Toshiba e-STUDIO 307/357/457/507 Service Manual Part 12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Gray scale74881Medium density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4
05Adjustmen t modeImage Processin gGamma balance adjustmen tSCN(black)Gray scale74882High density1280~255SYSThe larger the value is, the darker the image of the area surrounding the target area becomes.4
05Adjustmen t modeImage Processin gImage7489Amount of surrounding void (network scanning)00~255SYSWhen the value increases, the blank area around the scanned image becomes wider. (e.g.: In network scanning with 600 dpi, if the setting value is "1", the blank area increases by 1 dot.)1
Processin g
Density
adjustmen t
FAX(black)Manual
adjustment/Center value
7533Text/Photo1280~255SYSThe larger the value is, the darker the image at the center value becomes.1
Processin g
Density
adjustmen t
FAX(black)Simple binarization
adjustmentt/Center value
7534Text1280~255SYSThe larger the value is, the darker the image at the center value becomes.1
Processin g
Density
adjustmen t
FAX(black)Manual
7535Photo1280~255SYSThe larger the value is, the darker the image at the center value becomes.1
Processin g
Density
adjustmen t
FAX(black)Automatic density adjustment7542Text/Photo1280~255SYSWhen the value increases, the image becomes darker.1
Processin g
Density
adjustmen t
FAX(black)Automatic density adjustment7543Photo1280~255SYSWhen the value increases, the image becomes darker.1
Processin g
ImageSetting beam level conversion(FAX)FAX75950Beamlevel 0/400~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
Processin g
ImageSetting beam level conversion(FAX)FAX75951Beamlevel 1/420~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
g
ImageSetting beam level conversion(FAX)FAX75952Beamlevel 2/430~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
g
ImageSetting beam level conversion(FAX)FAX75953Beamlevel 3/440~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
Processin g
ImageSetting beam level conversion(FAX)FAX75954Beamlevel 4/480~10MThe smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced.4
05Adjustmen t modeImage Processin gBlank page judgment threshold adjustmen t7618PPC/SCN1280~255SYSThe larger the value is, the more the original tends to be judged as a blank page.1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gACS
judgment threshold
7630PPC/SCN700~255SYSThe larger the value is, the more an original tends to be judged as black even at the auto color mode. The smaller value is, the more it tends to be judged as color.1Yes
05Adjustmen t modeImage Processin gStroke adjustmen tPS/PDF automatic stroke adjustment600dpi82390Default setting00-1SYSThis code is used to change the width of fine line when PS and PDF printing. Automatic stroke adjustment is the function that prevents the width from changing by position.
This code sets whether the automatic stroke adjustment is enabled or disabled if automatic stroke adjustment is not included in the print data. If this setting is disabled, the case in which the width of fine line becomes thicker by 1 dot when printed increases. 0: Disabled
05Adjustmen t modeImage Processin gStroke adjustmen tPS/PDF automatic stroke adjustment600dpi82391Minimum stroke width when disabled21-2SYSThis code is used to change the width of fine line when PS and PDF printing. Automatic stroke adjustment is the function that prevents the width from changing by position.
This code sets the minimum width of fine line when the automatic stroke adjustment is disabled. For example, if automatic stroke adjustment is disabled and the width of fine line is set to "0" in the PS command, the width of line becomes 1 dot if the value of this code is set to "1", and the width of line becomes 2 dots if the value of this code is set to "2."
1: 1 dot
2: 2 dots
05Adjustmen t modeImage Processin gJPEG
compressi on level
NW SCN(color)83040High quality1280-255SYSWhen the value increases, the quality gets better, and the file size gets larger.4
compressi on level
NW SCN(color)83041Standard1280-255SYSWhen the value increases, the quality gets better, and the file size gets larger.4
compressi on level
NW SCN(color)83042Low quality1280-255SYSWhen the value increases, the quality gets better, and the file size gets larger.4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
Backgroun
d adjustmen
SCN (color)8309Text/Photo1280~255SYSThe smaller the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
SCN (color)8310Text1280~255SYSThe smaller the value is, the lighter the background becomes.1Yes
Processin g
Backgroun
d adjustmen
SCN (color)8311Printed image1280~255SYSThe smaller the value is, the lighter the background becomes.1Yes
05Adjustmen t modeImage Processin gFine adjustmen t of black densitySCN (color)8314Text/Photo10~4SYSThe larger the value is, the darker the black side of the image becomes.1Yes
05Adjustmen t modeImage Processin gFine adjustmen t of black densitySCN (color)8315Text00~4SYSThe larger the value is, the darker the black side of the image becomes.1Yes
05Adjustmen t modeImage Processin gFine adjustmen t of black densitySCN (color)8316Printed image00~4SYSThe larger the value is, the darker the black side of the image becomes.1Yes
05Adjustmen t modeImage Processin gRGB
conversion method selection
SCN (color)8319Text/photo00~3SYSSets the color space format of the output image. 0: sRGB
1: AppleRGB
2: ROMMRGB
3: AdobeRGB
1Yes
SCN (color)8320Text00~3SYSSets the color space format of the output image. 0: sRGB
1: AppleRGB
2: ROMMRGB
3: AdobeRGB
1Yes
SCN (color)8321Printed image00~3SYSSets the color space format of the output image. 0: sRGB
1: AppleRGB
2: ROMMRGB
3: AdobeRGB
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
Processin g
Saturation
adjustmen t
SCN (color)8324Text/photo1280~255SYSThe larger the value is, the brighter the image
becomes. The smaller the value is, the duller the image becomes.
1Yes
Processin g
Saturation
adjustmen t
SCN (color)8325Text1280~255SYSThe larger the value is, the brighter the image
1Yes
Processin g
Saturation
adjustmen t
SCN (color)8326Printed image1280~255SYSThe larger the value is, the brighter the image
1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN (color)Full color8335Text1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN (color)Full color8336Printed image1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1Yes
Processin g
Density
adjustmen t
SCN (color)Manual
8339Text/photo1280~255SYSWhen the value increases, the image becomes darker.1Yes
Processin g
Density
adjustmen t
SCN (color)Manual
8340Text1280~255SYSWhen the value increases, the image becomes darker.1Yes
Processin g
Density
adjustmen t
SCN (color)Manual
8341Printed image1280~255SYSWhen the value increases, the image becomes darker.1Yes
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN (color)8354Text/photo1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Automatic density adjustment8355Text/photo1280~255SYSThe larger the value is, the lighter the background becomes. The smaller the value is, the darker it becomes.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Manual density adjustment8356Text/photo1280~255SYSThe larger the value is, the lighter the background becomes. The smaller the value is, the darker it becomes.1
Processin g
Backgroun
d adjustmen
SCN (color)8370User custom1280~255SYSWhen the value increases, the background becomes lighter.1
05Adjustmen t modeImage Processin gFine adjustmen t of black densitySCN (color)8371User custom00~4SYSAdjusts the black density of the scanned image. When the value increases, the black density becomes darker.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
SCN (color)8372User custom00~3SYSSets the color space format of the output image.
0: sRGB 1: AppleRGB 2: ROMMRGB 3: AdobeRGB
Processin g
Saturation
adjustmen t
SCN (color)8373User custom1280~255SYSThe larger the value is, the brighter the image
05Adjustmen t modeImage Processin gSharpness adjustmen tSCN (color)Full color8375User custom1280~255SYSThe larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears.1
Processin g
Density
adjustmen t
SCN (color)Manual
8380User custom1280~255SYSWhen the value increases, the image becomes darker.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Automatic density adjustment8385Text1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Automatic density adjustment8386Printed image1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Automatic density adjustment8389User custom1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Manual density adjustment8390Text1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Manual density adjustment8391Printed image1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN (color)Manual density adjustment8394User custom1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1
05Adjustmen t modeImage Processin gBackgroun d offset adjustmen tSCN(black)Automatic density adjustment8400Text/Photo1280~255SYSThe larger the value is, the less easily the background (low density area) is printed. The smaller the value is, the more easily the background (low density area) is printed.1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05Adjustmen t modeImage Processin gADF scan noise reductionSCN(color)8412User custom1000-200SYSWhen the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller.
When the value is too small, text might be blurry. When "0" is set, this function is disabled.
05Adjustmen t modeImage Processin gADF scan noise reductionSCN(color)8413Text/Photo1000-200SYSWhen the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller.
05Adjustmen t modeImage Processin gADF scan noise reductionSCN(color)8414Text1000-200SYSWhen the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller.
05Adjustmen t modeImage Processin gADF scan noise reductionSCN(color)8415Photo1000-200SYSWhen the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller.
05Adjustmen t modeSystemMaintenan ce9043Equipment number (serial number) entry--SYSWhen this adjustment is performed with this code, the
setting code (08-9601) is also performed automatically (9 digits).
05Adjustmen t modeSystemImage9104Compression quality of s SLIM PDF background processing50~10SYS0-10
0: High compression, low image quality 10: Low compression, high image quality
05Adjustmen t modeSystemImage9149Saving image position adjustment log---Saves the image position adjustment log to the USB device. Insert the USB device to the equipment before performing this code.6
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
05AdjustmenSystemGeneral9960EquipmentRefer to0~2SYSDisplays the equipment information in SRAM.2
t modeinformation(SRAM)contents0: Not set
1: Destinations other than NAD
2: NAD
<Default value>
NAD: 2
Others: 1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser2002Fuser unit error status counter00~71M0: No error 1: C411 2: C412 3: C443 5: C445 6:
C450 7: C447 8: C447 9: C449 19: C449 21: C449
22: C449 23: C449 25: C449 27: C449 29: C449 45:
C449 62: C452
Other than listed above: C4B0
08Setting modeProcessFuser2009Fuser roller temperature on standby(Center thermistor)Refer to contents0~12M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
165°C 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10:
190°C 11: 130°C 12: 135°C
<Default value>
e-STUDIO207L/257/307: 2
e-STUDIO357/457/507: 4
08Setting modeProcessFuser2010Fuser roller temperature during printing(Center thermistor/Plain paper)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
190°C 11: 195°C 12: 200°C 13: 135°C 14: 135°C
<Default value>
08Setting modeProcessFuser2028Fuser roller temperature during printing(Center thermistor/Thick paper 3)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
190°C 11: 195°C 12: 200°C 13: 130°C 14: 135°C
<Default value>
e-STUDIO207L/257/307: 4
e-STUDIO357/457/507: 8
08Setting modeProcessFuser2031Pre-running time for first printing(Thick paper 3)100~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec. 6: 6 sec. 7: 7 sec. 8: 8 sec. 9: 9 sec. 10: 10 sec.
11: 12 sec. 12: 14 sec. 13: 16 sec. 14: 18 sec. 15: 20
sec.
08Setting modeProcessFuser2040Drop control when ready00~2M0: Invalid, 1:Valid, 2: Invalid in low temperature1
08Setting modeProcessFuserTemperature drop setting in ready status (Center thermistor)20410The first drop10~10MSetting value x -5°C: from 0°C to -50°C4
08Setting modeProcessFuserTemperature drop setting in ready status (Center thermistor)20411The second drop10~10MSetting value x -5°C: from 0°C to -50°C4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop setting in ready status (Center thermistor)20412The third drop10~10MSetting value x -5°C: from 0°C to -50°C4
08Setting modeProcessFuserTemperature drop setting in ready status (Center thermistor)20413The fourth drop10~10MSetting value x -5°C: from 0°C to -50°C4
08Setting modeProcessFuserEnergy Saving ModeFuser roller temperature2042Center thermistor00~13M0: OFF 1: 40°C 2: 50°C 3: 60°C 4: 70°C 5: 80°C 6: 90°
C 7: 100°C 8: 110°C 9: 120°C 10: 130°C 11: 140°C
12: 150°C 13: 160°C
1Yes
08Setting modeProcessFuser2049Fuser roller temperature during printing(Center thermistor/Thick paper 1)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
e-STUDIO357/457/507: 6
08Setting modeProcessFuser2050Fuser roller temperature during printing(Center thermistor /Thick paper 2)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
08Setting modeProcessFuser2051Fuser roller temperature during printing(Center thermistor/OHP film)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
08Setting modeProcessFuser2052Pre-running time for first printing (OHP film)00~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec.
08Setting modeProcessFuser2053Pre-running time for first printing(Plain paper/Low temperature)00~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser2054Pre-running time for first printing(Thick paper 1)100~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec.
08Setting modeProcessFuser2055Pre-running time for first printing(Thick paper 2)100~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
sec.
08Setting modeProcessFuser2075Pre-running operation cycle in ready status and energy saving mode (Times of heat source ON)Refer to contents0~6M0: Not controlled 1: 180 times 2: 360 times 3: 540
times 4: 720 times 5: 900 times 6: 1080 times
<Default value>
e-STUDIO357/457/507: 3
08Setting modeProcessFuser2100Temperature setting of warming-up(Center thermistor)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
e-STUDIO207L/257/307: 0
08Setting modeProcessFuser2101Temperature setting of warming-up(Side thermistor)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5:
<Default value>
08Setting modeProcessFuserFusing correction control temperature immediately after warm-up21080Center (1st correction)Refer to contents0-6M0: None 1: 5℃ 2: 10℃ 3: 15℃ 4: 20℃ 5: 25℃ 6:
30℃
<Default value>
08Setting modeProcessFuserFusing correction control temperature immediately after warm-up21081Side (1st correction)Refer to contents0-6M0: None 1: 5℃ 2: 10℃ 3: 15℃ 4: 20℃ 5: 25℃ 6:
30℃
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserFusing correction control temperature immediately after warm-up21082Supplementary (1st correction)40-6M0: None 1: 5℃ 2: 10℃ 3: 15℃ 4: 20℃ 5: 25℃ 6:
30℃
* This code is valid for e-STUDIO357/457/507 only.
08Setting modeProcessFuserFusing correction control temperature immediately after warm-up21083Center (2nd correction)Refer to contents0-6M0: None 1: 5℃ 2: 10℃ 3: 15℃ 4: 20℃ 5: 25℃ 6:
30℃
<Default value>
e-STUDIO207L/257/307/457/507: 0
e-STUDIO357: 2
08Setting modeProcessFuserFusing correction control temperature immediately after warm-up21084Side (2nd correction)Refer to contents0-6M0: None 1: 5℃ 2: 10℃ 3: 15℃ 4: 20℃ 5: 25℃ 6:
30℃
<Default value>
e-STUDIO357: 2
08Setting modeProcessFuserFusing correction control temperature immediately after warm-up21085Supplementary (2nd correction)Refer to contents0-6M0: None 1: 5℃ 2: 10℃ 3: 15℃ 4: 20℃ 5: 25℃ 6:
30℃
<Default value>
e-STUDIO457/507: 0
e-STUDIO357: 2
08Setting modeProcessFuser2111Pre-running time (Normal temperature)30~18M0: Disabled 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5
11: 15 sec. 12: 20 sec. 13: 25 sec. 14: 30 sec. 15: 40
sec. 16: 50 sec. 17: 60 sec.
18: 150 sec.
08Setting modeProcessFuser2120Fuser roller temperature in ready status(Side thermistor)Refer to contents0~12M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
C 6: 170°C 7: 175°C 8: 180°C 9: 185°C 10: 190°C 11:
130°C 12: 135°C
<Default value>
08Setting modeProcessFuserTemperature drop setting in ready status (Side thermistor)21210The first drop10~10MSetting value x -5°C: from 0°C to -50°C4
08Setting modeProcessFuserTemperature drop setting in ready status (Side thermistor)21211The second drop10~10MSetting value x -5°C: from 0°C to -50°C4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop setting in ready status (Side thermistor)21212The third drop10~10MSetting value x -5°C: from 0°C to -50°C4
08Setting modeProcessFuserTemperature drop setting in ready status (Side thermistor)21213The fourth drop10~10MSetting value x -5°C: from 0°C to -50°C4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Center thermistor)21330The first drop3010~60MSetting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Center thermistor)21331The second drop3010~60MSetting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Center thermistor)21332The third drop3010~60MSetting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Center thermistor)21333The fourth drop3010~60MSetting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Side thermistor)21340The first drop3010~60MSetting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Side thermistor)21341The second drop3010~60MSetting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Side thermistor)21342The third drop3010~60MSetting value x 1 min.: from 10 to 60 min. later4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop switching time setting in ready status (Side thermistor)21343The fourth drop3010~60MSetting value x 1 min.: from 10 to 60 min. later4
08Setting modeProcessFuser2140Fuser roller temperature during printing(Side thermistor/Plain paper)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuser2141Fuser roller temperature during printing(Side thermistor/Thick paper 1)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuser2142Fuser roller temperature during printing(Side thermistor/Thick paper 2)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuser2143Fuser roller temperature during printing(Side thermistor/OHP film)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing (Center thermistor)21900The first dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO357/457/507: 2
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop setting during printing (Center thermistor)21901The second dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
e-STUDIO207L/257/307: 1
08Setting modeProcessFuserTemperature drop setting during printing (Center thermistor)21902The third dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing (Center thermistor)21903The fourth dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing (Side thermistor)21910The first dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing (Side thermistor)21911The second dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing (Side thermistor)21912The third dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing (Side thermistor)21913The fourth dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuser2192Fuser roller temperature during printing(Side thermistor/Thick paper 3)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuser2194Fuser roller temperature during printing(Center thermistor/Envelope)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
e-STUDIO207L/257/307: 6
08Setting modeProcessFuser2195Fuser roller temperature during printing(Side thermistor/Envelope)Refer to contents0~14M0: 140°C 1: 145°C 2: 150°C 3: 155°C 4: 160°C 5: 165°
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Center thermistor)21980The first drop50~200MSetting value x 5 seconds: from 0 to 1000 seconds4
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Center thermistor)21981The second drop120~200MSetting value x 5 seconds: from 0 to 1000 seconds4
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Center thermistor)21982The third drop240~200MSetting value x 5 seconds: from 0 to 1000 seconds4
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Center thermistor)21983The fourth drop360~200MSetting value x 5 seconds: from 0 to 1000 seconds4
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Side thermistor)21990The first drop50~200MSetting value x 5 seconds: from 0 to 1000 seconds4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Side thermistor)21991The second drop120~200MSetting value x 5 seconds: from 0 to 1000 seconds4
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Side thermistor)21992The third drop240~200MSetting value x 5 seconds: from 0 to 1000 seconds4
08Setting modeProcessFuserTemperature drop switching time setting during printing on thick paper (Side thermistor)21993The fourth drop360~200MSetting value x 5 seconds: from 0 to 1000 seconds4
08Setting modeProcessFuserDropping temperature setting when printing on thick paper(Center thermistor)22000First dropRefer to contents0~10MSetting value x 5°C: 0 to 50°C
<Default value>
08Setting modeProcessFuserDropping temperature setting when printing on thick paper(Center thermistor)22001Second dropRefer to contents0~10MSetting value x 5°C: 0 to 50°C
<Default value>
08Setting modeProcessFuserDropping temperature setting when printing on thick paper(Center thermistor)22002Third dropRefer to contents0~10MSetting value x 5°C: 0 to 50°C
<Default value>
08Setting modeProcessFuserDropping temperature setting when printing on thick paper(Center thermistor)22003Fourth dropRefer to contents0~10MSetting value x 5°C: 0 to 50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing on thick paper (Side thermistor)22010The first dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop setting during printing on thick paper (Side thermistor)22011The second dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing on thick paper (Side thermistor)22012The third dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature drop setting during printing on thick paper (Side thermistor)22013The fourth dropRefer to contents0~10MSetting value x -5°C: from 0°C to -50°C
<Default value>
08Setting modeProcessFuserTemperature control lower limit (Plain paper; Normal/High temperature)22050Normal temperature/CenterRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
C 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
125°C 12: 120°C
<Default value>
e-STUDIO207L/257/307: 3
08Setting modeProcessFuserTemperature control lower limit (Plain paper; Normal/High temperature)22051Normal temperature/SideRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
125°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature control lower limit (Plain paper; Normal/High temperature)22052High temperature/Center30~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
125°C 12: 120°C
08Setting modeProcessFuserTemperature control lower limit (Plain paper; Normal/High temperature)22053High temperature/SideRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
125°C 12: 120°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingProcessFuserTemperature control22060Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (PlaincontentsC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
paper/Low125°C 12: 120°C
temperature)<Default value>
e-STUDIO357/457/507: 5
08SettingProcessFuserTemperature control22061Side thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
08SettingProcessFuserTemperature control22070Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (OHP film)contentsC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
125°C 12: 120°C
<Default value>
08SettingProcessFuserTemperature control22071Side thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
125°C 12: 120°C
<Default value>
08SettingProcessFuserTemperature control22080NormalRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (Thicktemperature/CentercontentsC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
paper 1)125°C 12: 120°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingProcessFuserTemperature control22081NormalRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (Thicktemperature/SidecontentsC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
<Default value>
08SettingProcessFuserTemperature control22082LowRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
<Default value>
08SettingProcessFuserTemperature control22083Low temperature/SideRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (ThickcontentsC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
<Default value>
08SettingProcessFuserTemperature control22084High30~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
modelower limit (Thicktemperature/CenterC 6: 160°C 7: 165°C 8: 170°C 9: 175°C 10: 180°C 11:
08SettingProcessFuserTemperature control22085HighRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
<Default value>
08SettingProcessFuserTemperature control22090Center thermistorRefer to0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°4
paper 2)125°C 12: 120°C
<Default value>
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature control lower limit (Thick paper 2)22091Side thermistorRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
125°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature control lower limit (Thick paper 3)22100Center thermistorRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
125°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature control lower limit (Thick paper 3)22101Side thermistorRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
125°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature control lower limit (Envelope)22110Center thermistorRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
125°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature control lower limit (Envelope)22111Side thermistorRefer to contents0~12M0: 130°C 1: 135°C 2: 140°C 3: 145°C 4: 150°C 5: 155°
125°C 12: 120°C
<Default value>
08Setting modeProcessFuserTemperature drop switching time setting during printing (Center thermistor)22120The first drop50~200MSetting value x 5 sec.: from 0 to 1,000 sec. later4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessFuserTemperature drop switching time setting during printing (Center thermistor)22121The second drop120~200MSetting value x 5 sec.: from 0 to 1,000 sec. later4
08Setting modeProcessFuserTemperature drop switching time setting during printing (Center thermistor)22122The third drop240~200MSetting value x 5 sec.: from 0 to 1,000 sec. later4
08Setting modeProcessFuserTemperature drop switching time setting during printing (Center thermistor)22123The fourth drop360~200MSetting value x 5 sec.: from 0 to 1,000 sec. later4
08Setting modeProcessFuserTemperature drop switching time setting during printing (Side thermistor)22130The first drop50~200MSetting value x 5 sec.: from 0 to 1,000 sec. later4
08Setting modeProcessFuserTemperature drop switching time setting during printing (Side thermistor)22131The second drop120~200MSetting value x 5 sec.: from 0 to 1,000 sec. later4
08Setting modeProcessFuserTemperature drop switching time setting during printing (Side thermistor)22132The third drop240~200MSetting value x 5 sec.: from 0 to 1,000 sec. later4
08Setting modeProcessFuserTemperature drop switching time setting during printing (Side thermistor)22133The fourth drop360~200MSetting value x 5 sec.: from 0 to 1,000 sec. later4
08Setting modeProcessFuserEnergy Saving ModeFuser roller temperature2250Side thermistor00~13M0: OFF 1: 40°C 2: 50°C 3: 60°C 4: 70°C 5: 80°C
6: 90°C 7: 100°C 8: 110°C 9: 120°C 10: 130°C
11: 140°C 12: 150°C 13: 160°C
1Yes
08Setting modeProcessFuser2282Pre-running time for first printing(Envelope)100~15M0: Invalid 1: 1 sec. 2: 2 sec. 3: 3 sec. 4: 4 sec. 5: 5 sec.
6: 6 sec. 7: 7 sec. 8: 8 sec. 9: 9 sec. 10: 10 sec. 11: 12
sec. 12: 14 sec. 13: 16 sec. 14: 18 sec. 15: 20 sec.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessDeveloper2827Developer bias AC control ON/OFF10~2M0: ON 1: ON-OFF 2: OFF1
08Setting modeProcessProcess2835Switching of recycled toner saving control00~1M0: Switched 1: Not switched1
08Setting modeProcessProcess2837Correction by temperature/humidity00~3MSets the correction by temperature/humidity. 0: All valid
1: All invalid
2: Valid only in autotoner sensor
3: All valid except transfer and separation
08Setting modeProcessProcess2847Life correction switching of drum reverse rotation amount60~30MSet value x 4 msec. = Drum rotation time e-STUDIO207L/257/307:
0: No correction
1 to 30: Corrected (4 to 120 msec.: approx. 0.5 to 16mm)
0: No correction
1 to 30: Corrected (4 to 120 msec.: approx. 0.8 to 25mm)
08Setting modeProcessProcess2848Life correction switching of normal rotation amount after drum reverse rotationRefer to contents0~30MSet value x 4 msec. = Drum rotation time e-STUDIO207L/257/307:
0: No correction
0: No correction
<Default value>
e-STUDIO207L/257/307: 14
e-STUDIO357/457/507: 13
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (Normal)29200PRT1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (Normal)29202PPC1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (Text)29203PPC1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (Photo)29204PPC1280~255MCorrects the value of the developer bias adjustment (05-2020).4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(FAX)29206FAX1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction (hardcopy security printing)29207PRT1280~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(Text/Photo/ OHP film)29210PRT1080~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(Text/Photo/ OHP film)29212PPC1080~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(Text/OHP film)29213PPC1080~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloperDeveloper bias Hi1 correction(Photo/OHP film)29214PPC1080~255MCorrects the value of the developer bias adjustment (05-2020).4
08Setting modeProcessDeveloper2922Developer bias Hi2 correction1240~255MCorrects the value of the developer bias adjustment (05-2020).1
08Setting modeProcessChargerMain charger bias correction (Normal)29260PRT1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (Normal)29262PPC1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (Text)29263PPC1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (Photo)29264PPC1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (FAX)29266PPC1280~255MCorrects the value of the main charger bias adjustment(05-2040).4
08Setting modeProcessChargerMain charger bias correction (hardcopy security printing)29267PRT1280~ 255MCorrects the value of the main charger bias adjustment (05-2040).4
08Setting modeProcessTransfer29280Transfer transformer DC correction (H)1280~255MCorrects the value of the transfer transformer DC output adjustment (05-2052).4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransfer29281Transfer transformer DC correction (C)1280~255MCorrects the value of the transfer transformer DC output adjustment (05-2052).4
08Setting modeProcessTransfer29282Transfer transformer DC correction (L)1120~255MCorrects the value of the transfer transformer DC output adjustment (05-2052).4
08Setting modeProcessTransfer29290Thick 1 transfer correction (H)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
e-STUDIO207L/257/307: 128
e-STUDIO357/457/507: 132
08Setting modeProcessTransfer29291Thick 1 transfer correction (C)Refer to contents0~255MThe output value of the transfer bias at the center of the paper is corrected.
<Default value>
08Setting modeProcessTransfer29292Thick 1 transfer correction (L)Refer to contents0~255MThe output value of the transfer bias at the trailing edge of paper is corrected.
<Default value>
e-STUDIO357/457/507: 124
08Setting modeProcessTransfer29300Thick 2 transfer correction (H)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
e-STUDIO207L/257/307: 166
e-STUDIO357/457/507: 185
08Setting modeProcessTransfer29301Thick 2 transfer correction (C)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
e-STUDIO207L/257/307: 146
e-STUDIO357/457/507: 152
08Setting modeProcessTransfer29302Thick 2 transfer correction (L)Refer to contents0~255MThe output value of the transfer bias at the trailing edge of paper is corrected.
<Default value>
e-STUDIO207L/257/307: 124
e-STUDIO357/457/507: 112
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessTransfer29320OHP film transfer correction (H)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
e-STUDIO207L/257/307: 110
e-STUDIO357/457/507: 118
08Setting modeProcessTransfer29321OHP film transfer correction (C)Refer to contents0~255MThe output value of the transfer bias at the center of the paper is corrected.
<Default value>
08Setting modeProcessTransfer29322OHP film transfer correction (L)Refer to contents0~255MThe output value of the transfer bias at the trailing edge of paper is corrected.
<Default value>
e-STUDIO207L/257/307: 114
e-STUDIO357/457/507: 110
08Setting modeProcessTransfer29330Envelope transfer correction (H)Refer to contents0~255MThe output value of the transfer bias at the leading edge of paper is corrected.
<Default value>
e-STUDIO207L/257/307: 168
e-STUDIO357/457/507: 189
08Setting modeProcessTransfer29331Envelope transfer correction (C)Refer to contents0~255MThe output value of the transfer bias at the center of the paper is corrected.
<Default value>
08Setting modeProcessTransfer29332Envelope transfer correction (L)Refer to contents0~255MThe output value of the transfer bias at the trailing edge of paper is corrected.
<Default value>
e-STUDIO207L/257/307: 134
e-STUDIO357/457/507: 136
08Setting modeProcessSeparation29340Separation
1280~255MCorrects the value of the separation transformer DC output adjustment (05-2078).4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessSeparation29341Separation transformer DC correction (H)Refer to contents0~255MCorrects the value of the separation transformer DC output adjustment (05-2078).
<Default value>
e-STUDIO207L/257/307: 118
e-STUDIO357/457/507: 121
08Setting modeProcessSeparation29342Separation transformer DC correction (L)Refer to contents0~255MCorrects the value of the separation transformer DC output adjustment (05-2078).
<Default value>
08Setting modeProcessSeparation29350Separation correction value at Duplex printing (H)1280~255M4
08Setting modeProcessSeparation29351Separation correction value at Duplex printing (C)1280~255M4
08Setting modeProcessSeparation29352Separation correction value at Duplex printing (L)1280~255M4
08Setting modeProcessSeparation29360Separation correction value for transparencies (H)1280~255M4
08Setting modeProcessSeparation29361Separation correction value for transparencies (C)1280~255M4
08Setting modeProcessSeparation29362Separation correction value for transparencies (L)1280~255M4
08Setting modeProcessLaserLaser power correction (Normal)29400PRT1280~255MCorrects the value of the laser power adjustment (05- 2250).4
correction (Text/Photo)
29402PPC1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessLaserLaser power correction (Text)29403PPC1280~255MCorrects the value of the laser power adjustment (05- 2250).4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessLaserLaser power correction (Photo)29404PPC1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessLaserLaser power correction (FAX)29406PPC1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessProcessLaser output correction (hardcopy security printing)29407PRT1280~255MCorrects the value of the laser power adjustment (05- 2250).4
08Setting modeProcessTransfer29610Thick 3 transfer correction (H)Refer to contents0~255M<Default value>
08Setting modeProcessTransfer29611Thick 3 transfer correction (C)Refer to contents0~255M<Default value>
08Setting modeProcessTransfer29612Thick 3 transfer correction (L)Refer to contents0~255M<Default value>
e-STUDIO207L/257/307: 117
e-STUDIO357/457/507: 108
08Setting modeProcessTransfer296202-sided thick paper transfer correction (H)Refer to contents0~255M<Default value>
e-STUDIO207L/257/307: 133
08Setting modeProcessTransfer296212-sided thick paper transfer correction (C)Refer to contents0~255M<Default value>
08Setting modeProcessTransfer296222-sided thick paper transfer correction (L)Refer to contents0~255M<Default value>
e-STUDIO357/457/507: 120
08Setting modeProcessTransfer29630Thin paper transfer leading edge output correction (H)Refer to contents0~255M<Default value>
e-STUDIO357/457/507: 98
08Setting modeProcessTransfer29631Thin paper transfer center output correction (C)Refer to contents0~255M<Default value>
e-STUDIO357/457/507: 102
08Setting modeProcessTransfer29632Thin paper transfer trailing edge output correction (L)Refer to contents0~255M<Default value>
e-STUDIO207L/257/307: 130
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessSeparation29660Thin paper separation leading edge output correction (H)1410~255M4
08Setting modeProcessSeparation29661Thin paper separation center output correction (C)Refer to contents0~255M<Default value>
e-STUDIO207L/257/307: 151
e-STUDIO357/457/507: 148
08Setting modeProcessSeparation29662Thin paper separation trailing edge output correction (L)Refer to contents0~255M<Default value>
08Setting modeProcessDeveloper2978Switching of correction of development contrast life40-8MAdjusts the density of the image. The smaller the corrected amount is, the darker the image becomes. 0 to 5: Starts correction when the developer counter counts 5k sheets.
6 to 8: Starts correction when the developer counter counts 10k sheets.
If the developer counter does not reach the values above, the density does not change even if the setting value is altered.
Corrected amount for 08-2978 0: -65
1: ±0
2: -22
3: -43
4: -85
5: -105
6: -65 (correction starts from 10k sheets) 7: -43 (correction starts from 10k sheets) 8: -85 (correction starts from 10k sheets) (Unit: V)
  • Be sure to check the image after the change.
  • The changed setting value is taken over after the replacement of the process unit or the developer material.
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeProcessProcess2987Transfer bias output correction between sheets of paperRefer to contents0~255MThe transfer cleaning bias is output between sheets of paper during printing so as to prevent the toner on the photoconductive drum from adhering to the transfer roller. This code is used to correct the output between sheets of paper to that adjusted in 05-2084 (Transfer cleaning bias adjustment (negative)). The larger the setting value is, the higher the value of the current (more negative) is. Note that toner with a different polarity will adhere easily if the setting value is too large or too small.
<Default value>
e-STUDIO357/457/507: 107
08Setting modeScannerScanner3015Pre-scan setting switchover00~1SYS0: Not performing pre-scanning 1: Performing pre- scanning1Yes
08Setting modeScannerRADF3021Set for switchback- mixed size copy00~1SYSThis setting is whether the original length is detected or not by transporting without scanning in reverse when A4-R/FOLIO paper or LT-R/LG paper is detected in a mixed-size copying.
0: Disabled - AMS:
A series - Judges as A4-R without transporting in reverse with no scanning.
LT series - Judges whether it is LT-R or LG by its length
without transporting in reverse with no scanning. APS:
A series - Judges whether it is A4-R or FOLIO without transporting in reverse with no scanning.
LT series - Judges whether it is LT-R or LG without transporting in reverse with no scanning.
1: Enable 1 AMS:
A series - Judges whether it is A4-R or FOLIO by transporting without scanning in reverse to detect its length.
LT series - Judges whether it is LT-R or LG by transporting
without scanning in reverse to detect its length. APS:
The same as that of APS in 0: Disabled.
1Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeScanner3025Correction of carriage position20-2SYS0: No correction
1: Performs correction before scanning 2: Performs correction after scanning
08Setting ModeScanner3065Initialization of model information in lens unit---Normally this code is not used. When an error occurs by installing the lens unit used for other models, perform this code to initialize the model information.3
08Setting ModeScannerRADF3075Allowing of trailing
edge adjustment of scanning
00-1SYS0: Not allowed
1: Allowed
08Setting ModeScanner3080Detection method of original size11, 3SYS1: Two-step detection (lights twice) 3: Single-step detection (lights once)
When "3" is set, the detection accuracy of dark originals may decrease.
08Setting ModeSystemUser interfaceCard reader3500Device setting00-
429496729
SYSTo enable the e-Bridge ID Gate, a card reading device should be set in the order of "ABYYZZZZ". (Enter the corresponding values to "A", "B", "YY" and "ZZZZ".)
  • AB: Special setting
    • A: Debugging NIC 0: Not used 1: Used
    • B: Interface
  • YY: Authentication
  • ZZZZ: Sub-code (Specifies the usage type of card ID) 0000: No authentication using card
0: USB connection 1: Serial connection (KP-2003 only)
00: No authentication using card 03: Mifare (KP-2005 only)
04: HID (KP-2004 only)
06: KB Emulation I/F Reader
07: 3Track Magnetic Swipe Reader 09: 2Track Magnetic Swipe Reader
0001: IDm (Felica/NFC-Felica) and (or) UID (Mifare/NFC-Mifare)
0002: Data (Felica/NFC-Felica/Mifare/NFC-Mifare)
0003: SSFC mode
5Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting ModeSystemUser interfaceCard reader3501Format information 100-
429496729
SYSTo access the data in the noncontact IC card, the Key Information "LLLL" and the Sector Number "MMMM" should be set. The "LLLL" should be set first, and then "MMMM".
<KP-2005>
LLLL: Key information
MMMM: Sector number (hexadecimal number)
5Yes
08Setting ModeSystemUser interfaceCard reader3502Format information 200-
429496729
SYSThe data of the block number in the noncontact IC is set.
<KP-2005>
RRBSEbse (hexadecimal number) RR: 00 (Fixed)
B: 1st area block number
S: 1st area beginning byte offset E: 1st area ending byte offset
b: 2nd area block number
s: 2nd area beginning byte offset e: 2nd area ending byte offset
* If the 2nd block/area is not used, set the SSTU to "FFFF" (hexadecimal number), the bse to"FFF" (hexadecimal number).
5Yes
08Setting ModeSystemUser interfaceCard reader3503Format information 300-
0xFFFFFF FFFFFFFF FF
SYSSecurity key "KKKKKKKKKKKK" (12 digits)
<hexadecimal number> in the [Key Information] of the [Sector Number] set in the code 08-3501 should be entered.
5Yes
08Setting modeSystemUser interfaceCard reader3504Card authentication LDAP server00~100SYSLDAP server number for the card authentication when a non-contact IC card is used should be set.1
08Setting modeSystemGeneral3612Date of unpacking-13 digitsSYSYear/month/date/day/hour/minute/second Example: 03 07 0 13 13 27 48
"Day" - "0" is for "Sunday". Proceeds Monday through Saturday from "1" to "6".
11Yes
08Setting modeSystemGeneral3615List print USB storage setting00~1SYS0: Enable (USB storage available)
1: Disable (USB storage not available)
08Setting modeSystemGeneral3619Clearing of service history list file--SYSInitializes the service history list file.3
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral3623Job filtering setting for real time log notification function00-65535SYSChanges target type of job for notification in real time log notification function.1
08Setting modeSystemGeneral3624Log item filtering setting for real time log notification function2147483
921
0~4294967
295
SYSChanges target log items for notification in real time log notification function.5
08Setting modeSystemGeneralReal time log notification function3626Department information transmission setting of real time log notification function00-1SYSSets whether the department information (number, name, code) is transmitted or not in the real time log notification function.
0: Department number, department name, department code
1: Department number, department name
08Setting modeSystemGeneral3629Enable/Disable setting of standard EWB function10-1SYS0: Disabled
* This code is valid for NAD, MJD and AUD only.
08Setting modeSystemNetwork3631Remote Access (SNMP)10-1SYS0: Disabled
08Setting modeSystemUser interface3635Trial copy function10~1SYS0: Invalid 1: Valid1
08Setting modeSystemNetworkInternetFax3637Addition of transmission header00-1SYS0: Disabled 1: Enabled1
08Setting modeSystemNetworkInternetFax3638Addition of receiving record00-1SYS0: Disabled 1: Enabled1
08Setting modeSystemNetworkInternetFax3639Adding method of transmission header11-2SYS1: Overwriting inside the image (5 mm from the top) 2: Adding outside the image (5 mm from the top)1
08Setting modeSystemNetworkMDSAuthentication3640Authentication of MDS system00-1SYS0: Disabled 1: Enabled1
08Setting modeSystemNetworkMDSAuthentication3641Display in TopAccess00-1SYSSets whether the information of MDS Authentication will be displayed or not in TopAccess.
0: Non display
1: Display
08Setting modeSystemNetwork36420User authentication setting for NW print/NW fax/Internet fax function00-3SYS0: Authentication with user name and domain name 1: No authentication control in the equipment
2: Authentication with user name
3: Authentication with domain participation information
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetworkWS scan36422Disabling job authentication/permis sion check/Quota check00-1SYS0: OFF
08Setting modeSystemUser interface3643Filtering condition for job list on the panel10-1SYS0: Filtered with user name
1: Filtered with domain name and user name
* This code is valid only when the value of 08-3642-0 is "1".
08Setting modeSystemGeneral3644Login restriction for reissued card00-1SYS0: Disabled 1: Enabled1
08Setting modeSystemUser interfaceUser authentication3646Copy10-1SSDK0: Disabled 1: Enabled1
08Setting modeSystemUser interfaceUser authentication3647FAX10-1SSDK0: Disabled 1: Enabled1
08Setting modeSystemUser interfaceUser authentication3648Printer/e-Filing10-1SSDK0: Disabled 1: Enabled1
08Setting modeSystemUser interfaceUser authentication3649Scanning10-1SSDK0: Disabled 1: Enabled1
08Setting modeSystemUser interfaceUser authentication3650List print10-1SSDK0: Disabled 1: Enabled1
08Setting modeSystemUser interfaceUser authentication3651Authentication
method for administrator
10-1SSDK0: Only password
1: User name and password
08Setting modeSystemUser interface3652Switchover of card reader display on the control panel00-1SYSSwitches the display on the control panel (authentication screen) depending on the connected card reader.
0: Non-contact type 1: Card insertion type
08Setting modeSystemNetwork3702Device name for device authenticationMFP's
serial number
--Maximum 128 letters
"MFP's serial number" is set as default. Perform 08- 9083 to set the default value.
08Setting modeSystemNetwork3704PDC (Primary Domain Controller) name 2 for user authentication--UTYUp to 128 letters12
08Setting modeSystemNetwork3705BDC (Backup Domain Controller) name 2 for user authentication--UTYUp to 128 letters12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork3706PDC (Primary Domain Controller) name 3 for user authentication--UTYUp to 128 letters12
08Setting modeSystemNetwork3707BDC (Backup Domain Controller) name 3 for user authentication--UTYUp to 128 letters12
08Setting modeSystemNetwork3719Windows domain No.
2 of user authentication
--UTYMaximum 128 letters12
08Setting modeSystemNetwork3720Windows domain No.
3 of user authentication
08Setting modeSystemNetwork3721AppleTalk Device NameMFP's
serial number
--Maximum 32 letters
08Setting modeSystemNetwork3722PDC/BDC timeout value of Windows Domain Authentication (Unit: Seconds)601~180NICApplied to the device authentication12
08Setting modeSystemNetwork3723User authentication PDC/BDC time-out period (Unit: Seconds)301~180NICApplied to the user authentication12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork3724Windows Domain Authentication method of Windows Domain/User Authentication11-4NICSets the Windows domain authentication method for device authentication, Scan to SMB, and user authentication. When the setting of the domain authentication method is unknown, it's strongly recommended to set the value of this code to "1" (Auto).
1: Auto 2: Kerberos 3: NTLMv2 4: NTLMv1
* Note that the internal processing is different between user authentication and Windows logon authentication/Scan to SMB as follows.
  • User authentication
  • Windows logon authentication/Scan to SMB "1" (Auto): Auto (Kerberos -> NTLMv1)
"1" (Auto): Auto (Kerberos -> NTLMv2) "4" (NTLMv1): NTLMv2
"4" (NTLMv1): NTLMv1
08Setting modeSystemNetwork3725IPP max connection161~16NIC12
08Setting modeSystemNetwork3726IPP active connection101~16NIC12
08Setting modeSystemNetwork3727LPD max connection101~16NIC12
08Setting modeSystemNetwork3728LPD active connection101~16NIC12
08Setting modeSystemNetwork3729ATalk PS max Connection101~16NIC12
08Setting modeSystemNetwork3730ATalk PS active Connection101~16NIC12
08Setting modeSystemNetwork3731Raw TCP max Connection101~16NIC12
08Setting modeSystemNetwork3732Raw TCP active connection101~16NIC12
08Setting modeSystemNetwork3736DNS Client Time Out51~180NICUse when a timeout occurred at DNS client connection12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork3739FTP Client Time Out (SCAN)301~180NICUse when a timeout occurred at FTP client connection12
08Setting modeSystemNetwork3743LDAP Client Time Out51~180NICUse when a timeout occurred at LDAP client connection12
08Setting modeSystemNetwork3754Switching DPWS Printer setting11~2NICDPWS printer /DPWS secure printer function is switched.
1: Enabled 2: Disabled
08Setting modeSystemNetwork3755Switching DPWS Scanner setting11~2NICDPWS scanner function is switched. 1: Enabled 2: Disabled12
08Setting modeSystemNetwork3757DPWS Discovery Port Number37021~65535NICPort number used for DPWS Discovery12
08Setting modeSystemNetwork3758DPWS Metadata
Exchange Port Number
500811~65535NICPort number used for DPWS Metadata Exchange12
08Setting modeSystemNetwork3759DPWS Print Port Number500821~65535NICPort number used for DPWS Print12
08Setting modeSystemNetwork3760DPWS Scan Port Number500831~65535NICPort number used for DPWS Scan12
08Setting modeSystemNetwork3765DPWS Print Max
numbers of connection
101~20NICMaximum numbers received from more than one connection request in the DPWS print12
08Setting modeSystemNetwork3766DPWS Print Max numbers of reception101~20NICMaximum numbers of data received from more than one clients in the DPWS print12
08Setting modeSystemNetwork3767Switching IPv6 setting21~2NICIPv6 function is switched. 1: Enabled 2: Disabled12
08Setting modeSystemNetworkIPv63768Switching IP(IPv6) Address Acquisition21~3NICIP(IPv6) Address Acquisition setting is switched. 1: Manual
2: Stateless
3: Stateful
08Setting modeSystemNetworkIPv63770IPv6 Address---Displays IPv6 address. Maximum 40 characters (byte).12
08Setting modeSystemNetworkIPv63771Prefix display setting---Sets the length of the displayed prefix. Maximum 3 characters (byte).12
08Setting modeSystemNetworkIPv63772Default Gateway setting---Sets the default gateway for IPv6 address. Maximum 40 characters (byte).12
08Setting modeSystemNetwork3774DHCPv6 Option setting21~2NICDHCPv6 Option is switched when the Manual is set. 1: Enabled 2: Disabled12
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetwork3777Stateless Address setting21~2NICIP Address is acquired by both Stateless and State full Address. 1: Enabled2: Disabled12
08Setting modeSystemNetwork3778Acquiring DHCPv6 Option21~2NICWhen Stateless Address is selected, an option is acquired from DHCPv6 server.
08Setting modeSystemNetwork3779Stateful Address setting11~2NICIP Address is acquired from DHCPv6 server. 1: Enabled 2: Disabled12
08Setting modeSystemNetwork3780Stateful Option setting11~2NICAn option is acquired from DHCPv6 server. 1: Enabled 2: Disabled12
08Setting modeSystemNetworkIPv63781Primary DNS Server Address Registration---Registration of Primary DNS Server Address. Maximum 40 characters (byte).12
08Setting modeSystemNetworkIPv63782Secondary DNS Server Address Registration(IPv6)---Registration of Secondary DNS Server Address. Maximum 40 characters (byte).12
08Setting modeSystemNetwork3793Switching LLTD setting11~2NICLLTD function is switched. 1: Enabled 2: Disabled12
08Setting modeSystemGeneral3802USB media direct printing Paper sizeRefer to contents0~13SYS0: ledger 1: legal 2: letter 3: computer 4: statement 5:
A3 6: A4 7: A5 9: B4 10: B5 11: Folio 12: Legal13" 13:
LetterSquare
<Default value> NAD: 2
Others: 6
08Setting modeSystemGeneral3803USB media direct
printing function setting
10~1SYSSets the USB media direct printing function.0: Disabled1: Enabled1
08Setting modeSystemScanner3805Department Management setting by Remote Scan30~3SYSDepartment Management is set when Remote Scan is performed.
0: w/o GUI OFF,w/ GUI OFF
1: w/o GUI ON,w/ GUI OFF
2: w/o GUI OFF,w/ GUI ON
3: w/o GUI ON,w/ GUI ON
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemNetworkDirect SMTP3810Communication setting00~1SYSWhen an Internet Fax is sent, Direct SMTP communication is set.
When "0: Disabled" is set, an Internet Fax is sent using an SMTP server.
When "1: Enabled" is set, direct SMTP communication is enabled and an Internet Fax is sent to MFPs on the intranet without using an SMTP server.
Since no SMTP server is used, the SSL encryption and SMTPAUTH function cannot be used for internet Fax transmission.
If "1: Enabled" is set in 08-3810, set "1: Enabled" in 08-
3812 as well.
1Yes
08Setting modeSystemNetworkDirect SMTP3811Image encrypting at the Direct SMTP00~1SYSWhen Direct SMTP communication is performed, an attached image is encrypted. 0: Disabled 1: Enabled1Yes
08Setting modeSystemNetworkInternet Fax3812Dummy full mode at I- Fax transmission00~1SYSWhen an Internet Fax is sent, the resolution ratio and the paper size of an attached image are set to the full mode.0: Disabled
1: Enabled If "1: Enabled" is set in 08-3810, set "1: Enabled" in 08-3812 as well.
1Yes
08Setting modeSystemScanner3815XPS file thumbnail addition10~1SYSThumbnail is added to the XPS file produced by the Scan function.
0: Not added 1: Only the top page added
08Setting modeSystemScanner3816XPS file paper size setting10~1SYSThe paper size of the XPS file produced by the Scan function is set.
0: Scanned image size 1: Standard size
08Setting modeSystemScanner3817PDF file version setting40~4SYSThe version of PDF file produced by the Scan function is set.
0: PDF V1.3 1: PDF V1.4 4: PDF V1.7
08Setting modeSystemGeneral3833Home directory function00~1SYSFunction to store a file in the user's home directory 0: Disabled 1: Enabled1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral3837Display switching for the machine name/computer name shown in the notification00~1SYSThe display method of the machine name/computer name shown in the event-related notification is switched.
0: IP address 1: NetBIOS name/FQDN
08Setting modeSystemGeneralLicense control3840Registration/Deletion---Registers electronic keys for setting related optional items (e.g. when the equipment is delivered). Returns the license file having the same ID as that in the one- time dongle. Displays all the electronic keys stored in a USB media connected to the equipment in a list.
Displays electronic keys registered in the equipment.
3Yes
08Setting modeSystemOptionFAX3847FAX mistransmission prevention00~1SYSFAX mistransmission prevention function is switched. 0: OFF (Disabled) 1: ON (Enabled)1Yes
08Setting modeSystemOptionFAX3848Restriction on Address Book destination setting00~1SYSAvailability of destination selection from the Address Book is switched as one of FAX mistransmission prevention functions when setting FAX destinations. 0: OFF (Disabled) 1: ON (Enabled)1Yes
08Setting modeSystemOptionFAX3849Restriction on destination direct entry00~1SYSAvailability of direct entry is switched as one of FAX mistransmission prevention functions when setting FAX destinations. 0: OFF (Disabled )1: ON (Enabled)1Yes
08Setting modeSystemGeneral3851Template display00~1SYSThe order of displaying templates on the LCD screen is switched.
0: Order of IDs 1: Alphabetical order
08Setting modeSystemGeneral3852Automatic summer time changeRefer to contents0~1SYSAutomatic summer time change on the day previously set is switched.
<Default value> NAD/MJD: 1
Others: 0
08Setting modeSystemGeneral3853Summer time mode Offset value20~7SYSSummer time is started as follows when 08-3852 is enabled.
0: +2:00 1: +1:30 2: +1:00 3: +0:30 4: -0:30 5: -1:00
6: -1:30 7: -2:00
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral3854Summer time mode Starting monthRefer to contents1~12SYSThe month in which summer time is started is set.
1: January 2: February 3: March 4: April 5: May 6: June
7: July 8: August 9: September 10: October 11:
November 12: December
<Default value> NAD/MJD: 3
Others: 1
08Setting modeSystemGeneral3855Summer time mode Starting weekRefer to contents1~5SYSThe week in which summer time is started is set. 1: 1st 2: 2nd 3: 3rd 4: 4th 5: Last
MJD: 5
Others: 1
08Setting modeSystemGeneral3856Summer time mode Starting day00~6SYSThe day on which summer time is started is set. 0: Sunday1: Monday2: Tuesday3: Wednesday4: Thursday5: Friday6: Saturday1
08Setting modeSystemGeneral3857Summer time mode Starting timeRefer to contents00~23SYSThe time at which summer time is started is set. 00-23
<Default value> NAD/MJD: 2
Others: 0
08Setting modeSystemGeneral3858Summer time mode Starting minute000~59SYSThe minute at which summer time is started is set. 00-591
08Setting modeSystemGeneral3859Summer time mode Ending monthRefer to contents1~12SYSThe month in which summer time is ended is set.
<Default value> NAD: 11
MJD: 10
Others: 1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modeSystemGeneral3860Summer time mode Ending weekRefer to contents1~5SYSThe week in which summer time is ended is set. 1: 1st 2: 2nd 3: 3rd 4: 4th 5: Last
<Default value> MJD: 5
Other: 1
08Setting modeSystemGeneral3861Summer time mode Ending day00~6SYSThe day on which summer time is ended is set.
0: Sunday 1: Monday 2: Tuesday 3: Wednesday 4:
Thursday 5: Friday 6: Saturday
08Setting modeSystemGeneral3862Summer time mode Ending timeRefer to contents00~23SYSThe time at which summer time is ended is set. 00-23
MJD: 3
Others: 0
08Setting modeSystemGeneral3863Summer time mode Ending minute000~59SYSThe minute at which summer time is ended is set.00-591
08Setting modeSystemNetwork3864Disclosure of telnet function00~1SYS0: Not disclosed 1: Disclosed
When this value is set at "0", the value of code 08-3865 must be "2".
08Setting modeSystemNetwork3865Availability of Telnet Server21~2NICAvailability of Telnet Server is switched. 1: Enabled 2: Disabled12
08Setting ModeSystemFax3875Address confirmation for multiple destinationsRefer to contents0-1SYSEnable this setting to display the address confirmation screen before sending fax to prevent wrong transmission when multiple destination addresses are specified.
<Default value> JPD: 1
Others: 0
08Setting modePrinterLaser4002Judged number of polygonal motor rotation error(Normal rotation)00~1MDisplays the error [CA10] when the set number of rotation error has been detected.
0: 2 times 1: 12 times
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterLaser4003Judged number of polygonal motor rotation error(At acceleration/decelerat ion)00~1M0: Time taken from an overshoot occurring to normal value range is 0.6 sec.
1: Time taken from an overshoot occurring to normal value range is 2.2 sec.
08Setting modePrinterLaser4004Polygonal motor
rotation number on standby
50~5M0: 38,090.55 rpm 1: 35,000 rpm 2: 30,000 rpm 3:
25,000 rpm
4: 20,000 rpm 5: 10,000 rpm
08Setting modePrinterLaser4005Polygonal motor rotation in the energy saving mode00~1M0: Stopped 1: 10,000 rpm1
08Setting modePrinterLaser4009Setting of polygonal motor type30~3MSet the type of polygonal motor.
0: 2-clock type 1: 3-clock type 2: 4-clock type 3: 6-clock type
08Setting modePrinterPaper feedingDefault setting of paper sourcePPC401000~5SYS0: A4/LT 1: LCF 2: Upper drawer 3: Lower drawer 4: PFP upper drawer 5: PFP lower drawer1
08Setting modePrinterFeeding system/Pa per transportAutomatic change of paper sourceAuto4011PPC11~2SYSSets whether or not changing the drawer automatically to the other drawer with the paper of the same size when paper in the selected drawer has run out.
1: Changes to the drawer with the same paper direction and size: e.g., A4 to A4
2: Changes to the drawer with the same paper size. Paper with the different direction is acceptable as long as the size is the same: e.g., A4 to A4-R, LT-R to LT. “1”is applied when the staple/hole-punch is specified.
1Yes
08Setting modePrinterLaser4012Pre-running rotation of polygonal motor00~2SYSSets whether or not switching the polygonal motor from the standby rotation to the normal rotation when the original is set on the RADF or the original cover is opened.
0: Valid (when using RADF and the original is set manually)
1: Invalid
2: Valid (when using RADF only)
08Setting modePrinterLaser4013Polygonal motor rotational status switching at the Auto Clear Mode00~1SYSSets whether or not switching the polygonal motor from the normal rotation to the standby rotation at the Auto Clear Mode. 0: Valid 1: Invalid1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterLaser4014Rotational status of polygonal motor on standby10~1SYSSets the rotational status of polygonal motor on standby.
0: Rotated (The rotational speed is set at 08-4005.) 1: Stopped
08Setting modePrinterLaser4015Timing of auto- clearing of polygonal motor pre-running rotation30~6SYSSwitches the polygonal motor to the standby rotation when a certain period of time has passed from the pre- running. At this code, the period to switch the status to the standby rotation is set.
0: 15 sec. 1: 20 sec. 2: 25 sec. 3: 30 sec. 4: 35 sec. 5:
40 sec. 6: 45 sec.
* This setting is effective when “0” or “2” is set at 08- 4012.
08Setting modePrinterFeeding system/Pa per transportAutomatic change of paper sourceWhen a drawer is specified40160PPC00~1SYSSets whether the automatic change of paper source is performed or not if the drawer is specified as the paper source and the paper in the specified drawer runs out when coping.
0: Does not change the paper source automatically 1: Changes the paper source automatically
4Yes
08Setting modePrinterFeeding system/Pa per transportAutomatic change of paper sourceWhen a drawer is specified40161Printing/BOX printing00~1SYSSets whether the automatic change of paper source is performed or not if the drawer is specified as the paper source and the paper in the specified drawer runs out when printing/BOX printing.
4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingUpper drawer40200Plain paper50~5MSets the number of times of the feeding retry from the upper drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingUpper drawer40201Others50~5MSets the number of times of the feeding retry from the upper drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingLower drawer40210Plain paper50~5MSets the number of times of the feeding retry from the lower drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingLower drawer40211Others50~5MSets the number of times of the feeding retry from the lower drawer.4Yes
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingPFP upper drawer40220Plain paper50~5MSets the number of times of the feeding retry from the PFP upper drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingPFP upper drawer40221Others50~5MSets the number of times of the feeding retry from the PFP upper drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingPFP lower drawer40230Plain paper50~5MSets the number of times of the feeding retry from the PFP lower drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingPFP lower drawer40231Others50~5MSets the number of times of the feeding retry from the PFP lower drawer.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingbypass feed40240Plain paper50~5MSets the number of times of the feeding retry from the bypass tray.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingbypass feed40241Others50~5MSets the number of times of the feeding retry from the bypass tray.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingLCF40250Plain paper50~5MSets the number of times of the feeding retry from the LCF.4Yes
08Setting modePrinterFeeding system/Pa per transportFeeding retry number settingLCF40251Others50~5MSets the number of times of the feeding retry from the LCF.4Yes
08Setting modePrinterFeeding system/Pa per transport4100Paper size for upper drawerRefer to contents0-255MPress the button on the LCD to select the size.
<Default value> EUR: A4
UC: LT JPN: A4
08Setting modePrinterFeeding system/Pa per transport4101Paper size for lower drawerRefer to contents0-255MPress the button on the LCD to select the size.
<Default value> EUR: A3
UC: LD JPN: A3
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transport4102Paper size for PFP upper drawerRefer to contents0-255MPress the button on the LCD to select the size.
<Default value> EUR: A4-R
UC: LT-R JPN: A4-R
08Setting modePrinterFeeding system/Pa per transport4103Paper size for PFP lower drawerRefer to contents0-255MPress the button on the LCD to select the size.
UC: LG JPN: B4
08Setting modePrinterFeeding system/Pa per transport4104Paper size setting
/LCF
UC: LT JPN: A4
08Setting modePrinterFeeding system/Pa per transport4105PFP/LCF installation00~4M0: Auto
1: PFP upper-drawer type installed
2: PFP upper-drawer and lower-drawer type installed 3: LCF installed
4: Neither PFP nor LCF installed
In the following case, set the value to "0" (Automatic) or change the value to the corresponding one.
  • When any of the above option is replaced
  • When any of the above option is installed while "4" (Not installed) has been set
08Setting modePrinterFeeding system/Pa per transport4106Paper size (A3) feeding/widthwise direction420/297182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4107Paper size (A4-R) feeding/widthwise direction297/210182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4108Paper size (A5-R) feeding/widthwise direction210/148182~432/1
40~297
M10
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08SettingPrinterFeeding4109Paper size (B4-R)364/257182~432/1M10
modesystem/Pafeeding/widthwise40~297
perdirection
transport
08SettingPrinterFeeding4110Paper size (B5-R)257/182182~432/1M10
perdirection
transport
08SettingPrinterFeeding4111Paper size (LT-R)279/216182~432/1M10
perdirection
transport
08SettingPrinterFeeding4112Paper size (LD-R)432/279182~432/1M10
perdirection
transport
08SettingPrinterFeeding4113Paper size (LG-R)356/216182~432/1M10
perdirection
transport
08SettingPrinterFeeding4114Paper size (ST-R)216/140182~432/1M10
perdirection
transport
08SettingPrinterFeeding4115Paper size356/257182~432/1M10
modesystem/Pa(COMPUTER-R)40~297
perfeeding/widthwise
transportdirection
08SettingPrinterFeeding4116Paper size (FOLIO)330/210182~432/1M10
perdirection
transport
08SettingPrinterFeeding4117Paper size (13" LG-R)330/216182~432/1M10
perdirection
transport
08SettingPrinterFeeding4118Paper size (8.5"X8.5"-216/216182~432/1M10
modesystem/PaR) feeding/widthwise40~297
perdirection
transport
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transport4119Paper size (Non- standard) feeding/widthwise direction432/279148~432/1
05~297
SYS10
08Setting modePrinterFeeding system/Pa per transport4120Paper size (8K-R) feeding/widthwise direction390/270182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4121Paper size (16K-R) feeding/widthwise direction270/195182~432/1
40~297
M10
08Setting modePrinterFeeding system/Pa per transport4123Paper size (A6-R) feeding/widthwise direction148/105148~432/1
05~297
M10
08Setting modePrinterFeeding system/Pa per transport4124Paper size (#10- R)feeding/widthwise direction241/105148~432/1
05~297
M10
08Setting modePrinterFeeding system/Pa per transport4127Paper size (DL- R)feeding/widthwise direction220/110148~432/1
05~297
M10
08Setting modePrinterFeeding system/Pa per transport4131Feeding retry setting00~1M0: Enabled
1: Disabled
* When the value of 08-9016 is set to "5", the value of this code is automatically set to "1".
1Yes
08Setting modePrinterFeeding system/Pa per transport4140Paper size for bypass feed2550-255SYSPress the button on the LCD to select the size.9
08Setting modePrinterFeeding system/Pa per transport4143Paper size (Envelope: Monarch- R)feeding/widthwise direction191/98148~432/9
8~297
M10
08Setting modePrinterFeeding system/Pa per transport4144Paper size (Envelope: CHO-3-
235/120148~432/1
05~297
M10
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transport4145Paper size (Envelope: YOU-4-
235/105148~432/1
05~297
M10
08Setting modePrinterFeeding system/Pa per transport4206Paper size (Postcard) feeding/widthwise direction148/100148~432/1
00~297
M* Postcard is supported only for JPN model.10
08Setting modePrinterFeeding system/Pa per transport4450Switching of paper pushing amount/lower drawer00~1MSwitches pushing process by the transport roller when paper loaded from the lower drawer starts to be transported from the registration section.
0: The paper is pushed until its trailing edge reaches the position where the 2nd transport sensor is turned OFF.
1: If the length of the paper is more than 297 mm, it is pushed by the transport roller for a specified time.
08Setting modePrinterFeeding system/Pa per transport4542Switching for incorrect size jam detection00~1M0: Enabled 1: Disabled1Yes
08Setting modePrinterFeeding system/Pa per transport4547Manual stapling time- out period153~30M3-30sec.(In increments of 1sec.)1
08Setting modePrinterFinisher4548Finisher model switching setting value00~1MSets the model of the finisher. 0: MJ-1032/1033/1101/1106
1: MJ-1032/1033/1101/1106
08Setting modePrinterGeneral4549Detection setting of new or old fuser unit00~1M0: Enabled 1: Disabled1
08Setting modePrinterGeneral4555Information check of new or old EPU
memory
652800 to 65535M65280 (0xFF00): New EPU 255 (0x00FF): Installed EPU2
08Setting modePrinterGeneral4556Detection setting of new or old EPU10~1M0: Disabled 1: Enabled1
08Setting modePrinterProcessConditions at the occurrence of fuser related error45700Center thermistor00-255MOutput value of thermistor4
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterProcessConditions at the occurrence of fuser related error45701Side thermistor00-255MOutput value of thermistor4
08Setting modePrinterProcessConditions at the occurrence of fuser related error45702Edge thermistor00-255MOutput value of thermistor4
08Setting modePrinterProcessConditions at the occurrence of fuser related error45705Error counter00-255M1-3: Fusing error when warm-up-40-degrees C detected
4-10: Fusing error when warm-up-100-degrees C detected
11-25: Fusing error when ready from warm-up 50-55: Fusing error at ready
100-111: Fusing error at printing
150-153: Fusing error in the prewarming/JAM/cover open/adjustment mode
08Setting modePrinterGeneral4581SRAM Backup---The data in the SRAM is backed up in the EEPROM.3
08Setting modePrinterGeneral4582SRAM copy---The data in the EEPROM is copied to the SRAM.3
08Setting modePrinterFeeding system/Pa per transportBypass paper size detection setting4621PPC/PRT00~1MDetects whether the size of paper fed by bypass feeding is the same as the paper size set on the control panel. If the sizes are not the same, the warning message is displayed (Paper jam does not occur).
When the bypass paper size detection is broken, the equipment can be used without the size detection by disabling this setting. After repair, enable this setting. 0: Enabled 1: Disabled
08Setting modePrinterFeeding system/Pa per transportBypass paper size detection counter4622PPC/PRT00~65535MThis is a counter for bypass paper size detection setting. If the printing is executed with the paper size that differs from the paper size set on the control panel, the counter is counted up.1
08Setting modePrinterGeneral4675Paper ejection setting
for wrong bypass paper size
20-2M0 and 1: Disabled
2: Ejected
08Setting modePrinterCounter4676Ejection counter for
00~65535MNumber of ejection times1
05/08ModeElementSub
element
ItemSubitemCodeSub-
code
DetailsDefault
value
Acceptable
value
RAMContentsProc
edure
UI
08Setting modePrinterFeeding system/Pa per transport4691Switching of the display of jam location in the drawer when paper feed jam occurs10~1M0: Disabled
08Setting modePrinterFinisher4695Synchronous writing of the finisher adjustment value--MWrites the adjustment code from 05-4819 to 4827 in the SRAM of the finisher. (for MJ-1032 and MJ-1033)3
08Setting modePrinterFinisher4696Synchronous reading of the finisher adjustment value--MReads the adjustment code from 05-4819 to 4827 from the SRAM of the finisher. (for MJ-1032 and MJ-1033)3
08Setting modeProcessProcess50010Print job end cleaning bias polarity switching frequency00~9MIn the cleaning operation of the transfer roller at the end of printing, the cleaning bias, in which the polarity is switched from positive to negative, is output so that the toner adhering to the transfer roller is returned to the photoconductive drum. This code is used to set the cleaning bias switching frequency. Perform adjustment when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller. Note that the drum driving time will increase if the setting value of the cleaning bias switching frequency is too large. The setting code differs depending on the operation status of the equipment when there is any stain on the back side of the printed paper. Select the code from 5001 to 5003 according to the operation status. Set this code when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller in normal printing.
0: Once 1: Twice 2: Three times 3: Four times 4: Five
times 5: Six times 6: Seven times 7: Eight times 8: Nine times 9: Ten times
08Setting modeProcessProcess50011Print job end cleaning bias polarity switching frequency (Bypass non-standard)30~9MSet this code when there is any stain on the back side of the printed paper (leading edge) caused by the transfer roller in printing non-standard paper from the bypass tray.
