05/08 | Mode | Element | Sub element | Item | Subitem | Code | Sub- code | Details | Default value | Acceptable value | RAM | Contents | Proc edure | Service UI |
08 | Setting mode | System | Network | 8800 | Enabling / Disabling of 802.1X | 2 | 1~2 | NIC | 1: Enabled 2: Disabled | 12 | ||||
08 | Setting mode | System | Network | 8802 | Enabling / Disabling of IPsec | 2 | 1~2 | NIC | 1: Enabled2: Disabled | 12 | ||||
08 | Setting mode | System | Network | 8803 | Enabling / Disabling of SNMPv3 | 2 | 1~2 | NIC | 1: Enabled2: Disabled | 12 | ||||
08 | Setting mode | System | Network | 8804 | Enabling / Disabling of IP filtering | 2 | 1~2 | SYS | 1: Enabled2: Disabled | 1 | ||||
08 | Setting mode | System | Network | 8805 | Enabling / Disabling of MAC address filtering | 2 | 1~2 | SYS | 1: Enabled2: Disabled | 1 | ||||
08 | Setting mode | System | Network | 8820 | IPsec NAT-Traversal setting | 1 | 1~3 | NIC | 1: Default (IKEv1: Disabled, IKEv2: Enabled) 2: Enable IKEv1 & IKEv2 3: Disable IKEv1 & IKEv2 | 12 | ||||
08 | Setting mode | System | Network | 8821 | IPsec CRL setting | 2 | 1~2 | NIC | 1: Enable CRL 2: Disable CRL | 12 | ||||
08 | Setting mode | System | Network | 8824 | FTP client mode | 0 | 0-2 | NIC | Sets the FTP transfer mode when FTP is selected for "FILE" to save the scanned data. 0: Automatic 1: Passive mode 2: Active mode | 12 | ||||
08 | Setting mode | System | Network | 8825 | Sending of host announcement in Super Sleep mode | 1 | 1-2 | NIC | Since MFP is deleted from the master browser of Windows network if MFP is in the Super Sleep mode for 36 minutes or more, enable this setting to always display MFP in the browse list. 1: Enabled 2: Disabled | 12 | ||||
08 | Setting mode | System | Network | Dynamic update of DNS server | 8826 | Enable/Disable setting | 1 | 1-2 | NIC | Sets whether the function that gets the secondary DNS server to work as the primary DNS server temporarily is enabled or not when the primary DNS server is not available. 1: Enabled 2: Disabled | 12 | |||
08 | Setting mode | System | Network | Dynamic update of DNS server | 8827 | Operating interval | 60 | 1-1440 | NIC | Sets the operating interval of dynamic update. 1-1440 (min.) | 12 | |||
08 | Setting mode | System | Network | 8831 | Time-out period for EWB network connection | 60 | 1-300 | SYS | 1 to 300 (sec.) | 1 |
08 | Setting mode | System | General | Registration number for workflow | 8900 | 0 | Total | 2000 | 1000-2000 | SYS | Changes the maximum number for workflow that is registrable. | 4 | ||
08 | Setting mode | System | General | Registration number for workflow | 8900 | 1 | Number of interrupt copy | 1 | 1 | SYS | Changes the maximum number for workflow that is registrable. | 4 | ||
08 | Setting mode | System | General | Registration number for workflow | 8900 | 2 | Number of transmission and calling of Fax/InternetFax | 100 | 10-100 | SYS | Changes the maximum number for workflow that is registrable. | 4 | ||
08 | Setting mode | System | General | Registration number for workflow | 8900 | 3 | Number of printing | 1000 | 150-1000 | SYS | Changes the maximum number for workflow that is registrable. | 4 | ||
08 | Setting mode | System | 8904 | Job jump instruction setting | 0 | 0-1 | SYS | Sets whether waiting job is executed or not if print job in process is interrupted. 0: Disabled 1: Enabled | 1 | |||||
08 | Setting mode | System | 8905 | Forcible printing against unacceptable paper error | 0 | 0-1 | SYS | 0: OFF (printing not continued) 1: ON (printing continued by automatically selecting the available exit tray) | 1 | |||||
08 | Setting mode | System | Continuou s print setting when punching dust box is full | 8906 | Copy | 0 | 0-1 | SYS | 0: OFF (copying not continued) 1: ON (copying continued by canceling punching setting) | 1 | ||||
08 | Setting mode | System | Continuou s print setting when punching dust box is full | 8907 | Printer/e-Filing | 1 | 0-1 | SYS | 0: OFF (copying not continued) 1: ON (copying continued by canceling punching setting) | 1 | ||||
08 | Setting mode | System | General | 8910 | Time to auto-clearing when in the self- diagnostic mode | 0 | 0-5 | SYS | 0: None 1: 1 min. 2: 5 min. 3: 10 min. 4: 30 min. 5: 99 min. | 1 |
08 | Setting mode | System | General | 8911 | Security mode (level) setting | 1 | 1-4 | SYS | Level setting for security function 1: Low level 2: - 3: High level 4: - | 1 | ||||
08 | Setting mode | System | Maintenan ce | General | 8912 | Serial number display of finisher | - | - | - | FIN S/N: XXXXXXXXX | 2 | |||
08 | Setting mode | System | Maintenan ce | General | 8913 | Warning display for password expiration | 15 | 0-30 | SYS | 0: None 1-30: Remaining days until the password expiration for warning start. | 1 | |||
08 | Setting mode | System | MFP function setting | 8914 | 0 | Copy | 1 | 0-1 | SYS | Sets whether the Copier function is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 1 | e-Filing | 1 | 0-1 | SYS | Sets whether the filing function is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 2 | Fax | 1 | 0-1 | SYS | Sets whether the Fax function is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 3 | InternetFAX | 1 | 0-1 | SYS | Sets whether the InternetFAX function is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 4 | 1 | 0-1 | SYS | Sets whether the email function is enabled or disabled. 0: Disabled 1: Enabled | 4 | ||||
08 | Setting mode | System | MFP function setting | 8914 | 5 | Save as Local HDD | 1 | 0-1 | SYS | Sets whether the function that saves data to HDD in the equipment is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 6 | Save as Local HDD from Print | 1 | 0-1 | SYS | Sets whether the function that saves data to HDD in the equipment using print function is enabled or disabled. 0: Disabled 1: Enabled | 4 |
08 | Setting mode | System | MFP function setting | 8914 | 7 | Save as Local HDD from Fax | 1 | 0-1 | SYS | Sets whether the function that saves data to HDD in the equipment using Fax function is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 8 | Save to USB Media | 1 | 0-1 | SYS | Sets whether the function that saves scanned data of originals to USB media is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 9 | Save as FTP | 1 | 0-1 | SYS | Sets whether the function that saves scanned data of originals to FTP server is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 10 | Save as FTPS | 1 | 0-1 | SYS | Sets whether the function that saves scanned data of originals to FTP server using SSL is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 11 | Save as SMB | 1 | 0-1 | SYS | Sets whether the function that saves scanned data of originals to the SMB server is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 12 | Save as Netware | 1 | 0-1 | SYS | Sets whether the function that saves scanned data of originals to the Netware server is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 13 | Web Service Scanning (WS Scan) | 1 | 0-1 | SYS | Sets whether the WS scanning function is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 14 | Twain Scanning (Remote Scan) | 1 | 0-1 | SYS | Sets whether the remote scanning function is enabled or disabled. 0: Disabled 1: Enabled | 4 |
08 | Setting mode | System | MFP function setting | 8914 | 15 | Send to External Controller | 1 | 0-1 | SYS | Sets whether the function that saves data to the external server is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 16 | Network Fax | 1 | 0-1 | SYS | Sets whether the Network Fax function is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | MFP function setting | 8914 | 17 | Network InternetFAX | 1 | 0-1 | SYS | Sets whether the Network InternetFAX function is enabled or disabled. 0: Disabled 1: Enabled | 4 | |||
08 | Setting mode | System | Network | 8915 | Automatic output of jobs at login | 0 | 0-1 | SYS | Sets whether jobs registered in the hold queue of user are automatically output or not when the user logs in. 0: Disabled 1: Enabled | 1 | ||||
08 | Setting mode | System | General | 8919 | Service password | - | - | SYS | Sets the password to log into the self-diagnostic mode and Service UI. | 11 | ||||
08 | Setting mode | System | Option | FAX | 8920 | Output tray for FAX/InternetFAX/e- mail printing | 0 | 0-2 | SYS | Sets the output tray of the equipment or options. <When no options are installed (equipment only)> 0: Inner tray 1: Inner tray 2: Inner tray <MJ-1032 is installed> 0: Stationary tray 1: Movable tray 2: Movable tray <MJ-1033 is installed> 0: Inner tray 1: Movable tray 2: Movable tray <MJ-1101 or MJ-1106 is installed> 0: Inner tray 1: Stationary tray 2: Movable tray <When MJ-5004 or MJ-5006 is installed> 0: Upper tray 1: Lower tray 2: Upper tray <When MJ-5005 is installed> 0: OCT tray 1: OCT tray 2: OCT tray | 1 | |||
08 | Setting mode | System | Departme nt managem ent | 8921 | Clearing of the user/department counter | 1 | 0-1 | SYS | 0: Not allowed 1: Allowed | 1 |
08 | Setting mode | System | User interface | 8922 | Email header print setting | 0 | 0-1 | SYS | Sets whether the header of an Email or an Internet Fax is printed or not as they are received. 0: Not printed 1: Printed | 1 | ||||
08 | Setting mode | System | User interface | 8923 | Email body print setting | 1 | 0-1 | SYS | Sets whether the body of an Email or an Internet Fax is printed or not as they are received. 0: Not printed 1: Printed | 1 | ||||
08 | Setting mode | System | User interface | 8924 | Registration of the received Fax / Internet Fax / Email jobs to hold queue | 0 | 0-1 | SYS | Registers the received Fax / Internet Fax / Email jobs to the hold queue instead of printing immediately. Data in the hold queue are not printed unless the user allows printing by means of the control panel. 0: Not registered (normal printing) 1: Register | 1 | ||||
08 | Setting mode | System | General | 8925 | Data tampering checking at startup | 0 | 0-1 | SYS | Sets whether data tampering is checked or not at startup. 0: Not checked 1: Checked | 1 | ||||
08 | Setting mode | System | Departme nt managem ent | 8926 | Clearing of all department counters | - | - | SYS | In cases when the administrator has prohibited the clearing of department counter data using code 08- 8921, a service technician can clear the data using this code. | 3 | ||||
08 | Setting mode | System | Departme nt managem ent | 8927 | Clearing of all user counter | - | - | SYS | In cases when the administrator has prohibited the clearing of user counter data using code 08-8921, a service technician can clear the data using this code. | 3 | ||||
08 | Setting mode | System | Finisher | Upper limit number of sheets of center fold | 8928 | 0 | Plain / Recycled paper | 0 | -25-25 | SYS | -25 to 25 | 4 | ||
08 | Setting mode | System | Finisher | Upper limit number of sheets of center fold | 8928 | 1 | Thick paper 1 | 0 | -25-25 | SYS | -25 to 25 | 4 | ||
08 | Setting mode | System | Finisher | Upper limit number of sheets of center fold | 8928 | 2 | Thick paper 2 | 0 | -25-25 | SYS | -25 to 25 | 4 | ||
08 | Setting mode | System | Finisher | Upper limit number of sheets of center fold | 8928 | 3 | Thick paper 3 | 0 | -25-25 | SYS | -25 to 25 | 4 | ||
08 | Setting mode | System | Password | 8929 | Administrator password reset | - | - | SYS | The default password is set. When "3: High level" is set for code 08-8911, the default password is set as a temporary password. | 3 | Yes |
08 | Setting mode | System | User interface | Off Device Customization Architecture | 8931 | Output Management Service setting | 1 | 0-1 | SYS | 0: Disabled 1: Enabled | 1 | |||
08 | Setting mode | System | User interface | 8932 | Availability of Netware | 2 | 1-2 | NIC | 1: Enabled 2: Disabled | 12 | ||||
08 | Setting mode | System | User interface | 8933 | SSL setting (SSL SMTP Client Off/on) | 2 | 1-3 | NIC | 1: Enabled (accepts all server certificates) 2: Disabled 3: Enabled (uses the imported CA certificate) | 12 | ||||
08 | Setting mode | System | User interface | 8934 | SSL setting (SMTP Client SSL/TLS) | 1 | 1-2 | NIC | 1:STARTTLS 2:Over SSL | 12 | ||||
08 | Setting mode | System | User interface | 8935 | Remote Scanning | 1 | 0-1 | NIC | 0: Disabled 1: Enabled | 12 | ||||
08 | Setting mode | System | User interface | 8936 | Remote Scanning with SSL | 0 | 0-1 | NIC | 0: Disabled 1: Enabled | 12 | ||||
08 | Setting mode | System | User interface | 8937 | Remote Scanning port number | 20080 | 0-65535 | NIC | 12 | |||||
08 | Setting mode | System | User interface | 8938 | Remote Scanning SSL port number | 20443 | 0-65535 | NIC | 12 | |||||
08 | Setting mode | System | 8942 | Debug level setting | 2 | 0, 2 | - | Sets the output volume of debug log. When the value is set to "0", the performance may decrease. 0: Debug log level - high 2: Debug log level - normal | 1 | |||||
08 | Setting mode | System | Maintenan ce | Remote service | 8946 | 0 | Acquisition starting time for RDMS | 0 | 0- 99999999 | SYS | Month/day/hour/minute of starting time | 14 | ||
08 | Setting mode | System | Maintenan ce | Remote service | 8946 | 1 | Acquisition ending time for RDMS | 0 | 0- 99999999 | SYS | Month/day/hour/minute of ending time | 14 | ||
08 | Setting mode | System | User interface | Card reader | 8947 | Automatic user registration for card authentication | 0 | 0-1 | SSDK | 0: Disabled 1: Enabled | 1 | |||
08 | Setting mode | System | User interface | General | 8948 | Language package information | - | - | - | Displays the information of the installed language package. | 2 | Yes | ||
08 | Setting mode | System | 8952 | External version of HDD data | - | - | - | External version of file system for system software. | 2 |
08 | Setting mode | Printer | Feeding system / Paper transport | 8967 | Rotation printing by guides width of bypass feed tray | 1 | 0-1 | SYS | If the printing size and the guides width of the bypass feed tray are different, it is judged that paper is set in the wrong direction. The occurrence frequency of interruption by the error of the guides width may be decreased. However, this code does not work depending on the conditions, such as when stapling is selected. Set this code when requested by user or the guides width sensor is broken. Related code: 08-4621. 0: Invalid 1: Valid | 1 | ||||
08 | Setting mode | System | User interface | General | 8968 | Language package information (Panel Help) | - | - | - | Displays the language package information of the installed Panel Help. | 2 | |||
08 | Setting mode | System | User interface | General | 8969 | Language package information (WebHelp) | - | - | - | Displays the language package information of the installed WebHelp. | 2 | |||
08 | Setting mode | System | User interface | General | 8970 | Language package information (Service UI) | - | - | - | Displays the language package information of the installed Service UI. | 2 | |||
08 | Setting mode | System | User interface | General | 8971 | Installation of language package | - | - | - | Installs the language package. | 3 | |||
08 | Setting mode | System | General | Self-certificate | 8973 | Length of public key | 1 | 0-1 | SYS | 0: 1024 bit 1: 2048 bit | 1 | |||
08 | Setting mode | System | General | Self-certificate | 8974 | Signature algorithm | 0 | 0-4 | SYS | 0: SHA1 1: SHA224 2: SHA256 3: SHA384 4: SHA512 | 1 | |||
08 | Setting mode | System | Network | 8975 | Data clearing of Point and Print | - | - | SYS | Point and Print in the equipment is deleted when this code is performed. Perform this code when a trouble occurs such as when uploading Point and Print is not possible. After performing this code, upload Point and Print from [Maintenance] menu in the [Administration] menu of TopAccess. | 3 |
08 | Setting mode | System | Scanning | 8980 | Execution of Remote Scan while control panel is operated | 0 | 0-1 | NIC | Sets whether the remote scanning is enabled or disabled if the user is logged in using the control panel when user authentication or department management is enabled. 0: Disabled 1: Enabled | 12 | ||||
08 | Setting mode | System | General | Scheduled automatic reboot | 8981 | Day of the week | 0 | 0-255 | SYS | Sets the condition and day of the week for scheduled automatic reboot. The condition and day of the week are assigned to each bit as follows. Input the sum of each bit as setting value. <Input value> bit1: Monday 0: Disabled 1: Enabled bit2: Tuesday 0: Disabled 2: Enabled bit3: Wednesday 0: Disabled 4: Enabled bit4: Thursday 0: Disabled 8: Enabled bit5: Friday 0: Disabled 16: Enabled bit6: Saturday 0: Disabled 32: Enabled bit7: Sunday 0: Disabled 64: Enabled bit8: Set the condition of reboot 0: Reboots only when in the sleep or super sleep mode 128: Reboots regardless of the sleep mode <Example>
(0+0+0+0+0+0+64+0=64) | 1 | |||
08 | Setting mode | System | General | Scheduled automatic reboot | 8982 | Time (Hour) | 0 | 0-23 | SYS | Sets time (hour) for scheduled automatic reboot. | 1 | |||
08 | Setting mode | System | General | Scheduled automatic reboot | 8983 | Time (Minute) | 0 | 0-59 | SYS | Sets time (minute) for scheduled automatic reboot. | 1 |
08 | Setting mode | System | User interface | NFC reader | 8986 | Usage type | 0 | 0- 429496729 5 | SYS | 0011ZZZZ (First 4 digits are fixed) -ZZZZ: Sub code 0000: No authentication using card 0001: IDm (Felica/NFC-FeliCa) and (or) UID (Mifare/NFC-Mifare) are used 0002: Data (Felica/NFC-FeliCa/Mifare/NFC-Mifare) 0003: SSFC mode | 5 | Yes | ||
08 | Setting mode | System | User interface | NFC reader | 8987 | Format information 1 | 0 | 0- 429496729 5 | SYS | 000ASSSS (hexadecimal, first 3 digits are fixed) -A: 0: A key 1: B key -SSSS: Sector number (first 2 digits are fixed to "0") | 5 | Yes | ||
08 | Setting mode | System | User interface | NFC reader | 8988 | Format information 2 | 0 | 0- 429496729 5 | SYS | 00BSEbse (hexadecimal, first 2 digits are fixed) -B: Block number of first block -S: Starting offset of first block -E: Ending offset of first block -b: Block number of second block -s: Starting offset of second block -e: Ending offset of second block | 5 | Yes | ||
08 | Setting mode | System | User interface | NFC reader | 8989 | Format information 3 | 0 | 0- 0xFFFFFF FFFFFFFF FF | SYS | 0000KKKKKKKKKKKK (hexadecimal, first 4 digits are fixed) -KKKKKKKKKKKK: key (12 digits) | 5 | Yes | ||
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Notification setting | 8991 | Notification setting | 0 | 0~1 | SYS | 0: Disabled 1: Enabled | 2 | Yes | |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Notification day 1 | 8992 | Notification day 1 | 0 | 0-31 | SYS | 1st to 31th. Input "0" to disable this setting. | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Notification day 2 | 8993 | Notification day 2 | 0 | 0-31 | SYS | 1st to 31th. Input "0" to disable this setting. | 1 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Notification day of the week | 8994 | Notification day of the week | 0 | 0-127 | SYS | Input the value which corresponds to the day of the week. Input "0" to disable this setting. Sunday: 64 Monday: 32 Tuesday: 16 Wednesday: 8 Thursday: 4 Friday: 2 Saturday: 1 e.g.) Monday: 32 Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday: 127 (64+32+16+8+4+2+1=127) | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Notification time | 8995 | Notification time | 300 | 0-2359 | SYS | (Hour/Hour/Minute/Minute) | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Email address 1 for notification | 8996 | Email address 1 for notification | - | - | SYS | Maximum 192 characters. | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Email address 2 for notification | 8997 | Email address 2 for notification | - | - | SYS | Maximum 192 characters. | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Email address 3 for notification | 8998 | Email address 3 for notification | - | - | SYS | Maximum 192 characters. | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Adjustment mode (05) data list | 8999 | 1 | Adjustment mode (05) data list | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Setting mode (08) data list | 8999 | 2 | Setting mode (08) data list | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | PM support mode data list | 8999 | 3 | PM support mode data list | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Pixel counter list | 8999 | 4 | Toner cartridge reference | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Pixel counter list | 8999 | 5 | Service engineer reference | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Error history list | 8999 | 6 | Maximum 1000 items | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Error history list | 8999 | 7 | Latest 80 items | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Firmware upgrade log | 8999 | 8 | Maximum 200 items | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Power ON/OFF log | 8999 | 9 | Power ON/OFF log | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Version list | 8999 | 10 | Version list | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Engine firmware log | 8999 | 11 | Engine firmware log | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | Maintenan ce | Notification of equipment information | Total counter list | 8999 | 12 | Total counter list | 0 | 0-1 | SYS | 0: Disabled 1: Enabled | 4 | Yes |
08 | Setting mode | System | General | 9000 | Destination selection | EUR: 0 UC: 1 JPN: 2 | 0~2 | M | 0: EUR 1: UC 2: JPN | 1 | ||||
08 | Setting mode | System | Option | FAX | 9001 | Destination setting | Refer to contents | 0~25 | SYS | 0: Japan 1: Asia 2: TAP 3: Hong Kong 4: U.S.A./Canada 5: Germany 6: U.K. 7: Italy 8: Belgium 9: Netherlands 10: Finland 11: Spain 12: Austria 13: Switzerland 14: Sweden 15: Denmark 16: Norway 17: Portugal 18: France 19: Greece 20: Poland 21: Hungary 22: Czech 23: Turkey 24: South Africa 25: Taiwan <Default value> EUR: 5 UC: 4 JPN: 0 Other: 1 | 1 | Yes | ||
08 | Setting mode | System | General | 9010 | Line adjustment mode | 0 | 0~1 | M | 0: For factory shipment 1: For line Field: "0" must be selected | 1 |
08 | Setting mode | System | User interface | 9012 | Language displayed at power-ON | Refer to contents | - | SYS | <Default value> JPD: Japanese TWD: Traditional Chinese CND: Simplified Chinese KRD: Korean Others: English | 11 | ||||
08 | Setting mode | System | User interface | 9016 | Counter installed externally | 0 | 0-5 | M | 0: No external counter 1: Coin controller (If the value of 08-9979 is "0" (ACS), it is changed to "2" (Full color).) 2: Totalizer/Key card (This value is valid only when "2" is set for 08-9000.) 3: Key counter 5: Coin controller supporting ACS/mixed-size (The value of 08-4131 is set to "1") * "4" cannot be set. | 1 | ||||
08 | Setting mode | System | Counter | 9017 | Setting for counter installed externally | 1 | 0-7 | M | Selects the job to count up for the external counter. 0: Not selected 1: Copier 2: Fax 3: Copier/Fax 4: Printer 5: Copier/Printer 6: Fax/Printer 7: Copier/Fax/Printer | 1 | ||||
08 | Setting mode | System | General | 9022 | Easy setup production process flag | 99 | 0~99 | SYS | Perform this code when an error occurs during the easy setup (unpacking manual adjustment) and you want to finish the easy setup, or when the error is canceled and you want to restart the unpacking manual adjustment. 0: Packing mode finished (before unpacking is started) 1: Auto-toner adjustment finished (The message prompting the installation of the toner cartridge is displayed.) 2: Toner cartridge is installed 3: Automatic gamma adjustment finished 99: All the unpacking adjustments finished | 1 |
08 | Setting mode | System | General | 9023 | Trial period setting | 254 | 1~60 | SYS | Sets the trial period from 1 to 60 days. This setting is effective only when the default value is "254". Once the default value is set, this value is only used for a reference. | 1 | Yes | |||
08 | Setting mode | System | General | 9025 | Notifying condition of trial period end | 3 | 0~255 | SYS | Sets when the end of trial period is notified.0: On the day it ends 1 to 255: n days before | 1 | Yes | |||
08 | Setting mode | System | General | 9026 | Notifying address of trial period end | 3 | 0~3 | SYS | Sets where the end of the trial period is to be notified. 0: OFF 1: User 2: Service center 3: User and service center | 1 | Yes | |||
08 | Setting mode | System | General | 9027 | Forcible end of trial period | - | - | SYS | [CANCEL]: Cancel [INITIALIZE]: Forcible end When the “Forcible end of trial period” is performed, “0” is set in the code (08-9023) to end up the trial period forcibly. | 3 | Yes | |||
08 | Setting mode | System | Initializatio n | 9030 | Initialization after software version up | - | - | SYS | Perform this code when the software in this equipment has been upgraded. | 3 | Yes | |||
08 | Setting mode | System | User interface | Counter installed externally | 9037 | Job handling-short paid-coin controller | 1 | 0~1 | SYS | Sets whether pause or stop the printing job when it is short paid using a coin controller.0: Pause the job 1: Stop the job | 1 | Yes | ||
08 | Setting mode | System | Maintenan ce | General | 9050 | Performing panel calibration | - | - | SYS | Performs the calibration of the pressing position on the touch panel (LCD screen). The calibration is performed by pressing 4 reference positions after this code is started up. | 1 | Yes | ||
08 | Setting mode | System | User interface | Screen setting | 9051 | Panel calibration setting value | 0 | 0~1 | SYS | Switches whether the screen for displaying panel calibration setting values is displayed or not.0: Disabled (screen not displayed) 1: Enabled (screen displayed) | 1 | Yes | ||
08 | Setting mode | System | 9060 | Destination display at SRAM initialization | Refer to contents | 0-255 | SYS | 0: MJD 1: NAD 2: JPD 3: AUD 4: CND 5: KRD 6: TWD 7: SAD 8: ASU 9: ASD 10: ARD <Default value> MJD: 0 NAD: 1 JPD: 2 AUD: 3 CND: 4 KRD: 5 TWD: 6 SAD: 7 ASU: 8 ASD: 9 ARD: 10 | 2 | |||||
08 | Setting mode | System | HDD | 9065 | HDD diagnostic menu display | - | - | SYS | Display the HDD information | 2 | Yes | |||
08 | Setting mode | System | HDD | 9072 | Performing HDD testing | - | - | SYS | Checks the bad sector. It may take more than 30 minutes to finish the checking. | 3 | Yes |
08 | Setting mode | System | General | 9081 | Initialization of department management information | - | - | SYS | Initializing of the department management information * Key in the code and press the [INITIALIZE] button to perform the initialization. If the area storing the department management information is destroyed for some reason, “Enter Department Code” is displayed on the control panel even if the department management function is not set on. In this case, initialize the area with this code. This area is normally initialized at the factory. | 3 | ||||
08 | Setting mode | System | Initializatio n | Initialization of NIC information | 9083 | Initialization of NIC information | - | - | SYS | Returns the value to the factory shipping default value. | 3 | Yes | ||
08 | Setting mode | System | All clearing | 9090 | Printer all clear | - | - | M | If the data of the self-diagnosis 05/08 code become abnormal, performing 08-4582 can restore them. If not, perform this code. All data of the self-diagnosis 05/08 code with "M" in the "RAM" field are initialized, except the destination setting data. Perform this code if the above problem occurs or the data of the self-diagnosis 05/08 code and the backup data are damaged after replacing the LGC board and performing 08-4582. Procedure: 1. Set 08-9000. 2. Perform 08-9090. 3. Perform 08-4581. 4. Set 08-9080 to "0". If you have got the order wrong, repeat the procedure from step 1. After this code is performed, it is necessary to replace the developer material and to adjust the autotoner sensor. Since the information of the PM counter is initialized, enter it again as required. | 3 | Yes | |||
08 | Setting mode | System | General | 9100 | Date and time setting | - | 13 digits | - | Year/month/date/day/hour/minute/second Example:03 07 0 13 13 27 48 "Day" - "0" is for "Sunday". Proceeds Monday through Saturday from "1" to "6". | 5 |
08 | Setting | System | User | 9102 | Date display format | Refer to | 0~2 | SYS | 0: YYYY.MM.DD. 1: DD.MM.YYYY 2: MM.DD.YYYY | 1 | ||||
mode | interface | contents | <Default value> | |||||||||||
EUR: 1 | ||||||||||||||
UC: 2 | ||||||||||||||
JPN: 0 | ||||||||||||||
08 | Setting | System | General | 9103 | Time differences | EUR: 24 | 0~47 | SYS | 0: +12.0h 1: +11.5h2: +11.0h 3: +10.5h 4: +10.0h 5: | 1 | ||||
mode | UC: 40 | +9.5h | ||||||||||||
JPN: 6 | 6: +9.0h 7: +8.5h 8: +8.0h 9: +7.5h 10: +7.0h 11: +6.5h | |||||||||||||
12: +6.0h 13: +5.5h 14: +5.0h 15: +4.5h 16: +4.0h 17: | ||||||||||||||
+3.5h | ||||||||||||||
18: +3.0h 19: +2.5h 20: +2.0h 21: +1.5h 22: +1.0h 23: | ||||||||||||||
+0.5h | ||||||||||||||
24: 0.0h 25: -0.5h 26: -1.0h 27: -1.5h 28: -2.0h 29: - | ||||||||||||||
2.5h | ||||||||||||||
30: -3.0h 31: -3.5h 32: -4.0h 33: -4.5h 34: -5.0h 35: - | ||||||||||||||
5.5h | ||||||||||||||
36: -6.0h 37: -6.5h 38: -7.0h 39: -7.5h 40: -8.0h 41: - | ||||||||||||||
8.5h | ||||||||||||||
08 | Setting mode | System | User interface | 9110 | Auto-clear timer setting | 3 | 0~10 | SYS | Timer to return the equipment to the default settings when the [START] button is not pressed after the function and the mode are set 0: Not cleared 1 to 10: Set number x 15 sec. | 1 | ||||
08 | Setting mode | System | User interface | 9111 | Auto power save mode timer setting | 4 | 0~15 | SYS | Timer to automatically switch to the Auto power save mode when the equipment has not been used. 0: Invalid 4: 1 min. 6: 3 min. 7: 4 min. 8: 5 min. 9: 7 min. 10: 10 min. 11: 15 min. 12: 20 min. 13: 30 min. 14: 45 min. 15: 60 min. | 1 | Yes | |||
08 | Setting | System | User | 9112 | Auto Shut Off timer | 21 | 0~21 | SYS | Timer to turn OFF the power or to enter the Sleep | 1 | Yes | |||
mode | interface | setting (Sleep Mode) | Mode automatically when the equipment has not been | |||||||||||
used. | ||||||||||||||
0: 3 min. 1: 5 min. 2: 10 min. 3: 15 min. 4: 20 min. 5: | ||||||||||||||
25 min. 6: 30 min. 7: 40 min. 8: 50 min. 9: 60 min. | ||||||||||||||
10: 70 min. 11: 80 min. 12: 90 min. 13: 100 min. 14: | ||||||||||||||
110 min. 15: 120 min. 16: 150 min. 17: 180 min. 18: | ||||||||||||||
210 min. 19: 240 min. 20: Disabled 21: 1 min. | ||||||||||||||
08 | Setting mode | System | User interface | Energy save | 9113 | Screen setting for automatic energy saver / automatic power OFF | Refer to contents | 0~1 | SYS | 0: OFF 1: ON <Default value> JPD/NAD: 1 Others: 0 | 1 | Yes | ||
08 | Setting mode | System | General | 9117 | Raw printing job(Blank page will not be printed) | 0 | 0~1 | SYS | 0: OFF 1: ON | 1 |
08 | Setting mode | System | User interface | Department setting | 9120 | Department setting | 0 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | Yes | ||
08 | Setting mode | System | User interface | Department setting | 9121 | Print setting without department/registratio n code | 1 | 0~2 | SYS | 0: Printed 1: Not printed (pooled in the invalid queue) 2: Deleted forcibly | 1 | Yes | ||
08 | Setting mode | System | User interface | Department setting | 9122 | Copy | 1 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | Yes | ||
08 | Setting mode | System | User interface | Department setting | 9123 | FAX | 1 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | Yes | ||
08 | Setting mode | System | User interface | Department setting | 9124 | Printer | 1 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | Yes | ||
08 | Setting mode | System | User interface | Department setting | 9125 | Scanning | 1 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | Yes | ||
08 | Setting mode | System | User interface | Department setting | 9126 | List print | 1 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | Yes | ||
08 | Setting mode | System | User interface | External counter | 9129 | Duplex print setting when coin controller is used | 1 | 0~1 | SYS | When the duplex printing is short paid with a coin controller, reverse side of the original is not printed and is considered as a defect (printing job may be cleared). To solve this problem, the selection of printing method is enabled with this setting .0: Invalid (Only one side printed) 1: Valid (Both sides printed/One side printed) | 1 | Yes | ||
08 | Setting mode | System | User interface | 9130 | Highlighting display on LCD | 0 | 0~1 | SYS | 0: Black letter on white background 1: White letter on black background | 1 |
08 | Setting mode | System | User interface | Default mode setting | Default setting | 9132 | Default setting of screen (Function) | 0 | 0-7, 99 | SYS | Sets the screen to be displayed after the auto-clear time has passed or it has recovered from the energy saving mode or sleep mode. 0: COPY 1: FAX 2: SCAN 3: BOX 4: PRINT 5: TEMPLATE 6: MENU 7: JOB STATUS 99: EWB * Only 0 to 7, and 99 can be entered. | 1 | Yes | |
08 | Setting mode | System | User interface | 9133 | Default setting for APS/AMS | 0 | 0~2 | SYS | 0: APS (Automatic Paper Selection) 1: AMS (Automatic Magnification Selection) 2: Not selected | 1 | ||||
08 | Setting mode | System | User interface | Default setting of RADF mode | 9134 | Default setting | 0 | 0~1 | SYS | 0: Continuous feeding (by pressing the [START] button) 1: Single feeding (by setting original on the tray) | 1 | Yes | ||
08 | Setting mode | System | User interface | 9135 | Book type original priority | 0 | 0~1 | SYS | 0: Left page to right page 1: Right page to left page | 1 | ||||
08 | Setting mode | System | User interface | 9136 | Maximum number of copy volume (MAX9) | 1 | 1~3 | SYS | 1: 999 2: 99 3: 9 | 1 | ||||
08 | Setting mode | System | User interface | Default mode setting | Default setting | 9137 | Setting for automatic duplexing mode | 0 | 0~3 | SYS | 0: Invalid 1: Single-sided to duplex copying 2: Double-sided to duplex copying 3: User selection | 1 | Yes | |
08 | Setting mode | System | User interface | 9140 | Paper size selection for [OTHER] button | Refer to contents | 0-255 | SYS | Press the button on the LCD to select the size. <Default value> EUR: FOLIO UC: COMP JPN: A5-R | 9 | ||||
08 | Setting mode | System | User interface | Default setting of RADF mode | 9142 | Default setting of RADF original size | 0 | 0~1 | SYS | 0: Scanned as all in same size 1: Scanned as each original size | 1 | Yes |
08 | Setting mode | System | Paper feeding | 9143 | Time lag before Auto Job Start of bypass feeding | 10 | 0~10 | SYS | Sets the time taken to add paper feeding when paper in the bypass tray has run out during the bypass feed copying. 0: Paper is not drawn in unless the [START] button is pressed. 1-10: Setting value x 0.5 sec. | 1 | ||||
08 | Setting mode | System | User interface | 9144 | Blank copying prevention mode during RADF jamming | 0 | 0~1 | SYS | 0: OFF 1: ON (Start printing when the scanning of each page is finished) | 1 | ||||
08 | Setting mode | System | User interface | Rotation printing | 9146 | Rotation printing at the non-sorting | 0 | 0~1 | SYS | 0: Not rotating 1: Rotating | 1 | Yes | ||
08 | Setting mode | System | User interface | 9147 | Direction priority of original image | 0 | 0~1 | SYS | 0: Automatic 1: Portrait | 1 | ||||
08 | Setting mode | System | User interface | 9148 | Inner receiving tray priority at Non-sort Mode | 0 | 0~1 | SYS | 0: Normal 1: Inner receiving tray | 1 | ||||
08 | Setting mode | System | User interface | 9149 | Width setting for image shift copying (linkage of front side and back side) | 0 | 0~1 | SYS | 0: ON 1: OFF | 1 | ||||
08 | Setting mode | System | User interface | 9150 | Automatic Sorting Mode setting (RADF) | 2 | 0~4 | SYS | 0: Invalid 1: STAPLE 2: SORT 3: GROUP 4: ROTATE SORT | 1 | ||||
08 | Setting mode | System | User interface | 9151 | Default setting of Sorter Mode | 0 | 0~4 | SYS | 0: NON-SORT 1: STAPLE 2: SORT 3: GROUP 4: ROTATE SORT | 1 | ||||
08 | Setting mode | System | User interface | 9152 | Correction of reproduction ratio in editing copy | 10 | 0~10 | SYS | Sets the reproduction ratio for the "X in 1" printing (including magazine sort) to the "Reproduction ratio x Correction ratio". 0: 90% 1: 91% 2: 92% 3: 93% 4: 94% 5: 95% 6: 96% 7: 97% 8: 98% 9: 99% 10: 100% | 1 | ||||
08 | Setting mode | System | User interface | 9153 | Image position in editing | 2 | 0~3 | SYS | Sets the page pasted position for "X in 1" to the upper left corner/center. 0: PPC:Cornering/PRT:Cornering 1: PPC:Centering/PRT:Cornering 2: PPC:Cornering/PRT:Centering 3: PPC:Centering/PRT:Centering | 1 | ||||
08 | Setting mode | System | User interface | 9155 | Magazine sort setting | 0 | 0~1 | SYS | 0: Left page to right page 1: Right page to left page | 1 |
08 | Setting mode | System | User interface | 9156 | 2 in 1/4 in 1 page allocating order setting | 0 | 0~1 | SYS | 0: Horizontal 1: Vertical | 1 | ||||
08 | Setting mode | System | User interface | 9157 | Printing format setting for Time stamp and Page Number | 2 | 0~3 | SYS | Hyphen (with page number) /Dropout (with date, time and page number) 0: OFF/OFF 1: ON/OFF 2: OFF/ON 3: ON/ON Note: Hyphen printing format ON: -1- OFF: 1 | 1 | ||||
08 | Setting mode | System | User interface | Cascade operation setting | PPC/FAX | 9158 | 0 | ON/OFF | 0 | 0~1 | SYS | Sets the tray switch operation if the output tray becomes full of paper while printing. 0: OFF 1: ON | 4 | |
08 | Setting mode | System | User interface | Cascade operation setting | PPC/FAX | 9158 | 1 | Cascade operation | 0 | 0~1 | SYS | 0: Switches one time 1: Circulation (loop) | 4 | |
08 | Setting mode | System | User interface | Cascade operation setting | PRINTER/BOX | 9159 | 0 | ON/OFF | 0 | 0~1 | SYS | Sets the tray switch operation if the output tray becomes full of paper while printing. 0: OFF 1: ON | 4 | |
08 | Setting mode | System | User interface | Cascade operation setting | PRINTER/BOX | 9159 | 1 | Cascade operation | 0 | 0~1 | SYS | 0: Switches one time 1: Circulation (loop) | 4 | |
08 | Setting mode | System | User interface | 9163 | Direction priority for date and time stamp printing | 0 | 0~1 | SYS | 0: Short edge 1: Long edge | 1 | ||||
08 | Setting mode | System | User interface | Paper Feed | 9164 | Auto-start setting for bypass feed printing | 0 | 0~1 | SYS | Sets whether or not feeding a paper automatically into the equipment when it is placed on the bypass tray. 0: OFF (Press the [START] button to start feeding.) 1: ON (Automatic feeding) | 1 | Yes | ||
08 | Setting mode | System | User interface | 9165 | Auto Job start setting for bypass feed printing | 1 | 0~1 | SYS | Sets whether or not feeding a paper automatically into the equipment when it is placed on the bypass tray. 0: OFF (Press the [START] button to start feeding.) 1: ON (Automatic feeding) | 1 | ||||
08 | Setting mode | System | Option | FAX | 9183 | Adaptation of paper source | 0 | 0~1 | SYS | 0: Not subjected for APS judgment 1: Subjected for APS judgment | 1 | Yes | ||
08 | Setting mode | System | User interface | 9184 | Centering printing of primary/secondary direction at AMS | 1 | 0~1 | SYS | 0: Invalid 1: Valid | 1 |
08 | Setting mode | System | User interface | Feeding paper media | 9185 | 0 | Copier | 1 | 1, 16, 17 | SYS | Sets a media type for APS drawer searching in the copier functions. Each bit 0: Excluded from feeding target media Each bit 1: Feeding target media bit 0: Plain paper bit 1: N/A (Always set "0") bit 2: N/A (Always set "0") bit 3: N/A (Always set "0") bit 4: Thick paper 1 | 4 | ||
08 | Setting mode | System | User interface | Feeding paper media | 9185 | 1 | Printer/Box | 1 | 1 | SYS | Sets a media type to print on plain paper in the printer/box functions. This setting is used for drawer searching or media type inconsistency judgment. The setting result does not affect other media types, other than plain paper. Each bit 0: Excluded from feeding target media Each bit 1: Feeding target media bit 0: Plain paper bit 1: N/A (Always set "0") bit 2: N/A (Always set "0") bit 3: N/A (Always set "0") bit 4: N/A (Always set "0") | 4 | ||
08 | Setting mode | System | Network | Retention period | 9193 | Web data retention period | 10 | 3 digits | SYS | When a certain period of time has passed without operation after accessing TopAccess, the data being registered is automatically reset. This period is set at this code. (Unit: Minute) | 1 | Yes | ||
08 | Setting mode | System | General | 9199 | Automatic interruption page setting during printing | 0 | 0~100 | SYS | Sets the number of pages to interrupt the printing automatically. If the setting value is one or more, printing is interrupted when the setting value x 10 is reached, then printing is resumed. 0-100: 0 to 100 pages | 1 | ||||
08 | Setting mode | System | Network | Retention period | 9200 | File retention period | 30 | 0~999 | SYS | 0: No limits 1 to 999: 1 to 999 days | 1 | Yes | ||
08 | Setting mode | System | Network | 9201 | Max. size in email transmission | 30 | 2~100 | SYS | 2 to 100 M bytes | 1 | Yes |
08 | Setting mode | System | Electronic Filing | 9203 | Full guarantee of documents in Electronic Filing when HDD is full | 1 | 0~1 | SYS | Sets the file retention level when editing the files in the Electronic Filing (at CutDoc/SaveDoc command execution). 0: Not full retained 1: Fully retained - Retains the source file until CutDoc/SaveDoc command is completed. * The file is not deleted even if the HDD has become full during the execution of command when “1” is set. | 1 | ||||
08 | Setting mode | System | User interface | 9204 | Binarizing level selection (When judging as black in the ACS Mode) | 3 | 1-5 | SYS | 0: Step -2 1: Step -1 2: Step 0 (center) 3: Step 1 4: Step 2 The binarizing level of each step is set at 08-9230. | 1 | ||||
08 | Setting mode | System | Electronic Filing | 9207 | Default value for user box retention period | 0 | 0~999 | SYS | Sets the data retention period when creating a user box. 0: Not deleted 1 to 999: Retention period (Unit: Day) | 1 | ||||
08 | Setting mode | System | HDD | 9208 | Warning notification- File Share/e-Filling | 90 | 0~100 | SYS | Sets the percentage of HDD partition filled when warning notification is sent. 0 to 100: 0 to 100% * Related code 08-9225 | 1 | Yes | |||
08 | Setting mode | System | Scanning | 9209 | Notification setting of E-mail saving time limit | 3 | 0~99 | SYS | Sets the days left the notification of E-mail saving time limit appears 0 to 99: 0 to 99 days | 1 | ||||
08 | Setting mode | System | Scanning | 9210 | Default setting of partial size when transmitting E-mail | 0 | 0~6 | SYS | Sets the default value for the partial size of E-mail to be transmitted when creating a template. 0: Not divided 1: 64 2: 128 3: 256 4: 512 5: 1024 6: 2048 (Unit: KB) | 1 | ||||
08 | Setting mode | System | Option | FAX | 9211 | Default setting of page by page-I FAX | 0 | 0~4 | SYS | Sets the default value for the page by page of Internet FAX to be transmitted when creating a template. 0: Not divide 1: 256 2: 512 3: 1024 4: 2048 (Unit: KB) | 1 | Yes | ||
08 | Setting mode | System | User interface | Default mode setting | Default setting (SCN) | 9213 | Default setting for density adjustment | 0 | 0~11 | SYS | 0: Automatic density 1: Step -5 2: Step -4 3: Step -3 4: Step -2 5: Step -1 6: Step 0 (center) 7: Step +1 8: Step +2 9: Step +3 10: Step +4 11: Step +5 (1 to 11: Manual density) | 1 | Yes | |
08 | Setting mode | System | User interface | 9214 | Default setting of background adjustment(Full Color) | 5 | 1~9 | SYS | 1: Step -4 2: Step -3 3: Step -2 4: Step -1 5: Step 0 (center) 6: Step +1 7: Step +2 8: Step +3 9: Step +4 | 1 |
08 | Setting mode | System | User interface | Default mode setting | Default setting (SCN) | 9215 | Color mode | 0 | 0~4 | SYS | 0: Black 1: Gray Scale 2: Unused 3: Full Color 4: Auto Color | 1 | Yes | |
08 | Setting mode | System | User interface | Default mode setting | Default setting of resolution (SCN) | 9216 | Full Color | 2 | 0~5 | SYS | 0: 100 dpi 1: 150 dpi 2: 200 dpi 3: 300dpi 4: 400 dpi 5: 600dpi | 1 | Yes | |
08 | Setting mode | System | User interface | Default mode setting | Default setting of resolution (SCN) | 9217 | Gray Scale | 2 | 0~5 | SYS | 0: 100 dpi 1: 150 dpi 2: 200 dpi 3: 300dpi 4: 400 dpi 5: 600dpi | 1 | Yes | |
08 | Setting mode | System | User interface | Default mode setting | Default setting of resolution (SCN) | 9218 | Black | 1 | 0~5 | SYS | 0: 150 dpi 1: 200 dpi 2: 300 dpi 3: 400dpi 4: 600dpi 5: 100dp | 1 | Yes | |
08 | Setting mode | System | User interface | Default mode setting | Default setting (SCN) | 9219 | Original mode (Full color) | 0 | 0~3 | SYS | 0: Text 1: Text/Photo 2: Photo 3: Custom (Valid only when a setting other than "0" is set for 08-8303) | 1 | Yes | |
08 | Setting mode | System | User interface | Default mode setting | Default setting (SCN) | 9220 | Original mode (Black) | 0 | 0~3 | SYS | 0: Text 1: Text/Photo 2: Photo 3: Custom The value other than "0" needs to be set for 08-7401 to select "3: Custom." | 1 | Yes | |
08 | Setting mode | System | User interface | 9221 | Default setting of duplex mode | 0 | 0~2 | SYS | 0: Single 1: Book 2: Tablet | 1 | ||||
08 | Setting mode | System | User interface | 9222 | Default setting of rotation angle of original | 0 | 0~3 | SYS | 0: 0 degree 1: 90 degrees 2: 180 degrees 3: 270 degrees | 1 | ||||
08 | Setting mode | System | User interface | 9223 | Default setting of original paper size | 0 | 0~22 | SYS | 0: Automatic 1: A3 2: A4 3: LD 4: LT 5: A4-R 6: A5-R 7: LT-R 8: LG 9: B4 10: B5 11: ST-R 12: COMP 13: B5-R 14: FOLIO 15: 13”LG 16: 8.5” x 8.5” 18: A6-R 19: Size mixed 20: 8K 21: 16K 22: 16K-R | 1 | ||||
08 | Setting mode | System | General | 9225 | Searching interval of deleting expired flies and checking capacity of HDD partitions | 12 | 1~24 | SYS | Sets the search interval of deleting expired files and checking capacity of HDD partition. (Unit: Hour) * Related code 08-9208 | 1 | ||||
08 | Setting mode | System | User interface | 9226 | Default setting of background adjustment(Gray Scale) | 5 | 1~9 | SYS | 1: Step -4 2: Step -3 3: Step -2 4: Step -1 5: Step 0 (center) 6: Step +1 7: Step +2 8: Step +3 9: Step +4 | 1 |
08 | Setting mode | System | User interface | Default setting of filing format | 9227 | Black | 1 | 0~6 | SYS | 0: TIFF (Multi) 1: PDF (Multi) 3: TIFF (Single) 4: PDF (Single) 5: XPS (Multi) 6: XPS (Single) | 1 | Yes | ||
08 | Setting mode | System | User interface | Default setting of filing format | Storing files | 9228 | Color/ACS | 1 | 0~8 | SYS | 0: TIFF (Multi) 1: PDF (Multi) 2: JPG 3: TIFF (Single) 4: PDF (Single) 5: SLIM PDF (Multi) 6: SLIM PDF (Single) 7: XPS (Multi) 8: XPS (Single) | 1 | Yes | |
08 | Setting mode | System | User interface | Default setting of filing format | Storing files | 9229 | Black | Refer to contents | 0~6 | SYS | 0: TIFF (Multi) 1: PDF (Multi) 3: TIFF (Single) 4: PDF (Single) 5: XPS (Multi) 6: XPS (Single) <Default value> MJD: 1 Others: 0 | 1 | Yes | |
08 | Setting mode | System | Image | Binarizing level setting (When judging as black in the ACS Mode) | 9230 | 0 | Step -2 | 88 | 0-255 | SYS | Sets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204. | 4 | ||
08 | Setting mode | System | Image | Binarizing level setting (When judging as black in the ACS Mode) | 9230 | 1 | Step -1 | 108 | 0-255 | SYS | Sets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204. | 4 | ||
08 | Setting mode | System | Image | Binarizing level setting (When judging as black in the ACS Mode) | 9230 | 2 | Step 0 (center) | 148 | 0-255 | SYS | Sets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204. | 4 | ||
08 | Setting mode | System | Image | Binarizing level setting (When judging as black in the ACS Mode) | 9230 | 3 | Step +1 | 178 | 0-255 | SYS | Sets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204. | 4 | ||
08 | Setting mode | System | Image | Binarizing level setting (When judging as black in the ACS Mode) | 9230 | 4 | Step +2 | 208 | 0-255 | SYS | Sets the binarizing level of each step. When the value increases, the image becomes darker. When the value decreases, the image becomes lighter. Refer to 08- 9204. | 4 | ||
08 | Setting mode | System | Electronic Filing | 9233 | Equipment name and user name setting to a folder when saving files | 0 | 0~2 | SYS | Sets whether or not adding the equipment name and user name to the folder when saving files. 0: Not add 1: Add the equipment name 2: Add the user name | 1 |
08 | Setting mode | System | User interface | 9236 | Default setting of print menu | 1 | 1~4 | SYS | 1: Private print screen (Job list of log-in user is displayed if user authentication is enabled.) 2: Hold print screen (Job list of log-in user is displayed if user authentication is enabled.) 3: Private print screen (If the private print screen is displayed when user authentication is enabled, user list is displayed if user logs in as GUEST, and job list of log-in user is displayed if user logs in as general user.) 4: Hold print screen (If the private print screen is displayed when user authentication is enabled, user list is displayed if user logs in as GUEST, and job list of log-in user is displayed if user logs in as general user.) * If user data department management (08-9264) is changed from OFF to ON, the value in this code changes from "1" to "2", and "3" to "4". The value does not change if it is "2" or"4". Reset this value as necessary when changing user data department management (08-9264) from OFF to ON. | 1 | ||||
08 | Setting mode | System | Data overwrite kit | 9240 | HDD data overwriting type setting | 3 | 0-3 | SYS | Select the type of the overwriting level for deleting HDD data. (This setting is enabled only when the GP-1070 is installed.) 0: LOW Standard overwriting method. 1: MEDIUM More secure overwriting method than LOW. The overwriting time is between LOW and HIGH. 2: HIGH The most secure overwriting method. The overwriting time is the longest. 3: SIMPLE Simple overwriting method. The time for overwriting is the shortest. | 1 | ||||
08 | Setting mode | System | Paper feeding | 9248 | Automatic feed setting of tab paper and insertion sheet(Remote) | 1 | 0~1 | SYS | 0: Disabled 1: Enabled | 1 |
08 | Setting mode | System | User interface | 9251 | Access code entry for Electronic Filing printing | 0 | 0~1 | SYS | 0: Renewed automatically 1: Enter every time | 1 | ||||
08 | Setting mode | System | User interface | 9252 | Clearing timing for files and Electronic Filing Agent | 1 | 0~1 | SYS | 0: Immediately after the completion of scanning 1: Cleared by Auto Clear | 1 | ||||
08 | Setting mode | System | Paper feeding | 9253 | Setting of paper size switching to 13" LG | 0 | 0~2 | SYS | 0: Not switched 1: LG → 13”LG 2: FOLIO → 13”LG | 1 | ||||
08 | Setting Mode | System | Option | FAX | 9255 | FOLIO/A4-R judgment when width of paper is mixed | 0 | 0-1 | SYS | When the value of this code is "0", the paper size is judged by performing switchback. When the value of this code is "1" and the paper size is AB-series, FOLIO is judged as A4-R and switchback is not performed. When the paper size is LT-series, the switchback is always performed. When the value of this code is set to "1", the scanning performance increases at fax transmission. However, the whole image cannot be output since FOLIO is judged as A4-R. 0: Judgment is enabled 1: Judgment is disabled | 1 | |||
08 | Setting mode | System | User interface | 9261 | Maximum number of time job build performed | 1000 | 5~1000 | SYS | Sets the maximum number of time a job build has been performed. 5-1000: 5 to 1000 times | 1 | ||||
08 | Setting mode | System | General | 9264 | User data department management | 0 | 0~1 | SYS | 0: Invalid 1: Valid * When this code is set to "1" (Valid), the department management setting (08-9120) should be "1" (Valid). | 1 | ||||
08 | Setting mode | System | Paper feeding | 9267 | Detection method of 13" LG for single-size document | 0 | 0~1 | SYS | 0: Disabled 1: Enabled | 1 | ||||
08 | Setting mode | System | Option | FAX | 9268 | Inbound FAX function (Forwarding by TSI) | 1 | 0~1 | SYS | 0: OFF(Function disabled) 1: ON(Function enabled) | 1 | Yes | ||
08 | Setting mode | System | Option | FAX | 9269 | Tab/cover sheet-FAX Printing stop function | 0 | 0~1 | SYS | Sets on or off of the printing function of special sheets such as tab or cover sheet of FAX, Email or list print. 0: Function off 1: Function on | 1 | Yes | ||
08 | Setting mode | System | Network | 9271 | Authentication method of "Scan to Email" | 0 | 0~2 | SYS | 0: Disable 1: SMTP authentication 2: LDAP authentication | 1 |
08 | Setting mode | System | Network | 9272 | Setting whether use of Internet FAX is permitted or not when it is given an authentication | 0 | 0~1 | SYS | 0: Not permitted 1: Permitted | 1 | ||||
08 | Setting mode | System | Network | 9274 | "From" address assignment method when it is given an authentication | 0 | 0~2 | SYS | 0: "User name" + @ + "Domain name"1: LDAP search 2: Use the address registered in "From" field of E-mail setting | 1 | ||||
08 | Setting mode | System | Network | 9276 | Setting for "From" address edit at "Scan to Email" | 0 | 0~1 | SYS | 0: Not permitted 1: Permitted | 1 | ||||
08 | Setting mode | System | Network | 9278 | E-mail domain name | - | - | SYS | 96+2 (delimiter) character ASCII sequence only | 11 | ||||
08 | Setting mode | System | User interface | Sound | 9280 | Error sound | 1 | 0~1 | SYS | 0: OFF 1: ON | 1 | Yes | ||
08 | Setting mode | System | User interface | Sound | 9281 | Sound setting -- Energy Saving | Refer to contents | 0~1 | SYS | 0: OFF 1: ON <Default value> JPD: 0 Other: 1 | 1 | Yes | ||
08 | Setting mode | System | General | 9293 | User authentication method | 0 | 0~2 | SYS | 0: Local 1: NTLM (NT Domain) 2: LDAP | 1 | ||||
08 | Setting Mode | System | General | 9294 | Automatic user registration for external authentication | 1 | 0-1 | SYS | 0: Disabled 1: Enabled | 1 | ||||
08 | Setting mode | System | General | 9295 | User data management limitation setting | 0 | 0~1 | SYS | 0: Disabled 1: Enabled | 1 | ||||
08 | Setting mode | System | General | 9296 | User data management limitation Setting by number of printouts | 0 | 7 digits | SYS | 0-9,999,999: 0-9,999,999 sheets | 1 | ||||
08 | Setting mode | System | Network | 9298 | Restriction on Address book operation by administrator | 0 | 0~1 | SYS | Some restrictions can be given on the administrator for operating the Address book. 0: No restriction 1: Can be operated only under the administrator's authorization | 1 |
08 | Setting mode | System | Network | 9299 | Restriction on "To" ("cc") address | 0 | 0~3 | SYS | 0: No restriction 1: Can be set from both of the Address book and LDAP server 2: Can be set only from the Address book 3: Can be set only from the LDAP server | 1 | ||||
08 | Setting mode | System | Paper feeding | 9300 | Drawer 1Paper information | 0 | 0~1 | SYS | 0: Plain paper 1: Thick paper 1 | 1 | ||||
08 | Setting mode | System | Paper feeding | 9301 | Drawer 2Paper information | 0 | 0~1 | SYS | 0: Plain paper 1: Thick paper 1 | 1 | ||||
08 | Setting mode | System | Paper feeding | 9302 | PFP 1 Paper information | 0 | 0~1 | SYS | 0: Plain paper 1: Thick paper 1 | 1 | ||||
08 | Setting mode | System | Paper feeding | 9303 | PFP 2 Paper information | 0 | 0~1 | SYS | 0: Plain paper 1: Thick paper 1 | 1 | ||||
08 | Setting mode | System | Paper feeding | 9304 | LCF Paper information | 0 | 0~1 | SYS | 0: Plain paper 1: Thick paper 1 | 1 | ||||
08 | Setting mode | System | Paper feeding | 9305 | Bypass tray Paper information | 0 | 0~3, 11, 16, 32 | SYS | 0: Plain paper 1: Thick paper 1 2: Thick paper 2 3: Thick paper 3 11: Thin paper 16: OHP film 32: Envelope | 1 | ||||
08 | Setting mode | System | Paper feeding | 9306 | LT <-> A4/LD <-> A3 | 0 | 0~1 | SYS | Sets whether the data is printed on the different but similar size paper or not when the paper of corresponding size is not available. 0: Valid (The data is printed on A4/A3 when LT/LD is selected or vice versa.) 1: Invalid (The message to use the selected paper size is displayed.) | 1 | ||||
08 | Setting mode | System | Network | Retention period | 9307 | Storage period at trail and private | 14 | 0-53 | SYS | 0: No limits 1 to 30: 1 to 30 days 31: 1 hour 32: 2 hours 33: 4 hours 34: 8 hours 35: 12 hours 50: 5 min. 51: 10 min. 52: 15 min. 53: 30 min. | 1 | Yes | ||
08 | Setting mode | System | Network | 9308 | Raw printing job (Duplex) | 1 | 0~1 | SYS | 0: Valid 1: Invalid | 1 | ||||
08 | Setting mode | System | Network | 9309 | Raw printing job(Paper size) | EUR: 6 UC: 2 JPN: 6 | 0 ~13 | SYS | 0: LD 1: LG 2: LT 3: COMP 4: ST 5: A3 6: A4 7: A5 8: A6 9: B4 10: B5 11: FOLIO 12: 13”LG 13: 8.5” x 8.5” | 1 | ||||
08 | Setting mode | System | Network | 9310 | Raw printing job(Paper type) | 0 | 0~6 | SYS | 0: Plain paper 1: Thick paper 1 2: Thick paper 2 3: Thick paper 3 4: OHP film 6: Thin paper | 1 |
08 | Setting mode | System | Network | 9311 | Raw printing job(Paper direction) | 0 | 0~1 | SYS | 0: Portrait 1: Landscape | 1 | ||||
08 | Setting mode | System | Network | 9312 | Raw printing job (Staple) | 1 | 0~1 | SYS | 0: Valid 1: Invalid | 1 | ||||
08 | Setting mode | System | Network | 9313 | Raw printing job(receiving tray) | 0 | 0~6 | SYS | 0: Inner tray 1: Finisher tray 1 2: Finisher tray 2 3: Not used 4: Job Separator upper tray 5: Job Separator lower tray * The settings 4 and 5 are effective only when the Job Separator (MJ- 5004) is installed. | 1 | ||||
08 | Setting mode | System | Network | 9314 | Raw printing job(Number of form lines) | 1200 | 500~12800 | SYS | Sets the number of form lines from 5 to 128. (A hundredfold of the number of form lines is defined as the setting value.) | 1 | ||||
08 | Setting mode | System | Network | 9315 | Raw printing job(PCL font pitch) | 1000 | 44~9999 | SYS | Sets the font pitch from 0.44 to 99.99. (A hundredfold of the font pitch is defined as the setting value.) | 1 | ||||
08 | Setting mode | System | Network | 9316 | Raw printing job(PCL font size) | 1200 | 400~99975 | SYS | Sets the font size from 4 to 999.75. (A hundredfold of the font size is defined as the setting value.) | 1 | ||||
08 | Setting mode | System | Network | 9317 | Raw printing job(PCL font number) | 0 | 0~9999 | SYS | Sets the PCL font number. | 1 | ||||
08 | Setting mode | System | Paper feeding | 9318 | Memory 1 Paper size (bypass feeding/non- standard type) feeding/widthwise direction | 148/100 | 148~432/1 00~297 | SYS | Registers the paper size of bypass feed (non-standard type) into [MEMORY 1]. | 10 | ||||
08 | Setting mode | System | Paper feeding | 9319 | Memory 2 Paper size (bypass feeding/non- standard type) feeding/widthwise direction | 148/100 | 148~432/1 00~297 | SYS | Registers the paper size of bypass feed (non-standard type) into [MEMORY 2]. | 10 |
05/08 | Mode | Element | Sub element | Item | Subitem | Code | Sub- code | Details | Default value | Acceptable value | RAM | Contents | Proc edure | Service UI |
08 | Setting mode | System | Paper feeding | 9320 | Memory 3 Paper size (bypass feeding/non- standard type) feeding/widthwise direction | 148/100 | 148~432/1 00~297 | SYS | Registers the paper size of bypass feed (non-standard type) into [MEMORY 3]. | 10 | ||||
08 | Setting mode | System | Paper feeding | 9321 | Memory 4 Paper size (bypass feeding/non- standard type) feeding/widthwise direction | 148/100 | 148~432/1 00~297 | SYS | Registers the paper size of bypass feed (non-standard type) into [MEMORY 4]. | 10 | ||||
08 | Setting mode | System | User interface | Sound | 9325 | Key touch sound of control panel | 1 | 0~1 | SYS | 0: OFF 1: ON | 1 | Yes | ||
08 | Setting mode | System | User interface | Screen setting | 9326 | Size indicator | 0 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | Yes | ||
08 | Setting mode | System | General | 9327 | Setting of banner advertising display | 0 | 0~1 | SYS | Sets whether or not displaying the banner advertising. The setting contents of 08-9328 and 08-9329 are displayed at the time display section on the right top of the screen. When both are set, each content is displayed alternately. 0: Not displayed 1: Displayed | 1 | ||||
08 | Setting mode | System | General | 9328 | Banner advertising display 1 | - | - | SYS | Maximum 27 letters (one-byte character) | 11 | ||||
08 | Setting mode | System | General | 9329 | Banner advertising display 2 | - | - | SYS | Maximum 27 letters (one-byte character) | 11 | ||||
08 | Setting mode | System | General | 9330 | Display of [BANNER MESSAGE] button | 0 | 0~1 | SYS | 0: Not displayed 1: Displayed * This button enables the entry of "Banner advertising display 1 (08-9328)" and "Banner advertising display 2 (08-9329)" on the control panel. | 1 | ||||
08 | Setting mode | System | Network | 9331 | Local I/F time-out period | 6 | 1~50 | SYS | Sets the period of time when the job is judged as completed in local I/F printing (USB or parallel). 1: 1.0 sec. 2: 1.5 sec. - 50: 25.5 sec. (in increments of 0.5 sec.) | 1 | ||||
08 | Setting mode | System | User interface | 9332 | Original counter display | MJD: 2 Other: 0 | 0,2,4 | SYS | Sets whether the original counter is displayed or not. 0: Not displayed 2: Displayed 4: Displayed (Double sized original is counted as 2.) | 1 |
08 | Setting mode | System | Network | 9334 | PCL line feed code setting | 0 | 0~3 | SYS | Sets the PCL line feed code.0: Automatic setting 1: CR=CR, LF=LF 2: CR=CR+LF, LF=LF 3: CR=CR, LF=CR+LF | 1 | ||||
08 | Setting mode | System | Feeding system/Pa per transport | 9335 | Feeding direction setting of envelope | 0 | 0~1 | SYS | Sets the feeding direction of envelopes. 0: Envelope flap comes on its trailing edge (front side of the equipment) 1: Envelope flap comes on its leading edge (rear side of the equipment) | 1 | Yes | |||
08 | Setting mode | System | Paper feeding | 9336 | Default setting of drawers(Printer/BOX) | 1 | 1~5 | SYS | 1: LCF 2: Upper drawer 3: Lower drawer 4: PFP upper drawer 5: PFP lower drawer | 1 | ||||
08 | Setting mode | System | User interface | 9337 | Restriction of the template function with the administrator privilege | 0 | 0~1 | SYS | Selects the restriction of the template function usage setting. 0: No restriction 1: Only available with the administrator privilege. | 1 | ||||
08 | Setting mode | System | Network | 9338 | Raw printing job(Paper feeding drawer) | 0 | 0~5 | SYS | 0: AUTO1: Upper drawer 2: Lower drawer 3: PFP upper drawer 4: PFP lower drawer 5: LCF | 1 | ||||
08 | Setting mode | System | Network | 9339 | Raw printing job(PCL symbol set) | 0 | 0~39 | SYS | 0: Roman-8 1: ISO 8859/1 Latin 1 2: ISO 8859/2 Latin 2 3: ISO 8859/9 Latin 5 4: PC-8,Code Page 437 5: PC- 8 D/N, Danish/ Norwegian 6: PC-850,Multilingual 7: PC- 852, Latin2 8: PC-8 Turkish 9: Windows 3.1 Latin 1 10: Windows 3.1 Latin 2 11: Windows 3.1 Latin 5 12: DeskTop 13: PS Text 14: Ventura International 15: Ventura US 16: Microsoft Publishing 17: Math-8 18: PS Math 19: Ventura Math 20: Pi Font 21: Legal 22: ISO 4: United Kingdom 23: ISO 6: ASCII 24: ISO 11 25: ISO 15: Italian 26: ISO 17 27: ISO 21: German 28: ISO 60: Danish/Norwegian 29: ISO 69: French 30: Windows 3.0 Latin 1 31: MC Text 32: PC Cyrillic 33: ITC Zapf Dingbats 34: ISO 8859/10 Latin 6 35: PC-775 36: PC- 1004 37: Symbol 38: Windows Baltic 39: Wingdings | 1 | ||||
08 | Setting mode | System | User interface | Binding margin setting | 9341 | 0 | Left binding front (Right binding back) | 7 | 0-100 | SYS | Sets the binding margin displayed as default on the setting screen for the top/bottom/left/right binding function when copying. (Unit: mm) | 4 |
08 | Setting mode | System | User interface | Binding margin setting | 9341 | 1 | Left binding back (Right binding front) | 7 | 0-100 | SYS | Sets the binding margin displayed as default on the setting screen for the top/bottom/left/right binding function when copying. (Unit: mm) | 4 | ||
08 | Setting mode | System | User interface | Binding margin setting | 9341 | 2 | Top binding front (Bottom binding back) | 7 | 0-100 | SYS | Sets the binding margin displayed as default on the setting screen for the top/bottom/left/right binding function when copying. (Unit: mm) | 4 | ||
08 | Setting mode | System | User interface | Binding margin setting | 9341 | 3 | Top binding back (Bottom binding front) | 7 | 0-100 | SYS | Sets the binding margin displayed as default on the setting screen for the top/bottom/left/right binding function when copying. (Unit: mm) | 4 | ||
08 | Setting mode | System | User interface | Binding margin setting | 9342 | Book binding | 14 | 0~30 | SYS | Sets the binding margin displayed as default on the setting screen for the book binding function when copying. | 1 | |||
08 | Setting mode | Printer | Paper feeding | Automatic change of paper source | Auto | 9343 | Printing/BOX printing | 1 | 1~2 | SYS | 1: Only in the same paper direction 2: In both the same and different paper directions | 1 | Yes | |
08 | Setting mode | System | Network | 9344 | Restriction mode of network printing | 0 | 0~3 | SYS | 0: Normal mode 1: Mode for Private Print 2: Mode for Hold Print 3: Mode for Private / Hold Print * When "1" (valid) is set for the code 08-9264 "User data department management", the setting value of this code is automatically set to "2" except for the case "0" is set for this code. Only "0" and "2" are selectable for this code unless "0" (invalid) is set for the code 08- 9264. | 1 | ||||
08 | Setting mode | System | User interface | 9352 | Display of paper size setting by installation operation of drawers | Refer to contents | 0~1 | SYS | 0: Not displayed 1: Displayed <Default value> JPD/MJD: 0 Other: 1 | 1 | ||||
08 | Setting mode | System | General | 9357 | Enhanced bold for PCL6 | 0 | 0~1 | SYS | 0:OFF 1:ON | 1 | ||||
08 | Setting mode | System | User interface | Paper Feed | 9359 | Printing resume after jam releasing | 1 | 0~1 | SYS | 0: Auto resume 1: Resume by users | 1 | Yes |
08 | Setting mode | System | User interface | 9379 | HD data scramble function setting | 0 | 0~2 | SYS | 0: Encryption invalid 1: Encryption valid (Security priority) Encrypts all of the user's data. 2: Encryption valid (Performance priority) Encrypts the user's data except the files temporarily created and deleted in the image processing such as copying or printing. | 1 | ||||
08 | Setting mode | System | User interface | 9380 | Converting 1-byte katakana into 2 byte- katakana at e-mail transmission | 0 | 0~1 | SYS | 0: Non-conversion 1: With conversion | 1 | ||||
08 | Setting mode | System | User interface | Default setting of filing format | 9384 | Color/ACS | 1 | 0~8 | SYS | 0: TIFF (Multi) 1: PDF (Multi) 2: JPG 3: TIFF (Single) 4: PDF (Single) 5: SLIM PDF (Multi) 6: SLIM PDF (Single) 7: XPS (Multi) 8: XPS (Single) | 1 | Yes | ||
08 | Setting mode | System | Network | Notification of scan job | 9386 | 0 | When job completed | 0 | 0~1 | SYS | Sets the notification method of scan job completion. 0: Invalid 1: Valid | 4 | ||
08 | Setting mode | System | Network | Notification of scan job | 9386 | 1 | On error | 0 | 0~1 | SYS | Sets the notification method of scan job completion. 0: Invalid 1: Valid | 4 | ||
08 | Setting mode | System | Network | 9387 | File name format of "Save as file" and Email transmission | 0 | 0~6 | SYS | Sets the naming method of the file of "Save as file" and Email transmission. 0: [FileName]-[Data]-[Page] 1: [FileName]-[Page]-[Data] 2: [Data]-[FileName]-[Page] 3: [Data]-[Page]-[FileName] 4: [Page]-[FileName]-[Data] 5: [Page]-[Data]-[FileName] 6: [HostName]_[Data]-[Page] | 1 |
08 | Setting mode | System | Network | 9388 | Date display format of the file name of "Save as file" and Email transmission | 0 | 0~5 | SYS | Sets the data display format of the file of "Save as file" and Email transmission. 0: [YYYY][MM][DD] [HH][mm][SS] 1: [YY][MM][DD] [HH][mm][SS] 2: [YYYY][MM][DD] 3: [YY][MM][DD] 4: [HH][mm][SS] 5: [YYYY][MM][DD] [HH][mm][SS][mm0] The order of [YY], [MM] and [DD] varies depending on the setting of the code 08-9102 (Data display format). | 1 | ||||
08 | Setting mode | System | Network | 9389 | Single page data saving directory at "Save as file" | 0 | 0~1 | SYS | Sets the directory where the file of "Save as file" is saved. 0: Save it under a subfolder 1: Save it without creating a subfolder | 1 | ||||
08 | Setting mode | System | Network | 9390 | Page number display format of the file of "Save as file" and Email transmission | 4 | 3~6 | SYS | Sets the digit of a page number attached on the file. 3-6: 3-6 digits | 1 | ||||
08 | Setting mode | System | Network | 9391 | Extension (suffix) format of the file of "Save as file" | 3 | 3~6 | SYS | Sets the extension digits of the file to be saved. 3: Auto 4: 4 digits 5: 5 digits 6: 6 digits | 1 | ||||
08 | Setting mode | System | Network | 9394 | Single-page option for storing File and sending Email | 0 | 0~1 | SYS | 0: Sets 1 page as 1 file 1: Makes a file based on the original | 1 | ||||
08 | Setting mode | System | Network | 9397 | Execution of user authentication when the user ID is not entered | 2 | 0~2 | SYS | 0: Forcible execution 1: Execution impossible (pooled in the invalid queue) 2: Forcible deletion | 1 | ||||
08 | Setting mode | System | User interface | Card reader | LDAP authentication | 9398 | LDAP attribute name settings 1 | eBMUse rCard | - | SYS | Maximum 32 characters (ASCII). | 11 | ||
08 | Setting mode | System | Network | 9399 | Role Based Access DAP search index | 0 | Refer to contents | SYS | This code is used to specify the ID for the LDAP server to implement Role-Based Access Control. <Acceptable value> 0~4294967295 | 5 | ||||
08 | Setting mode | System | Network | 9403 | Communication speed and settings of Ethernet | 1 | Refer to contents | NIC | 1: Auto(100MBPS) 3: 10MBPS Full Duplex 5: 100MBPS Full Duplex 6: Auto(1000MBPS) 7: 1000MBPS Full Duplex | 12 |
08 | Setting mode | System | Network | 9406 | Method for acquiring IP address | 2 | 1~3 | NIC | 1: Static IP address 2: Dynamic IP address (DHCP) 3: Dynamic IP address (DHCP) without AutoIP | 12 | ||||
08 | Setting mode | System | Network | Address | 9408 | IP address | Refer to contents | Refer to contents | NIC | <Default value> 0.0.0.0 <Acceptable value> 0.0.0.0-255.255.255.255 | 12 | Yes | ||
08 | Setting mode | System | Network | Address | 9409 | Subnet mask | Refer to contents | Refer to contents | NIC | <Default value> 0.0.0.0 <Acceptable value> 0.0.0.0-255.255.255.255 | 12 | Yes | ||
08 | Setting mode | System | Network | Address | 9410 | Gateway | Refer to contents | Refer to contents | NIC | <Default value> 0.0.0.0 <Acceptable value> 0.0.0.0-255.255.255.255 | 12 | Yes | ||
08 | Setting mode | System | Network | 9411 | Availability of IPX/SPX | 2 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9414 | Availability of AppleTalk | 2 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9416 | Availability of LDAP | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | DNS | 9417 | Availability of DNS | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 | Yes | ||
08 | Setting mode | System | Network | Address | 9418 | IP address to DNS server (Primary) | Refer to contents | Refer to contents | NIC | 000.000.000.000-255.255.255.255 <Default value> 000.000.000.000 <Acceptable value> 0.0.0.0~255.255.255.255 | 12 | Yes | ||
08 | Setting mode | System | Network | Address | 9419 | IP address to DNS server (Secondary) | Refer to contents | Refer to contents | NIC | 000.000.000.000-255.255.255.255 <Default value> 000.000.000.000 <Acceptable value> 0.0.0.0~255.255.255.255 | 12 | Yes | ||
08 | Setting mode | System | Network | 9421 | Availability of SLP | 1 | 1~2 | NIC | Sets the availability of SLP on NetWare. 1: Enabled 2: Disabled | 12 |
08 | Setting mode | System | Network | 9426 | Availability of Bindery | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9427 | Availability of NDS | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9430 | Availability of HTTP server | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9437 | Availability of SMTP client | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9440 | Availability of SMTP server | 1 | 1~2 | UTY | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9446 | Availability of POP3 clients | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9459 | Availability of FTP server | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 | ||||
08 | Setting mode | System | Network | 9463 | MIB function | 1 | 1~2 | NIC | 1: Valid 2: Invalid | 12 | ||||
08 | Setting mode | System | Network | 9473 | Availability of Raw/TCP | 1 | 1~2 | NIC | 1: Valid 2: Invalid | 12 | ||||
08 | Setting mode | System | Network | 9475 | Availability of LPD client | 1 | 1~2 | NIC | 1: Valid 2: Invalid | 12 | ||||
08 | Setting mode | System | Network | 9478 | Availability of IPP | 1 | 1~2 | NIC | 1: Valid 2: Invalid | 12 | ||||
08 | Setting mode | System | Network | 9481 | IPP printer name | MFPseri al | - | NIC | Maximum 127 letters The Network-related serial number of the equipment appears on “serial“ | 12 | ||||
08 | Setting mode | System | Network | 9486 | IPP printer "Make and Model" | mfp model name | - | NIC | Maximum 127 letters | 12 | ||||
08 | Setting mode | System | Network | 9487 | IPP printer information (more) MFGR | - | - | NIC | Maximum 127 letters | 12 | ||||
08 | Setting mode | System | Network | 9488 | IPP message from operator | - | - | NIC | Maximum 127 letters | 12 | ||||
08 | Setting mode | System | Network | 9489 | Availability of FTP print | 1 | 1~2 | NIC | 1: Available 2: Not available | 12 |
08 | Setting mode | System | Network | 9499 | Page number limitation for printing text of received E- mail | 5 | 1~99 | SYS | 1 | |||||
08 | Setting mode | System | Network | 9505 | Bonjour setting | 1 | 1~2 | NIC | 1: Valid 2: Invalid | 12 | ||||
08 | Setting mode | System | Network | 9515 | Windows domain No.1 of user authentication | - | - | UTY | Maximum 128 letters | 12 | ||||
08 | Setting mode | System | Network | 9516 | PDC (Primary Domain Controller) name | - | - | UTY | Maximum 128 letters | 12 | ||||
08 | Setting mode | System | Network | 9517 | BDC (Backup Domain Controller) name | - | - | UTY | Maximum 128 letters | 12 | ||||
08 | Setting mode | System | Network | Address | 9525 | Display of MAC address | - | - | - | (**:**:**:**:**:**) The address is displayed as above. 6-byte data is divided by colon. | 2 | Yes | ||
08 | Setting mode | System | Network | 9548 | SSL setting HTTP server OFF/ON setting | 2 | 1~2 | - | 1: Enabled 2: Disabled | 12 | ||||
08 | Setting mode | System | Network | 9550 | SSL setting IPP server OFF/ON setting | 2 | 1~2 | - | 1: Enabled 2: Disabled | 12 | ||||
08 | Setting mode | System | Network | 9552 | SSL setting SSL ftp server OFF/ON | 2 | 1~2 | - | OFF/ON 1: Valid2: Invalid | 12 | ||||
08 | Setting mode | System | Network | 9556 | SSL setting SSL POP3 Client OFF/ON | 2 | 1~3 | - | OFF/ON 1: Valid 2: Invalid 3: Use imported certificate | 12 | ||||
08 | Setting mode | System | Network | 9563 | IP Conflict Detect | 1 | 1~2 | - | OFF/ON 1: Valid 2: Invalid | 12 | ||||
08 | Setting mode | System | Network | 9564 | SNTP Enable | 2 | 1~2 | - | OFF/ON 1: Valid 2: Invalid | 12 | ||||
08 | Setting mode | System | Network | Enabling server's IP address acquired by DHCP | 9580 | Domain Name Server option (6) | 1 | 1~2 | - | 1: Enabled 2: Disabled * This value is used only when DHCP is enabled. | 12 | |||
08 | Setting mode | System | Network | Enabling server's IP address acquired by DHCP | 9581 | NetBIOS over TCP/IP Name Server option (44) = Primary and Secondary Wins NAME | 1 | 1~2 | - | 1: Enabled 2: Disabled * This value is used only when DHCP is enabled | 12 |
08 | Setting mode | System | Network | Enabling server's IP address acquired by DHCP | 9584 | SMTP Server Option (69) Simple Mail Server Address | 2 | 1~2 | - | 1: Enabled 2: Disabled * This value is used only when DHCP is enabled. | 12 | |||
08 | Setting mode | System | Network | Enabling server's IP address acquired by DHCP | 9585 | POP3 Server Option (70) Post Office Server Address | 2 | 1~2 | - | 1: Enabled 2: Disabled * This value is used only when DHCP is enabled. | 12 | |||
08 | Setting mode | System | Network | Enabling server's IP address acquired by DHCP | 9587 | SNTP Server Option (42) NTP Server Address | 2 | 1~2 | - | 1: Enabled 2: Disabled * This value is used only when DHCP is enabled. | 12 | |||
08 | Setting Mode | System | Network | 9599 | Samba server ON/OFF setting | 1 | 1-4 | NIC | 1: Samba enabled 2: Samba disabled 3: Print Share disabled 4: File Share disabled | 12 | ||||
08 | Setting mode | System | Maintenan ce | General | 9601 | Equipment number (serial number) display | 0 | 9 digits | SYS | This code can be also keyed in from the adjustment mode (05-9043). 9 digits | 11 | Yes | ||
08 | Setting mode | System | Maintenan ce | 9602 | Dealer's name | - | - | SYS | Maximum 100 letters Needed at initial registration | 11 | ||||
08 | Setting mode | System | Maintenan ce | Remote-controlled service | General | 9603 | Login name | - | - | SYS | Maximum 20 letters Needed at initial registration | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | Call /Display function | 9604 | Display set of [Service Notification] button | Refer to contents | 0~1 | SYS | 0: Not displayed 1: displayed <Default value> NAD: 1 MJD: 1 Other: 0 | 1 | Yes | |
08 | Setting mode | System | Maintenan ce (Remote) | 9605 | Sending error history of equipment | 0 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | ||||
08 | Setting mode | System | Maintenan ce (Remote) | 9606 | Setting total counter transmission interval | - | - | SYS | (Hour/Hour/Minute/Minute) | 1 | ||||
08 | Setting mode | System | Maintenan ce (Remote) | 9607 | Destination E-mail address 2 | - | - | SYS | Maximum 192 letters | 11 | ||||
08 | Setting mode | System | Maintenan ce (Remote) | 9608 | Destination E-mail address 3 | - | - | SYS | Maximum 192 letters | 11 |
08 | Setting mode | System | Maintenan ce | 9610 | Remote-controlled service polling day selection Day-1 | 0 | 0~31 | SYS | 0: OFF 1 to 31: 1st to 31st of a month | 1 | ||||
08 | Setting mode | System | Maintenan ce | 9611 | Remote-controlled service polling day selection Day-2 | 0 | 0~31 | SYS | 0: OFF 1 to 31: 1st to 31st of a month | 1 | ||||
08 | Setting mode | System | Maintenan ce | 9612 | Remote-controlled service polling day selection Day-3 | 0 | 0~31 | SYS | 0: OFF 1 to 31: 1st to 31st of a month | 1 | ||||
08 | Setting mode | System | Maintenan ce | 9613 | Remote-controlled service polling day selection Day-4 | 0 | 0~31 | SYS | 0: OFF 1 to 31: 1st to 31st of a month | 1 | ||||
08 | Setting Mode | System | Maintenan ce | RDMS | Remote-controlled service polling day | 9614 | Sunday | 1 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | Yes | |
08 | Setting Mode | System | Maintenan ce | RDMS | Remote-controlled service polling day | 9615 | Monday | 1 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | Yes | |
08 | Setting Mode | System | Maintenan ce | RDMS | Remote-controlled service polling day | 9616 | Tuesday | 1 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | Yes | |
08 | Setting Mode | System | Maintenan ce | RDMS | Remote-controlled service polling day | 9617 | Wednesday | 1 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | Yes | |
08 | Setting Mode | System | Maintenan ce | RDMS | Remote-controlled service polling day | 9618 | Thursday | 1 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | Yes | |
08 | Setting Mode | System | Maintenan ce | RDMS | Remote-controlled service polling day | 9619 | Friday | 1 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | Yes | |
08 | Setting Mode | System | Maintenan ce | RDMS | Remote-controlled service polling day | 9620 | Saturday | 1 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | Yes |
08 | Setting mode | System | Maintenan ce | 9624 | Information of supplies setting of toner cartridge K | 0 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | ||||
08 | Setting mode | System | Maintenan ce | Remote-controlled service | Remote-controlled service polling | 9626 | End of month | 0 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | ||
08 | Setting mode | System | Network | 9627 | Sending mail text of InternetFAX | 1 | 0-1 | SYS | 0: Invalid (Not sending the mail text) 1: Valid (Sending the mail text) | 1 | ||||
08 | Setting mode | System | Network | 9628 | From Name Creation setting in SMTP authentication | 0 | 0-2 | SYS | 0: Not edited 1: Account name of FROM ADDRESS and Device name 2: LDAP searching | 1 | ||||
08 | Setting mode | System | Wireless LAN | 9649 | Wireless LAN supplicant Wireless LAN setting | 2 | 1~2 | NIC | This setting is whether the wireless LAN connection is enabled or disabled. 1: Enabled 2: Disabled | 12 | ||||
08 | Setting mode | System | Bluetooth | 9680 | Bluetooth ON/OFF setting | 1 | 0~1 | SYS | 0: OFF 1: ON | 1 | ||||
08 | Setting mode | System | Bluetooth | 9681 | Bluetooth Device name | MFPseri al | - | SYS | Maximum 32 letters | 11 | ||||
08 | Setting mode | System | Bluetooth | 9682 | Bluetooth Discovery | 1 | 0~1 | SYS | 0: Not allowed 1: Allowed | 1 | ||||
08 | Setting mode | System | Bluetooth | 9683 | Bluetooth Security | 1 | 0~1 | SYS | 0: Security function OFF 1: Security function ON | 1 | ||||
08 | Setting mode | System | Bluetooth | 9684 | Bluetooth PIN | 0000 | - | SYS | Maximum 8 digits (8-digit sequence) This setting is valid only when the bluetooth security function is ON. | 11 | ||||
08 | Setting mode | System | Bluetooth | 9685 | Bluetooth Data encryption | 1 | 0~1 | SYS | 0: Not encrypted 1: Encrypted This setting is valid only when the bluetooth security function is ON. | 1 | ||||
08 | Setting mode | System | Network | Enabling server's IP address acquired by DHCP | 9694 | DNS domain name Option (15) DNS domain name of the client | 1 | 1~2 | - | 1: Enabled 2: Disabled * This value is used only when DHCP is enabled. | 12 | |||
08 | Setting mode | System | Maintenan ce | General | 9700 | Service technician telephone number | 0 | 32 digits | SYS | A telephone number can be entered up to 32 digits. Use the [Pause] button to enter a hyphen (-). | 11 | Yes | ||
08 | Setting mode | System | User interface | 9702 | Automatic calibration disclosure level | 1 | 0-2 | SYS | Sets the disclosing level of automatic calibration. 0: Service technician 1: Administrator 2: User | 1 | ||||
08 | Setting mode | Counter | Maintenan ce | 9703 | Error history display | - | - | SYS | Displaying of the latest 20 errors data | 2 |
08 | Setting mode | System | Network | 9709 | Default data saving directory of "Scan to File" | 0 | 0~2 | SYS | 0: Local directory 1: REMOTE 1 2: REMOTE 2 | 1 | ||||
08 | Setting mode | System | Maintenan ce | Remote-controlled service | General | 9710 | Remote-controlled service function | 2 | 0~2 | SYS | 0: Valid (Remote-controlled server) 1: Valid (L2) 2: Invalid | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9711 | Remote-controlled service URL setting | NULL | - | SYS | Maximum 256 Bytes | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9715 | Initially-registered server URL setting | Refer to contents | - | SYS | Maximum 256 letters <Default value> https://device.mfp- support.com:443/device/firstregist.ashx | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Short time interval of emergency mode | 9718 | Recovery time setting | 24 | 1~48 | SYS | Sets the time interval to recover from the emergency mode to the normal mode. (Unit: Hour) | 1 | |||
08 | Setting mode | System | Maintenan ce | Short time interval of emergency mode | 9719 | Interval setting | 60 | 30~360 | SYS | (Unit: Minute) | 1 | |||
08 | Setting mode | System | Maintenan ce | Remote-controlled service | General | 9723 | Periodical polling timing | 1700 | 0~2359 | SYS | 0 (0:00) to 2359 (23:59) | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | General | 9724 | Writing data of self- diagnostic code | 0 | 0~1 | SYS | 0: Prohibited 1: Accepted | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | General | 9726 | Remote-service initial registration | 0 | 0~3 | SYS | 0: OFF 1: Start 2: Only certification is scanned 3: RDMS communication starts | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | General | 9727 | Remote-controlled service tentative password | NULL | - | SYS | Maximum 10 letters | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | General | 9729 | Status of remote- service initial regist | 0 | 0~1 | SYS | 0: Not registered 1: Registered | 2 | Yes | |
08 | Setting Mode | System | Maintenan ce | RDMS | Call /Display function | 9730 | Service center call function | 1 | 0-2 | SYS | 0: OFF 1: Notifies all service calls 2: Notifies all but paper jams | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9732 | Service center call HTTP server URL setting | NULL | - | SYS | Maximum 256 letters | 11 | Yes | |
08 | Setting mode | System | Counter | 9736 | Validity of interrupt copying when external counters are installed | 0 | 0~1 | SYS | 0: Invalid1: Valid | 1 |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | Call /Display function | 9739 | Toner-end notification | 0 | 0~2 | SYS | 0: RDMS toner empty notified immediately 1: RDMS toner empty notified once a day 2: RDMS toner empty not notified | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9740 | HTTP proxy setting | 1 | 0~1 | SYS | 0: Valid 1: Invalid | 1 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9741 | HTTP proxy IP address setting | Refer to contents | - | SYS | Input IP address or FQDN. <Default value> 0.0.0.0 | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9742 | HTTP proxy port number setting | 0 | 0~65535 | SYS | 1 | Yes | ||
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9743 | HTTP proxy ID setting | NULL | - | SYS | Maximum 30 letters | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9744 | HTTP proxy password setting | NULL | - | SYS | Maximum 30 letters | 11 | Yes | |
08 | Setting mode | System | Maintenan ce | Remote-controlled service | HTTP | 9745 | HTTP proxy panel display | 1 | 0~1 | SYS | 0: Valid 1: Invalid | 1 | Yes | |
08 | Setting mode | System | Network | 9746 | 802.1X/Dynamic WEP selecting button display | 1 | 0~1 | SYS | Switches whether a selecting button for Security mode 802.1X/Dynamic WEP is displayed or not. 0: Not displayed 1: Displayed | 1 | ||||
08 | Setting mode | System | Network | 9749 | WIA Scan Driver | 1 | 1~2 | NIC | Selects WIA Scan Driver. 1: TTEC 2: Microsoft | 12 | ||||
08 | Setting mode | System | Maintenan ce | 9750 | Automatic ordering function of supplies | 3 | 0~3 | SYS | 0: Ordered by FAX 1: Ordered by E-mail 2: Ordered by HTTP 3: OFF | 1 | ||||
08 | Setting mode | System | Maintenan ce | 9751 | Automatic ordering function of supplies FAX number | - | SYS | Maximum 32 digits Enter hyphen with the [Pause] button | 11 | |||||
08 | Setting mode | System | Maintenan ce | 9752 | Automatic ordering function of supplies E- mail address | - | SYS | Maximum 192 letters List: 256 digits | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9756 | Automatic ordering function of supplies User's name | - | SYS | Maximum 50 letters | 11 |
08 | Setting mode | System | Maintenan ce (Remote) | 9757 | Automatic ordering function of supplies User's telephone number | - | SYS | Maximum 32 digits Enter hyphen with the [Pause] button | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9758 | Automatic ordering function of supplies User's E-mail address | - | SYS | Maximum 192 letters List: 256 digits | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9759 | Automatic ordering function of supplies User's address | - | SYS | Maximum 100 letters | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9760 | Automatic ordering function of supplies Service number | - | SYS | Maximum 5 digits | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9761 | Automatic ordering function of supplies Service technician's name | - | SYS | Maximum 50 letters | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9762 | Automatic ordering function of supplies Service technician's telephone number | - | SYS | Maximum 32 digits Enter hyphen with the [Pause] button | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9763 | Automatic ordering function of supplies Service technician's E-mail address | - | SYS | Maximum 192 letters List: 256 digits | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9764 | Automatic ordering function of supplies Supplier's name | - | SYS | Maximum 50 letters | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9765 | Automatic ordering function of supplies Supplier's address | - | SYS | Maximum 100 letters | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9766 | Automatic ordering function of supplies Notes | - | SYS | Maximum 128 letters | 11 |
08 | Setting mode | System | Maintenan ce (Remote) | 9776 | Information about supplies Part number of toner cartridge | - | SYS | Maximum 20 digits | 11 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9777 | Information about supplies Order quantity of toner cartridge | 1 | 1~99 | SYS | 1 | |||||
08 | Setting mode | System | Maintenan ce (Remote) | 9778 | Information about supplies Condition number of toner cartridge | 1 | 1~99 | SYS | 1 | |||||
08 | Setting mode | System | Maintenan ce | Remote-controlled service | Call /Display function | 9783 | Automatic supply ordering display | Refer to contents | 0~2 | SYS | 0: Valid (FAX/Internet FAX) 1: Valid (FAX/Internet FAX/HTTP) 2: Invalid <Default value> NAD: 0 Others: 2 | 1 | Yes | |
08 | Setting mode | System | Maintenan ce (Remote) | 9784 | Counter notification Remote FAX setting | - | SYS | Maximum 32 digits Enter hyphen with the [PAUSE] button. | 11 | |||||
08 | Setting mode | System | General | 9787 | Suspend when quota is empty | 0 | 0-1 | SYS | Sets whether the process is suspended immediately or suspended after the job is completed if quota is used up. 0: Suspended immediately 1: Suspended after the job is finished | 1 | ||||
08 | Setting mode | System | Maintenan ce | 9788 | Service call checking period setting | 6 | 0~12 | SYS | 0: No checking period specified (= Calls service technician immediately) 1: 10 minutes 2: 30 minutes 3: 1 hour 4: 6 hours 5: 12 hours 6: 24 hours 7: 48 hours 8: 7 days 9: 1 month 10: 1 year 11: 5 years 12: Not limited (= Calls service technician if such error has occurred in the past even once or more) | 1 | ||||
08 | Setting mode | System | Maintenan ce (Remote) | 9793 | Service Notification setting | 0 | 0~2 | SYS | Enables to set up to 3 E-mail addresses to be sent. (08-9793, 9794, 9795) 0: Invalid 1: Valid (E-mail) 2: Valid (FAX) | 1 | ||||
08 | Setting mode | System | Maintenan ce (Remote) | 9794 | Destination E-mail address 1 | - | SYS | Maximum 192 letters | 11 |
08 | Setting mode | System | Maintenan ce (Remote) | 9795 | Total counter information transmission setting | 0 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | ||||
08 | Setting mode | System | Maintenan ce (Remote) | 9796 | Total counter transmission date setting | 0 | 0~31 | SYS | 0 to 31 | 1 | ||||
08 | Setting mode | System | Maintenan ce (Remote) | 9797 | PM counter notification setting | 0 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | ||||
08 | Setting mode | System | Network | 9798 | Temporary communication password setting | 99999 | - | SYS | Sets a temporary communication password. The password can be entered in alphanumeric characters (A to Z, a to z, 0 to 9) up to 10 digits. The entered password is displayed with "*" on the touch panel and the self-diagnostic lists. (Maximum 10 digits, minimum 5 digits) | 11 | ||||
08 | Setting mode | System | General | 9799 | Local authentication mode switchover | 0 | 0~1 | SYS | Sets the authentication mode when "0: (Internal authentication)" is selected in the code 08-9293. 0: Card ID differs from the User ID 1: Card ID is the same as the User ID | 1 | ||||
08 | Setting mode | System | Process | 9804 | Forcible mode change in toner empty status | 1 | 0~2 | SYS | 0: SLEEP MODE 1: AUTO POWER SAVE 2: READY | 1 | ||||
08 | Setting mode | System | Laser | 9805 | Polygonal motor standby rotation Shift waiting time at job end | 3 | 0~9 | SYS | 0: 0 sec. (current setting) (Polygonal motor ready rotation at job end) 1 to 9:Setting value x 5sec. | 1 | ||||
08 | Setting mode | System | User interface | Interruption of stapling operation (no staple) | 9810 | 0 | Copying | 1 | 0~1 | SYS | 0: Continues printing by switching sort setting 1: Interrupts printing | 4 | ||
08 | Setting mode | System | User interface | Interruption of stapling operation (no staple) | 9810 | 1 | Printing / BOX printing | 0 | 0~1 | SYS | 0: Continues printing by switching sort setting 1: Interrupts printing | 4 | ||
08 | Setting mode | System | Finisher | Stapling setting Maximum number of sheets acceptable exceeding upper limit / Long size | 9811 | 0 | Plain/Recycled | 0 | -50~50 | SYS | -50 to 50 | 4 |
08 | Setting mode | System | Finisher | Stapling setting Maximum number of sheets acceptable exceeding upper limit / Long size | 9811 | 1 | Thick1 | 0 | -50~50 | SYS | -50 to 50 | 4 | ||
08 | Setting mode | System | Finisher | Stapling setting Maximum number of sheets acceptable exceeding upper limit / Long size | 9811 | 2 | Thick2 | 0 | -50~50 | SYS | -50 to 50 | 4 | ||
08 | Setting mode | System | Finisher | Stapling setting Maximum number of sheets acceptable exceeding upper limit / Long size | 9811 | 3 | Thick3 | 0 | -50~50 | SYS | -50 to 50 | 4 | ||
08 | Setting mode | System | General | 9816 | Addition of the page number to the multi- page file name of File | 0 | 0~1 | SYS | Only when job is executed with TimeStamp enabled for file storage, page number is added with the format set at 08-9387. 0: Invalid (Page number not added) 1: Valid (Page number added) | 1 | ||||
08 | Setting mode | System | General | 9817 | Maximum number of decimals in extension fields | 2 | 0~6 | SYS | 0: 0 digit 1: 1 digit 2: 2 digits 3: 3 digits 4: 4 digits 5: 5 digits 6: 6 digits | 1 | ||||
08 | Setting mode | System | General | 9818 | Default saving/attachment files of "File/Email" | 0 | 0~1 | SYS | 0: DOCYYMMDD 1: NetBios name | 1 | ||||
08 | Setting mode | System | User interface | Off Device Customization Architecture | 9819 | STAGE SSL | 0 | 0-1 | SYS | Sets whether SSL communication is enabled or disabled for remote scanning. 0: Disabled 1: Enabled | 1 | |||
08 | Setting mode | System | User interface | Off Device Customization Architecture | 9820 | STAGE I/F | 1 | 0-1 | SYS | Sets whether interface is enabled or disabled for remote scanning. 0: Disabled 1: Enabled | 1 |
08 | Setting mode | System | User interface | Off Device Customization Architecture | 9821 | Port number | 49629 | 0-65535 | SYS | Sets a port number for the remote scanning. | 1 | |||
08 | Setting mode | System | User interface | Off Device Customization Architecture | 9822 | SSL port number | 49630 | 0-65535 | SYS | Sets an SSL port number for remote scanning using SSL communication. | 1 | |||
08 | Setting mode | System | Network | 9823 | User name and password at user authentication or "Save as file" | 0 | 0~2 | SYS | 0: User name and password of the device 1: User name and password at the user authentication (Template registration information comes first when a template is retrieved.) 2: User name and password at the user authentication (User information of the authentication comes first when a template is retrieved.) | 1 | ||||
08 | Setting mode | System | Image | 9825 | Image quality of the black part in the ACS mode | 0 | 0~1 | SYS | 0: Black 1: Gray scale | 1 | ||||
08 | Setting mode | System | General | 9829 | Department management limitation setting | 0 | 0~1 | SYS | Decide the default limitation setting when the new department code is created. 0: No limit 1: Limited | 1 | ||||
08 | Setting mode | System | Bluetooth | 9841 | Bluetooth BIP Paper type | 0 | 0~3 | SYS | 0: Fit page 1: 1/2 size 2: 1/4 size 3: 1/8 size | 1 | ||||
08 | Setting mode | System | Bluetooth | 9846 | Bluetooth BIP Paper size | Refer to contents | 0~13 | SYS | 0: Ledger 1: Legal 2: Letter 3: Computer 4: Statement 5: A3 6: A4 7: A5 9: B4 10: B5 11: Folio 12: Legal13" 13: LetterSquare <Default value> NAD: 2 Others: 6 | 1 | ||||
08 | Setting mode | System | Finisher | 9847 | Hole punching setting | 0 | 0~1 | SYS | 0: Invalid 1: Valid | 1 | ||||
08 | Setting mode | System | General | 9880 | Total counter transmission date setting (2) | 0 | 0~31 | SYS | 0 to 31 | 1 | ||||
08 | Setting mode | System | General | 9881 | Day of total counter data transmission | 0 | 0~127 | SYS | 1 byte 00000000(0)-01111111(127) From the 2nd bit - Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday | 1 |
08 | Setting mode | System | General | 9883 | Hardcopy security printing | 0 | 0~1 | SYS | 0: Disable1 1: Enable | 1 | ||||
08 | Setting mode | System | Counter | 9884 | Count switching of hardcopy security printing level 1 | 0 | 0~1 | SYS | Sets the way of counting for hardcopy security printing. 0: Counted as 1 1: Counted as 2 | 2 | ||||
08 | Setting mode | System | Scanning | 9886 | Decimal point indication for Enhanced Scan Template | Refer to contents | 0~1 | SYS | 0: Comma 1: Period <Default value> MJD: 0 Others: 1 | 1 | ||||
08 | Setting mode | System | Scanner | 9888 | Permission setting for changing the scan parameter when recalling an extension | 0 | 0~1 | SYS | 0: Prohibited 1: Permitted | 1 | ||||
08 | Setting mode | System | General | Data cloning | 9889 | Status display for USB cloning | 0 | 0~1 | SYS | Acceptance of the usage of the USB data cloning tool 0: Accepted 1: Not accepted | 1 | Yes | ||
08 | Setting mode | System | User interface | Screen setting | 9891 | Warning message when PM time has come | 1 | 0~1 | SYS | 0: No warning notification 1: Display warning notification | 1 | Yes | ||
08 | Setting mode | System | General | 9894 | Calibration chart charging method | 0 | 0-1 | SYS | Decides whether the calibration chart printing is charged or not 0: No charge 1: Charge | 1 | ||||
08 | Setting mode | System | Image | 9897 | Default value setting of background peak adjustment (Black) | 5 | 1~9 | SYS | 1: -4 2: -3 3: -2 4: -1 5: 0 6: +1 7: +2 8: +3 9: +4 | 1 | ||||
08 | Setting mode | System | Image | 9898 | Default value setting of density in the scan mode (Color) | 6 | 0~11 | SYS | 0: Auto 1: -5 2: -4 3: -3 4: -2 5: -1 6: 0 7: +1 8: +2 9: +3 10: +4 11: +5 | 1 | ||||
08 | Setting mode | System | Image | 9899 | Default value setting of density in the scan mode (Gray) | 6 | 0~11 | SYS | 0: Auto 1: -5 2: -4 3: -3 4: -2 5: -1 6: 0 7: +1 8: +2 9: +3 10: +4 11: +5 | 1 | ||||
08 | Setting mode | System | Version | System | 9900 | System software ROM version | - | - | - | T160SYXXXXXX | 2 | |||
08 | Setting mode | System | Version | Engine | 9901 | Engine ROM version | - | - | 160M-XXX | 2 | Yes | |||
08 | Setting mode | System | Version | Engine | 9902 | Scanner ROM version | - | - | 160S-XXX | 2 | Yes |
08 | Setting mode | System | Version | Engine | 9903 | RADF ROM version | - | - | DF-XXXX | 2 | Yes | |||
08 | Setting mode | System | Version | Finisher | 9904 | Finisher ROM version | - | - | SDL-XXX FIN-XXX | 2 | Yes | |||
08 | Setting mode | System | Version | FAX | 9905 | Fax board ROM version | - | - | F670-XXX | 2 | Yes | |||
08 | Setting mode | System | Version | HDD | 9930 | System software OS version | - | - | T160SF0WXXXX | 2 | Yes | |||
08 | Setting mode | System | Network | 9933 | Domain participation confirmation of printing when LDAP authentication is used | 1 | 0~1 | SYS | When LDAP is selected as authentication method for user authentication, checking of domain participation of client computer for print job authentication is set. This function is available only when department management is enabled. 0: Disabled 1: Enabled | 1 | ||||
08 | Setting mode | System | Finisher | Stapling setting Acceptable number of sheets exceeding upper limit / Short size | 9937 | 0 | Plain/Recycled | 0 | -100~100 | SYS | -100 to 100 | 4 | ||
08 | Setting mode | System | Finisher | Stapling setting Acceptable number of sheets exceeding upper limit / Short size | 9937 | 1 | Thick1 | 0 | -100~100 | SYS | -100 to 100 | 4 | ||
08 | Setting mode | System | Finisher | Stapling setting Acceptable number of sheets exceeding upper limit / Short size | 9937 | 2 | Thick2 | 0 | -100~100 | SYS | -100 to 100 | 4 | ||
08 | Setting mode | System | Finisher | Stapling setting Acceptable number of sheets exceeding upper limit / Short size | 9937 | 3 | Thick3 | 0 | -100~100 | SYS | -100 to 100 | 4 | ||
08 | Setting mode | System | Finisher | Stapling Acceptable number of sheets exceeding upper limit / Saddle stitch | 9938 | 0 | Plain/Recycled | 0 | -15~15 | SYS | -15 to 15 | 4 |
08 | Setting mode | System | Finisher | Stapling Acceptable number of sheets exceeding upper limit / Saddle stitch | 9938 | 1 | Thick1 | 0 | -15~15 | SYS | -15 to 15 | 4 | ||
08 | Setting mode | System | Finisher | Stapling Acceptable number of sheets exceeding upper limit / Saddle stitch | 9938 | 2 | Thick2 | 0 | -15~15 | SYS | -15 to 15 | 4 | ||
08 | Setting mode | System | Finisher | Stapling Acceptable number of sheets exceeding upper limit / Saddle stitch | 9938 | 3 | Thick3 | 0 | -15~15 | SYS | -15 to 15 | 4 | ||
08 | Setting mode | System | Version | Finisher | 9944 | Finisher punch ROM version | - | - | - | PUN-XXX FIN-XXX | 2 | Yes | ||
08 | Setting mode | System | Version | 9945 | Finisher Converter ROM version | - | - | - | CNV-XXX | 2 | ||||
08 | Setting mode | System | Network | 9946 | Number of Email transmission retries | 3 | 0~14 | SYS | The number of times of E-mail communication retry for Scan to E-mail and Internet Fax is set. | 1 | Yes | |||
08 | Setting mode | System | Network | 9947 | E-mail transmission retry interval | 1 | 0~15 | SYS | When E-mail transmission retry for Scan to E-mail and Internet Fax is performed, the interval is set. 0 min - 15 min | 1 | Yes | |||
08 | Setting mode | System | General | 9954 | Control box counter / job list printing operation | 0 | 0-1 | SYS | 0: Invalid 1: Valid | 1 | ||||
08 | Setting mode | System | User interface | 9955 | Name of [EXTENSION] button | EXTENS ION | SYS | Sets the name of " EXTENSION" button displayed on the MENU screen. Maximum 10 characters with alphameric characters and symbols. | 11 | |||||
08 | Setting mode | System | Network | 9958 | Bcc address display ON/OFF setting (Job Log / Job Status) | 0 | 0~1 | SYS | Sets whether the Bcc address is displayed or not on the Job Log or Job Status. 0: OFF (Bcc address not displayed) 1: ON (Bcc address displayed) | 1 | ||||
08 | Setting mode | System | Network | 9959 | Bcc address display ON/OFF setting (Job Notification) | 1 | 0~1 | SYS | Sets whether the Bcc address is displayed or not on all the Job Notifications except for the administrator. 0: OFF (Bcc address not displayed) 1: ON (Bcc address displayed) | 1 |
