Ricoh MP4002/5002 service manual Part 16
Complexity Option 2
Use this SP to set the conditions for password entry to access the local address book. Specifically, this SP limits the password entry to lower case and defines the length of the password.
[0 to 32 / 0 / 1step]
  • This SP does not normally require adjustment.
  • This SP is enabled only after the system administrator has set up a group password policy to control access to the address book.
064Complexity Option 3
Use this SP to set the conditions for password entry to access the local address book. Specifically, this SP limits the password entry to numbers and defines the length of the password.
065Complexity Option 4
Use this SP to set the conditions for password entry to access the local address book. Specifically, this SP limits the password entry to symbols and defines the length of the password.
091FTP Auth Port Setting
Sets the FTP port to get the delivery server address book that is used in the individual authorization mode.
[0 to 65535 / 3671 / 1step]
094
Encryption Start
Shows the status of the encryption function of the address book on the LDAP server.
[0 to 255 / 1 ] No default
5847*
Rep Resolution Reduction
5847-2 through 5847-6 changes the default settings of image data sent externally by the Net File page reference function.
5847-21 sets the default for JPEG image quality of image files controlled by NetFile.
"NetFile" refers to jobs to be printed from the document server with a PC and the DeskTopBinder software.
002Rate for Copy B&W Text[0 to 6 / 0 / 1]0: 1x
1: 1/2x
2: 1/3x
3: 1/4x
4: 1/5x
5: 1/8x
6: 2/3x1
003Rate for Copy B&W Other[0 to 6 / 0 / 1]
005Rate for Printer B&W[0 to 6 / 0 / 1]
Rate for Printer B&W 1200dpi
[0 to 6 / 1 / 1]
021
Network Quality Default for JPEG
Sets the default value for the quality of JPEG images sent as NetFile pages. This function is available only with the MLB (Media Link Board) option installed.
[5 to 95 / 50 / 1step]
Appendix: Service Program Mode Tables
5848*
Web Service
5848-2 sets the 4-bit switch assignment for the access control setting. Setting of 0001 has no effect on access and delivery from Scan Router. 5848-100 sets the maximum size of images that can be downloaded. The default is equal to 1 gigabyte.
Acc. Ctrl.: Repository (only Lower 4 Bits)
0000: No access control 0001: Denies access to DeskTop Binder.
003Acc. Ctrl.: Doc. Svr. Print (Lower 4 Bits)
Switches access control on and off.
0000: OFF, 0001: ON
004Acc. Ctrl.: User Directory (Lower 4 Bits)
007Acc. Ctrl Comm. Log Fax (Lower 4 Bits)
009Acc. Ctrl.: Job Control (Lower 4 Bits)
011Acc. Ctrl: Device Management (Lower 4 Bits)
021Acc. Ctrl: Delivery (Lower 4 Bits)
022Acc. Ctrl: User Administration (Lower 4 Bits)
099Repository: Download Image Setting
100
Repository: Download Image Max. Size
Specified the max size of the image data that the machine can download/ [1 to 2048 / 2048 / 1 MB]
210
Setting: Log Type: Job 1
No information is available at this time.
211
Setting: Log Type: Job 2
212
Setting: Log Type: Access
213
Setting: Primary Srv
214
Setting: Secondary Srv
215
Setting: Start Time
216
Setting: Interval Time
217
Setting: Timing
5849
Installation Date
Displays or prints the installation date of the machine.
Display
The "Counter Clear Day" has been changed to "Installation Date" or "Inst. Date".
Switch to Print
Determines whether the installation date is printed on the printout for the total counter.
[0 to 1 / 1 / -]
0: OFF (No Print) 1: ON (Print)
Total Counter
When the total number of pages that are made reaches this value, the current date becomes the 'official' installation date for this machine.
[0 to 99999999 / 0 / 1]
5850*Address Book Function Japan Only
Replacement of Circuit Classification
The machine is sold ready to use with a G3 line. This SP allows you to switch all at once to convert to G4 after you add a G4 line. Conversely, if for some reason the G4 line becomes unusable, you can easily switch back to G3.
5851*
Bluetooth
Sets the operation mode for the Bluetooth Unit. Press either key.
[0: Public] / [1: Private]
5853
Stamp Data Download
Push [Execute] to download the fixed stamp data from the machine ROM onto the hard disk. Then these stamps can be used by the system. If this is not done, the user will not have access to the fixed stamps ("Confidential", "Secret", etc.).
You must always execute this SP after replacing the HDD or after formatting the HDD. Always switch the machine off and on after executing this SP.
5856Remote ROM Update
When set to "1" allows reception of firmware data via the local port (IEEE 1284) during a remote ROM update. This setting is reset to zero after the machine is cycled off and on. Allows the technician to upgrade the firmware using a parallel cable
[0 to 1 / 0 / 1 step]
0: Not allowed
1: Allowed
5857Save Debug Log
On/Off (1:ON 0:OFF)
Switches on the debug log feature. The debug log cannot be captured until this feature is switched on.
[0 to 1 / 0 / 1]
0: OFF, 1: ON
Target (2: HDD 3: SD)
Selects the destination where the debugging information generated by the event selected by SP5858 will be stored if an error is generated
[2 to 3 / 2 / 1]
2: HDD, 3: SD Card
Save to HDD
Specifies the decimal key number of the log to be written to the hard disk.
Save to SD Card
Specifies the decimal key number of the log to be written to the SD Card.
009
Copy HDD to SD Card (Latest 4 MB)
Takes the most recent 4 MB of the log written to the hard disk and copies them to the SD Card.
A unique file name is generated to avoid overwriting existing file names on the SD Card. Up to 4MB can be copied to an SD Card. 4 MB segments can be copied one by one to each SD Card.
010
Copy HDD to SD Card Latest 4 MB Any Key)
Takes the log of the specified key from the log on the hard disk and copies it to the SD Card.
A unique file name is generated to avoid overwriting existing file names on the SD Card. Up to 4 MB can be copied to an SD Card. 4 MB segments can be copied one by one to each SD Card. This SP does not execute if there is no log on the HDD with no key specified.
011
Erase HDD Debug Data
Erases all debug logs on the HDD
012
Erase SD Card Debug Data
Erases all debug logs on the SD Card. If the card contains only debugging files generated by an event specified by SP5858, the files are erased when SP5857 010 or 011 is executed.
To enable this SP, the machine must be cycled off and on.
013
Free Space on SD Card
Displays the amount of space available on the SD card.
014
Copy SD to SD (Latest 4MB)
Copies the last 4MB of the log (written directly to the card from shared memory) onto an SD card.
015
Copy SD to SD (Latest 4MB Any Key)
This SP copies the log on an SD card (the file that contains the information written directly from shared memory) to a log specified by key number.
016
Make HDD Debug
This SP creates a 32 MB file to store a log on the HDD.
017
Make SD Debug
This SP creates a 4 MB file to store a log on an SD card.
5858*
Debug Save When
These SPs select the content of the debugging information to be saved to the destination selected by SP5857-002.
SP5858-003 stores one SC specified by number.
001*
Engine SC Error (0:OFF 1:ON)
Stores SC codes generated by copier engine errors.
002*
Controller SC Error (0:OFF 1:ON)Stores SC codes generated by GW controller errors.
003*Any SC Error[0 to 65535 / 0 / 1step]
004*Jam (0:OFF 1:ON)Stores jam errors.
5859*Debug Save Key No.
001Key1
These SPs allow you to set up to 10 keys for log files for functions that use common memory on the controller board. [0 to 9999999 / 0 / 1]
002Key2
003Key3
004Key4
005Key5
006Key6
007Key7
008Key8
009Key9
010Key10
5860*SMTP/POP3/IMAP4
020
Partial Mail Receive Timeout
[1 to 168 / 72 / 1 hour]
Sets the amount of time to wait before saving a mail that breaks up during reception. The received mail is discarded if the remaining portion of the mail is not received during this prescribed time.
021
MDN Response RFC2298 Compliance
Determines whether RFC2298 compliance is switched on for MDN reply mail.
[0 to 1 / 1 / 1]
0: No, 1: Yes
022
SMTP Auth. From Field Replacement
Determines whether the FROM item of the mail header is switched to the validated account after the SMTP server is validated.
[0 to 1 / 0 / 1]
0: No. "From" item not switched. 1: Yes. "From" item switched.
025
SMTP Auth Direct Sending
Select the authentication method for SMPT. Bit 0: LOGIN
Bit 1: PLAIN
Bit 2: CRAM_MD5
Bit 3: DIGEST_MD5
Bit 4 to Bit 7: Not Used
  • This SP is activated only when SMTP authentication is enabled by UP mode.
026
S/MIME: MIME Header Setting
Selects the MIME header type of an E-mail sent by S/MIME. [0 to 2 / 0 / 1]
0: Microsoft Outlook Express standard 1: Internet Draft standard
2: RFC standard
028
S/MIME: Authentication Check
When sending S/MIME mail, specify whether to check the destination authentication.
[0 to 1 / 0 / 1]
0: Not checked
1: Checked
5866E-Mail Report
Report Validity
Enables or disables the E-mail alert function. [0 or 1 / 0 / – ] 0: Enabled, 1: Disabled
Add Date Field
Adds or does not add the date field to the header of the alert mail.
[0 or 1 / 0 / – ]
0: Not added, 1: Added
5870Common Key Info Writing
Writing
Writes to flash ROM the common proof for validating the device for @Remote specifications.
003InitializeInitializes the data area of the common proof for validating.
Writing: 2048bitWrites to flash ROM the common proof (2048-bit) for validating the device for @Remote specifications.
5873
SD Card Appli. Move
Allows you to move applications from one SD card another. For more, see "SD Card Appli Move" in the chapter "System Maintenance (Main Chapters).
001Move ExecExecutes the move from one SD card to another.
002Undo ExecThis is an undo function. It cancels the previous execution.
5875SC Auto Reboot
This SP determines whether the machine reboots automatically when an SC error occurs.
  • The reboot does not occur for Type A SC codes.
Reboot Setting
[0 to 1/ 0 / 1]
0: The machine reboots automatically when the machine issues an SC error and logs the SC error code. If the same SC occurs again, the machine does not reboot.
1: The machine does not reboot when an SC error occurs.
Reboot Type
[0 to 1 / 0 / 1]
0: Manual reboot, 1: Automatic reboot
5878Option Setup
Data Overwrite Security
Press [Execute] to initialize the Data Overwrite Security option for the copier. For more, see "DataOverwriteSecurity Unit" in the chapter "Installation".
5881
Fixed Phase Block Erasing
Detects the Fixed phrase.
CPM Set
DFU
5882
5885*Set WIM Function
020
DocSvr Acc Ctrl
Allows or disallows the functions of web image monitor.
0: OFF, 1: ON
Bit:
0: Forbid all document server access 1: Forbid user mode access
2: Forbid print function 3: Forbid Fax
4: Forbid scan sending 5: Forbid download
6: Forbid delete
7: Forbid guest user
050
DocSvr Format
Selects the display type for the document box list. [0 to 2 / 0 / 1]
0: Thumbnail, 1: Icon, 2: Details
051
DocSvr Trans
Sets the number of documents to be displayed in the document box list. [5 to 20 / 10 / 1]
100
Set Signature
[0 to 2 / 0 / 1/step]
0: Signature for each e-mail 1: Signature for all e-mails 2: No signature
Selects whether the signature is added to the scanned documents with the WIM when they are transmitted by an e-mail.
101
Set Encryption
Determines whether the scanned documents with the WIM are encrypted when they are transmitted by an e-mail.
[0 to 1 / 0 / 1]
0: Not encrypted, 1:Encryption
200Detect Mem LeakNot used
201DocSvr TimeoutNot used
5887
SD Get Counter
This SP determines whether the ROM can be updated.
This SP sends a text file to an SD card inserted in SD card Slot 2 (lower slot). The operation stores. The file is stored in a folder created in the root directory of the SD card called SD_COUNTER. The file is saved as a text file (*.txt) prefixed with the number of the machine.
  1. Insert the SD card in SD card Slot 2 (lower slot).
  2. Select SP5887 then touch [EXECUTE].
Touch [Execute] in the message when you are prompted.
5888*
Personal Information Protect
Selects the protection level for logs. [0 to 1 / 0 / 1]
0: No authentication, No protection for logs
1: No authentication, Protected logs (only an administrator can see the logs)
5893
SDK Application Counter
Displays the counter name of each SDK application.
001SDK-1
002SDK-2
003SDK-3
004SDK-4
005SDK-5
006SDK-6
5907
Plug & Play Maker/Model Name
Selects the brand name and the production name for Windows Plug & Play. This information is stored in the NVRAM. If the NVRAM is defective, these names should be registered again.
After selecting, press the "Original Type" key and "#" key at the same time. When the setting is completed, the beeper sounds five times.
5908*
LCT Paper Size
Specifies the paper size in the LCT. [0 or 1 / 0 / -]
0: A4
1: LT
5913*Switchover Permission Time
Print Application Timer[3 to 30 / 3 / 1 second step]
Sets the length of time to elapse before allowing another application to take control of the display when the application currently controlling the display is not operating because a key has not been pressed.
5919*HDD Encryption
Display Operation State
Shows the status of the encryption function for the HDD. [0 or 1 / 0 / - ]
0: Not Activated
1: Activated
5967*
Copy Server: Set Function0: ON, 1: OFF
Enable and disable the document server. This is a security measure that prevents image data from being left in the temporary area of the HDD. After changing this setting, you must switch the main switch off and on to enable the new setting.
5973*User Stamp Registration
101
Frame deletion setting [0 to 3 / 0 / 1 mm]
5974*
Cherry Server
Selects which version of the Scan Router application program, "Light" or "Full" (Professional) is installed.
[0 or 1 / 0 / - ]
0: Light
1: Full
5985
Device Setting
The NIC and USB support features are built into the GW controller. Use this SP to enable and disable these features. In order to use the NIC and USB functions built into the controller board, these SP codes must be set to "1".
On Board NIC
[0 to 2 / 0 / 1 /step]
0: Disable, 1: Enable, 2: Function limitation
When the "Function limitation" is set, "On board NIC" is limited only for the NRS or LDAP/NT authentication.
  • Other network applications than @Remote or LDAP/NT authentication are not available when this SP is set to "2". Even though you can change the initial settings of those network applications, the settings do not work
On Board USB
[0 or 1 / 0 / 1/step]
5987*Counter Falsification Prevention
This SP detects that a mechanical counter device is removed. If it is detected, SC610 occurs.
[0 or 1 / 1 / 1/step]
0: OFF. 1: ON
5990
SP Print Mode
Prints out the SMC sheets.
001All ( Data List)
002SP (Mode Data List)
003User Program
004Logging Data
005Diagnostic Report
006Non-Default
007NIB Summary
008Capture Log
021Copier User Program
022Scanner SP
023Scanner User Program
024SDK/J Summary
025SDK/J Application Info
026Print SP
5992
SP Text Mode
Writes the SMC sheets into the SD card.
001All ( Data List)
003User Program
004Logging Data
006Non-Default
007NIB Summary
008Capture Log
022Scanner SP
024SDK/J Summary
026Print SP
  1. SYSTEM SP TABLES-6​
    1. SP6-XXX: PERIPHERALS​
      6006*
      ADF Registration Adjust
      Adjusts the side-to-side and leading edge registration for simplex and duplex original feeding in ARDF mode.
      SP6006-5 sets the maximum setting allowed for rear edge erase.
      001Side-to-Side Regist: Front
      [–3 to 3 / 0 / 0.1 mm / step]
      002Side-to-Side Regist: Rear
      003Leading Edge Registration[–5 to 5 / 0 / 0.1 mm / step]
      005Buckle: Duplex Front[–3 to 3 / 0 / 0.1 mm / step]
      006Buckle: Duplex Rear[–2.5 to 2.5 / 0 / 0.1 mm / step]
      007Rear Edge Erase[–10 to 10 / 0 / 0.1 mm / step]
      6007ADF Input Check
      Original Length 1 (B5 Detection Sensor)
      0: Paper not detected 1: Paper detected
      Original Length 2 (A4 Detection Sensor)
      Original Length 3 (LG Detection Sensor)
      004Original Width Sensor 1
      005Original Width Sensor 2
      006Original Width Sensor 3
      007Original Width Sensor 4
      008Original Width Sensor 5
      009Original Set Sensor
      010Separation Sensor
      011Skew Correction Sensor
      012Scan Entrance Sensor
      013Registration Sensor
      014Exit Sensor
      015
      Feed Cover Sensor
      0: ADF cover closed 1: ADF cover open
      016
      Lift Up Sensor
      0: ADF closed
      1: ADF open
      017
      Inverter Sensor
      018
      Pick-up Roller HP Sensor
      0: HP (Pick-up roller: Up)
      1: Not HP (Pick-up roller: Down)
      019
      Original Set HP Sensor
      0: HP (Stopper: UP)
      1: Not HP (Stopper: Down)
      6008ADF Output Check
      001Pick-up Motor Forward
      002Pick-up Motor Reserve
      003Feed Motor Forward
      004Feed Motor Reserve
      005Relay Motor Forward
      007Inverter Motor Forward
      008Inverter Motor Reserve
      011Inverter Solenoid
      012Stamp
      013Fan Motor
      6009
      ADF FreeRun
      Performs an ARDF free run in duplex mode. Press [ON] to start, press [OFF] to stop.
      Note: This is a general free run controlled from the copier.
      001Free Run: Simplex Motion
      002Free Run: Duplex Motion
      003Free Run: Stamp Motion
      6010*
      ADF Stamp Position Adjust.[–5 to 5 / 0 / 0.1 mm step]
      Adjusts the horizontal position of the stamp on the scanned originals.
      6016*
      Original Size Detect Setting
      Specifies the original size for a size detected by the original sensor, since original sensors cannot recognize all sizes.
      (7) 0000 0000 (0)
      Different bits are used for detection, depending on the location as shown below.
      BitSizeLocation
      7A4 (L)/LT (L)
      Japan only
      611" x 15"/DLT (L)
      5DLT (L)/ 11" x 15"
      NA only
      4LT (S)/ US Exec (S)
      3LT (L)/ 8" x 10" (L)
      2LG (L)/ F4 (L)
      1A4 (L)/ 16K (L)
      EU/AA only
      08K (L)/ DLT (L)
      6017*
      DF Magnification Adj.[–5 to 5 / 0 / 0.1% step]
      Adjusts the magnification in the sub-scan direction for ADF mode. Use the key to toggle between + and - before entering the value
      6020*
      Skew Correction Moving Setting
      Turns the original skew correction in the ARDF for all original sizes on or off. [0 to 1 / 0 / 1 ]
      0: Off (only for small original sizes) 1: On (for all original sizes)
      6128
      Punch Position: Sub Scan
      Adjusts the punching position in the sub scan direction. (For D636/D637)
      0012-Hole: DOM (Japan)
      [-7.5 to 7.5 / 0 / 0.5 mm]
      0023-Hole: NA
      0034-Hole: EU
      0045-Hole: SCAN
      0052-Hole: NA
      6129
      Punch Position: Main Scan
      Adjusts the punching position in the main scan direction. (For D636/D637)
      [-2 to 2 / 0 / 0.4 mm]
      0023-Hole: NA
      0034-Hole: EU
      0044-Hole: SCAN
      0052-Hole: NA
      6130*
      Skew Correction: Buckle Adj.
      Adjusts the paper buckle at the punch unit for each paper size. (For D636/D637)
      001A3 SEF
      [-5 to 5 / 0 / 0.25 mm]
      002B4 SEF
      003A4 SEF
      004A4 LEF
      005B5 SEF
      006B5 LEF
      007DLT SEF
      008LG SEF
      009LT SEF
      010LT LEF
      01112" x 18"
      012Other
      6131*
      Skew Correction Control
      Selects the skew correction control for each paper size. (For D636/D637)
      001A3 SEF
      [0 to 1 / 1 / 1 mm]
      002B4 SEF
      003A4 SEF
      004A4 LEF
      005B5 SEF
      006B5 LEF
      007DLT SEF
      008LG SEF
      009LT SEF
      010LT LEF
      01112" x 18"
      012Other
      6132*
      Jogger Fence Fine Adj.
      This SP adjusts the distance between the jogger fences and the sides of the stack on the finisher stapling tray in the (Booklet) Finisher D636/D637. The adjustment is done perpendicular to the direction of paper feed.
      001A3 SEF
      [-1.5 to 1.5 / 0 / 0.5 mm]
      002B4 SEF
      003A4 SEF
      004A4 LEF
      005B5 SEF
      006B5 LEF
      007DLT SEF
      008LG SEF
      009LT SEF
      010LT LEF
      01112" x 18"
      012Other
      6133*
      Staple Position Adjustment
      Adjusts the staple position for each finisher (D636/D637).
      + Value: Moves the staple position to the rear side.
      - Value: Moves the staple position to the front side. [-3.5 to 3.5 / 0 / 0.5 mm]
      6134*
      Saddle Stitch Position Adj.
      Use this SP to adjust the stapling position of the booklet stapler when paper is stapled and folded in the Booklet Finisher (D637).
      001A3 SEF
      [-3 to 3 / 0 / 0.2 mm]
      + Value: Shifts staple position toward the crease.
      - Value: Shifts staple position away from the crease
      002B4 SEF
      003A4 SEF
      004B5 SEF
      005DLT SEF
      006LG SEF
      007LT SEF
      00812" x 18"
      009Other
      6135*
      Folder Position Adj.
      This SP corrects the folding position when paper is stapled and folded in the Booklet Finisher D637.
      001A3 SEF
      - Value: Shifts staple position away from the crease.
      002B4 SEF
      003A4 SEF
      004B5 SEF
      005DLT SEF
      006LG SEF
      007LT SEF
      00812" x 18"
      009Other
      6136*
      Book Fold Repeat
      Sets the number of times that folding is done in the Booklet Finisher D637. [2 to 30 / 2 / 1 time/step]
      6137
      Finisher Free Run
      These SPs are used for the D588 or D636/D637.
      Free Run 1
      D588: System free run
      D636/D637: Free run for paper edge stapling.
      Free Run 2
      D588: Free run for durability testing D636/D637: Not used
      003Free Run 3Not used
      004Free Run 4Not used
      6139
      Entrance Sensor
      Display the signals received from sensors and switches of the (booklet) finisher. (D588)
      p.3-251 "Input Check")
      6140
      FIN (EUP) INPUT Check
      Display the signals received from sensors and switches of the (booklet) finisher. (D636/D637)
      6144
      FIN (KIN) OUPUT Check
      p.3-263 "Output Check")
      6145
      FIN (EUP) OUPUT Check
      6149*
      Max. Pre-Stack Sheet[0 to 3 / 3 / 1 sheets step]
      This SP sets the number of sheets sent to the pre-stack tray.
      • You may need to adjust this setting or switch it off when feeding thick or slick paper.
      6800Sheet Conversion (Thick Paper)
      Permits punching, including tab sheets. Note: Do not change this setting.
      [1 to 3 / 3 / 1 sheet]
      1: 1 Sheet
      2: 2 Sheets
      3: 3 Sheets
      6830*
      Extra Staples
      More than the standard number of sheets can be stapled. This SP sets the additional number of sheets (This Setting + Standard Number = maximum number of sheets).
      Staple positions other than booklet stapling
      [0 to 50 / 0 /1]
      2 Booklet stapling
      [0 to 50 / 0 /1]
      • If the number of the maximum for staples is increased, and the mechanical warranty of the unit can be guaranteed, then the setting can take effect without changing the controller software.
      • However, assurance that mechanical performance can be guaranteed is required before changing the setting to increase the staple load for more than the maximum in the feed/exit specifications. Raising this setting without quality assurance could damage the machine.
      • Appendix: Service Program Mode Tables
      6910Shading Control
      ON/OFF
      [0 to 1 / 0 / 1 ]
      0= OFF, 1= ON
      Enables or disables the shading adjustment for DF mode.
      002Shading Interval: A[0 to 60 / 3 / 1 sec] DFU
      003Shading Interval: B[0 to 120 / 60 / 1 ] DFU
  2. SYSTEM SP TABLES-7​
    1. SP7-XXX: DATA LOG​
7401*Total SC Counter
SC Counter
Displays the total number of service calls that have occurred.
This SC counter can be reset by executing SP7807 (SC/Jam Counter Reset).
Total SC Counter
Displays the cumulative sum of service calls that have occurred.
This SC counter cannot be reset by executing SP7807 (SC/Jam Counter Reset).
7403*SC History
001Latest
Displays the most recent 10 service calls.
002Latest 1
003Latest 2
004Latest 3
005Latest 4
006Latest 5
007Latest 6
008Latest 7
009Latest 8
010Latest 9
7404*SC991 History
001Latest
Displays the 10 most recently detected SC991 codes.
002Latest 1
003Latest 2
004Latest 3
005Latest 4
006Latest 5
007Latest 6
008Latest 7
009Latest 8
010Latest 9
7502*Total Paper Jam
Jam Counter
Displays the total number of paper jams.
Total Jam Counter
Displays the cumulative sum of paper jams.
7503*Total Original Jam
Original Jam Counter
Displays the total number of original jams.
Total Original Counter
Displays the cumulative sum of original jams.
7504*
Total Jams Location
These SPs display the total number of paper jams by location. A "Check-in" (paper late) error occurs when the paper fails to activate the sensor at the precise time. A "Check-out" ("paper lag") paper jam occurs when the paper remains at the sensor for longer than the prescribed time.
001At power On
003Tray 1: On
004Tray 2: On
005Tray 3: On
006Tray 4: On
007LCT: On
008Bypass: On
009Duplex: On
011Vertical Transport 1: On
012Vertical Transport 2: On
013Bank: Transport Sn 1: On
014Bank: Transport Sn 2: On
017Registration: On
019Fusing Exit: On
020Paper Exit: On
021Bridge Exit On
022Bridge Transport: On
024Junction Gate Sensor: On
025Duplex Exit: On
026Duplex Entrance: On (In)
027Duplex Entrance: On (Out)
051Vertical Transport 1: Off
052Vertical Transport 2: Off
053Bank Transport 1: Off
054Bank Transport 2: Off
057Registration Sensor: Off
058LCT Feed Sensor: Off
060Paper Exit: Off
061Bridge: Exit: Off
062Bridge: Transport: Off
064Junction Gate Sensor: Off
065Duplex Exit: Off
066Duplex Entrance: Off (In)
067Duplex Entrance: Off (Out)
100Finisher Entrance: KIN
101Finisher Shift Tray Exit: KIN
102Finisher Staple: KIN
103Finisher Exit: KIN
105Finisher Tray Lift Motor: KIN
106Finisher Jogger Motor: KIN
107Finisher Shift Motor: KIN
108Finisher Staple Motor: KIN
109Finisher Exit Motor: KIN
191Finisher Entrance: EUP
192Finisher Proof Exit: EUP
193Finisher Shift Tray Exit: EUP
194Finisher Staple Exit: EUP
195Finisher Exit: EUP
198Finisher Folder: EUP
199Finisher Tray Motor: EUP
200Finisher Jogger Motor: EUP
201Finisher Shift Motor: EUP
202Finisher Staple Moving Motor: EUP
203Finisher Staple Motor: EUP
204Finisher Folder Motor: EUP
206Finisher Punch Motor: EUP
7505
Original Jam Detection
Displays the total number of original jams by location. These jams occur when the original does not activate the sensors. A Check-in ("paper late") error occurs when the paper fails to activate the sensor at the precise time. A Check-out ("paper lag") paper jam occurs when the paper remains at the sensor for longer than the prescribed time.
001At Power: On
003Separation Sensor: On
004Skew Correction Sensor: On
005Interval Sensor: On
006Registration Sensor: On
007Inverter Sensor: On
008Original Exit Sensor: On
053Separation Sensor: Off
054Skew Correction Sensor: Off
055Interval Sensor: Off
056Registration Sensor: Off
057Inverter Sensor: Off
058Original Exit Sensor: Off
7506*Jam Count by Paper Size
005A4 LEF
Displays the total number of copy jams by paper size.
006A5 LEF
014B5 LEF
038LT LEF
044HLT LEF
132A3 SEF
133A4 SEF
134A5 SEF
141B4 SEF
142B5 SEF
160DLT SEF
164LG SEF
166LT SEF
172HLT SEF
255Others
7507*PlotterJamHistory
001Last
002Latest 1
Displays the copy jam history (the most recent 10 jams)
003Latest 2Sample Display:
CODE:007
004Latest 3
005Latest 4TOTAL:0000334
DATE: Mon Mar 15 11:44:50 2000
006Latest 5
where:
007Latest 6CODE is the SP7504-*** number (see above.
SIZE is the ASAP paper size code in hex.
008Latest 7
TOTAL is the total jam error count (SP7502)
009Latest 8DATE is the date the jams occurred.
010Latest 9
SizeCodeSizeCodeSizeCode
A4 (S)05A3 (L)84DLT (L)A0
A5 (S)06A4 (L)85LG (L)A4
B5 (S)0EA5 (L)86LT (L)A6
LT (S)26B4 (L)8DHLT (L)AC
HLT (S)2CB5 (L)8EOthersFF
7508*OriginalJamHistory
001Last
002Last 1
Displays the original jam history (the most recent 10 jams).
003Last 2Sample Display:
CODE:007
004Last 3
005Last 4TOTAL:0000334
006Last 5
where:
007Last 6CODE is the SP7505*** number (see above.
008Last 7
TOTAL is the total jam error count (SP7503)
009Last 8DATE is the date the jams occurred.
010Last 9
7624*
Part Replacement Operation
Selects the PM maintenance for each part.
001PCU-BK
[0 to 1 / 1 / 1]
0:No (Not PM maintenance) 1: Yes (PM maintenance)
002Fuser
003Transfer Unit
004FuserCleaner
7801
ROM No./Firmware Version
This SP codes display the firmware versions of all ROMs in the system, including the mainframe, the ARDF, and peripheral devices.
7803*
PM Counter Display
Displays the PM counter since the last PM.
Paper[0 to 999999 / 0 / 1 page]
Displays the paper counter (pages)
Page: PCD[0 to 999999 / 0 / 1 page]
Displays the PCD (Drum and Development unit) counter (pages)
Page: Transfer[0 to 999999 / 0 / 1 page]
Displays the transfer unit counter (pages).
Page: Fuser[0 to 999999 / 0 / 1 page]
Displays the fusing unit counter (pages).
Rotation: PCD[0 to 999999999 / 0 / 1 mm ]
Displays the PCD rotation counter (distance).
Rotation: Transfer[0 to 999999999 / 0 / 1 mm ]
Displays the transfer unit rotation counter (distance).
Rotation: Fuser[0 to 999999999 / 0 / 1 mm ]
Displays the fuser unit rotation counter (distance).
008
Rotation(%): PCD[0 to 255 / 0 / 1 %]
Displays the PCD (%) rotation counter (Distance/PM).
009
Rotation(%):Transfer[0 to 255 / 0 / 1 %]
Displays the transfer unit (%) rotation counter (distance/PM).
010
Rotation(%):Fuser[0 to 255 / 0 / 1 %]
Displays the fuser unit (%) rotation counter (distance/PM).
011
Rotation(%):Web[0 to 255 / 0 / 1 %]
Displays the web unit (%) rotation counter (distance/PM).
7804
PM Counter Reset
Resets the PM counter.
Touch [Execute] two times > "Completed" > [Exit]
Paper
Resets the PM counter of the paper.
PCD
Resets the PM counter of the PCD (Drum and Development unit except developer).
Transfer
Resets the PM counter of the transfer unit.
Fuser
Resets the PM counter of the fuser unit.
Web
Reset the PM counter of the web unit.
All Clear
Resets all PM counter
7805Parts Counter
Page: OPC[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the OPC.
Page: Charge Roller[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the charge roller.
Page: Developer[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the developer.
Page: Belt Blade[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the transfer belt cleaning blade.
Page: Heat Roller[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the hot roller.
Page: Pressure Roller[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the pressure roller.
Page: Cleaning Roller[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the cleaning roller.
008
Page: Thermistor[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the thermistors.
009
Page: Stripper[0 to 999999 / 0 / 1 page]
Displays the parts counter (pages) of the strippers.
010
Rotation: OPC[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the OPC.
011
Rotation: Charge Roller[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the charge roller.
012
Rotation: Developer[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the developer.
013
Rotation: Belt Blade[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the transfer belt, blade.
014
Rotation: Heat Roller[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the hot roller.
015
Rotation: Pressure Roller[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the pressure roller.
016
Rotation: Cleaning Roller[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the cleaning roller.
017
Rotation: Thermistor[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the thermistors.
018
Rotation: Stripper[0 to 999999999 / 0 / 1 mm ]
Displays the parts counter (rotations) of the strippers.
019
Page(%): Web[0 to 255 / 0 / 1 %]
Displays the parts counter (rotations/PM %) of the cleaning web.
7806Counter Clear
OPC
Resets the parts counter of the OPC.
Charge Roller
Resets the parts counter of the charge roller.
Developer
Resets the parts counter of the developer.
Belt: Blade
Resets the parts counter of the transfer belt cleaning blade.
Heat Roller
Resets the parts counter of the hot roller.
Pressure Roller
Resets the parts counter of the pressure roller.
Cleaning Roller
Resets the parts counter of the cleaning roller.
008
Web
Resets the parts counter of the cleaning web.
009
Thermistor
Resets the parts counter of the thermistors.
010
Stripper
Resets the parts counter of the strippers.
011
All Clear
Resets all parts counters.
7807
Resets the SC and jam counters. To reset, press Execute on the touch panel.
This SP does not reset the jam history counters: SP7507, SP7508.
7826
MF Error Counter Japan Only
Displays the number of counts requested of the card/key counter.
Error Total
A request for the count total failed at power on. This error will occur if the device is installed but disconnected.
Error Staple
The request for a staple count failed at power on. This error will occur if the device is installed but disconnected.
7827
MF Error Counter Clear Japan Only
Press Execute to reset to 0 the values of SP7826. Japan Only
7832
Self-Diagnose Result Display
Execute to open the "Self-Diagnostics Result Display" to view details about errors. Use the keys in the display on the touch-panel to scroll through all the information. If no errors have occurred, you will see the "No Error" message on the screen.
7836
Total Memory Size
Displays the memory capacity of the controller system.
7852*
DF Glass Dust Check
Counts the number of occurrences (0 to 65,535) when dust was detected on the scanning glass of the ADF or resets the dust detection counter.
Counting is done only if SP4-020-1 (Dust Check) is switched on.
001Dust Detection Counter[0 to 65535 / 0 / 1 /step]
Dust Detection Clear Counter
7853Replacement Counter
PCD[0 to 255 / 0 / 1 ]
Displays the replacement counter of the PCD (Drum and Development unit).
Transfer[0 to 255 / 0 / 1 ]
Displays the replacement counter of the transfer unit.
Fuser[0 to 255 / 0 / 1 ]
Displays the replacement counter of the fusing unit.
Web[0 to 255 / 0 / 1 ]
Displays the replacement counter of the cleaning web.
7856*
zero cross[0 to 255 / 60 / 1 ]
Stores and displays the detected zero cross frequency of the main ac power supply from the wall socket.
7901
Assert Info. DFU
These SP numbers display the results of the occurrence of the most recent SC code generated by the machine.
001*File NameModule name
002*Number of LinesNumber of the lines where error occurred.
003*LocationValue
7906Prev Counter
Displays the counter (pages) of the previous PCD
Displays the previous counter (pages) of the previous transfer unit.
Displays the previous counter (pages) of the previous fusing unit.
Displays the previous counter (rotations) of the previous PCD
Displays the previous counter (rotations) of the previous transfer unit.
Displays the previous counter (rotations/PM %) of the previous fusing unit.
Rotation(%):pCD[0 to 255 / 0 / 1 mm]
Displays the previous counter (rotations/PM %) of the previous PCD
008
Rotation(%):Transfer[0 to 255 / 0 / 1 mm]
Displays the previous counter (rotations/PM %) of the previous transfer unit.
009
Rotation(%):Fuser[0 to 255 / 0 / 1 mm]
010
Displays the previous counter (rotations/PM %) of the previous cleaning web.
7950Replacement Date
PCD
Displays the replacement date of the PCD.
Transfer
Displays the replacement date of the transfer unit.
Fuser
Displays the replacement date of the fusing unit.
Web
Displays the replacement date of the web unit.
7951Remaining Counter
PCD(Page)[0 to 255 / 255 / 1 days]
Displays the remaining counter (pages) of the PCD.
Transfer(Page)[0 to 255 / 255 / 1 days]
Displays the remaining counter (pages) of the transfer unit.
Fuser(Page)[0 to 255 / 255 / 1 days]
Displays the remaining counter (pages) of the fusing unit.
PCD(Rotation)[0 to 255 / 255 / 1 days]
Displays the remaining counter (rotations) of the PCD.
Transfer(Rotation)[0 to 255 / 255 / 1 days]
Displays the remaining counter (rotations) of the transfer unit.
Fuser(Rotation)[0 to 255 / 255 / 1 days]
Displays the remaining counter (rotations) of the fusing unit.
009
PCD (%)[0 to 255 / 100 / 1 %]
Displays the remaining counter (%) of the PCD.
010
Transfer (%)[0 to 255 / 100 / 1 %]
Displays the remaining counter (%) of the transfer unit.
011
Fuser (%)[0 to 255 / 100 / 1 %]
Displays the remaining counter (%) of the fusing unit.
013
Web (%)[0 to 255 / 100 / 1 %]
Displays the remaining counter (%) of the cleaning web.
7952
PM Yield Setting
Sets the each yield of the following.
PCD(Page)[0 to 99999999/ 160000 / 1 sheet]
Sets the PM yield of the PCD (Pages).
Transfer(Page)[0 to 9999999 / 160000 / 1 sheet]
Sets the PM yield of the transfer unit (Pages).
Fuser(Page)[0 to 9999999 / 160000 / 1 sheet]
Sets the PM yield of the fusing unit (Pages).
PCD(Rotation)
C2b: [0 to 999999999 / 71990000 / 1 mm]
C2c: [0 to 999999999 / 75500000 / 1 mm]
Sets the PM yield of the PCD (Rotations).
Transfer(Rotation)
C2b: [0 to 999999999 / 62770000 / 1 mm]
C2c: [0 to 999999999 / 65420000 / 1 mm]
Sets the PM yield of the transfer unit (Rotations).
Fuser(Rotation)
C2b: [0 to 999999999 / 54880000 / 1 mm]
C2b: [0 to 999999999 / 55800000 / 1 mm]
Sets the PM yield of the fusing unit (Rotations).
009
Web (%)[0 to 255 / 92 / 1 %]
Sets the PM yield (%) of the web unit.
021
Day Threshold: PCD[1 to 30 / 15 / 1 days]
Adjusts the threshold day for the near end for the PCD.
022
Day Threshold: Transfer Unit[1 to 30 / 15 / 1 days]
Adjusts the threshold day for the near end for the transfer unit.
023
Day Threshold: Fusing Unit[1 to 30 / 15 / 1 days]
Adjusts the threshold day for the near end for the fusing unit.
7953Operation Env Log
T<10[0 to 99999999 / 0 / 1 mm]
Displays the PCU rotation distance in the environment: T<10°C
10<=T<=17[0 to 99999999 / 0 / 1 mm]
Displays the PCU rotation distance in the environment: 10°C<=T<=17°C
17<T<23[0 to 99999999 / 0 / 1 mm]
Displays the PCU rotation distance in the environment: 17<=T<=23
23<=T<=27[0 to 99999999 / 0 / 1 mm]
Displays the PCU rotation distance of the environment: 23<=T<=27
27<=T<=32[0 to 99999999 / 0 / 1 mm]
Displays the PCU rotation distance of the environment: 27<=T<=32
32<T[0 to 99999999 / 0 / 1 mm]
Displays the PCU rotation distance of the environment: 32<T
7954
Env Log Clear
Resets the environment logs (SP7953).
