05/08 | Mode | Element | Sub element | Item | Subitem | Code | Sub- code | Details | Default value | Acceptable value | RAM | Contents | Proc edure | Service UI |
08 | Setting mode | System | General | 9960 | Equipment information (SRAM) | Refer to contents | 0~2 | SYS | Displays the equipment information in SRAM. 0: Not set 1: Destinations other than NAD 2: NAD <Default value> NAD: 2 Others: 1 | 2 | ||||
08 | Setting Mode | System | User interface | 9963 | Display of receiving job on JOB STATUS screen | 0 | 0-1 | SYS | This setting is automatically disabled in the high security mode. 0: Disabled 1: Enabled | 1 | ||||
08 | Setting mode | System | User interface | Default mode setting | Default setting (PPC) | 9970 | Original mode (Black) | 0 | 0~5 | SYS | 0: Standard 1: Text 2: Photo 3: Not used (non- enterable) 4: Custom 5: Presentation | 1 | Yes | |
08 | Setting mode | System | General | 9971 | Image quality density adjustment at power- ON Default setting | 0 | 0~1 | SYS | 0: Automatic 1: Manual (Center) | 1 | ||||
08 | Setting mode | System | User interface | Blank page judgment Default setting | PPC | 9972 | Blank page judgment Default setting | 0 | -3~3 | SYS | The larger the value is, the more the paper is judged as a blank page. The smaller the value is, the less the paper is judged as a blank page. | 1 | ||
08 | Setting mode | System | User interface | Blank page judgment Default setting | SCN | 9973 | Blank page judgment Default setting | 0 | -3~3 | SYS | The larger the value is, the more the paper is judged as a blank page. The smaller the value is, the less the paper is judged as a blank page. | 1 | ||
08 | Setting mode | System | User interface | ACS judgment adjustment Default setting | SCN | 9975 | ACS judgment adjustment Default setting | 0 | -3~3 | SYS | The larger the value is, the more the original is judged as color data. The smaller the value is, the less the original is judged as black data. | 1 |
08 | Setting mode | System | Network | 9980 | Address setting for TO/CC/BCC at authentication | 0 | 0-4 | SYS | Sets address of TO/CC/BCC when the user authentication and E-mail authentication are enabled. When the value of this code is set to "1", the address specified as From Address is input to TO destination field. TO/CC/BCC field cannot be edited. When the value of this code is set to "2 to 4", the address specified as From Address is input to each field. TO/CC/BCC field can be edited by pressing the TO/CC/BCC button. 0: Disabled 1: Fixed to TO field. 2: Added to TO field. 3: Added to CC field. 4: Added to BCC field. | 1 | ||||
08 | Setting mode | System | Network | 9981 | Sending body text of email | 1 | 0~1 | SYS | Sets whether the job information is output in the body of e-mail when executing e-mail send job. 0: Disabled 1: Enabled | 1 | ||||
08 | Setting mode | System | User interface | 9982 | Switch of display attribute of [EXTENSION] icon | 0 | 0~1 | SYS | 0: Touch is invalid when authentication is not completed. 1: Touch is valid when authentication is not completed. | 1 | ||||
08 | Setting mode | System | Maintenan ce | 9984 | Document name in printing/scanning | 0 | 0~1 | SYS | 0: Not confidential name (default) 1: Confidential name | 1 | ||||
08 | Setting Mode | System | User interface | 9985 | Screen displayed by pressing MENU button | 0 | 0-1 | SYS | 0: MENU screen 1: EWB screen | 1 | ||||
08 | Setting mode | System | Maintenan ce | 9987 | Retention of fax sending settings | 0 | 0~3 | SYS | Sets whether the fax sending settings are retained or not. 0: Clears all settings (The authentication screen is displayed if user authentication or department management is enabled.) 1: Clears all 2: Clears only addresses 3: Retains all settings * When the value of this code is set to "3", the value of 08-3847 (FAX mistransmission prevention) is automatically set to "1" (Enabled). | 1 |
05 | Adjustmen t mode | Process | Developer | Automatic adjustment of auto-toner sensor | 2000 | Fuser heater ON | - | - | As the value increases, the sensor output increases correspondingly. The value starts changing approx. 2 minutes after this adjustment was started and is automatically set in the range of 2.35 to 2.45 V. * Selection is disable when developer unit is not installed. | 17 | Yes | |||
05 | Adjustmen t mode | Process | Developer | Correction of auto- toner sensor | 2001 | Fuser heater ON | 141 | 0~255 | M | Corrects the control value of the auto-toner sensor setup in 05-2000. * Selection is disable when developer unit is not installed. | 3 | Yes | ||
05 | Adjustmen t mode | Process | Developer | 2020 | Developer bias DC output adjustment | 149 | 0~255 | M | As the value increases, the transformer output increases correspondingly. Remove the developer unit and install the adjustment jig to make adjustment. | 3 | ||||
05 | Adjustmen t mode | Process | Charger | 2040 | Main charger grid bias output adjustment | Refer to contents | 0~255 | M | As the value increases, the transformer output increases correspondingly. Remove the developer unit and install the adjustment jig to make adjustment. <Default value> e-STUDIO207L/257/307: 105 e-STUDIO357/457/507: 107 | 3 | ||||
05 | Adjustmen t mode | Process | Transfer | 2052 | Transfer transformer DC output adjustment (C) | Refer to contents | 0~255 | M | As the value increases, the transformer output increases correspondingly. Remove the developer unit and install the adjustment jig to make adjustment. <Default value> e-STUDIO207L/257/307: 88 e-STUDIO357/457/507: 117 | 3 | ||||
05 | Adjustmen t mode | Process | Separation | 2078 | Separation transformer DC output adjustment (C) | 52 | 0~255 | M | As the value increases, the transformer output increases correspondingly. Remove the developer unit and install the adjustment jig to make adjustment. | 3 |
05 | Adjustmen t mode | Process | Transfer | Transfer cleaning bias adjustment | 2083 | Positive | Refer to contents | 0~255 | M | When the high-voltage transformer is replaced, the transfer cleaning bias needs to be adjusted with this code. The larger the setting value is, the higher the value of the current (more positive) is. This causes a reduction in the toner adhering to the transfer roller and an improvement in the cleaning performance. Perform this adjustment after the process units (cleaner and developer unit) have been removed. When the high- voltage transformer is replaced, adjusting with the following codes needs to be performed in addition to this adjustment. 05-2020, 05-2040, 05-2052, 05-2078 <Default value> e-STUDIO207L/257/307: 63 e-STUDIO357/457/507: 96 | 3 | |||
05 | Adjustmen t mode | Process | Transfer | Transfer cleaning bias adjustment | 2084 | Negative | 41 | 0~255 | M | When the high-voltage transformer is replaced, the transfer cleaning bias needs to be adjusted with this code. The larger the setting value is, the higher the value of the current (more negative) is. This causes a reduction in the toner adhering to the transfer roller and an improvement in the cleaning performance. Perform this adjustment after the process units (cleaner and developer unit) have been removed. When the high- voltage transformer is replaced, adjusting with the following codes need to be performed in addition to this adjustment. 05-2020, 05-2040, 05-2052, 05-2078 | 3 | |||
05 | Adjustmen t mode | Process | Transfer | Temperature/humidity sensor | 2192 | Humidity display | 50 | 0~100 | M | Displays the humidity value detected by temperature/humidity sensor. | 2 | Yes | ||
05 | Adjustmen t mode | Process | Process | Temperature/humidity sensor | 2194 | Temperature display | 25 | 0~50 | M | Displays the humidity value detected by temperature/humidity sensor. | 2 | Yes | ||
05 | Adjustmen t mode | Process | Charger | 2196 | Drum thermistor temperature display (K) | 25 | 0~100 | M | (Unit: °C) | 2 | Yes |
05 | Adjustmen t mode | Process | Image quality control | 2250 | Laser power adjustment | Refer to contents | 0~255 | M | When the value increases, the laser output increases correspondingly. <Default value> e-STUDIO207L/257/307: 73 e-STUDIO357/457/507: 124 | 3 | Yes | |||
05 | Adjustmen t mode | Process | Process | 2382 | Reverse time of the drum | Refer to contents | 0~255 | M | <Default value> e-STUDIO207L/257/307: 12 e-STUDIO357/457/507: 10 | 1 | ||||
05 | Adjustmen t mode | Process | Toner recycle | 2390 | Forced performing of idling | - | M | Perform this adjustment before the replacement of the developer material. (The toner is forcibly removed from the cleaner.) | 6 | Yes | ||||
05 | Adjustmen t mode | Scanner | Scanner | 3009 | Log table switching for RADF copying (color) | 2 | 0~4 | SYS | 0: Same log table as the one used at copying with original glass 1: Background reproduction - Light 2 2: Background reproduction - Light 1 3: Background reproduction - Dark 1 4: Background reproduction - Dark 2 | 1 | ||||
05 | Adjustmen t mode | Scanner | Scanner | Image location adjustment | 3030 | Primary scanning direction (scan. section) | 115 | 0~255 | SYS | When the value increases by "1", the image shifts by approx. 0.04233 mm toward the front side of the paper. | 1 | Yes | ||
05 | Adjustmen t mode | Scanner | Scanner | Image location adjustment | 3031 | Secondary scanning direction(scan.section ) | 124 | 90~166 | SYS | When the value increases by "1", the image shifts by approx. 0.13013 mm toward the trailing edge of the paper. | 1 | Yes | ||
05 | Adjustmen t mode | Scanner | Scanner | Reproduction ratio adjustment | 3032 | Adj. secondary scan.direction | 117 | 63~193 | SYS | When the value increases by "1", the reproduction ratio in the secondary scanning direction (vertical to paper feeding direction) increases by approx. 0.025 %. | 1 | Yes | ||
05 | Adjustmen t mode | Scanner | Scanner | Distortion mode | 3033 | Distortion mode | - | - | Moves carriages to the adjusting position. | 6 | Yes | |||
05 | Adjustmen t mode | Scanner | Scanner | Shading position adjustment | 3034 | Original glass | 117 | 92~165 | SYS | 0.13013 mm/step | 1 | |||
05 | Adjustmen t mode | Scanner | Scanner | Shading position adjustment | 3035 | RADF | 133 | 92~165 | SYS | 0.13013 mm/step | 1 | |||
05 | Adjustmen t mode | Scanner | RADF | Adjustment of RADF paper alignment | 3040 | Front side | 12 | 0~30 | SYS | When the value increases by "1", the aligning amount increases by approx. 0.5 mm. | 1 | Yes | ||
05 | Adjustmen t mode | Scanner | RADF | Adjustment of RADF paper alignment | 3041 | Back side | 12 | 0~30 | SYS | When the value increases by "1", the aligning amount increases by approx. 0.5 mm. | 1 | Yes |
05 | Adjustmen t mode | Scanner | RADF | 3042 | Fine adjustment of RADF transport speed | 50 | 0~100 | SYS | When the value increases by "1", the reproduction ratio of the secondary scanning direction when using the RADF increases by approx. 0.1%. | 1 | Yes | |||
05 | Adjustmen t mode | Scanner | RADF | 3043 | RADF sideways deviation adjustment | 128 | 0~255 | SYS | When the value increases by "1", the image of original fed from the RADF shifts toward the rear side of paper by approx. 0.08423 mm. | 1 | Yes | |||
05 | Adjustmen t mode | Scanner | RADF | RADF leading edge position adjustment | 3044 | Front side | 50 | 0~100 | SYS | When the value increases by "1", the copied image of original fed from the RADF shifts toward the trailing edge of paper by approx.0.2 mm. | 1 | Yes | ||
05 | Adjustmen t mode | Scanner | RADF | Leading edge position adjustment | 3045 | Back side | 50 | 0~100 | SYS | When the value increases by "1", the copied image of original fed from the RADF shifts toward the trailing edge of paper by approx.0.2 mm. | 1 | Yes | ||
05 | Adjustmen t mode | Scanner | Scanner | 3046 | Carriage position adjustment during scanning from RADF (black) | 128 | 0~255 | SYS | When the value increases by "1", the carriage position shifts by approx. 0.1 mm toward the exit side when using the RADF. | 1 | ||||
05 | Adjustmen t mode | Scanner | Scanner | 3047 | Carriage position adjustment during scanning from RADF (color) | 128 | 0~255 | SYS | When the value increases by "1", the carriage position shifts by approx. 0.1 mm toward the exit side when using the RADF. | 1 | ||||
05 | Adjustmen t mode | Scanner | Scanner | Data transfer of characteristic value | 3203 | SLG board -> SYS board | - | SYS | Transfers the characteristic values of the scanner (shading correction factor / RGB color correction / reproduction ratio color deviation correction / shading position correction factor / reproduction ratio correction value in primary scanning direction) | 6 | ||||
05 | Adjustmen t mode | Scanner | Scanner | 3209 | Data transfer of characteristic value of scanner / SYS board - > SLG board | - | SYS | Transfers the characteristic values of the scanner (shading correction factor / RGB color correction / reproduction ratio color aberration correction / shading position correction factor / reproduction ratio correction value in primary scanning direction) | 6 | |||||
05 | Adjustmen t mode | Scanner | Scanner | 3218 | Automatic dust detection adjustment for shading correction plate | - | - | - | Performs adjustment for shading correction plate by automatically detecting dust. If dust is detected, shading correction is performed by avoiding the dust. | 6 |
05 | Adjustmen t mode | Scanner | Scanner | Size detection of original | 3233 | Position adjustment in the primary scanning direction | Refer to contents | 0-255 | SYS | Adjusts the detection range for size of original. <Default value> NAD/TWD/CND: 128 Others: 58 | 1 | |||
05 | Adjustmen t mode | Scanner | Scanner | Size detection of original | 3234 | Waiting position adjustment of carriage | 200 | 0-255 | SYS | Adjusts the position where the carriage stops at the size detection of the original. Default value: 200 (20 mm from leading edge of original) Maximum value: 255 (25.5 mm from leading edge of original) Minimum value: 0 (0 mm from leading edge of original) | 1 | |||
05 | Adjustmen t mode | Scanner | Scanner | Size detection of original | 3236 | Adjustment of lamp lighting time | 128 | 0-255 | SYS | Adjusts the lighting time of the lamp at the size detection of the original. Maximum value: 255 (Minimum time + 2040ms) Minimum value: 0 (Minimum time) | 1 | |||
05 | Adjustmen t mode | Scanner | Scanner | Size detection of original | 3237 | Starting time adjustment of lamp lighting | 64 | 0-255 | SYS | Adjusts the starting time of lamp lighting when the detection accuracy of dark originals is poor. Maximum value: 255 (Minimum time + 2040 ms) Minimum value: 0 (Minimum time) | 1 | |||
05 | Adjustmen t mode | Scanner | RADF | 3350 | Trailing edge adjustment of scanning | 50 | 0-100 | SYS | When the value increases by "1", the trailing edge of scanned original becomes longer by 0.3 mm at RADF copying. When the value decreases by "1", the trailing edge of scanned original becomes shorter by 0.3 mm at RADF copying. * This code is effective when the value of 08-3075 is "1" (Allowed). | 1 | ||||
05 | Adjustmen t mode | Printer | Printer | Fine adjustment of polygonal motor rotation speed | Adjustment of primary scanning direction reproduction ratio | 4000 | PPC | 128 | 0~255 | M | When the value increases by "1", the reproduction ratio of primary scanning direction increases by approx. 0.07%. (approx. 0.1 mm/step) | 1 | Yes | |
05 | Adjustmen t mode | Printer | Printer | Fine adjustment of polygonal motor rotation speed | Adjustment of primary scanning direction reproduction ratio | 4001 | PRT | 133 | 0~255 | M | When the value increases by "1", the reproduction ratio of primary scanning direction increases by approx. 0.07%. (approx. 0.1 mm/step) | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | Adjustment of primary scanning laser writing start position. | 4005 | PPC | Refer to contents | 0~255 | M | When the value increases by "1", the writing start position shifts to the front side by approx. 0.0423 mm. <Default value> e-STUDIO207L/257/307: 88 e-STUDIO357/457/507: 99 | 1 | Yes |
05 | Adjustmen t mode | Printer | Image | Adjustment of primary scanning laser writing start position. | 4006 | PRT | Refer to contents | 0~255 | M | When the value increases by "1", the writing start position shifts to the front side by approx. 0.0423 mm. <Default value> e-STUDIO207L/257/307: 88 e-STUDIO357/457/507: 99 | 1 | Yes | ||
05 | Adjustmen t mode | Printer | Drive | Fine adjustment of main motor speed | Adjustment of secondary scanning direction reproduction ratio | 4009 | PPC/PRT | 132 | 0~255 | M | When the value increases by "1", the reproduction ratio of secondary scanning direction increases by approx. 0.04%. | 1 | Yes | |
05 | Adjustmen t mode | Printer | Drive | Fine adjustment of main motor speed | Adjustment of secondary scanning direction reproduction ratio | 4010 | FAX | 128 | 0~255 | M | When the value increases by "1", the reproduction ratio of secondary scanning direction increases by approx. 0.04%. | 1 | Yes | |
05 | Adjustmen t mode | Printer | Drive | Fine adjustment of exit motor speed | 4013 | PPC/PRT | 128 | 0~255 | M | e-STUDIO207L/257/307: When the value increases by "1", the rotation accelerates by approx. 0.03%. e-STUDIO357/457/507: When the value increases by "1", the rotation accelerates by approx. 0.05%. | 1 | Yes | ||
05 | Adjustmen t mode | Printer | Drive | Fine adjustment of exit motor speed | 4014 | FAX | 128 | 0~255 | M | e-STUDIO207L/257/307: When the value increases by "1", the rotation accelerates by approx. 0.03%. e-STUDIO357/457/507: When the value increases by "1", the rotation accelerates by approx. 0.05%. | 1 | Yes | ||
05 | Adjustmen t mode | Printer | Image | Adj. of drawer sideways deviation | 4018 | 0 | 1st drawer | 128 | 0~255 | M | When the value increases by "1", the image shifts toward the front side by 0.0423 mm. | 4 | Yes | |
05 | Adjustmen t mode | Printer | Image | Adj. of drawer sideways deviation | 4018 | 1 | 2nd drawer | 128 | 0~255 | M | When the value increases by "1", the image shifts toward the front side by 0.0423 mm. | 4 | Yes | |
05 | Adjustmen t mode | Printer | Image | Adj. of drawer sideways deviation | 4018 | 2 | PFP upper drawer | 128 | 0~255 | M | When the value increases by "1", the image shifts toward the front side by 0.0423 mm. | 4 | Yes | |
05 | Adjustmen t mode | Printer | Image | Adj. of drawer sideways deviation | 4018 | 3 | PFP lower drawer | 128 | 0~255 | M | When the value increases by "1", the image shifts toward the front side by 0.0423 mm. | 4 | Yes | |
05 | Adjustmen t mode | Printer | Image | Adj. of drawer sideways deviation | 4018 | 4 | T-LCF | 128 | 0~255 | M | When the value increases by "1", the image shifts toward the front side by 0.0423 mm. | 4 | Yes | |
05 | Adjustmen t mode | Printer | Image | Adj. of drawer sideways deviation | 4018 | 5 | Bypass feeding | 128 | 0~255 | M | When the value increases by "1", the image shifts toward the front side by 0.0423 mm. | 4 | Yes |
05 | Adjustmen t mode | Printer | Image | Adj. of primary scan. laser writing start | Duplex feeding | 4019 | 0 | Long size | Refer to contents | 0~255 | M | When the value increases by "1", the image shifts toward the front side by 0.0423 mm. <Default value> e-STUDIO207L/257/307: 115 e-STUDIO357/457/507: 123 | 4 | Yes |
05 | Adjustmen t mode | Printer | Image | Adj. of primary scan. laser writing start | Duplex feeding | 4019 | 1 | Short size | 148 | 0~255 | M | When the value increases by "1", the image shifts toward the front side by 0.0423 mm. | 4 | Yes |
05 | Adjustmen t mode | Printer | Image | Margin adjustment | PPC | 4050 | Top margin adjustment | 15 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | 4051 | Left margin adjustment(blank area at the left of the paper along the paper feeding direction) | 0 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 1 | ||||
05 | Adjustmen t mode | Printer | Image | Margin adjustment | PPC | 4052 | Right margin adjustment | Refer to contents | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. <Default value> e-STUDIO207L/257/307: 8 e-STUDIO357/457/507: 9 | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | Margin adjustment | PPC | 4053 | Bottom margin adjustment | 55 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | 4054 | Top margin adjustment(blank area at the leading edge of the paper) | 24 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 1 | ||||
05 | Adjustmen t mode | Printer | Image | 4055 | Left margin adjustment(blank area at the left of the paper along the paper feeding direction) | 0 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 1 |
05 | Adjustmen t mode | Printer | Image | 4056 | Right margin adjustment(blank area at the right of the paper along the paper feeding direction) | 0 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 1 | ||||
05 | Adjustmen t mode | Printer | Image | 4057 | Bottom margin adjustment(blank area at the trailing edge of the paper) | 0 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 1 | ||||
05 | Adjustmen t mode | Printer | Image | Leading edge position adjustment | Normal speed | 4058 | 1st drawer | 6 | 0~15 | M | When the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4 mm. | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | Leading edge position adjustment | Normal speed | 4059 | 2nd drawer | Refer to contents | 0~40 | M | When the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4 mm. <Default value> e-STUDIO207L/257/307: 21 e-STUDIO357/457/507: 29 | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | Leading edge position adjustment | Normal speed | 4060 | PFP | 8 | 0~15 | M | When the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4 mm. | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | Leading edge position adjustment | Normal speed | 4061 | Bypass feeding | Refer to contents | 0~15 | M | When the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4 mm. <Default value> e-STUDIO207L/257/307: 7 e-STUDIO357/457/507: 8 | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | Leading edge position adjustment | Normal speed | 4062 | Duplex feeding | 8 | 0~15 | M | When the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4 mm. | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | Leading edge position adjustment | Normal speed | 4063 | O-LCF | 8 | 0~15 | M | When the value increases by "1", the image shifts toward the trailing edge of the paper by approx. 0.4 mm. | 1 | Yes | |
05 | Adjustmen t mode | Printer | Image | 4064 | 0 | Bottom margin adjustment (blank area at the trailing edge of the paper)/Reverse side at duplexing | 24 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 4 |
05 | Adjustmen t mode | Printer | Image | 4064 | 1 | Right margin adjustment (blank area at the right of the paper along the paper feeding direction)/Reverse side at duplexing | 0 | 0~255 | M | When the value increases by "1", the blank area becomes wider by approx. 0.0423 mm. | 4 | |||
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 1st drawer | 4100 | 0 | Plain paper; Long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 37 e-STUDIO357/457: 21 e-STUDIO507: 17 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 1st drawer | 4100 | 1 | Plain paper; Middle size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 37 e-STUDIO357/457: 21 e-STUDIO507: 17 | 4 | Yes |
05 | Adjustmen | Printer | Feeding | Paper aligning | 1st drawer | 4100 | 2 | Plain paper; Short | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
t mode | system/Pa | amount adjustment | size1 | contents | “1”, the aligning amount increases by approx. 0.3 mm. | |||||||||
per | e-STUDIO357/457/507: When the value increases by | |||||||||||||
transport | “1”, the aligning amount increases by approx. 0.4 mm. | |||||||||||||
<Paper length> | ||||||||||||||
Long size: 330 mm or longer | ||||||||||||||
Middle size: 220 mm to 329 mm | ||||||||||||||
Short size: 219 mm or shorter | ||||||||||||||
<Default value> | ||||||||||||||
e-STUDIO207L/257/307: 37 | ||||||||||||||
e-STUDIO357/457: 21 | ||||||||||||||
e-STUDIO507: 17 | ||||||||||||||
05 | Adjustmen | Printer | Feeding | Paper aligning | 2nd drawer | 4101 | 0 | Plain paper; Long | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
t mode | system/Pa | amount adjustment | size | contents | “1”, the aligning amount increases by approx. 0.3 mm. | |||||||||
e-STUDIO207L/257/307: 30 | ||||||||||||||
e-STUDIO357/457: 15 | ||||||||||||||
e-STUDIO507: 9 |
05 | Adjustmen | Printer | Feeding | Paper aligning | 2nd drawer | 4101 | 1 | Plain paper; Middle | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
e-STUDIO207L/257/307: 28 | ||||||||||||||
e-STUDIO507: 9 | ||||||||||||||
05 | Adjustmen | Printer | Feeding | Paper aligning | 2nd drawer | 4101 | 2 | Plain paper; Short | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
e-STUDIO207L/257/307: 25 | ||||||||||||||
e-STUDIO357/457: 14 | ||||||||||||||
e-STUDIO507: 9 |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4103 | 0 | Plain paper; Long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4103 | 1 | Plain paper; Middle size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4103 | 2 | Plain paper; Short size1 | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4104 | 0 | Thick paper1; Long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4104 | 1 | Thick paper1; Middle size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4104 | 2 | Thick paper1; Short size1 | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4105 | 0 | Thick paper2; Long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4105 | 1 | Thick paper2; Middle size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4105 | 2 | Thick paper2; Short size1 | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4106 | 0 | Thick paper3; Long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4106 | 1 | Thick paper3; Middle size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4106 | 2 | Thick paper3; Short size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4106 | 3 | Postcard | 35 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4107 | 0 | OHP film; Long size | 24 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4107 | 1 | OHP film; Middle size | 24 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Bypass feeding | 4107 | 2 | OHP film; Short size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | PFP upper drawer | 4108 | 0 | Plain paper; Long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 30 e-STUDIO357/457: 15 e-STUDIO507: 12 | 4 | Yes |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP upper drawer | 4108 | 1 | Plain paper; Middle | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
t mode | system/Pa | amount adjustment | size | contents | “1”, the | |||||||||
per | aligning amount increases by approx. 0.3 mm. | |||||||||||||
transport | e-STUDIO357/457/507: When the value increases by | |||||||||||||
“1”, the aligning amount increases by approx. 0.4 mm. | ||||||||||||||
e-STUDIO507: 12 | ||||||||||||||
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP upper drawer | 4108 | 2 | Plain paper; Short | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
per | aligning amount increases by approx.0.3 mm. | |||||||||||||
“1”, the aligning amount increases by approx.0.4 mm. | ||||||||||||||
e-STUDIO507: 9 |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP lower drawer | 4109 | 0 | Plain paper; Long | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP lower drawer | 4109 | 1 | Plain paper; Middle | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
e-STUDIO507: 12 |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | PFP lower drawer | 4109 | 2 | Plain paper; Short size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx.0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx.0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 25 e-STUDIO357/457: 14 e-STUDIO507: 9 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | ADU | 4110 | 0 | Plain paper; Long size | 19 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | ADU | 4110 | 1 | Plain paper; Middle size | 19 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | ADU | 4110 | 2 | Plain paper; Short size | 19 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | T-LCF | 4111 | Plain paper | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx.0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx.0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 25 e-STUDIO357/457: 14 e-STUDIO507: 9 | 1 | Yes | |
05 | Adjustmen t mode | Printer | Paper feeding | Adjustment of paper pushing amount/Bypass feeding | 4112 | 0 | Plain paper | 0 | 0~20 | M | When the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section. *Postcard is supported only for JPN model. | 4 | ||
05 | Adjustmen t mode | Printer | Paper feeding | Adjustment of paper pushing amount/Bypass feeding | 4112 | 1 | Postcard | 0 | 0~20 | M | When the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section. *Postcard is supported only for JPN model. | 4 | ||
05 | Adjustmen t mode | Printer | Paper feeding | Adjustment of paper pushing amount/Bypass feeding | 4112 | 3 | Envelope | 0 | 0~20 | M | When the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section. *Postcard is supported only for JPN model. | 4 |
05 | Adjustmen t mode | Printer | Paper feeding | Adjustment of paper pushing amount/Bypass feeding | 4112 | 4 | Thick paper 1 | 0 | 0~20 | M | When the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section. *Postcard is supported only for JPN model. | 4 | ||
05 | Adjustmen t mode | Printer | Paper feeding | Adjustment of paper pushing amount/Bypass feeding | 4112 | 5 | Thick paper 2 | 0 | 0~20 | M | When the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section. *Postcard is supported only for JPN model. | 4 | ||
05 | Adjustmen t mode | Printer | Paper feeding | Adjustment of paper pushing amount/Bypass feeding | 4112 | 6 | Thick paper 3 | 0 | 0~20 | M | When the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section. *Postcard is supported only for JPN model. | 4 | ||
05 | Adjustmen t mode | Printer | Paper feeding | Adjustment of paper pushing amount/Bypass feeding | 4112 | 7 | OHP film | 0 | 0~20 | M | When the value increases by "1", the driving speed of bypass feed roller increases by approx. 10 msec. when the paper transport is started from the registration section. *Postcard is supported only for JPN model. | 4 | ||
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 1st drawer | 4115 | 0 | Thick paper1; Long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 37 e-STUDIO357/457: 21 e-STUDIO507: 17 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 1st drawer | 4115 | 1 | Thick paper1; Middle size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 37 e-STUDIO357/457: 21 e-STUDIO507: 17 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 1st drawer | 4115 | 2 | Thick paper1; Short size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 37 e-STUDIO357/457: 21 e-STUDIO507: 17 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 1st drawer | 4115 | 3 | Thick paper2; Long size | 20 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 1st drawer | 4115 | 4 | Thick paper2; Middle size | 20 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 1st drawer | 4115 | 5 | Thick paper2; Short size | 20 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | 2nd drawer | 4116 | 0 | Thick paper1; Long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 37 e-STUDIO357/457: 20 e-STUDIO507: 9 | 4 | Yes |
05 | Adjustmen | Printer | Feeding | Paper aligning | 2nd drawer | 4116 | 1 | Thick paper1; Middle | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
e-STUDIO357/457: 20 | ||||||||||||||
05 | Adjustmen | Printer | Feeding | Paper aligning | 2nd drawer | 4116 | 2 | Thick paper1; Short | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
e-STUDIO207L/257/307: 31 | ||||||||||||||
e-STUDIO357/457: 16 | ||||||||||||||
e-STUDIO507: 9 |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP upper drawer | 4117 | 0 | Thick paper1; Long | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP upper drawer | 4117 | 1 | Thick paper1; Middle | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
e-STUDIO507: 12 |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP upper drawer | 4117 | 2 | Thick paper1; Short | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP lower drawer | 4118 | 0 | Thick paper1; Long | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
e-STUDIO507: 12 |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP lower drawer | 4118 | 1 | Thick paper1; Middle | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
05 | Adjustmen | Printer | Feeding | Paper aligning | PFP lower drawer | 4118 | 2 | Thick paper1; Short | Refer to | 0~63 | M | e-STUDIO207L/257/307: When the value increases by | 4 | Yes |
e-STUDIO507: 9 |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | T-LCF | 4119 | Thick paper1 | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 37 e-STUDIO357/457: 15 e-STUDIO507: 9 | 1 | Yes | |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | ADU | 4120 | 0 | Thick paper1; Long size | 19 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | ADU | 4120 | 1 | Thick paper1; Middle size | 19 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | ADU | 4120 | 2 | Thick paper1; Short size | 19 | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Registration section | 4405 | 0 | Bypass feed/Envelope; long size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Registration section | 4405 | 1 | Bypass feed/Envelope; middle size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Feeding system/Pa per transport | Paper aligning amount adjustment | Registration section | 4405 | 2 | Bypass feed/Envelope; short size | Refer to contents | 0~63 | M | e-STUDIO207L/257/307: When the value increases by “1”, the aligning amount increases by approx. 0.3 mm. e-STUDIO357/457/507: When the value increases by “1”, the aligning amount increases by approx. 0.4 mm. <Paper length> Long size: 330 mm or longer Middle size: 220 mm to 329 mm Short size: 219 mm or shorter <Default value> e-STUDIO207L/257/307: 44 e-STUDIO357/457/507: 28 | 4 | Yes |
05 | Adjustmen t mode | Printer | Drive | Fine adjustment of reverse motor speed | 4817 | - | For resolution in inches | 128 | 0~255 | M | When the value increases by "1", the rotation accelerates by approx. 0.05%. | 1 | ||
05 | Adjustmen t mode | Printer | Drive | Fine adjustment of reverse motor speed | 4818 | - | For FAX resolution in millimeters | 128 | 0~255 | M | When the value increases by "1", the rotation accelerates by approx. 0.05%. | 1 | ||
05 | Adjustmen t mode | Printer | Printer | Tray position judgment time adjustment | 4819 | 0 | Drawer (upper/lower) | 44 | 0~255 | M | 4 | |||
05 | Adjustmen t mode | Printer | Printer | Tray position judgment time adjustment | 4819 | 1 | PFP drawer (upper/lower) | 44 | 0~255 | M | 4 | |||
05 | Adjustmen t mode | Printer | Finisher | Stapling position adjustment value | 4820 | 0 | LD/A3 | 0 | -17~17 | M | 4 | |||
05 | Adjustmen t mode | Printer | Finisher | Stapling position adjustment value | 4820 | 1 | LG/B4/8K/A4-R/LT- R/16K-R | 0 | -17~17 | M | 4 | |||
05 | Adjustmen t mode | Printer | Finisher | Paper stack folding position adjustment value | 4821 | 0 | LD/A3 | 0 | -17~17 | M | 4 | |||
05 | Adjustmen t mode | Printer | Finisher | Paper stack folding position adjustment value | 4821 | 1 | LG/B4/8K/A4-R/LT- R/16K-R | 0 | -17~17 | M | 4 | |||
05 | Adjustmen t mode | Printer | Finisher | Alignment position adjustment | 4822 | 0 | Front | 0 | -17~17 | M | 4 |
05 | Adjustmen t mode | Printer | Finisher | Alignment position adjustment | 4822 | 1 | Rear | 0 | -17~17 | M | 4 | |||
05 | Adjustmen t mode | Printer | Finisher | Stapling position adjustment | 4823 | 0 | One place (Rear) | 0 | -25~25 | M | 4 | Yes | ||
05 | Adjustmen t mode | Printer | Finisher | Stapling position adjustment | 4823 | 1 | One place (Rear/R- series sizes) | 0 | -17~25 | M | 4 | Yes | ||
05 | Adjustmen t mode | Printer | Finisher | Stapling position adjustment | 4823 | 2 | One place (Front) | 0 | -25~25 | M | 4 | Yes | ||
05 | Adjustmen t mode | Printer | Finisher | Stapling position adjustment | 4823 | 3 | One place (Front/R- series sizes) | 0 | -25~17 | M | 4 | Yes | ||
05 | Adjustmen t mode | Printer | Finisher | Stapling position adjustment | 4823 | 4 | Two places (Center) | 0 | -17~17 | M | 4 | Yes | ||
05 | Adjustmen t mode | Printer | Finisher | Stapling position adjustment | 4823 | 5 | Two places (Pitch) | 0 | -15~12 | M | 4 | Yes | ||
05 | Adjustmen t mode | Printer | Finisher | 4824 | Punching position center adjustment | 0 | -15~15 | M | 1 | Yes | ||||
05 | Adjustmen t mode | Printer | Finisher | 4825 | Punch hole position adjustment | 0 | -20~12 | M | 1 | Yes | ||||
05 | Adjustmen t mode | Printer | Finisher | 4826 | Saddle stitch alignment adjustment | 0 | -15~15 | M | 1 | Yes | ||||
05 | Adjustmen t mode | Printer | Finisher | 4827 | Gripper arm exiting position adjustment | 0 | -15~15 | M | 1 | Yes | ||||
05 | Adjustmen t mode | Image Processin g | Backgroun d offset adjustmen t | PPC/NW SCN/FAX(black) | 7025 | ADF | 128 | 0~255 | SYS | The smaller the adjustment value is, the lighter the background becomes. The larger the adjustment value is, the darker the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d offset adjustmen t | SCN(color) | 7026 | ADF | 128 | 0-255 | SYS | The smaller the adjustment value is, the lighter the background becomes. The larger the adjustment value is, the darker the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | Black/Automatic density adjustment | 7033 | Text/Photo | 128 | 0~255 | SYS | The larger the value is, the lighter the background becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | Black/Automatic density adjustment | 7034 | Text | 128 | 0~255 | SYS | The larger the value is, the lighter the background becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | Black/Manual density adjustment | 7041 | Text/Photo | 128 | 0~255 | SYS | The larger the value is, the lighter the background becomes. | 1 | Yes |
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | Black/Manual density adjustment | 7042 | Text | 128 | 0~255 | SYS | The larger the value is, the lighter the background becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | Black/Automatic density adjustment | 7043 | Photo | 128 | 0~255 | SYS | The larger the value is, the lighter the background becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | Black/Manual density adjustment | 7048 | Photo | 128 | 0~255 | SYS | The larger the value is, the lighter the background becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | PPC(black) | 7056 | Text/Photo | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | PPC(black) | 7057 | Text | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | PPC(black) | 7058 | Photo | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Smudged/f aint text adjustmen t | PPC(black) | 7097 | Text/Photo | 2 | 0~4 | SYS | 0: Faint text is suppressed most. 4: Smudged text is suppressed most. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Smudged/f aint text adjustmen t | PPC(black) | 7098 | Text | 2 | 0~4 | SYS | 0: Faint text is suppressed most. 4: Smudged text is suppressed most. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | 7100 | Text/Photo | 128 | 0-255 | SYS | The larger the value, the darker the background becomes. The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | 7101 | Text | 128 | 0-255 | SYS | The larger the value, the darker the background becomes. The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | 7102 | Photo | 128 | 0-255 | SYS | The larger the value, the darker the background becomes. The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | PPC(black) | 7106 | User custom | 128 | 0-255 | SYS | The larger the value, the darker the background becomes. The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | PPC(black) | Manual adjustment/Center value | 7114 | Text/Photo | 128 | 0~255 | SYS | The larger the value is, the darker the image at the center value becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | PPC(black) | Manual adjustment/Center value | 7115 | Text | 128 | 0~255 | SYS | The larger the value is, the darker the image at the center value becomes. | 1 | Yes |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | PPC(black) | Manual adjustment/Center value | 7116 | Photo | 128 | 0~255 | SYS | The larger the value is, the darker the image at the center value becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | PPC(black) | Automatic density adjustment | 7123 | Text/Photo | 128 | 0~255 | SYS | When the value increases, the image becomes darker. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | PPC(black) | Automatic density adjustment | 7124 | Text | 128 | 0~255 | SYS | When the value increases, the image becomes darker. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | PPC(black) | Automatic density adjustment | 7125 | Photo | 128 | 0~255 | SYS | When the value increases, the image becomes darker. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | PPC(black) | Manual adjustment/Center value | 7134 | User custom | 128 | 0-255 | SYS | The larger the value, the darker the image of the center value becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | PPC(black) | Automatic density adjustment | 7137 | User custom | 128 | 0-255 | SYS | The larger the value, the darker the image becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | PPC(black) | 7150 | User custom | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-7617) becomes larger. When the value increases, the effect of reducing streaks (set with 08-7617) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 | |||
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | PPC(black) | 7151 | Text/Photo | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-7617) becomes larger. When the value increases, the effect of reducing streaks (set with 08-7617) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 | |||
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | PPC(black) | 7152 | Text | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-7617) becomes larger. When the value increases, the effect of reducing streaks (set with 08-7617) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 | |||
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | PPC(black) | 7153 | Photo | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-7617) becomes larger. When the value increases, the effect of reducing streaks (set with 08-7617) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 |
05/08 | Mode | Element | Sub element | Item | Subitem | Code | Sub- code | Details | Default value | Acceptable value | RAM | Contents | Proc edure | Service UI |
05 | Adjustmen t mode | Image Processin g | Automatic gamma adjustmen t | PPC(black) | 7165 | All media types | - | - | - | When color deviation is found in gradation reproduction, the gradation reproduction of color K can be corrected with the automatic gamma adjustment. The result of the correction above will be applied to all media types. | 7 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Text/Photo | 7190 | 0 | Low density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Text/Photo | 7190 | 1 | Medium density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Text/Photo | 7190 | 2 | High density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Text | 7191 | 0 | Low density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Text | 7191 | 1 | Medium density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Text | 7191 | 2 | High density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Photo | 7192 | 0 | Low density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Photo | 7192 | 1 | Medium density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | Photo | 7192 | 2 | High density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text/Photo | 7218 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text/Photo | 7218 | 1 | Beam level 1/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text/Photo | 7218 | 2 | Beam level 2/4 | 5 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text/Photo | 7218 | 3 | Beam level 3/4 | 6 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text/Photo | 7218 | 4 | Beam level 4/4 | 7 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text | 7219 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text | 7219 | 1 | Beam level 1/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text | 7219 | 2 | Beam level 2/4 | 5 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text | 7219 | 3 | Beam level 3/4 | 6 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Text | 7219 | 4 | Beam level 4/4 | 8 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Photo | 7220 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Photo | 7220 | 1 | Beam level 1/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Photo | 7220 | 2 | Beam level 2/4 | 5 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Photo | 7220 | 3 | Beam level 3/4 | 6 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | PPC(black) | Photo | 7220 | 4 | Beam level 4/4 | 8 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Range correction adjustmen t | PPC(black) | Black/Manual density adjustment | 7237 | User custom | 1 | 0~1 | SYS | 0: Background peak - Fixed 1: Background peak - Varied | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | PPC(black) | 7249 | User custom | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | |||
05 | Adjustmen t mode | Image Processin g | Smudged/f aint text adjustmen t | PPC(black) | 7252 | User custom | 2 | 0~4 | SYS | 0: Smudged text is suppressed most. 4: Faint text is suppressed most. | 1 | |||
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | User custom | 7276 | 0 | Low density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | User custom | 7276 | 1 | Medium density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PPC(black) | User custom | 7276 | 2 | High density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Range correction adjustmen t | PPC(black) | Black/Manual density adjustment | 7286 | Text/Photo | 1 | 0~1 | SYS | 0: Background peak - Fixed 1: Background peak - Varied | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Range correction adjustmen t | PPC(black) | Black/Manual density adjustment | 7287 | Text | 1 | 0~1 | SYS | 0: Background peak - Fixed 1: Background peak - Varied | 1 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PS/Smooth/600dpi | 7315 | 0 | Low density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PS/Smooth/600dpi | 7315 | 1 | Medium density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PS/Smooth/600dpi | 7315 | 2 | High density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PS/Detail/600dpi | 7316 | 0 | Low density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PS/Detail/600dpi | 7316 | 1 | Medium density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PS/Detail/600dpi | 7316 | 2 | High density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PCL/Smooth/600dpi | 7317 | 0 | Low density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PCL/Smooth/600dpi | 7317 | 1 | Medium density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PCL/Smooth/600dpi | 7317 | 2 | High density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PCL/Detail/600dpi | 7318 | 0 | Low density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PCL/Detail/600dpi | 7318 | 1 | Medium density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | PCL/Detail/600dpi | 7318 | 2 | High density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | XPS/Smooth/600dpi | 7319 | 0 | Low density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | XPS/Smooth/600dpi | 7319 | 1 | Medium density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | XPS/Smooth/600dpi | 7319 | 2 | High density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | XPS/Detail/600dpi | 7320 | 0 | Low density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | XPS/Detail/600dpi | 7320 | 1 | Medium density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | PRT(black) | XPS/Detail/600dpi | 7320 | 2 | High density | 128 | 0~255 | SYS | When the value increases, the density in the target area becomes higher. L: Low density area M: Medium density area H: High density area | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Image | Adjustment of smudged/faint text | PRT | 7325 | PS | 5 | 0~9 | M | Adjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed. | 1 | Yes |
05 | Adjustmen t mode | Image Processin g | Image | Adjustment of smudged/faint text | PRT | 7326 | PCL | 5 | 0~9 | M | Adjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Image | Adjustment of smudged/faint text | PRT | 7327 | XPS | 5 | 0~9 | M | Adjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed. | 4 | Yes | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving OFF | 7350 | 0 | Beam level 0/4 | 0 | 0~10 | M | Adjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving OFF | 7350 | 1 | Beam level 1/4 | 4 | 0~10 | M | Adjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving OFF | 7350 | 2 | Beam level 2/4 | 5 | 0~10 | M | Adjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving OFF | 7350 | 3 | Beam level 3/4 | 6 | 0~10 | M | Adjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving OFF | 7350 | 4 | Beam level 4/4 | 8 | 0~10 | M | Adjustment of the smudged/faint text. With decreasing the value, the faint text is suppressed, and with increasing it, the smudged text is suppressed. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PS | 7351 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PS | 7351 | 1 | Beam level 1/4 | 1 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PS | 7351 | 2 | Beam level 2/4 | 2 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PS | 7351 | 3 | Beam level 3/4 | 3 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PS | 7351 | 4 | Beam level 4/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PCL | 7352 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PCL | 7352 | 1 | Beam level 1/4 | 1 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PCL | 7352 | 2 | Beam level 2/4 | 2 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PCL | 7352 | 3 | Beam level 3/4 | 3 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/PCL | 7352 | 4 | Beam level 4/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/XPS | 7353 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/XPS | 7353 | 1 | Beam level 1/4 | 1 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/XPS | 7353 | 2 | Beam level 2/4 | 2 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/XPS | 7353 | 3 | Beam level 3/4 | 3 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Toner saving ON/XPS | 7353 | 4 | Beam level 4/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Hardcopy security printing | 7354 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Hardcopy security printing | 7354 | 1 | Beam level 1/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Hardcopy security printing | 7354 | 2 | Beam level 2/4 | 5 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Hardcopy security printing | 7354 | 3 | Beam level 3/4 | 6 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Hardcopy security printing | 7354 | 4 | Beam level 4/4 | 8 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Test print | 7355 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Test print | 7355 | 1 | Beam level 1/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Test print | 7355 | 2 | Beam level 2/4 | 5 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Test print | 7355 | 3 | Beam level 3/4 | 6 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Test print | 7355 | 4 | Beam level 4/4 | 8 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Box printing | 7356 | 0 | Beam level 0/4 | 0 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Box printing | 7356 | 1 | Beam level 1/4 | 4 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Box printing | 7356 | 2 | Beam level 2/4 | 5 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Box printing | 7356 | 3 | Beam level 3/4 | 6 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Setting beam level conversion | Black NW printer | Box printing | 7356 | 4 | Beam level 4/4 | 8 | 0~10 | M | The smaller the value is, the narrower the beam width becomes and the smaller the dots are reproduced. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/text | 7360 | 0 | Low density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/text | 7360 | 1 | Medium density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/text | 7360 | 2 | High density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/graphics | 7361 | 0 | Low density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/graphics | 7361 | 1 | Medium density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/graphics | 7361 | 2 | High density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/image | 7362 | 0 | Low density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/image | 7362 | 1 | Medium density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | PS/image | 7362 | 2 | High density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/text | 7366 | 0 | Low density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/text | 7366 | 1 | Medium density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/text | 7366 | 2 | High density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/graphics | 7367 | 0 | Low density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/graphics | 7367 | 1 | Medium density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/graphics | 7367 | 2 | High density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/image | 7368 | 0 | Low density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/image | 7368 | 1 | Medium density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | Monochrome/600dpi/ Auto | XPS/image | 7368 | 2 | High density | 128 | 0-255 | SYS | Larger the value, the density value increases, and smaller the value, the density value decreases. | 4 |
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | SCN(black) | 7400 | User custom | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 | |||
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | SCN(black) | 7401 | Text/Photo | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 | |||
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | SCN(black) | 7402 | Text | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 | |||
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | SCN(black) | 7403 | Photo | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 | |||
05 | Adjustmen t mode | Image Processin g | ADF scan noise reduction | SCN(black) | 7404 | Gray scale | 100 | 0-200 | SYS | When the value decreases, the effect of reducing streaks (set with 08-8300) becomes larger. When the value increases, the effect of reducing streaks (set with 08-8300) becomes smaller. When the value is too small, text might be blurry. When "0" is set, this function is disabled. | 1 | |||
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | SCN(black) | 7430 | Text/Photo | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | SCN(black) | 7431 | Text | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | SCN(black) | 7432 | Photo | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | Yes |
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | SCN(black) | 7433 | Gray scale | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | SCN(black) | 7436 | Text/Photo | 128 | 0-255 | SYS | The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | SCN(black) | 7437 | Text | 128 | 0-255 | SYS | The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | SCN(black) | 7438 | Photo | 128 | 0-255 | SYS | The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | SCN(black) | 7439 | Gray scale | 128 | 0-255 | SYS | The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Backgroun d adjustmen | SCN(black) | 7441 | User custom | 128 | 0-255 | SYS | The smaller the value, the lighter the background becomes. | 1 | Yes | ||
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Manual adjustment/Center value | 7444 | Text/Photo | 128 | 0~255 | SYS | The larger the value is, the darker the image of the center value becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Manual adjustment/Center value | 7445 | Text | 128 | 0~255 | SYS | The larger the value is, the darker the image of the center value becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Manual adjustment/Center value | 7446 | Photo | 128 | 0~255 | SYS | The larger the value is, the darker the image of the center value becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Manual adjustment/Center value | 7447 | Gray scale | 128 | 0~255 | SYS | The larger the value is, the darker the image of the center value becomes. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Automatic density adjustment | 7456 | Text/Photo | 128 | 0~255 | SYS | When the value increases, the image becomes darker. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Automatic density adjustment | 7457 | Text | 128 | 0~255 | SYS | When the value increases, the image becomes darker. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Automatic density adjustment | 7458 | Photo | 128 | 0~255 | SYS | When the value increases, the image becomes darker. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Automatic density adjustment | 7459 | Gray scale | 128 | 0~255 | SYS | When the value increases, the image becomes darker. | 1 | Yes | |
05 | Adjustmen t mode | Image Processin g | Sharpness adjustmen t | SCN(black) | 7470 | User custom | 128 | 0~255 | SYS | The larger the value is, the sharper the image becomes. The smaller the value is, the softer the image becomes and the less moire appears. | 1 | |||
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Manual adjustment/Center value | 7475 | User custom | 128 | 0~255 | SYS | The larger the value is, the darker the image at the center value becomes. | 1 |
05 | Adjustmen t mode | Image Processin g | Density adjustmen t | SCN(black) | Automatic density adjustment | 7478 | User custom | 128 | 0~255 | SYS | The larger the value is, the darker the image at the center value becomes. | 1 | ||
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | User custom | 7480 | 0 | Low density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | User custom | 7480 | 1 | Medium density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | User custom | 7480 | 2 | High density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | Text/Photo | 7485 | 0 | Low density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | Text/Photo | 7485 | 1 | Medium density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | Text/Photo | 7485 | 2 | High density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | Yes |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | Photo | 7487 | 0 | Low density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | Photo | 7487 | 1 | Medium density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | Photo | 7487 | 2 | High density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 | |
05 | Adjustmen t mode | Image Processin g | Gamma balance adjustmen t | SCN(black) | Gray scale | 7488 | 0 | Low density | 128 | 0~255 | SYS | The larger the value is, the darker the image of the area surrounding the target area becomes. | 4 |
