BIT SWITCHES - 2
- Do not adjust a bit switch or use a setting that is described as "Not used", as this may cause the machine to malfunction or to operate in a manner that is not accepted by local regulations. Such bits are for use only in other areas, such as Japan.
I-FAX SWITCHES
I-fax Switch 00 (SP No. 1-102-001) No Function Comments
Original Width of TX Attachment FileThis setting sets the maximum size of the original that the destination can receive. (Bits 3~7 are reserved for future use or not used.) 0 A4
-1 B4 2 A3 3-6 Reserved 7 Not used 0: Off (not selected), 1: On (selected)
If more than one of these three bits is set to "1", the larger size has priority. For example, if both Bit 2 and Bit 1 are set to "1" then the maximum size is "A3" (Bit 2).
When mail is sent, there is no negotiation with the receiving machine at the destination, so the sending machine cannot make a selection for the receiving capabilities (original width setting) of the receiving machine. The original width selected with this switch is used as the RX machine's original width setting, and the original is reduced to this size before sending. The default is A4.
If the width selected with this switch is higher than the receiving machine can accept, the machine detects this and this causes an error.I-fax Switch 01 (SP No. 1-102-002) No Function Comments Original Line Resolution of TX Attachment File These settings set the maximum resolution of the original that the destination can receive. 0 200x100 Standard
0: Not selected
1: Selected
If more than one of these three bits is set to "1", the higher resolution has priority. For example, if both Bit 0 and Bit 2 are set to "1" Then The Resolution is set for "Bit 2 200 x 400.1 200x200 Detail 2 200x400 Fine 3 300 x 300 Reserve 4 400 x 400 Super Fine 5 600 x 600 Reserve 6 Reserve 7 mm/inch This setting selects mm/inch conversion for mail transmission. 0: Off (No conversion), 1: On (Conversion)
When on (set to "1"), the machine converts millimeters to inches for sending mail. There is no switch for converting inches to millimeters.
Unlike G3 fax transmissions which can negotiate between sender and receiver to determine the setting, mail cannot negotiate between terminals; the mm/inch selection is determined by the sender fax.
When this switch is Off (0):- Images scanned in inches are sent in inches.
- Images scanned in mm are sent in mm.
- Images received in inches are transmitted in inches.
- Images received in mm are transmitted in mm. When this switch is On (1):
- Images scanned in mm are converted to inches.
- Images received in mm are converted to inches.
Fax Option Type 5002 (D629)
I-fax Switch 02 (SP No. 1-102-003) No Function Comments
0RX Text Mail Header Processing This setting determines whether the header information is printed with text e-mails when they are received.
0: Prints only text mail.
1: Prints mail header information attached to text mail.
When a text mail is received with this switch On (1), the "From" address and "Subject" address are printed as header information.
When a mail with only binary data is received (a TIFF-F file, for example), this setting is ignored and no header is printed.
1Output from Attached Document at E-mail TX Error This setting determines whether only the first page or all pages of an e-mail attachment are printed at the sending station when a transmission error occurs. This allows the customer to see which documents have not reached their intended destinations if sent to the wrong e-mail addresses, for example.
0: Prints 1st page only. 1: Prints all pages.
2-3Text String for Return Receipt This setting determines the text string output for the Return Receipt that confirms the transmission was received normally at the destination. 00: "Dispatched"
Sends from PC mail a request for a Return Receipt. Receives the Return Receipt with "dispatched" in the 2nd part:
Disposition: Automatic-action/MDN-send automatically; dispatched The "dispatched" string is included in the Subject string.
01: "Displayed"
Sends from PC mail a request for a Return Receipt. Receives the Return Receipt with "displayed" in the 2nd part:
Disposition: Automatic-action/MDN-send automatically; displayed The "displayed" string is included in the Subject string.
10: Reserved
11: Reserved
A mail requesting a Return Receipt sent from an IFAX with this switch set to "00" (for "dispatched") received by Microsoft Outlook 2000 may cause an error. If any setting other than "displayed" (01) causes a problem, change the setting to "01" to enable normal sending of the Return Receipt.
4Media accept feature This setting adds or does not add the media accept feature to the answer mail to confirm a reception.
0: Does not add the media accept feature to the answer mail 1: Adds the media accept feature to the answer mail.
Use this bit switch if a problem occurs when the machine receives an answer mail, which contains the media accept feature field.5-6 Not Used
7Image Resolution of RX Text Mail This setting determines the image resolution of the received mail. 0: 200 x 200
1: 400 x 400
The "1" setting requires installation of the Memory Unit in order to have enough SAF (Store and Forward) memory to receive images at 400 x 400 resolution.I-fax Switch 04 (SP No. 1-102-005) No Function Comments
0Subject for Delivery TX/Memory Transfer This setting determines whether the RTI/CSI registered on this machine or the RTI/CSI of the originator is used in the subject lines of transferred documents. 0: Puts the RTI/CSI of the originator in the Subject line. If this is used, either the
RTI or CSI is used. Only one of these can be received for use in the subject line. 1: Puts the RTI/CSI registered on this machine in the Subject line.
When this switch is used to transfer and deliver mail to a PC, the information in the Subject line that indicates where the transmission originated can be used to determine automatically the destination folder for each e-mail.
1Subject corresponding to mail post database 0: Standard subject
1: Mail post database subject
The standard subject is replaced by the mail post database subject in the following three cases:
2-7 Not Used - When the service technician sets the service (software) switch.
- When memory sending or delivery specified by F code is applied by the SMTP server
- With relay broadcasting (1st stage without the Schmidt 4 function).
- This switch does not apply for condition 3) when the RX system is set up for memory sending, delivery by F-code, sending with SMTP RX and when operators are using FOL (to prevent problems when receiving transmissions).
I-fax Switch 03 - Not used (do not change these settings)
I-fax Switch 05 (SP No. 1-102-006) No Function Comments
0Mail Addresses of SMTP Broadcast Recipients Determines whether the e-mail addresses of the destinations that receive transmissions broadcasted using SMTP protocol are recorded in the Journal. For example:
"1st destination + Total number of destinations: 9" in the Journal indicates a broadcast to 9 destinations.
0: Not recorded
1: Recorded1-7 Not Used
I-fax Switch 06 - Not used (do not change the settings) I-fax Switch 07 - Not used (do not change the settings)
I-fax Switch 08 (SP No. 1-102-009) No Function Comments
0-7Memory Threshold for POP Mail Reception This setting determines the amount of SAF (Store and Forward) memory. (SAF stores fax messages to send later for transmission to more than one location, and also holds incoming messages if they cannot be printed.) When the amount of SAF memory available falls below this setting, mail can no longer be received; received mail is then stored on the mail server.
00-FF (0 to 1024 KB: HEX)
The hexadecimal number you enter is multiplied by 4 KB to determine the amount of memory.Fax Option Type 5002 (D629)
I-fax Switch 09 (SP No. 1-102-010) No Function Comments 0-3 Not used Do not change the settings
4-7
Restrict TX RetriesThis setting determines the number of retries when connection and transmission fails due to errors.
01-F (1-15 Hex)
I-fax Switch 0A - Not used (do not change the settings) I-fax Switch 0B - Not used (do not change the settings) I-fax Switch 0C - Not used (do not change the settings)
I-fax Switch 0D (SP No. 1-102-014) No Function Comments 0-1 Not used Do not change the settings
2-3Set to select the signature when sending mail notification of the send results
In response to IEEE2600.1.Bit 2 Bit 3 Setting 0 0 No sign 0 1 No setting 1 0 Individual setting 1 1 Always sign
4-5Set to select the signature when sending mail.
In response to IEEE2600.1.Bit 5 Bit 4 Setting 0 0 No sign 0 1 No setting 1 0 Individual setting 1 1 Always sign 6-7 Not used Do not change the settings.
I-fax Switch 0E - Not used (do not change the settings)
I-fax Switch 0F (SP No. 1-102-016) No Function Comments
0Delivery Method for SMTP RX Files This setting determines whether files received with SMTP protocol are delivered or output immediately.
0: Off. Files received via SMTP are output immediately without delivery.
1: On. Files received via SMTP are delivered immediately to their destinations.1-7 Not used Fax Option Type 5002 (D629)
PRINTER SWITCHES
Printer Switch 00 (SP No. 1-103-001) No Function Comments
0
Select page separation marks 0: Off
1: On0: If a 2 page RX transmission is split, [*] is printed in the bottom right corner of the 1st page and only a [2] is printed in the upper right corner of the 2nd page.
1: If a 2 page RX transmission is split into two pages, for example, [*] [2] is printed in the bottom right corner of the 1st page and only a [2] is printed in the upper right corner of the 2nd page.
1Repetition of data when the received page is longer than the printer paper
0: Off
1: On1: Default. 10 mm of the trailing edge of the previous page are repeated at the top of the next page.
0: The next page continues from where the previous page stopped without any repeated text.
Prints the date and time on received fax messages
1: EnabledThis switch is only effective when user parameter 02 - bit 2 (printing the received date and time on received fax messages) is enabled.
1: The machine prints the received and printed date and time at the bottom of each received page.3-7 Not used Do not change the settings. - This helps the user to identify pages that have been split because the size of the paper is smaller than the size of the document received. (When A5 is used to print an A4 size document, for example.)
Printer Switch 01 (SP No. 1-103-002) No Function Comments 0-2 Not used Do not change the settings.
3-4Maximum print width used in the setup protocol
These bits are only effective when bit 7 of printer switch 01 is "1".Bit 4 Bit 3 Setting 0 0 Not used 0 1 A3 1 0 B4 1 1 A4 5-6 Not used Do not change the settings.
Received message width restriction in the protocol signal to the sender
1: Enabled0: The machine informs the transmitting machine of the print width depending on the paper size available from the paper feed stations.
Refer to the table on the next page for how the machine chooses the paper width used in the setup protocol (NSF/DIS).
1: The machine informs the transmitting machine of the fixed paper width which is specified by bits 3 and 4 above.
Relationship between available paper sizes and printer width used in the setup protocol
Available Paper Size Printer width used in the Protocol (NSF/DIS) A4 or 8.5" x 11" 297 mm width B5 256 mm width A5 or 8.5" x 5.5" 216 mm width No paper available (Paper end) 216 mm width Fax Option Type 5002 (D629)
Printer Switch 02 (SP No. 1-103-003) No Function Comments
01st paper feed station usage for fax printing
0: Enabled
1: Disabled
0: The paper feed station can be used to print fax messages and reports.
1: The specified paper feed station will not be used for printing fax messages and reports.
12nd paper feed station usage for fax printing
0: Enabled
1: Disabled
23rd paper feed station usage for fax printing
0: Enabled
1: Disabled
34th paper feed station usage for fax printing
0: Enabled
1: Disabled
4LCT usage for fax printing 0: Enabled
1: Disabled5-7 Not used Do not change the settings. - Do not disable usage for a paper feed station which has been specified by User Parameter Switch 0F (15), or which is used for the Specified Cassette Selection feature.
Printer Switch 03 (SP No. 1-103-004) No Function Comments 0: Incoming pages are printed without length reduction. Length reduction of received (Page separation threshold: Printer Switch 03,
0data
0: Disabledbits 4 to 7)
1: Incoming page length is reduced when1: Enabled printing. (Maximum reducible length: Printer Switches 04, bits 0 to 4) 1-3 Not used Do not change the settings Page separation threshold (with reduction disabled with switch 03-0 above). Page separation setting when For example, if this setting is set to "10", and 4 sub scan compression is A4 is the selected paper size: to forbidden If the received document is 10 mm or less 7 00-0F (0-15 mm: Hex) longer than A4, then the 10 mm are cut and Default: 6 mm only 1 page prints. If the received document is 10 mm longer than A4, then the document is split into 2 pages. Fax Option Type 5002 (D629)
Printer Switch 04 (SP No. 1-103-005) No Function Comments
0
to 4Maximum reducible length when length reduction is enabled with switch 03-0 above.
[Maximum reducible length] = [Paper length] + (N x 5mm) "N" is the decimal value of the binary setting of bits 0 to 4.Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Setting 0 0 0 0 0 0 mm 0 0 0 0 1 5 mm 0 0 1 0 0 20 mm 1 1 1 1 1 155 mm For A5 sideways and B5 sideways paper
[Maximum reducible length] = [Paper length] + 0.75 x (N x 5mm)
6Length of the duplicated image on the next page, when page separation has taken place. Bit 6 Bit 5 Setting 0 0 4 mm 0 1 10 mm 1 0 15 mm 1 1 Not used 7 Not used. Do not change the setting. Printer Switch 0E (SP No. 1-103-015) No Function Comments
0
Paper size selection priority 0: Width
1: Length0: A paper size that has the same width as the received data is selected first.
1: A paper size which has enough length to print all the received lines without reduction is selected first.
1Paper size selected for printing A4 width fax data
0: 8.5" x 11" size
1: A4 sizeThis switch determines which paper size is selected for printing A4 width fax data, when the machine has both A4 and 8.5" x 11" size paper.
Page separation 0: Enabled
1: Disabled1: If all paper sizes in the machine require page separation to print a received fax message, the machine does not print the message (Substitute Reception is used). After a larger size of paper is set in a cassette, the machine automatically prints the fax message.
3-4Printing the sample image on reports
"Same size" means the sample image is printed at 100%, even if page separation occurs.
User Parameter Switch 19 (13H) bit 4 must be set to "0" to enable this switch. Refer to Detailed Section Descriptions for more on this feature.Bit 4 Bit 3 Setting 0 0 The upper half only
0
150% reduction (sub-scan only) 1 0 Same size 1 1 Not used 5-6 Not used Do not change the settings.
Printer Switch 0C - Not used (do not change the settings)
Printer Switch 05 - Not used (do not change the settings)
Printer Switch 06 (SP No. 1-103-007) No Function Comments
0Printing while a paper cassette is pulled out, when the Just Size Printing feature is enabled.
0: Printing will not start
1: Printing will start if another cassette has a suitable size of paper, based on the paper size selection priority tables.
Cross reference
Just size printing on/off – User switch 05, bit 51-7 Not used. Do not change the settings.
Printer Switch 07 (SP No. 1-103-008) No Function Comments 0-3 Not used. Do not change the settings.
4List of destinations in the Communication Failure Report for broadcasting
0: All destinations
1: Only destinations where communication failure occurred
1: Only destinations where communication failure occurred are printed on the Communication Failure Report.5-7 Not used. Do not change the settings.
Printer Switch 08 - Not used (do not change the settings) Printer Switch 09 - Not used (do not change the settings) Printer Switch 0A - Not used (do not change the settings) Printer Switch 0B - Not used (do not change the settings) 0: When page separation has taken Equalizing the reduction ratio among place, all the pages are reduced with the separated pages same reduction ratio. 7 (Page Separation) 1: Only the last page is reduced to fit the 0: Enabled selected paper size when page 1: Disabled separation has taken place. Other pages are printed without reduction.
Printer Switch 0F (SP No. 1-103-016) No Function Comments
0-1Smoothing feature
(0, 0) (0, 1): Disable smoothing if the machine receives halftone images from other manufacturers fax machines frequently.Bit 1 Bit 0 Setting 0 0 Disabled 0 1 Disabled 1 0 Enabled 1 1 Not used
2Duplex printing 0: Disabled
1: The machine always prints received fax messages in duplex printing mode:
Binding direction for Duplex printing 0: Left binding
1: Top binding0: Sets the binding for the left edge of the stack.
1: Sets the binding for the top of the stack.4-7 Not used Do not change the settings. Fax Option Type 5002 (D629)
BIT SWITCHES - 3
Default settings for bit switches are not listed in this manual. Refer to the System Parameter List printed by the machine.
COMMUNICATION SWITCHES
Communication Switch 00 (SP No. 1-104-001) No Function Comments
0-1Compression modes available in receive mode
These bits determine the compression capabilities to be declared in phase B (handshaking) of the T.30 protocol.Bit 1 Bit 0 Modes 0 0 MH only 0 1 MH/MR 1 0 MH/MR/MMR 1 1 MH/MR/MMR/JBIG
2-3Compression modes available in transmit mode
These bits determine the compression capabilities to be used in the transmission and to be declared in phase B (handshaking) of the T.30 protocol.Bit 3 Bit 2 Modes 0 0 MH only 0 1 MH/MR 1 0 MH/MR/MMR 1 1 MH/MR/MMR/JBIG 4 Not used Do not change the settings.
5JBIG compression method: Reception 0: Only basic supported
1: Basic and optional both supportedChange the setting when communication problems occur using JBIG compression.
6JBIG compression method: Transmission 0: Basic mode priority
1: Optional mode priorityChange the setting when communication problems occur using JBIG compression.
Closed network (reception) 0: Disabled
1: Enabled1: Reception will not go ahead if the polling ID code of the remote terminal does not match the polling ID code of the local terminal. This function is only available in NSF/NSS mode.
Communication Switch 01 (SP No. 1-104-002) No Function Comments
0
ECM
0: Off 1: OnIf this bit is set to 0, ECM is switched off for all communications.
In addition, V.8 protocol and JBIG compression are switched off automatically.1 Not used Do not change the setting.
2-3Wrong connection prevention method
(0,1): The machine will disconnect the line without sending a fax message, if the last 8 digits of the received CSI do not match the last 8 digits of the dialed telephone number. This does not work when manually dialed.
(1,0): The same as above, except that only the last 4 digits are compared.
(1,1): The machine will disconnect the line without sending a fax message, if the other endBit 3 Bit 2 Setting 0 0 None 0 1 8 digit CSI 1 0 4 digit CSI 1 1 CSI/RTI does not identify itself with an RTI or CSI. (0,0): Nothing is checked; transmission will always go ahead.
4-5 Not used Do not change the setting.
6-7Maximum printable page length available
The setting determined by these bits is informed to the transmitting terminal in the pre-message protocol exchange (in the DIS/NSF frames).Bit 7 Bit 6 Setting 0 0 No limit 0 1 B4 (364 mm) 1 0 A4 (297 mm) 1 1 Not used - This function does not work when dialing is done from the external telephone.
Communication Switch 02 (SP No. 1-104-003) No Function Comments
0
G3 Burst error threshold 0: Low 1: HighIf there are more consecutive error lines in the received page than the threshold, the machine will send a negative response.
The Low and High threshold values depend on the sub-scan resolution, and are as follows.100 dpi 6(L) 12(H) 200 dpi 12(L) 24(H) 300 dpi 18(L) 36(H) 400 dpi 24(L) 48(H)
Acceptable total error line ratio 0: 5% 1: 10%If the error line ratio for a page exceeds the acceptable ratio, RTN will be sent to the other end.
2Treatment of pages received with errors during G3 reception
0: Deleted from memory without printing
1: Printed
0: Pages received with errors are not printed.
Hang-up decision when a negative code (RTN or PIN) is received during G3 immediate transmission 0: No hang-up, 1: Hang-up0: The next page will be sent even if RTN or PIN is received.
1: The machine will send DCN and hang up if it receives RTN or PIN.
This bit is ignored for memory transmissions or if ECM is being used.4-7 Not used Do not change the settings.
Communication Switch 03 (SP No. 1-104-004) No Function Comments
0-7Maximum number of page retransmissions in a G3 memory transmission 00 - FF (Hex) times.
This setting is not used if ECM is switched on. Default setting - 03(H)
Communication Switch 04 - Not used (do not change the settings) Communication Switch 05 - Not used (do not change the settings) Communication Switch 06 - Not used (do not change the settings) Communication Switch 07 - Not used (do not change the settings) Communication Switch 08 - Not used (do not change the settings) Communication Switch 09 - Not used (do not change the settings) Fax Option Type 5002 (D629)
Communication Switch 0A (SP No. 1-104-011) No Function Comments Point of resumption of memory 0: The transmission begins from the page
0transmission upon redialing
0: From the error pagewhere transmission failed the previous time.
1: Transmission begins from the first page,1: From page 1 using normal memory transmission. 1-7 Not used Do not change the settings.
Communication Switch 0B (SP No. 1-104-012) No Function Comments 0-3 Not used Do not change the settings.
Printout of the message when acting as a Transfer Station
0: Disabled, 1: EnabledWhen the machine is acting as a Transfer Station, this bit determines whether the machine prints the fax message coming in from the Requesting Terminal. 5-7 Not used Do not change the settings.
Communication Switch 0C - Not used (do not change the settings)
Communication Switch 0D (SP No. 1-104-014) No Function Comments
0-7
The available memory threshold, below which ringing detection (and therefore reception into memory) is disabled00 to FF (Hex), unit = 4 kbytes (e.g., 06(H) = 24 kbytes)
One page is about 24 kbytes.
The machine refers to this setting before each fax reception. If the amount of remaining memory is below this threshold, the machine cannot receive any fax messages.
If this setting is kept at 0, the machine will detect ringing signals and go into receive mode even if there is no memory available. This will result in communication failure.
Communication Switch 0E (SP No. 1-104-015) No Function Comments 06 to FF (Hex), unit = 2 s
0-7Minimum interval between
automatic dialing attempts(e.g., 06(H) = 12 s)
This value is the minimum time that the machinewaits before it dials the next destination.
Communication Switch 0F – Not used (do not change the settings.)
Communication Switch 10 (SP No. 1-104-017) No Function Comments
0-7Memory transmission: Maximum number of dialing attempts to the same destination
01 – FE (Hex) timesCommunication Switch 12 (SP No. 1-104-019) No Function Comments
0-7Memory transmission: Interval between dialing attempts to the same destination
01 – FF (Hex) minutes
Communication Switch 11 – Not used (do not change the settings.)
Communication Switch 13 – Not used (do not change the settings.)
Communication Switch 14 (SP No. 1-104-021) No Function Comments
0
Inch-to-mm conversion during transmission
0: Disabled, 1: Enabled0: In immediate transmission, data scanned in inch format are transmitted without conversion.
In memory transmission, data stored in the SAF memory in mm format are transmitted without conversion.
Note: When storing the scanned data into SAF memory, the fax unit always converts the data into mm format.
1: The machine converts the scanned data or stored data in the SAF memory to the format which was specified in the set-up protocol (DIS/NSF) before transmission.1-5 Not used Do not change the factory settings.
6-7Available unit of resolution in which fax messages are received
For the best performance, do not change the factory settings.
The setting determined by these bits is informed to the transmitting terminal in the pre-message protocol exchange (in the DIS/NSF frames).Bit 7 Bit 6 Unit 0 0 mm 0 1 inch 1 0 mm and inch 1 1 Not used
Communication Switch 15 – Not used (do not change the settings) Fax Option Type 5002 (D629)
Communication Switch 16 (SP No. 1-104-023) No Function Comments 0 Not used Do not change the settings.
1Optional G3 unit (G3-2) 0: Not installed
1: Installed
Change this bit to 1 when installing the first optional G3 unit.2 Not used
Select PSTN connection 0: Off
1: OnThis switch enables the G3-2. 0: Off, no connection
1: Recognizes and enables G3-2.
This switch can be used only after G3-2 has been installed.4-7 Not used Do not change the settings.
Communication Switch 17 (SP No. 1-104-024)No Function Comments
0SEP reception 0: Disabled
1: Enabled0: Polling transmission to another maker's machine using the SEP (Selective Polling) signal is disabled.
1SUB reception 0: Disabled
1: Enabled0: Confidential reception to another maker's machine using the SUB (Sub-address) signal is disabled.
2PWD reception 0: Disabled
0: Disables features that require PWD (Password) signal reception.3-4 Not used Do not change the settings.
PSTN dial-in routing setting 0: OFF
1: ON1: The machine sets multiple PSTN dial-in numbers in the PSTN dial-in line and transfers received data from each PSTN dial-in number to each address. 6 Not used Do not change the settings.
7Action when there is no box with an F-code that matches the received SUB code
0: Disconnect the line
1: Receive the message (using normal reception mode)
Change this setting when the customer requires.
Communication Switch 18 (SP No. 1-104-025) No Function Comments 0-4 Not used Do not change the settings.
5IP-Fax dial-in routing selection 0: Off
1: On1: Transfers received data to each IP-Fax dial-in number.
IP-Fax dial-in number is a 4-digit number.
6PSTN 2 dial-in routing 0: Off
1: On
Enables or disables dial-in routing for the PSTN 2 connection.
7PSTN 3 dial-in routing 0: Off
1: On
Enables or disables dial-in routing for the PSTN 3 connection.Fax Option Type 5002 (D629)
Communication Switch 19 - Not used (do not change the settings) Communication Switch 1A - Not used (do not change the settings)
Communication Switch 1B (SP No. 1-104-028) No Function Comments If the PABX does not support V.8/V.34 protocol
0-7
Extension access code (0 to 7) to turn V.8 protocol On/Off
0: On
1: Offprocedure, set this bit to "1" to disable V.8. Example: If "0" is the PSTN access code, set bit 0 to 1. When the machine detects "0" as the first dialed number, it automatically disables V.8
protocol. (Alternatively, if "3" is the PSTN accesscode, set bit 3 to 1.)
Communication Switch 1C (SP No. 1-104-029) No Function Comments Refer to communication switch 1B. Extension access code (8 and Example: If "8" is the PSTN access code, set bit 0
0-19) to turn V.8 protocol On/Off
0: Onto 1. When the machine detects "8" as the first
dialed number, it automatically disables V.81: Off protocol. (If "9" is the PSTN access code, use bit 1.) 2-7 Not used Do not change the settings.
Communication Switch 1D - Not used (do not change the settings) Communication Switch 1E - Not used (do not change the settings) Communication Switch 1F - Not used (do not change the settings) - This function does not work when dialing is done from the external telephone.
BIT SWITCHES - 4
G3 SWITCHES
G3 Switch 00 (SP No. 1-105-001) No Function Comments
0
1Monitor speaker during communication (tx and rx)
(0, 0): The monitor speaker is disabled all through the communication.
(0, 1): The monitor speaker is on up to phase B in the T.30 protocol.
(1, 0): Used for testing. The monitor speaker is on all through the communication. Make sure that you reset these bits after testing.Bit 1 Bit 0 Setting 0 0 Disabled 0 1 Up to Phase B 1 0 All the time 1 1 Not used
2Monitor speaker during memory transmission
0: Disabled 1: Enabled
1: The monitor speaker is enabled during memory transmission.3-7 Not used Do not change the settings. Fax Option Type 5002 (D629)
G3 Switch 01 (SP No. 1-105-002) No Function Comments 0-3 Not used Do not change the settings.
DIS frame length
0: 10 bytes 1: 4 bytes1: The bytes in the DIS frame after the 4th byte will not be transmitted (set to 1 if there are communication problems with PC-based faxes which cannot receive the extended DIS frames). 5 Not used Do not change the setting.
6Forbid CED/AMsam output 0: Off
1: On (Forbid output)Do not change this setting (Default: 0: Off), unless communication problem is caused by a CED or ANSam transmission. 7 Not used Do not change the setting.
G3 Switch 02 (SP No. 1-105-003) No Function Comments
0
G3 protocol mode used
0: Standard and non-standard 1: Standard onlyChange this bit to 1 only when the other end can only communicate with machines that send
T.30-standard frames only.
1: Disables NSF/NSS signals (these are used in non-standard mode communication)1-6 Not used Do not change the settings.
7Short preamble
0: Disabled 1: EnabledRefer to Appendix B in the Group 3 Facsimile Manual for details about Short Preamble.
G3 Switch 03 (SP No. 1-105-004) No Function Comments
0
DIS detection number (Echo countermeasure) 0: 1
1: 20: The machine will hang up if it receives the same DIS frame twice.
1: Before sending DCS, the machine will wait for the second DIS which is caused by echo on the line.1 Not Used Do not change the settings.
V.8 protocol 0: Disabled 1: Enabled0: V.8/V.34 communications will not be possible.
3ECM frame size 0: 256 bytes
1: 64 bytes
Keep this bit at "0" in most cases.
CTC transmission conditions 0: After one PPR signal received
1: After four PPR signals received (ITU-T standard)0: When using ECM in non-standard (NSF/NSS) mode, the machine sends a CTC to drop back the modem rate after receiving a PPR, if the following condition is met in communications at 14.4, 12.0, 9.6, and 7.2 kbps.
NTransmit- Number of transmitted frames NResend- Number of frames to be retransmitted 1: When using ECM, the machine sends a CTC to drop back the modem rate after receiving four PPRs.
PPR, CTC: These are ECM protocol signals. This bit is not effective in V.34 communications.- Do not set to 0 unless the line condition is always bad enough to slow down the data rate to 14.4 kbps or lower.
5Modem rate used for the next page after receiving a negative code (RTN or PIN)
0: No change 1: Fallback
1: The machine's tx modem rate will fall back before sending the next page if a negative code is received. This bit is ignored if ECM is being used.6 Not used Do not change the settings
Select detection of reverse polarity in ringing
0: Off
1: OnThis switch is used to prevent reverse polarity in ringing on the phone line (applied to PSTN-G3 ringing). Do not change this setting
0: No detection
1: Detection (Japan and Korea only)
G3 Switch 04 (SP No. 1-105-005)No Function Comments
0-3
Training error detection threshold0 - F (Hex); 0 - 15 bits
If the number of error bits in the received TCF is below this threshold, the machine informs the sender that training has succeeded.4-7 Not used Do not change the settings.
G3 Switch 05 (SP No. 1-105-006) No Function Comments
0-3Initial Tx modem rate (kbps) These bits set the initial starting modem rate for transmission.
Use the dedicated transmission parameters if you need to change this for specific receivers.
If a modem rate 14.4 kbps or slower is selected, V.8 protocol should be disabled manually.
Cross reference
V.8 protocol on/off - G3 switch 03, bit 2Bit 3 Bit 2 Bit 1 Bit 0 kbps 0 0 0 1 2.4 0 0 1 0 4.8 0 0 1 1 7.2 0 1 0 0 9.6 0 1 0 1 12.0 0 1 1 0 14.4 0 1 1 1 16.8 1 0 0 0 19.2 1 0 0 1 21.6 1 0 1 0 24.0 1 0 1 1 26.4 1 1 0 0 28.8 1 1 0 1 31.2 0 0 1 1 33.6 Other settings - Not used
4-5Initial modem type for 9.6 k or 7.2 kbps.
These bits set the initial modem type for
9.6 and 7.2 kbps, if the initial modem rate is set at these speeds.Bit 5 Bit 4 Setting 0 0 V.29 0 1 V.17 1 0 V.34 1 1 Not used 6-7 Not used Do not change the settings. Fax Option Type 5002 (D629)
G3 Switch 06 (SP No. 1-105-007) No Function Comments
0-3Initial Rx modem rate(kbps)
These bits set the initial starting modem rate for reception.
Use a lower setting if high speeds pose problems during reception.
Cross reference
V.8 protocol on/off - G3 switch 03, bit2Bit 3 Bit 2 Bit 1 Bit 0 kbps 0 0 0 1 2.4 0 0 1 0 4.8 0 0 1 1 7.2 0 1 0 0 9.6 0 1 0 1 12.0 0 1 1 0 14.4 0 1 1 1 16.8 1 0 0 0 19.2 1 0 0 1 21.6 1 0 1 0 24.0 1 0 1 1 26.4 1 1 0 0 28.8 1 1 0 1 31.2 Other settings - Not used
4-7Modem types available for reception
The setting of these bits is used to inform the transmitting terminal of the available modem type for the machine in receive mode.
If V.34 is not selected, V.8 protocol must be disabled manually. Cross reference
V.8 protocol on/off - G3 switch 03, bit 2Bit 7 Bit 6 Bit 5 Bit 4 Types 0 0 0 1 V.27ter 0 0 1 0 V.27ter, V.29 0 0 1 1 V.27ter, V.29, V.33 0 1 0 0 V.27ter, V.29, V.17/V.33 0 1 0 1 V.27ter, V.29, V.17/V33, V.34 Other settings - Not used
G3 Switch 07 (SP No. 1-105-008) No Function Comments
0-1PSTN cable equalizer (tx mode: Internal) Use a higher setting if there is signal loss at higher frequencies because of the length of wire between the modem and the telephone exchange.
Use the dedicated transmission parameters for specific receivers.
Also, try using the cable equalizer if one or more of the following symptoms occurs.
Communication error
Modem rate fallback occurs frequently.
V.34 communications.Bit 1 Bit 0 Setting 0 0 None 0 1 Low 1 0 Medium 1 1 High - This setting is not effective in
2-3PSTN cable equalizer (rx mode: Internal) Use a higher setting if there is signal loss at higher frequencies because of the length of wire between the modem and the telephone exchange.
Communication error with error codes such as 0-20, 0-23, etc.
V.34 communications.Bit 3 Bit 2 Setting 0 0 None 0 1 Low 1 0 Medium 1 1 High
4PSTN cable equalizer (V.8/V.17 rx mode: External) 0: Disabled
Keep this bit at "1".5 Not used Do not change the settings.
6
Parameter selection for dial tone detection
0: Normal parameter
1: Specific parameter0: This uses the fixed table in the ROM for dial tone detection.
1: This uses the specific parameter adjusted with SRAM (69ECBEH - 69ECDEH). Select this if the dial tone cannot be detected when the "Normal parameter: 0" is selected.7 Not used Do not change the settings.
G3 Switch 08 - Not used (do not change the settings)
G3 Switch 09 - Not used (do not change the settings)
G3 Switch 0A (SP No. 1-105-011) No Function Comments
0-1Maximum allowable carrier drop during image data reception
These bits set the acceptable modem carrier drop time.
Try a longer setting if error code 0-22 is frequent.Bit 1 Bit 0 Value (ms) 0 0 200 0 1 400 1 0 800 1 1 Not used
2Select cancellation of high-speed RX if carrier signal lost while receiving
0: Off
1: OnThis switch setting determines if
high-speed receiving ends if the carrier signal is lost when receiving during non-ECM mode3 Not used Do not change the settings
Maximum allowable frame interval during image data reception.
0: 5 s 1: 13 sThis bit set the maximum interval between EOL (end-of-line) signals and the maximum interval between ECM frames from the other end.
Try using a longer setting if error code 0-21 is frequent.5 Not used Do not change the settings.
6
Reconstruction time for the first line in receive mode
0: 6 s 1: 12 sWhen the sending terminal is controlled by a computer, there may be a delay in receiving page data after the local machine accepts set-up data and sends CFR. This is outside the T.30 recommendation. But, if this delay occurs, set this bit to 1 to give the sending machine more time to send data. Refer to error code 0-20.
ITU-T T.30 recommendation: The first line should come within 5 s of CFR.7 Not used Do not change the settings. Fax Option Type 5002 (D629)
G3 Switch 0B Not used (do not change the settings). G3 Switch 0C Not used (do not change the settings). G3 Switch 0D Not used (do not change the settings).
G3 Switch 0E (SP No. 1-105-015) No Function Comments
0-7Set CNG send time interval
Some machines on the receiving side may not be able to automatically switch the 3-second CNG interval.
High order bit3000-2250ms: 3000-50xNms
3000 – 50 x Nms 0F (3000 ms) <= N <= FF (2250
ms)
Low order bit00-0E(3000-3700ms: 3000+50xNms
3000 – 50 x Nms 0F (3000 ms) <= N <= 0F (3700
ms)
G3 Switch 0F (SP No. 1-105-016) No Function Comments Alarm when an error occurred
0in Phase C or later
0: DisabledIf the customer wants to hear an alarm after each
error communication, change this bit to "1".1: Enabled Alarm when the handset is off-hook at the end of If the customer wants to hear an alarm if the 1 communication handset is off-hook at the end of fax 0: Disabled communication, change this bit to "1". 1: Enabled 2-3 Not used Do not change the settings.
4Sidaa manual calibration setting
0: Off
1: On
1: manually calibrates for communication with a line whose current change occurs such as an optical fiber line.5-7 Not used Do not change the settings. Fax Option Type 5002 (D629)
BIT SWITCHES - 5
G3-2 AND G3-3 SWITCHES
These switches require an optional G3 interface unit. G3-3 switches are the same as for G3-2 switches.
G3-2 Switch 00 (SP No. 1-106-001) No Function Comments
0
(1, 0): Used for testing. The monitor speaker is on all through the communication. Make sure that you reset these bits after testing.Bit 1 Bit 0 Setting 0 0 Disable 0 1 Up to Phase B 1 0 All the time 1 1 Not used
G3-2 Switch 01 (SP No. 1-106-002) No Function Comments 0-3 Not used Do not change the settings.
DIS frame length
G3-2 Switch 02 (SP No. 1-106-003) No Function Comments
0
7Short preamble
0: Disabled 1: EnabledRefer to Appendix B in the Group 3 Facsimile Manual for details about Short Preamble. Fax Option Type 5002 (D629)
G3-2 Switch 03 (SP No. 1-106-004) No Function Comments
0
1: 64 bytes
Ntransmit = Number of transmitted frames Nresend = Number of frames to be retransmitted 1: When using ECM, the machine sends a CTC to drop back the modem rate after receiving four PPRs.
0: Off
0: No detection
G3-2 Switch 04 (SP No. 1-106-005)No Function Comments
0-3
G3-2 Switch 05 (SP No. 1-106-006) No Function Comments
Cross reference
V.8 protocol on/off - G3 switch 03, bit 2Bit 3 Bit 2 Bit 1 Bit 0 kbps 0 0 0 1 2.4 0 0 1 0 4.8 0 0 1 1 7.2 0 1 0 0 9.6 0 1 0 1 12.0 0 1 1 0 14.4 0 1 1 1 16.8 1 0 0 0 19.2 1 0 0 1 21.6 1 0 1 0 24.0 1 0 1 1 26.4 1 1 0 0 28.8 1 1 0 1 31.2 Other settings - Not used
G3-2 Switch 06 (SP No. 1-106-007) No Function Comments
Cross reference
V.8 protocol on/off - G3 switch 03, bit 2Bit 7 Bit 6 Bit 5 Bit 4 Types 0 0 0 1 V.27ter 0 0 1 0 V.27ter 0 0 1 1 V.27ter 0 1 0 0 V.27ter 0 1 0 1 V.27ter Other settings - Not used Fax Option Type 5002 (D629)
G3-2 Switch 07 (SP No. 1-106-008) No Function Comments
Communication error
Keep this bit at "1".- This setting is not effective in
G3-2 Switch 08 - Not used (do not change the settings) G3-2 Switch 09 - Not used (do not change the settings)
G3-2 Switch 0A (SP No. 1-106-011) No Function Comments
0: Off
6
G3-2 Switch 0B- Not used (do not change the settings) G3-2 Switch 0C- Not used (do not change the settings)
G4 INTERNAL SWITCHES
The G4 internal switches (SW00 to 1F) are displayed but do not change these settings.
G4 PARAMETER SWITCHES
The G4 parameter switches (SW00 to 0F) are displayed but do not change these settings.
BIT SWITCHES - 6
IP FAX SWITCHES
IP Fax Switch 00 (SP No. 1-111-001) | ||
No. | Function | Comments |
0 | Not used | Do not change this setting. |
1 | IP Fax Transport 0: TCP, 1: UDP | Selects TCP or UDP protocol for IP-Fax |
2 | IP Fax single port selection 0: OFF, 1: ON (enable) | Selects single data port. |
3 | IP Fax double ports (single data port) selection 0: OFF, 1: ON (enable) | Selects whether IP-Fax uses a double port. |
4 | IP Fax Gatekeeper 0: OFF, 1: ON (enable) | Enables/disables the gatekeeper for IP-Fax. |
5 | IP Fax T30 bit signal reverse 0: LSB first, 1: MSB first | Reverses the T30 bit signal. |
6 | IP Fax max bit rate setting 0: Not affected, 1: Affected | When "0" is selected, the max bit rate does not affect the value of the DIS/DCS. When "1" is selected, the max bit rate affects the value of the DIS/DCS. |
7 | IP Fax received telephone number confirmation 0: No confirmation, 1: Confirmation | When "0" is selected, fax data is received without checking the telephone number. When "1" is selected, fax data is received only when confirming that the telephone number from the sender matches the registered telephone number in this machine. If this confirmation fails, the line is disconnected. |
IP Fax Switch 01 (SP No. 1-111-002) | |||||
No. | Function | Comments | |||
0-3 | IP Fax delay level setting Selects the acceptable delay level. Level 0 is the highest quality Default is "0000" (level 0). | ||||
Bit 3 | Bit 2 | Bit 1 | Bit 0 | ||
0 | 0 | 0 | 0 | Level 0 | |
0 | 0 | 0 | 1 | Level 1 | |
0 | 0 | 1 | 0 | Level 2 | |
0 | 0 | 1 | 1 | Level 3 | |
4-7 | IP Fax preamble wait time setting | Selects the preamble wait time. [00 to 0f] There are 16 values in this 4-bit binary switch combination. Waiting time: set value level x 100 ms Max: 0f (1500 ms) Min: 00 (No wait time) The default is "0000" (00H). |
