336Default setting of drawers(Printer/BOX)11~5SYS1: LCF 2: Upper drawer 3: Lower drawer 4: PFP upper drawer
5: PFP lower drawer
08Setting modeSystemUser interface9337Restriction of the template function with the administrator privilege00~1SYSSelects the restriction of the template function usage setting.
0: No restriction 1: Only available with the administrator privilege.
08Setting modeSystemNetwork9338Raw printing
job(Paper feeding drawer)
00~5SYS0: AUTO1: Upper drawer 2: Lower drawer 3: PFP upper drawer 4: PFP lower drawer 5: LCF1
08Setting modeSystemNetwork9339Raw printing job(PCL symbol set)00~39SYS0: Roman-8 1: ISO 8859/1 Latin 1 2: ISO 8859/2 Latin
2 3: ISO 8859/9 Latin 5 4: PC-8,Code Page 437 5: PC-
8 D/N, Danish/ Norwegian 6: PC-850,Multilingual 7: PC-
852, Latin2 8: PC-8 Turkish 9: Windows 3.1 Latin 1 10:
Windows 3.1 Latin 2 11: Windows 3.1 Latin 5 12:
DeskTop 13: PS Text 14: Ventura International 15:
Ventura US 16: Microsoft Publishing 17: Math-8 18: PS
Math 19: Ventura Math 20: Pi Font 21: Legal 22: ISO 4:
United Kingdom 23: ISO 6: ASCII 24: ISO 11 25: ISO
15: Italian 26: ISO 17 27: ISO 21: German 28: ISO 60:
Danish/Norwegian 29: ISO 69: French 30: Windows 3.0
Latin 1 31: MC Text 32: PC Cyrillic 33: ITC Zapf
Dingbats 34: ISO 8859/10 Latin 6 35: PC-775 36: PC-
1004 37: Symbol 38: Windows Baltic 39: Wingdings
08Setting modeSystemUser interfaceBinding margin setting93410Left binding front (Right binding back)70-100SYSSets the binding margin displayed as default on the setting screen for the top/bottom/left/right binding function when copying. (Unit: mm)4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interfaceBinding margin setting93411Left binding back (Right binding front)70-100SYSSets the binding margin displayed as default on the setting screen for the top/bottom/left/right binding function when copying. (Unit: mm)4Yes
08Setting modeSystemUser interfaceBinding margin setting93412Top binding front (Bottom binding back)70-100SYSSets the binding margin displayed as default on the setting screen for the top/bottom/left/right binding function when copying. (Unit: mm)4Yes
08Setting modeSystemUser interfaceBinding margin setting93413Top binding back (Bottom binding front)70-100SYSSets the binding margin displayed as default on the setting screen for the top/bottom/left/right binding function when copying. (Unit: mm)4Yes
08Setting modeSystemUser interfaceBinding margin setting9342Book binding140~30SYSSets the binding margin displayed as default on the
setting screen for the book binding function when copying.
1Yes
08Setting modePrinterPaper feedingAutomatic change of paper sourceAuto9343Printing/BOX printing11~2SYS1: Only in the same paper direction
2: In both the same and different paper directions
1Yes
08Setting modeSystemNetwork9344Restriction mode of network printing00~3SYS0: Normal mode
1: Mode for Private Print 2: Mode for Hold Print
3: Mode for Private / Hold Print
* When "1" (valid) is set for the code 08-9264 "User data department management", the setting value of this code is automatically set to "2" except for the case "0" is set for this code. Only "0" and "2" are selectable for this code unless "0" (invalid) is set for the code 08- 9264.
08Setting modeSystemUser interface9352Display of paper size setting by installation operation of drawersRefer to contents0~1SYS0: Not displayed 1: Displayed
<Default value> JPD/MJD: 0
Other: 1
08Setting modeSystemGeneral9357Enhanced bold for PCL600~1SYS0:OFF 1:ON1
08Setting modeSystemUser interfacePaper Feed9359Printing resume after jam releasing10~1SYS0: Auto resume 1: Resume by users1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemUser interface9379HD data scramble function setting00~2SYS0: Encryption invalid
1: Encryption valid (Security priority) Encrypts all of the user's data.
2: Encryption valid (Performance priority) Encrypts the user's
data except the files temporarily created and deleted in the image processing such as copying or printing.
08Setting modeSystemUser interface9380Converting 1-byte katakana into 2 byte- katakana at e-mail transmission00~1SYS0: Non-conversion 1: With conversion1
08Setting modeSystemUser interfaceDefault setting of filing formatE-mail9384Color/ACS10~8SYS0: TIFF (Multi) 1: PDF (Multi) 2: JPG 3: TIFF (Single) 4:
8: XPS (Single)
1Yes
08Setting modeSystemNetworkNotification of scan job93860When job completed00~1SYSSets the notification method of scan job completion. 0: Invalid 1: Valid4
08Setting modeSystemNetworkNotification of scan job93861On error00~1SYSSets the notification method of scan job completion. 0: Invalid 1: Valid4
08Setting modeSystemNetwork9387File name format of "Save as file" and Email transmission00~6SYSSets the naming method of the file of "Save as file" and Email transmission.
0: [FileName]-[Data]-[Page]
1: [FileName]-[Page]-[Data]
2: [Data]-[FileName]-[Page]
3: [Data]-[Page]-[FileName]
4: [Page]-[FileName]-[Data]
5: [Page]-[Data]-[FileName]
6: [HostName]_[Data]-[Page]
