Ricoh MP4002/5002 service manual Part 17
  1. SYSTEM SP TABLES-8​
    1. SP8-XXX: DATA LOG 2​
      Many of these counters are provided for features that are currently not available, such as sending color faxes, and so on. However, here are some Group 8codes that when used in combination with others, can provide useful information.
      SP NumbersWhat They Do
      SP8211 to SP8216The number of pages scanned to the document server.
      SP8401 to SP8406The number of pages printed from the document server.
      SP8691 to SP8696The number of pages sent from the document server.
      Appendix: Service Program Mode Tables​
      Specifically, the following questions can be answered: How is the document server actually being used?
      What application is using the document server most frequently? What data in the document server is being reused?
      Most of the SPs in this group are prefixed with a letter that indicates the mode of operation (the mode of operation is referred to as an 'application'). Before reading the Group 8 Service Table, make sure that you understand what these prefixes mean.
      PrefixesWhat It Means
      T:
      Total: (Grand Total).
      Grand total of the items counted for all applications (C, F, P, etc.).
      C:Copy application.
      Totals (pages, jobs, etc.) executed for each application when the job was not stored on the document server.
      F:Fax application.
      P:Print application.
      S:Scan application.
      L:
      Local storage (document server)
      Totals (jobs, pages, etc.) for the document server. The L: counters work differently case by case.
      Sometimes, they count jobs/pages stored on the document server; this can be in document server mode (from the document server window), or from another mode, such as from a printer driver or by pressing the Store File button in the Copy mode window. Sometimes, they include occasions when the user uses a file that is already on the document server. Each counter will be discussed case by case.
      O:
      Other applications (external network applications, for example)Refers to network applications such as Web Image Monitor. Utilities developed with the SDK (Software Development Kit) will also be counted with this group in the future.
      The Group 8 SP codes are limited to 17 characters, forced by the necessity of displaying them on the small LCDs of printers and faxes that also use these SPs. Read over the list of abbreviations below and refer to it again if you see the name of an SP that you do not understand.
      Key for Abbreviations​
      AbbreviationWhat It Means
      /"By", e.g. "T:Jobs/Apl" = Total Jobs "by" Application
      >More (2> "2 or more", 4> "4 or more"
      AddBookAddress Book
      AplApplication
      B/WBlack & White
      BkBlack
      CCyan
      ColCrColor Create
      ColModeColor Mode
      CombCombine
      CompCompression
      DelivDelivery
      DesApl
      Designated Application. The application (Copy, Fax, Scan, Print) used to store the job on the document server, for example.
      Dev CounterDevelopment Count, no. of pages developed.
      Dup, DuplexDuplex, printing on both sides
      EmulEmulation
      FCFull Color
      FINPost-print processing, i.e. finishing (punching, stapling, etc.)
      Full BleedNo Margins
      GenCopyGeneration Copy Mode
      GPC
      Get Print Counter. For jobs 10 pages or less, this counter does not count up. For jobs larger than 10 pages, this counter counts up by the number that is in excess of 10 (e.g., for an 11-page job, the counter counts up 11-10 =1)
      IFaxInternet Fax
      ImgEdt
      Image Edit performed on the original with the copier GUI, e.g. border removal, adding stamps, page numbers, etc.
      KBlack (YMCK)
      LSLocal Storage. Refers to the document server.
      LSizeLarge (paper) Size
      MagMagnification
      MCOne color (monochrome)
      NRS
      New Remote Service, which allows a service center to monitor machines remotely. "NRS" is used overseas, "CSS" is used in Japan.
      OrgOriginal for scanning
      OrgJamOriginal Jam
      Palm 2
      Print Job Manager/Desk Top Editor: A pair of utilities that allows print jobs to be distributed evenly among the printers on the network, and allows files to moved around, combined, and converted to different formats.
      PCPersonal Computer
      PGS
      Pages. A page is the total scanned surface of the original. Duplex pages count as two pages, and A3 simplex count as two pages if the A3/DLT counter SP is switched ON.
      PJobPrint Jobs
      PprPaper
      PrtJamPrinter (plotter) Jam
      PrtPGSPrint Pages
      Red (Toner Remaining). Applies to the wide format model A2 only. This machine is under development and currently not available.
      RezResolution
      SCService Code (Error SC code displayed)
      ScnScan
      Sim, SimplexSimplex, printing on 1 side.
      S-to-EmailScan-to-E-mail
      SMC
      SMC report printed with SP5990. All of the Group 8counters are recorded in the SMC report.
      SvrServer
      TonEndToner End
      TonSaveToner Save
      TXJobSend, Transmission
      YMCYellow, Magenta, Cyan
      YMCKYellow, Magenta, Cyan, BlacK
      • All of the Group 8 SPs are reset with SP5 801-1 Memory All Clear.
8001
T:Total Jobs
These SPs count the number of times each application is used to do a job.
[0 to 9999999 / 0 / 1]
Note: The L: counter is the total number of times the other applications are used to send a job to the document server, plus the number of times a file already on the document server is used.
8002C:Total Jobs
8003F:Total Jobs
8004P:Total Jobs
8005S:Total Jobs
8006L:Total Jobs
  • These SPs reveal the number of times an application is used, not the number of pages processed.
  • When an application is opened for image input or output, this counts as one job.
  • Interrupted jobs (paper jams, etc.) are counted, even though they do not finish.
  • Only jobs executed by the customer are counted. Jobs executed by the customer engineer using the SP modes are not counted.
  • When using secure printing (when a password is required to start the print job), the job is counted at the time when either "Delete Data" or "Specify Output" is specified.
  • A job is counted as a fax job when the job is stored for sending.
  • When a fax is received to fax memory, the F: counter increments but the L: counter does not (the document server is not used).
  • A fax broadcast counts as one job for the F: counter (the fax destinations in the broadcast are not counted separately).
  • A fax broadcast is counted only after all the faxes have been sent to their destinations. If one transmission generates an error, then the broadcast will not be counted until the transmission has been completed.
  • A printed fax report counts as one job for the F: counter.
  • The F: counter does not distinguish between fax sending or receiving.
  • When a copy job on the document server is printed, SP8022 also increments, and when a print job stored on the document server is printed, SP8024 also increments.
  • When an original is both copied and stored on the document server, the C: and L: counters both increment.
  • When a print job is stored on the document server, only the L: counter increments.
  • When the user presses the Document Server button to store the job on the document server, only the L: counter increments.
  • When the user enters document server mode and prints data stored on the document server, only the L: counter increments.
  • When an image received from Palm 2 is received and stored, the L: counter increments.
  • When the customer prints a report (user code list, for example), the O: counter increments. However, for fax reports and reports executed from the fax application, the F: counter increments.
    8011T:Jobs/LS
    These SPs count the number of jobs stored to the document server by each application, to reveal how local storage is being used for input.
    The L: counter counts the number of jobs stored from within the document server mode screen at the operation panel.
    8012C:Jobs/LS
    8013F:Jobs/LS
    8014P:Jobs/LS
    8015S:Jobs/LS
    8016L:Jobs/LS
    8017O:Jobs/LS
  • When a scan job is sent to the document server, the S: counter increments. When you enter document server mode and then scan an original, the L: counter increments.
  • When a print job is sent to the document server, the P: counter increments.
  • When a network application sends data to the document server, the O: counter increments.
  • When an image from Palm 2 is stored on the document server, the O: counter increments.
  • When a fax is sent to the document server, the F: counter increments.
    8021T:pjob/LS
    These SPs reveal how files printed from the document server were stored on the document server originally. [0 to 9999999 / 0 / 1]
    8022C:pjob/LS
    8023F:pjob/LS
    8024P:pjob/LS
    8025S:pjob/LS
    8026L:pjob/LS
    8027O:pjob/LS
  • When a copy job stored on the document server is printed with another application, the C: counter increments.
  • When an application like DeskTopBinder merges a copy job that was stored on the document server with a print job that was stored on the document server, the C: and P: counters both increment.
  • When a job already on the document server is printed with another application, the L: counter increments.
  • When a scanner job stored on the document server is printed with another application, the S: counter increments. If the original was scanned from within document server mode, then the L: counter increments.
  • When images stored on the document server by a network application (including Palm 2), are printed with another application, the O: counter increments.
  • When a copy job stored on the document server is printed with a network application (Web Image Monitor, for example), the C: counter increments.
  • When a fax on the document server is printed, the F: counter increments.
    8031T:pjob/DesApl
    These SPs reveal what applications were used to output documents from the document server.
    The L: counter counts the number of jobs printed from within the document server mode screen at the operation panel.
    8032C:pjob/DesApl
    8033F:pjob/DesApl
    8034P:pjob/DesApl
    8035S:pjob/DesApl
    8036L:pjob/DesApl
    8037O:pjob/DesApl
  • When documents already stored on the document server are printed, the count for the application that started the print job is incremented.
  • When the print job is started from a network application (Desk Top Binder, Web Image Monitor, etc.) the L: counter increments.
    8041T:TX Jobs/LS
    These SPs count the applications that stored files on the document server that were later accessed for transmission over the telephone line or over a network (attached to an e-mail, or as a fax image by I-Fax).
    Note: Jobs merged for sending are counted separately. The L: counter counts the number of jobs scanned from within the document server mode screen at the operation panel.
    8042C:TX Jobs/LS
    8043F:TX Jobs/LS
    8044P:TX Jobs/LS
    8045S:TX Jobs/LS
    8046L:TX Jobs/LS
    8047O:TX Jobs/LS
  • When a stored copy job is sent from the document server, the C: counter increments.
  • When images stored on the document server by a network application or Palm2 are sent as an e-mail, the O: counter increments.
    8051T:TX Jobs/DesApl
    These SPs count the applications used to send files from the document server over the telephone line or over a network (attached to an e-mail, or as a fax image by I-Fax). Jobs merged for sending are counted separately.
    The L: counter counts the number of jobs sent from within the document server mode screen at the operation panel.
    8052C:TX Jobs/DesApl
    8053F:TX Jobs/DesApl
    8054P:TX Jobs/DesApl
    8055S:TX Jobs/DesApl
    8056L:TX Jobs/DesApl
    8057O:TX Jobs/DesApl
  • If the send is started from Desk Top Binder or Web Image Monitor, for example, then the O: counter increments.
    8061
    T:FIN Jobs[0 to 9999999 / 0 / 1]
    These SPs total the finishing methods. The finishing method is specified by the application.
    8062
    C:FIN Jobs[0 to 9999999 / 0 / 1]
    These SPs total finishing methods for copy jobs only. The finishing method is specified by the application.
    8063
    F:FIN Jobs[0 to 9999999 / 0 / 1]
    These SPs total finishing methods for fax jobs only. The finishing method is specified by the application.
    Note: Finishing features for fax jobs are not available at this time.
    8064
    P:FIN Jobs[0 to 9999999 / 0 / 1]
    These SPs total finishing methods for print jobs only. The finishing method is specified by the application.
    8065
    S:FIN Jobs[0 to 9999999 / 0 / 1]
    These SPs total finishing methods for scan jobs only. The finishing method is specified by the application.
    Note: Finishing features for scan jobs are not available at this time.
    8066
    L:FIN Jobs[0 to 9999999 / 0 / 1]
    These SPs total finishing methods for jobs output from within the document server mode screen at the operation panel. The finishing method is specified from the print window within document server mode.
    8067
    O:FIN Jobs[0 to 9999999 / 0 / 1]
    These SPs total finishing methods for jobs executed by an external application, over the network. The finishing method is specified by the application.
    806x 1
    Sort
    Number of jobs started in Sort mode. When a stored copy job is set for Sort and then stored on the document server, the L: counter increments. (See SP8066 1)
    806x 2StackNumber of jobs started out of Sort mode.
    806x 3StapleNumber of jobs started in Staple mode.
    806x 4
    Booklet
    Number of jobs started in Booklet mode. If the machine is in staple mode, the Staple counter also increments.
    806x 5
    Z-Fold
    Number of jobs started In any mode other than the Booklet mode and set for folding (Z-fold).
    806x 6
    Punch
    Number of jobs started in Punch mode. When Punch is set for a print job, the P: counter increments. (See SP8064 6.)
    806x 7OtherReserved. Not used
    806x 8
    Inside-Fold
    Number of jobs started In any mode other than the Booklet mode and set for folding (Inside-fold).
    806x 9Three-IN-FoldLetter Fold-in Not Used
    806x 10Three-OUT-FoldLetter Fold-out Not Used
    806x 11Four-FoldDouble Parallel Fold Not Used
    806x 12KANNON-FoldGate Fold Not Used
    806x 13Perfect-BindPerfect Binder Not Used
    806x 14Ring-BindRing Binder Not Used
    8071
    T:Jobs/PGS[0 to 9999999 / 0 / 1]
    These SPs count the number of jobs broken down by the number of pages in the job, regardless of which application was used.
    8072
    C:Jobs/PGS[0 to 9999999 / 0 / 1]
    These SPs count and calculate the number of copy jobs by size based on the number of pages in the job.
    8073
    F:Jobs/PGS[0 to 9999999 / 0 / 1]
    These SPs count and calculate the number of fax jobs by size based on the number of pages in the job.
    8074
    P:Jobs/PGS[0 to 9999999 / 0 / 1]
    These SPs count and calculate the number of print jobs by size based on the number of pages in the job.
    8075
    S:Jobs/PGS[0 to 9999999 / 0 / 1]
    These SPs count and calculate the number of scan jobs by size based on the number of pages in the job.
    8076
    L:Jobs/PGS[0 to 9999999 / 0 / 1]
    These SPs count and calculate the number of jobs printed from within the document server mode window at the operation panel, by the number of pages in the job.
    8077
    O:Jobs/PGS[0 to 9999999 / 0 / 1]
    These SPs count and calculate the number of "Other" application jobs (Web Image Monitor, Palm 2, etc.) by size based on the number of pages in the job.
    807x 11 Page807x 821 to 50 Pages
    807x 22 Pages807x 951 to 100 Pages
    807x 33 Pages807x 10101 to 300 Pages
    807x 44 Pages807x 11301 to 500 Pages
    807x 55 Pages807x 12501 to 700 Pages
    807x 66 to 10 Pages807x 13701 to 1000 Pages
    807x 711 to 20 Pages807x 141001 to Pages
  • For example: When a copy job stored on the document server is printed in document server mode, the appropriate L: counter (SP8076 0xx) increments.
  • Printing a fax report counts as a job and increments the F: counter (SP 8073).
  • Interrupted jobs (paper jam, etc.) are counted, even though they do not finish.
  • If a job is paused and re-started, it counts as one job.
  • If the finisher runs out of staples during a print and staple job, then the job is counted at the time the error occurs.
  • For copy jobs (SP 8072) and scan jobs (SP 8075), the total is calculated by multiplying the number of sets of copies by the number of pages scanned. (One duplex page counts as 2.)
  • The first test print and subsequent test prints to adjust settings are added to the number of pages of the copy job (SP 8072).
  • When printing the first page of a job from within the document server screen, the page is counted.
    8111
    T:FAX TX Jobs[0 to 9999999 / 0 / 1]
    These SPs count the total number of jobs (color or black-and-white) sent by fax, either directly or using a file stored on the document server, on a telephone line.
    Note: Color fax sending is not available at this time.
    001B/WBlack TX
    8113
    F:FAX TX Jobs[0 to 9999999 / 0 / 1]
    These SPs count the total number of jobs (color or black-and-white) sent by fax directly on a telephone line.
    001B/WBlack TX
  • These counters count jobs, not pages.
  • This SP counts fax jobs sent over a telephone line with a fax application, including documents stored on the document server.
  • If the mode is changed during the job, the job will count with the mode set when the job started.
  • If the same document is faxed to both a public fax line and an I-Fax at a destination where both are available, then this counter increments, and the I-Fax counter (812x) also increments.
  • The fax job is counted when the job is scanned for sending, not when the job is sent.
    8121
    T:IFAX TX Jobs[0 to 9999999 / 0 / 1]
    These SPs count the total number of jobs (color or black-and-white) sent, either directly or using a file stored on the document server, as fax images using I-Fax.
    001B/WBlack TX
    8123
    F:IFAX TX Jobs[0 to 9999999 / 0 / 1]
    These SPs count the number of jobs (color or black-and-white) sent (not stored on the document server), as fax images using I-Fax.
    001B/WBlack TX
  • The counters for color are provided for future use; the color fax feature is not available at this time.
    8131
    T:S-to-Email Jobs[0 to 9999999 / 0 / 1]
    These SPs count the total number of jobs scanned and attached to an e-mail, regardless of whether the document server was used or not.
    001B/WBlack TX
    002ColorColor TX
    003ACSColor TX
    8135
    S:S-to-Email Jobs
    These SPs count the number of jobs scanned and attached to an e-mail, without storing the original on the document server.
    001B/WBlack TX
    002ColorColor TX
    003ACSColor TX
  • If the job is stored on the document server, after the job is stored it is determined to be color or black-and-white then counted.
  • If the job is cancelled during scanning, or if the job is cancelled while the document is waiting to be sent, the job is not counted.
  • If the job is cancelled during sending, it may or may not be counted, depending on what stage of the process had been reached when the job was cancelled.
  • If several jobs are combined for sending to the Scan Router, Scan-to-Email, or Scan-to-PC, or if one job is sent to more than one destination. each send is counted separately. For example, if the same document is sent by Scan-to-Email as well as Scan-to-PC, then it is counted twice (once for Scan-to-Email and once for Scan-to-PC).
    8141
    T:Deliv Jobs/Svr[0 to 9999999 / 0 / 1]
    These SPs count the total number of jobs scanned and sent to a Scan Router server.
    001B/WBlack Deliv
    002ColorColor Deliv
    003ACSColor Deliv
    8145
    S:Deliv Jobs/Svr
    These SPs count the number of jobs scanned and sent to a Scan Router server.
    001B/WBlack Deliv
    002ColorColor Deliv
    003ACSColor Deliv
  • The jobs are counted even though the arrival and reception of the jobs at the Scan Router server cannot be confirmed.
  • If even one color image is mixed with black-and-white images, then the job is counted as a "Color" job.
  • If the job is cancelled during scanning, or if the job is cancelled while the document is waiting to be delivered, the job is not counted.
  • Even if several files are combined for sending, the transmission counts as one job.
    8151
    T:Deliv Jobs/PC[0 to 9999999 / 0 / 1]
    These SPs count the total number of jobs scanned and sent to a folder on a PC (Scan-to-PC).
    Note: At the present time, 8151 and 8155 perform identical counts.
    001B/WBlack Deliv
    002ColorColor Deliv
    003ACSColor Deliv
    8155
    S:Deliv Jobs/PC
    These SPs count the total number of jobs scanned and sent with Scan-to-PC.
    001B/WBlack Deliv
    002ColorColor Deliv
    003ACSColor Deliv
  • If the job is cancelled during scanning, it is not counted.
  • If the job is cancelled while it is waiting to be sent, the job is not counted.
    8161T:pCFAX TX JobsThese SPs count the number of PC Fax transmission jobs. A job is counted from when it is registered for sending, not when it is sent.
    Note: At the present time, these counters perform identical counts.
    8163
    F:pCFAX TX Jobs
  • This counts fax jobs started from a PC using a PC fax application, and sending the data out to the destination from the PC through the copier.
    8171T:Deliv Jobs/WSD
    These SPs count the pages scanned by WSD. [0 to 9999999 / 0 / 1]
    8175S:Deliv Jobs/WSD
    001B/WBlack Deliv
    002ColorColor Deliv
    003ACSColor Deliv
    8181T:Scan to Media JobsThese SPs count the pages scanned to media by the scanner application.
    8185
    S:Scan to Media Jobs
    001B/WBlack Deliv
    002ColorColor Deliv
    003ACSColor Deliv
    8191T:Total Scan PGS
    These SPs count the pages scanned by each application that uses the scanner to scan images. [0 to 9999999 / 0 / 1]
    8192C:Total Scan PGS
    8193F:Total Scan PGS
    8195S:Total Scan PGS
    8196L:Total Scan PGS
  • SP 8191 to 8196 count the number of scanned sides of pages, not the number of physical pages.
  • These counters do not count reading user stamp data, or reading color charts to adjust color.
  • Previews done with a scanner driver are not counted.
  • A count is done only after all images of a job have been scanned.
  • Scans made in SP mode are not counted.
    Examples​
  • If 3 B5 pages and 1 A3 page are scanned with the scanner application but not stored, the S: count is 4.
  • If both sides of 3 A4 sheets are copied and stored to the document server using the Store
    File button in the Copy mode window, the C: count is 6 and the L: count is 6.
  • If both sides of 3 A4 sheets are copied but not stored, the C: count is 6.
  • If you enter document server mode then scan 6 pages, the L: count is 6.
    8201T:LSize Scan PGS[0 to 9999999 / 0 / 1]
    8203F Lsize Scan PGS[0 to 9999999 / 0 / 1]
    8205
    S:LSize Scan PGS[0 to 9999999 / 0 / 1]
    These SP codes count the total number of large pages input with the scanner for scan jobs only. Large size paper (A3/DLT) scanned for fax transmission are not counted.
    Note: These counters are displayed in the SMC Report, and in the User Tools display..
    8211T:Scan PGS/LSThese SPs count the number of pages scanned into the document server .
    The L: counter counts the number of pages stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen
    8212C:Scan PGS/LS
    8213F:Scan PGS/LS
    8215S:Scan PGS/LS
    8216L:Scan PGS/LS
  • Reading user stamp data is not counted.
  • If a job is cancelled, the pages output as far as the cancellation are counted.
  • If the scanner application scans and stores 3 B5 sheets and 1 A4 sheet, the S: count is 4.
  • If pages are copied but not stored on the document server, these counters do not change.
  • If both sides of 3 A4 sheets are copied and stored to the document server, the C: count is 6 and the L: count is 6.
    8221
    ADF Org Feeds[0 to 9999999 / 0 / 1]
    These SPs count the number of pages fed through the ADF for front and back side scanning.
    Front
    Number of front sides fed for scanning:
    With an ADF that can scan both sides simultaneously, the Front side count is the same as the number of pages fed for either simplex or duplex scanning.
    With an ADF that cannot scan both sides simultaneously, the Front side count is the same as the number of pages fed for duplex front side scanning. (The front side is determined by which side the user loads face up.)
    Back
    Number of rear sides fed for scanning:
    With an ADF that can scan both sides simultaneously, the Back count is the same as the number of pages fed for duplex scanning.
    With an ADF that cannot scan both sides simultaneously, the Back count is the same as the number of pages fed for duplex rear-side scanning.
  • When 1 sheet is fed for duplex scanning the Front count is 1 and the Back count is 1.
  • If a jam occurs during the job, recovery processing is not counted to avoid double counting. Also, the pages are not counted if the jam occurs before the first sheet is output.
    8231
    Scan PGS/Mode[0 to 9999999 / 0 / 1]
    These SPs count the number of pages scanned by each ADF mode to determine the work load on the ADF.
    Large Volume
    Selectable. Large copy jobs that cannot be loaded in the ADF at one time.
    SADF
    Selectable. Feeding pages one by one through the ADF.
    Mixed Size
    Selectable. Select "Mixed Sizes" on the operation panel.
    004Custom SizeSelectable. Originals of non-standard size.
    Platen
    Book mode. Raising the ADF and placing the original directly on the platen.
    Mixed 1side/2side
    Selectable. Select "Simplex/Duplex" on the operation panel.
  • If the scan mode is changed during the job, for example, if the user switches from ADF to Platen mode, the count is done for the last selected mode.
  • The user cannot select mixed sizes or non-standard sizes with the fax application so if the original's page sizes are mixed or non-standard, these are not counted.
  • If the user selects "Mixed Sizes" for copying in the platen mode, the Mixed Size count is enabled.
  • In the SADF mode if the user copies 1 page in platen mode and then copies 2 pages with SADF, the Platen count is 1 and the SADF count is 3.
    8241
    T:Scan PGS/Org[0 to 9999999 / 0 / 1]
    These SPs count the total number of scanned pages by original type for all jobs, regardless of which application was used.
    8242
    C:Scan PGS/Org[0 to 9999999 / 0 / 1]
    These SPs count the number of pages scanned by original type for Copy jobs.
    8243
    F:Scan PGS/Org[0 to 9999999 / 0 / 1]
    These SPs count the number of pages scanned by original type for Fax jobs.
    8245
    S:Scan PGS/Org[0 to 9999999 / 0 / 1]
    These SPs count the number of pages scanned by original type for Scan jobs.
    8246
    L:Scan PGS/Org[0 to 9999999 / 0 / 1]
    These SPs count the number of pages scanned and stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen
    82418242824382458246
    824x 1: TextYesYesYesYesYes
    824x 2: Text/PhotoYesYesYesYesYes
    824x 3: PhotoYesYesYesYesYes
    824x 4: GenCopy, PaleYesYesNoYesYes
    824x 5: MapYesYesNoNoYes
    824x 6: Normal/DetailYesNoYesNoNo
    824x 7: Fine/Super FineYesNoYesNoNo
    824x 8: BinaryYesNoNoYesNo
    824x 9: GrayscaleYesNoNoYesNo
    824x 10: ColorYesNoNoYesNo
    824x 11: OtherYesYesYesYesYes
    8251T:Scan PGS/ImgEdtThese SPs show how many times Image Edit
    features have been selected at the operation panel
    8252C:Scan PGS/ImgEdt
    for each application. Some examples of these
    8255S:Scan PGS/ImgEdtediting features are:
    Erase> Border
    8256L:Scan PGS/ImgEdt
    Erase> Center
    8257
    O:Scan PGS/ImgEdt
    Image Repeat
    Centering
    Positive/Negative
    Note: The count totals the number of times the edit
    features have been used. A detailed breakdown of
    exactly which features have been used is not given.
    The L: counter counts the number of pages stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen.
    8281T:Scan PGS/TWAINThese SPs count the number of pages scanned using a TWAIN driver. These counters reveal how the TWAIN driver is used for delivery functions.
    8285
    S:Scan PGS/TWAIN
    8291T:Scan PGS/StampThese SPs count the number of pages stamped with the stamp in the ADF unit.
    8293F:Scan PGS/Stamp
    8295
    S:Scan PGS/Stamp
    8301
    T:Scan PGS/Size[0 to 9999999 / 0 / 1]
    These SPs count by size the total number of pages scanned by all applications. Use these totals to compare original page size (scanning) and output (printing) page size [SP 8-441].
    8302
    C:Scan PGS/Size[0 to 9999999 / 0 / 1]
    These SPs count by size the total number of pages scanned by the Copy application. Use these totals to compare original page size (scanning) and output (printing) page size [SP 8-442].
    8303
    F:Scan PGS/Size[0 to 9999999 / 0 / 1]
    These SPs count by size the total number of pages scanned by the Fax application. Use these totals to compare original page size (scanning) and output page size [SP 8-443].
    8305
    S:Scan PGS/Size[0 to 9999999 / 0 / 1]
    These SPs count by size the total number of pages scanned by the Scan application. Use these totals to compare original page size (scanning) and output page size [SP 8-445].
    8306
    L:Scan PGS/Size[0 to 9999999 / 0 / 1]
    These SPs count by size the total number of pages scanned and stored from within the document server mode screen at the operation panel, and with the Store File button from within the Copy mode screen. Use these totals to compare original page size (scanning) and output page size [SP 8-446].
    830x 1A3
    830x 2A4
    830x 3A5
    830x 4B4
    830x 5B5
    830x 6DLT
    830x 7LG
    830x 8LT
    830x 9HLT
    830x 10Full Bleed
    830x 254Other (Standard)
    830x 255Other (Custom)
    8311
    T:Scan PGS/Rez[0 to 9999999 / 0 / 1]
    These SPs count by resolution setting the total number of pages scanned by applications that can specify resolution settings.
    8315
    S:Scan PGS/Rez[0 to 9999999 / 0 / 1]
    Note: At the present time, 8311 and 8315 perform identical counts.
    831x 11200dpi to
    831x 2600dpito1199dpi
    831x 3400dpito599dpi
    831x 4200dpito399dpi
    831x 5to199dpi
  • Copy resolution settings are fixed so they are not counted.
  • The Fax application does not allow finely-adjusted resolution settings so no count is done for the Fax application.
    8381T:Total PrtPGS
    These SPs count the number of pages printed by the customer. The counter for the application used for storing the pages increments.
    The L: counter counts the number of pages stored from within the document server mode screen at the operation panel. Pages stored with the Store File button from within the Copy mode screen go to the C: counter.
    8382C:Total PrtPGS
    8383F:Total PrtPGS
    8384P:Total PrtPGS
    8385S:Total PrtPGS
    8386L:Total PrtPGS
    8387O:Total PrtPGS
  • When the A3/DLT double count function is switched on with SP5104, 1 A3/DLT page is counted as 2.
  • When several documents are merged for a print job, the number of pages stored are counted for the application that stored them.
  • These counters are used primarily to calculate charges on use of the machine, so the following pages are not counted as printed pages:
    Blank pages in a duplex printing job.
    Blank pages inserted as document covers, chapter title sheets, and slip sheets. Reports printed to confirm counts.
    All reports done in the service mode (service summaries, engine maintenance reports, etc.) Test prints for machine image adjustment.
    Error notification reports.
    Partially printed pages as the result of a copier jam.
    8391
    LSize PrtPGS[0 to 9999999 / 0 / 1]
    These SPs count pages printed on paper sizes A3/DLT and larger.
    Note: In addition to being displayed in the SMC Report, these counters are also displayed in the User Tools display on the copy machine.
    8401T:prtPGS/LS
    These SPs count the number of pages printed from the document server. The counter for the application used to print the pages is incremented.
    8402C:prtPGS/LS
    8403F:prtPGS/LS
    8404P:prtPGS/LS
    8405S:prtPGS/LS
    8406L:prtPGS/LS
  • Print jobs done with Web Image Monitor and Desk Top Binder are added to the L: count.
  • Fax jobs done with Web Image Monitor and Desk Top Binder are added to the F: count.
    8411
    Prints/Duplex
    This SP counts the amount of paper (front/back counted as 1 page) used for duplex printing. Last pages printed only on one side are not counted.
    8421
    T:prtPGS/Dup Comb[0 to 9999999 / 0 / 1]
    These SPs count by binding and combine, and n-Up settings the number of pages processed for printing. This is the total for all applications.
    8422
    C:prtPGS/Dup Comb[0 to 9999999 / 0 / 1]
    These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by the copier application.
    8423
    F:prtPGS/Dup Comb[0 to 9999999 / 0 / 1]
    These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by the fax application.
    8424
    P:prtPGS/Dup Comb[0 to 9999999 / 0 / 1]
    These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by the printer application.
    8425
    S:prtPGS/Dup Comb[0 to 9999999 / 0 / 1]
    These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by the scanner application.
    8426
    L:prtPGS/Dup Comb[0 to 9999999 / 0 / 1]
    These SPs count by binding and combine, and n-Up settings the number of pages processed for printing from within the document server mode window at the operation panel.
    8427
    O:prtPGS/Dup Comb[0 to 9999999 / 0 / 1]
    These SPs count by binding and combine, and n-Up settings the number of pages processed for printing by Other applications
    842x 1Simplex> Duplex
    842x 2Duplex> Duplex
    842x 3Book> Duplex
    842x 4Simplex Combine
    842x 5Duplex Combine
    842x 62in12 pages on 1 side (2-Up)
    842x 74in14 pages on 1 side (4-Up)
    842x 86in16 pages on 1 side (6-Up)
    842x 98in18pages on 1 side (8-Up)
    842x 109in19 pages on 1 side (9-Up)
    842x 1116in116 pages on 1 side (16-Up)
    842x 12Booklet
    842x 13Magazine
    842x 142in1 + Booklet
    842x 154in1 + Booklet
    842x 166in1 + Booklet
    842x 178in1 + Booklet
    842x 189in1 + Booklet
    842x 192in1 + Magazine
    842x 204in1 + Magazine
    842x 216in1 + Magazine
    842x 228in1 + Magazine
    842x 239in1 + Magazine
    842x 2416in1 + Magazine
  • These counts (SP8421 to SP8427) are especially useful for customers who need to improve their compliance with ISO standards for the reduction of paper consumption.
  • Pages that are only partially printed with the n-Up functions are counted as 1 page.
  • Here is a summary of how the counters work for Booklet and Magazine modes:
    BookletMagazine
    Original PagesCountOriginal PagesCount
    1111
    2222
    3232
    4242
    5354
    6464
    7474
    8484
    8431
    T:prtPGS/ImgEdt[0 to 9999999 / 0 / 1]
    These SPs count the total number of pages output with the three features below, regardless of which application was used.
    8432
    C:prtPGS/ImgEdt[0 to 9999999 / 0 / 1]
    These SPs count the total number of pages output with the three features below with the copy application.
    8434
    P:prtPGS/ImgEdt[0 to 9999999 / 0 / 1]
    These SPs count the total number of pages output with the three features below with the print application.
    8436
    L:prtPGS/ImgEdt[0 to 9999999 / 0 / 1]
    These SPs count the total number of pages output from within the document server mode window at the operation panel with the three features below.
    8437
    O:prtPGS/ImgEdt[0 to 9999999 / 0 / 1]
    These SPs count the total number of pages output with the three features below with Other applications.
    843x 1
    Cover/Slip Sheet
    Total number of covers or slip sheets inserted. The count for a cover printed on both sides counts 2.
    843x 2
    Series/Book
    The number of pages printed in series (one side) or printed as a book with booklet right/left pagination.
    843x 3
    User Stamp
    The number of pages printed where stamps were applied, including page numbering and date stamping.
    8441
    T:prtPGS/Ppr Size[0 to 9999999 / 0 / 1]
    These SPs count by print paper size the number of pages printed by all applications.
    8442
    C:prtPGS/Ppr Size[0 to 9999999 / 0 / 1]
    These SPs count by print paper size the number of pages printed by the copy application.
    8443
    F:prtPGS/Ppr Size[0 to 9999999 / 0 / 1]
    These SPs count by print paper size the number of pages printed by the fax application.
    8444
    P:prtPGS/Ppr Size[0 to 9999999 / 0 / 1]
    These SPs count by print paper size the number of pages printed by the printer application.
    8445
    S:prtPGS/Ppr Size[0 to 9999999 / 0 / 1]
    These SPs count by print paper size the number of pages printed by the scanner application.
    8446
    L:prtPGS/Ppr Size[0 to 9999999 / 0 / 1]
    These SPs count by print paper size the number of pages printed from within the document server mode window at the operation panel.
    8447
    O:prtPGS/Ppr Size[0 to 9999999 / 0 / 1]
    These SPs count by print paper size the number of pages printed by Other applications.
    844x 1A3
    844x 2A4
    844x 3A5
    844x 4B4
    844x 5B5
    844x 6DLT
    844x 7LG
    844x 8LT
    844x 9HLT
    844x 10Full Bleed
    844x 254Other (Standard)
    844x 255Other (Custom)
  • These counters do not distinguish between LEF and SEF.
    8451
    PrtPGS/Ppr Tray[0 to 9999999 / 0 / 1]
    These SPs count the number of sheets fed from each paper feed station.
    001Bypass TrayBypass Tray
    002Tray 1Copier
    003Tray 2Copier
    004Tray 3Paper Tray Unit (Option)
    005Tray 4Paper Tray Unit (Option)
    006Tray 5LCT (Option)
    007Tray 6Currently not used.
    008Tray 7Currently not used.
    009Tray 8Currently not used.
    010Tray 9Currently not used.
    011Tray 10Currently not used.
    012Tray 11Currently not used.
    013Tray 12Currently not used.
    014Tray 13Currently not used.
    015Tray 14Currently not used.
    016Tray 15Currently not used.
    8461
    T:prtPGS/Ppr Type[0 to 9999999 / 0 / 1]
    These SPs count by paper type the number pages printed by all applications.
    These counters are not the same as the PM counter. The PM counter is based on feed timing to accurately measure the service life of the feed rollers. However, these counts are based on output timing.
    Blank sheets (covers, chapter covers, slip sheets) are also counted. During duplex printing, pages printed on both sides count as 1, and a page printed on one side counts as 1.
    8462
    C:prtPGS/Ppr Type[0 to 9999999 / 0 / 1]
    These SPs count by paper type the number pages printed by the copy application.
    8463
    F:prtPGS/Ppr Type[0 to 9999999 / 0 / 1]
    These SPs count by paper type the number pages printed by the fax application.
    8464
    P:prtPGS/Ppr Type[0 to 9999999 / 0 / 1]
    These SPs count by paper type the number pages printed by the printer application.
    8466
    L:prtPGS/Ppr Type[0 to 9999999 / 0 / 1]
    These SPs count by paper type the number pages printed from within the document server mode window at the operation panel.
    846x 1Normal
    846x 2Recycled
    846x 3Special
    846x 4Thick
    846x 5Normal (Back)
    846x 6Thick (Back)
    846x 7OHP
    846x 8Other
    8471
    PrtPGS/Mag[0 to 9999999 / 0 / 1]
    These SPs count by magnification rate the number of pages printed.
    001to 49%
    00250% to 99%
    003100%
    004101% to 200%
    005201% to
  • Counts are done for magnification adjusted for pages, not only on the operation panel but performed remotely with an external network application capable of performing magnification adjustment as well.
  • Magnification adjustments done with printer drivers with PC applications such as Excel are also counted.
  • Magnification adjustments done for adjustments after they have been stored on the document server are not counted.
  • Magnification adjustments performed automatically during Auto Reduce/Enlarge copying are counted.
  • The magnification rates of blank cover sheets, slip sheets, etc. are automatically assigned a rate of 100%.
    8481T:prtPGS/TonSave
    8484P:prtPGS/TonSave
    These SPs count the number of pages printed with the Toner Save feature switched on.
    Note: These SPs return the same results as this SP is limited to the Print application.
    8511
    T:prtPGS/Emul[0 to 9999999 / 0 / 1]
    These SPs count by printer emulation mode the total number of pages printed.
    8514
    P:prtPGS/Emul[0 to 9999999 / 0 / 1]
    001RPCS
    002RPDLJapan Only
    003PS3
    004R98
    Japan Only
    005R16
    006GL/GL2
    007R55
    008RTIFF
    009PDF
    010PCL5e/5c
    011PCL XL
    012IPDL-C
    013BM-LinksJapan Only
    014Other
    015IPDS
  • SP8511 and SP8514 return the same results as they are both limited to the Print application.
  • Print jobs output to the document server are not counted.
    8521
    T:prtPGS/FIN[0 to 9999999 / 0 / 1]
    These SPs count by finishing mode the total number of pages printed by all applications.
    8522
    C:prtPGS/FIN[0 to 9999999 / 0 / 1]
    These SPs count by finishing mode the total number of pages printed by the Copy application.
    8523
    F:prtPGS/FIN[0 to 9999999 / 0 / 1]
    These SPs count by finishing mode the total number of pages printed by the Fax application.
    Note:
    Print finishing options for received faxes are currently not available.
    8524
    P:prtPGS/FIN[0 to 9999999 / 0 / 1]
    These SPs count by finishing mode the total number of pages printed by the Print application.
    8525
    S:prtPGS/FIN[0 to 9999999 / 0 / 1]
    These SPs count by finishing mode the total number of pages printed by the Scanner application.
    8526
    L:prtPGS/FIN[0 to 9999999 / 0 / 1]
    These SPs count by finishing mode the total number of pages printed from within the document server mode window at the operation panel.
    852x 1Sort
    852x 2Stack
    852x 3Staple
    852x 4Booklet
    852x 5Z-Fold
    852x 6Punch
    852x 7Other
    852x 8Inside-Fold
    852x 9Three-IN-Fold
    852x 10Three-OUT-Fold
    852x 11Four-Fold
    852x 12KANNON-Fold
    852x 13Perfect-Bind
    852x 14Ring-Bind
    • If stapling is selected for finishing and the stack is too large for stapling, the unstapled pages are still counted.
    • The counts for staple finishing are based on output to the staple tray, so jam recoveries are counted.
      8531
      Staples
      This SP counts the amount of staples used by the machine.
      8551T:prtBooks/FIN
      8552C:prtBooks/FIN
      8554P:prtBooks/FIN
      8556L:prtBooks/FIN
      001Perfect-BindNot Used
      002Ring-BindNot Used
      8561T:A Sheet Of Paper[0 to 9999999 / 0 / 1]
      8562C:A Sheet Of Paper[0 to 9999999 / 0 / 1]
      8563F:A Sheet Of Paper[0 to 9999999 / 0 / 1]
      8564P:A Sheet Of Paper[0 to 9999999 / 0 / 1]
      8566L:A Sheet Of Paper[0 to 9999999 / 0 / 1]
      8567
      O:A Sheet Of Paper[0 to 9999999 / 0 / 1]
      These SPs count the totals number of duplex pages printed.
      001Total: Over A3/DLT
      002Total: Under A3/DLT
      003Duplex: Over A3/DLT
      004Duplex: Under A3/DLT
      8581
      T: Counter[0 to 9999999 / 0 / 1]
      These SPs count the total output broken down by color output, regardless of the application used. In addition to being displayed in the SMC Report, these counters are also displayed in the User Tools display on the copy machine.
      Note: This SP is expanded for color MFP and color LP machines. For this machine, the count is done for black only.
      8591
      O: Counter[0 to 9999999 / 0 / 1]
      These SPs count the totals for A3/DLT paper use, number of duplex pages printed, and the number of staples used. These totals are for Other (O:) applications only.
      001A3/DLT
      002Duplex
      8601
      T:Coverage Counter
      These SPs count the total coverage for each color and printout pages.
      001B/W[0 to 2147483647 / 0 / 1]
      011B/W Printing Pages[0 to 9999999 / 0 / 1]
      8602
      C:Coverage Counter[0 to 2147483647 / 0 / 1]
      These SPs count the total coverage for B/W.
      8603
      F:Coverage Counter[0 to 2147483647 / 0 / 1]
      8604
      P:Coverage Counter[0 to 2147483647 / 0 / 1]
      8606
      L:Coverage Counter[0 to 2147483647 / 0 / 1]
      8617
      SDK Apli Counter[0 to 9999999 / 0 / 1]
      These SPs count the total printout pages for each SDK applicaion.
      001SDK-1
      002SDK-2
      003SDK-3
      004SDK-4
      005SDK-5
      006SDK-6
      8621Func Use Counter-
      001 to 064Function-001 to Function-064
      8631
      T:FAX TX PGS[0 to 9999999 / 0 / 1]
      These SPs count by color mode the number of pages sent by fax to a telephone number.
      001B/WBlack TX
      8633
      F:FAX TX PGS[0 to 999999 / 0 / 1]
      001B/WBlack TX
  • If a document has color and black-and-white pages mixed, the pages are counted separately as B/W or Color.
  • At the present time, this feature is provided for the Fax application only so SP8631 and SP8633 are the same.
  • The counts include error pages.
  • If a document is sent to more than one destination with a Group transmission, the count is done for each destination.
  • Polling transmissions are counted but polling RX are not.
  • Relay, memory, and confidential mailbox transmissions and are counted for each destination.
    8641
    These SPs count by color mode the number of pages sent by fax to as fax images using I-Fax.
    001B/WBlack TX
    8643
    F:FAX TX PGS[0 o 9999999 / 0 / 1]
    These SPs count by color mode the number of pages sent by Fax as fax images using I-Fax.
    001B/WBlack TX
  • At the present time, this feature is provided for the Fax application only so SP8641 and SP8643 are the same.
    8651
    T:S-to-Email PGS[0 to 9999999 / 0 / 1]
    These SPs count by color mode the total number of pages attached to an e-mail for both the Scan and document server applications.
    001B/W
    002Color
    8655
    S:S-to-Email PGS[0 to 9999999 / 0 / 1]
    These SPs count by color mode the total number of pages attached to an e-mail for the Scan application only.
    001B/W
    002Color
    • The count for B/W and Color pages is done after the document is stored on the HDD. If the job is cancelled before it is stored, the pages are not counted.
    • If Scan-to-Email is used to send a 10-page document to 5 addresses, the count is 10 (the pages are sent to the same SMTP server together).
    • If Scan-to-PC is used to send a 10-page document to 5 folders, the count is 50 (the document is sent to each destination of the SMB/FTP server).
    • Due to restrictions on some devices, if Scan-to-Email is used to send a 10-page document to a large number of destinations, the count may be divided and counted separately. For example, if a 10-page document is sent to 200 addresses, the count is 10 for the first 100 destinations and the count is also 10 for the second 100 destinations, for a total of 20).
      8661
      T:Deliv PGS/Svr[0 to 9999999 / 0 / 1]
      These SPs count by color mode the total number of pages sent to a Scan Router server by both Scan and LS applications.
      001B/W
      002Color
      8665
      S:Deliv PGS/Svr[0 to 9999999 / 0 / 1]
      These SPs count by color mode the total number of pages sent to a Scan Router server by the Scan application.
      001B/W
      002Color
    • The B/W and Color counts are done after the document is stored on the HDD of the Scan Router server.
    • If the job is canceled before storage on the Scan Router server finishes, the counts are not done.
    • The count is executed even if regardless of confirmation of the arrival at the Scan Router server.
      8671
      T: Deliv PGS/PC[0 to 9999999 / 0 / 1]
      These SPs count by color mode the total number of pages sent to a folder on a PC (Scan-to-PC) with the Scan and LS applications.
      001B/W
      002Color
      8675
      S: Deliv PGS/PC[0 to 9999999 / 0 / 1]
      These SPs count by color mode the total number of pages sent with Scan-to-PC with the Scan application.
      001B/W
      002Color
      8681T:pCFAX TXPGSThese SPs count the number of pages sent by PC Fax. These SPs are provided for the Fax application only, so the counts for SP8681 and SP8683 are the same.
      8683
      F:pCFAX TXPGS
  • This counts pages sent from a PC using a PC fax application, from the PC through the copier to the destination.
  • When sending the same message to more than one place using broadcasting, the pages are only counted once. (For example, a 10-page fax is sent to location A and location B. The counter goes up by 10, not 20.)
    8691T:TX PGS/LS
    These SPs count the number of pages sent from the document server. The counter for the application that was used to store the pages is incremented.
    8692C:TX PGS/LS
    8693F:TX PGS/LS
    8694P:TX PGS/LS
    8695S:TX PGS/LS
    8696L:TX PGS/LS
    • Print jobs done with Web Image Monitor and Desk Top Binder are added to the count.
    • If several documents are merged for sending, the number of pages stored are counted for the application that stored them.
    • When several documents are sent by a Fax broadcast, the F: count is done for the number of pages sent to each destination.
8701
TX PGS/Port[0 to 9999999 / 0 / 1]
These SPs count the number of pages sent by the physical port used to send them. For example, if a 3-page original is sent to 4 destinations via ISDN G4, the count for ISDN (G3, G4) is 12.
001PSTN-1
002PSTN-2
003PSTN-3
004ISDN (G3,G4)
005Network
8711
T:Scan PGS/Comp[0 to 9999999 / 0 / 1]
These SPs count the number of compressed pages scanned into the document server, counted by the formats listed below.
001JPEG/JPEG2000
002TIFF (Multi/Single)
003PDF
004Other
005PDF/Comp
006PDF/A
8715
S:Scan PGS/Comp[0 to 9999999 / 0 / 1]
These SPs count the number of compressed pages scanned by the scan application, counted by the formats listed below.
001JPEG/JPEG2000
003PDF
004Other
005PDF/Comp
006PDF/A
8721T:Deliv PGS/WSD[0 to 9999999 / 0 / 1]
8725
S:Deliv PGS/WSD[0 to 9999999 / 0 / 1]
These SPs count the number of pages scanned by each scanner mode.
001B/W
002Color
8731T:Scan PGS/Media[0 to 9999999 / 0 / 1]
8735
S:Scan PGS/Media[0 to 9999999 / 0 / 1]
These SPs count the number of pages scanned and saved in a meia by each scanner mode.
001B/W
002Color
8741
RX PGS/Port[0to9999999/ 0 / 1]
These SPs count the number of pages received by the physical port used to receive them.
001PSTN-1
002PSTN-2
003PSTN-3
004ISDN (G3,G4)
005Network
8771
Dev Counter[0to9999999/ 0 / 1]
These SPs count the frequency of use (number of rotations of the development rollers) for black and other color toners.
Note: For machines that do not support color, the Black toner count is the same as the Total count.
8781
Toner_Botol_Info.
This SP displays the number of toner bottles used. The count is done based on the equivalent of 1,000 pages per bottle.
8791
LS Memory Remain
This SP displays the percent of space available on the document server for storing documents.
[0 to 100 / 0 / 1]
8801
Toner Remain[0 to 100 / 0 / 1]
This SP displays the percent of toner remaining for each color. This SP allows the user to check the toner supply at any time.
Note:
This precise method of measuring remaining toner supply (1% steps) is better than other machines in the market that can only measure in increments of 10 (10% steps).
8811Eco Counter
Eco Total[0 to 9999999 / 0 / 1]
Displays the number of pages reduced by using the duplex and the combine function.
Duplex[0 to 9999999 / 0 / 1]
Displays the number of pages reduced by using the duplex function.
Combine[0 to 9999999 / 0 / 1]
Displays the number of pages reduced by using the combine function.
008
Duplex(%)[0 to 100 / 0 / 1]
Displays the utilization ratio of the duplex function.
009
Combine(%)[0 to 100 / 0 / 1]
010
Paper Cut(%)[0 to 100 / 0 / 1]
Displays the paper reduction ratio.
101
Eco Totalr:Last[0 to 99999999 / 0 / 1]
104
Duplex:Last[0 to 99999999 / 0 / 1]
105
Combine:Last[0 to 99999999 / 0 / 1]
108
Duplex(%):Last[0 to 100 / 0 / 1]
109
Combine(%):Last[0 to 100 / 0 / 1]
110
Paper Cut(%):Last[0 to 100 / 0 / 1]
8851
Cvr Cnt:0-10%[0 to 9999999 / 0 / 1]
These SPs count the percentage of dot coverage for black other color toners.
0110 to 2%: BK
0213 to 4%: BK
0315 to 7%: BK
0418 to 10%: BK
8861
Cvr Cnt:11-20%[0 to 9999999 / 0 / 1]
001BKBlack toner
8871
Cvr Cnt:21-30%[0 to 9999999 / 0 / 1]
001BKBlack toner
