Photocopier and Printer
Ricoh
Ricoh MP C2004/C2504 Service Manual Part 32
<blockquote data-quote="John" data-source="post: 78" data-attributes="member: 2"><p> <table style='width: 100%'><tr><td>4-611-001</td><td>Book Scan</td><td>*ENG</td><td>[-384 to 255 / -<strong>100 </strong>/ 1digit/step]</td></tr><tr><td>4-611-002</td><td>DF Scan</td><td>*ENG</td><td>[-384 to 255 / -<strong>100 </strong>/ 1digit/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4635</td><td>[SSCG Correction Set]</td><td></td><td></td></tr><tr><td>4-635-001</td><td>Mode Selection</td><td>*ENG</td><td>[0 to 3 / <strong>1 </strong>/ 1/step]<br /> 0: Do not noise correct SSCG.<br /> 1: Only adjust analog (initial value) 2: Only adjust digital<br /> 3: Adjust both analog/digital</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4646</td><td>[Scan Adjust Error]</td><td></td><td></td></tr><tr><td>4-646-001</td><td>White level</td><td>ENG</td><td>[0 to 65535 / <strong>0 </strong>/ 1/step] Bit15:Unused<br /> Bit14: Unused<br /> Bit13:White level abnormal (F side/RED/EVEN pixel)<br /> Bit12: White level abnormal (F side /RED/ODD pixel)<br /> Bit11: White level abnormal (F side<br /> /GREEN/EVEN pixel)<br /> Bit10: White level abnormal (F side /GREEN/ODD pixel)<br /> Bit9: White level abnormal (F side /BLUE/EVEN pixel)<br /> Bit8:White level abnormal (F side /BLUE/ODD pixel)<br /> Bit7: Unused Bit6: Unused<br /> Bit5:gain abnormal (F side /RED/EVEN pixel) Bit4: gain abnormal (F side /RED/ODD pixel) Bit3: gain abnormal (F side /GREEN/EVEN pixel) Bit2: gain abnormal (F side /GREEN/ODD pixel) Bit1: gain abnormal (F side /BLUE/EVEN pixel) Bit0: gain abnormal (F side /BLUE/ODD pixel)</td></tr></table> <table style='width: 100%'><tr><td>4-646-002</td><td>Black level</td><td>ENG</td><td>[0 to 65535 / <strong>0 </strong>/ 1/step] Bit7: Unused<br /> Bit6: Unused<br /> Bit5: Black level abnormal (F side/RED/EVEN Pixel)<br /> Bit4: Black level abnormal (F side /RED/ODD Pixel)<br /> Bit3: Black level abnormal (F side /GREEN/EVEN Pixel)<br /> Bit2: Black level abnormal (F side /GREEN/ODD Pixel)<br /> Bit1: Black level abnormal (F side /BLUE/EVEN Pixel)<br /> Bit0: Black level abnormal (F side /BLUE/ODD Pixel)</td></tr><tr><td>4-646-003</td><td>SSCG<br /> Correction</td><td>ENG</td><td>[0 to 65535 / <strong>0 </strong>/ 1/step] Bit7: Unused<br /> Bit6: Unused<br /> Bit5: SSCG correction error (Fside/RED/EVEN Pixel)<br /> Bit4: SSCG correction error (Fside/RED/ODD Pixel)<br /> Bit3: SSCG correction error (Fside/GREEN/EVEN Pixel)<br /> Bit2: SSCG correction error (Fside/GREEN/ODD Pixel)<br /> Bit1: SSCG correction error (Fside/BLUE/EVEN Pixel)<br /> Bit0: SSCG correction error (Fside/BLUE/ODD Pixel)</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4647</td><td>[Scanner Hard Error]</td></tr></table> <table style='width: 100%'><tr><td>4-647-001</td><td>Power-ON</td><td>ENG</td><td>[0 to 65535 / <strong>0 </strong>/ 1/step] Bit15: Unused<br /> Bit14:SBU hardware error (Power ON/un-reset error)<br /> Bit13:SBU hardware error (Serial communication error: F side)<br /> Bit12:SBU hardware error (Reset error: F side) Bit11: Unused<br /> Bit10: Unused<br /> Bit9:SBU hardware error (Version error) Bit8: Unused<br /> Bit7: Unused Bit6: Unused<br /> Bit5:SBU hardware error (Serial communication error: L side)<br /> Bit4:SBU hardware error (Reset error:Lside) Bit3: Unused<br /> Bit2: Unused Bit1: Unused</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4688</td><td>[DF Density Adjustment]</td><td></td><td></td></tr><tr><td>4-688-001</td><td>ARDF</td><td>*ENG</td><td>[80 to 120 / <strong>106 </strong>/ 1%/step]</td></tr><tr><td>4688</td><td>[Scan Image Density Adjustment]</td><td></td><td></td></tr><tr><td>4-688-002</td><td>1-pass DF</td><td>*ENG</td><td>[[80 to 120 / <strong>101 </strong>/ 1%/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4699</td><td>[SBU Test Pattern Change]</td><td></td><td></td></tr><tr><td>4-699-001</td><td>-</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4700</td><td>[CIS ID Display]</td><td></td><td></td></tr><tr><td>4-700-001</td><td>-</td><td>ENG</td><td>[0x00 to 0xFF / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4712</td><td>[CIS GB Adj. Value: R]</td><td></td><td></td></tr><tr><td>4-712-001</td><td>-</td><td>*ENG</td><td>[0 to 2048 / <strong>1023 </strong>/ 1digit/step]</td></tr></table> <table style='width: 100%'><tr><td>4714</td><td>[CIS GB Adj. Value: B]</td><td></td><td></td></tr><tr><td>4-714-001</td><td>-</td><td>*ENG</td><td>[0 to 2048 / <strong>1023 </strong>/ 1digit/step]</td></tr></table><p></p><p></p><table style='width: 100%'><tr><td>4713</td><td>[CIS GB Adj. Value: G]</td><td></td><td></td></tr><tr><td>4-713-001</td><td>-</td><td>*ENG</td><td>[0 to 2048 / <strong>1023 </strong>/ 1digit/step]</td></tr></table><p></p><p></p><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4730</td><td>[FROM ADF Factory Setting]</td><td></td><td></td></tr><tr><td>4-730-001</td><td>CIS Parameter</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 0/step]</td></tr><tr><td>4730</td><td>[FROM Main Factory Setting]</td><td></td><td></td></tr><tr><td>4-730-002</td><td>Execution ON/OFF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 0/step]</td></tr><tr><td>4-730-003</td><td>Execution Flag</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>4730</td><td>[FROM Data Update]</td><td></td><td></td></tr><tr><td>4-730-004</td><td>-</td><td>ENG</td><td>[0 to 1 / <strong>0 </strong>/ 0/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4745</td><td>[CIS Image Level Error Flag]</td><td></td><td></td></tr><tr><td>4-745-001</td><td>-</td><td>ENG</td><td>[0 to 65535 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4746</td><td>[CIS GB Adj Error Flag]</td><td></td><td></td></tr><tr><td>4-746-001</td><td>-</td><td>ENG</td><td>[0 to 7 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4747</td><td>[CIS Hard Error Flag]</td><td></td><td></td></tr><tr><td>4-747-001</td><td>-</td><td>ENG</td><td>[0 to 15 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4796</td><td>[Low Density Color Correction]</td></tr></table> <table style='width: 100%'><tr><td>4-796-001</td><td>Front Side</td><td>*ENG</td><td>[0 to 3 / <strong>0 </strong>/ 1/step]<br /> 0: OFF<br /> 1: WEAK<br /> 2: MEDIUM<br /> 3: STRONG</td></tr><tr><td>4-796-002</td><td>Rear Side</td><td>*ENG</td><td>[0 to 3 / <strong>0 </strong>/ 1/step]<br /> 0: OFF<br /> 1: WEAK<br /> 2: MEDIUM<br /> 3: STRONG</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4797</td><td>[Rear Side: Digital AE]</td><td></td><td></td></tr><tr><td>4-797-001</td><td>Low Limit Setting</td><td>*ENG</td><td>[0 to 1023 / <strong>364 </strong>/ 1/step]</td></tr><tr><td>4-797-002</td><td>Background Erase Level</td><td>*ENG</td><td>[512 to 1535 / <strong>932 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4799</td><td>[CIS TEST Pattern]</td><td></td><td></td></tr><tr><td>4-799-001</td><td>select</td><td>ENG</td><td>[0 to 5 / <strong>0 </strong>/ 1/step]<br /> Sets CIS test pattern output. 0: Scanned Image<br /> 1: Fixed Value Pattern<br /> 2: EO Fixed Value Pattern 3: Main Scan Gradation 4: Sub Scan Gradation<br /> 5: Grid Pattern</td></tr><tr><td>4-799-002</td><td>Even Output Level Setting</td><td>ENG</td><td>[0 to 1023 / <strong>0 </strong>/ 1digit/step]</td></tr><tr><td>4-799-003</td><td>Odd Output Level Setting</td><td>ENG</td><td>[0 to 1023 / <strong>0 </strong>/ 1digit/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4803</td><td>[Home Position Adj Value]</td><td></td><td></td></tr><tr><td>4-803-001</td><td>-</td><td>ENG</td><td>[-2.0 to 2.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4853</td><td>[Partial LED ON]</td><td></td><td></td></tr><tr><td>4-853-001</td><td>ON/OFF(Scan)</td><td>*ENG</td><td>[0 or 1 / <strong>1 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>4871</td><td>[Distortion Corr.]</td><td></td><td></td></tr><tr><td>4-871-001</td><td>Distortion Corr. ON/OFF</td><td>*ENG</td><td>[0 or 1 / <strong>1 </strong>/ 1/step]</td></tr><tr><td>4-871-002</td><td>Distortion Initialization</td><td>*ENG</td><td>[0 to 3 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>4-871-003</td><td>Magnification Adjust(DF)</td><td>*ENG</td><td>[-0.35 to 0.35 / <strong>0.11 </strong>/ 0.01%/step]</td></tr><tr><td>4-871-004</td><td>Magnification Adjust(FB)</td><td>*ENG</td><td>[-0.35 to 0.35 / <strong>0 </strong>/ 0.01%/step]</td></tr></table><p></p><p></p><table style='width: 100%'><tr><td>4-853-002</td><td>ON/OFF(Size Detection)</td><td>*ENG</td><td>[0 or 1 / <strong>1 </strong>/ 1/step]</td></tr></table><p></p><p></p><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4902</td><td>[Disp ACC Data]</td><td></td><td></td></tr><tr><td>4-902-001</td><td>R_DATA1</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>4-902-002</td><td>G_DATA1</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>4-902-003</td><td>B_DATA1</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>4-902-004</td><td>R_DATA2</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>4-902-005</td><td>G_DATA2</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>4-902-006</td><td>B_DATA2</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4903</td><td>[Filter Setting]</td><td></td><td></td></tr><tr><td>4-903-001</td><td>Ind Dot Erase: Text</td><td>*ENG</td><td>[0 to 7 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>4-903-002</td><td>Ind Dot Erase: Generation Copy</td><td>*ENG</td><td><br /> [0 to 7 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4905</td><td>[Select Gradation Level]</td><td></td><td></td></tr><tr><td>4-905-001</td><td>-</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4918</td><td>[Man Gamma Adj]</td><td></td><td></td></tr><tr><td>4-918-009</td><td>-</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4930</td><td>[Coverage Ctrl: Text]</td></tr></table> <table style='width: 100%'><tr><td>4-930-001</td><td>Copy: Full Color 1</td><td>ENG</td><td>[0 to 400 / <strong>200 </strong>/ 1/step]</td></tr><tr><td>4-930-002</td><td>Copy: Full Color 2</td><td>ENG</td><td>[0 to 400 / <strong>200 </strong>/ 1/step]</td></tr><tr><td>4-930-003</td><td>Copy: Single Color</td><td>ENG</td><td>[0 to 400 / <strong>100 </strong>/ 1/step]</td></tr><tr><td>4-930-004</td><td>Copy: Color Conversion</td><td>ENG</td><td>[0 to 400 / <strong>180 </strong>/ 1/step]</td></tr><tr><td>4-930-005</td><td>Coverage Ctrl OFF</td><td>ENG</td><td>[0 to 400 / <strong>400 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4931</td><td>[Coverage Ctrl: Photo]</td><td></td><td></td></tr><tr><td>4-931-001</td><td>Copy: Full Color 1</td><td>ENG</td><td>[0 to 400 / <strong>240 </strong>/ 1/step]</td></tr><tr><td>4-931-002</td><td>Copy: Full Color 2</td><td>ENG</td><td>[0 to 400 / <strong>260 </strong>/ 1/step]</td></tr><tr><td>4-931-003</td><td>Copy: Single Color</td><td>ENG</td><td>[0 to 400 / <strong>100 </strong>/ 1/step]</td></tr><tr><td>4-931-004</td><td>Copy: Color Conversion</td><td>ENG</td><td>[0 to 400 / <strong>200 </strong>/ 1/step]</td></tr><tr><td>4-931-005</td><td>Coverage Ctrl OFF</td><td>ENG</td><td>[0 to 400 / <strong>400 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4938</td><td>[ACS:Edge Mask]</td><td></td><td></td></tr><tr><td>4-938-001</td><td>Copy:Sub LEdge</td><td>*ENG</td><td>[0 to 31 / <strong>10 </strong>/ 1mm/step]</td></tr><tr><td>4-938-002</td><td>Copy:Sub TEdge</td><td>*ENG</td><td>[0 to 31 / <strong>10 </strong>/ 1mm/step]</td></tr><tr><td>4-938-003</td><td>Copy:Main LEdge</td><td>*ENG</td><td>[0 to 31 / <strong>10 </strong>/ 1mm/step]</td></tr><tr><td>4-938-004</td><td>Copy:Main TEdge</td><td>*ENG</td><td>[0 to 31 / <strong>10 </strong>/ 1mm/step]</td></tr><tr><td>4-938-005</td><td>Scan:Sub LEdge</td><td>*ENG</td><td>[0 to 31 / <strong>15 </strong>/ 1mm/step]</td></tr><tr><td>4-938-006</td><td>Scan:Sub TEdge</td><td>*ENG</td><td>[0 to 31 / <strong>15 </strong>/ 1mm/step]</td></tr><tr><td>4-938-007</td><td>Scan:Main LEdge</td><td>*ENG</td><td>[0 to 31 / <strong>15 </strong>/ 1mm/step]</td></tr><tr><td>4-938-008</td><td>Scan:Main TEdge</td><td>*ENG</td><td>[0 to 31 / <strong>15 </strong>/ 1mm/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4939</td><td>[ACS:Color Range]</td></tr></table> <table style='width: 100%'><tr><td>4-939-001</td><td>-</td><td>*ENG</td><td>[-2 to 2 / <strong>0 </strong>/ 1/step]<br /> Change the value of this SP to negative (“-1” or “-2”) when a black and white document is misjudged as a color document.</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4954</td><td>[Restore Test Chart]</td><td></td><td></td></tr><tr><td>4-954-005</td><td>Chromaticity Rank</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4958</td><td>[Restore Test Chart: Rear]</td><td></td><td></td></tr><tr><td>4-958-005</td><td>Chromaticity Rank</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4984</td><td>[IBACC Target Den]</td><td></td><td></td></tr><tr><td>4-984-001</td><td>IBACC notch K</td><td>*ENG</td><td>[0 to 10 / <strong>5 </strong>/ 1/step]</td></tr><tr><td>4-984-002</td><td>IBACC notch C</td><td>*ENG</td><td></td></tr><tr><td>4-984-003</td><td>IBACC notch M</td><td>*ENG</td><td></td></tr><tr><td>4-984-004</td><td>IBACC notch Y</td><td>*ENG</td><td></td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4993</td><td>[High Light Correction]</td><td></td><td></td></tr><tr><td>4-993-001</td><td>Sensitivity Selection</td><td>ENG</td><td>[0 to 9 / <strong>4 </strong>/ 1/step]<br /> 0: Weak<br /> 9: Strong</td></tr><tr><td>4-993-002</td><td>Range Selection</td><td>ENG</td><td>[0 to 9 / <strong>4 </strong>/ 1/step]<br /> 0: Weak<br /> 9: Strong</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4994</td><td>[Adj Txt/Photo Recog Level]</td><td></td><td></td></tr><tr><td>4-994-001</td><td>High Compression PDF</td><td>ENG</td><td>[0 to 2 / <strong>1 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>4996</td><td>[White Paper Detection Level]</td></tr></table> <table style='width: 100%'><tr><td>4-996-001</td><td>-</td><td>ENG</td><td>[0 to 6 / <strong>3 </strong>/ 1/step]</td></tr></table><p></p><p></p><p>Engine SP Mode Tables</p><p></p><p></p><p></p><ol style="margin-left: 20px"> <li data-xf-list-type="ol"> <h3>ENGINE SP TABLES - SP5000</h3> <ol> <li data-xf-list-type="ol"> <h3>SP5-XXX (MODE)</h3> <br /> <table style='width: 100%'><tr><td>5126</td><td>[Set F-size Document]</td><td></td><td></td></tr><tr><td>5-126-001</td><td>-</td><td>ENG</td><td>[0 to 2 / <strong>0 </strong>/ 1/step]</td></tr><tr><td></td><td></td><td></td><td>0: 8 1/2 x13</td></tr><tr><td></td><td></td><td></td><td>1: 8 1/4 x13</td></tr><tr><td></td><td></td><td></td><td>2: 8 x13</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5131</td><td>[Paper Size Type Selection]</td><td></td><td></td></tr><tr><td>5-131-001</td><td>-</td><td>*ENG</td><td>[0 to 2 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 2, Asia: 2, CHN: 2, TWN: 2 ,<br /> KOR: 2<br /> ---<br /> 0: JP (Japan)<br /> 1: NA<br /> 2: EU</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5135</td><td>[LG_Oficio Change]</td><td></td><td></td></tr><tr><td>5-135-001</td><td>-</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5181</td><td>[Size Adjust]</td><td></td><td></td></tr><tr><td>5-181-001</td><td>TRAY 1</td><td>*ENG</td><td>[0 to 3 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: A4 LEF<br /> 1: LT LEF<br /> 2: B5 LEF<br /> 3: A5 LEF</td></tr></table> <table style='width: 100%'><tr><td>5-181-002</td><td>TRAY 2: 1</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: A4 LEF<br /> 1: LT LEF</td></tr><tr><td>5-181-003</td><td>TRAY 2: 2</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: A3<br /> 1: DLT</td></tr><tr><td>5-181-004</td><td>TRAY 2: 3</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: B4<br /> 1: LG</td></tr><tr><td>5-181-005</td><td>TRAY 2: 4</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: B5LEF<br /> 1: ExeLEF</td></tr><tr><td>5-181-006</td><td>TRAY 2: 5</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: SRA3<br /> 1: 12X18</td></tr><tr><td>5-181-007</td><td>TRAY 3/T-LCT: 1</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: A4LEF<br /> 1: LTLEF</td></tr><tr><td>5-181-008</td><td>TRAY 3: 2</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: A3<br /> 1: DLT</td></tr></table> <table style='width: 100%'><tr><td>5-181-009</td><td>TRAY 3: 3</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: B4<br /> 1: LG</td></tr><tr><td>5-181-010</td><td>TRAY 3: 4</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: B5LEF<br /> 1: ExeLEF</td></tr><tr><td>5-181-011</td><td>TRAY 3: 5</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: 12.6X17.7<br /> 1: 12X18</td></tr><tr><td>5-181-012</td><td>TRAY 4: 1</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: A4LEF<br /> 1: LTLEF</td></tr><tr><td>5-181-013</td><td>TRAY 4: 2</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: A3<br /> 1: DLT</td></tr><tr><td>5-181-014</td><td>TRAY 4: 3</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: B4<br /> 1: LG</td></tr><tr><td>5-181-015</td><td>TRAY 4: 4</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: B5LEF<br /> 1: ExeLEF</td></tr></table> Engine SP Mode Tables<br /> <br /> <br /> <table style='width: 100%'><tr><td>5-181-016</td><td>TRAY 4: 5</td><td>*ENG</td><td>[0 or 1 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: 12.6X17.7<br /> 1: 12X18</td></tr><tr><td>5-181-017</td><td>LCT</td><td>*ENG</td><td>[0 to 2 / <strong>* </strong>/ 1/step]<br /> *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 ,<br /> KOR: 0<br /> 0: A4LEF<br /> 1: LTLEF<br /> 2: B5LEF</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5186</td><td>[RK4]</td><td></td><td></td></tr><tr><td>5-186-001</td><td>-</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5610</td><td>[Base Gamma Ctrl Pt:Execute]</td><td></td><td></td></tr><tr><td>5-610-004</td><td>Get Factory Default</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5-610-005</td><td>Set Factory Default</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5-610-006</td><td>Restore Orginal Value</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5611</td><td>[Toner Color in 2C]</td><td></td><td></td></tr><tr><td>5-611-001</td><td>B-C</td><td>*ENG</td><td>[0 to 128 / <strong>100 </strong>/ 1/step]</td></tr><tr><td>5-611-002</td><td>B-M</td><td>*ENG</td><td>[0 to 128 / <strong>100 </strong>/ 1/step]</td></tr><tr><td>5-611-003</td><td>G-C</td><td>*ENG</td><td>[0 to 128 / <strong>100 </strong>/ 1/step]</td></tr><tr><td>5-611-004</td><td>G-Y</td><td>*ENG</td><td>[0 to 128 / <strong>100 </strong>/ 1/step]</td></tr><tr><td>5-611-005</td><td>R-M</td><td>*ENG</td><td>[0 to 128 / <strong>100 </strong>/ 1/step]</td></tr><tr><td>5-611-006</td><td>R-Y</td><td>*ENG</td><td>[0 to 128 / <strong>100 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5801</td><td>[Memory Clear]</td></tr></table> <table style='width: 100%'><tr><td>5803</td><td>[INPUT Check]</td></tr><tr><td>See page 3-385 "Input Check Table"</td><td></td></tr></table> <br /> <table style='width: 100%'><tr><td>5-801-002</td><td>Engine</td><td>ENG</td><td>[- / <strong>- </strong>/ -]<br /> [Execute]</td></tr></table> <br /> Engine SP Mode Tables<br /> <br /> <br /> <br /> <table style='width: 100%'><tr><td>5804</td><td>[OUTPUT Check]</td></tr><tr><td>See page 3-412 "Output Check Table"</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5805</td><td>[Anti-Condensation Heater]</td><td></td><td></td></tr><tr><td>5-805-001</td><td>0:OFF / 1:ON</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: OFF... Switches OFF when standby (default setting)<br /> 1: ON... Switches ON when standby</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5810</td><td>[SC Reset]</td><td></td><td></td></tr><tr><td>5-810-001</td><td>Fusing SC Reset</td><td>ENG</td><td>Clears the fusing SC.</td></tr><tr><td>5-810-002</td><td>Hard High Temp. Detection</td><td>ENG</td><td>Clears the fusing hardware SC.</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5811</td><td>[MachineSerial]</td><td></td><td></td></tr><tr><td>5-811-002</td><td>Display</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5811</td><td>[MachineSerial Set]</td><td></td><td></td></tr><tr><td>5-811-004</td><td>BCU</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5811</td><td>[Machine Serial: Update Date]</td><td></td><td></td></tr><tr><td>5-811-021</td><td>Latest</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5-811-022</td><td>Previous</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5811</td><td>[MachineSerial]</td><td></td><td></td></tr><tr><td>5-811-023</td><td>Previous</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>5811</td><td>[Machine Serial: Update Date]</td><td></td><td></td></tr><tr><td>5-811-024</td><td>Latest (BCU)</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5-811-025</td><td>Previous (BCU)</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5811</td><td>[MachineSerial]</td><td></td><td></td></tr><tr><td>5-811-026</td><td>Previous (BCU)</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5894</td><td>[External Mech Count Setting]</td><td></td><td></td></tr><tr><td>5-894-001</td><td>Mech Counter Switch Setting</td><td>*ENG</td><td>[0 to 2 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5900</td><td>[Engine Log Upload]</td><td></td><td></td></tr><tr><td>5-900-001</td><td>Pattern</td><td>*ENG</td><td>[0 to 4 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>5-900-002</td><td>Trigger</td><td>*ENG</td><td>[0 to 3 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>5998</td><td>[Fusing Warm UP]</td><td></td><td></td></tr><tr><td>5-998-001</td><td>Warm Up In Advance ON/OFF</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> Engine SP Mode Tables<br /> </li> </ol></li> <li data-xf-list-type="ol"> <h3>ENGINE SP TABLES - SP6000</h3> <ol> <li data-xf-list-type="ol"> <h3>SP6-XXX (PERIPHERALS)</h3> <br /> <table style='width: 100%'><tr><td>6006</td><td>[ADF Adjustment]</td><td></td><td></td></tr><tr><td>6-006-001</td><td>Side-to-Side Regist: Front</td><td>*ENG</td><td>[-3.0 to 3.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-002</td><td>Side-to-Side Regist: Rear</td><td>*ENG</td><td>[-3.0 to 3.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-003</td><td>Leading Edge Registration: Front</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-004</td><td>Leading Edge Registration: Rear</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-005</td><td>Buckle: Duplex Front</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-006</td><td>Buckle: Duplex Rear</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-007</td><td>Rear Edge Erase Front</td><td>*ENG</td><td>[-10.0 to 10.0 / <strong>-2.3 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-008</td><td>Rear Edge Erase Rear</td><td>*ENG</td><td>[-10.0 to 10.0 / <strong>-2.3 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-010</td><td>L-Edge Regist (1-Pass): Front</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-011</td><td>L-Edge Regist (1-Pass): Rear</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-012</td><td>1st Buckle (1-Pass)</td><td>*ENG</td><td>[-3.0 to 3.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-013</td><td>2nd Buckle (1-Pass)</td><td>*ENG</td><td>[-2.0 to 3.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-014</td><td>T-Edge Erase (1-Pass): Front</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>-3.0 </strong>/ 0.1mm/step]</td></tr><tr><td>6-006-015</td><td>T-Edge Erase (1-Pass): Rear</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>-2.5 </strong>/ 0.1mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6007</td><td>[ADF INPUT Check]</td></tr><tr><td>See page 3-385 "Input Check Table"</td><td></td></tr></table> <table style='width: 100%'><tr><td>6008</td><td>[ADF OUTPUT Check]</td></tr><tr><td>See page 3-412 "Output Check Table"</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6009</td><td>[ADF FreeRun]</td><td></td><td></td></tr><tr><td>6-009-001</td><td>Free Run Simplex Motion</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-009-002</td><td>Free Run Duplex Motion</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-009-003</td><td>Free Run Stamp Motion</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-009-004</td><td>Free Run Simplex Motion(low speed)</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-009-005</td><td>Free Run Simplex Motion(high speed)</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-009-006</td><td>Free Run Duplex Motion(low speed)</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-009-007</td><td>Free Run Duplex Motion(high speed)</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6010</td><td>[Stamp Position Adj.]</td><td></td><td></td></tr><tr><td>6-010-001</td><td>-</td><td>*ENG</td><td>[-5.0 to 5.0 / <strong>0 </strong>/ 0.1mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6011</td><td>[1-Pass ADF INPUT Check]</td></tr><tr><td>See page 3-385 "Input Check Table"</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6012</td><td>[1-Pass ADF OUTPUT Check]</td></tr><tr><td>See page 3-412 "Output Check Table"</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6016</td><td>[Original Size Detect Setting]</td><td></td><td></td></tr><tr><td>6-016-001</td><td>-</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6017</td><td>[DF Magnification Adj.]</td></tr></table> <table style='width: 100%'><tr><td>6020</td><td>[Skew Correction Moving Setting]</td><td></td><td></td></tr><tr><td>6-020-001</td><td>-</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <table style='width: 100%'><tr><td>6-017-001</td><td>-</td><td>*ENG</td><td>[-5 to 5 / <strong>0 </strong>/ 0.1%/step]</td></tr></table> <br /> Engine SP Mode Tables<br /> <br /> <br /> <br /> <table style='width: 100%'><tr><td>6121</td><td>[NV Adj. Data Mod.]</td><td></td><td></td></tr><tr><td>6-121-001</td><td>Jogger Pos. Factory Adj.</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-121-002</td><td>Folding Pos. Factory Adj.</td><td>ENG</td><td>[-1.4 to 1.4 / <strong>0 </strong>/ 0.2mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6125</td><td>[Use Paper Guide(Big Size)]</td><td></td><td></td></tr><tr><td>6-125-001</td><td>All Size</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6126</td><td>[Use Paper Guide(Small Size)]</td><td></td><td></td></tr><tr><td>6-126-001</td><td>All Size</td><td>ENG</td><td>[0 or 1 / 0 / 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6130</td><td>[Sub-scan PunchPosAdj:FrontFIN]</td><td></td><td></td></tr><tr><td>6-130-001</td><td>Domestic 2Hole(Europe 2Hole)</td><td>ENG</td><td>[-7.5 to 7.5 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-130-002</td><td>North America 3Hole</td><td>ENG</td><td></td></tr><tr><td>6-130-003</td><td>Europe 4Hole</td><td>ENG</td><td></td></tr><tr><td>6-130-004</td><td>North Europe 4Hole</td><td>ENG</td><td></td></tr><tr><td>6-130-005</td><td>North America 2Hole</td><td>ENG</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6131</td><td>[Main-scan PunchPosAdj:FrontFIN]</td><td></td><td></td></tr><tr><td>6-131-001</td><td>Domestic 2Hole(Europe 2Hole)</td><td>ENG</td><td>[-2 to 2 / <strong>0 </strong>/ 0.4mm/step]</td></tr><tr><td>6-131-002</td><td>North America 3Hole</td><td>ENG</td><td></td></tr><tr><td>6-131-003</td><td>Europe 4Hole</td><td>ENG</td><td></td></tr></table> <table style='width: 100%'><tr><td>6-131-004</td><td>North Europe 4Hole</td><td>ENG</td><td></td></tr><tr><td>6-131-005</td><td>North America 2Hole</td><td>ENG</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6132</td><td>[Jogger Fence Fine Adj:FrontFIN]</td><td></td><td></td></tr><tr><td>6-132-001</td><td>A3T</td><td>ENG</td><td>[-1.5 to 1.5 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-002</td><td>B4T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-003</td><td>A4T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-004</td><td>A4Y</td><td>ENG</td><td>[-1.5 to <strong>1.5 </strong>/ 0 / 0.5mm/step]</td></tr><tr><td>6-132-005</td><td>B5T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-006</td><td>B5Y</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-007</td><td>DLT-T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-008</td><td>LG-T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-009</td><td>Oficio-T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-010</td><td>LT-T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-011</td><td>LT-Y</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-012</td><td>8K-T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-013</td><td>16K-T</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-014</td><td>16K-Y</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-132-015</td><td>Other</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.5mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6133</td><td>[Staple Position Adj: FrontFIN]</td><td></td><td></td></tr><tr><td>6-133-001</td><td>Finisher1</td><td>ENG</td><td>[-2 to 2 / <strong>0 </strong>/ 0.5mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6134</td><td>[Finisher Free Run: FrontFIN]</td><td></td><td></td></tr><tr><td>6-134-001</td><td>Free Run1</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-134-002</td><td>Free Run2</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>6135</td><td>[INPUT Check: FrontFIN]</td></tr><tr><td>See page 3-385 "Input Check Table"</td><td></td></tr></table> <br /> <table style='width: 100%'><tr><td>6-134-003</td><td>Free Run3</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-134-004</td><td>Free Run4</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> Engine SP Mode Tables<br /> <br /> <br /> <br /> <table style='width: 100%'><tr><td>6136</td><td>[OUTPUT Check: FrontFIN]</td></tr><tr><td>See page 3-412 "Output Check Table"</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6140</td><td>[Staple Position Adj: 1K FIN]</td><td></td><td></td></tr><tr><td>6-140-001</td><td>-</td><td>ENG</td><td>[-3.5 to 3.5 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-140-002</td><td>-</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.3mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6141</td><td>[Booklet Stapler Pos Adj:1K FIN]</td><td></td><td></td></tr><tr><td>6-141-001</td><td>A3 SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-141-002</td><td>B4 SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-141-003</td><td>A4 SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-141-004</td><td>B5 SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-141-005</td><td>DLT SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-141-006</td><td>LG SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-141-007</td><td>Oficio SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-141-008</td><td>LT SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-141-009</td><td>12"x18"</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6142</td><td>[Sub-scan Punch Pos Adj:1K FIN]</td><td></td><td></td></tr><tr><td>6-142-001</td><td>JPN/EU: 2-Hole</td><td>ENG</td><td>[-7.5 to 7.5 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-142-002</td><td>NA: 3-Hole</td><td>ENG</td><td></td></tr></table> <table style='width: 100%'><tr><td>6-142-003</td><td>Europe: 4-Hole</td><td>ENG</td><td></td></tr><tr><td>6-142-004</td><td>NEU: 4-Hole</td><td>ENG</td><td></td></tr><tr><td>6-142-005</td><td>NA: 2-Hole</td><td>ENG</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6143</td><td>[Jogger Pos Adj:1K FIN]</td><td></td><td></td></tr><tr><td>6-143-001</td><td>A3 SEF</td><td>ENG</td><td><br /> [-1.5 to 1.5 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-143-002</td><td>B4 SEF</td><td>ENG</td><td></td></tr><tr><td>6-143-003</td><td>A4 SEF</td><td>ENG</td><td></td></tr><tr><td>6-143-004</td><td>A4 LEF</td><td>ENG</td><td></td></tr><tr><td>6-143-005</td><td>B5 SEF</td><td>ENG</td><td></td></tr><tr><td>6-143-006</td><td>B5 LEF</td><td>ENG</td><td><br /> [-1.5 to 1.5 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-143-007</td><td>DLT SEF</td><td>ENG</td><td></td></tr><tr><td>6-143-008</td><td>LG SEF</td><td>ENG</td><td></td></tr><tr><td>6-143-009</td><td>Oficio SEF</td><td>ENG</td><td></td></tr><tr><td>6-143-010</td><td>LT SEF</td><td>ENG</td><td></td></tr><tr><td>6-143-011</td><td>LT LEF</td><td>ENG</td><td></td></tr><tr><td>6-143-012</td><td>12"x18"</td><td>ENG</td><td></td></tr><tr><td>6-143-013</td><td>8K SEF</td><td>ENG</td><td><br /> [-1.5 to 1.5 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-143-014</td><td>16K SEF</td><td>ENG</td><td></td></tr><tr><td>6-143-015</td><td>16K LEF</td><td>ENG</td><td></td></tr><tr><td>6-143-016</td><td>Other</td><td>ENG</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6144</td><td>[Main-scan Punch Pos Adj:1K FIN]</td><td></td><td></td></tr><tr><td>6-144-001</td><td>JPN/EU: 2-Hole</td><td>ENG</td><td>[-2 to 2 / <strong>0 </strong>/ 0.4mm/step]</td></tr><tr><td>6-144-002</td><td>NA: 3-Hole</td><td>ENG</td><td></td></tr><tr><td>6-144-003</td><td>Europe: 4-Hole</td><td>ENG</td><td></td></tr></table> <table style='width: 100%'><tr><td>6145</td><td>[Skew Correct Buckle Adj:1K FIN]</td><td></td><td></td></tr><tr><td>6-145-001</td><td>A3 SEF</td><td>ENG</td><td><br /> [-5 to 5 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-145-002</td><td>B4 SEF</td><td>ENG</td><td></td></tr><tr><td>6-145-003</td><td>A4 SEF</td><td>ENG</td><td></td></tr><tr><td>6-145-004</td><td>A4 LEF</td><td>ENG</td><td></td></tr><tr><td>6-145-005</td><td>B5 SEF</td><td>ENG</td><td></td></tr><tr><td>6-145-006</td><td>B5 LEF</td><td>ENG</td><td><br /> [-5 to 5 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-145-007</td><td>A5 LEF</td><td>ENG</td><td></td></tr><tr><td>6-145-008</td><td>DLT SEF</td><td>ENG</td><td></td></tr><tr><td>6-145-009</td><td>LG SEF</td><td>ENG</td><td></td></tr><tr><td>6-145-010</td><td>Oficio SEF</td><td>ENG</td><td></td></tr><tr><td>6-145-011</td><td>LT SEF</td><td>ENG</td><td><br /> [-5 to 5 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-145-012</td><td>LT LEF</td><td>ENG</td><td></td></tr><tr><td>6-145-013</td><td>HLT LEF</td><td>ENG</td><td></td></tr><tr><td>6-145-014</td><td>12"x18"</td><td>ENG</td><td></td></tr><tr><td>6-145-015</td><td>8K SEF</td><td>ENG</td><td></td></tr><tr><td>6-145-016</td><td>16K SEF</td><td>ENG</td><td></td></tr><tr><td>6-145-017</td><td>16K LEF</td><td>ENG</td><td></td></tr><tr><td>6-145-018</td><td>Other</td><td>ENG</td><td>[-5 to 5 / <strong>0 </strong>/ 0.2mm/step]</td></tr></table> <br /> <table style='width: 100%'><tr><td>6-144-004</td><td>NEU: 4-Hole</td><td>ENG</td><td></td></tr><tr><td>6-144-005</td><td>NA: 2-Hole</td><td>ENG</td><td></td></tr></table> <br /> Engine SP Mode Tables<br /> <br /> <br /> <br /> <br /> <table style='width: 100%'><tr><td>6146</td><td>[Skew Correct Ctrl SW:1K FIN]</td><td></td><td></td></tr><tr><td>6-146-001</td><td>A3 SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr></table> <table style='width: 100%'><tr><td>6-146-002</td><td>B4 SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-003</td><td>A4 SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-004</td><td>A4 LEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-005</td><td>B5 SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-006</td><td>B5 LEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-007</td><td>A5 LEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-008</td><td>DLT SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-009</td><td>LG SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-010</td><td>Oficio SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-011</td><td>LT SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-012</td><td>LT LEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr></table> <table style='width: 100%'><tr><td>6-146-013</td><td>HLT LEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-014</td><td>12"x18"</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-015</td><td>8K SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-016</td><td>16K SEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-017</td><td>16K LEF</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr><tr><td>6-146-018</td><td>Other</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: enable<br /> 1: disable</td></tr></table> Engine SP Mode Tables<br /> <br /> <br /> <br /> <br /> <table style='width: 100%'><tr><td>6147</td><td>[Booklet Folder Pos Adj:1K FIN]</td><td></td><td></td></tr><tr><td>6-147-001</td><td>A3 SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-002</td><td>B4 SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-003</td><td>A4 SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-004</td><td>B5 SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-005</td><td>DLT SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-006</td><td>LG SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-007</td><td>Oficio SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-008</td><td>LT SEF</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-009</td><td>12"x18"</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-010</td><td>A3 SEF(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr></table> <table style='width: 100%'><tr><td>6-147-011</td><td>A3 SEF(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-012</td><td>A3 SEF(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-013</td><td>B4 SEF(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-014</td><td>B4 SEF(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-015</td><td>B4 SEF(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-016</td><td>A4 SEF(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-017</td><td>A4 SEF(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-018</td><td>A4 SEF(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-019</td><td>B5 SEF(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-020</td><td>B5 SEF(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-021</td><td>B5 SEF(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-022</td><td>DLT SEF(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-023</td><td>DLT SEF(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-024</td><td>DLT SEF(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-025</td><td>LG SEF(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-026</td><td>LG SEF(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-027</td><td>LG SEF(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-028</td><td>Oficio SEF(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-029</td><td>Oficio SEF(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-030</td><td>Oficio SEF(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-031</td><td>LT SEF(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-032</td><td>LT SEF(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-033</td><td>LT SEF(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-034</td><td>12"x18"(1-5)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-035</td><td>12"x18"(6-10)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr><tr><td>6-147-036</td><td>12"x18"(11-over)</td><td>ENG</td><td>[-3 to 3 / <strong>0 </strong>/ 0.2mm/step]</td></tr></table> <table style='width: 100%'><tr><td>6149</td><td>[Last Paper Pos Time Adj:1K FIN]</td><td></td><td></td></tr><tr><td>6-149-001</td><td>-</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1time/step]</td></tr></table> <br /> <table style='width: 100%'><tr><td>6148</td><td>[Fold Times Adj: 1K FIN]</td><td></td><td></td></tr><tr><td>6-148-001</td><td>-</td><td>ENG</td><td>[0 to 29 / <strong>0 </strong>/ 1sec/step]</td></tr></table> <br /> Engine SP Mode Tables<br /> <br /> <br /> <br /> <br /> <table style='width: 100%'><tr><td>6150</td><td>[PositioningStrtTimingAdj:1KFIN]</td><td></td><td></td></tr><tr><td>6-150-001</td><td>A3 SEF</td><td>ENG</td><td>[-100 to 100 / <strong>0 </strong>/ 10msec/step]</td></tr><tr><td>6-150-002</td><td>B4 SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-003</td><td>A4 SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-004</td><td>A4 LEF</td><td>ENG</td><td></td></tr><tr><td>6-150-005</td><td>B5 SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-006</td><td>B5 LEF</td><td>ENG</td><td></td></tr><tr><td>6-150-007</td><td>DLT SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-008</td><td>LG SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-009</td><td>Oficio SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-010</td><td>LT SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-011</td><td>LT LEF</td><td>ENG</td><td></td></tr><tr><td>6-150-012</td><td>12"x18"</td><td>ENG</td><td></td></tr><tr><td>6-150-013</td><td>8K SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-014</td><td>16K SEF</td><td>ENG</td><td></td></tr><tr><td>6-150-015</td><td>16K LEF</td><td>ENG</td><td></td></tr><tr><td>6-150-016</td><td>Other</td><td>ENG</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6151</td><td>[PosTimeAdj(LstPr2ndTime):1KFIN]</td><td></td><td></td></tr><tr><td>6-151-001</td><td>-</td><td>ENG</td><td>[-100 to 100 / <strong>0 </strong>/ 10msec/step]</td></tr></table> <br /> <table style='width: 100%'><tr><td>6152</td><td>[PosTiAdj(ExcLstPr3rdTi):1KFIN]</td><td></td><td></td></tr><tr><td>6-152-001</td><td>A3 SEF</td><td>ENG</td><td>[-100 to 100 / <strong>0 </strong>/ 10msec/step]</td></tr><tr><td>6-152-002</td><td>B4 SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-003</td><td>A4 SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-004</td><td>A4 LEF</td><td>ENG</td><td></td></tr><tr><td>6-152-005</td><td>B5 SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-006</td><td>B5 LEF</td><td>ENG</td><td></td></tr><tr><td>6-152-007</td><td>DLT SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-008</td><td>LG SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-009</td><td>Oficio SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-010</td><td>LT SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-011</td><td>LT LEF</td><td>ENG</td><td></td></tr><tr><td>6-152-012</td><td>12"x18"</td><td>ENG</td><td></td></tr><tr><td>6-152-013</td><td>8K SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-014</td><td>16K SEF</td><td>ENG</td><td></td></tr><tr><td>6-152-015</td><td>16K LEF</td><td>ENG</td><td></td></tr><tr><td>6-152-016</td><td>Other</td><td>ENG</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6154</td><td>[Pos Time Adj By Sheet: 1K FIN]</td><td></td><td></td></tr><tr><td>6-154-001</td><td>1 - 10 Sheets</td><td>ENG</td><td>[-100 to 100 / <strong>0 </strong>/ 10msec/step]</td></tr><tr><td>6-154-002</td><td>11 - 20 Sheets</td><td>ENG</td><td></td></tr><tr><td>6-154-003</td><td>21 - 30 Sheets</td><td>ENG</td><td></td></tr><tr><td>6-154-004</td><td>31 - 40 Sheets</td><td>ENG</td><td></td></tr><tr><td>6-154-005</td><td>41 - 50 Sheets</td><td>ENG</td><td></td></tr></table> <table style='width: 100%'><tr><td>6156</td><td>[Paper Guide Retra Adj: 1K FIN]</td><td></td><td></td></tr><tr><td>6-156-001</td><td>-</td><td>ENG</td><td>[-50 to 50 / <strong>0 </strong>/ 5mm/step]</td></tr></table> <br /> <table style='width: 100%'><tr><td>6155</td><td>[Paper Guide Poss Adj: 1K FIN]</td><td></td><td></td></tr><tr><td>6-155-001</td><td>-</td><td>ENG</td><td>[-10 to 10 / <strong>0 </strong>/ 1mm/step]</td></tr></table> <br /> Engine SP Mode Tables<br /> <br /> <br /> <br /> <table style='width: 100%'><tr><td>6157</td><td>[Paper Guide Acept Adj: 1K FIN]</td><td></td><td></td></tr><tr><td>6-157-001</td><td>-</td><td>ENG</td><td>[-50 to 50 / <strong>0 </strong>/ 5msec/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6160</td><td>[Finisher Free Run: 1K FIN]</td><td></td><td></td></tr><tr><td>6-160-001</td><td>Free Run 1</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-160-002</td><td>Free Run 2</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-160-003</td><td>Free Run 3</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>6-160-004</td><td>Free Run 4</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6161</td><td>[FIN (1K FIN) INPUT Check]</td></tr><tr><td>See page 3-385 "Input Check Table"</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6162</td><td>[FIN (1K FIN) OUTPUT Check]</td></tr><tr><td>See page 3-412 "Output Check Table"</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6163</td><td>[Use Paper Guide]</td><td></td><td></td></tr><tr><td>6-163-001</td><td>Big Size</td><td>ENG</td><td>[0 or 1 / <strong>1 </strong>/ 1/step]</td></tr><tr><td>6-163-002</td><td>Small Size</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6164</td><td>[NV Adj. Data Mod. 1KShtFIN]</td><td></td><td></td></tr><tr><td>6-164-001</td><td>Jogger Pos. Factory Adj.</td><td>ENG</td><td>[-1.5 to 1.5 / <strong>0 </strong>/ 0.5mm/step]</td></tr><tr><td>6-164-002</td><td>Stapling Pos. Factory Adj.</td><td>ENG</td><td>[-2 to 2 / <strong>0 </strong>/ 0.5mm/step]</td></tr></table> <table style='width: 100%'><tr><td>6164</td><td>[NV Adj. Data Mod. 1KShtFIN HY]</td><td></td><td></td></tr><tr><td>6-164-003</td><td>Stapling Pos. Factory Adj. (HY)</td><td>ENG</td><td>[-2.1 to 2.1 / <strong>0 </strong>/ 0.3mm/step]</td></tr><tr><td>6-164-004</td><td>Stapleless Stapling Pos. Factory Adj.</td><td><br /> ENG</td><td><br /> [-2.1 to 2.1 / <strong>0 </strong>/ 0.3mm/step]</td></tr><tr><td>6164</td><td>[NV Adj. Data Mod. 1KShtFIN]</td><td></td><td></td></tr><tr><td>6-164-005</td><td>Folding Pos. Factory Adj.</td><td>ENG</td><td>[-2 to 2 / <strong>0 </strong>/ 0.1mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6180</td><td>[M-ScanBindPosAdj:NoStplBindFIN]</td><td></td><td></td></tr><tr><td>6-180-001</td><td>-</td><td>ENG</td><td>[-1 to 1 / <strong>0 </strong>/ 0.5mm/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6181</td><td>[BindSpeedSetting:NoStplBindFIN]</td><td></td><td></td></tr><tr><td>6-181-001</td><td>-</td><td>ENG</td><td>[1 to 3 / <strong>3 </strong>/ 2/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6182</td><td>[ExitSpeedSwitch:NoStplBindFIN]</td><td></td><td></td></tr><tr><td>6-182-001</td><td>PaperLength:297.0-457.2mm,Thick(106-300g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>2 </strong>/ 1/step]</td></tr><tr><td>6-182-002</td><td>PaperLength:297.0-457.2mm,Plain(60-105g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>2 </strong>/ 1/step]</td></tr><tr><td>6-182-003</td><td>PaperLength:297.0-457.2mm,Thin(52-59g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>4 </strong>/ 1/step]</td></tr><tr><td>6-182-004</td><td>PaperLength:210.0-296.9mm,Thick(106-300g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>2 </strong>/ 1/step]</td></tr><tr><td>6-182-005</td><td>PaperLength:210.0-296.9mm,Plain(60-105g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>2 </strong>/ 1/step]</td></tr><tr><td>6-182-006</td><td>PaperLength:210.0-296.9mm,Thin(52-59g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>4 </strong>/ 1/step]</td></tr><tr><td>6-182-007</td><td>PaperLength:148.0-209.9mm,Thick(106-300g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>2 </strong>/ 1/step]</td></tr><tr><td>6-182-008</td><td>PaperLength:148.0-209.9mm,Plain(60-105g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>2 </strong>/ 1/step]</td></tr><tr><td>6-182-009</td><td>PaperLength:148.0-209.9mm,Thin(52-59g/m2)</td><td>ENG</td><td>[1 to 5 / <strong>4 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6183</td><td>[FinisherFreeRun:NoStplBindFIN]</td><td></td><td></td></tr><tr><td>6-183-001</td><td>Free Run 1</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 0/step]</td></tr></table> <table style='width: 100%'><tr><td>6184</td><td>[Input Check:NoStplBindFIN]</td></tr><tr><td>See page 3-385 "Input Check Table"</td><td></td></tr></table> <br /> <table style='width: 100%'><tr><td>6-183-002</td><td>Free Run 2</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 0/step]</td></tr><tr><td>6-183-003</td><td>Free Run 3</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 0/step]</td></tr></table> <br /> Engine SP Mode Tables<br /> <br /> <br /> <br /> <table style='width: 100%'><tr><td>6185</td><td>[Output Check:NoStplBindFIN]</td></tr><tr><td>See page 3-412 "Output Check Table"</td><td></td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6186</td><td>[BindTimes NoStplBindFIN]</td><td></td><td></td></tr><tr><td>6-186-001</td><td>-</td><td>*ENG</td><td>[1 to 2 / <strong>2 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6801</td><td>[1-pass Stamp Unit]</td><td></td><td></td></tr><tr><td>6-801-001</td><td>-</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: NO<br /> 1: YES</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6900</td><td>[ADF Bottom Plate Setting]</td><td></td><td></td></tr><tr><td>6-900-001</td><td>-</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <br /> <table style='width: 100%'><tr><td>6901</td><td>[ADF Operation Setting]</td><td></td><td></td></tr><tr><td>Setting to give priority to stackability.</td><td></td><td></td><td></td></tr><tr><td>6-901-001</td><td>-</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: Higher quietness<br /> 1: Higher throughput</td></tr><tr><td>6-901-002</td><td>-</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]<br /> 0: Normal<br /> 1: Higher stackability</td></tr></table> <table style='width: 100%'><tr><td>7622</td><td>[PM Counter Reset]</td><td></td><td></td></tr><tr><td>7-622-002</td><td># PCU:K</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-004</td><td>Developer:K</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-025</td><td># PCU:C</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-027</td><td>Developer:C</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-048</td><td># PCU:M</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-050</td><td>Developer:M</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-071</td><td># PCU:Y</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-073</td><td>Developer:Y</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-093</td><td># ITB Unit</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-109</td><td># PTR Unit</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-131</td><td>Dust Filter</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-206</td><td>ADF Pick-up Roller</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-207</td><td>ADF Supply Belt</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-208</td><td>ADF Reverse Roller</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <br /> <table style='width: 100%'><tr><td>7-621-207</td><td>ADF Supply Belt</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-208</td><td>ADF Reverse Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr></table> <br /> Engine SP Mode Tables<br /> <br /> </li> </ol></li> <li data-xf-list-type="ol"> <h3>ENGINE SP TABLES - SP7000</h3> <ol> <li data-xf-list-type="ol"> <h3>SP7-XXX (DATA LOG)</h3> </li> </ol></li> </ol><p></p><p></p><table style='width: 100%'><tr><td>7621</td><td>[PM Counter Display: Pages]</td><td></td><td></td></tr><tr><td>7-621-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-003</td><td># Dev Unit:K</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-026</td><td># Dev Unit:C</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-049</td><td># Dev Unit:M</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-072</td><td># Dev Unit:Y</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-131</td><td>Dust Filter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-621-142</td><td>Waste Toner Bottle</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mg/step]</td></tr><tr><td>7-621-206</td><td>ADF Pick-up Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr></table> <table style='width: 100%'><tr><td>7-622-245</td><td>PCU:All Colors</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-622-246</td><td>Development Unit:All Colors</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-247</td><td>Developer:All Colors</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-622-250</td><td>SCS</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7623</td><td>[PM Value Setting: Life Pages]</td><td></td><td></td></tr><tr><td>7-623-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-623-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>240000 </strong>/ 1page/step]</td></tr><tr><td>7-623-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>240000 </strong>/ 1page/step]</td></tr><tr><td>7-623-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>240000 </strong>/ 1page/step]</td></tr><tr><td>7-623-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>240000 </strong>/ 1page/step]</td></tr><tr><td>7-623-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 99999999 / <strong>240000 </strong>/ 1page/step]</td></tr><tr><td>7-623-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>240000 </strong>/ 1page/step]</td></tr><tr><td>7-623-131</td><td>Dust Filter</td><td>ENG</td><td>[0 to 99999999 / <strong>300000 </strong>/ 1page/step]</td></tr></table> <table style='width: 100%'><tr><td>7-623-142</td><td>Waste Toner Bottle</td><td>ENG</td><td>[0 to 999999999 / <strong>1200000 </strong>/ 1mg/step]</td></tr><tr><td>7-623-206</td><td>ADF Pick-up Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>120000 </strong>/ 1page/step]</td></tr><tr><td>7-623-207</td><td>ADF Supply Belt</td><td>ENG</td><td>[0 to 99999999 / <strong>120000 </strong>/ 1page/step]</td></tr><tr><td>7-623-208</td><td>ADF Reverse Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>120000 </strong>/ 1page/step]</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7625</td><td>[Previous Unit Counter: Pages]</td><td></td><td></td></tr><tr><td>7-625-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-131</td><td>Dust Filter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-142</td><td>Waste Toner Bottle</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr></table> <table style='width: 100%'><tr><td>7-625-206</td><td>ADF Pick-up Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-207</td><td>ADF Supply Belt</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-625-208</td><td>ADF Reverse Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7626</td><td>[Previous Unit Counter2: Pages]</td><td></td><td></td></tr><tr><td>7-626-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-131</td><td>Dust Filter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-142</td><td>Waste Toner Bottle</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mg/step]</td></tr><tr><td>7-626-206</td><td>ADF Pick-up Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr></table> <table style='width: 100%'><tr><td>7628</td><td>[PM Counter Reset]</td><td></td><td></td></tr><tr><td>7-628-002</td><td>SCS</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><table style='width: 100%'><tr><td>7-626-207</td><td>ADF Supply Belt</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr><tr><td>7-626-208</td><td>ADF Reverse Roller</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1page/step]</td></tr></table><p></p><p></p><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7720</td><td>[Ave. Cvrg for Eng.]</td><td></td><td></td></tr><tr><td>7-720-001</td><td>K</td><td>*ENG</td><td>[0 to 100 / <strong>0 </strong>/ 0.01%/step]</td></tr><tr><td>7-720-002</td><td>C</td><td>*ENG</td><td>[0 to 100 / <strong>0 </strong>/ 0.01%/step]</td></tr><tr><td>7-720-003</td><td>M</td><td>*ENG</td><td>[0 to 100 / <strong>0 </strong>/ 0.01%/step]</td></tr><tr><td>7-720-004</td><td>Y</td><td>*ENG</td><td>[0 to 100 / <strong>0 </strong>/ 0.01%/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7801</td><td>[ROM No.]</td><td></td><td></td></tr><tr><td>7-801-002</td><td>Engine</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-005</td><td>ADF</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-007</td><td>Finisher</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-009</td><td>PTU</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-010</td><td>LCT</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-019</td><td>PTU2</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7801</td><td>[ROM No./ Firmware Version]</td><td></td><td></td></tr><tr><td>7-801-102</td><td>Engine</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-105</td><td>ADF</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-107</td><td>Finisher</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-109</td><td>PTU</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr><tr><td>7-801-110</td><td>LCT</td><td>ENG</td><td>[- / <strong>- </strong>/ -]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7852</td><td>[DF Glass Dust Check]</td></tr></table> <table style='width: 100%'><tr><td>7-852-001</td><td>Dust Detection Counter</td><td>*ENG</td><td>[0 to 65535 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-852-002</td><td>Dust Counter Clear Counter</td><td>*ENG</td><td>[0 to 65535 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-852-003</td><td>Dust Detection Counter: Back</td><td>*ENG</td><td>[0 to 65535 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7853</td><td>[Replace Counter]</td><td></td><td></td></tr><tr><td>7-853-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-131</td><td>Dust Filter</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-142</td><td>Waste Toner Bottle</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>7-853-206</td><td>ADF Pick-up Roller</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-207</td><td>ADF Supply Belt</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-853-208</td><td>ADF Reverse Roller</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7906</td><td>[Previous Unit Counter<img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big grin :D" loading="lazy" data-shortname=":D" />istance]</td><td></td><td></td></tr><tr><td>7-906-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-027</td><td>Developer: C</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-050</td><td>Developer: M</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-073</td><td>Developer: Y</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-230</td><td>Low Speed: # PCU:K</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-231</td><td>Low Speed: # PCU:C</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-232</td><td>Low Speed: # PCU:M</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr></table> <table style='width: 100%'><tr><td>7-906-233</td><td>Low Speed: # PCU:Y</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-234</td><td>Middle Speed: # PCU:K</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-235</td><td>Middle Speed: # PCU:C</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-236</td><td>Middle Speed: # PCU:M</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-906-237</td><td>Middle Speed: # PCU:Y</td><td>ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7907</td><td>[Previous Unit Cntr<img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big grin :D" loading="lazy" data-shortname=":D" />istance(%)]</td><td></td><td></td></tr><tr><td>7-907-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-907-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr></table> <table style='width: 100%'><tr><td>7908</td><td>[Previous Unit Counter<img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite7" alt=":p" title="Stick out tongue :p" loading="lazy" data-shortname=":p" />ages(%)]</td><td></td><td></td></tr><tr><td>7-908-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-131</td><td>Dust Filter</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-142</td><td>Waste Toner Bottle</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-206</td><td>ADF Pick-up Roller</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-207</td><td>ADF Supply Belt</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-908-208</td><td>ADF Reverse Roller</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7931</td><td>[Toner Bottle Bk]</td><td></td></tr></table> <table style='width: 100%'><tr><td>7-931-001</td><td>Machine Serial ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-002</td><td>Cartridge Ver</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-003</td><td>Brand ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-004</td><td>Area ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-005</td><td>Product ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-006</td><td>Color ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-007</td><td>Maintenance ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-008</td><td>New Product Information</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-009</td><td>Recycle Counter</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-010</td><td>Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-011</td><td>SerialNo.</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-012</td><td>Toner Remaining</td><td>*ENG</td><td>[0 to 100 / <strong>100 </strong>/ 1%/step]</td></tr><tr><td>7-931-013</td><td>EDP Code</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-014</td><td>End History</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-015</td><td>Refill Information</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-016</td><td>Attachment: Total Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-931-017</td><td>Attachment: Color Counter</td><td><br /> *ENG</td><td><br /> [0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-018</td><td>End: Total Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-019</td><td>End: Color Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-020</td><td>Attachment Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-931-021</td><td>End Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7932</td><td>[Toner Bottle M]</td><td></td><td></td></tr><tr><td>7-932-001</td><td>Machine Serial ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-002</td><td>Cartridge Ver</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>7-932-003</td><td>Brand ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-004</td><td>Area ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-005</td><td>Product ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-006</td><td>Color ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-007</td><td>Maintenance ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-008</td><td>New Product Information</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-009</td><td>Recycle Counter</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-010</td><td>Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-011</td><td>SerialNo.</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-012</td><td>Toner Remaining</td><td>*ENG</td><td>[0 to 100 / <strong>100 </strong>/ 1%/step]</td></tr><tr><td>7-932-013</td><td>EDP Code</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-014</td><td>End History</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-015</td><td>Refill Information</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-016</td><td>Attachment: Total Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-932-017</td><td>Attachment: Color Counter</td><td><br /> *ENG</td><td><br /> [0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-018</td><td>End: Total Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-019</td><td>End: Color Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-020</td><td>Attachment Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-932-021</td><td>End Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7933</td><td>[Toner Bottle C]</td><td></td><td></td></tr><tr><td>7-933-001</td><td>MachineSerialID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-002</td><td>Cartridge Ver</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-003</td><td>Brand ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-004</td><td>Area ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>7-933-005</td><td>Product ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-006</td><td>Color ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-007</td><td>Maintenance ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-008</td><td>New Product Information</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-009</td><td>Recycle Counter</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-010</td><td>Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-011</td><td>SerialNo.</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-012</td><td>Toner Remaining</td><td>*ENG</td><td>[0 to 100 / <strong>100 </strong>/ 1%/step]</td></tr><tr><td>7-933-013</td><td>EDP Code</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-014</td><td>End History</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-015</td><td>Refill Information</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-016</td><td>Attachment: Total Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-933-017</td><td>Attachment: Color Counter</td><td><br /> *ENG</td><td><br /> [0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-018</td><td>End: Total Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-019</td><td>End: Color Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-020</td><td>Attachment Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-933-021</td><td>End Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7934</td><td>[Toner Bottle Y]</td><td></td><td></td></tr><tr><td>7-934-001</td><td>MachineSerialID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-002</td><td>Cartridge Ver</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-003</td><td>Brand ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-004</td><td>Area ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-005</td><td>Product ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-006</td><td>Color ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>7-934-007</td><td>Maintenance ID</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-008</td><td>New Product Information</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-009</td><td>Recycle Counter</td><td>*ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-010</td><td>Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-011</td><td>SerialNo.</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-012</td><td>Toner Remaining</td><td>*ENG</td><td>[0 to 100 / <strong>100 </strong>/ 1%/step]</td></tr><tr><td>7-934-013</td><td>EDP Code</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-014</td><td>End History</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-015</td><td>Refill Information</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-016</td><td>Attachment: Total Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-934-017</td><td>Attachment: Color Counter</td><td><br /> *ENG</td><td><br /> [0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-018</td><td>End: Total Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-019</td><td>End: Color Counter</td><td>*ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-020</td><td>Attachment Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-934-021</td><td>End Date</td><td>*ENG</td><td>[0 to 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7935</td><td>[Toner Bottle Log 1: Bk]</td><td></td><td></td></tr><tr><td>7-935-001</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-002</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-003</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-004</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7935</td><td>[Toner Bottle Log 2: Bk]</td><td></td><td></td></tr><tr><td>7-935-011</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-012</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-013</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>7-935-014</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7935</td><td>[Toner Bottle Log 3: Bk]</td><td></td><td></td></tr><tr><td>7-935-021</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-022</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-023</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-024</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7935</td><td>[Toner Bottle Log 4: Bk]</td><td></td><td></td></tr><tr><td>7-935-031</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-032</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-033</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-034</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7935</td><td>[Toner Bottle Log 5: Bk]</td><td></td><td></td></tr><tr><td>7-935-041</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-042</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-043</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-935-044</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7936</td><td>[Toner Bottle Log 1: M]</td><td></td><td></td></tr><tr><td>7-936-001</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-002</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-936-003</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-004</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7936</td><td>[Toner Bottle Log 2: M]</td><td></td><td></td></tr><tr><td>7-936-011</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-012</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td><br /> 7-936-013</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-014</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7936</td><td>[Toner Bottle Log 3: M]</td><td></td><td></td></tr><tr><td>7-936-021</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-022</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-936-023</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-024</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7936</td><td>[Toner Bottle Log 4: M]</td><td></td><td></td></tr><tr><td>7-936-031</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-032</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-936-033</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-034</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7936</td><td>[Toner Bottle Log 5: M]</td><td></td><td></td></tr><tr><td>7-936-041</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-042</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-936-043</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-936-044</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7937</td><td>[Toner Bottle Log 1: C]</td><td></td><td></td></tr><tr><td>7-937-001</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-002</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-937-003</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-004</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td>7937</td><td>[Toner Bottle Log 2: C]</td><td></td><td></td></tr><tr><td>7-937-011</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-012</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-937-013</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-014</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7937</td><td>[Toner Bottle Log 3: C]</td><td></td><td></td></tr><tr><td>7-937-021</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-022</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-937-023</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-024</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7937</td><td>[Toner Bottle Log 4: C]</td><td></td><td></td></tr><tr><td>7-937-031</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-032</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-937-033</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-034</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7937</td><td>[Toner Bottle Log 5: C]</td><td></td><td></td></tr><tr><td>7-937-041</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-042</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-937-043</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-937-044</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7938</td><td>[Toner Bottle Log 1: Y]</td><td></td><td></td></tr><tr><td>7-938-001</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-002</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table> <table style='width: 100%'><tr><td><br /> 7-938-003</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-004</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7938</td><td>[Toner Bottle Log 2: Y]</td><td></td><td></td></tr><tr><td>7-938-011</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-012</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-938-013</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-014</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7938</td><td>[Toner Bottle Log 3: Y]</td><td></td><td></td></tr><tr><td>7-938-021</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-022</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-938-023</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-024</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7938</td><td>[Toner Bottle Log 4: Y]</td><td></td><td></td></tr><tr><td>7-938-031</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-032</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-938-033</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-034</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7938</td><td>[Toner Bottle Log 5: Y]</td><td></td><td></td></tr><tr><td>7-938-041</td><td>SerialNo.</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-042</td><td>Attachment Date</td><td>ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr><tr><td><br /> 7-938-043</td><td>Attachment: Total Counter</td><td>ENG</td><td>[0 to 99999999 / <strong>0 </strong>/ 1/step]</td></tr><tr><td>7-938-044</td><td>Refill Information</td><td>*ENG</td><td>[0 or 1 / <strong>0 </strong>/ 1/step]</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7940</td><td>[PM Value Setting:Life Distance]</td><td></td><td></td></tr><tr><td>7-940-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 999999999 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-940-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 999999999 / <strong>128410397 </strong>/<br /> 1mm/step]</td></tr><tr><td>7-940-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 999999999 / <strong>128410397 </strong>/<br /> 1mm/step]</td></tr><tr><td>7-940-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 999999999 / <strong>128410397 </strong>/<br /> 1mm/step]</td></tr><tr><td>7-940-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 999999999 / <strong>291305000 </strong>/<br /> 1mm/step]</td></tr><tr><td>7-940-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 999999999 / <strong>291305000 </strong>/<br /> 1mm/step]</td></tr><tr><td>7-940-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 999999999 / <strong>291305000 </strong>/<br /> 1mm/step]</td></tr></table><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7942</td><td>[PM Counter Display<img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big grin :D" loading="lazy" data-shortname=":D" />istance(%)]</td><td></td><td></td></tr><tr><td>7-942-002</td><td># PCU:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr></table> <table style='width: 100%'><tr><td>7-942-003</td><td># Dev Unit:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-004</td><td>Developer:K</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-025</td><td># PCU:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-026</td><td># Dev Unit:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-027</td><td>Developer:C</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-048</td><td># PCU:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-049</td><td># Dev Unit:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-050</td><td>Developer:M</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-071</td><td># PCU:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-072</td><td># Dev Unit:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-073</td><td>Developer:Y</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-093</td><td># ITB Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-102</td><td># ITB Cleaning Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-109</td><td># PTR Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-115</td><td># Fusing Unit</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-116</td><td>Fusing Belt</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr><tr><td>7-942-118</td><td>Pressure Roller</td><td>ENG</td><td>[0 to 255 / <strong>0 </strong>/ 1%/step]</td></tr></table><p>Engine SP Mode Tables</p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><p></p><table style='width: 100%'><tr><td>7944</td><td>[PM Counter Display: Distance]</td><td></td><td></td></tr><tr><td>7-944-002</td><td># PCU:K</td><td>*ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-944-003</td><td># Dev Unit:K</td><td>*ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-944-004</td><td>Developer:K</td><td>*ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-944-025</td><td># PCU:C</td><td>*ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-944-026</td><td># Dev Unit:C</td><td>*ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-944-027</td><td>Developer:C</td><td>*ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr><tr><td>7-944-048</td><td># PCU:M</td><td>*ENG</td><td>[0 to 4294967295 / <strong>0 </strong>/ 1mm/step]</td></tr></table></blockquote><p></p>
[QUOTE="John, post: 78, member: 2"] [TABLE] [TR] [TD]4-611-001[/TD] [TD]Book Scan[/TD] [TD]*ENG[/TD] [TD][-384 to 255 / -[B]100 [/B]/ 1digit/step][/TD] [/TR] [TR] [TD]4-611-002[/TD] [TD]DF Scan[/TD] [TD]*ENG[/TD] [TD][-384 to 255 / -[B]100 [/B]/ 1digit/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4635[/TD] [TD][SSCG Correction Set][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-635-001[/TD] [TD]Mode Selection[/TD] [TD]*ENG[/TD] [TD][0 to 3 / [B]1 [/B]/ 1/step] 0: Do not noise correct SSCG. 1: Only adjust analog (initial value) 2: Only adjust digital 3: Adjust both analog/digital[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4646[/TD] [TD][Scan Adjust Error][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-646-001[/TD] [TD]White level[/TD] [TD]ENG[/TD] [TD][0 to 65535 / [B]0 [/B]/ 1/step] Bit15:Unused Bit14: Unused Bit13:White level abnormal (F side/RED/EVEN pixel) Bit12: White level abnormal (F side /RED/ODD pixel) Bit11: White level abnormal (F side /GREEN/EVEN pixel) Bit10: White level abnormal (F side /GREEN/ODD pixel) Bit9: White level abnormal (F side /BLUE/EVEN pixel) Bit8:White level abnormal (F side /BLUE/ODD pixel) Bit7: Unused Bit6: Unused Bit5:gain abnormal (F side /RED/EVEN pixel) Bit4: gain abnormal (F side /RED/ODD pixel) Bit3: gain abnormal (F side /GREEN/EVEN pixel) Bit2: gain abnormal (F side /GREEN/ODD pixel) Bit1: gain abnormal (F side /BLUE/EVEN pixel) Bit0: gain abnormal (F side /BLUE/ODD pixel)[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4-646-002[/TD] [TD]Black level[/TD] [TD]ENG[/TD] [TD][0 to 65535 / [B]0 [/B]/ 1/step] Bit7: Unused Bit6: Unused Bit5: Black level abnormal (F side/RED/EVEN Pixel) Bit4: Black level abnormal (F side /RED/ODD Pixel) Bit3: Black level abnormal (F side /GREEN/EVEN Pixel) Bit2: Black level abnormal (F side /GREEN/ODD Pixel) Bit1: Black level abnormal (F side /BLUE/EVEN Pixel) Bit0: Black level abnormal (F side /BLUE/ODD Pixel)[/TD] [/TR] [TR] [TD]4-646-003[/TD] [TD]SSCG Correction[/TD] [TD]ENG[/TD] [TD][0 to 65535 / [B]0 [/B]/ 1/step] Bit7: Unused Bit6: Unused Bit5: SSCG correction error (Fside/RED/EVEN Pixel) Bit4: SSCG correction error (Fside/RED/ODD Pixel) Bit3: SSCG correction error (Fside/GREEN/EVEN Pixel) Bit2: SSCG correction error (Fside/GREEN/ODD Pixel) Bit1: SSCG correction error (Fside/BLUE/EVEN Pixel) Bit0: SSCG correction error (Fside/BLUE/ODD Pixel)[/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]4647[/TD] [TD][Scanner Hard Error][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4-647-001[/TD] [TD]Power-ON[/TD] [TD]ENG[/TD] [TD][0 to 65535 / [B]0 [/B]/ 1/step] Bit15: Unused Bit14:SBU hardware error (Power ON/un-reset error) Bit13:SBU hardware error (Serial communication error: F side) Bit12:SBU hardware error (Reset error: F side) Bit11: Unused Bit10: Unused Bit9:SBU hardware error (Version error) Bit8: Unused Bit7: Unused Bit6: Unused Bit5:SBU hardware error (Serial communication error: L side) Bit4:SBU hardware error (Reset error:Lside) Bit3: Unused Bit2: Unused Bit1: Unused[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4688[/TD] [TD][DF Density Adjustment][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-688-001[/TD] [TD]ARDF[/TD] [TD]*ENG[/TD] [TD][80 to 120 / [B]106 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]4688[/TD] [TD][Scan Image Density Adjustment][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-688-002[/TD] [TD]1-pass DF[/TD] [TD]*ENG[/TD] [TD][[80 to 120 / [B]101 [/B]/ 1%/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4699[/TD] [TD][SBU Test Pattern Change][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-699-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4700[/TD] [TD][CIS ID Display][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-700-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0x00 to 0xFF / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4712[/TD] [TD][CIS GB Adj. Value: R][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-712-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 to 2048 / [B]1023 [/B]/ 1digit/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4714[/TD] [TD][CIS GB Adj. Value: B][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-714-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 to 2048 / [B]1023 [/B]/ 1digit/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4713[/TD] [TD][CIS GB Adj. Value: G][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-713-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 to 2048 / [B]1023 [/B]/ 1digit/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]4730[/TD] [TD][FROM ADF Factory Setting][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-730-001[/TD] [TD]CIS Parameter[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 0/step][/TD] [/TR] [TR] [TD]4730[/TD] [TD][FROM Main Factory Setting][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-730-002[/TD] [TD]Execution ON/OFF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 0/step][/TD] [/TR] [TR] [TD]4-730-003[/TD] [TD]Execution Flag[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4730[/TD] [TD][FROM Data Update][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-730-004[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 0/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4745[/TD] [TD][CIS Image Level Error Flag][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-745-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 to 65535 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4746[/TD] [TD][CIS GB Adj Error Flag][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-746-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 to 7 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4747[/TD] [TD][CIS Hard Error Flag][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-747-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 to 15 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4796[/TD] [TD][Low Density Color Correction][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4-796-001[/TD] [TD]Front Side[/TD] [TD]*ENG[/TD] [TD][0 to 3 / [B]0 [/B]/ 1/step] 0: OFF 1: WEAK 2: MEDIUM 3: STRONG[/TD] [/TR] [TR] [TD]4-796-002[/TD] [TD]Rear Side[/TD] [TD]*ENG[/TD] [TD][0 to 3 / [B]0 [/B]/ 1/step] 0: OFF 1: WEAK 2: MEDIUM 3: STRONG[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4797[/TD] [TD][Rear Side: Digital AE][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-797-001[/TD] [TD]Low Limit Setting[/TD] [TD]*ENG[/TD] [TD][0 to 1023 / [B]364 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-797-002[/TD] [TD]Background Erase Level[/TD] [TD]*ENG[/TD] [TD][512 to 1535 / [B]932 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4799[/TD] [TD][CIS TEST Pattern][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-799-001[/TD] [TD]select[/TD] [TD]ENG[/TD] [TD][0 to 5 / [B]0 [/B]/ 1/step] Sets CIS test pattern output. 0: Scanned Image 1: Fixed Value Pattern 2: EO Fixed Value Pattern 3: Main Scan Gradation 4: Sub Scan Gradation 5: Grid Pattern[/TD] [/TR] [TR] [TD]4-799-002[/TD] [TD]Even Output Level Setting[/TD] [TD]ENG[/TD] [TD][0 to 1023 / [B]0 [/B]/ 1digit/step][/TD] [/TR] [TR] [TD]4-799-003[/TD] [TD]Odd Output Level Setting[/TD] [TD]ENG[/TD] [TD][0 to 1023 / [B]0 [/B]/ 1digit/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4803[/TD] [TD][Home Position Adj Value][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-803-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][-2.0 to 2.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4853[/TD] [TD][Partial LED ON][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-853-001[/TD] [TD]ON/OFF(Scan)[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]1 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4871[/TD] [TD][Distortion Corr.][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-871-001[/TD] [TD]Distortion Corr. ON/OFF[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]1 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-871-002[/TD] [TD]Distortion Initialization[/TD] [TD]*ENG[/TD] [TD][0 to 3 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-871-003[/TD] [TD]Magnification Adjust(DF)[/TD] [TD]*ENG[/TD] [TD][-0.35 to 0.35 / [B]0.11 [/B]/ 0.01%/step][/TD] [/TR] [TR] [TD]4-871-004[/TD] [TD]Magnification Adjust(FB)[/TD] [TD]*ENG[/TD] [TD][-0.35 to 0.35 / [B]0 [/B]/ 0.01%/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4-853-002[/TD] [TD]ON/OFF(Size Detection)[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]1 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]4902[/TD] [TD][Disp ACC Data][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-902-001[/TD] [TD]R_DATA1[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-902-002[/TD] [TD]G_DATA1[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-902-003[/TD] [TD]B_DATA1[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-902-004[/TD] [TD]R_DATA2[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-902-005[/TD] [TD]G_DATA2[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-902-006[/TD] [TD]B_DATA2[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4903[/TD] [TD][Filter Setting][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-903-001[/TD] [TD]Ind Dot Erase: Text[/TD] [TD]*ENG[/TD] [TD][0 to 7 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-903-002[/TD] [TD]Ind Dot Erase: Generation Copy[/TD] [TD]*ENG[/TD] [TD] [0 to 7 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4905[/TD] [TD][Select Gradation Level][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-905-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4918[/TD] [TD][Man Gamma Adj][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-918-009[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4930[/TD] [TD][Coverage Ctrl: Text][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4-930-001[/TD] [TD]Copy: Full Color 1[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]200 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-930-002[/TD] [TD]Copy: Full Color 2[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]200 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-930-003[/TD] [TD]Copy: Single Color[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]100 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-930-004[/TD] [TD]Copy: Color Conversion[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]180 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-930-005[/TD] [TD]Coverage Ctrl OFF[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]400 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4931[/TD] [TD][Coverage Ctrl: Photo][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-931-001[/TD] [TD]Copy: Full Color 1[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]240 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-931-002[/TD] [TD]Copy: Full Color 2[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]260 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-931-003[/TD] [TD]Copy: Single Color[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]100 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-931-004[/TD] [TD]Copy: Color Conversion[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]200 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-931-005[/TD] [TD]Coverage Ctrl OFF[/TD] [TD]ENG[/TD] [TD][0 to 400 / [B]400 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4938[/TD] [TD][ACS:Edge Mask][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-938-001[/TD] [TD]Copy:Sub LEdge[/TD] [TD]*ENG[/TD] [TD][0 to 31 / [B]10 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]4-938-002[/TD] [TD]Copy:Sub TEdge[/TD] [TD]*ENG[/TD] [TD][0 to 31 / [B]10 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]4-938-003[/TD] [TD]Copy:Main LEdge[/TD] [TD]*ENG[/TD] [TD][0 to 31 / [B]10 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]4-938-004[/TD] [TD]Copy:Main TEdge[/TD] [TD]*ENG[/TD] [TD][0 to 31 / [B]10 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]4-938-005[/TD] [TD]Scan:Sub LEdge[/TD] [TD]*ENG[/TD] [TD][0 to 31 / [B]15 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]4-938-006[/TD] [TD]Scan:Sub TEdge[/TD] [TD]*ENG[/TD] [TD][0 to 31 / [B]15 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]4-938-007[/TD] [TD]Scan:Main LEdge[/TD] [TD]*ENG[/TD] [TD][0 to 31 / [B]15 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]4-938-008[/TD] [TD]Scan:Main TEdge[/TD] [TD]*ENG[/TD] [TD][0 to 31 / [B]15 [/B]/ 1mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4939[/TD] [TD][ACS:Color Range][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4-939-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][-2 to 2 / [B]0 [/B]/ 1/step] Change the value of this SP to negative (“-1” or “-2”) when a black and white document is misjudged as a color document.[/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]4954[/TD] [TD][Restore Test Chart][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-954-005[/TD] [TD]Chromaticity Rank[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4958[/TD] [TD][Restore Test Chart: Rear][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-958-005[/TD] [TD]Chromaticity Rank[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4984[/TD] [TD][IBACC Target Den][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-984-001[/TD] [TD]IBACC notch K[/TD] [TD]*ENG[/TD] [TD][0 to 10 / [B]5 [/B]/ 1/step][/TD] [/TR] [TR] [TD]4-984-002[/TD] [TD]IBACC notch C[/TD] [TD]*ENG[/TD] [TD][/TD] [/TR] [TR] [TD]4-984-003[/TD] [TD]IBACC notch M[/TD] [TD]*ENG[/TD] [TD][/TD] [/TR] [TR] [TD]4-984-004[/TD] [TD]IBACC notch Y[/TD] [TD]*ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4993[/TD] [TD][High Light Correction][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-993-001[/TD] [TD]Sensitivity Selection[/TD] [TD]ENG[/TD] [TD][0 to 9 / [B]4 [/B]/ 1/step] 0: Weak 9: Strong[/TD] [/TR] [TR] [TD]4-993-002[/TD] [TD]Range Selection[/TD] [TD]ENG[/TD] [TD][0 to 9 / [B]4 [/B]/ 1/step] 0: Weak 9: Strong[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4994[/TD] [TD][Adj Txt/Photo Recog Level][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]4-994-001[/TD] [TD]High Compression PDF[/TD] [TD]ENG[/TD] [TD][0 to 2 / [B]1 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4996[/TD] [TD][White Paper Detection Level][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]4-996-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 to 6 / [B]3 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [INDENT][LIST=1] [*][HEADING=2]ENGINE SP TABLES - SP5000[/HEADING] [LIST=1] [*][HEADING=2]SP5-XXX (MODE)[/HEADING] [TABLE] [TR] [TD]5126[/TD] [TD][Set F-size Document][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-126-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 to 2 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD]0: 8 1/2 x13[/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD]1: 8 1/4 x13[/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD]2: 8 x13[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5131[/TD] [TD][Paper Size Type Selection][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-131-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 to 2 / [B]* [/B]/ 1/step] *NA: 1, EU: 2, Asia: 2, CHN: 2, TWN: 2 , KOR: 2 --- 0: JP (Japan) 1: NA 2: EU[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5135[/TD] [TD][LG_Oficio Change][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-135-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5181[/TD] [TD][Size Adjust][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-181-001[/TD] [TD]TRAY 1[/TD] [TD]*ENG[/TD] [TD][0 to 3 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: A4 LEF 1: LT LEF 2: B5 LEF 3: A5 LEF[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5-181-002[/TD] [TD]TRAY 2: 1[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: A4 LEF 1: LT LEF[/TD] [/TR] [TR] [TD]5-181-003[/TD] [TD]TRAY 2: 2[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: A3 1: DLT[/TD] [/TR] [TR] [TD]5-181-004[/TD] [TD]TRAY 2: 3[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: B4 1: LG[/TD] [/TR] [TR] [TD]5-181-005[/TD] [TD]TRAY 2: 4[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: B5LEF 1: ExeLEF[/TD] [/TR] [TR] [TD]5-181-006[/TD] [TD]TRAY 2: 5[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: SRA3 1: 12X18[/TD] [/TR] [TR] [TD]5-181-007[/TD] [TD]TRAY 3/T-LCT: 1[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: A4LEF 1: LTLEF[/TD] [/TR] [TR] [TD]5-181-008[/TD] [TD]TRAY 3: 2[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: A3 1: DLT[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5-181-009[/TD] [TD]TRAY 3: 3[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: B4 1: LG[/TD] [/TR] [TR] [TD]5-181-010[/TD] [TD]TRAY 3: 4[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: B5LEF 1: ExeLEF[/TD] [/TR] [TR] [TD]5-181-011[/TD] [TD]TRAY 3: 5[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: 12.6X17.7 1: 12X18[/TD] [/TR] [TR] [TD]5-181-012[/TD] [TD]TRAY 4: 1[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: A4LEF 1: LTLEF[/TD] [/TR] [TR] [TD]5-181-013[/TD] [TD]TRAY 4: 2[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: A3 1: DLT[/TD] [/TR] [TR] [TD]5-181-014[/TD] [TD]TRAY 4: 3[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: B4 1: LG[/TD] [/TR] [TR] [TD]5-181-015[/TD] [TD]TRAY 4: 4[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: B5LEF 1: ExeLEF[/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]5-181-016[/TD] [TD]TRAY 4: 5[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: 12.6X17.7 1: 12X18[/TD] [/TR] [TR] [TD]5-181-017[/TD] [TD]LCT[/TD] [TD]*ENG[/TD] [TD][0 to 2 / [B]* [/B]/ 1/step] *NA: 1, EU: 0, Asia: 0, CHN: 0, TWN: 0 , KOR: 0 0: A4LEF 1: LTLEF 2: B5LEF[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5186[/TD] [TD][RK4][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-186-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5610[/TD] [TD][Base Gamma Ctrl Pt:Execute][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-610-004[/TD] [TD]Get Factory Default[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-610-005[/TD] [TD]Set Factory Default[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-610-006[/TD] [TD]Restore Orginal Value[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5611[/TD] [TD][Toner Color in 2C][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-611-001[/TD] [TD]B-C[/TD] [TD]*ENG[/TD] [TD][0 to 128 / [B]100 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-611-002[/TD] [TD]B-M[/TD] [TD]*ENG[/TD] [TD][0 to 128 / [B]100 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-611-003[/TD] [TD]G-C[/TD] [TD]*ENG[/TD] [TD][0 to 128 / [B]100 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-611-004[/TD] [TD]G-Y[/TD] [TD]*ENG[/TD] [TD][0 to 128 / [B]100 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-611-005[/TD] [TD]R-M[/TD] [TD]*ENG[/TD] [TD][0 to 128 / [B]100 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-611-006[/TD] [TD]R-Y[/TD] [TD]*ENG[/TD] [TD][0 to 128 / [B]100 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5801[/TD] [TD][Memory Clear][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5803[/TD] [TD][INPUT Check][/TD] [/TR] [TR] [TD]See page 3-385 "Input Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5-801-002[/TD] [TD]Engine[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -] [Execute][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]5804[/TD] [TD][OUTPUT Check][/TD] [/TR] [TR] [TD]See page 3-412 "Output Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5805[/TD] [TD][Anti-Condensation Heater][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-805-001[/TD] [TD]0:OFF / 1:ON[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: OFF... Switches OFF when standby (default setting) 1: ON... Switches ON when standby[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5810[/TD] [TD][SC Reset][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-810-001[/TD] [TD]Fusing SC Reset[/TD] [TD]ENG[/TD] [TD]Clears the fusing SC.[/TD] [/TR] [TR] [TD]5-810-002[/TD] [TD]Hard High Temp. Detection[/TD] [TD]ENG[/TD] [TD]Clears the fusing hardware SC.[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5811[/TD] [TD][MachineSerial][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-811-002[/TD] [TD]Display[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5811[/TD] [TD][MachineSerial Set][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-811-004[/TD] [TD]BCU[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5811[/TD] [TD][Machine Serial: Update Date][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-811-021[/TD] [TD]Latest[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-811-022[/TD] [TD]Previous[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5811[/TD] [TD][MachineSerial][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-811-023[/TD] [TD]Previous[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5811[/TD] [TD][Machine Serial: Update Date][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-811-024[/TD] [TD]Latest (BCU)[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-811-025[/TD] [TD]Previous (BCU)[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5811[/TD] [TD][MachineSerial][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-811-026[/TD] [TD]Previous (BCU)[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5894[/TD] [TD][External Mech Count Setting][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-894-001[/TD] [TD]Mech Counter Switch Setting[/TD] [TD]*ENG[/TD] [TD][0 to 2 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5900[/TD] [TD][Engine Log Upload][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-900-001[/TD] [TD]Pattern[/TD] [TD]*ENG[/TD] [TD][0 to 4 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]5-900-002[/TD] [TD]Trigger[/TD] [TD]*ENG[/TD] [TD][0 to 3 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]5998[/TD] [TD][Fusing Warm UP][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]5-998-001[/TD] [TD]Warm Up In Advance ON/OFF[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [/LIST] [*][HEADING=2]ENGINE SP TABLES - SP6000[/HEADING] [LIST=1] [*][HEADING=2]SP6-XXX (PERIPHERALS)[/HEADING] [TABLE] [TR] [TD]6006[/TD] [TD][ADF Adjustment][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-006-001[/TD] [TD]Side-to-Side Regist: Front[/TD] [TD]*ENG[/TD] [TD][-3.0 to 3.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-002[/TD] [TD]Side-to-Side Regist: Rear[/TD] [TD]*ENG[/TD] [TD][-3.0 to 3.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-003[/TD] [TD]Leading Edge Registration: Front[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-004[/TD] [TD]Leading Edge Registration: Rear[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-005[/TD] [TD]Buckle: Duplex Front[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-006[/TD] [TD]Buckle: Duplex Rear[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-007[/TD] [TD]Rear Edge Erase Front[/TD] [TD]*ENG[/TD] [TD][-10.0 to 10.0 / [B]-2.3 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-008[/TD] [TD]Rear Edge Erase Rear[/TD] [TD]*ENG[/TD] [TD][-10.0 to 10.0 / [B]-2.3 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-010[/TD] [TD]L-Edge Regist (1-Pass): Front[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-011[/TD] [TD]L-Edge Regist (1-Pass): Rear[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-012[/TD] [TD]1st Buckle (1-Pass)[/TD] [TD]*ENG[/TD] [TD][-3.0 to 3.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-013[/TD] [TD]2nd Buckle (1-Pass)[/TD] [TD]*ENG[/TD] [TD][-2.0 to 3.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-014[/TD] [TD]T-Edge Erase (1-Pass): Front[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]-3.0 [/B]/ 0.1mm/step][/TD] [/TR] [TR] [TD]6-006-015[/TD] [TD]T-Edge Erase (1-Pass): Rear[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]-2.5 [/B]/ 0.1mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6007[/TD] [TD][ADF INPUT Check][/TD] [/TR] [TR] [TD]See page 3-385 "Input Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6008[/TD] [TD][ADF OUTPUT Check][/TD] [/TR] [TR] [TD]See page 3-412 "Output Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6009[/TD] [TD][ADF FreeRun][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-009-001[/TD] [TD]Free Run Simplex Motion[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-009-002[/TD] [TD]Free Run Duplex Motion[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-009-003[/TD] [TD]Free Run Stamp Motion[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-009-004[/TD] [TD]Free Run Simplex Motion(low speed)[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-009-005[/TD] [TD]Free Run Simplex Motion(high speed)[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-009-006[/TD] [TD]Free Run Duplex Motion(low speed)[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-009-007[/TD] [TD]Free Run Duplex Motion(high speed)[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6010[/TD] [TD][Stamp Position Adj.][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-010-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][-5.0 to 5.0 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6011[/TD] [TD][1-Pass ADF INPUT Check][/TD] [/TR] [TR] [TD]See page 3-385 "Input Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6012[/TD] [TD][1-Pass ADF OUTPUT Check][/TD] [/TR] [TR] [TD]See page 3-412 "Output Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6016[/TD] [TD][Original Size Detect Setting][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-016-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6017[/TD] [TD][DF Magnification Adj.][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6020[/TD] [TD][Skew Correction Moving Setting][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-020-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-017-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][-5 to 5 / [B]0 [/B]/ 0.1%/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]6121[/TD] [TD][NV Adj. Data Mod.][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-121-001[/TD] [TD]Jogger Pos. Factory Adj.[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-121-002[/TD] [TD]Folding Pos. Factory Adj.[/TD] [TD]ENG[/TD] [TD][-1.4 to 1.4 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6125[/TD] [TD][Use Paper Guide(Big Size)][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-125-001[/TD] [TD]All Size[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6126[/TD] [TD][Use Paper Guide(Small Size)][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-126-001[/TD] [TD]All Size[/TD] [TD]ENG[/TD] [TD][0 or 1 / 0 / 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6130[/TD] [TD][Sub-scan PunchPosAdj:FrontFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-130-001[/TD] [TD]Domestic 2Hole(Europe 2Hole)[/TD] [TD]ENG[/TD] [TD][-7.5 to 7.5 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-130-002[/TD] [TD]North America 3Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-130-003[/TD] [TD]Europe 4Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-130-004[/TD] [TD]North Europe 4Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-130-005[/TD] [TD]North America 2Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6131[/TD] [TD][Main-scan PunchPosAdj:FrontFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-131-001[/TD] [TD]Domestic 2Hole(Europe 2Hole)[/TD] [TD]ENG[/TD] [TD][-2 to 2 / [B]0 [/B]/ 0.4mm/step][/TD] [/TR] [TR] [TD]6-131-002[/TD] [TD]North America 3Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-131-003[/TD] [TD]Europe 4Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-131-004[/TD] [TD]North Europe 4Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-131-005[/TD] [TD]North America 2Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6132[/TD] [TD][Jogger Fence Fine Adj:FrontFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-132-001[/TD] [TD]A3T[/TD] [TD]ENG[/TD] [TD][-1.5 to 1.5 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-002[/TD] [TD]B4T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-003[/TD] [TD]A4T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-004[/TD] [TD]A4Y[/TD] [TD]ENG[/TD] [TD][-1.5 to [B]1.5 [/B]/ 0 / 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-005[/TD] [TD]B5T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-006[/TD] [TD]B5Y[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-007[/TD] [TD]DLT-T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-008[/TD] [TD]LG-T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-009[/TD] [TD]Oficio-T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-010[/TD] [TD]LT-T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-011[/TD] [TD]LT-Y[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-012[/TD] [TD]8K-T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-013[/TD] [TD]16K-T[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-014[/TD] [TD]16K-Y[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-132-015[/TD] [TD]Other[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6133[/TD] [TD][Staple Position Adj: FrontFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-133-001[/TD] [TD]Finisher1[/TD] [TD]ENG[/TD] [TD][-2 to 2 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6134[/TD] [TD][Finisher Free Run: FrontFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-134-001[/TD] [TD]Free Run1[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-134-002[/TD] [TD]Free Run2[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6135[/TD] [TD][INPUT Check: FrontFIN][/TD] [/TR] [TR] [TD]See page 3-385 "Input Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-134-003[/TD] [TD]Free Run3[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-134-004[/TD] [TD]Free Run4[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]6136[/TD] [TD][OUTPUT Check: FrontFIN][/TD] [/TR] [TR] [TD]See page 3-412 "Output Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6140[/TD] [TD][Staple Position Adj: 1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-140-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][-3.5 to 3.5 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-140-002[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.3mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6141[/TD] [TD][Booklet Stapler Pos Adj:1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-141-001[/TD] [TD]A3 SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-141-002[/TD] [TD]B4 SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-141-003[/TD] [TD]A4 SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-141-004[/TD] [TD]B5 SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-141-005[/TD] [TD]DLT SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-141-006[/TD] [TD]LG SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-141-007[/TD] [TD]Oficio SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-141-008[/TD] [TD]LT SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-141-009[/TD] [TD]12"x18"[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6142[/TD] [TD][Sub-scan Punch Pos Adj:1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-142-001[/TD] [TD]JPN/EU: 2-Hole[/TD] [TD]ENG[/TD] [TD][-7.5 to 7.5 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-142-002[/TD] [TD]NA: 3-Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-142-003[/TD] [TD]Europe: 4-Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-142-004[/TD] [TD]NEU: 4-Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-142-005[/TD] [TD]NA: 2-Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6143[/TD] [TD][Jogger Pos Adj:1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-143-001[/TD] [TD]A3 SEF[/TD] [TD]ENG[/TD] [TD] [-1.5 to 1.5 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-143-002[/TD] [TD]B4 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-003[/TD] [TD]A4 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-004[/TD] [TD]A4 LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-005[/TD] [TD]B5 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-006[/TD] [TD]B5 LEF[/TD] [TD]ENG[/TD] [TD] [-1.5 to 1.5 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-143-007[/TD] [TD]DLT SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-008[/TD] [TD]LG SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-009[/TD] [TD]Oficio SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-010[/TD] [TD]LT SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-011[/TD] [TD]LT LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-012[/TD] [TD]12"x18"[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-013[/TD] [TD]8K SEF[/TD] [TD]ENG[/TD] [TD] [-1.5 to 1.5 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-143-014[/TD] [TD]16K SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-015[/TD] [TD]16K LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-143-016[/TD] [TD]Other[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6144[/TD] [TD][Main-scan Punch Pos Adj:1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-144-001[/TD] [TD]JPN/EU: 2-Hole[/TD] [TD]ENG[/TD] [TD][-2 to 2 / [B]0 [/B]/ 0.4mm/step][/TD] [/TR] [TR] [TD]6-144-002[/TD] [TD]NA: 3-Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-144-003[/TD] [TD]Europe: 4-Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6145[/TD] [TD][Skew Correct Buckle Adj:1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-145-001[/TD] [TD]A3 SEF[/TD] [TD]ENG[/TD] [TD] [-5 to 5 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-145-002[/TD] [TD]B4 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-003[/TD] [TD]A4 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-004[/TD] [TD]A4 LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-005[/TD] [TD]B5 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-006[/TD] [TD]B5 LEF[/TD] [TD]ENG[/TD] [TD] [-5 to 5 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-145-007[/TD] [TD]A5 LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-008[/TD] [TD]DLT SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-009[/TD] [TD]LG SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-010[/TD] [TD]Oficio SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-011[/TD] [TD]LT SEF[/TD] [TD]ENG[/TD] [TD] [-5 to 5 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-145-012[/TD] [TD]LT LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-013[/TD] [TD]HLT LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-014[/TD] [TD]12"x18"[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-015[/TD] [TD]8K SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-016[/TD] [TD]16K SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-017[/TD] [TD]16K LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-145-018[/TD] [TD]Other[/TD] [TD]ENG[/TD] [TD][-5 to 5 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-144-004[/TD] [TD]NEU: 4-Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-144-005[/TD] [TD]NA: 2-Hole[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]6146[/TD] [TD][Skew Correct Ctrl SW:1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-146-001[/TD] [TD]A3 SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-146-002[/TD] [TD]B4 SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-003[/TD] [TD]A4 SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-004[/TD] [TD]A4 LEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-005[/TD] [TD]B5 SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-006[/TD] [TD]B5 LEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-007[/TD] [TD]A5 LEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-008[/TD] [TD]DLT SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-009[/TD] [TD]LG SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-010[/TD] [TD]Oficio SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-011[/TD] [TD]LT SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-012[/TD] [TD]LT LEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-146-013[/TD] [TD]HLT LEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-014[/TD] [TD]12"x18"[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-015[/TD] [TD]8K SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-016[/TD] [TD]16K SEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-017[/TD] [TD]16K LEF[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [TR] [TD]6-146-018[/TD] [TD]Other[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: enable 1: disable[/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]6147[/TD] [TD][Booklet Folder Pos Adj:1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-147-001[/TD] [TD]A3 SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-002[/TD] [TD]B4 SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-003[/TD] [TD]A4 SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-004[/TD] [TD]B5 SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-005[/TD] [TD]DLT SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-006[/TD] [TD]LG SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-007[/TD] [TD]Oficio SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-008[/TD] [TD]LT SEF[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-009[/TD] [TD]12"x18"[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-010[/TD] [TD]A3 SEF(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-147-011[/TD] [TD]A3 SEF(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-012[/TD] [TD]A3 SEF(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-013[/TD] [TD]B4 SEF(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-014[/TD] [TD]B4 SEF(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-015[/TD] [TD]B4 SEF(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-016[/TD] [TD]A4 SEF(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-017[/TD] [TD]A4 SEF(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-018[/TD] [TD]A4 SEF(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-019[/TD] [TD]B5 SEF(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-020[/TD] [TD]B5 SEF(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-021[/TD] [TD]B5 SEF(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-022[/TD] [TD]DLT SEF(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-023[/TD] [TD]DLT SEF(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-024[/TD] [TD]DLT SEF(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-025[/TD] [TD]LG SEF(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-026[/TD] [TD]LG SEF(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-027[/TD] [TD]LG SEF(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-028[/TD] [TD]Oficio SEF(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-029[/TD] [TD]Oficio SEF(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-030[/TD] [TD]Oficio SEF(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-031[/TD] [TD]LT SEF(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-032[/TD] [TD]LT SEF(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-033[/TD] [TD]LT SEF(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-034[/TD] [TD]12"x18"(1-5)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-035[/TD] [TD]12"x18"(6-10)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [TR] [TD]6-147-036[/TD] [TD]12"x18"(11-over)[/TD] [TD]ENG[/TD] [TD][-3 to 3 / [B]0 [/B]/ 0.2mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6149[/TD] [TD][Last Paper Pos Time Adj:1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-149-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1time/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6148[/TD] [TD][Fold Times Adj: 1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-148-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 to 29 / [B]0 [/B]/ 1sec/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]6150[/TD] [TD][PositioningStrtTimingAdj:1KFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-150-001[/TD] [TD]A3 SEF[/TD] [TD]ENG[/TD] [TD][-100 to 100 / [B]0 [/B]/ 10msec/step][/TD] [/TR] [TR] [TD]6-150-002[/TD] [TD]B4 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-003[/TD] [TD]A4 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-004[/TD] [TD]A4 LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-005[/TD] [TD]B5 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-006[/TD] [TD]B5 LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-007[/TD] [TD]DLT SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-008[/TD] [TD]LG SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-009[/TD] [TD]Oficio SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-010[/TD] [TD]LT SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-011[/TD] [TD]LT LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-012[/TD] [TD]12"x18"[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-013[/TD] [TD]8K SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-014[/TD] [TD]16K SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-015[/TD] [TD]16K LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-150-016[/TD] [TD]Other[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6151[/TD] [TD][PosTimeAdj(LstPr2ndTime):1KFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-151-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][-100 to 100 / [B]0 [/B]/ 10msec/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6152[/TD] [TD][PosTiAdj(ExcLstPr3rdTi):1KFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-152-001[/TD] [TD]A3 SEF[/TD] [TD]ENG[/TD] [TD][-100 to 100 / [B]0 [/B]/ 10msec/step][/TD] [/TR] [TR] [TD]6-152-002[/TD] [TD]B4 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-003[/TD] [TD]A4 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-004[/TD] [TD]A4 LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-005[/TD] [TD]B5 SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-006[/TD] [TD]B5 LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-007[/TD] [TD]DLT SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-008[/TD] [TD]LG SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-009[/TD] [TD]Oficio SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-010[/TD] [TD]LT SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-011[/TD] [TD]LT LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-012[/TD] [TD]12"x18"[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-013[/TD] [TD]8K SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-014[/TD] [TD]16K SEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-015[/TD] [TD]16K LEF[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-152-016[/TD] [TD]Other[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6154[/TD] [TD][Pos Time Adj By Sheet: 1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-154-001[/TD] [TD]1 - 10 Sheets[/TD] [TD]ENG[/TD] [TD][-100 to 100 / [B]0 [/B]/ 10msec/step][/TD] [/TR] [TR] [TD]6-154-002[/TD] [TD]11 - 20 Sheets[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-154-003[/TD] [TD]21 - 30 Sheets[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-154-004[/TD] [TD]31 - 40 Sheets[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [TR] [TD]6-154-005[/TD] [TD]41 - 50 Sheets[/TD] [TD]ENG[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6156[/TD] [TD][Paper Guide Retra Adj: 1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-156-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][-50 to 50 / [B]0 [/B]/ 5mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6155[/TD] [TD][Paper Guide Poss Adj: 1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-155-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][-10 to 10 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]6157[/TD] [TD][Paper Guide Acept Adj: 1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-157-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][-50 to 50 / [B]0 [/B]/ 5msec/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6160[/TD] [TD][Finisher Free Run: 1K FIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-160-001[/TD] [TD]Free Run 1[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-160-002[/TD] [TD]Free Run 2[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-160-003[/TD] [TD]Free Run 3[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-160-004[/TD] [TD]Free Run 4[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6161[/TD] [TD][FIN (1K FIN) INPUT Check][/TD] [/TR] [TR] [TD]See page 3-385 "Input Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6162[/TD] [TD][FIN (1K FIN) OUTPUT Check][/TD] [/TR] [TR] [TD]See page 3-412 "Output Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6163[/TD] [TD][Use Paper Guide][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-163-001[/TD] [TD]Big Size[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]1 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-163-002[/TD] [TD]Small Size[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6164[/TD] [TD][NV Adj. Data Mod. 1KShtFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-164-001[/TD] [TD]Jogger Pos. Factory Adj.[/TD] [TD]ENG[/TD] [TD][-1.5 to 1.5 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [TR] [TD]6-164-002[/TD] [TD]Stapling Pos. Factory Adj.[/TD] [TD]ENG[/TD] [TD][-2 to 2 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6164[/TD] [TD][NV Adj. Data Mod. 1KShtFIN HY][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-164-003[/TD] [TD]Stapling Pos. Factory Adj. (HY)[/TD] [TD]ENG[/TD] [TD][-2.1 to 2.1 / [B]0 [/B]/ 0.3mm/step][/TD] [/TR] [TR] [TD]6-164-004[/TD] [TD]Stapleless Stapling Pos. Factory Adj.[/TD] [TD] ENG[/TD] [TD] [-2.1 to 2.1 / [B]0 [/B]/ 0.3mm/step][/TD] [/TR] [TR] [TD]6164[/TD] [TD][NV Adj. Data Mod. 1KShtFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-164-005[/TD] [TD]Folding Pos. Factory Adj.[/TD] [TD]ENG[/TD] [TD][-2 to 2 / [B]0 [/B]/ 0.1mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6180[/TD] [TD][M-ScanBindPosAdj:NoStplBindFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-180-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][-1 to 1 / [B]0 [/B]/ 0.5mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6181[/TD] [TD][BindSpeedSetting:NoStplBindFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-181-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][1 to 3 / [B]3 [/B]/ 2/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6182[/TD] [TD][ExitSpeedSwitch:NoStplBindFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-182-001[/TD] [TD]PaperLength:297.0-457.2mm,Thick(106-300g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]2 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-182-002[/TD] [TD]PaperLength:297.0-457.2mm,Plain(60-105g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]2 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-182-003[/TD] [TD]PaperLength:297.0-457.2mm,Thin(52-59g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]4 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-182-004[/TD] [TD]PaperLength:210.0-296.9mm,Thick(106-300g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]2 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-182-005[/TD] [TD]PaperLength:210.0-296.9mm,Plain(60-105g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]2 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-182-006[/TD] [TD]PaperLength:210.0-296.9mm,Thin(52-59g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]4 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-182-007[/TD] [TD]PaperLength:148.0-209.9mm,Thick(106-300g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]2 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-182-008[/TD] [TD]PaperLength:148.0-209.9mm,Plain(60-105g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]2 [/B]/ 1/step][/TD] [/TR] [TR] [TD]6-182-009[/TD] [TD]PaperLength:148.0-209.9mm,Thin(52-59g/m2)[/TD] [TD]ENG[/TD] [TD][1 to 5 / [B]4 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6183[/TD] [TD][FinisherFreeRun:NoStplBindFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-183-001[/TD] [TD]Free Run 1[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 0/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6184[/TD] [TD][Input Check:NoStplBindFIN][/TD] [/TR] [TR] [TD]See page 3-385 "Input Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6-183-002[/TD] [TD]Free Run 2[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 0/step][/TD] [/TR] [TR] [TD]6-183-003[/TD] [TD]Free Run 3[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 0/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]6185[/TD] [TD][Output Check:NoStplBindFIN][/TD] [/TR] [TR] [TD]See page 3-412 "Output Check Table"[/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6186[/TD] [TD][BindTimes NoStplBindFIN][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-186-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][1 to 2 / [B]2 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6801[/TD] [TD][1-pass Stamp Unit][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-801-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: NO 1: YES[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6900[/TD] [TD][ADF Bottom Plate Setting][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-900-001[/TD] [TD]-[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]6901[/TD] [TD][ADF Operation Setting][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]Setting to give priority to stackability.[/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]6-901-001[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: Higher quietness 1: Higher throughput[/TD] [/TR] [TR] [TD]6-901-002[/TD] [TD]-[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step] 0: Normal 1: Higher stackability[/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7622[/TD] [TD][PM Counter Reset][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-622-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-131[/TD] [TD]Dust Filter[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-206[/TD] [TD]ADF Pick-up Roller[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-207[/TD] [TD]ADF Supply Belt[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-208[/TD] [TD]ADF Reverse Roller[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-621-207[/TD] [TD]ADF Supply Belt[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-208[/TD] [TD]ADF Reverse Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [/LIST] [*][HEADING=2]ENGINE SP TABLES - SP7000[/HEADING] [LIST=1] [*][HEADING=2]SP7-XXX (DATA LOG)[/HEADING] [/LIST] [/LIST][/INDENT] [TABLE] [TR] [TD]7621[/TD] [TD][PM Counter Display: Pages][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-621-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-003[/TD] [TD]# Dev Unit:K[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-026[/TD] [TD]# Dev Unit:C[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-049[/TD] [TD]# Dev Unit:M[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-131[/TD] [TD]Dust Filter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-621-142[/TD] [TD]Waste Toner Bottle[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mg/step][/TD] [/TR] [TR] [TD]7-621-206[/TD] [TD]ADF Pick-up Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-622-245[/TD] [TD]PCU:All Colors[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-622-246[/TD] [TD]Development Unit:All Colors[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-247[/TD] [TD]Developer:All Colors[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-622-250[/TD] [TD]SCS[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7623[/TD] [TD][PM Value Setting: Life Pages][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-623-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]240000 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]240000 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]240000 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]240000 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]240000 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]240000 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-131[/TD] [TD]Dust Filter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]300000 [/B]/ 1page/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-623-142[/TD] [TD]Waste Toner Bottle[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]1200000 [/B]/ 1mg/step][/TD] [/TR] [TR] [TD]7-623-206[/TD] [TD]ADF Pick-up Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]120000 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-207[/TD] [TD]ADF Supply Belt[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]120000 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-623-208[/TD] [TD]ADF Reverse Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]120000 [/B]/ 1page/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7625[/TD] [TD][Previous Unit Counter: Pages][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-625-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-131[/TD] [TD]Dust Filter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-142[/TD] [TD]Waste Toner Bottle[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-625-206[/TD] [TD]ADF Pick-up Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-207[/TD] [TD]ADF Supply Belt[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-625-208[/TD] [TD]ADF Reverse Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7626[/TD] [TD][Previous Unit Counter2: Pages][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-626-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-131[/TD] [TD]Dust Filter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-142[/TD] [TD]Waste Toner Bottle[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mg/step][/TD] [/TR] [TR] [TD]7-626-206[/TD] [TD]ADF Pick-up Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7628[/TD] [TD][PM Counter Reset][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-628-002[/TD] [TD]SCS[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-626-207[/TD] [TD]ADF Supply Belt[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [TR] [TD]7-626-208[/TD] [TD]ADF Reverse Roller[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1page/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7720[/TD] [TD][Ave. Cvrg for Eng.][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-720-001[/TD] [TD]K[/TD] [TD]*ENG[/TD] [TD][0 to 100 / [B]0 [/B]/ 0.01%/step][/TD] [/TR] [TR] [TD]7-720-002[/TD] [TD]C[/TD] [TD]*ENG[/TD] [TD][0 to 100 / [B]0 [/B]/ 0.01%/step][/TD] [/TR] [TR] [TD]7-720-003[/TD] [TD]M[/TD] [TD]*ENG[/TD] [TD][0 to 100 / [B]0 [/B]/ 0.01%/step][/TD] [/TR] [TR] [TD]7-720-004[/TD] [TD]Y[/TD] [TD]*ENG[/TD] [TD][0 to 100 / [B]0 [/B]/ 0.01%/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7801[/TD] [TD][ROM No.][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-801-002[/TD] [TD]Engine[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-005[/TD] [TD]ADF[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-007[/TD] [TD]Finisher[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-009[/TD] [TD]PTU[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-010[/TD] [TD]LCT[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-019[/TD] [TD]PTU2[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7801[/TD] [TD][ROM No./ Firmware Version][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-801-102[/TD] [TD]Engine[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-105[/TD] [TD]ADF[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-107[/TD] [TD]Finisher[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-109[/TD] [TD]PTU[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [TR] [TD]7-801-110[/TD] [TD]LCT[/TD] [TD]ENG[/TD] [TD][- / [B]- [/B]/ -][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7852[/TD] [TD][DF Glass Dust Check][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-852-001[/TD] [TD]Dust Detection Counter[/TD] [TD]*ENG[/TD] [TD][0 to 65535 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-852-002[/TD] [TD]Dust Counter Clear Counter[/TD] [TD]*ENG[/TD] [TD][0 to 65535 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-852-003[/TD] [TD]Dust Detection Counter: Back[/TD] [TD]*ENG[/TD] [TD][0 to 65535 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7853[/TD] [TD][Replace Counter][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-853-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-131[/TD] [TD]Dust Filter[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-142[/TD] [TD]Waste Toner Bottle[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-853-206[/TD] [TD]ADF Pick-up Roller[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-207[/TD] [TD]ADF Supply Belt[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-853-208[/TD] [TD]ADF Reverse Roller[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7906[/TD] [TD][Previous Unit Counter:Distance][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-906-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-027[/TD] [TD]Developer: C[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-050[/TD] [TD]Developer: M[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-073[/TD] [TD]Developer: Y[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-230[/TD] [TD]Low Speed: # PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-231[/TD] [TD]Low Speed: # PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-232[/TD] [TD]Low Speed: # PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-906-233[/TD] [TD]Low Speed: # PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-234[/TD] [TD]Middle Speed: # PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-235[/TD] [TD]Middle Speed: # PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-236[/TD] [TD]Middle Speed: # PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-906-237[/TD] [TD]Middle Speed: # PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7907[/TD] [TD][Previous Unit Cntr:Distance(%)][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-907-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-907-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7908[/TD] [TD][Previous Unit Counter:Pages(%)][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-908-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-131[/TD] [TD]Dust Filter[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-142[/TD] [TD]Waste Toner Bottle[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-206[/TD] [TD]ADF Pick-up Roller[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-207[/TD] [TD]ADF Supply Belt[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-908-208[/TD] [TD]ADF Reverse Roller[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7931[/TD] [TD][Toner Bottle Bk][/TD] [TD][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-931-001[/TD] [TD]Machine Serial ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-002[/TD] [TD]Cartridge Ver[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-003[/TD] [TD]Brand ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-004[/TD] [TD]Area ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-005[/TD] [TD]Product ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-006[/TD] [TD]Color ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-007[/TD] [TD]Maintenance ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-008[/TD] [TD]New Product Information[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-009[/TD] [TD]Recycle Counter[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-010[/TD] [TD]Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-011[/TD] [TD]SerialNo.[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-012[/TD] [TD]Toner Remaining[/TD] [TD]*ENG[/TD] [TD][0 to 100 / [B]100 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-931-013[/TD] [TD]EDP Code[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-014[/TD] [TD]End History[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-015[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-016[/TD] [TD]Attachment: Total Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-931-017[/TD] [TD]Attachment: Color Counter[/TD] [TD] *ENG[/TD] [TD] [0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-018[/TD] [TD]End: Total Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-019[/TD] [TD]End: Color Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-020[/TD] [TD]Attachment Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-931-021[/TD] [TD]End Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7932[/TD] [TD][Toner Bottle M][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-932-001[/TD] [TD]Machine Serial ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-002[/TD] [TD]Cartridge Ver[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-932-003[/TD] [TD]Brand ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-004[/TD] [TD]Area ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-005[/TD] [TD]Product ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-006[/TD] [TD]Color ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-007[/TD] [TD]Maintenance ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-008[/TD] [TD]New Product Information[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-009[/TD] [TD]Recycle Counter[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-010[/TD] [TD]Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-011[/TD] [TD]SerialNo.[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-012[/TD] [TD]Toner Remaining[/TD] [TD]*ENG[/TD] [TD][0 to 100 / [B]100 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-932-013[/TD] [TD]EDP Code[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-014[/TD] [TD]End History[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-015[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-016[/TD] [TD]Attachment: Total Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-932-017[/TD] [TD]Attachment: Color Counter[/TD] [TD] *ENG[/TD] [TD] [0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-018[/TD] [TD]End: Total Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-019[/TD] [TD]End: Color Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-020[/TD] [TD]Attachment Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-932-021[/TD] [TD]End Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7933[/TD] [TD][Toner Bottle C][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-933-001[/TD] [TD]MachineSerialID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-002[/TD] [TD]Cartridge Ver[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-003[/TD] [TD]Brand ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-004[/TD] [TD]Area ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-933-005[/TD] [TD]Product ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-006[/TD] [TD]Color ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-007[/TD] [TD]Maintenance ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-008[/TD] [TD]New Product Information[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-009[/TD] [TD]Recycle Counter[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-010[/TD] [TD]Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-011[/TD] [TD]SerialNo.[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-012[/TD] [TD]Toner Remaining[/TD] [TD]*ENG[/TD] [TD][0 to 100 / [B]100 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-933-013[/TD] [TD]EDP Code[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-014[/TD] [TD]End History[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-015[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-016[/TD] [TD]Attachment: Total Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-933-017[/TD] [TD]Attachment: Color Counter[/TD] [TD] *ENG[/TD] [TD] [0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-018[/TD] [TD]End: Total Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-019[/TD] [TD]End: Color Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-020[/TD] [TD]Attachment Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-933-021[/TD] [TD]End Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7934[/TD] [TD][Toner Bottle Y][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-934-001[/TD] [TD]MachineSerialID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-002[/TD] [TD]Cartridge Ver[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-003[/TD] [TD]Brand ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-004[/TD] [TD]Area ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-005[/TD] [TD]Product ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-006[/TD] [TD]Color ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-934-007[/TD] [TD]Maintenance ID[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-008[/TD] [TD]New Product Information[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-009[/TD] [TD]Recycle Counter[/TD] [TD]*ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-010[/TD] [TD]Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-011[/TD] [TD]SerialNo.[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-012[/TD] [TD]Toner Remaining[/TD] [TD]*ENG[/TD] [TD][0 to 100 / [B]100 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-934-013[/TD] [TD]EDP Code[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-014[/TD] [TD]End History[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-015[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-016[/TD] [TD]Attachment: Total Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-934-017[/TD] [TD]Attachment: Color Counter[/TD] [TD] *ENG[/TD] [TD] [0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-018[/TD] [TD]End: Total Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-019[/TD] [TD]End: Color Counter[/TD] [TD]*ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-020[/TD] [TD]Attachment Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-934-021[/TD] [TD]End Date[/TD] [TD]*ENG[/TD] [TD][0 to 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7935[/TD] [TD][Toner Bottle Log 1: Bk][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-935-001[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-002[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-003[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-004[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7935[/TD] [TD][Toner Bottle Log 2: Bk][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-935-011[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-012[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-013[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-935-014[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7935[/TD] [TD][Toner Bottle Log 3: Bk][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-935-021[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-022[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-023[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-024[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7935[/TD] [TD][Toner Bottle Log 4: Bk][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-935-031[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-032[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-033[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-034[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7935[/TD] [TD][Toner Bottle Log 5: Bk][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-935-041[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-042[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-043[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-935-044[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7936[/TD] [TD][Toner Bottle Log 1: M][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-936-001[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-002[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-936-003[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-004[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7936[/TD] [TD][Toner Bottle Log 2: M][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-936-011[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-012[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] 7-936-013[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-014[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7936[/TD] [TD][Toner Bottle Log 3: M][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-936-021[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-022[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-936-023[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-024[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7936[/TD] [TD][Toner Bottle Log 4: M][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-936-031[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-032[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-936-033[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-034[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7936[/TD] [TD][Toner Bottle Log 5: M][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-936-041[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-042[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-936-043[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-936-044[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7937[/TD] [TD][Toner Bottle Log 1: C][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-937-001[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-002[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-937-003[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-004[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7937[/TD] [TD][Toner Bottle Log 2: C][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-937-011[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-012[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-937-013[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-014[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7937[/TD] [TD][Toner Bottle Log 3: C][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-937-021[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-022[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-937-023[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-024[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7937[/TD] [TD][Toner Bottle Log 4: C][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-937-031[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-032[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-937-033[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-034[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7937[/TD] [TD][Toner Bottle Log 5: C][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-937-041[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-042[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-937-043[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-937-044[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7938[/TD] [TD][Toner Bottle Log 1: Y][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-938-001[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-002[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD] 7-938-003[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-004[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7938[/TD] [TD][Toner Bottle Log 2: Y][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-938-011[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-012[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-938-013[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-014[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7938[/TD] [TD][Toner Bottle Log 3: Y][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-938-021[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-022[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-938-023[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-024[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7938[/TD] [TD][Toner Bottle Log 4: Y][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-938-031[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-032[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-938-033[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-034[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7938[/TD] [TD][Toner Bottle Log 5: Y][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-938-041[/TD] [TD]SerialNo.[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-042[/TD] [TD]Attachment Date[/TD] [TD]ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD] 7-938-043[/TD] [TD]Attachment: Total Counter[/TD] [TD]ENG[/TD] [TD][0 to 99999999 / [B]0 [/B]/ 1/step][/TD] [/TR] [TR] [TD]7-938-044[/TD] [TD]Refill Information[/TD] [TD]*ENG[/TD] [TD][0 or 1 / [B]0 [/B]/ 1/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7940[/TD] [TD][PM Value Setting:Life Distance][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-940-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]128410397 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]128410397 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]128410397 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]291305000 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]291305000 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-940-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 999999999 / [B]291305000 [/B]/ 1mm/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7942[/TD] [TD][PM Counter Display:Distance(%)][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-942-002[/TD] [TD]# PCU:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [/TABLE] [TABLE] [TR] [TD]7-942-003[/TD] [TD]# Dev Unit:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-004[/TD] [TD]Developer:K[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-025[/TD] [TD]# PCU:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-026[/TD] [TD]# Dev Unit:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-027[/TD] [TD]Developer:C[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-048[/TD] [TD]# PCU:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-049[/TD] [TD]# Dev Unit:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-050[/TD] [TD]Developer:M[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-071[/TD] [TD]# PCU:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-072[/TD] [TD]# Dev Unit:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-073[/TD] [TD]Developer:Y[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-093[/TD] [TD]# ITB Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-102[/TD] [TD]# ITB Cleaning Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-109[/TD] [TD]# PTR Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-115[/TD] [TD]# Fusing Unit[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-116[/TD] [TD]Fusing Belt[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [TR] [TD]7-942-118[/TD] [TD]Pressure Roller[/TD] [TD]ENG[/TD] [TD][0 to 255 / [B]0 [/B]/ 1%/step][/TD] [/TR] [/TABLE] Engine SP Mode Tables [TABLE] [TR] [TD]7944[/TD] [TD][PM Counter Display: Distance][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]7-944-002[/TD] [TD]# PCU:K[/TD] [TD]*ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-944-003[/TD] [TD]# Dev Unit:K[/TD] [TD]*ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-944-004[/TD] [TD]Developer:K[/TD] [TD]*ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-944-025[/TD] [TD]# PCU:C[/TD] [TD]*ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-944-026[/TD] [TD]# Dev Unit:C[/TD] [TD]*ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-944-027[/TD] [TD]Developer:C[/TD] [TD]*ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [TR] [TD]7-944-048[/TD] [TD]# PCU:M[/TD] [TD]*ENG[/TD] [TD][0 to 4294967295 / [B]0 [/B]/ 1mm/step][/TD] [/TR] [/TABLE] [/QUOTE]
Photocopier and Printer
Ricoh
Ricoh MP C2004/C2504 Service Manual Part 32
