Blank Margin
Main Scan Magnification
Parallelogram Image Adjustment
Do the following procedure if a parallelogram prints while adjusting the printing registration or printing margin using a trimming area pattern.
The following procedure should be done after adjusting the side-to-side registration for each paper tray station.
Use SP2-109-1 No. 14 (Trimming Area) to determine whether a parallelogram image appears. If the parallelogram pattern appears, perform the following procedure.
- If the leading edge/side-to-side registration cannot be adjusted within specifications, adjust the leading/left side edge blank margin.
- Check the trailing edge [A], right edge , leading edge [C] and left edge [D] blank margins, and adjust them with the following SP modes.
SP No. Specification Leading Edge SP2-103-1
3.0 mm [0.0 to 9.0 mm]Trailing Edge SP2-103-2 Left SP2-103-3
2.0 mm [0.0 to 9.0 mm]Right SP2-103-4 Duplex: Trailing Edge: L Size: Plain
SP2-103-5
1.0 mm [0.0 to 4.0 mm]Duplex: Trailing Edge: M Size: Plain
SP2-103-6
0.8 mm [0.0 to 4.0 mm]Duplex: Trailing Edge: S Size: Plain
SP2-103-7
0.6 mm [0.0 to 4.0 mm]Duplex: Left: Plain SP2-103-8
0.3 mm [0.0 to 1.5 mm]Duplex: Right: Plain SP2-103-9 SP No. Specification Duplex: Trailing Edge: L Size: Thick
SP2-103-100.8 mm [0.0 to 4.0 mm] Duplex: Trailing Edge: M Size: Thick
SP2-103-11
0.6 mm [0.0 to 4.0 mm]Duplex: Trailing Edge: S Size: Thick
SP2-103-12
0.4 mm [0.0 to 4.0 mm]Duplex: Left: Thick SP2-103-13
0.1 mm [0.0 to 1.5 mm]Duplex: Right: Thick SP2-103-14
- L Size: Paper length is 297.1 mm or more.
- M Size: Paper length is 216.1 to 297 mm
- S Size: Paper length is 216 mm or less.
- Use SP2-109-001 no 5 (Grid Pattern) to print a single dot pattern.
- Check magnification, and then SP2-102 (Magnification Adjustment Main Scan) to adjust magnification if required. Specification: ±2%.
- Laser unit [A]
- Bracket
[*]Install adjustment cam [C] (P/N: A2309003).
[*]Secure positioning pin [D] (P/N A2309004) with the two screws removed with the bracket . Do not tighten the screws at this time.
[*]To adjust the position of the laser unit [E]
- Adjust the laser unit position by turning the adjustment cam. (See the illustration above.)
- Tighten the adjustment bracket.
- Print the trimming area pattern to check the image. If the results are not satisfactory, repeat steps 5-1) to 5-3).
SCANNING
Before doing the following scanner adjustments, perform or check the printing registration/side-to-side adjustment and the blank margin adjustment.
- Use the S5S test chart to perform the following adjustments.
Registration: Platen Mode
- Place the test chart on the exposure glass and make a copy from one of the feed stations.
- Check the leading edge [A] and side-to-side registration, and adjust them with the following SP modes if necessary.
SP No. Specification Leading Edge SP4-010-1 0 ±2.0 mm Side-to-side SP4-011-1 0 ±2.5 mm
Use the S5S test chart to perform the following adjustment.
Sub Scan Magnification
- Check the magnification ratio. Use SP4-008 (Scanner Sub Scan Magnification) to adjust if necessary. Specification: ±0.9%.
- Copy Adjustments: Printing/Scanning
[*]ADF
Registration
- Make a temporary test chart as shown above using A3/DLT paper.
- Place the temporary test chart on the ADF and make a copy from one of the feed stations.
- Check the registration, and adjust using the following SP modes if necessary.
SP No. Specification Side-to-side: 1st side SP6-006-1
0.0 mm ±3 mmSide-to-side: 2nd side SP6-006-2 Leading Edge SP6-006-3 0.0 mm ±5 mm Leading Edge: 1st side SP6-006-5 0.0 mm ±3 mm Leading Edge: 2nd side SP6-006-6 0.0 mm ±2.5 mm Trailing Erase edge: SP6-006-7 0.0 mm ±10.0 mm TOUCH SCREEN CALIBRATION
After clearing the memory, replacing the operation panel or NVRAM, or if the touch panel detection function is not working correctly, follow this procedure to calibrate the touch screen.
- Do not attempt to use items [2] to [7] on the Self-Diagnostic Menu. These items are for design use only.
- Press
- On the touch screen press "Touch Screen Adjust" (or press "1").
- Use a pointed (not sharp!) tool to press the upper left mark
- Press the lower right mark
- Touch a few spots on the touch panel to confirm that the marker (+) appears exactly where the screen is touched.
If the + mark does not appear where the screen is touched, press Cancel and repeat from Step 2. - When you are finished, press [#] OK on the screen (or press
- Touch [#] Exit on the screen to close the Self-Diagnostic menu and save the calibration settings.
SERVICE TABLES
RE V IS ION H IST ORY | ||
SERVICE TABLES
SERVICE PROGRAM MODE
- Never turn off the main power switch when the power LED is lit or flashing. To avoid damaging the hard disk or memory, press the operation switch to switch the power off, wait for the power LED to go off, and then switch the main power switch off.
- The main power LED lights or flashes while the platen cover or ARDF is open, while the main machine is communicating with a facsimile or the network server, or while the machine is accessing the hard disk or memory for reading or writing data.
SERVICE PROGRAM MODE OPERATION
The service program (SP) mode is used to check electrical data, change modes, and adjust values.
Service Tables
Service Mode Lock/Unlock
At locations where the machine contains sensitive data, the customer engineer cannot operate the machine until the Administrator turns the service mode lock off. This function makes sure that work on the machine is always done with the permission of the Administrator.- If you cannot go into the SP mode, ask the Administrator to log in with the User Tool and then set "Service Mode Lock" to OFF. After he or she logs in:
[User Tools] > System Settings > Administrator Tools > Service Mode Lock > OFF- This unlocks the machine and lets you get access to all the SP codes.
- The service technician can do servicing on the machine and turn the machine off and on. It is not necessary to ask the Administrator to log in again each time the machine is turned on.
- If you must use the printer bit switches, go into the SP mode and set SP5169 to "1".
- After machine servicing is completed:
- Change SP5169 from "1" to "0".
- Turn the machine off and on.
- Tell the administrator that you completed servicing the machine.
- The administrator will then set the "Service Mode Lock" to ON.
SERVICE PROGRAM MODE TABLES
Please note these general changes in this section:- Group 8(Data Log 2) is a new group of counters.
- Along with the addition of Group 8, many of the Group 7 counters have been removed.
Service Table Key
Notation What it means
[range / default / step]Example: [-9 to +9 / 0 / 0.1 mm step]. The setting can be adjusted in the range ±9, value reset to +3.0 after an NVRAM reset, and the value can be changed in 0.1 mm steps with each key press.
*Value stored in NVRAM. After a RAM reset, this default value (factory setting) is restored. DFU Denotes "Design or Factory Use". Do not change this value.
Japan onlyThe feature or item is for Japan only. Do not change this value. C2b D129 C2c D130 SSP This denotes a "Special Service Program" mode.
SP TABLES
There are the most commonly used SP codes in the "Main SP Tables - 1 to - 9" of "Main Chapters".
See "Appendices" for the following information:- System SP Tables
- Printer SP Tables
Service Tables
- Scanner SP Tables
MAIN SP TABLES-1
SP1-XXX: FEED
1001*Leading Edge Registration Adjusts the leading edge registration by changing the registration clutch operation timing. 001 Tray: Plain
[–9 to 9/ 0 / 0.1 mm step]002 Tray: Thick 1 003 Tray: Thick 2 004 By-pass: Plain 005 By-pass: Thick 1 006 By-pass: Thick 2 007 Duplex: Plain 008 Duplex: Thick 1
1002*Side-to-Side Registration Adjusts the side to side registration by changing the laser main scan start position for each mode. 001 By-pass
[–4 to 4/ 0 / 0.1 mm step]002 Tray 1 003 Tray 2 004 Tray 3 005 Tray 4 006 LCT 007 Duplex
1003*Registration Buckle Adjustment Adjusts the paper feed motor timing. Paper feed motor timing determines the amount of paper buckle at Registration. (A "+" setting causes more buckling.) 001 Tray 1: Plain
[-9 to 5 / -4 / 1 mm step]002 Tray 1: Thick 1 003 Tray 1: Thick 2 004 Tray 2, 3, 4: Plain 005 Tray 2, 3, 4: Thick1 006 Tray 2, 3, 4: Thick2 007 By-pass: Plain
[-9 to 5 / -2 /1 mm step]008 By-pass: Thick 1 009 By-pass: Thick 2 010 Duplex: Plain [-9 to 5 / -4 / 1 mm step] 011 Duplex: Thick 1 [-9 to 5 / -3 / 1 mm step] 012 LCT: Plain
[-9 to 5 / -4 / 1 mm step]013 LCT: Thick1 014 LCT: Thick2
1007*By-pass Paper Size Detection Controls paper size detection for the by-pass feed table. 001 Detection Timing [-15 to 15 / 0 / 5 mm step]
LG Detection[0 to 1 / 0 / 1]
0: LTSEF, 1: LG
1105*Fusing Temperature Adjustment Allows adjustment of the hot roller temperature at the center and ends of the roller for the quality or thickness of the paper. The hot roller in this machine has two fusing lamps: one heats the center of the roller, the other heats both ends. Each fusing lamp can be adjusted separately.
The "re-load temperature" is the "print ready temperature". When the fusing temperature exceeds this setting, the machine can operate. Do not set up a re-load temperature (Re-load Temp. = Fusing. Temp – SP Value.) that is higher than the SP1-105-2 setting.
Roller CenterC2b: [100 to 170 / 140 / 1 deg]
C2c: [100 to 170 / 150 / 1 deg]Adjusts the fusing temperature at the center of the hot roller.
Roller EndsC2b: [100 to 170 / 145 / 1 deg]
C2c: [100 to 170 / 155 / 1 deg]Adjusts the fusing temperature at the ends of the hot roller.
003Re-load Temp. Minus: Roller Center [0 to 60 / 0 / 1 deg] Sets the reload temperature for the center of the hot roller. This setting depends on the target temperature.
Reload temp. = Target Temp – This SP Setting
004Re-load Temp. Minus: Roller Ends [0 to 60 / 0 / 1 deg] Sets the reload temperature for the ends of the hot roller. This setting depends on the target temperature.
005 to
022The following SPs adjust the fusing temperature at the center or ends of the hot roller for each paper type. - Do not set a temperature that is higher than the setting for SP1105 1 (Roller Center: Trays)
- Do not set a temperature that is higher than the setting for SP1105 2 (Roller Ends: Trays)
Roller Center: M-ThickC2b: [100 to 170 / 145 / 1 deg]
Roller Ends: M-ThickC2b: [100 to 170 / 150 / 1 deg]
C2c: [100 to 170 / 160 / 1 deg]007 Roller Center: Thick 1
[100 to 170 / 130 / 1 deg]008 Roller Ends: Thick 1 009 Roller Center: Thick 2
[100 to 170 / 150/ 1 deg]010 Wait Temp: Center Minus
011
Wait Temp: Ends MinusC2b: [100 to 170 / 130 / 1 deg]
C2c: [100 to 170 / 140 / 1 deg]
012
Roller Ends: ThinC2b: [100 to 170 / 135 / 1 deg]
C2c: [100 to 170 / 145 / 1 deg]013 Roller Center: OHP: Plain [100 to 170 / 150/ 1 deg] 014 Roller Ends: OHP: Plain
[100 to 170 / 155/ 1 deg]015 Roller Center: OHP: Thick 016 Roller Ends: OHP: Thick [100 to 170 / 160/ 1 deg]
017
Roller Center: Special 1C2b: [100 to 170 / 140 / 1 deg]
018
Roller Ends: Special 1C2b: [100 to 170 / 145 / 1 deg]
019
Roller Center: Special 2C2b: [100 to 170 / 140 / 1 deg]
020
Roller Ends: Special 2C2b: [100 to 170 / 145 / 1 deg]
021
Roller Center: Special 3C2b: [100 to 170 / 140 / 1 deg]
022
Roller Ends: Special 3C2b: [100 to 170 / 145 / 1 deg]
023 Feed Waiting: Plain Turns the feed waiting mode on or off for each paper type.
[0 to 1 / 0 / 1] 0=Off, 1=On
The paper waits at the registration roller until the fusing temperature reaches the prescribed temperature (adjustable with SP1105-028 to -37).
If you enable this feature, also set SP 1105-38 to a convenient value for the customer.024 Feed Waiting: M-Thick 025 Feed Waiting: Thick 1 026 Feed Waiting: Thick 2
027
Feed Waiting: Thin028 Feed Wait: Center Minus: Plain
Adjusts the offset value for each re-load temperature to exit the feed waiting mode.
[0 to 60 / 0 / 1 deg]029 Feed Wait: Ends Minus: Plain 030 Feed Wait: Center Minus: M-Thick 031 Feed Wait: Ends Minus: M-Thick 032 Feed Wait: Center Minus: Thick 1 033 Feed Wait: Ends Minus: Thick 1 034 Feed Wait: Center Minus: Thick 2 035 Feed Wait: Ends Minus: Thick 2 036 Feed Wait: Center Minus: Thin 037 Feed Wait: Ends Minus: Thin
038
Feed Waiting: Maximum TimeSets the maximum feed waiting time. [0 to 30 / 0 / 1 sec]
The paper is fed when the time specified with this SP has passed even though the fusing temperature has not reached the prescribed temperature.
0: Disabled.
1106 Fusing Temperature Display 001 Roller Center Displays the temperature of the fusing unit.
[-20 to 250 / 0 / 1 deg]
Roller Ends003 Machine Inside at Power On Displays the temperature inside the machine.
Machine Inside
1801*MotorSpeedAdjust Adjusts the speeds of each motor. Each step decreases or increases motor speed in 0.05% increments
Regist: Registration motor, Feed: Feed motor,
Duplex: Duplex/By-pass motor, Inverter: Duplex inverter motor, Exit: Paper exit motor, Bridge: Bridge unit drive motor,
OpcMot: Drum motor, TransferMot: Transfer/Development Motor, FusingMot: Fusing motor,
DevPuddleMot: Development Paddle motor001 Regist: 90: Thick 2
[-2 to 2 / 0.4 / 0.05 %]002 Regist: 154: Thick 1 003 Regist: 180: Plain 004 Regist: 230: Plain 005 Feed: 90: Thick 2
[-2 to 2 / -0.4 / 0.05 %]006 Feed: 154: Thick 1 007 Feed: 180: Plain
[-2 to 2 / -1 / 0.05 %]008 Feed: 230: Plain 009 Duplex_CW: 90: Thick 2
[-4 to 4 / 0.4 / 0.1 %]010 Duplex_CW: 154: Thick 1 011 Duplex_CW: 180: Plain [-4 to 4 / -2.3 / 0.1 %] 012 Duplex_CW: 230: Plain 013 Duplex_CCW: 90: Thick 2
[-4 to 4 / 0.4 / 0.1 %]014 Duplex_CCW: 154: Thick 1 015 Duplex_CCW: 180: Plain
[-4 to 4 / -0.2 / 0.1 %]016 Duplex_CCW: 230: Plain 017 Inverter_CW: 90: Thick 2
[-4 to 4 / 0 / 0.1 %]018 Inverter_CW: 154: Thick 1 019 Inverter_CW: 180: Plain 020 Inverter_CW: 230: Plain 021 Inverter_CCW: 90: Thick 2 022 Inverter_CCW: 154: Thick 1 023 Inverter_CCW: 180: Plain 024 Inverter_CCW: 230: Plain 025 Exit_CW: 90: Thick 2 026 Exit_CW: 154: Thick 1 027 Exit_CW: 180: Plain 028 Exit_CW: 230: Plain 029 Bridge: 90: Thick 2 030 Bridge: 154: Thick 1 031 Bridge: 180: Plain 032 Bridge: 230: Plain 033 OpcMot:90
[-4 to 4 / 0 / 0.01 %]034 OpcMot:154 035 OpcMot:180 036 OpcMot:230 037 TransferMot:90 038 TransferMot:154 039 TransferMot:180 040 TransferMot:230 041 FusingMot:90 042 FusingMot:154 043 FusingMot:180 044 FusingMot:230 045 DevPuddleMot [-4 to 4 / 0 / 0.1 %]
1902* Cleaning Web Setting
001Web Consumption [0 to 120 / 0 / 1 %] Displays the consumed amount of the web roll.
Web Motor IntervalC2b: [3 to 130 / 8.4 / 0.1 sec]
C2c: [3 to 130 / 6.7 / 0.1 sec]Adjusts the interval for web motor rotation.
003Web Motor Time [0.3 to 10 / 4.2 / 0.1 sec] Adjusts the rotation time of the web motor.
Web Near End SettingC2b: EU [0 to 100 / 90 / 1 %]
C2b: ASIA/NA [0 to 100 / 92 / 1 %]
C2c: EU [0 to 100 / 90 / 1 %]
C2c: ASIA/NA [0 to 100 / 92 / 1 %]Adjusts the threshold for web near end.
005Web Motor Interval: Thick 1 [3 to 130 / 11.2 / 0.1 sec] Adjusts the interval for web motor rotation (thick 1).
006Web Motor Interval: Thick 2 [3 to 130 / 16.8 / 0.1 sec] Adjusts the interval for web motor rotation (thick 2).
007Paper Interval Time [0 to 10 / 5 / 1 sec] Adjusts the threshold for paper feeding. When the time between trailing edge detection and leading edge detection is within the value of this setting, the machine determines that the paper is still being fed.
008Web Motor Setting: Web End [0 to 60 / 27 / 1 sec] Adjusts the motor rotation time after the web end.
009Web Motor Rotation: Power On [0 to 10 / 0 / 1 times] Adjusts the number of web motor rotations at the re-load state.
010Web Motor Interval: Pre-idle [0 to 30 / 0 / 1 sec] Adjusts the motor waiting time after the fusing motor idling.
011Web Motor Rotation: Pre-idle [0 to 10 / 0 / 1 times] Adjusts the number of web motor rotations at the fusing idling state.
1950*Tray Lock at Jam [0 or 1 / 0 / 1 ] 0= OFF, 1= ON Not used
MAIN SP TABLES-2
Service Tables
SP2-XXX: DRUM
2005* Bias Control
001Bias Correction 1 [0.1 to 1 / 0.85 / 0.05 step] Adjusts the lower threshold value for the charge roller correction.
When the value of VSDP/VSG is greater than this value, the charge roller voltage increases by 30 V (e.g., from –500 to –530).
002Bias Correction 2 [0.1 to 1 / 0.9 / 0.05 step] Adjusts the upper threshold value for the charge roller correction.
When the value of VSDP/VSG is greater than this value, the charge roller voltage decreases by 30 V (absolute value).
003Bias Adjustment 1 [1000 to 2000 / 1500 / 10 vol] Adjusts the lower limit value for charge roller voltage correction.
004Bias Adjustment 2 [1000 to 2000 / 2000 / 10 vol] Adjusts the upper limit value for charge roller voltage correction.
005Bias Adjustment 3 [0 to 100 / 30 / 10 vol] Adjusts the correction voltage adjustment step size.
2103*Erase Margin Adjustment Adjusts the erase margin by deleting image data at the margins. L Size: 297.1 mm or more (length)
M Size: 216.1 to 297 mm (length) S Size: 216 mm or less (length)001 Leading Edge
[0 to 9 / 3 / 0.1mm]002 Trailing Edge 003 Left [0 to 9 / 2 / 0.1mm] 004 Right 005 Duplex Trail.: L Size: Plain [0 to 4 / 1 / 0.1mm] 006 Duplex Trail.: M Size: Plain [0 to 4 / 0.8 / 0.1mm] 007 Duplex Trail.: S Size: Plain [0 to 4 / 0.6 / 0.1mm] 008 Duplex Left: Plain
[0 to 1.5 / 0.3 / 0.1mm]009 Duplex Right: Plain 010 Duplex Trail.: L Size: Thick [0 to 4 / 0.8 / 0.1mm] 011 Duplex Trail.: M Size: Thick [0 to 4 / 0.6 / 0.1mm] 012 Duplex Trail.: S Size: Thick [0 to 4 / 0.4 / 0.1mm] 013 Duplex Left: Thick
[0 to 1.5 / 0.1 / 0.1mm]014 Duplex Right: Thick
2105*LD Power Adjustment Adjusts the LD power for each mode.
Each LD power setting is decided by the process control.001 LD1: Copy
[–50 to 79 / -24 (C2b), 5 (C2c) /1 ]002 LD2: Copy 003 LD1: Printer/Fax
[–50 to 79 / -44 (C2b), -25 (C2c)/1 ]004 LD2: Printer/Fax
2109 Test Pattern
Pattern Selection[0 to 24 / 0 /1 ]
Test pattern of the GAVD0: None
1: Vertical Line (1 dot)
2: Vertical Line (2 dot)
3: Horizontal Line (1 dot)
4: Horizontal Line (2 dot) 5: Grid Vertical Line
6: Grid Horizontal Line 7: Grid pattern small 8: Grid Pattern Large
9: Argyle Pattern Small 10: Argyle Pattern Large
11: Independent pattern (1 dot)
12: Independent Pattern (2 dot)
13: Independent Pattern (4 dot)
14: Trimming Area
15: Hound’s Tooth Check (Vertical) 16: Hound’s Tooth Check (Horizontal) 17: Black Band (Horizontal)
18: Black band (Vertical) 19: Checker Flag Pattern
20: Grayscale (Vertical Margin) 21: Grayscale (Horizontal Margin) 22: Two Beam Density Pattern 23: Full Dot Pattern
24:All white Pattern
Density[0 to 15 / 15 /1 ] Set the density of the test pattern which is output in SP2109-001. This SP is not used for the Grayscale patterns.
2220*Vref Setting Adjusts the TD sensor reference voltage (Vref). Change this value after replacing the development unit with another development unit that contains toner.
[1 to 5 / 4 / 0.01 ]- Check the value of SP2-220 in both the machine containing the test unit and the machine that you are going to move it to.
- Install the test development unit, and then input the VREF for this unit into SP2-220.
- After the test, put back the old development unit, and change SP2-220 back to the original value.
2221*Reverse Interval Drum,Transfer [0 to 2000 / 0 / 1 sheets] Adjusts the threshold for the reverse rotation of the drum and development/transfer motors. This helps the drum and transfer belt cleaning operations. This reverse rotation will interrupt a multiple printing job.
2801TD Sensor Initial Setting Initialization Performs the TD sensor initial setting and allows the service technician to enter the lot number of the developer. (The lot number is embossed on the edge of the developer package.) This SP mode controls the voltage applied to the TD sensor to make the TD sensor output about 3.0 V. Press "Execute" to start. After finishing this, the TD sensor output voltage is displayed.
Use this mode only after installing the machine, changing the TD sensor, or adding new developer.
2960*Toner Overflow Sensor [0 = OFF, 1= ON] Selects whether or not the toner overflow sensor is activated.
2972*Grayscale Limit (SSP) Controls the halftone density level to prevent deterioration of the OPC. The halftone density is detected by the ID sensor, and the machine adjusts the intensity of the LD beam according to the upper/lower limit setting.
001Upper Limit [0 to 100 / 58 (C2b), 63 (C2c)/ 1vol ] Defines the upper limit for grayscale.
A larger value allows a wider range of halftones at the pale end of the scale. If the image contains pale areas with fuzzy borders surrounded by dark areas, reduce this value to make the borders clearer.
002Lower Limit [0 to 100 / 52 (C2b), 57 (C2c) / 1vol ] Defines the lower limit for grayscale.
A smaller value allows a wider range of halftones at the dark end of the scale.
2973*Grayscale Cycle (SSP) [0 to 1000 / 100 / 10 sheets ] Set s the halftone operation interval in order to prevent deterioration of the OPC. If the number of copies exceeds this setting, at the end of the job, or if the door is opened and closed, charge correction is executed.
2974* Image Density
001Adjustment Mode [1 to 5 / 3 / 1 ] Adjusts image density. Changing this setting adjusts development bias and ID sensor output voltage that in turn raises or lowers image density.
2980*Charge Counter [0 to 1000000 / 0 / 1 sheets ] Set the number of pages to print after toner and carrier initialization before the charge input is increased to compensate for deterioration over time in the polarity of the carrier.
The strength in the polarity of the carrier in the toner will eventually decrease and cause lower charge output. Setting the charge output to increase after a specified number of copies can compensate for this effect.
MAIN SP TABLES-3
SP3-XXX: PROCESS
3001 P Sensor Setting
001*Current [0 to 43 / 13 / 0.1 mA ] Allows you to reset the PWM of the ID sensor LED to avoid a service call error after clearing NVRAM or replacing the NVRAM.
The PWM data is stored by executing SP-3001-2.
002Initialization - Performs the ID sensor initial setting. ID sensor output for the bare drum (VSG) is adjusted automatically to 4.0 ±0.2 V.
Press "Execute" to start. Perform this setting after replacing or cleaning the ID sensor, replacing the drum, or clearing NVRAM.
3045* Toner End Setting DFU 001 ON/OFF [0 to 1 / 0 / 1] 0=Off, 1=On
3902* New PCU Detection (Not used)
ON/OFF Setting[0 to 1 / 0 / 1]
0: On, 1: OffTurns on or off the new unit detection for the transfer belt unit and fusing unit.
MAIN SP TABLES-4
Service Tables
SP4-XXX: SCANNER
4008*Sub Scan Mag. Adjustment Adjusts the magnification of the sub scan direction during scanning. Changing this value changes the scanner motor speed.
[–1 to 1 / 0 / 0.1% ]
4010*L-Edge Regist Adjustment Adjusts the leading edge registration for scanning. [–2 to 2 / 0 / 0.1 mm ]
As you enter a negative value, the image moves toward the leading edge.
4012*Scanner Erase Margin: Scale Adjusts scanning margins for the leading and trailing edges (sub scan) and right and left edge (main scan).
001 Book: Leading Edge [0 to 3 / 1 / 0.1 mm] 002 Book: Trailing Edge [0 to 3 / 0 / 0.1 mm] 003 Book: Left [0 to 3 / 1 / 0.1 mm] 004 Book: Right [0 to 3 / 0 / 0.1 mm] 005 ADF: Leading Edge [0 to 3 / 0 / 0.1 mm] 007 ADF: Right [0 to 3 / 0 / 0.1 mm] 008 ADF: Left [0 to 3 / 0 / 0.1 mm] - Do not adjust unless the customer desires a scanner margin greater than the printer margin.
- These settings are adjusted to erase shadows caused by the gap between the original and the scale of the scanner unit.
4013Scanner Free Run Performs a scanner free run with the exposure lamp on or off. 001 Lamp: OFF
[0 to 1 / 0 / 1] 0=Off, 1=On002 Lamp: ON
4014 Scan 001 HP Detection Enable Scanner free run with HP sensor check. 002 HP Detection Disable Scanner free run without HP sensor check.
4020*Dust Check This function checks the narrow scanning glass of the ADF for dust that can cause black lines in copies. If dust is detected a system banner message is displayed, but processing does not stop.
001Dust Detect: On/Off Issues a warning if there is dust on the narrow scanning glass of the ADF when the original size is detected before a job starts. This function can detect dust on the white plate above the scanning glass, as well as dust on the glass. Sensitivity of the level of detection is adjusted with SP4020-2.
[0 to 1 / 1 / 1]
0: Off. No dust warning.
1: On. Dust warning. This warning does not stop the job.
002 Dust Detect: Lvl - Before switching this setting on, clean the ADF scanning glass and the white plate above the scanning glass.
Adjusts the sensitivity for dust detection on the ADF scanning glass. This SP is available only after SP4020-1 is switched on.
[0 to 8 / 4 / 1]
If you see black streaks in copies when no warning has been issued, raise the setting to increase the level of sensitivity. If warnings are issued when you see not black streaks in copies, lower the setting.
003Dust Reject: Lvl Selects the level of the sub scan line correction when using the ARDF. [0 to 4 / 0 / 1]
0: OFF, 1: Weakest, 2: Weak, 3: Strong, 4: Strongest
- Dust that triggers a warning could move be removed from the glass by the originals in the feed path. If the dust is removed by passing originals, this is not detected and the warning remains on.
- Service Tables
4301APS Operation Check Displays a code that represents the original size detected by the original sensors.
4303APS Min. Size Determines whether an original of non-standard size is detected as A5/HLT size by the APS sensor.
0: No original
1: A5 - lengthwise (SEF) 2: A5 - Sideways (LEF)
If "0" is selected, "Cannot detect original size" will be displayed.
43058K/16K Detection [0 to 3 / 0 / 1 step]
0: Normal Detection ( the machine detects A4/LT size as A4 or LT, depending on the paper size setting)
1: A4-sideways LT-Lengthwise
2: LT-sideways A4-Lenghtwise
3: 8K 16K
4308* Scan Size Detection
001Detection ON/OFF Selects whether the machine detects the original size. [0 to 1 / 1 / 1 step]
4309* Scan Size Detect: Setting
001Original Density Thresh Adjust the density for the scan size detection. [0 to 255 / 18 / 1 step]
002Detection Time Adjust the detection time for scan size detection. [20 to 100 / 60 / 20 msec]
003Lamp ON: Delay Time Adjust the timing when to lamp on for the scan size detection. [0 to 200 / 40 / 20 msec]
004LED PWM Duty Adjust the light value for the scan size detection. [0 to 100 / 60 / 1 %]
4310Scan Size Detect Value [0 to 255 / 0 / 1 digit] Displays the scanned data for the original width detection. 001 S1: R 002 S1: G 003 S1: B 004 S2: R 005 S2: G 006 S2: B 007 S3: R 008 S3: G 009 S3: B
Service Tables
- Each detection point (S1, S2, S3) in SP4310 is as follows.
4417IPU Test Pattern Selects the IPU test Pattern.
Test Pattern[0 to 28 / 0 / 1] 0: Scanned image 15: Gray pattern (1) 1: Gradation main scan A 16: Gray pattern (2) 2: Gradation main scan B 17: Gray pattern (3) 3: Gradation main scan C 18: Shading pattern 4: Gradation main scan D 19: Thin line pattern 5: Gradation sub scan (1) 20: Scanned + Grid pattern 6: Grid pattern (1) 21: Scanned + Gray scale 7: Slant grid pattern 22: Scanned + Color patch 8: Gradation K 23: Scanned + Slant Grid C 9: Gray patch 16 24: Scanned + Slant Grid D 10: Gray patch 16 (1) 25: Gray Scale 18 text 11: Gray patch 16 (2) 26: Gray Scale 18 photo 12: Gray patch 64 27: Gray Scale 256 text 13: Grid pattern (2) 28: Gray Scale 256 photo 14: Color patch K
4429* Select Copy Data Security 001 Copying Adjusts the density of the embedded message with the copy data security unit.
[0 to 3 / 3 / 1 ]
3: Darkest density002 Scanning 003 Fax Operation
4450 Scan Image Path Selection
001Black Subtraction ON/OFF [0 to 1 / 1 / 1] 0=OFF, 1=ON Uses or does not use the black reduction image path.
002SH ON/OFF [0 to 1 / 0 / 1] 0=OFF, 1=ON Uses or does not use the shading image path.
4540*Printer Vector Correction This SP corrects the printer coverage of 12 hues (RY, YR, YG, etc. x 4 Colors [R, G, B, Option]) for a total of 48 parameters. 001-004 RY Phase: Option/R/G/B
Specifies the printer vector correction value. [0 to 255 / 0 / 1 ]005-008 YR Phase: Option/R/G/B 009-012 YG Phase: Option/R/G/B 013-016 GY Phase: Option/R/G/B 017-020 GC Phase: Option/R/G/B 021-024 CG Phase: Option/R/G/B 025-028 CB Phase: Option/R/G/B 029-032 BC Phase: Option/R/G/B 033-036 BM Phase: Option/R/G/B 037-040 MB Phase: Option/R/G/B 041-044 MR Phase: Option/R/G/B 045-048 RM Phase: Option/R/G/B
4600 SBU Version 001 SBU ID Displays the ID of the SBU. 002 GASBU-N ID Displays the ID of the GASBU. 003 VSP5100 ID Displays the ID of the VSP5100.
4602 Scanner Memory Access
Scanner Memory AccessEnables the read and write check for the SBU registers.
4603 AGC Execution 001 HP Detection Enable Executes the AGC with the scanner detection. 002 HP Detection Disable Executes the AGC with the scanner detection.
4609* Gray Balance Set: R
001Book Scan [-384 to 255 / -46 / 1 digit] Displays the scanning level value (adjustment) for the red signal in Book Scan.
002DF Scan [-384 to 255 / -46 / 1 digit] Displays the scanning level value (adjustment) for the red signal in DF Scan.
4610* Gray Balance Set: G
001Book Scan [-384 to 255 / -20 / 1 digit] Displays the scanning level value (adjustment) for the green signal in Book Scan.
002DF Scan [-384 to 255 / -20 / 1 digit] Displays the scanning level value (adjustment) for the green signal in DF Scan. 4611* Gray Balance Set: B
001Book Scan [-384 to 255 / -28 / 1 digit] Displays the scanning level value (adjustment) for the blue signal in Book Scan.
002DF Scan [-384 to 255 / -28 / 1 digit] Displays the scanning level value (adjustment) for the blue signal in DF Scan.
4623 Black Level Adj. Display
001Latest: RE Color [0 to 16383 / 0 / 1 digit] Displays the black offset value (rough adjustment) for the even red signal in the SBU (color printing speed).
002Latest: RO Color [0 to 16383 / 0 / 1 digit] Displays the black offset value (rough adjustment) for the odd red signal in the SBU (color printing speed).
Service Tables
- RE: Red Even signal, RO: Red Odd signal
4624 Black Level Adj. Display
001Latest: GE Color [0 to 16383 / 0 / 1 digit]
Displays the black offset value (rough adjustment) for the even green signal in the SBU (color printing speed).
002Latest: GO Color [0 to 16383 / 0 / 1 digit]
Displays the black offset value (rough adjustment) for the odd green signal in the SBU (color printing speed).
- GE: Green Even signal, GO: Green Odd signal
4625 Black Level Adj. Display
001Latest: BE Color [0 to 16383 / 0 / 1 digit]
Displays the black offset value (rough adjustment) for the even blue signal in the SBU (color printing speed).
002Latest: BO Color [0 to 16383 / 0 / 1 digit]
Displays the black offset value (rough adjustment) for the odd blue signal in the SBU (color printing speed).
- BE: Blue Even signal, BO: Blue Odd signal
4628Analog Gain Adjust Displays the gain value of the amplifiers on the controller for Red. Only for the color scanner 001 Latest: R Color [0 to 7 / 0 / 1 digit]
4629Analog Gain Adjust Displays the gain value of the amplifiers on the controller for Green. SP4629-003 and -004 are used only for the color scanner model. 001 Latest: G Color [0 to 7 / 0 / 1 digit]
4630Analog Gain Adjust Displays the gain value of the amplifiers on the controller for Blue. 001 Latest: B Color [0 to 7 / 0 / 1 digit]
4631Digital Gain Adjust Displays the gain value of the amplifiers on the controller for RE or RO. 001 Latest: RE Color [0 to 1023 / 0 / 1 digit] 002 Latest RO Color [0 to 1023 / 0 / 1 digit]
4632Digital Gain Adjust Displays the gain value of the amplifiers on the controller for GE or GO. 001 Latest: GE Color [0 to 1023 / 0 / 1 digit] 002 Latest: GO Color [0 to 1023 / 0 / 1 digit]
4633Digital Gain Adjust Displays the gain value of the amplifiers on the controller for BE or BO. 001 Latest: BE Color [0 to 1023 / 0 / 1 digit] 002 Latest: BO Color [0 to 1023 / 0 / 1 digit]
4645Scan Adjust Error Displays the error value of the white level or black level adjustment. 001 White level [0 to 65535 / 0 / 1 digit] 002 Black level [0 to 65535 / 0 / 1 digit]
4647Scanner Hard Error Displays the result of the SBU connection check.
Power-ON[0 to 35535 / 0 / 1 ]
0: OK, 1: SBU connection check failure
If the SBU connection check fails, SC144-001, -002 or
-003 occurs.4654* Black Level Adj. Display
001Latest Correct Value: RE Color [0 to 16383 / 0 / 1 digit ]
Displays the previous black offset value (rough adjustment) for the even red signal in the SBU (color printing speed).
002Last Correct Value: RO Color [0 to 16383 / 0 / 1 digit ]
Displays the previous black offset value (rough adjustment) for the odd red signal in the SBU (color printing speed).
4655* Black Level Adj. Display
001Last Correct Value: GE Color [0 to 16383 / 0 / 1 digit ]
Displays the previous black offset value (rough adjustment) for the even green signal in the SBU (color printing speed).
002Last Correct Value: GO Color [0 to 16383 / 0 / 1 digit ]
4656* Black Level Adj. Display
001Last Correct Value: BE Color [0 to 16383 / 0 / 1 digit ]
Displays the previous black offset value (rough adjustment) for the even blue signal in the SBU (color printing speed).
002Last Correct Value: BO Color [0 to 16383 / 0 / 1 digit ]
Displays the previous black offset value (rough adjustment) for the odd blue signal in the SBU (color printing speed).
Service Tables
4658*Analog Gain Adjust Displays the previous gain value of the amplifiers on the controller for Red. 001 Last Correct Value: R Color [0 to 7 / 0 / 1 digit ]
4659*Analog Gain Adjust Displays the previous gain value of the amplifiers on the controller for Green. SP4659-003 and -004 are used only for the color scanner model. 001 Last Correct Value: G Color [0 to 7 / 0 / 1 digit ]
4660*Analog Gain Adjust Displays the previous gain value of the amplifiers on the controller for Blue. 001 Last Correct Value: B Color [0 to 7 / 0 / 1 digit ]
4661* Digital Gain Adjust
001Last Correct Value: RE Color [0 to 1023 / 0 / 1 digit ]
Displays the previous 2nd black offset value (rough adjustment) for the even red signal in the SBU (color printing speed).
002Last Correct Value: RO Color [0 to 1023 / 0 / 1 digit ]
Displays the previous 2nd black offset value (rough adjustment) for the odd red signal in the SBU (color printing speed).
4662* Digital Gain Adjust
001Last Correct Value: GE Color [0 to 1023 / 0 / 1 digit ]
Displays the previous 2nd black offset value (rough adjustment) for the even green signal in the SBU (color printing speed).
002Last Correct Value: GO Color [0 to 1023 / 0 / 1 digit ]
Displays the previous 2nd black offset value (rough adjustment) for the odd green signal in the SBU (color printing speed).
4663* Digital Gain Adjust
001Last Correct Value: BE Color [0 to 1023 / 0 / 1 digit ]
Displays the previous 2nd black offset value (rough adjustment) for the even blue signal in the SBU (color printing speed).
002Last Correct Value: BO Color [0 to 1023 / 0 / 1 digit ]
Displays the previous 2nd black offset value (rough adjustment) for the odd blue signal in the SBU (color printing speed).
4673 Black Level Adj. Display
001Factory Setting: RE Color [0 to 16383 / 0 / 1 digit ]
Displays the factory setting value of the 2nd black offset level rough adjustment for the even red signal in the SBU (color printing speed).
002Factory Setting: RO Color [0 to 16383 / 0 / 1 digit ]
Displays the factory setting values of the 2nd black offset level rough adjustment for the odd red signal in the SBU (color printing speed).
Service Tables
4674 Black Level Adj. Display
001Factory Setting: GE Color [0 to 16383 / 0 / 1 digit ]
Displays the factory setting value of the 2nd black offset level rough adjustment for the even green signal in the SBU (color printing speed).
002Factory Setting: GO Color [0 to 16383 / 0 / 1 digit ]
Displays the factory setting values of the 2nd black offset level rough adjustment for the odd green signal in the SBU (color printing speed).
4675 Black Level Adj. Display
001Factory Setting: BE Color [0 to 16383 / 0 / 1 digit ]
Displays the factory setting value of the 2nd black offset level rough adjustment for the even blue signal in the SBU (color printing speed).
002Factory Setting: BO Color [0 to 16383 / 0 / 1 digit ]
Displays the factory setting values of the 2nd black offset level rough adjustment for the odd blue signal in the SBU (color printing speed).
4677Analog Gain Adjust Displays the factory setting values of the gain adjustment for Red. SP4677-003 and -004 are used only for the color scanner model. 001 Factory Setting: R [ 0 to 7 / 0 / 1 digit]
4678Analog Gain Adjust Displays the factory setting values of the gain adjustment for Green. SP4678-003 and -004 are used only for the color scanner model. 001 Factory Setting: G [ 0 to 7 / 0 / 1 digit]
4679Analog Gain Adjust Displays the factory setting values of the gain adjustment for Blue. 001 Factory Setting: B [ 0 to 7 / 0 / 1 digit]
4680* Digital Gain Adjust
001Factory Setting: RE Color [0 to 1023 / 0 / 1 digit ]
002Factory Setting: RO Color [0 to 1023 / 0 / 1 digit ]
Displays the gain value of the amplifiers on the controller for odd Red.
4681* Digital Gain Adjust
001Factory Setting: GE Color [0 to 1023 / 0 / 1 digit ]
002Factory Setting: GO Color [0 to 1023 / 0 / 1 digit ]
Displays the gain value of the amplifiers on the controller for odd Green.
4682* Digital Gain Adjust
001Factory Setting: BE Color [0 to 1023 / 0 / 1 digit ]
002Factory Setting: BO Color Displays the gain value of the amplifiers on the controller for odd Blue.
4688*Scan Image Density Adjustment Adjusts the white shading parameter when scanning an image with the ARDF. Adjusts the density level if the ID of outputs made in the DF and Platen mode is different. [80 to 120 / 98 / 1 % ]
4690White Level Peak Read Displays the peak level of the white level scanning. 001 RE
[0 to 1023 / 0 / 1 digit ]002 RO
4691White Level Peak Read Displays the peak level of the white level scanning. 001 GE
[0 to 1023 / 0 / 1 digit ]002 GO
4692White Level Peak Read Displays the peak level of the white level scanning. 001 BE
[0 to 1023 / 0 / 1 digit ]002 BO
4693Black Level Peak Read Displays the peak level of the black level scanning. 001 RE
4694Black Level Peak Read Display the peak level of the black level scanning. 001 GE
4695Black Level Peak Read Display the peak level of the black level scanning. 001 BE
4802 DF Shading FreeRun 001 Lamp OFF [0 to 1 / 0 / 1 ]
Executes the scanner free run of the shading movement with exposure lamp on or off.
Press "OFF" to stop this free run. Otherwise, the free run continues.
Lamp ON
4804
Home PositionMoves the exposure lamp a short distance and immediately returns it to its home position.
Touch [Execute] > "Completed" > [Exit]
4806Carriage Save Moves the exposure lamp a short distance away from the home position and stops.
Do SP4804 to return the exposure lamp to its home position.
- This SP is done before shipping the machine to another location.
- Cycling the machine power off/on also returns the exposure lamp to its home position.
4807SBU Test Pattern Change [0 to 255 / 0 / 1 /step]
1: Grid pattern
2: Gradation main scan 3: Gradation sub scan
4 to 250: Default (Scanning Image)
4808 Factory Setting Input 002* Execution Flag
4918Man Gamma Adj (DFU) Adjusts the offset data of the printer gamma for black in Photo mode or Letter mode.
Touch [Change] to open the printer gamma screen. Enter the manual gamma adjustment screen.
4954 Read/Restore Std
001Read New Chart Execute the scanning of the A4 chart.
002Recall Prev Chart Clear the data of the scanned A4 chart.
003Read Std Chart Execute the scanning of the A4 standard chart.
004Set Std Chart Overwrite the standard data.
005*Read/Restore Std [0 to 255 / 0 / 1] Adjusts chromaticity rank. When replacing the scanner lamp, select a number according to the barcode on the new scanner lamp.
4991 IPU Image Pass Selection DFU
001RGB Frame Memory Selects the image path. Enter the number to be selected using the 10-key pad.
[0 to 11 / 2/ 1]0 Scanner input RGB images 1 Scanner I/F RGB images
2RGB images done by Shading correction (Shading ON, Black offset ON) 3 Shading data 4 Inner pattern data: Gray scale 5 RGB images done by Line skipping correction 6 RGB images done by Digital AE 7 RGB images done by Vertical line correction 8 RGB image done by Scanner gamma correction 9 RGB image done by Filtering correction 10 RGB images done by Full color ADS 11 RGB image done by Color correction
4993* High Light Correction
Sensitivity SelectionSelects the Highlight correction level. [0 to 9 / 4 / 1 /step]
0: weakest sensitivity
9: strongest sensitivity
Range SelectionSelects the Highlight correction level. [0 to 9 / 4 / 1 /step]
0: weakest skew correction, 9: strongest skew correction
4994* Text/Photo Detect Level Adj.
001High Compression PDF Selects the definition level between Text and Photo for high compression PDF.
[0 to 2 / 1 / 1 ]
0: Text priority
1: Normal
2: Photo priority
MAIN SP TABLES-5
Service Tables
SP5-XXX: MODE
5024* | mm/inch Display Selection | 0: Europe/Asia (mm) 1: North America (inch) |
Selects the unit of measurement. After selection, turn the main power switch off and on. |
5047* | Paper Display |
Turns on or off the printed paper display on the LCD. [0 to 1 / 0 / 1] 0: Not displayed, 1: Displayed |
5055* | Display IP Address |
Display or does not display the IP address on the LCD. [0 to 1 / 0 / 1] 0: OFF, 1: ON |
5056* | Coverage Counter Display |
Display or does not display the coverage counter on the LCD. [0 to 1 / 0 / 1] 0: Not displayed, 1: Displayed |
5061* | Toner Remaining Icon Display Change |
Display or does not display the remaining toner display icon on the LCD. [0 to 1 / 0 / 1 ] 0: Not display, 1: Display |
