Read This First
Safety and Symbols
Replacement Procedure Safety
- Turn off the main power switch and unplug the machine before beginning any of the replacement procedures in this manual.
Symbols Used in this Manual
This manual uses the following symbols.
: See or Refer to
: Screws
: Connector
: Clip ring
: E-ring
REPLACEMENT AND ADJUSTMENT
ELECTRICAL COMPONENTS
1 Bin Tray BN3100 (D632)
PAPER SENSOR
1. Open the right door of the machine [A].
Remove the front right cover [A] ( x 1).
2.
- Harness cover [A]
Electrical Components
- Disconnect the connector of the 1-bin tray [A]
5.
- 1-bin sorter unit [A]
- Paper sensor cover [A]
- Paper sensor [A]
- Harness cover [A]
1-BIN CONTROL BOARD
- 1-bin tray
- 1-bin sorter unit
- 1-bin control board [A]
D388/D633 INTERNAL SHIFT TRAY
SH3040/SH3060
R EVI SIO N HIS TORY | ||
INTERNAL SHIFT TRAY SH3040/SH3060 (D388/D633)
REPLACEMENT AND ADJUSTMENT 1
- TRAY COVER 1
- TRAY MOTOR AND HALF TURN SENSOR BOARD 2
Read This First
Safety and Symbols
This manual uses the following symbols.: See or Refer to
: Screws
: Connector
: Clip ring
: Clamp
: E-ring
Tray Cover
TRAY COVER
1. Remove the tray cover [A] by pressing on the two pawls on the left side of the cover.
- When Attaching the Tray Cover –
- The right side of the tray cover should be attached first.
- Fit the pawls [C] on the shift tray.
- Align the square [D] so that it fits into the groove in the underside of the tray cover and does not interfere with the attachment of the cover.
Internal Shift Tray SH3040/ SH3060 (D388/D633)
- Complete the attachment by inserting the left side pawls into place.
Tray Motor and Half Turn Sensor Board
[*]TRAY MOTOR AND HALF TURN SENSOR BOARD
- Top cover ( p.1 "Tray Cover")
- Slip disc [A]
- Tray motor ( x 1)
[*]Half turn sensor board [C] ( x 1).
D388/D633 2 SM
BOOKLET FINISHER SR3020 (B803)/ SR3110 (D637)/SR4020 (D373) FINISHER SR3030 (B805)/
SR3120 (D636)/SR4010 (D374)
- COVERS 1
- EXTERIOR COVERS 1
- UPPER TRAY, END FENCE 2
- MAIN UNIT 3
- UPPER TRAY LIMIT SENSOR, LIMIT SWITCH 3
- POSITIONING ROLLER 4
- PROOF TRAY EXIT SENSOR 5
- UPPER TRAY HEIGHT SENSORS 1, 2 5
- EXIT GUIDE PLATE, UPPER TRAY EXIT SENSOR 6
- PROOF TRAY FULL SENSOR 7
- FINISHER ENTRANCE SENSOR 7
- PRE-STACK TRAY EXIT SENSOR 8
- STAPLER UNIT 9
- CORNER STAPLER 9
- POSITIONING ROLLER 10
- FOLD UNIT 11
- FOLD UNIT 11
- FOLD UNIT ENTRANCE SENSOR 13
- FOLD UNIT EXIT SENSOR 14
- STACK PRESENT SENSOR 15
- FOLDING HORIZONTAL SKEW ADJUSTMENT (FOR B804 ONLY) 16
- FOLD VERTICAL SKEW ADJUSTMENT (FOR B804 ONLY) 19
- BOOKLET STAPLER UNIT 21
- BOOKLET STAPLER 21
- BOOKLET STAPLER MOTOR 22
To Reattach the Booklet Stapler Motor 23
- COVERS 1
DETAILED SECTION DESCRIPTIONS 24
- COMPONENT LAYOUT 24
- GENERAL LAYOUT 24
Paper direction 24
Proof tray 25
Upper tray 25
Pre-stack tray 25
Lower tray 25 - ELECTRICAL COMPONENTS 26
Upper Area B804/B805 26
Lower Area B804/B805 27
Punch Unit B702 28
Stacker/Stapler - B804/B805 29
B804 Fold unit 30 - SUMMARY OF ELECTRICAL COMPONENTS 31
- DRIVE LAYOUT 41
- GENERAL LAYOUT 24
- JUNCTION GATES 42
- PROOF MODE 42
- SHIFT MODE 42
- STAPLE MODE 43
- PRE-STACKING 44
- TRAY MOVEMENT MECHANISM 46
- UPPER TRAY 46
- LOWER TRAY (B804 ONLY) 48
- CORNER STAPLING 51
- STACKING AND JOGGING 51
- STAPLER MOVEMENT 52
- CORNER STAPLING 53
- BOOKLET STAPLING (B804 ONLY) 54
- BOOKLET PRESSURE MECHANISM 54
- BOOKLET STAPLING AND FOLDING 55
Overview 55 - BOOKLET STAPLING AND FOLDING MECHANISMS 61
- UPPER TRAY OUTPUT 64
- FEED OUT 64
- FEED OUT STACKING 65
- PUNCH UNIT B702 (FOR B804/B805) 66
- OVERVIEW OF OPERATION 66
B803/B805/D373/D374/D636/D637 ii SM
Skew Correction before Punching 66
Punch Unit Position Correction 67 - PUNCH MECHANISMS 69
Paper Position Detection 69
Punch Unit Movement 70
Punch Selection and Firing 71 - PUNCH HOPPER MECHANISM 72
- FINISHER JAM DETECTION 73
Read This First
Safety and Symbols
: Screws
: Connector
: Clip ring
: E-ring
COVERS
EXTERIOR COVERS
Booklet Finisher & Finishers (B803/B805/ D373/D374/ D636/D637)
- Open the front door [D].
- Small upper cover [A] ( x1)
- Upper cover ( x2)
[*]Front door bracket [C] ( x1)
[*]Front door [D]
[*]Front left side cover [E] ( x2)
[*]Cover [F]
[*]Paper exit cover [G] ( x2)
[*]Rear cover [H] ( x2)
[*]UPPER TRAY, END FENCE
1. Remove the rear cover. ( "Exterior Covers")
- Support the tray [A] with your right hand.
- Pull gear toward you to release.
[*]Slowly lower the tray until it stops.
[*]Front side cover [C] ( x1)
[*]Rear side cover [D] ( x1)
[*]Upper tray [E] ( x1)
[*]Tray bracket [F] ( x4, x1 shoulder screw )
[*]End Fence [G]( x3)
[*]MAIN UNIT
- Front door, front left side cover, rear cover, upper cover ( "Exterior Cover")
- End fence ( "Upper Tray, End Fence")
- Upper tray exit mechanism [A] ( x4, x3)
- Upper tray limit sensor ( x1, x1)
[*]Upper tray limit switch [C] ( x2)
[*]POSITIONING ROLLER
- Open the front door [A].
- Pull out the stapling unit .
[*]Positioning roller [C] ( x1, timing belt x1)
[*]PROOF TRAY EXIT SENSOR
- Small upper cover ( "Exterior Cover")
- Proof tray exit sensor bracket [A] ( x1)
- Proof tray exit sensor ( x1)
[*]UPPER TRAY HEIGHT SENSORS 1, 2
- Small upper cover, upper cover ( "Exterior Cover")
- Upper tray paper height sensor bracket [A] ( x1)
- Upper tray paper height sensor – staple mode (S08) ( x1)
[*]Upper tray paper height sensor [C] – non-staple mode (S09) ( x1)
[*]EXIT GUIDE PLATE, UPPER TRAY EXIT SENSOR
- Rear cover, Upper covers, Front door, Cover, Paper exit cover ( "Exterior Cover")
- Inner cover [A] ( x2)
- Exit guide plate ( x1, Link and spring, x1, x1)
[*]Upper tray exit sensor [C] (S6) ( x1)
[*]PROOF TRAY FULL SENSOR
- Exit guide plate. ( "Exit Guide Plate, Upper Tray Exit Sensor")
- Guide plate [A] (hook x 2)
- Sensor bracket ( x1)
[*]Proof tray full sensor [C] (S11) ( x1)
[*]FINISHER ENTRANCE SENSOR
- Disconnect the finisher if it is connected to the copier.
- Sensor bracket [A] ( x1)
- Finisher entrance sensor (S1) ( x1)
[*]PRE-STACK TRAY EXIT SENSOR
- Pre-stack tray exit sensor (S2)
[*]STAPLER UNIT
CORNER STAPLER
- Open the front door.
- Pull out the stapler unit.
- Inner cover [A] ( x3)
- Stapler unit holder ( x1)
[*]Corner stapler [C] (M20) ( x1)
[*]FOLD UNIT
FOLD UNIT
- Remove the back cover ( "Exterior Covers").
- The stapler unit is heavy.
- Ground cable [A] ( x1)
- Harness ( x6, x6)
[*]Stapler unit [C] ( x4)
- Support the fold unit with your hand to prevent it from falling.
- The fold unit is heavy.
If you have replaced the folding unit:
- Read the DIP SW settings on the decal [A] attached to the back of the new folding unit.
- Check the DIP SW settings on the main board of the finisher.
[*]If these settings are different, change these settings to match the settings printed on the decal attached to the folding unit.
- Set DIP switches 1 to 4 (the switch set on the right). Do not touch the other DIP switches.
[*]FOLD UNIT ENTRANCE SENSOR
- Pull out the stapler unit ( "Positioning Roller").
- Fold unit entrance sensor bracket [A] ( x2)
- Fold unit entrance sensor (S26) ( x1, x1)
[*]FOLD UNIT EXIT SENSOR
- Fold unit vertical guide plate [A]
- Fold unit inner cover ( x2, Spring pin x1)
[*]Fold unit upper cover [C] ( x1)
[*]Paper clamp mechanism [D] ( x4)
[*]Fold unit exit sensor bracket [E] ( x1)
[*]Fold unit exit sensor [F] (S31) ( x1)
[*]STACK PRESENT SENSOR
- If you intend to correct the horizontal and vertical skew for the fold unit at the same time, do those adjustments first, then replace the sensor. ( "Folding Horizontal Skew Adjustment" or "Fold Vertical Skew Adjustment")
- Remove the stapler unit ( "Fold Unit")
- Guide plate [A].
- Stay ( x4)
[*]Left plate [C] ( x4)
[*]Sensor bracket [D] ( x1)
[*]Stack present sensor [E] (S32) ( x1)
[*]FOLDING HORIZONTAL SKEW ADJUSTMENT (FOR B804 ONLY)
- The fold unit is adjusted for optimum performance before the finisher is shipped from the factory. Do this adjustment only if the edges of folded booklets are not even.
- Switch the copier on and enter the SP mode.
- Europe, Asia: Use SP6-134-001 (this is for A3 paper). North America: Use SP6-134-005 (this is for DLT paper).
- If the original setting of SP6-134-001 or -005 is not "0", then you must do the vertical skew adjustment ( "Fold Vertical Skew Adjustment") after you finish this horizontal skew procedure.
- Use the 10-key pad to input "-2" (mm) for the SP value. (Press to enter the minus sign.)
- Press [#] then exit the SP mode.
- Open the front door and pull the stapler unit [A] out of the finisher.
- Open the guide plate .
[*]Loosen the adjustment screw [C] and then tighten until it stops. (Do not over tighten.)
[*]Remove the lock screw [D].
[*]Raise the tip [E] of the adjustment screw very slightly and allow it to descend under its own weight.
[*]Push the stapler unit into the finisher and close the front door.
[*]Do a folding test.
- Switch the copier on.
- Put one page of A3 or DLT paper in the ARDF.
- On the copier operation panel, select booklet stapling.
- Press [Start]. One sheet is folded.
[*]Hold the folded sheet with the creased side pointing down and face-up (the same way that it came out of the finisher).
[*]Referring to the diagram, determine if the skew is + [F] or - [G].
[*]Open the front door of the finisher and pull the stapler unit [H] out.
[*]Open the guide plate .
[*]Turn the adjustment screw [J] to correct the amount of skew you measured from the test sheet.
- For + skew [F], turn the adjustment screw (clockwise).
- For – skew [G], turn the adjustment screw to the left (counter-clockwise).
- Every click in the +/– direction adjusts the fold position by 0.1 mm by moving the bottom fence [K].
[*]Attach and tighten the lock screw [L].
[*]Push the stapler unit into the machine, close the front door, then turn the copier on.
[*]Europe, Asia: Do SP6-134-001 (this is for A3 paper). North America: Do SP6-134-005 (this is for DLT paper).
[*]Reset it to "0".
[*]Do the test again.
[*]If the result is satisfactory, this completes the adjustment. -or- If some skew remains, repeat this adjustment.
- After doing this adjustment, adjust for vertical skew, if necessary. ( "Fold Vertical Skew Adjustment")
[*]FOLD VERTICAL SKEW ADJUSTMENT (FOR B804 ONLY)
- Do a folding test.
- Hold the folded sheet with the creased side pointing down, and face-up (the same way that it came out of the finisher).
- Referring to the diagram, determine if the skew is positive [A] or negative .
[*]Measure the amount of skew.
[*]Enter the SP mode
- North America: Use SP6-134-005 (this is for DLT paper).
-1.2 mm, enter -0.6 mm
- The range for measurement is –3.0 mm to +3.0 mm in 0.2 mm steps for every notch adjustment.
[*]Repeat this procedure until the skew is corrected.
The illustration below shows the effects of +/- adjustment with SP6113. (The vertical arrows show the direction of paper feed.)
[*]BOOKLET STAPLER UNIT
BOOKLET STAPLER
- Harness cover [A] ( x2)
- Booklet stapler support stay ( x4, x2, x4)
[*]Stapler [C] ( x4)
[*]BOOKLET STAPLER MOTOR
[*]Open the front door.
[*]Remove the stapler unit. ( "Fold Unit")
3. Stay [A] ( x4).
- Left plate ( x4)
[*]Harness cover [C] ( x2)
[*]Booklet stapler support stay [D] ( x4, x2, x4)
[*]Booklet stapler [E] ( x4)
[*]Booklet stapler motor [F] ( x2, x1)
- Reattach the booklet stapler motor.
- Do not tighten the screws.
- Attach the special tool [A] and reattach the booklet stapler stay.
- This tool is included with the stapler spare part.
- Turn the gear with your finger until it stops.
[*]Tighten the screws to attach to the booklet stapler motor.
[*]Remove the stay again and remove the special tool.
[*]Reattach the booklet stapler stay.
[*]Push the stapler unit into the machine.
COMPONENT LAYOUT
GENERAL LAYOUT
- Lower Tray (Booklet)*1
- Folder Rollers*1
- Folder Plate*1
- Booklet Stapler*1
- Upper Tray (Shift)
- Proof Tray
- Proof Tray Junction Gate
- Punch Unit
- Stapler Junction Gate
- Pre-Stack Junction Gate
- Pre-Stack Tray
- Corner Stapler (M20)
Paper direction
The operation of the proof tray and stapler junction gates direct the flow of the paper once it enters
the finisher:
Proof Junction Gate Stapler Junction Gate Paper Feeds Closed Closed Paper feeds straight through Open Closed Paper feeds to the proof tray Closed Open Paper feds to the staple tray
Proof tray
Copies are sent to the proof tray (12) when neither sorting nor stapling are selected for the job.
Upper tray
The upper tray (11) receives copies that are sorted and shifted and also receives copies that have been corner stapled. Corner stapling is provided on both the B804 and the B805.
Pre-stack tray
The pre-stack tray has a switchback mechanism to increase the productivity of stapling. (
"Pre-Stacking) Pre-stacking is done for corner stapling in the B804/B805 and for booklet stapling in the B804.
Lower tray
The lower tray (7) receives copies that have been center folded and stapled (booklet stapling). Booklet stapling is not provided on the B805.ELECTRICAL COMPONENTS
- Upper Tray Limit Switch (SW2)
- Stacking Roller HP Sensor (S13)
- Stacking Sponge Roller Motor (M10)
- Upper Tray Exit Sensor (S6)
- Upper Tray Paper Height Sensor (S8) (Staple Mode)
- Shift Roller HP Sensor (S5)
- Shift Roller Motor (M18)
- Exit Guide Plate Motor (M19)
- Proof Junction Gate Solenoid (SOL1)
- Upper/Proof Exit Motor (M4)
- Stapling Tray Junction Gate Solenoid (SOL2)
- Upper Transport Motor (M2)
- Exit Guide Plate HP Sensor (S7)
- Proof Tray Exit Sensor (S10)
- Proof Tray Full Sensor (S11)
- Finisher Entrance Sensor (S1)
- Upper Tray Paper Height Sensor (S9) (Non-Staple Mode)
- Upper Tray Limit Sensor (S12)
- Positioning Roller Motor (M14)
- Lower Tray Full Sensor – Front (S34)*1
- Lower Tray Full Sensor – Rear (S33)*1
- Main Board (PCB1)
- Upper Tray Full Sensor – (S20) *2
- Upper Tray Full Sensor – (S19)
- Booklet Stapler Board (PCB2)*1
- Booklet Pressure Roller Solenoid – (SOL5)
- Upper Tray Lift Motor (M21)
- Lower Transport Motor (M3)
- Entrance Motor (M1)
- Front Door Safety Switch (SW1)
- Pre-Stack Tray Exit Sensor (S2)
- Stapling Edge Pressure Plate Solenoid (SOL4)
- Positioning Roller Solenoid (SOL3)
*1: B804 Only, *2: B805 Only
- Punch Encoder Sensor (S24)
- Punch Drive Motor (M24)
- Punch HP Sensor (S24)
- Punch Unit Board (PCB3)
- Paper position sensor slide motor (M7)
Punch Unit B702
- Paper Position Slide HP Sensor (S22)
- Paper Position Sensor (S3)
- Punch Hopper Full Sensor (S4)
- Punch Movement Motor (M9)
- Punch Movement HP Sensor (S21)
