Ricoh MP4002/5002 service manual Part 22
CodeMeaningSuggested Cause/Action
14-08Data Send to SMTP Server Failed (5XX)
  • Failed to access the SMTP server because the transmission failed.
  • SMTP server operating incorrectly
  • Destination folder setting incorrect.
  • Direct SMTP sending not operating correctly.
  • Software application error.
14-09Authorization Failed for Sending to SMTP Server
  • POP-Before-SMTP or SMTP authorization failed.
  • Incorrect setting for file transfer
14-10Addresses Exceeded
  • Number of broadcast addresses exceeded the limit for the SMTP server.
14-11Buffer Full
  • The send buffer is full so the transmission could not be completed. Buffer is full due to using Scan-to-Email while the buffer is being used send mail at the same time.
14-12Data Size Too Large
  • Transmission was cancelled because the detected size of the file was too large.
14-13Send Cancelled
  • Processing is interrupted because the user pressed Stop.
14-14Security Locked File Error
  • Update the software because of the defective software.
14-15Mail Data Error
  • The transmitting a mail is interrupted via DCS due to the incorrect data.
14-16Maximum Division Number Error
  • When a mail is divided for the mail transmission and the division number of a mail are more than the specified number, the mail transmission is interrupted.
Fax Option Type 5002 (D629)
14-17Incorrect Ticket
14-18Access to MCS File Error
  • The access to MCS file is denied due to the no permission of access.
14-20SMTP Authentication errorMake sure the administrator's e-mail address is same as the SMTP authentication address or POP before SMTP address.
14-21Transmission error of S/MIMERegister the correct user certificate and device certificate.
14-30MCS File Creation FailedFailed to create the MCS file because:
  • The number of files created with other applications on the Document Server has exceeded the limit.
  • HDD is full or not operating correctly.
  • Software error.
14-31UFS File Creation FailedUFS file could not be created:
  • Not enough space in UFS area to handle both Scan-to-Email and IFAX transmission.
  • HDD full or not operating correctly.
  • Software error.
14-32Cancelled the Mail Due to Error Detected by NFAX
  • Error detected with NFAX and send was cancelled due to a software error.
14-33No Mail Address For the Machine
  • Neither the mail address of the machine nor the mail address of the network administrator is registered.
14-34Address designated in the domain for SMTP sending does not exist
  • Operational error in normal mail sending or direct SMTP sending.
  • Check the address selected in the address book for SMTP sending.
  • Check the domain selection.
14-50Mail Job Task ErrorDue to an FCU mail job task error, the send was cancelled:
  • Address book was being edited during creation of the notification mail.
  • Software error.
14-51UCS Destination Download ErrorNot even one return notification can be downloaded:
  • The address book was being edited.
  • The number for the specified destination does not exist (it was deleted or edited after the job was created).
14-60Send Cancel Failed
  • The cancel operation by the user failed to cancel the send operation.
14-61Notification Mail Send Failed for All Destinations
  • All addresses for return notification mail failed.
14-62Transmission Error due to the existence of zero line page
  • When the 0 line page exists in received pages with G3 communication, the transmission is interrupted.
15-01POP3/IMAP4 Server Not Registered
  • At startup, the system detected that the IP address of the POP3/IMAP4 server has not been registered in the machine.
15-02POP3/IMAP4 Mail Account Information Not Registered
  • The POP3/IMAP4 mail account has not been registered.
15-03Mail Address Not Registered
  • The mail address has not been registered.
15-10DCS Mail Receive Error
  • Error other than 15-11 to 15-18.
15-11Connection ErrorThe DNS or POP3/IMAP4 server could not be found:
  • The IP address for DNS or POP3/IMAP4 server is not stored in the machine.
  • The DNS IP address is not registered.
  • Network not operating correctly.
15-12Authorization ErrorPOP3/IMAP4 send authorization failed:
  • Incorrect IFAX user name or password.
  • Access was attempted by another device, such as the PC.
  • POP3/IMAP4 settings incorrect.
15-13Receive Buffer Full
  • Occurs only during manual reception. Transmission cannot be received due to insufficient buffer space. The buffer is being used for mail send or Scan-to-Email.
15-14Mail Header Format Error
  • The mail header is not standard format. For example, the Date line description is incorrect.
15-15Mail Divide Error
  • The e-mail is not in standard format. There is no boundary between parts of the
e-mail, including the header.
15-16Mail Size Receive Error
  • The mail cannot be received because it is too large.
15-17Receive Timeout
  • May occur during manual receiving only because the network is not operating correctly.
15-18Incomplete Mail Received
  • Only one portion of the mail was received.
15-31Final Destination for Transfer Request Reception Format Error
  • The format of the final destination for the transfer request was incorrect.
15-39Send/Delivery Destination ErrorThe transmission cannot be delivered to the final destination:
  • Destination file format is incorrect.
  • Could not create the destination for the file transmission.
15-41SMTP Receive Error
  • Reception rejected because the transaction exceeded the limit for the “Auth. E-mail RX” setting.
15-42Off Ramp Gateway Error
  • The delivery destination address was specified with Off Ramp Gateway OFF.
15-43Address Format Error
  • Format error in the address of the Off Ramp Gateway.
15-44Addresses Over
  • The number of addresses for the Off Ramp Gateway exceeded the limit of 30.
15-61Attachment File Format Error
  • The attached file is not TIFF format.
15-62TIFF File Compatibility ErrorCould not receive transmission due to:
  • Resolution error
  • Image of resolution greater than 200 dpi without extended memory.
  • Resolution is not supported.
  • Page size error
  • The page size was larger than A3.
  • Compression error
  • File was compressed with other than MH, MR, or MMR.
15-63TIFF Parameter ErrorThe TIFF file sent as the attachment could not be received because the TIFF header is incorrect:
  • The TIFF file attachment is a type not supported.
  • The TIFF file attachment is corrupted.
  • Software error.
15-64TIFF Decompression ErrorThe file received as an attachment caused the TIFF decompression error:
  • The TIFF format of the attachment is corrupted.
  • Software error.
15-71Not Binary Image Data
  • The file could not be received because the attachment was not binary image data.
15-73MDN Status Error
  • Could not find the Disposition line in the header of the Return Receipt, or there is a problem with the firmware.
15-74MDN Message ID Error
  • Could not find the Original Message ID line in the header of the Return Receipt, or there is a problem with the firmware.
15-80Mail Job Task Read Error
  • Could not receive the transmission because the destination buffer is full and the destination could not be created (this error may occur when receiving a transfer request or a request for notification of reception).
15-81Repeated Destination Registration Error
  • Could not repeat receive the transmission because the destination buffer is full and the destination could not be created (this error may occur when receiving a transfer request or a request for notification of reception).
15-91Send Registration ErrorCould not receive the file for transfer to the final destination:
  • The format of the final destination or the transfer destination is incorrect.
  • Destinations are full so the final and transfer destinations could not be created.
15-92Memory Overflow
  • Transmission could not be received because memory overflowed during the transaction.
15-93Memory Access Error
  • Transaction could not complete due to a malfunction of SAF memory.
15-94Incorrect ID Code
  • The machine rejected an incoming e-mail for transfer request, because the ID code in the incoming e-mail did not match the ID code registered in the machine.
15-95Transfer Station Function
  • The machine rejected an incoming e-mail for transfer because the transfer function was unavailable.
22-00Original length exceeded the maximum scan length
  • Divide the original into more than one page.
  • Check the resolution used for scanning. Lower the scan resolution if possible.
  • Add optional page memory.
22-01Memory overflow while receiving
  • Wait for the files in the queue to be sent.
  • Delete unnecessary files from memory.
  • Transfer the substitute reception files to an another fax machine, if the machine’s printer is busy or out of order.
  • Add an optional SAF memory card or hard disk.
22-02Tx or rx job stalled due to line disconnection at the other end
  • The job started normally but did not finish normally; data may or may not have been received fully.
  • Restart the machine.
22-04The machine cannot store received data in the SAF
  • Update the ROM
  • Replace the FCU.
22-05No G3 parameter confirmation answer
  • Defective FCU board or firmware.
23-00Data read timeout during construction
  • Replace the FCU.
25-00The machine software resets itself after a fatal transmission error occurred
  • Update the ROM
  • Replace the FCU.
F0-xxV.34 modem error
  • Replace the FCU.
F6-xxSG3 modem error
  • Update the SG3 modem ROM.
  • Replace the SG3 board.
  • Check for line noise or other line problems.
  • Try communicating another V.8/V.34 fax.
  1. IFAX TROUBLESHOOTING​
    Use the following procedures to determine whether the machine or another part of the network is causing the problem.
    Communication Route
    Item
    Action [Remarks]
    General LAN1. Connection with the LAN
    2. LAN activityCheck that other devices connected to the LAN can communicate through the LAN.
    Between IFAX and PC1. Network settings on the PC
    2. Check that PC can connect with the machine[At the MS-DOS prompt, type ping then the IP address of the machine, then press Enter.]
    3. LAN settings in the machine[Use the “Network” function in the User Tools.
    If there is an IP address conflict, inform the administrator.]
    • Check that the LAN cable is connected to the machine.
    • Check that the LEDs on the hub are lit.
    • Check the network settings on the PC. [Is the IP address registered in the TCP/IP properties in the network setup correct? Check the IP address with the administrator of the network.]
    • Use the “ping” command on the PC to contact the machine.
    • Check the LAN parameters
    • Check if there is an IP address conflict with other PCs.
    • Communication Route
      Item
      Action [Remarks]
      Between machine and e-mail server1. LAN settings in the machine[Use the “Network” function in the User Tools.
      2. E-mail account on the server[Ask the administrator to check.]
      3. E-mail server[Ask the administrator to check.
      Send a test e-mail with the machine’s own number as the destination. The machine receives the returned e-mail if the communication is performed successfully.]
      Between e-mail server and internet1. E-mail account on the Server[Ask the administrator to check.]
    • Make sure that the machine can log into the e-mail server.
    • Check that the account and password stored in the server are the same as in the machine.
    • Make sure that the client devices which have an account in the server can send/receive e-mail.
    • Make sure that the PC can log into the e-mail server.
      Item
      Action [Remarks]
      2. E-mail server[Ask the administrator to check.
      3. Destination e-mail address
      4. Router settings[Ask the administrator of the server to check.]
      5. Error message by e-mail from the network of the destination.
    • Make sure that the e-mail address is actually used.
    • Check that the e-mail address contains no incorrect characters such as spaces.
    • Use the “ping” command to contact the router.
    • Check that other devices connected to the router can sent data over the router.
    • Check whether e-mail can be sent to another address on the same network, using the application e-mail software.
    • Check the error e-mail message. [Inform the administrator of the LAN.]
    • Fax Option Type 5002 (D629)
  2. IP-FAX TROUBLESHOOTING​
    1. IP-FAX TRANSMISSION​
      Cannot send by IP Address/Host Name​
      Check PointAction
      1LAN cable connected?Check the LAN cable connection.
      2Specified IP address/host name correct?Check the IP address/host name.
      Firewall/NAT is installed?
      Cannot breach the firewall. Send by using another method (Fax, Internet Fax)
      4Transmission sent manually?Manual sending not supported.
      5IP address of local machine registered?Register the IP address.
      6
      Remote terminal port number setting other than 1720 (when using H.323) or 5060 (when using SIP)?
      Send by specifying the port number.
      Specified port number correct?
      Confirm the port number of the remote fax.
      DNS server registered when host name specified?
      Contact the network administrator.
      Remote fax a T.38 terminal?
      Check whether the remote fax is a T38 terminal.
      10
      Remote fax switched off or busy?
      Check that the remote fax is switched on.
      Network bandwidth too narrow?
      Request the network administrator to increase the bandwidth.
      Raise the delay level. IPFAX SW 01 Bit 0 to 3
      IP-Fax bandwidth is the same as the DCS speed. Set IP-Fax SW00 Bit 6 to 1.
      Remote fax cancelled transmission?
      Check whether the remote fax cancelled the transmission.
      Cannot send via VoIP Gateway​
      Check PointAction
      2VoIP Gateway T.38 standard?Contact the network administrator.
      3VoIP Gateway installed correctly?Contact the network administrator.
      4VoIP Gateway power switched on?Contact the network administrator.
      Is the IP address/host name of the specified Gateway correct?
      6Number of the specified fax correct?Check the remote fax number.
      8Transmission sent manually?Manual sending not supported.
      9IP address of local fax registered?Register the IP address.
      10
      DNS registered when host name specified?
      11Remote fax a G3 fax?Check that the remote fax is a G3 fax.
      12G3 fax is connected to VoIP gateway?Check that G3 fax is connected.
      13Remote G3 fax turned on?Check that G3 fax is switched on.
      Raise the network delay level. IPFAX SW 01 Bit 0 to 3
      Cannot send by Alias Fax number.​
      Check PointAction
      Number of specified Alias fax correct?
      Confirm the Alias of the remote fax. Error Code: 13-14
      Firewall/NAT installed?
      5Gatekeeper/SIP server installed correctly?Contact the network administrator.
      6
      Gatekeeper/SIP server power switched on?
      IP address/host name of Gatekeeper/SIP server correct?
      DNS server registered when Gatekeeper/SIP server host name specified?
      Enable H.323/Enable SIP SW is set to on?
      Check the settings.
      See User Parameter SW 34 Bit 0/SW 34 Bit 1
      10IP address of local fax registered?Register the IP address of the local fax.
      Alias number of local fax registered?
      Register the Alias number of the local fax.
      12Remote fax registered in Gatekeeper?Contact the network administrator.
      13
      14Remote fax switched off or busy?Contact the network administrator.
      15
      Request the system administrator to increase the bandwidth.
      Lower the modem transmission baud rate.
      IPFAX SW 05
      16
    2. IP-FAX RECEPTION​
Cannot receive via IP Address/Host Name.​
Check PointAction
3IP address of local fax registered?Register the IP address.
Port number specified at remote sender fax (if required)?Request the sender to specify the port number.
Specified port number correct (if required)?Request the sender to check the port number.
6
DNS server registered when host name specified on sender side?
  • The sender machine displays this error code if the sender fax is a Ricoh model.
Lower the start modem reception baud rate on the receiving side.
IPFAX SW06
Cannot receive by VoIP Gateway.​
Check PointAction
Cannot breach the firewall. Request the remote fax to send by using another method (Fax, Internet Fax)
IP address/host name of specified VoIP Gateway correct on sender’s side?Request the remote fax to check the IP address/host name.
6
8G3 fax connected?Check that G3 fax is connected.
9G3 fax power switched on?Check that G3 fax is switched on.
Cannot receive by Alias Fax number.​
Check PointAction
Cannot the breach firewall. Request the remote fax to send by using another method (Fax, Internet Fax)
  • The sender machine displays this error code when the sender fax is a Ricoh model.
Power to Gatekeeper/SIP server switched on?
IP address/host name of Gatekeeper/SIP server correct on the sender’s side?
Request the sender to check the IP address/host name.
6
DNS server registered when Gatekeeper/SIP server host name specified on sender’s side?
Request the sender to check the settings. User Parameter SW 34 Bit 0/SW 34 Bit 1
  • Only if the remote sender fax is a Ricoh fax.
8Local fax IP address registered?Register the IP address.
9Local fax Alias number registered?Register the Alias number.
10
IPFAX SW06
Local fax registered in Gatekeeper/SIP server?
  1. SERVICE TABLES​
    1. CAUTIONS​
      • Never turn off the main power switch when the power LED is lit or flashing. To avoid damaging the hard disk or memory, press the operation power switch to switch the power off, wait for the power LED to go off, and then switch the main power switch off.
      • The main power LED lights or flashes while the platen cover or ARDF is open, while the main machine is communicating with a facsimile or the network server, or while the machine is accessing the hard disk or memory for reading or writing data.
    2. SERVICE PROGRAM TABLES​
    1. SP1-XXX (BIT SWITCHES)​
      Bit Switches
      1Mode No.Function
      101
      System Switch
      001 – 032
      00 – 1F
      Change the bit switches for system settings for the fax option
      "System Switches" in "Bit Switches - 1"
      102
      Ifax Switch
      001 – 016
      00 – 0F
      Change the bit switches for internet fax settings for the fax option
      "I-Fax Switches" in "Bit Switches - 2"
      103
      Printer Switch
      001 – 016
      00 – 0F
      Change the bit switches for printer settings for the fax option
      "Printer Switches" in "Bit Switches - 2"
      104
      Communication Switch
      001 – 032
      00 – 1F
      Change the bit switches for communication settings for the fax option
      "Communication Switches" in "Bit Switches - 3"
      105
      G3-1 Switch
      001 – 016
      00 – 0F
      Change the bit switches for the protocol settings of the standard G3 board
      "G3 Switches" in "Bit Switches - 4"
      106
      G3-2 Switch
      001 – 016
      00 – 0F
      Change the bit switches for the protocol settings of the optional G3 board
      "G3-2 and G3-3 Switches" in "Bit Switches - 5"
      107
      G3-3 Switch
      001 – 016
      00 – 0F
      108
      G4 Internal Switch
      001 – 03200 – 1FNot used (Do not change the bit switches)
      109
      G4 Parameter Switch
      001 – 01600 – 0FNot used (Do not change the bit switches)
      111
      IP fax Switch
      001 – 016
      00 – 0F
      Change the bit switches for optional IP fax parameters
      "IP Fax Switches" in "Bit Switches - 6"
    2. SP2-XXX (RAM DATA)​
      2Mode No.Function
      101
      RAM Read/Write
      Change RAM data for the fax board directly.
      p.164 "Service RAM Addresses"
      102
      Memory Dump
      G3-1 Memory DumpPrint out RAM data for the fax board.
      G3-2 Memory DumpPrint out RAM data for the optional SG3 board.
      G3-3 Memory DumpPrint out RAM data for the optional SG3 board.
      004G4 Memory DumpNot used
      103G3-1 NCU Parameters
      001 – 023
      CC, 01 – 22
      NCU parameter settings for the standard G3 board.
      p.140 "NCU Parameters"
      104
      G3-2 NCU Parameters
      001 – 023
      CC, 01 – 22
      NCU parameter settings for the optional G3 board.
      105
      G3-3 NCU Parameters
      001 – 023
      CC, 01 – 22
    3. SP3-XXX (TEL LINE SETTINGS)​
      3Mode No.Function
      101
      Service Station
      001Fax NumberEnter the fax number of the service station.
      002Select LineSelect the line type.
      102
      Serial Number
      000Enter the fax unit’s serial number.
      103
      PSTN-1 Port Settings
      Select Line
      Select the line type setting for the G3-1 line. If the machine is installed on a PABX line, select “PABX”, “PABX(GND)” or “PABX(FLASH)”.
      PSTN Access NumberEnter the PSTN access number for the G3-1 line.
      Memory Lock Disabled
      Not used
      104
      PSTN-2 Port Settings
      Select Line
      Select the line setting for the G3-2 line. If the machine is installed on a PABX line, select “PABX”, “PABX(GND)” or “PABX(FLASH)”.
      PSTN Access NumberEnter the PSTN access number for the G3-2 line.
      Not used
      Transmission DisabledIf you turn this SP on, the machine does not send any fax messages on the G3-2 line.
      105
      PSTN-3 Port Settings
      Select Line
      Select the line setting for the G3-3 line. If the machine is installed on a PABX line, select “PABX”, “PABX(GND)” or “PABX(FLASH)”.
      PSTN Access NumberEnter the PSTN access number for the G3-3 line.
      Not used
      Transmission DisabledIf you turn this SP on, the machine does not send any fax messages on the G3-3 line.
      106
      ISDN Port Settings
      001Select Line
      Not used (Do not change the settings.)
      PSTN Access Number
      106
      107
      IPFAX Port Settings
      001H323 PortSets the H323 port number.
      002SIP PortSets the SIP port number.
      003RAS PortSets the RAS port number.
      004Gatekeeper portSets the Gatekeeper port number.
      005T.38 PortSets the T.38 port number.
      006SIP Server PortSets the SIP port number.
      IPFAX Protocol Priority
      Select "H323" or "SIP".
      201
      FAX SW
      001 – 03200 – 1F
    4. SP4-XXX (ROM VERSIONS)​
      4Mode No.Function
      101001FCU ROM VersionDisplays the FCU ROM version.
      102001Error CodesDisplays the latest 64 fax error codes.
      103001G3-1 ROM VersionDisplays the G3-1 modem version.
      104001G3-2 ROM VersionDisplays the G3-2 modem version.
      105001G3-3 ROM VersionDisplays the G3-3 modem version.
      106001G4 ROM VersionNot used (Do not change the settings.)
    5. SP5-XXX (RAM CLEAR)​
      5Mode No.Function
      101
      Initialize SRAM (Except Secure)
      000
      Initializes the bit switches and user parameters, user data in the SRAM, files in the SAF memory, and clock.
      102
      Erase All Files
      000Erases all files stored in the SAF memory.
      103
      Reset Bit Switches (Except Secure)
      000Resets the bit switches and user parameters.
      104
      Factory Setting
      000
      Resets the bit switches and user parameters, user data in the SRAM and files in the SAF memory.
      105
      Reset All Bit Switches
      000Resets all the current bit switch settings.
      106
      Reset Security Bit Switches
      000
      Resets only the security bit switches. If you select automatic output/display for the user parameter switches, the security settings are initialized.
    6. SP6-XXX (REPORTS)​
      6Mode No.Function
      101
      System Parameter List
      000
      Touch the “ON” button to print the system parameter list.
      102
      Service Monitor Report
      000
      Touch the “ON” button to print the service monitor report.
      103
      G3 Protocol Dump List
      G3 All CommunicationsPrints the protocol dump list of all communications for all G3 lines.
      G3-1 (All
      Communications)
      Prints the protocol dump list of all communications for the G3-1 line.
      G3-1
      (1 Communication)
      Prints the protocol dump list of the last communication for the G3-1 line.
      G3-2
      (All Communications)
      Prints the protocol dump list of all communications for the G3-2 line.
      G3-2
      (1 Communication)
      Prints the protocol dump list of the last communication for the G3-2 line.
      G3-3
      Prints the protocol dump list of all communications for the G3-3 line.
      G3-3
      (1 Communication)
      Prints the protocol dump list of the last communication for the G3-3 line.
      104
      G4 Protocol Dump List
      001Dch + Bch 1
      002Dch
      003Bch 1 Link Layer
      004Dch Link Layer
      005Dch +Bch 2
      006Bch 2 Link Layer
      105
      All Files print out
      000
      Prints out all the user files in the SAF memory, including confidential messages.
      106
      Journal Print out
      All Journals
      The machine prints all the communication records on the report.
      Specified Date
      The machine prints all communication records after the specified date.
      • Do not use this function, unless the customer is having trouble printing confidential messages or recovering files stored using the memory lock feature.
      107
      Log List Print out
      001All log files
      These log print out functions are for designer use only.
      002Printer
      003SC/TRAP Stored
      004Decompression
      005Scanner
      006JOB/SAF
      007Reconstruction
      008JBIG
      009Fax Driver
      010G3CCU
      011Fax Job
      012CCU
      013Scanner Condition
      108
      IP Protocol Dump List
      All Communications
      Prints the protocol dump list of all communications for the IP fax line.
      1 Communication
      Prints the protocol dump list of the last communication for the IP fax line.
    7. SP7-XXX (TESTS)​
      These are the test modes for PTT approval.
      7Function
      101G3-1 Modem Tests
      102G3-1 DTMF Tests
      103Ringer Test
      104G3-1 V34 (S2400baud)
      105G3-1 V34 (S2800baud)
      106G3-1 V34 (S3000baud)
      107G3-1 V34 (S3200baud)
      108G3-1 V34 (S3429baud)
      109Recorded Message Test
      110G3-2 Modem Tests
      111G3-2 DTMF Tests
      112G3-2 V34 (S2400baud)
      113G3-2 V34 (S2800baud)
      114G3-2 V34 (S3000baud)
      115G3-2 V34 (S3200baud)
      116G3-2 V34 (S3429baud)
      117G3-3 Modem Tests
      118G3-3 DTMF Tests
      119G3-3 V34 (S2400baud)
      120G3-3 V34 (S2800baud)
      121G3-3 V34 (S3000baud)
      122G3-3 V34 (S3200baud)
      123G3-3 V34 (S3429baud)
      124IG3-1 Modem Tests - Not used
      125IG3-1 DTMF Tests - Not used
      126IG3-1 V34 (S2400baud) - Not used
      127IG3-1 V34 (S2800baud) - Not used
      128IG3-1 V34 (S3000baud) - Not used
      129IG3-1 V34 (S3200baud) - Not used
      130IG3-1 V34 (S3429baud) - Not used
      131IG3-2 Modem Tests - Not used
      132IG3-2 DTMF Tests - Not used
      133IG3-2 V34 (S2400baud) - Not used
      134IG3-2 V34 (S2800baud) - Not used
      135IG3-2 V34 (S3000baud) - Not used
      136IG3-2 V34 (S3200baud) - Not used
      137IG3-2 V34 (S3429baud) - Not used
  1. BIT SWITCHES - 1​
    • Do not adjust a bit switch or use a setting that is described as "Not used", as this may cause the machine to malfunction or to operate in a manner that is not accepted by local regulations. Such bits are for use only in other areas, such as Japan.
    • Default settings for bit switches are not listed in this manual. Refer to the System Parameter List printed by the machine.
    1. SYSTEM SWITCHES​
System Switch 00 (SP No. 1-101-001)
NoFunctionComments
Dedicated transmissionSet this bit to 1 before changing any dedicated
0
parameter programming
transmission parameters.
This setting is automatically reset to "0" after
1: Enabledturning off and on.
1Not usedDo not change
Technical data printout on the Journal
1: Instead of the personal name, the following data are listed on the Journal for each G3 communication.
Example:
(1): EQM value (Line quality data). A larger number means more errors. (2): Symbol rate (V.34 only)
(3): Final modem type used
(4): Starting data rate (for example, 288 means 28.8 kbps) (5): Final data rate
(6): Rx revel (see below for how to read the rx level)
(7): Total number of error lines that occurred during non-ECM reception.
(8): Total number of burst error lines that occurred during non-ECM reception.
  • EQM and rx level are fixed at "FFFF" in tx mode.
  • The seventh and eighth numbers are fixed at "00" for transmission records and ECM reception records.
Rx level calculation Example:
The four-digit hexadecimal value (N) after "L" indicates the rx level.
The high byte is given first, followed by the low byte. Divide the decimal value of N by -16 to get the rx level.
In the above example, the decimal value of N (= 0100 [H]) is 256. So, the actual rx level is 256/-16 = -16 dB
3Not usedDo not change this setting.
Line error mark print 0: OFF, 1: ON (print)
When "1" is selected, a line error mark is printed on the printout if a line error occurs during reception. This shows error locations when ECM is turned off.
G3/G4 communication parameter display
This is a fault-finding aid. The LCD shows the key parameters (see "G3 Communication Parameters" below this table). This is normally disabled because it cancels the CSI display for the user.
Be sure to reset this bit to "0" after testing.
6
Protocol dump list output after each communication
0: Off
1: On
This is only used for communication troubleshooting. It shows the content of the transmitted facsimile protocol signals. Always reset this bit to 0 after finishing testing.
If system switch 09 bit 6 is at "1", the list is only printed if there was an error during the communication.
7Not usedDo not change the setting.
Modem rate
336: 33600 bps 168: 16800 bps
312: 31200 bps 144: 14400 bps
288: 28800 bps 120: 12000 bps
264: 26400 bps 96: 9600 bps
240: 24000 bps 72: 7200 bps
216: 21600 bps 48: 4800 bps
192: 19200 bps 24: 2400 bps
Resolution
S: Standard (8 x 3.85 dots/mm)
D: Detail (8 x 7.7 dots/mm)
F: Fine (8 x 15.4 dots/mm)
SF: Superfine (16 x 15.4 dots/mm)
21: Standard (200 x 100 dpi)
22: Detail (200 x 200 dpi)
44: Superfine (400 x 400 dpi)
Compression mode
MMR: MMR compression MR: MR compression MH: MH compression
JBO: JBIG compression (Optional mode) JBB: JBIG compression (Basic mode)
Communication modeECM: With ECM
NML: With no ECM
Width and reduction
A4: A4 (8.3"), no reduction B4: B4 (10.1"), no reduction A3: A3 (11.7"), no reduction
I/O rate
0: 0 ms/line
5: 5 ms/line
10: 10 ms/line
20: 20 ms/line
25: 2.5 ms/line
40: 40 ms/line
  • "40" is displayed while receiving a fax message using AI short protocol.
System Switch 01 - Not used (Do not change the factory settings.)
System Switch 02 (SP No. 1-101-003)
NoFunctionComments
0Not usedDo not change these settings.
Forced reset after transmission stalls
0: Off
1: On
With this setting on, the machine resets itself automatically if a transmission stalls and fails to complete the job.
3Not usedDo not change these settings.
File retention time
0: Depends on User Parameter 24 [18(H)]
1: No limit
1: A file that had a communication error will not be erased unless the communication is successful.
5Not usedDo not change this setting.
6-7
Memory read/write by RDS(0,0): All RDS systems are always locked out. (0,1), (1,0): Normally, RDS systems are locked out, but the user can temporarily switch RDS on to allow RDS operations to take place. RDS will automatically be locked out again after a certain time, which is stored in System Switch
03. Note that if an RDS operation takes place, RDS will not switch off until this time limit has expired.
(1,1): At any time, an RDS system can access the machine.
Bit 7Bit 6Setting
00Always disabled
01User selectable
10User selectable
11Always enabled
System Switch 03 (SP No. 1-101-004)
NoFunctionComments
0
to 7
Length of time that RDS is temporarily switched on when bits 6 and 7 of System Switch 02 are set to "User selectable"00 - 99 hours (BCD).
This setting is only valid if bits 6 and 7 of System Switch 02 are set to "User selectable". The default setting is 24 hours.
System Switch 04 (SP No. 1-101-005)
NoFunctionComments
0-2Not usedDo not change these settings.
1: Each Quick/Speed dial number on the list is
Printing dedicated txprinted with the dedicated tx parameters (10
parameters on Quick/Speedbytes each).
3Dial ListsThe first 10 bytes of data are the programmed
0: Disableddedicated tx parameters; 34 bytes of data are
1: Enabledprinted (the other 24 bytes have no use for
service technicians).
4-7Not usedDo not change these settings.
System Switch 05 - Not used (Do not change the factory settings.)
System Switch 06 - Not used (Do not change the factory settings.)
System Switch 07 - Not used (Do not change the factory settings.)
System Switch 08 - Not used (Do not change the factory settings.)
System Switch 09 (SP No. 1-101-010)
NoFunctionComments
0
Addition of image data from confidential transmissions on the transmission result report 0: Disabled 1: Enabled
If this feature is enabled, the top half of the first page of confidential messages will be printed on transmission result reports.
Print timing of communication reports on the Journal when no image data was exchanged.
0: After DCS/NSS communication (default), 1: After polling
0: The Journal is printed only when image data is sent.
1: The Journal is printed when any data is sent.
Automatic error report printout 0: Disabled 1: Enabled
0: Error reports will not be printed.
1: Error reports will be printed automatically after failed communications.
Printing of the error code on the error report
0: No 1: Yes
1: Error codes are printed on the error reports. This can be used for detecting an error which occurs rarely.
4Not usedDo not change this setting.
Power failure report 0: Disabled
1: Enabled (default)
1: A power failure report will be automatically printed after the power is switched on if a fax message disappeared from the memory when the power was turned off last.
NOTE: If "0" is selected, no reports are printed and no one may recognize that fax data is gone due to a power failure.
6
Conditions for printing the protocol dump list
0: Print for all communications 1: Print only when there is a communication error
This switch becomes effective only when system switch 00 bit 6 is set to 1.
1: Set this bit to 1 when you wish to print a protocol dump list only for communications with errors.
NOTE: The memory size is limited. Use this bit switch only when some log reports are necessary.
Priority given to various types of
remote terminal ID whenThis bit determines which set of priorities the
printing reportsmachine uses when listing remote terminal
70: RTI > CSI > Dial label > Tel.names on reports.
numberDial Label: The name stored, by the user, for
1: Dial label > Tel. number > RTIthe Quick/Speed Dial number.
> CSI
System Switch 0A (SP No. 1-101-011)
NoFunctionComments
0
Automatic port selection 0: Disabled, 1: Enabled
When "1" is selected, a suitable port is automatically selected if the selected port is not used.
NOTE: This bit is useful if all communication lines at a customer site are not the same quality
1-3Not usedDo not change these settings.
Dialing on the ten-key pad when the external telephone is
off-hook
0: Prevents dialing from the ten-key pad while the external telephone is off-hook. Use this setting when the external telephone is not by the machine, or if a wireless telephone is connected as an external telephone.
1: The user can dial on the machine's ten-key pad when the handset is off-hook.
On hook dial
0: On hook dial is disabled.
6-7Not usedDo not change the factory settings
System Switch 0B - Not used (Do not change the factory settings.)
System Switch 0C - Not used (Do not change the factory settings.)
System Switch 0D - Not used (Do not change the factory settings.)
System Switch 0E (SP No. 1-101-015)
NoFunctionComments
0-1Not usedDo not change the settings.
Enable/disable for direct sending selection
0: Direct sending off 1: Direct sending on
Direct sending cannot operate when the capture function is on during sending. Setting this switch to "1" enables direct sending without capture.
Setting this switch to "0" masks the direct sending function on the operation panel so direct sending with ScanRouter cannot be selected.
Action when the external handset goes off-hook
0: Manual tx and rx operation 1: Memory tx and rx operation (the display remains the same)
0: Manual tx is possible while the external handset is off-hook. However, manual tx during handset off-hook may not be sent to a correct direction. Manual tx is not possible.
1: The display stays in standby mode even when the external handset is used, so that other people can use the machine for memory tx operation. Note that manual tx and rx are not possible with this setting.
System Switch 0F (SP No. 1-101-016)
NoFunctionComments
0
to 7
Country/area code for functional settings (Hex)
This country/area code determines the factory settings of bit switches and RAM addresses. However, it has no effect on the NCU parameter settings and communication parameter RAM addresses.
Cross reference NCU country code:
SP No. 2-103-001 for G3-1 SP No. 2-104-001 for G3-2 SP No. 2-105-001 for G3-3
00: France12: Asia
01: Germany13: Japan
02: UK14: Hong Kong
03: Italy15: South Africa
04: Austria16: Australia
05: Belgium17: New Zealand
06: Denmark18: Singapore
07: Finland19: Malaysia
08: Ireland1A: China
09: Norway1B: Taiwan
0A: Sweden1C: Korea
0B: Switz.1D: Brazil
0C: Portugal20: Turkey
0D: Holland21: Greece
0E: Spain22: Hungary
0F: Israel23: Czech
10: ---24: Poland
11: USA
System Switch 10 (SP No. 1-101-017)
NoFunctionComments
0-7
Threshold memory level for parallel memory transmission
Threshold = N x 128 KB + 256 KB N can be between 00 - FF(H) Default setting: 02(H) = 512 KB
System Switch 11 (SP No. 1-101-018)
NoFunctionComments
0
TTI printing position
0: Superimposed on the page data
1: Printed before the data leading edge
Change this bit to 1 if the TTI overprints information that the customer considers to be important (G3 transmissions).
NOTE: If "1" is selected, it is possible that sent data is printed on two sheets of paper.
1-2Not usedDo not change the factory settings.
TTI used for broadcasting
0: The TTIs selected for each Quick/Speed dial are used
1: The same TTI is used for all destinations
1: The TTI (TTI_1 or TTI_2) which is selected for all destinations during broadcasting.
4-7Not usedDo not change the factory settings.
System Switch 12 (SP No. 1-101-019)
NoFunctionComments
0-7
TTI printing position in the main scan direction
TTI: 08 to 92 (BCD) mm
Input even numbers only.
This setting determines the print start position for the TTI from the left edge of the paper. If the TTI is moved too far to the right, it may overwrite the file number which is on the top right of the page. On an A4 page, if the TTI is moved over by more than 50 mm, it may overwrite the page number.
System Switch 13 - Not used (do not change these settings)
System Switch 14 - Not used (do not change these settings)
System Switch 15 (SP No. 1-101-022)
NoFunctionComments
0Not usedDo not change the settings.
1: The machine will restart from the Energy
Saver mode quickly, because the +5V power
Going into the Energy Saver mode automatically
0: Enabled
1: Disabled
supply is active even in the Energy Saver mode. The LED of the operation switch is flashing instead of entering Energy Saver mode.
Use this setting if an external telephone has to
be used when the machine is in the Energy
Saver mode.
2-3Not usedDo not change these settings.
4-5
Interval for preventing the machine from entering Energy Saver mode if there is a pending transmission file.
If there is a file waiting for transmission, the machine does not go to Energy Saver mode during the selected period.
After transmitting the file, if there is no file waiting for transmission, the machine goes to the Energy Saver mode.
Bit 5Bit 4Setting
001 min
0130 min
101 hour
1124 hours
System Switch 16 (SP No. 1-101-023)
NoFunctionComments
0
Parallel Broadcasting 0: Disabled
1: The machine sends messages simultaneously using all available ports during broadcasting.
NOTE: If a customer wants to keep a line available for fax reception or other reasons, select "0" (Disable).
Priority setting for the G3 line. 0: PSTN-1 > PSTN-2 or 3
1: PSTN-2 or 3 > PSTN-1
This function allows the user to select the default G3 line type. The optional SG3 units are required to use the PSTN-2 or 3 setting.
2-7Not usedDo not change these settings.
System Switch 17 - Not used (do not change these settings)
System Switch 18 - Not used (do not change these settings)
System Switch 19 (SP No. 1-101-026)
NoFunctionComments
0-5Not usedDo not change the settings.
6
Extended scanner page memory after memory option is installed
0: After installing the memory expansion option, the scanner page memory is extended to 4 MB from 2 MB.
1: If this bit is set to 1 after installing the memory expansion option, the scanner page memory is extended to 12 MB. But the SAF memory decreases to 18 MB.
Special Original mode 0: Disabled
1: If the customer frequently wishes to transmit a form or letterhead which has a colored or printed background, change this bit to "1". "Original 1" and "Original 2" can be selected in addition to the "Text", "Text/Photo" and "Photo" modes.
System Switch 1A (SP No. 1-101-027)
NoFunctionComments
Sets the value to x4KB. When the amount of
0
to 7
LS RX memory capacity threshold setting
00-FF (0-1020 Kbyte: Hex)
available memory drops below this setting, RX documents are printed to conserve memory.
Initial setting 0x80 (512 KB)
NOTE: If a customer wants available memory
size to be larger, decrease this threshold
System Switch 1B - Not used (do not change these settings)
System Switch 1C - Not used (do not change these settings)
System Switch 1D (SP No. 1-101-030)
NoFunctionComments
0
RTI/CSI/CPS code display 0: Enable
1: Disable
0: RTI, CSI, CPS codes are displayed on the top line of the LCD panel during communication.
1: Codes are switched off (no display)
1-7Not usedDo not change these settings.
System Switch 1E (SP No. 1-101-031)
NoFunctionComments
0
Communication after the Journal data storage area has become full
0: Impossible
1: Possible
0: When this switch is on and the journal history becomes full, the next report prints. If the journal history is not deleted, the next transmission cannot be received. This prevents overwriting communication records before the machine can print them.
1: If the buffer memory of the communication records for the Journal is full, fax communications are still possible. But the machine will overwrite the oldest communication records.
  • This setting is effective only when Automatic Journal printout is enabled but the machine cannot print the report (e.g., no paper).
Action when the SAF memory has become full during scanning
0: The current page is erased. 1: The entire file is erased.
0: If the SAF memory becomes full during scanning for a memory transmission, the successfully scanned pages are transmitted. 1: If the SAF memory becomes full during scanning for a memory transmission, the file is erased and no pages are transmitted.
RTI/CSI display priority 0: RTI 1: CSI
This bit determines which identifier, RTI or CSI, is displayed on the LCD while the machine is communicating in G3 non-standard mode.
File No. printing 0: Enabled
1: Disabled
1: File numbers are not printed on any reports. NOTE: The file numbers may not be printed in the sequential order. If a customer does not like this numbering, select "0".
0: If the user has stored no acceptable sender
RTIs or CSIs, the user can select “ON” in the
Action when authorizedauthorized reception setting but the setting
reception is enabled butbecomes invalid (“OFF”). The machine will not
authorized RTIs/CSIs are notbe able to receive any fax messages.
4yet programmedIf the customer wishes to receive messages
0: Faxes can be received if thefrom any sender that includes an RTI or CSI,
sender has an RTI or CSIand to block messages from senders that do
1: All fax reception is disablednot include an RTI or CSI, change this bit to
"0", then enable Authorized Reception.
Otherwise, keep this bit at "1 (default setting)".
5-7Not usedDo not change the settings
System Switch 1F (SP No. 1-101-032)
NoFunctionComments
Report printout after an original jam during SAF storage or if the SAF memory fills up
0: Enabled
1: Disabled
0: When an original jams, or the SAF memory overflows during scanning, a report will be printed.
Change this bit to "1" if the customer does not want to have a report in these cases.
Memory tx – Memory storage report
Parallel memory tx – Transmission result report
2Not usedDo not change the settings.
Received fax print start timing (G3 reception)
0: After receiving each page 1: After receiving all pages
0: The machine prints each page immediately after the machine receives it.
1: The machine prints the complete message after the machine receives all the pages in the memory.
4-6Not usedDo not change the factory settings.
Action when a fax SC has occurred
0: Automatic reset 1: Fax unit stops
0: When the fax unit detects a fax SC code other than SC1201 and SC1207, the fax unit automatically resets itself.
1: When the fax unit detects any fax SC code, the fax unit stops.
Cross Reference
Fax SC codes - See "Troubleshooting"
