806x 13 | Perfect-Bind | Perfect Binder Not Used |
806x 14 | Ring-Bind | Ring Binder Not Used |
8071 | T:Jobs/PGS | [0 to 9999999 / 0 / 1] | |
These SPs count the number of jobs broken down by the number of pages in the job, regardless of which application was used. | |||
8072 | C:Jobs/PGS | [0 to 9999999 / 0 / 1] | |
These SPs count and calculate the number of copy jobs by size based on the number of pages in the job. | |||
8073 | F:Jobs/PGS | [0 to 9999999 / 0 / 1] | |
These SPs count and calculate the number of fax jobs by size based on the number of pages in the job. | |||
8074 | P:Jobs/PGS | [0 to 9999999 / 0 / 1] | |
These SPs count and calculate the number of print jobs by size based on the number of pages in the job. | |||
8075 | S:Jobs/PGS | [0 to 9999999 / 0 / 1] | |
These SPs count and calculate the number of scan jobs by size based on the number of pages in the job. | |||
8076 | L:Jobs/PGS | [0 to 9999999 / 0 / 1] | |
These SPs count and calculate the number of jobs printed from within the document server mode window at the operation panel, by the number of pages in the job. | |||
8077 | O:Jobs/PGS | [0 to 9999999 / 0 / 1] | |
These SPs count and calculate the number of "Other" application jobs (Web Image Monitor, Palm 2, etc.) by size based on the number of pages in the job. | |||
807x 1 | 1 Page | 807x 8 | 21 to 50 Pages |
807x 2 | 2 Pages | 807x 9 | 51 to 100 Pages |
807x 3 | 3 Pages | 807x 10 | 101 to 300 Pages |
807x 4 | 4 Pages | 807x 11 | 301 to 500 Pages |
807x 5 | 5 Pages | 807x 12 | 501 to 700 Pages |
807x 6 | 6 to 10 Pages | 807x 13 | 701 to 1000 Pages |
807x 7 | 11 to 20 Pages | 807x 14 | 1001 to Pages |
- For example: When a copy job stored on the document server is printed in document server mode, the appropriate L: counter (SP8076 0xx) increments.
- Printing a fax report counts as a job and increments the F: counter (SP 8073).
- Interrupted jobs (paper jam, etc.) are counted, even though they do not finish.
- If a job is paused and re-started, it counts as one job.
- If the finisher runs out of staples during a print and staple job, then the job is counted at the time the error occurs.
- For copy jobs (SP 8072) and scan jobs (SP 8075), the total is calculated by multiplying the number of sets of copies by the number of pages scanned. (One duplex page counts as 2.)
- The first test print and subsequent test prints to adjust settings are added to the number of pages of the copy job (SP 8072).
Service Tables
- When printing the first page of a job from within the document server screen, the page is counted.
8111T:FAX TX Jobs [0 to 9999999 / 0 / 1] These SPs count the total number of jobs (color or black-and-white) sent by fax, either directly or using a file stored on the document server, on a telephone line.
Note: Color fax sending is not available at this time.001 B/W Black TX
8113F:FAX TX Jobs [0 to 9999999 / 0 / 1] These SPs count the total number of jobs (color or black-and-white) sent by fax directly on a telephone line.
Note: Color fax sending is not available at this time.001 B/W Black TX - These counters count jobs, not pages.
- This SP counts fax jobs sent over a telephone line with a fax application, including documents stored on the document server.
- If the mode is changed during the job, the job will count with the mode set when the job started.
- If the same document is faxed to both a public fax line and an I-Fax at a destination where both are available, then this counter increments, and the I-Fax counter (812x) also increments.
- The fax job is counted when the job is scanned for sending, not when the job is sent.
8121T:IFAX TX Jobs [0 to 9999999 / 0 / 1] These SPs count the total number of jobs (color or black-and-white) sent, either directly or using a file stored on the document server, as fax images using I-Fax.
8123F:IFAX TX Jobs [0 to 9999999 / 0 / 1] These SPs count the number of jobs (color or black-and-white) sent (not stored on the document server), as fax images using I-Fax.
- The counters for color are provided for future use; the color fax feature is not available at this time.
8131T:S-to-Email Jobs [0 to 9999999 / 0 / 1] These SPs count the total number of jobs scanned and attached to an e-mail, regardless of whether the document server was used or not. 001 B/W Black TX 002 Color Color TX 003 ACS Color TX
8135S:S-to-Email Jobs These SPs count the number of jobs scanned and attached to an e-mail, without storing the original on the document server. 001 B/W Black TX 002 Color Color TX 003 ACS Color TX
Service Tables
- If the job is stored on the document server, after the job is stored it is determined to be color or black-and-white then counted.
- If the job is cancelled during scanning, or if the job is cancelled while the document is waiting to be sent, the job is not counted.
- If the job is cancelled during sending, it may or may not be counted, depending on what stage of the process had been reached when the job was cancelled.
- If several jobs are combined for sending to the Scan Router, Scan-to-Email, or Scan-to-PC, or if one job is sent to more than one destination. each send is counted separately. For example, if the same document is sent by Scan-to-Email as well as Scan-to-PC, then it is counted twice (once for Scan-to-Email and once for Scan-to-PC).
8141T eliv Jobs/Svr
[0 to 9999999 / 0 / 1] These SPs count the total number of jobs scanned and sent to a Scan Router server. 001 B/W Black Deliv 002 Color Color Deliv 003 ACS Color Deliv
8145S eliv Jobs/Svr
These SPs count the number of jobs scanned and sent to a Scan Router server. 001 B/W Black Deliv 002 Color Color Deliv 003 ACS Color Deliv
- The jobs are counted even though the arrival and reception of the jobs at the Scan Router server cannot be confirmed.
- If even one color image is mixed with black-and-white images, then the job is counted as a "Color" job.
- If the job is cancelled during scanning, or if the job is cancelled while the document is waiting to be delivered, the job is not counted.
- Even if several files are combined for sending, the transmission counts as one job.
8151T eliv Jobs/PC
[0 to 9999999 / 0 / 1] These SPs count the total number of jobs scanned and sent to a folder on a PC (Scan-to-PC).
Note: At the present time, 8151 and 8155 perform identical counts.001 B/W Black Deliv 002 Color Color Deliv 003 ACS Color Deliv
8155S eliv Jobs/PC
These SPs count the total number of jobs scanned and sent with Scan-to-PC. 001 B/W Black Deliv 002 Color Color Deliv 003 ACS Color Deliv
Service Tables
- If the job is cancelled during scanning, it is not counted.
- If the job is cancelled while it is waiting to be sent, the job is not counted.
8161 T CFAX TX Jobs
These SPs count the number of PC Fax transmission jobs. A job is counted from when it is registered for sending, not when it is sent.
Note: At the present time, these counters perform identical counts.
8163
FCFAX TX Jobs
- This counts fax jobs started from a PC using a PC fax application, and sending the data out to the destination from the PC through the copier.
8171 T eliv Jobs/WSD
These SPs count the pages scanned by WSD. [0 to 9999999 / 0 / 1]8175 S eliv Jobs/WSD
8181 T:Scan to Media Jobs These SPs count the pages scanned to media by the scanner application.
8185
S:Scan to Media Jobs001 B/W Black Deliv 002 Color Color Deliv 003 ACS Color Deliv
8191 T:Total Scan PGS
These SPs count the pages scanned by each application that uses the scanner to scan images. [0 to 9999999 / 0 / 1]8192 C:Total Scan PGS 8193 F:Total Scan PGS 8195 S:Total Scan PGS 8196 L:Total Scan PGS
- SP 8191 to 8196 count the number of scanned sides of pages, not the number of physical pages.
- These counters do not count reading user stamp data, or reading color charts to adjust color.
- Previews done with a scanner driver are not counted.
- A count is done only after all images of a job have been scanned.
- Scans made in SP mode are not counted.
Examples
- If 3 B5 pages and 1 A3 page are scanned with the scanner application but not stored, the S: count is 4.
Service Tables
- If both sides of 3 A4 sheets are copied and stored to the document server using the Store File button in the Copy mode window, the C: count is 6 and the L: count is 6.
- If both sides of 3 A4 sheets are copied but not stored, the C: count is 6.
- If you enter document server mode then scan 6 pages, the L: count is 6.
8201 T:LSize Scan PGS [0 to 9999999 / 0 / 1] 8203 F Lsize Scan PGS [0 to 9999999 / 0 / 1]
8205S:LSize Scan PGS [0 to 9999999 / 0 / 1] These SP codes count the total number of large pages input with the scanner for scan jobs only. Large size paper (A3/DLT) scanned for fax transmission are not counted.
Note: These counters are displayed in the SMC Report, and in the User Tools display..
8211 T:Scan PGS/LS These SPs count the number of pages scanned into the document server .
The L: counter counts the number of pages stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen8212 C:Scan PGS/LS 8213 F:Scan PGS/LS 8215 S:Scan PGS/LS 8216 L:Scan PGS/LS
- Reading user stamp data is not counted.
- If a job is cancelled, the pages output as far as the cancellation are counted.
- If the scanner application scans and stores 3 B5 sheets and 1 A4 sheet, the S: count is 4.
- If pages are copied but not stored on the document server, these counters do not change.
- If both sides of 3 A4 sheets are copied and stored to the document server, the C: count is 6 and the L: count is 6.
8221ADF Org Feeds [0 to 9999999 / 0 / 1] These SPs count the number of pages fed through the ADF for front and back side scanning.
FrontNumber of front sides fed for scanning:
With an ADF that can scan both sides simultaneously, the Front side count is the same as the number of pages fed for either simplex or duplex scanning.
With an ADF that cannot scan both sides simultaneously, the Front side count is the same as the number of pages fed for duplex front side scanning. (The front side is determined by which side the user loads face up.)
BackNumber of rear sides fed for scanning:
With an ADF that can scan both sides simultaneously, the Back count is the same as the number of pages fed for duplex scanning.
With an ADF that cannot scan both sides simultaneously, the Back count is the same as the number of pages fed for duplex rear-side scanning. - When 1 sheet is fed for duplex scanning the Front count is 1 and the Back count is 1.
- If a jam occurs during the job, recovery processing is not counted to avoid double counting. Also, the pages are not counted if the jam occurs before the first sheet is output.
8231Scan PGS/Mode [0 to 9999999 / 0 / 1] These SPs count the number of pages scanned by each ADF mode to determine the work load on the ADF.
Large VolumeSelectable. Large copy jobs that cannot be loaded in the ADF at one time.
SADFSelectable. Feeding pages one by one through the ADF.
Mixed SizeSelectable. Select "Mixed Sizes" on the operation panel. 004 Custom Size Selectable. Originals of non-standard size.
PlatenBook mode. Raising the ADF and placing the original directly on the platen.
Mixed 1side/2sideSelectable. Select "Simplex/Duplex" on the operation panel.
Service Tables
- If the scan mode is changed during the job, for example, if the user switches from ADF to Platen mode, the count is done for the last selected mode.
- The user cannot select mixed sizes or non-standard sizes with the fax application so if the original's page sizes are mixed or non-standard, these are not counted.
- If the user selects "Mixed Sizes" for copying in the platen mode, the Mixed Size count is enabled.
- In the SADF mode if the user copies 1 page in platen mode and then copies 2 pages with SADF, the Platen count is 1 and the SADF count is 3.
8241T:Scan PGS/Org [0 to 9999999 / 0 / 1] These SPs count the total number of scanned pages by original type for all jobs, regardless of which application was used. 8242 C:Scan PGS/Org [0 to 9999999 / 0 / 1] These SPs count the number of pages scanned by original type for Copy jobs.
8243F:Scan PGS/Org [0 to 9999999 / 0 / 1] These SPs count the number of pages scanned by original type for Fax jobs.
8245S:Scan PGS/Org [0 to 9999999 / 0 / 1] These SPs count the number of pages scanned by original type for Scan jobs.
8246L:Scan PGS/Org [0 to 9999999 / 0 / 1] These SPs count the number of pages scanned and stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen 8241 8242 8243 8245 8246 824x 1: Text Yes Yes Yes Yes Yes 824x 2: Text/Photo Yes Yes Yes Yes Yes 824x 3: Photo Yes Yes Yes Yes Yes 824x 4: GenCopy, Pale Yes Yes No Yes Yes 824x 5: Map Yes Yes No No Yes 824x 6: Normal/Detail Yes No Yes No No 824x 7: Fine/Super Fine Yes No Yes No No 824x 8: Binary Yes No No Yes No 824x 9: Grayscale Yes No No Yes No 824x 10: Color Yes No No Yes No 824x 11: Other Yes Yes Yes Yes Yes
8251 T:Scan PGS/ImgEdt These SPs show how many times Image Edit features have been selected at the operation panel 8252 C:Scan PGS/ImgEdt for each application. Some examples of these 8255 S:Scan PGS/ImgEdt editing features are: Erase> Border 8256 L:Scan PGS/ImgEdt Erase> Center
8257
O:Scan PGS/ImgEdtImage Repeat Centering Positive/Negative [0 to 9999999 / 0 / 1] Note: The count totals the number of times the edit features have been used. A detailed breakdown of exactly which features have been used is not given.
Service Tables
The L: counter counts the number of pages stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen.
8281 T:Scan PGS/TWAIN These SPs count the number of pages scanned using a TWAIN driver. These counters reveal how the TWAIN driver is used for delivery functions.
8285
S:Scan PGS/TWAIN
8291 T:Scan PGS/Stamp These SPs count the number of pages stamped with the stamp in the ADF unit.
The L: counter counts the number of pages stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen8293 F:Scan PGS/Stamp
8295
S:Scan PGS/Stamp
8301T:Scan PGS/Size [0 to 9999999 / 0 / 1] These SPs count by size the total number of pages scanned by all applications. Use these totals to compare original page size (scanning) and output (printing) page size [SP 8-441].
8302C:Scan PGS/Size [0 to 9999999 / 0 / 1] These SPs count by size the total number of pages scanned by the Copy application. Use these totals to compare original page size (scanning) and output (printing) page size [SP 8-442].
8303F:Scan PGS/Size [0 to 9999999 / 0 / 1] These SPs count by size the total number of pages scanned by the Fax application. Use these totals to compare original page size (scanning) and output page size [SP 8-443].
8305S:Scan PGS/Size [0 to 9999999 / 0 / 1] These SPs count by size the total number of pages scanned by the Scan application. Use these totals to compare original page size (scanning) and output page size [SP 8-445].
8306L:Scan PGS/Size [0 to 9999999 / 0 / 1] These SPs count by size the total number of pages scanned and stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen. Use these totals to compare original page size (scanning) and output page size [SP 8-446]. 830x 1 A3 830x 2 A4 830x 3 A5 830x 4 B4 830x 5 B5 830x 6 DLT 830x 7 LG 830x 8 LT 830x 9 HLT 830x 10 Full Bleed 830x 254 Other (Standard) 830x 255 Other (Custom)
8311T:Scan PGS/Rez [0 to 9999999 / 0 / 1] These SPs count by resolution setting the total number of pages scanned by applications that can specify resolution settings.
8315S:Scan PGS/Rez [0 to 9999999 / 0 / 1] These SPs count by resolution setting the total number of pages scanned by applications that can specify resolution settings.
Note: At the present time, 8311 and 8315 perform identical counts.831x 1 1200dpi to 831x 2 600dpito1199dpi 831x 3 400dpito599dpi 831x 4 200dpito399dpi 831x 5 to199dpi
Service Tables
- Copy resolution settings are fixed so they are not counted.
- The Fax application does not allow finely-adjusted resolution settings so no count is done for the Fax application.
8381 T:Total PrtPGS
These SPs count the number of pages printed by the customer. The counter for the application used for storing the pages increments.
The L: counter counts the number of pages stored from within the document server mode screen at the operation panel. Pages stored with the Store File button from within the Copy mode screen go to the C: counter.8382 C:Total PrtPGS 8383 F:Total PrtPGS 8384 P:Total PrtPGS 8385 S:Total PrtPGS 8386 L:Total PrtPGS 8387 O:Total PrtPGS
- When the A3/DLT double count function is switched on with SP5104, 1 A3/DLT page is counted as 2.
- When several documents are merged for a print job, the number of pages stored are counted for the application that stored them.
- These counters are used primarily to calculate charges on use of the machine, so the following pages are not counted as printed pages:
Blank pages in a duplex printing job.
Blank pages inserted as document covers, chapter title sheets, and slip sheets. Reports printed to confirm counts.
All reports done in the service mode (service summaries, engine maintenance reports, etc.) Test prints for machine image adjustment.
Error notification reports.
Partially printed pages as the result of a copier jam.
8391LSize PrtPGS [0 to 9999999 / 0 / 1] These SPs count pages printed on paper sizes A3/DLT and larger.
Note: In addition to being displayed in the SMC Report, these counters are also displayed in the User Tools display on the copy machine.
8401 T rtPGS/LS
These SPs count the number of pages printed from the document server. The counter for the application used to print the pages is incremented.
The L: counter counts the number of jobs stored from within the document server mode screen at the operation panel.
[0 to 9999999 / 0 / 1]8402 C rtPGS/LS
8403 F rtPGS/LS
8404 P rtPGS/LS
8405 S rtPGS/LS
8406 L rtPGS/LS
- Print jobs done with Web Image Monitor and Desk Top Binder are added to the L: count.
Service Tables
- Fax jobs done with Web Image Monitor and Desk Top Binder are added to the F: count.
8411
Prints/DuplexThis SP counts the amount of paper (front/back counted as 1 page) used for duplex printing. Last pages printed only on one side are not counted.
8421T rtPGS/Dup Comb
[0 to 9999999 / 0 / 1] These SPs count by binding and combine, and n-Up settings the number of pages processed for printing. This is the total for all applications.
8422C rtPGS/Dup Comb
[0 to 9999999 / 0 / 1] These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by the copier application.
8423F rtPGS/Dup Comb
[0 to 9999999 / 0 / 1] These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by the fax application.
8424P rtPGS/Dup Comb
[0 to 9999999 / 0 / 1] These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by the printer application. 8425 S rtPGS/Dup Comb
[0 to 9999999 / 0 / 1] These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by the scanner application.
8426L rtPGS/Dup Comb
[0 to 9999999 / 0 / 1] These SPs count by binding and combine, and n-Up settings the number of pages processed for printing from within the document server mode window at the operation panel.
8427O rtPGS/Dup Comb
[0 to 9999999 / 0 / 1] These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by Other applications 842x 1 Simplex> Duplex 842x 2 Duplex> Duplex 842x 3 Book> Duplex 842x 4 Simplex Combine 842x 5 Duplex Combine 842x 6 2in1 2 pages on 1 side (2-Up) 842x 7 4in1 4 pages on 1 side (4-Up) 842x 8 6in1 6 pages on 1 side (6-Up) 842x 9 8in1 8pages on 1 side (8-Up) 842x 10 9in1 9 pages on 1 side (9-Up) 842x 11 16in1 16 pages on 1 side (16-Up) 842x 12 Booklet 842x 13 Magazine 842x 14 2in1 + Booklet 842x 15 4in1 + Booklet 842x 16 6in1 + Booklet 842x 17 8in1 + Booklet 842x 18 9in1 + Booklet 842x 19 2in1 + Magazine 842x 20 4in1 + Magazine 842x 21 6in1 + Magazine 842x 22 8in1 + Magazine 842x 23 9in1 + Magazine 842x 24 16in1 + Magazine
- These counts (SP8421 to SP8427) are especially useful for customers who need to improve their compliance with ISO standards for the reduction of paper consumption.
- Pages that are only partially printed with the n-Up functions are counted as 1 page.
Service Tables
- Here is a summary of how the counters work for Booklet and Magazine modes:
Booklet Magazine Original Pages Count Original Pages Count 1 1 1 1 2 2 2 2 3 2 3 2 4 2 4 2 5 3 5 4 6 4 6 4 7 4 7 4 8 4 8 4
8431T rtPGS/ImgEdt
[0 to 9999999 / 0 / 1] These SPs count the total number of pages output with the three features below, regardless of which application was used.
8432C rtPGS/ImgEdt
[0 to 9999999 / 0 / 1] These SPs count the total number of pages output with the three features below with the copy application.
8434P rtPGS/ImgEdt
[0 to 9999999 / 0 / 1] These SPs count the total number of pages output with the three features below with the print application.
8436L rtPGS/ImgEdt
[0 to 9999999 / 0 / 1] These SPs count the total number of pages output from within the document server mode window at the operation panel with the three features below.
8437O rtPGS/ImgEdt
[0 to 9999999 / 0 / 1] These SPs count the total number of pages output with the three features below with Other applications.
843x 1
Cover/Slip SheetTotal number of covers or slip sheets inserted. The count for a cover printed on both sides counts 2.
843x 2
Series/BookThe number of pages printed in series (one side) or printed as a book with booklet right/left pagination.
843x 3
User StampThe number of pages printed where stamps were applied, including page numbering and date stamping.
8441T rtPGS/Ppr Size
[0 to 9999999 / 0 / 1] These SPs count by print paper size the number of pages printed by all applications. 8442 C rtPGS/Ppr Size
[0 to 9999999 / 0 / 1] These SPs count by print paper size the number of pages printed by the copy application.
8443F rtPGS/Ppr Size
[0 to 9999999 / 0 / 1] These SPs count by print paper size the number of pages printed by the fax application.
8444P rtPGS/Ppr Size
[0 to 9999999 / 0 / 1] These SPs count by print paper size the number of pages printed by the printer application.
8445S rtPGS/Ppr Size
[0 to 9999999 / 0 / 1] These SPs count by print paper size the number of pages printed by the scanner application.
8446L rtPGS/Ppr Size
[0 to 9999999 / 0 / 1] These SPs count by print paper size the number of pages printed from within the document server mode window at the operation panel.
8447O rtPGS/Ppr Size
[0 to 9999999 / 0 / 1] These SPs count by print paper size the number of pages printed by Other applications. 844x 1 A3 844x 2 A4 844x 3 A5 844x 4 B4 844x 5 B5 844x 6 DLT 844x 7 LG 844x 8 LT 844x 9 HLT 844x 10 Full Bleed
844x 254 Other (Standard) 844x 255 Other (Custom)
- These counters do not distinguish between LEF and SEF.
8451PrtPGS/Ppr Tray [0 to 9999999 / 0 / 1] These SPs count the number of sheets fed from each paper feed station. 001 Bypass Tray Bypass Tray 002 Tray 1 Copier 003 Tray 2 Copier 004 Tray 3 Paper Tray Unit (Option) 005 Tray 4 Paper Tray Unit (Option) 006 Tray 5 LCT (Option) 007 Tray 6 Currently not used. 008 Tray 7 Currently not used. 009 Tray 8 Currently not used. 010 Tray 9 Currently not used. 011 Tray 10 Currently not used. 012 Tray 11 Currently not used. 013 Tray 12 Currently not used. 014 Tray 13 Currently not used. 015 Tray 14 Currently not used. 016 Tray 15 Currently not used.
8461T rtPGS/Ppr Type
[0 to 9999999 / 0 / 1] These SPs count by paper type the number pages printed by all applications.
These counters are not the same as the PM counter. The PM counter is based on feed timing to accurately measure the service life of the feed rollers. However, these counts are based on output timing.
Blank sheets (covers, chapter covers, slip sheets) are also counted. During duplex printing, pages printed on both sides count as 1, and a page printed on one side counts as 1.
8462C rtPGS/Ppr Type
[0 to 9999999 / 0 / 1] These SPs count by paper type the number pages printed by the copy application.
8463F rtPGS/Ppr Type
[0 to 9999999 / 0 / 1] These SPs count by paper type the number pages printed by the fax application.
8464P rtPGS/Ppr Type
[0 to 9999999 / 0 / 1] These SPs count by paper type the number pages printed by the printer application.
8466L rtPGS/Ppr Type
[0 to 9999999 / 0 / 1] These SPs count by paper type the number pages printed from within the document server mode window at the operation panel. 846x 1 Normal 846x 2 Recycled 846x 3 Special 846x 4 Thick 846x 5 Normal (Back) 846x 6 Thick (Back) 846x 7 OHP 846x 8 Other
8471PrtPGS/Mag [0 to 9999999 / 0 / 1] These SPs count by magnification rate the number of pages printed. 001 to 49% 002 50% to 99% 003 100% 004 101% to 200% 005 201% to
- Counts are done for magnification adjusted for pages, not only on the operation panel but performed remotely with an external network application capable of performing magnification adjustment as well.
- Magnification adjustments done with printer drivers with PC applications such as Excel are also counted.
- Magnification adjustments done for adjustments after they have been stored on the document server are not counted.
- Magnification adjustments performed automatically during Auto Reduce/Enlarge copying are counted.
- The magnification rates of blank cover sheets, slip sheets, etc. are automatically assigned a rate of 100%.
8481 T rtPGS/TonSave
8484 P rtPGS/TonSave
These SPs count the number of pages printed with the Toner Save feature switched on.
Note: These SPs return the same results as this SP is limited to the Print application.
8511T rtPGS/Emul
[0 to 9999999 / 0 / 1] These SPs count by printer emulation mode the total number of pages printed.
8514P rtPGS/Emul
[0 to 9999999 / 0 / 1] These SPs count by printer emulation mode the total number of pages printed. 001 RPCS 002 RPDL 003 PS3 004 R98 005 R16 006 GL/GL2 007 R55 008 RTIFF 009 PDF 010 PCL5e/5c 011 PCL XL 012 IPDL-C 013 BM-Links Japan Only 014 Other 015 IPDS
Service Tables
- SP8511 and SP8514 return the same results as they are both limited to the Print application.
- Print jobs output to the document server are not counted.
8521T rtPGS/FIN
[0 to 9999999 / 0 / 1] These SPs count by finishing mode the total number of pages printed by all applications.
8522C rtPGS/FIN
[0 to 9999999 / 0 / 1] These SPs count by finishing mode the total number of pages printed by the Copy application.
8523F rtPGS/FIN
[0 to 9999999 / 0 / 1] These SPs count by finishing mode the total number of pages printed by the Fax application.
Note:
Print finishing options for received faxes are currently not available.
8524P rtPGS/FIN
[0 to 9999999 / 0 / 1] These SPs count by finishing mode the total number of pages printed by the Print application.
8525S rtPGS/FIN
[0 to 9999999 / 0 / 1] These SPs count by finishing mode the total number of pages printed by the Scanner application.
8526L rtPGS/FIN
[0 to 9999999 / 0 / 1] These SPs count by finishing mode the total number of pages printed from within the document server mode window at the operation panel. 852x 1 Sort 852x 2 Stack 852x 3 Staple 852x 4 Booklet 852x 5 Z-Fold 852x 6 Punch 852x 7 Other 852x 8 Inside-Fold 852x 9 Three-IN-Fold 852x 10 Three-OUT-Fold 852x 11 Four-Fold 852x 12 KANNON-Fold 852x 13 Perfect-Bind 852x 14 Ring-Bind
- If stapling is selected for finishing and the stack is too large for stapling, the unstapled pages are still counted.
Service Tables
- The counts for staple finishing are based on output to the staple tray, so jam recoveries are counted.
8531
StaplesThis SP counts the amount of staples used by the machine.
8551 T rtBooks/FIN
8552 C rtBooks/FIN
8554 P rtBooks/FIN
8556 L rtBooks/FIN
001 Perfect-Bind Not Used 002 Ring-Bind Not Used
8561 T:A Sheet Of Paper [0 to 9999999 / 0 / 1] 8562 C:A Sheet Of Paper [0 to 9999999 / 0 / 1] 8563 F:A Sheet Of Paper [0 to 9999999 / 0 / 1] 8564 P:A Sheet Of Paper [0 to 9999999 / 0 / 1] 8566 L:A Sheet Of Paper [0 to 9999999 / 0 / 1]
8567O:A Sheet Of Paper [0 to 9999999 / 0 / 1] These SPs count the totals number of duplex pages printed. 001 Total: Over A3/DLT 002 Total: Under A3/DLT 003 Duplex: Over A3/DLT 004 Duplex: Under A3/DLT
8581T: Counter [0 to 9999999 / 0 / 1] These SPs count the total output broken down by color output, regardless of the application used. In addition to being displayed in the SMC Report, these counters are also displayed in the User Tools display on the copy machine.
Note: This SP is expanded for color MFP and color LP machines. For this machine, the count is done for black only.
8591O: Counter [0 to 9999999 / 0 / 1] These SPs count the totals for A3/DLT paper use, number of duplex pages printed, and the number of staples used. These totals are for Other (O applications only.
001 A3/DLT 002 Duplex
8601T:Coverage Counter These SPs count the total coverage for each color and printout pages. 001 B/W [0 to 2147483647 / 0 / 1] 011 B/W Printing Pages [0 to 9999999 / 0 / 1]
8602C:Coverage Counter [0 to 2147483647 / 0 / 1] These SPs count the total coverage for B/W.
8603F:Coverage Counter [0 to 2147483647 / 0 / 1] These SPs count the total coverage for B/W.
8604P:Coverage Counter [0 to 2147483647 / 0 / 1] These SPs count the total coverage for B/W.
8606L:Coverage Counter [0 to 2147483647 / 0 / 1] These SPs count the total coverage for B/W.
8617SDK Apli Counter [0 to 9999999 / 0 / 1] These SPs count the total printout pages for each SDK applicaion. 001 SDK-1 002 SDK-2 003 SDK-3 004 SDK-4 005 SDK-5 006 SDK-6
8631T:FAX TX PGS [0 to 9999999 / 0 / 1] These SPs count by color mode the number of pages sent by fax to a telephone number. 001 B/W Black TX
8633F:FAX TX PGS [0 to 999999 / 0 / 1] These SPs count by color mode the number of pages sent by fax to a telephone number. 001 B/W Black TX
- If a document has color and black-and-white pages mixed, the pages are counted separately as B/W or Color.
- At the present time, this feature is provided for the Fax application only so SP8631 and SP8633 are the same.
- The counts include error pages.
- If a document is sent to more than one destination with a Group transmission, the count is done for each destination.
- Polling transmissions are counted but polling RX are not.
- Relay, memory, and confidential mailbox transmissions and are counted for each destination.
8641T:FAX TX PGS [0 to 9999999 / 0 / 1] These SPs count by color mode the number of pages sent by fax to as fax images using I-Fax. 001 B/W Black TX
8643F:FAX TX PGS [0 o 9999999 / 0 / 1] These SPs count by color mode the number of pages sent by Fax as fax images using I-Fax. 001 B/W Black TX
- At the present time, this feature is provided for the Fax application only so SP8641 and SP8643 are the same.
Service Tables
8651T:S-to-Email PGS [0 to 9999999 / 0 / 1] These SPs count by color mode the total number of pages attached to an e-mail for both the Scan and document server applications. 001 B/W 002 Color
8655S:S-to-Email PGS [0 to 9999999 / 0 / 1] These SPs count by color mode the total number of pages attached to an e-mail for the Scan application only. 001 B/W 002 Color
- The count for B/W and Color pages is done after the document is stored on the HDD. If the job is cancelled before it is stored, the pages are not counted.
- If Scan-to-Email is used to send a 10-page document to 5 addresses, the count is 10 (the pages are sent to the same SMTP server together).
- If Scan-to-PC is used to send a 10-page document to 5 folders, the count is 50 (the document is sent to each destination of the SMB/FTP server).
- Due to restrictions on some devices, if Scan-to-Email is used to send a 10-page document to a large number of destinations, the count may be divided and counted separately. For example, if a 10-page document is sent to 200 addresses, the count is 10 for the first 100 destinations and the count is also 10 for the second 100 destinations, for a total of 20).
8661T eliv PGS/Svr
[0 to 9999999 / 0 / 1] These SPs count by color mode the total number of pages sent to a Scan Router server by both Scan and LS applications. 001 B/W 002 Color
8665S eliv PGS/Svr
[0 to 9999999 / 0 / 1] These SPs count by color mode the total number of pages sent to a Scan Router server by the Scan application. 001 B/W 002 Color
- The B/W and Color counts are done after the document is stored on the HDD of the Scan Router server.
Service Tables
- If the job is canceled before storage on the Scan Router server finishes, the counts are not done.
- The count is executed even if regardless of confirmation of the arrival at the Scan Router server.
8671T: Deliv PGS/PC [0 to 9999999 / 0 / 1] These SPs count by color mode the total number of pages sent to a folder on a PC (Scan-to-PC) with the Scan and LS applications. 001 B/W 002 Color
8675S: Deliv PGS/PC [0 to 9999999 / 0 / 1] These SPs count by color mode the total number of pages sent with Scan-to-PC with the Scan application. 001 B/W 002 Color
8681 T CFAX TXPGS
These SPs count the number of pages sent by PC Fax. These SPs are provided for the Fax application only, so the counts for SP8681 and SP8683 are the same.
8683
FCFAX TXPGS
- This counts pages sent from a PC using a PC fax application, from the PC through the copier to the destination.
- When sending the same message to more than one place using broadcasting, the pages are only counted once. (For example, a 10-page fax is sent to location A and location B. The counter goes up by 10, not 20.)
8691 T:TX PGS/LS
These SPs count the number of pages sent from the document server. The counter for the application that was used to store the pages is incremented.
The L: counter counts the number of pages stored from within the document server mode screen at the operation panel. Pages stored with the Store File button from within the Copy mode screen go to the C: counter.8692 C:TX PGS/LS 8693 F:TX PGS/LS 8694 P:TX PGS/LS 8695 S:TX PGS/LS 8696 L:TX PGS/LS
- Print jobs done with Web Image Monitor and Desk Top Binder are added to the count.
- If several documents are merged for sending, the number of pages stored are counted for the application that stored them.
- When several documents are sent by a Fax broadcast, the F: count is done for the number of pages sent to each destination.
8701 | TX PGS/Port | [0 to 9999999 / 0 / 1] |
These SPs count the number of pages sent by the physical port used to send them. For example, if a 3-page original is sent to 4 destinations via ISDN G4, the count for ISDN (G3, G4) is 12. | ||
001 | PSTN-1 | |
002 | PSTN-2 | |
003 | PSTN-3 | |
004 | ISDN (G3,G4) | |
005 | Network |
8711 | T:Scan PGS/Comp | [0 to 9999999 / 0 / 1] |
These SPs count the number of compressed pages scanned into the document server, counted by the formats listed below. | ||
001 | JPEG/JPEG2000 | |
002 | TIFF (Multi/Single) | |
003 | ||
004 | Other | |
005 | PDF/Comp | |
006 | PDF/A |
8715 | S:Scan PGS/Comp | [0 to 9999999 / 0 / 1] |
These SPs count the number of compressed pages scanned by the scan application, counted by the formats listed below. | ||
003 |
004 | Other | |
005 | PDF/Comp | |
006 | PDF/A |
8721 | T | [0 to 9999999 / 0 / 1] |
8725 | S | [0 to 9999999 / 0 / 1] |
These SPs count the number of pages scanned by each scanner mode. | ||
001 | B/W | |
002 | Color |
8731 | T:Scan PGS/Media | [0 to 9999999 / 0 / 1] |
8735 | S:Scan PGS/Media | [0 to 9999999 / 0 / 1] |
These SPs count the number of pages scanned and saved in a meia by each scanner mode. | ||
001 | B/W | |
002 | Color |
8741 | RX PGS/Port | [0to9999999/ 0 / 1] |
These SPs count the number of pages received by the physical port used to receive them. | ||
001 | PSTN-1 | |
002 | PSTN-2 | |
003 | PSTN-3 | |
005 | Network |
8771 | Dev Counter | [0to9999999/ 0 / 1] |
These SPs count the frequency of use (number of rotations of the development rollers) for black and other color toners. Note: For machines that do not support color, the Black toner count is the same as the Total count. |
8781 | Toner_Botol_Info. |
This SP displays the number of toner bottles used. The count is done based on the equivalent of 1,000 pages per bottle. |
8791 | LS Memory Remain | This SP displays the percent of space available on the document server for storing documents. [0 to 100 / 0 / 1] |
8801 | Toner Remain | [0 to 100 / 0 / 1] |
This SP displays the percent of toner remaining for each color. This SP allows the user to check the toner supply at any time. Note: This precise method of measuring remaining toner supply (1% steps) is better than other machines in the market that can only measure in increments of 10 (10% steps). This SP is expanded for color MFP and color LP machines. For this machine, the count is done for black only. |
8811 | Eco Counter | |
001 | Eco Total | [0 to 9999999 / 0 / 1] |
Displays the number of pages reduced by using the duplex and the combine function. | ||
004 | Duplex | [0 to 9999999 / 0 / 1] |
Displays the number of pages reduced by using the duplex function. | ||
005 | Combine | [0 to 9999999 / 0 / 1] |
Displays the number of pages reduced by using the combine function. | ||
008 | Duplex(%) | [0 to 100 / 0 / 1] |
Displays the utilization ratio of the duplex function. | ||
009 | Combine(%) | [0 to 100 / 0 / 1] |
010 | Paper Cut(%) | [0 to 100 / 0 / 1] |
Displays the paper reduction ratio. |
8851 | Cvr Cnt:0-10% | [0 to 9999999 / 0 / 1] |
These SPs count the percentage of dot coverage for black other color toners. | ||
011 | 0 to 2%: BK | |
021 | 3 to 4%: BK | |
031 | 5 to 7%: BK | |
041 | 8 to 10%: BK |
8861 | Cvr Cnt:11-20% | [0 to 9999999 / 0 / 1] |
001 | BK | Black toner |
8871 | Cvr Cnt:21-30% | [0 to 9999999 / 0 / 1] |
8881 | Cvr Cnt:31%- | [0 to 9999999 / 0 / 1] |
8891 | Page/Toner Bottle | [0 to 9999999 / 0 / 1] |
These SPs display the amount of the remaining current toner. | ||
8901 | Page/Toner_Prev1 | [0 to 9999999 / 0 / 1] |
These SPs display the amount of the remaining previous toner. | ||
8911 | Page/Toner_Prev2 | [0 to 9999999 / 0 / 1] |
These SPs display the amount of the remaining 2nd previous toner. | ||
8921 | Cvr Cnt/Total | [0 to 9999999 / 0 / 1] |
Displays the total coverage and total printout number for each color. | ||
001 | Coverage (%) BK | |
011 | Coverage/P:BK |
8941 | Machine Status | [0 to 9999999 / 0 / 1] |
These SPs count the amount of time the machine spends in each operation mode. These SPs are useful for customers who need to investigate machine operation for improvement in their compliance with ISO Standards. | ||
001 | Operation Time | Engine operation time. Does not include time while controller is saving data to HDD (while engine is not operating). |
002 | Standby Time | Engine not operating. Includes time while controller saves data to HDD. Does not include time spent in Energy Save, Low Power, or Off modes. |
003 | Energy Save Time | Includes time while the machine is performing background printing. |
004 | Low Power Time | Includes time in Energy Save mode with Engine on. Includes time while machine is performing background printing. |
005 | Off Mode Time | Includes time while machine is performing background printing. Does not include time machine remains powered off with the power switches. |
006 | SC | Total down time due to SC errors. |
007 | PrtJam | Total down time due to paper jams during printing. |
008 | OrgJam | Total down time due to original jams during scanning. |
009 | Supply PM Unit End | Total down time due to supply unit end. |
8951 | AddBook Register | ||
These SPs count the number of events when the machine manages data registration. | |||
001 | User Code /User ID | User code registrations. | [0 to 9999999 / 0 / 1] |
002 | Mail Address | Mail address registrations. | |
003 | Fax Destination | Fax destination registrations. | |
004 | Group | Group destination registrations. | |
005 | Transfer Request | Fax relay destination registrations for relay TX. | |
006 | F-Code | F-Code box registrations. | |
007 | Copy Program | Copy application registrations with the Program (job settings) feature. | [0 to 255 / 0 / 255] |
008 | Fax Program | Fax application registrations with the Program (job settings) feature. | |
009 | Printer Program | Printer application registrations with the Program (job settings) feature. |
Scanner application | |||
010 | Scanner Program | registrations with the Program (job settings) | |
feature. |
8999 | Adomin. Counter List | [0 to 9999999 / 0 / 1] |
Display the total coverage and total printout number for each color. | ||
001 | Total | |
003 | Copy: BW | |
007 | Printer: BW | |
010 | Fax Print: BW | |
012 | A3/DLT | |
013 | Duplex | |
023 | Copy: BW (%) | |
027 | Printer: BW (%) | |
030 | Fax Print: BW (%) | |
101 | Transmission Total: Color | |
102 | Transmission Total: BW | |
103 | Fax Transmission | |
104 | Scanner Transmission: Color | |
105 | Scanner Transmission: BW |
MAIN SP TABLES-9
INPUT CHECK TABLE
When entering the Input Check mode, 8 digits display the result for a section. Each digit corresponds to a different device as shown in the table.
Bit No. 7 6 5 4 3 2 1 0 Result 0 or 1 0 or 1 0 or 1 0 or 1 0 or 1 0 or 1 0 or 1 0 or 1
Service Tables
Copier
5803Input Check
DescriptionReading 0 1 001 Tray 1: Paper Size Sensor See the table 1 following this table. 002 Tray 1: Tray Set Sensor Set Not set 003 Tray 1: Paper Lift Sensor Not upper limit Upper limit 004 Tray 1: Paper End Sensor No paper Paper remaining
005Tray 1:
Paper Height Sensor 1
See the table 2 following this table.
006Tray 1:
Paper Height Sensor 2007 Tray 2: Paper Size Sensor See the table 1 following this table. 008 Tray 2: Tray Set Sensor Set Not set 009 Tray 2: Paper Lift Sensor Not upper limit Upper limit 010 Tray 2: Paper End Sensor No paper Paper remaining
011Tray 2:
012Tray 2:
Paper Height Sensor 2013 Tray 1: Paper Feed Sensor Paper detected No paper detected 014 Tray 2: Paper Feed Sensor Paper detected No paper detected 015 Tray 3: Paper Feed Sensor Paper detected No paper detected 016 Tray 4: Paper Feed Sensor Paper detected No paper detected 017 LCT: Paper Feed Sensor No paper detected Paper detected 018 Relay Sensor 1 Paper detected No paper detected 019 Relay Sensor 2 Paper detected No paper detected 020 Relay Sensor 3 No paper detected Paper detected 021 Relay Sensor 4 No paper detected Paper detected 022 Relay Sensor: LCT No paper detected Paper detected 023 By-pass: Paper End Sensor Not end Paper end 024 By-pass: Paper Size Sensor See the table 3 following this table. 025 Registration Sensor Paper detected No paper detected 026 Fusing Exit Sensor No paper detected Paper detected 027 Fusing Entrance Sensor Paper detected No paper detected 028 Junction Gate Relay Sensor Paper detected No paper detected 029 Exit Sensor Paper detected No paper detected 030 Paper Overflow Sensor Not full Full 031 Right Cover Open/Close Close Open 032 Duplex Unit Open/Close Open Close 033 Duplex Entrance Sensor Paper detected No paper detected 034 Duplex Exit Sensor Paper detected No paper detected 035 Bank Right Cover Open/Close Close Open 036 Tray Cover Open/Close Close Open 037 LCT Set Set Not set 038 Bridge/Exit Tray: Exit Sensor Paper detected No paper detected 039 Bridge/Exit Tray: Relay Sensor Paper detected No paper detected 040 Bridge/Exit/Shift: Set Detection Set Not set
041Bridge/Exit Tray: Left Guide Open/Close
Close
Open
042Bridge/Exit Tray: Right Guide Open/Close
Close
Open043 Transfer Belt Unit HP Sensor Not HP HP 046 Fusing Unit Set Set (Bit1) Not set (Bit1) 047 Toner Overflow Sensor Not full Full
048
Interlock Detection 1Right or front door is open. Right or front door is close.
049
Interlock Detection 2Right or front door is open. Right or front door is close. 050 Key Card Set Set Not set 051 Key Counter Set Set Not set 052 Mechanical Counter Set Not set set 053 1-Bin Unit Set Set Not set 054 1-Bin Unit: Paper Set Paper detected No paper detected 057 Cleaning Web End Not end End 060 Shift Sensor No paper detected Paper detected 064 Shift Tray Sensor Stay at rear Stay at front
065Bypass Tray Paper Length Detection
Paper detected
No paper detected
200 Scanner HP Sensor Not HP HP 201 Platen Cover Sensor Open Close
Table 1: Paper Height Sensor
0: Deactivated, 1: Activated (actuator inside sensor)
Remaining paper Paper height sensor 1 Paper height sensor 2 Full 0 0 Nearly full 1 0 Near end 1 1 Almost empty 0 1 Table 2: Paper Size Switch
Service Tables
Switch 1 is used for the tray set detection. 0: Pushed, 1: Not pushed
Models Switch Location North America Europe/Asia 4 3 2 11" x 17" SEF*1 (A3 SEF) A3 SEF*1
(11" x 17" SEF)
0
0
18.5" x 14" SEF *2 (B4 SEF) B4 SEF *2
(8.5" x 14" SEF)
0
0
0A4 SEF A4 SEF 1 1 0 8.5" x 11" SEF 8.5" x 11" SEF 1 1 1 B5 SEF B5 SEF 0 1 1 11" x 81/2" LEF*3 (A4 LEF) A4 LEF*3
(11" x 81/2" LEF)
0
010.5" x 7.25" LEF*4 (B5 LEF) B5 LEF*4
(10.5" x 7.25" LEF)
0
0A5 LEF A5 LEF 1 0 1 *1: The machine detects either 11" x 17" SEF or A3 SEF, depending on the setting of SP 5-181-002 (Tray 1) or -006 (Tray 2).
*2: The machine detects either 8.5" x 14" SEF or B4 SEF, depending on the setting of SP 5-181-003 (Tray 1) or -007 (Tray 2).
*3: The machine detects either 11" x 81/2" LEF or A4 LEF, depending on the setting of SP 5-181-001 (Tray 1) or -005 (Tray 2).
*4: The machine detects either B5 LEF or 10.5" x 7.25" LEF, depending on the setting of SP 5-181-004 (Tray 1) or -008 (Tray 2)..Table 3: Paper Size (By-pass Table)
Models Bit No. North America Europe/Asia 3 2 1 0 11" x 17" SEF*1
(11" x 8.5" LEF)A3 SEF*1 (A4 LEF)
011" x 17" SEF*1
0
08.5" x 11" SEF*1
(8.5" x 11" SEF*2)A4 SEF*1 (A5 LEF)
0
18.5" x 11" SEF*1
(8.5" x 11" SEF*2)A4 SEF*1 (B5 LEF)
0
0
15.5" x 8.5" SEF A5 SEF 1 0 1 1 5.5" x 8.5" SEF A5 SEF 0 0 1 1 5.5" x 8.5" SEF A6 SEF 0 1 1 1 5.5" x 8.5" SEF A6 SEF 1 1 1 1
- *1: When the machine determines that the paper feed direction is "LEF", it considers that the paper size is bracketed size.
APS Original Size Detection
Original Size | Length Sensor | Width Sensor | SP4-301 display | ||||
Metric version | Inch version | L3 | L2 | L1 | W1 | W2 | |
A3 | 11" x 17" | O | O | O | O | O | 00011111 |
B4 | 10" x 14" | O | O | O | O | X | 00011110 |
F4 8.5" x 13", 8.25" x 13", or 8" x 13" SP 5126 controls the size that is detected | 8.5" x 14" | O | O | O | X | X | 00011100 |
A4 LEF | 8.5" x 11" | X | X | X | O | O | 00000011 |
B5 LEF | - | X | X | X | O | X | 00000010 |
A4 SEF | 11" x 8.5" | X | O | O | X | X | 00001100 |
B5 SEF | - | X | X | O | X | X | 00000100 |
A5 LEF/ SEF | 5.5" x 8.5", 8.5" x 5.5" | X | X | X | X | X | 00000000 |
3000/2000-Sheet (Booklet) Finisher (D636/D637)
6140 | Bit | Description | Reading |
0 | 1 | ||
001 | Entrance Sensor | No paper detected | Paper detected |
002 | Proof Exit Sensor | No paper detected | Paper detected |
003 | Proof Full Detection Sensor | Not Full | Full |
004 | Upper Tray Exit Sensor | No paper detected*1 | Paper detected*1 |
005 | Staple Exit Sensor | No paper detected | Paper detected |
006 | Shift Roller HP Sensor | Not HP | HP |
007 | Shift Exit Sensor | No paper detected | Paper detected |
008 | Exit Guide Plate HP Sensor | Not HP | HP |
009 | Lower Tray Height Sensor | No paper detected | Paper detected |
010 | Upper Tray Height Sensor | No paper detected | Paper detected |
011 | Upper Tray Full Sensor | Not Full | Full |
012 | Stack Roller HP Sensor | Not HP | HP |
013 | Jogger HP Sensor | Not HP | HP |
014 | Feed Out Belt HP Sensor | HP | Not HP |
015 | Stapling Tray Paper Sensor | No paper detected | Paper detected |
016 | Corner Stapler HP Sensor | Not HP | HP |
017 | Stapler Rotation HP Sensor | Not HP | HP |
018 | Upper Tray Limit SW | Not Limit | Limit |
019 | Door Switch | Closed | Open |
020 | Corner Stapler Operation | Not HP | HP |
0 | 1 | ||
021 | Staple Detection | No staple detected | Staple detected |
022 | Staple Dip Detection | No staple detected | Staple detected |
023 | Punch Movement HP Sensor | Not HP | HP |
024 | Paper Position Slide HP Sensor | Not HP | HP |
025 | Paper Position Sensor | No paper detected | Paper detected |
026 | Punch Full Sensor | Not Full | Full |
027 | Punch HP Sensor | Not HP | HP |
028 | Punch DIP SW 1 | See *1 | |
029 | Punch DIP SW 2 | See *1 | |
030 | Stack Junction Gate HP Sensor | Not HP | HP |
031 | Stack Present Sensor | No paper detected | Paper detected |
032 | Clamp Roller HP Sensor | Not HP | HP |
033 | Fold Entrance Sensor | No paper detected | Paper detected |
034 | Bottom Fence HP Sensor | Not HP | HP |
035 | Fold Cam HP Sensor | Not HP | HP |
036 | Fold Plate HP Sensor | Not HP | HP |
037 | Fold Unit Exit Sensor | No paper detected | Paper detected |
038 | Lower Tray Full Sensor: Front | No paper detected*2 | Paper detected*2 |
039 | Lower Tray Full Sensor: Rear | No paper detected*2 | Paper detected*2 |
040 | Booklet Stapler 1: Operation (Rotation/Front) | Not HP | HP |
041 | Booklet Stapler 1: Staple In (Front) | No staple detected | Staple detected |
