Ricoh MP4002/5002 service manual Part 13
Rev. 8/21/2012
PM Tables
1-Bin Tray Unit
Appendix: Preventive Maintenance Tables
D632EMNote
1-Bin Tray Unit
RollersCDry or damp cloth
Copy TrayCDry or damp cloth
SensorsCBlower brush
Side Tray
D635EMNote
Side Tray
Shift Tray
D633EMNote
Shift Tray
APPENDIX:​
SERVICE PROGRAM MODE TABLES​
REVISION HISTORY
PageDateAdded/ Updated/ New
8211/15/2012SP5104 Default changed to 1 Blinks, added Note to SP5083
82 ~ 8308/21/2012SP5083 [LED Light Switch Setting - Toner Near End]
10508/27/2012Added SP5747 204 and 205.
  1. APPENDIX: SERVICE PROGRAM MODE TABLES​
    1. SYSTEM SP TABLE-1​
      Appendix: Service Program Mode Tables
      1. SP1-XXX: FEED​
        1001*
        Leading Edge Registration:
        Adjusts the leading edge registration by changing the registration clutch operation timing.
        001Tray: Plain
        [–9 to 9/ 0 / 0.1 mm step]
        002Tray: Thick 1
        003Tray: Thick 2
        004By-pass: Plain
        005By-pass: Thick 1
        006By-pass: Thick 2
        007Duplex: Plain
        008Duplex: Thick 1
        1002*
        Side-to-Side Registration
        Adjusts the side to side registration by changing the laser main scan start position for each mode.
        001By-pass
        [–4 to 4/ 0 / 0.1 mm step]
        002Tray 1
        003Tray 2
        004Tray 3
        005Tray 4
        006LCT
        007Duplex
        1003*
        Registration Buckle Adjustment
        Adjusts the paper feed motor timing. Paper feed motor timing determines the amount of paper buckle at Registration. (A "+" setting causes more buckling.)
        001Tray 1: Plain
        [-9 to 5 / -4 / 1 mm step]
        002Tray 1: Thick 1
        003Tray 1: Thick 2
        004Tray 2, 3, 4: Plain
        005Tray 2, 3, 4: Thick1
        006Tray 2, 3, 4: Thick2
        007By-pass: Plain
        [-9 to 5 / -2 /1 mm step]
        008By-pass: Thick 1
        009By-pass: Thick 2
        010Duplex: Plain[-9 to 5 / -4 / 1 mm step]
        011Duplex: Thick 1[-9 to 5 / -3 / 1 mm step]
        012LCT: Plain
        013LCT: Thick1
        014LCT: Thick2
        1007*
        By-pass Paper Size Detection
        Controls paper size detection for the by-pass feed table.
        001Detection Timing[-15 to 15 / 0 / 5 mm step]
        LG Detection
        [0 to 1 / 0 / 1]
        0: LT SEF, 1: LG
        1103*
        Fusing Idling
        Switches fusing idling on/off. When on, printing will not start until enough time has elapsed so the hot roller can reach optimum temperature. This ensures even heat on the hot roller.
        Switch on if fusing on the 1st and 2nd copies is incomplete (this may occur if the room is cold.). You must switch SP1103-1 ON before you set the fusing interval with SP1103-2.
        001Enable Fusing Idling0 = Off, 1 = On
        002Interval[0 to 60 / 30 / 1 sec.]
        Idling Time at Every Job
        Sets the machine to fusing idling only for 30 sec. for every job (when the original is set on the ARDF, when the ARDF cover is opened, etc.) and the fusing unit has reached the reload temperature (optimum temperature for operation).
        [0 to 30 / 0 / 1 sec.]
        0: No idling done before a job.
        1104*
        Fusing Temperature Control
        On-Off/Phase
        Selects the fusing temperature control method. After changing this setting, be sure to turn the machine off and on again with the main power switch to enable the new setting.
        [0 to 1 / 0 / 1]
        0: Normal (ON/OFF control). Allows full application from ac power supply to bring the hot roller up to the target fusing temperature then shuts off.
        Determines the on-time from the present temperature (detected by the thermistor on the hot roller) and the temperature of 1 cycle before.
        1: Phase (hysterisis) control. Sets the upper and lower limits for the temperature; at the lower temperature the fusing lamp is on and at the higher temperature the fusing lamp is off.
        Change this setting to "0" only if the user has excessive electrical noise or interference on the power supply line. Such interference can cause voltage to drop when power is applied using the ON/OFF control method.
        Interference can be caused by the general poor quality of the power supply lines, or if the machine is sharing a power supply with other electrical devices such as fluorescent lights. Before changing this setting, make sure that the machine is connected to a power supply not shared by other electrical equipment.
        • Selecting Phase control ("1") could cause the fusing temperature control board to emit low pitched noise
        1105*
        Fusing Temperature Adjustment
        Allows adjustment of the hot roller temperature at the center and ends of the roller for the quality or thickness of the paper. The hot roller in this machine has two fusing lamps: one heats the center of the roller, the other heats both ends. Each fusing lamp can be adjusted separately.
        The "re-load temperature" is the "print ready temperature". When the fusing temperature exceeds this setting, the machine can operate. Do not set up a re-load temperature (Re-load Temp. = Fusing. Temp – SP Value.) that is higher than the SP1-105-2 setting.
        Roller Center
        C1b/C1.5b: [100 to 170 / 140 / 1 deg]
        C1c/C1.5c: [100 to 170 / 150 / 1 deg]
        Adjusts the fusing temperature at the center of the hot roller.
        Roller Ends
        C1b/C1.5b: [100 to 170 / 145 / 1 deg]
        C1c/C1.5c: [100 to 170 / 155 / 1 deg]
        Adjusts the fusing temperature at the ends of the hot roller.
        Re-load Temp. Minus: Roller Center[0 to 60 / 0 / 1 deg]
        Sets the reload temperature for the center of the hot roller. This setting depends on the target temperature.
        Reload temp. = Target Temp – This SP Setting
        Re-load Temp. Minus: Roller Ends[0 to 60 / 0 / 1 deg]
        Sets the reload temperature for the ends of the hot roller. This setting depends on the target temperature.
        005 to
        022
        The following SPs adjust the fusing temperature at the center or ends of the hot roller for each paper type.
        Roller Center: M-Thick
        Roller Ends: M-Thick
        C1b/C1.5b: [100 to 170 / 150 / 1 deg]
        C1c/C1.5c: [100 to 170 / 160 / 1 deg]
        007Roller Center: Thick 1
        [100 to 170 / 130 / 1 deg]
        008Roller Ends: Thick 1
        009Roller Center: Thick 2
        [100 to 170 / 150/ 1 deg]
        010Roller Ends: Thick 2
        • Do not set a temperature that is higher than the setting for SP1105 1 (Roller Center: Trays)
        • Do not set a temperature that is higher than the setting for SP1105 2 (Roller Ends: Trays)
        • Appendix: Service Program Mode Tables
        011
        Roller Center: Thin
        C1b/C1.5b: [100 to 170 / 130 / 1 deg]
        C1c/C1.5c: [100 to 170 / 140 / 1 deg]
        012
        Roller Ends: Thin
        C1b/C1.5b: [100 to 170 / 135 / 1 deg]
        C1c/C1.5c: [100 to 170 / 145 / 1 deg]
        013Roller Center: OHP: Plain[100 to 170 / 150/ 1 deg]
        014Roller Ends: OHP: Plain
        [100 to 170 / 155/ 1 deg]
        015Roller Center: OHP: Thick
        016Roller Ends: OHP: Thick[100 to 170 / 160/ 1 deg]
        017
        Roller Center: Special 1
        018
        Roller Ends: Special 1
        019
        Roller Center: Special 2
        020
        Roller Ends: Special 2
        021
        Roller Center: Special 3
        022
        Roller Ends: Special 3
        023Feed Waiting: PlainTurns the feed waiting mode on or off for each paper type.
        [0 to 1 / 0 / 1] 0=Off, 1=On
        The paper waits at the registration roller until the fusing temperature reaches the prescribed temperature (adjustable with SP1105-028 to -37).
        If you enable this feature, also set SP 1105-38 to a convenient value for the customer.
        024Feed Waiting: M-Thick
        025Feed Waiting: Thick 1
        026Feed Waiting: Thick 2
        027
        Feed Waiting: Thin
        028Feed Wait: Center Minus: Plain
        Adjusts the offset value for each re-load temperature to exit the feed waiting mode.
        029Feed Wait: Ends Minus: Plain
        030Feed Wait: Center Minus: M-Thick
        031Feed Wait: Ends Minus: M-Thick
        032Feed Wait: Center Minus: Thick 1
        033Feed Wait: Ends Minus: Thick 1
        034Feed Wait: Center Minus: Thick 2
        035Feed Wait: Ends Minus: Thick 2
        036Feed Wait: Center Minus: Thin
        037Feed Wait: Ends Minus: Thin
        038
        Feed Waiting: Maximum Time
        Sets the maximum feed waiting time. [0 to 30 / 0 / 1 sec]
        The paper is fed when the time specified with this SP has passed even though the fusing temperature has not reached the prescribed temperature.
        0: Disabled.
        1106Fusing Temperature Display
        001Roller CenterDisplays the temperature of the fusing unit.
        [-20 to 250 / 0 / 1 deg]
        Roller Ends
        003Machine Inside at Power OnDisplays the temperature inside the machine.
        Machine Inside
        1109*
        Fusing Nip Band Check
        Checks the fusing nip band.
        001Execution
        Idling Rotation Time[0 to 120 / 60 / 1 sec]
        Specifies the fusing rotation time before executing SP1109-001.
        Pre-Idling Time[5 to 30 / 10 / 1 sec]
        Specifies the time that the paper stops in the fusing unit for measuring the nip.
        1159
        Fusing Jam Detection
        SC Code Display
        [0 to 1 / 0 / 1] 0:OFF, 1:ON
        This SP setting determines whether SC559 is issued after three paper late jams occur in the fusing unit. After this SP code is turned on, a counter monitors the number of paper late jams that occur in the fusing unit. After the 3rd occurrence of a fusing jam, SC559 is issued and the machine cannot be used until the service technician releases the error.
        • Switching the machine off/on does not reset this jam counter. The counter is reset after the cause of the jam has been removed and a sheet of paper successfully passes the fusing exit sensor.
        1801*
        Motor Speed Adjustment
        Adjusts the speeds of each motor. Each step decreases or increases motor speed in 0.05% increments
        Regist: Registration motor, Feed: Feed motor,
        Duplex: Duplex/By-pass motor, Inverter: Duplex inverter motor, Exit: Paper exit motor, Bridge: Bridge unit drive motor,
        OpcMot: Drum motor, TransferMot: Transfer/Development Motor, FusingMot: Fusing motor,
        DevPuddleMot: Development Paddle motor
        001Regist: 90: Thick 2
        [-2 to 2 / 0.4 / 0.05 %]
        002Regist: 154: Thick 1
        003Regist: 180: Plain
        004Regist: 230: Plain
        005Feed: 90: Thick 2
        [-2 to 2 / -0.4 / 0.05 %]
        006Feed: 154: Thick 1
        007Feed: 180: Plain
        [-2 to 2 / -1 / 0.05 %]
        008Feed: 230: Plain
        009Duplex_CW: 90: Thick 2
        [-4 to 4 / 0.4 / 0.1 %]
        010Duplex_CW: 154: Thick 1
        011Duplex_CW: 180: Plain
        [-4 to 4 / -2.3 / 0.1 %]
        012Duplex_CW: 230: Plain
        013Duplex_CCW: 90: Thick 2
        014Duplex_CCW: 154: Thick 1
        015Duplex_CCW: 180: Plain
        016Duplex_CCW: 230: Plain
        017Inverter_CW: 90: Thick 2
        [-4 to 4 / 0 / 0.1 %]
        018Inverter_CW: 154: Thick 1
        019Inverter_CW: 180: Plain
        020Inverter_CW: 230: Plain
        021Inverter_CCW: 90: Thick 2
        022Inverter_CCW: 154: Thick 1
        023Inverter_CCW: 180: Plain
        024Inverter_CCW: 230: Plain
        025Exit_CW: 90: Thick 2
        026Exit_CW: 154: Thick 1
        027Exit_CW: 180: Plain
        028Exit_CW: 230: Plain
        029Bridge: 90: Thick 2
        030Bridge: 154: Thick 1
        031Bridge: 180: Plain
        032Bridge: 230: Plain
        033OpcMot:90
        [-4 to 4 / 0 / 0.01 %]
        034OpcMot:154
        035OpcMot:180
        036OpcMot:230
        037TransferMot:90
        038TransferMot:154
        039TransferMot:180
        040TransferMot:230
        041FusingMot:90
        042FusingMot:154
        043FusingMot:180
        044FusingMot:230
        045DevPuddleMot[-4 to 4 / 0 / 0.1 %]
        1902Cleaning Web Setting
        Web Consumption[0 to 120 / 0 / 1 %]
        Displays the consumed amount of the web roll.
        Web Motor Interval
        C1b/C1.5b: [3 to 130 / 8.4 / 0.1 sec]
        C1c/C1.5c: [3 to 130 / 6.7 / 0.1 sec]
        Adjusts the interval for web motor rotation.
        Web Motor Time[0.3 to 10 / 4.2 / 0.1 sec]
        Adjusts the rotation time of the web motor.
        Web Near End Setting
        C1b/C1.5b: EU [0 to 100 / 90 / 1 %]
        C1b/C1.5b: ASIA/NA [0 to 100 / 92 / 1 %]
        C1c/C1.5c: EU [0 to 100 / 90 / 1 %]
        C1c/C1.5c: ASIA/NA [0 to 100 / 92 / 1 %]
        Adjusts the threshold for web near end.
        Web Motor Interval: Thick 1[3 to 130 / 11.2 / 0.1 sec]
        Adjusts the interval for web motor rotation (thick 1).
        Web Motor Interval: Thick 2[3 to 130 / 16.8 / 0.1 sec]
        Adjusts the interval for web motor rotation (thick 2).
        Paper Interval Time[0 to 10 / 5 / 1 sec]
        Adjusts the threshold for paper feeding. When the time between trailing edge detection and leading edge detection is within the value of this setting, the machine determines that the paper is still being fed.
        008
        Web Motor Setting: Web End[0 to 60 / 27 / 1 sec]
        Adjusts the motor rotation time after the web end.
        009Web Motor Rotation: Power On[0 to 10 / 2 / 1 times]
        Adjusts the number of web motor rotations at the re-load state.
        010
        Web Motor Interval: Pre-idle[0 to 30 / 5 / 1 sec]
        Adjusts the motor waiting time after the fusing motor idling.
        011
        Web Motor Rotation: Pre-idle[0 to 10 / 2 / 1 times]
        Adjusts the number of web motor rotations at the fusing idling state.
        1903Cleaning Web Setting
        Total Paper Counter[0 to 999999999 / 0 / 1 sec]
        Displays the total paper feeding time.
        Total Web Motor Drive Time[0 to 999999999 / 0 / 1 sec]
        Displays the total time of web motor rotation.
        1907Paper Feed Timing Adj. (DFU)
        001Feed Solenoid ON: Plain
        [-10 to 40 / 0 / 2.5 mm]
        002Feed Solenoid ON: Thick
        003Feed Solenoid OFF: Plain
        [-10 to 10 / 0 / 1 mm]
        004Feed Solenoid OFF: Thick
        005Feed Clutch ON: Plain
        006Feed Clutch ON: Thick
        007Stop Position before Inverter
        008Stop Position after Inverter
        009Re-Feed Stop Position
        010By-pass Solenoid OFF[0 to 40 / 0 / 1 mm]
        011By-pass Solenoid ON[0 to 1 / 1 / 1 mm]
        012By-pass Feed Clutch ON[-10 to 10 / 0 / 1 mm]
        013Exit Roller: Shift: 180
        014Exit Roller: Shift: 230
        015Exit: Junction Solenoid ON
        016Exit: Junction Solenoid OFF
        017Bridge: Junction Solenoid ON
        018Bridge: Junction Solenoid OFF
        0191-Bin: Junction Solenoid ON
        0201-Bin: Junction Solenoid OFF
        021Shift Motor ON[-1 to 1 / 0 / 0.1 mm]
        1908Paper Bank Feed Timing Adj (DFU)
        001Feed Clutch ON: Plain
        002Feed Clutch ON: Thick
        1916
        CPM Down Setting
        When this machine gets a sequence of coping/printing jobs, the machine uses CPM down mode to prevent the fusing temperature from becoming too low.
        001Temp.: Plain
        Adjusts the thresholds for each environmental condition (between Low and Medium).
        [10 to 23 / 17 / 1 deg]
        002Temp.: M-Thick
        003Temp.: Thick 1
        004Temp.: Thick 2
        005Temp.: Thin
        006ON/OFF: Low: Plain
        Turns on or off the CPM down setting for each paper type and ambient temperature.
        [0 to 1 / 0 / 1 ]
        0= Off, 1= On
        007ON/OFF: Low: M-Thick
        008ON/OFF: Low: Thick 1
        009ON/OFF: Low: Thick 2
        010ON/OFF: Low: Thin
        011ON/OFF: Medium: Plain
        012ON/OFF: Medium: M-Thick
        013ON/OFF: Medium:: Thick 1
        014ON/OFF: Medium: Thick 2
        015ON/OFF: Medium: Thin
        016Waiting Time: Low: Plain
        Adjusts the threshold time to enter the CPM down mode.
        [0 to 180 / 60 / 1 sec]
        The machine determines whether the CPM down mode is activated or not after the time specified with these SPs has passed.
        017Waiting Time: Low: M-Thick
        018Waiting Time: Low: Thick 1
        019Waiting Time: Low: Thick 2
        020Waiting Time: Low: Thin
        021Waiting Time: Medium: Plain
        022Waiting Time: Medium: M-Thick
        023Waiting Time: Medium: Thick 1
        024Waiting Time: Medium: Thick 2
        025Waiting Time: Medium: Thin
        026Temp.: Low: Plain
        Adjusts the threshold temperature of the fusing unit to enter the CPM down mode.
        [100 to 200 / 120 / 1 deg]
        If the temperature of the fusing unit is less than the temperature specified with these SPs, the machine changes the CPM (adjustable with SP1916-36 to -45).
        027Temp.: Low: Plain
        028Temp.: Low: Thick 1
        029Temp.: Low: Thick 2
        030Temp.: Low: Thin
        031Temp.: Medium: Plain
        032Temp.: Medium: M-Thick
        033Temp.: Medium: Thick 1
        034Temp.: Medium: Thick 2
        035Temp.: Medium: Thin
        036
        CPM: Low: Plain
        Adjusts the CPM in the CPM down mode.
        C1b/C1.5b: [20 to 35 / 35 / 5 cpm]
        C1c/C1.5c: [20 to 45 / 45 / 5 cpm]
        037
        CPM: Low: M-Thick
        038
        CPM: Low: Thick 1
        C1b/C1.5b: [5 to 15 / 15 / 5 cpm]
        C1c/C1.5c: [5 to 25 / 25 / 5 cpm]
        039
        CPM: Low: Thick 2
        040CPM: Low: ThinAdjusts the CPM in the CPM down mode.
        C1c/C1.5c: [30 to 45 / 45 / 5 cpm]
        041CPM: Medium: Plain
        042CPM: Medium: M-Thick
        043
        CPM: Medium: Thick 1
        044
        CPM: Medium: Thick 2
        045
        CPM: Medium: Thin
        1930OnOff Time Adjust
        On Time Adjust[0 to 100 / 40 / 10 msec]
        Adjusts the Off-On interval of the transfer belt contact motor. ("On" means that the transfer belt is in contact with the drum.)
        Off Time Adjust[0 to 100 / 20 / 10 msec]
        Adjusts the On-Off interval of the transfer belt contact motor. ("Off" means that the transfer belt is away from the drum.)
        1950
        Tray Lock at Jam[0 or 1 / 0 / 1 ] 0= OFF, 1= ON
        Not used
    2. SYSTEM SP TABLES-2​
      1. SP2-XXX: DRUM​
        2001*Charge Bias
        Setting (Copying)[1000 to 2000 / 1500 / 10 V]
        Adjusts the voltage applied to the charge roller for copying.
        Setting (P Pattern)[0 to 700 / 250 / 10 V]
        Adjusts the voltage applied to the charge roller when making the VSDP ID sensor pattern (for charge roller voltage correction). The actual charge roller voltage is this value plus the value of SP2001-1.
        2005*Bias Control
        Bias Correction 1[0.1 to 1 / 0.85 / 0.05 step]
        Adjusts the lower threshold value for the charge roller correction.
        When the value of VSDP/VSG is greater than this value, the charge roller voltage increases by 30 V (e.g., from –500 to –530).
        Bias Correction 2[0.1 to 1 / 0.9 / 0.05 step]
        Adjusts the upper threshold value for the charge roller correction.
        When the value of VSDP/VSG is greater than this value, the charge roller voltage decreases by 30 V (absolute value).
        Bias Adjustment 1[1000 to 2000 / 1500 / 10 vol]
        Adjusts the lower limit value for charge roller voltage correction.
        Bias Adjustment 2[1000 to 2000 / 2000 / 10 vol]
        Adjusts the upper limit value for charge roller voltage correction.
        Bias Adjustment 3[0 to 100 / 30 / 10 vol]
        Adjusts the correction voltage adjustment step size.
        2102*
        Magnification Adjustment
        Main Scan[-2 to 2 / 0 / 0.1 %]
        Adjusts the magnification in the main scan direction for copy mode and printer mode.
        2103*
        Erase Margin Adjustment
        Adjusts the erase margin by deleting image data at the margins. L Size: 297.1 mm or more (length)
        M Size: 216.1 to 297 mm (length) S Size: 216 mm or less (length)
        001Leading Edge
        [0 to 9 / 3 / 0.1mm]
        002Trailing Edge
        003Left
        [0 to 9 / 2 / 0.1mm]
        004Right
        005Duplex Trail.: L Size: Plain[0 to 4 / 1 / 0.1mm]
        006Duplex Trail.: M Size: Plain[0 to 4 / 0.8 / 0.1mm]
        007Duplex Trail.: S Size: Plain[0 to 4 / 0.6 / 0.1mm]
        008Duplex Left: Plain
        [0 to 1.5 / 0.3 / 0.1mm]
        009Duplex Right: Plain
        010Duplex Trail.: L Size: Thick[0 to 4 / 0.8 / 0.1mm]
        011Duplex Trail.: M Size: Thick[0 to 4 / 0.6 / 0.1mm]
        012Duplex Trail.: S Size: Thick[0 to 4 / 0.4 / 0.1mm]
        013Duplex Left: Thick
        [0 to 1.5 / 0.1 / 0.1mm]
        014Duplex Right: Thick
        2105*
        LD Power Adjustment(DFU)
        Adjusts the LD power for each mode.
        Each LD power setting is decided by the process control.
        001LD1: Copy
        [–50 to 79 / -24 (C2b), 5 (C2c) /1 ]
        002LD2: Copy
        003LD1: Printer/Fax
        [–50 to 79 / -44 (C2b), -25 (C2c)/1 ]
        004LD2: Printer/Fax
        2106*POL REV TIME (Polygon motor rotation time)
        PRE TIME[0 to 60 / 10 /1 sec]
        Adjusts the time of polygon motor rotation before a job. If this is set to "0", this SP is not activated.
        POST TIME[0 to 60 / 0 /1 sec]
        Adjusts the time of the polygon motor rotation after a job.
        If this is set to "0", the polygon motor never switches off in standby mode. However, if the machine enters the energy saver mode, the polygon motor will ignore the zero setting and switch itself off.
        2109Test Pattern
        Pattern Selection
        [0 to 24 / 0 /1 ]
        Test pattern of the GAVD
        0: None
        1: Vertical Line (1 dot)
        2: Vertical Line (2 dot)
        3: Horizontal Line (1 dot)
        4: Horizontal Line (2 dot) 5: Grid Vertical Line
        6: Grid Horizontal Line 7: Grid pattern small 8: Grid Pattern Large
        9: Argyle Pattern Small 10: Argyle Pattern Large
        11: Independent pattern (1 dot)
        12: Independent Pattern (2 dot)
        13: Independent Pattern (4 dot)
        14: Trimming Area
        15: Hound's Tooth Check (Vertical) 16: Hound's Tooth Check (Horizontal) 17: Black Band (Horizontal)
        18: Black band ( Vertical) 19: Checker Flag Pattern
        20: Grayscale (Vertical Margin) 21: Grayscale (Horizontal Margin) 22: Two Beam Density Pattern 23: Full Dot Pattern
        24:All white Pattern
        Density
        [0 to 15 / 15 /1 ]
        Set the density of the test pattern which is output in SP2109-001. This SP is not used for the Grayscale patterns.
        2201*Development Bias Adjustment
        Development Bias[200 to 700 / 560 / 10V ]
        Adjusts the development bias for copying.
        Use as a temporary measure to correct faint copies from an aging drum.
        ID Sensor Pattern[200 to 700 / 400 / 10V ]
        Adjusts the development bias for the ID sensor pattern for VSP
        2207
        Forced Toner Supply
        Forces the toner bottle to supply toner at 1-second intervals for up to 30 seconds. To start, press [EXECUTE].
        2208*
        Toner Supply Mode[0: Sensor, 1: pixel ]
        Selects the toner mode.
        If you select "1", SP2-209-002 should be set to its default value. Use image pixel count modes only as a temporary measure if the ID or TD sensor is defective.
        2209*Toner Supply Rate
        Toner Rate[10 to 800 / 60 mg/s / 5 mg ]
        Sets the amount of toner supplied every second by the toner supply motor. The length of time the motor remains on is determined by the data read by the TD sensor and ID sensor.
        Increasing this value reduces the toner supply clutch on time. Use a lower value if the user tends to make lots of copies that have a high proportion of black.
        Correction Data[25 to 300 / 300 / 25 ]
        Displays the toner supply correction coefficient (K). It can also be used to adjust K, but the value is changed again when VT is measured for the next copy.
        The toner supply rate depends on the amount of toner in the toner bottle. This change is corrected using this coefficient. This SP can be used to check the toner supply condition. The lower the value of K, the lower the toner density
        2210*
        P Pattern Cycle
        Sets the interval between ID sensor pattern prints.
        001*
        Job Page Count[0 to 200 / 10 / 1 sheet]
        Sets the interval between ID sensor pattern printing. For users that do not make many copies daily, set a smaller interval to compensate for the effects of seasonal and weather changes.
        002*
        Forced Page Count[2 to 999 / 100 / 1 sheet]
        Forces creation of the ID sensor pattern to prevent low density copies for customers who use the copier for long copy jobs.
        2213*
        Toner End Setting
        Selects the detection type for toner end. [0 to 2 / 0 / 1 step]
        [0: 90 copies, 1: No copies, 2: 10 copies]
        Vt(10)) is detected 90 times after toner near end.
        • 90 copies: Toner end is determined if a low density image (Vref 
        • If "1" is selected, the machine stops printing when the TD sensor output drops below the prescribed level.
        • Select 1 or 2 if the customer normally makes copies of very high density.
        2220*
        Vref Setting
        Adjusts the TD sensor reference voltage (Vref). Change this value after replacing the development unit with another development unit that contains toner.
        [1 to 5 / 4 / 0.01 ]
        1. Check the value of SP2-220 in both the machine containing the test unit and the machine that you are going to move it to.
        2. Install the test development unit, and then input the VREF for this unit into SP2-220.
        3. After the test, put back the old development unit, and change SP2-220 back to the original value.
        2221*
        Reverse Interval Drum,Transfer[0 to 2000 / 0 / 1 sheets]
        Adjusts the threshold for the reverse rotation of the drum and development/transfer motors. This helps the drum and transfer belt cleaning operations. This reverse rotation will interrupt a multiple printing job.
        2223*Vt Display
        Current[0 to 5 / 4 / 0.01]
        Displays the TD sensor output voltage for the immediately previous copy.
        Average 10 copies[0 to 5 / 4 / 0.01]
        Displays the average of the most recent TD sensor outputs (from the previous 10 copies).
        Rate of Change[-10000 to 10000 / 0 / 1]
        Displays the rate of change in the TD sensor output.
        GAIN[0 to 255 / 0 / 1]
        Displays the GAIN value used to calculate the on time for the toner supply motor.
        Image Pixel Count[0 to 255 / 0 / 1]
        Displays the image pixel count.
        2228*
        Developer Lot
        Displays the lot number of the developer. (The lot number is embossed on the top edge of the developer pack.)
        2301*
        Transfer Current Adjustment
        If the transfer current of image area is set highly than normal, the print image is easily come out. If the leading transfer current is set as same, the black line is come out due to exfoliation leave.
        Image Area: 1st Side
        C2b: [10 to 100 / 35 /
        A]
        C2c: [10 to 100 / 45 /
        A]
        Adjusts the transfer current for printing the first side of the paper
        Image Area: 2nd Side
        A]
        C2c: [10 to 100 / 40 /
        A]
        Adjusts the transfer current for printing the second side of the paper
        Leading Edge: 1st Side[10 to 100 / 20 /
        A]
        Adjusts the transfer current for copying at leading edge the first side of the paper.
        Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        Leading Edge: 2nd Side[10 to 100 / 20 /
        A]
        Adjusts the transfer current for copying at leading edge the second side of the paper.
        By-pass: Image Area
        A]
        A]
        Adjusts the transfer current for copying from the by-pass tray.
        If the user normally feeds thicker paper from the bypass tray, use a higher setting.
        By-pass: Leading Edge[10 to 100 / 20 /
        A ]
        Adjusts the transfer current for copying at the leading edge of paper fed from the by-pass tray.
        008
        No Image Area (SSP)[10 to 100 / 15 /
        A ]
        Adjusts the transfer current for copying.
        2309*Current: Paper Size Correction (SSP)
        Paper Lower Width (a)[1 to 150 / 150 / 1 mm ]
        Adjusts the lower paper width threshold for the transfer current, charge voltage, and development bias corrections.
        Use this SP when an image problem (e.g., insufficient toner transfer) occurs with a small width paper. If the paper width is smaller than this value, the transfer current will be multiplied by the factor in SP2-309-3 (paper tray) or SP2-309-5 (by-pass).
        Paper Upper Width (a)[151 to 296 / 216 / 1 mm ]
        Adjusts the upper paper width threshold for the transfer current, charge voltage, and development bias corrections.
        As for SP2-309-1, but the factors are in SP2-309-4 (paper tray) and SP2-309-6 (by-pass).
        Paper Tray: Plain (alpha)[1 to 3 / 1 / 0.1 ]
        Adjusts the transfer current correction coefficient used if the paper width is less than the setting of SP2-309-1.
        Paper Tray: Plain (beta)[1 to 3 / 1 / 0.1 ]
        Adjusts the transfer current correction coefficient used if the paper width is less than the setting of SP2-309-2.
        By-pass: Plain (gamma)[1 to 3 / 1.1 / 0.1 ]
        By-pass: Plain (delta)[1 to 3 / 1.1 / 0.1 ]
        007Paper Tray: Thick 1 (alpha)
        [1 to 3 / 1 / 0.1 ]
        008Paper Tray: Thick 1 (beta)
        009By-pass: Thick 1 (gamma)
        010By-pass: Thick 1 (delta)
        011Paper Tray: Thick 2 (alpha)
        012Paper Tray: Thick 2 (beta)
        013By-pass: Thick 2 (gamma)
        [1 to 3 / 1.5 / 0.1 ]
        014By-pass: Thick 2 (delta)
        015Paper Tray: M-Thick (alpha)
        [1 to 3 / 1 / 0.1 ]
        016Paper Tray: M-Thick (beta)
        017By-pass: M-Thick (gamma)
        018By-pass: M-Thick (delta)
        019Paper Tray: Thin (alpha)
        [1 to 3 / 1 / 0.1 ]
        020Paper Tray: Thin (beta)
        021By-pass: Thin (gamma)
        022By-pass: Thin (delta)
        023Paper Tray: Special 1 (alpha)
        [1 to 3 / 1 / 0.1 ]
        024Paper Tray: Special 1 (beta)
        025By-pass: Special 1 (gamma)
        026By-pass: Special 1 (delta)
        027Paper Tray: Special 2 (alpha)
        [1 to 3 / 1 / 0.1 ]
        028Paper Tray: Special 2 (beta)
        029By-pass: Special 2 (gamma)
        030By-pass: Special 2 (delta)
        031Paper Tray: Special 3 (alpha)
        [1 to 3 / 1 / 0.1 ]
        032Paper Tray: Special 3 (beta)
        033By-pass: Special 3 (gamma)
        034By-pass: Special 3 (delta)
        2310*
        Current: Paper Type Correction (SSP)
        Adjust the transfer current for each paper type. If the transfer current of image area is set highly than normal, the print image is easily come out. If the leading transfer current is set as same, the black line is come out due to exfoliation leave.
        Image 1st Side: Thick 1[10 to 100 / 18 /
        A]
        Adjusts the transfer current for printing the first side of the paper (Thick 1).
        Leading Edge 1st Side: Thick 1[10 to 100 / 15 /
        A]
        Adjusts the transfer current for copying at leading edge the first side of the paper. Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions (Thick 1).
        Image 2nd Side: Thick 1[10 to 100 / 18 /
        A]
        Adjusts the transfer current for printing the second side of the paper (Thick 1).
        Leading Edge 2nd Side: Thick 1[10 to 100 / 15 /
        A]
        Adjusts the transfer current for copying at leading edge the second side of the paper (Thick 1). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        Image: Thick 2[10 to 100 / 18 /
        A]
        Adjusts the transfer current for printing (Thick 2).
        Leading Edge: Thick 2[10 to 100 / 15 /
        A]
        Adjusts the transfer current for copying at the leading edge of paper (Thick 2). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        Image: OHP[10 to 100 / 20 /
        A]
        Adjusts the transfer current for printing (OHP).
        008
        Leading Edge: OHP[10 to 100 / 20 /
        A]
        Adjusts the transfer current for copying at the leading edge of paper (OHP). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        009
        Image: Envelope[10 to 100 / 20 /
        A]
        Adjusts the transfer current for printing (Envelope).
        010
        Leading Edge: Envelope[10 to 100 / 20 /
        A]
        Adjusts the transfer current for copying at the leading edge of paper (Envelope). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        011
        Image 1st Side: M-Thick
        C2b: [10 to 100 / 24 /
        A]
        C2c: [10 to 100 / 32 /
        A]
        Adjusts the transfer current for printing the first side of the paper (M-Thick).
        012
        Leading Edge 1st Side: M-Thick[10 to 100 / 20 /
        A]
        Adjusts the transfer current for copying at leading edge the first side of the paper (M-Thick). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        013
        Image 2nd Side: M-Thick
        A]
        A]
        Adjusts the transfer current for printing the second side of the paper (M-Thick).
        014
        Leading Edge 2nd Side: M-Thick[10 to 100 / 20 /
        A]
        Adjusts the transfer current for copying at leading edge the second side of the paper (M-Thick). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        015
        Image 1st Side: Special 1
        A]
        A]
        Adjusts the transfer current for printing the first side of the paper (Special 1).
        016
        Leading Edge 1st Side: Special 1[10 to 100 / 20 /
        A]
        Adjusts the transfer current for copying at leading edge the first side of the paper (Special 1). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        017
        Image 2nd Side: Special 1
        A]
        A]
        Adjusts the transfer current for printing the second side of the paper (Special 1).
        018
        Leading Edge 2nd Side: Special 1[10 to 100 / 20 /
        A]
        Adjusts the transfer current for copying at leading edge the second side of the paper (Special 1). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        019
        Image 1st Side: Special 2
        A]
        A]
        Adjusts the transfer current for printing the first side of the paper (Special 2).
        020
        Leading Edge 1st Side: Special 2
        A]
        A]
        Adjusts the transfer current for copying at leading edge the first side of the paper (Special 2). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        021
        Image 2nd Side: Special 2
        A]
        A]
        Adjusts the transfer current for printing the second side of the paper (Special 2).
        022
        Leading Edge 2nd Side: Special 2
        A]
        A]
        Adjusts the transfer current for copying at leading edge the second side of the paper (Special 2). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        023
        Image 1st Side: Special 3
        A]
        A]
        Adjusts the transfer current for printing the first side of the paper (Special 3).
        024
        Leading Edge 1st Side: Special 3
        A]
        A]
        Adjusts the transfer current for copying at leading edge the first side of the paper (Special 3). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        025
        Image 2nd Side: Special 3
        A]
        A]
        Adjusts the transfer current for printing the second side of the paper (Special 3).
        026
        Leading Edge 2nd Side: Special 3
        A]
        A]
        Adjusts the transfer current for copying at leading edge the second side of the paper (Special 3). Increase the current to separate the paper from the drum properly in high humidity and high temperature conditions.
        2602*
        PTL Control (SSP)
        Use this SP when an image problem occurs caused by the pick-off paws. This SP is for the printing which target line speed is 230 or 180 mm/sec. Set the PTL control (SP2603-001) to “1: ON” after installing the PTL. If the PTL control is set to ON, the black line is come out due to exfoliation leave. Set SP2911-002 (or 005, 008, 011) to “20” when using the PTL.
        1st Side: OFF/ON[0 to 1 / 0 / 1]
        Sets the PTL control setting for printing the first side of the paper.
        1st Side: OFF Timing[-10 to 10 / 2 / 1]
        Sets the PTL control time for printing the first side of the paper when SP2602-001 is set to “1”.
        2nd Side: OFF/ON[0 to 1 / 0 / 1]
        Sets the PTL control setting for printing the second side of the paper.
        2nd Side: OFF Timing[-10 to 10 / 2 / 1]
        Sets the PTL control time for printing the second side of the paper when SP2602-003 is set to “1”.
        2603*
        PTL Control: 154 mm/s (SSP)
        Use this SP when an image problem occurs caused by the pick-off paws. This SP is for the printing which target line speed is 154 mm/sec. Set the PTL control (SP2603-001) to “1: ON” after installing the PTL. If the PTL control is set to ON, the black line is come out due to exfoliation leave. Set SP2911-002 (or 005, 008, 011) to “20” when using the PTL.
        2604*
        PTL Control: 90 mm/s (SSP)
        Use this SP when an image problem occurs caused by the pick-off paws. This SP is for the printing which target line speed is 90 mm/sec. Set the PTL control (SP2603-001) to “1: ON” after installing the PTL. If the PTL control is set to ON, the black line is come out due to exfoliation leave. Set
        2801*
        TD Sensor Initial SettingInitialization
        Performs the TD sensor initial setting and allows the service technician to enter the lot number of the developer. (The lot number is embossed on the edge of the developer package.) This SP mode controls the voltage applied to the TD sensor to make the TD sensor output about 3.0 V. Press "Execute" to start. After finishing this, the TD sensor output voltage is displayed.
        Use this mode only after installing the machine, changing the TD sensor, or adding new developer.
        2802*
        TD Sensor Manual Setting
        Allows you to adjust the TD sensor output manually for the following.
        VTS[1 to 5 / 4.78 / 0.01vol ]
        Adjusts the TD sensor output (VT).
        Change this value after replacing the development unit with another one that already contains toner. For example, when using a development unit from another machine for test purposes. To adjust VT, use a similar procedure as for SP2-220.
        VTMAX[1 to 5 / 4.78 / 0.01vol ]
        Adjusts the maximum value for SP2802 1.
        VTMIN[1 to 5 / 1 / 0.01vol ]
        Adjusts the minimum value for SP2802 1.
        2805
        Process Setting
        Performs the developer initialization. Press "Execute" to start. This SP should be performed after doing SP2801 at installation and after replacing the drum.
        2810
        Grayscale Setting
        Initializes the LD power setting. This SP should be done after replacing the drum.
        2812*Drum Reverse Rotation (SSP)
        Reverse time[0 to 9 / 4 / 1 ]
        Sets the reverse time of the drum motor after the end of a job.
        Interval time[0 to 19 / 9 /1 ]
        Sets the waiting time of the drum motor reverse after the end of a job.
        2911*Transfer Current On/Off Timing (SSP)
        La (On Timing)[-20 to 20 / 0 / 1 mm]
        Adjust the timing to turn on the transfer current for the leading edge.
        Lb (Switch Timing)[0 to 30 / 10 / 1 mm]
        Adjust the timing to switch transfer current from the leading edge to the image area.
        Lc (Off Timing)[-20 to 20 / -5 / 1 mm]
        Adjust the timing to turn off the transfer current for the image area.
        La (On Timing): Special 1[-20 to 20 / 0 / 1 mm]
        Adjust the timing to turn on the transfer current for the leading edge (Special 1).
        Lb (Switch Timing): Special 1[0 to 30 / 10 / 1 mm]
        Adjust the timing to switch transfer current from the leading edge to the image area (Special 1).
        Lc (Off Timing): Special 1[-20 to 20 / -5 / 1 mm]
        Adjust the timing to turn off the transfer current for the image area (Special 1).
        La (On Timing): Special 2[-20 to 20 / 0 / 1 mm]
        Adjust the timing to turn on the transfer current for the leading edge (Special 2).
        008
        Lb (Switch Timing): Special 2[0 to 30 / 10 / 1 mm]
        Adjust the timing to switch transfer current from the leading edge to the image area (Special 2).
        009
        Lc (Off Timing): Special 2[-20 to 20 / -5 / 1 mm]
        Adjust the timing to turn off the transfer current for the image area (Special 2).
        010
        La (On Timing): Special 3[-20 to 20 / 0 / 1 mm]
        011
        Lb (Switch Timing): Special 3[0 to 30 / 10 / 1 mm]
        012
        Lc (Off Timing): Special 3[-20 to 20 / -5 / 1 mm]
        2912*Transfer Reverse Rotation
        Interval[0 to 10 / 3 / 1 ]
        Sets the reverse time of the transfer/development motor after the end of a job.
        2914*Paper Setting
        C-alpha[0 to 400 / 150 / 10vol ]
        Adjusts the charge roller voltage used when paper with a small width is fed from the by-pass tray. The paper width below which the correction starts depends on the value of SP2-309-1.
        Use this SP when an image problem (such as white spots at the center of black dots or breaks in thin black lines) occurs when paper with a small width is fed from the by-pass feed tray.
        C-beta[0 to 400 / 0 / 10vol ]
        Adjusts the charge roller voltage used when paper with a small width is fed from the by-pass tray. The paper width below which the correction starts depends on the value of SP2-309-2.
        Use this SP when an image problem (see 2-914-1) occurs when paper with a small width is fed from the by-pass feed tray.
        B-gamma[0 to 300 / 200 / 10vol ]
        Adjusts the development bias used when paper with a small width is fed from the by-pass tray. The paper width below which the correction starts depends on the value of SP2-309-1.
        B-delta[0 to 300 / 50 / 10vol ]
        Adjusts the development bias used when paper with a small width is fed from the by-pass tray. The paper width below which the correction starts depends on the value of SP2-309-2.
        2940*Toner consump. (SSP)
        [0: OFF 1: ON][0 to 1 / 1 / 1]
        If this SP is set to ON, toner bottle consumes toner when the SP2801 (TD Sensor Initial Setting) is executed. This prevents the image offset.
        Setting[0 to 1 / 0.06 / 0.01]
        Specifies the threshold value for the toner consumption mode if SP2940-001 is set to ON.
        2960*
        Toner Overflow Sensor[0 = OFF, 1= ON]
        Selects whether or not the toner overflow sensor is activated.
        2964*
        Trans Cleaning Blade Forming (SSP)
        Applies a pattern of toner to the transfer belt at a defined interval between sheets on the transfer belt in order to reduce friction between the belt surface and the cleaning blade.
        Under conditions of high temperature and high humidity, the density control feature may reduce the amount of toner, which also reduces the amount of toner on the surface of the transfer belt. With less toner on the belt, the friction between the belt and the blade increases, and could cause the blade to bend or scour the surface of the belt.
        0010: OFF, 1: ON[0 to 1 / 0 / 1 ]
        002Pattern Interval[1 to 100 / 15 / 1 sheet]
        003Pattern Number[1 to 3 / 1 / 1 line]
        004Pattern LD Power[0 to 15 / 2 / 1 ]
        2972*
        Grayscale Limit (SSP)
        Controls the halftone density level to prevent deterioration of the OPC. The halftone density is detected by the ID sensor, and the machine adjusts the intensity of the LD beam according to the upper/lower limit setting.
        Upper Limit[0 to 100 / 58 (C2b), 63 (C2c)/ 1vol ]
        Defines the upper limit for grayscale.
        A larger value allows a wider range of halftones at the pale end of the scale. If the image contains pale areas with fuzzy borders surrounded by dark areas, reduce this value to make the borders clearer.
        Lower Limit[0 to 100 / 52 (C2b), 57 (C2c) / 1vol ]
        Defines the lower limit for grayscale.
        A smaller value allows a wider range of halftones at the dark end of the scale.
        2973*
        Grayscale Cycle (SSP)[0 to 1000 / 100 / 10 sheets ]
        Set s the halftone operation interval in order to prevent deterioration of the OPC. If the number of copies exceeds this setting, at the end of the job, or if the door is opened and closed, charge correction is executed.
        2974*Image Density
        Adjustment Mode[1 to 5 / 3 / 1 ]
        Adjusts image density. Changing this setting adjusts development bias and ID sensor output voltage that in turn raises or lowers image density.
        2975*
        Near End Setting
        Detection Time[0 to 2000 / 0 / 10 sec ]
        Sets a time for toner supply motor rotation for issuing the toner near end warning on the operation panel. The time may need to be shorter for customers who run especially large print jobs (working at night, for example) to ensure earlier warning of the toner near end condition so toner out does not interrupt a long job.
        2976*
        Bottle Motor Time
        Displays the total ON time of the toner supply motor, calculated from when the toner bottle was replaced. Use this to check that the toner end count (SP2975) is working properly.
        When SP2975 is set to any value other than "0", this value is displayed when it matches the setting of SP2975. When SP2975 is set to "0", SP2976 is disabled. SP2976 is automatically set to zero by toner end recovery.)
        Time[0 to 7,000,000 / 0 / 1 msec]
        2977*
        Toner End Status
        Indicates the toner near end or end condition.
        Near End
        [0 to 10 / 0 / 1 ]
        0: Not detected
        1: Detected by SP2975-001
        2: Vt (10) - Vref > 0.2 and Vsp > 0.6
        3: Vt (10) - Vref > 0.45
        4: 0.45  Vt (10) - Vref > 0.2 and toner end counter > 300
        5 to 10: Not used
        End
        [0 to 10 / 0 / 1 ]
        0: Not detected
        1: Vsp > 2.0
        2: Toner end counter > 90 when SP2213-001 is set to "0". 3: Toner end counter  90 and Vt (10)  (Vref + 0.3) when SP2213-001 is set to "0".
        4: When SP2213-001 is set to "2"
        5: Vsp > 0.9 when SP2213-001 is set to "2" 6: Special order
        7 to 10: Not used
        2980*
        Charge Counter[0 to 1000000 / 0 / 1 sheets ]
        Set the number of pages to print after toner and carrier initialization before the charge input is increased to compensate for deterioration over time in the polarity of the carrier.
        The strength in the polarity of the carrier in the toner will eventually decrease and cause lower charge output. Setting the charge output to increase after a specified number of copies can compensate for this effect.
    3. SYSTEM SP TABLE-3​
      1. SP3-XXX: PROCESS​
        3001*P Sensor Setting
        Current[0 to 43 / 13 / 0.1 mA ]
        Allows you to reset the PWM of the ID sensor LED to avoid a service call error after clearing NVRAM or replacing the NVRAM.
        The PWM data is stored by executing SP-3001-2.
        ID Initialization-
        Performs the ID sensor initial setting. ID sensor output for the bare drum (VSG) is adjusted automatically to 4.0 ±0.2 V.
        Press "Execute" to start. Perform this setting after replacing or cleaning the ID sensor, replacing the drum, or clearing NVRAM.
        3045*
        Toner End Setting, ON/OFFDFU
        3103*
        P Sensor Output
        Displays the current VSG, VSP, VSDP, and grayscale control.
        If the P sensor does not detect the P pattern, "VSP = 5.0 V/VSG = 5.0 V" is displayed and an SC code is generated.
        If the P sensor does not detect the bare area of the drum, "VSP = 0.0 V/VSG =0.0 V" is displayed and an SC code is generated.
        001Vsg[0 to 5 / 0 / 0.1]
        002Vsp[0 to 5 / 0 / 0.1]
        003Vsdp[0 to 5 / 0 / 0.1]
        004Vsm/Vsg[0 to 5 / 0 / 0.1]
        3902*New PCU Detection (Not used)
        On/OFF Setting
        [0 to 1 / 0 / 1]
        0: On, 1: Off
        Turns on or off the new unit detection for the transfer belt unit and fusing unit.
        3905*
        Hot Roller Stripper Cleaning
        "Cleaning A": 15 sec. off/on cycle for the fusing motor.
        "Cleaning B": Off (45 sec.) and On (15 sec.) cycle for the fusing motor.
        1st Cleaning: Interval
        Sets the threshold for the 1st cleaning mode. "Cleaning A" is done once.
        [0 to 5 / 5 / 1 sheets]
        1st Cleaning: Mode Setting
        Sets the number of additional execution times of the 1st cleaning mode. [0 to 5 / 0 / 1 times]
        2nd Cleaning: Interval
        Sets the threshold for the 2nd cleaning mode. "Cleaning A" is done twice.
        [6 to 49 / 30 / 1 sheets]
        2nd Cleaning: Mode Setting
        Sets the number of additional execution times of the 2nd cleaning mode. [0 to 5 / 0 / 1 times]
        3rd Cleaning: Interval
        Sets the threshold for the 3rd cleaning mode.
        "Cleaning A" is done twice and "Cleaning B" is done "N" times. "N" is specified with SP3905-006.
        [50 to 999 / 100 / 1 sheets]
        3rd Cleaning: Mode Setting
        Sets the number of execution times of the 3rd cleaning mode. [0 to 5 / 0 / 1 times]
        Cleaning Priority Setting
        [0 to 1 / 0 / 1 sheets]
        0: Priority to printing (No job interruption) 1: Priority to cleaning (Job interruption)
        • All fans remain on during cleaning and then switch off 60sec after the cleaning cycle ends.
    4. SYSTEM SP TABLES-4​
      1. SP4-XXX: SCANNER​
4008*
Sub Scan Mag. Adjustment
Adjusts the magnification of the sub scan direction during scanning. Changing this value changes the scanner motor speed.
[–1 to 1 / 0 / 0.1% ]
4010*
L-Edge Regist Adjustment
Adjusts the leading edge registration for scanning. [–2 to 2 / 0 / 0.1 mm ]
As you enter a negative value, the image moves toward the leading edge.
4011*
S-to-S Regist Adjustment
Adjusts side-to-side registration for scanning. [–2.5 to 2.5 / 0 / 0.1 mm ]
As you enter negative values, the image will disappear at the left, and as you enter positive values, the image will appear at the left.
4012*
Scanner Erase Margin: Scale
Adjusts scanning margins for the leading and trailing edges (sub scan) and right and left edge (main scan).
  • Do not adjust unless the customer desires a scanner margin greater than the printer margin.
  • These settings are adjusted to erase shadows caused by the gap between the original and the scale of the scanner unit.
001Book: Leading Edge[0 to 3 / 1 / 0.1 mm]
002Book: Trailing Edge[0 to 3 / 0 / 0.1 mm]
003Book: Left[0 to 3 / 1 / 0.1 mm]
