Rev. 09/11/2012
Exterior Covers
Rev. 09/11/2012
Exterior Covers
4.3.8 INNER TRAY
- Left cover ( p.4-4)
- Upper inner cover ( p.4-3 "Front Door, Upper and Lower Inner Cover")
- Paper exit cover ( p.4-8)
- Connector cover [A]
- Inner rear cover [A]
- Inner tray [A]
Rev. 09/11/2012
SCANNER
EXPOSURE GLASS
- Glass cover [A] ( x 2)
- ARDF exposure glass
[*]Rear scale [C] ( x 3)
[*]Exposure glass with left scale [D]
- Position the white marker [E] at the rear-left corner and the black or blue marker at the front-left corner when you reattach the ARDF exposure glass.
[*]SCANNER EXTERIOR PANELS AND OPERATION PANEL
Operation panel
1. Remove the Operation Panel ( 4.3.6)
Scanner left cover
1. Scanner left cover [A] ( x 3)
Rev. 09/11/2012 Scanner
Scanner right cover
1. Scanner right cover [A] ( x 2)
Scanner front cover
- Operation panel ( p.4-7)
- Scanner front cover [A] ( x 2)
Scanner rear cover
1. Scanner rear cover [A] ( x 1)
[*]LENS BLOCK ASSEMBLY
- Exposure glass
- Scanner right cover
3.
- Original size sensor bracket
- Lens block assembly [A]
- Do not remove the other screws on the lens block unit.
- SP4–008 (Sub Scan Mag):
- SP4–010 (Sub Mag Reg.):
- SP4–011 (Main Scan Reg):
- SP4–688 (DF: Density Adjustment): Use this to adjust the density level if the ID of outputs made in the DF and Platen mode is different.
ORIGINAL SIZE SENSOR
- Exposure glass with left scale
- SBU cover
- Remove the screw [A] on the sensor board bracket.
- Circuit chip [A]
- Original size sensor bracket [A]
- Original size sensors [A] (hooks)
EXPOSURE LAMP
- Before replacing the scanner lamp, check and note the first three digits in the bar-code on the new scanner lamp
- Operation panel
- Exposure glass
- Move the first scanner carriage [A] to the position shown above.
- Remove the two screws on the scanner lamp [A].
- Disconnect the connector [A] on the scanner lamp.
- Pull out the scanner lamp [A].
Chromaticity rank adjustment
Each scanner lamp has a specific chromaticity rank. The chromaticity rank is indicated by the bar-code on the new scanner lamp. After replacing the lamp, adjust the chromaticity rank to correspond to the new scanner lamp.
- Check the first three digits [A] in the bar-code on the new scanner lamp before installing the new lamp.
- After installing the new lamp, go to SP4-954-005 and enter the SP setting number referring to the table below.
1st Three Digits SP Setting (SP4-954-005) 1st Three Digits SP Setting (SP4-954-005) 139 3 166 12 140 2 167 11 141 1 168 10 142 6 169 15 143 5 170 14 144 4 171 13 145 9 172 18 146 8 173 17 147 7 174 16 148 12 204 3 149 11 205 2 150 10 206 1 151 15 207 6 152 14 208 5 153 13 209 4 154 18 210 9 155 17 211 8 156 16 212 7 157 3 213 12 158 2 214 11 159 1 215 10 160 6 216 15 1st Three Digits SP Setting (SP4-954-005) 1st Three Digits SP Setting (SP4-954-005) 161 5 217 14 162 4 218 13 163 9 219 18 164 8 220 17 165 7 221 16 - Operation panel
SCANNER HP SENSOR/PLATEN COVER SENSOR
Scanner HP Sensor
- Scanner rear cover
- Exposure glass
- Move the 1st scanner carriage [A] to the right side.
- Remove the mylar [A].
- Remove the scanner HP sensor [A]
Platen Cover Sensor
- Platen cover sensor [A]
SCANNER MOTOR
- Remove the 8 screws of the scanner rear frame [A].
- Disconnect the two connectors.
- Pull over the scanner rear stay [A] and remove it
Scanner motor bracket [A] ( x 1)
5.
Scanner motor [A] ( x 2,
x 1, spring x 1, belt x 1)
6.
- After replacing the scanner motor, do the image adjustments in the following section of the manual
SCANNER MOTOR DRIVE BOARD
- Scanner rear stay.
- SIO [A]
FRONT SCANNER WIRE
- Scanner left cover
- Scanner left stay [A]
- Scanner left rail frame .
[*]Operation panel stay [A]
[*]Scanner front stay [A]
[*]To make reassembly easy, slide the 1st scanner carriage to the right.
[*]Front scanner wire clamp [A]
[*]Front scanner wire bracket
[*]Front scanner wire and scanner drive pulley [C]
Reassembling the Front Scanner Wire
- Position the center ball [A] in the middle of the forked holder.
- Pass the right end (with the ball) through the square hole. Pass the left end (with the ring) [C] through the notch.
[*]Wind the right end counterclockwise (shown from the machine’s front) five times. Wind the left end clockwise twice.
- The two red marks [D] come together when you have done this. Stick the wire to the pulley with tape. This lets you easily handle the assembly at the time of installation.
- Do not attach the pulley to the shaft with the screw at this time.
[*]Hook the right end onto the front scanner wire bracket . The end should go via the front track of the right pulley [J] and the front track of the movable pulley [K].
- Do not attach the scanner wire bracket with the screw at this time.
[*]Insert a scanner-positioning pin [L] through the 2nd carriage hole [M] and the left holes [N] in the front rail. Insert another scanner positioning pin [O] through the 1st carriage hole [P] and the right holes in the front rail [Q].
[*]Insert two more scanner positioning pins through the holes in the rear rail.
[*]Screw the drive pulley to the shaft [R].
[*]Screw the scanner wire bracket to the front rail.
[*]Install the scanner wire clamp [T].
[*]Pull out the positioning pins.
- Make sure the 1st and 2nd carriages move smoothly after you remove the positioning pins. Do steps 8 through 13 again if they do not.
- After replacing the scanner wire, do the image adjustments in the following section of the manual
[*]REAR SCANNER WIRE
[*]Scanner front cover
[*]Scanner left cover
[*]Scanner left stay
[*]Scanner left rail frame
[*]Scanner rear cover
[*]Scanner rear stay
[*]Rear rail frame [A]
[*]SIO
[*]To make reassembly easy, slide the first scanner to the center.
[*]Rear scanner wire clamp
[*]Rear scanner wire bracket [C]
[*]Scanner motor gear [D]
[*]Rear scanner wire and scanner drive pulley [E]
Reassembling the Rear Scanner Wire
- Position the center ball in the middle of the forked holder.
[*]Pass the end with the ball [A] through the right square hole from the front.
[*]Position the center ball in the middle of the notch, as shown by the arrow.
[*]Pass the ball end [A] through the drive pulley notch.
[*]Wind the end with the ring [C] clockwise (shown from the machine’s front) three times; wind the ball end [A] clockwise (shown from the machine’s front) five times.
- The two red marks [D] should meet when you have done this.
[*]Install the drive pulley on the shaft.
- Do not screw the pulley onto the shaft yet.
- The winding of the wire on the three pulleys at the rear of the scanner should be the same as the winding on the three pulleys at the front. This must show as a mirror image. Example: At the front of the machine, the side of the drive pulley with the three windings must face the front of the machine. At the rear of the machine, it must face the rear.
LASER UNIT
- Turn off the main power switch and unplug the machine before attempting any of the procedures in this section. Laser beams can seriously damage your eyes.
CAUTION DECAL LOCATIONS
Two caution decals are located in the laser section as shown below. (See the next page for removal instructions.)
LASER UNIT
- Open the front door.
- Front door [A] (pins x 2)
- Upper inner cover
[*]Glass cap [C]
[*]Shield glass [D]
[*]Lower inner cover [E]
[*]Laser unit connectors [E]
- Do not disconnect the harnesses on the LD board [F] unless the LD unit has to be replaced. This board is precisely adjusted in the factory.
- When sliding out the laser unit, do not hold the LD board. Hold the laser unit.
[*]POLYGON MIRROR MOTOR
- Laser unit
- Laser unit cover [A]
- Polygon mirror motor
[*]After replacing the polygon mirror motor, do the image adjustment
[*]LASER SYNCHRONIZATION DETECTOR
- Laser unit
- Laser synchronization detector [A]
LD UNIT
- Laser unit
- Upper spring plate [A]
- Lower spring plate
[*]LD unit [C]
- To avoid damaging the LD board, hold it securely when disconnecting the connectors. Hold the laser unit casing.
Laser Beam Pitch Adjustment
- Install a (new) LD unit [A] with the left side of the LD unit being lower than the right side. (This makes this adjustment easier.)
- Print the test pattern "Hounds Tooth Check (2-Dot Horizontal)" (No. 16 in SP2109-001).
- Check if the vertical stripes appear on the second pattern (counted from the leading edge) of the printout.
- Correct: No vertical stripes appear (see the sample following this procedure.)
- Wrong: Vertical stripes appear (see the sample following this procedure.)
- Turn the adjustor screw by 90 degrees clockwise (counterclockwise).
- If the image of the printout is getting worse, try reverse rotation (clockwise
[*]Try steps 2 to 4 again until you get an image with no vertical stripes.
[*]Reassemble the machine after completing this adjustment.
Incorrect: Vertical stripes appear
[*]PCDU
PCDU (PHOTOCONDUCTOR AND DEVELOPMENT UNIT)
- Open the right door [A].
- Release the lock lever .
[*]Pull out the PCDU [C] and place it on a clean flat surface.
[*]Spread a large piece of paper on a flat surface.
- Make sure the area is free of pins, paper clips, staples, etc. to avoid attraction to the magnetic development roller.
Reinstallation
Open the right cover before you install the PCDU in the machine.
[*]DRUM
- Remove the PCDU
- Toner cap [A]
- Insert cap [A] into the opening of the PCDU .
- Make sure that the cap is inserted completely into the opening.
[*]Bracket [D]
[*]Pull the drum [E] towards the front
- Never touch the drum surface with bare hands.
Re-installation
- Replace the drum and close the PCDU
- Put the opening cap [A in the previous procedure] back in its original place.
- After replacing the drum, do these SPs:
- SP 2001: Charge Bias Setting – make sure that this is at the default setting
- SP 3001-2: P Sensor Initial Setting (P sensor = ID Sensor)
- SP 2805: Process Setting
- SP 2810-1: Grayscale Setting
PICK-OFF PAWLS
1. Drum
- Pawl assembly [A]
- Pick-off pawl (spring x 1, spur x 1)
Pick-off Pawl Position Adjustment
If the pick-off pawl has marked the drum with a line, the pick-off pawl position can be adjusted using either method:
- Changing the spur position
- Changing the pick-off pawl assembly position
CHARGE ROLLER AND CLEANING ROLLER
1. Drum
- Push the charge roller holder [A] toward the front of the drum
[*]Charge roller [C].
- Disengage the charge roller on the right side to remove it. Try to avoid touching the charge roller.
- Disengage the cleaning roller on the left to remove it.
- If this is not done, the carrier will be attracted to the drum because the charge roller voltage will be too high.
[*]DRUM CLEANING BLADE
1. Drum
- Charge roller and cleaning roller
- Remove drum cleaning blade [A]
Re-installation
Put toner on the edge of cleaning blade and the mylar at the back side of cleaning blade before re-installing this blade.
[*]ID SENSOR
1. PCDU
- Fusing unit
- ID sensor bracket [A]
- ID sensor
- Do SP3-001-002 to initialize the ID sensor after replacing.
[*]DEVELOPMENT
DEVELOPMENT FILTER
1. PCDU- Open the PCDU.
- Upper development cover [A]
- Development filter
[*]DEVELOPMENT ROLLER
1. PCDU
- Open the PCDU.
- Development roller [A]
- Work carefully to avoid scratching or nicking the development roller.
- Remove the two screws [A] and open the PCDU as shown above.
- Remove the upper development cover [A]
- Fold up a sheet of copy paper [A] to fit the width of the uncovered area of the development roller, as shown below.
- Slide the paper [A] along the length of the roller to clean the toner off the surface.
- Rotate the development roller [A] in the direction of the arrow until the section you cleaned is no longer visible.
- Repeat steps 5 and 6 until you have cleaned the entire surface of the roller.
- Reassemble the PCDU and install the PCDU into the machine.
DEVELOPER
1. PCDU
- Open the PCDU.
- Joint bracket [A]
- Development unit
[*]Tip out the old developer [C].
[*]Turn drive gear [D] to ensure that no developer remains in the unit or on the developer roller.
- Dispose of the used developer in accordance with local regulations. Work carefully to avoid scratching or nicking the development roller.
[*]Pour approximately 1/3 of the developer [E] evenly along the length of the development unit.
[*]Rotate the drive gear [F] to work the developer into the unit.
[*]Repeat steps 8 and 9 until all toner is in the unit and level with the edges.
[*]Re-install the development roller.
- Make sure that the seals at the both sides of the development roller are set inside the case after you re-install the development roller.
[*]Secure the drum [H] to the development unit, to close the PCDU
[*]Install the PCDU in the machine and close the front and right doors.
[*]Turn on the main power switch, and wait for the machine to warm up.
[*]Do SP2801 to initialize the TD sensor and enter the developer lot number.
[*]After performing the TD sensor initial setting, remove the sheet of paper from the PCDU.
[*]TD SENSOR
1. PCDU
- Empty all developer from the development unit.
- Seal
- TD sensor [A]
- The TD sensor is attached to the casing with double-sided tape . Pry it off with the flat head of a screwdriver. Use fresh double-sided tape to re-attach the sensor.
[*]Pour new developer into the development unit and perform the TD sensor initial setting using SP2-801.
- When performing the TD sensor initial setting, cover the toner entrance hole with a piece of paper.
- Open the PCDU.
[*]TRANSFER
TRANSFER BELT UNIT
- To avoid exposing the drum to strong light, cover it with paper if the right cover will be open for a long period.
- Release the lever .
[*]Transfer belt unit [C]
- Avoid touching the transfer belt surface.
[*]TRANSFER BELT
- Transfer belt unit
- Connector [A]
- Remove the springs (front and rear) .
[*]Release the hooks (front and rear) [C].
[*]Transfer belt with rollers [D]
[*]Lay the transfer belt with rollers on a flat clean surface, and fold the unit [E] to release the tension on the belt
[*]Transfer belt [F]
- Before installing the new transfer belt, clean all the rollers and shafts with alcohol to prevent the belt from slipping.
- When reinstalling the transfer belt, make sure that the belt is under the pin [F].
- To avoid damaging the transfer belt during installation, manually turn the rollers and make sure that the new transfer belt is not running over the edges of any of the rollers.
[*]TONER OVERFLOW SENSOR
- Toner overflow sensor [A]
[*]TRANSFER BELT CLEANING BLADE/TONER OVERFLOW SENSOR
Transfer Belt Cleaning Blade
- Transfer belt
- Transfer belt cleaning blade [A]
- Avoid touching the edge of the new blade. Check the new blade for dust or damage.
[*]PAPER FEED
PAPER FEED UNIT
Tray 1 and Tray 2
- Right rear cover
- Duplex unit
- Pull out tray 1 and tray 2.
- Paper guide plate [A] (hook x 2)
5.
6. Paper feed unit [A]
- Right rear cover
PICK-UP, FEED AND SEPARATION ROLLERS
Tray 1 and Tray 2
- Paper feed unit
- Roller holder [A]
- Pick-up roller
[*]Feed roller [C]
[*]Separation roller [D] and torque limiter [E]
[*]TRAY LIFT MOTOR
- Rear cover
- Tray lift motor 1 or 2 [A]
RELAY, TRAY LIFT, PAPER END AND PAPER FEED SENSORS
Tray 1 and Tray 2
- Right rear cover
- Duplex unit
- Paper feed unit
- Tray lift sensor [A]
- Paper end feeler and paper end sensor [C] (hook,
[*]Relay sensor bracket [D]
[*]Relay sensor [E]
[*]Paper feed sensor bracket [F]
[*]Paper feed sensor [G]
[*]REGISTRATION SENSOR
- Paper feed unit
[*]Right rear cover
[*]Duplex unit
[*]Paper feed unit for tray 1
[*]Paper Trays 1 and 2
[*]Paper dust box [A]
[*]Open the front door.
[*]Pull out the paper dust container .
[*]Remove two screws [C].
- This makes the paper guide [D] tilt a little bit. Now you can access the screw [E].
[*]Sensor bracket [G]
- You can only access the screw on the sensor bracket from the inside (paper tray location) of the machine.
Reinstall the registration sensor
It is very difficult to secure the sensor bracket to the frame. First attach the sensor bracket with tape temporarily.
