Ricoh MP4002/5002 service manual Part 15
5431External Auth User Preset
010
Tag
[0 or 1 / 1 / -]
0: Not permit, 1: Permit
Turns on or off the tag copy permission for the external authentication.
011
Entry
[0 or 1 / 1 / -]
Turns on or off the copy permission of the entry information for the external authentication.
012
Group
[0 or 1 / 1 / -]
Turns on or off the copy permission of the group information for the external authentication.
020
Mail
[0 or 1 / 1 / -]
Turns on or off the copy permission of the mail information for the external authentication.
030
Fax
[0 or 1 / 1 / -]
Turns on or off the copy permission of the fax information for the external authentication.
031
FaxSub
[0 or 1 / 1 / -]
Turns on or off the copy permission of the fax additional information for the external authentication.
032
Folder
[0 or 1 / 1 / -]
Turns on or off the copy permission of the folder information for the external authentication.
033
ProtectCode
[0 or 1 / 1 / -]
Turns on or off the copy permission of the protection code information for the external authentication.
034
SmtpAuth
[0 or 1 / 1 / -]
Turns on or off the copy permission of the SMTP information for the external authentication.
035
LdapAuth
[0 or 1 / 1 / -]
Turns on or off the copy permission of the LDAP information for the external authentication.
036
Smb Ftp Fldr Auth
[0 or 1 / 1 / -]
Turns on or off the copy permission of the SMB/FTP information for the external authentication.
037
AcntAcl
[0 or 1 / 1 / -]
Turns on or off the copy permission of the account ACL information for the external authentication.
038
DocumentAcl
[0 or 1 / 1 / -]
Turns on or off the copy permission of the document ACL information for the external authentication.
Appendix: Service Program Mode Tables
040
CertCrypt
[0 or 1 / 1 / -]
Turns on or off the copy permission of the authentication information for the external authentication.
050
UserLimitCount
[0 or 1 / 1 / -]
Turns on or off the copy permission of the maximum number information for the external authentication.
5481
Authentication Error Code
These SP codes determine how the authentication failures are displayed.
System Log Disp
[0 or 1 / 0 / -]
0: OFF [Default], 1: ON
Determines whether an error code appears in the system log after a user authentication failure occurs.
Panel Disp
[0 or 1 / 1 / 1]
0: OFF, 1: ON [Default]
Determines whether an error code appears on the operation panel after a user authentication failure occurs.
5490
MF KeyCard (Japan only)
Sets up operation of the machine with a keycard. [0 to 1 / 0 / 1]
0: Disabled. Cancels operation without a user code. 1: Enabled. Allows operation without a user code.
5491*
Optional Counter
Determines whether to cancel the job when MK1 keycard is pulled out from the machine during job.
[0 to 11111111 / 0 / 1]
0: On. Cancels the job.
1: Off. Allows operation if MK1 keycard is pulled out from the machine during the job.
5501*PM Alarm
PM Alarm Level
Sets the PM alarm level.
[0 to 9999 / 0 / 1 k copies/step] 0: No PM alarm
Original Count Alarm (DFU)
Selects whether the PM alarm for the number of scans is enabled or not. If this is "1", the PM alarm function is enabled.
[0 = No / 1 = Yes]
5504*
Jam Alarm
Sets the alarm to sound for the specified jam level (document misfeeds are not included).
[0 to 3 / 3 / 1 step]
0: Zero (Off)
1: Low (2.5K jams) 2: Medium (3K jams) 3: High (6K jams)
5505*
Error Alarm
Sets the number of sheets to clear the error alarm counter.
The error alarm counter counts "1" when any SC is detected. However, the error alarm counter decreases by "1" when an SC is not detected during a set number of copied sheets (for example, default 5000 (C1b) or 10000 (C1c) sheets). The error alarm occurs when the SC error alarm counter reaches "5".
[0 to 255 / 45 (C2b), 50 (C1b/C1.5b), 60 (C2c), 100 (C1c/C1.5c) / 100
copies / step]
5507*Supply Alarm
Paper supply Alarm (0:Off 1:On)
Switches the control call on/off for the paper supply. (DFU)
0: Off, 1: On
0: No alarm.
1: Sets the alarm to sound for the specified number transfer sheets for each paper size (A3, A4, B4, B5, DLT, LG, LT, HLT)
Staple Supply Alarm (0:Off 1:On)
Switches the control call on/off for the stapler installed in the finisher. (DFU)
0: Off, 1: On
0: No alarm
1: Alarm goes off for every 1K of staples used.
Toner Supply Alarm (0:Off 1:On)
Switches the control call on/off for the toner end.
(DFU)
0: Off, 1: On
If you select "1" the alarm will sound when the copier detects toner end.
080
Toner Call Timing
Changes the timing of the "Toner Supply Call" via the @Remote, when the following conditions occur.
0: At replacement 1: At near end
128Interval: Others
The "Paper Supply Call Level: nn" SPs specify the paper control call interval for the referenced paper sizes. (DFU)
[250 to 10000 / 1000 / 1 Step]
132Interval: A3
133Interval: A4
134Interval: A5
141Interval: B4
142Interval: B5
160Interval: DLT
164Interval: LG
166Interval: LT
172Interval: HLT
5508CC Call
001Jam RemainsEnables/disables initiating a call. [0 to 1 / 1 / 1]
0: Disable
1: Enable
002Continuous Jams
003Continuous Door Open
011
Jam Detection: Time Length
Sets the length of time to determine the length of an unattended paper jam.
[3 to 30 / 10 / 1 minute]
012
Jam Detection Continuous Count
Sets the number of continuous paper jams required to initiate a call.
[2 to 10 / 5 / 1 time]
013
Door Open: Time Length
Sets the length of time the remains opens to determine when to initiate a call.
[3 to 30/ 10 / 1 minute]
5515*
SC/Alarm Setting
With @Remote in use, these SP codes can be set to issue an SC call when an SC error occurs. If this SP is switched off, the SC call is not issued when an SC error occurs.
001SC Call
[0 or 1 / 1 / 1]
002Service Parts Near End Call
003Service Parts End Call
004User Call
006Communication Information Test Call
007Machine Information Notice
008Alarm Notice
010Supply Automatic Ordering Call
011Supply Management Report Call
012Jam/Door Open Call
5516
Individual PM Part Alarm Call
With @Remote in use, these SP codes can be set to issue an PM alarm call when one of SP parts reaches its yield.
Disable/Enable Setting (0: Not send, 1: Send)[0 or 1 / 1 / - ]
004Percent yield for triggering PM alert[1 to 255 / 75 / 1 %/step]
5730
Extend Function Setting
DFU
5734PDF Setting
PDF/A Fixed [0 or 1 / 0 / - ]
0: No Limit
1: Limited
5741
Node Authentication Timuout
DFU
5743
Network Security Level
DFU
Rev. 11/15/2012​
System SP Tables-5
5744Management
DFU
5745
EcoCountTime
DFU
5747[Vertical Scroll Bar display mode] (See IMPORTANT below)
204Vertical Scroll Bar display mode0: Always display (Default)
1: Display when pressing “Program Key
205
Confirmation dialog display setting
NOTE:
  • If enabled, the “Page change confirmation dialog” is displayed when the user moves from the current page to a different one.
  • The “SSL certificate confirmation dialog” is displayed when an SSL-related problem occurs.
  • If the customer is using an internal (original) Web application, i.e. a fully trusted application, this SP can be set to “2” (do not display either dialog).
ValuePage change confirmation dialogSSL
0 (Default)DisplayDisplay
1Not displayDisplay
2Not DisplayNot display
3DisplayNot display
IMPORTANT: Only use these SP Modes with Browser Version 2.00.0 or newer, EXJS version 1.11.00 or newer, and Specification 2.01 or newer.
206Displayed but it should not be used (Not for field use).
5749
Import/Export NOTE: Refer to Section 3-13 Detailed Description of SP5749 for more information.
DFU
001Import
101Export
251Export Result Print (SP)
252Import Result Print (SP)
5792
MCS Debug SW
DFU
5793
ECS Debug SW
DFU
5801
Memory Clear
Resets NVRAM data to the default settings. Before executing any of these SP codes, print an SMC Report.
001All ClearInitializes items 2 to 15 below.
Engine
Initializes all registration settings for the engine and copy process settings.
SCS
Initializes default system settings, SCS (System Control Service) settings, operation display coordinates, and ROM update information.
IMH Memory Clr
Initializes the image file system. (IMH: Image Memory Handler)
MCS
Initializes the automatic delete time setting for stored documents.
(MCS: Memory Control Service)
006Copier applicationInitializes all copier application settings.
Fax Application
Initializes the fax reset time, job login ID, all TX/RX settings, local storage file numbers, and off-hook timer.
008
Printer Application
Initializes the printer defaults, programs registered, the printer SP bit switches, and the printer CSS counter.
009
Scanner Application
Initializes the defaults for the scanner and all the scanner SP modes.
010
Web Service
Deletes the Netfile (NFA) management files and thumbnails, and initializes the Job login ID.
Netfiles: Jobs to be printed from the document server using a PC and the DeskTopBinder software
011
NCS
Initializes the system defaults and interface settings (IP addresses also), the SmartDeviceMonitor for Admin settings, WebStatusMonitor settings, and the TELNET settings.
(NCS: Network Control Service)
012
R-FAX
Initializes the job login ID, SmartDeviceMonitor for Admin, job history, and local storage file numbers.
014Clear DCS SettingInitializes the DCS (Delivery Control Service) settings.
015
Clear UCS Setting
Initializes the UCS (User Information Control Service) settings.
016
MIRS Setting
Initializes the MIRS (Machine Information Report Service) settings.
017
CCS
Initializes the CCS (Certification and Charge-control Service) settings.
018
SRM Memory Clr
Initializes the SRM (System Resource Manager) settings.
019LCSInitializes the LCS (Log Count Service) settings.
020Web UapliInitializes the web user application settings.
021ECSInitializes ECS (Engine Control Service).
023AICSInitializes the AICS settings.
5802*
FreeRun
Performs a free run on the copier engine.
The correct paper should be loaded in the 1st tray or 2nd tray, but paper is not fed.
The main switch has to be turned off and on after using the free run mode for a test.
001TRAY1:A4LEF-
002TRAY2:A3-
003TRAY2:A4SEF-
5803
Input Check
Displays the signals received from sensors and switches.
p.3-251 "Input Check")
5804
Output Check
Turns on the electrical components individually for test purposes. (
p.3-263 "Output Check")
5805
Anti-Condensation Heater
[0 or 1 / 0 / -] 0:OFF / 1:ON
5810SC Reset
Fusing SC Reset
Resets all level A service call conditions, such as fusing errors. To clear the service call, touch "Execute" on the LCD, then turn the main power switch off/on.
5811MachineSerial
002DisplayDisplays the machine serial number.
003BCUInputs the serial number.
005FRAMDisplays the FRAM serial number.
5812*Service Tel. No. Setting
Inputs the telephone number of the CE (displayed when a service call condition occurs.)
Facsimile
Use this to input the fax number of the CE printed on the Counter Report (UP mode).
Supply
Inputs the telephone number of the supplier displayed on the user mode screen.
Operation
Allows the service center contact telephone number to be displayed on the user mode screen.
5816Remote Service
I/F Setting
Selects the remote service setting. [0 to 2 / 2 / 1 /step]
0: Remote service off
1: CSS remote service on 2: @Remote service on
CE Call
Performs the CE Call at the start or end of the service. [0 or 1 / 0 / 1 /step]
0: Start of the service 1: End of the service
NOTE: This SP is activated only when SP 5816-001 is set to “2”.
Function Flag
Enables or disables the remote service function. [0 to 1 / 0 / 1 /step]
0: Disabled, 1: Enabled
NOTE: This SP setting is changed to "1" after @Remote registration has been completed.
Communication Test Call
This SP issues a test call from a GW machine to determine whether it can communicate successfully with the call center after it has been set up for NRS. Successful return will be in the range 0 to 99.
Device Information Call
This SP issues a call to notify the NRS device information to the call center. Successful return will be in the range 0 to 99.
SSL Disable
Uses or does not use the RCG certification by SSL when calling the RCG. [0 to 1 / 0 / 1 /step]
0: Uses the RCG certification
1: Does no use the RCG certification
008
RCG Connect Timeout
Specifies the connect timeout interval when calling the RCG. [1 to 90 / 30 / 1 second /step]
009
RCG Write Timeout
Specifies the write timeout interval when calling the RCG. [0 to 100 / 60 / 1 second /step]
010
RCG Read Timeout
Specifies the read timeout interval when calling the RCG. [0 to 100 / 60 / 1 second /step]
011
Port 80 Enable
Enables/disables access via port 80 to the SOAP method. [0 or 1 / 0 / – ]
012
@Remote Communication Permission
[0 to 2 / 1 / 1 ]
0: Not permitted
1: Permitted
2: Partially limit
013
RFU (Remote Firmware Update) Timing
Selects the RFU timing. [0 or 1 / 1 / – ]
0: RFU is executed whenever update request is received.
1: RFU is executed only when the machine is in the sleep mode.
014
RCG Error Cause
[0 or 1 / 0 / – ]
0: Normal
1: Fails to reflect the client/server certificate settings by network failure to reboot. Transition to 0 on restart the machine.
021
RCG–C Registed
This SP displays the Embedded RC Gate installation end flag. 0: Installation not completed
1: Installation completed
023
Connect Type (N/M)
This SP displays and selects the Embedded RC Gate connection method. [0 or 1 / 0 / 1 /step
0: Internet connection
1: Dial-up connection
061
Cert. Expire Timing DFU
Proximity of the expiration of the certification.
062
Use Proxy
This SP setting determines if the proxy server is used when the machine communicates with the service center.
063
Proxy Host
This SP sets the address of the proxy server used for communication between Embedded RC Gate-N and the gateway. Use this SP to set up or display the customer proxy server address. The address is necessary to set up Embedded RC Gate-N.
  • The address display is limited to 128 characters. Characters beyond the 128 character are ignored.
  • This address is customer information and is not printed in the SMC report.
064
Proxy Port Number
This SP sets the port number of the proxy server used for communication between Embedded RC Gate-N and the gateway. This setting is necessary to set up Embedded RC Gate-N.
  • This port number is customer information and is not printed in the SMC report.
065Proxy User Name
This SP sets the HTTP proxy certification user name.
  • The length of the name is limited to 31 characters. Any character beyond the 31st character is ignored.
  • This name is customer information and is not printed in the SMC report.
066Proxy Password
This SP sets the HTTP proxy certification password.
  • The length of the password is limited to 31 characters. Any character beyond the 31st character is ignored.
067
CERT: Up State
Displays the status of the certification update.
0The certification used by Embedded RC Gate is set correctly.
The certification request (setAuthKey) for update has been received from the GW URL and certification is presently being updated.
The certification update is completed and the GW URL is being notified of the successful update.
The certification update failed, and the GW URL is being notified of the failed update.
The period of the certification has expired and new request for an update is being sent to the GW URL.
A rescue update for certification has been issued and a rescue certification setting is in progress for the rescue GW connection.
The rescue certification setting is completed and the GW URL is being notified of the certification update request.
13
The notification of the request for certification update has completed successfully, and the system is waiting for the certification update request from the rescue GW URL.
The notification of the certification request has been received from the rescue GW controller, and the certification is being stored.
15
The certification has been stored, and the GW URL is being notified of the successful completion of this event.
16
The storing of the certification has failed, and the GW URL is being notified of the failure of this event.
17
The certification update request has been received from the GW URL, the GW URL was notified of the results of the update after it was completed, but a certification error has been received, and the rescue certification is being recorded.
18
The rescue certification of No. 17 has been recorded, and the GW URL is being notified of the failure of the certification update.
068
CERT: Error
Displays a number code that describes the reason for the request for update of the certification.
0Normal. There is no request for certification update in progress.
Request for certification update in progress. The current certification has expired.
An SSL error notification has been issued. Issued after the certification has expired.
Notification of shift from a common authentication to an individual certification.
4Notification of a common certification without ID2.
5Notification that no certification was issued.
6Notification that GW URL does not exist.
069CERT: Up IDThe ID of the request for certification.
083Firm Up StatusDisplays the status of the firmware update.
085
Firm Up User Check
This SP setting determines if the operator can confirm the previous version of the firmware before the firmware update execution. If the option to confirm the previous version is selected, a notification is sent to the system manager and the firmware update is done with the firmware files from the URL.
086
Firmware Size
Allows the service technician to confirm the size of the firmware data files during the firmware update execution.
087
CERT: Macro Ver.
Displays the macro version of the @Remote certification.
088
CERT: PAC Ver.
Displays the PAC version of the @Remote certification.
089
CERT: ID2 Code
Displays ID2 for the @Remote certification. Spaces are displayed as underscores (_). Asteriskes (*) indicate that no @Remote certification exists. "000000 " indicates "Common certification".
090
CERT: Subject
Displays the common name of the @Remote certification subject. CN = the following 17 bytes. Spaces are displayed as underscores (_).
Asterisks (*) indicate that no @Remote certification exists. "000000 " indicates "Common certification".
091
CERT: SerialNo.
Displays serial number for the @Remote certification. Asterisks (*) indicate that no
092
CERT: Issuer
Displays the common name of the issuer of the
@Remote certification. CN = the following 30 bytes. Asteriskes () indicate that no @Remote certification exists.
093
CERT: Valid Start
Displays the start time of the period for which the current @Remote certification is enabled.
094
CERT: Valid End
Displays the end time of the period for which the current @Remote certification is enabled.
096
Server CN Check
Not used
096
GW Host
Not used
097
GW URL Path
Not used
099
Debug RescueG/WURL Set
Not used
102*CERT: Encrypt Level
Displays the encryption level for the NRS certificate. [1 or 2 / 1 / – ]
1: Indicates that the certificate encryption level is 512-bit. 2: Indicates that the certificate encryption level is 2048-bit.
150
Selection Country
Not used
151
Line Type Automatic Judgment
Not used
152
Line Type Judgment Result
Not used
153
Selection Dial / Push
Not used
154
Outside Line Outgoing Number
Not used
156
Dial Up User Name
Not used
157
Dial Up Password
Not used
161
Local Phone Number
Not used
162
Connection Timing Adjustment Incoming
Not used
163
Access Point
Not used
164
Line Connecting
Not used
173
Modem Serial No.
Not used
174
Retransmission Limit
Not used
186
RCG-C M DebugBitSW
Not used
187
FAX TX Priority
Not used
200
Manual Polling
Executes the manual polling.
201
Regist Status
Displays a number that indicates the status of the @Remote service device. 0: Neither the @Remote device nor Embedded RCG Gate is set.
1: The Embedded RCG Gate is being set. Only Box registration is completed. In this status, @Remote device cannot communicate with this device.
2: The Embedded RCG Gate is set. In this status, the @Remote device cannot communicate with this device.
3: The @Remote device is being set. In this status the Embedded RCG Gate cannot be set.
4: The @Remote module has not started.
202
Letter Number
Allows entry of the request number needed for the Embedded RCG Gate.
203
Confirm Execute
Executes the confirmation request to the @Remote Gateway.
204Confirm Result
Displays a number that indicates the result of the confirmation executed with SP5816-203.
0: Succeeded
1: Confirmation number error 2: Registration in progress
3: Proxy error (proxy enabled) 4: Proxy error (proxy disabled)
5: Proxy error (Illegal user name or password) 6: Communication error
7: Certification update error 8: Other error
9: Confirmation executing
205
Confirm Place
Displays the result of the notification sent to the device from the Gateway in answer to the confirmation request. Displayed only when the result is registered at the Gateway.
206Register ExecuteExecutes "Embedded RCG Registration".
207
Register Result
Displays a number that indicates the registration result. 0: Succeeded
9: Registration executing
208
Error Code
Displays a number that describes the error code that was issued when either SP5816-204 or SP5816-207 was executed.
CauseCodeMeaning
Illegal Modem Parameter
-11001Chat parameter error
-11002Chat execution error
-11003Unexpected error
Operation Error, Incorrect Setting
-12002
Inquiry, registration attempted without acquiring device status.
-12003
Attempted registration without execution of an inquiry and no previous registration.
-12004
Attempted setting with illegal entries for certification and ID2.
-12005
@Remote communication is prohibited.
The device has an Embedded RC gate-related problem.
-12006
A confirmation request was made after the confirmation had been already completed.
-12007
The request number used at registration was different from the one used at confirmation.
-12008
Update certification failed because mainframe was in use.
-12009
ID2 mismatch between an individual certification and NVRAM
-12010Certification area is not initialized.
Error Caused by Response from GW URL
-2385
Attempted dial up overseas without the correct international prefix for the telephone number.
-2387Not supported at the Service Center
-2389Database out of service
-2390Program out of service
-2391Two registrations for same device
-2392Parameter error
-2393RCG device not managed
-2394Device not managed
-2395Box ID for RCG device is illegal
-2396Device ID for RCG device is illegal
-2397Incorrect ID2 format
-2398Incorrect request number format
209
Instl Clear
Releases the machine from its Embedded RCG Gate setup.
NOTE: Turn off and on the main power switch after this setting has been changed.
250CommLog PrintPrints the communication log.
5821*Remote Service Address
RCG IP Address
Sets the IP address of the RCG (Remote Communication Gate) destination for call processing at the remote service center. [00000000h to FFFFFFFFh / 00000000h / 1]
RCG Port
Sets the port number of the RCG (Remote Communication Gate) destination for call processing at the remote service center. [0 to 65535 / 443 / 1]
RCG URL Path
Sets the URL path of the RCG (Remote Communication Gate) destination for call processing at the remote service center. [0 to 16 characters / /RCG/services/ /-]
5824
NV-RAM Data Upload
Uploads the NVRAM data to an SD card. Push Execute.
Note: When uploading data in this SP mode, the front door must be open.
5825
NV-RAM Data Download
Downloads data from an SD card to the NVRAM in the machine. After downloading is completed, remove the card and turn the machine power off and on.
5828Network Setting
IPv4 Address (Ethernet/IEEE 802.11)
This SP allows you to check and reset the IPv4 address for Ethernet and wireless LAN (802.11): aaa.bbb.ccc.ddd
IPv4 Subnet Mask (Ethernet/IEEE 802.11)
This SP allows you to check and reset the IPv4 subnet mask for Ethernet and wireless LAN (802.11): aaa.bbb.ccc.ddd
IPv4 Default Gateway (Ethernet/IEEE 802.11)
This SP allows you to check and reset the IPv4 default gateway used by the network for Ethernet and wireless LAN (802.11): aaa.bbb.ccc.ddd
DHCP (Ethernet/IEEE 802.11)
This SP code allows you check and change the setting that determines whether the IP address is used with DHCP on an Ethernet or wireless (802.11) LAN network.
[0 to 1 / 1 / 1]
0: Not used (manual setting) 1: Used
021
Active IPv4 Address
This SP allows you to check the IPv4 address that was used when the machine started up with DHCP.
022
Active IPv4 Subnet Mask
This SP allows you to check the IPv4 subnet mask setting that was used when the machine started up with DHCP.
023
Active IPv4 Gateway Address
This SP allows you to check the IPv4 default gateway setting that was used when the machine started up with DHCP.
1284 Compatibility
050
(Centro)
Enables and disables bi-directional communication on the parallel connection between the machine and a computer.
[0 to 1 / 1 / 1 ]
0:Off, 1: On
052 ECP (Centro)
Disables and enables the ECP feature (1284 Mode) for data transfer.
[0 to 1 / 1 / 1]
065 Job Spooling
Switches the job spooling on and off. [0 to 1 / 0 / 1]
0: No spooling, 1: Spooling enabled
Job Spooling Clear: Start
066
Time
This SP determines whether the job interrupted at power off is resumed at the next power on. This SP operates only when SP5828-065 is set to "1".
[0 to 1 / 1 / 1]
1: OFF Resumes printing spooled jog. 0: ON Clears spooled job.
Job Spooling (Protocol)
This SP determines whether job spooling is enabled or disabled for each protocol. This is a 8-bit setting.
[0 to 1 / 1 / 1]
069
  1. LPR 4 BMLinks (Japan Only)
  2. FTP (Not Used) 5 DIPRINT
  3. IPP 6 Reserved (Not Used)
  4. SMB 7 Reserved (Not Used)
087 @Remote Protocol Cnt (DFU)
090
TELNET (0:OFF 1:ON)
Disables or enables Telnet operation. If this SP is disabled, the Telnet port is closed.
[0 to 1 / 1 / 1]
0: Disable, 1: Enable
091
Web
(0:OFF 1:ON)
Disables or enables the Web operation. [0 to 1 / 1 / 1]
145
Active IPv6 Link Local Address
This is the IPv6 local address referenced on the Ethernet or wireless LAN (802.11) in the format: "Link-Local address" + "Prefix Length"
The IPv6 address consists of a total 128 bits configured in 8 blocks of 16 bits each. These notations can be abbreviated. See "Note: IPV6 Addresses " below this table.
147
Active IPv6 Stateless Address 1
These SPs are the IPv6 stateless addresses (1 to 5) referenced on the Ethernet or wireless LAN (802.11) in the format:
"Stateless Address" + "Prefix Length"
149
Active IPv6 Stateless Address 2
151
Active IPv6 Stateless Address 3
153
Active IPv6 Stateless Address 4
155
Active IPv6 Stateless Address 5
156
IPv6 Manual Address
This SP is the IPv6 manually set address referenced on the Ethernet or wireless LAN (802.11) in the format:
"Manual Set Address" + "Prefix Length"
The IPv6 address consists of a total 128 bits configured in 8 blocks of 16 bits each. These notations can be abbreviated. See "Note: IPV6 Addresses" below this table.
158
IPv6 Gateway Address
This SP is the IPv6 gateway address referenced on the Ethernet or wireless LAN (802.11). The IPv6 address consists of a total 128 bits configured in 8 blocks of 16 bits each. These notations can be abbreviated. See "Note: IPV6 Addresses" below this table.
Ethernet and the Wireless LAN (802.11) reference the IPV6 "Link-Local address + Prefix Length". The IPV6 address consists of 128 bits divided into 8 blocks of 16 bits: aaaa:bbbb:cccc:dddd:eeee:ffff:gggg:hhhh:
The prefix length is inserted at the 17th byte (Prefix Range: 0x0 to 0x80). The initial setting is 0x40 (64).
For example, the data: "2001123456789012abcdef012345678940h" is expressed: "2001:1234:5678:9012:abcd:ef01:2345:6789": prefixlen 64
However, the actual IPV6 address display is abbreviated according to the following rules.
Rules for Abbreviating IPV6 Addresses
  1. The IPV6 address is expressed in hexadecimal delimited by colons :)) with the following characters:
  2. A colon is inserted as a delimiter every 4th hexadecimal character. fe80:0000:0000:0000:0207:40ff:0000:340e
  3. The notations can be abbreviated by eliminating zeros where the MSB and digits following the MSB are zero. The example in "2" above, then, becomes fe80:0:0:0207:40ff:0:340e
  4. Sections where only zeros exist can be abbreviated with double colons :):). This abbreviation can be done also where succeeding sections contain only zeros (but this can be done only at one point in the address). The example in "2" and "3" above then becomes:
0123456789abcdefABCDEF
fe80::207:40ff:0:340e (only the first null sets zero digits are abbreviated as "::")
-or-
fe80:0:0:0:207:40ff::340e (only the last null set before "340e" is abbreviated as "::")
161
IPv6 Stateless Auto Setting
Enable or disables the automatic setting for IPv6 stateless.
[0 or 1 / 1 / 1]
1: Enable, 0: Disable
236
Web Item visible
Displays or does not display the Web system items.
[0 x 0000 to 0 x ffff / 0 x ffff] 0: Not displayed, 1: Displayed bit0: Net RICOH
bit1: Consumable Supplier bit2-15: Reserved (all)
237
Web shopping link visible
Displays or does not display the link to Net RICOH on the top page and link page of the web system.
[0 to 1 / 1 / 1]
0: Not display, 1:Display
238
Web supplies Link visible
Displays or does not display the link to Consumable Supplier on the top page and link page of the web system.
[0 to 1 / 1 / 1]
239
Web Link1 Name
This SP confirms or changes the URL1 name on the link page of the web system. The maximum characters for the URL name are 31 characters.
240
Web Link1 URL
his SP confirms or changes the link to URL1 on the link page of the web system. The maximum characters for the URL are 127 characters.
241
Web Link1 visible
Displays or does not display the link to URL1 on the top page of the web system.
[0 to 1 / 1 / 1]
242Web Link2 NameSame as "-239"
243Web Link2 URLSame as "-240"
244Web Link2 visibleSame as "-241"
249
DHCPv6 DUID
Sets DHCPv6 DUID. [0000000000000000000000000000h to FFFFFFFFFFFFFFFFFFFFFFFFFFFFh / 0000000000000000000000000000h / -]
5832
HDD
Enter the SP number for the partition to initialize, then press #. When the execution ends, cycle the machine off and on.
001HDD Formatting (All)
002HDD Formatting (IMH)
003HDD Formatting (Thumbnail)
004HDD Formatting (Job Log)
005HDD Formatting (Printer Fonts)
006HDD Formatting (User Info)
007Mail RX Data
008Mail TX Data
009HDD Formatting (Data for Design)
010HDD Formatting (Log)
011HDD Formatting (Ridoc I/F) (for Ridoc Desk Top Binder)
5836*Capture Setting
Capture Function (0:Off 1:On)
With this function disabled, the settings related to the capture feature cannot be initialized, displayed, or selected.
[0 to 1 / 0 / 1]
Panel Setting
Determines whether each capture related setting can be selected or updated from the initial system screen.
[0 to 1 / 0 / 1]
The setting for SP5836-001 has priority.
072
Reduction for Copy B&W Text
[0 to 6 / 0 / 1]
0:1, 1:1/2, 2:1/3, 3:1/4, 6:2/3
073
Reduction for Copy B&W Other
[0 to 6 / 0 / 1]
075
Reduction for Printer B&W
[0 to 6 / 0 / 1]
0 1, 1:1/2, 2:1/3, 3:1/4, 6:2/3
078Reduction for Printer B&W 12001: 1/2, 3: 1/4, 4: 1/6, 5: 1/8
082
Format for Copy B&W Text
[0 to 3 / 1 / 1]
0: JFIF/JPEG, 1: TIFF/MMR, 2:
TIFF/MH, 3: TIFF/MR
083
Format Copy B&W Other
[0 to 3 / 1 / 1]
TIFF/MH, 3: TIFF/MR
085
Format for Printer B&W
[0 to 3 / 1 / 1]
TIFF/MH, 3: TIFF/MR
091
Default for JPEG[5 to 95 / 50 / 1]
Sets the JPEG format default for documents sent to the document management server with the MLB, with JPEG selected as the format. Enabled only when optional File Format Converter (MLB: Media Link Board) is installed.
101
Primary srv IP address
Sets the IP address for the primary capture server. This is basically adjusted by the remote system.
102
Primary srv scheme
103
Primary srv port number
104
Primary srv URL path
111
Secondary srv IP address
Sets the IP address for the secondary capture server. This is basically adjusted by the remote system.
112
Secondary srv scheme
113
Secondary srv port number
114
Secondary srv URL path
122Reso: Copy (Mono)[0 to 255 / 3 / 1/step]
Selects the resolution for BW copy mode. This is basically adjusted by the remote system.
0: 600dpi/ 1: 400dpi/ 2: 300dpi/ 3: 200dpi/ 4: 150dpi/ 5: 100dpi
124
Reso: Print (Mono)
Selects the resolution for BW print mode. This is basically adjusted by the remote system.
126
Reso: Fax (Mono)
Selects the resolution for BW fax mode. This is basically adjusted by the remote system.
0: 600dpi/ 1: 400dpi/ 2: 300dpi/ 3: 200dpi/ 4: 150dpi/ 5: 100dpi/ 6: 75dpi
127
Reso: Scan (Color)
[0 to 255 / 4 / 1/step]
Selects the resolution for color scanning mode. This is basically adjusted by the remote system.
128
Reso: Scan (Mono)
Selects the resolution for BW scanning mode. This is basically adjusted by the remote system.
141
All Addr Info Switch
[0 or 1 / 1 / -]
0: Off, 1: On
Turns on or off the all address information transmission for the captured resources.
142Stand-by Doc Max Number[10 to 9999 / 2000 / 1/step]
Selects the maximum number of captured documents to be transmitted to the document server.
5840*IEEE 802.11
Channel MAX
Sets the maximum range of the bandwidth for the wireless LAN. This bandwidth setting varies for different countries.
[1 to 14 / 11 (NA), 13 (EU), 14 (JPN) / 1]
JPN: 1 to 14, NA: 1 to 11, EU: 1 to 13
Channel MIN
Sets the minimum range of the bandwidth for operation of the wireless LAN. This bandwidth setting varies for different countries.
[1 to 14 / 1 / 1]
008
Transmission speed[0 x 00 to 0 x FF / 0 x FF to Auto / -]
0 x FF to Auto [Default] 0 x 11 - 55M Fix
0 x 10 - 48M Fix
0 x 0F - 36M Fix
0 x 0E - 18M Fix
0 x 0D - 12M Fix 0 x 0B - 9M Fix 0 x 0A - 6M Fix
0 x 07 - 11M Fix
0 x 05 - 5.5M Fix
0 x 08 - 1M Fix
0 x 13 - 0 x FE (reserved)
0 x 12 - 72M (reserved)
0 x 09 - 22M (reserved)
011
WEP Key Select
Selects the WEP key. Bit 1 and 0
00: Key1, 01: Key2 (Reserved),
10: Key3 (Reserved), 11: Key4(Reserved)
This SP is displayed only when the IEEE802.11 card is installed.
013
RTS/CTS Thresh
Adjusts the RTS/CTS threshold for the IEEE802.11 card. [0 to 3000 / 2432 / 1]
042
Fragment Thresh
Adjusts the fragment threshold for the IEEE802.11 card. [256 to 2346 / 2346 / 1]
043
11g CTS to Self
Determines whether the CTS self function is turned on or off. [0 to 1 / 1 / 1] 0: Off, 1: On
044
11g Slot Time
Selects the slot time for IEEE802.11. [0 to 1 / 0 / 1] 0: 20
m, 1: 9
m
045
WPA Debug Lvl
Selects the debug level for WPA authentication application. [1 to 3 / 3 / 1] 1: Info, 2: warning, 3: error
5841*
Supply Name Setting
Press the User Tools key. These names appear when the user presses the Inquiry button on the User Tools screen.
001Toner Name Setting: Black
007OrgStamp
011StapleStd1
012StapleStd2
013StapleStd3
014StapleStd4
021StapleBind1
022StapleBind2
023StapleBind3
5842*
GWWS Analysis (DFU)
BitGroups
0System & other groups (LSB)
This is a debugging tool. It
1Capture related
sets the debugging output2Certification related
mode of each Net File
3Address book related
process.
Bit SW 0011 11114Machine management related
5Output related (printing, delivery)
6Repository related
Setting 1
Default: 00000000 – do not change
Setting 2
Adjusts the debug program mode setting. Bit7: 5682 mmseg-log setting
0: Date/Hour/Minute/Second
1: Minute/Second/Msec.
0 to 6: Not used
5844USB
Transfer Rate
Sets the speed for USB data transmission. [0 x 01 or 0 x 04 / 0 x 04 /-]
0 x 01 [Full Speed], 0 x 04 [Auto Change]
Vendor ID
Sets the vendor ID:
Initial Setting: 0x05A Ricoh Company [0x0000 to 0xFFFF/1] (DFU)
Product ID
Sets the product ID. [0x0000 to 0xFFFF/1] (DFU)
Device Release No.
Sets the device release number of the BCD (binary coded decimal) display. [0000 to 9999 / 100 / 1] (DFU)
Enter as a decimal number. NCS converts the number to hexadecimal number recognized as the BCD.
005Fixed USB Port
This SP standardizes for common use the model name and serial number for USB PnP (Plug & Play). It determines whether the driver requires
re-installation. [0 to 2 / 0 / 1]
1: Level 1
2: Level 2
006PnP Model Name
This SP sets the model name to be used by the USB PnP when "Function Enable (Level 2) is set so the USB Serial No. can have a common name (SP5844-5).
Default: Laser Printer (up to 20 characters allowed).
007PnP Serial Number
This SP sets the serial number to be used by the USB PnP when "Function Enable (Level 2)
set so the USB Serial No. can have a common name (SP5844-5). Default: None (up to 12 characters allowed for entry).
  • Make sure that this entry is the same as the serial number in use.
  • At initialization the serial number generated from the model name is used, not the setting of this SP code.
  • At times other than initialization, the value set for this SP code is used.
100Notify Unsupport
This SP determines whether an alert message appears on the control panel when a USB device (unsupported device) that cannot use an A-connector is connected.
[0 to 1 / 1 / 1]
0: Function enable
1: Function disable
  • An unsupported device is a device that cannot use the functions of the USB device. For example, a USB mouse cannot be used even if it connected.
  • If the PictBridge option is not mounted, even if a digital camera is connected it cannot be used because it is an unsupported device.
5845*
Delivery Server Setting
These are delivery server settings.
FTP Port No.
[0 to 65535 / 3670 / 1]
IP Address (Primary)
Use this SP to set the Scan Router Server address. The IP address under the transfer tab can be used with the initial system setting.
[Range: 000.000.000.000 to 255.255.255.255]
Delivery Error Display Time
Use this setting to set the length of time that the message is shown when a test error occurs during document transfer with the NetFile application and an external device.
[0 to 999 / 300 / 1 sec]
008
IP Address (Secondary)
Sets the IP address that is given to the computer that is the secondary delivery server for Scan Router. This SP lets you set only the IP address, and does not refer to the DNS setting.
009
Delivery Server Model
Lets you change the model of the delivery server that is registered by the I/O device.
[0 to 4 / 0 / 1 step]
0: Unknown
1: SG1 Provided
2: SG1 Package
3: SG2 Provided
4: SG2 Package
010
Delivery Svr. Capability
Changes the functions that the registered I/O device can do. [0 to 255 / 0 / 1 step]
Bit7 = 1 Comment information exits
Bit6 = 1 Direct specification of mail address possible Bit5 = 1 Mail RX confirmation setting possible
Bit4 = 1 Address book automatic update function exists Bit3 = 1 Fax RX delivery function exists
Bit2 = 1 Sender password function exists
Bit1 = 1 Function to link MK-1 user and Sender exists
Bit0 = 1 Sender specification required (if set to 1, Bit6 is set to "0")
011
Delivery Svr.Capability (Ext)
These settings are for future use. They will let you increase the number of registered devices (in addition to those registered for SP5845 010).
There are eight bits (Bit 0 to Bit 7). All are unused at this time.
013Server Scheme (Primary)
014Server port Number (Primary)[1 to 65535 / 80 / 1]
015Server URL Path (Primary)
016Server Scheme (Secondary)
017Server Port Number(Secondary)[1 to 65535 / 80 / 1]
018Server URL Path (Secondary)
022
Rapid Sending Control
[0 to 1 / 1 / -]
Enables or disables the prevention function for the continuous data sending error.
5846*UCS Setting
Machine ID (for Delivery Server)
Displays the unique device ID in use by the delivery server directory. The value is only displayed and cannot be changed.
This ID is created from the NIC MAC or IEEE 1394 EUI. The ID is displayed as either 6-byle or 8-byte binary.
Machine ID Clear (for Delivery Server)
Clears the unique ID of the device used as the name in the file transfer directory. Execute this SP if the connection of the device to the delivery server is unstable. After clearing the ID, the ID will be established again automatically by cycling the machine off and on.
Maximum Entries
Changes the maximum number of entries that UCS can handle. [2000 to 20000 / 2000 / 1 step]
If a value smaller than the present value is set, the UCS managed data is cleared, and the data (excluding user code information) is displayed.
Delivery Server Retry Timer
Sets the interval for retry attempts when the delivery server fails to acquire the delivery server address book.
0: No retries
Delivery Server Retry Times
Sets the number of retry attempts when the delivery server fails to acquire the delivery server address book.
[0 to 255 / 0 / 1step]
008
Delivery Server Maximum Entries
Lets you set the maximum number of account entries and information about the users of the delivery server controlled by UCS.
010
LDAP Search Timeout
Sets the length of the time-out for the search of the LDAP server. [1 to 255 / 60 /1 step]
020
WSD Maximum Entries
WSD (Web Services on Devices) is the Microsoft standard for connectivity to web-service enabled devices.
[50 to 250 / 250 / 1]
021
Folder Auth Change
This SP determines whether the user login information (Login User name and Password) or address (destination setting in the address book for
Scan-to-SMB) is used to permit folder access. The machine must be cycled off/on for this setting to take effect if it is changed.
[0 to 1 / 0 / 1]
0: Login User
Uses operator login information (initial value of main machine) 1: Destination
Uses address authorization information
022
Initial Value of Upper Limit Count
[0 to 999999 / 500 / 1]
040
Addr Book Migration (USB -> HDD)
This SP moves the address book data from the SD card or flash ROM on the controller board to the HDD. You must cycle the machine off and on after executing this SP.
  1. Turn the machine off.
  2. Install the HDD.
  3. Turn the machine on. 4. Do SP5846 040.
  4. Turn the machine off/on.
    • Executing this SP overwrites any address book data already on the HDD with the data from the flash ROM on the controller board.
    • We recommend that you back up all directory information to an SD card with SP5846-051 before you execute this SP.
    • After the address book data is copied to HDD, all the address book data is deleted from the flash ROM. If the operation fails, the data is not erased from the flash ROM.
041Fill Addr Acl Info.
This SP must be executed immediately after installation of an HDD unit in a basic machine that previously had no HDD. The first time the machine is powered on with the new HDD installed, the system automatically takes the address book from the NVRAM and writes it onto the new HDD. However, the new address book on the HDD can be accessed only by the system administrator at this stage. Executing this SP by the service technician immediately after power on grants full address book access to all users.
Procedure
  2. Install the new HDD.
  4. The address book and its initial data are created on the HDD automatically. However, at this point the address book can be accessed by only the system administrator or key operator.
  5. Enter the SP mode and do SP5846 041. After this SP executes successfully, any user can access the address book.
043Addr Book Media
Displays the slot number where an address book data is in. [0 to 30 / - /1]
0: Unconfirmed
1: SD Slot 1
2: SD Slot 2
4: USB Flash ROM
20: HDD
30: Nothing
046
Initialize All Setting & Addr Book
Initializes all settings and the address book.
047
Initialize Local Address Book
Clears all of the address information from the local address book of a machine managed with UCS.
048
Initialize Delivery Addr Book
Push [Execute] to delete all items (this does not include user codes) in the delivery address book that is controlled by UCS.
049
Initialize LDAP Addr Book
Push [Execute] to delete all items (this does not include user codes) in the LDAP address book that is controlled by UCS.
050
Initialize All Addr Book
Clears everything (including users codes) in the directory information managed by UCS. However, the accounts and passwords of the system administrators are not deleted.
051
Backup All Addr Book
Copies all directory information to the SD card. Do this SP before replacing the controller board or HDD. The operation may not succeed if the controller board or HDD is damaged.
052
Restore All Addr Book
Copies back all directory information from the SD card to the flash ROM or HDD. Upload the address book from the old flash ROM or HDD with SP5846-51 before removing it. Do SP5846 52 after installing the new HDD.
053
Clear Backup Info
Deletes the address book uploaded from the SD card in the slot 2. Deletes only the files uploaded for that machine. This feature does not work if the card is write-protected.
Note: After you do this SP, go out of the SP mode, turn the power off. Do not remove the SD card until the Power LED stops flashing.
060
Search Option
This SP uses bit switches to set up the fuzzy search options for the UCS local address book.
BitMeaning
0Checks both upper/lower case characters
Japan Only
4--- Not Used ---
5--- Not Used ---
6--- Not Used ---
7--- Not Used ---
062
Complexity Option 1
Use this SP to set the conditions for password entry to access the local address book. Specifically, this SP limits the password entry to upper case and sets the length of the password.
[0 to 32 / 0 / 1step]
  • This SP does not normally require adjustment.
  • This SP is enabled only after the system administrator has set up a group password policy to control access to the address book.
