Photocopier and Printer
Ricoh
Ricoh MP4002/5002 service manual Part 28
<blockquote data-quote="John" data-source="post: 30" data-attributes="member: 2"><p><h3>Read This First</h3><p></p><p></p><h3>Important Safety Notices</h3><p></p><p></p><p><img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_001.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><ul> <li data-xf-list-type="ul">Never install telephone wiring during a lightning storm.</li> <li data-xf-list-type="ul">Never install telephone jacks in wet locations unless the jack is specifically designed for wet locations.</li> <li data-xf-list-type="ul">Never touch uninsulated telephone wires or terminals unless the telephone line has been disconnected at the network interface.</li> <li data-xf-list-type="ul">Use caution when installing or modifying telephone lines.</li> <li data-xf-list-type="ul">Avoid using a telephone (other than a cordless type) during an electrical storm. There may be a remote risk of electric shock from lightning.</li> <li data-xf-list-type="ul">Do not use a telephone or cellular phone to report a gas leak in the vicinity of the leak.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_002.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></li> <li data-xf-list-type="ul">Before installing the fax unit, switch off the main switch, and disconnect the power cord.</li> <li data-xf-list-type="ul">The fax unit contains a lithium battery. The danger of explosion exists if a battery of this type is incorrectly replaced. Replace only with the same or an equivalent type recommended by the manufacturer. Discard batteries in accordance with the manufacturer's instructions and local regulations.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_003.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></li> <li data-xf-list-type="ul">Note for Australia:</li> <li data-xf-list-type="ul">Unit must be connected to Telecommunication Network through a line cord which meets the requirements of ACA Technical Standard TS008.<br /> <h3>Safety and Symbols</h3> <h4>Conventions Used in this Manual</h4> This manual uses several symbols.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_004.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> : See or Refer to<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_005.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> : Screws<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_006.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> : Connector<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_007.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> : Clip ring<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_008.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> : E-ring<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_009.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> : Clamp<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_010.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <h4>Cautions, Notes, etc.</h4> The following headings provide special information:<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_011.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></li> <li data-xf-list-type="ul">Failure to obey warning information could result in serious injury or death.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_012.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></li> <li data-xf-list-type="ul">Obey these guidelines to ensure safe operation and prevent minor injuries.<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_013.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></li> <li data-xf-list-type="ul">Obey these guidelines to avoid problems such as misfeeds, damage to originals, loss of valuable data and to prevent damage to the machine.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_014.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></li> <li data-xf-list-type="ul">This information provides tips and advice about how to best service the machine.</li> </ul><p></p><p></p><ol> <li data-xf-list-type="ol"> <h3>INSTALLATION</h3> <ol> <li data-xf-list-type="ol"> <h3>OVERVIEW</h3> <br /> This section describes the installation procedures for printer, scanner, and other options for D129/D130 series machines.<br /> <br /> Printer Scanner Unit Type 5002 (D641)<br /> <ol> <li data-xf-list-type="ol"> <h4>PRINTER/SCANNER OPTIONS</h4> <br /> <table style='width: 100%'><tr><td>No.</td><td>Item</td><td>Merge Options</td></tr><tr><td>D641</td><td>Printer/Scanner Unit Type 5002</td><td>-</td></tr><tr><td>D641</td><td>Printer Unit Type 5002</td><td>Scanner Enhance Option</td></tr><tr><td>D641</td><td>Scanner Enhance Option Type 5002</td><td>-</td></tr></table> </li> <li data-xf-list-type="ol"> <h4>OTHER OPTIONS</h4> <br /> <table style='width: 100%'><tr><td>No.</td><td>Item</td><td>Slots</td></tr><tr><td>D377</td><td>File Format Converter Type E</td><td><br /> Board Slot. Only one of these boards can be installed at one time.</td></tr><tr><td>G874</td><td>Gigabit Ethernet Board Type A</td><td></td></tr><tr><td><br /> D377</td><td>IEEE 802.11a/g Interface Unit Type J<br /> -or-<br /> IEEE 802.11g Interface Unit Type K</td><td></td></tr><tr><td>B679</td><td>IEEE 1284 Interface Board Type A</td><td></td></tr><tr><td>D566</td><td>Bluetooth Interface Unit Type D</td><td>USB slot</td></tr><tr><td>D641</td><td>PostScript3 Unit Type 5002</td><td>SD Card Slot 1 (Upper Slot)</td></tr><tr><td>D641</td><td>IPDS Unit Type 5002</td><td>SD Card Slot 1 (Upper Slot)</td></tr><tr><td><br /> D640</td><td><br /> Browser Unit Type I</td><td>SD Card Slot 1 (Upper Slot) (Install, then remove)</td></tr><tr><td>D640</td><td>VM Card Type U</td><td>SD Card Slot 2</td></tr><tr><td>D629</td><td>SD card for NetWare printing Type K</td><td>SD Card Slot 1 (Upper Slot)</td></tr><tr><td>D594</td><td>Memory Unit Type L 512MB</td><td>Controller Board</td></tr></table> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_015.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">If more than one SD card application is required, the applications must be moved to one SD card with SP5873-1. For more details about merging applications from SD card Slot 2 (Lower Slot) to Slot 1 (Upper Slot), see "Scanner Enhance Option" in this chapter.</li> </ul></li> <li data-xf-list-type="ol"> <h4>BOARD, SD CARD SLOTS</h4> The machine controller box has one board slot and two SD card slots.<ul> <li data-xf-list-type="ul">Only one interface board option can be installed.</li> <li data-xf-list-type="ul">Only two SD cards are available for applications and maintenance.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_016.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> Printer Scanner Unit Type 5002 (D641)<br /> <br /> Board Slots<br /> <br /> <table style='width: 100%'><tr><td>No.</td><td>Name</td><td>Description</td></tr><tr><td>1</td><td>USB-A</td><td>Both USB slots are used for the Bluetooth option and a card authentication device.</td></tr><tr><td>2</td><td>USB-B</td><td>Built-in for connection of USB devices (USB 2.0)</td></tr><tr><td>3</td><td>SD Card Slot 1 (Upper Slot)</td><td>For options provided on SD cards. The application SD card (with the exception of the VM card) can be installed in Slot 1 (Upper Slot). If two or more applications are to be used, move the applications to the same SD card with SP5873.</td></tr><tr><td>4</td><td>SD Card Slot 2 (Lower Slot)</td><td>For options provided on SD cards and servicing. The VM card must be installed in Slot 2 (Lower Slot).</td></tr></table> <table style='width: 100%'><tr><td>No.</td><td>Name</td><td>Description</td></tr><tr><td>5</td><td>Ethernet</td><td>Standard LAN connection point. 100BASE-TX/10BASE-T LAN</td></tr><tr><td>6</td><td>ISDN</td><td>Jack for ISDN connection (<strong>Japan Only</strong>)</td></tr><tr><td>7</td><td>Line 3</td><td>Jack for a 3rd line connection to the Fax Interface Unit (D596) (G3) when this option is installed.</td></tr><tr><td>8</td><td>Line 1</td><td>Jack for the main telephone line from the outside for connection to Fax Option (D596).</td></tr><tr><td>9</td><td>TEL1</td><td>Jack for telephone connection</td></tr><tr><td>10</td><td>Line 2</td><td>Jack for a 2nd line connection to the Fax Interface Unit (D596) (G3) when this option is installed.</td></tr><tr><td>11</td><td>Board Slot</td><td>Optional interface boards are installed here.</td></tr></table> <ul> <li data-xf-list-type="ul">Orange LED: Lights when the network is connected and operating.</li> <li data-xf-list-type="ul">Green LED: Lights when 10BASE-TX or 100BASE-TX is operating.<br /> </li> </ul></li> <li data-xf-list-type="ul">Only two SD Card slots are available for applications.</li> <li data-xf-list-type="ul">To install more applications, they must be moved onto one SD Card.<br /> <h4>Board Slot</h4> The following optional interface boards are available. There is only one board slot so only one can be installed.<br /> <br /> <table style='width: 100%'><tr><td>No.</td><td>Interface Board</td></tr><tr><td>D377</td><td>File Format Converter Type E</td></tr><tr><td>G874</td><td>Gigabit Ethernet Board Type A</td></tr><tr><td><br /> D377</td><td>IEEE 802.11a/g Interface Unit Type J<br /> -or-<br /> IEEE 802.11g Interface Unit Type K</td></tr><tr><td>B679</td><td>IEEE 1284 Interface Board Type A</td></tr></table> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_017.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> Printer Scanner Unit Type 5002 (D641)<br /> <ul> <li data-xf-list-type="ul">Only one of these boards can be installed at one time.<br /> <h4>SD Card Slot</h4> The following options are provided on SD cards.</li> </ul></li> <li data-xf-list-type="ul">Two SD card slots are available.</li> <li data-xf-list-type="ul">The VM application SD card must be installed in Slot 2 (Lower Slot).</li> <li data-xf-list-type="ul">Other applications should be installed in Slot 1 (Upper Slot). If more than one application is required, applications can be moved onto one SD card with SP5873-1.<br /> <br /> <table style='width: 100%'><tr><td>No.</td><td>SD Card Applications</td></tr><tr><td>D641</td><td>PostScript3 Unit Type 5002</td></tr><tr><td>D641</td><td>IPDS Unit Type 5002</td></tr><tr><td>D640</td><td>Browser Unit Type I</td></tr><tr><td>D629</td><td>SD card for NetWare printing Type K</td></tr><tr><td>D641</td><td>Printer/Scanner Unit Type 5002</td></tr><tr><td>D641</td><td>Printer Unit Type 5002</td></tr><tr><td>D641</td><td>Scanner Enhance Option Type 5002</td></tr></table> <br /> <h4>USB Slots</h4> The following option is provided on a USB Device.<br /> <br /> <table style='width: 100%'><tr><td>No.</td><td>USB Device</td></tr><tr><td>D566</td><td>Bluetooth Interface Unit Type D</td></tr></table> </li> </ul></li> </ol></li> <li data-xf-list-type="ol"> <h3>PRINTER AND P/S OPTIONS (BASIC MODELS)</h3> <ol> <li data-xf-list-type="ol"> <h4>OVERVIEW</h4> This section describes the installation of the following items:<ul> <li data-xf-list-type="ul">Printer Unit</li> <li data-xf-list-type="ul">Printer/Scanner Unit</li> <li data-xf-list-type="ul">512 Memory. Optional memory is required for each unit. (Included in the Printer Unit or P/S Unit for NA models)<br /> Printer Scanner Unit Type 5002 (D641)<br /> <br /> </li> <li data-xf-list-type="ul">Scanner Enhance Option<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_018.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <h4>Three Main Units</h4> </li> <li data-xf-list-type="ul">Printer Unit Type 5002:<br /> For customers who do not require the extended scanning features but need more printing capability (PCL printer languages are provided). The 512 MB memory is required.</li> <li data-xf-list-type="ul">Printer/Scanner Unit Type 5002:<br /> For customers who require the full range of DS features (advanced scanning and printing features such as "scan-to" solutions, virtual mailboxes, PCL, etc.). The 512 MB memory unit is required.<br /> <h4>Separate Options</h4> There are two separate options: 512 MB memory and PS3.</li> <li data-xf-list-type="ul">512 MB memory:<br /> Every unit (Printer Unit, P/S unit) requires installation of the 512 MB memory.</li> <li data-xf-list-type="ul">PostScript 3 Unit:<br /> The PS3 option can be used with the Printer Unit, or the Printer/Scanner Unit.<br /> <br /> <h4>Enhance Options</h4> Scanner Enhance Option Type 5002 updates the Printer Unit by adding the advanced scanning features.</li> </ul></li> <li data-xf-list-type="ol"> <h4>KIT CONTENTS</h4> Check the accessories and their quantities against the list below and the illustration on the next page. This is a common list for all the kits.<br /> <br /> <h4>Common Accessory Table</h4> This common accessory table lists all the items of the following units.<ul> <li data-xf-list-type="ul">PU: Printer Unit</li> <li data-xf-list-type="ul">P/S: Printer/Scanner Unit</li> <li data-xf-list-type="ul">SEO: Scanner Enhance Unit<br /> <br /> <table style='width: 100%'><tr><td><br /> No.</td><td><br /> Description</td><td><br /> Q'ty</td><td>Kit Contents</td><td></td><td></td></tr><tr><td>PU</td><td>P/S</td><td>SEO</td><td></td><td></td><td></td></tr><tr><td></td><td>512 MB Memory*1</td><td>-</td><td>No</td><td>No</td><td>No</td></tr><tr><td>1</td><td>HDD Unit</td><td>1</td><td>Yes</td><td>Yes</td><td>No</td></tr><tr><td>2</td><td>Screw</td><td>3</td><td>Yes</td><td>Yes</td><td>No</td></tr><tr><td>3</td><td>SD Card</td><td>1</td><td>Yes</td><td>Yes</td><td>Yes</td></tr></table> <br /> *1: The 512 Memory is a separate option and it is not provided in the kits. However, one memory unit is required for the installation of every print unit. (Included in the Printer Unit or P/S Unit for NA models)</li> </ul></li> <li data-xf-list-type="ol"> <h4>PRINTER/SCANNER INSTALLATION</h4> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_019.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Turn off the main power switch and disconnect the power supply cord.<br /> <br /> 1. Remove the controller board [A] ( x 2).<br /> <br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_020.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> Printer Scanner Unit Type 5002 (D641)<br /> </li> </ul></li> </ol></li> </ol></li> <li data-xf-list-type="ol">Connect the two harnesses to the HDD unit [A] <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_021.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 2).<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_022.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></li> <li data-xf-list-type="ol">Install the connecting board unit [A] on the HDD unit <strong> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_023.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 2).<br /> <br /> <br /> [*]Connect the two harnesses from the HDD unit to the connecting board [A] <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_024.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 2).<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_025.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> [*]Install the HDD unit [A] on the controller board unit <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_026.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x3).<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_027.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> [*]Install the 512 MB memory [A].<br /> [*]Reinstall the controller board.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_028.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> Printer Scanner Unit Type 5002 (D641)<br /> <br /> <br /> [*]Remove the controller cover [A].<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_029.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> [*]Insert the Printer/Scanner SD card in SD card Slot 1 (Upper Slot) [A].<br /> [*]Reattach the cover.<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_030.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> [*]Attach the supplied ferrite core [A] at the machine end of the Ethernet cable.<br /> <br /> <br /> [*]Connect the Ethernet interface cable to the 10BASE-T/100BASE-TX port [A].<br /> [*]Connect the other end of the Ethernet interface cable to a network connection device such as a hub.<br /> [*]Connect the machine’s power cord and turn the main power switch on.<br /> [*]Enable the NIB and/or USB function.<br /> <ul> <li data-xf-list-type="ul">To enable the NIB function, enter the SP mode and set SP5985-001 (On Board NIC) to "1" (Enable).</li> <li data-xf-list-type="ul">To enable the USB function, enter the SP mode and set SP5985-002 (On Board USB) to “1" (Enable).<ol> <li data-xf-list-type="ol"> <h4>SCANNER ENHANCE OPTION</h4> <br /> <h4>Accessory Check</h4> Refer to the "Common Accessory Table" in this chapter.<br /> <br /> <h4>Installation (Application Merge)</h4> The installation of the scanner enhance option are done with <strong>SP5873-001 (Application Move)</strong>.<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_031.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">If you are going to update the RPCS unit with both the printer and scanner enhance options, the order of execution is not important.<ol> <li data-xf-list-type="ol">Turn off the copier.</li> <li data-xf-list-type="ol">Remove the cover <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_032.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" />x1).</li> <li data-xf-list-type="ol">Confirm that the Printer Unit SD card is in SD card Slot <strong>1 </strong>(Upper Slot).</li> <li data-xf-list-type="ol">Put the option SD Card (Scanner Enhance Option) in SD card Slot <strong>2 </strong>(Lower Slot).</li> <li data-xf-list-type="ol">Open the front door.</li> <li data-xf-list-type="ol">Turn the copier on.</li> <li data-xf-list-type="ol">Go into the SP mode and select <strong>SP5873-001</strong>.</li> <li data-xf-list-type="ol">Touch "Execute".</li> <li data-xf-list-type="ol">Read the instructions on the display and touch "Execute" to start.</li> <li data-xf-list-type="ol">When the display tells you copying is completed, touch "Exit", then turn the copier off.</li> <li data-xf-list-type="ol">Remove the option SD card from Slot <strong>2 </strong>(Lower Slot).</li> <li data-xf-list-type="ol">Turn the copier on.</li> <li data-xf-list-type="ol">Go into the User Tools mode and confirm that update was successful.</li> <li data-xf-list-type="ol">User Tools> System Settings> Administrator Tools> Firmware Version> Next</li> <li data-xf-list-type="ol">Turn the copier off again, then reattach the cover.</li> <li data-xf-list-type="ol">Return the copied SD card to the customer for safekeeping, or tape it to the faceplate of the controller.<br /> </li> </ol> <h4>To undo an option update</h4> <ol> <li data-xf-list-type="ol">Turn the main switch off.</li> <li data-xf-list-type="ol">Confirm that the Printer Unit SD card is in SD card Slot <strong>1 </strong>(Upper Slot).</li> <li data-xf-list-type="ol">Put the original option SD card (Scanner Enhance Option) in SD card Slot <strong>2 </strong>(Lower Slot).</li> <li data-xf-list-type="ol">Turn the main switch on.</li> <li data-xf-list-type="ol">Go into the SP mode and do <strong>SP5873-002 </strong>(Undo Exec).</li> <li data-xf-list-type="ol">Follow the messages on the operation panel to complete the procedure.<br /> Printer Scanner Unit Type 5002 (D641)<br /> <br /> </li> <li data-xf-list-type="ol">Turn the main switch off.</li> <li data-xf-list-type="ol">Remove the option SD card from Slot <strong>2 </strong>(Lower Slot).</li> <li data-xf-list-type="ol">Turn the main switch on.</li> <li data-xf-list-type="ol">Go into the User Tools mode and confirm that undo was successful.<br /> User Tools> System Settings> Administrator Tools> Firmware Version> Next</li> <li data-xf-list-type="ol">Turn the copier off again, then reattach the cover.<br /> </li> </ol> <h4>Important Notes about SD Cards</h4> Here are some basic rules about merging applications on SD cards.<ul> <li data-xf-list-type="ul">The data necessary for authentication is transferred with the application program to the target SD card.</li> <li data-xf-list-type="ul">The SD card is the only evidence that the customer is licensed to use the application program. The service technician may occasionally need to check the SD card and its data to solve problems. SD cards must be stored in a safe location at the work site.</li> <li data-xf-list-type="ul">Once the merge is completed, the SD card from which the application was copied cannot be used again, but the customer must keep the card to serve as proof of purchase.</li> <li data-xf-list-type="ul">An SD card from which an application has been moved to another SD card can be restored to full operation with <strong>SP5873-002 </strong>(Undo).</li> <li data-xf-list-type="ul">Before storing the card from which an application has been copied, label it carefully so that you can identify it easily if you need to do the undo procedure later.</li> </ul></li> </ul></li> <li data-xf-list-type="ol"> <h4>APPLICATION MERGE</h4> This machine has two SD card slots only. However, more than two optional applications are supplied for this machine. Always keep SD card Slot 2 (Lower Slot) vacant for servicing (except for the VM Card). Because of this, SD card merge is required if a customer wants to use many applications.<br /> Consider the following limitations when you try to merge SD cards.<ul> <li data-xf-list-type="ul">The destination SD card should have the largest memory size of all the application SD cards. Refer to the following table for the memory size of each SD card.<br /> <br /> <table style='width: 100%'><tr><td>SD Card Options</td><td>SD Card Size</td></tr><tr><td>Printer/Scanner Unit Type 5000</td><td>512 MB</td></tr><tr><td>Printer Unit Type 5002</td><td>512 MB</td></tr><tr><td>Scanner Enhance Option Type 5002</td><td>128 MB</td></tr><tr><td>PostScript3 Unit Type 5000</td><td>512 MB</td></tr><tr><td>IPDS Unit Type 5002</td><td>128 MB</td></tr><tr><td>SD card for NetWare printing Type K</td><td>128 MB</td></tr><tr><td>Browser Unit Type I</td><td>128 MB</td></tr><tr><td>VM Card Type U</td><td>512 MB</td></tr></table> <br /> <h4>If more than one application is required…</h4> Merge all applications which the customer wants to use into one SD card (Destination card inserted in Slot 1 (Upper Slot)).</li> </ul></li> </ol></li> <li data-xf-list-type="ul"> <h3>INSTALLING CONTROLLER OPTIONS</h3> <ol> <li data-xf-list-type="ol"> <h4>OVERVIEW</h4> Printer Scanner Unit Type 5002 (D641)<br /> <br /> This machine has a board slot for optional I/F connection and two SD card slots for applications. After you install an option, check that the machine can recognize it. <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_033.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> p.30 "Check All Connections")<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_034.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> <h4>Board Slot</h4> <ul> <li data-xf-list-type="ul">This slot [4] is used for one of the optional board connections (only one can be installed): IEEE1284, IEEE802.11a/g, g (Wireless LAN), Gigabit Ethernet, or File Format Converter.<br /> <br /> <h4>SD Card Slots</h4> </li> <li data-xf-list-type="ul">PostScript3 Unit, IPDS Unit, Browser Unit, SD Card for Netware printing should be installed in Slot 1 (Upper Slot) [1].</li> <li data-xf-list-type="ul">VM Card must be installed in Slot 2 (Lower Slot) [2]. However, it can also be merged to the SD card in Slot 1 (Upper Slot).<br /> <br /> <h4>USB Slots</h4> </li> <li data-xf-list-type="ul">Bluetooth Interface Unit is installed in the USB slot [3].</li> </ul></li> <li data-xf-list-type="ol"> <h4>POSTSCRIPT 3 UNIT (D641)</h4> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_035.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Unplug the main machine power cord before you do the following procedure.<br /> <br /> 1. Remove the controller cover [A] ( x 2)<br /> <br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_036.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <ol> <li data-xf-list-type="ol">Turn the SD-card label face to the rear of the machine. Then push it slowly into Slot 1 (Upper Slot) [A] until you hear a click.</li> <li data-xf-list-type="ol">Attach the controller cover <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_037.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 2).<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_038.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></li> <li data-xf-list-type="ol">Attach the "Adobe PostScript 3" decal [A] to the front door.</li> <li data-xf-list-type="ol">Make sure that the machine can recognize the option. <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_039.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> p.30 "Check All Connections")</li> </ol></li> </ul></li> <li data-xf-list-type="ol"> <h4>FILE FORMAT CONVERTER (D377)</h4> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_040.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Unplug the main machine power cord before you do the following procedure.<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_041.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> Printer Scanner Unit Type 5002 (D641)<br /> <ol> <li data-xf-list-type="ol">Remove the slot cover [A] from the board slot <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_042.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 2).</li> <li data-xf-list-type="ol">Install the file format converter into the board slot, and then fasten it with screws.</li> <li data-xf-list-type="ol">Plug in and turn on the main power switch.</li> <li data-xf-list-type="ol">Check or set the following SP codes with the values shown below.<br /> <br /> <table style='width: 100%'><tr><td>SP No.</td><td>Title</td><td>Setting</td></tr><tr><td>SP5-836-001</td><td>Capture Function (0:Off 1:On)</td><td>"1"</td></tr><tr><td>SP5-836-002</td><td>Panel Setting</td><td>"0"</td></tr></table> <br /> </li> <li data-xf-list-type="ol">Check the operation.</li> <li data-xf-list-type="ol">Make sure that the machine can recognize the option. <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_043.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> p.30 "Check All Connections")</li> </ol></li> </ul></li> <li data-xf-list-type="ol"> <h4>IEEE 1284 INTERFACE BOARD (B679)</h4> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_044.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Unplug the main machine power cord before you do the following procedure.</li> </ul></li> </ol></li> </ul></strong></li> </ol><p><strong></strong></p><p><strong>You can only install one of the following network interfaces at one time: (IEEE 802.11a/g, g (Wireless LAN), IEEE1284, Bluetooth).</strong></p><p><strong></strong></p><p><strong></strong></p><p><strong></strong></p><p><strong><img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_045.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></strong></p><p><strong></strong></p><ol> <li data-xf-list-type="ol"><strong>Remove the slot cover [A] from the board slot <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_046.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 2).</strong></li> <li data-xf-list-type="ol"><strong>Install the interface board (Knob-screw x 2) into the board slot.</strong></li> <li data-xf-list-type="ol"><strong>Make sure that the machine can recognize the option. <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_047.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> p.30 "Check All Connections")<br /> <h4>1.3.5 IEEE 802.11A/G OR G (D377)</h4> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_048.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Unplug the main machine power cord before you do the following procedure.</strong></li> </ul></li> </ol><p>You can only install one of the following network interfaces at one time: (IEEE 802.11a/g, g (Wireless LAN), IEEE1284, Bluetooth).</strong></p><p><strong></strong></p><p><strong></strong></p><p><strong></strong></p><p><strong><img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_049.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></strong></p><p><strong></strong></p><p><strong>Printer Scanner Unit Type 5002 (D641)</strong></p><p><strong></strong></p><p><strong></strong></p><p><strong></strong></p><ol> <li data-xf-list-type="ol"><strong><strong>Remove the slot cover [A] from the board slot <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_050.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 2).</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Install the wireless LAN board (Knob-screw x 2) into the board slot.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Make sure that the machine can recognize the option. <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_051.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> p.30 "Check All Connections")<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_052.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Peel off the double-sided tapes on the Velcro fasteners [A], and then attach them <strong> at the front left and rear right of the machine.<br /> [*]Attach the "ANT1" (having a black ferrite core) to the front left of the machine.<br /> [*]Attach the "ANT2" (having a white ferrite core) to the rear right of the machine.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_053.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <ul> <li data-xf-list-type="ul">"ANT1" is a transmission/reception antenna and "ANT2" is a reception antenna. Do not attach them at the wrong places.</strong></strong></li> </ul>[*]Attach the clamps as shown above.<br /> [*]Wire the cables and clamp them <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_054.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 8).<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_055.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <ul> <li data-xf-list-type="ul"><strong><strong>Make sure that the cables are not slack. Keep them wired tightly along the covers. You may have to move the machine if the reception is not clear.</strong></strong></li> </ul></strong></li> </ol><p><strong></strong></strong></p><p><strong><strong> <ul> <li data-xf-list-type="ul"><strong><strong>Make sure that the machine is not located near an appliance or any type of equipment that generates strong magnetic fields.</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>Put the machine as close as possible to the access point.<br /> <br /> <h4>User Tool Settings for IEEE 802.11a/g</h4> Go into the User Tools mode and do the procedure below. These settings take effect every time the machine is powered on.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_056.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">You cannot use IEEE 802.11a/g if you use Ethernet.</strong></strong></li> </ul></li> </ul> <ol> <li data-xf-list-type="ol"><strong><strong>Press the “User Tools” key.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>On the touch panel, touch “System Settings”.<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_057.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Select “Interface Settings”> “Network” > “LAN Type”. The “LAN Type” (default: Ethernet) must be set for either Ethernet or wireless LAN.</strong></strong></li> </ul></li> <li data-xf-list-type="ol"><strong><strong>Select “Interface Settings”> “Wireless LAN”. Only the wireless LAN options show.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Set the “Communication Mode“.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Enter the “SSID setting”. (The setting is case sensitive.)</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Set the “Ad-hoc Channel”. You need this setting when Ad Hoc Mode is selected. The allowed range for the channel settings may vary for different countries.<ul> <li data-xf-list-type="ul">Region A (mainly Europe and Asia)<br /> Range: 1-13, 36, 40, 44 and 48 channels (default: 11)<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_058.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">In some countries, only the following channels are available:</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>Range: 1-11 channels (default: 11)</strong></strong></li> </ul></li> <li data-xf-list-type="ul"><strong><strong>Region B (mainly North America)<br /> Range: 1-11, 36, 40, 44 and 48 channels (default: 11)</strong></strong></li> </ul></li> <li data-xf-list-type="ol"><strong><strong>Set the “Security Method” to specify the encryption of the Wireless LAN.<ul> <li data-xf-list-type="ul">The “WEP” (Wired Equivalent Privacy) setting is designed to protect wireless data transmission. The same WEP key is required on the receiving side in order to unlock encoded data. There are 64 bit and 128 bit WEP keys.<br /> Range of Allowed Settings: 64 bit: 10 characters<br /> 128 bit: 26 characters</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>Specify “WPA” when “Communication Mode” is set to “Infrastructure Mode”. Set the “WPA Encryption Method” and “WPA Authent. Method”.<ul> <li data-xf-list-type="ul">WPA Encryption Method:<br /> Printer Scanner Unit Type 5002 (D641)<br /> <br /> Select either "TKIP" or "CCMP (AES)".</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>WPA Authent. Method:<br /> Select either “WPA-PSK”, “WPA”, “WPA2-PSK", or “WPA2”.<br /> If you select “WPA-PSK” or “WPA2-PSK”, enter the pre-shared key (PSK) of 8 - 63 characters in ASCII code.<br /> When “WPA” or “WPA2” are selected, authentication settings and certificate installation settings are required.</strong></strong></li> </ul></li> </ul></li> <li data-xf-list-type="ol"><strong><strong>Press “Wireless LAN Signal” to check the machine's radio wave status using the operation panel.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Press “Restore Factory Defaults” to initialize the wireless LAN settings. Press “Yes” to initialize the following settings:<ul> <li data-xf-list-type="ul">Transmission mode</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>Channel</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>Transmission Speed</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>WEP</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>SSID</strong></strong></li> <li data-xf-list-type="ul"><strong><strong>WEP Key</strong></strong></li> </ul></li> </ol><h4>SP Mode Settings for IEEE 802.11 Wireless LAN</h4><p>The following SP commands and UP modes can be set for IEEE 802.11</strong></strong></p><p><strong><strong></strong></strong></p><p><strong><strong></strong></strong></p><p><strong><strong></strong></strong></p><p><strong><strong> <table style='width: 100%'><tr><td>SP No.</td><td>Name</td><td>Function</td></tr><tr><td><br /> 5840 006</td><td><br /> Channel MAX</td><td>Sets the maximum range of the channel settings for the country.</td></tr><tr><td><br /> 5840 007</td><td><br /> Channel MIN</td><td>Sets the minimum range of the channels settings allowed for your country.</td></tr><tr><td><br /> 5840 008</td><td><br /> Transmission Speed</td><td>Sets the transmission speed.<br /> Auto, 54 Mbps, 48 Mbps, 36 Mbps, 24 Mbps, 18 Mbps,<br /> 12 Mbps, 9 Mbps, 6 Mbps, 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps (default: Auto).</td></tr><tr><td>5840 011</td><td>WEP Key Select</td><td>Used to select the WEP key (Default: 00).</td></tr><tr><td><br /> UP mode</td><td>Name</td><td>Function</td></tr><tr><td>SSID</td><td>Used to confirm the current SSID setting.</td><td></td></tr><tr><td>WEP Key</td><td>Used to confirm the current WEP key setting.</td><td></td></tr><tr><td><br /> WEP Mode</td><td>Used to show the maximum length of the string that can be used for the WEP Key entry.</td><td></td></tr><tr><td>WPA Encryption Method</td><td><br /> Used to confirm the current WPA encryption setting.</td><td></td></tr><tr><td>WPA Authent. Method</td><td>Used to confirm the current WPA authentication setting and pre-shared key.</td><td></td></tr></table> <ol style="margin-left: 20px"> <li data-xf-list-type="ol"><strong><strong><ol> <li data-xf-list-type="ol"> <h4>BLUETOOTH UNIT (D566)</h4> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_059.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Turn off the main power switch and disconnect the power supply cord.<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_060.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> Printer Scanner Unit Type 5002 (D641)<br /> <ol> <li data-xf-list-type="ol">Insert the Bluetooth unit into the USB-A slot [A].</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Make sure that the machine can recognize the option. <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_061.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> p.30 "Check All Connections")<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_062.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Bluetooth Unit and IEEE 802.11a/g or g Interface Unit cannot be set at the same time.</strong></strong></li> </ul></li> </ol></li> </ul></li> <li data-xf-list-type="ol"><strong><strong> <h4>GIGABIT ETHERNET (G874)</h4> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_063.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Unplug the main machine power cord before you do the following procedure.<br /> You can only install one of the following network interfaces at one time: (IEEE 802.11a/g, g (Wireless LAN), IEEE1284, IEEE1394, Bluetooth).<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_064.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ol> <li data-xf-list-type="ol">Remove the slot cover [A] from the board slot <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_065.gif" alt="image" class="fr-fic fr-dii fr-draggable " style="" /> x 2).</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Insert the Gigabit Ethernet Board into the I/F slot and fasten it with the screws.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Print a configuration page to confirm that the machine recognizes the installed board for USB2.0:<br /> User Tools > Printer Features > List/Test Print > Configuration Page</strong></strong></li> </ol></li> </ul></li> <li data-xf-list-type="ol"><strong><strong> <h4>IPDS UNIT (D641)</h4> <br /> <h4>Accessories</h4> Check the accessories and their quantities against the table below.<br /> <br /> <table style='width: 100%'><tr><td>No.</td><td>Description</td><td>Q'ty</td></tr><tr><td>1</td><td>IPDS Emulation SD Card</td><td>1</td></tr><tr><td>2</td><td>Decal</td><td>1</td></tr></table> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_066.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <br /> Printer Scanner Unit Type 5002 (D641)<br /> <ul> <li data-xf-list-type="ul">Only two slots are available for SD cards that contain applications. If you want to use more than two applications, merge all applications into two SD cards (SP5873-001).<br /> <h4>Installation</h4> <ol> <li data-xf-list-type="ol">Check the software version.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>If necessary, update the firmware to the required version.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Turn off the main switch.<br /> </strong></strong></li> </ol><br /> Remove the controller cover [A] ( x 2)<br /> <br /> 4.<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_067.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ol> <li data-xf-list-type="ol"><strong><strong>Insert the IPDS SD Card into Slot 1 (Upper Slot) [A].<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_068.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">Pushing in the SD Card releases it for removal. Make sure the SD Card is inserted and locked in place. If it is partially out of the slot, push it in gently until it locks in place.</strong></strong></li> </ul></li> <li data-xf-list-type="ol"><strong><strong>Reattach the controller cover and turn ON the main switch.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Do one of the following ("A" or "B") to enable the IPDS function.<ol> <li data-xf-list-type="ol">[Enable the IPDS function via telnet]<ol> <li data-xf-list-type="ol">Connect the machine via telnet.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Execute the following commands: msh> <strong>set ipds up</strong><br /> ***If you want to stop the function. msh> <strong>set ipds down</strong></strong></strong></li> </ol></li> <li data-xf-list-type="ol"><strong><strong>[Enable the IPDS option via WebImageMonitor]<ol> <li data-xf-list-type="ol">Log in to WebImageMonitor.</strong></strong></li> <li data-xf-list-type="ol"><strong><strong>Change the setting to enable IPDS.</strong></strong></li> </ol></li> </ol><img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_069.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> Printer Scanner Unit Type 5002 (D641)<br /> <br /> </li> <li data-xf-list-type="ol"><strong><strong>Attach the decal [A] as shown in the photo above.<ul> <li data-xf-list-type="ul">Line up the left side of the decal with the left edged of the main power switch. (<strong>: 10 mm or more)<br /> </strong></strong></strong></li> </ul><strong><br /> </strong></li> </ol><strong><br /> </strong></li> </ul><strong><br /> [*] <h4>VM CARD TYPE U (D640)</h4> This option is only for basic models.<br /> <br /> <h4>Accessories</h4> Check the accessories and their quantities against the table below.<br /> <br /> <table style='width: 100%'><tr><td>Description</td><td>Q'ty</td></tr><tr><td>1. VM SD Card</td><td>1</td></tr><tr><td>2. Decal</td><td>1</td></tr></table> <h4>Installation</h4> Printer Scanner Unit Type 5002 (D641)<br /> <br /> 1. Switch the machine off.<br /> <br /> <br /> Remove the controller cover [A] ( x 2)<br /> <br /> 2.<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_070.jpg" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><br /> <ol> <li data-xf-list-type="ol"><strong><strong>Insert the SD card into SD Slot 2 (Lower Slot) [A].<br /> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_071.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">This SD card must be inserted into Slot 2 (Lower Slot).</strong></strong></li> </ul></li> </ol></strong></li> </ol><strong><br /> [*] <h3>CHECK ALL CONNECTIONS</h3> </strong></li> </ol><p><strong></strong></strong></strong></p><p><strong><strong><strong></strong></strong></strong></p><p><strong><strong><strong></strong></strong></strong></p><p><strong><strong><strong>Plug in the power cord. Then turn on the main switch.</strong></strong></strong></p><p><strong><strong><strong></strong></strong></strong></p><p><strong><strong><strong>Enter the printer user mode. Then print the configuration page. User Tools > Printer Features > List Test Print > Configuration Page All installed options are shown in the “System Reference” column.</strong></strong></strong></p><p><strong><strong><strong></strong></strong></strong></p><p><strong><strong><strong></strong></strong></strong></p><p><strong><strong><strong></strong></strong></strong></p><p><strong><strong><ol> <li data-xf-list-type="ol"><strong><strong><strong> <h3>SERVICE TABLES</h3> <ol> <li data-xf-list-type="ol"> <h3>PRINTER SERVICE TABLES</h3> <br /> Printer Scanner Unit Type 5002 (D641)<br /> <ol> <li data-xf-list-type="ol"> <h4>SP1-XXX (SERVICE MODE)</h4> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td></tr><tr><td>001</td><td>Bit Switch 1</td><td>0</td><td>1</td></tr><tr><td>bit 0</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 1</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 2</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 3</td><td>No I/O Timeout</td><td>0: Disable</td><td>1: Enable</td></tr><tr><td>Enable: The MFP I/O Timeout setting will have no effect. I/O Timeouts will never occur.</td><td></td><td></td><td></td></tr><tr><td>bit 4</td><td>SD Card Save Mode</td><td>0: Disable</td><td>1: Enable</td></tr><tr><td>Enable: Print jobs will be saved to an SD Card in the GW SD slot.</td><td></td><td></td><td></td></tr><tr><td>bit 5</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 6</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 7</td><td>[RPCS,PCL]: Printable area frame border</td><td>0: Disable</td><td>1: Enable</td></tr><tr><td>Enable: The machine prints all RPCS and PCL jobs with a border on the edges of the printable area.</td><td></td><td></td><td></td></tr></table> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td></tr><tr><td>002</td><td>Bit Switch 2</td><td>0</td><td>1</td></tr><tr><td>bit 0</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 1</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 2</td><td>Applying a collation Type</td><td>Shift Collate</td><td>Normal Collate</td></tr><tr><td>A collation type (shift or normal) will be applied to all jobs that do not already have a ‘Collate Type’ configured.<br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_072.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /></td><td></td><td></td><td></td></tr><tr><td>bit 3</td><td>[PCL5e/c,PS]: PDL Auto Switching</td><td>0: Enable</td><td>1: Disable</td></tr><tr><td>Disable: The MFPs ability to change the PDL processor mid-job.<br /> Some host systems submit jobs that contain both PS and PCL5e/c. If Auto PDL switching is disabled, these jobs will not be printed properly.</td><td></td><td></td><td></td></tr><tr><td>bit 4</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 5</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 6</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 7</td><td>DFU</td><td>-</td><td>-</td></tr></table> <ul> <li data-xf-list-type="ul">If #5-0 is enabled, this Bit Switch has no effect.<br /> Printer Scanner Unit Type 5002 (D641)</strong></strong></strong></li> </ul><br /> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td></tr><tr><td>003</td><td>Bit Switch 3</td><td>0</td><td>1</td></tr><tr><td>bit 0</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 1</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 2</td><td>[PCL5e/c]: Legacy HP compatibility</td><td>0: Disable</td><td>1: Enable</td></tr><tr><td>Enable: Uses the same left margin as older HP models such as HP4000/HP8000.<br /> In other words, the left margin defined in the job (usually "<ESC>*r0A") will be changed to "<ESC>*r1A"</td><td></td><td></td><td></td></tr><tr><td>bit 3</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 4</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 5</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 6</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 7</td><td>DFU</td><td>-</td><td>-</td></tr></table> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td><td></td></tr><tr><td>004</td><td>Bit Switch 4</td><td>0</td><td>1</td><td></td></tr><tr><td></td><td>bit 0</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td>bit 1</td><td>DFU</td><td>-</td><td>-</td><td></td></tr><tr><td>bit 2</td><td>DFU</td><td>-</td><td>-</td><td></td></tr><tr><td>bit 3</td><td>IPDS print-side reversal</td><td>0: Disable</td><td>1: Enable</td><td></td></tr><tr><td>Enable: Increases printing speed but simplex pages may be printed on the back side of the sheet.</td><td></td><td></td><td></td><td></td></tr><tr><td>bit 4</td><td>DFU</td><td>-</td><td>-</td><td></td></tr><tr><td>bit 5</td><td>DFU</td><td>-</td><td>-</td><td></td></tr><tr><td>bit 6</td><td>DFU</td><td>-</td><td>-</td><td></td></tr><tr><td>bit 7</td><td>DFU</td><td>-</td><td>-</td><td></td></tr></table> Printer Scanner Unit Type 5002 (D641)<br /> <br /> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td><td></td></tr><tr><td>005</td><td>Bit Switch 5</td><td>0</td><td>1</td><td></td></tr><tr><td></td><td><br /> bit 0</td><td>Show "Collate Type", "Staple Type" and "Punch Type" buttons on the operation panel.</td><td><br /> Disable</td><td><br /> Enable</td></tr><tr><td>If enabled, users will be able to configure a Collate Type, Staple Type, and Punch Type from the operation panel. The available types will depend on the device and configured options.<br /> After enabling the function, the settings will appear under: "User Tools > Printer Features > System"</td><td></td><td></td><td></td><td></td></tr><tr><td></td><td>bit 1</td><td>Multiple copies if a paper size or type mismatch occurs</td><td>0: Disable (Single copy)</td><td><br /> 1: Enable (Multiple copy)</td></tr><tr><td>If a paper size or type mismatch occurs during the printing of multiple copies, only a single copy is output by default. Using this Bit Switch, the device can be configured to print all copies even if a paper mismatch occurs.</td><td></td><td></td><td></td><td></td></tr><tr><td></td><td>bit 2</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td></td><td>bit 3</td><td>[PS] PS Criteria</td><td>Pattern3</td><td>Pattern1</td></tr><tr><td>Change the number of PS criterion used by the PS interpreter to determine whether a job is PS data or not.<br /> Pattern3: includes most PS commands.<br /> Pattern1: A small number of PS tags and headers</td><td></td><td></td><td></td><td></td></tr><tr><td></td><td>bit 4</td><td>Increase max number of the stored jobs to 1000 jobs.</td><td>Disable (100)</td><td>Enable (1000)</td></tr><tr><td>Enable: Changes the maximum number of jobs that can be stored on the HDD via Job Type settings to 1000. The default is 100.</td><td></td><td></td><td></td><td></td></tr><tr><td></td><td>bit 5</td><td>DFU</td><td>-</td><td>-</td></tr></table> <br /> <table style='width: 100%'><tr><td></td><td>bit 6</td><td>Method for determining the image rotation for the edge to bind on.</td><td><br /> 0: Disable</td><td><br /> 1: Enable</td></tr><tr><td>If enabled, the image rotation will be performed as they were in the specifications of older models for the binding of pages of mixed orientation jobs.<br /> The old models are below:</td><td></td><td></td><td></td><td></td></tr><tr><td></td><td>bit 7</td><td><br /> Letterhead mode printing</td><td><br /> 0: Disable</td><td>1: Enable (Duplex)</td></tr><tr><td>Routes all pages through the duplex unit.<br /> If this is disabled, simplex pages or the last page of an odd-paged duplex job are not routed through the duplex unit. This could result in problems with letterhead/pre-printed pages.<br /> Only affects pages specified as Letterhead paper.</td><td></td><td></td><td></td><td></td></tr></table> <ul> <li data-xf-list-type="ul"><strong><strong><strong>PCL: Pre-04A models</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>PS/PDF/RPCS<img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite7" alt=":p" title="Stick out tongue :p" loading="lazy" data-shortname=":p" />re-05S models<br /> </strong></strong></strong></li> </ul><br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td></tr><tr><td>006</td><td>Bit Switch 6 <strong>DFU</strong></td><td>-</td><td>-</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td><td></td></tr><tr><td>007</td><td>Bit Switch 7</td><td>0</td><td>1</td><td></td></tr><tr><td></td><td><br /> bit 0</td><td>Print path</td><td>0: Disable</td><td>1: Enable</td></tr><tr><td>If enabled, simplex pages (in mixed simplex/duplex PS/PCL5 jobs only) and the last page of an odd paged duplex job (PS, PCL5, PCL6), are always routed through the duplex unit. Not having to switch paper paths increases the print speed slightly.</td><td></td><td></td><td></td><td></td></tr><tr><td></td><td>bit 1<br /> to 7</td><td><br /> DFU</td><td><br /> -</td><td><br /> -</td></tr></table> Printer Scanner Unit Type 5002 (D641)<br /> <br /> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td></tr><tr><td>008</td><td>Bit Switch 8 <strong>DFU</strong></td><td>-</td><td>-</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td><td></td></tr><tr><td>009</td><td>Bit Switch 9</td><td>0</td><td>1</td><td></td></tr><tr><td></td><td><br /> bit 0</td><td>PDL Auto Detection timeout of jobs submitted via USB or Parallel Port (IEEE 1284).</td><td><br /> "Disabled (Immediately)"</td><td><br /> "Enabled (10 seconds)"</td></tr><tr><td></td><td>To be used if PDL auto-detection fails. A failure of PDL autodetection doesn't necessarily mean that the job can't be printed. This bit switch tells the device whether to time-out immediately (default) upon failure or to wait 10 seconds.</td><td></td><td></td><td></td></tr><tr><td></td><td>bit 1</td><td>DFU</td><td>-</td><td>-</td></tr><tr><td></td><td>bit 2</td><td>Job Cancel</td><td>Disabled (Not cancelled)</td><td><br /> Enabled (Cancelled)</td></tr><tr><td>If this bit switch, all jobs will be cancelled after a jam occurs.<br /> Note: If this bitsw is enabled, printing under the following conditions might result in problems:</td><td></td><td></td><td></td><td></td></tr><tr><td></td><td>bit 3</td><td>PCL/PS bypass tray paper rotation (SEF/LEF)</td><td><br /> 0: Disable</td><td><br /> 1: Enable</td></tr><tr><td></td><td></td><td>This bitsw causes the device to revert to the behavior of previous generations. It only takes effect if "Bypass Tray Setting Priority" = "Driver/Command".<br /> Previous spec (bitsw=1): If a standard sized paper mismatch occurred in the bypass tray, the MFP always prompted for SEF paper.<br /> If this bitsw=0 (default) then in the event of a standard sized paper mismatch, the MFP will always prompt for paper of the rotation (SEF/LEF) determined by the MFP bypass tray paper setting or by the bypass tray sensor.</td><td></td><td></td></tr></table> <ul> <li data-xf-list-type="ul"><strong><strong><strong>Job submission via USB or Parallel Port</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>Spool printing (WIM >Configuration > Device Settings > System)<br /> <table style='width: 100%'><tr><td></td><td>bit 4</td><td>Response to PJL USTATUS when multiple collated copies are printed</td><td><br /> 0: Disable</td><td><br /> 1: Enable</td></tr><tr><td></td><td></td><td>When enabled, if multiple collated copies are printed, the device no longer responds to PJL USTATUS with the number of pages in the current copy. Instead the device will return the total number of pages for all copies.</td><td></td><td></td></tr><tr><td></td><td>Bit 5<br /> to 7</td><td>DFU</td><td><br /> -</td><td><br /> -</td></tr></table> </strong></strong></strong></li> </ul><br /> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td><td></td></tr><tr><td>010</td><td>Bit Switch 10</td><td>0</td><td>1</td><td></td></tr><tr><td></td><td>bit 0<br /> to 4</td><td><br /> DFU</td><td><br /> -</td><td><br /> -</td></tr><tr><td></td><td>bit 5</td><td>List / Test Print Lock</td><td>0: Disable</td><td>1: Enable</td></tr><tr><td></td><td>If enabled, you can lock or unlock the [List/Test Print] items under the Pinter Features menu when the Store and Skip Errored Job Function is on.</td><td></td><td></td><td></td></tr><tr><td></td><td>Bit 6</td><td>Optional charge machines</td><td>-</td><td>-</td></tr><tr><td></td><td>If enabled, you can use the optional charge machines when the Store and Skip Errored Job Function is on.</td><td><br /> 0: Disable</td><td><br /> 1: Enable</td><td></td></tr><tr><td></td><td>Bit 7</td><td>DFU</td><td>-</td><td>-</td></tr></table> Printer Scanner Unit Type 5002 (D641)<br /> <br /> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td><td></td></tr><tr><td>011</td><td>Bit Switch 11</td><td>0</td><td>1</td><td></td></tr><tr><td></td><td>bit 0</td><td>List / Test Print menu</td><td>0: Disable</td><td>1: Enable</td></tr><tr><td></td><td></td><td>When enabled, [Multiple Lists] menu is displayed in [List / Test Print] under the Printer Features menu.</td><td></td><td></td></tr><tr><td></td><td>bit 1</td><td>Interrupt printing</td><td>0: Job</td><td>1: Page</td></tr><tr><td></td><td>Selects the interrupting units for the interrupt printing function. When you select "0," you can interrupt printing of a job while being processed.<br /> When you select "1," you can interrupt printing of a page while being processed.</td><td></td><td></td><td></td></tr><tr><td></td><td>Bit 2<br /> to 7</td><td>DFU</td><td><br /> -</td><td><br /> -</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>1001</td><td>Bit Switch</td><td></td><td></td><td></td></tr><tr><td>012</td><td>Bit Switch 12</td><td>0</td><td>1</td><td></td></tr><tr><td></td><td>bit 0<br /> to 7</td><td><br /> DFU</td><td><br /> -</td><td><br /> -</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>1003</td><td>[Clear Setting]</td></tr><tr><td><br /> 1003 001</td><td>Initialize Printer System</td></tr><tr><td>Initializes settings in the "System" menu of the user mode.</td><td></td></tr><tr><td>1003 003</td><td>Delete Program</td></tr></table> <br /> <table style='width: 100%'><tr><td>1004</td><td>[Print Summary]</td></tr><tr><td><br /> 1004 001</td><td>Print Printer Summary</td></tr><tr><td>Prints the service summary sheet (a summary of all the controller settings).</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>1006</td><td>[Sample/Locked Print]</td><td>*CTL</td><td>0: Link with Doc. Svr, 1: Enable</td></tr><tr><td><br /> 1006 001</td><td>Enables and disables the document server. When you select "0," the document server is enabled or disabled in accordance with Copy Service Mode SP5-967. When you select "1," the document server is enabled regardless of Copy Service Mode SP5-967.</td><td></td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>1110</td><td>[Media Print Device Setting]</td><td></td></tr><tr><td>1110 002</td><td>0: Disable <strong>1</strong>: Enable</td><td>Selects the setting for the media print device.</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>1111</td><td>[All Job Delete Mode]</td><td></td></tr><tr><td><br /> 1111 001</td><td><br /> 0: excluding New Job<br /> 1: including New Job</td><td>Select whether to include an image processing job in jobs subject to full cancellation from the SCS job list.</td></tr></table> </li> </ol></li> <li data-xf-list-type="ol"><strong><strong><strong> <h3>SCANNER SERVICE TABLES</h3> <br /> Printer Scanner Unit Type 5002 (D641)<br /> <ol> <li data-xf-list-type="ol"> <h4>SP1-XXX (SYSTEM AND OTHERS)</h4> <br /> <table style='width: 100%'><tr><td><br /> 1005</td><td>[Erase margin (Remote Scan)]</td><td></td><td></td></tr><tr><td>Creates an erase margin for all edges of the scanned image.<br /> If the machine has scanned the edge of the original, create a margin. This SP is activated only when the machine uses TWAIN scanning.</td><td></td><td></td><td></td></tr><tr><td>1005 1</td><td>Range from 0 to 5 mm</td><td>*CTL</td><td>[0 to 5 / <strong>0 </strong>/ 1 mm/step ]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td><br /> 1009</td><td><br /> [Remote scan disable]</td><td><br /> *CTL</td><td>[0 or 1 / <strong>0 </strong>/ - ]<br /> 0: enable, 1: disable</td></tr><tr><td>1009 1</td><td>Enable or disable remote scan.</td><td></td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td><br /> 1010</td><td>[Non Display Clear Light PDF]</td><td><br /> *CTL</td><td>[0 or 1 / <strong>0 </strong>/ - ]<br /> 0: Display, 1: No display</td></tr><tr><td>1010 1</td><td>Enable or disable remote scan.</td><td></td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td><br /> 1011</td><td><br /> [Org Count Disp]</td><td><br /> *CTL</td><td>[0 or 1 / <strong>0 </strong>/ - ]<br /> 0: No display, 1: Display</td></tr><tr><td>1011 1</td><td>This SP codes switches the original count display on/off.</td><td></td><td></td></tr></table> <br /> <table style='width: 100%'><tr><td><br /> 1012</td><td><br /> [User Info Release]</td><td><br /> *CTL</td><td>[0 or 1 / <strong>1 </strong>/ - ]<br /> 0: Do not release, 1: Release</td></tr><tr><td><br /> 1012 1</td><td>This SP code sets the machine to release or not release the following items at job end.</td><td></td><td></td></tr></table> <ul> <li data-xf-list-type="ul">Destination (E-mail/Folder/CS)</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>Sender name</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>Mail Text</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>Subject line</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>File name<br /> </strong></strong></strong></li> </ul><br /> <table style='width: 100%'><tr><td><br /> 1013</td><td>[Scan Media Device Setting]</td><td><br /> *CTL</td><td>[0 or 1 / <strong>1 </strong>/ - ]<br /> 0: Disable, 1: Enable</td></tr><tr><td><br /> 1013 1</td><td>This SP code enables/disables the multi-media function option (USB 2.0/SD Slot) mounted on the left rear corner of the machine. Operators can scan documents to either an SD card or a USB memory device inserted into this unit. This SP must be enabled (set to "1") in order for the device to function.</td><td></td><td></td></tr></table> Printer Scanner Unit Type 5002 (D641)<br /> <br /> </li> <li data-xf-list-type="ol"><strong><strong><strong> <h4>SP2-XXX (SCANNING-IMAGE QUALITY)</h4> <br /> <table style='width: 100%'><tr><td><br /> 2021</td><td>[Compression Level (Gray-scale)]</td><td></td><td></td></tr><tr><td>Selects the compression ratio for grayscale processing mode (JPEG) for the three settings that can be selected at the operation panel.</td><td></td><td></td><td></td></tr><tr><td>2021 1</td><td>Comp1: 5-95</td><td><br /> *CTL</td><td>[5 to 95 / <strong>20 </strong>/ 1 /step ]</td></tr><tr><td>2021 2</td><td>Comp2: 5-95</td><td>[5 to 95 / <strong>40 </strong>/ 1 /step ]</td><td></td></tr><tr><td>2021 3</td><td>Comp3: 5-95</td><td>[5 to 95 / <strong>65 </strong>/ 1 /step ]</td><td></td></tr><tr><td>2021 4</td><td>Comp4: 5-95</td><td>[5 to 95 / <strong>80 </strong>/ 1 /step ]</td><td></td></tr><tr><td>2021 5</td><td>Comp5: 5-95</td><td>[5 to 95 / <strong>95 </strong>/ 1 /step ]</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td><br /> 2024</td><td>[Compression ratio of ClearLight PDF]</td><td></td><td></td></tr><tr><td>Selects the compression ratio for clearlight PDF for the two settings that can be selected at the operation panel.</td><td></td><td></td><td></td></tr><tr><td>2024 1</td><td>Compression Ratio (Normal)</td><td><br /> *CTL</td><td>[5 to 95 / <strong>25 </strong>/ 1 /step ]</td></tr><tr><td>2024 2</td><td>Compression Ratio (High)</td><td>[5 to 95 / <strong>20 </strong>/ 1 /step ]</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td><br /> 2025</td><td>[Compression ratio of ClearLight PDF JPEG2000]</td><td></td><td></td></tr><tr><td>Selects the compression ratio for clearlight PDF for the two settings that can be selected at the operation panel.</td><td></td><td></td><td></td></tr><tr><td>2025 1</td><td>Compression Ratio (Normal) JPEG2000</td><td><br /> *CTL</td><td>[5 to 95 / <strong>25 </strong>/ 1 /step ]</td></tr><tr><td>2025 2</td><td>Compression Ratio (High) JEPG2000</td><td>[5 to 95 / <strong>20 </strong>/ 1 /step ]</td><td></td></tr></table> </strong></strong></strong></li> </ol></li> </ol></li> <li data-xf-list-type="ol"><strong><strong><strong> <h3>SPECIFICATIONS</h3> <ol> <li data-xf-list-type="ol"> <h3>PRINTER SPECIFICATIONS</h3> <br /> <table style='width: 100%'><tr><td><br /> Printer Languages:</td><td>PCL 6/5e<br /> PDF Direct<br /> Adobe PostScript 3 (optional) IPDS (optional)<br /> MediaPrint: JPEG/TIFF (optional)</td></tr><tr><td><br /> Resolution and Gradation:</td><td>PCL 5e:<br /> 300 x 300 dpi<br /> 600 x 600 dpi : Fast (1-bit) PCL 6:<br /> 600 x 600 dpi : Fast (1-bit) PDF Direct:<br /> 300 x 300 dpi/600 x 600 dpi PS3:<br /> 300 x 300 dpi/600 x 600 dpi XPS:<br /> 600 x 600 dpi : Fast (1-bit) IPDS:<br /> 300 x 300 dpi/ 600 x 600 dpi</td></tr><tr><td><br /> Printing speed:</td><td>D129: 40 ppm<br /> D130: 50 ppm</td></tr><tr><td><br /> Resident Fonts:</td><td>PCL 6/5e (Standard): 45 Compatible fonts<br /> 13 International fonts<br /> 6 Bitmap fonts<br /> Adobe PostScript 3 (Optional): 136 fonts<br /> IPDS (Optional): 108 fonts</td></tr></table> <table style='width: 100%'><tr><td><br /> Host Interfaces:</td><td>USB2.0 Type A and Type B: Standard Ethernet (100 Base-TX/10 Base-T): Standard Gigabit Ethernet (1000 Base-T): Optional IEEE1284 parallel x 1: Optional IEEE802.11a/b/g (Wireless LAN): Optional Bluetooth (USB type): Optional</td></tr><tr><td>Network Protocols:</td><td>TCP/IP (IPv4, IPv6), IPX/SPX</td></tr></table> Printer Scanner Unit Type 5002 (D641)<br /> <br /> </strong></strong></strong></li> <li data-xf-list-type="ol"><strong><strong><strong> <h3>USB SPECIFICATIONS</h3> <br /> USB connectivity is built into the controller.<br /> <br /> <table style='width: 100%'><tr><td>Interface</td><td>USB 2.0</td></tr><tr><td><br /> Data rates</td><td>480 Mbps (high speed), 12 Mbps (full speed), 1.5 Mbps (low speed)<br /> High speed mode is only supported by USB 2.0.</td></tr></table> <br /> </strong></strong></strong></li> <li data-xf-list-type="ol"><strong><strong><strong> <h3>IEEE 802.11A/B/G SPECIFICATIONS</h3> <br /> <table style='width: 100%'><tr><td>Standard applied</td><td>IEEE802.11a/b/g</td><td></td></tr><tr><td>Network protocols</td><td>TCP/IP, Apple Talk, NetBEUI, IPX/SPX, SMB</td><td></td></tr><tr><td>Frequency range</td><td></td><td></td></tr><tr><td>(Center</td><td></td><td>2412 - 2462 MHz (1-11 channels)</td></tr><tr><td>Frequency)</td><td></td><td>5180 - 5320 MHz (36, 40, 44, 48, 52, 56, 60, and 64 channels)</td></tr><tr><td>(US model)</td><td></td><td></td></tr><tr><td>Frequency range</td><td></td><td></td></tr><tr><td>(Center</td><td></td><td>2412 - 2472 MHz (1-13 channels)</td></tr><tr><td>Frequency)</td><td></td><td>5180 - 5320 MHz (36, 40, 44, 48, 52, 56, 60, and 64 channels)</td></tr><tr><td>(EU model)</td><td></td><td></td></tr></table> </strong></strong></strong></li> <li data-xf-list-type="ol"><strong><strong><strong> <h3>BLUETOOTH SPECIFICATIONS</h3> <br /> <table style='width: 100%'><tr><td>Transmission Specifications</td><td><br /> Based on Bluetooth Ver2.0+EDR</td></tr><tr><td>Transmission Speed</td><td></td></tr><tr><td><br /> Profile</td><td>Hard Copy Cable Replacement Profile (HCRP), Serial Port Profile (SPP), Basic Imaging Profile (BIP)</td></tr></table> <ul> <li data-xf-list-type="ul">Asynchronous Communication : Approximately 2.1 Mbps (Max)</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>Synchronous Communication : Approximately 1.3 Mbps (Max)<br /> </strong></strong></strong></li> </ul>Printer Scanner Unit Type 5002 (D641)<br /> <br /> </li> <li data-xf-list-type="ol"><strong><strong><strong> <h3>SCANNER SPECIFICATIONS</h3> <br /> <table style='width: 100%'><tr><td>Standard Scanner Resolution:</td><td>Main scan/Sub scan 200 to 600 dpi</td></tr><tr><td><br /> Available scanning Resolution Range:</td><td>Twain Mode: 100 to 1200 dpi Delivery Mode:<br /> 100/200/300/400/600 dpi</td></tr><tr><td>Grayscales:</td><td>1 bit or 8 bits/pixel each for RGB</td></tr><tr><td><br /> Scanning Throughput (ARDF mode):</td><td>BW: 61 ipm (A4LEF / BW Text/ Photo / 200dpi /Compression: On (MH))<br /> FC: 31 ipm (A4LEF / FC Text / Photo / 200dpi / Compression: Standard)</td></tr><tr><td><br /> Interface:</td><td>Ethernet 10Base-T / 100Base-TX, Gigabit Ethernet (1000Base-T), Wireless LAN (IEEE 802.11a/b/g)</td></tr><tr><td>Compression Method:</td><td>B&W: TIFF (MH, MR, MMR, JBIG2), Gray Scale<br /> Full Color: JPEG</td></tr></table> </strong></strong></strong></li> <li data-xf-list-type="ol"><strong><strong><strong> <h3>SOFTWARE ACCESSORIES</h3> <br /> The printer drivers and utility software are provided on one CD-ROM. An auto-run installer allows you to select which components to install.<ol> <li data-xf-list-type="ol"> <h4>PRINTER DRIVERS</h4> <br /> <table style='width: 100%'><tr><td><br /> Printer Language</td><td>Windows XP, Server 2003, Server 2008, Vista, 7</td><td>MacOSX10.2<br /> or later</td></tr><tr><td>PCL5c<br /> / PCL6</td><td><br /> Yes</td><td><br /> No</td></tr><tr><td>PS3</td><td>Yes</td><td>Yes</td></tr><tr><td>RPCS</td><td>No</td><td>No</td></tr></table> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_073.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">The PCL5c/6 and PS3 drivers are provided on the printer/scanner CD-ROM.</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>The PS3 drivers are all genuine Adobe PS drivers, except for Windows XP/Server 2003/Server 2008/Vista/7. A PPD file for each operating system is provided with the driver.</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>The PPD installer for Macintosh supports Mac OS X 10.2 or later versions.<br /> </strong></strong></strong></li> </ul></li> <li data-xf-list-type="ol"><strong><strong><strong> <h4>SCANNER AND LAN FAX DRIVERS</h4> <br /> <table style='width: 100%'><tr><td>Printer Language</td><td>Windows XP, Server 2003, Server 2008, Vista, 7</td><td>MacOSX10.2<br /> or later</td></tr><tr><td>Network TWAIN</td><td>Yes</td><td>No</td></tr><tr><td>LAN-FAX</td><td>Yes</td><td>No</td></tr></table> <br /> <img src="https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_074.png" alt="image" class="fr-fic fr-dii fr-draggable " style="" /><ul> <li data-xf-list-type="ul">The Network TWAIN and LAN Fax drivers are provided on the printer and scanner drivers CD-ROM.</strong></strong></strong></li> <li data-xf-list-type="ul"><strong><strong><strong>This software lets you fax documents directly from your PC. Address Book Editor and Cover Sheet Editor are to be installed as well. (These require the optional fax unit.)</strong></strong></strong></li> </ul></li> </ol></li> </ol></li> </ol></p></blockquote><p></p>
[QUOTE="John, post: 30, member: 2"] [HEADING=2]Read This First[/HEADING] [HEADING=2]Important Safety Notices[/HEADING] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_001.png[/IMG] [LIST] [*]Never install telephone wiring during a lightning storm. [*]Never install telephone jacks in wet locations unless the jack is specifically designed for wet locations. [*]Never touch uninsulated telephone wires or terminals unless the telephone line has been disconnected at the network interface. [*]Use caution when installing or modifying telephone lines. [*]Avoid using a telephone (other than a cordless type) during an electrical storm. There may be a remote risk of electric shock from lightning. [*]Do not use a telephone or cellular phone to report a gas leak in the vicinity of the leak. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_002.png[/IMG] [*]Before installing the fax unit, switch off the main switch, and disconnect the power cord. [*]The fax unit contains a lithium battery. The danger of explosion exists if a battery of this type is incorrectly replaced. Replace only with the same or an equivalent type recommended by the manufacturer. Discard batteries in accordance with the manufacturer's instructions and local regulations. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_003.png[/IMG] [*]Note for Australia: [*]Unit must be connected to Telecommunication Network through a line cord which meets the requirements of ACA Technical Standard TS008. [HEADING=2]Safety and Symbols[/HEADING] [HEADING=3]Conventions Used in this Manual[/HEADING] This manual uses several symbols. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_004.gif[/IMG] : See or Refer to [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_005.gif[/IMG] : Screws [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_006.gif[/IMG] : Connector [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_007.gif[/IMG] : Clip ring [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_008.jpg[/IMG] : E-ring [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_009.gif[/IMG] : Clamp [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_010.gif[/IMG] [HEADING=3]Cautions, Notes, etc.[/HEADING] The following headings provide special information: [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_011.png[/IMG] [*]Failure to obey warning information could result in serious injury or death. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_012.png[/IMG] [*]Obey these guidelines to ensure safe operation and prevent minor injuries. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_013.png[/IMG] [*]Obey these guidelines to avoid problems such as misfeeds, damage to originals, loss of valuable data and to prevent damage to the machine. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_014.png[/IMG] [*]This information provides tips and advice about how to best service the machine. [/LIST] [LIST=1] [*][HEADING=2]INSTALLATION[/HEADING] [LIST=1] [*][HEADING=2]OVERVIEW[/HEADING] This section describes the installation procedures for printer, scanner, and other options for D129/D130 series machines. Printer Scanner Unit Type 5002 (D641) [LIST=1] [*][HEADING=3]PRINTER/SCANNER OPTIONS[/HEADING] [TABLE] [TR] [TD]No.[/TD] [TD]Item[/TD] [TD]Merge Options[/TD] [/TR] [TR] [TD]D641[/TD] [TD]Printer/Scanner Unit Type 5002[/TD] [TD]-[/TD] [/TR] [TR] [TD]D641[/TD] [TD]Printer Unit Type 5002[/TD] [TD]Scanner Enhance Option[/TD] [/TR] [TR] [TD]D641[/TD] [TD]Scanner Enhance Option Type 5002[/TD] [TD]-[/TD] [/TR] [/TABLE] [*][HEADING=3]OTHER OPTIONS[/HEADING] [TABLE] [TR] [TD]No.[/TD] [TD]Item[/TD] [TD]Slots[/TD] [/TR] [TR] [TD]D377[/TD] [TD]File Format Converter Type E[/TD] [TD] Board Slot. Only one of these boards can be installed at one time.[/TD] [/TR] [TR] [TD]G874[/TD] [TD]Gigabit Ethernet Board Type A[/TD] [TD][/TD] [/TR] [TR] [TD] D377[/TD] [TD]IEEE 802.11a/g Interface Unit Type J -or- IEEE 802.11g Interface Unit Type K[/TD] [TD][/TD] [/TR] [TR] [TD]B679[/TD] [TD]IEEE 1284 Interface Board Type A[/TD] [TD][/TD] [/TR] [TR] [TD]D566[/TD] [TD]Bluetooth Interface Unit Type D[/TD] [TD]USB slot[/TD] [/TR] [TR] [TD]D641[/TD] [TD]PostScript3 Unit Type 5002[/TD] [TD]SD Card Slot 1 (Upper Slot)[/TD] [/TR] [TR] [TD]D641[/TD] [TD]IPDS Unit Type 5002[/TD] [TD]SD Card Slot 1 (Upper Slot)[/TD] [/TR] [TR] [TD] D640[/TD] [TD] Browser Unit Type I[/TD] [TD]SD Card Slot 1 (Upper Slot) (Install, then remove)[/TD] [/TR] [TR] [TD]D640[/TD] [TD]VM Card Type U[/TD] [TD]SD Card Slot 2[/TD] [/TR] [TR] [TD]D629[/TD] [TD]SD card for NetWare printing Type K[/TD] [TD]SD Card Slot 1 (Upper Slot)[/TD] [/TR] [TR] [TD]D594[/TD] [TD]Memory Unit Type L 512MB[/TD] [TD]Controller Board[/TD] [/TR] [/TABLE] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_015.png[/IMG] [LIST] [*]If more than one SD card application is required, the applications must be moved to one SD card with SP5873-1. For more details about merging applications from SD card Slot 2 (Lower Slot) to Slot 1 (Upper Slot), see "Scanner Enhance Option" in this chapter. [/LIST] [*][HEADING=3]BOARD, SD CARD SLOTS[/HEADING] The machine controller box has one board slot and two SD card slots. [LIST] [*]Only one interface board option can be installed. [*]Only two SD cards are available for applications and maintenance. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_016.jpg[/IMG] Printer Scanner Unit Type 5002 (D641) Board Slots [TABLE] [TR] [TD]No.[/TD] [TD]Name[/TD] [TD]Description[/TD] [/TR] [TR] [TD]1[/TD] [TD]USB-A[/TD] [TD]Both USB slots are used for the Bluetooth option and a card authentication device.[/TD] [/TR] [TR] [TD]2[/TD] [TD]USB-B[/TD] [TD]Built-in for connection of USB devices (USB 2.0)[/TD] [/TR] [TR] [TD]3[/TD] [TD]SD Card Slot 1 (Upper Slot)[/TD] [TD]For options provided on SD cards. The application SD card (with the exception of the VM card) can be installed in Slot 1 (Upper Slot). If two or more applications are to be used, move the applications to the same SD card with SP5873.[/TD] [/TR] [TR] [TD]4[/TD] [TD]SD Card Slot 2 (Lower Slot)[/TD] [TD]For options provided on SD cards and servicing. The VM card must be installed in Slot 2 (Lower Slot).[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]No.[/TD] [TD]Name[/TD] [TD]Description[/TD] [/TR] [TR] [TD]5[/TD] [TD]Ethernet[/TD] [TD]Standard LAN connection point. 100BASE-TX/10BASE-T LAN[/TD] [/TR] [TR] [TD]6[/TD] [TD]ISDN[/TD] [TD]Jack for ISDN connection ([B]Japan Only[/B])[/TD] [/TR] [TR] [TD]7[/TD] [TD]Line 3[/TD] [TD]Jack for a 3rd line connection to the Fax Interface Unit (D596) (G3) when this option is installed.[/TD] [/TR] [TR] [TD]8[/TD] [TD]Line 1[/TD] [TD]Jack for the main telephone line from the outside for connection to Fax Option (D596).[/TD] [/TR] [TR] [TD]9[/TD] [TD]TEL1[/TD] [TD]Jack for telephone connection[/TD] [/TR] [TR] [TD]10[/TD] [TD]Line 2[/TD] [TD]Jack for a 2nd line connection to the Fax Interface Unit (D596) (G3) when this option is installed.[/TD] [/TR] [TR] [TD]11[/TD] [TD]Board Slot[/TD] [TD]Optional interface boards are installed here.[/TD] [/TR] [/TABLE] [LIST] [*]Orange LED: Lights when the network is connected and operating. [*]Green LED: Lights when 10BASE-TX or 100BASE-TX is operating. [/LIST] [*]Only two SD Card slots are available for applications. [*]To install more applications, they must be moved onto one SD Card. [HEADING=3]Board Slot[/HEADING] The following optional interface boards are available. There is only one board slot so only one can be installed. [TABLE] [TR] [TD]No.[/TD] [TD]Interface Board[/TD] [/TR] [TR] [TD]D377[/TD] [TD]File Format Converter Type E[/TD] [/TR] [TR] [TD]G874[/TD] [TD]Gigabit Ethernet Board Type A[/TD] [/TR] [TR] [TD] D377[/TD] [TD]IEEE 802.11a/g Interface Unit Type J -or- IEEE 802.11g Interface Unit Type K[/TD] [/TR] [TR] [TD]B679[/TD] [TD]IEEE 1284 Interface Board Type A[/TD] [/TR] [/TABLE] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_017.png[/IMG] Printer Scanner Unit Type 5002 (D641) [LIST] [*]Only one of these boards can be installed at one time. [HEADING=3]SD Card Slot[/HEADING] The following options are provided on SD cards. [/LIST] [*]Two SD card slots are available. [*]The VM application SD card must be installed in Slot 2 (Lower Slot). [*]Other applications should be installed in Slot 1 (Upper Slot). If more than one application is required, applications can be moved onto one SD card with SP5873-1. [TABLE] [TR] [TD]No.[/TD] [TD]SD Card Applications[/TD] [/TR] [TR] [TD]D641[/TD] [TD]PostScript3 Unit Type 5002[/TD] [/TR] [TR] [TD]D641[/TD] [TD]IPDS Unit Type 5002[/TD] [/TR] [TR] [TD]D640[/TD] [TD]Browser Unit Type I[/TD] [/TR] [TR] [TD]D629[/TD] [TD]SD card for NetWare printing Type K[/TD] [/TR] [TR] [TD]D641[/TD] [TD]Printer/Scanner Unit Type 5002[/TD] [/TR] [TR] [TD]D641[/TD] [TD]Printer Unit Type 5002[/TD] [/TR] [TR] [TD]D641[/TD] [TD]Scanner Enhance Option Type 5002[/TD] [/TR] [/TABLE] [HEADING=3]USB Slots[/HEADING] The following option is provided on a USB Device. [TABLE] [TR] [TD]No.[/TD] [TD]USB Device[/TD] [/TR] [TR] [TD]D566[/TD] [TD]Bluetooth Interface Unit Type D[/TD] [/TR] [/TABLE] [/LIST] [/LIST] [*][HEADING=2]PRINTER AND P/S OPTIONS (BASIC MODELS)[/HEADING] [LIST=1] [*][HEADING=3]OVERVIEW[/HEADING] This section describes the installation of the following items: [LIST] [*]Printer Unit [*]Printer/Scanner Unit [*]512 Memory. Optional memory is required for each unit. (Included in the Printer Unit or P/S Unit for NA models) Printer Scanner Unit Type 5002 (D641) [*]Scanner Enhance Option [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_018.jpg[/IMG] [HEADING=3]Three Main Units[/HEADING] [*]Printer Unit Type 5002: For customers who do not require the extended scanning features but need more printing capability (PCL printer languages are provided). The 512 MB memory is required. [*]Printer/Scanner Unit Type 5002: For customers who require the full range of DS features (advanced scanning and printing features such as "scan-to" solutions, virtual mailboxes, PCL, etc.). The 512 MB memory unit is required. [HEADING=3]Separate Options[/HEADING] There are two separate options: 512 MB memory and PS3. [*]512 MB memory: Every unit (Printer Unit, P/S unit) requires installation of the 512 MB memory. [*]PostScript 3 Unit: The PS3 option can be used with the Printer Unit, or the Printer/Scanner Unit. [HEADING=3]Enhance Options[/HEADING] Scanner Enhance Option Type 5002 updates the Printer Unit by adding the advanced scanning features. [/LIST] [*][HEADING=3]KIT CONTENTS[/HEADING] Check the accessories and their quantities against the list below and the illustration on the next page. This is a common list for all the kits. [HEADING=3]Common Accessory Table[/HEADING] This common accessory table lists all the items of the following units. [LIST] [*]PU: Printer Unit [*]P/S: Printer/Scanner Unit [*]SEO: Scanner Enhance Unit [TABLE] [TR] [TD] No.[/TD] [TD] Description[/TD] [TD] Q'ty[/TD] [TD]Kit Contents[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]PU[/TD] [TD]P/S[/TD] [TD]SEO[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]512 MB Memory*1[/TD] [TD]-[/TD] [TD]No[/TD] [TD]No[/TD] [TD]No[/TD] [/TR] [TR] [TD]1[/TD] [TD]HDD Unit[/TD] [TD]1[/TD] [TD]Yes[/TD] [TD]Yes[/TD] [TD]No[/TD] [/TR] [TR] [TD]2[/TD] [TD]Screw[/TD] [TD]3[/TD] [TD]Yes[/TD] [TD]Yes[/TD] [TD]No[/TD] [/TR] [TR] [TD]3[/TD] [TD]SD Card[/TD] [TD]1[/TD] [TD]Yes[/TD] [TD]Yes[/TD] [TD]Yes[/TD] [/TR] [/TABLE] *1: The 512 Memory is a separate option and it is not provided in the kits. However, one memory unit is required for the installation of every print unit. (Included in the Printer Unit or P/S Unit for NA models) [/LIST] [*][HEADING=3]PRINTER/SCANNER INSTALLATION[/HEADING] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_019.png[/IMG] [LIST] [*]Turn off the main power switch and disconnect the power supply cord. 1. Remove the controller board [A] ( x 2). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_020.jpg[/IMG] Printer Scanner Unit Type 5002 (D641) [/LIST] [/LIST] [/LIST] [*]Connect the two harnesses to the HDD unit [A] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_021.gif[/IMG] x 2). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_022.jpg[/IMG] [*]Install the connecting board unit [A] on the HDD unit [B] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_023.gif[/IMG] x 2). [*]Connect the two harnesses from the HDD unit to the connecting board [A] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_024.gif[/IMG] x 2). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_025.jpg[/IMG] [*]Install the HDD unit [A] on the controller board unit [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_026.gif[/IMG] x3). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_027.jpg[/IMG] [*]Install the 512 MB memory [A]. [*]Reinstall the controller board. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_028.jpg[/IMG] Printer Scanner Unit Type 5002 (D641) [*]Remove the controller cover [A]. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_029.jpg[/IMG] [*]Insert the Printer/Scanner SD card in SD card Slot 1 (Upper Slot) [A]. [*]Reattach the cover. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_030.gif[/IMG] [*]Attach the supplied ferrite core [A] at the machine end of the Ethernet cable. [*]Connect the Ethernet interface cable to the 10BASE-T/100BASE-TX port [A]. [*]Connect the other end of the Ethernet interface cable to a network connection device such as a hub. [*]Connect the machine’s power cord and turn the main power switch on. [*]Enable the NIB and/or USB function. [LIST] [*]To enable the NIB function, enter the SP mode and set SP5985-001 (On Board NIC) to "1" (Enable). [*]To enable the USB function, enter the SP mode and set SP5985-002 (On Board USB) to “1" (Enable). [LIST=1] [*][HEADING=3]SCANNER ENHANCE OPTION[/HEADING] [HEADING=3]Accessory Check[/HEADING] Refer to the "Common Accessory Table" in this chapter. [HEADING=3]Installation (Application Merge)[/HEADING] The installation of the scanner enhance option are done with [B]SP5873-001 (Application Move)[/B]. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_031.png[/IMG] [LIST] [*]If you are going to update the RPCS unit with both the printer and scanner enhance options, the order of execution is not important. [LIST=1] [*]Turn off the copier. [*]Remove the cover [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_032.gif[/IMG]x1). [*]Confirm that the Printer Unit SD card is in SD card Slot [B]1 [/B](Upper Slot). [*]Put the option SD Card (Scanner Enhance Option) in SD card Slot [B]2 [/B](Lower Slot). [*]Open the front door. [*]Turn the copier on. [*]Go into the SP mode and select [B]SP5873-001[/B]. [*]Touch "Execute". [*]Read the instructions on the display and touch "Execute" to start. [*]When the display tells you copying is completed, touch "Exit", then turn the copier off. [*]Remove the option SD card from Slot [B]2 [/B](Lower Slot). [*]Turn the copier on. [*]Go into the User Tools mode and confirm that update was successful. [*]User Tools> System Settings> Administrator Tools> Firmware Version> Next [*]Turn the copier off again, then reattach the cover. [*]Return the copied SD card to the customer for safekeeping, or tape it to the faceplate of the controller. [/LIST] [HEADING=3]To undo an option update[/HEADING] [LIST=1] [*]Turn the main switch off. [*]Confirm that the Printer Unit SD card is in SD card Slot [B]1 [/B](Upper Slot). [*]Put the original option SD card (Scanner Enhance Option) in SD card Slot [B]2 [/B](Lower Slot). [*]Turn the main switch on. [*]Go into the SP mode and do [B]SP5873-002 [/B](Undo Exec). [*]Follow the messages on the operation panel to complete the procedure. Printer Scanner Unit Type 5002 (D641) [*]Turn the main switch off. [*]Remove the option SD card from Slot [B]2 [/B](Lower Slot). [*]Turn the main switch on. [*]Go into the User Tools mode and confirm that undo was successful. User Tools> System Settings> Administrator Tools> Firmware Version> Next [*]Turn the copier off again, then reattach the cover. [/LIST] [HEADING=3]Important Notes about SD Cards[/HEADING] Here are some basic rules about merging applications on SD cards. [LIST] [*]The data necessary for authentication is transferred with the application program to the target SD card. [*]The SD card is the only evidence that the customer is licensed to use the application program. The service technician may occasionally need to check the SD card and its data to solve problems. SD cards must be stored in a safe location at the work site. [*]Once the merge is completed, the SD card from which the application was copied cannot be used again, but the customer must keep the card to serve as proof of purchase. [*]An SD card from which an application has been moved to another SD card can be restored to full operation with [B]SP5873-002 [/B](Undo). [*]Before storing the card from which an application has been copied, label it carefully so that you can identify it easily if you need to do the undo procedure later. [/LIST] [/LIST] [*][HEADING=3]APPLICATION MERGE[/HEADING] This machine has two SD card slots only. However, more than two optional applications are supplied for this machine. Always keep SD card Slot 2 (Lower Slot) vacant for servicing (except for the VM Card). Because of this, SD card merge is required if a customer wants to use many applications. Consider the following limitations when you try to merge SD cards. [LIST] [*]The destination SD card should have the largest memory size of all the application SD cards. Refer to the following table for the memory size of each SD card. [TABLE] [TR] [TD]SD Card Options[/TD] [TD]SD Card Size[/TD] [/TR] [TR] [TD]Printer/Scanner Unit Type 5000[/TD] [TD]512 MB[/TD] [/TR] [TR] [TD]Printer Unit Type 5002[/TD] [TD]512 MB[/TD] [/TR] [TR] [TD]Scanner Enhance Option Type 5002[/TD] [TD]128 MB[/TD] [/TR] [TR] [TD]PostScript3 Unit Type 5000[/TD] [TD]512 MB[/TD] [/TR] [TR] [TD]IPDS Unit Type 5002[/TD] [TD]128 MB[/TD] [/TR] [TR] [TD]SD card for NetWare printing Type K[/TD] [TD]128 MB[/TD] [/TR] [TR] [TD]Browser Unit Type I[/TD] [TD]128 MB[/TD] [/TR] [TR] [TD]VM Card Type U[/TD] [TD]512 MB[/TD] [/TR] [/TABLE] [HEADING=3]If more than one application is required…[/HEADING] Merge all applications which the customer wants to use into one SD card (Destination card inserted in Slot 1 (Upper Slot)). [/LIST] [/LIST] [*][HEADING=2]INSTALLING CONTROLLER OPTIONS[/HEADING] [LIST=1] [*][HEADING=3]OVERVIEW[/HEADING] Printer Scanner Unit Type 5002 (D641) This machine has a board slot for optional I/F connection and two SD card slots for applications. After you install an option, check that the machine can recognize it. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_033.gif[/IMG] p.30 "Check All Connections") [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_034.jpg[/IMG] [HEADING=3]Board Slot[/HEADING] [LIST] [*]This slot [4] is used for one of the optional board connections (only one can be installed): IEEE1284, IEEE802.11a/g, g (Wireless LAN), Gigabit Ethernet, or File Format Converter. [HEADING=3]SD Card Slots[/HEADING] [*]PostScript3 Unit, IPDS Unit, Browser Unit, SD Card for Netware printing should be installed in Slot 1 (Upper Slot) [1]. [*]VM Card must be installed in Slot 2 (Lower Slot) [2]. However, it can also be merged to the SD card in Slot 1 (Upper Slot). [HEADING=3]USB Slots[/HEADING] [*]Bluetooth Interface Unit is installed in the USB slot [3]. [/LIST] [*][HEADING=3]POSTSCRIPT 3 UNIT (D641)[/HEADING] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_035.png[/IMG] [LIST] [*]Unplug the main machine power cord before you do the following procedure. 1. Remove the controller cover [A] ( x 2) [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_036.jpg[/IMG] [LIST=1] [*]Turn the SD-card label face to the rear of the machine. Then push it slowly into Slot 1 (Upper Slot) [A] until you hear a click. [*]Attach the controller cover [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_037.gif[/IMG] x 2). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_038.jpg[/IMG] [*]Attach the "Adobe PostScript 3" decal [A] to the front door. [*]Make sure that the machine can recognize the option. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_039.gif[/IMG] p.30 "Check All Connections") [/LIST] [/LIST] [*][HEADING=3]FILE FORMAT CONVERTER (D377)[/HEADING] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_040.png[/IMG] [LIST] [*]Unplug the main machine power cord before you do the following procedure. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_041.jpg[/IMG] Printer Scanner Unit Type 5002 (D641) [LIST=1] [*]Remove the slot cover [A] from the board slot [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_042.gif[/IMG] x 2). [*]Install the file format converter into the board slot, and then fasten it with screws. [*]Plug in and turn on the main power switch. [*]Check or set the following SP codes with the values shown below. [TABLE] [TR] [TD]SP No.[/TD] [TD]Title[/TD] [TD]Setting[/TD] [/TR] [TR] [TD]SP5-836-001[/TD] [TD]Capture Function (0:Off 1:On)[/TD] [TD]"1"[/TD] [/TR] [TR] [TD]SP5-836-002[/TD] [TD]Panel Setting[/TD] [TD]"0"[/TD] [/TR] [/TABLE] [*]Check the operation. [*]Make sure that the machine can recognize the option. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_043.gif[/IMG] p.30 "Check All Connections") [/LIST] [/LIST] [*][HEADING=3]IEEE 1284 INTERFACE BOARD (B679)[/HEADING] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_044.png[/IMG] [LIST] [*]Unplug the main machine power cord before you do the following procedure. [/LIST] [/LIST] [/LIST] [/B][/LIST][B] You can only install one of the following network interfaces at one time: (IEEE 802.11a/g, g (Wireless LAN), IEEE1284, Bluetooth). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_045.jpg[/IMG] [LIST=1] [*]Remove the slot cover [A] from the board slot [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_046.gif[/IMG] x 2). [*]Install the interface board (Knob-screw x 2) into the board slot. [*]Make sure that the machine can recognize the option. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_047.gif[/IMG] p.30 "Check All Connections") [HEADING=3]1.3.5 IEEE 802.11A/G OR G (D377)[/HEADING] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_048.png[/IMG] [LIST] [*]Unplug the main machine power cord before you do the following procedure. [/LIST] [/LIST] You can only install one of the following network interfaces at one time: (IEEE 802.11a/g, g (Wireless LAN), IEEE1284, Bluetooth). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_049.jpg[/IMG] Printer Scanner Unit Type 5002 (D641) [LIST=1] [*]Remove the slot cover [A] from the board slot [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_050.gif[/IMG] x 2). [*]Install the wireless LAN board (Knob-screw x 2) into the board slot. [*]Make sure that the machine can recognize the option. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_051.gif[/IMG] p.30 "Check All Connections") [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_052.jpg[/IMG] [*]Peel off the double-sided tapes on the Velcro fasteners [A], and then attach them [B] at the front left and rear right of the machine. [*]Attach the "ANT1" (having a black ferrite core) to the front left of the machine. [*]Attach the "ANT2" (having a white ferrite core) to the rear right of the machine. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_053.png[/IMG] [LIST] [*]"ANT1" is a transmission/reception antenna and "ANT2" is a reception antenna. Do not attach them at the wrong places. [/LIST] [*]Attach the clamps as shown above. [*]Wire the cables and clamp them [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_054.gif[/IMG] x 8). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_055.png[/IMG] [LIST] [*]Make sure that the cables are not slack. Keep them wired tightly along the covers. You may have to move the machine if the reception is not clear. [/LIST] [/B][/LIST][B] [LIST] [*]Make sure that the machine is not located near an appliance or any type of equipment that generates strong magnetic fields. [*]Put the machine as close as possible to the access point. [HEADING=3]User Tool Settings for IEEE 802.11a/g[/HEADING] Go into the User Tools mode and do the procedure below. These settings take effect every time the machine is powered on. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_056.png[/IMG] [LIST] [*]You cannot use IEEE 802.11a/g if you use Ethernet. [/LIST] [/LIST] [LIST=1] [*]Press the “User Tools” key. [*]On the touch panel, touch “System Settings”. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_057.png[/IMG] [LIST] [*]Select “Interface Settings”> “Network” > “LAN Type”. The “LAN Type” (default: Ethernet) must be set for either Ethernet or wireless LAN. [/LIST] [*]Select “Interface Settings”> “Wireless LAN”. Only the wireless LAN options show. [*]Set the “Communication Mode“. [*]Enter the “SSID setting”. (The setting is case sensitive.) [*]Set the “Ad-hoc Channel”. You need this setting when Ad Hoc Mode is selected. The allowed range for the channel settings may vary for different countries. [LIST] [*]Region A (mainly Europe and Asia) Range: 1-13, 36, 40, 44 and 48 channels (default: 11) [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_058.png[/IMG] [LIST] [*]In some countries, only the following channels are available: [*]Range: 1-11 channels (default: 11) [/LIST] [*]Region B (mainly North America) Range: 1-11, 36, 40, 44 and 48 channels (default: 11) [/LIST] [*]Set the “Security Method” to specify the encryption of the Wireless LAN. [LIST] [*]The “WEP” (Wired Equivalent Privacy) setting is designed to protect wireless data transmission. The same WEP key is required on the receiving side in order to unlock encoded data. There are 64 bit and 128 bit WEP keys. Range of Allowed Settings: 64 bit: 10 characters 128 bit: 26 characters [*]Specify “WPA” when “Communication Mode” is set to “Infrastructure Mode”. Set the “WPA Encryption Method” and “WPA Authent. Method”. [LIST] [*]WPA Encryption Method: Printer Scanner Unit Type 5002 (D641) Select either "TKIP" or "CCMP (AES)". [*]WPA Authent. Method: Select either “WPA-PSK”, “WPA”, “WPA2-PSK", or “WPA2”. If you select “WPA-PSK” or “WPA2-PSK”, enter the pre-shared key (PSK) of 8 - 63 characters in ASCII code. When “WPA” or “WPA2” are selected, authentication settings and certificate installation settings are required. [/LIST] [/LIST] [*]Press “Wireless LAN Signal” to check the machine's radio wave status using the operation panel. [*]Press “Restore Factory Defaults” to initialize the wireless LAN settings. Press “Yes” to initialize the following settings: [LIST] [*]Transmission mode [*]Channel [*]Transmission Speed [*]WEP [*]SSID [*]WEP Key [/LIST] [/LIST] [HEADING=3]SP Mode Settings for IEEE 802.11 Wireless LAN[/HEADING] The following SP commands and UP modes can be set for IEEE 802.11 [TABLE] [TR] [TD]SP No.[/TD] [TD]Name[/TD] [TD]Function[/TD] [/TR] [TR] [TD] 5840 006[/TD] [TD] Channel MAX[/TD] [TD]Sets the maximum range of the channel settings for the country.[/TD] [/TR] [TR] [TD] 5840 007[/TD] [TD] Channel MIN[/TD] [TD]Sets the minimum range of the channels settings allowed for your country.[/TD] [/TR] [TR] [TD] 5840 008[/TD] [TD] Transmission Speed[/TD] [TD]Sets the transmission speed. Auto, 54 Mbps, 48 Mbps, 36 Mbps, 24 Mbps, 18 Mbps, 12 Mbps, 9 Mbps, 6 Mbps, 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps (default: Auto).[/TD] [/TR] [TR] [TD]5840 011[/TD] [TD]WEP Key Select[/TD] [TD]Used to select the WEP key (Default: 00).[/TD] [/TR] [TR] [TD] UP mode[/TD] [TD]Name[/TD] [TD]Function[/TD] [/TR] [TR] [TD]SSID[/TD] [TD]Used to confirm the current SSID setting.[/TD] [TD][/TD] [/TR] [TR] [TD]WEP Key[/TD] [TD]Used to confirm the current WEP key setting.[/TD] [TD][/TD] [/TR] [TR] [TD] WEP Mode[/TD] [TD]Used to show the maximum length of the string that can be used for the WEP Key entry.[/TD] [TD][/TD] [/TR] [TR] [TD]WPA Encryption Method[/TD] [TD] Used to confirm the current WPA encryption setting.[/TD] [TD][/TD] [/TR] [TR] [TD]WPA Authent. Method[/TD] [TD]Used to confirm the current WPA authentication setting and pre-shared key.[/TD] [TD][/TD] [/TR] [/TABLE] [INDENT][LIST=1] [LIST=1] [*][HEADING=3]BLUETOOTH UNIT (D566)[/HEADING] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_059.png[/IMG] [LIST] [*]Turn off the main power switch and disconnect the power supply cord. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_060.jpg[/IMG] Printer Scanner Unit Type 5002 (D641) [LIST=1] [*]Insert the Bluetooth unit into the USB-A slot [A]. [*]Make sure that the machine can recognize the option. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_061.gif[/IMG] p.30 "Check All Connections") [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_062.png[/IMG] [LIST] [*]Bluetooth Unit and IEEE 802.11a/g or g Interface Unit cannot be set at the same time. [/LIST] [/LIST] [/LIST] [*][HEADING=3]GIGABIT ETHERNET (G874)[/HEADING] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_063.png[/IMG] [LIST] [*]Unplug the main machine power cord before you do the following procedure. You can only install one of the following network interfaces at one time: (IEEE 802.11a/g, g (Wireless LAN), IEEE1284, IEEE1394, Bluetooth). [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_064.jpg[/IMG] [LIST=1] [*]Remove the slot cover [A] from the board slot [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_065.gif[/IMG] x 2). [*]Insert the Gigabit Ethernet Board into the I/F slot and fasten it with the screws. [*]Print a configuration page to confirm that the machine recognizes the installed board for USB2.0: User Tools > Printer Features > List/Test Print > Configuration Page [/LIST] [/LIST] [*][HEADING=3]IPDS UNIT (D641)[/HEADING] [HEADING=3]Accessories[/HEADING] Check the accessories and their quantities against the table below. [TABLE] [TR] [TD]No.[/TD] [TD]Description[/TD] [TD]Q'ty[/TD] [/TR] [TR] [TD]1[/TD] [TD]IPDS Emulation SD Card[/TD] [TD]1[/TD] [/TR] [TR] [TD]2[/TD] [TD]Decal[/TD] [TD]1[/TD] [/TR] [/TABLE] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_066.png[/IMG] Printer Scanner Unit Type 5002 (D641) [LIST] [*]Only two slots are available for SD cards that contain applications. If you want to use more than two applications, merge all applications into two SD cards (SP5873-001). [HEADING=3]Installation[/HEADING] [LIST=1] [*]Check the software version. [*]If necessary, update the firmware to the required version. [*]Turn off the main switch. [/LIST] Remove the controller cover [A] ( x 2) 4. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_067.jpg[/IMG] [LIST=1] [*]Insert the IPDS SD Card into Slot 1 (Upper Slot) [A]. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_068.png[/IMG] [LIST] [*]Pushing in the SD Card releases it for removal. Make sure the SD Card is inserted and locked in place. If it is partially out of the slot, push it in gently until it locks in place. [/LIST] [*]Reattach the controller cover and turn ON the main switch. [*]Do one of the following ("A" or "B") to enable the IPDS function. [LIST=1] [*][Enable the IPDS function via telnet] [LIST=1] [*]Connect the machine via telnet. [*]Execute the following commands: msh> [B]set ipds up[/B] ***If you want to stop the function. msh> [B]set ipds down[/B] [/LIST] [*][Enable the IPDS option via WebImageMonitor] [LIST=1] [*]Log in to WebImageMonitor. [*]Change the setting to enable IPDS. [/LIST] [/LIST] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_069.jpg[/IMG] Printer Scanner Unit Type 5002 (D641) [*]Attach the decal [A] as shown in the photo above. [LIST] [*]Line up the left side of the decal with the left edged of the main power switch. ([B]: 10 mm or more) [/B][/LIST][B] [/b][/LIST][B] [/b][/LIST][B] [*][HEADING=3]VM CARD TYPE U (D640)[/HEADING] This option is only for basic models. [HEADING=3]Accessories[/HEADING] Check the accessories and their quantities against the table below. [TABLE] [TR] [TD]Description[/TD] [TD]Q'ty[/TD] [/TR] [TR] [TD]1. VM SD Card[/TD] [TD]1[/TD] [/TR] [TR] [TD]2. Decal[/TD] [TD]1[/TD] [/TR] [/TABLE] [HEADING=3]Installation[/HEADING] Printer Scanner Unit Type 5002 (D641) 1. Switch the machine off. Remove the controller cover [A] ( x 2) 2. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_070.jpg[/IMG] [LIST=1] [*]Insert the SD card into SD Slot 2 (Lower Slot) [A]. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_071.png[/IMG] [LIST] [*]This SD card must be inserted into Slot 2 (Lower Slot). [/LIST] [/LIST] [/b][/LIST][B] [*][HEADING=2]CHECK ALL CONNECTIONS[/HEADING] [/b][/LIST][B][/b][/INDENT][B] Plug in the power cord. Then turn on the main switch. Enter the printer user mode. Then print the configuration page. User Tools > Printer Features > List Test Print > Configuration Page All installed options are shown in the “System Reference” column. [LIST=1] [*][HEADING=2]SERVICE TABLES[/HEADING] [LIST=1] [*][HEADING=2]PRINTER SERVICE TABLES[/HEADING] Printer Scanner Unit Type 5002 (D641) [LIST=1] [*][HEADING=3]SP1-XXX (SERVICE MODE)[/HEADING] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]001[/TD] [TD]Bit Switch 1[/TD] [TD]0[/TD] [TD]1[/TD] [/TR] [TR] [TD]bit 0[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 1[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 2[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 3[/TD] [TD]No I/O Timeout[/TD] [TD]0: Disable[/TD] [TD]1: Enable[/TD] [/TR] [TR] [TD]Enable: The MFP I/O Timeout setting will have no effect. I/O Timeouts will never occur.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]bit 4[/TD] [TD]SD Card Save Mode[/TD] [TD]0: Disable[/TD] [TD]1: Enable[/TD] [/TR] [TR] [TD]Enable: Print jobs will be saved to an SD Card in the GW SD slot.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]bit 5[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 6[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 7[/TD] [TD][RPCS,PCL]: Printable area frame border[/TD] [TD]0: Disable[/TD] [TD]1: Enable[/TD] [/TR] [TR] [TD]Enable: The machine prints all RPCS and PCL jobs with a border on the edges of the printable area.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]002[/TD] [TD]Bit Switch 2[/TD] [TD]0[/TD] [TD]1[/TD] [/TR] [TR] [TD]bit 0[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 1[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 2[/TD] [TD]Applying a collation Type[/TD] [TD]Shift Collate[/TD] [TD]Normal Collate[/TD] [/TR] [TR] [TD]A collation type (shift or normal) will be applied to all jobs that do not already have a ‘Collate Type’ configured. [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_072.png[/IMG][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]bit 3[/TD] [TD][PCL5e/c,PS]: PDL Auto Switching[/TD] [TD]0: Enable[/TD] [TD]1: Disable[/TD] [/TR] [TR] [TD]Disable: The MFPs ability to change the PDL processor mid-job. Some host systems submit jobs that contain both PS and PCL5e/c. If Auto PDL switching is disabled, these jobs will not be printed properly.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]bit 4[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 5[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 6[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 7[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [/TABLE] [LIST] [*]If #5-0 is enabled, this Bit Switch has no effect. Printer Scanner Unit Type 5002 (D641) [/LIST] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]003[/TD] [TD]Bit Switch 3[/TD] [TD]0[/TD] [TD]1[/TD] [/TR] [TR] [TD]bit 0[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 1[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 2[/TD] [TD][PCL5e/c]: Legacy HP compatibility[/TD] [TD]0: Disable[/TD] [TD]1: Enable[/TD] [/TR] [TR] [TD]Enable: Uses the same left margin as older HP models such as HP4000/HP8000. In other words, the left margin defined in the job (usually "<ESC>*r0A") will be changed to "<ESC>*r1A"[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]bit 3[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 4[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 5[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 6[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 7[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]004[/TD] [TD]Bit Switch 4[/TD] [TD]0[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 0[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD]bit 1[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [TD][/TD] [/TR] [TR] [TD]bit 2[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [TD][/TD] [/TR] [TR] [TD]bit 3[/TD] [TD]IPDS print-side reversal[/TD] [TD]0: Disable[/TD] [TD]1: Enable[/TD] [TD][/TD] [/TR] [TR] [TD]Enable: Increases printing speed but simplex pages may be printed on the back side of the sheet.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]bit 4[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [TD][/TD] [/TR] [TR] [TD]bit 5[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [TD][/TD] [/TR] [TR] [TD]bit 6[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [TD][/TD] [/TR] [TR] [TD]bit 7[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [TD][/TD] [/TR] [/TABLE] Printer Scanner Unit Type 5002 (D641) [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]005[/TD] [TD]Bit Switch 5[/TD] [TD]0[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD] bit 0[/TD] [TD]Show "Collate Type", "Staple Type" and "Punch Type" buttons on the operation panel.[/TD] [TD] Disable[/TD] [TD] Enable[/TD] [/TR] [TR] [TD]If enabled, users will be able to configure a Collate Type, Staple Type, and Punch Type from the operation panel. The available types will depend on the device and configured options. After enabling the function, the settings will appear under: "User Tools > Printer Features > System"[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 1[/TD] [TD]Multiple copies if a paper size or type mismatch occurs[/TD] [TD]0: Disable (Single copy)[/TD] [TD] 1: Enable (Multiple copy)[/TD] [/TR] [TR] [TD]If a paper size or type mismatch occurs during the printing of multiple copies, only a single copy is output by default. Using this Bit Switch, the device can be configured to print all copies even if a paper mismatch occurs.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 2[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD][/TD] [TD]bit 3[/TD] [TD][PS] PS Criteria[/TD] [TD]Pattern3[/TD] [TD]Pattern1[/TD] [/TR] [TR] [TD]Change the number of PS criterion used by the PS interpreter to determine whether a job is PS data or not. Pattern3: includes most PS commands. Pattern1: A small number of PS tags and headers[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 4[/TD] [TD]Increase max number of the stored jobs to 1000 jobs.[/TD] [TD]Disable (100)[/TD] [TD]Enable (1000)[/TD] [/TR] [TR] [TD]Enable: Changes the maximum number of jobs that can be stored on the HDD via Job Type settings to 1000. The default is 100.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 5[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD][/TD] [TD]bit 6[/TD] [TD]Method for determining the image rotation for the edge to bind on.[/TD] [TD] 0: Disable[/TD] [TD] 1: Enable[/TD] [/TR] [TR] [TD]If enabled, the image rotation will be performed as they were in the specifications of older models for the binding of pages of mixed orientation jobs. The old models are below:[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 7[/TD] [TD] Letterhead mode printing[/TD] [TD] 0: Disable[/TD] [TD]1: Enable (Duplex)[/TD] [/TR] [TR] [TD]Routes all pages through the duplex unit. If this is disabled, simplex pages or the last page of an odd-paged duplex job are not routed through the duplex unit. This could result in problems with letterhead/pre-printed pages. Only affects pages specified as Letterhead paper.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [LIST] [*]PCL: Pre-04A models [*]PS/PDF/RPCS:Pre-05S models [/LIST] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]006[/TD] [TD]Bit Switch 6 [B]DFU[/B][/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]007[/TD] [TD]Bit Switch 7[/TD] [TD]0[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD] bit 0[/TD] [TD]Print path[/TD] [TD]0: Disable[/TD] [TD]1: Enable[/TD] [/TR] [TR] [TD]If enabled, simplex pages (in mixed simplex/duplex PS/PCL5 jobs only) and the last page of an odd paged duplex job (PS, PCL5, PCL6), are always routed through the duplex unit. Not having to switch paper paths increases the print speed slightly.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 1 to 7[/TD] [TD] DFU[/TD] [TD] -[/TD] [TD] -[/TD] [/TR] [/TABLE] Printer Scanner Unit Type 5002 (D641) [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]008[/TD] [TD]Bit Switch 8 [B]DFU[/B][/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]009[/TD] [TD]Bit Switch 9[/TD] [TD]0[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD] bit 0[/TD] [TD]PDL Auto Detection timeout of jobs submitted via USB or Parallel Port (IEEE 1284).[/TD] [TD] "Disabled (Immediately)"[/TD] [TD] "Enabled (10 seconds)"[/TD] [/TR] [TR] [TD][/TD] [TD]To be used if PDL auto-detection fails. A failure of PDL autodetection doesn't necessarily mean that the job can't be printed. This bit switch tells the device whether to time-out immediately (default) upon failure or to wait 10 seconds.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 1[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD][/TD] [TD]bit 2[/TD] [TD]Job Cancel[/TD] [TD]Disabled (Not cancelled)[/TD] [TD] Enabled (Cancelled)[/TD] [/TR] [TR] [TD]If this bit switch, all jobs will be cancelled after a jam occurs. Note: If this bitsw is enabled, printing under the following conditions might result in problems:[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 3[/TD] [TD]PCL/PS bypass tray paper rotation (SEF/LEF)[/TD] [TD] 0: Disable[/TD] [TD] 1: Enable[/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD]This bitsw causes the device to revert to the behavior of previous generations. It only takes effect if "Bypass Tray Setting Priority" = "Driver/Command". Previous spec (bitsw=1): If a standard sized paper mismatch occurred in the bypass tray, the MFP always prompted for SEF paper. If this bitsw=0 (default) then in the event of a standard sized paper mismatch, the MFP will always prompt for paper of the rotation (SEF/LEF) determined by the MFP bypass tray paper setting or by the bypass tray sensor.[/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [LIST] [*]Job submission via USB or Parallel Port [*]Spool printing (WIM >Configuration > Device Settings > System) [TABLE] [TR] [TD][/TD] [TD]bit 4[/TD] [TD]Response to PJL USTATUS when multiple collated copies are printed[/TD] [TD] 0: Disable[/TD] [TD] 1: Enable[/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD]When enabled, if multiple collated copies are printed, the device no longer responds to PJL USTATUS with the number of pages in the current copy. Instead the device will return the total number of pages for all copies.[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]Bit 5 to 7[/TD] [TD]DFU[/TD] [TD] -[/TD] [TD] -[/TD] [/TR] [/TABLE] [/LIST] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]010[/TD] [TD]Bit Switch 10[/TD] [TD]0[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 0 to 4[/TD] [TD] DFU[/TD] [TD] -[/TD] [TD] -[/TD] [/TR] [TR] [TD][/TD] [TD]bit 5[/TD] [TD]List / Test Print Lock[/TD] [TD]0: Disable[/TD] [TD]1: Enable[/TD] [/TR] [TR] [TD][/TD] [TD]If enabled, you can lock or unlock the [List/Test Print] items under the Pinter Features menu when the Store and Skip Errored Job Function is on.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]Bit 6[/TD] [TD]Optional charge machines[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [TR] [TD][/TD] [TD]If enabled, you can use the optional charge machines when the Store and Skip Errored Job Function is on.[/TD] [TD] 0: Disable[/TD] [TD] 1: Enable[/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]Bit 7[/TD] [TD]DFU[/TD] [TD]-[/TD] [TD]-[/TD] [/TR] [/TABLE] Printer Scanner Unit Type 5002 (D641) [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]011[/TD] [TD]Bit Switch 11[/TD] [TD]0[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 0[/TD] [TD]List / Test Print menu[/TD] [TD]0: Disable[/TD] [TD]1: Enable[/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD]When enabled, [Multiple Lists] menu is displayed in [List / Test Print] under the Printer Features menu.[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 1[/TD] [TD]Interrupt printing[/TD] [TD]0: Job[/TD] [TD]1: Page[/TD] [/TR] [TR] [TD][/TD] [TD]Selects the interrupting units for the interrupt printing function. When you select "0," you can interrupt printing of a job while being processed. When you select "1," you can interrupt printing of a page while being processed.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]Bit 2 to 7[/TD] [TD]DFU[/TD] [TD] -[/TD] [TD] -[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1001[/TD] [TD]Bit Switch[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]012[/TD] [TD]Bit Switch 12[/TD] [TD]0[/TD] [TD]1[/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD]bit 0 to 7[/TD] [TD] DFU[/TD] [TD] -[/TD] [TD] -[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1003[/TD] [TD][Clear Setting][/TD] [/TR] [TR] [TD] 1003 001[/TD] [TD]Initialize Printer System[/TD] [/TR] [TR] [TD]Initializes settings in the "System" menu of the user mode.[/TD] [TD][/TD] [/TR] [TR] [TD]1003 003[/TD] [TD]Delete Program[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1004[/TD] [TD][Print Summary][/TD] [/TR] [TR] [TD] 1004 001[/TD] [TD]Print Printer Summary[/TD] [/TR] [TR] [TD]Prints the service summary sheet (a summary of all the controller settings).[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1006[/TD] [TD][Sample/Locked Print][/TD] [TD]*CTL[/TD] [TD]0: Link with Doc. Svr, 1: Enable[/TD] [/TR] [TR] [TD] 1006 001[/TD] [TD]Enables and disables the document server. When you select "0," the document server is enabled or disabled in accordance with Copy Service Mode SP5-967. When you select "1," the document server is enabled regardless of Copy Service Mode SP5-967.[/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1110[/TD] [TD][Media Print Device Setting][/TD] [TD][/TD] [/TR] [TR] [TD]1110 002[/TD] [TD]0: Disable [B]1[/B]: Enable[/TD] [TD]Selects the setting for the media print device.[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]1111[/TD] [TD][All Job Delete Mode][/TD] [TD][/TD] [/TR] [TR] [TD] 1111 001[/TD] [TD] 0: excluding New Job 1: including New Job[/TD] [TD]Select whether to include an image processing job in jobs subject to full cancellation from the SCS job list.[/TD] [/TR] [/TABLE] [/LIST] [*][HEADING=2]SCANNER SERVICE TABLES[/HEADING] Printer Scanner Unit Type 5002 (D641) [LIST=1] [*][HEADING=3]SP1-XXX (SYSTEM AND OTHERS)[/HEADING] [TABLE] [TR] [TD] 1005[/TD] [TD][Erase margin (Remote Scan)][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]Creates an erase margin for all edges of the scanned image. If the machine has scanned the edge of the original, create a margin. This SP is activated only when the machine uses TWAIN scanning.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]1005 1[/TD] [TD]Range from 0 to 5 mm[/TD] [TD]*CTL[/TD] [TD][0 to 5 / [B]0 [/B]/ 1 mm/step ][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] 1009[/TD] [TD] [Remote scan disable][/TD] [TD] *CTL[/TD] [TD][0 or 1 / [B]0 [/B]/ - ] 0: enable, 1: disable[/TD] [/TR] [TR] [TD]1009 1[/TD] [TD]Enable or disable remote scan.[/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] 1010[/TD] [TD][Non Display Clear Light PDF][/TD] [TD] *CTL[/TD] [TD][0 or 1 / [B]0 [/B]/ - ] 0: Display, 1: No display[/TD] [/TR] [TR] [TD]1010 1[/TD] [TD]Enable or disable remote scan.[/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] 1011[/TD] [TD] [Org Count Disp][/TD] [TD] *CTL[/TD] [TD][0 or 1 / [B]0 [/B]/ - ] 0: No display, 1: Display[/TD] [/TR] [TR] [TD]1011 1[/TD] [TD]This SP codes switches the original count display on/off.[/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] 1012[/TD] [TD] [User Info Release][/TD] [TD] *CTL[/TD] [TD][0 or 1 / [B]1 [/B]/ - ] 0: Do not release, 1: Release[/TD] [/TR] [TR] [TD] 1012 1[/TD] [TD]This SP code sets the machine to release or not release the following items at job end.[/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [LIST] [*]Destination (E-mail/Folder/CS) [*]Sender name [*]Mail Text [*]Subject line [*]File name [/LIST] [TABLE] [TR] [TD] 1013[/TD] [TD][Scan Media Device Setting][/TD] [TD] *CTL[/TD] [TD][0 or 1 / [B]1 [/B]/ - ] 0: Disable, 1: Enable[/TD] [/TR] [TR] [TD] 1013 1[/TD] [TD]This SP code enables/disables the multi-media function option (USB 2.0/SD Slot) mounted on the left rear corner of the machine. Operators can scan documents to either an SD card or a USB memory device inserted into this unit. This SP must be enabled (set to "1") in order for the device to function.[/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] Printer Scanner Unit Type 5002 (D641) [*][HEADING=3]SP2-XXX (SCANNING-IMAGE QUALITY)[/HEADING] [TABLE] [TR] [TD] 2021[/TD] [TD][Compression Level (Gray-scale)][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]Selects the compression ratio for grayscale processing mode (JPEG) for the three settings that can be selected at the operation panel.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]2021 1[/TD] [TD]Comp1: 5-95[/TD] [TD] *CTL[/TD] [TD][5 to 95 / [B]20 [/B]/ 1 /step ][/TD] [/TR] [TR] [TD]2021 2[/TD] [TD]Comp2: 5-95[/TD] [TD][5 to 95 / [B]40 [/B]/ 1 /step ][/TD] [TD][/TD] [/TR] [TR] [TD]2021 3[/TD] [TD]Comp3: 5-95[/TD] [TD][5 to 95 / [B]65 [/B]/ 1 /step ][/TD] [TD][/TD] [/TR] [TR] [TD]2021 4[/TD] [TD]Comp4: 5-95[/TD] [TD][5 to 95 / [B]80 [/B]/ 1 /step ][/TD] [TD][/TD] [/TR] [TR] [TD]2021 5[/TD] [TD]Comp5: 5-95[/TD] [TD][5 to 95 / [B]95 [/B]/ 1 /step ][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] 2024[/TD] [TD][Compression ratio of ClearLight PDF][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]Selects the compression ratio for clearlight PDF for the two settings that can be selected at the operation panel.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]2024 1[/TD] [TD]Compression Ratio (Normal)[/TD] [TD] *CTL[/TD] [TD][5 to 95 / [B]25 [/B]/ 1 /step ][/TD] [/TR] [TR] [TD]2024 2[/TD] [TD]Compression Ratio (High)[/TD] [TD][5 to 95 / [B]20 [/B]/ 1 /step ][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] 2025[/TD] [TD][Compression ratio of ClearLight PDF JPEG2000][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]Selects the compression ratio for clearlight PDF for the two settings that can be selected at the operation panel.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]2025 1[/TD] [TD]Compression Ratio (Normal) JPEG2000[/TD] [TD] *CTL[/TD] [TD][5 to 95 / [B]25 [/B]/ 1 /step ][/TD] [/TR] [TR] [TD]2025 2[/TD] [TD]Compression Ratio (High) JEPG2000[/TD] [TD][5 to 95 / [B]20 [/B]/ 1 /step ][/TD] [TD][/TD] [/TR] [/TABLE] [/LIST] [/LIST] [*][HEADING=2]SPECIFICATIONS[/HEADING] [LIST=1] [*][HEADING=2]PRINTER SPECIFICATIONS[/HEADING] [TABLE] [TR] [TD] Printer Languages:[/TD] [TD]PCL 6/5e PDF Direct Adobe PostScript 3 (optional) IPDS (optional) MediaPrint: JPEG/TIFF (optional)[/TD] [/TR] [TR] [TD] Resolution and Gradation:[/TD] [TD]PCL 5e: 300 x 300 dpi 600 x 600 dpi : Fast (1-bit) PCL 6: 600 x 600 dpi : Fast (1-bit) PDF Direct: 300 x 300 dpi/600 x 600 dpi PS3: 300 x 300 dpi/600 x 600 dpi XPS: 600 x 600 dpi : Fast (1-bit) IPDS: 300 x 300 dpi/ 600 x 600 dpi[/TD] [/TR] [TR] [TD] Printing speed:[/TD] [TD]D129: 40 ppm D130: 50 ppm[/TD] [/TR] [TR] [TD] Resident Fonts:[/TD] [TD]PCL 6/5e (Standard): 45 Compatible fonts 13 International fonts 6 Bitmap fonts Adobe PostScript 3 (Optional): 136 fonts IPDS (Optional): 108 fonts[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] Host Interfaces:[/TD] [TD]USB2.0 Type A and Type B: Standard Ethernet (100 Base-TX/10 Base-T): Standard Gigabit Ethernet (1000 Base-T): Optional IEEE1284 parallel x 1: Optional IEEE802.11a/b/g (Wireless LAN): Optional Bluetooth (USB type): Optional[/TD] [/TR] [TR] [TD]Network Protocols:[/TD] [TD]TCP/IP (IPv4, IPv6), IPX/SPX[/TD] [/TR] [/TABLE] Printer Scanner Unit Type 5002 (D641) [*][HEADING=2]USB SPECIFICATIONS[/HEADING] USB connectivity is built into the controller. [TABLE] [TR] [TD]Interface[/TD] [TD]USB 2.0[/TD] [/TR] [TR] [TD] Data rates[/TD] [TD]480 Mbps (high speed), 12 Mbps (full speed), 1.5 Mbps (low speed) High speed mode is only supported by USB 2.0.[/TD] [/TR] [/TABLE] [*][HEADING=2]IEEE 802.11A/B/G SPECIFICATIONS[/HEADING] [TABLE] [TR] [TD]Standard applied[/TD] [TD]IEEE802.11a/b/g[/TD] [TD][/TD] [/TR] [TR] [TD]Network protocols[/TD] [TD]TCP/IP, Apple Talk, NetBEUI, IPX/SPX, SMB[/TD] [TD][/TD] [/TR] [TR] [TD]Frequency range[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD](Center[/TD] [TD][/TD] [TD]2412 - 2462 MHz (1-11 channels)[/TD] [/TR] [TR] [TD]Frequency)[/TD] [TD][/TD] [TD]5180 - 5320 MHz (36, 40, 44, 48, 52, 56, 60, and 64 channels)[/TD] [/TR] [TR] [TD](US model)[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]Frequency range[/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD](Center[/TD] [TD][/TD] [TD]2412 - 2472 MHz (1-13 channels)[/TD] [/TR] [TR] [TD]Frequency)[/TD] [TD][/TD] [TD]5180 - 5320 MHz (36, 40, 44, 48, 52, 56, 60, and 64 channels)[/TD] [/TR] [TR] [TD](EU model)[/TD] [TD][/TD] [TD][/TD] [/TR] [/TABLE] [*][HEADING=2]BLUETOOTH SPECIFICATIONS[/HEADING] [TABLE] [TR] [TD]Transmission Specifications[/TD] [TD] Based on Bluetooth Ver2.0+EDR[/TD] [/TR] [TR] [TD]Transmission Speed[/TD] [TD][/TD] [/TR] [TR] [TD] Profile[/TD] [TD]Hard Copy Cable Replacement Profile (HCRP), Serial Port Profile (SPP), Basic Imaging Profile (BIP)[/TD] [/TR] [/TABLE] [LIST] [*]Asynchronous Communication : Approximately 2.1 Mbps (Max) [*]Synchronous Communication : Approximately 1.3 Mbps (Max) [/LIST] Printer Scanner Unit Type 5002 (D641) [*][HEADING=2]SCANNER SPECIFICATIONS[/HEADING] [TABLE] [TR] [TD]Standard Scanner Resolution:[/TD] [TD]Main scan/Sub scan 200 to 600 dpi[/TD] [/TR] [TR] [TD] Available scanning Resolution Range:[/TD] [TD]Twain Mode: 100 to 1200 dpi Delivery Mode: 100/200/300/400/600 dpi[/TD] [/TR] [TR] [TD]Grayscales:[/TD] [TD]1 bit or 8 bits/pixel each for RGB[/TD] [/TR] [TR] [TD] Scanning Throughput (ARDF mode):[/TD] [TD]BW: 61 ipm (A4LEF / BW Text/ Photo / 200dpi /Compression: On (MH)) FC: 31 ipm (A4LEF / FC Text / Photo / 200dpi / Compression: Standard)[/TD] [/TR] [TR] [TD] Interface:[/TD] [TD]Ethernet 10Base-T / 100Base-TX, Gigabit Ethernet (1000Base-T), Wireless LAN (IEEE 802.11a/b/g)[/TD] [/TR] [TR] [TD]Compression Method:[/TD] [TD]B&W: TIFF (MH, MR, MMR, JBIG2), Gray Scale Full Color: JPEG[/TD] [/TR] [/TABLE] [*][HEADING=2]SOFTWARE ACCESSORIES[/HEADING] The printer drivers and utility software are provided on one CD-ROM. An auto-run installer allows you to select which components to install. [LIST=1] [*][HEADING=3]PRINTER DRIVERS[/HEADING] [TABLE] [TR] [TD] Printer Language[/TD] [TD]Windows XP, Server 2003, Server 2008, Vista, 7[/TD] [TD]MacOSX10.2 or later[/TD] [/TR] [TR] [TD]PCL5c / PCL6[/TD] [TD] Yes[/TD] [TD] No[/TD] [/TR] [TR] [TD]PS3[/TD] [TD]Yes[/TD] [TD]Yes[/TD] [/TR] [TR] [TD]RPCS[/TD] [TD]No[/TD] [TD]No[/TD] [/TR] [/TABLE] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_073.png[/IMG] [LIST] [*]The PCL5c/6 and PS3 drivers are provided on the printer/scanner CD-ROM. [*]The PS3 drivers are all genuine Adobe PS drivers, except for Windows XP/Server 2003/Server 2008/Vista/7. A PPD file for each operating system is provided with the driver. [*]The PPD installer for Macintosh supports Mac OS X 10.2 or later versions. [/LIST] [*][HEADING=3]SCANNER AND LAN FAX DRIVERS[/HEADING] [TABLE] [TR] [TD]Printer Language[/TD] [TD]Windows XP, Server 2003, Server 2008, Vista, 7[/TD] [TD]MacOSX10.2 or later[/TD] [/TR] [TR] [TD]Network TWAIN[/TD] [TD]Yes[/TD] [TD]No[/TD] [/TR] [TR] [TD]LAN-FAX[/TD] [TD]Yes[/TD] [TD]No[/TD] [/TR] [/TABLE] [IMG alt="image"]https://todaynetnews.com/uploads/ricoh/ricoh-mp-4002-5002-service-manual/part28/Image_074.png[/IMG] [LIST] [*]The Network TWAIN and LAN Fax drivers are provided on the printer and scanner drivers CD-ROM. [*]This software lets you fax documents directly from your PC. Address Book Editor and Cover Sheet Editor are to be installed as well. (These require the optional fax unit.) [/LIST] [/LIST] [/LIST] [/LIST][/b][/b][/b] [/QUOTE]
Photocopier and Printer
Ricoh
Ricoh MP4002/5002 service manual Part 28
