Toshiba e-STUDIO 307/357/457/507 Service Manual Part 1
SERVICE MANUAL
MULTIFUNCTIONAL DIGITAL SYSTEMS​
e-STUDIO206L/256/306/356/456/506
e-STUDIO306S/356S/456S e-STUDIO256SE/306SE/356SE/456SE/506SE
e-STUDIO306SD/356SD/456SD
e-STUDIO207L/257/307/357/457/507 e-STUDIO257S/307S/357S/457S e-STUDIO307SD/357SD/457SD
e-STUDIO206L/256/306/356/456/506 e-STUDIO207L/257/307/357/457/507
Model: DP-2095/2530/3020/3590/4590/5010 / 2072/2572/3072/3572/4572/5072
Publish Date: May 2011 File No. SME110006F0 R110421J3903-TTEC Ver06 F _2014-04
  1. Error Code List​
    The following error codes is displayed at the upper right of the screen when the “CLEAR PAPER” or “CALL SERVICE” symbol is blinking.
    8​
    1. Jam​
      Error codeClassificationContentsTroubleshooting
      E010Paper exit jamJam not reaching the exit sensor: The paper which has passed through the fuser unit does not reach the exit sensor.P. 8-45
      E020Stop jam at the exit sensor: The trailing edge of the paper does not pass the exit sensor after its leading edge has reached this sensor.P. 8-45
      E030Other jamPower-ON jam: The paper is remaining on the paper transport path when power is turned ON.P. 8-75
      E061Incorrect paper size setting for upper drawer: The size of paper in the 1st drawer differs from size setting of the equipment.P. 8-76
      E062Incorrect paper size setting for lower drawer: The size of paper in the 2nd drawer differs from size setting of the equipment.P. 8-76
      E063Incorrect paper size setting for PFP upper drawer: The size of paper in the 3rd drawer differs from size setting of the equipment.P. 8-76
      E064Incorrect paper size setting for PFP lower drawer: The size of paper in the 4th drawer differs from size setting of the equipment.P. 8-76
      E065Incorrect paper size setting for bypass tray: The size of paper in the bypass tray differs from size setting of the equipment.P. 8-76
      E090HDD abnormality causes jam: Image data to be printed cannot be prepared.P. 8-59
      E110Paper misfeedingADU misfeeding (Paper not reaching the registration sensor): The paper which has passed through ADU does not reach the registration sensor during duplex printing.P. 8-59
      E120Bypass misfeeding (Paper not reaching the 1st transport sensor): The paper fed from the bypass tray does not reach the 1st transport sensor.P. 8-60
      E130Upper drawer misfeeding (Paper not reaching the 1st transport sensor): The paper fed from the upper drawer does not reach the 1st transport sensor.P. 8-61
      E140Lower drawer misfeeding (Paper not reaching the 2nd transport sensor): The paper fed from the lower drawer does not reach the 2nd transport sensor.P. 8-62
      E150PFP upper drawer misfeeding (Paper not reaching the PFP upper drawer feed sensor): The paper fed from the PFP upper drawer does not reach the PFP upper drawer feed sensor.P. 8-63
      E160PFP lower drawer misfeeding (Paper not reaching the PFP lower drawer feed sensor): The paper fed from the PFP lower drawer does not reach the PFP lower drawer feed sensor.P. 8-64
      E190LCF misfeeding (Paper not reaching the LCF feed sensor): The paper fed from the LCF does not reach the LCF feed sensor.P. 8-66
      E200Paper transport jamUpper drawer transport jam (Paper not reaching the registration sensor): The paper does not reach the registration sensor after it has passed the 1st transport sensor.P. 8-46
      E210Lower drawer transport jam (Paper not reaching the registration sensor): The paper does not reach the registration sensor after it has passed the 1st transport sensor.P. 8-46
      E220Lower drawer transport jam (Paper not reaching the 1st transport sensor): The paper does not reach the 1st transport sensor after it has passed the lower drawer feed sensor.P. 8-48
      E270Bypass transport jam (paper not reaching the registration sensor): The paper does not reach the registration sensor after it has passed the 1st transport sensor.P. 8-47
      E280ADU transport jam (paper not reaching the registration sensor): The paper which has passed through ADU and the 1st transport sensor does not reach the registration sensor during duplex printing.P. 8-47
      E300PFP upper drawer transport jam (Paper not reaching the registration sensor): The paper does not reach the registration sensor after it has passed the 1st transport sensor.P. 8-46
      E310PFP upper drawer transport jam (Paper not reaching the 1st transport sensor): The paper does not reach the 1st transport sensor after it has passed the 2nd transport sensor.P. 8-48
      E320PFP upper drawer transport jam (Paper not reaching the 2nd transport sensor): The paper does not reach the 2nd transport sensor after it has passed the PFP upper drawer feed sensor.P. 8-49
      E330PFP lower drawer transport jam (Paper not reaching the registration sensor): The paper does not reach the registration sensor after it has passed the 1st transport sensor.P. 8-46
      E340PFP lower drawer transport jam (Paper not reaching the 1st transport sensor): The paper does not reach the 1st transport sensor after it has passed the PFP lower drawer feed sensor.P. 8-48
      E350PFP lower drawer transport jam (Paper not reaching the 2nd transport sensor): The paper does not reach the 2nd transport sensor after it has passed the PFP upper drawer feed sensor.P. 8-49
      E360PFP lower drawer transport jam (Paper not reaching the PFP upper drawer feed sensor): The paper does not reach the PFP upper drawer feed sensor after it has passed the PFP lower drawer feed sensor.P. 8-57
      E3C0LCF transport jam (Paper not reaching the registration sensor): The paper does not reach the registration sensor after it has passed the 1st transport sensor.P. 8-46
      E3D0LCF transport jam (Paper not reaching the 1st transport sensor): The paper does not reach the 1st transport sensor after it has passed the 2nd transport sensor.P. 8-48
      E3E0LCF transport jam (Paper not reaching the 2nd transport sensor): The paper does not reach the 2nd transport sensor after it has passed the LCF feed sensor.P. 8-49
      E410Cover open jamFront cover open jam: The front cover has opened during printing.P. 8-67
      E420PFP side cover open jam: The PFP side cover has opened during printing.P. 8-68
      E430ADU open jam: The ADU has opened during printing.P. 8-69
      E440Feed cover open jam: The feed cover has opened during printing.P. 8-70
      E450LCF side cover open jam: The LCF side cover has opened during printing.P. 8-71
      E480Bridge unit open jam: The bridge unit has opened during printing.P. 8-72
      E490Job separator cover open jam: The job separator cover has opened during printing.P. 8-73
      E491Offset tray cover open jam: The offset tray cover has opened during printing.P. 8-74
      E510Paper transport jam (ADU section)Jam not reaching the ADU entrance sensor: The paper does not reach the ADU entrance sensor after it is switchbacked in the exit section.P. 8-50
      E520Stop jam in the ADU: The paper does not reach the ADU exit sensor after it has passed the ADU entrance sensor.P. 8-52
      E550Other jamPaper remaining jam on the transport path: The paper is remaining on the transport path when printing is finished (caused by a multiple paper feeding).P. 8-76
      E551Paper remaining jam on the transport path (when a service call occurs)P. 8-77
      E552Paper remaining jam on the transport path (when the cover is closed)P. 8-77
      E570Paper transport jamJam not reaching the reverse sensor: The paper which has passed the exit sensor does not reach the reverse sensor.P. 8-53
      E580Stop jam at the reverse sensor: The trailing edge of the paper does not pass the reverse sensor after its leading edge has reached this sensor.P. 8-53
      8​
      E712RADF jamJam not reaching the registration sensor: The original fed from the original feeding tray does not reach the registration sensor.P. 8-80
      E714Feed signal reception jam: The feed signal is received even no original exists on the original feeding tray.P. 8-80
      E721Jam not reaching the read sensor: The original does not reach the read sensor after it has passed the registration sensor (when scanning obverse side) or the reverse sensor (when scanning reverse side).P. 8-81
      E722Jam not reaching the exit sensor (during scanning): The original which passed the read sensor does not reach the exit sensor when it is transported from the scanning section to exit section.P. 8-81
      E724Stop jam at the registration sensor: The trailing edge of the original does not pass the registration sensor after its leading edge has reached this sensor.P. 8-82
      E725Stop jam at the read sensor: The trailing edge of the original does not pass the read sensor after its leading edge has reached this sensor.P. 8-82
      E726Transport/exit signal reception jam: RADF receives the transport/exit reception signal from the equipment when no original is at the exposure waiting position.P. 8-83
      E731Stop jam at the exit sensor: The trailing edge of the original does not pass the exit sensor after its leading edge has reached this sensor.P. 8-83
      E860RADF jam access cover open: The RADF jam access cover has opened during RADF operation.P. 8-84
      E870RADF open jam: RADF has opened during RADF operation.P. 8-84
      E871Cover open jam in the read ready status: Jam caused by opening of the RADF jam access cover or front cover while the RADF is waiting for the scanning start signal from the equipment. (MR- 3021/3022)P. 8-85
      E910Finisher jam (Bridge unit)Jam at the bridge unit transport sensor-1: The paper does not reach the bridge unit transport sensor-1 after it has passed the exit sensor.P. 8-86
      E920Stop jam at the bridge unit transport sensor-1: The trailing edge of the paper does not pass the bridge unit transport sensor-1 after its leading edge has reached the sensor.P. 8-86
      E930Jam at the bridge unit transport sensor-2: The trailing edge of the paper does not reach the bridge unit transport sensor-2 after its leading edge has reached the bridge unit transport sensor-1.P. 8-87
      E940Stop jam at the bridge unit transport sensor-2: The trailing edge of the paper does not reach the bridge unit transport sensor-2 after its leading edge has reached the bridge unit transport sensor-2.P. 8-87
      E950Job separator jamJam not reaching the job separator transport sensor: The paper has passed through the exit sensor does not reach the job separator transport sensor.P. 8-88
      E951Stop jam at the job separator transport sensor: The trailing edge of the paper does not pass the job separator transport sensor.P. 8-88
      E960Offset tray jamJam not reaching the offset tray transport sensor: The paper has passed through the exit sensor does not reach the offset tray transport sensor.P. 8-89
      E961Stop jam at the offset tray transport sensor: The trailing edge of the paper does not pass the offset tray transport sensor.P. 8-89
      E9F0Finisher jam (Puncher unit)Punching jam: An error occurs during the detecting of the home position of the punch motor. This occurs when an attempt is made to punch paper which has been multiply fed from the equipment and exceeds the punching capability. [MJ-1032/MJ- 1033]P. 8-90
      EA10Finisher jamPaper transport delay jam: The paper which hasP. 8-92
      (Finisher section)passed the bridge unit does not reach the inlet
      sensor.[MJ-1101/1107]
      The paper which has passed the bridge unit doesP. 8-92
      not reach the inlet sensor. [MJ-1106/1108]
      Paper transport delay jam: Paper does not reach
      the entrance sensor of the Finisher. [MJ-1032]P. 8-94
      EA20Paper transport stop jam:
      The paper does not pass through the inlet sensor. The paper which has passed through the inlet sensor does not reach the feeding sensor.
      [MJ-1101/1107/MJ-1106/1108]
      Paper transport stop jam: Paper has reached the entrance sensor but does not pass through it (paper is remaining for a longer period than specified). [MJ-1032/MJ-1033]
      P. 8-93
      P. 8-94
      EA21Paper size error jam: Paper does not reach the sensor because the paper is shorter than spec. [MJ-1101/1107/MJ-1106/1108]P. 8-94
      EA22Paper transport jam (Finisher paper punching edge detection sensor): The paper position sensor on the Finisher transport path detects paper shorter than the acceptable paper size. [MJ-1101/1107/MJ-1106/ 1108]P. 8-94
      EA23Finisher jam (Finisher section)Paper transport jam (transport sensor): Paper being transported on the Finisher transport path is stopped at the outlet sensor at 27.56 inches or longer. [MJ-1101/1107/MJ-1106/1108]P. 8-95
      EA24Paper transport jam (between entrance and transport sensors): The leading edge of paper which has passed the entrance sensor on the Finisher transport path does not reach the transport sensor. [MJ-1101/1107/MJ-1106/1108]P. 8-95
      EA25Paper transport jam (after paper stack exit): The finishing tray paper detection sensor detects paper after a stack of paper exits from the finishing tray. [MJ-1101/1107/MJ-1106/1108]
      Paper transport jam in the Finisher (after paper stack exit): Paper is detected in the finishing tray sensor after the paper stack has exited from the finishing tray. [MJ-1032]
      Paper transport jam in the Finisher (after paper stack exit): (1) Paper is detected in the finishing tray sensor after the paper stack has exited from the finishing tray. (2) Paper cannot be detected in the gripper arm exit sensor after the paper stack has exited from the finishing tray. [MJ-1033]
      P. 8-95
      8​
      © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507
      ERROR CODE AND TROUBLESHOOTING
      EA26Finisher jam (Finisher section)Paper transport jam (stop command request): A command to stop equipment operation is received while paper is being transported in the Finisher. [MJ-1101/1107/MJ-1106/1108]
      Paper transport jam in the Finisher (stop command request): The equipment is required to stop during the transporting of paper in the Finisher.
      [MJ-1032/MJ-1033]
      P. 8-95
      EA27Paper transport jam (paper not inserted): The equipment detects a paper-not-inserted jam but the entrance sensor is turned ON before the equipment is stopped. [MJ-1101/1107/MJ-1106/1108]P. 8-95
      EA28Paper transport jam (paper holder plate operation delay): An attempt to start the arm assisting operation for dropping paper on the finishing tray is made, but the previous arm assisting operation has not yet been finished. [MJ-1101/1107/MJ-1106/ 1108]P. 8-95
      EA29Paper transport jam (stack transport delay): The buffer tray is extended to drop a stack of paper on the finishing tray but the previous stack has not yet exited. [MJ-1101/1107/MJ-1106/1108]P. 8-95
      EA2APaper transport jam in the Finisher (between the entrance path and middle path sensor): The leading edge of the paper has passed the entrance path sensor, but does not reach the middle path sensor in the Finisher Unit transport path. [MJ-1032]-
      EA2BPaper transport jam in the Finisher (middle path sensor): The paper remains at the middle path sensor for a longer period than specified while being transported on the Finisher Unit transport path. [MJ-1032]-
      EA2CPaper transport jam in the Finisher (between the entrance path and sub-path sensor): The leading edge of the paper has passed the entrance sensor, but does not reach the sub-path sensor in the Finisher Unit transport path.
      [MJ-1032]
      EA2DPaper transport jam in the Finisher (sub-path sensor): The paper remains at the sub-path sensor for a longer period than specified while being transported on the Finisher Unit transport path. [MJ-1032]-
      EA2EPaper transport remaining jam in the Finisher (sub- path sensor): Paper is detected in the sub-path sensor when the power is turned ON or the cover is closed. [MJ-1032]P. 8-97
      EA31Transport path paper remaining jam. [MJ-1101/1107/MJ-1106/1108]
      Paper transport remaining jam in the Finisher: Paper is detected in the entrance path sensor or middle path sensor when the power is turned ON or the cover is closed. [MJ-1032]
      Paper transport remaining jam in the Finisher: Paper is detected in any of the path sensors when the power is turned ON or the cover is closed. [MJ-1033]
      P. 8-97
      P. 8-97
      P. 8-98
      e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507 © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved ERROR CODE AND TROUBLESHOOTING
      EA32Finisher jamExit paper remaining jam. [MJ-1101/1107/MJ-1106/P. 8-99
      (Finisher section)1108]
      Exit paper remaining jam in the Finisher: Paper is
      detected in the finishing tray sensor when theP. 8-99
      power is turned ON. [MJ-1032/MJ-1033]
      EA40Cover open error:
      The front cover or stationary tray cover is opened during paper transport. [MJ-1101/1107/MJ-1106/ 1108]
      Finisher cover open jam:
      P. 8-100
      P. 8-101
      EA50Stapling jam: Stapling is not performed properly. [MJ-1032/MJ-1033]P. 8-101
      EA60Early arrival jam: A paper jam occurs because paper from the equipment arrives at the Finisher too early. [MJ-1032/MJ-1033]P. 8-102
      EA70Stack exit belt home position error: The stack exit belt is not at the home position. [MJ-1101/1107/MJ- 1106/1108]P. 8-103
      EA80Finisher jam (Saddle Stitcher section)Stapling jam: Stapling is not performed properly. [MJ-1032/MJ-1033]P. 8-104
      EA81The detection of the home position of the saddle stitch 3rd transport roller drive motor ends abnormally.-
      EA90Door open jam: The delivery cover or inlet cover has opened during printing. [MJ-1106/1108]P. 8-104
      EAA0Paper remaining in Saddle Stitch Finisher: Paper remaining in Saddle Stitch Finisher [MJ-1106/1108]P. 8-105
      EAB0Paper transport jam in Saddle Stitch Finisher: Paper transport jam in Saddle Stitch Finisher [MJ-1106/1108]P. 8-105
      EAB1Short paper jam: Short paper jam (Saddle Stitch Finisher) [MJ-1106/1108]P. 8-107
      EAC1The detection of the home position of the folding blade motor ends abnormally.-
      EAD0Other jamPrint end command time-out jam: The printing has not finished normally because of the communication error between the SYS board and LGC board at the end of printing.P. 8-79
      1. A paper jam occurs when any of the covers is opened during the transporting of paper in the Finisher (until the paper exit is completed after the B command has been received).
      2. A paper jam occurs when the supplying of the voltage of 24V is stopped during the transporting of paper. [MJ-1032/MJ-1033]
      8​
      EAE0Finisher jamReceiving time-out jam: The printing has been interrupted because of the communication error between the equipment and finisher when the paper is transported from the equipment to the finisher.P. 8-108
      EAF1Stack exit roller nip motor home position detection error: The detection of the home position of the stack exit roller nip motor ends abnormally. This error may occur if paper is jammed while being transported, so it is treated as a paper jam.
      [MJ-1032/MJ-1033]
      EAF2Stapler unit sliding motor home position detection error: The detection of the home position of the stapler unit sliding motor ends abnormally. This error may occur if paper is jammed while being transported, so it is treated as a paper jam.
      [MJ-1032/MJ-1033]
      EAF3Gripper arm motor home position detection error: The detection of the home position of the gripper arm ends abnormally. This error may occur if paper is jammed while being transported, so it is treated as a paper jam. [MJ-1033]P. 8-109
      EB30Ready time-out jam: The equipment judges that the paper transport to the finisher is disabled because of the communication error between the equipment and finisher at the start of printing.P. 8-109
      EB50Paper transport jamPaper remaining on the transport path: The multiple feeding of preceding paper caused the misfeeding of upcoming paper.P. 8-54
      EB60Paper remaining on the transport path: The multiple feeding of preceding paper caused the misfeeding of upcoming paper (redetection after no jam is detected at [EB50]).P. 8-57
      ED10Finisher jam (Finisher section)Skew adjustment motor (M1) home position detection abnormality: The Skew adjustment motor is not at the home position. [MJ-1101/1106 (when MJ-6103 is installed), MJ-1107/1108 (when MJ- 6104 is installed)]P. 8-109
      ED11Sideways adjustment motor (M2) home position detection error: The Sideways adjustment motor is not at the home position. [MJ-1101/1106 (when MJ- 6103 is installed), MJ-1107/1108 (when MJ-6104 is installed)]P. 8-110
      ED12Shutter home position error: The shutter is not at the home position. [MJ-1101/1107/MJ-1106/1108]P. 8-110
      ED13Front alignment plate home position error: The front alignment plate is not at the home position. [MJ- 1101/1107/MJ-1106/1108]P. 8-111
      ED14Rear alignment plate home position error: The rear alignment plate is not at the home position. [MJ- 1101/1107/MJ-1106/1108]P. 8-112
      ED15Paddle home position error: The paddle is not at the home position. [MJ-1101/1107/MJ-1106/1108]P. 8-113
      ED16Buffer tray home position error: The buffer tray is not at the home position. [MJ-1101/1107/MJ-1106/ 1108]P. 8-114
      EF10Finisher jam (Finisher section)Paper not supported for Saddle Stitch Finisher: Unsupported paper size, type and an excess number of pages for stapling are selected. [MJ- 1106/1108]P. 8-115
      EF11Saddle Stitch Finisher stapling error (front): Front stapling is not correctly done. [MJ-1106/1108]P. 8-115
      EF12Saddle Stitch Finisher stapling error (rear): Rear stapling is not correctly done. [MJ-1106/1108]P. 8-116
      EF13Saddle paper holder home position detection abnormality: The paper holder home position cannot be detected. [MJ-1106/1108]P. 8-116
      EF14Saddle paper exit jam: Outputting paper is not completed within a fixed time. [MJ-1106/1108]P. 8-116
      EF15Saddle Stitch Finisher side alignment motor home position detection abnormality: The side alignment motor home position cannot be detected. [MJ-1106/ 1108]P. 8-117
      EF16Saddle Stitch Finisher stacker motor home position detection abnormality: The stacker motor home position cannot be detected. [MJ-1106/1108]P. 8-118
      EF17Saddle Stitch Finisher folding blade home position detection abnormality: The folding blade home position cannot be detected. [MJ-1106/1108]P. 8-118
      EF18Saddle Stitch Finisher additional folding roller home position detection abnormality: The additional folding roller home position cannot be detected. [MJ-1106/1108]P. 8-119
      EF19Saddle paper folding jam: Fold processed paper cannot be transported to the additional folding roller. [MJ-1106/1108]P. 8-119
      EF1AThe trailing edge of the paper passed the entrance path sensor on the Finisher unit transport path.
      After the switchback, the paper is transported to the saddle stitch unit transport path, but does not reach the saddle stitch entrance path sensor.
      EF1BPaper remains at the saddle stitch positioning paper exit sensor for a longer period than specified while being transported in the pushing/folding operation. [MJ-1033]P. 8-120
      EF1CPaper is transported in the pushing/folding operation, but does not reach the saddle stitch exit path sensor.P. 8-117
      EF20Saddle stacker jam: Transported paper cannot be detected in the stacker. [MJ-1106/1108]P. 8-120
      8​
    2. Service call​
      C010Drive system related service callMain motor abnormality: The main motor is not rotating normally.P. 8-121
      C040Paper feeding system related service callPFP motor abnormality: The PFP motor is not rotating normally.P. 8-122
      C130Upper drawer tray abnormality: The upper drawer tray motor is not rotating or the upper drawer tray is not moving normally.P. 8-123
      C140Lower drawer tray abnormality: The lower drawer tray motor is not rotating or the lower drawer tray is not moving normally.P. 8-123
      C150PFP upper drawer tray abnormality: The PFP upper drawer tray motor is not rotating or the PFP upper drawer tray is not moving normally.P. 8-124
      C160PFP lower drawer tray abnormality: The PFP lower drawer tray motor is not rotating or the PFP lower drawer tray is not moving normally.P. 8-124
      C180LCF tray-up motor abnormality: The LCF tray-up motor is not rotating or the LCF tray is not moving normally.P. 8-125
      C1A0LCF end fence motor abnormality: The LCF end fence motor is not rotating or the LCF end fence is not moving normally.P. 8-126
      C1B0LCF transport motor abnormality: The LCF transport motor is not rotating normally.P. 8-127
      C260Scanning system related service callPeak detection error: Lighting of the exposure lamp (white reference) is not detected when power is turned ON.P. 8-128
      C261Peak detection error (high-light intensity):
      (e-STUDIO207L/257/307/357/457/507 only)
      C262Peak detection error (communication error):
      C270Carriage home position sensor not turning OFF within a specified period of time: The carriage does not shift from its home position in a specified period of time.P. 8-131
      C280Carriage home position sensor not turning ON within a specified period of time: The carriage does not reach to its home position in a specified period of time.P. 8-134
      C290Scanner fuse blowout: 24V power for the scanning system is not supplied at the scanner warming-up after power-ON.P. 8-136
      C3D0Process related service callEPU board memory overwriting error: The overwriting of the EPU board memory fails.P. 8-138
      C3D1EPU board memory new parts detection error: The EPU board detects the process unit as a new unit when the equipment is started in the normal mode.P. 8-138
      C3D2EPU board memory old parts detection error: The EPU board cannot detect the new process unit when the equipment is started in the EPU replacement mode ([7] + [START]).P. 8-139
      C410Fuser unit related
      service call
      Thermistor or heater abnormality at power-ON:
      Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON.
      (e-STUDIO206L/256/306/356/456/506 only)
      P. 8-141
      C411Thermistor or heater abnormality at power-ON:
      P. 8-141
      C412Thermistor or heater abnormality at power-ON:
      P. 8-141
      C430Thermistor abnormality: Abnormality of the thermistor is
      detected after a specified period of time has passed from power-ON (including ready state).
      P. 8-142
      C440Fuser roller abnormality: The temperature of the fuser
      roller has exceeded the range of control or does not even reach the range.
      P. 8-142
      C443Thermistor or heater abnormality at power-ON:
      P. 8-144
      C445Thermistor or heater abnormality at power-ON:
      P. 8-144
      C447Thermistor or heater abnormality: Abnormality of service
      call the thermistor is detected or the temperature of the fuser roller does not rise in a specified period of time. (e-STUDIO207L/257/307/357/457/507 only)
      P. 8-144
      C449Fuser roller abnormality: The temperature of the fuser
      roller has exceeded the range.
      P. 8-145
      C450Thermistor abnormality during printing: Abnormality of the
      thermistor is detected during printing.
      P. 8-146
      C452Thermistor abnormality at ready state: Abnormality of the
      thermistor is detected during ready state.
      P. 8-146
      C4B0Fuser unit error counter abnormalityP. 8-147
      C4C0Fuser unit new/old detection fuse abnormalityP. 8-147
      C550Optional
      communication related service call
      RADF I/F error: Communication error has occurred
      between the RADF and the scanner.
      P. 8-148
      C551Document feeder model detection error: An optional
      document feeder that is not compatible to this equipment is installed.
      P. 8-148
      C570Communication error between Engine-CPU and CNV
      board
      P. 8-148
      C580Communication error between CNV board and finisherP. 8-149
      C5A0Circuit related
      service call
      EEPROM communication abnormality (LGC board)P. 8-151
      C8E0Optional
      ADF communication abnormality: The system has to be
      stopped because the control abnormality occurred
      P. 8-149
      8​
      C911Circuit related
      service call
      Toner cartridge IC chip abnormalityP. 8-140
      C940Circuit related
      service call
      Engine-CPU abnormalityP. 8-151
      C970Process related
      service call
      High-voltage transformer abnormality: Leakage of the
      main charger is detected.
      P. 8-140
      CA10Laser optical unit related service callPolygonal motor abnormality: The polygonal motor is not rotating normally.P. 8-154
      CA20H-Sync detection error: H-Sync detection PC board cannot detect laser beams.P. 8-154
      CB00Finisher related
      service call
      Finisher not connectedP. 8-155
      CB01Finisher communication errorP. 8-155
      CB10Entrance motor abnormality: The entrance motor is not
      rotating normally. [MJ-1101/1107/MJ-1106/1108]
      P. 8-155
      CB11Buffer tray guide motor abnormality: The buffer tray guide
      motor is not rotating or the buffer tray guide is not moving normally. [MJ-1101/1107/MJ-1106/1108]
      P. 8-156
      CB12Buffer roller drive motor abnormality: The buffer roller
      drive motor is not rotating or the buffer roller is not moving normally. [MJ-1101/1107/MJ-1106/1108]
      P. 8-156
      CB13Finisher exit motor abnormality [MJ-1101/1107/MJ-1106/
      1108]
      P. 8-157
      CB14Paper holding arm motor abnormality [MJ-1101/1107/MJ-
      1106/1108]
      P. 8-157
      CB30Movable tray shift motor abnormality: The movable trayP. 8-158
      shift motor is not rotating or the movable tray is not
      moving normally. [MJ-1101/1107]
      Movable tray shift motor abnormality: The movable trayP. 8-159
      shift motor or the movable tray does not work properly.
      [MJ-1032]
      Movable tray shift motor abnormality: The movable trayP. 8-160
      [MJ-1033]
      CB31Movable tray paper-full detection error: The actuator of
      the movable tray paper-full detection sensor does not move smoothly. [MJ-1101/1107/MJ-1106/1108]
      P. 8-160
      CB40Front alignment motor abnormality: The front alignmentP. 8-161
      motor is not rotating or the front align/1106/1108ment
      plate is not moving normally. [MJ-1101/1107]
      Front alignment plate home position detection error: TheP. 8-163
      detection of the home position ends abnormally because
      the front alignment plate has not worked properly.
      [MJ-1032/MJ-1033]
      CB50Stapler home position error: The stapler home positionP. 8-163
      sensor does not work. [MJ-1101/1107/MJ-1106/1108]
      Stapler unit home position detection error: The detectionP. 8-164
      of the home position of the stapler unit ends abnormally.
      [MJ-1032/MJ-1033]P. 8-164
      CB51Stapler shift home position error: The stapler is not at theP. 8-165
      Stapler unit sliding home position detection error: TheP. 8-166
      ends abnormally. [MJ-1032/MJ-1033]P. 8-167
      CB60Finisher related
      service call
      Stapler shift motor abnormality: Stapler shift motor is not
      rotating or staple unit is not moving normally. [MJ-1101/1107/MJ-1106/1108]
      P. 8-167
      CB80Backup RAM data abnormality:
      Abnormality of checksum value on finisher controller PC board is detected when the power is turned ON.
      EEPROM data abnormality: An error occurs during the writing of data into the EEPROM of the Finisher. [MJ- 1032/MJ-1033]
      P. 8-168
      P. 8-168
      CB81Flash ROM abnormality: Abnormality of checksum value
      on finisher controller PC board is detected when the power is turned ON. [MJ-1101/1107/MJ-1106/1108]
      P. 8-169
      CB82Finisher - Main CPU program errorP. 8-169
      CB83Saddle Stitch Finisher - Main CPU program error [MJ-
      1106/1108]
      P. 8-170
      CB84Hole Punch Unit - Main CPU program errorP. 8-170
      CB90Paper pushing plate motor abnormality: Paper pushing
      plate motor is not rotating or paper pushing plate is not moving normally.
      P. 8-170
      CB91Saddle Stitch Finisher flash ROM abnormality [MJ-1106/
      1108]
      P. 8-171
      CB92Saddle Stitch Finisher RAM abnormality [MJ-1106/1108]P. 8-171
      CB93Additional folding motor abnormality [MJ-1106/1108]P. 8-171
      CB94Saddle transport motor abnormality [MJ-1106/1108]P. 8-172
      CB95Stacker motor abnormality [MJ-1106/1108]P. 8-172
      CBA0Front saddle stapler home position error: The stapler
      home position detection is abnormally operated and finished. [MJ-1106/1108]
      P. 8-173
      CBB0Rear saddle stapler home position error: The stapler
      P. 8-173
      CBC0Saddle Stitch Finisher side alignment motor (M15)
      abnormality: The alignment motor is not rotating or the alignment plate is not working properly. [MJ-1106/1108]
      P. 8-173
      CBE0Saddle Stitch Finisher folding motor (M17) abnormality:
      The folding motor is not rotating or the folding roller is not moving normally. [MJ-1106/1108]
      P. 8-174
      CBF0Stacker motor (M9) abnormality:
      The stacker motor is not rotating. [MJ-1033]
      P. 8-175
      8​
      CC01Finisher related
      service call
      A model not supporting the Finisher is connected. Note
      that this error is recognized in the communication converter and is output.
      CC02Stack exit roller nip home position detection error: The
      detection of the home position of the stack exit roller nip ends abnormally. [MJ-1032/MJ-1033]
      P. 8-175
      CC20Saddle communication error [MJ-1106/1108]P. 8-176
      CC21The detection of the home position of the saddle stitch
      P. 8-176
      CC22The detection of the home position of the saddle stitch
      P. 8-177
      CC23An abnormal interruption of the encoder pulse of the
      folding blade occurs.
      CC30Stack transport motor abnormality: The stack transport motor is not rotating or the stack transport belt is not moving normally. [MJ-1101/1107/MJ-1106/1108]P. 8-178
      CC31Transport motor abnormality: The transport motor is not
      rotating or the stack transport roller -1 and -2 is not rotating normally. [MJ-1101/1107/MJ-1106/1108]
      P. 8-178
      CC41Paper holder cam home position abnormality: The paper
      holder cam is not at the home position. [MJ-1101/1107]
      P. 8-179
      CC51Sideways adjustment motor (M2) abnormality: Sideways
      adjustment motor is not rotating or puncher is not shifting normally. [MJ-1101/1106 (when MJ-6103 is installed), MJ- 1107/1108 (when MJ-6104 is installed)]
      P. 8-180
      CC52Skew adjustment motor (M1) abnormality: Skew
      P. 8-181
      CC53An abnormality occurs in the punch waste full sensor.P. 8-182
      CC54Hole punch registration sensor detection error: An
      abnormality occurs in the hole punch registration sensor. [MJ-1032/MJ-1033]
      P. 8-182
      CC60Punch motor abnormality: Punch motor is not rotating or
      puncher is not shifting normally.]
      P. 8-185
      CC61Punch motor (M3) home position detection error: Punch
      motor is not rotating or puncher is not shifting normally. [MJ-1101/1106 (when MJ-6103 is installed), MJ-1107/ 1108 (when MJ-6104 is installed)]
      P. 8-185
      CC71Punch ROM checksum error: Abnormality of checksum
      value on Hole punch controller PC board is detected when the power is turned on. [MJ-1101/1106 (when MJ- 6103 is installed), MJ-1107/1108 (when MJ-6104 is installed)]
      P. 8-186
      CC72Punch RAM read/write error: Abnormality of checksum
      P. 8-186
      CC80Rear alignment motor abnormality: The rear alignment
      motor is not rotating or the rear alignment plate is not moving normally. [MJ-1101/1107/MJ-1106/1108]
      Rear alignment plate home position detection error: The detection of the home position ends abnormally because the rear alignment plate has not worked properly.
      [MJ-1032/MJ-1033]
      P. 8-186
      CC91Finisher related
      service call
      ends abnormality.
      P. 8-188
      CC92The movable tray exceeds its upper limit.P. 8-188
      CC93Knurled roller shift solenoid abnormality: An abnormality
      occurs in the knurled roller shift solenoid. [MJ-1032]
      P. 8-189
      CC941st fan motor abnormality: The 1st fan motor is locked
      abnormally. [MJ-1032]
      P. 8-189
      CCF1Tray safety switch abnormality -
      The tray safety switch turned on during tray operation (moving up or down).
      CDE0Paddle motor abnormality: The paddle motor does not
      rotate properly.
      P. 8-189
      CDF0Offset tray related
      service call
      Initialization error of the offset tray: The home position of
      the separator cannot be detected when the power is turned ON.
      P. 8-191
      CE00Optional
      Communication error between finisher unit and puncher
      unit: Communication error between the finisher controller PC board and punch controller PC board.
      P. 8-150
      CE50Process related
      service call
      Temperature/humidity sensor abnormality: The output
      value of this sensor is out of a specified range.
      P. 8-139
      CE90Drum thermistor abnormality: The output value of the
      drum thermistor-K is out of a specified range.
      P. 8-139
      CF10Finisher related
      service call
      Communication module SRAM reading failure. [MJ-1101/
      1107]
      P. 8-190
      F070Communication
      Communication error between System-CPU and Engine-
      CPU
      P. 8-190
      F090Circuit related
      service call
      SRAM abnormality on the SYS boardP. 8-151
      F100_0Other service callHDD format error: Operation of HDD key data fails.P. 8-192
      F100_1HDD format error: Encryption key data of either the SYS
      board or the SRAM board for the SYS board are damaged.
      P. 8-192
      F100_2HDD format error: Encryption key data of both the SYS
      board and the SRAM board for the SYS board are damaged.
      P. 8-193
      F101_0HDD connection error (HDD connection cannot be
      detected.)
      P. 8-194
      F101_1Root partition mount error (HDD formatting fails.): The
      HDD cannot be connected (mounted) caused by damage to the areas in which the program is mainly stored.
      P. 8-194
      F101_2Partition mount error: The HDD cannot be connected
      (mounted) caused by damage to areas other than those described in the F101_1 and F101_4 to F101_9 errors.
      P. 8-194
      F101_3Partition mount error: The HDD cannot be connected
      P. 8-194
      F101_4Partition mount error: The HDD cannot be connected
      (mounted) caused by damage to the “/work” partition.
      P. 8-195
      F101_5Partition mount error: The HDD cannot be connected
      (mounted) caused by damage to the “/registration” partition.
      P. 8-196
      F101_6Partition mount error: The HDD cannot be connected
      (mounted) caused by damage to the “/backup” partition.
      P. 8-197
      F101_7Partition mount error: The HDD cannot be connected
      (mounted) caused by damage to the “/imagedata” partition.
      P. 8-198
      F101_8Partition mount error: The HDD cannot be connected
      (mounted) caused by damage to the “/storage” partition.
      P. 8-199
      F101_9Partition mount error: The HDD cannot be connected
      (mounted) caused by damage to the “/encryption” partition.
      P. 8-200
      F102HDD start error: HDD cannot become ‘Ready’ state.P. 8-201
      8​
      F103Other service callHDD transfer time-out: Reading/writing cannot be
      performed in the specified period of time.
      P. 8-201
      F104HDD data error: Abnormality is detected in the data of
      HDD.
      P. 8-201
      F105HDD other errorP. 8-201
      F106_0ADI-HDD error: Illegal disk replacement detected (ADI-
      HDD Exchange to SATA-HDD)
      P. 8-201
      F106_1ADI-HDD error: HDD type detection errorP. 8-202
      F106_2ADI-HDD error: ADI encryption key download operation
      error
      P. 8-202
      F106_3ADI-HDD error: ADI authentication Admin Password generation errorP. 8-203
      F106_4ADI-HDD error: Authentication random number
      generation error
      P. 8-203
      F106_5ADI-HDD error: Authentication data transmission errorP. 8-203
      F106_6ADI-HDD error: Error caused by reason other than
      F106_0 to 5 errors.
      P. 8-204
      F106_7P. 8-204
      F106_8P. 8-204
      F106_10P. 8-204
      F106_UND EFP. 8-204
      F109_0Key consistency error: Consistency check operation
      error.
      P. 8-204
      F109_1Key consistency error: SRAM encryption AES key data
      damage.
      P. 8-205
      F109_2Key consistency error: Signature Check public key
      damage.
      P. 8-205
      F109_3Key consistency error: HDD encryption parameter
      damage.
      P. 8-206
      F109_4Key consistency error: license data damage.P. 8-207
      F109_5Key consistency error: Encryption key for ADI-HDD is
      damaged.
      P. 8-208
      F109_6Key consistency error: Administrator password error for
      ADI-HDD authentication.
      P. 8-210
      F110Communication
      Scanner-CPU
      P. 8-153
      F111Scanner response abnormalityP. 8-153
      F120Other service callDatabase abnormality: Database is not operating
      normally.
      P. 8-211
      F121Database abnormality (user information management
      database)
      P. 8-212
      F122Database abnormality (Message/Job log management
      database)
      P. 8-212
      F124Database abnormality: Database is
      not operating normally. (Language management database)
      P. 8-213
      F130Invalid MAC addressP. 8-213
      F131Error due to damage to filtering setting fileP. 8-213
      F140ASIC format error: ASIC formatting fails or memory
      acquiring fails when software is formatted.
      P. 8-213
      F200Data Overwrite option (GP-1070) disabledP. 8-214
      F350Circuit related
      service call
      SLG board abnormalityP. 8-152
      F400SYS board cooling fan abnormalityP. 8-152
      F500Other service callHD partition damageP. 8-214
      F510Application start errorP. 8-214
      F520Operating system start errorP. 8-215
      F521Integrity check errorP. 8-215
      F550Encryption partition errorP. 8-215
      F600Software update errorP. 8-215
      F700Overwrite errorP. 8-216
      F800Date errorP. 8-216
      F900Model information errorP. 8-217
      F901Engine speed error: The speed information of the LGC
      board is damaged.
      P. 8-218
      F901_1Engine speed error: The speed information of the LGC
      board is damaged.
      P. 8-218
      8​
    3. Error in Internet FAX / Scanning Function​
      1. Internet FAX related error
        Error codeContentsTroubleshooting
        1C10System access abnormalityP. 8-219
        1C11Insufficient memoryP. 8-219
        1C12Message reception errorP. 8-219
        1C13Message transmission errorP. 8-219
        1C14Invalid parameterP. 8-219
        1C15Exceeding file capacityP. 8-220
        1C20System management module access abnormalityP. 8-220
        1C21Job control module access abnormalityP. 8-220
        1C22Job control module access abnormalityP. 8-220
        1C30Directory creation failureP. 8-220
        1C31File creation failureP. 8-220
        1C32File deletion failureP. 8-219
        1C33File access failureP. 8-220
        1C40Image conversion abnormalityP. 8-220
        1C60HDD full failure during processingP. 8-221
        1C61Address Book reading failureP. 8-221
        1C63Terminal IP address unsetP. 8-221
        1C64Terminal mail address unsetP. 8-221
        1C65SMTP address unsetP. 8-221
        1C66Server time-out errorP. 8-222
        1C69SMTP server connection errorP. 8-222
        1C6BTerminal mail address errorP. 8-222
        1C6CDestination mail address errorP. 8-222
        1C6DSystem errorP. 8-222
        1C70SMTP client OFFP. 8-223
        1C71SMTP authentication errorP. 8-223
        1C72POP before SMTP errorP. 8-223
        1C80Internet FAX transmission failure when processing E-mail job receivedP. 8-223
        1C81Onramp Gateway transmission failureP. 8-223
        1C82Internet FAX transmission failure when processing FAX job receivedP. 8-223
        1CC0Job canceling-
        1CC1Power failureP. 8-223
        8​
      2. RFC related error
        Error codeMessage displayed in the TopAccess screenContentsTroubleshooting
        2500Syntax error, command unrecognizedHOST NAME error (RFC: 500)
        Destination mail address error (RFC: 500)
        Terminal mail address error (RFC: 500)
        P. 8-225
        2501Syntax error in parameters or argumentsHOST NAME error (RFC: 501)
        Destination mail address error (RFC: 501)
        Terminal mail address error (RFC: 501)
        P. 8-225
        2503Bad sequence of commandsDestination mail address error (RFC: 503)P. 8-225
        2504Command parameter not implementedHOST NAME error (RFC: 504)P. 8-225
        2550Mailbox unavailableDestination mail address error (RFC: 550)P. 8-225
        2551User not localDestination mail address error (RFC: 551)P. 8-225
        2552Insufficient system storageTerminal/Destination mail address error (RFC: 552)P. 8-225
        2553Mailbox name not allowedDestination mail address error (RFC: 553)P. 8-226
      3. Electronic Filing related error
        2B10There was no applicable job.No applicable job error in job control moduleP. 8-227
        2B11Job status failed.JOB status abnormalityP. 8-227
        2B20Failed to access file.File library function errorP. 8-227
        2B21Message size exceeded limit or maximum sizeExceeding file capacityP. 8-227
        2B30Insufficient disk space.Insufficient disk space in /SHR partitionP. 8-227
        2B31Failed to access Electronic Filing.Status of specified Electronic Filing or folder is undefined or being created/ deletedP. 8-227
        2B32Failed to print Electronic Filing document.Electronic Filing printing failure: Specified document can not be printed because of client's access (being edited, etc.).P. 8-227
        2B50Failed to process image.Image library errorP. 8-228
        2B51Failed to process print image.List library errorP. 8-228
        2B60The folder was renamed. A folder of the same name already existed.A folder with the same name exists in the box.-
        2B70The document was renamed. A document of the same name already existed.A document with the same name exists in the box or folder.-
        2B71Document(s) expire(s) in a few daysDocuments expiring in a few days exist-
        2B80Hard Disk space for Electronic Filing nearly full.Hard disk space in /SHR partition is nearly full (90%).-
        2B90Insufficient Memory.Insufficient memory capacityP. 8-228
        2BA0Invalid Box password specified.Invalid Box passwordP. 8-228
        2BA1Incorrect paper sizeA Paper size not supported in the Electronic Filing function is being selected.P. 8-228
        2BB0Job canceledJob canceling-
        2BB1Power failure occurredPower failureP. 8-229
        2BC0System fatal error.Fatal failure occurred.P. 8-228
        2BC1Failed to acquire resource.System management module resource acquiring failureP. 8-228
        2BD0Power failure occurred during e- Filing restoring.Power failure occurred during restoring of Electronic FilingP. 8-229
        2BE0Failed to get machine parameter.Machine parameter reading failureP. 8-229
        2BF0Maximum number of pages has been exceeded (list Maximum)Exceeding maximum number of pagesP. 8-229
        2BF1Maximum number of documents has been exceeded (list Maximum)Exceeding maximum number of documentsP. 8-229
        2BF2Maximum number of folders has been exceeded (list Maximum)Exceeding maximum number of foldersP. 8-229
        8​
      4. Remote scanning related error
        2A20Failed to acquire resourceSystem management module resource acquiring failureP. 8-230
        2A31WS Scan function is not availableDisabled WS ScanP. 8-230
        2A40System fatal errorSystem errorP. 8-230
        2A50Job cancelingJob canceling-
        2A51Power failurePower failureP. 8-230
        2A60Authentication for WS Scan failedWS Scan user authentication failureP. 8-230
        2A70Insufficient permission to execute Remote ScanRemote Scan privilege check errorP. 8-231
        2A71Insufficient permission to execute WS ScanWS Scan privilege check errorP. 8-231
        2A72Insufficient permission to access e- Filing box using scan utility.e-Filing data access privilege check error (Scan Utility)P. 8-231
      5. E-mail related error
        2C10Illegal Job statusSystem access abnormalityP. 8-232
        2C11Not enough memoryInsufficient memoryP. 8-232
        2C12Illegal Job statusMessage reception errorP. 8-232
        2C13Illegal Job statusMessage transmission errorP. 8-232
        2C14Invalid parameter specifiedInvalid parameterP. 8-232
        2C15Message size exceeded limit or maximum sizeExceeding file capacityP. 8-232
        2C20Illegal Job statusSystem management module access abnormalityP. 8-233
        2C21Illegal Job statusJob control module access abnormalityP. 8-233
        2C22Illegal Job statusJob control module access abnormalityP. 8-233
        2C30Failed to create directoryDirectory creation failureP. 8-233
        2C31Failed to create fileFile creation failureP. 8-233
        2C32Failed to delete fileFile deletion failureP. 8-232
        2C33Failed to create fileFile access failureP. 8-233
        2C40Failed to convert image file formatImage conversion abnormalityP. 8-233
        2C43Encryption error. Failed to create file.Encryption errorP. 8-233
        2C44Creating the image file was not permitted.Encryption PDF enforced mode errorP. 8-234
        2C45Failed in making meta data.Meta data creation error (Scan to Email)P. 8-234
        2C60Failed to process your Job. Insufficient disk space.HDD full failure during processingP. 8-234
        2C61Failed to read AddressBookAddress Book reading failureP. 8-234
        2C62Not enough memoryMemory acquiring failureP. 8-233
        2C63Invalid Domain AddressTerminal IP address unsetP. 8-234
        2C64Invalid Domain AddressTerminal mail address unsetP. 8-235
        2C65Failed to connect to SMTP serverSMTP address unsetP. 8-235
        2C66Failed to connect to SMTP serverServer time-out errorP. 8-235
        2C69Failed to connect to SMTP serverSMTP server connection errorP. 8-235
        2C6AFailed to send E-Mail messageHOST NAME error (No RFC error)P. 8-235
        2C6BInvalid address specified in From: fieldTerminal mail address errorP. 8-236
        2C6CInvalid address specified in To: fieldDestination mail address error (No RFC error)P. 8-236
        2C70SMTP service is not availableSMTP client OFFP. 8-236
        2C71Failed SMTP AuthenticationSMTP authentication errorP. 8-236
        2C72POP Before SMTP Authentication FailedPOP before SMTP errorP. 8-236
        2C80Failed to process received E-mail jobE-mail transmission failure when processing E-mail job receivedP. 8-236
        2C81Failed to process received Fax jobProcess failure of FAX job receivedP. 8-237
        2CC0Job canceledJob canceling-
        2CC1Power failure occurredPower failureP. 8-237
        8​
      6. File sharing related error
        2D10Illegal Job statusSystem access abnormalityP. 8-238
        2D11Not enough memoryInsufficient memoryP. 8-238
        2D12Illegal Job statusMessage reception errorP. 8-238
        2D13Illegal Job statusMessage transmission errorP. 8-238
        2D14Invalid parameter specifiedInvalid parameterP. 8-238
        2D15There are too many documents in the folder. Failed in creating new document.Exceeding document numberP. 8-239
        2D20Illegal Job statusSystem management module access abnormalityP. 8-239
        2D21Illegal Job statusJob control module access abnormalityP. 8-239
        2D22Illegal Job statusJob control module access abnormalityP. 8-239
        2D30Failed to create directoryDirectory creation failureP. 8-239
        2D31Failed to create fileFile creation failureP. 8-239
        2D32Failed to delete fileFile deletion failureP. 8-239
        2D33Failed to create fileFile access failureP. 8-239
        2D40Failed to convert image file formatImage conversion abnormalityP. 8-239
        2D43Encryption error. Failed to create file.Encryption errorP. 8-240
        2D44Creating the image file was not permitted.Encryption PDF enforced mode errorP. 8-240
        2D45Failed in making meta data.Meta data creation error (Scan to File)P. 8-240
        2D60Failed to copy fileFile library access abnormalityP. 8-239
        2D61Invalid parameter specifiedInvalid parameterP. 8-238
        2D62Failed to connect to network destination. Check destination pathFile server connection errorP. 8-240
        2D63Specified network path is invalid. Check destination pathInvalid network pathP. 8-240
        2D64Logon to file server failed. Check username and passwordLogin failureP. 8-241
        2D65There are too many documents in the folder. Failed in creating new document.Exceeding documents in folder: Creating new document is failed.P. 8-241
        2D66Failed to process your Job. Insufficient disk space.HDD full failure during processingP. 8-239
        2D67FTP service is not availableFTP service not availableP. 8-241
        2D68File Sharing service is not availableFile sharing service not availableP. 8-241
        2D69NetWare service is not availableNetWare service not availableP. 8-242
        2DA0Expired scan documents deleted from share folder.Periodical deletion of scanned documents completed properly.-
        2DA1Expired Sent Fax documents deleted from shared folder.Periodical deletion of transmitted FAX documents completed properly.-
        2DA2Expired Received Fax documents deleted from shared folder.Periodical deletion of received FAX documents completed properly.-
        2DA3Scanned documents in shared folder deleted upon user's request.Manual deletion of scanned documents completed properly.-
        2DA4Sent Fax Documents in shared folder deleted upon user's request.Manual deletion of transmitted FAX documents completed properly.-
        2DA5Received Fax Documents in shared folder deleted upon user's request.Manual deletion of received FAX documents completed properly.-
        2DA6Failed to delete file.File deletion failureP. 8-238
        2DA7Failed to acquire resource.Resource acquiring failureP. 8-238
        2DA8The HDD is running out of capacity for the shared folder.Hard disk space in /SHA partition is nearly full (90%).-
        2DC0Job canceledJob canceling-
        2DC1Power failure occurredPower failureP. 8-242
        2E10Failed to store document(s) in USB folder.USB storage system access abnormalityP. 8-242
        2E11Failed to store document(s) in USB folder.Insufficient memory capacity for USB storageP. 8-242
        2E12Failed to store document(s) in USB folder.Message reception error in USB storageP. 8-242
        2E13Failed to store document(s) in USB folder.Message transmission error in USB storageP. 8-242
        2E14Failed to store document(s) in USB folder.Invalid parameter for USB storageP. 8-243
        2E15Document size exceeded limit or maximum sizeExceeding the maximum size for file sharingP. 8-243
        2E30Failed to store document(s) in USB folder.Creation of a directory failed.P. 8-243
        2E31Failed to store document(s) in USB folder.File creation failure in USB storageP. 8-243
        2E32Failed to store document(s) in USB folder.File deletion failure in USB storageP. 8-243
        2E33Failed to store document(s) in USB folder.File access failure in USB storageP. 8-244
        2E40Failed to convert image file formatImage conversion abnormality in USB storageP. 8-244
        2E43Encryption error. Failed to create file.Encryption failure in USB storageP. 8-244
        2E44Creating the image file was not permitted.Encryption PDF enforced mode error in USB storageP. 8-244
        2E45Failed in making meta data.Meta data creation error in USB storage (Scan to File)P. 8-244
        2E65There are too many documents in folders. Failed in creating new document.File creation error due to insufficient USB folder capacityP. 8-245
        2E66Failed To Process your Job. Insufficient Storage space.HDD full failure during USB storageP. 8-245
        2EC0Job CanceledJob Canceled-
        2EC1Power Failure Job AbortedPower failure in USB storageP. 8-245
        8​
      7. E-mail reception related error
      3A10MIME Error has been detected in the received mail.E-mail MIME errorP. 8-246
      3A20Analyze Error has been detected in the received mail.E-mail analysis errorP. 8-246
      3A30Whole partial mails were not reached by timeout.Partial mail time-out errorP. 8-246
      3A40Partial Mail Error has been detected in the received mail.Partial mail related errorP. 8-246
      3A50HDD Full Error has been occurred in this mail.Insufficient HDD capacity errorP. 8-247
      3A70Receiving partial mail was aborted since the partial mail setting has been changed to Disable.Warning of partial mail interruptionP. 8-247
      3A80Partial mail was received during the partial mail setting is disabled.Partial mail reception setting OFFP. 8-247
      3B10Format Error has been detected in the received mail.E-mail format errorP. 8-246
      3B20Content-Type Error has been detected in the received mail.Content-Type errorP. 8-247
      3B40Decode Error has been detected in the received mail.E-mail decode errorP. 8-246
      3C10Tiff Analyze Error has been detected in the received mail.TIFF analysis errorP. 8-248
      3C13Tiff Analyze Error has been detected in the received mail.P. 8-248
      3C20Tiff Compression Error has been detected in the received mail.TIFF compression errorP. 8-248
      3C30Tiff Resolution Error has been detected in the received mail.TIFF resolution errorP. 8-248
      3C40Tiff Paper Size Error has been detected in the received mail.TIFF paper size errorP. 8-248
      3C50Offramp Destination Error has been detected in the received mail.Offramp destination errorP. 8-249
      3C60Offramp Security Error has been detected in the received mail.Offramp security errorP. 8-249
      3C70Power Failure has been occurred in E-mail receiving.Power failure errorP. 8-249
      3C90OffRamp Fax transmission disable error has been detected in the received mail.OffRamp Fax transmission disable errorP. 8-249
      3D10SMTP Destination Error has been detected in the received mail.
      This mail was deleted.
      Destination address errorP. 8-249
      3D20Offramp Destination limitation Error has been detected in the received mail.Offramp destination limitation errorP. 8-250
      3D30Fax Board Error has been occurred in the received mail.FAX board errorP. 8-250
      3E10POP3 Connection Error has been occurred in the received mail.POP3 server connection errorP. 8-250
      3E20POP3 Connection Timeout Error has been occurred in the received mail.POP3 server connection time-out errorP. 8-250
      3E30POP3 Login Error has been occurred in the received mail.POP3 login errorP. 8-250
      3E40POP3 Login Error occurred in received mail.POP3 login method errorP. 8-251
      3F10File I/O Error has been occurred in this mail. The mail could not be received until File I/O is recovered.File I/O errorP. 8-251
      3F20P. 8-251
    4. Printer function error​
      8​
      Following codes are displayed at the end of the user name on the print job log screen
      4011Print job cancellation: Print job (copy, list print, network print) is deleted from the print job screen.P. 8-252
      4021Print job power failure: The power of the equipment is turned OFF during print job (copy, list print, network print).P. 8-252
      4031HDD full during print: Large quantity image data by private print or invalid network print are saved in HDD.P. 8-252
      4032Private-print-only error: Jobs other than Private print jobs cannot be performed.P. 8-252
      4033Printing data storing limitation error: Printing with its data being stored to the HDD temporarily (Proof print, Private print, Scheduled print, etc.) cannot be performed.P. 8-252
      4034e-Filing storing limitation error: Printing with its data being stored to the HDD (print and e-Filing, print to e-Filing, etc.) cannot be performed.P. 8-253
      4035Local file storing limitation error: Network FAX or Internet FAX cannot be sent when “Local” is selected for the destination of the file to save.P. 8-253
      4037Hardcopy security printing error: hardcopy security printing job is performed when the function is restricted.P. 8-253
      4038Restriction error (only for hold print jobs)P. 8-253
      4039Restriction error (only for private/hold print jobs)P. 8-253
      4040Not being authorized to perform JOBP. 8-253
      4041User authentication error: The user who intended to print a document is not registered as a user.P. 8-254
      4042Department authentication error? A department whose code is specified for a print job is not registered.P. 8-254
      4050Problem in LDAP server connection or LDAP server authorization settingsP. 8-254
      4111Quota over error (The number of the assigned pages set by department and user management has reached 0.): The numbers of output pages have exceeded those specified with both of the department code and the user code at the same time.P. 8-254
      4112Quota over error (The number of the assigned pages set by user management has reached 0.): The number of output pages has exceeded the one specified with the user code.P. 8-254
      4113Quota over error (The number of the assigned pages set by department management has reached 0.): The number of output pages has exceeded the one specified with the department code.P. 8-255
      4121Job canceling due to external counter errorP. 8-255
      4214Fax/Internet FAX transmission limitation error: Fax / Internet FAX transmission function or Network Fax/Internet Fax function is disabled.P. 8-255
      4241No Printer Kit / Printer Kit function disabled: The Printer Kit or the Printer/ Scanner Kit is not installed. Or network printing of an XPS file is performed, or network printing is performed after the termination of a trial period.P. 8-252
      4242Internet FAX or storing to a share folder function using a network fax driver is disabled since the Scanner kit is not installed firmly, but the Printer kit is installed.P. 8-252
      4300USB direct printing: Job execution error due to functional restrictions - Printing with he USB direct printing function restrictedP. 8-256
      4301USB direct printing: File conversion error - Printing a file whose format is not supported, or an invalid fileP. 8-256
      4311Printing not permitted: Printing is not permitted or only printing in a low resolution level is permitted due to the encryption language of the encrypted PDF file.
      * Permitted only when a user password is entered.
      P. 8-256
      4312Password mismatching: The entered password is neither matched with a user password nor an owner password.P. 8-256
      4313File storing limitation error: The file storing function is set to “disabled”.P. 8-256
      4314Fax/Internet Fax transmission limitation error: Fax / Internet FAX transmission function or Network Fax/Internet FAX function is disabled.P. 8-256
      4411Image data creation failure: Data that you tried to print may be corrupted.P. 8-257
      4412Double-sign encoding error: A double-sign encoding error occurred because the PDF file is encrypted in a forbidden language or in a language not supported.P. 8-257
      4611Font download failure (exceeding maximum number of registrations): A new font cannot be registered because the number of fonts registered in this equipment has reached the limit.P. 8-257
      4612Font download failure (HDD full): A new font cannot be registered because there is not sufficient space in the font storage area of this equipment.P. 8-257
      4613Font download failure (others): A new font cannot be registered due to other abnormality.P. 8-257
      4621Font deletion failure: A font cannot be deleted because the specified font does not exist, the specified font is undeletable or any other abnormality occurred.P. 8-257
      4F10Printing was not performed successfully due to other abnormalities.P. 8-258
      • Network print: Data are corrupted or invalid.
      • Direct print: A file is corrupted or not in a supported format.
      8​
    5. TOSHIBA Remote monitoring system error (TopAccess related error)​
      5010-Internal setting error: There is a print job, a proof print job, a private print job, a print job without a set department code, a scan job or a fax job remaining in this equipment.P. 8-259
      5012Invalid temporary password and permanent passwordAuthentication error: A temporary password downloaded from e- Bridge and entered in this equipment is not valid, or the permanent password set in the e- Bridge is not valid.P. 8-259
      5013e-Bridge communication errore-Bridge communication error: Communication is attempted while the e-Bridge is enabled for some reason such as version upgrade.P. 8-259
      5014No SSL certificateNo SSL certificate: There is no SSL certificate or the certificate is not in a correct file format.P. 8-259
      5015Invalid SSL certificateInvalid SSL certificate: SSL certificate is not valid.P. 8-260
      5016Expired SSL certificateIncorrect time in MFPExpired SSL certificate: SSL certificate is expired.P. 8-260
      5017Other SSL certificate related errorOther SSL certificate related error: SSL certificate is invalid.P. 8-260
      5018Invalid DNS errorInvalid DNS error: DNS address is invalid.P. 8-260
      5019Connection errorConnection error: Settings for initial URL and proxy are incorrect.P. 8-260
      501AProxy errorProxy error: IP address or port for proxy setting is invalid.P. 8-261
      501BNo URL (host/port) or invalid pathNo URL (host/port) or invalid path: Initial URL is invalid.P. 8-261
      5030HTTP communication errorAn error in the HTTP communicationP. 8-261
      50FFeBR2 internal errorA fatal error occurred in the MFPP. 8-261
      5110Toner Not Recognized - Please Check Toner.Toner cartridge detection error.P. 8-261
      5BD0Power failure occurred during restorePower supply is cut off during the restoration of database sent from TopAccessP. 8-262
      5C10FAX Unit is not attached.Network FAX is disabled because the FAX Unit is not attachedP. 8-262
      5C11Security error on Address Book.The network FAX job failed because the specified address is not registered in the Address BookP. 8-262
      5C20The file has been importedDisplayed when data have been imported from TopAccess
      (Not an error message)
      P. 8-262
      5C21Failed to import the file - Invalid file formatData import from TopAccess failed due to invalid file formatP. 8-263
      8​
    6. MFP access error​
      6007Failed user loginUnsuccessful User Login to MFP: User authentication cannot be done because connection to the authentication server has failed.P. 8-264
      6008Failed to connect on External LDAP server for Role Base Access ControlFailed to connect on External Role Base Access Control (LDAP) Server: User authentication cannot be done because connection to an external RBAC server has failed.P. 8-264
      6013Failed to connect on the authentication serverConnection failure to the authentication server: Failed to connect to the authentication serverP. 8-264
      6014Detected the authentication server that cannot be connectedDetected the authentication server that cannot be connected: The authentication server that cannot be accessed is detected.P. 8-264
      6032Illegal period.Card related error: Expired card: The card cannot be used because it has expired.P. 8-264
      6033No entering record.Card related error: Invalid flag data (no room-entry data): The card cannot be used because no room-entry data are recorded in it.P. 8-265
      6034Illegal entering record.Card related error: Invalid flag data (invalid card data): The card cannot be used because the data required for the use of the card are not correctly set.P. 8-265
      6037You cannot be used.No permission flagP. 8-265
      6041Card Authentication Failed because of Card Reading ErrorCard authentication: Card related error: Card data cannot be obtained correctly.P. 8-265
      6042Card Authentication Failed because of Setting ErrorCard authentication: Card setting error: The self-diagnostic code required for card authentication is not set in this equipment correctly.P. 8-265
      6100User account is lockedUser account locking outP. 8-265
      6101Box is lockede-Filing box locking outP. 8-266
      6102Failed to login because the user account had been locked out.User account being locking outP. 8-266
      6103Failed to access Box because the Box had been locked out.e-Filing box being locking outP. 8-266
      6121Failed to Secure EraseAutomatic Secure Erase failureP. 8-266
      6131MFP fail to verify clock with Time ServerClock skew failure to time serverP. 8-266
      6150Print Log full (100% Used) Log OverWrite will be startPrint log DB fullP. 8-266
      6151Print Log near full (95% Used)Print log DB near-full (95%)P. 8-267
      6152Print Log near full (90% Used)Print log DB near-full (90%)P. 8-267
      6153Print Log near full (80% Used)Print log DB near-full (80%)P. 8-267
      6154Print Log near full (70% Used)Print log DB near-full (70%)P. 8-267
      6160Scan Log full (100% Used) Log OverWrite will be startScan log DB fullP. 8-267
      6161Scan Log near full (95% Used)Scan log DB near-full (95%)P. 8-267
      6162Scan Log near full (90% Used)Scan log DB near-full (90%)P. 8-268
      6163Scan Log near full (80% Used)Scan log DB near-full (80%)P. 8-268
      6164Scan Log near full (70% Used)Scan log DB near-full (70%)P. 8-268
      6170FAX_Transmission Log full (100% Used) Log OverWrite will be startedFAX transmission log DB fullP. 8-268
      6171FAX_Transmission Log near full (95% Used)FAX transmission log DB near- full (95%)P. 8-268
      6172FAX_Transmission Log near full (90% Used)FAX transmission log DB near- full (90%)P. 8-268
      6173FAX_Transmission Log near full (80% Used)FAX transmission log DB near- full (80%)P. 8-268
      6174FAX_Transmission Log near full (70% Used)FAX transmission log DB near- full (70%)P. 8-269
      6180FAX_Receive Log full (100% Used) Log OverWrite will be startFAX reception log DB fullP. 8-269
      6181FAX_Receive Log near full (95% Used)FAX reception log DB near-full (95%)P. 8-269
      6182FAX_Receive Log near full (90% Used)FAX reception log DB near-full (90%)P. 8-269
      6183FAX_Receive Log near full (80% Used)FAX reception log DB near-full (80%)P. 8-269
      6184FAX_Receive Log near full (70% Used)FAX reception log DB near-full (70%)P. 8-269
      6190Message Log full (100% Used) Log OverWrite will be startMessage log DB fullP. 8-270
      6191Message Log near full (95% Used)Message log DB near-full (95%)P. 8-270
      6192Message Log near full (90% Used)Message log DB near-full (90%)P. 8-270
      6193Message Log near full (80% Used)Message log DB near-full (80%)P. 8-270
      6194Message Log near full (70% Used)Message log DB near-full (70%)P. 8-270
      8​
    7. Maintenance error​
      7101Failed to update Copier FirmwareSystem firmware installation failureP. 8-271
      7103Failed to update Copier Engine FirmwareEngine firmware installation failureP. 8-271
      7105Failed to update Copier Scanner FirmwareScanner firmware installation failureP. 8-271
      7107Failed to update Copier MEP FirmwareMEP firmware installation failureP. 8-271
      7109Failed to update Printer DriverPrinter driver upload failureP. 8-271
      710BFailed to update Point And PrintPoint and Print data upload failureP. 8-271
      710FFailed to install Language PackFailed to install Language Pack Language Pack installation failureP. 8-271
      7111Failed to install PatchPatch installation failureP. 8-271
      7113Failed to install PluginPlug-in installation failureP. 8-271
      7115Failed to update HDD DataHDD data installation failureP. 8-271
      7117Failed to update Reversing Automatic Document Feeder ROMADF firmware installation failureP. 8-271
      711DFailed to remove License KeyLicense key returning failureP. 8-272
      711FFailed to install License KeyLicense key installation failureP. 8-272
      7121Failed to import Address BookAddress Book data import failureP. 8-272
      7123Failed to import TemplateTemplate data import failureP. 8-272
      7125Failed to import Mail BoxesMailBox data import failureP. 8-272
      7127Failed to import XML Format FileFormat file for Meta Scan import failureP. 8-273
      7129Failed to import User InformationUser Information import failureP. 8-273
      712BFailed to import Role InformationRole information import failureP. 8-273
      712DFailed to import Department CodeDepartment code data import failureP. 8-273
      712FFailed to import ICC ProfileICC Profile import failureP. 8-273
      7131Failed to import Print Data ConverterPrint Data Converter import failureP. 8-273
      7132Failed to import some User InformationUser Information import partial successP. 8-274
      7133Failed to import some User, Role and Group informationUser Combined data import partial successP. 8-274
      7134Failed to import some Department CodeDepartment code data import partial successP. 8-274
      7139Failed to import the certificate by SCEPCertification from SCEP server acquisition failureP. 8-274
      713BFailed to import the certificateCertification import failureP. 8-274
      713DFailed to import Combined data (User Information, Role, Group)User Combined data import failureP. 8-275
      713FFailed to import Combined data (Template, Address Book, Mail Boxes)All data (Template/AddressBook/ MailBox) import failureP. 8-275
      7141Failed to export Address BookAddress Book data export failureP. 8-275
      7143Failed to export TemplateTemplate data export failureP. 8-275
      7145Failed to export Mail BoxesMailBox data export failureP. 8-275
      7147Failed to export XML Format FileFormat file for Meta Scan export failureP. 8-275
      7149Failed to export User InformationUser Information export failureP. 8-276
      714BFailed to export Role InformationRole information export failureP. 8-276
      714DFailed to export Department CodeDepartment code data export failureP. 8-276
      714FFailed to export ICC ProfileICC Profile export failureP. 8-276
      7151Failed to export Log dataLog data export failureP. 8-276
      715BFailed to export Print Data ConverterPrint Data Converter export failureP. 8-276
      715DFailed to export Combined data (User Information, Role, Group)User Combined data export failureP. 8-277
      715FFailed to export Combined data (Template, Address Book, Mail Boxes)All data (Template/AddressBook/ MailBox) export failureP. 8-277
      7191Failed to upload DDNS public key fileDownload of DDNS public key file has failedP. 8-277
      7193Failed to upload DDNS private key fileDownload of DDNS nonpublic key file has failedP. 8-277
      71A2Failed to add CA certificateCA certification addition failureP. 8-277
      71A4Failed in consistency confirmation of cryptographic keyEncryption key consistency confirmation failureP. 8-278
      71A6Failed to delete Device Certificate.Device certification deletion failureP. 8-278
      71A8Failed to delete CA Certificate.CA certification deletion failureP. 8-278
      71AAInvalid Error Occurred while getting Certificate from SCEP serverUnidentified error during certificate acquisition from SCEP serverP. 8-278
      71ABTimeout Error Occurred while getting Certificate from SCEP serverTimeout error during certificate acquisition from SCEP serverP. 8-278
      71ACFile Save Error Occurred while getting Certificate from SCEP serverFile save error during certificate acquisition from SCEP serverP. 8-279
      71ADSCEP operation failure.SCEP operation has failedP. 8-279
      71B0Failed to decrypt Software PackageSoftware package file decryption failureP. 8-279
      71D0Failed to restore Factory Default settingsFactory Default failureP. 8-279
      71F1Failed to create Clone FileClone file creation failureP. 8-279
      71F3Failed to import Clone FileClone data import failureP. 8-280
      71F4Failed to decrypt Clone FileClone file decryption failureP. 8-280
      71F5Failed to encrypt Cone FileClone file encryption failureP. 8-280
      8​
    8. Network error​
      8000Static IPv4 duplicated address detectedIPv4 address overlaps.P. 8-281
      8011Link Local address of IPv6 was duplicated.Linklocal Address ConflictP. 8-281
      8012Manual address of IPv6 was duplicated.Manual IPv6 Address ConflictP. 8-281
      8013Stateless address of IPv6 was duplicated.Stateless Address ConflictP. 8-281
      8014Stateful address of IPv6 was duplicated.Stateful Address ConflictP. 8-281
      8021-Used to delete error message on panel.-
      8022Authentication FailureFailed in 802.1X authentication.P. 8-281
      8023Can not contact Authentication Server/SwitchFailed in connection to authentication server and switch.P. 8-281
      8024Certificate verification FailureFailed in verification of certificate.P. 8-282
      8031No IKE proposal chosenIpsec error for ikev1 certification failedP. 8-282
      8032IKE Certificate Authentication failedIpsec error for wrong proposal chosenP. 8-282
      8033IKE Pre-shared key Authentication failedIpsec error if auth for shared key failedP. 8-282
      8034Invalid CertificateIpsec error if invalid certificate uploadedP. 8-282
      8035Certificate Type unsupportedIpsec error if certificate not supportedP. 8-282
      8036Invalid certificate authorityIpsec error if invalid certificate authenticationP. 8-283
      8037Certificate unavailableIpsec error if certificate are not availableP. 8-283
      8038No ISAKMP SA establishedIpsec error for SA is not presentP. 8-283
      8039Invalid SignatureIpsec error for invalid signature for certificateP. 8-283
      803ANo IKEv2 proposal chosenIpsec error is proposal chosen is wrongP. 8-283
      803BIKEv2 Certificate Authentication failedIpsec error for ikev2 certification failedP. 8-284
      803CIKEv2 Secret key Authentication failedIpsec error for ikev2 if secret key auth failedP. 8-284
      803DFalling Back to IKEv1Ipsec error if peer does not support IKEv2 and falling back to IKEv1P. 8-284
      803EISAKMP SA unusable (deleted)Ipsec error if ISAKMP SA is not created of destroyed due to some uncertain conditionP. 8-284
      803FCrypto operation failedIpsec error for ikev2 if crypto operation failedP. 8-284
      8040Invalid key informationIpsec error for ikev2 if key info is invalidP. 8-285
      8041CA not trustedIpsec error for ikev2 if CA is not trustedP. 8-285
      8042Authentication Method mismatchIpsec error if auth method is not matchingP. 8-285
      8043IKE Version mismatchIpsec error if ike version is not matchingP. 8-285
      8044Encapsulation mode mismatchIpsec error for encapsulation is not matchingP. 8-285
      8045Peer IP Address mismatchIpsec error for peer ip mismatchP. 8-285
      8046Local IP Address mismatchIpsec error for local ip mismatchP. 8-286
      8047Local ID mismatchIpsec error for local id mismatchP. 8-286
      8048Remote ID mismatchIpsec error for remote id mismatchP. 8-286
      8049IPsec Remote IP mismatchIpsec error for remote ip mismatchP. 8-286
      804AIKEv1/IKEv2 Timed outIpsec error for ike timeoutP. 8-286
      804BInvalid manual key dataIpsec error id manual key is not validP. 8-286
      8061Secure Update to Primary IPv4 DDNS failed.Secure primary DDNS update errorP. 8-287
      8062Secure Update to Secondary IPv4 DDNS failedSecure secondary DDNS update errorP. 8-287
      8063Secure Update to Primary IPv6 DDNS failed.Secure primary DDNS update errorP. 8-287
      8064Secure Update to Secondary IPv6 DDNS failedSecure secondary DDNS update errorP. 8-287
      8065IPv6 Update to Primary DDNS failed.IPv6 primary DDNS update errorP. 8-287
      8066IPv6 Update to Secondary DDNS failed.IPv6 secondary DDNS update errorP. 8-287
      8067IPv4 Update to Primary DDNS failed.IPv4 primary DDNS update errorP. 8-287
      8068IPv4 Update to Secondary DDNS failed.IPv4 secondary DDNS update errorP. 8-287
      8069Invalid TSIG/SIG(0) Key file uploadedThis message is displayed when the key file for SIG(0) or TSIG is invalidP. 8-287
      8101Wireless association with Access point failureWireless association with Access point failureP. 8-287
      8102Unable to contact Access pointMFP not able to contact the Access point with the specified SSIDP. 8-287
      8103Certificate verification FailureWireless Certificate verification failureP. 8-288
      8111SNMP set request failureAn error occurred during SNMP data writing.P. 8-288
      8112SNMP communication failureSNMP communication failed.P. 8-288
      8121General failureDomain authentication error: Domain authentication errorP. 8-288
      8122Invalid Username / PasswordDomain authentication error: Invalid user name or passwordP. 8-288
      8123Server not exists on the NetWorkDomain authentication error: Invalid serverP. 8-289
      8124User Account has been DisabledDomain authentication error: Invalid user accountP. 8-289
      8125User Account has been ExpiredDomain authentication error: Expired user accountP. 8-289
      8126User Account has been Locked outDomain authentication error: User account lockoutP. 8-289
      8127Invalid logon hours for User AccountDomain authentication error: Invalid logon hoursP. 8-290
      8128Time delay between Server and MFPActive Directory domain authentication error: Time delay between server and equipmentP. 8-290
      8129Ticket has been ExpiredActive Directory domain authentication error: Expired Kerberos ticketP. 8-290
      812ATicket Verification has been failedActive Directory domain authentication error: Kerberos ticket authentication errorP. 8-290
      812BUnknown RealmActive Directory domain authentication error: invalid realm nameP. 8-290
      8​
      © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507
      ERROR CODE AND TROUBLESHOOTING
    9. Error history​
In the setting mode (08-9703), the latest twenty groups of error data will be displayed.
Display example
EA10999999992013-07-11 17:05:320640642362_1000_0000_0_
XXXXXXXXXX
Error codeTotal counterYYYY-MM-DD HH:MM:SSMMMNNNABCD_EFHI_JLOP_Q
_R
4 digits8 digits14 digits3 digits3 digits23 digits
APaper source
0: Not selected 1: Bypass feed 2: LCF 3: Upper drawer 4: Lower drawer 5: PFP upper drawer
6: PFP lower drawer 7: Unused 8: Unused
BPaper size code
0: A5/ST 1: A5-R 2: ST-R 3: LT 4: A4 5: B5-R 6: LT-R 7: A4-R 8: OTHER/UNIV 9: B5 A: FOLIO/COMP B: LG C: B4 D: LD E: A3 F: 13” LG G: Unused H: A6-R I: Postcard
J: 8.5SQ K: Unused L: Unused M: 8K N: 16K-R O: 16K P: Envelope COM10 Q: Envelope DL R: Envelope Monarch S: Envelope (lengthwise, No. 3) T: Envelope (lengthwise, No. 4) U: Unused V: Unused Z: Not selected
CSort mode/staple mode
0: Non-sort/Non-staple 1: Group 2: Sort 7: Front staple 8: Double staple 9: Rear staple A: Saddle stitch
DADF mode
0: Unused 1: AUTO FEED (SADF) 2: STACK FEED
EAPS/AMS mode
0: Not selected 1: APS 2: AMS
FDuplex mode
Copy:
0: Single-sided/Single-sided 1: Book 2: Double-sided/Single-sided 4: Double-sided/ Duplex copying
8: Single-sided/Duplex copying
Printer
0: Single-sided 8: Double-sided
FAX
e-Filing
List printing
0: Single-sided -
GUnused
HImage shift
0: Unused 1: Book 2: Left 3: Right 4: Top 5: Bottom 6: Book+Top 7: Book+Bottom 8: Left+Top
9: Left+Bottom A: Right+Top B: Right+Bottom
IEditing
0: Unused 1: Masking 2: Trimming 3: Mirror image 4: Positive/negative reverse 5: Unused
JEdge erase/Dual-page
0: Unused 1: Edge erase 2: Dual-page 3: Edge erase & Dual-page
e-STUDIO206L/256/306/356/456/506 / 207L/257/307/357/457/507 © 2011-2014 TOSHIBA TEC CORPORATION All rights reserved ERROR CODE AND TROUBLESHOOTING
KUnused
LFunction
0: Unused 1: Copying 2: FAX/Internet FAX transmission
3: FAX/Internet FAX/E-mail reception printing 4: Unused 5: Printing/List print 6: Scan/E-mail transmission
MMMPrimary scanning reproduction ratio (Display in hexadecimal)
Mx256)+(Mx16)+M
OMode
0: Auto color 1: Full color
6: Unused 7: Unused
2: Black3: Unused4: Unused5: Gray scale
PMedia type
0: Plain paper 1: Thick 1 2: Thick 2 3: Thick 3 4: Thick 4 5: Special paper 1 6: Special
paper 2
7: Recycled paper 8: Plain paper 1 9: Plain paper 2 A: Thin paper B: OHP film C: Thick 1/ reverse D: Thick 2/ reverse E: Thick 3/ reverse F: Thick 4/ reverse G: Special paper 1/ reverse
H: Special paper 2/ reverse I: Envelope J: Tab paper Z: Unused
QRADF size mixed
0: Unused 1: Size mixed 2: Single-size document
RWorkflow ID: 10-digit ID
8​
  1. Diagnosis and Prescription for Each Error Code​
    1. Check item​
      Check itemContents
      Sensor check
      Connector check
      Harness check
      Motor check
      Board check
      • Check the sensor in the test mode.
      • Check that there is no dust on the sensor.
      • Check that the actuator is correctly operated.
      • Check that the connector is not disconnected.
      • Check that the pins are not deformed and do not come off.
      • Disconnect and reconnect the connector.
      • Check if the harnesses are open circuited.
      • Check the motor in the test mode.
      • Check that there is no abnormality in the driving section.
      • Check that there is no abnormality in the roller.
      • Check if the board is short circuited or open circuited.
    2. Paper exit jam​
      8​
      [E010] Leading edge of paper not reaching the exit sensor [E020] Trailing edge of paper not passing the exit sensor
      ClassificationError content
      Paper exit jamJam not reaching the exit sensor Stop jam at the exit sensor
      Proce dureCheck itemResultMeasureNext Step
      1Open the Automatic duplexing unit. Is there any paper on the transport path?YesRemove the paper.
      No2
      2Is the exit sensor working? (Perform the input check in the test mode: 03- [FAX]ON/[9]/)
      [TD]Yes[/TD]
      [TD][/TD]
      [TD]3[/TD]
      [TD]No[/TD]
      [TD][/TD]
      [TD][/TD]
      [TD][/TD]
      [TD][/TD]
      [TD]3[/TD]
      [TD]Is the registration roller clutch working?
      (Perform the output check in the test mode: 03-108/ 158)[/TD]
      [TD]Yes[/TD]
      [TD][/TD]
      [TD]4[/TD]
      [TD]No[/TD]
      [TD][/TD]
      [TD][/TD]
      [TD][/TD]
      [TD][/TD]
      [TD]4[/TD]
      [TD]Registration roller[/TD]
      [TD][/TD]
      [TD][/TD]
      [TD][/TD]
      • Check if the connector of the exit sensor is disconnected.
      • Check if the connector CN309 on the LGC board is disconnected.
      • Check if the connector pins are disconnected and the harnesses are open circuited.
      • Check if the conductor pattern on the LGC board is short circuited or open circuited.
      • Replace the exit sensor
      • Replace the LGC board
      • Check if the connector of the registration roller clutch is disconnected.
      • Check if the connector CN315 on the LGC board is disconnected.
      • Replace the registration roller clutch.
      • Replace the LGC board.
      • Check the registration roller. Replace it if it is worn out.
      Parts to be replacedRemark
      Exit sensor
      LGC board
      Registration roller clutch
      Registration roller
      Paper transport jam​
[E200] Paper fed from the upper drawer not reaching the registration sensor [E210] Paper fed from the lower drawer not reaching the registration sensor [E300] Paper fed from the PFP upper drawer not reaching the registration sensor [E330] Paper fed from the PFP lower drawer not reaching the registration sensor [E3C0] Paper fed from the LCF not reaching the registration sensor
Paper transport jamPaper not reaching the registration sensor
1Open the Automatic duplexing unit. Is there paper in front of the registration sensor?YesRemove the paper.
No2
2Is the registration sensor working?
(Perform the input check in the test mode: 03- [FAX]ON/[9]/[A]
Yes3
No
  • Check if the connector of the registration sensor is disconnected.
  • Check if the connector CN316 on the LGC board is disconnected.
  • Replace the registration sensor.
3Are the (high-speed/low- speed) clutches working? (Perform the output check in the test mode: 03-203, 205)Yes4
No
  • Check if the connectors of the (high-speed/ low-speed) transport clutches are disconnected.
  • Replace the (high-speed/low-speed) transport clutches.
4Feed roller Separation roller Pickup roller Transfer roller
  • Check the condition of the feed roller, separation roller and pickup roller of each paper source, and replace them if they are worn out.
  • Check the transport roller. Replace it if it is worn out.
Registration roller
LGC board
High-speed/low-speed transport clutches
Feed roller
Separation roller
Pickup roller
Transfer roller
8​
[E270] Bypass transport jam (Paper not reaching the registration sensor) [E280] ADU transport jam (Paper not reaching the registration sensor)
Paper transport jamJam not reaching the registration sensor
No2
Yes3
No
3Is the bypass feed clutch/ ADU clutch working? (Perform the output check in the test mode: 03-204/ 222)Yes4
No
  • Check if the connector of the bypass feed clutch/ADU clutch is disconnected.
  • Check if the connector CN311 on the LGC board is disconnected.
  • Replace the bypass feed clutch/ADU clutch.
4Registration roller
Registration sensor.
LGC board
Bypass feed clutch
ADU clutch
Registration roller
[E220] Paper fed from the lower drawer not reaching the 1st transport sensor [E310] Paper fed from the PFP upper drawer not reaching the 1st transport sensor [E340] Paper fed from the PFP lower drawer not reaching the 1st transport sensor [E3D0] Paper fed from the LCF not reaching the 1st transport sensor
Paper transport jamJam not reaching the 1st transport sensor
1Open the Automatic duplexing unit. Is there paper in front of the 1st transport sensor?YesRemove the paper.
No2
2Is the 1st transport sensor working?
(Perform the input check in the test mode: 03- [FAX]OFF/[6]/[A])
Yes3
No
  • Check if the connector of the 1st transport sensor is disconnected.
  • Replace the 1st transport sensor.
3Are the (high-speed/low- speed) transport clutches working?
Yes4
No
LGC board
Feed roller
Separation roller
Pickup roller
Transfer roller
8​
[E320] Paper fed from the PFP upper drawer not reaching the 2nd transport sensor [E350] Paper fed from the PFP lower drawer not reaching the 2nd transport sensor [E3E0] Paper fed from the LCF not reaching the 2nd transport sensor
Paper transport jamJam not reaching the 2nd transport sensor
1Open the side cover. Is there paper in front of the 2nd transport sensor?YesRemove the paper.
No2
2Is the 2nd transport sensor working?
(Perform the input check in the test mode: 03- [FAX]OFF/[7]/[A]
Yes3
No
  • Check if the connector of the 2nd transport sensor is disconnected.
  • Replace the 2nd transport sensor.
3Is the PFP transport clutch working? (Perform the output check in the test mode: 03-225)Yes4
No
  • Check if the connector of the PFP transport clutch is disconnected.
  • Check if any of the connectors CN241 and CN244 on the PFP board is disconnected.
  • Check if the connector CN318 on the LGC board is disconnected.
  • Check if the conductor patterns on the PFP board and LGC board are short circuited or open circuited.
  • Replace the PFP transport clutch.
  • Replace the PFP board.
4Feed roller Separation roller] Pickup roller Transfer roller
LGC board
PFP board
Feed roller
Separation roller
Pickup roller
Transfer roller
[E510] ADU stack jam (paper not reaching the ADU entrance sensor
Paper transport jam (ADU section)Jam not reaching the ADU entrance sensor
1Open the ADU. Is there any paper in front of the ADU entrance sensor?YesRemove the paper.
No2
2Is the ADU entrance sensor working? (Perform the input check in the test mode: 03-[FAX]OFF/[1]/ [D])Yes3
No
  • Check if the connector of the ADU entrance sensor is disconnected.
  • Check if the conductor patterns on the MOT board and LGC board are short circuited or open circuited. (e-STUDIO206L/256/306 / 207L/257/307)
  • Check if the conductor patterns on the MOT2 board and LGC board are short circuited or open circuited.
  • Replace the ADU entrance sensor.
(e-STUDIO356/456/506 / 357/457/507)
3Is the exit motor (rotating in reverse) working? (Perform the output check in the test mode: 03-121/ 171): e-STUDIO206L/256/
306 / 207L/257/307
(Perform the output check in the test mode: 03-124/ 174): e-STUDIO356/456/
506 / e-STUDIO357/457/
507
Yes4
No
  • Check if the connector of the exit motor is disconnected.
  • Check if the connector CN431 on the MOT board is disconnected.
  • Check if the connector CN405 on the MOT2 board is disconnected.
  • Check if the conductor pattern on the LGC board and MOT board is short circuited or open circuited. (e-STUDIO206L/256/306 / 207L/257/307)
  • Check if the conductor pattern on the LGC board and MOT2 board is short circuited or open circuited. (e-STUDIO356/456/506 / 357/457/507)
  • Replace the exit motor.
  • Replace the MOT board. (e-STUDIO206L/ 256/356 / 207L/257/357)
  • Replace the MOT2 board. (e-STUDIO356/ 456/506 / 357/457/507)
4ADU
  • Check the rollers in the ADU and the exit roller of the equipment. Replace them if they are worn out.
ADU entrance sensor
LGC board
Exit motor
ADU exit sensor
Exit board
LGC board
Rollers in the ADU
Exit roller
8​
[E520] ADU transport jam (paper not reaching the ADU exit sensor
Paper transport jam (ADU section)Jam not reaching the ADU exit sensor
1Open the ADU. Is there any paper in front of the ADU exit sensor?YesRemove the paper.
No2
2Is the ADU exit sensor working?
(Perform the input check in the test mode: 03- [FAX]OFF/[1]/[E])
Yes3
No
  • Check if the connector of the ADU exit sensor is disconnected.
  • Check if the conductor patterns on the LGC board are short circuited or open circuited.
  • Replace the ADU exit sensor.
3Is the ADU motor working? (Perform the output check in the test mode: 03-119)Yes4
No
  • Check if the connector of the ADU motor is disconnected.
  • Check if the connector CN402 and CN404 on the MOT/MOT2 board is disconnected.
  • Check if the connector CN303 on the LGC board is disconnected.
  • Replace the MOT/MOT2 board.
4ADU
  • Check the rollers in the ADU. Replace them if they are worn out.
ADU exit sensor
LGC board
ADU exit sensor
MOT board
MOT2 board
Rollers in the ADU
8​
[E570] Jam not reaching the reverse sensor [E580] Stop jam at the reverse sensor
Paper transport jamJam not reaching the reverse sensor Stop jam at the reverse sensor
1Checking of paper
  • Open the ADU and remove paper if there is any on the transport path.
* If the error still occurs, check the following:
2Is the reverse sensor working? (Perform the input check in the test mode: 03-[FAX]ON/[9]/[C])Yes3
No
  • Check if the connector pins are disconnected or the harnesses are open circuited between the reverse sensor and the connector CN304 on the LGC board. Correct if there is any abnormality.
  • Replace the reverse sensor.
3Is the reverse motor working? (Perform the output check in the test mode: 03-123/173)YesCheck the exit roller. Replace it if it is worn out.
No
  • Check if the connector pins are disconnected or the harnesses are open circuited between the reverse motor and the connector CN304 on the LGC board (and also the connectors CN401 and CN406 on the MOT2 board). Correct if there is any abnormality.
  • Replace the reverse motor.
Reverse sensor
LGC board
Exit roller
Reverse motor
MOT2 board
