062 | Complexity Option 1 |
Use this SP to set the conditions for password entry to access the local address book. Specifically, this SP limits the password entry to upper case and sets the length of the password. [0 to 32 / 0 / 1step] ![]()
063 | Complexity Option 2 |
Use this SP to set the conditions for password entry to access the local address book. Specifically, this SP limits the password entry to lower case and defines the length of the password. [0 to 32 / 0 / 1step] ![]()
064 | Complexity Option 3 |
Use this SP to set the conditions for password entry to access the local address book. Specifically, this SP limits the password entry to numbers and defines the length of the password. [0 to 32 / 0 / 1step] ![]()
Service Tables
065 | Complexity Option 4 |
Use this SP to set the conditions for password entry to access the local address book. Specifically, this SP limits the password entry to symbols and defines the length of the password. [0 to 32 / 0 / 1step] ![]()
091 | FTP Auth Port Setting |
Sets the FTP port to get the delivery server address book that is used in the individual authorization mode. [0 to 65535 / 3671 / 1step] | |
094 | Encryption Start |
Shows the status of the encryption function of the address book on the LDAP server. [0 to 255 / 1 ] No default |
5847* | Rep Resolution Reduction | ||
5847-2 through 5847-6 changes the default settings of image data sent externally by the Net File page reference function. 5847-21 sets the default for JPEG image quality of image files controlled by NetFile. "NetFile" refers to jobs to be printed from the document server with a PC and the DeskTopBinder software. | |||
002 | Rate for Copy B&W Text | [0 to 6 / 0 / 1] | 0: 1x |
1: 1/2x | |||
003 | Rate for Copy B&W Other | [0 to 6 / 0 / 1] | |
2: 1/3x | |||
005 | Rate for Printer B&W | [0 to 6 / 0 / 1] | 3: 1/4x |
4: 1/5x | |||
5: 1/8x | |||
6: 2/3x1 |
007 | Rate for Printer B&W 1200dpi | [0 to 6 / 1 / 1] | |
021 | Network Quality Default for JPEG | ||
Sets the default value for the quality of JPEG images sent as NetFile pages. This function is available only with the MLB (Media Link Board) option installed. [5 to 95 / 50 / 1step] |
5848* | Web Service | |
5848-2 sets the 4-bit switch assignment for the access control setting. Setting of 0001 has no effect on access and delivery from Scan Router. 5848-100 sets the maximum size of images that can be downloaded. The default is equal to 1 gigabyte. | ||
002 | Acc. Ctrl.: Repository (only Lower 4 Bits) | 0000: No access control 0001: Denies access to DeskTop Binder. |
003 | Acc. Ctrl.: Doc. Svr. Print (Lower 4 Bits) | Switches access control on and off. 0000: OFF, 0001: ON |
004 | Acc. Ctrl.: User Directory (Lower 4 Bits) | |
007 | Acc. Ctrl Comm. Log Fax (Lower 4 Bits) | |
009 | Acc. Ctrl.: Job Control (Lower 4 Bits) | |
011 | Acc. Ctrl: Device Management (Lower 4 Bits) | |
021 | Acc. Ctrl: Delivery (Lower 4 Bits) | |
022 | Acc. Ctrl: User Administration (Lower 4 Bits) | |
099 | Repository: Download Image Setting |
Service Tables
100 | Repository: Download Image Max. Size | Specified the max size of the image data that the machine can download/ [1 to 2048 / 2048 / 1 MB] |
210 | Setting: Log Type: Job 1 | |
No information is available at this time. | ||
211 | Setting: Log Type: Job 2 | |
212 | Setting: Log Type: Access | |
213 | Setting: Primary Srv | |
214 | Setting: Secondary Srv | |
215 | Setting: Start Time | |
216 | Setting: Interval Time | |
217 | Setting: Timing | |
5849 | Installation Date | |
Displays or prints the installation date of the machine. | ||
001 | Display | The "Counter Clear Day" has been changed to "Installation Date" or "Inst. Date". |
002 | Switch to Print | Determines whether the installation date is printed on the printout for the total counter. [0 to 1 / 1 / -] 0: OFF (No Print) 1: ON (Print) |
003 | Total Counter | When the total number of pages that are made reaches this value, the current date becomes the 'official' installation date for this machine. [0 to 99999999 / 0 / 1] |
5850* | Address Book Function Japan Only |
003 | Replacement of Circuit Classification |
The machine is sold ready to use with a G3 line. This SP allows you to switch all at once to convert to G4 after you add a G4 line. Conversely, if for some reason the G4 line becomes unusable, you can easily switch back to G3. |
5851* | Bluetooth |
Sets the operation mode for the Bluetooth Unit. Press either key. [0: Public] / [1: Private] |
Service Tables
5853 | Stamp Data Download |
Push [Execute] to download the fixed stamp data from the machine ROM onto the hard disk. Then these stamps can be used by the system. If this is not done, the user will not have access to the fixed stamps ("Confidential", "Secret", etc.). You must always execute this SP after replacing the HDD or after formatting the HDD. Always switch the machine off and on after executing this SP. |
5856 | Remote ROM Update |
002 | When set to "1" allows reception of firmware data via the local port (IEEE 1284) during a remote ROM update. This setting is reset to zero after the machine is cycled off and on. Allows the technician to upgrade the firmware using a parallel cable [0 to 1 / 0 / 1 step] 0: Not allowed 1: Allowed |
5857 | Save Debug Log |
001 | On/Off (1:ON 0:OFF) |
Switches on the debug log feature. The debug log cannot be captured until this feature is switched on. [0 to 1 / 0 / 1] 0: OFF, 1: ON | |
002 | Target (2: HDD 3: SD) |
Selects the destination where the debugging information generated by the event selected by SP5858 will be stored if an error is generated [2 to 3 / 2 / 1] 2: HDD, 3: SD Card |
005 | Save to HDD |
Specifies the decimal key number of the log to be written to the hard disk. | |
006 | Save to SD Card |
Specifies the decimal key number of the log to be written to the SD Card. | |
009 | Copy HDD to SD Card (Latest 4 MB) |
Takes the most recent 4 MB of the log written to the hard disk and copies them to the SD Card. A unique file name is generated to avoid overwriting existing file names on the SD Card. Up to 4MB can be copied to an SD Card. 4 MB segments can be copied one by one to each SD Card. | |
010 | Copy HDD to SD Card Latest 4 MB Any Key) |
Takes the log of the specified key from the log on the hard disk and copies it to the SD Card. A unique file name is generated to avoid overwriting existing file names on the SD Card. Up to 4 MB can be copied to an SD Card. 4 MB segments can be copied one by one to each SD Card. This SP does not execute if there is no log on the HDD with no key specified. | |
011 | Erase HDD Debug Data |
Erases all debug logs on the HDD | |
012 | Erase SD Card Debug Data |
Erases all debug logs on the SD Card. If the card contains only debugging files generated by an event specified by SP5858, the files are erased when SP5857 010 or 011 is executed. To enable this SP, the machine must be cycled off and on. |
Service Tables
013 | Free Space on SD Card |
Displays the amount of space available on the SD card. | |
014 | Copy SD to SD (Latest 4MB) |
Copies the last 4MB of the log (written directly to the card from shared memory) onto an SD card. | |
015 | Copy SD to SD (Latest 4MB Any Key) |
This SP copies the log on an SD card (the file that contains the information written directly from shared memory) to a log specified by key number. | |
016 | Make HDD Debug |
This SP creates a 32 MB file to store a log on the HDD. | |
017 | Make SD Debug |
This SP creates a 4 MB file to store a log on an SD card. |
5858* | Debug Save When | |
These SPs select the content of the debugging information to be saved to the destination selected by SP5857-002. SP5858-003 stores one SC specified by number. | ||
001* | Engine SC Error (0:OFF 1:ON) | Stores SC codes generated by copier engine errors. |
002* | Controller SC Error (0:OFF 1:ON) | Stores SC codes generated by GW controller errors. |
003* | Any SC Error | [0 to 65535 / 0 / 1step] |
004* | Jam (0:OFF 1:ON) | Stores jam errors. |
5859* | Debug Save Key No. | ||
001 | Key | 1 | These SPs allow you to set up to 10 keys for log files for functions that use common memory on the controller board. [0 to 9999999 / 0 / 1] |
002 | Key | 2 | |
003 | Key | 3 | |
004 | Key | 4 | |
005 | Key | 5 | |
006 | Key | 6 | |
007 | Key | 7 | |
008 | Key | 8 | |
009 | Key | 9 | |
010 | Key | 10 |
5860* | SMTP/POP3/IMAP4 |
020 | Partial Mail Receive Timeout |
[1 to 168 / 72 / 1 hour] Sets the amount of time to wait before saving a mail that breaks up during reception. The received mail is discarded if the remaining portion of the mail is not received during this prescribed time. | |
021 | MDN Response RFC2298 Compliance |
Determines whether RFC2298 compliance is switched on for MDN reply mail. [0 to 1 / 1 / 1] 0: No, 1: Yes |
Service Tables
022 | SMTP Auth. From Field Replacement |
Determines whether the FROM item of the mail header is switched to the validated account after the SMTP server is validated. [0 to 1 / 0 / 1] 0: No. "From" item not switched. 1: Yes. "From" item switched. | |
025 | SMTP Auth Direct Sending |
Select the authentication method for SMPT. Bit 0: LOGIN Bit 1: PLAIN Bit 2: CRAM_MD5 Bit 3: DIGEST_MD5 Bit 4 to Bit 7: Not Used ![]()
026 | S/MIME: MIME Header Setting |
Selects the MIME header type of an E-mail sent by S/MIME. [0 to 2 / 0 / 1] 0: Microsoft Outlook Express standard 1: Internet Draft standard 2: RFC standard | |
028 | S/MIME: Authentication Check |
When sending S/MIME mail, specifies whether to check the destination authentication. [0 to 1 / 0 / 1] 0: Not checked 1: Checked |
5870 | Common Key Info Writing | |
001 | Writing | Writes to flash ROM the common proof for validating the device for @Remote specifications. |
003 | Initialize | Initializes the data area of the common proof for validating. |
004 | Writing: 2048bit | Writes to flash ROM the common proof (2048-bit) for validating the device for @Remote specifications. |
5873 | SD Card Appli Move | |
Allows you to move applications from one SD card another. For more, see "SD Card Appli Move" in the chapter "System Maintenance (Main Chapters). | ||
001 | Move Exec | Executes the move from one SD card to another. |
002 | Undo Exec | This is an undo function. It cancels the previous execution. |
5875 | SC Auto Reboot | |
This SP determines whether the machine reboots automatically when an SC error occurs.![]()
001 | Reboot Setting | [0 to 1/ 0 / 1] 0: The machine reboots automatically when the machine issues an SC error and logs the SC error code. If the same SC occurs again, the machine does not reboot. 1: The machine does not reboot when an SC error occurs. |
002 | Reboot Type | [0 to 1 / 0 / 1] 0: Manual reboot, 1: Automatic reboot |
Service Tables
5878 | Option Setup | |
001 | Data Overwrite Security | Press [Execute] to initialize the Data Overwrite Security option for the copier. For more, see "DataOverwriteSecurity Unit" in the chapter "Installation". |
5881 | Fixed Phase Block Erasing |
Detects the Fixed phrase. |
5885* | Set WIM Function | |
020 | DocSvr Acc Ctrl | Allows or disallows the functions of web image monitor. 0: OFF, 1: ON Bit: 0: Forbid all document server access 1: Forbid user mode access 2: Forbid print function 3: Forbid Fax 4: Forbid scan sending 5: Forbid download 6: Forbid delete 7: Forbid guest user |
50 | DocSvr Format | |
Selects the display type for the document box list. [0 to 2 / 0 / 1] 0: Thumbnail, 1: Icon, 2: Details | ||
51 | DocSvr Trans | |
Sets the number of documents to be displayed in the document box list. [5 to 20 / 10 / 1] |
100 | Set Signature | |
[0 to 2 / 0 / 1/step] 0: Signature for each e-mail 1: Signature for all e-mails 2: No signature | ||
Selects whether the signature is added to the scanned documents with the WIM when they are transmitted by an e-mail. | ||
101 | Set Encryption | |
Determines whether the scanned documents with the WIM are encrypted when they are transmitted by an e-mail. [0 to 1 / 0 / 1] 0: Not encrypted, 1:Encryption | ||
200 | Detect Mem Leak | Not used |
201 | DocSvr Timeout | Not used |
5887 | SD Get Counter |
This SP determines whether the ROM can be updated. | |
001 | This SP sends a text file to an SD card inserted in SD card Slot 2 (lower slot). The operation stores. The file is stored in a folder created in the root directory of the SD card called SD_COUNTER. The file is saved as a text file (*.txt) prefixed with the number of the machine.
Service Tables
5888* | Personal Information Protect |
Selects the protection level for logs. [0 to 1 / 0 / 1] 0: No authentication, No protection for logs 1: No authentication, Protected logs (only an administrator can see the logs) |
5893 | SDK Application Counter |
Displays the counter name of each SDK application. | |
1 | SDK-1 |
2 | SDK-2 |
3 | SDK-3 |
4 | SDK-4 |
5 | SDK-5 |
6 | SDK-6 |
5907 | Plug & Play Maker/Model Name |
Selects the brand name and the production name for Windows Plug & Play. This information is stored in the NVRAM. If the NVRAM is defective, these names should be registered again. After selecting, press the "Original Type" key and "#" key at the same time. When the setting is completed, the beeper sounds five times. |
5913* | Switchover Permission Time | |
002 | Print Application Timer | [3 to 30 / 3 / 1 second step] |
Sets the length of time to elapse before allowing another application to take control of the display when the application currently controlling the display is not operating because a key has not been pressed. |
5967* | Copy Server: Set Function | 0: ON, 1: OFF |
Enable and disable the document server. This is a security measure that prevents image data from being left in the temporary area of the HDD. After changing this setting, you must switch the main switch off and on to enable the new setting. |
5974* | Cherry Server |
Selects which version of the Scan Router application program, "Light" or "Full" (Professional) is installed. [0 or 1 / 0 / - ] 0: Light 1: Full |
5985 | Device Setting | |
The NIC and USB support features are built into the GW controller. Use this SP to enable and disable these features. In order to use the NIC and USB functions built into the controller board, these SP codes must be set to "1". | ||
001 | On Board NIC | [0 to 2 / 0 / 1 /step] 0: Disable, 1: Enable, 2: Function limitation When the "Function limitation" is set, "On board NIC" is limited only for the NRS or LDAP/NT authentication. ![]()
002 | On Board USB | [0 or 1 / 0 / 1/step] 0: Disable, 1: Enable |
Service Tables
5987* | Counter Falsification Prevention |
This SP detects that a mechanical counter device is removed. If it is detected, SC610 occurs. [0 or 1 / 1 / 1/step] 0: OFF. 1: ON |
5990 | SP Print Mode |
Prints out the SMC sheets. | |
001 | All ( Data List) |
002 | SP (Mode Data List) |
003 | User Program |
004 | Logging Data |
005 | Diagnostic Report |
006 | Non-Default |
007 | NIB Summary |
008 | Capture Log |
021 | Copier User Program |
022 | Scanner SP |
023 | Scanner User Program |
024 | SDK/J Summary |
025 | SDK/J Application Info |
026 | Print SP |
MAIN SP TABLES-6
SP6-XXX: PERIPHERALS
6006*ADF Registration Adjust Adjusts the side-to-side and leading edge registration for simplex and duplex original feeding in ARDF mode.
SP6006-5 sets the maximum setting allowed for rear edge erase.001 Side-to-Side Regist: Front
[–3 to 3 / 0 / 0.1 mm / step]002 Side-to-Side Regist: Rear 003 Leading Edge Registration [–5 to 5 / 0 / 0.1 mm / step] 005 Buckle: Duplex Front [–3 to 3 / 0 / 0.1 mm / step] 006 Buckle: Duplex Rear [–2.5 to 2.5 / 0 / 0.1 mm / step] 007 Rear Edge Erase [–10 to 10 / 0 / 0.1 mm / step]
6007 ADF Input Check
001Original Length 1 (B5 Detection Sensor)
0: Paper not detected
1: Paper detected
002Original Length 2 (A4 Detection Sensor)
003Original Length 3 (LG Detection Sensor) 004 Original Width Sensor 1 005 Original Width Sensor 2 006 Original Width Sensor 3 007 Original Width Sensor 4 008 Original Width Sensor 5 009 Original Set Sensor 010 Separation Sensor 011 Skew Correction Sensor 012 Scan Entrance Sensor 013 Registration Sensor 014 Exit Sensor
015
Feed Cover Sensor0: ADF cover closed 1: ADF cover open
016
Lift Up Sensor0: ADF closed
1: ADF open
017
Inverter Sensor0: Paper not detected 1: Paper detected
018
Pick-up Roller HP Sensor0: HP (Pick-up roller: Up)
1: Not HP (Pick-up roller: Down)
019
Original Set HP Sensor0: HP (Stopper: UP)
1: Not HP (Stopper: Down)Service Tables
6008 ADF Output Check 001 Pick-up Motor Forward 002 Pick-up Motor Reserve 003 Feed Motor Forward 004 Feed Motor Reserve 005 Relay Motor Forward 007 Inverter Motor Forward 008 Inverter Motor Reserve 011 Inverter Solenoid 012 Stamp 013 Fan Motor
6009ADF FreeRun Performs an ARDF free run in duplex mode. Press [ON] to start, press [OFF] to stop.
Note: This is a general free run controlled from the copier.001 Free Run: Simplex Motion 002 Free Run: Duplex Motion 003 Free Run: Stamp Motion
6010*ADF Stamp Position Adjust. [–5 to 5 / 0 / 0.1 mm step] Adjusts the horizontal position of the stamp on the scanned originals.
6016*Original Size Detect Setting Specifies the original size for a size detected by the original sensor, since original sensors cannot recognize all sizes.
(7) 0000 0000 (0)
Different bits are used for detection, depending on the location as shown below.Bit Size Location 7 A4 (L)/LT (L)
Japan only6 11" x 15"/DLT (L) 5 DLT (L)/ 11" x 15"
NA only4 LT (S)/ US Exec (S) 3 LT (L)/ 8" x 10" (L) 2 LG (L)/ F4 (L) 1 A4 (L)/ 16K (L)
EU/AA only0 8K (L)/ DLT (L) Service Tables
6017*DF Magnification Adj. [–5 to 5 / 0 / 0.1% step] Adjusts the magnification in the sub-scan direction for ADF mode. Use the key to toggle between + and - before entering the value
6020*Skew Correction Moving Setting Turns the original skew correction in the ARDF for all original sizes on or off. [0 to 1 / 0 / 1 ]
0: Off (only for small original sizes) 1: On (for all original sizes)
6128Punch Position: Sub Scan Adjusts the punching position in the sub scan direction. (For D636/D637) 001 2-Hole: DOM (Japan)
[-7.5 to 7.5 / 0 / 0.5 mm]002 3-Hole: NA 003 4-Hole: EU 004 5-Hole: SCAN 005 2-Hole: NA
6129Punch Position: Main Scan Adjusts the punching position in the main scan direction. (For D636/D637) 001 2-Hole: DOM (Japan)
[-2 to 2 / 0 / 0.4 mm]002 3-Hole: NA 003 4-Hole: EU 004 4-Hole: SCAN 005 2-Hole: NA
6130*Skew Correction: Buckle Adj. Adjusts the paper buckle at the punch unit for each paper size. (For D636/D637) 001 A3 SEF
[-5 to 5 / 0 / 0.25 mm]002 B4 SEF 003 A4 SEF 004 A4 LEF 005 B5 SEF 006 B5 LEF 007 DLT SEF 008 LG SEF 009 LT SEF 010 LT LEF 011 12" x 18" 012 Other
6131*Skew Correction Control Selects the skew correction control for each paper size. (For D636/D637) 001 A3 SEF
[0 to 1 / 1 / 1 mm]002 B4 SEF 003 A4 SEF 004 A4 LEF 005 B5 SEF 006 B5 LEF 007 DLT SEF 008 LG SEF 009 LT SEF 010 LT LEF 011 12" x 18" 012 Other Service Tables
6132*Jogger Fence Fine Adj. This SP adjusts the distance between the jogger fences and the sides of the stack on the finisher stapling tray in the (Booklet) Finisher D636/D637. The adjustment is done perpendicular to the direction of paper feed. 001 A3 SEF
[-1.5 to 1.5 / 0 / 0.5 mm]002 B4 SEF 003 A4 SEF 004 A4 LEF 005 B5 SEF 006 B5 LEF 007 DLT SEF 008 LG SEF 009 LT SEF 010 LT LEF 011 12" x 18" 012 Other
6133*Staple Position Adjustment Adjusts the staple position for each finisher (D636/D637).
+ Value: Moves the staple position to the rear side.
- Value: Moves the staple position to the front side. [-3.5 to 3.5 / 0 / 0.5 mm]
6134*Saddle Stitch Position Adj. Use this SP to adjust the stapling position of the booklet stapler when paper is stapled and folded in the Booklet Finisher (D637). 001 A3 SEF
[-3 to 3 / 0 / 0.2 mm]
+ Value: Shifts staple position toward the crease.
- Value: Shifts staple position away from the crease
002 B4 SEF 003 A4 SEF 004 B5 SEF 005 DLT SEF 006 LG SEF 007 LT SEF 008 12" x 18" 009 Other Service Tables
6135*Folder Position Adj. This SP corrects the folding position when paper is stapled and folded in the Booklet Finisher D637. 001 A3 SEF
- Value: Shifts staple position away from the crease.
6136*Book Fold Repeat Sets the number of times that folding is done in the Booklet Finisher D637. [2 to 30 / 2 / 1 time/step]
6139Entrance Sensor Display the signals received from sensors and switches of the (booklet) finisher. (D588)
6140FIN (EUP) INPUT Check Display the signals received from sensors and switches of the (booklet) finisher. (D636/D637)
6144FIN (KIN) OUPUT Check Display the signals received from sensors and switches of the (booklet) finisher. (D588)
6145FIN (EUP) OUPUT Check Display the signals received from sensors and switches of the (booklet) finisher. (D636/D637)
6149*Max. Pre-Stack Sheet [0 to 3 / 3 / 1 sheets step] This SP sets the number of sheets sent to the pre-stack tray.
- You may need to adjust this setting or switch it off when feeding thick or slick paper.
MAIN SP TABLES-7
Service Tables
SP7-XXX: DATA LOG
7401* Total SC Counter
001SC Counter Displays the total number of service calls that have occurred.
This SC counter can be reset by executing SP7807 (SC/Jam Counter Reset).
002Total SC Counter Displays the cumulative sum of service calls that have occurred.
This SC counter cannot be reset by executing SP7807 (SC/Jam Counter Reset).
7403* SC History 001 Latest
Displays the most recent 10 service calls.002 Latest 1 003 Latest 2 004 Latest 3 005 Latest 4 006 Latest 5 007 Latest 6 008 Latest 7 009 Latest 8 010 Latest 9
7502* Total Paper Jam
001Jam Counter Displays the total number of paper jams.
002Total Jam Counter Displays the cumulative sum of paper jams.
7503* Total Original Jam
001Original Jam Counter Displays the total number of original jams.
002Total Original Counter Displays the cumulative sum of original jams.
013 Bank: Transport Sn 1: On
7504*Total Jams Location These SPs display the total number of paper jams by location. A "Check-in" (paper late) error occurs when the paper fails to activate the sensor at the precise time. A "Check-out" ("paper lag") paper jam occurs when the paper remains at the sensor for longer than the prescribed time. 001 At power On 003 Tray 1: On 004 Tray 2: On 005 Tray 3: On 006 Tray 4: On 007 LCT: On 008 Bypass: On 009 Duplex: On 013 Bank: Transport Sn 1: On 011 Vertical Transport 1: On 012 Vertical Transport 2: On 014 Bank: Transport Sn 2: On 017 Registration: On 019 Fusing Exit: On 020 Paper Exit: On 021 Bridge Exit On 022 Bridge Transport: On 024 Junction Gate Sensor: On 025 Duplex Exit: On 026 Duplex Entrance: On (In) 027 Duplex Entrance: On (Out) 051 Vertical Transport 1: Off 052 Vertical Transport 2: Off 053 Bank Transport 1: Off 054 Bank Transport 2: Off 057 Registration Sensor: Off 058 LCT Feed Sensor: Off 060 Paper Exit: Off 061 Bridge: Exit: Off 062 Bridge: Transport: Off 064 Junction Gate Sensor: Off 065 Duplex Exit: Off 066 Duplex Entrance: Off (In) Service Tables
013 Bank: Transport Sn 1: On 067 Duplex Entrance: Off (Out) 100 Finisher Entrance: KIN 101 Finisher Shift Tray Exit: KIN 102 Finisher Staple: KIN 103 Finisher Exit: KIN 105 Finisher Tray Lift Motor: KIN 106 Finisher Jogger Motor: KIN 107 Finisher Shift Motor: KIN 108 Finisher Staple Motor: KIN 109 Finisher Exit Motor: KIN 191 Finisher Entrance: EUP 192 Finisher Proof Exit: EUP 193 Finisher Shift Tray Exit: EUP 194 Finisher Staple Exit: EUP 195 Finisher Exit: EUP 198 Finisher Folder: EUP 199 Finisher Tray Motor: EUP 200 Finisher Jogger Motor: EUP 201 Finisher Shift Motor: EUP 202 Finisher Staple Moving Motor: EUP 203 Finisher Staple Motor: EUP 204 Finisher Folder Motor: EUP 206 Finisher Punch Motor:EUP
7505Original Jam Detection Displays the total number of original jams by location. These jams occur when the original does not activate the sensors. A Check-in ("paper late") error occurs when the paper fails to activate the sensor at the precise time. A Check-out ("paper lag") paper jam occurs when the paper remains at the sensor for longer than the prescribed time. 001 At Power: On 003 Separation Sensor: On 004 Skew Correction Sensor: On 005 Interval Sensor: On 006 Registration Sensor: On 007 Inverter Sensor: On 008 Original Exit Sensor: On 053 Separation Sensor: Off 054 Skew Correction Sensor: Off 055 Interval Sensor: Off 056 Registration Sensor: Off 057 Inverter Sensor: Off 058 Original Exit Sensor: Off Service Tables
7506* Jam Count by Paper Size 005 A4 LEF
Displays the total number of copy jams by paper size.006 A5 LEF 014 B5 LEF 038 LT LEF 044 HLT LEF 132 A3 SEF 133 A4 SEF 134 A5 SEF 141 B4 SEF 142 B5 SEF 160 DLT SEF 164 LG SEF 166 LT SEF 172 HLT SEF 255 Others Service Tables
7507* Plotter Jam History 001 Last 002 Latest 1
Displays the copy jam history (the most recent 10 jams)003 Latest 2 Sample Display: CODE:007 004 Latest 3 SIZE:05h 005 Latest 4 TOTAL:0000334 DATE: Mon Mar 15 11:44:50 2000 006 Latest 5 where: 007 Latest 6 CODE is the SP7504-*** number (see above. SIZE is the ASAP paper size code in hex. 008 Latest 7 TOTAL is the total jam error count (SP7502) 009 Latest 8 DATE is the date the jams occurred. 010 Latest 9 Size Code Size Code Size Code A4 (S) 05 A3 (L) 84 DLT (L) A0 A5 (S) 06 A4 (L) 85 LG (L) A4 B5 (S) 0E A5 (L) 86 LT (L) A6 LT (S) 26 B4 (L) 8D HLT (L) AC HLT (S) 2C B5 (L) 8E Others FF
7508* Original Jam History 001 Last 002 Last 1
Displays the original jam history (the most recent 10 jams).003 Last 2 Sample Display: CODE:007 004 Last 3 SIZE:05h 005 Last 4 TOTAL:0000334 DATE: Mon Mar 15 11:44:50 2000 006 Last 5 where: 007 Last 6 CODE is the SP7505*** number (see above. SIZE is the ASAP paper size code in hex. 008 Last 7 TOTAL is the total jam error count (SP7503) 009 Last 8 DATE is the date the jams occurred. 010 Last 9 Size Code Size Code Size Code A4 (S) 05 A3 (L) 84 DLT (L) A0 A5 (S) 06 A4 (L) 85 LG (L) A4 B5 (S) 0E A5 (L) 86 LT (L) A6 LT (S) 26 B4 (L) 8D HLT (L) AC HLT (S) 2C B5 (L) 8E Others FF
7801ROM No./Firmware Version This SP codes display the firmware versions of all ROMs in the system, including the mainframe, the ARDF, and peripheral devices. Service Tables
7803*PM Counter Display Displays the PM counter since the last PM.
001Paper [0 to 999999 / 0 / 1 page] Displays the paper counter (pages)
002Page: PCD [0 to 999999 / 0 / 1 page] Displays the PCD (Drum and Development unit) counter (pages)
003Page: Transfer [0 to 999999 / 0 / 1 page] Displays the transfer unit counter (pages).
004Page: Fuser [0 to 999999 / 0 / 1 page] Displays the fusing unit counter (pages).
005Rotation: PCD [0 to 999999999 / 0 / 1 mm ] Displays the PCD rotation counter (distance).
006Rotation: Transfer [0 to 999999999 / 0 / 1 mm ] Displays the transfer unit rotation counter (distance).
007Rotation: Fuser [0 to 999999999 / 0 / 1 mm ] Displays the fuser unit rotation counter (distance).
008Rotation(%): PCD [0 to 255 / 0 / 1 %] Displays the PCD (%) rotation counter (Distance/PM).
009Rotation(%):Transfer [0 to 255 / 0 / 1 %] Displays the transfer unit (%) rotation counter (distance/PM).
010Rotation(%):Fuser [0 to 255 / 0 / 1 %] Displays the fuser unit (%) rotation counter (distance/PM).
011Rotation(%):Web [0 to 255 / 0 / 1 %] Displays the web unit (%) rotation counter (distance/PM).
7804PM Counter Reset Resets the PM counter.
Touch [Execute] two times > "Completed" > [Exit]
001Paper Resets the PM counter of the paper.
002PCD Resets the PM counter of the PCD (Drum and Development unit except developer).
003Transfer Resets the PM counter of the transfer unit.
004Fuser Resets the PM counter of the fuser unit.
005Web Reset the PM counter of the web unit.
006All Clear Resets all PM counter
7807SC/Jam Counter Reset Resets the SC and jam counters. To reset, press Execute on the touch panel.
This SP does not reset the jam history counters: SP7507, SP7508.Service Tables
7832Self-Diagnose Result Display Execute to open the "Self-Diagnostics Result Display" to view details about errors. Use the keys in the display on the touch-panel to scroll through all the information. If no errors have occurred, you will see the "No Error" message on the screen.
7836Total Memory Size Displays the memory capacity of the controller system.
7852*DF Glass Dust Check Counts the number of occurrences (0 to 65,535) when dust was detected on the scanning glass of the ADF or resets the dust detection counter.
Counting is done only if SP4-020-1 (Dust Check) is switched on.001 Dust Detection Counter [0 to 65535 / 0 / 1 /step]
002Dust Detection Clear Counter
7853 Replacement Counter
001PCD [0 to 255 / 0 / 1 ] Displays the replacement counter of the PCD (Drum and Development unit).
002Transfer [0 to 255 / 0 / 1 ] Displays the replacement counter of the transfer unit.
003Fuser [0 to 255 / 0 / 1 ] Displays the replacement counter of the fusing unit.
004Web [0 to 255 / 0 / 1 ] Displays the replacement counter of the cleaning web.
7906 Prev Counter
001Page: PCD [0 to 999999 / 0 / 1 page] Displays the counter (pages) of the previous PCD
002Page: Transfer [0 to 999999 / 0 / 1 page] Displays the previous counter (pages) of the previous transfer unit.
003Page: Fuser [0 to 999999 / 0 / 1 page] Displays the previous counter (pages) of the previous fusing unit.
004Rotation: PCD [0 to 999999999 / 0 / 1 mm ] Displays the previous counter (rotations) of the previous PCD
005Rotation: Transfer [0 to 999999999 / 0 / 1 mm ] Displays the previous counter (rotations) of the previous transfer unit.
006Rotation: Fuser [0 to 999999999 / 0 / 1 mm ] Displays the previous counter (rotations/PM %) of the previous fusing unit.
007Rotation(%) CD
[0 to 255 / 0 / 1 mm] Displays the previous counter (rotations/PM %) of the previous PCD
008Rotation(%):Transfer [0 to 255 / 0 / 1 mm] Displays the previous counter (rotations/PM %) of the previous transfer unit.
009Rotation(%):Fuser [0 to 255 / 0 / 1 mm] Displays the previous counter (rotations/PM %) of the previous fusing unit.
010Rotation(%):Web [0 to 255 / 0 / 1 %] Displays the previous counter (rotations/PM %) of the previous cleaning web. Service Tables
7950 Replacement Date
001PCD Displays the replacement date of the PCD.
002Transfer Displays the replacement date of the transfer unit.
003Fuser Displays the replacement date of the fusing unit.
004Web Displays the replacement date of the web unit.
7951 Remaining Counter
001PCD(Page) [0 to 255 / 255 / 1 days] Displays the remaining counter (pages) of the PCD.
002Transfer(Page) [0 to 255 / 255 / 1 days] Displays the remaining counter (pages) of the transfer unit.
003Fuser(Page) [0 to 255 / 255 / 1 days] Displays the remaining counter (pages) of the fusing unit.
005PCD(Rotation) [0 to 255 / 255 / 1 days] Displays the remaining counter (rotations) of the PCD.
006Transfer(Rotation) [0 to 255 / 255 / 1 days] Displays the remaining counter (rotations) of the transfer unit.
007Fuser(Rotation) [0 to 255 / 255 / 1 days] Displays the remaining counter (rotations) of the fusing unit.
009PCD (%) [0 to 255 / 100 / 1 %] Displays the remaining counter (%) of the PCD.
010Transfer (%) [0 to 255 / 100 / 1 %] Displays the remaining counter (%) of the transfer unit.
011Fuser (%) [0 to 255 / 100 / 1 %] Displays the remaining counter (%) of the fusing unit.
013Web (%) [0 to 255 / 100 / 1 %] Displays the remaining counter (%) of the cleaning web.
7952PM Yield Setting Sets the each yield of the following.
001PCD(Page) [0 to 99999999/ 160000 / 1 sheet] Sets the PM yield of the PCD (Pages).
002Transfer(Page) [0 to 9999999 / 160000 / 1 sheet] Sets the PM yield of the transfer unit (Pages).
003Fuser(Page) [0 to 9999999 / 160000 / 1 sheet] Sets the PM yield of the fusing unit (Pages).
PCD(Rotation)C2b: [0 to 999999999 / 71990000 / 1 mm]
C2c: [0 to 999999999 / 75500000 / 1 mm]Sets the PM yield of the PCD (Rotations).
Transfer(Rotation)C2b: [0 to 999999999 / 62770000 / 1 mm]
C2c: [0 to 999999999 / 65420000 / 1 mm]Sets the PM yield of the transfer unit (Rotations).
Fuser(Rotation)C2b: [0 to 999999999 / 54880000 / 1 mm]
C2b: [0 to 999999999 / 55800000 / 1 mm]Sets the PM yield of the fusing unit (Rotations).
009Web (%) [0 to 255 / 92 / 1 %] Sets the PM yield (%) of the web unit.
021Day Threshold: PCD [1 to 30 / 15 / 1 days] Adjusts the threshold day for the near end for the PCD.
022Day Threshold: Transfer Unit [1 to 30 / 15 / 1 days] Adjusts the threshold day for the near end for the transfer unit.
023Day Threshold: Fusing Unit [1 to 30 / 15 / 1 days] Adjusts the threshold day for the near end for the fusing unit. Service Tables
7953 Operation Env Log
001T<10 [0 to 99999999 / 0 / 1 mm] Displays the PCU rotation distance in the environment: T<10°C
00210<=T<=17 [0 to 99999999 / 0 / 1 mm] Displays the PCU rotation distance in the environment: 10°C<=T<=17°C
00317<T<23 [0 to 99999999 / 0 / 1 mm] Displays the PCU rotation distance in the environment: 17<=T<=23
00423<=T<=27 [0 to 99999999 / 0 / 1 mm] Displays the PCU rotation distance of the environment: 23<=T<=27
00527<=T<=32 [0 to 99999999 / 0 / 1 mm] Displays the PCU rotation distance of the environment: 27<=T<=32
00632<T [0 to 99999999 / 0 / 1 mm] Displays the PCU rotation distance of the environment: 32<T
7954Env Log Clear Resets the environment logs (SP7953).
MAIN SP TABLES-8
SP8-XXX: DATA LOG 2
Many of these counters are provided for features that are currently not available, such as sending color faxes, and so on. However, here are some Group 8codes that when used in combination with others, can provide useful information.
SP Numbers What They Do SP8211 to SP8216 The number of pages scanned to the document server. SP8401 to SP8406 The number of pages printed from the document server. SP8691 to SP8696 The number of pages sent from the document server.
Specifically, the following questions can be answered: How is the document server actually being used?
What application is using the document server most frequently? What data in the document server is being reused?
Most of the SPs in this group are prefixed with a letter that indicates the mode of operation (the mode of operation is referred to as an 'application'). Before reading the Group 8 Service Table, make sure that you understand what these prefixes mean.
Prefixes What It Means
T:
Total: (Grand Total).Grand total of the items counted for all applications (C, F, P, etc.). C: Copy application.
Totals (pages, jobs, etc.) executed for each application when the job was not stored on the document server.F: Fax application. P: Print application. S: Scan application.
L:
Local storage (document server)Totals (jobs, pages, etc.) for the document server. The L: counters work differently case by case.
Sometimes, they count jobs/pages stored on the document server; this can be in document server mode (from the document server window), or from another mode, such as from a printer driver or by pressing the Store File button in the Copy mode window. Sometimes, they include occasions when the user uses a file that is already on the document server. Each counter will be discussed case by case.
O:Other applications (external network applications, for example) Refers to network applications such as Web Image Monitor. Utilities developed with the SDK (Software Development Kit) will also be counted with this group in the future.
The Group 8 SP codes are limited to 17 characters, forced by the necessity of displaying them on the small LCDs of printers and faxes that also use these SPs. Read over the list of abbreviations below and refer to it again if you see the name of an SP that you do not understand.
Service Tables
Key for Abbreviations
Abbreviation What It Means / "By", e.g. "T:Jobs/Apl" = Total Jobs "by" Application > More (2> "2 or more", 4> "4 or more" AddBook Address Book Apl Application B/W Black & White Bk Black C Cyan ColCr Color Create ColMode Color Mode Abbreviation What It Means Comb Combine Comp Compression Deliv Delivery
DesAplDesignated Application. The application (Copy, Fax, Scan, Print) used to store the job on the document server, for example. Dev Counter Development Count, no. of pages developed. Dup, Duplex Duplex, printing on both sides Emul Emulation FC Full Color FIN Post-print processing, i.e. finishing (punching, stapling, etc.) Full Bleed No Margins GenCopy Generation Copy Mode
GPCGet Print Counter. For jobs 10 pages or less, this counter does not count up. For jobs larger than 10 pages, this counter counts up by the number that is in excess of 10 (e.g., for an 11-page job, the counter counts up 11-10 =1) IFax Internet Fax
ImgEdtImage Edit performed on the original with the copier GUI, e.g. border removal, adding stamps, page numbers, etc. K Black (YMCK) LS Local Storage. Refers to the document server. LSize Large (paper) Size Mag Magnification MC One color (monochrome) Abbreviation What It Means
NRSNew Remote Service, which allows a service center to monitor machines remotely. "NRS" is used overseas, "CSS" is used in Japan. Org Original for scanning OrgJam Original Jam
Palm 2Print Job Manager/Desk Top Editor: A pair of utilities that allows print jobs to be distributed evenly among the printers on the network, and allows files to moved around, combined, and converted to different formats. PC Personal Computer
PGSPages. A page is the total scanned surface of the original. Duplex pages count as two pages, and A3 simplex count as two pages if the A3/DLT counter SP is switched ON. PJob Print Jobs Ppr Paper PrtJam Printer (plotter) Jam PrtPGS Print Pages
RRed (Toner Remaining). Applies to the wide format model A2 only. This machine is under development and currently not available. Rez Resolution SC Service Code (Error SC code displayed) Scn Scan Sim, Simplex Simplex, printing on 1 side. S-to-Email Scan-to-E-mail
SMCSMC report printed with SP5990. All of the Group 8counters are recorded in the SMC report. Service Tables
Abbreviation What It Means Svr Server TonEnd Toner End TonSave Toner Save TXJob Send, Transmission YMC Yellow, Magenta, Cyan YMCK Yellow, Magenta, Cyan, BlacK
- All of the Group 8 SPs are reset with SP5 801-1 Memory All Clear.
8001 | T:Total Jobs | These SPs count the number of times each application is used to do a job. [0 to 9999999 / 0 / 1] Note: The L: counter is the total number of times the other applications are used to send a job to the document server, plus the number of times a file already on the document server is used. |
8002 | C:Total Jobs | |
8003 | F:Total Jobs | |
8004 | P:Total Jobs | |
8005 | S:Total Jobs | |
8006 | L:Total Jobs |
- These SPs reveal the number of times an application is used, not the number of pages processed.
- When an application is opened for image input or output, this counts as one job.
- Interrupted jobs (paper jams, etc.) are counted, even though they do not finish.
- Only jobs executed by the customer are counted. Jobs executed by the customer engineer using the SP modes are not counted.
- When using secure printing (when a password is required to start the print job), the job is counted at the time when either "Delete Data" or "Specify Output" is specified.
- A job is counted as a fax job when the job is stored for sending.
- When a fax is received to fax memory, the F: counter increments but the L: counter does not (the document server is not used).
- A fax broadcast counts as one job for the F: counter (the fax destinations in the broadcast
are not counted separately). - A fax broadcast is counted only after all the faxes have been sent to their destinations. If one transmission generates an error, then the broadcast will not be counted until the transmission has been completed.
- A printed fax report counts as one job for the F: counter.
- The F: counter does not distinguish between fax sending or receiving.
- When a copy job on the document server is printed, SP8022 also increments, and when a print job stored on the document server is printed, SP8024 also increments.
- When an original is both copied and stored on the document server, the C: and L: counters both increment.
- When a print job is stored on the document server, only the L: counter increments.
- When the user presses the Document Server button to store the job on the document server, only the L: counter increments.
- When the user enters document server mode and prints data stored on the document server, only the L: counter increments.
- When an image received from Palm 2 is received and stored, the L: counter increments.
Service Tables
- When the customer prints a report (user code list, for example), the O: counter increments. However, for fax reports and reports executed from the fax application, the F: counter increments.
8011 T:Jobs/LS
These SPs count the number of jobs stored to the document server by each application, to reveal how local storage is being used for input.
The L: counter counts the number of jobs stored from within the document server mode screen at the operation panel.8012 C:Jobs/LS 8013 F:Jobs/LS 8014 P:Jobs/LS 8015 S:Jobs/LS 8016 L:Jobs/LS 8017 O:Jobs/LS
- When a scan job is sent to the document server, the S: counter increments. When you enter document server mode and then scan an original, the L: counter increments.
- When a print job is sent to the document server, the P: counter increments.
- When a network application sends data to the document server, the O: counter increments.
- When an image from Palm 2 is stored on the document server, the O: counter increments.
- When a fax is sent to the document server, the F: counter increments.
8021 T job/LS
These SPs reveal how files printed from the document server were stored on the document server originally. [0 to 9999999 / 0 / 1]
The L: counter counts the number of jobs stored from within the document server mode screen at the operation panel.8022 C job/LS
8023 F job/LS
8024 P job/LS
8025 S job/LS
8026 L job/LS
8027 O job/LS
- When a copy job stored on the document server is printed with another application, the C: counter increments.
- When an application like DeskTopBinder merges a copy job that was stored on the document server with a print job that was stored on the document server, the C: and P: counters both increment.
- When a job already on the document server is printed with another application, the L: counter increments.
- When a scanner job stored on the document server is printed with another application, the S: counter increments. If the original was scanned from within document server mode, then the L: counter increments.
- When images stored on the document server by a network application (including Palm 2), are printed with another application, the O: counter increments.
- When a copy job stored on the document server is printed with a network application (Web Image Monitor, for example), the C: counter increments.
- When a fax on the document server is printed, the F: counter increments.
8031 T job/DesApl
These SPs reveal what applications were used to output documents from the document server.
The L: counter counts the number of jobs printed from within the document server mode screen at the operation panel.8032 C job/DesApl
8033 F job/DesApl
8034 P job/DesApl
8035 S job/DesApl
8036 L job/DesApl
8037 O job/DesApl
- When documents already stored on the document server are printed, the count for the application that started the print job is incremented.
Service Tables
- When the print job is started from a network application (Desk Top Binder, Web Image Monitor, etc.) the L: counter increments.
8041 T:TX Jobs/LS
These SPs count the applications that stored files on the document server that were later accessed for transmission over the telephone line or over a network (attached to an e-mail, or as a fax image by I-Fax).
Note: Jobs merged for sending are counted separately. The L: counter counts the number of jobs scanned from within the document server mode screen at the operation panel.8042 C:TX Jobs/LS 8043 F:TX Jobs/LS 8044 P:TX Jobs/LS 8045 S:TX Jobs/LS 8046 L:TX Jobs/LS 8047 O:TX Jobs/LS
- When a stored copy job is sent from the document server, the C: counter increments.
- When images stored on the document server by a network application or Palm2 are sent as an e-mail, the O: counter increments.
8051 T:TX Jobs/DesApl
These SPs count the applications used to send files from the document server over the telephone line or over a network (attached to an e-mail, or as a fax image by I-Fax). Jobs merged for sending are counted separately.
The L: counter counts the number of jobs sent from within the document server mode screen at the operation panel.8052 C:TX Jobs/DesApl 8053 F:TX Jobs/DesApl 8054 P:TX Jobs/DesApl 8055 S:TX Jobs/DesApl 8056 L:TX Jobs/DesApl 8057 O:TX Jobs/DesApl
- If the send is started from Desk Top Binder or Web Image Monitor, for example, then the O: counter increments.
8061 | T:FIN Jobs | [0 to 9999999 / 0 / 1] |
These SPs total the finishing methods. The finishing method is specified by the application. | ||
8062 | C:FIN Jobs | [0 to 9999999 / 0 / 1] |
These SPs total finishing methods for copy jobs only. The finishing method is specified by the application. | ||
8063 | F:FIN Jobs | [0 to 9999999 / 0 / 1] |
These SPs total finishing methods for fax jobs only. The finishing method is specified by the application. Note: Finishing features for fax jobs are not available at this time. | ||
8064 | P:FIN Jobs | [0 to 9999999 / 0 / 1] |
These SPs total finishing methods for print jobs only. The finishing method is specified by the application. | ||
8065 | S:FIN Jobs | [0 to 9999999 / 0 / 1] |
These SPs total finishing methods for scan jobs only. The finishing method is specified by the application. Note: Finishing features for scan jobs are not available at this time. |
8066 | L:FIN Jobs | [0 to 9999999 / 0 / 1] |
These SPs total finishing methods for jobs output from within the document server mode screen at the operation panel. The finishing method is specified from the print window within document server mode. | ||
8067 | O:FIN Jobs | [0 to 9999999 / 0 / 1] |
These SPs total finishing methods for jobs executed by an external application, over the network. The finishing method is specified by the application. | ||
806x 1 | Sort | Number of jobs started in Sort mode. When a stored copy job is set for Sort and then stored on the document server, the L: counter increments. (See SP8066 1) |
806x 2 | Stack | Number of jobs started out of Sort mode. |
806x 3 | Staple | Number of jobs started in Staple mode. |
806x 4 | Booklet | Number of jobs started in Booklet mode. If the machine is in staple mode, the Staple counter also increments. |
806x 5 | Z-Fold | Number of jobs started In any mode other than the Booklet mode and set for folding (Z-fold). |
806x 6 | Punch | Number of jobs started in Punch mode. When Punch is set for a print job, the P: counter increments. (See SP8064 6.) |
806x 7 | Other | Reserved. Not used |
806x 8 | Inside-Fold | Number of jobs started In any mode other than the Booklet mode and set for folding (Inside-fold). |
806x 9 | Three-IN-Fold | Letter Fold-in Not Used |
806x 10 | Three-OUT-Fold | Letter Fold-out Not Used |
806x 11 | Four-Fold | Double Parallel Fold Not Used |
806x 12 | KANNON-Fold | Gate Fold Not Used |
Service Tables
