Ricoh MP4002/5002 service manual Part 12
D
Log Data Error
An error is detected in the handling of the log data at power on or during machine operation. This can be caused by switching the machine off while it is operating.
-01
Log Data Error 1
  • Damaged log data file in the HDD
Initialize the HDD with SP5832-004.
-02
Log Data Error 2
  • HDD encryption unit not installed
  1. Ask the customer's administrator to disable the HDD encryption setting with a user tool.
  2. Install the HDD encryption unit.
-03
Log Data Error 3
  • Invalid log encryption key due to defective NVRAM data
  1. Initialize the HDD with SP5832-004.
  2. Ask the customer's administrator to disable the HDD encryption setting with a user tool.
-04
Log Data Error 4
  • Unusual HDD encryption function due to defective NVRAM data
-05
Log Data Error 5
  • Installed a NVRAM or HDD which was used in another machine
  1. Reinstall the previous NVRAM or HDD.
  2. Initialize the HDD with SP5832-004.
-99
Log Data Error 99
  • Other than the above causes
Ask your supervisor.
Trouble- shooting
877
B
HDD DataOverwriteSecurity SD card error
The 'all delete' function cannot be executed but the DataOverwriteSecurity Unit is installed and activated.
  • Defective SD card
  • SD card not installed
  1. Replace the NVRAM and then install the new SD card.
  2. Check and reinstall the SD card.
878DUSB Flash Error
-00
TPM system authentication error
The system firmware is not authenticated by TPM (security chip).
  • Incorrect updating for the system firmware
  • Defective flash ROM on the controller board Replace the controller board.
-01
USB Flash Error
File system in the USB flash device is defective.
  • Cannot mount partition 3 in the USB flash device.
  • Encryption key does not exist.
  • Cannot find the file for KMMD to be operated. Replace the controller board.
-02
TPM Error
An error occurred in TPM or in TPM driver.
  • TPM defective
-03
TCSD Error
  • TPM defective
880
B
File Format Converter (MLB) error
A request to get access to the MLB is not answered within the specified time.
  • MLB defective, replace the MLB
881
D
Authentication area error
Authentication application error is detected.
  • Error data in an authentication application reaches the management limit.
899
D
Software performance error
If the processing program shows abnormal performance and the program is abnormally ended, this SC is issued.
  • Controller board defective
  • Software defective
Trouble- shooting
SC Tables: SC9xx
900
D
Electrical total counter error
The total counter contains something that is not a number.
  • NVRAM incorrect type
  • NVRAM defective
  • NVRAM data scrambled
  • Unexpected error from external source
920BPrinter error
-01
Timeout error during the PM operation
-02Working memory error
-03Cannot start-up the filtering process
-04Abnormal exit from the filtering process
An internal application error was detected and operation cannot continue.
  • Software defective; turn the machine off/on, or change the controller firmware
  • Insufficient memory
921DPrinter font error
-01-Resident font is not found
-02-Option font is not found
A necessary font is not found in the SD card.
  • A necessary font is not found in the SD card.
  • The SD card data is corrupted.
925BNet File function error
-00-HDD is defective
-01-NetFile management file is broken
The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. The HDDs are defective and they cannot be debugged or partitioned, so the Scan Router functions (delivery of received faxes, document capture, etc.), Web services, and other network functions cannot be used.
HDD status codes are displayed below the SC code.
  • Refer to the four procedures below (Recovery from SC 925).
Here is a list of HDD status codes:
DisplayMeaning
(-1)HDD not connected
(-2)HDD not ready
(-3)No label
(-4)Partition type incorrect
(-5)Error returned during label read or check
(-6)Error returned during label read or check
(-7)"filesystem" repair failed
(-8)"filesystem" mount failed
(-9)Drive does not answer command
(-10)Internal kernel error
(-11)Size of drive is too small
(-12)Specified partition does not exist
DisplayMeaning
(-13)Device file does not exist
Recovery from SC 925 Procedure 1
If the machine shows SC codes for HDD errors (SC860 to SC865) with SC 925, do the recovery procedures for SC860 to SC865.
Procedure 2
If the machine does not show one of the five HDD errors (SC860 to SC865), turn the machine power off and on. If this is not the solution for the problem, then initialize the NetFile partition on the HDD with SP5832-011 (HDD Formatting – Ridoc I/F).
NetFiles: Jobs printed from the document server using a PC and DeskTopBinder
  • Before you initialize the NetFile partition on the HDD, tell the customer that:
  • Received faxes on the delivery server will be erased
  • All captured documents will be erased
  • DeskTopBinder/Print Job Manager/Desk Top Editor job history will be erased
  • Documents on the document server, and scanned documents, will not be erased.
  • The first time that the network gets access to the machine, the management information must be configured again (this will use a lot of time).
Before you initialize the Netfile partition with SP5832-011, do these steps:
  1. Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
  2. In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
    Trouble- shooting
  3. Do SP5832-011, then turn the machine power off and on.
Procedure 3
If "Procedure 2" is not the solution for the problem, do SP5832-001 (HDD Formatting – All), then turn the machine power off and on.
SP5832-001 erases all document and address book data on the hard disks. Ask the customer before you do this SP code.
Procedure 4
If "Procedure 3" is not the solution for the problem, replace the HDD.
990
D
Software error 1
The software performs an unexpected function and the program cannot continue.
  • Software defective, re-boot
991
Software error 2
The software performs an unexpected function. However, unlike SC990, recovery processing allows the program to continue.
In order to get more details about SC990 and SC991:
  1. Execute SP7403 or print an SMC Report (SP5990) to read the history of the 10 most recent logged errors.
  2. If you press the zero key on the operation panel with the SP selection menu displayed, you will see detailed information about the recently logged SC990 or SC991, including the software file name, line number, and so on.
    • 1) is the recommended method, because another SC could write over the information for the previous SC.
992
D
Undefined error
Defective software program
  • An error undetectable by any other SC code occurred
994
Application Item Error
The number of executed application items on the operation panel reach the maximum limit for the operation panel structure.
  • Too much executed application items
995DCPM setting error
-01
  • Defective BCU
  • NVRAM Replacement error
  1. Install the previous NVRAM.
  2. Input the serial number with SP5811-003, and turn the main power switch off/on.
-02
  • Defective NVRAM
  • Defective controller
  1. Update the controller firmware.
  2. Install a new NVRAM, and turn off and on the main power switch after SC995-002 has occurred.
-03
  • Incorrect type controller installed
1. Replace the controller with the correct type.
-04
  • Incorrect model controller installed.
1. Replace the controller with the correct model.
Trouble- shooting
997
B
Software Error 3: Cannot select application function
An application does not start after the user pushed the correct key on the operation panel.
  • Software bug
  • A RAM or DIMM option necessary for the application is not installed or not installed correctly.
998
D
Software Error 4: Application cannot start
Register processing does not operate for an application within 60 s after the machine power is turned on. No applications start correctly, and all end abnormally.
  • Software bug
  1. ELECTRICAL COMPONENT DEFECTS​
    Trouble- shooting
    1. SENSORS​
      Component (Symbol)
      CN
      Condition
      Symptom
      By-pass Paper Length Sensor
      236-2 (IOB)
      Open
      Paper size error
      Shorted
      Duplex Entrance
      217-A8 (IOB)
      OpenJam Z
      ShortedJam Z
      Duplex Cover
      217-A11 (IOB)
      Open"Open Cover" is displayed.
      Shorted“Open cover" cannot be detected.
      Duplex Exit
      217-A14 (IOB)
      OpenJam Z
      Shortedam Z (Jam 1)
      By-pass Paper End
      217-B3 (IOB)
      Open
      The Paper End indicator lights even if paper is placed on the by-pass tray.
      Shorted
      The Paper End indicator does not light even if there is no paper on the by-pass tray.
      By-pass Paper Size
      217-B9, B10,B12,B13 (IOB)Open
      Paper size error
      Shorted
      Toner Overflow
      217-B15 (IOB)
      Open
      CPU cannot detect the toner overflow even the waste toner in the transfer belt unit is full.
      Shorted
      CPU detects the toner overflow even the waste toner in the transfer belt unit is not full.
      Component (Symbol)
      CN
      Condition
      Symptom
      Paper Feed 1
      216-A4 (IOB)
      Open/Shorted
      No symptom, but this may cause Jam A, and some pieces of paper are remaining at the paper feed unit when tray 1 is opened.
      Relay 1
      216-A7 (IOB)
      OpenJam A
      ShortedJam A, B
      Paper End 1
      216-A10 (IOB)
      Open
      The Paper End indicator lights even if paper is placed in the paper tray 1.
      Shorted
      The Paper End indicator does not light even if there is no paper in the paper tray 1.
      Tray Lift 1
      216-A13 (IOB)Open/ Shorted
      SC501 is displayed.
      Paper Feed 2
      216-B4 (IOB)
      Open/ Shorted
      No symptom, but this may cause Jam A and some pieces of paper are remaining at the paper feed unit when tray 2 is opened.
      Relay 2
      216-B7 (IOB)
      OpenJam A
      ShortedJam A, B
      Paper End 2
      216-B10 (IOB)
      Open
      The Paper End indicator lights even if paper is placed in the paper tray 2.
      Shorted
      The Paper End indicator does not light even if there is no paper in the paper tray 2.
      Trouble- shooting
      Component (Symbol)
      CN
      Condition
      Symptom
      Tray Lift 2
      216-B13 (IOB)Open/ Shorted
      SC502 is displayed.
      Registration
      209-2 (IOB)
      OpenJam A (Jam 8, 17)
      ShortedJam A, B (Jam 1)
      Paper Size 1
      209-4, 5, 5, 8 (IOB)Open/ Shorted
      Paper size error in tray 1
      Paper Size 2
      209-9, 10,
      11, 13 (IOB)
      Open/ Shorted
      Paper size error in tray 2
      Lower Paper Height 1
      210-4 (IOB)
      Open/ Shorted
      Remaining paper volume in tray 2 on the LCD is wrong.
      Lower Paper Height 2
      210-7 (IOB)
      Open/ Shorted
      Upper Paper Height 1
      210-12 (IOB)
      Open/ Shorted
      Remaining paper volume in tray 1 on the LCD is wrong.
      Upper Paper Height 2
      210-15 (IOB)
      Open/ Shorted
      Junction Jam
      221-A10 (IOB)Open/ Shorted
      Jam C
      Paper Exit
      221-B2 (IOB)
      OpenJam C
      ShortedJam C
      Fusing Exit
      221-B5 (IOB)
      OpenJam C
      ShortedJam C
      Component (Symbol)
      CN
      Condition
      Symptom
      Paper Overflow
      221-B8 (IOB)
      Open
      Paper overflow message is not displayed when a paper overflow condition exists.
      Shorted
      Paper overflow message is displayed when a paper overflow condition does not exist.
      TD (Toner Density)
      213-14 (IOB)
      Open
      The add toner indicator blinks even if there is toner in the development unit.
      ShortedSC390 is displayed.
      Web End
      208-16 (IOB)
      Open
      CPU detects the web end even the web is not used up.
      Shorted
      CPU cannot detect the web end even the web is used up.
      ID (Image Density)
      208-11 (IOB)
      OpenSC350 is displayed after copying.
      ShortedSC351 is displayed after copying.
      Fusing Entrance
      208-8 (IOB)
      Open
      CPU cannot detect paper even a sheet of paper remains at the fusing unit.
      Shorted
      CPU detects paper even a sheet of paper does not remain at the fusing unit.
      Scanner Home Position
      318-2 (SIO)
      OpenSC121 is displayed.
      ShortedSC120 is displayed.
      Component (Symbol)
      CN
      Condition
      Symptom
      Platen Cover
      318-5 (SIO)
      Open
      APS and ARE do not function properly.
      ShortedNo symptom.
      Original Length 1
      313-2 (SIO)
      Open/ Shorted
      CPU cannot detect the original size properly. APS and ARE do not function correctly.
      Original Length 2
      313-8 (SIO)
      Open/ Shorted
      Trouble- shooting
    2. SWITCHES​
      Component (Symbol)
      CN
      Condition
      Symptom
      Right Door
      221-B10 (IOB)
      Open
      "Open Cover" is displayed even if the right door is closed.
      Shorted
      The LCD goes blank when the right door is opened.
      Main Power
      903-1,2 (PSU)
      OpenThe machine does not turn on.
      ShortedThe machine does not turn off.
      Interlock
      913-1,2 (PSU)
      Open
      "Doors/Covers Open" is displayed even if the front or right door is closed.
      Shorted
      The LCD goes blank when the front or right door is opened.
  2. BLOWN FUSE CONDITIONS​
    • Use a correct rating fuse for the fuse replacement. Never use a wrong rating fuse. If do so, the machine may be damaged.
    Fuse
    Rating
    Symptom at power on
    115V210 to 230V
    Power Supply Board
    FU216.3A / 250V6.3A / 250VSC 533 (Power to IOB)
    FU226.3A / 250V6.3A / 250VSC 144-02 (Power to SIO)
    FU23
    10A / 250V
    10A / 250V
    "Open Cover" is displayed. (Power to Interlock Switch)
    FU24
    10A / 250V
    10A / 250V
    FU25
    6.3A / 250V
    6.3A / 250V
    Alert LED turns on and operation panel does not turn on. (Power to MB)
    FU26
    6.3A / 250V
    6.3A / 250V
    Stack paper in the optional paper feed unit or LCT is not detected. SC 503 is issued after opening and closing the tray 3 or 4. (Power to optional PFU or LCT)
    FU27
    6.3A / 250V
    6.3 A/ 250V
    The machine does not detect a finisher. (Power to optional Finisher)
    FU10115A / 250V8A / 250VNo response
    FU10212A / 250V4A / 250VNo response
    Trouble- shooting
  3. FUSES​
Fuse AddressPart No.Q'ty
FU11110712291
FU21, 22, 25, 26, 27110712955
FU23, 24110712162
FU101110712521
FU102110713201
FU103, 12, 14110712253
D129/D130​
SERVICE MANUAL APPENDICES​
D129/D130 APPENDICES​
TABLE OF CONTENTS​
  1. APPENDIX: GENERAL SPECIFICATIONS 1-1​
    1. GENERAL SPECIFICATIONS 1-1
      1. GENERAL 1-1
      2. POWER CONSUMPTION 1-4
      3. PRINTER CONTROLLER 1-5
      4. SCANNER SPECIFICATIONS 1-7
    2. OPTIONAL EQUIPMENT 1-8
      1.2.1 ARDF (D630) 1-8
      1.2.2 TWO-TRAY PAPER FEED UNIT (D580) 1-9
      1.2.3 LCT 2000-SHEET (D581) 1-9
      1.2.4 LCT 1200-SHEET (D631) 1-10
      1.2.5 1-BIN TRAY UNIT (D632) 1-10
      1.2.6 SIDE TRAY (D635) 1-11
        1. INTERNAL SHIFT TRAY (D633) 1-11
        2. BRIDGE UNIT (D634) 1-12
        1.2.9 1000-SHEET FINISHER (D588) 1-12
      Upper Tray 1-12
      Lower Tray 1-13
      1.2.10 3000-SHEET FINISHER (D636) 1-14
      1. 2000-SHEET BOOKLET FINISHER (D637) 1-16
      2. PUNCH UNIT FOR 2000/3000-SHEET (BOOKLET) FINISHER1-18
  2. APPENDIX: PM TABLES 2-1​
    1. PM TABLES 2-1
      1. MAINFRAME 2-1
      2. OPTIONS 2-5
        ARDF 2-6
        PFU 2-6
        LCT 2-7
        SR5020 2-7
        2000/3000-Sheet (Booklet) Finisher 2-8
        Rev. 11/15/2012
        Bridge Unit 2-8
        1-Bin Tray Unit 2-9
  3. APPENDIX: SERVICE PROGRAM MODE TABLES 3-1​
    1. SYSTEM SP TABLE-1 3-1
      1. SP1-XXX: FEED 3-1
    2. SYSTEM SP TABLES-2 3-17
      1. SP2-XXX: DRUM 3-17
    3. SYSTEM SP TABLE-3 3-43
      1. SP3-XXX: PROCESS 3-43
    4. SYSTEM SP TABLES-4 3-46
      1. SP4-XXX: SCANNER 3-46
    5. SYSTEM SP TABLES-5 3-79
      1. SP5-XXX: MODE 3-79
    6. SYSTEM SP TABLES-6 3-165
      1. SP6-XXX: PERIPHERALS 3-165
    7. SYSTEM SP TABLES-7 3-176
      1. SP7-XXX: DATA LOG 3-176
    8. SYSTEM SP TABLES-8 3-197
      1. SP8-XXX: DATA LOG 2 3-197
    9. INPUT CHECK 3-251
      1. COPIER 3-251
        Table 1: Paper Height Sensor 3-254
        Table 2: Paper Size Switch 3-255
        Table 3: Paper Size (By-pass Table) 3-256
        APS Original Size Detection 3-257
      2. OPTIONS 3-258
        3000/2000-Sheet (Booklet) Finisher (D636/D637) 3-258
        1000-Sheet Finisher (D588) 3-261
    10. OUTPUT CHECK 3-263
      1. COPIER 3-263
        3.10.2 1000-SHEET FINISHER (D588) 3-268
        3.10.3 3000 /2000-SHEET (BOOKLET) FINISHER (D636/D637) 3-269
    11. PRINTER SERVICE TABLES 3-271
      1. SP1-XXX (SERVICE MODE) 3-271
    12. SCANNER SERVICE TABLE 3-282
      1. SP TABLES 3-282
    13. DETAILED DESCRIPTION OF SP5-749 3-284
RE V IS ION H IST ORY
PageDateAdded/ Updated/ New
APPENDIX: SPECIFICATIONS​
Appendix: Specifications
  1. APPENDIX: GENERAL SPECIFICATIONS​
    1. GENERAL SPECIFICATIONS​
      1. GENERAL​
        ConfigurationDesktop
        Copy ProcessDry electrostatic transfer system
        OriginalSheet, book, three-dimensional object
        Original SizeMaximum A3/11" x 17"
        Copy Paper Size
        Paper trays:
        A3/11" x 17" - A5 LEF
        Non-standard sizes:
        Width: 182 - 297 mm (7.2" - 11.7")
        Length: 148 mm - 432 mm (5.8" - 17")
        By-pass tray:
        12" x 18"/305 x 457.2 mm, A3/11" x 17" - A6 SEF
        Non-standard sizes:
        Width: 90 - 305 mm (3.6" - 12")
        Length: 148 - 600 mm (5.8" - 23.6")
        Duplex:
        Non-standard sizes:
        Width: 90 - 297 mm (3.6" - 11.7")
        Length: 148 - 432 mm (5.8" - 17")
        Copy Paper Weight
        Paper trays:60 - 216 g/m2 (16 lb. Bond - 80 lb. Cover)
        By-pass:52 - 220 g/m2 (14 lb. Bond - 80 lb. Cover)
        Duplex:60 - 169 g/m2 (16 lb. Bond - 90 lb. Index)
        Reproduction Ratios
        7R5E:
        Metric version (%): 400, 200, 141, 122, 115,
        93, 82, 75, 71, 65, 50, 25
        Inch version (%): 400, 200, 155, 129, 121, 93,
        85, 78, 73, 65, 50, 25
        Zoom:25 to 400% in 1% steps
        Copying Speed
        D12940 cpm A4, 81/2" x 11" LEF, 1-to-1 (ADF)
        D13050 cpm, A4, 81/2" x 11" LEF, 1-to-1 (ADF)
        First Copy Time
        Basic4.1 s, 1st Tray, A4/81/2" x 11" LEF
        SP3.5 s, 1st Tray, A4/81/2" x 11" LEF
        Warm-up Time
        BasicLess than 14.7s
        SPLess than 19 s
        Continuous Copy1 to 999 (operation panel entry)
        Paper Capacity (without options)1,200 sheets
        (550 sheets/tray x 2 with 100 sheets in the by-pass tray)
        Paper Capacity (with options)
        4,400 sheets
        (550 sheets/tray x 2 with 100 sheets in the by-pass tray, 1200-sheet LCT and 2000-sheet LCT)
        Paper Output
        A4, 81/2" x 11" and smaller:
        500 sheets
        B4 and larger:250 sheets
        Power Source
        North America:120 – 127V/60 Hz, 12 A
        Europe/Asia:220 – 240 V/50, 60 Hz, 7 A
        Taiwan110V/60Hz, 14 A
        Dimensions (w x d x h)
        Without ADF
        670 mm x 682 mm x 760 mm (26.4" x
        26.9" x 30.0")
        With ADF
        670 mm x 682 mm x 895 mm (26.3" x
        26.9" x 35.3")
        Weight
        EULess than 85 kg (187.4 lb.)
        NALess than 97 kg (213.9 lb.)
        Resolution600 dpi (Scanning and Printing)
        Gradation256 levels (Scanning and Printing)
        Original Archive
        More than 2,500 A4 pages for document server (ITU-T No. 4 Chart)
        Toner ReplenishmentCartridge exchange (630 g)
        Total CounterElectric counter
        Noise Emission: Copying
        Mainframe OnlyFull System
        D12964.6 dB(A)71.1 dB(A)
        D13066.4 dB(A)71.6 dB(A)
        Noise Emission: Stand-by
        D12933.8 dB(A)34.0 dB(A)
        D13032.6 dB(A)33.6 dB(A)
      2. POWER CONSUMPTION​
        BasicD129D130
        Ready
        NA156 WNA165 W
        EU, Asia157 WEU, Asia166 W
        Operating
        NA745 WNA835 W
        EU, Asia742 WEU, Asia849 W
        Maximum
        NA1490 WNA1490 W
        EU, Asia1460WEU, Asia1460 W
        SPD129D130
        Ready
        NA160 WNA167 W
        EU, Asia159 WEU, Asia172 W
        Operating
        NA736 WNA828 W
        EU, Asia754 WEU, Asia864 W
        Maximum
        NA1490 WNA1490 W
        Full SystemD129D130
        Maximum
        NA1584 WNA1584 W
        EU, Asia1550 WEU, Asia1550 W
        • The above measurements were made in accordance with ISO 7779.
        • In the above "Panel Off" condition, the polygonal mirror motor is not rotating.
      3. PRINTER CONTROLLER​
        Printer Languages:
        PCL 6/5e
        PDF Direct
        Adobe PostScript 3 (optional) IPDS (optional)
        MediaPrint: JPEG/TIFF
        Resolution and Gradation:
        PCL 5e:
        300 x 300 dpi
        600 x 600 dpi : Fast (1-bit) PCL 6:
        600 x 600 dpi : Fast (1-bit) PDF Direct:
        300 x 300 dpi/600 x 600 dpi PS3:
        300 x 300 dpi/600 x 600 dpi XPS:
        600 x 600 dpi : Fast (1-bit) IPDS:
        300 x 300 dpi/ 600 x 600 dpi
        Printing speed:
        D129: Maximum 40 ppm (A4/LT LEF) D130: Maximum 50 ppm (A4/LT LEF)
        Resident Fonts:
        PCL 6/5e (Standard): 45 Compatible fonts, 13 International fonts, 6 Bitmap fonts
        PDF Direct: 136 fonts IPDS (Optional): 108 fonts
        Host Interfaces:
        USB2.0 Type A and Type B: Standard Ethernet (100 Base-TX/10 Base-T): Standard Gigabit Ethernet (1000 Base-T): Optional IEEE1284 parallel x 1: Optional IEEE802.11a/b/g (Wireless LAN): Optional Bluetooth (USB type): Optional
        Network Protocols:TCP/IP (IPv4, IPv6), IPX/SPX
        RAM:
        Maximum
        Basic model: 512 MB
        SP model: 1024 MB (Resident 512 MB + Additional 512)
        • Additional 512 MB is required for all printer/scanner unit and printer units.
      4. SCANNER SPECIFICATIONS​
        Standard Scanner Resolution:Main scan/Sub scan 100 to 600 dpi
        Available scanning Resolution Range:
        Twain Mode: 100 to 1200 dpi Delivery Mode:
        100/200/300/400/600 dpi
        Grayscales:1 bit or 8 bits/pixel each for RGB
        Scanning Throughput (ARDF mode):
        BW: 61 ipm (A4LEF / BW Text/ Photo / 200dpi /Compression: On (MH))
        FC: 31 ipm (A4LEF / FC Text / Photo / 200dpi / Compression: Standard)
        Interface:
        Ethernet 10Base-T / 100Base-TX, Gigabit Ethernet (1000Base-T), Wireless LAN (IEEE 802.11a/b/g)
        Compression Method:B&W: TIFF (MH, MR, MMR, JBIG2)
        Gray Scale/Full Color: JPEG
        Video Memory Capacity:
        109.41 MB (A4, Full Color, 600dpi)
        Image Storage Capacity:
        Number of originals per file: Maximum 1,000 pages Maximum of files: 3,000 files
        Storage on Doc.Server: Maximum 9,000 pages (B&W (ITU-T No.1/200 dpi MMR)
    2. OPTIONAL EQUIPMENT​
      1. ARDF (D630)​
        Paper Size/Weight:
        Simplex
        SizeA3 to A5, DLT to HLT
        Weight40 to 128 g/m2 (11 to 34 lb.)
        Duplex
        Weight52 to 128 g/m2 (14 to 34 lb.)
        Table Capacity:100 sheets (81.4 g/m2, 22 lb)
        Original Standard Position:Rear left corner
        Separation:Feed belt and separation roller
        Original Transport:Roller transport
        Original Feed Order:From the top original
        Supported Magnification Ratios:
        32 to 200 %
        Power Source:DC 24V, 5V from the scanner unit
        Power Consumption:Less than 70W
        Dimensions (W x D x H):570 mm x 520 mm x 135 mm (22.4"x20.5"x5.3")
        Weight:Less than 12kg (26.5 lb.)
      2. TWO-TRAY PAPER FEED UNIT (D580)​
        Paper Feed System:FRR
        Paper Height Detection:5 steps (100%, 70%, 30%, 10% (Near end), and Empty)
        Capacity:550 sheets x 2 trays
        Paper Weight:60 to 216 g/m2 (16 to 80 lb. Cover)
        Paper Size:A3 SEF to A5, DLT SEF to HLT
        Power Source:DC 24V, 5V (from the main frame)
        Power Consumption:Less than 40 W (Max.)/ Less than 25 W (Ave,)
        Dimensions (W x D x H):580 mm x 629 mm x 260 mm (22.8" x 24.8" x 10.2")
        Weight:26 kg (57.3 lb.)
        1.2.3 LCT 2000-SHEET (D581)​
        Paper Size:A4 LEF/LT LEF
        Paper Weight:60 g/m2 to 216 g/m2, 16 lb. Bond to 80 lb. Cover
        Tray Capacity:2,000 sheets (80 g/m2, 20 lb. Bond)
        Remaining Paper Detection:
        5 steps (100%, 70%, 30%, 10%, Empty): Right Tray
        4 steps (100%, 70%, 30%, Empty): Left Tray
        Power Source:DC 24 V, 5 V (from copier/printer)
        Power Consumption:45 W (Max.)/27 W (Ave.)
        Dimensions (W x D x H):580 mm x 620 mm x 260 mm (22.8" x 24.4" x 10.2")
        1.2.4 LCT 1200-SHEET (D631)​
        Paper SizeA4 LEF/ LT LEF/ B5 LEF
        Tray Capacity:1200 sheets (80 g/m2, 20lb. Bond)
        Remaining Paper Detection:5 steps (100%, 75%, 30%, 10%, End)
        Power Consumption:55 W (Max)/ 25 W (Ave.)
        Dimensions (W x D x H):348 mm x 540 mm x 290 mm (13.7" x 21.3" x 11.4")
        Weight:14 kg (30.8 lb.)
          1. 1-BIN TRAY UNIT (D632)​
            Paper Size:
            Standard Size:
            A3 /DLT to A6/ HLT SEF
            Paper Weight:60 to 169 g/m2, 16 to 45 lb. Bond
            Tray Capacity:125 sheets (80 g/m2, 20 lb. Bond, A4)
            Power Source:DC 24 V, 5 V (from the copier)
            Power Consumption:12 W or less
            Dimensions (W x D x H):565 mm x 410 mm x 115 mm (22.3"x16.2"x4.6")
            Weight:2 .5 kg (5.6 lb.)
          2. SIDE TRAY (D635)​
            Paper Size:
            Standard Size:
            Paper Weight:52 to 300 g/m2, 14 lb. Bond to 110 lb. Cover
            Tray Capacity:
            Internal tray:
            250 sheets (80 g/m2, 20 lb. Bond, A4/LT or smaller) 125 sheets (80 g/m2, 20 lb. Bond, B4, LG or larger)
            External tray:
            125 sheets (80 g/m2, 20 lb. Bond)
            Power Consumption:20 W or less
            Dimensions (W x D x H):780 mm x 412 mm x 138 mm (30.8"x16.3"x5.5")
            Weight:4.5 kg (10.0 lb.)
          3. INTERNAL SHIFT TRAY (D633)​
            Paper Size:
            Standard Size:
            Paper Weight:52 to 160 g/m2, 14 lb. Bond to 60 lb. Cover
            Tray Capacity:
            Power Consumption:10 W or less
            Dimensions (W x D x H):432 mm x 468 mm x 114 mm (16.7"x18.5"x4.5")
            Weight:2 kg (4.5 lb.)
          4. BRIDGE UNIT (D634)​
            Paper Weight:52 g/m2 to 256 g/m2, 16 lb. Bond to 68 lb. Bond
            Tray Capacity:
            Power Source:DC 24 V, 5 V (form the copier/printer)
            Dimensions (W x D x H):415 mm x 412 mm x 111 mm (16.3" x 16.2" x 4.4")
            Weight4 kg (8.9 lb.)
          5. 1000-SHEET FINISHER (D588)​
            Upper Tray
            Paper Size:
            12" x 18"/305 x 457.2 mm, A3 to A6, 11" x 17" to 5.5" x
            8.5"
            Paper Weight:52 to 256 g/m2 (14 to 68 lb. Bond)
            Paper Capacity:
            250 sheets (A4, LT or smaller) 50 sheets (B4, LG or larger)
            Lower Tray
            Paper Size:
            No staple mode:
            Staple mode:
            mm, A3 to B5, DLT to HLT mm, A3, B4, A4, B5, DLT to
            LT
            Paper Weight:
            No staple mode: 52 to 160 g/m2 (14 lb. Bond to 60 lb. Cover)
            Staple mode: 64 to 90 g/m2 (17 to 24 lb. Bond)
            Stapler Capacity:
            50
            30
            sheets sheets(A4,
            (A3,
            B5,
            B4,
            LT) DLT,
            LG)
            Paper Capacity:
            No staple mode:
            1,000 sheets (A4/LT or smaller: 80 g/m2, 20 lb.) 500 sheets (B4 /LG or larger: 80 g/m2, 20 lb.) Staple mode: (80 g/m2, 20 lb., number of sets)
            Paper SizeSheetsSets
            A4,/LT LEF, B5 LEF2 to 9100
            A4,/LT LEF,10 to 50100 to 20
            A4,/LT LEF, B5 LEF10 to 5050 to 10
            A3, B4, DLT, LG2 to 950
            A3, B4, DLT, LG10 to 3050 to 10
            Staple positions:Top, Bottom, 2 Staples
            Staple Replenishment:Cartridge (5,000 staples/cartridge)
            Power Source:DC 24 V, 5 V (from the copier/printer)
            Power Consumption:50 W
            Weight:25 kg (55.2 lbs)
            Dimensions(W x D x H):520 x 520 x 790 mm (20.5" x 20.5" x 31.2")
          6. 3000-SHEET FINISHER (D636)​
            Finisher
            Dimension (w x d x h) 657 mm x 613 mm x 960 mm (25.9" x 24.2" x 37.8")
            Weight
            Less than 54 kg (119 lb.) (no punch unit) Less than 56 kg (123.5 lb.) (with punch unit)
            Power Consumption Less than 96 W
            Noise Less than 75 db
            Configuration Console type attached base-unit
            Power Source From base-unit
            Stack Capacity
            250 sheets: A4, 8.5" x 11" or smaller
            50 sheets: B4, 8.5" x 14 or larger
            Proof Tray
            Paper Size
            A6 SEF, B6 SEF, A5-A3 SEF,
            5.5" x 8.5"-11" x 17" SEF, 12" x 18" SEF
            Paper Weight 52 g/m2 - 160 g/m2 (14 lb. Bond - 60 lb. Cover)
            3,000 sheets A4 LEF, 8.5" x 11" LEF
            Stack Capacity
            1,500 sheets
            A3 SEF, A4 SEF, B4 SEF, B5, 11" x 17" SEF, 8.5" x 14" SEF, 8.5" x 11" SEF,
            12" x 18" SEF
            Shift Tray
            500 sheets A5 LEF
            A5 SEF, B6 SEF, A6 SEF,
            100 sheets
            5.5" x 8.5" SEF
            Paper Size
            A5 - A3 SEF, A6 SEF, B6 SEF, 5.5" x 8.5"- 11" x 17" SEF, 12" x 18" SEF
            Paper Weight 52 g/m2 - 256 g/m2 (14 lb. Bond - 68 lb. Bond)
            Staples
            Paper Size
            B5 - A3
            8.5" x 11" - 11" x 17", 12" x 18"
            Paper Weight64 g/m2 - 90 g/m2 (17 lb. Bond - 20 lb. Bond)
            Staple PositionTop, Bottom, 2 Staple, Top-slant
            Stapling Capacity
            Same Paper Size
            50 sheetsA4, 8.5" x 11" or smaller
            30 sheetsB4, 8.5" x 14" or larger
            Mixed Paper Size
            30 sheets
            A4 LEF + A3 SEF, B5 LEF + B4 SEF, 8.5" x11" LEF + 11" x 17" SEF
            Staple ReplenishmentCartridge exchange / 5000 pins per cartridge
            Stapled Stack Capacity (same size)
            Paper SizePages/SetSets
            20 - 50 pages150 - 60 sets
            2 - 19 pages150 sets
            A4 SEF, B5, 8.5" x 11" SEF
            15 - 50 pages100 - 30 sets
            2 - 14 pages100 sets
            Others
            15 - 30 pages100 - 33 sets
            Stapled Stack Capacity (mixed sizes)
            A4 LEF & A3 SEF, B5 LEF & B4 SEF, 8.5" x11" LEF & 11" x 17" SEF,
            2 - 30 pages
            50 set
          7. 2000-SHEET BOOKLET FINISHER (D637)​
            Finisher
            Dimension W x D x H657 mm x 613 mm x 960 mm (25.9 x 24.2 x 37.8")
            Weight
            Less than 63 kg (138.6 lb.) (no punch unit) Less than 65 kg (143 lb.) (with punch unit)
            Power ConsumptionLess than 96 W
            NoiseLess than 75 db
            ConfigurationConsole type attached base-unit
            Power SourceFrom base-unit
            Proof Tray
            Stack Capacity
            Paper Size
            Paper Weight52 g/m2 - 160 g/m2 (14 lb. Bond - 60 lb. Cover)
            Shift Tray
            Stack Capacity
            2,000
            sheets
            1,000
            sheets
            A3 SEF, A4 SEF, B4 SEF, B5 11" x 17" SEF, 8.5" x 14" SEF,
            8.5" x 11" SEF, 12"x18" SEF
            500 sheetsA5 LEF
            100 sheets
            A5 SEF, B6 SEF, A6 SEF, 5.5" x 8.5" SEF
            Paper Size
            5.5" x 8.5" to 11" x 17" SEF, 12" x 18" SEF
            Paper Weight52 g/m2 - 256 g/m2 (14 lb. Bond - 68 lb. Bond)
            Staple
            Paper SizeB5-A3, 8.5" x 11" - 11" x 17", 12" x 18"
            Paper Weight64 g/m2 - 90 g/m2, 17 lb. Bond - 28 lb. Bond
            Staples Capacity
            Same Paper Size
            Mixed Paper Size
            30 sheets
            A4 LEF & A3 SEF, B5 LEF & B4 SEF, 8.5" x 11" LEF & 11" x 17" SEF
            Booklet Stapling
            15 sheets
            A4 SEF, A3 SEF, B5 SEF, B4 SEF, 8.5" x 11" SEF, 8.5" x 14" SEF,
            Corner staple
            5,000 staples per cartridge
            Booklet staple
            2,000 staples per cartridge
            Corner Staple Capacity
            Same Size
            13 - 50 pages
            2 - 12 pages
            10 - 50 pages
            2 - 9 pages
            Others
            10 - 30 pages
            2 - 9 pages
            Mixed Size
            A4 LEF + A3 SEF B5 LEF + B4 SEF
            8.5" x 11" LEF + 11" x 17" SEF
            2 - 30 pages
            Booklet Staple Capacity
            8.5" x 11" SEF, 8.5" x 14" SEF, 11" x 17" SEF
            12" x 18" SEF
            2 - 5 pages
            6 - 10 pages
            11 - 15 pages
          8. PUNCH UNIT FOR 2000/3000-SHEET (BOOKLET) FINISHER​
        Available Punch Units
        NA2/3 holes switchable
        EU2/4 holes switchable
        Scandinavia4 holes
        Punch Waste Replenishment
        NA 2-holesUp to 5,000 sheets
        NA 3-holesUp to 5,000 sheets
        EU 2-holesUp to 14,000 sheets
        EU 4-holesUp to 7,000 sheets
        Scandinavia 4-holes
        Up to 7,000 sheets
        Paper Weight52 g/m2 - 163 g/m2, 14 lb Bond - 43 lb Bond
        Paper Sizes
        NA 2-holes
        SEFA5 to A3, 5.5" x 8.5" to 11" x 17"
        LEFA5 to A4, 5.5" x 8.5" , 8.5" x 11"
        NA 3-holes
        SEFA3, B4, 11" x 17"
        LEFA4, B5, 8.5" x 11"
        EU 2-holes
        LEFA5 to A4, 5.5" x 8.5", 8.5" x 11"
        EU 4-holes
        SEFA3, B4, 11"x17"
        Scandinavia 4-holes
        APPENDIX: PREVENTIVE MAINTENANCE TABLES​
        REVISION HISTORY
        1 ~ 98/21/2012PM tables
  2. APPENDIX: PM TABLES​
    1. PM TABLES​
      Appendix: Preventive Maintenance Tables
      Amounts mentioned as the PM interval indicate the number of prints.
      1. MAINFRAME​
        Symbol key: C: Clean, R: Replace, L: Lubricate, I: Inspect
        EM160K320K800KNote
        Scanner/Optics
        ReflectorCOptics cloth
        1st MirrorCOptics cloth
        2nd MirrorCOptics cloth
        3rd MirrorCOptics cloth
        Scanner Guide RailsCDo not use alcohol.
        Exposure GlassCCCleaner
        Toner Shield GlassCCDry cloth or cleaner
        APS SensorCDry cloth
        Exposure Glass (Sheet through)
        Cleaner
        LED BoardC
        Drum (OPC) Area
        OPC DrumIR
        Charge RollerR
        Charge Roller Cleaning Roller
        Drum Cleaning Blade 1R
        EM160K320K800KNote
        Quenching LampCDry cloth
        Pick-off PawlsR
        SpursCCDry cloth
        ID Sensor
        Perform SP3-001-2 after blower brush cleaning.
        Cleaning Entrance Seal
        Blower brush. Replace if required.
        Side SealC
        Development Unit
        Development Drive Gears
        Dry cloth
        Development FilterR
        DeveloperIR
        Entrance SealCC
        Side SealI
        Development RollerCDry cloth
        Development CaseCC
        Development SleeveC
        Lock LeverCC
        Paper Feed
        Registration RollerICWater
        Idle Roller Dust Blade
        I
        Detach and tap gently on flat surface to empty.
        Blower brush.
        EM160K320K800KNote
        Registration Roller Dust Blade
        I
        Blower brush.
        Feed RollersICWater
        Pick-up RollersICWater
        Separation RollersICWater
        By-pass Feed RollerICWater
        By-pass Pick-up RollerICWater
        By-pass Separation Roller
        I
        Water
        Paper Feed GuidesICDry cloth
        Relay RollersICWater
        Bottom Plate PadICWater
        Bottom Plate Pad (By-pass feed)
        I
        Water
        Registration SensorICBlower brush
        By-pass Feed Roller Gear
        I
        L
        Silicone Grease G-501
        Relay SensorsICBlower Brush
        Paper Feed SensorsICBlower Brush
        Duplex Unit
        Inverter RollersICWater
        Transport RollersICWater
        Entrance SensorICWater
        Exit SensorICWater
        EM160K320K800KNote
        Transfer Belt Unit
        Transfer Belt
        Dry cloth.
        To prevent damage to the cleaning blade, always replace these items together.
        Transfer Belt Cleaning Blade
        Transfer Belt RollersCDry cloth
        Entrance SealCDry cloth
        Transfer Entrance GuideCCDry cloth
        Used Toner TankICEmpty the tank
        Seal (for paper dust)C
        Paper Exit
        Paper Exit SensorIIBlower brush
        Junction Gate Jam sensor
        I
        Blower brush
        Fusing Exit SensorIIBlower brush
        Paper Exit RollersIIWater
        Junction Transport RollerIIWater
        Paper Exit GuideIIWater
        • Due to their durability and extended service life, the feed rollers, separation rollers, and pick-up rollers of the mainframe, optional paper trays, and LCT are not replaced at PM.
          *1: Lubricate the by-pass feed clutch gear with Silicone Grease G501 every P.M.
          EM160K320K800KNote
          Fusing Unit and Paper Exit
          Fusing Entrance and Exit Guide Plates
          Water or alcohol
          Hot RollerR
          Pressure RollerR
          Fusing ThermistorsR
          Cleaning Roller Bushings
          L
          Grease: Barrierta JFE 55/2
          Hot Roller StrippersR
          Web Supply RollerR
          Web Holder RollerR
          Brake PadR
      2. OPTIONS​
Amounts mentioned as the PM interval indicate the number of prints/ originals. Symbol key: C: Clean, R: Replace, L: Lubricate, I: Inspect
ARDF
D630
EM
120K
(Originals)
Note
ARDF (for originals)
Pick-up RollerCRDamp cloth; alcohol
Feed BeltCRDamp cloth; alcohol
Separation RollerCRDamp cloth; alcohol
SensorsCBlower brush
Platen Sheet CoverCDamp cloth; alcohol (Replace if required.)
White PlateCDry or damp cloth
Drive GearLGrease G501
Transport RollerCDamp cloth; alcohol
Exit RollerCDamp cloth; alcohol
Inverter RollerCDamp cloth; alcohol
Idle RollersCDamp cloth; alcohol
 PFU
D580EM150K300K450KNote
Paper Feed Unit
Relay RollersCDry or damp cloth
Bottom Plate PadCDry or damp cloth
Relay SensorsCDry or damp cloth
Paper Feed SensorsCDry or damp cloth
Paper Feed RollersCDry or damp cloth
 LCT
D581EM150K300K450KNote
LCT 2000-sheet
D631EM150K300K450KNote
LCT 1200-sheet
B588EM150K300K450KNote
1000-Sheet Finisher
RollersCWater or alcohol.
Discharge BrushCCDry cloth
Jogger FencesIIReplace if required.
D637/D636EMNote
Discharge BrushCDry cloth
Jogger FencesIReplace if required.
Punch Unit
Punch ChadsCDiscard chads.
Bridge Unit
D634EMNote
Bridge Unit
Copy TrayCDry or damp cloth
