Toshiba e-STUDIO 307/357/457/507 Service Manual Part 13
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessProcess50012Print job end cleaning bias polarity switching frequency (Mass printing of small size paper)30~9MSet this code when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller in printing maximum size paper after printing a large amount of small size paper (1 to 9).
0: Once 1: Twice 2: Three times 3: Four times 4: Five
times 5: Six times 6: Seven times 7: Eight times 8: Nine times 9: Ten times
08Setting modeProcessProcess5002Job end cleaning bias polarity switching frequency (When not printing)30~9MSet this code when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller after the warming-up, forced toner supply or auto-toner adjustment.
08Setting modeProcessProcess5003Job end cleaning bias polarity switching frequency (At jam recovery)30~9MSets when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller after a paper jam is cleared.
4: Five times 5: Six times 6: Seven times 7: Eight times
08Setting modeProcessTransfer5005Switching transfer
bias between sheets of paper
10~1M0: Positive, 1: Negative1
08Setting modeProcessTransfer5016Switchover of paper size/environment/life correction at transfer of thin paper10-2M0: Switches all corrections 1: No switchover
2: Only paper width correction is applied
08Setting modeProcessTransfer5018Correction of transfer control for back side00-1M0: Correction is applied 1: No correction1
08Setting modeProcessTransfer50750Paper width transfer output correction (H) (Middle)Refer to contents0~255M<Default value>
e-STUDIO207L/257/307: 138
e-STUDIO357/457/507: 146
08Setting modeProcessTransfer50751Paper width transfer output correction (C) (Middle)Refer to contents0~255M<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransfer50752Paper width transfer output correction (L) (Middle)Refer to contents0~255M<Default value>
e-STUDIO207L/257/307: 146
e-STUDIO357/457/507: 156
08Setting modeProcessTransfer50760Paper width transfer output correction (H) (Small)Refer to contents0~255M<Default value>
e-STUDIO207L/257/307: 152
e-STUDIO357/457/507: 168
08Setting modeProcessTransfer50761Paper width transfer output correction (C) (Small)Refer to contents0~255M<Default value>
08Setting modeProcessTransfer50762Paper width transfer output correction (L) (Small)Refer to contents0~255M<Default value>
e-STUDIO207L/257/307: 162
e-STUDIO357/457/507: 170
08Setting modeProcessTransferPaper width correction (middle)Plain paper/Duplex50820HighRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 142
e-STUDIO357/457/507: 152
08Setting modeProcessTransferPaper width correction (middle)Plain paper/Duplex50821CenterRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (middle)Plain paper/Duplex50822LowRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 144
08Setting modeProcessTransferPaper width correction (small)Plain paper/Duplex50830HighRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 160
e-STUDIO357/457/507: 172
08Setting modeProcessTransferPaper width correction (small)Plain paper/Duplex50831CenterRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (small)Plain paper/Duplex50832LowRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (middle)Thick paper 1/Duplex50840HighRefer to contents0-255M<Default value>
e-STUDIO357/457/507: 158
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransferPaper width correction (middle)Thick paper 1/Duplex50841CenterRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (middle)Thick paper 1/Duplex50842LowRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 150
08Setting modeProcessTransferPaper width correction (small)Thick paper 1/Duplex50850HighRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 165
e-STUDIO357/457/507: 179
08Setting modeProcessTransferPaper width correction (small)Thick paper 1/Duplex50851CenterRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (small)Thick paper 1/Duplex50852LowRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 164
e-STUDIO357/457/507: 164
08Setting modeProcessTransferPaper width correction (middle)Thick paper 250860HighRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 128
e-STUDIO357/457/507: 128
08Setting modeProcessTransferPaper width correction (middle)Thick paper 250861CenterRefer to contents0-255M<Default value>
e-STUDIO357/457/507: 150
08Setting modeProcessTransferPaper width correction (middle)Thick paper 250862LowRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 148
08Setting modeProcessTransferPaper width correction (small)Thick paper 250870HighRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (small)Thick paper 250871CenterRefer to contents0-255M<Default value>
e-STUDIO357/457/507: 160
08Setting modeProcessTransferPaper width correction (small)Thick paper 250872LowRefer to contents0-255M<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransferPaper width correction (middle)Thick paper 350880HighRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (middle)Thick paper 350881CenterRefer to contents0-255M<Default value>
e-STUDIO357/457/507: 154
08Setting modeProcessTransferPaper width correction (middle)Thick paper 350882LowRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 147
08Setting modeProcessTransferPaper width correction (small)Thick paper 350890HighRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (small)Thick paper 350891CenterRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (small)Thick paper 350892LowRefer to contents0-255M<Default value>
e-STUDIO207L/257/307: 163
e-STUDIO357/457/507: 175
08Setting modeProcessTransferPaper width correction (middle)Envelope50900HighRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (middle)Envelope50901CenterRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (middle)Envelope50902LowRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (small)Envelope50910HighRefer to contents0-255M<Default value>
08Setting modeProcessTransferPaper width correction (small)Envelope50911CenterRefer to contents0-255M<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransferPaper width correction (small)Envelope50912LowRefer to contents0-255M<Default value>
e-STUDIO357/457/507: 177
08Setting modeProcessChargerMain charger grid
correction for thin paper
PRT50920Standard960-255M4
PPC50922Standard960-255M4
PPC50923Text960-255M4
PPC50924Photo960-255M4
50926Fax960-255M4
50927Hardcopy security printing960-255M4
08Setting modeProcessDevelopm entDeveloper bias
PRT50930Standard1050-255M4
PPC50932Standard1050-255M4
PPC50933Text1050-255M4
PPC50934Photo1050-255M4
08Setting modeProcessDevelopm entDeveloper bias correction for thin
paper
50936Fax1050-255M4
paper
50937Hardcopy security printing1050-255M4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessDevelopm entToner near empty5155Toner near empty threshold setting10-5M0: The period from the appearance of the toner near- empty sign to the actual complete consumption of the toner is set to long.
1: Normal (Default)
2: The period from the appearance of the toner near- empty sign to the actual complete consumption of the toner is set to short.
3: No detection
4: Toner near-empty status threshold value: (%)*
5: Toner near-empty status threshold value: (Number of sheets)*
* The toner near-empty status is displayed if the remaining amount of toner is equal to or less than the amount set in 08-5810/5811 (percentage or number of sheets).
1Yes
08Setting modeProcessDevelopm entToner near emptyFine adjustment of threshold for displaying remaining toner and toner near empty51563K10050-150MAdjusts the threshold value for displaying remaining amount of toner and toner near empty.
Display threshold value = default threshold value x setting value/100 (unit: %)
08Setting modeProcessFuserFusing correction control time immediately after warming-up521001st temperature correction20~15M0: Disabled, 1: 1 min. 2: 2 min. 3: 3 min. 4: 4 min. 5:
5 min. 6: 6 min. 7: 7 min. 8: 8 min. 9: 10 min. 10: 15
min. 11: 10 sec. 12: 20 sec. 13: 30 sec. 14: 40 sec.
15: 50 sec.
08Setting modeProcessFuserFusing correction control time immediately after warming-up52101Maximum time of lamp ON20~15M0: Disabled, 1: 1 min. 2: 2 min. 3: 3 min. 4: 4 min. 5:
15: 50 sec.
08Setting modeProcessFuserFusing correction control time immediately after warming-up521022nd temperature correction130~15M0: Disabled, 1: 1 min. 2: 2 min. 3: 3 min. 4: 4 min. 5:
15: 50 sec.
* This code is valid for e-STUDIO357/457/507 only.
08Setting modeProcessFuser5285Fusing temperature during printing (Plain paper/Sub)Refer to contents0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
C 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10: 190°C 11:
195°C 12: 200°C 13: 130°C 14: 135°C
<Default value>
e-STUDIO207L/257/307: - e-STUDIO357/457/507: 3
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser5328Fusing temperature during printing (Thick paper 1/Sub)Refer to contents0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
e-STUDIO207L/257/307: - e-STUDIO357/457/507: 6
08Setting modeProcessFuser5329Fusing temperature during printing (Thick paper 2/Sub)Refer to contents0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
e-STUDIO207L/257/307: - e-STUDIO357/457/507: 8
08Setting modeProcessFuser5330Fusing temperature during printing (Thick paper 3/Sub)Refer to contents0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuser5331Fusing temperature during printing (Overhead transparencies /Sub)Refer to contents0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
e-STUDIO207L/257/307: - e-STUDIO357/457/507: 4
08Setting modeProcessFuser5332Fusing temperature during printing (Envelope/Sub)Refer to contents0 to 14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuserTemperature drop during printing (Sub)Normal temperature53330The first drop00 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)Normal temperature53331The second drop00 to 10MSetting value x -5°C: from 0°C to -50°C
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop during printing (Sub)Normal temperature53332The third drop00 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)Normal temperature53333The forth drop00 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)Low temperature53334The first drop10 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)Low temperature53335The second drop10 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)Low temperature53336The third drop10 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)Low temperature53337The forth drop10 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)High temperature53338The first drop20 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)High temperature53339The second drop40 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)High temperature533310The third drop40 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing (Sub)High temperature533311The forth drop40 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop switching time setting (Sub)53340The first drop50 to 200MSetting value x 5 seconds: from 0 to 1000 seconds
08Setting modeProcessFuserTemperature drop switching time setting (Sub)53341The second drop120 to 200MSetting value x 5 seconds: from 0 to 1000 seconds
08Setting modeProcessFuserTemperature drop switching time setting (Sub)53342The third drop240 to 200MSetting value x 5 seconds: from 0 to 1000 seconds
08Setting modeProcessFuserTemperature drop switching time setting (Sub)53343The forth drop360 to 200MSetting value x 5 seconds: from 0 to 1000 seconds
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)Normal temperature53350The first drop20 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)Normal temperature53351The second drop20 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)Normal temperature53352The third drop20 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)Normal temperature53353The forth drop20 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)Low temperature53354The first drop10 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)Low temperature53355The second drop10 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)Low temperature53356The third drop10 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)Low temperature53357The forth drop10 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)High temperature53358The first drop20 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)High temperature53359The second drop40 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)High temperature533510The third drop40 to 10MSetting value x -5°C: from 0°C to -50°C
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop during printing on thick paper (Sub)High temperature533511The forth drop40 to 10MSetting value x -5°C: from 0°C to -50°C
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Sub)53360The first drop50 to 200MSetting value x 5 seconds: from 0 to 1000 seconds
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Sub)53361The second drop120 to 200MSetting value x 5 seconds: from 0 to 1000 seconds
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Sub)53362The third drop240 to 200MSetting value x 5 seconds: from 0 to 1000 seconds
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Sub)53363The fourth drop360 to 200MSetting value x 5 seconds: from 0 to 1000 seconds
08Setting modeProcessFuserCorrection of temperature rising prevention (Latest value)53370Ready00~15M0: 0℃ 1: -1℃ 2: -2℃ 3: -3℃ 4: -4℃ 5: -5℃ 6: -6℃
7: -7℃ 8: -8℃ 9: -9℃ 10: -10℃ 11: -11℃ 12: -12℃
13: -13℃ 14: -14℃ 15: -15℃
08Setting modeProcessFuserCorrection of temperature rising prevention (Latest value)53371Print00~15M0: 0℃ 1: -1℃ 2: -2℃ 3: -3℃ 4: -4℃ 5: -5℃ 6: -6℃
08Setting modeProcessFuser5469Enable/Disable setting of energy saving controlRefer to contents0-1M0: Disabled 1: Enabled
<Default value> e-STUDIO357: 1
e-STUDIO457/507: 0
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser5497Maximum lamp ON period at energy saving control (supplementary)Refer to contents0-60M0: Disabled
Setting value x 1 sec.
<Default value> e-STUDIO357: 5
e-STUDIO457/507: 0
08Setting modeProcessFuser5498Minimum lamp OFF period at energy saving control (supplementary)Refer to contents0-60M0: Disabled
<Default value>
e-STUDIO357: 38
e-STUDIO457/507: 0
08Setting modeCounterMaintenan ce5554PM counter setting value for developer material (K)Refer to content8 digitsMSets the number of printed sheets to display the message that prompts the PM of developer material.
<Default value> e-STUDIO207L:
JPD: 0
Other: 80000 e-STUDIO257:
JPD: 0
Other: 100000 e-STUDIO307:
JPD: 0
Other: 120000 e-STUDIO357:
JPD: 0
Other: 125000 e-STUDIO457:
JPD: 0
Other: 150000 e-STUDIO507:
JPD: 0
Other: 150000
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterMaintenan ce5555PM time counter setting value for developer material (K)Refer to contents8 digitsMSets the accumulated driving time to display the message that prompts the PM of developer material.
<Default value>
e-STUDIO207L/257/307: 161000
e-STUDIO357/457/507: 135000
08Setting modeCounterMaintenan ce5562PM counter setting value for partRefer to content8 digitsMSets the number of printed sheets to display the message that prompts the PM of part.
JPD: 0
Other: 240000 e-STUDIO257:
JPD: 0
Other: 200000 e-STUDIO307:
JPD: 0
Other: 240000 e-STUDIO357:
JPD: 0
Other: 250000 e-STUDIO457:
JPD: 0
Other: 300000 e-STUDIO507:
JPD: 0
Other: 300000
08Setting modeCounterMaintenan ce5563PM time counter setting value for partRefer to content8 digitsMSets the accumulated driving time to display the message that prompts the PM of part.
<Default value>
e-STUDIO207L: 483000
e-STUDIO257/307: 322000
e-STUDIO357/457/507: 270000
08Setting modeCounterMaintenan ce5568Current value of PM counter for developer material (K)08 digitsMDisplays the current number of printed sheets. Counts up by turning on the registration sensor.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterMaintenan ce5569Current value of PM time counter for developer material (K)08 digitsMDisplays the current driving time.1
08Setting modeCounterMaintenan ce5576Current value of PM counter for part08 digitsMDisplays the current number of printed sheets. Counts up by turning on the registration sensor.1
08Setting modeCounterMaintenan ce5577Current value of PM time counter for part08 digitsMDisplays the current driving time of fuser.1
08Setting modeCounterMaintenan ce5581Switching of output pages/driving counts at PM/developer material (K)00~2M0: Pages 1: driving count 2: Whichever comes faster1
08Setting modeCounterMaintenan ce5585Switching of output pages/driving counts at PM/part00~2M0: Pages 1: driving count 2: Whichever comes faster1
08Setting modeProcessDevelopm entToner near empty5810Toner near-empty status threshold value setting (%)31-99MThis code is used when the value of 08-5155 is set to "4". Use this code to specify the threshold value (unit:
%) for displaying the toner near-empty status. The accuracy of value is influenced by usage environment or originals.
08Setting modeProcessDevelopm entToner near empty5811Toner near-empty status threshold value setting (number of sheets)10001-9999MThis code is used when the value of 08-5155 is set to "5". Use this code to specify the threshold value (unit: number of sheets) for displaying the toner near-empty status. The accuracy of value is influenced by usage environment or originals.1
08Setting modeCounterDouble countFor fee chargingPaper size6010Large-sized paperRefer to contents0~2M0: Counted as 1 1: Counted as 2 2: Counted as 1 (Mechanical counter is double counter)
<Default value> JPN: 0
OTHER: 1
1Yes
08Setting modeCounterDouble countFor fee chargingPaper size6011Definition setting of large sized paper00~1M0: A3/LD 1: A3/LD/B4/LG/FOLIO/COMP/8K1Yes
08Setting modeCounterDouble countFor PMPaper size6012Large-sized paper10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterDouble countFor PMPaper size6013Definition setting of large sized paper10~1M0: A3/LD 1: A3/LD/B4/LG/FOLIO/COMP1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterDouble countFor PMPaper type6014Thick paper10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterDouble countFor PMPaper type6015OHP10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterDouble countFor PMPaper type6016Envelope10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterDouble countFor PMPaper type6017Tab paper10~1M0: Counted as 1 1: Counted as 21Yes
08Setting modeCounterCounterDisplay of number of output pages in copier functionPPC60630Large08 digitsSYSCounts the number of output pages in the Copier Function according to its size (large/small).
Large: Number of output pages of large-sized paper defined at 08-6011
Small: Number of output pages other than set as large- sized paper
Total: Total number output pages of all paper sizes.
08Setting modeCounterCounterDisplay of number of output pages in copier functionPPC60631Small08 digitsSYSCounts the number of output pages in the Copier Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of output pages in printer functionPRT60640Large08 digitsSYSCounts the number of output pages in the Printer Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of output pages in printer functionPRT60641Small08 digitsSYSCounts the number of output pages in the Printer Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of output pages at list print modePRT60650Large08 digitsSYSCounts the number of output pages at the List Print Mode Function according to its size (large/small). Large: Number of output pages of large-sized paper defined at 08-6011
paper
08Setting modeCounterCounterDisplay of number of output pages at list print modePRT60651Small08 digitsSYSCounts the number of output pages at the List Print Mode Function according to its size (large/small). Large: Number of output pages of large-sized paper defined at 08-6011
paper
08Setting modeCounterCounterDisplay of number of output pages in FAX functionPRT60660Large08 digitsSYSCounts the number of output pages in the FAX Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of output pages in FAX functionPRT60661Small08 digitsSYSCounts the number of output pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages at Full Color Mode in Scanning FunctionSCN60680Large08 digitsSYSCounts the number of scanning pages at the Full Color Mode in the Scanning Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages at Full Color Mode in Scanning FunctionSCN60681Small08 digitsSYSCounts the number of scanning pages at the Full Color Mode in the Scanning Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in copier functionPPC60700Large08 digitsSYSCounts the number of scanning pages in the Copier Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of scanning pages in copier functionPPC60701Small08 digitsSYSCounts the number of scanning pages in the Copier Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in FAX functionFAX60710Large08 digitsSYSCounts the number of scanning pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in FAX functionFAX60711Small08 digitsSYSCounts the number of scanning pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of scanning pages in scanning functionSCN60720Large08 digitsSYSCounts the number of scanning pages in the Scanning Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of scanning pages in scanning functionSCN60721Small08 digitsSYSCounts the number of scanning pages in the Scanning Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of transmitted pages in FAX functionFAX60730Large08 digitsSYSCounts the number of transmitted pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of transmitted pages in FAX functionFAX60731Small08 digitsSYSCounts the number of transmitted pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCounterDisplay of number of received pages in FAX functionFAX60740Large08 digitsSYSCounts the number of received pages in the FAX Function according to its size (large/small).
paper
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterDisplay of number of received pages in FAX functionFAX60741Small08 digitsSYSCounts the number of received pages in the FAX Function according to its size (large/small).
paper
08Setting modeCounterCustom counterFor dealer6080Enabling/Disabling custom counter00~1SYSWhen this setting is enabled, the custom counter of total counter is enabled. Related code: 08-6088, 6089. When this setting is enabled, 08-6010 does not affect the total counter. Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
1Yes
08Setting modeCounterCustom counter/Jo b QuotaFor administratorWeighting/Scanning60810Black/Gray00~9999SYSWeights subtraction of scanning from department/user Job Quota and addition of Scan Counter to Custom Counter.
0 (weight: 0.00) – 9999 (weight: 99.99)
4Yes
08Setting modeCounterCustom counter/Jo b QuotaFor administratorWeighting/Scanning60811Full Color00~9999SYSWeights subtraction of scanning from department/user Job Quota and addition of Scan Counter to Custom Counter.
4Yes
08Setting modeCounterDouble count setting for paper type60831Thick1/2/3/4 (Back)Refer to contents0~1SYSSets the weight of fee charging count for printing per page. Scan counter and fax counter are not influenced. 0: Single
1: Double
<Default value> JPD/CND: 0
Others: 1
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingCounterDouble60832Special1/2 (Back)Refer to0~1SYSSets the weight of fee charging count for printing per4Yes
modecountcontentspage. Scan counter and fax counter are not influenced.
setting for0: Single
paper type1: Double
<Default value>
JPD/CND: 0
Others: 1
08SettingCounterDouble60833TransparencyRefer to0~1SYSSets the weight of fee charging count for printing per4Yes
paper type1: Double
<Default value>
JPD/CND: 0
Others: 1
08SettingCounterDouble60834EnvelopRefer to0~1SYSSets the weight of fee charging count for printing per4Yes
paper type1: Double
<Default value>
JPD/CND: 0
Others: 1
08SettingCounterDouble60835Tab paperRefer to0~1SYSSets the weight of fee charging count for printing per4Yes
paper type1: Double
<Default value>
JPD/CND: 0
Others: 1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCustom counter/Jo b QuotaFor administrator6084Enabling/Disabling custom counter/Job Quota00-1SYSWhen this setting is enabled, the custom counter and Job Quota of department/user are enabled. Related code: 08-6081, 6085.
When this setting is enabled, 08-6010 does not affect the counter/Quota of department/user.
1Yes
08Setting modeCounterCustom counter/Jo b QuotaFor administratorWeighting/Print60850Black/Small1000~9999SYSWeights subtraction of printing from department/user Job Quota and addition of printing to Custom Counter. 0 (weight: 0.00) – 9999 (weight: 99.99)4
08Setting modeCounterCustom counter/Jo b QuotaFor administratorWeighting/Print60851Black/Large1000~9999SYSWeights subtraction of printing from department/user Job Quota and addition of printing to Custom Counter. 0 (weight: 0.00) – 9999 (weight: 99.99)4
08Setting ModeCounterCounter Settings6087Color/Black quota selection at twin/mono color count00-1SYSWhen the pages are counted for twin/mono color counter, this code sets whether the pages are subtracted from ColorQuota or BlackQuota.
Not all the pages of TwinColor/MonoColor are subtracted. The pages assigned to twin/mono color counter are subtracted. The setting of this code is enabled only in the Color/BlackQuota mode and not enabled in the JobQuota mode.
If the value of this code is set to "0" (ColorQuota), an error occurs if a user without color permission performs twin color printing. Note that the same error occurs in the JobQuota mode.
0: ColorQuota 1: BlackQuota Related code:
08-6084, 08-9128, 08-9892
08Setting ModeCounterCustom counterFor dealerWeighting/Scanning60880Black/Gray00-9999SYSWeights addition of Scan Counter to Custom Counter (Total Counter). Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeCounterCustom counterFor dealerWeighting/Scanning60881Full Color00-9999SYSWeights addition of Scan Counter to Custom Counter (Total Counter). Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
4Yes
08Setting ModeCounterCustom counterFor dealerWeighting/Print60890Black/Small1000-9999SYSWeights addition of print to Custom Counter (Total Counter). Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
4Yes
08Setting ModeCounterCustom counterFor dealerWeighting/Print60891Black/Large1000-9999SYSWeights addition of print to Custom Counter (Total Counter). Since the count is calculated based on the existing Large/Small counter, the count before changing this setting is also included in the count.
4Yes
08Setting ModeCounterCustom counterFor dealer6090Truncation after decimal point of custom counter value00-1SYSSets the display method of custom counter value of total counter.
When the value is displayed as integer, the total counter value (total value of each color) is sum of the truncated custom counter value of each color. Note that the value is slightly decreases compared to display with decimal point.
0: Displays 2 decimal places.
1: Displays integer (Truncation after decimal point)
1Yes
08Setting ModeCounterCustom counterFor dealer6091Output of annotation for custom counter10-1SYSSets whether the annotation "Custom Counter is result of..." for custom counter of total counter is output or not. 0: Annotation is not output
1: Annotation is output
1Yes
08Setting modeCounterCounter of Paper feed6110Upper drawer08 digitsMCounts the number of sheets fed from upper drawer2Yes
08Setting modeCounterCounter of Paper feed6111Lower drawer08 digitsMCounts the number of sheets fed from lower drawer2Yes
08Setting modeCounterCounter of Paper feed6112Bypass feed08 digitsMCounts the number of sheets fed from bypass feed2Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounter of Paper feed6113LCF08 digitsMCounts the number of sheets fed from LCF2Yes
08Setting modeCounterCounter of Paper feed6114PFP upper drawer08 digitsMCounts the number of sheets fed from PFP upper drawer2Yes
08Setting modeCounterCounter of Paper feed6115PFP lower drawer08 digitsMCounts the number of sheets fed from PFP lower drawer2Yes
08Setting modeCounterCounter of Paper feed6116ADU08 digitsMCounts the number of output pages of duplex printing.2Yes
08Setting modeCounterCounter of Paper feed6117RADF08 digitsSYSCounts the number of originals fed from RADF2Yes
08Setting modeCounterMaintenan cePM counterK6190Setting valueRefer to contents8 digitsM<Default>
e-STUDIO207L: JPD: 0
JPD: 0
JPD: 0
JPD: 0
Other: 125000
e-STUDIO457/507: JPD: 0
Other: 150000
1Yes
08Setting modeCounterMaintenan cePM drive counterK6191Setting valueRefer to contents8 digitsMTime accumulating counter
<Default value>
e-STUDIO207L/257/307: JPD: 0
Other: 161000
e-STUDIO357/457/507: JPD: 0
Other: 135000
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterMaintenan cePM counterK6194Current value08 digitsMCounts up when the registration sensor is ON.1Yes
08Setting modeCounterMaintenan cePM drive counterK6195Current value08 digitsMCounts the drum driving time.1Yes
08Setting modeCounterMaintenan ce6198Switching of output pages/ driving counts at K-PM00~2MSelects the reference to notify the PM timing. (The message is displayed on the LCD screen.)
0: PM counter (The number of output pages is set at 08-6190.)
1: PM time counter (The timing is set at 08-6191.) 2: Whichever comes faster
08Setting modeCounterCounter6225Number of output pages(Thick paper 1)08 digitsMCounts up when the registration sensor is ON. When the counter value of the fuser roller is cleared, this counter value is also cleared in sync at the PM support mode.1
08Setting modeCounterCounter6226Number of output pages(Thick paper 2)08 digitsMCounts up when the registration sensor is ON. When the counter value of the fuser roller is cleared, this counter value is also cleared in sync at PM support mode.1
08Setting modeCounterCounter6227Number of output pages(Thick paper 3)08 digitsMCounts up when the registration sensor is ON. When the counter value of the fuser roller is cleared, this counter value is also cleared in sync at PM support mode.1
08Setting modeCounterCounter6228Number of output pages (OHP film)08 digitsMCounts up when the registration sensor is ON. When the counter value of the fuser roller is cleared, this counter value is also cleared in sync at PM support mode.1
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6230Upper drawer08 digitsMCounts the number of times of the feeding retry from the upper drawer.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6231Lower drawer08 digitsMCounts the number of times of the feeding retry from the lower drawer.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6232PFP upper drawer08 digitsMCounts the number of times of the feeding retry from the PFP upper drawer.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6233PFP lower drawer08 digitsMCounts the number of times of the feeding retry from the PFP lower drawer.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6234Bypass feed08 digitsMCounts the number of times of the feeding retry from the bypass tray.1Yes
08Setting modeCounterFeeding system/Pa per transportFeeding retry counter6235LCF08 digitsMCounts the number of times of the feeding retry from the LCF.1Yes
08Setting modeCounterPaper feeding6236Feeding retry counter upper limit value(Upper drawer)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6237Feeding retry counter upper limit value(Lower drawer)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6238Feeding retry counter upper limit value(PFP upper drawer)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6239Feeding retry counter upper limit value(PFP lower drawer)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterPaper feeding6240Feeding retry counter upper limit value(Bypass feed)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPaper feeding6241Feeding retry counter upper limit value(Tandem LCF)08 digitsMWhen the number of feeding retry (08-6230 to 08-6235) exceeds the setting value, the feeding retry will not be performed subsequently. In case "0" is set as a setting value, however, the feeding retry continues regardless of the counter setting value.1
08Setting modeCounterCounter6244Counter for tab paper08 digitsMCounts up when the registration sensor is ON in the tab paper mode.1
08Setting modeCounterCounter6247Counter for envelope08 digitsMCounts up when the registration sensor is ON.
When the counter value of the fuser roller is reset, this counter is reset in sync at the PM support mode.
1Yes
08Setting modeCounterPM
counter
Photoconductive drum62500Present number of output pages08 digitsM4
counter
Photoconductive drum62501Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
e-STUDIO207L: 80,000
e-STUDIO257: 100,000
e-STUDIO307: 120,000
e-STUDIO357: 125,000
e-STUDIO457/507: 150,000
counter
Photoconductive drum62502Number of output
pages at the last replacement
08 digitsM4
counter
Photoconductive drum62503Present driving counts08 digitsM4
counter
Photoconductive drum62504Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
e-STUDIO207L/257/307: 161,000
e-STUDIO357/457/507: 135,000
counter
Photoconductive drum62505Driving counts at the last replacement08 digitsM4
counter
Photoconductive drum62506Present output pages for control08 digitsM4
counter
Photoconductive drum62507Present driving counts for control08 digitsM4
counter
Photoconductive drum62508Number of times replaced08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Photoconductive drum6251-Date of previous replacement08 digitsM2
counter
Drum cleaning blade62580Present number of output pages08 digitsM4
counter
Drum cleaning blade62581Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Drum cleaning blade62582Number of output
08 digitsM4
counter
Drum cleaning blade62583Present driving counts08 digitsM4
counter
Drum cleaning blade62584Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Drum cleaning blade62585Driving counts at the last replacement08 digitsM4
counter
Drum cleaning blade62586Present output pages for control08 digitsM4
counter
Drum cleaning blade62587Present driving counts for control08 digitsM4
counter
Drum cleaning blade62588Number of times replaced08 digitsM4
counter
Drum cleaning blade6259-Date of previous replacement08 digitsM2
counter
Drum separation finger62720Present number of output pages08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Drum separation finger62721Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Drum separation finger62722Number of output
08 digitsM4
counter
Drum separation finger62723Present driving counts08 digitsM4
counter
Drum separation finger62724Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Drum separation finger62725Driving counts at the last replacement08 digitsM4
counter
Drum separation finger62726Present output pages for control08 digitsM4
counter
Drum separation finger62727Present driving counts for control08 digitsM4
counter
Drum separation finger62728Number of times replaced08 digitsM4
counter
Drum separation finger6273-Date of previous replacement08 digitsM2
counter
Charger grid62740Present number of output pages08 digitsM4
counter
Charger grid62741Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Charger grid62742Number of output pages at the last
replacement
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Charger grid62743Present driving counts08 digitsM4
counter
Charger grid62744Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Charger grid62745Driving counts at the last replacement08 digitsM4
counter
Charger grid62746Present output pages for control08 digitsM4
counter
Charger grid62747Present driving counts for control08 digitsM4
counter
Charger grid62748Number of times replaced08 digitsM4
counter
Charger grid6275-Date of previous replacement08 digitsM2
counter
Charger (Wire)62820Present number of output pages08 digitsM4
counter
Charger (Wire)62821Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Charger (Wire)62822Number of output
08 digitsM4
counter
Charger (Wire)62823Present driving counts08 digitsM4
counter
Charger (Wire)62824Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Charger (Wire)62825Driving counts at the last replacement08 digitsM4
counter
Charger (Wire)62826Present output pages for control08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Charger (Wire)62827Present driving counts for control08 digitsM4
counter
Charger (Wire)62828Number of times replaced08 digitsM4
counter
Charger (Wire)6283-Date of previous replacement08 digitsM2
counter
Ozone filter62980Present number of output pages08 digitsM4
counter
Ozone filter62981Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
e-STUDIO207L: 240,000
e-STUDIO257: 200,000
e-STUDIO307: 240,000
e-STUDIO357: 250,000
e-STUDIO457/507: 300,000
counter
Ozone filter62982Number of output
08 digitsM4
counter
Ozone filter62983Present driving counts08 digitsM4
counter
Ozone filter62984Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
e-STUDIO207L: 483,000
e-STUDIO257/307: 322,000
e-STUDIO357/457/507: 270,000
counter
Ozone filter62985Driving counts at the last replacement08 digitsM4
counter
Ozone filter62986Present output pages for control08 digitsM4
counter
Ozone filter62987Present driving counts for control08 digitsM4
counter
Ozone filter62988Number of times replaced08 digitsM4
counter
Ozone filter6299-Date of previous replacement08 digitsM2
counter
Developer material63000Present number of output pages08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Developer material63001Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Developer material63002Number of output
08 digitsM4
counter
Developer material63003Present driving counts08 digitsM4
counter
Developer material63004Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Developer material63005Driving counts at the last replacement08 digitsM4
counter
Developer material63006Present output pages for control08 digitsM4
counter
Developer material63007Present driving counts for control08 digitsM4
counter
Developer material63008Number of times replaced08 digitsM4
counter
Developer material6301-Date of previous replacement08 digitsM2
counter
Transfer (wire/belt/ roller)63140Present number of output pages08 digitsM4
counter
Transfer (wire/belt/ roller)63141Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Transfer (wire/belt/ roller)63142Number of output pages at the last
replacement
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Transfer (wire/belt/ roller)63143Present driving counts08 digitsM4
counter
Transfer (wire/belt/ roller)63144Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Transfer (wire/belt/ roller)63145Driving counts at the last replacement08 digitsM4
counter
Transfer (wire/belt/ roller)63146Present output pages for control08 digitsM4
counter
Transfer (wire/belt/ roller)63147Present driving counts for control08 digitsM4
counter
Transfer (wire/belt/ roller)63148Number of times replaced08 digitsM4
counter
Transfer (wire/belt/ roller)6315-Date of previous replacement08 digitsM2
counter
Fuser roller63460Present number of output pages08 digitsM4
counter
Fuser roller63461Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Fuser roller63462Number of output
08 digitsM4
counter
Fuser roller63463Present driving counts08 digitsM4
counter
Fuser roller63464Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Fuser roller63465Driving counts at the last replacement08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Fuser roller63466Present output pages for control08 digitsM4
counter
Fuser roller63467Present driving counts for control08 digitsM4
counter
Fuser roller63468Number of times replaced08 digitsM4
counter
Fuser roller6347-Date of previous replacement08 digitsM2
counter
Pressure roller63500Present number of output pages08 digitsM4
counter
Pressure roller63501Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Pressure roller63502Number of output
08 digitsM4
counter
Pressure roller63503Present driving counts08 digitsM4
counter
Pressure roller63504Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Pressure roller63505Driving counts at the last replacement08 digitsM4
counter
Pressure roller63506Present output pages for control08 digitsM4
counter
Pressure roller63507Present driving counts for control08 digitsM4
counter
Pressure roller63508Number of times replaced08 digitsM4
counter
Pressure roller6351-Date of previous replacement08 digitsM2
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Fuser roller separation finger63680Present number of output pages08 digitsM4
counter
Fuser roller separation finger63681Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Fuser roller separation finger63682Number of output
08 digitsM4
counter
Fuser roller separation finger63683Present driving counts08 digitsM4
counter
Fuser roller separation finger63684Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Fuser roller separation finger63685Driving counts at the last replacement08 digitsM4
counter
Fuser roller separation finger63686Present output pages for control08 digitsM4
counter
Fuser roller separation finger63687Present driving counts for control08 digitsM4
counter
Fuser roller separation finger63688Number of times replaced08 digitsM4
counter
Fuser roller separation finger6369-Date of previous replacement08 digitsM2
counter
Pickup roller (RADF)63820Present number of output pages08 digitsSYS4
counter
Pickup roller (RADF)63821Recommended number of output pages for replacement120,0008 digitsSYS4
counter
Pickup roller (RADF)63822Number of output
08 digitsSYS4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Pickup roller (RADF)63828Number of times replaced08 digitsSYS4
counter
Pickup roller (RADF)6383-Date of previous replacement08 digitsSYS2
counter
Feed roller (RADF)63840Present number of output pages08 digitsSYS4
counter
Feed roller (RADF)63841Recommended number of output pages for replacement120,0008 digitsSYS4
counter
Feed roller (RADF)63842Number of output
08 digitsSYS4
counter
Feed roller (RADF)63848Number of times replaced08 digitsSYS4
counter
Feed roller (RADF)6385-Date of previous replacement08 digitsSYS2
counter
Separation roller (RADF)63860Present number of output pages08 digitsSYS4
counter
Separation roller (RADF)63861Recommended number of output pages for replacement120,0008 digitsSYS4
counter
Separation roller (RADF)63862Number of output
08 digitsSYS4
counter
Separation roller (RADF)63868Number of times replaced08 digitsSYS4
counter
Separation roller (RADF)6387-Date of previous replacement08 digitsSYS2
counter
Pickup roller (Upper drawer of equipment)63900Present number of output pages08 digitsM4
counter
Pickup roller (Upper drawer of equipment)63901Recommended number of output pages for replacement80,0008 digitsM4
counter
Pickup roller (Upper drawer of equipment)63902Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Pickup roller (Upper drawer of equipment)63908Number of times replaced08 digitsM4
counter
Pickup roller (Upper drawer of equipment)6391-Date of previous replacement08 digitsM2
counter
Pickup roller (Lower drawer of equipment)63920Present number of output pages08 digitsM4
counter
Pickup roller (Lower drawer of equipment)63921Recommended number of output pages for replacement80,0008 digitsM4
counter
Pickup roller (Lower drawer of equipment)63922Number of output
08 digitsM4
counter
Pickup roller (Lower drawer of equipment)63928Number of times replaced08 digitsM4
counter
Pickup roller (Lower drawer of equipment)6393-Date of previous replacement08 digitsM2
counter
Pickup roller (Optional LCF)63940Present number of output pages08 digitsM4
counter
Pickup roller (Optional LCF)63941Recommended number of output pages for replacement160,0008 digitsM4
counter
Pickup roller (Optional LCF)63942Number of output
08 digitsM4
counter
Pickup roller (Optional LCF)63948Number of times replaced08 digitsM4
counter
Pickup roller (Optional LCF)6395-Date of previous replacement08 digitsM2
counter
Feed roller (Upper drawer of equipment)63980Present number of output pages08 digitsM4
counter
Feed roller (Upper drawer of equipment)63981Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Upper drawer of equipment)63982Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Feed roller (Upper drawer of equipment)63988Number of times replaced08 digitsM4
counter
Feed roller (Upper drawer of equipment)6399-Date of previous replacement08 digitsM2
counter
Feed roller (Lower drawer of equipment)64000Present number of output pages08 digitsM4
counter
Feed roller (Lower drawer of equipment)64001Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Lower drawer of equipment)64002Number of output
08 digitsM4
counter
Feed roller (Lower drawer of equipment)64008Number of times replaced08 digitsM4
counter
Feed roller (Lower drawer of equipment)6401-Date of previous replacement08 digitsM2
counter
Feed roller (Optional LCF)64020Present number of output pages08 digitsM4
counter
Feed roller (Optional LCF)64021Recommended number of output pages for replacement160,0008 digitsM4
counter
Feed roller (Optional LCF)64022Number of output
08 digitsM4
counter
Feed roller (Optional LCF)64028Number of times replaced08 digitsM4
counter
Feed roller (Optional LCF)6403-Date of previous replacement08 digitsM2
counter
Separation roller
64060Present number of output pages08 digitsM4
counter
Separation roller (Upper drawer of equipment)64061Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller
64062Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Separation roller
64068Number of times replaced08 digitsM4
counter
Separation roller
6407-Date of previous replacement08 digitsM2
counter
Separation roller
64080Present number of output pages08 digitsM4
counter
Separation roller (Lower drawer of equipment)64081Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller
64082Number of output
08 digitsM4
counter
Separation roller
64088Number of times replaced08 digitsM4
counter
Separation roller
6409-Date of previous replacement08 digitsM2
counter
Separation roller (Optional LCF)64100Present number of output pages08 digitsM4
counter
Separation roller (Optional LCF)64101Recommended number of output pages for replacement160,0008 digitsM4
counter
Separation roller (Optional LCF)64102Number of output
08 digitsM4
counter
Separation roller (Optional LCF)64108Number of times replaced08 digitsM4
counter
Separation roller (Optional LCF)6411-Date of previous replacement08 digitsM2
counter
Separation roller
(Upper drawer of PFP)
64120Present number of output pages08 digitsM4
counter
Separation roller (Upper drawer of PFP)64121Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller
64122Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Separation roller
64128Number of times replaced08 digitsM4
counter
Separation roller
6413-Date of previous replacement08 digitsM2
counter
Separation roller
(Lower drawer of PFP)
64140Present number of output pages08 digitsM4
counter
Separation roller (Lower drawer of PFP)64141Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller
64142Number of output
08 digitsM4
counter
Separation roller
64148Number of times replaced08 digitsM4
counter
Separation roller
6415-Date of previous replacement08 digitsM2
counter
Separation roller (Bypass unit)64160Present number of output pages08 digitsM4
counter
Separation roller (Bypass unit)64161Recommended number of output pages for replacement80,0008 digitsM4
counter
Separation roller (Bypass unit)64162Number of output
08 digitsM4
counter
Separation roller (Bypass unit)64168Number of times replaced08 digitsM4
counter
Separation roller (Bypass unit)6417-Date of previous replacement08 digitsM2
counter
Feed roller (Upper drawer of PFP)64200Present number of output pages08 digitsM4
counter
Feed roller (Upper drawer of PFP)64201Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Upper drawer of PFP)64202Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Feed roller (Upper drawer of PFP)64208Number of times replaced08 digitsM4
counter
Feed roller (Upper drawer of PFP)6421-Date of previous replacement08 digitsM2
counter
Feed roller (Lower drawer of PFP)64220Present number of output pages08 digitsM4
counter
Feed roller (Lower drawer of PFP)64221Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Lower drawer of PFP)64222Number of output
08 digitsM4
counter
Feed roller (Lower drawer of PFP)64228Number of times replaced08 digitsM4
counter
Feed roller (Lower drawer of PFP)6423-Date of previous replacement08 digitsM2
counter
Feed roller (Bypass unit)64240Present number of output pages08 digitsM4
counter
Feed roller (Bypass unit)64241Recommended number of output pages for replacement80,0008 digitsM4
counter
Feed roller (Bypass unit)64242Number of output
08 digitsM4
counter
Feed roller (Bypass unit)64248Number of times replaced08 digitsM4
counter
Feed roller (Bypass unit)6425-Date of previous replacement08 digitsM2
counter
Pickup roller (Upper drawer of PFP)64280Present number of output pages08 digitsM4
counter
Pickup roller (Upper drawer of PFP)64281Recommended number of output pages for replacement80,0008 digitsM4
counter
Pickup roller (Upper drawer of PFP)64282Number of output
08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Pickup roller (Upper drawer of PFP)64288Number of times replaced08 digitsM4
counter
Pickup roller (Upper drawer of PFP)6429-Date of previous replacement08 digitsM2
counter
Pickup roller (Lower drawer of PFP)64300Present number of output pages08 digitsM4
counter
Pickup roller (Lower drawer of PFP)64301Recommended number of output pages for replacement80,0008 digitsM4
counter
Pickup roller (Lower drawer of PFP)64302Number of output
08 digitsM4
counter
Pickup roller (Lower drawer of PFP)64308Number of times replaced08 digitsM4
counter
Pickup roller (Lower drawer of PFP)6431-Date of previous replacement08 digitsM2
counter
Recovery blade64360Present number of output pages08 digitsM4
counter
Recovery blade64361Recommended number of output pages for replacementRefer to contents8 digitsM<Default value>
counter
Recovery blade64362Number of output
08 digitsM4
counter
Recovery blade64363Present driving counts08 digitsM4
counter
Recovery blade64364Recommended driving counts to be replacedRefer to contents8 digitsM<Default value>
counter
Recovery blade64365Driving counts at the last replacement08 digitsM4
counter
Recovery blade64366Present output pages for control08 digitsM4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
counter
Recovery blade64367Present driving counts for control08 digitsM4
counter
Recovery blade64368Number of times replaced08 digitsM4
counter
Recovery blade6437-Date of previous replacement08 digitsM2
08Setting modeCounterPixel counter6500Standard paper size settingRefer to contents0~1SYSSelects the standard paper size to convert it into the pixel count (%).
0: A4 1: LT
<Default value> NAD: 1
Other: 0
08Setting modeCounterPixel counter6501Pixel counter all clearing--SYSClears all information related to the pixel counter.3
08Setting modeCounterPixel counter6502Service technician reference counter clearing--SYSClears all information related to the service technician reference pixel counter.3
08Setting modeCounterPixel counter6503Toner cartridge
--SYSClears all information related to the toner cartridge reference pixel counter.3
08Setting modeCounterPixel counter6504Pixel counter display setting10~1SYSSelects whether or not to display the pixel counter on the LCD screen. 0: Displayed 1: Not displayed1
08Setting modeCounterPixel counter6505Displayed reference setting00~1SYSSelects the reference when displaying the pixel counter on the LCD screen.
0: Service technician reference 1: Toner cartridge reference
08Setting modeCounterPixel counter6506Counter setting for toner empty00~1SYS0: Number of sheets 1: Value of pixel counter1
08Setting modeCounterPixel counter6507Number of sheets for toner empty8000~999SYSSets the number of sheets for toner empty.1
08Setting modeCounterPixel counter6508Pixel counter value for toner empty351000~60000SYSSets the pixel counter value for toner empty.1
08Setting modeCounterPixel counter6509Pixel counter clear flag/Service technician reference00~1SYSBecomes "1" when 08-6502 is performed.2
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counter6510Service technician
reference cleared date
-0~9999999
SYSDisplays the date on which 08-6502 was performed.2
08Setting modeCounterPixel counter6514Toner cartridge
-0~9999999
SYSDisplays the date on which 08-6503 was performed.2
08Setting modeCounterPixel counter6522Toner cartridge
reference count started date
-0~9999999
08Setting modeCounterPixel counterNumber of output pages(Service technician reference)6558PPC08 digitsSYSCounts the number of output pages converted to the standard paper size in the copy function and service technician reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Service technician reference)6560PRT08 digitsSYSCounts the number of output pages converted to the standard paper size in the printer function and service technician reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Service technician reference)6561FAX08 digitsSYSCounts the number of output pages converted to the standard paper size in the FAX function and service technician reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Toner cartridge reference)6563PPC08 digitsSYSCounts the number of output pages converted to the standard paper size in the copy function and toner cartridge reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Toner cartridge reference)6565PRT08 digitsSYSCounts the number of output pages converted to the standard paper size in the printer function and toner cartridge reference. [Unit. page]2
08Setting modeCounterPixel counterNumber of output pages(Toner cartridge reference)6566FAX08 digitsSYSCounts the number of output pages converted to the standard paper size in the FAX function and toner cartridge reference. [Unit. page]2
08Setting modeCounterPixel counter6576Toner cartridge replacement counter03 digitsSYSCounts the number of time of the toner cartridge replacement.2
08Setting modeCounterPixel counterAverage pixel count(Service technician reference)6602PPC00~10000SYSDisplays the average pixel count in the copy function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Service technician reference)6603PRT00~10000SYSDisplays the average pixel count in the printer function and service technician reference. [Unit: 0.01%]2
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterAverage pixel count(Service technician reference)6604FAX00~10000SYSDisplays the average pixel count in the FAX function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Service technician reference)6605PPC/PRT/FAX00~10000SYSDisplays the average pixel count in the copy/printer/FAX function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterLatest pixel count(Service technician reference)6616PPC00~10000SYSDisplays the latest pixel count in the copy function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterLatest pixel count(Service technician reference)6617PRT00~10000SYSDisplays the latest pixel count in the printer function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterLatest pixel count(Service technician reference)6618FAX00~10000SYSDisplays the latest pixel count in the FAX function and service technician reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Toner cartridge reference)6623PPC00~10000SYSDisplays the average pixel count in the copy function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Toner cartridge reference)6629PRT00~10000SYSDisplays the average pixel count in the printer function, and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Toner cartridge reference)6634PPC/PRT/FAX00~10000SYSDisplays the average pixel count in the copy/printer/FAX function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterAverage pixel count(Toner cartridge reference)6635FAX00~10000SYSDisplays the average pixel count in the FAX function and toner cartridge reference. [Unit: 0.01%]2
6644FAX00~10000SYSDisplays the latest pixel count in the FAX function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterPixel count distributionPPC672100-5%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterPixel count distributionPPC672115.1-10%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721210.1-15%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721315.1-20%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721420.1-25%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721525.1-30%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721630.1-40%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721740.1-60%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721860.1-80%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPPC6721980.1-100%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the copy function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT672200-5%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT672215.1-10%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterPixel count distributionPRT6722210.1-15%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722315.1-20%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722420.1-25%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722525.1-30%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722630.1-40%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722740.1-60%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722860.1-80%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionPRT6722980.1-100%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the printer function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX672300-5%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX672315.1-10%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723210.1-15%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterPixel counterPixel count distributionFAX6723315.1-20%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723420.1-25%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723525.1-30%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723630.1-40%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723740.1-60%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723860.1-80%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterPixel count distributionFAX6723980.1-100%08 digitsSYSThe pixel count data are divided into 10 ranges. The number of output pages in each range is displayed. In this code, the distributions in the FAX function are displayed. [Unit: page]14
08Setting modeCounterPixel counterLatest pixel count/black(Toner cartridge reference)6724PPC00~10000SYSDisplays the latest pixel count in the copy function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterPixel counterLatest pixel count/black(Toner cartridge reference)6725PRT00~10000SYSDisplays the latest pixel count in the printer function and toner cartridge reference. [Unit: 0.01%]2
08Setting modeCounterCounter for toner- save modePrint in toner-save mode68200Small size/black08 digitsSYSNumber of printed sheets in the toner-save mode.4
08Setting modeCounterCounter for toner- save modePrint in non-toner- save mode68201Small size/black08 digitsSYSNumber of printed sheets in the non-toner-save mode.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounter for toner- save modePrint in toner-save mode68230Large size/black08 digitsSYSNumber of printed sheets in the toner-save mode.4
08Setting modeCounterCounter for toner- save modePrint in non-toner- save mode68231Large size/black08 digitsSYSNumber of printed sheets in the non-toner-save mode.4
08Setting modeCounterBlack job counter68520PPC08 digitsSYSCounter for monochrome copy job.4
08Setting modeCounterBlack job counter68521PRT08 digitsSYSCounter for monochrome print job.4
08Setting modeCounterBlack job counter68522PPC/PRT08 digitsSYSTotal counter for monochrome copy and print job.4
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)69770Latest01 digit or 8digitsM1 digit: Production location indicated.
-0: Cartridge not installed
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
-6: Cartridge not detected (when the IC chip information cannot be detected)
8 digits: Lot No. indicated
4Yes
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)697711 cartridge earlier01 digit or 8digitsM1 digit: Production location indicated.
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)697722 cartridges earlier01 digit or 8digitsM1 digit: Production location indicated.
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
4Yes
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)697733 cartridges earlier01 digit or 8digitsM1 digit: Production location indicated.
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
4Yes
08Setting modeCounterCounterToner cartridge usage history (Lot. No.)697744 cartridges earlier01 digit or 8digitsM1 digit: Production location indicated.
-1: TESS cartridge
-2: TABS cartridge
-3: TEIS cartridge
4Yes
08Setting modeImage Processin gImageClearing of adjustment values of all image process (PPC) related 05/08 codes7000PPC--SYScl earClears the gamma correction table values and the setting values of 05/08 codes related to image processing (PPC).3
08Setting modeImage Processin gImageClearing of all gamma correction table values (PPC related areas only)7001PPC--SYSClears all the gamma correction table values in the PPC related areas of the HDD.3
08Setting modeImage
Processin g
ImageError diffusion and dither setting7014Photo mode10~1SYSSets the image reproduction method at photo mode. 0: Error diffusion 1: Dither1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeImage Processin gImageError diffusion and dither setting7015Photo mode (Custom Mode)10~1SYSSwitches the image processing method when Custom Mode 3 is set.
08Setting modeImage Processin gUser interfaceUser mode setting7034PPC00~3SYS0: Not used 1: Text/Photo is set as a base 2: Text is set as a base
3: Photo is set as a base
1Yes
08Setting modeImage Processin gAutomatic tone correction dataLast updated date and time7051Monochrome PPC00-
421231235
SYSLast updated date and time of automatic tone correction data.
YYMMDDHHMM
YY: year, MM: month, DD: day, HH: hour, MM: minute
2Yes
08Setting ModeImage Processin gImage7300Clearing of adjustment values of all image process (network print) related 05/08 codes-M/SY
Sclea r
Clears the setting values of 05/08 codes related to image processing (NW PRT).3
08Setting ModeImage Processin gImage7400Clearing of adjustment values of all image process (network scan) related 05/08 codes-SYScl earClears the setting values of 05/08 codes related to image processing (NW SCN).3
08Setting modeImage
Processin g
User interfaceUser mode settingSCN7401Black00~3SYS0: Unused 1: Text/Photo base 2: Text base 3: Photo base1Yes
08Setting ModeImage Processin gImage7500Clearing of adjustment values of all image process (Fax) related 05/08 codes-M/SY
Sclea r
Clears the setting values of 05/08 codes related to image processing (NW FAX).3
08Setting modeImage Processin gImagePPC7617ADF scan noise reduction30-3SYSSets the adjustment level for reducing color streaks when the RADF is used.
3: Disabled (default)
2: Noise reduction level - Low
1: Noise reduction level - Middle (recommended) 0: Noise reduction level - High
