Ricoh MP4002/5002 service manual Part 11
D
Transfer belt contact motor error
The transfer belt HP sensor detects incorrect movement of the transfer belt after the transfer belt contact motor has turned on.
  • Dirty transfer belt HP sensor
  • Defective transfer belt contact motor
  • Disconnected connector of the transfer belt HP sensor or motor
  • Disconnected cable
  • Defective IOB
SC Tables: SC5xx​
501
B
1st tray lift malfunction
The tray lift sensor is not activated after the tray lift motor has been on for 10 seconds. If the main power switch is turned on when the paper is already at the feed height, the paper height position is detected again. At this time, the tray lift sensor should de-activate within 1.5 sec after the paper bottom plate starts to drop. If it does not deactivate within 1.5 sec., a message will prompt the user to reset Tray 1. After two attempts to release the error by re-setting the paper tray, if this does not solve the problem then this SC is displayed.
  • An obstruction (jammed paper, paper scraps, etc.) has blocked the motor drive and caused an overload.
  • Tray lift sensor connection loose, disconnected, or damaged
  • Tray lift sensor defective
  • Tray lift motor connection loose, disconnected, or damaged
  • Tray lift motor defective
Trouble- shooting
502
B
2nd tray lift malfunction
The tray lift sensor is not activated after the tray lift motor has been on for 10 seconds. If the main power switch is turned on when the paper is already at the feed height, the paper height position is detected again. At this time, the tray lift sensor should de-activate within 1.5 sec. after the paper bottom plate starts to drop. If it does not deactivate within 1.5 sec., a message will prompt the user to reset Tray 2. After two attempts to re-set the paper tray, if this does not solve the problem then this SC is displayed.
503B3rd tray lift malfunction (optional paper feed unit or LCT)
-01
For the paper feed unit:
  • SC 503-01 occurs if the lift sensor does not turn on within 10 seconds after the tray lift motor has turned on.
  • SC 503-01 occurs if the lift sensor does not turn on or turn off within 8 seconds after the tray lift motor has turned on to lift or lower the tray.
For the LCT:
  • Defective tray lift motor or connector disconnection
  • Defective lift sensor or connector disconnection
  • Defective stack transport clutch or connector disconnection
  • Defective tray motor or connector disconnection
  • Defective end fence home position sensor or connector disconnection
  • Defective upper limit sensor or connector disconnection
For the LCT:
-02
This SC is generated if the following condition occurs 3 consecutive times.
  • When the tray lowers, the tray lift sensor does not go off within 1.5 sec.
  • When the main switch is turned on or when the LCT is set, if the end fence is not in its position (home position sensor ON), the tray lift motor stops.
  • If the upper limit does not go off for 1.5 seconds even the tray lift motor turns on to lower the tray after the upper limit has been detected at power on.
For the LCT:
For the LCT:
504
B
4th tray lift malfunction (optional paper feed unit or LCT)
For the two-tray paper feed unit:
  • When the tray lift motor is turned on, the upper limit is not detected within 15 seconds. If this condition occurs three consecutive times, the SC is generated.
  • After the job is finished, if the end fence is not in the home position (home position sensor ON), the tray lift motor stops.
  • When the main switch is turned on or when the paper feed unit is set, if the end fence is not in the home position (home position sensor ON), the tray lift motor stops. If this condition occurs three consecutive times, the SC is generated.
  • If the upper or lower limit is not detected within 8 seconds when the tray lift motor is turned on to lift up or lower the tray.
For the LCT:
For the LCT:
Trouble- shooting
505
B
5th tray lift malfunction (optional LCT)
  • If the upper limit of the LCT 1200-sheet is not detected within 8 seconds when the tray lift motor is turned on to lift up the tray.
  • If the upper limit of the LCT 1200-sheet is not detected within 8 seconds when the tray lift motor is turned on to lift up or lower the tray.
  • The tray lift sensor of the LCT 1200-sheet does not go off within 1.5 seconds when the tray lowers. If this condition occurs three consecutive times, the SC is generated.
For the LCT:
  • Tray lift motor defective or disconnected
  • Upper limit sensor defective or disconnected
530
D
Fusing exhaust fan motor error
The IOB does not receive the lock signal for10 seconds after turning on the fusing exhaust fan.
  • Defective fusing exhaust fan motor or connector disconnection
  • Defective IOB
  • Disconnected harness
531
D
Exhaust fan motor error
The IOB does not receive the lock signal for 10 seconds after turning on the exhaust fan motor.
  • Defective exhaust fan motor or connector disconnection.
  • Defective IOB
532
D
Cooling fan motor error
The machine does not detect the fan motor lock signal for 10 seconds after turning on the cooling fan motor.
  • Defective cooling fan motor or connector disconnection.
  • Defective IOB
533
D
Paper exit cooling fan motor error
The machine does not detect the fan motor lock signal for 10 seconds after turning on the paper exit cooling fan motor.
  • Defective paper exit cooling fan motor or connector disconnection.
  • Defective IOB
540
D
Fusing motor error
The IOB does not receive the lock signal for 2 seconds after turning on the fusing motor.
  • Motor overload
  • Defective fusing motor or connector disconnection.
  • Defective IOB
Trouble- shooting
541
A
Fusing thermistor open (center)
The thermistor (center) detects 0°C or less for 5 sec.
  • Fusing thermistor disconnected
  • Fusing thermistor connector defective
542
A
Fusing temperature warm-up error(center)
This SC is generated if the following condition occurs:
  • The thermistor (center) does not detect an 8°C increment in the fusing temperature for 1.5 sec. just after the fusing temperature reached 45°C.
  • The temperature of the center thermistor does not reach the target temperature for 28 seconds after the fusing lamps turned on.
  • Thermistor warped or broken
543
A
Fusing overheat error 1 (software detection)
A fusing temperature (at the center) of over 230°C (446°F) is detected for 1 second by the fusing thermistors at the center or at either end of the fusing roller.
  • Power supply unit defective
  • I/O board (IOB) defective
  • BCU defective
  • TRIAC short on PSU (PSU defective)
544
A
Fusing overheat error 1 (hardware detection)
A fusing temperature (at the center) over 250°C is detected by the fusing temperature monitor circuit in the BCU board.
  • BCU defective
545
A
Fusing lamp consecutive full power 1
After warm-up the fusing lamp remains at full power for 15 seconds without the hot roller rotating.
  • Disconnected or defective thermistors (center)
  • Defective fusing lamp
547
D
Zero cross error
  • The zero cross signal is detected three times even though the heater relay is off when turning on the main power.
  • The zero cross signal is not detected for 2 seconds even though the heater relay is on after turning on the main power or closing the front door.
  • The detection error occurs twice or more in the 11 zero cross signal detections. This error is defined when the detected zero cross signal is less than 45.
  • Defective fusing lamp relay
  • Defective fusing lamp relay circuit
  • Unstable power supply
551
A
Fusing thermistor open (end)
The thermistor (end) detects 0°C or less for 5 sec.
  • Fusing thermistor (end) disconnected
  • Fusing thermistor (end) connector defective
552
A
Fusing temperature warm-up error (end)
  • The thermistor (end) does not detect an 8°C increment in the fusing temperature for 1.5 sec. just after the fusing temperature reached 45°C.
  • The temperature of the end thermistor does not reach the target temperature for 31 seconds after the fusing lamps turned on.
Trouble- shooting
553
A
A fusing temperature (at the end) of over 230°C (446°F) is detected for 1 second by the fusing thermistors at the center or at either end of the fusing roller.
  • BCU defective
554
A
A fusing temperature (at the end) over 250°C is detected by the fusing temperature monitor circuit in the BCU board.
  • BCU defective
555
A
After warm-up, the fusing lamp remains at full power for 40 seconds without the hot roller rotating.
  • Disconnected or defective thermistors (ends)
557
Zero cross frequency error
When the zero cross signal is 66 or more and it is detected 10 times or more in 11 detections, the machine determines that input 60 Hz and SC557 occurs.
  • Noise (High frequency)
559
A
Fusing unit jam
The fusing sensor detected a fusing unit paper late jam three times. The paper was late and the fusing exit sensor could not detect the paper three times.
  • Remove the paper that is stopped in the fusing unit.
  • Check that the fusing unit is clean and has no obstacles in the paper feed path.
  • If the error persists, replace the fusing unit.
  • SC559 does not operate until SP1159 has been set to "1" (ON). This sets the machine to count the number of occurrences of paper late jams in the fusing unit. The default setting is "0" (OFF).
  • SC559 is issued after the third occurrence of a paper late jam in the fusing unit. Once this SC has been issued, the machine cannot be used until the service technician removes the cause of the jam and restores it to normal operation.
  • The jam counter is reset after a sheet of paper successfully passes the fusing exit sensor after the cause of the jam has been removed.
    Trouble- shooting
    SC Tables: SC6xx​
    610
    D
    Mechanical counter error: BK
    This SC is only for NA models.
    The machine detects the mechanical counter error when SP5987-001 is set to "1".
    • Disconnected mechanical counter
    • Defective mechanical counter
    620DADF communication error
    -01
    Communication error between machine and ADF
    Communication error between machine and ADF with ASAP is detected.
    -02
    Communication error between IPU and ADF
    After the ARDF is detected, the break signal occurs or communication timeout occurs.
    • ARDF defective
    • IPU board defective External noise
    • Incorrect installation of ARDF
    • ARDF defective
    • External noise
    621
    D
    Communication timeout error between IOB and finisher or mailbox
    A break (low) signal is received from the finisher or the mailbox.
    • Defective IOB
    • Defective main board in the peripherals
    622
    D
    Paper feed unit communication error
    While the IOB communicates with a peripheral, an SC code is displayed if one of following conditions occurs.
    • The IOB receives the break signal which is generated by the peripheral only just after the main switch is turned on.
    • The IOB receives the break signal which is generated by URAT.
    • Defective main control board of the peripheral
    • Defective BCU or IOB
    • Disconnected peripheral
    623
    D
    2nd Paper Bank communication error
    This SC is not issued for this machine when a communication error signal between the 1st paper bank and 2nd paper bank is received.
    • Loose connector
    630
    CSS communication error
    A communication error occurred during communication with the CSS.
    • Communication line error
    632
    B
    MF accounting device error 1
    The controller sends data to the accounting device, but the device does not respond. This occurs three times.
    • Loose connection between the controller and the accounting device
    633
    B
    MF accounting device error 2
    After communication is established, the controller receives the brake signal from the accounting device.
    • Trouble- shooting
    634
    B
    MF accounting device error 3
    The accounting device sends the controller the report that indicates a backup RAM error has occurred.
    • Defective controller of the MF accounting device
    • Battery error
    635
    B
    MF accounting device error 4
    The accounting device sends the controller the report that indicates the battery voltage error has occurred.
    • Battery error
    636DIC Card Error
    -01
    D
    External authentication module error
    This SC is generated if the external authentication is enabled and following condition occurs:
    -02
    D
    Version error
    The version of the external authentication module is not correct.
    -11
    D
    OSM User Code File Error
    The correct "usercode" file could not be found in the root folder of the SD card because the file is not present, or the existing file is corrupted or the wrong type file.
    Make sure the eccm.mod file is in the root folder of the SD card.
    Note: Check the eccm.mod file is in the root folder of the SD card.
    • No external authentication module
    • SD card error or external authentication module broken
    • No DESS module
    • Incorrect module version
    -99
    D
    Management area error
    The management number of the external authentication module exceeds the maximum limit.
    • Software error
    637DTracking Information Notice Error
    -01
    D
    Tracking Application Error
    When the tracking information is lost, this SC is issued.
    -02
    D
    • The machine failed to give notice the tracking information to the tracking SDK application.
    • Tracking information is lost, and the machine cannot count correctly.
    • The machine failed to give notice the tracking information to the management server.
    641
    D
    BCU communication error
    The BCU does not respond to the frame transmitted from the controller.
    • Detective BCU
    • Trouble- shooting
    650
    Communication error of the remote service modem (Embedded RCG-M)
    -001
    Authentication error
    The authentication for the Embedded RCG-M fails at a dial up connection.
    Check and set the correct user name (SP5816-156) and password (SP5816-157).
    -004
    Incorrect modem setting
    Dial up fails due to the incorrect modem setting.
    Check and set the correct AT command (SP5816-160).
    -005
    The supplied voltage is not sufficient due to a defective communication line or defective connection.
    Consult with the user's local telephone company.
    -013
    Modem board error 1
    The modem board does not work properly even though the setting of the modem board is installed with a dial up connection.
    -014
    Modem board error 2
    The modem board is installed even though the RCG-N is installed.
    • Incorrect SP settings
    • Disconnected telephone line
    • Disconnected modem board
    • Same as -001
    • Same as -001
    • Same as -001
    • Install the modem board.
    • Check and reset the modem board setting with SP5816.
    • Replace the modem board.
    • Uninstall the modem board, if it is installed.
    • Check that the Wireless LAN or Ethernet LAN is working properly.
    651
    Incorrect dial up connection
    -001: Program parameter error
    -002: Program execution error
    An unexpected error occurs when the modem (Embedded RCG-M) tries to call the center with a dial up connection.
    • Caused by a software bug
    652
    D
    ID2 mismatching
    ID2 for @Remote certification is mismatching between the controller board and NVRAM.
    • Used controller board installed
    • Used NVRAM installed
    • Install the correct controller board or new controller board.
    • Install the correct NVRAM or new NVRAM.
    653
    D
    ID2 error
    ID2 stored in the NVRAM is incorrect.
    Clear the ID2 in the NVRAM, and then input a correct ID2.
    • Trouble- shooting
    669DEEPROM error
    [1]Open communication error: ID error
    [2]Open communication error: Channel error
    [3]Open communication error: Device error
    [4]Open communication error: Communication failed error
    [5]Open communication error: Communication time error
    [6]
    Open communication error: Communication suspended error
    [7]Open communication error: Buffer full error
    [8]Close communication error: No error code
    [9]Close communication error: ID error
    [10]Close communication error: No error code
    [11]Data write error: ID error
    [12]Data write error: Channel error
    [13]Data write error: Device error
    [14]Data write error: Communication suspended error
    [15]Data write error: Communication time over error
    [16]Data write error: Communication suspended error
    [17]Data write error: Buffer full error
    [18]Data write error: No error code
    [19]Data read error: ID error
    [20]Data read error: Channel error
    [21]Data read error: Device error
    [22]Data read error: Communication failed error
    [23]Data read error: Communication time over error
    [24]Data read error: Communication suspended error
    [25]Data read error: Buffer full error
    [26]Data read error: No error code
    [27]Device detection error: ID error
    [28]Device detection error: Channel error
    [29]Device detection error: Device error
    [30]Device detection error: Communication failed error
    [31]Device detection error: Communication time over error
    [32]Device detection error: Communication suspended error
    [33]Device detection error: Buffer full error
    [34]Device detection error: No error code
    Retry of EEPROM communication fails three times after the machine has detected the EEPROM error.
    • Caused by noise
    670
    D
    Engine startup error
    The BCU fails to respond with the prescribed time when the machine is turned on.
    • Connections between BCU and controller board are loose, disconnected, or damaged
    • Replace the BCU
    • Replace the controller board
    • Trouble- shooting
    672
    D
    Controller-to-operation panel communication error at startup
    Check the setting of SP5875-001. If the setting is set to "1 (OFF)", change it to "0 (ON)".
    • After the machine is powered on, the communication between the controller and the operation panel is not established, or communication with controller is interrupted after a normal startup.
    • After startup reset of the operation panel, the attention code or the attention acknowledge code is not sent from the controller within 30 seconds.
    • After the controller issues a command to check the communication line with the controller at 30-second intervals, the controller fails to respond twice.
    • Controller stalled
    • Controller board installed incorrectly
    • Controller board defective
    • Operation panel connector loose or defective
    • The controller is not completely shutdown when you turn the main switch off.
    674
    D
    Transmission error in controller board
    Video transmission error is detected in the controller board.
    • Defective Controller Board
    687
    D
    Memory address (PER) command error
    The BCU does not receive a memory address command from the controller for the prescribed time after the paper has reached the registration sensor.
    • Harness Disconnection at BCU
    • Controller board loose or broken
    • Defective BCU
    • SC Tables: SC7xx
    700DScanner feeding error 1
    01
    Pick-up roller HP error
    When the pick-up motor turns on counterclockwise, the pick-up roller HP sensor does not detect the home position of the pick-up roller.
    02
    Original stopper HP error
    When the pick-up motor turns on clockwise, the original stopper HP sensor does not detect the home position of the original stopper.
    DF fan motor 1 error
    DF fan motor lock signal is detected after the original transportation has finished.
    • Defective pick-up roller HP sensor
    • Defective pick-up motor
    • Defective DF drive board
    • Defective original stopper HP sensor
    • Turn the main switch off and on.
    701DScanner feeding error 2
    02
    Pick-up motor driver error
    The error flag of the pick-up motor driver IC is asserted when the jam error is issued.
    Pick-up motor driver detected an error.
    Trouble- shooting
    03
    Paper feed motor error
    The error flag of the paper feed motor driver IC is asserted when the jam error is issued.
    720B2000/3000-Sheet (booklet) Finisher Error
    -24
    Finisher exit guide plate motor error
    After moving away from the guide plate position sensor, the exit guide is not detected at the home position within the prescribed time.
    The 1st detection failure issues a jam error, and the 2nd failure issues this SC code.
    -25
    Finisher punch motor error
    The punch HP sensor is not activated within the specified time after the punch motor turned on.
    The 1st detection failure causes a jam error, and the 2nd failure causes this SC code.
    • Guide plate motor disconnected, defective
    • Guide plate motor overloaded due to obstruction
    • Guide plate position sensor disconnected, defective
    • Punch HP sensor disconnected, defective
    • Punch motor disconnected or defective
    • Punch motor overload due to obstruction
    -30
    Finisher jogger motor error
    The jogger fences move out of the home position but the HP sensor output does not change within the specified number of pulses.
    The 1st failure issues an original jam message, and the 2nd failure issues this SC code.
    -41
    Stack feed-out motor error
    -42
    Finisher stapler movement motor error
    Staple movement is not finished within a certain time.
    • Jogger HP sensor disconnected, defective
    • Jogger motor disconnected, defective
    • Jogger motor overloaded due to obstruction
    • Finisher main board and jogger motor
    • The stack feed-out HP sensor does not detect the home position of the stack feed-out belt 3000ms after the stack feed-out belt has moved to its home position.
    • The stack feed-out HP sensor does not turn off 200 ms after the stack feed-out belt has moved from its home position.
    • Defective stack feed-out HP sensor
    • Overload on the stack feed-out motor
    • Defective stack feed-out motor
    • Disconnected or defective harness
    • Motor overload
    • Loose connection of the stapler home position sensor
    • Loose connection of the stapler movement motor
    • Defective stapler home position sensor
    • Defective stapler movement motor
    • Trouble- shooting
    -43
    Finisher corner stapler rotation motor error
    The stapler does not return to its home position within the specified time after stapling.
    -44
    Finisher corner stapler motor error
    • Defective stapler rotation motor
    • Overload on the stapler rotation motor
    • Defective stapler rotation HP sensor
    • The stapler motor does not switch off within the prescribed time after operating.
    • The HP sensor of the staple unit does not detect the home position after the staple unit moves to its home position.
    • The HP sensor of the staple unit detects the home position after the staple unit moves from its home position.
    • Staple jam
    • Motor overload
    • Defective stapler motor
    -52
    Finisher folder plate motor error
    The folder plate moves but is not detected at the home position within the specified time.
    -53
    Folding unit bottom fence lift motor
    The folding unit bottom fence movement is not finished within a certain time. The 1st detection failure causes a jam error, and the 2nd failure causes this SC code.
    -55
    Clamp roller retraction motor error
    The clamp roller movement is not finished within a certain time.
    -57
    Stack junction gate motor error
    The stack junction gate motor moves but the stack junction gate is not detected at its position within a specific time.
    • Folder plate HP sensor disconnected, defective
    • Folder plate motor disconnected, defective
    • Folder plate motor overloaded due to obstruction.
    • Motor harness loose, broken
    • Motor drive obstructed
    • Motor defective
    • Motor defective
    • Motor broken
    • Motor connection loose
    • Motor overloaded
    • -60
      Booklet stapler motor error 1
      The front stapler unit saddle-stitch motor does not start operation within the specified time.
      -61
      Booklet staple motor error 2
      The rear stapler unit saddle-stitch motor does not start operation within the specified time.
      -70
      Tray lift motor error
      The upper tray paper height sensor does not change its status with the specified time after the tray raises or lowers.
    • Motor overload
    • Loose connection of the front stapler motor
    • Defective front stapler motor
    • Motor overload
    • Loose connection of the rear stapler motor
    • Defective rear stapler motor
    • Motor overload
    • Loose connection of the tray lift motor
    • Trouble- shooting
    -71
    Finisher Tray 1 shift motor error
    The shift roller HP sensor of the upper tray does not activate within the prescribed time after the shift tray starts to move toward or away from the home position.
    -72
    Shift jogger motor 1 error
    The side fence does not retract within the prescribed time after the shift jogger motor 1 switches on.
    -73
    Shift jogger motor 2 error
    The side fence does not retract within the prescribed time after the shift jogger motor 2 switches on.
    • Shift tray HP sensor of the upper tray disconnected, defective
    • Shift tray motor of the upper tray disconnected, defective
    • Shift tray motor of the upper tray overloaded due to obstruction
    • Shift jogger motor 1 disconnected, defective
    • Shift jogger motor 1 overloaded due to obstruction
    • Shift jogger 1 HP sensor disconnected, defective
    • Shift jogger motor 2 disconnected, defective
    • Shift jogger motor 2 overloaded due to obstruction
    • Shift jogger 2 HP sensor disconnected, defective
    • Trouble- shooting
    -74
    Shift jogger retraction motor error
    The side fences do not retract within the prescribed time after the retraction motor switches on.
    -75
    Return roller motor error
    This occurs during the operation of the lower tray pressure motor
    -80
    Punch movement motor error
    The punch unit moves but is not detected at the home position within the specified time.
    -81
    Paper position sensor slide motor error
    The paper position sensor moves but is not detected at the home position within the specified time.
    • Shift jogger retraction motor broken
    • Shift jogger retraction motor connection loose
    • Shift jogger retraction motor overloaded
    • Defective shift jogger retraction HP sensor
    • Motor harness disconnected, loose, defective
    • Motor overloaded
    • Home position sensor harness disconnected, loose, defective
    • Home position defective
    • Defective motor
    • Defective motor
    • 722B1000-Sheet Finisher Error
      -10
      Upper transport motor error
      The upper transport motor in the finisher is not operating.
      -14
      Lower transport motor error
      The lower transport motor in the finisher is not operating.
      -17
      Exit motor error
      The exit motor in the finisher is not operating.
      -24
      The exit guide plate HP sensor did not activate within the prescribed time after the exit guide plate motor turned on.
    • Upper transport motor drive is obstructed (jammed paper, paper scraps, etc.)
    • The motor harness is loose or broken
    • Upper transport motor defective
    • Lower transport motor drive is obstructed (jammed paper, paper scraps, etc.)
    • Lower transport motor defective
    • Exit motor drive is obstructed (jammed paper, paper scraps, etc.)
    • Exit motor defective
    • Finisher exit guide plate motor drive is obstructed (jammed paper, paper scraps, etc.)
    • Exit guide plate motor harness loose, broken
    • Exit guide plate HP sensor harness loose, broken
    • Exit guide plate motor defective
    • Exit guide plate HP sensor defective
    • Trouble- shooting
    -30
    Front fence motor error
    The jogger fence motor in the finisher is not operating.
    -41
    Feed-out belt motor error
    The feed-out belt did not return to the home position within the prescribed time.
    -42
    Stapler movement motor
    The 1st detection failure issues a jam error, and the 2nd failure causes this SC code.
    The stapler HP sensor is not activated within the specified time after the stapler motor turned on.
    • Jogger motor drive is obstructed (jammed paper, paper scraps, etc.)
    • Jogger fence HP sensor dirty, loose, defective
    • Jogger fence motor defective
    • Feed-out belt motor drive is obstructed (jammed paper, paper scraps, etc.)
    • Motor harness loose or broken
    • Feed-out belt HP sensor dirty, disconnected, broken
    • Motor defective
    • Stapler or motor drive is blocked by obstruction
    • Stapler HP sensor harness loose, broken
    • Motor defective
    • Stapler HP sensor defective
    -44
    Corner stapler motor error
    -70
    The tray lift motor is not operating.
    -71
    Shift tray motor error
    The shift tray motor is not operating.
    • Staple jam
    • Number of sheets in stack exceeds allowed number of sheets for stapling
    • Stapler motor obstructed
    • Stapler motor defective
    • Stack height sensor dirty, harness loose, broken
    • Motor defective
    • Stack height sensor defective
    • Shift motor drive is obstructed (jammed paper, paper scraps, etc.)
    • Shift motor harness loose, broken
    • Shift tray HP sensor harness loose, broken
    • Shift motor defective
    • Shit tray HP sensor defective
    • Trouble- shooting
    770
    B
    Shift motor error
    The shift motor HP sensor does not detect any change for 1.86 seconds after the shift motor has turned on at power on or during its operation.
    • Defective shift motor
    • Defective shift motor HP sensor
    791
    D
    Bridge unit error
    The machine recognizes the finisher, but does not recognize the bridge unit.
    • Defective connector
    • Broken harness
    792
    B
    Finisher error
    The machine does not recognize the finisher, but recognizes the bridge unit.
    • Defective harness
    • SC Tables: SC8xx
    816
    D
    Energy save I/O sub-system error
    Energy saver sub-system detects an error.
    • Defective controller board
    817
    D
    Monitor Error
    This is a file detection and electronic file signature check error when the boot loader attempts to read the self-diagnostic module, system kernel, or root system files from the OS Flash ROM, or the items on the SD card in the controller slot are false or corrupted.
    • OS Flash ROM data defective; change the controller firmware
    • SD card data defective; use another SD card
    818
    D
    Watchdog timer error
    The watchdog timer detect the error even if system processing normally.
    • System program defective
    • Optional board defective
    819
    Fatal kernel error
    Due to a control error, a RAM overflow occurred during system processing. One of the following messages was displayed on the operation panel.
    0x62616261 6420 6469 7200 00 -> "bad dir"
    0x696e0x69742064 -> "init died"
    0x766d0x5f706167 -> "vm_pageout: VM is full"
    554CUL (USB error)
    ----Error in the OS
    "init died", "vm_pageout: VM is full", "Cache Error"
    • Replace controller firmware
    Trouble- shooting
  • For more details about this SC code error, execute SP5990 to print an SMC report so you can read the error code. The error code is not displayed on the operation panel.
    820
    CTL DSelf-diagnostics error: CPU [XXXX]: Detailed error code
    [0001] to [06FF]
    [0801] to [4005]
    CPU error
    During the self-diagnostic, the controller CPU detects an error. There are 47 types of error code (0001 to 4005) depending on the cause of the error. The CPU detects an error and displays the specific error code with the program address where the error occurs.
    When the problem cannot be fixed with the above procedure, the following information displayed on the screen needs to be fed back to a technical support center.
    [0701] to [070A]
    CPU/Memory Error
    • System firmware problem
    • Reinstall the controller system firmware.
    • Replace the controller.
    • SC code
    • Detailed error code
    • Program address
    • Defective RAM-DIMM
    1. Reinstall the controller system software.
    2. Replace the RAM-DIMM.
    3. Replace the controller.
    821
    D
    Self-diagnostics error: ASIC [XXXX]: Detailed error code
    [0B00]
    ASIC error
    The write-&-verify check error has occurred in the ASIC.
    [0D05]
    Self-diagnosis error: ASIC
    The CPU checks if the ASIC timer works correctly compared with the CPU timer. If the ASIC timer does not function in the specified range, this SC code is displayed.
    [50A1]
    Video bridge device (ASIC) error 1
    The CPU does not detect the video bridge device.
    [50A2]
    Video bridge device (ASIC) register error 1
    The CPU detects the video bridge device, but detects error data from the video bridge device.
    • Defective ASIC device Replace the controller board.
    • Defective controller Replace the controller board.
    • Defective I/F between the video bridge device and controller
    Trouble- shooting
822BSelf-diagnostic error: HDD
[3003]
Check performed only when HDD is installed:
  • HDD device busy for over 31 s.
  • After a diagnostic command is set for the HDD, but the device remains busy for over 6 s.
  • HDD defective
  • HDD harness disconnected, defective
[3004]No response to the self-diagnostic command from the ASIC to the HDDs.
  • HDD defective
823
B
Self-diagnostic error: NIB [XXXX]: Detailed error code
[6101]
MAC address check sum error
The result of the MAC address check sum does not match the check sum stored in ROM.
[6104]
PHY IC error
The PHY IC on the controller cannot be correctly recognized.
[6105]
PHY IC loop-back error
An error occurred during the loop-back test for the PHY IC on the controller.
824
D
Self-diagnostic error : NVRAM
NVRAM device does not exist, NVRAM device is damaged, or NVRAM socket damaged.
  • NVRAM defective
  • NVRAM backup battery exhausted
  • NVRAM socket damaged
Trouble- shooting
826DSelf-diagnostic Error: RTC/optional NVRAM
[1501]
The one second counted by the RTC is different from the one second counted by the CPU on the controller.
  • Defective RTC device
[15FF]The RTC device is not detected.
  • NVRAM without RTC installed
  • Discharged backup battery
827
D
Self-diagnostic error: Standard SDRAM DIMM [XXXX]: Detailed error code
[0201]
Verification error
Error detected during a write/verify check for the standard RAM (SDRAM DIMM).
  • Loose connection
  • Defective SDRAM DIMM
[0202]Resident memory error
The SPD values in all RAM DIMM are incorrect or unreadable.
  • Defective RAM DIMM
  • Defective SPD ROM on RAM DIMM
  • Defective 12C bus
Replace the RAM DIMM.
828
D
Self-diagnostic error: ROM [XXXX]: Detailed error code
[0101]
Check sum error 1
  • The boot monitor and OS program stored in the ROM DIMM is checked. If the check sum of the program is incorrect, this SC code is displayed.
1. Replace the controller board.
829
D
Self-diagnostic error: Optional RAM [XXXX]: Detailed error code
[0301]
Verification error
Error detected during a write/verify check for the optional RAM (SDRAM DIMM).
  • Loose connection
Turn the main switch off and on. Replace the SDRAM DIMM. Replace the controller.
[0302]
Memory structure data error
The memory structure data error for the optional RAM (SDRAM DIMM) is detected when the self-diagnostic is executed.
  • Defective 12C bus
Trouble- shooting
833CSelf-diagnostic error 8: Engine I/F ASIC
[0F30]
[0F31]
ASIC (Mandolin) for system control could not be detected. After the PCI configuration, the device ID for the ASIC could not be checked.
Replace the IPU.
[0F41]
Replace the IPU.
[50B1]
Could not initialize or read the bus connection.
Check for loose connections at the mother board.
Replace the IPU.
[50B2]
Value of the SSCG register is incorrect.
Replace the IPU.
835CSelf-diagnostic error: Centronic device
[1102]
Loopback connector is connected but check results in an error.
  • IEEE1284 connector error
  • Centronic loopback connector defective Replace the controller board.
[110C]Loopback connector is connected but check results in an error.
  • ASIC device error
[1120]Centronic loopback connector is not connected for detailed self-diagnostic test.
  • Centronic loopback connector not connected correctly
  • ASIC device defective
838BSelf-diagnostic Error: Clock Generator
[2701]
A verify error occurred when setting data was read from the clock generator via the I2C bus.
  • Defective clock generator
  • Defective I2C bus
  • Defective I2C port on the CPU Replace the controller board.
Trouble- shooting
839CUSB NAND Flash ROM error
[9001]
USB NAND Flash ROM cannot be read.
[9101]The ID of the USB NAND Flash ROM cannot be read.
[9110]The USB NAND Flash ROM controller is disconnected.
840
B
EEPROM error 1: EEPROM access
  • During the I/O processing, a reading error occurred. The 3rd reading failure causes this SC code.
  • During the I/O processing, a writing error occurred.
Defective EEPROM
841
B
EEPROM error 2: EEPROM read/write error
Mirrored data of the EEPROM is different from the original data in EEPROM.
Data in the EEPROM is overwritten for some reason.
842
B
Flash ROM verification error
Verification error of the flash ROM on the controller board occurs.
  • This SC is logged at 1st error detection.SC819 is issued at 2nd error detection.
  • SC819 is issued at 2nd error detection.
Defective flash ROM (controller board)
851
B
IEEE 1394 I/F error
Driver setting incorrect and cannot be used by the 1394 I/F.
Not supported by this machine
  • NIB (PHY), LINK module defective; change the Interface Board Controller board defective
853
B
Wireless LAN Error 1
During machine operation, the Wireless LAN device (Bluetooth) is inserted into the controller board.
  • During machine operation, the Wireless LAN device (Bluetooth) is inserted into the controller board.
854
B
Wireless LAN Error 2
During machine operation, the Wireless LAN device (Bluetooth) is pulled out from the controller board.
  • During machine operation, the Wireless LAN device (Bluetooth) is pulled out from the controller board.
855
B
Wireless LAN error 3
An error is detected on the wireless LAN card (802.11a/g, g).
  • Wireless LAN card defective
  • Wireless LAN card connection incorrect
857
B
USB I/F Error
The USB driver is not stable and caused an error.
  • Bad USB card connection Replace the controller board
Trouble- shooting
858
HDD Encryption unit error 1
A serious error occurs when data is encrypted to update an encryption key with the HDD encryption unit.
-00
Encryption key acquisition error:
The controller fails to get a new encryption key.
  • Defective controller board Replace the controller board.
-01
Encryption key setting for HDD error:
The controller fails to copy a new encryption key to the HDD.
  • Defective SATA chip on the controller board Replace the controller board.
-02
NVRAM data encryption error 1:
An error occurs while the NVRAM data is encrypted.
  • Defective NVRAM on the controller board Replace the NVRAM.
-30
NVRAM data encryption error 2:
An error occurs before the NVRAM data is encrypted.
-31
Other error:
A serious error occurs while the data is encrypted.
  • Same as SC991
859
HDD Encryption unit error 2
A serious error occurs when the HDD data is encrypted to update an encryption key with the HDD encryption unit.
-08
HDD check error:
The HDD is not correctly installed.
  • No HDD installed
  • Unformatted HDD
  • The encryption key on the controller is different from the one on the HDD
  1. Install the HDD correctly.
  2. Initialize the HDD.
-09
Power failure during the data encryption:
The data encryption (NVRAM and HDD) has not been completed.
  • Power failure during the data encryption Initialize the HDD.
-10
Data read/write error:
The DMAC error is detected twice or more.
  • Same as SC863
860
B
HDD startup error at main power on
  • HDD is connected but a driver error is detected.
  • The driver does not respond with the HDD within 30 s.
  • HDD is not initialized
  • Label data is corrupted
  • Defective HDD
Initialize the HDD with SP5832-001.
Trouble- shooting
861
D
HDD re-try failure
At power on, the HDD is detected. Power supply to the HDD is interrupted after the system has entered the energy save mode, but after the HDD has been awakened from the energy save mode, it does not return to the ready status within 30 sec.
  • Harness between HDD and controller board disconnected, defective
  • HDD power connector disconnected
  • HDD defective
862
D
Bad sector number error
The number of bad sectors in the HDD (image data area) goes over 101.
  • Defective HDD
Format the HDD with SP5-832-002. Replace the HDD.
863DHDD data read failure
The data written to the HDD cannot be read normally, due to bad sectors generated during operation.
Note: [001] to [017] indicate the type of partition where the error occurred. Enable display of these numbers with SP7902.
[001]An area which does not belong to a partition
[002]a partition
[003]b partition
[004]c partition
[005]d partition
[006]e partition
[007]f partition
[008]g partition
[009]h partition
[010]i partition
[011]j partition
[012]k partition
[013]l partition
[014]m partition
[015]n partition
[016]o partition
[017]p partition
[018]q partition
[019]r partition
[020]s partition
[021]q partition
[022]t partition
[023]u partition
  • HDD defective
Note: If the bad sectors are generated at the image partition, the bad sector information is written to NVRAM, and the next time the HDD is accessed, these bad sectors will not be accessed for read/write operation.
Trouble- shooting
864DHDD data CRC error
During HDD operation, the HDD cannot respond to a CRC error query. Data transfer does not execute normally while data is being written to the HDD. Note: [001] to [017] indicate the type of partition where the error occurred. Enable display of these numbers with SP7902.
[002]a partition
[003]b partition
[004]c partition
[005]d partition
[006]e partition
[007]f partition
[008]g partition
[009]h partition
[010]i partition
[011]j partition
[012]k partition
[013]l partition
[014]m partition
[015]n partition
[016]o partition
[017]p partition
[018]q partition
[019]r partition
--[020]s partition
[021]q partition
[022]t partition
[023]u partition
  • HDD defective
865DHDD access error
HDD responded to an error during operation for a condition other than those for SC863, 864.
[002]a partition
[003]b partition
[004]c partition
[005]d partition
[006]e partition
[007]f partition
[008]g partition
[009]h partition
[010]i partition
[011]j partition
[012]k partition
[013]l partition
[014]m partition
[015]n partition
[016]o partition
[017]p partition
[018]q partition
[019]r partition
[020]s partition
[021]q partition
[022]t partition
[023]u partition
  • HDD defective.
Trouble- shooting
866
B
SD card error 1: Confirmation
The machine detects an electronic license error in the application on the SD card in the controller slot immediately after the machine is turned on. The program on the SD card contains electronic confirmation license data. If the program does not contain this license data, or if the result of the check shows that the license data in the program on the SD card is incorrect, then the checked program cannot execute and this SC code is displayed.
  • Program missing from the SD card
  • Download the correct program for the machine to the SD card
867
D
SD card error 2: SD card removed
The SD card in the slot is removed while the machine is on.
Insert the SD card, then turn the machine off and on.
868
D
SD card error 3: SC card access
An error occurs while an SD card is used.
  • SD card not inserted correctly
  • SD card defective
Note: If you want to try to reformat the SC card, use SD Formatter Ver 1.1.
870
B
Address book data error
The address book data cannot be read from the HDD, SD card or flash ROM on the controller where it is stored, or the data read from the media is defective.
  • Software defective:
  • HDD defective.
Turn the machine off/on. If this is not the solution for the problem, then replace the controller firmware.
More Details
  • Do SP5846-046 (Initialize All Setting & Addr Book) to reset all address book data.
  • Reset the user information with SP5832-006 (HDD Formatting– User Information).
  • Replace the HDDs.
872
B
HDD mail receive data error
  • The machine detects that the HDD is not operating correctly at power on.
  • The machine detects that the HDD is not operating correctly (can neither read nor write) while processing incoming email.
  • HDD defective
  • The machine is turned off while the HDD is being accessed. Do SP5832-008 to format the mail RX data on the HDD.
Trouble- shooting
873
B
HDD mail send data error
An error is detected on the HDD immediately after the machine has been turned on, or power has been turned off while the machine has used the HDD.
  1. Do SP5832-008 (Format HDD – Mail TX Data) to initialize the HDD.
  2. Replace the HDD
874
D
Delete All error 1: HDD
A data error is detected for the HDD/NVRAM after the Delete All option has been used.
Note: The source of this error is the DataOverwriteSecurity Unit running from an SD card.
  1. Turn the main switch off/on and try the operation again.
  2. Install the DataOverwriteSecurity Unit again. For more, see "Installation".
  3. HDD defective
875
D
Delete All error 2: Data area
An error occurs while the machine deletes data from the HDD.
Note: The source of this error is the DataOverwriteSecurity Unit (D362) running from an SD card.
-001An error occurs in hddchack-i.
-002Failed to delete data from the HDD.
-003
